RTEMS 6.3
Register definitions. More...
#include <stdint.h>Go to the source code of this file.
Register Macros | |
| #define | OR1K_REG(x) |
| #define | OR1K_BIT(n) |
Internal OR1K UART Registers | |
| #define | OR1K_BSP_CLOCK_FREQ 50000000UL |
| #define | OR1K_BSP_UART_BASE 0x90000000 |
| #define | OR1K_BSP_UART_REG_TX (OR1K_BSP_UART_BASE+0) |
| #define | OR1K_BSP_UART_REG_RX (OR1K_BSP_UART_BASE+0) |
| #define | OR1K_BSP_UART_REG_DEV_LATCH_LOW (OR1K_BSP_UART_BASE+0) |
| #define | OR1K_BSP_UART_REG_DEV_LATCH_HIGH (OR1K_BSP_UART_BASE+1) |
| #define | OR1K_BSP_UART_REG_INT_ENABLE (OR1K_BSP_UART_BASE+1) |
| #define | OR1K_BSP_UART_REG_INT_ID (OR1K_BSP_UART_BASE+2) |
| #define | OR1K_BSP_UART_REG_FIFO_CTRL (OR1K_BSP_UART_BASE+2) |
| #define | OR1K_BSP_UART_REG_LINE_CTRL (OR1K_BSP_UART_BASE+3) |
| #define | OR1K_BSP_UART_REG_MODEM_CTRL (OR1K_BSP_UART_BASE+4) |
| #define | OR1K_BSP_UART_REG_LINE_STATUS (OR1K_BSP_UART_BASE+5) |
| #define | OR1K_BSP_UART_REG_MODEM_STATUS (OR1K_BSP_UART_BASE+6) |
| #define | OR1K_BSP_UART_REG_SCRATCH (OR1K_BSP_UART_BASE+7) |
| #define | OR1K_BSP_UART_REG_FIFO_CTRL_TRIGGER_1 (0x00) |
| #define | OR1K_BSP_UART_REG_FIFO_CTRL_ENABLE_FIFO (0x01) |
| #define | OR1K_BSP_UART_REG_FIFO_CTRL_CLEAR_RCVR (0x02) |
| #define | OR1K_BSP_UART_REG_FIFO_CTRL_CLEAR_XMIT (0x03) |
| #define | OR1K_BSP_UART_REG_FIFO_CTRL_DMA_SELECT (0x08) |
| #define | OR1K_BSP_UART_REG_FIFO_CTRL_TRIGGER_4 (0x40) |
| #define | OR1K_BSP_UART_REG_FIFO_CTRL_TRIGGER_8 (0x80) |
| #define | OR1K_BSP_UART_REG_FIFO_CTRL_TRIGGER_14 (0xC0) |
| #define | OR1K_BSP_UART_REG_FIFO_CTRL_TRIGGER_MASK (0xC0) |
| #define | OR1K_BSP_UART_REG_LINE_CTRL_WLEN5 (0x00) |
| #define | OR1K_BSP_UART_REG_LINE_CTRL_WLEN6 (0x01) |
| #define | OR1K_BSP_UART_REG_LINE_CTRL_WLEN7 (0x02) |
| #define | OR1K_BSP_UART_REG_LINE_CTRL_WLEN8 (0x03) |
| #define | OR1K_BSP_UART_REG_LINE_CTRL_STOP (0x04) |
| #define | OR1K_BSP_UART_REG_LINE_CTRL_PARITY (0x08) |
| #define | OR1K_BSP_UART_REG_LINE_CTRL_EPAR (0x10) |
| #define | OR1K_BSP_UART_REG_LINE_CTRL_SPAR (0x20) |
| #define | OR1K_BSP_UART_REG_LINE_CTRL_SBC (0x40) |
| #define | OR1K_BSP_UART_REG_LINE_CTRL_DLAB (0x80) |
| #define | OR1K_BSP_UART_REG_LINE_STATUS_DR (0x01) |
| #define | OR1K_BSP_UART_REG_LINE_STATUS_OE (0x02) |
| #define | OR1K_BSP_UART_REG_LINE_STATUS_PE (0x04) |
| #define | OR1K_BSP_UART_REG_LINE_STATUS_FE (0x08) |
| #define | OR1K_BSP_UART_REG_LINE_STATUS_BI (0x10) |
| #define | OR1K_BSP_UART_REG_LINE_STATUS_THRE (0x20) |
| #define | OR1K_BSP_UART_REG_LINE_STATUS_TEMT (0x40) |
| #define | OR1K_BSP_UART_REG_MODEM_CTRL_DTR (0x01) |
| #define | OR1K_BSP_UART_REG_MODEM_CTRL_RTS (0x02) |
| #define | OR1K_BSP_UART_REG_MODEM_CTRL_OUT1 (0x04) |
| #define | OR1K_BSP_UART_REG_MODEM_CTRL_OUT2 (0x08) |
| #define | OR1K_BSP_UART_REG_MODEM_CTRL_LOOP (0x10) |
| #define | OR1K_BSP_UART_REG_MODEM_STATUS_DCTS (0x01) |
| #define | OR1K_BSP_UART_REG_MODEM_STATUS_DDSR (0x02) |
| #define | OR1K_BSP_UART_REG_MODEM_STATUS_TERI (0x04) |
| #define | OR1K_BSP_UART_REG_MODEM_STATUS_DDCD (0x08) |
| #define | OR1K_BSP_UART_REG_MODEM_STATUS_CTS (0x10) |
| #define | OR1K_BSP_UART_REG_MODEM_STATUS_DSR (0x20) |
| #define | OR1K_BSP_UART_REG_MODEM_STATUS_RI (0x40) |
| #define | OR1K_BSP_UART_REG_MODEM_STATUS_DCD (0x80) |
| #define | OR1K_BSP_UART_REG_MODEM_STATUS_ANY_DELTA (0x0F) |
