RTEMS
6.3
Toggle main menu visibility
bsps
arm
imxrt
mcux-sdk
devices
MIMXRT1166
drivers
fsl_soc_mipi_csi2rx.h
1
2
* Copyright 2019-2020 NXP
3
* All rights reserved.
4
5
* SPDX-License-Identifier: BSD-3-Clause
6
7
8
#ifndef _FSL_SOC_MIPI_CSI2RX_H_
9
#define _FSL_SOC_MIPI_CSI2RX_H_
10
11
#include "fsl_common.h"
12
15
17
18
19
* Definitions
20
22
#define FSL_SOC_MIPI_CSI2RX_DRIVER_VERSION (MAKE_VERSION(2, 0, 2))
23
24
25
* API
26
27
28
#if defined(__cplusplus)
29
extern
"C"
30
#endif
/* __cplusplus */
31
39
void
MIPI_CSI2RX_SoftwareReset
MIPI_CSI2RX_Type
*base,
bool
reset);
40
48
void
MIPI_CSI2RX_InitInterface
MIPI_CSI2RX_Type
*base, uint8_t tHsSettle_EscClk);
49
56
void
MIPI_CSI2RX_DeinitInterface
MIPI_CSI2RX_Type
*base);
57
58
59
60
61
62
#endif
/* __cplusplus */
63
65
66
#endif
/* _FSL_SOC_MIPI_CSI2RX_H_ */
void MIPI_CSI2RX_DeinitInterface(MIPI_CSI2RX_Type *base)
Deinitialize the CSI2RX interface.
Definition
fsl_soc_mipi_csi2rx.c:65
void MIPI_CSI2RX_InitInterface(MIPI_CSI2RX_Type *base, uint8_t tHsSettle_EscClk)
Initialize the CSI2RX interface.
Definition
fsl_soc_mipi_csi2rx.c:42
void MIPI_CSI2RX_SoftwareReset(MIPI_CSI2RX_Type *base, bool reset)
Assert or deassert CSI2RX reset in system level.
Definition
fsl_soc_mipi_csi2rx.c:30
MIPI_CSI2RX_Type
Definition
MIMXRT1166_cm4.h:63541
