RTEMS 6.3
Soc_mipi_csi2rx
file  bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_soc_mipi_csi2rx.h
#define FSL_SOC_MIPI_CSI2RX_DRIVER_VERSION   (MAKE_VERSION(2, 0, 2))
 Driver version.
void MIPI_CSI2RX_SoftwareReset (MIPI_CSI2RX_Type *base, bool reset)
 Assert or deassert CSI2RX reset in system level.
void MIPI_CSI2RX_InitInterface (MIPI_CSI2RX_Type *base, uint8_t tHsSettle_EscClk)
 Initialize the CSI2RX interface.
void MIPI_CSI2RX_DeinitInterface (MIPI_CSI2RX_Type *base)
 Deinitialize the CSI2RX interface.
◆ MIPI_CSI2RX_DeinitInterface()
void MIPI_CSI2RX_DeinitInterface ( MIPI_CSI2RX_Type * base)
Parameters
baseThe CSI2RX peripheral base address.
Note
Don't call this function directly.
◆ MIPI_CSI2RX_InitInterface()
void MIPI_CSI2RX_InitInterface ( MIPI_CSI2RX_Type * base,
uint8_t tHsSettle_EscClk )
Parameters
tHsSettle_EscClkt-HS_SETTLE in esc clock period.
Note
◆ MIPI_CSI2RX_SoftwareReset()
void MIPI_CSI2RX_SoftwareReset ( MIPI_CSI2RX_Type * base,
bool reset )
Parameters
resetPass in true to set to reset state, false to release reset.
Note
