RTEMS 6.3
fsl_flexspi_edma.h
1/*
2 * Copyright (c) 2016, Freescale Semiconductor, Inc.
3 * Copyright 2016-2020 NXP
4 * All rights reserved.
5 *
6 * SPDX-License-Identifier: BSD-3-Clause
7 */
8
9#ifndef _FSL_FLEXSPI_EDMA_H_
10#define _FSL_FLEXSPI_EDMA_H_
11
12#include "fsl_flexspi.h"
13#if defined(FSL_FEATURE_SOC_DMAMUX_COUNT) && FSL_FEATURE_SOC_DMAMUX_COUNT
14#include "fsl_dmamux.h"
15#endif
16#include "fsl_edma.h"
17
22
23/*******************************************************************************
24 * Definitions
25 ******************************************************************************/
26
30#define FSL_FLEXSPI_EDMA_DRIVER_VERSION (MAKE_VERSION(2, 3, 2))
32
33typedef struct _flexspi_edma_handle flexspi_edma_handle_t;
34
37 flexspi_edma_handle_t *handle,
38 status_t status,
39 void *userData);
40
50
64
65/*******************************************************************************
66 * APIs
67 ******************************************************************************/
68#if defined(__cplusplus)
69extern "C" {
70#endif
71
76
88 flexspi_edma_handle_t *handle,
90 void *userData,
91 edma_handle_t *txDmaHandle,
92 edma_handle_t *rxDmaHandle);
93
104 flexspi_edma_handle_t *handle,
106
119status_t FLEXSPI_TransferEDMA(FLEXSPI_Type *base, flexspi_edma_handle_t *handle, flexspi_transfer_t *xfer);
120
129void FLEXSPI_TransferAbortEDMA(FLEXSPI_Type *base, flexspi_edma_handle_t *handle);
130
140status_t FLEXSPI_TransferGetTransferCountEDMA(FLEXSPI_Type *base, flexspi_edma_handle_t *handle, size_t *count);
141
142/* @} */
143
144#if defined(__cplusplus)
145}
146#endif
147
148/* @} */
149
150#endif /* _FSL_FLEXSPI_EDMA_H_ */
struct _edma_handle edma_handle_t
eDMA transfer handle structure
Transfers FLEXSPI data using an eDMA non-blocking method.
Definition fsl_flexspi_edma.c:161
_flexspi_edma_ntransfer_size
eDMA transfer configuration
Definition fsl_flexspi_edma.h:43
uint32_t state
Definition fsl_flexspi_edma.h:60
size_t transferSize
Definition fsl_flexspi_edma.h:56
flexspi_edma_transfer_nsize_t nsize
Definition fsl_flexspi_edma.h:57
void * userData
Definition fsl_flexspi_edma.h:62
void FLEXSPI_TransferCreateHandleEDMA(FLEXSPI_Type *base, flexspi_edma_handle_t *handle, flexspi_edma_callback_t callback, void *userData, edma_handle_t *txDmaHandle, edma_handle_t *rxDmaHandle)
Initializes the FLEXSPI handle for transfer which is used in transactional functions and set the call...
Definition fsl_flexspi_edma.c:108
enum _flexspi_edma_ntransfer_size flexspi_edma_transfer_nsize_t
Aborts the transfer data using eDMA.
Definition fsl_flexspi_edma.c:315
flexspi_edma_callback_t completionCallback
Definition fsl_flexspi_edma.h:61
edma_handle_t * txDmaHandle
Definition fsl_flexspi_edma.h:54
Gets the transferred counts of transfer.
Definition fsl_flexspi_edma.c:334
void(*) flexspi_edma_callback_t(FLEXSPI_Type *base, flexspi_edma_handle_t *handle, status_t status, void *userData)
FLEXSPI eDMA transfer callback function for finish and error.
Definition fsl_flexspi_edma.h:36
void FLEXSPI_TransferUpdateSizeEDMA(FLEXSPI_Type *base, flexspi_edma_handle_t *handle, flexspi_edma_transfer_nsize_t nsize)
Update FLEXSPI EDMA transfer source data transfer size(SSIZE) and destination data transfer size(DSIZ...
Definition fsl_flexspi_edma.c:142
uint8_t nbytes
Definition fsl_flexspi_edma.h:58
edma_handle_t * rxDmaHandle
Definition fsl_flexspi_edma.h:55
uint8_t count
Definition fsl_flexspi_edma.h:59
@ kFLEXPSI_EDMAnSize2Bytes
Definition fsl_flexspi_edma.h:45
@ kFLEXPSI_EDMAnSize4Bytes
Definition fsl_flexspi_edma.h:46
@ kFLEXPSI_EDMAnSize1Bytes
Definition fsl_flexspi_edma.h:44
@ kFLEXPSI_EDMAnSize8Bytes
Definition fsl_flexspi_edma.h:47
@ kFLEXPSI_EDMAnSize32Bytes
Definition fsl_flexspi_edma.h:48
struct _flexspi_transfer flexspi_transfer_t
Transfer structure for FLEXSPI.
int32_t status_t
Type used for all status and error return values.
Definition fsl_common.h:225
Definition MIMXRT1052.h:21299
FLEXSPI DMA transfer handle, users should not touch the content of the handle.
Definition fsl_flexspi_edma.h:53
