RTEMS 6.3
Flexspi
struct  _flexspi_ahbBuffer_config
struct  _flexspi_config
 FLEXSPI configuration structure. More...
struct  _flexspi_config::[struct].ahbConfig
struct  _flexspi_handle
 Transfer handle structure for FLEXSPI. More...
struct  _flexspi_transfer
 Transfer structure for FLEXSPI. More...
struct  _flexspi_device_config
 External device configuration items. More...
uint8_t _flexspi_ahbBuffer_config::priority
uint8_t _flexspi_ahbBuffer_config::masterIndex
uint16_t _flexspi_ahbBuffer_config::bufferSize
bool _flexspi_ahbBuffer_config::enablePrefetch
flexspi_read_sample_clock_t _flexspi_config::rxSampleClock
bool _flexspi_config::enableSckFreeRunning
bool _flexspi_config::enableCombination
bool _flexspi_config::enableDoze
bool _flexspi_config::enableHalfSpeedAccess
bool _flexspi_config::enableSckBDiffOpt
bool _flexspi_config::enableSameConfigForAll
uint16_t _flexspi_config::seqTimeoutCycle
uint8_t _flexspi_config::ipGrantTimeoutCycle
uint8_t _flexspi_config::txWatermark
uint8_t _flexspi_config::rxWatermark
bool _flexspi_config::enableAHBWriteIpTxFifo
bool _flexspi_config::enableAHBWriteIpRxFifo
uint8_t _flexspi_config::ahbGrantTimeoutCycle
uint16_t _flexspi_config::ahbBusTimeoutCycle
uint8_t _flexspi_config::resumeWaitCycle
flexspi_ahbBuffer_config_t _flexspi_config::buffer [FSL_FEATURE_FLEXSPI_AHB_BUFFER_COUNT]
bool _flexspi_config::enableClearAHBBufferOpt
bool _flexspi_config::enableReadAddressOpt
bool _flexspi_config::enableAHBPrefetch
bool _flexspi_config::enableAHBBufferable
bool _flexspi_config::enableAHBCachable
struct  _flexspi_config::ahbConfig
uint32_t _flexspi_device_config::flexspiRootClk
bool _flexspi_device_config::isSck2Enabled
uint32_t _flexspi_device_config::flashSize
flexspi_cs_interval_cycle_unit_t _flexspi_device_config::CSIntervalUnit
uint16_t _flexspi_device_config::CSInterval
uint8_t _flexspi_device_config::CSHoldTime
uint8_t _flexspi_device_config::CSSetupTime
uint8_t _flexspi_device_config::dataValidTime
uint8_t _flexspi_device_config::columnspace
bool _flexspi_device_config::enableWordAddress
uint8_t _flexspi_device_config::AWRSeqIndex
uint8_t _flexspi_device_config::AWRSeqNumber
uint8_t _flexspi_device_config::ARDSeqIndex
uint8_t _flexspi_device_config::ARDSeqNumber
flexspi_ahb_write_wait_unit_t _flexspi_device_config::AHBWriteWaitUnit
uint16_t _flexspi_device_config::AHBWriteWaitInterval
bool _flexspi_device_config::enableWriteMask
uint32_t _flexspi_transfer::deviceAddress
flexspi_port_t _flexspi_transfer::port
flexspi_command_type_t _flexspi_transfer::cmdType
uint8_t _flexspi_transfer::seqIndex
uint8_t _flexspi_transfer::SeqNumber
uint32_t * _flexspi_transfer::data
size_t _flexspi_transfer::dataSize
uint32_t _flexspi_handle::state
uint8_t * _flexspi_handle::data
size_t _flexspi_handle::dataSize
size_t _flexspi_handle::transferTotalSize
flexspi_transfer_callback_t _flexspi_handle::completionCallback
void * _flexspi_handle::userData
Driver version
enum  { kStatus_FLEXSPI_Busy = MAKE_STATUS(kStatusGroup_FLEXSPI, 0) , kStatus_FLEXSPI_SequenceExecutionTimeout = MAKE_STATUS(kStatusGroup_FLEXSPI, 1) , kStatus_FLEXSPI_IpCommandSequenceError = MAKE_STATUS(kStatusGroup_FLEXSPI, 2) , kStatus_FLEXSPI_IpCommandGrantTimeout = MAKE_STATUS(kStatusGroup_FLEXSPI, 3) }
 Status structure of FLEXSPI. More...
enum  {
  kFLEXSPI_Command_STOP = 0x00U , kFLEXSPI_Command_SDR = 0x01U , kFLEXSPI_Command_RADDR_SDR = 0x02U , kFLEXSPI_Command_CADDR_SDR = 0x03U ,
  kFLEXSPI_Command_MODE1_SDR = 0x04U , kFLEXSPI_Command_MODE2_SDR = 0x05U , kFLEXSPI_Command_MODE4_SDR = 0x06U , kFLEXSPI_Command_MODE8_SDR = 0x07U ,
  kFLEXSPI_Command_WRITE_SDR = 0x08U , kFLEXSPI_Command_READ_SDR = 0x09U , kFLEXSPI_Command_LEARN_SDR = 0x0AU , kFLEXSPI_Command_DATSZ_SDR = 0x0BU ,
  kFLEXSPI_Command_DUMMY_SDR = 0x0CU , kFLEXSPI_Command_DUMMY_RWDS_SDR = 0x0DU , kFLEXSPI_Command_DDR = 0x21U , kFLEXSPI_Command_RADDR_DDR = 0x22U ,
  kFLEXSPI_Command_CADDR_DDR = 0x23U , kFLEXSPI_Command_MODE1_DDR = 0x24U , kFLEXSPI_Command_MODE2_DDR = 0x25U , kFLEXSPI_Command_MODE4_DDR = 0x26U ,
  kFLEXSPI_Command_MODE8_DDR = 0x27U , kFLEXSPI_Command_WRITE_DDR = 0x28U , kFLEXSPI_Command_READ_DDR = 0x29U , kFLEXSPI_Command_LEARN_DDR = 0x2AU ,
  kFLEXSPI_Command_DATSZ_DDR = 0x2BU , kFLEXSPI_Command_DUMMY_DDR = 0x2CU , kFLEXSPI_Command_DUMMY_RWDS_DDR = 0x2DU , kFLEXSPI_Command_JUMP_ON_CS = 0x1FU
 CMD definition of FLEXSPI, use to form LUT instruction, _flexspi_command. More...
enum  _flexspi_pad { kFLEXSPI_1PAD = 0x00U , kFLEXSPI_2PAD = 0x01U , kFLEXSPI_4PAD = 0x02U , kFLEXSPI_8PAD = 0x03U }
 pad definition of FLEXSPI, use to form LUT instruction. More...
enum  _flexspi_flags {
  kFLEXSPI_SequenceExecutionTimeoutFlag = FLEXSPI_INTEN_SEQTIMEOUTEN_MASK , kFLEXSPI_AhbBusTimeoutFlag = FLEXSPI_INTEN_AHBBUSTIMEOUTEN_MASK , kFLEXSPI_SckStoppedBecauseTxEmptyFlag , kFLEXSPI_SckStoppedBecauseRxFullFlag ,
  kFLEXSPI_DataLearningFailedFlag = FLEXSPI_INTEN_DATALEARNFAILEN_MASK , kFLEXSPI_IpTxFifoWatermarkEmptyFlag = FLEXSPI_INTEN_IPTXWEEN_MASK , kFLEXSPI_IpRxFifoWatermarkAvailableFlag = FLEXSPI_INTEN_IPRXWAEN_MASK , kFLEXSPI_AhbCommandSequenceErrorFlag ,
  kFLEXSPI_IpCommandSequenceErrorFlag = FLEXSPI_INTEN_IPCMDERREN_MASK , kFLEXSPI_AhbCommandGrantTimeoutFlag , kFLEXSPI_IpCommandGrantTimeoutFlag , kFLEXSPI_IpCommandExecutionDoneFlag ,
  kFLEXSPI_AllInterruptFlags = 0xFFFU
 FLEXSPI interrupt status flags. More...
enum  _flexspi_read_sample_clock { kFLEXSPI_ReadSampleClkLoopbackInternally = 0x0U , kFLEXSPI_ReadSampleClkLoopbackFromDqsPad = 0x1U , kFLEXSPI_ReadSampleClkLoopbackFromSckPad = 0x2U , kFLEXSPI_ReadSampleClkExternalInputFromDqsPad = 0x3U }
 FLEXSPI sample clock source selection for Flash Reading. More...
enum  _flexspi_cs_interval_cycle_unit { kFLEXSPI_CsIntervalUnit1SckCycle = 0x0U , kFLEXSPI_CsIntervalUnit256SckCycle = 0x1U }
 FLEXSPI interval unit for flash device select. More...
enum  _flexspi_ahb_write_wait_unit {
  kFLEXSPI_AhbWriteWaitUnit2AhbCycle = 0x0U , kFLEXSPI_AhbWriteWaitUnit8AhbCycle = 0x1U , kFLEXSPI_AhbWriteWaitUnit32AhbCycle = 0x2U , kFLEXSPI_AhbWriteWaitUnit128AhbCycle = 0x3U ,
  kFLEXSPI_AhbWriteWaitUnit512AhbCycle = 0x4U , kFLEXSPI_AhbWriteWaitUnit2048AhbCycle = 0x5U , kFLEXSPI_AhbWriteWaitUnit8192AhbCycle = 0x6U , kFLEXSPI_AhbWriteWaitUnit32768AhbCycle = 0x7U
 FLEXSPI AHB wait interval unit for writing. More...
enum  _flexspi_ip_error_code {
  kFLEXSPI_IpCmdErrorNoError = 0x0U , kFLEXSPI_IpCmdErrorJumpOnCsInIpCmd = 0x2U , kFLEXSPI_IpCmdErrorUnknownOpCode = 0x3U , kFLEXSPI_IpCmdErrorSdrDummyInDdrSequence = 0x4U ,
  kFLEXSPI_IpCmdErrorDdrDummyInSdrSequence = 0x5U , kFLEXSPI_IpCmdErrorInvalidAddress = 0x6U , kFLEXSPI_IpCmdErrorSequenceExecutionTimeout = 0xEU , kFLEXSPI_IpCmdErrorFlashBoundaryAcrosss = 0xFU
 Error Code when IP command Error detected. More...
enum  _flexspi_ahb_error_code {
  kFLEXSPI_AhbCmdErrorNoError = 0x0U , kFLEXSPI_AhbCmdErrorJumpOnCsInWriteCmd = 0x2U , kFLEXSPI_AhbCmdErrorUnknownOpCode = 0x3U , kFLEXSPI_AhbCmdErrorSdrDummyInDdrSequence = 0x4U ,
  kFLEXSPI_AhbCmdErrorDdrDummyInSdrSequence = 0x5U , kFLEXSPI_AhbCmdSequenceExecutionTimeout = 0x6U
 Error Code when AHB command Error detected. More...
enum  _flexspi_port {
  kFLEXSPI_PortA1 = 0x0U , kFLEXSPI_PortA2 , kFLEXSPI_PortB1 , kFLEXSPI_PortB2 ,
  kFLEXSPI_PortCount
 FLEXSPI operation port select. More...
enum  _flexspi_arb_command_source { kFLEXSPI_AhbReadCommand = 0x0U , kFLEXSPI_AhbWriteCommand = 0x1U , kFLEXSPI_IpCommand = 0x2U , kFLEXSPI_SuspendedCommand = 0x3U }
 Trigger source of current command sequence granted by arbitrator.
enum  _flexspi_command_type { kFLEXSPI_Command , kFLEXSPI_Config , kFLEXSPI_Read , kFLEXSPI_Write }
 Command type. More...
typedef enum _flexspi_pad flexspi_pad_t
typedef enum _flexspi_flags flexspi_flags_t
typedef enum _flexspi_read_sample_clock flexspi_read_sample_clock_t
typedef enum _flexspi_cs_interval_cycle_unit flexspi_cs_interval_cycle_unit_t
typedef enum _flexspi_ahb_write_wait_unit flexspi_ahb_write_wait_unit_t
typedef enum _flexspi_ip_error_code flexspi_ip_error_code_t
typedef enum _flexspi_ahb_error_code flexspi_ahb_error_code_t
typedef enum _flexspi_port flexspi_port_t
typedef enum _flexspi_arb_command_source flexspi_arb_command_source_t
typedef enum _flexspi_command_type flexspi_command_type_t
 Command type.
typedef struct _flexspi_ahbBuffer_config flexspi_ahbBuffer_config_t
typedef struct _flexspi_config flexspi_config_t
typedef struct _flexspi_device_config flexspi_device_config_t
typedef struct _flexspi_transfer flexspi_transfer_t
typedef struct _flexspi_handle flexspi_handle_t
typedef void(*) flexspi_transfer_callback_t(FLEXSPI_Type *base, flexspi_handle_t *handle, status_t status, void *userData)
 FLEXSPI transfer callback function.
#define FSL_FLEXSPI_DRIVER_VERSION   (MAKE_VERSION(2, 5, 0))
 FLEXSPI driver version.
#define FSL_FEATURE_FLEXSPI_AHB_BUFFER_COUNT   FSL_FEATURE_FLEXSPI_AHB_BUFFER_COUNTn(0)
#define FLEXSPI_LUT_SEQ(cmd0, pad0, op0, cmd1, pad1, op1)
 Formula to form FLEXSPI instructions in LUT table.
Initialization and deinitialization
uint32_t FLEXSPI_GetInstance (FLEXSPI_Type *base)
 Get the instance number for FLEXSPI.
status_t FLEXSPI_CheckAndClearError (FLEXSPI_Type *base, uint32_t status)
 Check and clear IP command execution errors.
void FLEXSPI_Init (FLEXSPI_Type *base, const flexspi_config_t *config)
 Initializes the FLEXSPI module and internal state.
void FLEXSPI_GetDefaultConfig (flexspi_config_t *config)
 Gets default settings for FLEXSPI.
void FLEXSPI_Deinit (FLEXSPI_Type *base)
 Deinitializes the FLEXSPI module.
void FLEXSPI_UpdateDllValue (FLEXSPI_Type *base, flexspi_device_config_t *config, flexspi_port_t port)
 Update FLEXSPI DLL value depending on currently flexspi root clock.
void FLEXSPI_SetFlashConfig (FLEXSPI_Type *base, flexspi_device_config_t *config, flexspi_port_t port)
 Configures the connected device parameter.
Bus Operations
void FLEXSPI_UpdateRxSampleClock (FLEXSPI_Type *base, flexspi_read_sample_clock_t clockSource)
 Update read sample clock source.
void FLEXSPI_UpdateLUT (FLEXSPI_Type *base, uint32_t index, const uint32_t *cmd, uint32_t count)
 Updates the LUT table.
status_t FLEXSPI_WriteBlocking (FLEXSPI_Type *base, uint8_t *buffer, size_t size)
 Sends a buffer of data bytes using blocking method.
status_t FLEXSPI_ReadBlocking (FLEXSPI_Type *base, uint8_t *buffer, size_t size)
 Receives a buffer of data bytes using a blocking method.
status_t FLEXSPI_TransferBlocking (FLEXSPI_Type *base, flexspi_transfer_t *xfer)
 Execute command to transfer a buffer data bytes using a blocking method.
Transactional
void FLEXSPI_TransferCreateHandle (FLEXSPI_Type *base, flexspi_handle_t *handle, flexspi_transfer_callback_t callback, void *userData)
 Initializes the FLEXSPI handle which is used in transactional functions.
status_t FLEXSPI_TransferNonBlocking (FLEXSPI_Type *base, flexspi_handle_t *handle, flexspi_transfer_t *xfer)
 Performs a interrupt non-blocking transfer on the FLEXSPI bus.
status_t FLEXSPI_TransferGetCount (FLEXSPI_Type *base, flexspi_handle_t *handle, size_t *count)
 Gets the master transfer status during a interrupt non-blocking transfer.
void FLEXSPI_TransferAbort (FLEXSPI_Type *base, flexspi_handle_t *handle)
 Aborts an interrupt non-blocking transfer early.
void FLEXSPI_TransferHandleIRQ (FLEXSPI_Type *base, flexspi_handle_t *handle)
 Master interrupt handler.
◆ FLEXSPI_LUT_SEQ
#define FLEXSPI_LUT_SEQ ( cmd0,
pad0,
op0,
cmd1,
pad1,
op1 )
Value:
FLEXSPI_LUT_NUM_PADS1(pad1) | FLEXSPI_LUT_OPCODE1(cmd1))
#define FLEXSPI_LUT_NUM_PADS0(x)
Definition MIMXRT1052.h:22264
#define FLEXSPI_LUT_OPERAND1(x)
Definition MIMXRT1052.h:22276
#define FLEXSPI_LUT_OPCODE1(x)
Definition MIMXRT1052.h:22288
#define FLEXSPI_LUT_OPERAND0(x)
Definition MIMXRT1052.h:22258
#define FLEXSPI_LUT_OPCODE0(x)
Definition MIMXRT1052.h:22270
◆ anonymous enum
anonymous enum
FLEXSPI is busy
Sequence execution timeout error occurred during FLEXSPI transfer.
IP command Sequence execution timeout error occurred during FLEXSPI transfer.
IP command grant timeout error occurred during FLEXSPI transfer.
◆ anonymous enum
anonymous enum
Stop execution, deassert CS.
Transmit Command code to Flash, using SDR mode.
Transmit Row Address to Flash, using SDR mode.
Transmit Column Address to Flash, using SDR mode.
Transmit 1-bit Mode bits to Flash, using SDR mode.
Transmit 2-bit Mode bits to Flash, using SDR mode.
Transmit 4-bit Mode bits to Flash, using SDR mode.
Transmit 8-bit Mode bits to Flash, using SDR mode.
Transmit Programming Data to Flash, using SDR mode.
Receive Read Data from Flash, using SDR mode.
Receive Read Data or Preamble bit from Flash, SDR mode.
Transmit Read/Program Data size (byte) to Flash, SDR mode.
Leave data lines undriven by FlexSPI controller.
Leave data lines undriven by FlexSPI controller, dummy cycles decided by RWDS.
Transmit Command code to Flash, using DDR mode.
Transmit Row Address to Flash, using DDR mode.
Transmit Column Address to Flash, using DDR mode.
Transmit 1-bit Mode bits to Flash, using DDR mode.
Transmit 2-bit Mode bits to Flash, using DDR mode.
Transmit 4-bit Mode bits to Flash, using DDR mode.
Transmit 8-bit Mode bits to Flash, using DDR mode.
Transmit Programming Data to Flash, using DDR mode.
Receive Read Data from Flash, using DDR mode.
Receive Read Data or Preamble bit from Flash, DDR mode.
Transmit Read/Program Data size (byte) to Flash, DDR mode.
Stop execution, deassert CS and save operand[7:0] as the instruction start pointer for next sequence
◆ _flexspi_ahb_error_code
No error.
AHB Write command with JMP_ON_CS instruction used in the sequence.
Unknown instruction opcode in the sequence.
Instruction DUMMY_SDR/DUMMY_RWDS_SDR used in DDR sequence.
Instruction DUMMY_DDR/DUMMY_RWDS_DDR used in SDR sequence.
Sequence execution timeout.
◆ _flexspi_ahb_write_wait_unit
AWRWAIT unit is 2 ahb clock cycle.
AWRWAIT unit is 8 ahb clock cycle.
AWRWAIT unit is 32 ahb clock cycle.
AWRWAIT unit is 128 ahb clock cycle.
AWRWAIT unit is 512 ahb clock cycle.
AWRWAIT unit is 2048 ahb clock cycle.
AWRWAIT unit is 8192 ahb clock cycle.
AWRWAIT unit is 32768 ahb clock cycle.
◆ _flexspi_command_type
Command type.
kFLEXSPI_Command
FlexSPI operation: Only command, both TX and Rx buffer are ignored.
kFLEXSPI_Config
FlexSPI operation: Configure device mode, the TX fifo size is fixed in LUT.
◆ _flexspi_cs_interval_cycle_unit
Chip selection interval: CSINTERVAL * 1 serial clock cycle.
Chip selection interval: CSINTERVAL * 256 serial clock cycle.
◆ _flexspi_flags
AHB Bus timeout.
SCK is stopped during command sequence because Async TX FIFO empty.
SCK is stopped during command sequence because Async RX FIFO full.
Data learning failed.
IP TX FIFO WaterMark empty.
IP RX FIFO WaterMark available.
AHB triggered Command Sequences Error.
IP triggered Command Sequences Error.
AHB triggered Command Sequences Grant Timeout.
IP triggered Command Sequences Grant Timeout.
IP triggered Command Sequences Execution finished.
All flags.
◆ _flexspi_ip_error_code
No error.
IP command with JMP_ON_CS instruction used.
Flash access start address exceed the whole flash address range (A1/A2/B1/B2).
Flash boundary crossed.
◆ _flexspi_pad
kFLEXSPI_1PAD
Transmit command/address and transmit/receive data only through DATA0/DATA1.
kFLEXSPI_2PAD
Transmit command/address and transmit/receive data only through DATA[1:0].
kFLEXSPI_4PAD
Transmit command/address and transmit/receive data only through DATA[3:0].
kFLEXSPI_8PAD
Transmit command/address and transmit/receive data only through DATA[7:0].
◆ _flexspi_port
kFLEXSPI_PortA1
Access flash on A1 port.
kFLEXSPI_PortA2
Access flash on A2 port.
kFLEXSPI_PortB1
Access flash on B1 port.
kFLEXSPI_PortB2
Access flash on B2 port.
◆ _flexspi_read_sample_clock
Dummy Read strobe generated by FlexSPI Controller and loopback internally.
Dummy Read strobe generated by FlexSPI Controller and loopback from DQS pad.
SCK output clock and loopback from SCK pad.
Flash provided Read strobe and input from DQS pad.
◆ FLEXSPI_CheckAndClearError()
status_t FLEXSPI_CheckAndClearError ( FLEXSPI_Type * base,
uint32_t status )
Parameters
baseFLEXSPI base pointer.
statusinterrupt status.
◆ FLEXSPI_Deinit()
void FLEXSPI_Deinit ( FLEXSPI_Type * base)
Clears the FLEXSPI state and FLEXSPI module registers.
Parameters
baseFLEXSPI peripheral base address.
brief Deinitializes the FLEXSPI module.
Clears the FLEXSPI state and FLEXSPI module registers. param base FLEXSPI peripheral base address.
◆ FLEXSPI_GetDefaultConfig()
void FLEXSPI_GetDefaultConfig ( flexspi_config_t * config)
Parameters
configFLEXSPI configuration structure.
brief Gets default settings for FLEXSPI.
param config FLEXSPI configuration structure.
◆ FLEXSPI_GetInstance()
uint32_t FLEXSPI_GetInstance ( FLEXSPI_Type * base)
Parameters
◆ FLEXSPI_Init()
void FLEXSPI_Init ( FLEXSPI_Type * base,
const flexspi_config_t * config )
This function enables the clock for FLEXSPI and also configures the FLEXSPI with the input configure parameters. Users should call this function before any FLEXSPI operations.
Parameters
configFLEXSPI configure structure.
brief Initializes the FLEXSPI module and internal state.
param base FLEXSPI peripheral base address. param config FLEXSPI configure structure.
◆ FLEXSPI_ReadBlocking()
status_t FLEXSPI_ReadBlocking ( FLEXSPI_Type * base,
uint8_t * buffer,
size_t size )
Note
This function blocks via polling until all bytes have been sent.
Parameters
bufferThe data bytes to send
sizeThe number of data bytes to receive
Return values
kStatus_Successread success without error
kStatus_FLEXSPI_SequenceExecutionTimeoutsequence execution timeout
kStatus_FLEXSPI_IpCommandSequenceErrorIP command sequencen error detected
kStatus_FLEXSPI_IpCommandGrantTimeoutIP command grant timeout detected
brief Receives a buffer of data bytes using a blocking method. note This function blocks via polling until all bytes have been sent. param base FLEXSPI peripheral base address param buffer The data bytes to send param size The number of data bytes to receive retval kStatus_Success read success without error retval kStatus_FLEXSPI_SequenceExecutionTimeout sequence execution timeout retval kStatus_FLEXSPI_IpCommandSequenceError IP command sequence error detected retval kStatus_FLEXSPI_IpCommandGrantTimeout IP command grant timeout detected
◆ FLEXSPI_SetFlashConfig()
void FLEXSPI_SetFlashConfig ( FLEXSPI_Type * base,
flexspi_device_config_t * config,
flexspi_port_t port )
This function configures the connected device relevant parameters, such as the size, command, and so on. The flash configuration value cannot have a default value. The user needs to configure it according to the connected device.
Parameters
configFlash configuration parameters.
portFLEXSPI Operation port.
brief Configures the connected device parameter.
param base FLEXSPI peripheral base address. param config Flash configuration parameters. param port FLEXSPI Operation port.
◆ FLEXSPI_TransferAbort()
void FLEXSPI_TransferAbort ( FLEXSPI_Type * base,
flexspi_handle_t * handle )
Note
This API can be called at any time when an interrupt non-blocking transfer initiates to abort the transfer early.
Parameters
handlepointer to flexspi_handle_t structure which stores the transfer state
brief Aborts an interrupt non-blocking transfer early.
note This API can be called at any time when an interrupt non-blocking transfer initiates to abort the transfer early.
param base FLEXSPI peripheral base address. param handle pointer to flexspi_handle_t structure which stores the transfer state
◆ FLEXSPI_TransferBlocking()
status_t FLEXSPI_TransferBlocking ( FLEXSPI_Type * base,
flexspi_transfer_t * xfer )
Parameters
xferpointer to the transfer structure.
Return values
kStatus_Successcommand transfer success without error
kStatus_FLEXSPI_IpCommandSequenceErrorIP command sequence error detected
brief Execute command to transfer a buffer data bytes using a blocking method. param base FLEXSPI peripheral base address param xfer pointer to the transfer structure. retval kStatus_Success command transfer success without error retval kStatus_FLEXSPI_SequenceExecutionTimeout sequence execution timeout retval kStatus_FLEXSPI_IpCommandSequenceError IP command sequence error detected retval kStatus_FLEXSPI_IpCommandGrantTimeout IP command grant timeout detected
◆ FLEXSPI_TransferCreateHandle()
void FLEXSPI_TransferCreateHandle ( FLEXSPI_Type * base,
flexspi_handle_t * handle,
void * userData )
Parameters
handlepointer to flexspi_handle_t structure to store the transfer state.
callbackpointer to user callback function.
userDatauser parameter passed to the callback function.
brief Initializes the FLEXSPI handle which is used in transactional functions.
param base FLEXSPI peripheral base address. param handle pointer to flexspi_handle_t structure to store the transfer state. param callback pointer to user callback function. param userData user parameter passed to the callback function.
◆ FLEXSPI_TransferGetCount()
status_t FLEXSPI_TransferGetCount ( FLEXSPI_Type * base,
size_t * count )
Parameters
handlepointer to flexspi_handle_t structure which stores the transfer state.
countNumber of bytes transferred so far by the non-blocking transaction.
Return values
kStatus_InvalidArgumentcount is Invalid.
kStatus_SuccessSuccessfully return the count.
brief Gets the master transfer status during a interrupt non-blocking transfer.
param base FLEXSPI peripheral base address. param handle pointer to flexspi_handle_t structure which stores the transfer state. param count Number of bytes transferred so far by the non-blocking transaction. retval kStatus_InvalidArgument count is Invalid. retval kStatus_Success Successfully return the count.
◆ FLEXSPI_TransferHandleIRQ()
void FLEXSPI_TransferHandleIRQ ( FLEXSPI_Type * base,
Parameters
handlepointer to flexspi_handle_t structure.
brief Master interrupt handler.
param base FLEXSPI peripheral base address. param handle pointer to flexspi_handle_t structure.
◆ FLEXSPI_TransferNonBlocking()
status_t FLEXSPI_TransferNonBlocking ( FLEXSPI_Type * base,
Note
Calling the API returns immediately after transfer initiates. The user needs to call FLEXSPI_GetTransferCount to poll the transfer status to check whether the transfer is finished. If the return status is not kStatus_FLEXSPI_Busy, the transfer is finished. For FLEXSPI_Read, the dataSize should be multiple of rx watermark level, or FLEXSPI could not read data properly.
Parameters
xferpointer to flexspi_transfer_t structure.
Return values
kStatus_SuccessSuccessfully start the data transmission.
kStatus_FLEXSPI_BusyPrevious transmission still not finished.
brief Performs a interrupt non-blocking transfer on the FLEXSPI bus.
note Calling the API returns immediately after transfer initiates. The user needs to call FLEXSPI_GetTransferCount to poll the transfer status to check whether the transfer is finished. If the return status is not kStatus_FLEXSPI_Busy, the transfer is finished. For FLEXSPI_Read, the dataSize should be multiple of rx watermark level, or FLEXSPI could not read data properly.
param base FLEXSPI peripheral base address. param handle pointer to flexspi_handle_t structure which stores the transfer state. param xfer pointer to flexspi_transfer_t structure. retval kStatus_Success Successfully start the data transmission. retval kStatus_FLEXSPI_Busy Previous transmission still not finished.
◆ FLEXSPI_UpdateDllValue()
void FLEXSPI_UpdateDllValue ( FLEXSPI_Type * base,
Parameters
brief Update FLEXSPI DLL value depending on currently flexspi root clock.
◆ FLEXSPI_UpdateLUT()
void FLEXSPI_UpdateLUT ( FLEXSPI_Type * base,
uint32_t index,
const uint32_t * cmd,
uint32_t count )
Parameters
indexFrom which index start to update. It could be any index of the LUT table, which also allows user to update command content inside a command. Each command consists of up to 8 instructions and occupy 4*32-bit memory.
cmdCommand sequence array.
countNumber of sequences.
brief Updates the LUT table.
param base FLEXSPI peripheral base address. param index From which index start to update. It could be any index of the LUT table, which also allows user to update command content inside a command. Each command consists of up to 8 instructions and occupy 4*32-bit memory. param cmd Command sequence array. param count Number of sequences.
◆ FLEXSPI_UpdateRxSampleClock()
void FLEXSPI_UpdateRxSampleClock ( FLEXSPI_Type * base,
flexspi_read_sample_clock_t clockSource )
Parameters
clockSourceclockSource of type flexspi_read_sample_clock_t
brief Update read sample clock source
param base FLEXSPI peripheral base address. param clockSource clockSource of type flexspi_read_sample_clock_t
◆ FLEXSPI_WriteBlocking()
status_t FLEXSPI_WriteBlocking ( FLEXSPI_Type * base,
uint8_t * buffer,
size_t size )
Note
Parameters
sizeThe number of data bytes to send
Return values
kStatus_Successwrite success without error
brief Sends a buffer of data bytes using blocking method. note This function blocks via polling until all bytes have been sent. param base FLEXSPI peripheral base address param buffer The data bytes to send param size The number of data bytes to send retval kStatus_Success write success without error retval kStatus_FLEXSPI_SequenceExecutionTimeout sequence execution timeout retval kStatus_FLEXSPI_IpCommandSequenceError IP command sequence error detected retval kStatus_FLEXSPI_IpCommandGrantTimeout IP command grant timeout detected
Variable Documentation
◆ ahbBusTimeoutCycle
uint16_t { ... } ::ahbBusTimeoutCycle
Timeout wait cycle for AHB read/write access, timeout after ahbBusTimeoutCycle*1024 AHB clock cycles.
◆ ahbGrantTimeoutCycle
uint8_t { ... } ::ahbGrantTimeoutCycle
Timeout wait cycle for AHB command grant, timeout after ahbGrantTimeoutCyle*1024 AHB clock cycles.
◆ AHBWriteWaitInterval
AHB write wait interval, multiply AHB write interval unit to get the AHB write wait cycles.
◆ AHBWriteWaitUnit
AHB write wait unit.
◆ ARDSeqIndex
Sequence ID for AHB read command.
◆ ARDSeqNumber
Sequence number for AHB read command.
◆ AWRSeqIndex
Sequence ID for AHB write command.
◆ AWRSeqNumber
Sequence number for AHB write command.
◆ buffer
flexspi_ahbBuffer_config_t { ... } ::buffer[FSL_FEATURE_FLEXSPI_AHB_BUFFER_COUNT]
AHB buffer size.
◆ bufferSize
AHB buffer size in byte.
◆ cmdType
Execution command type.
◆ columnspace
Column space size.
◆ completionCallback
Callback for users while transfer finish or error occurred
◆ CSHoldTime
CS line hold time.
◆ CSInterval
CS line assert interval, multiply CS interval unit to get the CS line assert interval cycles.
◆ CSIntervalUnit
CS interval unit, 1 or 256 cycle.
◆ CSSetupTime
CS line setup time.
◆ data [1/2]
uint8_t* _flexspi_handle::data
Data buffer.
◆ data [2/2]
uint32_t* _flexspi_transfer::data
Data buffer.
◆ dataSize [1/2]
Remaining Data size in bytes.
◆ dataSize [2/2]
Data size in bytes.
◆ dataValidTime
Data valid time for external device.
◆ deviceAddress
Operation device address.
◆ enableAHBBufferable
bool { ... } ::enableAHBBufferable
Enable/disable AHB bufferable write access support, when enabled, FLEXSPI return before waiting for command execution finished.
◆ enableAHBCachable
bool { ... } ::enableAHBCachable
Enable AHB bus cachable read access support.
◆ enableAHBPrefetch
bool { ... } ::enableAHBPrefetch
Enable/disable AHB read prefetch feature, when enabled, FLEXSPI will fetch more data than current AHB burst.
◆ enableAHBWriteIpRxFifo
bool { ... } ::enableAHBWriteIpRxFifo
Enable AHB bus write access to IP RX FIFO.
◆ enableAHBWriteIpTxFifo
bool { ... } ::enableAHBWriteIpTxFifo
Enable AHB bus write access to IP TX FIFO.
◆ enableClearAHBBufferOpt
bool { ... } ::enableClearAHBBufferOpt
Enable/disable automatically clean AHB RX Buffer and TX Buffer when FLEXSPI returns STOP mode ACK.
◆ enableCombination
Enable/disable combining PORT A and B Data Pins (SIOA[3:0] and SIOB[3:0]) to support Flash Octal mode.
◆ enableDoze
Enable/disable doze mode support.
◆ enableHalfSpeedAccess
Enable/disable divide by 2 of the clock for half speed commands.
◆ enablePrefetch
AHB Read Prefetch Enable for current AHB RX Buffer corresponding Master, allows prefetch disable/enable separately for each master.
◆ enableReadAddressOpt
bool { ... } ::enableReadAddressOpt
Enable/disable remove AHB read burst start address alignment limitation. when enable, there is no AHB read burst start address alignment limitation.
◆ enableSameConfigForAll
Enable/disable same configuration for all connected devices when enabled, same configuration in FLASHA1CRx is applied to all.
◆ enableSckBDiffOpt
Enable/disable SCKB pad use as SCKA differential clock output, when enable, Port B flash access is not available.
◆ enableSckFreeRunning
Enable/disable SCK output free-running.
◆ enableWordAddress
If enable word address.
◆ enableWriteMask
Enable/Disable FLEXSPI drive DQS pin as write mask when writing to external device.
◆ flashSize
Flash size in KByte.
◆ flexspiRootClk
FLEXSPI serial root clock.
◆ ipGrantTimeoutCycle
Timeout wait cycle for IP command grant, timeout after ipGrantTimeoutCycle*1024 AHB clock cycles.
◆ isSck2Enabled
FLEXSPI use SCK2.
◆ masterIndex
AHB Master ID the AHB RX Buffer is assigned.
◆ port
Operation port.
◆ priority
This priority for AHB Master Read which this AHB RX Buffer is assigned.
◆ resumeWaitCycle
uint8_t { ... } ::resumeWaitCycle
Wait cycle for idle state before suspended command sequence resume, timeout after ahbBusTimeoutCycle AHB clock cycles.
◆ rxSampleClock
Sample Clock source selection for Flash Reading.
◆ rxWatermark
FLEXSPI receive watermark value.
◆ seqIndex
Sequence ID for command.
◆ SeqNumber
Sequence number for command.
◆ seqTimeoutCycle
Timeout wait cycle for command sequence execution, timeout after ahbGrantTimeoutCyle*1024 serial root clock cycles.
◆ state
Internal state for FLEXSPI transfer
◆ transferTotalSize
Total Data size in bytes.
◆ txWatermark
FLEXSPI IP transmit watermark value.
◆ userData
void* _flexspi_handle::userData
FLEXSPI callback function parameter.
