RTEMS 6.3
fsl-mpc5668.h
1/*
2 * Modifications of the original file provided by Freescale are:
3 *
4 * Copyright (c) 2013 embedded brains GmbH & Co. KG
5 *
6 * Redistribution and use in source and binary forms, with or without
7 * modification, are permitted provided that the following conditions
8 * are met:
9 * 1. Redistributions of source code must retain the above copyright
10 * notice, this list of conditions and the following disclaimer.
11 * 2. Redistributions in binary form must reproduce the above copyright
12 * notice, this list of conditions and the following disclaimer in the
13 * documentation and/or other materials provided with the distribution.
14 *
15 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
16 * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
17 * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
18 * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
19 * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
20 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
21 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
22 * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
23 * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
24 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
25 * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
26 */
27
28/**************************************************************************
29 * FILE NAME: mpc5668.h COPYRIGHT (c) Freescale 2009 *
30 * REVISION: 1.1 All Rights Reserved *
31 * *
32 * DESCRIPTION: *
33 * This file contain all of the register and bit field definitions for *
34 * MPC5668. *
35 **************************************************************************/
36/*>>>>NOTE! this file is auto-generated please do not edit it!<<<<*/
37
38/**************************************************************************
39 * Example register & bit field write: *
40 * *
41 * <MODULE>.<REGISTER>.B.<BIT> = 1; *
42 * <MODULE>.<REGISTER>.R = 0x10000000; *
43 * *
44 **************************************************************************/
45
46#ifndef _MPC5668_H_
47#define _MPC5668_H_
48
49#ifndef ASM
50
51#include <stdint.h>
52
53#include <mpc55xx/regs-edma.h>
54
55#ifdef __cplusplus
56extern "C" {
57#endif
58
59#ifdef __MWERKS__
60#pragma push
61#pragma ANSI_strict off
62#endif
63
64/*************************************************************************/
65/* MODULE : ADC */
66/*************************************************************************/
67 struct ADC_tag {
68
69 union {
70 uint32_t R;
71 struct {
72 uint32_t OWREN:1;
73 uint32_t WLSIDE:1;
74 uint32_t MODE:1;
75 uint32_t EDGLEV:1;
76 uint32_t TRGEN:1;
77 uint32_t EDGE:1;
78 uint32_t XSTRTEN:1;
79 uint32_t NSTART:1;
80 uint32_t:1;
81 uint32_t JTRGEN:1;
82 uint32_t JEDGE:1;
83 uint32_t JSTART:1;
84 uint32_t:2;
85 uint32_t CTUEN:1;
86 uint32_t:8;
87 uint32_t ADCLKSEL:1;
88 uint32_t ABORTCHAIN:1;
89 uint32_t ABORT:1;
90 uint32_t ACKO:1;
91 uint32_t OFFREFRESH:1;
92 uint32_t OFFCANC:1;
93 uint32_t:2;
94 uint32_t PWDN:1;
95 } B;
96 } MCR; /* MAIN CONFIGURATION REGISTER */
97
98 union {
99 uint32_t R;
100 struct {
101 uint32_t:7;
102 uint32_t NSTART:1;
103 uint32_t JABORT:1;
104 uint32_t:2;
105 uint32_t JSTART:1;
106 uint32_t:3;
107 uint32_t CTUSTART:1;
108 uint32_t CHADDR:7;
109 uint32_t:3;
110 uint32_t ACKO:1;
111 uint32_t OFFREFRESH:1;
112 uint32_t OFFCANC:1;
113 uint32_t ADCSTATUS:3;
114 } B;
115 } MSR; /* MAIN STATUS REGISTER */
116
117 uint32_t adc_reserved1[2];
118
119 union {
120 uint32_t R;
121 struct {
122 uint32_t:25;
123 uint32_t OFFCANCOVR:1;
124 uint32_t EOFFSET:1;
125 uint32_t EOCTU:1;
126 uint32_t JEOC:1;
127 uint32_t JECH:1;
128 uint32_t EOC:1;
129 uint32_t ECH:1;
130 } B;
131 } ISR; /* INTERRUPT STATUS REGISTER */
132
133 union {
134 uint32_t R;
135 struct {
136 uint32_t EOCCH31:1;
137 uint32_t EOCCH30:1;
138 uint32_t EOCCH29:1;
139 uint32_t EOCCH28:1;
140 uint32_t EOCCH27:1;
141 uint32_t EOCCH26:1;
142 uint32_t EOCCH25:1;
143 uint32_t EOCCH24:1;
144 uint32_t EOCCH23:1;
145 uint32_t EOCCH22:1;
146 uint32_t EOCCH21:1;
147 uint32_t EOCCH20:1;
148 uint32_t EOCCH19:1;
149 uint32_t EOCCH18:1;
150 uint32_t EOCCH17:1;
151 uint32_t EOCCH16:1;
152 uint32_t EOCCH15:1;
153 uint32_t EOCCH14:1;
154 uint32_t EOCCH13:1;
155 uint32_t EOCCH12:1;
156 uint32_t EOCCH11:1;
157 uint32_t EOCCH10:1;
158 uint32_t EOCCH9:1;
159 uint32_t EOCCH8:1;
160 uint32_t EOCCH7:1;
161 uint32_t EOCCH6:1;
162 uint32_t EOCCH5:1;
163 uint32_t EOCCH4:1;
164 uint32_t EOCCH3:1;
165 uint32_t EOCCH2:1;
166 uint32_t EOCCH1:1;
167 uint32_t EOCCH0:1;
168 } B;
169 } CEOCFR0; /* CHANNEL PENDING REGISTER 0 */
170
171 union {
172 uint32_t R;
173 struct {
174 uint32_t EOCCH63:1;
175 uint32_t EOCCH62:1;
176 uint32_t EOCCH61:1;
177 uint32_t EOCCH60:1;
178 uint32_t EOCCH59:1;
179 uint32_t EOCCH58:1;
180 uint32_t EOCCH57:1;
181 uint32_t EOCCH56:1;
182 uint32_t EOCCH55:1;
183 uint32_t EOCCH54:1;
184 uint32_t EOCCH53:1;
185 uint32_t EOCCH52:1;
186 uint32_t EOCCH51:1;
187 uint32_t EOCCH50:1;
188 uint32_t EOCCH49:1;
189 uint32_t EOCCH48:1;
190 uint32_t EOCCH47:1;
191 uint32_t EOCCH46:1;
192 uint32_t EOCCH45:1;
193 uint32_t EOCCH44:1;
194 uint32_t EOCCH43:1;
195 uint32_t EOCCH42:1;
196 uint32_t EOCCH41:1;
197 uint32_t EOCCH40:1;
198 uint32_t EOCCH39:1;
199 uint32_t EOCCH38:1;
200 uint32_t EOCCH37:1;
201 uint32_t EOCCH36:1;
202 uint32_t EOCCH35:1;
203 uint32_t EOCCH34:1;
204 uint32_t EOCCH33:1;
205 uint32_t EOCCH32:1;
206 } B;
207 } CEOCFR1; /* CHANNEL PENDING REGISTER 1 */
208
209 union {
210 uint32_t R;
211 struct {
212 uint32_t EOCCH95:1;
213 uint32_t EOCCH94:1;
214 uint32_t EOCCH93:1;
215 uint32_t EOCCH92:1;
216 uint32_t EOCCH91:1;
217 uint32_t EOCCH90:1;
218 uint32_t EOCCH89:1;
219 uint32_t EOCCH88:1;
220 uint32_t EOCCH87:1;
221 uint32_t EOCCH86:1;
222 uint32_t EOCCH85:1;
223 uint32_t EOCCH84:1;
224 uint32_t EOCCH83:1;
225 uint32_t EOCCH82:1;
226 uint32_t EOCCH81:1;
227 uint32_t EOCCH80:1;
228 uint32_t EOCCH79:1;
229 uint32_t EOCCH78:1;
230 uint32_t EOCCH77:1;
231 uint32_t EOCCH76:1;
232 uint32_t EOCCH75:1;
233 uint32_t EOCCH74:1;
234 uint32_t EOCCH73:1;
235 uint32_t EOCCH72:1;
236 uint32_t EOCCH71:1;
237 uint32_t EOCCH70:1;
238 uint32_t EOCCH69:1;
239 uint32_t EOCCH68:1;
240 uint32_t EOCCH67:1;
241 uint32_t EOCCH66:1;
242 uint32_t EOCCH65:1;
243 uint32_t EOCCH64:1;
244 } B;
245 } CEOCFR2; /* CHANNEL PENDING REGISTER 2 */
246
247 union {
248 uint32_t R;
249 struct {
250 uint32_t:25;
251 uint32_t MSKOFFCANCOVR:1;
252 uint32_t MSKEOFFSET:1;
253 uint32_t MSKEOCTU:1;
254 uint32_t MSKJEOC:1;
255 uint32_t MSKJECH:1;
256 uint32_t MSKEOC:1;
257 uint32_t MSKECH:1;
258 } B;
259 } IMR; /* INTERRUPT MASK REGISTER */
260
261 union {
262 uint32_t R;
263 struct {
264 uint32_t CIM31:1;
265 uint32_t CIM30:1;
266 uint32_t CIM29:1;
267 uint32_t CIM28:1;
268 uint32_t CIM27:1;
269 uint32_t CIM26:1;
270 uint32_t CIM25:1;
271 uint32_t CIM24:1;
272 uint32_t CIM23:1;
273 uint32_t CIM22:1;
274 uint32_t CIM21:1;
275 uint32_t CIM20:1;
276 uint32_t CIM19:1;
277 uint32_t CIM18:1;
278 uint32_t CIM17:1;
279 uint32_t CIM16:1;
280 uint32_t CIM15:1;
281 uint32_t CIM14:1;
282 uint32_t CIM13:1;
283 uint32_t CIM12:1;
284 uint32_t CIM11:1;
285 uint32_t CIM10:1;
286 uint32_t CIM9:1;
287 uint32_t CIM8:1;
288 uint32_t CIM7:1;
289 uint32_t CIM6:1;
290 uint32_t CIM5:1;
291 uint32_t CIM4:1;
292 uint32_t CIM3:1;
293 uint32_t CIM2:1;
294 uint32_t CIM1:1;
295 uint32_t CIM0:1;
296 } B;
297 } CIMR0; /* CHANNEL INTERRUPT MASK REGISTER 0 */
298
299 union {
300 uint32_t R;
301 struct {
302 uint32_t CIM63:1;
303 uint32_t CIM62:1;
304 uint32_t CIM61:1;
305 uint32_t CIM60:1;
306 uint32_t CIM59:1;
307 uint32_t CIM58:1;
308 uint32_t CIM57:1;
309 uint32_t CIM56:1;
310 uint32_t CIM55:1;
311 uint32_t CIM54:1;
312 uint32_t CIM53:1;
313 uint32_t CIM52:1;
314 uint32_t CIM51:1;
315 uint32_t CIM50:1;
316 uint32_t CIM49:1;
317 uint32_t CIM48:1;
318 uint32_t CIM47:1;
319 uint32_t CIM46:1;
320 uint32_t CIM45:1;
321 uint32_t CIM44:1;
322 uint32_t CIM43:1;
323 uint32_t CIM42:1;
324 uint32_t CIM41:1;
325 uint32_t CIM40:1;
326 uint32_t CIM39:1;
327 uint32_t CIM38:1;
328 uint32_t CIM37:1;
329 uint32_t CIM36:1;
330 uint32_t CIM35:1;
331 uint32_t CIM34:1;
332 uint32_t CIM33:1;
333 uint32_t CIM32:1;
334 } B;
335 } CIMR1; /* CHANNEL INTERRUPT MASK REGISTER 1 */
336
337 union {
338 uint32_t R;
339 struct {
340 uint32_t CIM63:1;
341 uint32_t CIM62:1;
342 uint32_t CIM61:1;
343 uint32_t CIM60:1;
344 uint32_t CIM59:1;
345 uint32_t CIM58:1;
346 uint32_t CIM57:1;
347 uint32_t CIM56:1;
348 uint32_t CIM55:1;
349 uint32_t CIM54:1;
350 uint32_t CIM53:1;
351 uint32_t CIM52:1;
352 uint32_t CIM51:1;
353 uint32_t CIM50:1;
354 uint32_t CIM49:1;
355 uint32_t CIM48:1;
356 uint32_t CIM47:1;
357 uint32_t CIM46:1;
358 uint32_t CIM45:1;
359 uint32_t CIM44:1;
360 uint32_t CIM43:1;
361 uint32_t CIM42:1;
362 uint32_t CIM41:1;
363 uint32_t CIM40:1;
364 uint32_t CIM39:1;
365 uint32_t CIM38:1;
366 uint32_t CIM37:1;
367 uint32_t CIM36:1;
368 uint32_t CIM35:1;
369 uint32_t CIM34:1;
370 uint32_t CIM33:1;
371 uint32_t CIM32:1;
372 } B;
373 } CIMR2; /* CHANNEL INTERRUPT MASK REGISTER 2 */
374
375 union {
376 uint32_t R;
377 struct {
378 uint32_t:24;
379 uint32_t WDG3H:1;
380 uint32_t WDG2H:1;
381 uint32_t WDG1H:1;
382 uint32_t WDG0H:1;
383 uint32_t WDG3L:1;
384 uint32_t WDG2L:1;
385 uint32_t WDG1L:1;
386 uint32_t WDG0L:1;
387 } B;
388 } WTISR; /* WATCHDOG INTERRUPT THRESHOLD REGISTER */
389
390 union {
391 uint32_t R;
392 struct {
393 uint32_t:24;
394 uint32_t MSKWDG3H:1;
395 uint32_t MSKWDG2H:1;
396 uint32_t MSKWDG1H:1;
397 uint32_t MSKWDG0H:1;
398 uint32_t MSKWDG3L:1;
399 uint32_t MSKWDG2L:1;
400 uint32_t MSKWDG1L:1;
401 uint32_t MSKWDG0L:1;
402 } B;
403 } WTIMR; /* WATCHDOG INTERRUPT THRESHOLD MASK REGISTER */
404
405 uint32_t adc_reserved2[2];
406
407 union {
408 uint32_t R;
409 struct {
410 uint32_t:30;
411 uint32_t DCLR:1;
412 uint32_t DMAEN:1;
413 } B;
414 } DMAE; /* DMA ENABLE REGISTER */
415
416 union {
417 uint32_t R;
418 struct {
419 uint32_t DMA31:1;
420 uint32_t DMA30:1;
421 uint32_t DMA29:1;
422 uint32_t DMA28:1;
423 uint32_t DMA27:1;
424 uint32_t DMA26:1;
425 uint32_t DMA25:1;
426 uint32_t DMA24:1;
427 uint32_t DMA23:1;
428 uint32_t DMA22:1;
429 uint32_t DMA21:1;
430 uint32_t DMA20:1;
431 uint32_t DMA19:1;
432 uint32_t DMA18:1;
433 uint32_t DMA17:1;
434 uint32_t DMA16:1;
435 uint32_t DMA15:1;
436 uint32_t DMA14:1;
437 uint32_t DMA13:1;
438 uint32_t DMA12:1;
439 uint32_t DMA11:1;
440 uint32_t DMA10:1;
441 uint32_t DMA9:1;
442 uint32_t DMA8:1;
443 uint32_t DMA7:1;
444 uint32_t DMA6:1;
445 uint32_t DMA5:1;
446 uint32_t DMA4:1;
447 uint32_t DMA3:1;
448 uint32_t DMA2:1;
449 uint32_t DMA1:1;
450 uint32_t DMA0:1;
451 } B;
452 } DMAR0; /* DMA CHANNEL SELECT REGISTER 0 */
453
454 union {
455 uint32_t R;
456 struct {
457 uint32_t DMA63:1;
458 uint32_t DMA62:1;
459 uint32_t DMA61:1;
460 uint32_t DMA60:1;
461 uint32_t DMA59:1;
462 uint32_t DMA58:1;
463 uint32_t DMA57:1;
464 uint32_t DMA56:1;
465 uint32_t DMA55:1;
466 uint32_t DMA54:1;
467 uint32_t DMA53:1;
468 uint32_t DMA52:1;
469 uint32_t DMA51:1;
470 uint32_t DMA50:1;
471 uint32_t DMA49:1;
472 uint32_t DMA48:1;
473 uint32_t DMA47:1;
474 uint32_t DMA46:1;
475 uint32_t DMA45:1;
476 uint32_t DMA44:1;
477 uint32_t DMA43:1;
478 uint32_t DMA42:1;
479 uint32_t DMA41:1;
480 uint32_t DMA40:1;
481 uint32_t DMA39:1;
482 uint32_t DMA38:1;
483 uint32_t DMA37:1;
484 uint32_t DMA36:1;
485 uint32_t DMA35:1;
486 uint32_t DMA34:1;
487 uint32_t DMA33:1;
488 uint32_t DMA32:1;
489 } B;
490 } DMAR1; /* DMA CHANNEL SELECT REGISTER 1 */
491
492 union {
493 uint32_t R;
494 struct {
495 uint32_t DMA95:1;
496 uint32_t DMA94:1;
497 uint32_t DMA93:1;
498 uint32_t DMA92:1;
499 uint32_t DMA91:1;
500 uint32_t DMA90:1;
501 uint32_t DMA89:1;
502 uint32_t DMA88:1;
503 uint32_t DMA87:1;
504 uint32_t DMA86:1;
505 uint32_t DMA85:1;
506 uint32_t DMA84:1;
507 uint32_t DMA83:1;
508 uint32_t DMA82:1;
509 uint32_t DMA81:1;
510 uint32_t DMA80:1;
511 uint32_t DMA79:1;
512 uint32_t DMA78:1;
513 uint32_t DMA77:1;
514 uint32_t DMA76:1;
515 uint32_t DMA75:1;
516 uint32_t DMA74:1;
517 uint32_t DMA73:1;
518 uint32_t DMA72:1;
519 uint32_t DMA71:1;
520 uint32_t DMA70:1;
521 uint32_t DMA69:1;
522 uint32_t DMA68:1;
523 uint32_t DMA67:1;
524 uint32_t DMA66:1;
525 uint32_t DMA65:1;
526 uint32_t DMA64:1;
527 } B;
528 } DMAR2; /* DMA CHANNEL SELECT REGISTER 2 */
529
530 union {
531 uint32_t R;
532 struct {
533 uint32_t:16;
534 uint32_t THREN:1;
535 uint32_t THRINV:1;
536 uint32_t THROP:1;
537 uint32_t:6;
538 uint32_t THRCH:7;
539 } B;
540 } TRC[4]; /* THRESHOLD CONTROL REGISTER */
541
542 union {
543 uint32_t R;
544 struct {
545 uint32_t:6;
546 uint32_t THRH:10;
547 uint32_t:6;
548 uint32_t THRL:10;
549 } B;
550 } THRHLR[4]; /* THRESHOLD REGISTER */
551
552 union {
553 uint32_t R;
554 struct {
555 uint32_t:6;
556 uint32_t THRH:10;
557 uint32_t:6;
558 uint32_t THRL:10;
559 } B;
560 } THRALT[4]; /* ALTERNATE THRESHOLD REGISTER */
561
562 union {
563 uint32_t R;
564 struct {
565 uint32_t:25;
566 uint32_t PREVAL2:2;
567 uint32_t PREVAL1:2;
568 uint32_t PREVAL0:2;
569 uint32_t PRECONV:1;
570 } B;
571 } PSCR; /* PRESAMPLING CONTROL REGISTER */
572
573 union {
574 uint32_t R;
575 struct {
576 uint32_t PSR31:1;
577 uint32_t PSR30:1;
578 uint32_t PSR29:1;
579 uint32_t PSR28:1;
580 uint32_t PSR27:1;
581 uint32_t PSR26:1;
582 uint32_t PSR25:1;
583 uint32_t PSR24:1;
584 uint32_t PSR23:1;
585 uint32_t PSR22:1;
586 uint32_t PSR21:1;
587 uint32_t PSR20:1;
588 uint32_t PSR19:1;
589 uint32_t PSR18:1;
590 uint32_t PSR17:1;
591 uint32_t PSR16:1;
592 uint32_t PSR15:1;
593 uint32_t PSR14:1;
594 uint32_t PSR13:1;
595 uint32_t PSR12:1;
596 uint32_t PSR11:1;
597 uint32_t PSR10:1;
598 uint32_t PSR9:1;
599 uint32_t PSR8:1;
600 uint32_t PSR7:1;
601 uint32_t PSR6:1;
602 uint32_t PSR5:1;
603 uint32_t PSR4:1;
604 uint32_t PSR3:1;
605 uint32_t PSR2:1;
606 uint32_t PSR1:1;
607 uint32_t PSR0:1;
608 } B;
609 } PSR0; /* PRESAMPLING REGISTER 0 */
610
611 union {
612 uint32_t R;
613 struct {
614 uint32_t PSR63:1;
615 uint32_t PSR62:1;
616 uint32_t PSR61:1;
617 uint32_t PSR60:1;
618 uint32_t PSR59:1;
619 uint32_t PSR58:1;
620 uint32_t PSR57:1;
621 uint32_t PSR56:1;
622 uint32_t PSR55:1;
623 uint32_t PSR54:1;
624 uint32_t PSR53:1;
625 uint32_t PSR52:1;
626 uint32_t PSR51:1;
627 uint32_t PSR50:1;
628 uint32_t PSR49:1;
629 uint32_t PSR48:1;
630 uint32_t PSR47:1;
631 uint32_t PSR46:1;
632 uint32_t PSR45:1;
633 uint32_t PSR44:1;
634 uint32_t PSR43:1;
635 uint32_t PSR42:1;
636 uint32_t PSR41:1;
637 uint32_t PSR40:1;
638 uint32_t PSR39:1;
639 uint32_t PSR38:1;
640 uint32_t PSR37:1;
641 uint32_t PSR36:1;
642 uint32_t PSR35:1;
643 uint32_t PSR34:1;
644 uint32_t PSR33:1;
645 uint32_t PSR32:1;
646 } B;
647 } PSR1; /* PRESAMPLING REGISTER 1 */
648
649 union {
650 uint32_t R;
651 struct {
652 uint32_t PSR95:1;
653 uint32_t PSR94:1;
654 uint32_t PSR93:1;
655 uint32_t PSR92:1;
656 uint32_t PSR91:1;
657 uint32_t PSR90:1;
658 uint32_t PSR89:1;
659 uint32_t PSR88:1;
660 uint32_t PSR87:1;
661 uint32_t PSR86:1;
662 uint32_t PSR85:1;
663 uint32_t PSR84:1;
664 uint32_t PSR83:1;
665 uint32_t PSR82:1;
666 uint32_t PSR81:1;
667 uint32_t PSR80:1;
668 uint32_t PSR79:1;
669 uint32_t PSR78:1;
670 uint32_t PSR77:1;
671 uint32_t PSR76:1;
672 uint32_t PSR75:1;
673 uint32_t PSR74:1;
674 uint32_t PSR73:1;
675 uint32_t PSR72:1;
676 uint32_t PSR71:1;
677 uint32_t PSR70:1;
678 uint32_t PSR69:1;
679 uint32_t PSR68:1;
680 uint32_t PSR67:1;
681 uint32_t PSR66:1;
682 uint32_t PSR65:1;
683 uint32_t PSR64:1;
684 } B;
685 } PSR2; /* PRESAMPLING REGISTER 2 */
686
687 uint32_t adc_reserved3;
688
689 union {
690 uint32_t R;
691 struct {
692 uint32_t:16;
693 uint32_t INPLATCH:1;
694 uint32_t:1;
695 uint32_t OFFSHIFT:2;
696 uint32_t:1;
697 uint32_t INPCMP:2;
698 uint32_t:1;
699 uint32_t INPSAMP:8;
700 } B;
701 } CTR0; /* CONVERSION TIMING REGISTER 0 */
702
703 union {
704 uint32_t R;
705 struct {
706 uint32_t:16;
707 uint32_t INPLATCH:1;
708 uint32_t:4;
709 uint32_t INPCMP:2;
710 uint32_t:1;
711 uint32_t INPSAMP:8;
712 } B;
713 } CTR1; /* CONVERSION TIMING REGISTER 1 */
714
715 union {
716 uint32_t R;
717 struct {
718 uint32_t:16;
719 uint32_t INPLATCH:1;
720 uint32_t:4;
721 uint32_t INPCMP:2;
722 uint32_t:1;
723 uint32_t INPSAMP:8;
724 } B;
725 } CTR2; /* CONVERSION TIMING REGISTER 2 */
726
727 uint32_t adc_reserved4;
728
729 union {
730 uint32_t R;
731 struct {
732 uint32_t CH31:1;
733 uint32_t CH30:1;
734 uint32_t CH29:1;
735 uint32_t CH28:1;
736 uint32_t CH27:1;
737 uint32_t CH26:1;
738 uint32_t CH25:1;
739 uint32_t CH24:1;
740 uint32_t CH23:1;
741 uint32_t CH22:1;
742 uint32_t CH21:1;
743 uint32_t CH20:1;
744 uint32_t CH19:1;
745 uint32_t CH18:1;
746 uint32_t CH17:1;
747 uint32_t CH16:1;
748 uint32_t CH15:1;
749 uint32_t CH14:1;
750 uint32_t CH13:1;
751 uint32_t CH12:1;
752 uint32_t CH11:1;
753 uint32_t CH10:1;
754 uint32_t CH9:1;
755 uint32_t CH8:1;
756 uint32_t CH7:1;
757 uint32_t CH6:1;
758 uint32_t CH5:1;
759 uint32_t CH4:1;
760 uint32_t CH3:1;
761 uint32_t CH2:1;
762 uint32_t CH1:1;
763 uint32_t CH0:1;
764 } B;
765 } NCMR0; /* NORMAL CONVERSION MASK REGISTER 0 */
766
767 union {
768 uint32_t R;
769 struct {
770 uint32_t CH63:1;
771 uint32_t CH62:1;
772 uint32_t CH61:1;
773 uint32_t CH60:1;
774 uint32_t CH59:1;
775 uint32_t CH58:1;
776 uint32_t CH57:1;
777 uint32_t CH56:1;
778 uint32_t CH55:1;
779 uint32_t CH54:1;
780 uint32_t CH53:1;
781 uint32_t CH52:1;
782 uint32_t CH51:1;
783 uint32_t CH50:1;
784 uint32_t CH49:1;
785 uint32_t CH48:1;
786 uint32_t CH47:1;
787 uint32_t CH46:1;
788 uint32_t CH45:1;
789 uint32_t CH44:1;
790 uint32_t CH43:1;
791 uint32_t CH42:1;
792 uint32_t CH41:1;
793 uint32_t CH40:1;
794 uint32_t CH39:1;
795 uint32_t CH38:1;
796 uint32_t CH37:1;
797 uint32_t CH36:1;
798 uint32_t CH35:1;
799 uint32_t CH34:1;
800 uint32_t CH33:1;
801 uint32_t CH32:1;
802 } B;
803 } NCMR1; /* NORMAL CONVERSION MASK REGISTER 1 */
804
805 union {
806 uint32_t R;
807 struct {
808 uint32_t PSR95:1;
809 uint32_t PSR94:1;
810 uint32_t PSR93:1;
811 uint32_t PSR92:1;
812 uint32_t PSR91:1;
813 uint32_t PSR90:1;
814 uint32_t PSR89:1;
815 uint32_t PSR88:1;
816 uint32_t PSR87:1;
817 uint32_t PSR86:1;
818 uint32_t PSR85:1;
819 uint32_t PSR84:1;
820 uint32_t PSR83:1;
821 uint32_t PSR82:1;
822 uint32_t PSR81:1;
823 uint32_t PSR80:1;
824 uint32_t PSR79:1;
825 uint32_t PSR78:1;
826 uint32_t PSR77:1;
827 uint32_t PSR76:1;
828 uint32_t PSR75:1;
829 uint32_t PSR74:1;
830 uint32_t PSR73:1;
831 uint32_t PSR72:1;
832 uint32_t PSR71:1;
833 uint32_t PSR70:1;
834 uint32_t PSR69:1;
835 uint32_t PSR68:1;
836 uint32_t PSR67:1;
837 uint32_t PSR66:1;
838 uint32_t PSR65:1;
839 uint32_t PSR64:1;
840 } B;
841 } NCMR2; /* NORMAL CONVERSION MASK REGISTER 2 */
842
843 uint32_t adc_reserved5;
844
845 union {
846 uint32_t R;
847 struct {
848 uint32_t CH31:1;
849 uint32_t CH30:1;
850 uint32_t CH29:1;
851 uint32_t CH28:1;
852 uint32_t CH27:1;
853 uint32_t CH26:1;
854 uint32_t CH25:1;
855 uint32_t CH24:1;
856 uint32_t CH23:1;
857 uint32_t CH22:1;
858 uint32_t CH21:1;
859 uint32_t CH20:1;
860 uint32_t CH19:1;
861 uint32_t CH18:1;
862 uint32_t CH17:1;
863 uint32_t CH16:1;
864 uint32_t CH15:1;
865 uint32_t CH14:1;
866 uint32_t CH13:1;
867 uint32_t CH12:1;
868 uint32_t CH11:1;
869 uint32_t CH10:1;
870 uint32_t CH9:1;
871 uint32_t CH8:1;
872 uint32_t CH7:1;
873 uint32_t CH6:1;
874 uint32_t CH5:1;
875 uint32_t CH4:1;
876 uint32_t CH3:1;
877 uint32_t CH2:1;
878 uint32_t CH1:1;
879 uint32_t CH0:1;
880 } B;
881 } JCMR0; /* INJECTED CONVERSION MASK REGISTER 0 */
882
883 union {
884 uint32_t R;
885 struct {
886 uint32_t CH63:1;
887 uint32_t CH62:1;
888 uint32_t CH61:1;
889 uint32_t CH60:1;
890 uint32_t CH59:1;
891 uint32_t CH58:1;
892 uint32_t CH57:1;
893 uint32_t CH56:1;
894 uint32_t CH55:1;
895 uint32_t CH54:1;
896 uint32_t CH53:1;
897 uint32_t CH52:1;
898 uint32_t CH51:1;
899 uint32_t CH50:1;
900 uint32_t CH49:1;
901 uint32_t CH48:1;
902 uint32_t CH47:1;
903 uint32_t CH46:1;
904 uint32_t CH45:1;
905 uint32_t CH44:1;
906 uint32_t CH43:1;
907 uint32_t CH42:1;
908 uint32_t CH41:1;
909 uint32_t CH40:1;
910 uint32_t CH39:1;
911 uint32_t CH38:1;
912 uint32_t CH37:1;
913 uint32_t CH36:1;
914 uint32_t CH35:1;
915 uint32_t CH34:1;
916 uint32_t CH33:1;
917 uint32_t CH32:1;
918 } B;
919 } JCMR1; /* INJECTED CONVERSION MASK REGISTER 1 */
920
921 union {
922 uint32_t R;
923 struct {
924 uint32_t PSR95:1;
925 uint32_t PSR94:1;
926 uint32_t PSR93:1;
927 uint32_t PSR92:1;
928 uint32_t PSR91:1;
929 uint32_t PSR90:1;
930 uint32_t PSR89:1;
931 uint32_t PSR88:1;
932 uint32_t PSR87:1;
933 uint32_t PSR86:1;
934 uint32_t PSR85:1;
935 uint32_t PSR84:1;
936 uint32_t PSR83:1;
937 uint32_t PSR82:1;
938 uint32_t PSR81:1;
939 uint32_t PSR80:1;
940 uint32_t PSR79:1;
941 uint32_t PSR78:1;
942 uint32_t PSR77:1;
943 uint32_t PSR76:1;
944 uint32_t PSR75:1;
945 uint32_t PSR74:1;
946 uint32_t PSR73:1;
947 uint32_t PSR72:1;
948 uint32_t PSR71:1;
949 uint32_t PSR70:1;
950 uint32_t PSR69:1;
951 uint32_t PSR68:1;
952 uint32_t PSR67:1;
953 uint32_t PSR66:1;
954 uint32_t PSR65:1;
955 uint32_t PSR64:1;
956 } B;
957 } JCMR2; /* INJECTED CONVERSION MASK REGISTER 2 */
958
959 union {
960 uint32_t R;
961 struct {
962 uint32_t:15;
963 uint32_t OFFSETLOAD:1;
964 uint32_t:8;
965 uint32_t OFFSET_WORD:8;
966 } B;
967 } OFFWR; /* OFFSET WORD REGISTER */
968
969 union {
970 uint32_t R;
971 struct {
972 uint32_t:24;
973 uint32_t DSD:8;
974 } B;
975 } DSDR; /* DECODE SIGNALS DELAY REGISTER */
976
977 union {
978 uint32_t R;
979 struct {
980 uint32_t:24;
981 uint32_t PDED:8;
982 } B;
983 } PDEDR; /* DECODE SIGNALS DELAY REGISTER */
984
985 uint32_t adc_reserved6[9];
986
987 union {
988 uint32_t R;
989 struct {
990 uint32_t:16;
991 uint32_t TEST_CTL:16;
992 } B;
993 } TCTLR; /* TEST CONTROL REGISTER */
994
995 uint32_t adc_reserved7[3];
996
997 union {
998 uint32_t R;
999 struct {
1000 uint32_t:12;
1001 uint32_t VALID:1;
1002 uint32_t OVERW:1;
1003 uint32_t RESULT:2;
1004 uint32_t:6;
1005 uint32_t CDATA:10;
1006 } B;
1007 } PRECDATAREG[32]; /* PRESISION DATA REGISTER */
1008
1009 union {
1010 uint32_t R;
1011 struct {
1012 uint32_t:12;
1013 uint32_t VALID:1;
1014 uint32_t OVERW:1;
1015 uint32_t RESULT:2;
1016 uint32_t:6;
1017 uint32_t CDATA:10;
1018 } B;
1019 } INTDATAREG[32]; /* PRESISION DATA REGISTER */
1020
1021 union {
1022 uint32_t R;
1023 struct {
1024 uint32_t:12;
1025 uint32_t VALID:1;
1026 uint32_t OVERW:1;
1027 uint32_t RESULT:2;
1028 uint32_t:6;
1029 uint32_t CDATA:10;
1030 } B;
1031 } EXTDATAREG[32]; /* PRESISION DATA REGISTER */
1032
1033 }; /* end of ADC_tag */
1034/**************************************************************************/
1035/* MODULE : AXBS Crossbar Switch (XBAR) */
1036/**************************************************************************/
1037 struct XBAR_tag {
1038
1039 union {
1040 uint32_t R;
1041 struct {
1042 uint32_t:1;
1043 uint32_t MSTR7:3;
1044 uint32_t:1;
1045 uint32_t MSTR6:3;
1046 uint32_t:9;
1047 uint32_t MSTR5:3;
1048 uint32_t:1;
1049 uint32_t MSTR3:3;
1050 uint32_t:1;
1051 uint32_t MSTR2:3;
1052 uint32_t:1;
1053 uint32_t MSTR1:3;
1054 uint32_t:1;
1055 uint32_t MSTR0:1;
1056 } B;
1057 } MPR0; /* Master Priority Register 0 */
1058
1059 uint32_t xbar_reserved1[3];
1060
1061 union {
1062 uint32_t R;
1063 struct {
1064 uint32_t R0:1;
1065 uint32_t:21;
1066 uint32_t ARB:2;
1067 uint32_t:2;
1068 uint32_t PCTL:2;
1069 uint32_t:1;
1070 uint32_t PARK:3;
1071 } B;
1072 } SGPCR0; /* Master Priority Register 0 */
1073
1074 uint32_t xbar_reserved2[58];
1075
1076 union {
1077 uint32_t R;
1078 struct {
1079 uint32_t:1;
1080 uint32_t MSTR7:3;
1081 uint32_t:1;
1082 uint32_t MSTR6:3;
1083 uint32_t:9;
1084 uint32_t MSTR5:3;
1085 uint32_t:1;
1086 uint32_t MSTR3:3;
1087 uint32_t:1;
1088 uint32_t MSTR2:3;
1089 uint32_t:1;
1090 uint32_t MSTR1:3;
1091 uint32_t:1;
1092 uint32_t MSTR0:1;
1093 } B;
1094 } MPR1; /* Master Priority Register 1 */
1095
1096 uint32_t xbar_reserved3[3];
1097
1098 union {
1099 uint32_t R;
1100 struct {
1101 uint32_t R0:1;
1102 uint32_t:21;
1103 uint32_t ARB:2;
1104 uint32_t:2;
1105 uint32_t PCTL:2;
1106 uint32_t:1;
1107 uint32_t PARK:3;
1108 } B;
1109 } SGPCR1; /* Master Priority Register 1 */
1110
1111 uint32_t xbar_reserved4[58];
1112
1113 union {
1114 uint32_t R;
1115 struct {
1116 uint32_t:1;
1117 uint32_t MSTR7:3;
1118 uint32_t:1;
1119 uint32_t MSTR6:3;
1120 uint32_t:9;
1121 uint32_t MSTR5:3;
1122 uint32_t:1;
1123 uint32_t MSTR3:3;
1124 uint32_t:1;
1125 uint32_t MSTR2:3;
1126 uint32_t:1;
1127 uint32_t MSTR1:3;
1128 uint32_t:1;
1129 uint32_t MSTR0:1;
1130 } B;
1131 } MPR2; /* Master Priority Register 2 */
1132
1133 uint32_t xbar_reserved5[3];
1134
1135 union {
1136 uint32_t R;
1137 struct {
1138 uint32_t R0:1;
1139 uint32_t:21;
1140 uint32_t ARB:2;
1141 uint32_t:2;
1142 uint32_t PCTL:2;
1143 uint32_t:1;
1144 uint32_t PARK:3;
1145 } B;
1146 } SGPCR2; /* Master Priority Register 2 */
1147
1148 uint32_t xbar_reserved6[58];
1149
1150 union {
1151 uint32_t R;
1152 struct {
1153 uint32_t:1;
1154 uint32_t MSTR7:3;
1155 uint32_t:1;
1156 uint32_t MSTR6:3;
1157 uint32_t:9;
1158 uint32_t MSTR5:3;
1159 uint32_t:1;
1160 uint32_t MSTR3:3;
1161 uint32_t:1;
1162 uint32_t MSTR2:3;
1163 uint32_t:1;
1164 uint32_t MSTR1:3;
1165 uint32_t:1;
1166 uint32_t MSTR0:1;
1167 } B;
1168 } MPR3; /* Master Priority Register 3 */
1169
1170 uint32_t xbar_reserved7[3];
1171
1172 union {
1173 uint32_t R;
1174 struct {
1175 uint32_t R0:1;
1176 uint32_t:21;
1177 uint32_t ARB:2;
1178 uint32_t:2;
1179 uint32_t PCTL:2;
1180 uint32_t:1;
1181 uint32_t PARK:3;
1182 } B;
1183 } SGPCR3; /* Master Priority Register 3 */
1184
1185 uint32_t xbar_reserved8[186];
1186
1187 union {
1188 uint32_t R;
1189 struct {
1190 uint32_t:1;
1191 uint32_t MSTR7:3;
1192 uint32_t:1;
1193 uint32_t MSTR6:3;
1194 uint32_t:9;
1195 uint32_t MSTR5:3;
1196 uint32_t:1;
1197 uint32_t MSTR3:3;
1198 uint32_t:1;
1199 uint32_t MSTR2:3;
1200 uint32_t:1;
1201 uint32_t MSTR1:3;
1202 uint32_t:1;
1203 uint32_t MSTR0:1;
1204 } B;
1205 } MPR6; /* Master Priority Register 6 */
1206
1207 uint32_t xbar_reserved9[3];
1208
1209 union {
1210 uint32_t R;
1211 struct {
1212 uint32_t R0:1;
1213 uint32_t:21;
1214 uint32_t ARB:2;
1215 uint32_t:2;
1216 uint32_t PCTL:2;
1217 uint32_t:1;
1218 uint32_t PARK:3;
1219 } B;
1220 } SGPCR6; /* Master Priority Register 6 */
1221
1222 uint32_t xbar_reserved10[58];
1223
1224 union {
1225 uint32_t R;
1226 struct {
1227 uint32_t:1;
1228 uint32_t MSTR7:3;
1229 uint32_t:1;
1230 uint32_t MSTR6:3;
1231 uint32_t:9;
1232 uint32_t MSTR5:3;
1233 uint32_t:1;
1234 uint32_t MSTR3:3;
1235 uint32_t:1;
1236 uint32_t MSTR2:3;
1237 uint32_t:1;
1238 uint32_t MSTR1:3;
1239 uint32_t:1;
1240 uint32_t MSTR0:1;
1241 } B;
1242 } MPR7; /* Master Priority Register 7 */
1243
1244 uint32_t xbar_reserved11[3];
1245
1246 union {
1247 uint32_t R;
1248 struct {
1249 uint32_t R0:1;
1250 uint32_t:21;
1251 uint32_t ARB:2;
1252 uint32_t:2;
1253 uint32_t PCTL:2;
1254 uint32_t:1;
1255 uint32_t PARK:3;
1256 } B;
1257 } SGPCR7; /* Master Priority Register 7 */
1258
1259 uint32_t xbar_reserved12[506];
1260
1261 union {
1262 uint32_t R;
1263 struct {
1264 uint32_t R0:1;
1265 uint32_t:21;
1266 uint32_t ARB:2;
1267 uint32_t:2;
1268 uint32_t PCTL:2;
1269 uint32_t:1;
1270 uint32_t PARK:3;
1271 } B;
1272 } MGPCR7; /* Master General Purpose Register 7 */
1273
1274 };
1275/*************************************************************************/
1276/* MODULE : CRP */
1277/*************************************************************************/
1278 struct CRP_tag {
1279
1280 union {
1281 uint32_t R;
1282 struct {
1283 uint32_t IRCTRIMEN:1;
1284 uint32_t:4;
1285 uint32_t PREDIV:3;
1286 uint32_t:4;
1287 uint32_t EN128KIRC:1;
1288 uint32_t EN32KOSC:1;
1289 uint32_t ENLPOSC:1;
1290 uint32_t EN40MOSC:1;
1291 uint32_t:3;
1292 uint32_t TRIM128IRC:5;
1293 uint32_t:2;
1294 uint32_t TRIM16IRC:6;
1295 } B;
1296 } CLKSRC; /* CLOCK SOURCE REGISTER */
1297
1298 uint32_t crp_reserved1[3];
1299
1300 union {
1301 uint32_t R;
1302 struct {
1303 uint32_t CNTEN:1;
1304 uint32_t RTCIE:1;
1305 uint32_t FRZEN:1;
1306 uint32_t ROVREN:1;
1307 uint32_t RTCVAL:12;
1308 uint32_t APIEN:1;
1309 uint32_t APIIE:1;
1310 uint32_t CLKSEL:2;
1311 uint32_t DIV512EN:1;
1312 uint32_t DIV32EN:1;
1313 uint32_t APIVAL:10;
1314 } B;
1315 } RTCC; /* RTC CONTROL REGISTER */
1316
1317 union {
1318 uint32_t R;
1319 struct {
1320 uint32_t:2;
1321 uint32_t RTCF:1;
1322 uint32_t:15;
1323 uint32_t APIF:1;
1324 uint32_t:2;
1325 uint32_t ROVRF:1;
1326 uint32_t:10;
1327 } B;
1328 } RTSC; /* RTC STATUS REGISTER */
1329
1330 union {
1331 uint32_t R;
1332 struct {
1333 uint32_t RTCCNT:32;
1334 } B;
1335 } RTCCNT; /* RTC Counter Register */
1336
1337 uint32_t crp_reserved2[9];
1338
1339 union {
1340 uint32_t R;
1341 struct {
1342 uint32_t PWK31:2;
1343 uint32_t PWK30:2;
1344 uint32_t PWK29:2;
1345 uint32_t PWK28:2;
1346 uint32_t PWK27:2;
1347 uint32_t PWK26:2;
1348 uint32_t PWK25:2;
1349 uint32_t PWK24:2;
1350 uint32_t PWK23:2;
1351 uint32_t PWK22:2;
1352 uint32_t PWK21:2;
1353 uint32_t PWK20:2;
1354 uint32_t PWK19:2;
1355 uint32_t PWK18:2;
1356 uint32_t PWK17:2;
1357 uint32_t PWK16:2;
1358 } B;
1359 } PWKENH; /* PIN WAKEUP ENABLE HIGH REGISTER */
1360
1361 union {
1362 uint32_t R;
1363 struct {
1364 uint32_t PWK15:2;
1365 uint32_t PWK14:2;
1366 uint32_t PWK13:2;
1367 uint32_t PWK12:2;
1368 uint32_t PWK11:2;
1369 uint32_t PWK10:2;
1370 uint32_t PWK9:2;
1371 uint32_t PWK8:2;
1372 uint32_t PWK7:2;
1373 uint32_t PWK6:2;
1374 uint32_t PWK5:2;
1375 uint32_t PWK4:2;
1376 uint32_t PWK3:2;
1377 uint32_t PWK2:2;
1378 uint32_t PWK1:2;
1379 uint32_t PWK0:2;
1380 } B;
1381 } PWKENL; /* PIN WAKEUP ENABLE LOW REGISTER */
1382
1383 union {
1384 uint32_t R;
1385 struct {
1386 uint32_t PWKSRCIE31:1;
1387 uint32_t PWKSRCIE30:1;
1388 uint32_t PWKSRCIE29:1;
1389 uint32_t PWKSRCIE28:1;
1390 uint32_t PWKSRCIE27:1;
1391 uint32_t PWKSRCIE26:1;
1392 uint32_t PWKSRCIE25:1;
1393 uint32_t PWKSRCIE24:1;
1394 uint32_t PWKSRCIE23:1;
1395 uint32_t PWKSRCIE22:1;
1396 uint32_t PWKSRCIE21:1;
1397 uint32_t PWKSRCIE20:1;
1398 uint32_t PWKSRCIE19:1;
1399 uint32_t PWKSRCIE18:1;
1400 uint32_t PWKSRCIE17:1;
1401 uint32_t PWKSRCIE16:1;
1402 uint32_t PWKSRCIE15:1;
1403 uint32_t PWKSRCIE14:1;
1404 uint32_t PWKSRCIE13:1;
1405 uint32_t PWKSRCIE12:1;
1406 uint32_t PWKSRCIE11:1;
1407 uint32_t PWKSRCIE10:1;
1408 uint32_t PWKSRCIE9:1;
1409 uint32_t PWKSRCIE8:1;
1410 uint32_t PWKSRCIE7:1;
1411 uint32_t PWKSRCIE6:1;
1412 uint32_t PWKSRCIE5:1;
1413 uint32_t PWKSRCIE4:1;
1414 uint32_t PWKSRCIE3:1;
1415 uint32_t PWKSRCIE2:1;
1416 uint32_t PWKSRCIE1:1;
1417 uint32_t PWKSRCIE0:1;
1418 } B;
1419 } PWKSRCIE; /* PIN WAKEUP SOURCE INTERRUPT ENABLE REGISTER */
1420
1421 union {
1422 uint32_t R;
1423 struct {
1424 uint32_t PWKSRCIE31:1;
1425 uint32_t PWKSRCIE30:1;
1426 uint32_t PWKSRCIE29:1;
1427 uint32_t PWKSRCIE28:1;
1428 uint32_t PWKSRCIE27:1;
1429 uint32_t PWKSRCIE26:1;
1430 uint32_t PWKSRCIE25:1;
1431 uint32_t PWKSRCIE24:1;
1432 uint32_t PWKSRCIE23:1;
1433 uint32_t PWKSRCIE22:1;
1434 uint32_t PWKSRCIE21:1;
1435 uint32_t PWKSRCIE20:1;
1436 uint32_t PWKSRCIE19:1;
1437 uint32_t PWKSRCIE18:1;
1438 uint32_t PWKSRCIE17:1;
1439 uint32_t PWKSRCIE16:1;
1440 uint32_t PWKSRCIE15:1;
1441 uint32_t PWKSRCIE14:1;
1442 uint32_t PWKSRCIE13:1;
1443 uint32_t PWKSRCIE12:1;
1444 uint32_t PWKSRCIE11:1;
1445 uint32_t PWKSRCIE10:1;
1446 uint32_t PWKSRCIE9:1;
1447 uint32_t PWKSRCIE8:1;
1448 uint32_t PWKSRCIE7:1;
1449 uint32_t PWKSRCIE6:1;
1450 uint32_t PWKSRCIE5:1;
1451 uint32_t PWKSRCIE4:1;
1452 uint32_t PWKSRCIE3:1;
1453 uint32_t PWKSRCIE2:1;
1454 uint32_t PWKSRCIE1:1;
1455 uint32_t PWKSRCIE0:1;
1456 } B;
1457 } PWKSRCF; /* PIN WAKEUP SOURCE FLAG REGISTER */
1458
1459 union {
1460 uint32_t R;
1461 struct {
1462 uint32_t Z6VECB:20;
1463 uint32_t:10;
1464 uint32_t Z6RST:1;
1465 uint32_t VLE:1;
1466 } B;
1467 } Z6VEC; /* Z6 RESET VECTOR REGISTER */
1468
1469 union {
1470 uint32_t R;
1471 struct {
1472 uint32_t Z0VECB:30;
1473 uint32_t Z0RST:1;
1474 uint32_t:1;
1475 } B;
1476 } Z0VEC; /* Z0 RESET VECTOR REGISTER */
1477
1478 union {
1479 uint32_t R;
1480 struct {
1481 uint32_t RECPTR:30;
1482 uint32_t FASTREC:1;
1483 uint32_t:1;
1484 } B;
1485 } RECPTR; /* RESET RECOVERY POINTER REGISTER */
1486
1487 uint32_t crp_reserved3;
1488
1489 union {
1490 uint32_t R;
1491 struct {
1492 uint32_t SLEEPF:1;
1493 uint32_t:12;
1494 uint32_t RTCOVRWKF:1;
1495 uint32_t RTCWKF:1;
1496 uint32_t APIWKF:1;
1497 uint32_t SLEEP:1;
1498 uint32_t:4;
1499 uint32_t RAMSEL:3;
1500 uint32_t:4;
1501 uint32_t WKCLKSEL:1;
1502 uint32_t RTCOVRWKEN:1;
1503 uint32_t RTCWKEN:1;
1504 uint32_t APIWKEN:1;
1505 } B;
1506 } PSCR; /* POWER STATUS AND CONTROL REGISTER */
1507
1508 uint32_t crp_reserved4[3];
1509
1510 union {
1511 uint32_t R;
1512 struct {
1513 uint32_t LVI5LOCK:1;
1514 uint32_t LVI5RE:1;
1515 uint32_t:7;
1516 uint32_t LVI5HIE:1;
1517 uint32_t LVI5NIE:1;
1518 uint32_t LVI5IE:1;
1519 uint32_t:2;
1520 uint32_t FRIE:1;
1521 uint32_t FDIS:1;
1522 uint32_t:9;
1523 uint32_t LVI5HIF:1;
1524 uint32_t LVI5NF:1;
1525 uint32_t LVI5F:1;
1526 uint32_t:2;
1527 uint32_t FRF:1;
1528 uint32_t FRDY:1;
1529 } B;
1530 } SOCSC; /* LVI Status and Control Register */
1531
1532 }; /* end of CRP_tag */
1533/*************************************************************************/
1534/* MODULE : CTU */
1535/*************************************************************************/
1536 struct CTU_tag {
1537
1538 union {
1539 uint32_t R;
1540 struct {
1541 uint32_t:24;
1542 uint32_t TRGIEN:1;
1543 uint32_t TRGI:1;
1544 uint32_t:2;
1545 uint32_t PRESC_CONF:4;
1546 } B;
1547 } CSR; /* Control Status Register */
1548
1549 union {
1550 uint32_t R;
1551 struct {
1552 uint32_t:23;
1553 uint32_t SV:9;
1554 } B;
1555 } SVR[7]; /* Start Value Register */
1556
1557 union {
1558 uint32_t R;
1559 struct {
1560 uint32_t:23;
1561 uint32_t CV:9;
1562 } B;
1563 } CVR[4]; /* Current Value Register */
1564
1565 union {
1566 uint32_t R;
1567 struct {
1568 uint32_t:16;
1569 uint32_t TM:1;
1570 uint32_t:1;
1571 uint32_t COUNT_GROUP:2;
1572 uint32_t:1;
1573 uint32_t DELAY_INDEX:3;
1574 uint32_t CLR_FG:1;
1575 uint32_t:1;
1576 uint32_t CHANNEL_VALUE:6;
1577 } B;
1578 } EVTCFGR[33]; /* Event Configuration Register */
1579
1580 }; /* end of CTU_tag */
1581/*************************************************************************/
1582/* MODULE : DMAMUX */
1583/*************************************************************************/
1584 struct DMAMUX_tag {
1585 union {
1586 uint8_t R;
1587 struct {
1588 uint8_t ENBL:1;
1589 uint8_t TRIG:1;
1590 uint8_t SOURCE:6;
1591 } B;
1592 } CHCONFIG[32]; /* DMA Channel Configuration Register */
1593
1594 }; /* end of DMAMUX_tag */
1595/*************************************************************************/
1596/* MODULE : DSPI */
1597/*************************************************************************/
1598 struct DSPI_tag {
1599 union DSPI_MCR_tag {
1600 uint32_t R;
1601 struct {
1602 uint32_t MSTR:1;
1603 uint32_t CONT_SCKE:1;
1604 uint32_t DCONF:2;
1605 uint32_t FRZ:1;
1606 uint32_t MTFE:1;
1607 uint32_t PCSSE:1;
1608 uint32_t ROOE:1;
1609 uint32_t:2;
1610 uint32_t PCSIS5:1;
1611 uint32_t PCSIS4:1;
1612 uint32_t PCSIS3:1;
1613 uint32_t PCSIS2:1;
1614 uint32_t PCSIS1:1;
1615 uint32_t PCSIS0:1;
1616 uint32_t:1;
1617 uint32_t MDIS:1;
1618 uint32_t DIS_TXF:1;
1619 uint32_t DIS_RXF:1;
1620 uint32_t CLR_TXF:1;
1621 uint32_t CLR_RXF:1;
1622 uint32_t SMPL_PT:2;
1623 uint32_t:7;
1624 uint32_t HALT:1;
1625 } B;
1626 } MCR; /* Module Configuration Register */
1627
1628 uint32_t dspi_reserved1;
1629
1630 union {
1631 uint32_t R;
1632 struct {
1633 uint32_t SPI_TCNT:16;
1634 uint32_t:16;
1635 } B;
1636 } TCR;
1637
1638 union DSPI_CTAR_tag {
1639 uint32_t R;
1640 struct {
1641 uint32_t DBR:1;
1642 uint32_t FMSZ:4;
1643 uint32_t CPOL:1;
1644 uint32_t CPHA:1;
1645 uint32_t LSBFE:1;
1646 uint32_t PCSSCK:2;
1647 uint32_t PASC:2;
1648 uint32_t PDT:2;
1649 uint32_t PBR:2;
1650 uint32_t CSSCK:4;
1651 uint32_t ASC:4;
1652 uint32_t DT:4;
1653 uint32_t BR:4;
1654 } B;
1655 } CTAR[8]; /* Clock and Transfer Attributes Registers */
1656
1657 union DSPI_SR_tag {
1658 uint32_t R;
1659 struct {
1660 uint32_t TCF:1;
1661 uint32_t TXRXS:1;
1662 uint32_t:1;
1663 uint32_t EOQF:1;
1664 uint32_t TFUF:1;
1665 uint32_t:1;
1666 uint32_t TFFF:1;
1667 uint32_t:5;
1668 uint32_t RFOF:1;
1669 uint32_t:1;
1670 uint32_t RFDF:1;
1671 uint32_t:1;
1672 uint32_t TXCTR:4;
1673 uint32_t TXNXTPTR:4;
1674 uint32_t RXCTR:4;
1675 uint32_t POPNXTPTR:4;
1676 } B;
1677 } SR; /* Status Register */
1678
1679 union DSPI_RSER_tag {
1680 uint32_t R;
1681 struct {
1682 uint32_t TCFRE:1;
1683 uint32_t:2;
1684 uint32_t EOQFRE:1;
1685 uint32_t TFUFRE:1;
1686 uint32_t:1;
1687 uint32_t TFFFRE:1;
1688 uint32_t TFFFDIRS:1;
1689 uint32_t:4;
1690 uint32_t RFOFRE:1;
1691 uint32_t:1;
1692 uint32_t RFDFRE:1;
1693 uint32_t RFDFDIRS:1;
1694 uint32_t:16;
1695 } B;
1696 } RSER; /* DMA/Interrupt Request Select and Enable Register */
1697
1698 union DSPI_PUSHR_tag {
1699 uint32_t R;
1700 struct {
1701 uint32_t CONT:1;
1702 uint32_t CTAS:3;
1703 uint32_t EOQ:1;
1704 uint32_t CTCNT:1;
1705 uint32_t:4;
1706 uint32_t PCS5:1;
1707 uint32_t PCS4:1;
1708 uint32_t PCS3:1;
1709 uint32_t PCS2:1;
1710 uint32_t PCS1:1;
1711 uint32_t PCS0:1;
1712 uint32_t TXDATA:16;
1713 } B;
1714 } PUSHR; /* PUSH TX FIFO Register */
1715
1716 union DSPI_POPR_tag {
1717 uint32_t R;
1718 struct {
1719 uint32_t:16;
1720 uint32_t RXDATA:16;
1721 } B;
1722 } POPR; /* POP RX FIFO Register */
1723
1724 union {
1725 uint32_t R;
1726 struct {
1727 uint32_t TXCMD:16;
1728 uint32_t TXDATA:16;
1729 } B;
1730 } TXFR[4]; /* Transmit FIFO Registers */
1731
1732 uint32_t DSPI_reserved_txf[12];
1733
1734 union {
1735 uint32_t R;
1736 struct {
1737 uint32_t:16;
1738 uint32_t RXDATA:16;
1739 } B;
1740 } RXFR[4]; /* Transmit FIFO Registers */
1741
1742 uint32_t DSPI_reserved_rxf[12];
1743
1744 union {
1745 uint32_t R;
1746 struct {
1747 uint32_t:11;
1748 uint32_t TSBC:1;
1749 uint32_t TXSS:1;
1750 uint32_t:2;
1751 uint32_t CID:1;
1752 uint32_t DCONT:1;
1753 uint32_t DSICTAS:3;
1754 uint32_t:6;
1755 uint32_t DPCS5:1;
1756 uint32_t DPCS4:1;
1757 uint32_t DPCS3:1;
1758 uint32_t DPCS2:1;
1759 uint32_t DPCS1:1;
1760 uint32_t DPCS0:1;
1761 } B;
1762 } DSICR; /* DSI Configuration Register */
1763
1764 union {
1765 uint32_t R;
1766 struct {
1767 uint32_t SER_DATA:32;
1768 } B;
1769 } SDR; /* DSI Serialization Data Register */
1770
1771 union {
1772 uint32_t R;
1773 struct {
1774 uint32_t ASER_DATA:32;
1775 } B;
1776 } ASDR; /* DSI Alternate Serialization Data Register */
1777
1778 union {
1779 uint32_t R;
1780 struct {
1781 uint32_t COMP_DATA:32;
1782 } B;
1783 } COMPR; /* DSI Transmit Comparison Register */
1784
1785 union {
1786 uint32_t R;
1787 struct {
1788 uint32_t DESER_DATA:32;
1789 } B;
1790 } DDR; /* DSI deserialization Data Register */
1791
1792 union {
1793 uint32_t R;
1794 struct {
1795 uint32_t:3;
1796 uint32_t TSBCNT:5;
1797 uint32_t:16;
1798 uint32_t DPCS1_7:1;
1799 uint32_t DPCS1_6:1;
1800 uint32_t DPCS1_5:1;
1801 uint32_t DPCS1_4:1;
1802 uint32_t DPCS1_3:1;
1803 uint32_t DPCS1_2:1;
1804 uint32_t DPCS1_1:1;
1805 uint32_t DPCS1_0:1;
1806 } B;
1807 } DSICR1; /* DSI Configuration Register 1 */
1808
1809 }; /* end of DSPI_tag */
1810/*************************************************************************/
1811/* MODULE : ECSM */
1812/*************************************************************************/
1813 struct ECSM_tag {
1814
1815 uint32_t ecsm_reserved1[9];
1816
1817 union {
1818 uint32_t R;
1819 struct {
1820 uint32_t FXSBE0:1;
1821 uint32_t FXSBE1:1;
1822 uint32_t FXSBE2:1;
1823 uint32_t FXSBE3:1;
1824 uint32_t:2;
1825 uint32_t FXSBE6:1;
1826 uint32_t FXSBE7:1;
1827 uint32_t RBEN:1;
1828 uint32_t WBEN:1;
1829 uint32_t ACCERR:1;
1830 uint32_t:21;
1831 } B;
1832 } FBOMCR; /* FEC Burst Optimisation Master Control Register */
1833
1834 uint8_t ecsm_reserved2[27];
1835
1836 union {
1837 uint8_t R;
1838 struct {
1839 uint8_t:2;
1840 uint8_t EPR1BR:1;
1841 uint8_t EPF1BR:1;
1842 uint8_t:2;
1843 uint8_t EPRNCR:1;
1844 uint8_t EPFNCR:1;
1845 } B;
1846 } ECR; /* ECC Configuration Register */
1847
1848 uint8_t ecsm_reserved3[3];
1849
1850 union {
1851 uint8_t R;
1852 struct {
1853 uint8_t:2;
1854 uint8_t PR1BC:1;
1855 uint8_t PF1BC:1;
1856 uint8_t:2;
1857 uint8_t PRNCE:1;
1858 uint8_t PFNCE:1;
1859 } B;
1860 } ESR; /* ECC Status Register */
1861
1862 uint16_t ecsm_reserved4;
1863
1864 union {
1865 uint16_t R;
1866 struct {
1867 uint16_t:2;
1868 uint16_t FRC1BI:1;
1869 uint16_t FR11BI:1;
1870 uint16_t:2;
1871 uint16_t FRCNCI:1;
1872 uint16_t FR1NCI:1;
1873 uint16_t PREI_SEL:1;
1874 uint16_t ERRBIT:7;
1875 } B;
1876 } EEGR; /* ECC Error Generation Register */
1877
1878 uint32_t ecsm_reserved5;
1879
1880 union {
1881 uint32_t R;
1882 struct {
1883 uint32_t PFEAR:32;
1884 } B;
1885 } PFEAR; /* Platform Flash ECC Address Register */
1886
1887 uint16_t ecsm_reserved6;
1888
1889 union {
1890 uint8_t R;
1891 struct {
1892 uint8_t:4;
1893 uint8_t PFEMR:4;
1894 } B;
1895 } PFEMR; /* Platform Flash ECC Address Register */
1896
1897 union {
1898 uint8_t R;
1899 struct {
1900 uint8_t WRITE:1;
1901 uint8_t SIZE:3;
1902 uint8_t PROTECTION:4;
1903 } B;
1904 } PFEAT; /* Flash ECC Attributes Register */
1905
1906 union {
1907 uint32_t R;
1908 struct {
1909 uint32_t PFEDRH:32;
1910 } B;
1911 } PFEDRH; /* Flash ECC Data High Register */
1912
1913 union {
1914 uint32_t R;
1915 struct {
1916 uint32_t PFEDRL:32;
1917 } B;
1918 } PFEDRL; /* Flash ECC Data Low Register */
1919
1920 union {
1921 uint32_t R;
1922 struct {
1923 uint32_t PREAR:32;
1924 } B;
1925 } PREAR; /* Platform RAM ECC Address Register */
1926
1927 uint16_t ecsm_reserved8;
1928
1929 union {
1930 uint8_t R;
1931 struct {
1932 uint8_t:4;
1933 uint8_t PREMR:4;
1934 } B;
1935 } PREMR; /* RAM ECC Attributes Register */
1936
1937 union {
1938 uint8_t R;
1939 struct {
1940 uint8_t WRITE:1;
1941 uint8_t SIZE:3;
1942 uint8_t PROTECTION:4;
1943 } B;
1944 } PREAT; /* Platform RAM ECC Attributes Register */
1945
1946 union {
1947 uint32_t R;
1948 struct {
1949 uint32_t PREDR:32;
1950 } B;
1951 } PREDRH; /* Platform RAM ECC Data Low Register High */
1952
1953 union {
1954 uint32_t R;
1955 struct {
1956 uint32_t PREDR:32;
1957 } B;
1958 } PREDRL; /* Platform RAM ECC Data Low Register Low */
1959
1960 }; /* end of ECSM_tag */
1961/*************************************************************************/
1962/* MODULE : EMIOS */
1963/*************************************************************************/
1964 struct EMIOS_tag {
1965 union EMIOS_MCR_tag {
1966 uint32_t R;
1967 struct {
1968 uint32_t:1;
1969 uint32_t MDIS:1;
1970 uint32_t FRZ:1;
1971 uint32_t GTBE:1;
1972 uint32_t:1;
1973 uint32_t GPREN:1;
1974 uint32_t:10;
1975 uint32_t GPRE:8;
1976 uint32_t:8;
1977 } B;
1978 } MCR; /* Module Configuration Register */
1979
1980 union {
1981 uint32_t R;
1982 struct {
1983 uint32_t F31:1;
1984 uint32_t F30:1;
1985 uint32_t F29:1;
1986 uint32_t F28:1;
1987 uint32_t F27:1;
1988 uint32_t F26:1;
1989 uint32_t F25:1;
1990 uint32_t F24:1;
1991 uint32_t F23:1;
1992 uint32_t F22:1;
1993 uint32_t F21:1;
1994 uint32_t F20:1;
1995 uint32_t F19:1;
1996 uint32_t F18:1;
1997 uint32_t F17:1;
1998 uint32_t F16:1;
1999 uint32_t F15:1;
2000 uint32_t F14:1;
2001 uint32_t F13:1;
2002 uint32_t F12:1;
2003 uint32_t F11:1;
2004 uint32_t F10:1;
2005 uint32_t F9:1;
2006 uint32_t F8:1;
2007 uint32_t F7:1;
2008 uint32_t F6:1;
2009 uint32_t F5:1;
2010 uint32_t F4:1;
2011 uint32_t F3:1;
2012 uint32_t F2:1;
2013 uint32_t F1:1;
2014 uint32_t F0:1;
2015 } B;
2016 } GFR; /* Global FLAG Register */
2017
2018 union {
2019 uint32_t R;
2020 struct {
2021 uint32_t OU31:1;
2022 uint32_t OU30:1;
2023 uint32_t OU29:1;
2024 uint32_t OU28:1;
2025 uint32_t OU27:1;
2026 uint32_t OU26:1;
2027 uint32_t OU25:1;
2028 uint32_t OU24:1;
2029 uint32_t OU23:1;
2030 uint32_t OU22:1;
2031 uint32_t OU21:1;
2032 uint32_t OU20:1;
2033 uint32_t OU19:1;
2034 uint32_t OU18:1;
2035 uint32_t OU17:1;
2036 uint32_t OU16:1;
2037 uint32_t OU15:1;
2038 uint32_t OU14:1;
2039 uint32_t OU13:1;
2040 uint32_t OU12:1;
2041 uint32_t OU11:1;
2042 uint32_t OU10:1;
2043 uint32_t OU9:1;
2044 uint32_t OU8:1;
2045 uint32_t OU7:1;
2046 uint32_t OU6:1;
2047 uint32_t OU5:1;
2048 uint32_t OU4:1;
2049 uint32_t OU3:1;
2050 uint32_t OU2:1;
2051 uint32_t OU1:1;
2052 uint32_t OU0:1;
2053 } B;
2054 } OUDR; /* Output Update Disable Register */
2055
2056 union {
2057 uint32_t R;
2058 struct {
2059 uint32_t UC31:1;
2060 uint32_t UC30:1;
2061 uint32_t UC29:1;
2062 uint32_t UC28:1;
2063 uint32_t UC27:1;
2064 uint32_t UC26:1;
2065 uint32_t UC25:1;
2066 uint32_t UC24:1;
2067 uint32_t UC23:1;
2068 uint32_t UC22:1;
2069 uint32_t UC21:1;
2070 uint32_t UC20:1;
2071 uint32_t UC19:1;
2072 uint32_t UC18:1;
2073 uint32_t UC17:1;
2074 uint32_t UC16:1;
2075 uint32_t UC15:1;
2076 uint32_t UC14:1;
2077 uint32_t UC13:1;
2078 uint32_t UC12:1;
2079 uint32_t UC11:1;
2080 uint32_t UC10:1;
2081 uint32_t UC9:1;
2082 uint32_t UC8:1;
2083 uint32_t UC7:1;
2084 uint32_t UC6:1;
2085 uint32_t UC5:1;
2086 uint32_t UC4:1;
2087 uint32_t UC3:1;
2088 uint32_t UC2:1;
2089 uint32_t UC1:1;
2090 uint32_t UC0:1;
2091 } B;
2092 } UCDIS; /* Disable Channel Register */
2093
2094 uint32_t emios_reserved1[4];
2095
2096 struct EMIOS_CH_tag {
2097 union {
2098 uint32_t R;
2099 struct {
2100 uint32_t:16;
2101 uint32_t A:16; /* Channel A Data Register */
2102 } B;
2103 } CADR;
2104
2105 union {
2106 uint32_t R;
2107 struct {
2108 uint32_t:16;
2109 uint32_t B:16; /* Channel B Data Register */
2110 } B;
2111 } CBDR;
2112
2113 union {
2114 uint32_t R; /* Channel Counter Register */
2115 struct {
2116 uint32_t:16;
2117 uint32_t C:16; /* Channel C Data Register */
2118 } B;
2119 } CCNTR;
2120
2121 union EMIOS_CCR_tag {
2122 uint32_t R;
2123 struct {
2124 uint32_t FREN:1;
2125 uint32_t ODIS:1;
2126 uint32_t ODISSL:2;
2127 uint32_t UCPRE:2;
2128 uint32_t UCPREN:1;
2129 uint32_t DMA:1;
2130 uint32_t:1;
2131 uint32_t IF:4;
2132 uint32_t FCK:1;
2133 uint32_t FEN:1;
2134 uint32_t:3;
2135 uint32_t FORCMA:1;
2136 uint32_t FORCMB:1;
2137 uint32_t:1;
2138 uint32_t BSL:2;
2139 uint32_t EDSEL:1;
2140 uint32_t EDPOL:1;
2141 uint32_t MODE:7;
2142 } B;
2143 } CCR; /* Channel Control Register */
2144
2145 union EMIOS_CSR_tag {
2146 uint32_t R;
2147 struct {
2148 uint32_t OVR:1;
2149 uint32_t:15;
2150 uint32_t OVFL:1;
2151 uint32_t:12;
2152 uint32_t UCIN:1;
2153 uint32_t UCOUT:1;
2154 uint32_t FLAG:1;
2155 } B;
2156 } CSR; /* Channel Status Register */
2157
2158 union {
2159 uint32_t R; /* Alternate Channel A Data Register */
2160 } ALTA;
2161
2162 uint32_t emios_channel_reserved[2];
2163
2164 } CH[32];
2165
2166 }; /* end of EMIOS_tag */
2167/*************************************************************************/
2168/* MODULE : eSCI */
2169/*************************************************************************/
2170 struct ESCI_tag {
2171 union ESCI_CR1_tag {
2172 uint32_t R;
2173 struct {
2174 uint32_t:3;
2175 uint32_t SBR:13;
2176 uint32_t LOOPS:1;
2177 uint32_t:1;
2178 uint32_t RSRC:1;
2179 uint32_t M:1;
2180 uint32_t WAKE:1;
2181 uint32_t ILT:1;
2182 uint32_t PE:1;
2183 uint32_t PT:1;
2184 uint32_t TIE:1;
2185 uint32_t TCIE:1;
2186 uint32_t RIE:1;
2187 uint32_t ILIE:1;
2188 uint32_t TE:1;
2189 uint32_t RE:1;
2190 uint32_t RWU:1;
2191 uint32_t SBK:1;
2192 } B;
2193 } CR1; /* Control Register 1 */
2194
2195 union ESCI_CR2_tag {
2196 uint16_t R;
2197 struct {
2198 uint16_t MDIS:1;
2199 uint16_t FBR:1;
2200 uint16_t BSTP:1;
2201 uint16_t IEBERR:1;
2202 uint16_t RXDMA:1;
2203 uint16_t TXDMA:1;
2204 uint16_t BRK13:1;
2205 uint16_t TXDIR:1;
2206 uint16_t BESM13:1;
2207 uint16_t SBSTP:1;
2208 uint16_t RXPOL:1;
2209 uint16_t PMSK:1;
2210 uint16_t ORIE:1;
2211 uint16_t NFIE:1;
2212 uint16_t FEIE:1;
2213 uint16_t PFIE:1;
2214 } B;
2215 } CR2; /* Control Register 2 */
2216
2217 union ESCI_DR_tag {
2218 uint16_t R;
2219 struct {
2220 uint16_t RN:1;
2221 uint16_t TN:1;
2222 uint16_t ERR:1;
2223 uint16_t:1;
2224 uint16_t RD_11:4;
2225 uint16_t D:8;
2226 } B;
2227 } DR; /* Data Register */
2228
2229 union ESCI_SR_tag {
2230 uint32_t R;
2231 struct {
2232 uint32_t TDRE:1;
2233 uint32_t TC:1;
2234 uint32_t RDRF:1;
2235 uint32_t IDLE:1;
2236 uint32_t OR:1;
2237 uint32_t NF:1;
2238 uint32_t FE:1;
2239 uint32_t PF:1;
2240 uint32_t:3;
2241 uint32_t BERR:1;
2242 uint32_t:2;
2243 uint32_t TACT:1;
2244 uint32_t RACT:1;
2245 uint32_t RXRDY:1;
2246 uint32_t TXRDY:1;
2247 uint32_t LWAKE:1;
2248 uint32_t STO:1;
2249 uint32_t PBERR:1;
2250 uint32_t CERR:1;
2251 uint32_t CKERR:1;
2252 uint32_t FRC:1;
2253 uint32_t:6;
2254 uint32_t UREQ:1;
2255 uint32_t OVFL:1;
2256 } B;
2257 } SR; /* Status Register */
2258
2259 union {
2260 uint32_t R;
2261 struct {
2262 uint32_t LRES:1;
2263 uint32_t WU:1;
2264 uint32_t WUD0:1;
2265 uint32_t WUD1:1;
2266 uint32_t:2;
2267 uint32_t PRTY:1;
2268 uint32_t LIN:1;
2269 uint32_t RXIE:1;
2270 uint32_t TXIE:1;
2271 uint32_t WUIE:1;
2272 uint32_t STIE:1;
2273 uint32_t PBIE:1;
2274 uint32_t CIE:1;
2275 uint32_t CKIE:1;
2276 uint32_t FCIE:1;
2277 uint32_t:6;
2278 uint32_t UQIE:1;
2279 uint32_t OFIE:1;
2280 uint32_t:8;
2281 } B;
2282 } LCR; /* LIN Control Register */
2283
2284 union {
2285 uint8_t R;
2286 } LTR; /* LIN Transmit Register */
2287
2288 uint8_t eSCI_reserved1[3];
2289
2290 union {
2291 uint8_t R;
2292 } LRR; /* LIN Recieve Register */
2293
2294 uint8_t eSCI_reserved2[3];
2295
2296 union {
2297 uint16_t R;
2298 } LPR; /* LIN CRC Polynom Register */
2299
2300 union {
2301 uint8_t R;
2302 struct {
2303 uint8_t:3;
2304 uint8_t SYNM:1;
2305 uint8_t EROE:1;
2306 uint8_t ERFE:1;
2307 uint8_t ERPE:1;
2308 uint8_t M2:1;
2309 } B;
2310 } CR3; /* Control Register 3 */
2311
2312 uint8_t eSCI_reserved3[5];
2313 }; /* end of ESCI_tag */
2314/*************************************************************************/
2315/* MODULE : FEC */
2316/*************************************************************************/
2317 struct FEC_tag {
2318
2319 uint32_t fec_reserved_start;
2320
2321 union {
2322 uint32_t R;
2323 struct {
2324 uint32_t HBERR:1;
2325 uint32_t BABR:1;
2326 uint32_t BABT:1;
2327 uint32_t GRA:1;
2328 uint32_t TXF:1;
2329 uint32_t TXB:1;
2330 uint32_t RXF:1;
2331 uint32_t RXB:1;
2332 uint32_t MII:1;
2333 uint32_t EBERR:1;
2334 uint32_t LC:1;
2335 uint32_t RL:1;
2336 uint32_t UN:1;
2337 uint32_t:19;
2338 } B;
2339 } EIR; /* Interrupt Event Register */
2340
2341 union {
2342 uint32_t R;
2343 struct {
2344 uint32_t HBERR:1;
2345 uint32_t BABR:1;
2346 uint32_t BABT:1;
2347 uint32_t GRA:1;
2348 uint32_t TXF:1;
2349 uint32_t TXB:1;
2350 uint32_t RXF:1;
2351 uint32_t RXB:1;
2352 uint32_t MII:1;
2353 uint32_t EBERR:1;
2354 uint32_t LC:1;
2355 uint32_t RL:1;
2356 uint32_t UN:1;
2357 uint32_t:19;
2358 } B;
2359 } EIMR; /* Interrupt Mask Register */
2360
2361 uint32_t fec_reserved_eimr;
2362
2363 union {
2364 uint32_t R;
2365 struct {
2366 uint32_t:7;
2367 uint32_t R_DES_ACTIVE:1;
2368 uint32_t:24;
2369 } B;
2370 } RDAR; /* Receive Descriptor Active Register */
2371
2372 union {
2373 uint32_t R;
2374 struct {
2375 uint32_t:7;
2376 uint32_t X_DES_ACTIVE:1;
2377 uint32_t:24;
2378 } B;
2379 } TDAR; /* Transmit Descriptor Active Register */
2380
2381 uint32_t fec_reserved_tdar[3];
2382
2383 union {
2384 uint32_t R;
2385 struct {
2386 uint32_t:30;
2387 uint32_t ETHER_EN:1;
2388 uint32_t RESET:1;
2389 } B;
2390 } ECR; /* Ethernet Control Register */
2391
2392 uint32_t fec_reserved_ecr[6];
2393
2394 union {
2395 uint32_t R;
2396 struct {
2397 uint32_t ST:2;
2398 uint32_t OP:2;
2399 uint32_t PA:5;
2400 uint32_t RA:5;
2401 uint32_t TA:2;
2402 uint32_t DATA:16;
2403 } B;
2404 } MMFR; /* MII Data Register */
2405
2406 union {
2407 uint32_t R;
2408 struct {
2409 uint32_t:24;
2410 uint32_t DIS_PREAMBLE:1;
2411 uint32_t MII_SPEED:6;
2412 uint32_t:1;
2413 } B;
2414 } MSCR; /* MII Speed Control Register */
2415
2416 uint32_t fec_reserved_mscr[7];
2417
2418 union {
2419 uint32_t R;
2420 struct {
2421 uint32_t MIB_DISABLE:1;
2422 uint32_t MIB_IDLE:1;
2423 uint32_t:30;
2424 } B;
2425 } MIBC; /* MIB Control Register */
2426
2427 uint32_t fec_reserved_mibc[7];
2428
2429 union {
2430 uint32_t R;
2431 struct {
2432 uint32_t:5;
2433 uint32_t MAX_FL:11;
2434 uint32_t:10;
2435 uint32_t FCE:1;
2436 uint32_t BC_REJ:1;
2437 uint32_t PROM:1;
2438 uint32_t MII_MODE:1;
2439 uint32_t DRT:1;
2440 uint32_t LOOP:1;
2441 } B;
2442 } RCR; /* Receive Control Register */
2443
2444 uint32_t fec_reserved_rcr[15];
2445
2446 union {
2447 uint32_t R;
2448 struct {
2449 uint32_t:27;
2450 uint32_t RFC_PAUSE:1;
2451 uint32_t TFC_PAUSE:1;
2452 uint32_t FDEN:1;
2453 uint32_t HBC:1;
2454 uint32_t GTS:1;
2455 } B;
2456 } TCR; /* Transmit Control Register */
2457
2458 uint32_t fec_reserved_tcr[7];
2459
2460 union {
2461 uint32_t R;
2462 struct {
2463 uint32_t PADDR1:32;
2464 } B;
2465 } PALR; /* Physical Address Low Register */
2466
2467 union {
2468 uint32_t R;
2469 struct {
2470 uint32_t PADDR2:16;
2471 uint32_t TYPE:16;
2472 } B;
2473 } PAUR; /* Physical Address High + Type Register */
2474
2475 union {
2476 uint32_t R;
2477 struct {
2478 uint32_t OPCODE:16;
2479 uint32_t PAUSE_DUR:16;
2480 } B;
2481 } OPD; /* Opcode/Pause Duration Register */
2482
2483 uint32_t fec_reserved_opd[10];
2484
2485 union {
2486 uint32_t R;
2487 struct {
2488 uint32_t IADDR1:32;
2489 } B;
2490 } IAUR; /* Descriptor Individual Upper Address Register */
2491
2492 union {
2493 uint32_t R;
2494 struct {
2495 uint32_t IADDR2:32;
2496 } B;
2497 } IALR; /* Descriptor Individual Lower Address Register */
2498
2499 union {
2500 uint32_t R;
2501 struct {
2502 uint32_t GADDR1:32;
2503 } B;
2504 } GAUR; /* Descriptor Group Upper Address Register */
2505
2506 union {
2507 uint32_t R;
2508 struct {
2509 uint32_t GADDR2:32;
2510 } B;
2511 } GALR; /* Descriptor Group Lower Address Register */
2512
2513 uint32_t fec_reserved_galr[7];
2514
2515 union {
2516 uint32_t R;
2517 struct {
2518 uint32_t:30;
2519 uint32_t X_WMRK:2;
2520 } B;
2521 } TFWR; /* FIFO Transmit FIFO Watermark Register */
2522
2523 uint32_t fec_reserved_tfwr;
2524
2525 union {
2526 uint32_t R;
2527 struct {
2528 uint32_t:22;
2529 uint32_t R_BOUND:8;
2530 uint32_t:2;
2531 } B;
2532 } FRBR; /* FIFO Receive Bound Register */
2533
2534 union {
2535 uint32_t R;
2536 struct {
2537 uint32_t:22;
2538 uint32_t R_FSTART:8;
2539 uint32_t:2;
2540 } B;
2541 } FRSR; /* FIFO Receive Start Register */
2542
2543 uint32_t fec_reserved_frsr[11];
2544
2545 union {
2546 uint32_t R;
2547 struct {
2548 uint32_t R_DES_START:30;
2549 uint32_t:2;
2550 } B;
2551 } ERDSR; /* Receive Descriptor Ring Start Register */
2552
2553 union {
2554 uint32_t R;
2555 struct {
2556 uint32_t X_DES_START:30;
2557 uint32_t:2;
2558 } B;
2559 } ETDSR; /* Transmit Descriptor Ring Start Register */
2560
2561 union {
2562 uint32_t R;
2563 struct {
2564 uint32_t:21;
2565 uint32_t R_BUF_SIZE:7;
2566 uint32_t:4;
2567 } B;
2568 } EMRBR; /* Receive Buffer Size Register */
2569
2570 uint32_t fec_reserved_emrbr[29];
2571
2572 union {
2573 uint32_t R;
2574 } RMON_T_DROP; /* Count of frames not counted correctly */
2575
2576 union {
2577 uint32_t R;
2578 } RMON_T_PACKETS; /* RMON Tx packet count */
2579
2580 union {
2581 uint32_t R;
2582 } RMON_T_BC_PKT; /* RMON Tx Broadcast Packets */
2583
2584 union {
2585 uint32_t R;
2586 } RMON_T_MC_PKT; /* RMON Tx Multicast Packets */
2587
2588 union {
2589 uint32_t R;
2590 } RMON_T_CRC_ALIGN; /* RMON Tx Packets w CRC/Align error */
2591
2592 union {
2593 uint32_t R;
2594 } RMON_T_UNDERSIZE; /* RMON Tx Packets < 64 bytes, good crc */
2595
2596 union {
2597 uint32_t R;
2598 } RMON_T_OVERSIZE; /* RMON Tx Packets > MAX_FL bytes, good crc */
2599
2600 union {
2601 uint32_t R;
2602 } RMON_T_FRAG; /* RMON Tx Packets < 64 bytes, bad crc */
2603
2604 union {
2605 uint32_t R;
2606 } RMON_T_JAB; /* RMON Tx Packets > MAX_FL bytes, bad crc */
2607
2608 union {
2609 uint32_t R;
2610 } RMON_T_COL; /* RMON Tx collision count */
2611
2612 union {
2613 uint32_t R;
2614 } RMON_T_P64; /* RMON Tx 64 byte packets */
2615
2616 union {
2617 uint32_t R;
2618 } RMON_T_P65TO127; /* RMON Tx 65 to 127 byte packets */
2619
2620 union {
2621 uint32_t R;
2622 } RMON_T_P128TO255; /* RMON Tx 128 to 255 byte packets */
2623
2624 union {
2625 uint32_t R;
2626 } RMON_T_P256TO511; /* RMON Tx 256 to 511 byte packets */
2627
2628 union {
2629 uint32_t R;
2630 } RMON_T_P512TO1023; /* RMON Tx 512 to 1023 byte packets */
2631
2632 union {
2633 uint32_t R;
2634 } RMON_T_P1024TO2047; /* RMON Tx 1024 to 2047 byte packets */
2635
2636 union {
2637 uint32_t R;
2638 } RMON_T_P_GTE2048; /* RMON Tx packets w > 2048 bytes */
2639
2640 union {
2641 uint32_t R;
2642 } RMON_T_OCTETS; /* RMON Tx Octets */
2643
2644 union {
2645 uint32_t R;
2646 } IEEE_T_DROP; /* Count of frames not counted correctly */
2647
2648 union {
2649 uint32_t R;
2650 } IEEE_T_FRAME_OK; /* Frames Transmitted OK */
2651
2652 union {
2653 uint32_t R;
2654 } IEEE_T_1COL; /* Frames Transmitted with Single Collision */
2655
2656 union {
2657 uint32_t R;
2658 } IEEE_T_MCOL; /* Frames Transmitted with Multiple Collisions */
2659
2660 union {
2661 uint32_t R;
2662 } IEEE_T_DEF; /* Frames Transmitted after Deferral Delay */
2663
2664 union {
2665 uint32_t R;
2666 } IEEE_T_LCOL; /* Frames Transmitted with Late Collision */
2667
2668 union {
2669 uint32_t R;
2670 } IEEE_T_EXCOL; /* Frames Transmitted with Excessive Collisions */
2671
2672 union {
2673 uint32_t R;
2674 } IEEE_T_MACERR; /* Frames Transmitted with Tx FIFO Underrun */
2675
2676 union {
2677 uint32_t R;
2678 } IEEE_T_CSERR; /* Frames Transmitted with Carrier Sense Error */
2679
2680 union {
2681 uint32_t R;
2682 } IEEE_T_SQE; /* Frames Transmitted with SQE Error */
2683
2684 union {
2685 uint32_t R;
2686 } IEEE_T_FDXFC; /* Flow Control Pause frames transmitted */
2687
2688 union {
2689 uint32_t R;
2690 } IEEE_T_OCTETS_OK; /* Octet count for Frames Transmitted w/o Error */
2691
2692 uint32_t fec_reserved_rmon_t_octets_ok[2];
2693
2694 union {
2695 uint32_t R;
2696 } RMON_R_DROP; /* Count of frames not counted correctly */
2697
2698 union {
2699 uint32_t R;
2700 } RMON_R_PACKETS; /* RMON Rx packet count */
2701
2702 union {
2703 uint32_t R;
2704 } RMON_R_BC_PKT; /* RMON Rx Broadcast Packets */
2705
2706 union {
2707 uint32_t R;
2708 } RMON_R_MC_PKT; /* RMON Rx Multicast Packets */
2709
2710 union {
2711 uint32_t R;
2712 } RMON_R_CRC_ALIGN; /* RMON Rx Packets w CRC/Align error */
2713
2714 union {
2715 uint32_t R;
2716 } RMON_R_UNDERSIZE; /* RMON Rx Packets < 64 bytes, good crc */
2717
2718 union {
2719 uint32_t R;
2720 } RMON_R_OVERSIZE; /* RMON Rx Packets > MAX_FL bytes, good crc */
2721
2722 union {
2723 uint32_t R;
2724 } RMON_R_FRAG; /* RMON Rx Packets < 64 bytes, bad crc */
2725
2726 union {
2727 uint32_t R;
2728 } RMON_R_JAB; /* RMON Rx Packets > MAX_FL bytes, bad crc */
2729
2730 uint32_t fec_reserved_rmon_r_jab;
2731
2732 union {
2733 uint32_t R;
2734 } RMON_R_P64; /* RMON Rx 64 byte packets */
2735
2736 union {
2737 uint32_t R;
2738 } RMON_R_P65TO127; /* RMON Rx 65 to 127 byte packets */
2739
2740 union {
2741 uint32_t R;
2742 } RMON_R_P128TO255; /* RMON Rx 128 to 255 byte packets */
2743
2744 union {
2745 uint32_t R;
2746 } RMON_R_P256TO511; /* RMON Rx 256 to 511 byte packets */
2747
2748 union {
2749 uint32_t R;
2750 } RMON_R_P512TO1023; /* RMON Rx 512 to 1023 byte packets */
2751
2752 union {
2753 uint32_t R;
2754 } RMON_R_P1024TO2047; /* RMON Rx 1024 to 2047 byte packets */
2755
2756 union {
2757 uint32_t R;
2758 } RMON_R_P_GTE2048; /* RMON Rx packets w > 2048 bytes */
2759
2760 union {
2761 uint32_t R;
2762 } RMON_R_OCTETS; /* RMON Rx Octets */
2763
2764 union {
2765 uint32_t R;
2766 } IEEE_R_DROP; /* Count of frames not counted correctly */
2767
2768 union {
2769 uint32_t R;
2770 } IEEE_R_FRAME_OK; /* Frames Received OK */
2771
2772 union {
2773 uint32_t R;
2774 } IEEE_R_CRC; /* Frames Received with CRC Error */
2775
2776 union {
2777 uint32_t R;
2778 } IEEE_R_ALIGN; /* Frames Received with Alignment Error */
2779
2780 union {
2781 uint32_t R;
2782 } IEEE_R_MACERR; /* Receive Fifo Overflow count */
2783
2784 union {
2785 uint32_t R;
2786 } IEEE_R_FDXFC; /* Flow Control Pause frames received */
2787
2788 union {
2789 uint32_t R;
2790 } IEEE_R_OCTETS_OK; /* Octet count for Frames Rcvd w/o Error */
2791
2792 }; /* end of FEC_tag */
2793/*************************************************************************/
2794/* MODULE : FLASH */
2795/*************************************************************************/
2796 struct FLASH_tag {
2797 union {
2798 uint32_t R;
2799 struct {
2800 uint32_t:5;
2801 uint32_t SIZE:3;
2802 uint32_t:1;
2803 uint32_t LAS:3;
2804 uint32_t:3;
2805 uint32_t MAS:1;
2806 uint32_t EER:1;
2807 uint32_t RWE:1;
2808 uint32_t SBC:1;
2809 uint32_t:1;
2810 uint32_t PEAS:1;
2811 uint32_t DONE:1;
2812 uint32_t PEG:1;
2813 uint32_t:4;
2814 uint32_t PGM:1;
2815 uint32_t PSUS:1;
2816 uint32_t ERS:1;
2817 uint32_t ESUS:1;
2818 uint32_t EHV:1;
2819 } B;
2820 } MCR; /* Module Configuration Register */
2821
2822 union {
2823 uint32_t R;
2824 struct {
2825 uint32_t LME:1;
2826 uint32_t:10;
2827 uint32_t SLOCK:1;
2828 uint32_t:2;
2829 uint32_t MLOCK:2;
2830 uint32_t:6;
2831 uint32_t LLOCK:10;
2832 } B;
2833 } LML; /* Low/Mid-address space block locking Register */
2834
2835 union {
2836 uint32_t R;
2837 struct {
2838 uint32_t HBE:1;
2839 uint32_t:25;
2840 uint32_t HBLOCK:6;
2841 } B;
2842 } HBL; /* High-address space block locking Register */
2843
2844 union {
2845 uint32_t R;
2846 struct {
2847 uint32_t SLE:1;
2848 uint32_t:10;
2849 uint32_t SSLOCK:1;
2850 uint32_t:2;
2851 uint32_t SMLOCK:2;
2852 uint32_t:6;
2853 uint32_t SLLOCK:10;
2854 } B;
2855 } SLL; /* Secondary low/mid-address space block locking Register */
2856
2857 union {
2858 uint32_t R;
2859 struct {
2860 uint32_t:14;
2861 uint32_t MSEL:2;
2862 uint32_t:6;
2863 uint32_t LSEL:10;
2864 } B;
2865 } LMS; /* Low/Mid-address space block locking Register */
2866
2867 union {
2868 uint32_t R;
2869 struct {
2870 uint32_t:26;
2871 uint32_t HBSEL:6;
2872 } B;
2873 } HBS; /* High-address space block locking Register */
2874
2875 union {
2876 uint32_t R;
2877 struct {
2878 uint32_t SAD:1;
2879 uint32_t:10;
2880 uint32_t ADDR:18;
2881 uint32_t:3;
2882 } B;
2883 } ADR; /* Address Register */
2884
2885 union {
2886 uint32_t R;
2887 struct {
2888 uint32_t LBCFG:4;
2889 uint32_t ARB:1;
2890 uint32_t PRI:1;
2891 uint32_t:1;
2892 uint32_t M8PFE:1;
2893 uint32_t:1;
2894 uint32_t M6PFE:1;
2895 uint32_t M5PFE:1;
2896 uint32_t M4PFE:1;
2897 uint32_t:1;
2898 uint32_t M2PFE:1;
2899 uint32_t M1PFE:1;
2900 uint32_t M0PFE:1;
2901 uint32_t APC:3;
2902 uint32_t WWSC:2;
2903 uint32_t RWSC:3;
2904 uint32_t:1;
2905 uint32_t DPFEN:1;
2906 uint32_t:1;
2907 uint32_t IPFEN:1;
2908 uint32_t:1;
2909 uint32_t PFLIM:2;
2910 uint32_t BFEN:1;
2911 } B;
2912 } PFCRP0; /* Platform Flash Configuration Register for Port 0 */
2913
2914 union {
2915 uint32_t R;
2916 struct {
2917 uint32_t LBCFG:4;
2918 uint32_t:3;
2919 uint32_t M8PFE:1;
2920 uint32_t:1;
2921 uint32_t M6PFE:1;
2922 uint32_t M5PFE:1;
2923 uint32_t M4PFE:1;
2924 uint32_t:1;
2925 uint32_t M2PFE:1;
2926 uint32_t M1PFE:1;
2927 uint32_t M0PFE:1;
2928 uint32_t APC:3;
2929 uint32_t WWSC:2;
2930 uint32_t RWSC:3;
2931 uint32_t:1;
2932 uint32_t DPFEN:1;
2933 uint32_t:1;
2934 uint32_t IPFEN:1;
2935 uint32_t:1;
2936 uint32_t PFLIM:2;
2937 uint32_t BFEN:1;
2938 } B;
2939 } PFCRP1; /* Platform Flash Configuration Register for Port 1 */
2940
2941 union {
2942 uint32_t R;
2943 struct {
2944 uint32_t M7AP:2;
2945 uint32_t M6AP:2;
2946 uint32_t M5AP:2;
2947 uint32_t M4AP:2;
2948 uint32_t M3AP:2;
2949 uint32_t M2AP:2;
2950 uint32_t M1AP:2;
2951 uint32_t M0AP:2;
2952 uint32_t SHSACC:4;
2953 uint32_t:4;
2954 uint32_t SHDACC:4;
2955 uint32_t:4;
2956 } B;
2957 } PFAPR; /* Platform Flash access protection Register */
2958
2959 union {
2960 uint32_t R;
2961 struct {
2962 uint32_t:1;
2963 uint32_t SACC:31;
2964 } B;
2965 } PFSACC; /* PFlash Supervisor Access Control Register */
2966
2967 union {
2968 uint32_t R;
2969 struct {
2970 uint32_t:1;
2971 uint32_t DACC:31;
2972 } B;
2973 } PFDACC; /* PFlash Data Access Control Register */
2974
2975 uint32_t FLASH_reserved1[3];
2976
2977 union {
2978 uint32_t R;
2979 struct {
2980 uint32_t UTE:1;
2981 uint32_t SCBE:1;
2982 uint32_t:6;
2983 uint32_t DSI:8;
2984 uint32_t:10;
2985 uint32_t MRE:1;
2986 uint32_t MRV:1;
2987 uint32_t EIE:1;
2988 uint32_t AIS:1;
2989 uint32_t AIE:1;
2990 uint32_t AID:1;
2991 } B;
2992 } UT0; /* User Test Register 0 */
2993
2994 union {
2995 uint32_t R;
2996 struct {
2997 uint32_t DAI:32;
2998 } B;
2999 } UT1; /* User Test Register 1 */
3000
3001 union {
3002 uint32_t R;
3003 struct {
3004 uint32_t DAI:32;
3005 } B;
3006 } UT2; /* User Test Register 2 */
3007
3008 union {
3009 uint32_t R;
3010 struct {
3011 uint32_t MISR:32;
3012 } B;
3013 } MISR[5]; /* Multiple Input Signature Register */
3014
3015 }; /* end of FLASH_tag */
3016/*************************************************************************/
3017/* MODULE : FlexCAN */
3018/*************************************************************************/
3019 struct FLEXCAN_tag {
3020 union {
3021 uint32_t R;
3022 struct {
3023 uint32_t MDIS:1;
3024 uint32_t FRZ:1;
3025 uint32_t FEN:1;
3026 uint32_t HALT:1;
3027 uint32_t NOTRDY:1;
3028 uint32_t WAKMSK:1;
3029 uint32_t SOFTRST:1;
3030 uint32_t FRZACK:1;
3031 uint32_t SUPV:1;
3032 uint32_t SLFWAK:1;
3033 uint32_t WRNEN:1;
3034 uint32_t LPMACK:1;
3035 uint32_t WAKSRC:1;
3036 uint32_t DOZE:1;
3037 uint32_t SRXDIS:1;
3038 uint32_t BCC:1;
3039 uint32_t:2;
3040 uint32_t LPRIO_EN:1;
3041 uint32_t AEN:1;
3042 uint32_t:2;
3043 uint32_t IDAM:2;
3044 uint32_t:2;
3045 uint32_t MAXMB:6;
3046 } B;
3047 } MCR; /* Module Configuration Register */
3048
3049 union {
3050 uint32_t R;
3051 struct {
3052 uint32_t PRESDIV:8;
3053 uint32_t RJW:2;
3054 uint32_t PSEG1:3;
3055 uint32_t PSEG2:3;
3056 uint32_t BOFFMSK:1;
3057 uint32_t ERRMSK:1;
3058 uint32_t CLKSRC:1;
3059 uint32_t LPB:1;
3060 uint32_t TWRNMSK:1;
3061 uint32_t RWRNMSK:1;
3062 uint32_t:2;
3063 uint32_t SMP:1;
3064 uint32_t BOFFREC:1;
3065 uint32_t TSYN:1;
3066 uint32_t LBUF:1;
3067 uint32_t LOM:1;
3068 uint32_t PROPSEG:3;
3069 } B;
3070 } CTRL; /* Control Register */
3071
3072 union {
3073 uint32_t R;
3074 } TIMER; /* Free Running Timer */
3075
3076 uint32_t FLEXCAN_reserved1;
3077
3078 union {
3079 uint32_t R;
3080 struct {
3081 uint32_t MI:32;
3082 } B;
3083 } RXGMASK; /* RX Global Mask */
3084
3085 union {
3086 uint32_t R;
3087 struct {
3088 uint32_t MI:32;
3089 } B;
3090 } RX14MASK; /* RX 14 Mask */
3091
3092 union {
3093 uint32_t R;
3094 struct {
3095 uint32_t MI:32;
3096 } B;
3097 } RX15MASK; /* RX 15 Mask */
3098
3099 union {
3100 uint32_t R;
3101 struct {
3102 uint32_t:16;
3103 uint32_t RXECNT:8;
3104 uint32_t TXECNT:8;
3105 } B;
3106 } ECR; /* Error Counter Register */
3107
3108 union {
3109 uint32_t R;
3110 struct {
3111 uint32_t:14;
3112 uint32_t TWRNINT:1;
3113 uint32_t RWRNINT:1;
3114 uint32_t BIT1ERR:1;
3115 uint32_t BIT0ERR:1;
3116 uint32_t ACKERR:1;
3117 uint32_t CRCERR:1;
3118 uint32_t FRMERR:1;
3119 uint32_t STFERR:1;
3120 uint32_t TXWRN:1;
3121 uint32_t RXWRN:1;
3122 uint32_t IDLE:1;
3123 uint32_t TXRX:1;
3124 uint32_t FLTCONF:2;
3125 uint32_t:1;
3126 uint32_t BOFFINT:1;
3127 uint32_t ERRINT:1;
3128 uint32_t WAKINT:1;
3129 } B;
3130 } ESR; /* Error and Status Register */
3131
3132 union {
3133 uint32_t R;
3134 struct {
3135 uint32_t BUF63M:1;
3136 uint32_t BUF62M:1;
3137 uint32_t BUF61M:1;
3138 uint32_t BUF60M:1;
3139 uint32_t BUF59M:1;
3140 uint32_t BUF58M:1;
3141 uint32_t BUF57M:1;
3142 uint32_t BUF56M:1;
3143 uint32_t BUF55M:1;
3144 uint32_t BUF54M:1;
3145 uint32_t BUF53M:1;
3146 uint32_t BUF52M:1;
3147 uint32_t BUF51M:1;
3148 uint32_t BUF50M:1;
3149 uint32_t BUF49M:1;
3150 uint32_t BUF48M:1;
3151 uint32_t BUF47M:1;
3152 uint32_t BUF46M:1;
3153 uint32_t BUF45M:1;
3154 uint32_t BUF44M:1;
3155 uint32_t BUF43M:1;
3156 uint32_t BUF42M:1;
3157 uint32_t BUF41M:1;
3158 uint32_t BUF40M:1;
3159 uint32_t BUF39M:1;
3160 uint32_t BUF38M:1;
3161 uint32_t BUF37M:1;
3162 uint32_t BUF36M:1;
3163 uint32_t BUF35M:1;
3164 uint32_t BUF34M:1;
3165 uint32_t BUF33M:1;
3166 uint32_t BUF32M:1;
3167 } B;
3168 } IMASK2; /* Interruput Masks Register */
3169
3170 union {
3171 uint32_t R;
3172 struct {
3173 uint32_t BUF31M:1;
3174 uint32_t BUF30M:1;
3175 uint32_t BUF29M:1;
3176 uint32_t BUF28M:1;
3177 uint32_t BUF27M:1;
3178 uint32_t BUF26M:1;
3179 uint32_t BUF25M:1;
3180 uint32_t BUF24M:1;
3181 uint32_t BUF23M:1;
3182 uint32_t BUF22M:1;
3183 uint32_t BUF21M:1;
3184 uint32_t BUF20M:1;
3185 uint32_t BUF19M:1;
3186 uint32_t BUF18M:1;
3187 uint32_t BUF17M:1;
3188 uint32_t BUF16M:1;
3189 uint32_t BUF15M:1;
3190 uint32_t BUF14M:1;
3191 uint32_t BUF13M:1;
3192 uint32_t BUF12M:1;
3193 uint32_t BUF11M:1;
3194 uint32_t BUF10M:1;
3195 uint32_t BUF09M:1;
3196 uint32_t BUF08M:1;
3197 uint32_t BUF07M:1;
3198 uint32_t BUF06M:1;
3199 uint32_t BUF05M:1;
3200 uint32_t BUF04M:1;
3201 uint32_t BUF03M:1;
3202 uint32_t BUF02M:1;
3203 uint32_t BUF01M:1;
3204 uint32_t BUF00M:1;
3205 } B;
3206 } IMASK1; /* Interruput Masks Register */
3207
3208 union {
3209 uint32_t R;
3210 struct {
3211 uint32_t BUF63I:1;
3212 uint32_t BUF62I:1;
3213 uint32_t BUF61I:1;
3214 uint32_t BUF60I:1;
3215 uint32_t BUF59I:1;
3216 uint32_t BUF58I:1;
3217 uint32_t BUF57I:1;
3218 uint32_t BUF56I:1;
3219 uint32_t BUF55I:1;
3220 uint32_t BUF54I:1;
3221 uint32_t BUF53I:1;
3222 uint32_t BUF52I:1;
3223 uint32_t BUF51I:1;
3224 uint32_t BUF50I:1;
3225 uint32_t BUF49I:1;
3226 uint32_t BUF48I:1;
3227 uint32_t BUF47I:1;
3228 uint32_t BUF46I:1;
3229 uint32_t BUF45I:1;
3230 uint32_t BUF44I:1;
3231 uint32_t BUF43I:1;
3232 uint32_t BUF42I:1;
3233 uint32_t BUF41I:1;
3234 uint32_t BUF40I:1;
3235 uint32_t BUF39I:1;
3236 uint32_t BUF38I:1;
3237 uint32_t BUF37I:1;
3238 uint32_t BUF36I:1;
3239 uint32_t BUF35I:1;
3240 uint32_t BUF34I:1;
3241 uint32_t BUF33I:1;
3242 uint32_t BUF32I:1;
3243 } B;
3244 } IFLAG2; /* Interruput Flag Register */
3245
3246 union {
3247 uint32_t R;
3248 struct {
3249 uint32_t BUF31I:1;
3250 uint32_t BUF30I:1;
3251 uint32_t BUF29I:1;
3252 uint32_t BUF28I:1;
3253 uint32_t BUF27I:1;
3254 uint32_t BUF26I:1;
3255 uint32_t BUF25I:1;
3256 uint32_t BUF24I:1;
3257 uint32_t BUF23I:1;
3258 uint32_t BUF22I:1;
3259 uint32_t BUF21I:1;
3260 uint32_t BUF20I:1;
3261 uint32_t BUF19I:1;
3262 uint32_t BUF18I:1;
3263 uint32_t BUF17I:1;
3264 uint32_t BUF16I:1;
3265 uint32_t BUF15I:1;
3266 uint32_t BUF14I:1;
3267 uint32_t BUF13I:1;
3268 uint32_t BUF12I:1;
3269 uint32_t BUF11I:1;
3270 uint32_t BUF10I:1;
3271 uint32_t BUF09I:1;
3272 uint32_t BUF08I:1;
3273 uint32_t BUF07I:1;
3274 uint32_t BUF06I:1;
3275 uint32_t BUF05I:1;
3276 uint32_t BUF04I:1;
3277 uint32_t BUF03I:1;
3278 uint32_t BUF02I:1;
3279 uint32_t BUF01I:1;
3280 uint32_t BUF00I:1;
3281 } B;
3282 } IFLAG1; /* Interruput Flag Register */
3283
3284 uint32_t FLEXCAN_reserved2[19];
3285
3286 struct canbuf_t {
3287 union {
3288 uint32_t R;
3289 struct {
3290 uint32_t:4;
3291 uint32_t CODE:4;
3292 uint32_t:1;
3293 uint32_t SRR:1;
3294 uint32_t IDE:1;
3295 uint32_t RTR:1;
3296 uint32_t LENGTH:4;
3297 uint32_t TIMESTAMP:16;
3298 } B;
3299 } CS;
3300
3301 union {
3302 uint32_t R;
3303 struct {
3304 uint32_t PRIO:3;
3305 uint32_t STD_ID:11;
3306 uint32_t EXT_ID:18;
3307 } B;
3308 } ID;
3309
3310 union {
3311 /* uint8_t B[8]; Data buffer in Bytes (8 bits) */
3312 /* uint16_t H[4]; Data buffer in Half-words (16 bits) */
3313 uint32_t W[2]; /* Data buffer in words (32 bits) */
3314 /* uint32_t R[2]; Data buffer in words (32 bits) */
3315 } DATA;
3316
3317 } BUF[64];
3318
3319 uint32_t FLEXCAN_reserved3[256];
3320
3321 union {
3322 uint32_t R;
3323 struct {
3324 uint32_t MI:32;
3325 } B;
3326 } RXIMR[64]; /* RX Individual Mask Registers */
3327
3328 }; /* end of CTU_tag */
3329/**************************************************************************/
3330/* MODULE : FlexRay */
3331/**************************************************************************/
3332
3333 typedef union uMVR {
3334 uint16_t R;
3335 struct {
3336 uint16_t CHIVER:8; /* CHI Version Number */
3337 uint16_t PEVER:8; /* PE Version Number */
3338 } B;
3339 } MVR_t;
3340
3341 typedef union uMCR {
3342 uint16_t R;
3343 struct {
3344 uint16_t MEN:1; /* module enable */
3345 uint16_t:1;
3346 uint16_t SCMD:1; /* single channel mode */
3347 uint16_t CHB:1; /* channel B enable */
3348 uint16_t CHA:1; /* channel A enable */
3349 uint16_t SFFE:1; /* synchronization frame filter enable */
3350 uint16_t:5;
3351 uint16_t CLKSEL:1; /* protocol engine clock source select */
3352 uint16_t PRESCALE:3; /* protocol engine clock prescaler */
3353 uint16_t:1;
3354 } B;
3355 } MCR_t;
3356 typedef union uSTBSCR {
3357 uint16_t R;
3358 struct {
3359 uint16_t WMD:1; /* write mode */
3360 uint16_t STBSSEL:7; /* strobe signal select */
3361 uint16_t:3;
3362 uint16_t ENB:1; /* strobe signal enable */
3363 uint16_t:2;
3364 uint16_t STBPSEL:2; /* strobe port select */
3365 } B;
3366 } STBSCR_t;
3367 typedef union uMBDSR {
3368 uint16_t R;
3369 struct {
3370 uint16_t:1;
3371 uint16_t MBSEG2DS:7; /* message buffer segment 2 data size */
3372 uint16_t:1;
3373 uint16_t MBSEG1DS:7; /* message buffer segment 1 data size */
3374 } B;
3375 } MBDSR_t;
3376
3377 typedef union uMBSSUTR {
3378 uint16_t R;
3379 struct {
3380
3381 uint16_t:2;
3382 uint16_t LAST_MB_SEG1:6; /* last message buffer control register for message buffer segment 1 */
3383 uint16_t:2;
3384 uint16_t LAST_MB_UTIL:6; /* last message buffer utilized */
3385 } B;
3386 } MBSSUTR_t;
3387
3388 typedef union uPOCR {
3389 uint16_t R;
3390 uint8_t byte[2];
3391 struct {
3392 uint16_t WME:1; /* write mode external correction command */
3393 uint16_t:3;
3394 uint16_t EOC_AP:2; /* external offset correction application */
3395 uint16_t ERC_AP:2; /* external rate correction application */
3396 uint16_t BSY:1; /* command write busy / write mode command */
3397 uint16_t:3;
3398 uint16_t POCCMD:4; /* protocol command */
3399 } B;
3400 } POCR_t;
3401/* protocol commands */
3402 typedef union uGIFER {
3403 uint16_t R;
3404 struct {
3405 uint16_t MIF:1; /* module interrupt flag */
3406 uint16_t PRIF:1; /* protocol interrupt flag */
3407 uint16_t CHIF:1; /* CHI interrupt flag */
3408 uint16_t WKUPIF:1; /* wakeup interrupt flag */
3409 uint16_t FNEBIF:1; /* receive FIFO channel B not empty interrupt flag */
3410 uint16_t FNEAIF:1; /* receive FIFO channel A not empty interrupt flag */
3411 uint16_t RBIF:1; /* receive message buffer interrupt flag */
3412 uint16_t TBIF:1; /* transmit buffer interrupt flag */
3413 uint16_t MIE:1; /* module interrupt enable */
3414 uint16_t PRIE:1; /* protocol interrupt enable */
3415 uint16_t CHIE:1; /* CHI interrupt enable */
3416 uint16_t WKUPIE:1; /* wakeup interrupt enable */
3417 uint16_t FNEBIE:1; /* receive FIFO channel B not empty interrupt enable */
3418 uint16_t FNEAIE:1; /* receive FIFO channel A not empty interrupt enable */
3419 uint16_t RBIE:1; /* receive message buffer interrupt enable */
3420 uint16_t TBIE:1; /* transmit buffer interrupt enable */
3421 } B;
3422 } GIFER_t;
3423 typedef union uPIFR0 {
3424 uint16_t R;
3425 struct {
3426 uint16_t FATLIF:1; /* fatal protocol error interrupt flag */
3427 uint16_t INTLIF:1; /* internal protocol error interrupt flag */
3428 uint16_t ILCFIF:1; /* illegal protocol configuration flag */
3429 uint16_t CSAIF:1; /* cold start abort interrupt flag */
3430 uint16_t MRCIF:1; /* missing rate correctio interrupt flag */
3431 uint16_t MOCIF:1; /* missing offset correctio interrupt flag */
3432 uint16_t CCLIF:1; /* clock correction limit reached interrupt flag */
3433 uint16_t MXSIF:1; /* max sync frames detected interrupt flag */
3434 uint16_t MTXIF:1; /* media access test symbol received flag */
3435 uint16_t LTXBIF:1; /* pdLatestTx violation on channel B interrupt flag */
3436 uint16_t LTXAIF:1; /* pdLatestTx violation on channel A interrupt flag */
3437 uint16_t TBVBIF:1; /* Transmission across boundary on channel B Interrupt Flag */
3438 uint16_t TBVAIF:1; /* Transmission across boundary on channel A Interrupt Flag */
3439 uint16_t TI2IF:1; /* timer 2 expired interrupt flag */
3440 uint16_t TI1IF:1; /* timer 1 expired interrupt flag */
3441 uint16_t CYSIF:1; /* cycle start interrupt flag */
3442 } B;
3443 } PIFR0_t;
3444 typedef union uPIFR1 {
3445 uint16_t R;
3446 struct {
3447 uint16_t EMCIF:1; /* error mode changed interrupt flag */
3448 uint16_t IPCIF:1; /* illegal protocol command interrupt flag */
3449 uint16_t PECFIF:1; /* protocol engine communication failure interrupt flag */
3450 uint16_t PSCIF:1; /* Protocol State Changed Interrupt Flag */
3451 uint16_t SSI3IF:1; /* slot status counter incremented interrupt flag */
3452 uint16_t SSI2IF:1; /* slot status counter incremented interrupt flag */
3453 uint16_t SSI1IF:1; /* slot status counter incremented interrupt flag */
3454 uint16_t SSI0IF:1; /* slot status counter incremented interrupt flag */
3455 uint16_t:2;
3456 uint16_t EVTIF:1; /* even cycle table written interrupt flag */
3457 uint16_t ODTIF:1; /* odd cycle table written interrupt flag */
3458 uint16_t:4;
3459 } B;
3460 } PIFR1_t;
3461 typedef union uPIER0 {
3462 uint16_t R;
3463 struct {
3464 uint16_t FATLIE:1; /* fatal protocol error interrupt enable */
3465 uint16_t INTLIE:1; /* internal protocol error interrupt interrupt enable */
3466 uint16_t ILCFIE:1; /* illegal protocol configuration interrupt enable */
3467 uint16_t CSAIE:1; /* cold start abort interrupt enable */
3468 uint16_t MRCIE:1; /* missing rate correctio interrupt enable */
3469 uint16_t MOCIE:1; /* missing offset correctio interrupt enable */
3470 uint16_t CCLIE:1; /* clock correction limit reached interrupt enable */
3471 uint16_t MXSIE:1; /* max sync frames detected interrupt enable */
3472 uint16_t MTXIE:1; /* media access test symbol received interrupt enable */
3473 uint16_t LTXBIE:1; /* pdLatestTx violation on channel B interrupt enable */
3474 uint16_t LTXAIE:1; /* pdLatestTx violation on channel A interrupt enable */
3475 uint16_t TBVBIE:1; /* Transmission across boundary on channel B Interrupt enable */
3476 uint16_t TBVAIE:1; /* Transmission across boundary on channel A Interrupt enable */
3477 uint16_t TI2IE:1; /* timer 2 expired interrupt enable */
3478 uint16_t TI1IE:1; /* timer 1 expired interrupt enable */
3479 uint16_t CYSIE:1; /* cycle start interrupt enable */
3480 } B;
3481 } PIER0_t;
3482 typedef union uPIER1 {
3483 uint16_t R;
3484 struct {
3485 uint16_t EMCIE:1; /* error mode changed interrupt enable */
3486 uint16_t IPCIE:1; /* illegal protocol command interrupt enable */
3487 uint16_t PECFIE:1; /* protocol engine communication failure interrupt enable */
3488 uint16_t PSCIE:1; /* Protocol State Changed Interrupt enable */
3489 uint16_t SSI3IE:1; /* slot status counter incremented interrupt enable */
3490 uint16_t SSI2IE:1; /* slot status counter incremented interrupt enable */
3491 uint16_t SSI1IE:1; /* slot status counter incremented interrupt enable */
3492 uint16_t SSI0IE:1; /* slot status counter incremented interrupt enable */
3493 uint16_t:2;
3494 uint16_t EVTIE:1; /* even cycle table written interrupt enable */
3495 uint16_t ODTIE:1; /* odd cycle table written interrupt enable */
3496 uint16_t:4;
3497 } B;
3498 } PIER1_t;
3499 typedef union uCHIERFR {
3500 uint16_t R;
3501 struct {
3502 uint16_t FRLBEF:1; /* flame lost channel B error flag */
3503 uint16_t FRLAEF:1; /* frame lost channel A error flag */
3504 uint16_t PCMIEF:1; /* command ignored error flag */
3505 uint16_t FOVBEF:1; /* receive FIFO overrun channel B error flag */
3506 uint16_t FOVAEF:1; /* receive FIFO overrun channel A error flag */
3507 uint16_t MSBEF:1; /* message buffer search error flag */
3508 uint16_t MBUEF:1; /* message buffer utilization error flag */
3509 uint16_t LCKEF:1; /* lock error flag */
3510 uint16_t DBLEF:1; /* double transmit message buffer lock error flag */
3511 uint16_t SBCFEF:1; /* system bus communication failure error flag */
3512 uint16_t FIDEF:1; /* frame ID error flag */
3513 uint16_t DPLEF:1; /* dynamic payload length error flag */
3514 uint16_t SPLEF:1; /* static payload length error flag */
3515 uint16_t NMLEF:1; /* network management length error flag */
3516 uint16_t NMFEF:1; /* network management frame error flag */
3517 uint16_t ILSAEF:1; /* illegal access error flag */
3518 } B;
3519 } CHIERFR_t;
3520 typedef union uMBIVEC {
3521 uint16_t R;
3522 struct {
3523
3524 uint16_t:2;
3525 uint16_t TBIVEC:6; /* transmit buffer interrupt vector */
3526 uint16_t:2;
3527 uint16_t RBIVEC:6; /* receive buffer interrupt vector */
3528 } B;
3529 } MBIVEC_t;
3530
3531 typedef union uPSR0 {
3532 uint16_t R;
3533 struct {
3534 uint16_t ERRMODE:2; /* error mode */
3535 uint16_t SLOTMODE:2; /* slot mode */
3536 uint16_t:1;
3537 uint16_t PROTSTATE:3; /* protocol state */
3538 uint16_t SUBSTATE:4; /* protocol sub state */
3539 uint16_t:1;
3540 uint16_t WAKEUPSTATUS:3; /* wakeup status */
3541 } B;
3542 } PSR0_t;
3543
3544/* protocol states */
3545/* protocol sub-states */
3546/* wakeup status */
3547 typedef union uPSR1 {
3548 uint16_t R;
3549 struct {
3550 uint16_t CSAA:1; /* cold start attempt abort flag */
3551 uint16_t SCP:1; /* cold start path */
3552 uint16_t:1;
3553 uint16_t REMCSAT:5; /* remanining coldstart attempts */
3554 uint16_t CPN:1; /* cold start noise path */
3555 uint16_t HHR:1; /* host halt request pending */
3556 uint16_t FRZ:1; /* freeze occured */
3557 uint16_t APTAC:5; /* allow passive to active counter */
3558 } B;
3559 } PSR1_t;
3560 typedef union uPSR2 {
3561 uint16_t R;
3562 struct {
3563 uint16_t NBVB:1; /* NIT boundary violation on channel B */
3564 uint16_t NSEB:1; /* NIT syntax error on channel B */
3565 uint16_t STCB:1; /* symbol window transmit conflict on channel B */
3566 uint16_t SBVB:1; /* symbol window boundary violation on channel B */
3567 uint16_t SSEB:1; /* symbol window syntax error on channel B */
3568 uint16_t MTB:1; /* media access test symbol MTS received on channel B */
3569 uint16_t NBVA:1; /* NIT boundary violation on channel A */
3570 uint16_t NSEA:1; /* NIT syntax error on channel A */
3571 uint16_t STCA:1; /* symbol window transmit conflict on channel A */
3572 uint16_t SBVA:1; /* symbol window boundary violation on channel A */
3573 uint16_t SSEA:1; /* symbol window syntax error on channel A */
3574 uint16_t MTA:1; /* media access test symbol MTS received on channel A */
3575 uint16_t CLKCORRFAILCNT:4; /* clock correction failed counter */
3576 } B;
3577 } PSR2_t;
3578 typedef union uPSR3 {
3579 uint16_t R;
3580 struct {
3581 uint16_t:2;
3582 uint16_t WUB:1; /* wakeup symbol received on channel B */
3583 uint16_t ABVB:1; /* aggregated boundary violation on channel B */
3584 uint16_t AACB:1; /* aggregated additional communication on channel B */
3585 uint16_t ACEB:1; /* aggregated content error on channel B */
3586 uint16_t ASEB:1; /* aggregated syntax error on channel B */
3587 uint16_t AVFB:1; /* aggregated valid frame on channel B */
3588 uint16_t:2;
3589 uint16_t WUA:1; /* wakeup symbol received on channel A */
3590 uint16_t ABVA:1; /* aggregated boundary violation on channel A */
3591 uint16_t AACA:1; /* aggregated additional communication on channel A */
3592 uint16_t ACEA:1; /* aggregated content error on channel A */
3593 uint16_t ASEA:1; /* aggregated syntax error on channel A */
3594 uint16_t AVFA:1; /* aggregated valid frame on channel A */
3595 } B;
3596 } PSR3_t;
3597 typedef union uCIFRR {
3598 uint16_t R;
3599 struct {
3600 uint16_t:8;
3601 uint16_t MIFR:1; /* module interrupt flag */
3602 uint16_t PRIFR:1; /* protocol interrupt flag */
3603 uint16_t CHIFR:1; /* CHI interrupt flag */
3604 uint16_t WUPIFR:1; /* wakeup interrupt flag */
3605 uint16_t FNEBIFR:1; /* receive fifo channel B no empty interrupt flag */
3606 uint16_t FNEAIFR:1; /* receive fifo channel A no empty interrupt flag */
3607 uint16_t RBIFR:1; /* receive message buffer interrupt flag */
3608 uint16_t TBIFR:1; /* transmit buffer interrupt flag */
3609 } B;
3610 } CIFRR_t;
3611 typedef union uSYMATOR {
3612 uint16_t R;
3613 struct {
3614 uint16_t:11;
3615 uint16_t TIMEOUT:5; /* system memory time out value */
3616 } B;
3617 } SYMATOR_t;
3618
3619 typedef union uSFCNTR {
3620 uint16_t R;
3621 struct {
3622 uint16_t SFEVB:4; /* sync frames channel B, even cycle */
3623 uint16_t SFEVA:4; /* sync frames channel A, even cycle */
3624 uint16_t SFODB:4; /* sync frames channel B, odd cycle */
3625 uint16_t SFODA:4; /* sync frames channel A, odd cycle */
3626 } B;
3627 } SFCNTR_t;
3628
3629 typedef union uSFTCCSR {
3630 uint16_t R;
3631 struct {
3632 uint16_t ELKT:1; /* even cycle tables lock and unlock trigger */
3633 uint16_t OLKT:1; /* odd cycle tables lock and unlock trigger */
3634 uint16_t CYCNUM:6; /* cycle number */
3635 uint16_t ELKS:1; /* even cycle tables lock status */
3636 uint16_t OLKS:1; /* odd cycle tables lock status */
3637 uint16_t EVAL:1; /* even cycle tables valid */
3638 uint16_t OVAL:1; /* odd cycle tables valid */
3639 uint16_t:1;
3640 uint16_t OPT:1; /*one pair trigger */
3641 uint16_t SDVEN:1; /* sync frame deviation table enable */
3642 uint16_t SIDEN:1; /* sync frame ID table enable */
3643 } B;
3644 } SFTCCSR_t;
3645 typedef union uSFIDRFR {
3646 uint16_t R;
3647 struct {
3648 uint16_t:6;
3649 uint16_t SYNFRID:10; /* sync frame rejection ID */
3650 } B;
3651 } SFIDRFR_t;
3652
3653 typedef union uTICCR {
3654 uint16_t R;
3655 struct {
3656 uint16_t:2;
3657 uint16_t T2CFG:1; /* timer 2 configuration */
3658 uint16_t T2REP:1; /* timer 2 repetitive mode */
3659 uint16_t:1;
3660 uint16_t T2SP:1; /* timer 2 stop */
3661 uint16_t T2TR:1; /* timer 2 trigger */
3662 uint16_t T2ST:1; /* timer 2 state */
3663 uint16_t:3;
3664 uint16_t T1REP:1; /* timer 1 repetitive mode */
3665 uint16_t:1;
3666 uint16_t T1SP:1; /* timer 1 stop */
3667 uint16_t T1TR:1; /* timer 1 trigger */
3668 uint16_t T1ST:1; /* timer 1 state */
3669
3670 } B;
3671 } TICCR_t;
3672 typedef union uTI1CYSR {
3673 uint16_t R;
3674 struct {
3675 uint16_t:2;
3676 uint16_t TI1CYCVAL:6; /* timer 1 cycle filter value */
3677 uint16_t:2;
3678 uint16_t TI1CYCMSK:6; /* timer 1 cycle filter mask */
3679
3680 } B;
3681 } TI1CYSR_t;
3682
3683 typedef union uSSSR {
3684 uint16_t R;
3685 struct {
3686 uint16_t WMD:1; /* write mode */
3687 uint16_t:1;
3688 uint16_t SEL:2; /* static slot number */
3689 uint16_t:1;
3690 uint16_t SLOTNUMBER:11; /* selector */
3691 } B;
3692 } SSSR_t;
3693
3694 typedef union uSSCCR {
3695 uint16_t R;
3696 struct {
3697 uint16_t WMD:1; /* write mode */
3698 uint16_t:1;
3699 uint16_t SEL:2; /* selector */
3700 uint16_t:1;
3701 uint16_t CNTCFG:2; /* counter configuration */
3702 uint16_t MCY:1; /* multi cycle selection */
3703 uint16_t VFR:1; /* valid frame selection */
3704 uint16_t SYF:1; /* sync frame selection */
3705 uint16_t NUF:1; /* null frame selection */
3706 uint16_t SUF:1; /* startup frame selection */
3707 uint16_t STATUSMASK:4; /* slot status mask */
3708 } B;
3709 } SSCCR_t;
3710 typedef union uSSR {
3711 uint16_t R;
3712 struct {
3713 uint16_t VFB:1; /* valid frame on channel B */
3714 uint16_t SYB:1; /* valid sync frame on channel B */
3715 uint16_t NFB:1; /* valid null frame on channel B */
3716 uint16_t SUB:1; /* valid startup frame on channel B */
3717 uint16_t SEB:1; /* syntax error on channel B */
3718 uint16_t CEB:1; /* content error on channel B */
3719 uint16_t BVB:1; /* boundary violation on channel B */
3720 uint16_t TCB:1; /* tx conflict on channel B */
3721 uint16_t VFA:1; /* valid frame on channel A */
3722 uint16_t SYA:1; /* valid sync frame on channel A */
3723 uint16_t NFA:1; /* valid null frame on channel A */
3724 uint16_t SUA:1; /* valid startup frame on channel A */
3725 uint16_t SEA:1; /* syntax error on channel A */
3726 uint16_t CEA:1; /* content error on channel A */
3727 uint16_t BVA:1; /* boundary violation on channel A */
3728 uint16_t TCA:1; /* tx conflict on channel A */
3729 } B;
3730 } SSR_t;
3731 typedef union uMTSCFR {
3732 uint16_t R;
3733 struct {
3734 uint16_t MTE:1; /* media access test symbol transmission enable */
3735 uint16_t:1;
3736 uint16_t CYCCNTMSK:6; /* cycle counter mask */
3737 uint16_t:2;
3738 uint16_t CYCCNTVAL:6; /* cycle counter value */
3739 } B;
3740 } MTSCFR_t;
3741
3742 typedef union uRSBIR {
3743 uint16_t R;
3744 struct {
3745 uint16_t WMD:1; /* write mode */
3746 uint16_t:1;
3747 uint16_t SEL:2; /* selector */
3748 uint16_t:5;
3749 uint16_t RSBIDX:7; /* receive shadow buffer index */
3750 } B;
3751 } RSBIR_t;
3752
3753 typedef union uRFDSR {
3754 uint16_t R;
3755 struct {
3756 uint16_t FIFODEPTH:8; /* fifo depth */
3757 uint16_t:1;
3758 uint16_t ENTRYSIZE:7; /* entry size */
3759 } B;
3760 } RFDSR_t;
3761
3762 typedef union uRFRFCFR {
3763 uint16_t R;
3764 struct {
3765 uint16_t WMD:1; /* write mode */
3766 uint16_t IBD:1; /* interval boundary */
3767 uint16_t SEL:2; /* filter number */
3768 uint16_t:1;
3769 uint16_t SID:11; /* slot ID */
3770 } B;
3771 } RFRFCFR_t;
3772
3773 typedef union uRFRFCTR {
3774 uint16_t R;
3775 struct {
3776 uint16_t:4;
3777 uint16_t F3MD:1; /* filter mode */
3778 uint16_t F2MD:1; /* filter mode */
3779 uint16_t F1MD:1; /* filter mode */
3780 uint16_t F0MD:1; /* filter mode */
3781 uint16_t:4;
3782 uint16_t F3EN:1; /* filter enable */
3783 uint16_t F2EN:1; /* filter enable */
3784 uint16_t F1EN:1; /* filter enable */
3785 uint16_t F0EN:1; /* filter enable */
3786 } B;
3787 } RFRFCTR_t;
3788 typedef union uPCR0 {
3789 uint16_t R;
3790 struct {
3791 uint16_t ACTION_POINT_OFFSET:6;
3792 uint16_t STATIC_SLOT_LENGTH:10;
3793 } B;
3794 } PCR0_t;
3795
3796 typedef union uPCR1 {
3797 uint16_t R;
3798 struct {
3799 uint16_t:2;
3800 uint16_t MACRO_AFTER_FIRST_STATIC_SLOT:14;
3801 } B;
3802 } PCR1_t;
3803
3804 typedef union uPCR2 {
3805 uint16_t R;
3806 struct {
3807 uint16_t MINISLOT_AFTER_ACTION_POINT:6;
3808 uint16_t NUMBER_OF_STATIC_SLOTS:10;
3809 } B;
3810 } PCR2_t;
3811
3812 typedef union uPCR3 {
3813 uint16_t R;
3814 struct {
3815 uint16_t WAKEUP_SYMBOL_RX_LOW:6;
3816 uint16_t MINISLOT_ACTION_POINT_OFFSET:5;
3817 uint16_t COLDSTART_ATTEMPTS:5;
3818 } B;
3819 } PCR3_t;
3820
3821 typedef union uPCR4 {
3822 uint16_t R;
3823 struct {
3824 uint16_t CAS_RX_LOW_MAX:7;
3825 uint16_t WAKEUP_SYMBOL_RX_WINDOW:9;
3826 } B;
3827 } PCR4_t;
3828
3829 typedef union uPCR5 {
3830 uint16_t R;
3831 struct {
3832 uint16_t TSS_TRANSMITTER:4;
3833 uint16_t WAKEUP_SYMBOL_TX_LOW:6;
3834 uint16_t WAKEUP_SYMBOL_RX_IDLE:6;
3835 } B;
3836 } PCR5_t;
3837
3838 typedef union uPCR6 {
3839 uint16_t R;
3840 struct {
3841 uint16_t:1;
3842 uint16_t SYMBOL_WINDOW_AFTER_ACTION_POINT:8;
3843 uint16_t MACRO_INITIAL_OFFSET_A:7;
3844 } B;
3845 } PCR6_t;
3846
3847 typedef union uPCR7 {
3848 uint16_t R;
3849 struct {
3850 uint16_t DECODING_CORRECTION_B:9;
3851 uint16_t MICRO_PER_MACRO_NOM_HALF:7;
3852 } B;
3853 } PCR7_t;
3854
3855 typedef union uPCR8 {
3856 uint16_t R;
3857 struct {
3858 uint16_t MAX_WITHOUT_CLOCK_CORRECTION_FATAL:4;
3859 uint16_t MAX_WITHOUT_CLOCK_CORRECTION_PASSIVE:4;
3860 uint16_t WAKEUP_SYMBOL_TX_IDLE:8;
3861 } B;
3862 } PCR8_t;
3863
3864 typedef union uPCR9 {
3865 uint16_t R;
3866 struct {
3867 uint16_t MINISLOT_EXISTS:1;
3868 uint16_t SYMBOL_WINDOW_EXISTS:1;
3869 uint16_t OFFSET_CORRECTION_OUT:14;
3870 } B;
3871 } PCR9_t;
3872
3873 typedef union uPCR10 {
3874 uint16_t R;
3875 struct {
3876 uint16_t SINGLE_SLOT_ENABLED:1;
3877 uint16_t WAKEUP_CHANNEL:1;
3878 uint16_t MACRO_PER_CYCLE:14;
3879 } B;
3880 } PCR10_t;
3881
3882 typedef union uPCR11 {
3883 uint16_t R;
3884 struct {
3885 uint16_t KEY_SLOT_USED_FOR_STARTUP:1;
3886 uint16_t KEY_SLOT_USED_FOR_SYNC:1;
3887 uint16_t OFFSET_CORRECTION_START:14;
3888 } B;
3889 } PCR11_t;
3890
3891 typedef union uPCR12 {
3892 uint16_t R;
3893 struct {
3894 uint16_t ALLOW_PASSIVE_TO_ACTIVE:5;
3895 uint16_t KEY_SLOT_HEADER_CRC:11;
3896 } B;
3897 } PCR12_t;
3898
3899 typedef union uPCR13 {
3900 uint16_t R;
3901 struct {
3902 uint16_t FIRST_MINISLOT_ACTION_POINT_OFFSET:6;
3903 uint16_t STATIC_SLOT_AFTER_ACTION_POINT:10;
3904 } B;
3905 } PCR13_t;
3906
3907 typedef union uPCR14 {
3908 uint16_t R;
3909 struct {
3910 uint16_t RATE_CORRECTION_OUT:11;
3911 uint16_t LISTEN_TIMEOUT_H:5;
3912 } B;
3913 } PCR14_t;
3914
3915 typedef union uPCR15 {
3916 uint16_t R;
3917 struct {
3918 uint16_t LISTEN_TIMEOUT_L:16;
3919 } B;
3920 } PCR15_t;
3921
3922 typedef union uPCR16 {
3923 uint16_t R;
3924 struct {
3925 uint16_t MACRO_INITIAL_OFFSET_B:7;
3926 uint16_t NOISE_LISTEN_TIMEOUT_H:9;
3927 } B;
3928 } PCR16_t;
3929
3930 typedef union uPCR17 {
3931 uint16_t R;
3932 struct {
3933 uint16_t NOISE_LISTEN_TIMEOUT_L:16;
3934 } B;
3935 } PCR17_t;
3936
3937 typedef union uPCR18 {
3938 uint16_t R;
3939 struct {
3940 uint16_t WAKEUP_PATTERN:6;
3941 uint16_t KEY_SLOT_ID:10;
3942 } B;
3943 } PCR18_t;
3944
3945 typedef union uPCR19 {
3946 uint16_t R;
3947 struct {
3948 uint16_t DECODING_CORRECTION_A:9;
3949 uint16_t PAYLOAD_LENGTH_STATIC:7;
3950 } B;
3951 } PCR19_t;
3952
3953 typedef union uPCR20 {
3954 uint16_t R;
3955 struct {
3956 uint16_t MICRO_INITIAL_OFFSET_B:8;
3957 uint16_t MICRO_INITIAL_OFFSET_A:8;
3958 } B;
3959 } PCR20_t;
3960
3961 typedef union uPCR21 {
3962 uint16_t R;
3963 struct {
3964 uint16_t EXTERN_RATE_CORRECTION:3;
3965 uint16_t LATEST_TX:13;
3966 } B;
3967 } PCR21_t;
3968
3969 typedef union uPCR22 {
3970 uint16_t R;
3971 struct {
3972 uint16_t:1;
3973 uint16_t COMP_ACCEPTED_STARTUP_RANGE_A:11;
3974 uint16_t MICRO_PER_CYCLE_H:4;
3975 } B;
3976 } PCR22_t;
3977
3978 typedef union uPCR23 {
3979 uint16_t R;
3980 struct {
3981 uint16_t micro_per_cycle_l:16;
3982 } B;
3983 } PCR23_t;
3984
3985 typedef union uPCR24 {
3986 uint16_t R;
3987 struct {
3988 uint16_t CLUSTER_DRIFT_DAMPING:5;
3989 uint16_t MAX_PAYLOAD_LENGTH_DYNAMIC:7;
3990 uint16_t MICRO_PER_CYCLE_MIN_H:4;
3991 } B;
3992 } PCR24_t;
3993
3994 typedef union uPCR25 {
3995 uint16_t R;
3996 struct {
3997 uint16_t MICRO_PER_CYCLE_MIN_L:16;
3998 } B;
3999 } PCR25_t;
4000
4001 typedef union uPCR26 {
4002 uint16_t R;
4003 struct {
4004 uint16_t ALLOW_HALT_DUE_TO_CLOCK:1;
4005 uint16_t COMP_ACCEPTED_STARTUP_RANGE_B:11;
4006 uint16_t MICRO_PER_CYCLE_MAX_H:4;
4007 } B;
4008 } PCR26_t;
4009
4010 typedef union uPCR27 {
4011 uint16_t R;
4012 struct {
4013 uint16_t MICRO_PER_CYCLE_MAX_L:16;
4014 } B;
4015 } PCR27_t;
4016
4017 typedef union uPCR28 {
4018 uint16_t R;
4019 struct {
4020 uint16_t DYNAMIC_SLOT_IDLE_PHASE:2;
4021 uint16_t MACRO_AFTER_OFFSET_CORRECTION:14;
4022 } B;
4023 } PCR28_t;
4024
4025 typedef union uPCR29 {
4026 uint16_t R;
4027 struct {
4028 uint16_t EXTERN_OFFSET_CORRECTION:3;
4029 uint16_t MINISLOTS_MAX:13;
4030 } B;
4031 } PCR29_t;
4032
4033 typedef union uPCR30 {
4034 uint16_t R;
4035 struct {
4036 uint16_t:12;
4037 uint16_t SYNC_NODE_MAX:4;
4038 } B;
4039 } PCR30_t;
4040
4041 typedef struct uMSG_BUFF_CCS {
4042 union {
4043 uint16_t R;
4044 struct {
4045 uint16_t:1;
4046 uint16_t MCM:1; /* message buffer commit mode */
4047 uint16_t MBT:1; /* message buffer type */
4048 uint16_t MTD:1; /* message buffer direction */
4049 uint16_t CMT:1; /* commit for transmission */
4050 uint16_t EDT:1; /* enable / disable trigger */
4051 uint16_t LCKT:1; /* lock request trigger */
4052 uint16_t MBIE:1; /* message buffer interrupt enable */
4053 uint16_t:3;
4054 uint16_t DUP:1; /* data updated */
4055 uint16_t DVAL:1; /* data valid */
4056 uint16_t EDS:1; /* lock status */
4057 uint16_t LCKS:1; /* enable / disable status */
4058 uint16_t MBIF:1; /* message buffer interrupt flag */
4059 } B;
4060 } MBCCSR;
4061 union {
4062 uint16_t R;
4063 struct {
4064 uint16_t MTM:1; /* message buffer transmission mode */
4065 uint16_t CHNLA:1; /* channel assignement */
4066 uint16_t CHNLB:1; /* channel assignement */
4067 uint16_t CCFE:1; /* cycle counter filter enable */
4068 uint16_t CCFMSK:6; /* cycle counter filter mask */
4069 uint16_t CCFVAL:6; /* cycle counter filter value */
4070 } B;
4071 } MBCCFR;
4072 union {
4073 uint16_t R;
4074 struct {
4075 uint16_t:5;
4076 uint16_t FID:11; /* frame ID */
4077 } B;
4078 } MBFIDR;
4079
4080 union {
4081 uint16_t R;
4082 struct {
4083 uint16_t:9;
4084 uint16_t MBIDX:7; /* message buffer index */
4085 } B;
4086 } MBIDXR;
4087 } MSG_BUFF_CCS_t;
4088 typedef union uSYSBADHR {
4089 uint16_t R;
4090 } SYSBADHR_t;
4091 typedef union uSYSBADLR {
4092 uint16_t R;
4093 } SYSBADLR_t;
4094 typedef union uPADR {
4095 uint16_t R;
4096 } PADR_t;
4097 typedef union uPDAR {
4098 uint16_t R;
4099 } PDAR_t;
4100 typedef union uCASERCR {
4101 uint16_t R;
4102 } CASERCR_t;
4103 typedef union uCBSERCR {
4104 uint16_t R;
4105 } CBSERCR_t;
4106 typedef union uCYCTR {
4107 uint16_t R;
4108 } CYCTR_t;
4109 typedef union uMTCTR {
4110 uint16_t R;
4111 } MTCTR_t;
4112 typedef union uSLTCTAR {
4113 uint16_t R;
4114 } SLTCTAR_t;
4115 typedef union uSLTCTBR {
4116 uint16_t R;
4117 } SLTCTBR_t;
4118 typedef union uRTCORVR {
4119 uint16_t R;
4120 } RTCORVR_t;
4121 typedef union uOFCORVR {
4122 uint16_t R;
4123 } OFCORVR_t;
4124 typedef union uSFTOR {
4125 uint16_t R;
4126 } SFTOR_t;
4127 typedef union uSFIDAFVR {
4128 uint16_t R;
4129 } SFIDAFVR_t;
4130 typedef union uSFIDAFMR {
4131 uint16_t R;
4132 } SFIDAFMR_t;
4133 typedef union uNMVR {
4134 uint16_t R;
4135 } NMVR_t;
4136 typedef union uNMVLR {
4137 uint16_t R;
4138 } NMVLR_t;
4139 typedef union uT1MTOR {
4140 uint16_t R;
4141 } T1MTOR_t;
4142 typedef union uTI2CR0 {
4143 uint16_t R;
4144 } TI2CR0_t;
4145 typedef union uTI2CR1 {
4146 uint16_t R;
4147 } TI2CR1_t;
4148 typedef union uSSCR {
4149 uint16_t R;
4150 } SSCR_t;
4151 typedef union uRFSR {
4152 uint16_t R;
4153 } RFSR_t;
4154 typedef union uRFSIR {
4155 uint16_t R;
4156 } RFSIR_t;
4157 typedef union uRFARIR {
4158 uint16_t R;
4159 } RFARIR_t;
4160 typedef union uRFBRIR {
4161 uint16_t R;
4162 } RFBRIR_t;
4163 typedef union uRFMIDAFVR {
4164 uint16_t R;
4165 } RFMIDAFVR_t;
4166 typedef union uRFMIAFMR {
4167 uint16_t R;
4168 } RFMIAFMR_t;
4169 typedef union uRFFIDRFVR {
4170 uint16_t R;
4171 } RFFIDRFVR_t;
4172 typedef union uRFFIDRFMR {
4173 uint16_t R;
4174 } RFFIDRFMR_t;
4175 typedef union uLDTXSLAR {
4176 uint16_t R;
4177 } LDTXSLAR_t;
4178 typedef union uLDTXSLBR {
4179 uint16_t R;
4180 } LDTXSLBR_t;
4181
4182 typedef struct FR_tag {
4183 volatile MVR_t MVR; /*module version register *//*0 */
4184 volatile MCR_t MCR; /*module configuration register *//*2 */
4185 volatile SYSBADHR_t SYSBADHR; /*system memory base address high register *//*4 */
4186 volatile SYSBADLR_t SYSBADLR; /*system memory base address low register *//*6 */
4187 volatile STBSCR_t STBSCR; /*strobe signal control register *//*8 */
4188 uint16_t reserved0[1]; /*A */
4189 volatile MBDSR_t MBDSR; /*message buffer data size register *//*C */
4190 volatile MBSSUTR_t MBSSUTR; /*message buffer segment size and utilization register *//*E */
4191 uint16_t reserved1[1]; /*10 */
4192 uint16_t reserved2[1]; /*12 */
4193 volatile POCR_t POCR; /*Protocol operation control register *//*14 */
4194 volatile GIFER_t GIFER; /*global interrupt flag and enable register *//*16 */
4195 volatile PIFR0_t PIFR0; /*protocol interrupt flag register 0 *//*18 */
4196 volatile PIFR1_t PIFR1; /*protocol interrupt flag register 1 *//*1A */
4197 volatile PIER0_t PIER0; /*protocol interrupt enable register 0 *//*1C */
4198 volatile PIER1_t PIER1; /*protocol interrupt enable register 1 *//*1E */
4199 volatile CHIERFR_t CHIERFR; /*CHI error flag register *//*20 */
4200 volatile MBIVEC_t MBIVEC; /*message buffer interrupt vector register *//*22 */
4201 volatile CASERCR_t CASERCR; /*channel A status error counter register *//*24 */
4202 volatile CBSERCR_t CBSERCR; /*channel B status error counter register *//*26 */
4203 volatile PSR0_t PSR0; /*protocol status register 0 *//*28 */
4204 volatile PSR1_t PSR1; /*protocol status register 1 *//*2A */
4205 volatile PSR2_t PSR2; /*protocol status register 2 *//*2C */
4206 volatile PSR3_t PSR3; /*protocol status register 3 *//*2E */
4207 volatile MTCTR_t MTCTR; /*macrotick counter register *//*30 */
4208 volatile CYCTR_t CYCTR; /*cycle counter register *//*32 */
4209 volatile SLTCTAR_t SLTCTAR; /*slot counter channel A register *//*34 */
4210 volatile SLTCTBR_t SLTCTBR; /*slot counter channel B register *//*36 */
4211 volatile RTCORVR_t RTCORVR; /*rate correction value register *//*38 */
4212 volatile OFCORVR_t OFCORVR; /*offset correction value register *//*3A */
4213 volatile CIFRR_t CIFRR; /*combined interrupt flag register *//*3C */
4214 volatile SYMATOR_t SYMATOR; /*system memory acess time-out register *//*3E */
4215 volatile SFCNTR_t SFCNTR; /*sync frame counter register *//*40 */
4216 volatile SFTOR_t SFTOR; /*sync frame table offset register *//*42 */
4217 volatile SFTCCSR_t SFTCCSR; /*sync frame table configuration, control, status register *//*44 */
4218 volatile SFIDRFR_t SFIDRFR; /*sync frame ID rejection filter register *//*46 */
4219 volatile SFIDAFVR_t SFIDAFVR; /*sync frame ID acceptance filter value regiater *//*48 */
4220 volatile SFIDAFMR_t SFIDAFMR; /*sync frame ID acceptance filter mask register *//*4A */
4221 volatile NMVR_t NMVR[6]; /*network management vector registers (12 bytes) *//*4C */
4222 volatile NMVLR_t NMVLR; /*network management vector length register *//*58 */
4223 volatile TICCR_t TICCR; /*timer configuration and control register *//*5A */
4224 volatile TI1CYSR_t TI1CYSR; /*timer 1 cycle set register *//*5C */
4225 volatile T1MTOR_t T1MTOR; /*timer 1 macrotick offset register *//*5E */
4226 volatile TI2CR0_t TI2CR0; /*timer 2 configuration register 0 *//*60 */
4227 volatile TI2CR1_t TI2CR1; /*timer 2 configuration register 1 *//*62 */
4228 volatile SSSR_t SSSR; /*slot status selection register *//*64 */
4229 volatile SSCCR_t SSCCR; /*slot status counter condition register *//*66 */
4230 volatile SSR_t SSR[8]; /*slot status registers 0-7 *//*68 */
4231 volatile SSCR_t SSCR[4]; /*slot status counter registers 0-3 *//*78 */
4232 volatile MTSCFR_t MTSACFR; /*mts a config register *//*80 */
4233 volatile MTSCFR_t MTSBCFR; /*mts b config register *//*82 */
4234 volatile RSBIR_t RSBIR; /*receive shadow buffer index register *//*84 */
4235 volatile RFSR_t RFSR; /*receive fifo selection register *//*86 */
4236 volatile RFSIR_t RFSIR; /*receive fifo start index register *//*88 */
4237 volatile RFDSR_t RFDSR; /*receive fifo depth and size register *//*8A */
4238 volatile RFARIR_t RFARIR; /*receive fifo a read index register *//*8C */
4239 volatile RFBRIR_t RFBRIR; /*receive fifo b read index register *//*8E */
4240 volatile RFMIDAFVR_t RFMIDAFVR; /*receive fifo message ID acceptance filter value register *//*90 */
4241 volatile RFMIAFMR_t RFMIAFMR; /*receive fifo message ID acceptance filter mask register *//*92 */
4242 volatile RFFIDRFVR_t RFFIDRFVR; /*receive fifo frame ID rejection filter value register *//*94 */
4243 volatile RFFIDRFMR_t RFFIDRFMR; /*receive fifo frame ID rejection filter mask register *//*96 */
4244 volatile RFRFCFR_t RFRFCFR; /*receive fifo range filter configuration register *//*98 */
4245 volatile RFRFCTR_t RFRFCTR; /*receive fifo range filter control register *//*9A */
4246 volatile LDTXSLAR_t LDTXSLAR; /*last dynamic transmit slot channel A register *//*9C */
4247 volatile LDTXSLBR_t LDTXSLBR; /*last dynamic transmit slot channel B register *//*9E */
4248 volatile PCR0_t PCR0; /*protocol configuration register 0 *//*A0 */
4249 volatile PCR1_t PCR1; /*protocol configuration register 1 *//*A2 */
4250 volatile PCR2_t PCR2; /*protocol configuration register 2 *//*A4 */
4251 volatile PCR3_t PCR3; /*protocol configuration register 3 *//*A6 */
4252 volatile PCR4_t PCR4; /*protocol configuration register 4 *//*A8 */
4253 volatile PCR5_t PCR5; /*protocol configuration register 5 *//*AA */
4254 volatile PCR6_t PCR6; /*protocol configuration register 6 *//*AC */
4255 volatile PCR7_t PCR7; /*protocol configuration register 7 *//*AE */
4256 volatile PCR8_t PCR8; /*protocol configuration register 8 *//*B0 */
4257 volatile PCR9_t PCR9; /*protocol configuration register 9 *//*B2 */
4258 volatile PCR10_t PCR10; /*protocol configuration register 10 *//*B4 */
4259 volatile PCR11_t PCR11; /*protocol configuration register 11 *//*B6 */
4260 volatile PCR12_t PCR12; /*protocol configuration register 12 *//*B8 */
4261 volatile PCR13_t PCR13; /*protocol configuration register 13 *//*BA */
4262 volatile PCR14_t PCR14; /*protocol configuration register 14 *//*BC */
4263 volatile PCR15_t PCR15; /*protocol configuration register 15 *//*BE */
4264 volatile PCR16_t PCR16; /*protocol configuration register 16 *//*C0 */
4265 volatile PCR17_t PCR17; /*protocol configuration register 17 *//*C2 */
4266 volatile PCR18_t PCR18; /*protocol configuration register 18 *//*C4 */
4267 volatile PCR19_t PCR19; /*protocol configuration register 19 *//*C6 */
4268 volatile PCR20_t PCR20; /*protocol configuration register 20 *//*C8 */
4269 volatile PCR21_t PCR21; /*protocol configuration register 21 *//*CA */
4270 volatile PCR22_t PCR22; /*protocol configuration register 22 *//*CC */
4271 volatile PCR23_t PCR23; /*protocol configuration register 23 *//*CE */
4272 volatile PCR24_t PCR24; /*protocol configuration register 24 *//*D0 */
4273 volatile PCR25_t PCR25; /*protocol configuration register 25 *//*D2 */
4274 volatile PCR26_t PCR26; /*protocol configuration register 26 *//*D4 */
4275 volatile PCR27_t PCR27; /*protocol configuration register 27 *//*D6 */
4276 volatile PCR28_t PCR28; /*protocol configuration register 28 *//*D8 */
4277 volatile PCR29_t PCR29; /*protocol configuration register 29 *//*DA */
4278 volatile PCR30_t PCR30; /*protocol configuration register 30 *//*DC */
4279 uint16_t reserved3[17];
4280 volatile MSG_BUFF_CCS_t MBCCS[128]; /* message buffer configuration, control & status registers 0-31 *//*100 */
4281 } FR_tag_t;
4282
4283 typedef union uF_HEADER /* frame header */
4284 {
4285 struct {
4286 uint16_t:5;
4287 uint16_t HDCRC:11; /* Header CRC */
4288 uint16_t:2;
4289 uint16_t CYCCNT:6; /* Cycle Count */
4290 uint16_t:1;
4291 uint16_t PLDLEN:7; /* Payload Length */
4292 uint16_t:1;
4293 uint16_t PPI:1; /* Payload Preamble Indicator */
4294 uint16_t NUF:1; /* Null Frame Indicator */
4295 uint16_t SYF:1; /* Sync Frame Indicator */
4296 uint16_t SUF:1; /* Startup Frame Indicator */
4297 uint16_t FID:11; /* Frame ID */
4298 } B;
4299 uint16_t WORDS[3];
4300 } F_HEADER_t;
4301 typedef union uS_STSTUS /* slot status */
4302 {
4303 struct {
4304 uint16_t VFB:1; /* Valid Frame on channel B */
4305 uint16_t SYB:1; /* Sync Frame Indicator channel B */
4306 uint16_t NFB:1; /* Null Frame Indicator channel B */
4307 uint16_t SUB:1; /* Startup Frame Indicator channel B */
4308 uint16_t SEB:1; /* Syntax Error on channel B */
4309 uint16_t CEB:1; /* Content Error on channel B */
4310 uint16_t BVB:1; /* Boundary Violation on channel B */
4311 uint16_t CH:1; /* Channel */
4312 uint16_t VFA:1; /* Valid Frame on channel A */
4313 uint16_t SYA:1; /* Sync Frame Indicator channel A */
4314 uint16_t NFA:1; /* Null Frame Indicator channel A */
4315 uint16_t SUA:1; /* Startup Frame Indicator channel A */
4316 uint16_t SEA:1; /* Syntax Error on channel A */
4317 uint16_t CEA:1; /* Content Error on channel A */
4318 uint16_t BVA:1; /* Boundary Violation on channel A */
4319 uint16_t:1;
4320 } RX;
4321 struct {
4322 uint16_t VFB:1; /* Valid Frame on channel B */
4323 uint16_t SYB:1; /* Sync Frame Indicator channel B */
4324 uint16_t NFB:1; /* Null Frame Indicator channel B */
4325 uint16_t SUB:1; /* Startup Frame Indicator channel B */
4326 uint16_t SEB:1; /* Syntax Error on channel B */
4327 uint16_t CEB:1; /* Content Error on channel B */
4328 uint16_t BVB:1; /* Boundary Violation on channel B */
4329 uint16_t TCB:1; /* Tx Conflict on channel B */
4330 uint16_t VFA:1; /* Valid Frame on channel A */
4331 uint16_t SYA:1; /* Sync Frame Indicator channel A */
4332 uint16_t NFA:1; /* Null Frame Indicator channel A */
4333 uint16_t SUA:1; /* Startup Frame Indicator channel A */
4334 uint16_t SEA:1; /* Syntax Error on channel A */
4335 uint16_t CEA:1; /* Content Error on channel A */
4336 uint16_t BVA:1; /* Boundary Violation on channel A */
4337 uint16_t TCA:1; /* Tx Conflict on channel A */
4338 } TX;
4339 uint16_t R;
4340 } S_STATUS_t;
4341
4342 typedef struct uMB_HEADER /* message buffer header */
4343 {
4344 F_HEADER_t FRAME_HEADER;
4345 uint16_t DATA_OFFSET;
4346 S_STATUS_t SLOT_STATUS;
4347 } MB_HEADER_t;
4348/**************************************************************************/
4349/* MODULE : FMPLL */
4350/**************************************************************************/
4351 struct FMPLL_tag {
4352
4353 uint32_t FMPLL_reserved0;
4354
4355 union FMPLL_SYNSR_tag { /* Synthesiser Status Register */
4356 uint32_t R;
4357 struct {
4358 uint32_t:22;
4359 uint32_t LOLF:1;
4360 uint32_t LOC:1;
4361 uint32_t MODE:1;
4362 uint32_t PLLSEL:1;
4363 uint32_t PLLREF:1;
4364 uint32_t LOCKS:1;
4365 uint32_t LOCK:1;
4366 uint32_t LOCF:1;
4367 uint32_t CALDONE:1;
4368 uint32_t CALPASS:1;
4369 } B;
4370 } SYNSR;
4371
4372 union FMPLL_ESYNCR1_tag {
4373 uint32_t R;
4374 struct {
4375 uint32_t:1;
4376 uint32_t CLKCFG:3;
4377 uint32_t:8;
4378 uint32_t EPREDIV:4;
4379 uint32_t:8;
4380 uint32_t EMFD:8;
4381 } B;
4382 } ESYNCR1;
4383
4384 union FMPLL_ESYNCR2_tag {
4385 uint32_t R;
4386 struct {
4387 uint32_t:8;
4388 uint32_t LOCEN:1;
4389 uint32_t LOLRE:1;
4390 uint32_t LOCRE:1;
4391 uint32_t LOLIRQ:1;
4392 uint32_t LOCIRQ:1;
4393 uint32_t:1;
4394 uint32_t ERATE:2;
4395 uint32_t:5;
4396 uint32_t EDEPTH:3;
4397 uint32_t:2;
4398 uint32_t ERFD:6;
4399 } B;
4400 } ESYNCR2;
4401
4402 };
4403/*************************************************************************/
4404/* MODULE : i2c */
4405/*************************************************************************/
4406 struct I2C_tag {
4407 union {
4408 uint8_t R;
4409 struct {
4410 uint8_t AD:7;
4411 uint8_t:1;
4412 } B;
4413 } IBAD; /* Module Bus Address Register */
4414
4415 union {
4416 uint8_t R;
4417 struct {
4418 uint8_t MULT:2;
4419 uint8_t ICR:6;
4420 } B;
4421 } IBFD; /* Module Bus Frequency Register */
4422
4423 union {
4424 uint8_t R;
4425 struct {
4426 uint8_t MDIS:1;
4427 uint8_t IBIE:1;
4428 uint8_t MS:1;
4429 uint8_t TX:1;
4430 uint8_t NOACK:1;
4431 uint8_t RSTA:1;
4432 uint8_t DMAEN:1;
4433 uint8_t:1;
4434 } B;
4435 } IBCR; /* Module Bus Control Register */
4436
4437 union {
4438 uint8_t R;
4439 struct {
4440 uint8_t TCF:1;
4441 uint8_t IAAS:1;
4442 uint8_t IBB:1;
4443 uint8_t IBAL:1;
4444 uint8_t:1;
4445 uint8_t SRW:1;
4446 uint8_t IBIF:1;
4447 uint8_t RXAK:1;
4448 } B;
4449 } IBSR; /* Module Status Register */
4450
4451 union {
4452 uint8_t R;
4453 struct {
4454 uint8_t DATA:8;
4455 } B;
4456 } IBDR; /* Module Data Register */
4457
4458 union {
4459 uint8_t R;
4460 struct {
4461 uint8_t BIIE:1;
4462 uint8_t:7;
4463 } B;
4464 } IBIC; /* Module Interrupt Configuration Register */
4465
4466 }; /* end of i2c_tag */
4467/*************************************************************************/
4468/* MODULE : INTC */
4469/*************************************************************************/
4470 struct INTC_tag {
4471 union {
4472 uint32_t R;
4473 struct {
4474 uint32_t:18;
4475 uint32_t VTES_PRC1:1;
4476 uint32_t:4;
4477 uint32_t HVEN_PRC1:1;
4478 uint32_t:2;
4479 uint32_t VTES:1;
4480 uint32_t:4;
4481 uint32_t HVEN:1;
4482 } B;
4483 } MCR; /* Module Configuration Register */
4484
4485 int32_t INTC_reserved1;
4486
4487 union {
4488 uint32_t R;
4489 struct {
4490 uint32_t:28;
4491 uint32_t PRI:4;
4492 } B;
4493 } CPR; /* Processor 0 (Z6) Current Priority Register */
4494
4495 union {
4496 uint32_t R;
4497 struct {
4498 uint32_t:28;
4499 uint32_t PRI:4;
4500 } B;
4501 } CPR_PRC1; /* Processor 1 (Z0) Current Priority Register */
4502
4503 union {
4504 uint32_t R;
4505 struct {
4506 uint32_t VTBA:21;
4507 uint32_t INTVEC:9;
4508 uint32_t:2;
4509 } B;
4510 } IACKR; /* Processor 0 (Z6) Interrupt Acknowledge Register */
4511
4512 union {
4513 uint32_t R;
4514 struct {
4515 uint32_t VTBA_PRC1:21;
4516 uint32_t INTVEC_PRC1:9;
4517 uint32_t:2;
4518 } B;
4519 } IACKR_PRC1; /* Processor 1 (Z0) Interrupt Acknowledge Register */
4520
4521 union {
4522 uint32_t R;
4523 struct {
4524 uint32_t:32;
4525 } B;
4526 } EOIR; /* Processor 0 End of Interrupt Register */
4527
4528 union {
4529 uint32_t R;
4530 struct {
4531 uint32_t:32;
4532 } B;
4533 } EOIR_PRC1; /* Processor 1 End of Interrupt Register */
4534
4535 union {
4536 uint8_t R;
4537 struct {
4538 uint8_t:6;
4539 uint8_t SET:1;
4540 uint8_t CLR:1;
4541 } B;
4542 } SSCIR[8]; /* Software Set/Clear Interruput Register */
4543
4544 uint32_t intc_reserved2[6];
4545
4546 union {
4547 uint8_t R;
4548 struct {
4549 uint8_t PRC_SEL:2;
4550 uint8_t:2;
4551 uint8_t PRI:4;
4552 } B;
4553 } PSR[316]; /* Software Set/Clear Interrupt Register */
4554
4555 }; /* end of INTC_tag */
4556/*************************************************************************/
4557/* MODULE : MLB */
4558/*************************************************************************/
4559 struct MLB_tag {
4560
4561 union {
4562 uint32_t R;
4563 struct {
4564 uint32_t MDE:1;
4565 uint32_t LBM:1;
4566 uint32_t MCS:2;
4567 uint32_t:1;
4568 uint32_t MLK:1;
4569 uint32_t MLE:1;
4570 uint32_t MHRE:1;
4571 uint32_t MRS:1;
4572 uint32_t:15;
4573 uint32_t MDA:8;
4574 } B;
4575 } DCCR; /* Device Control Configuration Register */
4576
4577 union {
4578 uint32_t R;
4579 struct {
4580 uint32_t:24;
4581 uint32_t SSRE:1;
4582 uint32_t SDMU:1;
4583 uint32_t SDML:1;
4584 uint32_t SDSC:1;
4585 uint32_t SDCS:1;
4586 uint32_t SDNU:1;
4587 uint32_t SDNL:1;
4588 uint32_t SDR:1;
4589 } B;
4590 } SSCR; /* MLB Blank Register */
4591
4592 union {
4593 uint32_t R;
4594 struct {
4595 uint32_t MSD:32;
4596 } B;
4597 } SDCR; /* MLB Status Register */
4598
4599 union {
4600 uint32_t R;
4601 struct {
4602 uint32_t:25;
4603 uint32_t SMMU:1;
4604 uint32_t SMML:1;
4605 uint32_t SMSC:1;
4606 uint32_t SMCS:1;
4607 uint32_t SMNU:1;
4608 uint32_t SMNL:1;
4609 uint32_t SMR:1;
4610 } B;
4611 } SMCR; /* RX Control Channel Address Register */
4612
4613 uint32_t MLB_reserved1[3];
4614
4615 union {
4616 uint32_t R;
4617 struct {
4618 uint32_t UMA:8;
4619 uint32_t UMI:8;
4620 uint32_t MMA:8;
4621 uint32_t MMI:8;
4622 } B;
4623 } VCCR; /* Version Control Configuration Register */
4624
4625 union {
4626 uint32_t R;
4627 struct {
4628 uint32_t SRBA:16;
4629 uint32_t STBA:16;
4630 } B;
4631 } SBCR; /* Sync Base Address Config Register */
4632
4633 union {
4634 uint32_t R;
4635 struct {
4636 uint32_t ARBA:16;
4637 uint32_t ATBA:16;
4638 } B;
4639 } ABCR; /* Async Base Address Channel Config Register */
4640
4641 union {
4642 uint32_t R;
4643 struct {
4644 uint32_t CRBA:16;
4645 uint32_t CTBA:16;
4646 } B;
4647 } CBCR; /* Control Base Address Config Register */
4648
4649 union {
4650 uint32_t R;
4651 struct {
4652 uint32_t IRBA:16;
4653 uint32_t ITBA:16;
4654 } B;
4655 } IBCR; /* Isochronous Base Address Config Register */
4656
4657 union {
4658 uint32_t R;
4659 struct {
4660 uint32_t:16;
4661 uint32_t CSU:16;
4662 } B;
4663 } CICR; /* Channel Interrupt Config Register */
4664
4665 uint32_t MLB_reserved2[3];
4666
4667 struct mlbch_t {
4668
4669 union {
4670 uint32_t R;
4671 struct {
4672 uint32_t CE:1;
4673 uint32_t TR:1;
4674 uint32_t CT:2;
4675 uint32_t FSE_FCE:1;
4676 uint32_t MDS:2;
4677 uint32_t:2;
4678 uint32_t MLFS:1;
4679 uint32_t:1;
4680 uint32_t MBE:1;
4681 uint32_t MBS:1;
4682 uint32_t MBD:1;
4683 uint32_t MDB:1;
4684 uint32_t MPE:1;
4685 uint32_t FSCD_IPL:1;
4686 uint32_t IPL:2;
4687 uint32_t FSPC_IPL:5;
4688 uint32_t CA:8;
4689 } B;
4690 } CECR; /* Channel Entry Config Register */
4691
4692 union {
4693 uint32_t R;
4694 struct {
4695 uint32_t BM:1;
4696 uint32_t BF:1;
4697 uint32_t:10;
4698 uint32_t IVB:2;
4699 uint32_t GIRB_GB:1;
4700 uint32_t RDY:1;
4701 uint32_t:4;
4702 uint32_t PBS:1;
4703 uint32_t PBD:1;
4704 uint32_t PBDB:1;
4705 uint32_t PBPE:1;
4706 uint32_t:1;
4707 uint32_t LFS:1;
4708 uint32_t HBE:1;
4709 uint32_t BE:1;
4710 uint32_t CBS:1;
4711 uint32_t CBD:1;
4712 uint32_t CBDB:1;
4713 uint32_t CBPE:1;
4714 } B;
4715 } CSCR; /* Channel Status Config Register */
4716
4717 union {
4718 uint32_t R;
4719 struct {
4720 uint32_t BCA:16;
4721 uint32_t BFA:16;
4722 } B;
4723 } CCBCR; /* Channel Current Buffer Config Register */
4724
4725 union {
4726 uint32_t R;
4727 struct {
4728 uint32_t BSA:16;
4729 uint32_t BEA:16;
4730 } B;
4731 } CNBCR; /* Channel Next Buffer Config Register */
4732
4733 } CH[16];
4734
4735 uint32_t MLB_reserved3[80];
4736
4737 union {
4738 uint32_t R;
4739 struct {
4740 uint32_t BSA:16;
4741 uint32_t BEA:16;
4742 } B;
4743 } LCBCR[16]; /* Local Channel Buffer Config Register */
4744
4745 }; /* end of MLB_tag */
4746/*************************************************************************/
4747/* MODULE : MPU */
4748/*************************************************************************/
4749 struct MPU_tag {
4750 union {
4751 uint32_t R;
4752 struct {
4753 uint32_t MPERR:8;
4754 uint32_t:4;
4755 uint32_t HRL:4;
4756 uint32_t NSP:4;
4757 uint32_t NGRD:4;
4758 uint32_t:7;
4759 uint32_t VLD:1;
4760 } B;
4761 } CESR; /* Module Control/Error Status Register */
4762
4763 uint32_t mpu_reserved1[3];
4764
4765 union {
4766 uint32_t R;
4767 struct {
4768 uint32_t EADDR:32;
4769 } B;
4770 } EAR0; /* Error Address Register */
4771
4772 union {
4773 uint32_t R;
4774 struct {
4775 uint32_t EACD:16;
4776 uint32_t EPID:8;
4777 uint32_t EMN:4;
4778 uint32_t EATTR:3;
4779 uint32_t ERW:1;
4780 } B;
4781 } EDR0; /* Error Detail Register */
4782
4783 union {
4784 uint32_t R;
4785 struct {
4786 uint32_t EADDR:32;
4787 } B;
4788 } EAR1;
4789
4790 union {
4791 uint32_t R;
4792 struct {
4793 uint32_t EACD:16;
4794 uint32_t EPID:8;
4795 uint32_t EMN:4;
4796 uint32_t EATTR:3;
4797 uint32_t ERW:1;
4798 } B;
4799 } EDR1;
4800
4801 union {
4802 uint32_t R;
4803 struct {
4804 uint32_t EADDR:32;
4805 } B;
4806 } EAR2;
4807
4808 union {
4809 uint32_t R;
4810 struct {
4811 uint32_t EACD:16;
4812 uint32_t EPID:8;
4813 uint32_t EMN:4;
4814 uint32_t EATTR:3;
4815 uint32_t ERW:1;
4816 } B;
4817 } EDR3;
4818
4819 union {
4820 uint32_t R;
4821 struct {
4822 uint32_t EADDR:32;
4823 } B;
4824 } EAR3;
4825
4826 union {
4827 uint32_t R;
4828 struct {
4829 uint32_t EACD:16;
4830 uint32_t EPID:8;
4831 uint32_t EMN:4;
4832 uint32_t EATTR:3;
4833 uint32_t ERW:1;
4834 } B;
4835 } EDR2;
4836
4837 uint32_t mpu_reserved2[244];
4838
4839 struct {
4840 union {
4841 uint32_t R;
4842 struct {
4843 uint32_t SRTADDR:27;
4844 uint32_t:5;
4845 } B;
4846 } WORD0; /* Region Descriptor n Word 0 */
4847
4848 union {
4849 uint32_t R;
4850 struct {
4851 uint32_t ENDADDR:27;
4852 uint32_t:5;
4853 } B;
4854 } WORD1; /* Region Descriptor n Word 1 */
4855
4856 union {
4857 uint32_t R;
4858 struct {
4859 uint32_t:2;
4860 uint32_t M6RE:1;
4861 uint32_t M6WE:1;
4862 uint32_t M5RE:1;
4863 uint32_t M5WE:1;
4864 uint32_t M4RE:1;
4865 uint32_t M4WE:1;
4866 uint32_t:6;
4867 uint32_t M2PE:1;
4868 uint32_t M2SM:2;
4869 uint32_t M2UM:3;
4870 uint32_t M1PE:1;
4871 uint32_t M1SM:2;
4872 uint32_t M1UM:3;
4873 uint32_t M0PE:1;
4874 uint32_t M0SM:2;
4875 uint32_t M0UM:3;
4876 } B;
4877 } WORD2; /* Region Descriptor n Word 2 */
4878
4879 union {
4880 uint32_t R;
4881 struct {
4882 uint32_t PID:8;
4883 uint32_t PIDMASK:8;
4884 uint32_t:15;
4885 uint32_t VLD:1;
4886 } B;
4887 } WORD3; /* Region Descriptor n Word 3 */
4888
4889 } RGD[16];
4890
4891 uint32_t mpu_reserved3[192];
4892
4893 union {
4894 uint32_t R;
4895 struct {
4896 uint32_t:2;
4897 uint32_t M6RE:1;
4898 uint32_t M6WE:1;
4899 uint32_t M5RE:1;
4900 uint32_t M5WE:1;
4901 uint32_t M4RE:1;
4902 uint32_t M4WE:1;
4903 uint32_t:6;
4904 uint32_t M2PE:1;
4905 uint32_t M2SM:2;
4906 uint32_t M2UM:3;
4907 uint32_t M1PE:1;
4908 uint32_t M1SM:2;
4909 uint32_t M1UM:3;
4910 uint32_t M0PE:1;
4911 uint32_t M0SM:2;
4912 uint32_t M0UM:3;
4913 } B;
4914 } RGDAAC[16]; /* Region Descriptor Alternate Access Control n */
4915 };
4916/**************************************************************************/
4917/* MODULE : pit */
4918/**************************************************************************/
4919 struct PIT_tag {
4920
4922 uint32_t R;
4923 struct {
4924 uint32_t:30;
4925 uint32_t MDIS:1;
4926 uint32_t FRZ:1;
4927 } B;
4928 } PITMCR;
4929
4930 uint32_t pit_reserved1[59];
4931
4933 union {
4934 uint32_t R;
4935 struct {
4936 uint32_t TSV:32;
4937 } B;
4938 } LDVAL;
4939
4940 union {
4941 uint32_t R;
4942 struct {
4943 uint32_t TVL:32;
4944 } B;
4945 } CVAL;
4946
4948 uint32_t R;
4949 struct {
4950 uint32_t:30;
4951 uint32_t TIE:1;
4952 uint32_t TEN:1;
4953 } B;
4954 } TCTRL;
4955
4957 uint32_t R;
4958 struct {
4959 uint32_t:31;
4960 uint32_t TIF:1;
4961 } B;
4962 } TFLG;
4963 } CHANNEL[9];
4964 };
4965
4966 /* Compatibility with MPC5643L */
4967 typedef struct PIT_CHANNEL_tag PIT_RTI_CHANNEL_tag;
4968 typedef union PIT_MCR_tag PIT_RTI_PITMCR_32B_tag;
4969 typedef union PIT_TCTRL_tag PIT_RTI_TCTRL_32B_tag;
4970 typedef union PIT_TFLG_tag PIT_RTI_TFLG_32B_tag;
4971/**************************************************************************/
4972/* MODULE : sem4 */
4973/**************************************************************************/
4974 struct SEMA4_tag {
4975 union {
4976 uint8_t R;
4977 struct {
4978 uint8_t:6;
4979 uint8_t GTFSM:2;
4980 } B;
4981 } GATE[16]; /* Gate n Register */
4982
4983 uint32_t sema4_reserved1[12]; /* {0x40-0x10}/4 = 0x0C */
4984
4985 union {
4986 uint16_t R;
4987 struct {
4988 uint16_t INE0:1;
4989 uint16_t INE1:1;
4990 uint16_t INE2:1;
4991 uint16_t INE3:1;
4992 uint16_t INE4:1;
4993 uint16_t INE5:1;
4994 uint16_t INE6:1;
4995 uint16_t INE7:1;
4996 uint16_t INE8:1;
4997 uint16_t INE9:1;
4998 uint16_t INE10:1;
4999 uint16_t INE11:1;
5000 uint16_t INE12:1;
5001 uint16_t INE13:1;
5002 uint16_t INE14:1;
5003 uint16_t INE15:1;
5004 } B;
5005 } CP0INE;
5006
5007 uint16_t sema4_reserved2[3]; /* {0x48-0x42}/2 = 0x03 */
5008
5009 union {
5010 uint16_t R;
5011 struct {
5012 uint16_t INE0:1;
5013 uint16_t INE1:1;
5014 uint16_t INE2:1;
5015 uint16_t INE3:1;
5016 uint16_t INE4:1;
5017 uint16_t INE5:1;
5018 uint16_t INE6:1;
5019 uint16_t INE7:1;
5020 uint16_t INE8:1;
5021 uint16_t INE9:1;
5022 uint16_t INE10:1;
5023 uint16_t INE11:1;
5024 uint16_t INE12:1;
5025 uint16_t INE13:1;
5026 uint16_t INE14:1;
5027 uint16_t INE15:1;
5028 } B;
5029 } CP1INE;
5030
5031 uint16_t sema4_reserved3[27]; /* {0x80-0x4A}/2 = 0x1B */
5032
5033 union {
5034 uint16_t R;
5035 struct {
5036 uint16_t GN0:1;
5037 uint16_t GN1:1;
5038 uint16_t GN2:1;
5039 uint16_t GN3:1;
5040 uint16_t GN4:1;
5041 uint16_t GN5:1;
5042 uint16_t GN6:1;
5043 uint16_t GN7:1;
5044 uint16_t GN8:1;
5045 uint16_t GN9:1;
5046 uint16_t GN10:1;
5047 uint16_t GN11:1;
5048 uint16_t GN12:1;
5049 uint16_t GN13:1;
5050 uint16_t GN14:1;
5051 uint16_t GN15:1;
5052 } B;
5053 } CP0NTF;
5054
5055 uint16_t sema4_reserved4[3]; /* {0x88-0x82}/2 = 0x03 */
5056
5057 union {
5058 uint16_t R;
5059 struct {
5060 uint16_t GN0:1;
5061 uint16_t GN1:1;
5062 uint16_t GN2:1;
5063 uint16_t GN3:1;
5064 uint16_t GN4:1;
5065 uint16_t GN5:1;
5066 uint16_t GN6:1;
5067 uint16_t GN7:1;
5068 uint16_t GN8:1;
5069 uint16_t GN9:1;
5070 uint16_t GN10:1;
5071 uint16_t GN11:1;
5072 uint16_t GN12:1;
5073 uint16_t GN13:1;
5074 uint16_t GN14:1;
5075 uint16_t GN15:1;
5076 } B;
5077 } CP1NTF;
5078
5079 uint16_t sema4_reserved5[59]; /* {0x100-0x8A}/2 = 0x3B */
5080
5081 union {
5082 uint16_t R;
5083 struct {
5084 uint16_t:2;
5085 uint16_t RSTGSM:2;
5086 uint16_t:1;
5087 uint16_t RSTGMS:3;
5088 uint16_t RSTGTN:8;
5089 } B;
5090 } RSTGT;
5091
5092 uint16_t sema4_reserved6;
5093
5094 union {
5095 uint16_t R;
5096 struct {
5097 uint16_t:2;
5098 uint16_t RSTNSM:2;
5099 uint16_t:1;
5100 uint16_t RSTNMS:3;
5101 uint16_t RSTNTN:8;
5102 } B;
5103 } RSTNTF;
5104 };
5105/*************************************************************************/
5106/* MODULE : SIU */
5107/*************************************************************************/
5108 struct SIU_tag {
5109
5110 int32_t SIU_reserved0;
5111
5112 union {
5113 uint32_t R;
5114 struct {
5115 uint32_t PARTNUM:16;
5116 uint32_t CSP:1;
5117 uint32_t PKG:5;
5118 uint32_t:2;
5119 uint32_t MASKNUM_MAJOR:4;
5120 uint32_t MASKNUM_MINOR:4;
5121 } B;
5122 } MIDR; /* MCU ID Register */
5123
5124 int32_t SIU_reserved1;
5125
5126 union {
5127 uint32_t R;
5128 struct {
5129 uint32_t PORS:1;
5130 uint32_t ERS:1;
5131 uint32_t LLRS:1;
5132 uint32_t LCRS:1;
5133 uint32_t WDRS:1;
5134 uint32_t CRS:1;
5135 uint32_t:8;
5136 uint32_t SSRS:1;
5137 uint32_t:15;
5138 uint32_t BOOTCFG:1;
5139 uint32_t:1;
5140 } B;
5141 } RSR; /* Reset Status Register */
5142
5143 union {
5144 uint32_t R;
5145 struct {
5146 uint32_t SSR:1;
5147 uint32_t:15;
5148 uint32_t CRE0:1;
5149 uint32_t CRE1:1;
5150 uint32_t:6;
5151 uint32_t SSRL:1;
5152 uint32_t:7;
5153 } B;
5154 } SRCR; /* System Reset Control Register */
5155
5156 union {
5157 uint32_t R;
5158 struct {
5159 uint32_t NMI0:1;
5160 uint32_t NMI1:1;
5161 uint32_t:14;
5162 uint32_t EIF15:1;
5163 uint32_t EIF14:1;
5164 uint32_t EIF13:1;
5165 uint32_t EIF12:1;
5166 uint32_t EIF11:1;
5167 uint32_t EIF10:1;
5168 uint32_t EIF9:1;
5169 uint32_t EIF8:1;
5170 uint32_t EIF7:1;
5171 uint32_t EIF6:1;
5172 uint32_t EIF5:1;
5173 uint32_t EIF4:1;
5174 uint32_t EIF3:1;
5175 uint32_t EIF2:1;
5176 uint32_t EIF1:1;
5177 uint32_t EIF0:1;
5178 } B;
5179 } EISR; /* External Interrupt Status Register */
5180
5181 union SIU_DIRER_tag {
5182 uint32_t R;
5183 struct {
5184 uint32_t:16;
5185 uint32_t EIRE15:1;
5186 uint32_t EIRE14:1;
5187 uint32_t EIRE13:1;
5188 uint32_t EIRE12:1;
5189 uint32_t EIRE11:1;
5190 uint32_t EIRE10:1;
5191 uint32_t EIRE9:1;
5192 uint32_t EIRE8:1;
5193 uint32_t EIRE7:1;
5194 uint32_t EIRE6:1;
5195 uint32_t EIRE5:1;
5196 uint32_t EIRE4:1;
5197 uint32_t EIRE3:1;
5198 uint32_t EIRE2:1;
5199 uint32_t EIRE1:1;
5200 uint32_t EIRE0:1;
5201 } B;
5202 } DIRER; /* DMA/Interrupt Request Enable Register */
5203
5204 union SIU_DIRSR_tag {
5205 uint32_t R;
5206 struct {
5207 uint32_t:30;
5208 uint32_t DIRS1:1;
5209 uint32_t DIRS0:1;
5210 } B;
5211 } DIRSR; /* DMA/Interrupt Select Register */
5212
5213 union {
5214 uint32_t R;
5215 struct {
5216 uint32_t:16;
5217 uint32_t OVF15:1;
5218 uint32_t OVF14:1;
5219 uint32_t OVF13:1;
5220 uint32_t OVF12:1;
5221 uint32_t OVF11:1;
5222 uint32_t OVF10:1;
5223 uint32_t OVF9:1;
5224 uint32_t OVF8:1;
5225 uint32_t OVF7:1;
5226 uint32_t OVF6:1;
5227 uint32_t OVF5:1;
5228 uint32_t OVF4:1;
5229 uint32_t OVF3:1;
5230 uint32_t OVF2:1;
5231 uint32_t OVF1:1;
5232 uint32_t OVF0:1;
5233 } B;
5234 } OSR; /* Overrun Status Register */
5235
5236 union SIU_ORER_tag {
5237 uint32_t R;
5238 struct {
5239 uint32_t:16;
5240 uint32_t ORE15:1;
5241 uint32_t ORE14:1;
5242 uint32_t ORE13:1;
5243 uint32_t ORE12:1;
5244 uint32_t ORE11:1;
5245 uint32_t ORE10:1;
5246 uint32_t ORE9:1;
5247 uint32_t ORE8:1;
5248 uint32_t ORE7:1;
5249 uint32_t ORE6:1;
5250 uint32_t ORE5:1;
5251 uint32_t ORE4:1;
5252 uint32_t ORE3:1;
5253 uint32_t ORE2:1;
5254 uint32_t ORE1:1;
5255 uint32_t ORE0:1;
5256 } B;
5257 } ORER; /* Overrun Request Enable Register */
5258
5259 union SIU_IREER_tag {
5260 uint32_t R;
5261 struct {
5262 uint32_t NREE0:1;
5263 uint32_t NREE1:1;
5264 uint32_t:14;
5265 uint32_t IREE15:1;
5266 uint32_t IREE14:1;
5267 uint32_t IREE13:1;
5268 uint32_t IREE12:1;
5269 uint32_t IREE11:1;
5270 uint32_t IREE10:1;
5271 uint32_t IREE9:1;
5272 uint32_t IREE8:1;
5273 uint32_t IREE7:1;
5274 uint32_t IREE6:1;
5275 uint32_t IREE5:1;
5276 uint32_t IREE4:1;
5277 uint32_t IREE3:1;
5278 uint32_t IREE2:1;
5279 uint32_t IREE1:1;
5280 uint32_t IREE0:1;
5281 } B;
5282 } IREER; /* External IRQ Rising-Edge Event Enable Register */
5283
5284 union SIU_IFEER_tag {
5285 uint32_t R;
5286 struct {
5287 uint32_t NFEE0:1;
5288 uint32_t NFEE1:1;
5289 uint32_t:14;
5290 uint32_t IFEE15:1;
5291 uint32_t IFEE14:1;
5292 uint32_t IFEE13:1;
5293 uint32_t IFEE12:1;
5294 uint32_t IFEE11:1;
5295 uint32_t IFEE10:1;
5296 uint32_t IFEE9:1;
5297 uint32_t IFEE8:1;
5298 uint32_t IFEE7:1;
5299 uint32_t IFEE6:1;
5300 uint32_t IFEE5:1;
5301 uint32_t IFEE4:1;
5302 uint32_t IFEE3:1;
5303 uint32_t IFEE2:1;
5304 uint32_t IFEE1:1;
5305 uint32_t IFEE0:1;
5306 } B;
5307 } IFEER; /* External IRQ Falling-Edge Event Enable Register */
5308
5309 union SIU_IDFR_tag {
5310 uint32_t R;
5311 struct {
5312 uint32_t:28;
5313 uint32_t DFL:4;
5314 } B;
5315 } IDFR; /* External IRQ Digital Filter Register */
5316
5317 union {
5318 uint32_t R;
5319 struct {
5320 uint32_t FNMI0:1;
5321 uint32_t FNMI1:1;
5322 uint32_t:14;
5323 uint32_t FI15:1;
5324 uint32_t FI14:1;
5325 uint32_t FI13:1;
5326 uint32_t FI12:1;
5327 uint32_t FI11:1;
5328 uint32_t FI10:1;
5329 uint32_t FI9:1;
5330 uint32_t FI8:1;
5331 uint32_t FI7:1;
5332 uint32_t FI6:1;
5333 uint32_t FI5:1;
5334 uint32_t FI4:1;
5335 uint32_t FI3:1;
5336 uint32_t FI2:1;
5337 uint32_t FI1:1;
5338 uint32_t FI0:1;
5339 } B;
5340 } IFIR; /* External IRQ Filtered Input Register */
5341
5342 int32_t SIU_reserved2[2];
5343
5344 union SIU_PCR_tag {
5345 uint16_t R;
5346 struct {
5347 uint16_t:4;
5348 uint16_t PA:2;
5349 uint16_t OBE:1;
5350 uint16_t IBE:1;
5351 uint16_t DSC:2;
5352 uint16_t ODE:1;
5353 uint16_t HYS:1;
5354 uint16_t SRC:2;
5355 uint16_t WPE:1;
5356 uint16_t WPS:1;
5357 } B;
5358 } PCR[155]; /* Pad Configuration Registers */
5359
5360 int32_t SIU_reserved3[290];
5361
5362 union {
5363 uint8_t R;
5364 struct {
5365 uint8_t:7;
5366 uint8_t PDO:1;
5367 } B;
5368 } GPDO[155]; /* GPIO Pin Data Output Registers */
5369
5370 int8_t SIU_reserved4[357];
5371
5372 union {
5373 uint8_t R;
5374 struct {
5375 uint8_t:7;
5376 uint8_t PDI:1;
5377 } B;
5378 } GPDI[155]; /* GPIO Pin Data Input Registers */
5379
5380 int32_t SIU_reserved5[26];
5381
5382 union {
5383 uint32_t R;
5384 struct {
5385 uint32_t ESEL15:2;
5386 uint32_t ESEL14:2;
5387 uint32_t ESEL13:2;
5388 uint32_t ESEL12:2;
5389 uint32_t ESEL11:2;
5390 uint32_t ESEL10:2;
5391 uint32_t ESEL9:2;
5392 uint32_t ESEL8:2;
5393 uint32_t ESEL7:2;
5394 uint32_t ESEL6:2;
5395 uint32_t ESEL5:2;
5396 uint32_t ESEL4:2;
5397 uint32_t ESEL3:2;
5398 uint32_t ESEL2:2;
5399 uint32_t ESEL1:2;
5400 uint32_t ESEL0:2;
5401 } B;
5402 } ISEL1; /* IMUX Register */
5403
5404 union {
5405 uint32_t R;
5406 struct {
5407 uint32_t ESEL15:2;
5408 uint32_t ESEL14:2;
5409 uint32_t ESEL13:2;
5410 uint32_t ESEL12:2;
5411 uint32_t ESEL11:2;
5412 uint32_t ESEL10:2;
5413 uint32_t ESEL9:2;
5414 uint32_t ESEL8:2;
5415 uint32_t ESEL7:2;
5416 uint32_t ESEL6:2;
5417 uint32_t ESEL5:2;
5418 uint32_t ESEL4:2;
5419 uint32_t ESEL3:2;
5420 uint32_t ESEL2:2;
5421 uint32_t ESEL1:2;
5422 uint32_t ESEL0:2;
5423 } B;
5424 } ISEL2; /* IMUX Register */
5425
5426 int32_t SIU_reserved6;
5427
5428 union {
5429 uint32_t R;
5430 struct {
5431 uint32_t:17;
5432 uint32_t TSEL1:7;
5433 uint32_t:1;
5434 uint32_t TSEL0:7;
5435 } B;
5436 } ISEL4; /* IMUX Register */
5437
5438 int32_t SIU_reserved7[27];
5439
5440 union {
5441 uint32_t R;
5442 struct {
5443 uint32_t:14;
5444 uint32_t MATCH:1;
5445 uint32_t DISNEX:1;
5446 uint32_t:8;
5447 uint32_t TESTLOCK:1;
5448 uint32_t:7;
5449 } B;
5450 } CCR; /* Chip Configuration Register Register */
5451
5452 union {
5453 uint32_t R;
5454 struct {
5455 uint32_t:28;
5456 uint32_t ECEN:1;
5457 uint32_t:1;
5458 uint32_t ECDF:2;
5459 } B;
5460 } ECCR; /* External Clock Configuration Register Register */
5461
5462 union {
5463 uint32_t R;
5464 } GPR0; /* General Purpose Register 0 */
5465
5466 union {
5467 uint32_t R;
5468 } GPR1; /* General Purpose Register 1 */
5469
5470 union {
5471 uint32_t R;
5472 } GPR2; /* General Purpose Register 2 */
5473
5474 union {
5475 uint32_t R;
5476 } GPR3; /* General Purpose Register 3 */
5477
5478 int32_t SIU_reserved8[2];
5479
5480 union {
5481 uint32_t R;
5482 struct {
5483 uint32_t SYSCLKSEL:2;
5484 uint32_t SYSCLKDIV:3;
5485 uint32_t:19;
5486 uint32_t LPCLKDIV3:2;
5487 uint32_t LPCLKDIV2:2;
5488 uint32_t LPCLKDIV1:2;
5489 uint32_t LPCLKDIV0:2;
5490 } B;
5491 } SYSCLK; /* System CLock Register */
5492
5493 union {
5494 uint32_t R;
5495 struct {
5496 uint32_t:6;
5497 uint32_t HLT6:1;
5498 uint32_t HLT7:1;
5499 uint32_t:1;
5500 uint32_t HLT9:1;
5501 uint32_t HLT10:1;
5502 uint32_t HLT11:1;
5503 uint32_t HLT12:1;
5504 uint32_t HLT13:1;
5505 uint32_t HLT14:1;
5506 uint32_t HLT15:1;
5507 uint32_t HLT16:1;
5508 uint32_t HLT17:1;
5509 uint32_t HLT18:1;
5510 uint32_t HLT19:1;
5511 uint32_t HLT20:1;
5512 uint32_t HLT21:1;
5513 uint32_t HLT22:1;
5514 uint32_t HLT23:1;
5515 uint32_t:2;
5516 uint32_t HLT26:1;
5517 uint32_t HLT27:1;
5518 uint32_t HLT28:1;
5519 uint32_t HLT29:1;
5520 uint32_t:1;
5521 uint32_t HLT31:1;
5522 } B;
5523 } HLT0; /* Halt Register 0 */
5524
5525 union {
5526 uint32_t R;
5527 struct {
5528 uint32_t:3;
5529 uint32_t HLT3:1;
5530 uint32_t HLT4:1;
5531 uint32_t:15;
5532 uint32_t HLT20:1;
5533 uint32_t HLT21:1;
5534 uint32_t HLT22:1;
5535 uint32_t HLT23:1;
5536 uint32_t:2;
5537 uint32_t HLT26:1;
5538 uint32_t HLT27:1;
5539 uint32_t HLT28:1;
5540 uint32_t HLT29:1;
5541 uint32_t:2;
5542 } B;
5543 } HLT1; /* Halt Register 1 */
5544
5545 union {
5546 uint32_t R;
5547 struct {
5548 uint32_t:6;
5549 uint32_t HLTACK6:1;
5550 uint32_t HLTACK7:1;
5551 uint32_t:1;
5552 uint32_t HLTACK9:1;
5553 uint32_t HLTACK10:1;
5554 uint32_t HLTACK11:1;
5555 uint32_t HLTACK12:1;
5556 uint32_t HLTACK13:1;
5557 uint32_t HLTACK14:1;
5558 uint32_t HLTACK15:1;
5559 uint32_t HLTACK16:1;
5560 uint32_t HLTACK17:1;
5561 uint32_t HLTACK18:1;
5562 uint32_t HLTACK19:1;
5563 uint32_t HLTACK20:1;
5564 uint32_t HLTACK21:1;
5565 uint32_t HLTACK22:1;
5566 uint32_t HLTACK23:1;
5567 uint32_t:2;
5568 uint32_t HLTACK26:1;
5569 uint32_t HLTACK27:1;
5570 uint32_t HLTACK28:1;
5571 uint32_t HLTACK29:1;
5572 uint32_t:1;
5573 uint32_t HLTACK31:1;
5574 } B;
5575 } HLTACK0; /* Halt Acknowledge Register 0 */
5576
5577 union {
5578 uint32_t R;
5579 struct {
5580 uint32_t HLTACK0:1;
5581 uint32_t HLTACK1:1;
5582 uint32_t:1;
5583 uint32_t HLTACK3:1;
5584 uint32_t HLTACK4:1;
5585 uint32_t:11;
5586 uint32_t HLTACK20:1;
5587 uint32_t HLTACK21:1;
5588 uint32_t HLTACK22:1;
5589 uint32_t HLTACK23:1;
5590 uint32_t:2;
5591 uint32_t HLTACK26:1;
5592 uint32_t HLTACK27:1;
5593 uint32_t HLTACK28:1;
5594 uint32_t HLTACK29:1;
5595 uint32_t:2;
5596 } B;
5597 } HLTACK1; /* Halt Acknowledge Register 0 */
5598
5599 union {
5600 uint32_t R;
5601 struct {
5602 uint32_t EMIOSSEL31:4;
5603 uint32_t EMIOSSEL30:4;
5604 uint32_t EMIOSSEL29:4;
5605 uint32_t EMIOSSEL28:4;
5606 uint32_t EMIOSSEL27:4;
5607 uint32_t EMIOSSEL26:4;
5608 uint32_t EMIOSSEL25:4;
5609 uint32_t EMIOSSEL24:4;
5610 } B;
5611 } EMIOS_SEL0; /* eMIOS Select Register 0 */
5612
5613 union {
5614 uint32_t R;
5615 struct {
5616 uint32_t EMIOSSEL23:4;
5617 uint32_t EMIOSSEL22:4;
5618 uint32_t EMIOSSEL21:4;
5619 uint32_t EMIOSSEL20:4;
5620 uint32_t EMIOSSEL19:4;
5621 uint32_t EMIOSSEL18:4;
5622 uint32_t EMIOSSEL17:4;
5623 uint32_t EMIOSSEL16:4;
5624 } B;
5625 } EMIOS_SEL1; /* eMIOS Select Register 1 */
5626
5627 union {
5628 uint32_t R;
5629 struct {
5630 uint32_t EMIOSSEL15:4;
5631 uint32_t EMIOSSEL14:4;
5632 uint32_t EMIOSSEL13:4;
5633 uint32_t EMIOSSEL12:4;
5634 uint32_t EMIOSSEL11:4;
5635 uint32_t EMIOSSEL10:4;
5636 uint32_t EMIOSSEL9:4;
5637 uint32_t EMIOSSEL8:4;
5638 } B;
5639 } EMIOS_SEL2; /* eMIOS Select Register 2 */
5640
5641 union {
5642 uint32_t R;
5643 struct {
5644 uint32_t EMIOSSEL7:4;
5645 uint32_t EMIOSSEL6:4;
5646 uint32_t EMIOSSEL5:4;
5647 uint32_t EMIOSSEL4:4;
5648 uint32_t EMIOSSEL3:4;
5649 uint32_t EMIOSSEL2:4;
5650 uint32_t EMIOSSEL1:4;
5651 uint32_t EMIOSSEL0:4;
5652 } B;
5653 } EMIOS_SEL3; /* eMIOS Select Register 3 */
5654
5655 union {
5656 uint32_t R;
5657 struct {
5658 uint32_t ESEL15:2;
5659 uint32_t ESEL14:2;
5660 uint32_t ESEL13:2;
5661 uint32_t ESEL12:2;
5662 uint32_t ESEL11:2;
5663 uint32_t ESEL10:2;
5664 uint32_t ESEL9:2;
5665 uint32_t ESEL8:2;
5666 uint32_t ESEL7:2;
5667 uint32_t ESEL6:2;
5668 uint32_t ESEL5:2;
5669 uint32_t ESEL4:2;
5670 uint32_t ESEL3:2;
5671 uint32_t ESEL2:2;
5672 uint32_t ESEL1:2;
5673 uint32_t ESEL0:2;
5674 } B;
5675 } ISEL2A; /* External Interrupt Select Register 2A */
5676
5677 int32_t SIU_reserved9[142];
5678
5679 union {
5680 uint32_t R;
5681 struct {
5682 uint32_t:16;
5683 uint32_t PB:16;
5684 } B;
5685 } PGPDO0; /* Parallel GPIO Pin Data Output Register */
5686
5687 union {
5688 uint32_t R;
5689 struct {
5690 uint32_t PC:16;
5691 uint32_t PD:16;
5692 } B;
5693 } PGPDO1; /* Parallel GPIO Pin Data Output Register */
5694
5695 union {
5696 uint32_t R;
5697 struct {
5698 uint32_t PE:16;
5699 uint32_t PF:16;
5700 } B;
5701 } PGPDO2; /* Parallel GPIO Pin Data Output Register */
5702
5703 union {
5704 uint32_t R;
5705 struct {
5706 uint32_t PG:16;
5707 uint32_t PH:16;
5708 } B;
5709 } PGPDO3; /* Parallel GPIO Pin Data Output Register */
5710
5711 union {
5712 uint32_t R;
5713 struct {
5714 uint32_t PJ:16;
5715 uint32_t PK:11;
5716 uint32_t:5;
5717 } B;
5718 } PGPDO4; /* Parallel GPIO Pin Data Output Register */
5719
5720 int32_t SIU_reserved10[11];
5721
5722 union {
5723 uint32_t R;
5724 struct {
5725 uint32_t PA:16;
5726 uint32_t PB:16;
5727 } B;
5728 } PGPDI0; /* Parallel GPIO Pin Data Input Register */
5729
5730 union {
5731 uint32_t R;
5732 struct {
5733 uint32_t PC:16;
5734 uint32_t PD:16;
5735 } B;
5736 } PGPDI1; /* Parallel GPIO Pin Data Input Register */
5737
5738 union {
5739 uint32_t R;
5740 struct {
5741 uint32_t PE:16;
5742 uint32_t PF:16;
5743 } B;
5744 } PGPDI2; /* Parallel GPIO Pin Data Input Register */
5745
5746 union {
5747 uint32_t R;
5748 struct {
5749 uint32_t PG:16;
5750 uint32_t PH:16;
5751 } B;
5752 } PGPDI3; /* Parallel GPIO Pin Data Input Register */
5753
5754 union {
5755 uint32_t R;
5756 struct {
5757 uint32_t PJ:16;
5758 uint32_t PK:11;
5759 uint32_t:5;
5760 } B;
5761 } PGPDI4; /* Parallel GPIO Pin Data Input Register */
5762
5763 int32_t SIU_reserved11[12];
5764
5765 union {
5766 uint32_t R;
5767 struct {
5768 uint32_t PB_MASK:16;
5769 uint32_t PB:16;
5770 } B;
5771 } MPGPDO1; /* Masked Parallel GPIO Pin Data Input Register */
5772
5773 union {
5774 uint32_t R;
5775 struct {
5776 uint32_t PC_MASK:16;
5777 uint32_t PC:16;
5778 } B;
5779 } MPGPDO2; /* Masked Parallel GPIO Pin Data Input Register */
5780
5781 union {
5782 uint32_t R;
5783 struct {
5784 uint32_t PD_MASK:16;
5785 uint32_t PD:16;
5786 } B;
5787 } MPGPDO3; /* Masked Parallel GPIO Pin Data Input Register */
5788
5789 union {
5790 uint32_t R;
5791 struct {
5792 uint32_t PE_MASK:16;
5793 uint32_t PE:16;
5794 } B;
5795 } MPGPDO4; /* Masked Parallel GPIO Pin Data Input Register */
5796
5797 union {
5798 uint32_t R;
5799 struct {
5800 uint32_t PF_MASK:16;
5801 uint32_t PF:16;
5802 } B;
5803 } MPGPDO5; /* Masked Parallel GPIO Pin Data Input Register */
5804
5805 union {
5806 uint32_t R;
5807 struct {
5808 uint32_t PG_MASK:16;
5809 uint32_t PG:16;
5810 } B;
5811 } MPGPDO6; /* Masked Parallel GPIO Pin Data Input Register */
5812
5813 union {
5814 uint32_t R;
5815 struct {
5816 uint32_t PH_MASK:16;
5817 uint32_t PH:16;
5818 } B;
5819 } MPGPDO7; /* Masked Parallel GPIO Pin Data Input Register */
5820
5821 union {
5822 uint32_t R;
5823 struct {
5824 uint32_t PJ_MASK:16;
5825 uint32_t PJ:16;
5826 } B;
5827 } MPGPDO8; /* Masked Parallel GPIO Pin Data Input Register */
5828
5829 union {
5830 uint32_t R;
5831 struct {
5832 uint32_t PK_MASK:11;
5833 uint32_t:5;
5834 uint32_t PK:11;
5835 uint32_t:5;
5836 } B;
5837 } MPGPDO9; /* Masked Parallel GPIO Pin Data Input Register */
5838
5839 int32_t SIU_reserved12[22];
5840
5841 union {
5842 uint32_t R;
5843 struct {
5844 uint32_t MASK31:1;
5845 uint32_t MASK30:1;
5846 uint32_t MASK29:1;
5847 uint32_t MASK28:1;
5848 uint32_t MASK27:1;
5849 uint32_t MASK26:1;
5850 uint32_t MASK25:1;
5851 uint32_t MASK24:1;
5852 uint32_t MASK23:1;
5853 uint32_t MASK22:1;
5854 uint32_t MASK21:1;
5855 uint32_t MASK20:1;
5856 uint32_t MASK19:1;
5857 uint32_t MASK18:1;
5858 uint32_t MASK17:1;
5859 uint32_t MASK16:1;
5860 uint32_t DATA31:1;
5861 uint32_t DATA30:1;
5862 uint32_t DATA29:1;
5863 uint32_t DATA28:1;
5864 uint32_t DATA27:1;
5865 uint32_t DATA26:1;
5866 uint32_t DATA25:1;
5867 uint32_t DATA24:1;
5868 uint32_t DATA23:1;
5869 uint32_t DATA22:1;
5870 uint32_t DATA21:1;
5871 uint32_t DATA20:1;
5872 uint32_t DATA19:1;
5873 uint32_t DATA18:1;
5874 uint32_t DATA17:1;
5875 uint32_t DATA16:1;
5876 } B;
5877 } DSPIAH; /* Masked Serial GPO for DSPI_A High Register */
5878
5879 union {
5880 uint32_t R;
5881 struct {
5882 uint32_t MASK15:1;
5883 uint32_t MASK14:1;
5884 uint32_t MASK13:1;
5885 uint32_t MASK12:1;
5886 uint32_t MASK11:1;
5887 uint32_t MASK10:1;
5888 uint32_t MASK9:1;
5889 uint32_t MASK8:1;
5890 uint32_t MASK7:1;
5891 uint32_t MASK6:1;
5892 uint32_t MASK5:1;
5893 uint32_t MASK4:1;
5894 uint32_t MASK3:1;
5895 uint32_t MASK2:1;
5896 uint32_t MASK1:1;
5897 uint32_t MASK0:1;
5898 uint32_t DATA15:1;
5899 uint32_t DATA14:1;
5900 uint32_t DATA13:1;
5901 uint32_t DATA12:1;
5902 uint32_t DATA11:1;
5903 uint32_t DATA10:1;
5904 uint32_t DATA9:1;
5905 uint32_t DATA8:1;
5906 uint32_t DATA7:1;
5907 uint32_t DATA6:1;
5908 uint32_t DATA5:1;
5909 uint32_t DATA4:1;
5910 uint32_t DATA3:1;
5911 uint32_t DATA2:1;
5912 uint32_t DATA1:1;
5913 uint32_t DATA0:1;
5914 } B;
5915 } DSPIAL; /* Masked Serial GPO for DSPI_A Low Register */
5916
5917 union {
5918 uint32_t R;
5919 struct {
5920 uint32_t MASK31:1;
5921 uint32_t MASK30:1;
5922 uint32_t MASK29:1;
5923 uint32_t MASK28:1;
5924 uint32_t MASK27:1;
5925 uint32_t MASK26:1;
5926 uint32_t MASK25:1;
5927 uint32_t MASK24:1;
5928 uint32_t MASK23:1;
5929 uint32_t MASK22:1;
5930 uint32_t MASK21:1;
5931 uint32_t MASK20:1;
5932 uint32_t MASK19:1;
5933 uint32_t MASK18:1;
5934 uint32_t MASK17:1;
5935 uint32_t MASK16:1;
5936 uint32_t DATA31:1;
5937 uint32_t DATA30:1;
5938 uint32_t DATA29:1;
5939 uint32_t DATA28:1;
5940 uint32_t DATA27:1;
5941 uint32_t DATA26:1;
5942 uint32_t DATA25:1;
5943 uint32_t DATA24:1;
5944 uint32_t DATA23:1;
5945 uint32_t DATA22:1;
5946 uint32_t DATA21:1;
5947 uint32_t DATA20:1;
5948 uint32_t DATA19:1;
5949 uint32_t DATA18:1;
5950 uint32_t DATA17:1;
5951 uint32_t DATA16:1;
5952 } B;
5953 } DSPIBH; /* Masked Serial GPO for DSPI_B High Register */
5954
5955 union {
5956 uint32_t R;
5957 struct {
5958 uint32_t MASK15:1;
5959 uint32_t MASK14:1;
5960 uint32_t MASK13:1;
5961 uint32_t MASK12:1;
5962 uint32_t MASK11:1;
5963 uint32_t MASK10:1;
5964 uint32_t MASK9:1;
5965 uint32_t MASK8:1;
5966 uint32_t MASK7:1;
5967 uint32_t MASK6:1;
5968 uint32_t MASK5:1;
5969 uint32_t MASK4:1;
5970 uint32_t MASK3:1;
5971 uint32_t MASK2:1;
5972 uint32_t MASK1:1;
5973 uint32_t MASK0:1;
5974 uint32_t DATA15:1;
5975 uint32_t DATA14:1;
5976 uint32_t DATA13:1;
5977 uint32_t DATA12:1;
5978 uint32_t DATA11:1;
5979 uint32_t DATA10:1;
5980 uint32_t DATA9:1;
5981 uint32_t DATA8:1;
5982 uint32_t DATA7:1;
5983 uint32_t DATA6:1;
5984 uint32_t DATA5:1;
5985 uint32_t DATA4:1;
5986 uint32_t DATA3:1;
5987 uint32_t DATA2:1;
5988 uint32_t DATA1:1;
5989 uint32_t DATA0:1;
5990 } B;
5991 } DSPIBL; /* Masked Serial GPO for DSPI_B Low Register */
5992
5993 union {
5994 uint32_t R;
5995 struct {
5996 uint32_t MASK31:1;
5997 uint32_t MASK30:1;
5998 uint32_t MASK29:1;
5999 uint32_t MASK28:1;
6000 uint32_t MASK27:1;
6001 uint32_t MASK26:1;
6002 uint32_t MASK25:1;
6003 uint32_t MASK24:1;
6004 uint32_t MASK23:1;
6005 uint32_t MASK22:1;
6006 uint32_t MASK21:1;
6007 uint32_t MASK20:1;
6008 uint32_t MASK19:1;
6009 uint32_t MASK18:1;
6010 uint32_t MASK17:1;
6011 uint32_t MASK16:1;
6012 uint32_t DATA31:1;
6013 uint32_t DATA30:1;
6014 uint32_t DATA29:1;
6015 uint32_t DATA28:1;
6016 uint32_t DATA27:1;
6017 uint32_t DATA26:1;
6018 uint32_t DATA25:1;
6019 uint32_t DATA24:1;
6020 uint32_t DATA23:1;
6021 uint32_t DATA22:1;
6022 uint32_t DATA21:1;
6023 uint32_t DATA20:1;
6024 uint32_t DATA19:1;
6025 uint32_t DATA18:1;
6026 uint32_t DATA17:1;
6027 uint32_t DATA16:1;
6028 } B;
6029 } DSPICH; /* Masked Serial GPO for DSPI_C High Register */
6030
6031 union {
6032 uint32_t R;
6033 struct {
6034 uint32_t MASK15:1;
6035 uint32_t MASK14:1;
6036 uint32_t MASK13:1;
6037 uint32_t MASK12:1;
6038 uint32_t MASK11:1;
6039 uint32_t MASK10:1;
6040 uint32_t MASK9:1;
6041 uint32_t MASK8:1;
6042 uint32_t MASK7:1;
6043 uint32_t MASK6:1;
6044 uint32_t MASK5:1;
6045 uint32_t MASK4:1;
6046 uint32_t MASK3:1;
6047 uint32_t MASK2:1;
6048 uint32_t MASK1:1;
6049 uint32_t MASK0:1;
6050 uint32_t DATA15:1;
6051 uint32_t DATA14:1;
6052 uint32_t DATA13:1;
6053 uint32_t DATA12:1;
6054 uint32_t DATA11:1;
6055 uint32_t DATA10:1;
6056 uint32_t DATA9:1;
6057 uint32_t DATA8:1;
6058 uint32_t DATA7:1;
6059 uint32_t DATA6:1;
6060 uint32_t DATA5:1;
6061 uint32_t DATA4:1;
6062 uint32_t DATA3:1;
6063 uint32_t DATA2:1;
6064 uint32_t DATA1:1;
6065 uint32_t DATA0:1;
6066 } B;
6067 } DSPICL; /* Masked Serial GPO for DSPI_C Low Register */
6068
6069 union {
6070 uint32_t R;
6071 struct {
6072 uint32_t MASK31:1;
6073 uint32_t MASK30:1;
6074 uint32_t MASK29:1;
6075 uint32_t MASK28:1;
6076 uint32_t MASK27:1;
6077 uint32_t MASK26:1;
6078 uint32_t MASK25:1;
6079 uint32_t MASK24:1;
6080 uint32_t MASK23:1;
6081 uint32_t MASK22:1;
6082 uint32_t MASK21:1;
6083 uint32_t MASK20:1;
6084 uint32_t MASK19:1;
6085 uint32_t MASK18:1;
6086 uint32_t MASK17:1;
6087 uint32_t MASK16:1;
6088 uint32_t DATA31:1;
6089 uint32_t DATA30:1;
6090 uint32_t DATA29:1;
6091 uint32_t DATA28:1;
6092 uint32_t DATA27:1;
6093 uint32_t DATA26:1;
6094 uint32_t DATA25:1;
6095 uint32_t DATA24:1;
6096 uint32_t DATA23:1;
6097 uint32_t DATA22:1;
6098 uint32_t DATA21:1;
6099 uint32_t DATA20:1;
6100 uint32_t DATA19:1;
6101 uint32_t DATA18:1;
6102 uint32_t DATA17:1;
6103 uint32_t DATA16:1;
6104 } B;
6105 } DSPIDH; /* Masked Serial GPO for DSPI_D High Register */
6106
6107 union {
6108 uint32_t R;
6109 struct {
6110 uint32_t MASK15:1;
6111 uint32_t MASK14:1;
6112 uint32_t MASK13:1;
6113 uint32_t MASK12:1;
6114 uint32_t MASK11:1;
6115 uint32_t MASK10:1;
6116 uint32_t MASK9:1;
6117 uint32_t MASK8:1;
6118 uint32_t MASK7:1;
6119 uint32_t MASK6:1;
6120 uint32_t MASK5:1;
6121 uint32_t MASK4:1;
6122 uint32_t MASK3:1;
6123 uint32_t MASK2:1;
6124 uint32_t MASK1:1;
6125 uint32_t MASK0:1;
6126 uint32_t DATA15:1;
6127 uint32_t DATA14:1;
6128 uint32_t DATA13:1;
6129 uint32_t DATA12:1;
6130 uint32_t DATA11:1;
6131 uint32_t DATA10:1;
6132 uint32_t DATA9:1;
6133 uint32_t DATA8:1;
6134 uint32_t DATA7:1;
6135 uint32_t DATA6:1;
6136 uint32_t DATA5:1;
6137 uint32_t DATA4:1;
6138 uint32_t DATA3:1;
6139 uint32_t DATA2:1;
6140 uint32_t DATA1:1;
6141 uint32_t DATA0:1;
6142 } B;
6143 } DSPIDL; /* Masked Serial GPO for DSPI_D Low Register */
6144
6145 int32_t SIU_reserved13[9];
6146
6147 union {
6148 uint32_t R;
6149 struct {
6150 uint32_t EMIOS31:1;
6151 uint32_t EMIOS30:1;
6152 uint32_t EMIOS29:1;
6153 uint32_t EMIOS28:1;
6154 uint32_t EMIOS27:1;
6155 uint32_t EMIOS26:1;
6156 uint32_t EMIOS25:1;
6157 uint32_t EMIOS24:1;
6158 uint32_t EMIOS23:1;
6159 uint32_t EMIOS22:1;
6160 uint32_t EMIOS21:1;
6161 uint32_t EMIOS20:1;
6162 uint32_t EMIOS19:1;
6163 uint32_t EMIOS18:1;
6164 uint32_t EMIOS17:1;
6165 uint32_t EMIOS16:1;
6166 uint32_t EMIOS15:1;
6167 uint32_t EMIOS14:1;
6168 uint32_t EMIOS13:1;
6169 uint32_t EMIOS12:1;
6170 uint32_t EMIOS11:1;
6171 uint32_t EMIOS10:1;
6172 uint32_t EMIOS9:1;
6173 uint32_t EMIOS8:1;
6174 uint32_t EMIOS7:1;
6175 uint32_t EMIOS6:1;
6176 uint32_t EMIOS5:1;
6177 uint32_t EMIOS4:1;
6178 uint32_t EMIOS3:1;
6179 uint32_t EMIOS2:1;
6180 uint32_t EMIOS1:1;
6181 uint32_t EMIOS0:1;
6182 } B;
6183 } EMIOSA; /* EMIOS A Select Register */
6184
6185 union {
6186 uint32_t R;
6187 struct {
6188 uint32_t DSPIAH31:1;
6189 uint32_t DSPIAH30:1;
6190 uint32_t DSPIAH29:1;
6191 uint32_t DSPIAH28:1;
6192 uint32_t DSPIAH27:1;
6193 uint32_t DSPIAH26:1;
6194 uint32_t DSPIAH25:1;
6195 uint32_t DSPIAH24:1;
6196 uint32_t DSPIAH23:1;
6197 uint32_t DSPIAH22:1;
6198 uint32_t DSPIAH21:1;
6199 uint32_t DSPIAH20:1;
6200 uint32_t DSPIAH19:1;
6201 uint32_t DSPIAH18:1;
6202 uint32_t DSPIAH17:1;
6203 uint32_t DSPIAH16:1;
6204 uint32_t DSPIAL15:1;
6205 uint32_t DSPIAL14:1;
6206 uint32_t DSPIAL13:1;
6207 uint32_t DSPIAL12:1;
6208 uint32_t DSPIAL11:1;
6209 uint32_t DSPIAL10:1;
6210 uint32_t DSPIAL9:1;
6211 uint32_t DSPIAL8:1;
6212 uint32_t DSPIAL7:1;
6213 uint32_t DSPIAL6:1;
6214 uint32_t DSPIAL5:1;
6215 uint32_t DSPIAL4:1;
6216 uint32_t DSPIAL3:1;
6217 uint32_t DSPIAL2:1;
6218 uint32_t DSPIAL1:1;
6219 uint32_t DSPIAL0:1;
6220 } B;
6221 } DSPIAHLA; /* DSPIAH/L Select Register for DSPI A */
6222
6223 int32_t SIU_reserved14[2];
6224
6225 union {
6226 uint32_t R;
6227 struct {
6228 uint32_t EMIOS31:1;
6229 uint32_t EMIOS30:1;
6230 uint32_t EMIOS29:1;
6231 uint32_t EMIOS28:1;
6232 uint32_t EMIOS27:1;
6233 uint32_t EMIOS26:1;
6234 uint32_t EMIOS25:1;
6235 uint32_t EMIOS24:1;
6236 uint32_t EMIOS23:1;
6237 uint32_t EMIOS22:1;
6238 uint32_t EMIOS21:1;
6239 uint32_t EMIOS20:1;
6240 uint32_t EMIOS19:1;
6241 uint32_t EMIOS18:1;
6242 uint32_t EMIOS17:1;
6243 uint32_t EMIOS16:1;
6244 uint32_t EMIOS15:1;
6245 uint32_t EMIOS14:1;
6246 uint32_t EMIOS13:1;
6247 uint32_t EMIOS12:1;
6248 uint32_t EMIOS11:1;
6249 uint32_t EMIOS10:1;
6250 uint32_t EMIOS9:1;
6251 uint32_t EMIOS8:1;
6252 uint32_t EMIOS7:1;
6253 uint32_t EMIOS6:1;
6254 uint32_t EMIOS5:1;
6255 uint32_t EMIOS4:1;
6256 uint32_t EMIOS3:1;
6257 uint32_t EMIOS2:1;
6258 uint32_t EMIOS1:1;
6259 uint32_t EMIOS0:1;
6260 } B;
6261 } EMIOSB; /* EMIOS B Select Register */
6262
6263 union {
6264 uint32_t R;
6265 struct {
6266 uint32_t DSPIBH31:1;
6267 uint32_t DSPIBH30:1;
6268 uint32_t DSPIBH29:1;
6269 uint32_t DSPIBH28:1;
6270 uint32_t DSPIBH27:1;
6271 uint32_t DSPIBH26:1;
6272 uint32_t DSPIBH25:1;
6273 uint32_t DSPIBH24:1;
6274 uint32_t DSPIBH23:1;
6275 uint32_t DSPIBH22:1;
6276 uint32_t DSPIBH21:1;
6277 uint32_t DSPIBH20:1;
6278 uint32_t DSPIBH19:1;
6279 uint32_t DSPIBH18:1;
6280 uint32_t DSPIBH17:1;
6281 uint32_t DSPIBH16:1;
6282 uint32_t DSPIBL15:1;
6283 uint32_t DSPIBL14:1;
6284 uint32_t DSPIBL13:1;
6285 uint32_t DSPIBL12:1;
6286 uint32_t DSPIBL11:1;
6287 uint32_t DSPIBL10:1;
6288 uint32_t DSPIBL9:1;
6289 uint32_t DSPIBL8:1;
6290 uint32_t DSPIBL7:1;
6291 uint32_t DSPIBL6:1;
6292 uint32_t DSPIBL5:1;
6293 uint32_t DSPIBL4:1;
6294 uint32_t DSPIBL3:1;
6295 uint32_t DSPIBL2:1;
6296 uint32_t DSPIBL1:1;
6297 uint32_t DSPIBL0:1;
6298 } B;
6299 } DSPIBHLB; /* DSPIBH/L Select Register for DSPI B */
6300
6301 int32_t SIU_reserved115[2];
6302
6303 union {
6304 uint32_t R;
6305 struct {
6306 uint32_t EMIOS31:1;
6307 uint32_t EMIOS30:1;
6308 uint32_t EMIOS29:1;
6309 uint32_t EMIOS28:1;
6310 uint32_t EMIOS27:1;
6311 uint32_t EMIOS26:1;
6312 uint32_t EMIOS25:1;
6313 uint32_t EMIOS24:1;
6314 uint32_t EMIOS23:1;
6315 uint32_t EMIOS22:1;
6316 uint32_t EMIOS21:1;
6317 uint32_t EMIOS20:1;
6318 uint32_t EMIOS19:1;
6319 uint32_t EMIOS18:1;
6320 uint32_t EMIOS17:1;
6321 uint32_t EMIOS16:1;
6322 uint32_t EMIOS15:1;
6323 uint32_t EMIOS14:1;
6324 uint32_t EMIOS13:1;
6325 uint32_t EMIOS12:1;
6326 uint32_t EMIOS11:1;
6327 uint32_t EMIOS10:1;
6328 uint32_t EMIOS9:1;
6329 uint32_t EMIOS8:1;
6330 uint32_t EMIOS7:1;
6331 uint32_t EMIOS6:1;
6332 uint32_t EMIOS5:1;
6333 uint32_t EMIOS4:1;
6334 uint32_t EMIOS3:1;
6335 uint32_t EMIOS2:1;
6336 uint32_t EMIOS1:1;
6337 uint32_t EMIOS0:1;
6338 } B;
6339 } EMIOSC; /* EMIOS C Select Register */
6340
6341 union {
6342 uint32_t R;
6343 struct {
6344 uint32_t DSPICH31:1;
6345 uint32_t DSPICH30:1;
6346 uint32_t DSPICH29:1;
6347 uint32_t DSPICH28:1;
6348 uint32_t DSPICH27:1;
6349 uint32_t DSPICH26:1;
6350 uint32_t DSPICH25:1;
6351 uint32_t DSPICH24:1;
6352 uint32_t DSPICH23:1;
6353 uint32_t DSPICH22:1;
6354 uint32_t DSPICH21:1;
6355 uint32_t DSPICH20:1;
6356 uint32_t DSPICH19:1;
6357 uint32_t DSPICH18:1;
6358 uint32_t DSPICH17:1;
6359 uint32_t DSPICH16:1;
6360 uint32_t DSPICL15:1;
6361 uint32_t DSPICL14:1;
6362 uint32_t DSPICL13:1;
6363 uint32_t DSPICL12:1;
6364 uint32_t DSPICL11:1;
6365 uint32_t DSPICL10:1;
6366 uint32_t DSPICL9:1;
6367 uint32_t DSPICL8:1;
6368 uint32_t DSPICL7:1;
6369 uint32_t DSPICL6:1;
6370 uint32_t DSPICL5:1;
6371 uint32_t DSPICL4:1;
6372 uint32_t DSPICL3:1;
6373 uint32_t DSPICL2:1;
6374 uint32_t DSPICL1:1;
6375 uint32_t DSPICL0:1;
6376 } B;
6377 } DSPICHLC; /* DSPIAH/L Select Register for DSPI C */
6378
6379 int32_t SIU_reserved16[2];
6380
6381 union {
6382 uint32_t R;
6383 struct {
6384 uint32_t EMIOS31:1;
6385 uint32_t EMIOS30:1;
6386 uint32_t EMIOS29:1;
6387 uint32_t EMIOS28:1;
6388 uint32_t EMIOS27:1;
6389 uint32_t EMIOS26:1;
6390 uint32_t EMIOS25:1;
6391 uint32_t EMIOS24:1;
6392 uint32_t EMIOS23:1;
6393 uint32_t EMIOS22:1;
6394 uint32_t EMIOS21:1;
6395 uint32_t EMIOS20:1;
6396 uint32_t EMIOS19:1;
6397 uint32_t EMIOS18:1;
6398 uint32_t EMIOS17:1;
6399 uint32_t EMIOS16:1;
6400 uint32_t EMIOS15:1;
6401 uint32_t EMIOS14:1;
6402 uint32_t EMIOS13:1;
6403 uint32_t EMIOS12:1;
6404 uint32_t EMIOS11:1;
6405 uint32_t EMIOS10:1;
6406 uint32_t EMIOS9:1;
6407 uint32_t EMIOS8:1;
6408 uint32_t EMIOS7:1;
6409 uint32_t EMIOS6:1;
6410 uint32_t EMIOS5:1;
6411 uint32_t EMIOS4:1;
6412 uint32_t EMIOS3:1;
6413 uint32_t EMIOS2:1;
6414 uint32_t EMIOS1:1;
6415 uint32_t EMIOS0:1;
6416 } B;
6417 } EMIOSD; /* EMIOS D Select Register */
6418
6419 union {
6420 uint32_t R;
6421 struct {
6422 uint32_t DSPIDH31:1;
6423 uint32_t DSPIDH30:1;
6424 uint32_t DSPIDH29:1;
6425 uint32_t DSPIDH28:1;
6426 uint32_t DSPIDH27:1;
6427 uint32_t DSPIDH26:1;
6428 uint32_t DSPIDH25:1;
6429 uint32_t DSPIDH24:1;
6430 uint32_t DSPIDH23:1;
6431 uint32_t DSPIDH22:1;
6432 uint32_t DSPIDH21:1;
6433 uint32_t DSPIDH20:1;
6434 uint32_t DSPIDH19:1;
6435 uint32_t DSPIDH18:1;
6436 uint32_t DSPIDH17:1;
6437 uint32_t DSPIDH16:1;
6438 uint32_t DSPIDL15:1;
6439 uint32_t DSPIDL14:1;
6440 uint32_t DSPIDL13:1;
6441 uint32_t DSPIDL12:1;
6442 uint32_t DSPIDL11:1;
6443 uint32_t DSPIDL10:1;
6444 uint32_t DSPIDL9:1;
6445 uint32_t DSPIDL8:1;
6446 uint32_t DSPIDL7:1;
6447 uint32_t DSPIDL6:1;
6448 uint32_t DSPIDL5:1;
6449 uint32_t DSPIDL4:1;
6450 uint32_t DSPIDL3:1;
6451 uint32_t DSPIDL2:1;
6452 uint32_t DSPIDL1:1;
6453 uint32_t DSPIDL0:1;
6454 } B;
6455 } DSPIDHLD; /* DSPIAH/L Select Register for DSPI D */
6456
6457 }; /* end of SIU_tag */
6458/**************************************************************************/
6459/* MODULE : STM */
6460/**************************************************************************/
6461 struct STM_tag {
6462
6463 union {
6464 uint32_t R;
6465 struct {
6466 uint32_t:16;
6467 uint32_t CPS:8;
6468 uint32_t:6;
6469 uint32_t FRZ:1;
6470 uint32_t TEN:1;
6471 } B;
6472 } CR; /* STM Control Register */
6473
6474 union {
6475 uint32_t R;
6476 } CNT; /* STM Count Register */
6477
6478 int32_t STM_reserved[2];
6479
6480 union {
6481 uint32_t R;
6482 struct {
6483 uint32_t:31;
6484 uint32_t CEN:1;
6485 } B;
6486 } CCR0; /* STM Channel Control Register 0 */
6487
6488 union {
6489 uint32_t R;
6490 struct {
6491 uint32_t:31;
6492 uint32_t CIF:1;
6493 } B;
6494 } CIR0; /* STM Channel Interrupt Register 0 */
6495
6496 union {
6497 uint32_t R;
6498 } CMP0; /* STM Channel Compare Register 0 */
6499
6500 int32_t STM_reserved1;
6501
6502 union {
6503 uint32_t R;
6504 struct {
6505 uint32_t:31;
6506 uint32_t CEN:1;
6507 } B;
6508 } CCR1; /* STM Channel Control Register 1 */
6509
6510 union {
6511 uint32_t R;
6512 struct {
6513 uint32_t:31;
6514 uint32_t CIF:1;
6515 } B;
6516 } CIR1; /* STM Channel Interrupt Register 1 */
6517
6518 union {
6519 uint32_t R;
6520 } CMP1; /* STM Channel Compare Register 1 */
6521
6522 int32_t STM_reserved2;
6523
6524 union {
6525 uint32_t R;
6526 struct {
6527 uint32_t:31;
6528 uint32_t CEN:1;
6529 } B;
6530 } CCR2; /* STM Channel Control Register 2 */
6531
6532 union {
6533 uint32_t R;
6534 struct {
6535 uint32_t:31;
6536 uint32_t CIF:1;
6537 } B;
6538 } CIR2; /* STM Channel Interrupt Register 2 */
6539
6540 union {
6541 uint32_t R;
6542 } CMP2; /* STM Channel Compare Register 2 */
6543
6544 int32_t STM_reserved3;
6545
6546 union {
6547 uint32_t R;
6548 struct {
6549 uint32_t:31;
6550 uint32_t CEN:1;
6551 } B;
6552 } CCR3; /* STM Channel Control Register 3 */
6553
6554 union {
6555 uint32_t R;
6556 struct {
6557 uint32_t:31;
6558 uint32_t CIF:1;
6559 } B;
6560 } CIR3; /* STM Channel Interrupt Register 3 */
6561
6562 union {
6563 uint32_t R;
6564 } CMP3; /* STM Channel Compare Register 3 */
6565
6566 }; /* end of STM_tag */
6567/**************************************************************************/
6568/* MODULE : SWT */
6569/**************************************************************************/
6570 struct SWT_tag {
6571 union {
6572 uint32_t R;
6573 struct {
6574 uint32_t MAP0:1;
6575 uint32_t MAP1:1;
6576 uint32_t MAP2:1;
6577 uint32_t MAP3:1;
6578 uint32_t MAP4:1;
6579 uint32_t MAP5:1;
6580 uint32_t MAP6:1;
6581 uint32_t MAP7:1;
6582 uint32_t:14;
6583 uint32_t KEY:1;
6584 uint32_t RIA:1;
6585 uint32_t WND:1;
6586 uint32_t ITR:1;
6587 uint32_t HLK:1;
6588 uint32_t SLK:1;
6589 uint32_t:2;
6590 uint32_t FRZ:1;
6591 uint32_t WEN:1;
6592 } B;
6593 } CR; /* SWT Control Register */
6594
6595 union {
6596 uint32_t R;
6597 struct {
6598 uint32_t:31;
6599 uint32_t TIF:1;
6600 } B;
6601 } IR; /* SWT Interrupt Register */
6602
6603 union {
6604 uint32_t R;
6605 struct {
6606 uint32_t WTO:32;
6607 } B;
6608 } TO; /* SWT Time-Out Register */
6609
6610 union {
6611 uint32_t R;
6612 struct {
6613 uint32_t WST:32;
6614 } B;
6615 } WN; /* SWT Window Register */
6616
6617 union {
6618 uint32_t R;
6619 struct {
6620 uint32_t:16;
6621 uint32_t WSC:16;
6622 } B;
6623 } SR; /* SWT Service Register */
6624
6625 union {
6626 uint32_t R;
6627 struct {
6628 uint32_t CNT:32;
6629 } B;
6630 } CO; /* SWT Counter Output Register */
6631
6632 union {
6633 uint32_t R;
6634 struct {
6635 uint32_t:16;
6636 uint32_t SK:16;
6637 } B;
6638 } SK; /* SWT Service Key Register */
6639
6640 }; /* end of SWT_tag */
6641
6642/* Define memories */
6643
6644#define SRAM0_START 0x40000000UL
6645#define SRAM0_SIZE 0x80000UL
6646#define SRAM0_END 0x4007FFFFUL
6647
6648#define SRAM1_START 0x40080000UL
6649#define SRAM1_SIZE 0x14000UL
6650#define SRAM1_END 0x40093FFFUL
6651
6652#define FLASH_START 0x0UL
6653#define FLASH_SIZE 0x200000UL
6654#define FLASH_END 0x1FFFFFUL
6655
6656/* Define instances of modules AIPS_A */
6657#define MLB (*(volatile struct MLB_tag *) 0xC3F84000UL)
6658#define I2C_C (*(volatile struct I2C_tag *) 0xC3F88000UL)
6659#define I2C_D (*(volatile struct I2C_tag *) 0xC3F8C000UL)
6660#define DSPI_C (*(volatile struct DSPI_tag *) 0xC3F90000UL)
6661#define DSPI_D (*(volatile struct DSPI_tag *) 0xC3F94000UL)
6662#define ESCI_J (*(volatile struct ESCI_tag *) 0xC3FA0000UL)
6663#define ESCI_K (*(volatile struct ESCI_tag *) 0xC3FA4000UL)
6664#define ESCI_L (*(volatile struct ESCI_tag *) 0xC3FA8000UL)
6665#define ESCI_M (*(volatile struct ESCI_tag *) 0xC3FAC000UL)
6666#define FR (*(volatile struct FR_tag *) 0xC3FDC000UL)
6667
6668/* Define instances of modules AIPS_B */
6669#define XBAR (*(volatile struct XBAR_tag *) 0xFFF04000UL)
6670#define SEMA4 (*(volatile struct SEMA4_tag *) 0xFFF10000UL)
6671#define MPU (*(volatile struct MPU_tag *) 0xFFF14000UL)
6672#define SWT (*(volatile struct SWT_tag *) 0xFFF38000UL)
6673#define STM (*(volatile struct STM_tag *) 0xFFF3C000UL)
6674#define ECSM (*(volatile struct ECSM_tag *) 0xFFF40000UL)
6675#define EDMA (*(volatile struct EDMA_tag *) 0xFFF44000UL)
6676#define INTC (*(volatile struct INTC_tag *) 0xFFF48000UL)
6677#define FEC (*(volatile struct FEC_tag *) 0xFFF4C000UL)
6678#define ADC (*(volatile struct ADC_tag *) 0xFFF80000UL)
6679#define I2C_A (*(volatile struct I2C_tag *) 0xFFF88000UL)
6680#define I2C_B (*(volatile struct I2C_tag *) 0xFFF8C000UL)
6681#define DSPI_A (*(volatile struct DSPI_tag *) 0xFFF90000UL)
6682#define DSPI_B (*(volatile struct DSPI_tag *) 0xFFF94000UL)
6683#define ESCI_A (*(volatile struct ESCI_tag *) 0xFFFA0000UL)
6684#define ESCI_B (*(volatile struct ESCI_tag *) 0xFFFA4000UL)
6685#define ESCI_C (*(volatile struct ESCI_tag *) 0xFFFA8000UL)
6686#define ESCI_D (*(volatile struct ESCI_tag *) 0xFFFAC000UL)
6687#define ESCI_E (*(volatile struct ESCI_tag *) 0xFFFB0000UL)
6688#define ESCI_F (*(volatile struct ESCI_tag *) 0xFFFB4000UL)
6689#define ESCI_G (*(volatile struct ESCI_tag *) 0xFFFB8000UL)
6690#define ESCI_H (*(volatile struct ESCI_tag *) 0xFFFBC000UL)
6691#define CAN_A (*(volatile struct FLEXCAN_tag *) 0xFFFC0000UL)
6692#define CAN_B (*(volatile struct FLEXCAN_tag *) 0xFFFC4000UL)
6693#define CAN_C (*(volatile struct FLEXCAN_tag *) 0xFFFC8000UL)
6694#define CAN_D (*(volatile struct FLEXCAN_tag *) 0xFFFCC000UL)
6695#define CAN_E (*(volatile struct FLEXCAN_tag *) 0xFFFD0000UL)
6696#define CAN_F (*(volatile struct FLEXCAN_tag *) 0xFFFD4000UL)
6697#define CTU (*(volatile struct CTU_tag *) 0xFFFD8000UL)
6698#define DMAMUX (*(volatile struct DMAMUX_tag *) 0xFFFDC000UL)
6699#define PIT (*(volatile struct PIT_tag *) 0xFFFE0000UL)
6700#define PIT_RTI (*(volatile struct PIT_tag *) 0xFFFE0000UL)
6701#define EMIOS (*(volatile struct EMIOS_tag *) 0xFFFE4000UL)
6702#define SIU (*(volatile struct SIU_tag *) 0xFFFE8000UL)
6703#define CRP (*(volatile struct CRP_tag *) 0xFFFEC000UL)
6704#define FMPLL (*(volatile struct FMPLL_tag *) 0xFFFF0000UL)
6705#define FLASH (*(volatile struct FLASH_tag *) 0xFFFF8000UL)
6706
6707#ifdef __MWERKS__
6708#pragma pop
6709#endif
6710
6711#ifdef __cplusplus
6712}
6713#endif
6714#endif /* ASM */
6715#endif /* ifdef _MPC5668_H */
#define MCM
Definition MIMXRT1166_cm4.h:62459
#define SRC
Definition MIMXRT1052.h:43055
#define PE
Parity Error.
Definition uart.h:125
#define MCR
Modem Control Register.
Definition uart.h:91
#define FE
Framing Error.
Definition uart.h:126
Definition fsl-mpc5668.h:67
Definition fsl-mpc551x.h:67
Definition fsl-mpc5668.h:1536
Definition fsl-mpc551x.h:224
Definition fsl-mpc551x.h:238
Definition fsl-mpc555x.h:2173
Definition fsl-mpc551x.h:636
Definition fsl-mpc551x.h:525
Definition fsl-mpc551x.h:893
Definition fsl-mpc556x.h:2976
Definition fsl-mpc551x.h:1021
Definition fsl-mpc551x.h:1432
Definition fsl-mpc551x.h:1165
Definition fsl-mpc551x.h:1478
Definition fsl-mpc551x.h:3616
Definition fsl-mpc551x.h:1533
Definition fsl-mpc551x.h:1597
Definition fsl-mpc5668.h:4667
Definition fsl-mpc551x.h:3785
Definition fsl-mpc551x.h:1837
Definition fsl-mpc5668.h:4932
Definition fsl-mpc551x.h:1985
Definition fsl-mpc551x.h:2081
Definition fsl-mpc551x.h:2215
Definition fsl-mpc5668.h:6461
Definition fsl-mpc5668.h:6570
Definition fsl-mpc555x.h:1976
Definition fsl-mpc551x.h:3777
Definition fsl-mpc551x.h:3475
Definition fsl-mpc564xL.h:16535
Definition fsl-mpc551x.h:278
Definition fsl-mpc551x.h:356
Definition fsl-mpc551x.h:338
Definition fsl-mpc551x.h:319
Definition fsl-mpc551x.h:297
Definition fsl-mpc551x.h:661
Definition fsl-mpc551x.h:894
Definition fsl-mpc551x.h:918
Definition fsl-mpc551x.h:940
Definition fsl-mpc551x.h:950
Definition fsl-mpc551x.h:1499
Definition fsl-mpc551x.h:1511
Definition fsl-mpc551x.h:1482
Definition fsl-mpc564xL.h:5538
Definition fsl-mpc564xL.h:5570
Definition fsl-mpc564xL.h:5582
Definition fsl-mpc5668.h:4947
Definition fsl-mpc5668.h:4956
Definition fsl-mpc5668.h:4921
Definition fsl-mpc551x.h:2288
Definition fsl-mpc551x.h:2311
Definition fsl-mpc551x.h:2419
Definition fsl-mpc551x.h:2394
Definition fsl-mpc551x.h:2369
Definition fsl-mpc551x.h:2346
Definition fsl-mpc551x.h:2454
Definition fsl-mpc551x.h:3534
Definition fsl-mpc551x.h:3537
Definition fsl-mpc551x.h:2933
Definition fsl-mpc551x.h:3031
Definition fsl-mpc551x.h:3540
Definition fsl-mpc551x.h:3718
Definition fsl-mpc551x.h:2836
Definition fsl-mpc551x.h:3609
Definition fsl-mpc551x.h:3612
Definition fsl-mpc551x.h:2801
Definition fsl-mpc551x.h:2954
Definition fsl-mpc551x.h:2811
Definition fsl-mpc551x.h:2775
Definition fsl-mpc551x.h:3543
Definition fsl-mpc551x.h:3165
Definition fsl-mpc551x.h:2767
Definition fsl-mpc551x.h:3570
Definition fsl-mpc551x.h:3567
Definition fsl-mpc551x.h:3555
Definition fsl-mpc551x.h:3528
Definition fsl-mpc551x.h:3222
Definition fsl-mpc551x.h:3307
Definition fsl-mpc551x.h:3316
Definition fsl-mpc551x.h:3325
Definition fsl-mpc551x.h:3333
Definition fsl-mpc551x.h:3341
Definition fsl-mpc551x.h:3349
Definition fsl-mpc551x.h:3356
Definition fsl-mpc551x.h:3364
Definition fsl-mpc551x.h:3371
Definition fsl-mpc551x.h:3379
Definition fsl-mpc551x.h:3230
Definition fsl-mpc551x.h:3387
Definition fsl-mpc551x.h:3395
Definition fsl-mpc551x.h:3403
Definition fsl-mpc551x.h:3412
Definition fsl-mpc551x.h:3419
Definition fsl-mpc551x.h:3428
Definition fsl-mpc551x.h:3435
Definition fsl-mpc551x.h:3444
Definition fsl-mpc551x.h:3451
Definition fsl-mpc551x.h:3459
Definition fsl-mpc551x.h:3238
Definition fsl-mpc551x.h:3467
Definition fsl-mpc551x.h:3246
Definition fsl-mpc551x.h:3255
Definition fsl-mpc551x.h:3263
Definition fsl-mpc551x.h:3272
Definition fsl-mpc551x.h:3281
Definition fsl-mpc551x.h:3289
Definition fsl-mpc551x.h:3298
Definition fsl-mpc551x.h:3531
Definition fsl-mpc551x.h:2895
Definition fsl-mpc551x.h:2916
Definition fsl-mpc551x.h:2857
Definition fsl-mpc551x.h:2878
Definition fsl-mpc551x.h:2822
Definition fsl-mpc551x.h:2965
Definition fsl-mpc551x.h:2981
Definition fsl-mpc551x.h:2994
Definition fsl-mpc551x.h:3012
Definition fsl-mpc551x.h:3591
Definition fsl-mpc551x.h:3594
Definition fsl-mpc551x.h:3187
Definition fsl-mpc551x.h:3606
Definition fsl-mpc551x.h:3603
Definition fsl-mpc551x.h:3600
Definition fsl-mpc551x.h:3597
Definition fsl-mpc551x.h:3196
Definition fsl-mpc551x.h:3207
Definition fsl-mpc551x.h:3588
Definition fsl-mpc551x.h:3585
Definition fsl-mpc551x.h:3176
Definition fsl-mpc551x.h:3552
Definition fsl-mpc551x.h:3053
Definition fsl-mpc551x.h:3564
Definition fsl-mpc551x.h:3561
Definition fsl-mpc551x.h:3079
Definition fsl-mpc551x.h:3063
Definition fsl-mpc551x.h:3558
Definition fsl-mpc551x.h:3546
Definition fsl-mpc551x.h:3549
Definition fsl-mpc551x.h:3128
Definition fsl-mpc551x.h:3582
Definition fsl-mpc551x.h:3144
Definition fsl-mpc551x.h:3117
Definition fsl-mpc551x.h:2790
Definition fsl-mpc551x.h:3045
Definition fsl-mpc551x.h:3522
Definition fsl-mpc551x.h:3525
Definition fsl-mpc551x.h:3736
Definition fsl-mpc551x.h:3573
Definition fsl-mpc551x.h:3106
Definition fsl-mpc551x.h:3576
Definition fsl-mpc551x.h:3579
Definition fsl-mpc551x.h:3087
