RTEMS 6.3
i386 UART definitions More...
file  bsps/i386/include/uart.h
#define BSP_UART_INTR_CTRL_DISABLE   (0)
 Command values for BSP_uart_intr_ctrl(), values are strange in order to catch errors with assert.
#define BSP_UART_INTR_CTRL_GDB   (0xaa)
 RX only.
#define BSP_UART_INTR_CTRL_ENABLE   (0xbb)
 Normal operations.
#define BSP_UART_INTR_CTRL_TERMIOS   (0xcc)
 RX & line status.
#define BSP_UART_STATUS_ERROR   (-1)
 Return values for uart_polled_status().
#define BSP_UART_STATUS_NOCHAR   (0)
 No character.
#define BSP_UART_STATUS_CHAR   (1)
 Character present.
#define BSP_UART_STATUS_BREAK   (2)
 Break point is detected.
#define BSP_UART_COM1   (0)
 PC UART definitions.
#define BSP_UART_COM2   (1)
#define COM1_BASE_IO   0x3F8
 Base IO for UART.
#define COM2_BASE_IO   0x2F8
#define RBR   (0)
 Offsets from base.
#define THR   (0)
 Tx Buffer Register (write).
#define IER   (1)
 Interrupt Enable Register.
#define IIR   (2)
 DLAB X.
#define FCR   (2)
 FIFO Control Register (write).
#define LCR   (3)
 Line Control Register.
#define MCR   (4)
 Modem Control Register.
#define LSR   (5)
 Line Status Register.
#define MSR   (6)
 Modem Status Register.
#define SCR   (7)
 Scratch register.
#define DLL   (0)
 DLAB 1.
#define DLM   (1)
 Divisor Latch, MSB.
#define AFR   (2)
 Alternate Function register.
#define MODEM_STATUS   0
 Interrupt source definition via IIR.
#define NO_MORE_INTR   1
#define TRANSMITTER_HODING_REGISTER_EMPTY   2
#define RECEIVER_DATA_AVAIL   4
#define RECEIVER_ERROR   6
#define CHARACTER_TIMEOUT_INDICATION   12
#define RECEIVE_ENABLE   0x1
 Bits definition of IER.
#define TRANSMIT_ENABLE   0x2
#define RECEIVER_LINE_ST_ENABLE   0x4
#define MODEM_ENABLE   0x8
#define INTERRUPT_DISABLE   0x0
#define DR   0x01
 Bits definition of the Line Status Register (LSR).
#define OE   0x02
 Overrun Error.
#define PE   0x04
 Parity Error.
#define FE   0x08
 Framing Error.
#define BI   0x10
 Break Interrupt.
#define THRE   0x20
 Transmitter Holding Register Empty.
#define TEMT   0x40
 Transmitter Empty.
#define ERFIFO   0x80
 Error receive Fifo.
#define DTR   0x01
 Bits definition of the MODEM Control Register (MCR).
#define RTS   0x02
 Request To Send.
#define OUT_1   0x04
 Output 1, (reserved on COMPAQ I/O Board).
#define OUT_2   0x08
 Output 2, Enable Asynchronous Port Interrupts.
#define LB   0x10
 Enable Internal Loop Back.
#define CHR_5_BITS   0
 Bits definition of the Line Control Register (LCR).
#define CHR_6_BITS   1
#define CHR_7_BITS   2
#define CHR_8_BITS   3
#define WL   0x03
 Word length mask.
#define STB   0x04
 1 Stop Bit, otherwise 2 Stop Bits
#define PEN   0x08
 Parity Enabled.
#define EPS   0x10
 Even Parity Select, otherwise Odd.
#define SP   0x20
 Stick Parity.
#define BCB   0x40
 Break Control Bit.
#define DLAB   0x80
 Enable Divisor Latch Access.
#define DCTS   0x01
 Bits definition of the MODEM Status Register (MSR).
#define DDSR   0x02
 Delta Data Set Ready.
#define TERI   0x04
 Trailing Edge Ring Indicator.
#define DDCD   0x08
 Delta Carrier Detect Indicator.
#define CTS   0x10
 Clear To Send (when loop back is active).
#define DSR   0x20
 Data Set Ready (when loop back is active).
#define RI   0x40
 Ring Indicator (when loop back is active).
#define DCD   0x80
 Data Carrier Detect (when loop back is active).
#define FIFO_CTRL   0x01
 Bits definition of the FIFO Control Register : WD16C552 or NS16550.
#define FIFO_EN   0x01
 Enable the FIFO.
#define XMIT_RESET   0x02
 Transmit FIFO Reset.
#define RCV_RESET   0x04
 Receive FIFO Reset.
#define FCR3   0x08
 do not understand manual!
#define RECEIVE_FIFO_TRIGGER1   0x0
 trigger recieve interrupt after 1 byte
#define RECEIVE_FIFO_TRIGGER4   0x40
 trigger recieve interrupt after 4 byte
#define RECEIVE_FIFO_TRIGGER8   0x80
 trigger recieve interrupt after 8 byte
#define RECEIVE_FIFO_TRIGGER12   0xc0
 trigger recieve interrupt after 12 byte
#define TRIG_LEVEL   0xc0
 Mask for the trigger level.
void BSP_uart_init (int uart, unsigned long baud, unsigned long databits, unsigned long parity, unsigned long stopbits, int hwFlow)
void BSP_uart_set_attributes (int uart, unsigned long baud, unsigned long databits, unsigned long parity, unsigned long stopbits)
void BSP_uart_set_baud (int uart, unsigned long baud)
void BSP_uart_intr_ctrl (int uart, int cmd)
void BSP_uart_throttle (int uart)
void BSP_uart_unthrottle (int uart)
int BSP_uart_polled_status (int uart)
void BSP_uart_polled_write (int uart, int val)
int BSP_uart_polled_read (int uart)
void BSP_uart_termios_set (int uart, void *ttyp)
int BSP_uart_termios_read_com1 (int uart)
int BSP_uart_termios_read_com2 (int uart)
ssize_t BSP_uart_termios_write_com1 (int minor, const char *buf, size_t len)
ssize_t BSP_uart_termios_write_com2 (int minor, const char *buf, size_t len)
void BSP_uart_termios_isr_com1 (void *)
void BSP_uart_termios_isr_com2 (void *)
void BSP_uart_dbgisr_com1 (void)
void BSP_uart_dbgisr_com2 (void)
int BSP_poll_char_via_serial (void)
void BSP_output_char_via_serial (char val)
int BSPConsolePort
int BSPBaseBaud
◆ BSP_UART_STATUS_ERROR
No character
◆ DCTS
#define DCTS   0x01
Delta Clear To Send
◆ DLL
#define DLL   (0)
DLAB 1.
Divisor Latch, LSB
◆ DR
#define DR   0x01
Data Ready
◆ DTR
#define DTR   0x01
Data Terminal Ready
◆ FIFO_CTRL
Set to 1 permit access to other bits
◆ IIR
#define IIR   (2)
DLAB X.
Interrupt Ident Register (read)
◆ RBR
#define RBR   (0)
Offsets from base.
DLAB 0 Rx Buffer Register (read)
