RTEMS
6.3
Toggle main menu visibility
libfs
src
dosfs
fat_fat_operations.h
1
11
12
13
* Copyright (C) 2001 OKTET Ltd., St.-Petersburg, Russia
14
* Author: Eugeny S. Mints <Eugeny.Mints@oktet.ru>
15
16
* The license and distribution terms for this file may be
17
* found in the file LICENSE in this distribution or at
18
* http://www.rtems.org/license/LICENSE.
19
20
21
#ifndef __DOSFS_FAT_FAT_OPERATIONS_H__
22
#define __DOSFS_FAT_FAT_OPERATIONS_H__
23
24
rtems.h
25
rtems/libio_.h
26
27
rtems/bdbuf.h
28
35
#ifdef __cplusplus
36
extern
"C"
37
#endif
38
39
#include "
fat.h
40
41
int
42
fat_get_fat_cluster(fat_fs_info_t *fs_info,
43
uint32_t cln,
44
uint32_t *ret_val);
45
46
int
47
fat_set_fat_cluster(fat_fs_info_t *fs_info,
48
uint32_t cln,
49
uint32_t in_val);
50
51
int
52
fat_scan_fat_for_free_clusters(
53
54
uint32_t *chain,
55
uint32_t count,
56
uint32_t *cls_added,
57
uint32_t *last_cl,
58
bool
zero_fill
59
60
61
int
62
fat_free_fat_clusters_chain(
63
64
uint32_t chain
65
66
67
#ifdef __cplusplus
68
69
#endif
71
#endif
/* __DOSFS_FAT_FAT_OPERATIONS_H__ */
bdbuf.h
Block Device Buffer Management.
fat.h
Constants/Data Structures/Prototypes on a Volume with FAT Filesystem.
libio_.h
LibIO Internal Interface.
rtems.h
