RTEMS 6.3
sparc64 Directory Reference
cpu.c
 SPARC64 CPU Dependent Source.
sparc64-syscall.h
A lot of explanation needed, will do when known.
The score/cpu/sparc64 contains only code that can execute without accessing privileged registers or using privileged instructions. This was done because the privileged registers differ between the sun4u and sun4v models.
The model specific and privileged code that would normally be found in score/cpu/sparc64 resides in libcpu/sparc64/@RTEMS_CPU_MODEL@/score or in libcpu/sparc64/shared/score directory. This is primarily the interrupt handling code.
