RTEMS 6.3
Files | |
| _kernel_cpuset.h | |
| This header file provides CPU set definitions for the kernel space (_KERNEL is defined before including <sys/cpuset.h>). | |
| _kernel_in.h | |
| This header file provides IPv4 definitions for the kernel space (_KERNEL is defined before including <netinet/in.h>). | |
| _kernel_in6.h | |
| This header file provides IPv6 definitions for the kernel space (_KERNEL is defined before including <netinet6/in6.h>). | |
| _kernel_mman.h | |
| This header file provides memory map definitions for the kernel space (_KERNEL is defined before including <sys/mman.h>). | |
| _kernel_param.h | |
| This header file provides parameter definitions for the kernel space (_KERNEL is defined before including <sys/param.h>). | |
| _kernel_time.h | |
| This header file provides time definitions for the kernel space (_KERNEL is defined before including <sys/time.h>). | |
| _kernel_types.h | |
| This header file provides type definitions for the kernel space (_KERNEL is defined before including <sys/types.h>). | |
| _kernel_uio.h | |
| This header file provides device driver I/O definitions for the kernel space (_KERNEL is defined before including <sys/uio.h>). | |
| _timecounter.h | |
| This header file provides timecounter definitions for the kernel space (_KERNEL is defined before including <sys/time.h>) and RTEMS. | |
