RTEMS
6.3
Toggle main menu visibility
include
machine
_kernel_time.h
1
2
* SPDX-License-Identifier: BSD-3-Clause
3
4
* Copyright (C) 2016 embedded brains GmbH & Co. KG
5
6
* Copyright (c) 1982, 1986, 1993
7
* The Regents of the University of California. All rights reserved.
8
9
10
* modification, are permitted provided that the following conditions
11
* are met:
12
* 1. Redistributions of source code must retain the above copyright
13
* notice, this list of conditions and the following disclaimer.
14
* 2. Redistributions in binary form must reproduce the above copyright
15
* notice, this list of conditions and the following disclaimer in the
16
* documentation and/or other materials provided with the distribution.
17
* 3. Neither the name of the University nor the names of its contributors
18
* may be used to endorse or promote products derived from this software
19
* without specific prior written permission.
20
21
* THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
22
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24
* ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
25
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
26
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
27
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
28
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
29
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
30
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
31
* SUCH DAMAGE.
32
33
* @(#)time.h 8.5 (Berkeley) 5/4/95
34
* $FreeBSD$
35
36
45
46
#if defined(_SYS_TIME_H_) && defined(_KERNEL)
47
48
machine/_timecounter.h
49
50
/* Operations on timespecs */
51
#ifndef timespecclear
52
#define timespecclear(tvp) ((tvp)->tv_sec = (tvp)->tv_nsec = 0)
53
#endif
54
#ifndef timespecisset
55
#define timespecisset(tvp) ((tvp)->tv_sec || (tvp)->tv_nsec)
56
#endif
57
#ifndef timespeccmp
58
#define timespeccmp(tvp, uvp, cmp) \
59
(((tvp)->tv_sec == (uvp)->tv_sec) ? \
60
((tvp)->tv_nsec cmp (uvp)->tv_nsec) : \
61
((tvp)->tv_sec cmp (uvp)->tv_sec))
62
#endif
63
64
#ifndef timespecadd
65
#define timespecadd(tsp, usp, vsp) \
66
do { \
67
(vsp)->tv_sec = (tsp)->tv_sec + (usp)->tv_sec; \
68
(vsp)->tv_nsec = (tsp)->tv_nsec + (usp)->tv_nsec; \
69
if ((vsp)->tv_nsec >= 1000000000L) { \
70
(vsp)->tv_sec++; \
71
(vsp)->tv_nsec -= 1000000000L; \
72
73
} while (0)
74
#endif
75
#ifndef timespecsub
76
#define timespecsub(tsp, usp, vsp) \
77
do { \
78
(vsp)->tv_sec = (tsp)->tv_sec - (usp)->tv_sec; \
79
(vsp)->tv_nsec = (tsp)->tv_nsec - (usp)->tv_nsec; \
80
if ((vsp)->tv_nsec < 0) { \
81
(vsp)->tv_sec--; \
82
(vsp)->tv_nsec += 1000000000L; \
83
84
} while (0)
85
#endif
86
87
88
* Simple macros to convert ticks to milliseconds
89
* or microseconds and vice-versa. The answer
90
* will always be at least 1. Note the return
91
* value is a uint32_t however we step up the
92
* operations to 64 bit to avoid any overflow/underflow
93
* problems.
94
95
#define TICKS_2_MSEC(t) max(1, (uint32_t)(hz == 1000) ? \
96
(t) : (((uint64_t)(t) * (uint64_t)1000)/(uint64_t)hz))
97
#define TICKS_2_USEC(t) max(1, (uint32_t)(hz == 1000) ? \
98
((t) * 1000) : (((uint64_t)(t) * (uint64_t)1000000)/(uint64_t)hz))
99
#define MSEC_2_TICKS(m) max(1, (uint32_t)((hz == 1000) ? \
100
(m) : ((uint64_t)(m) * (uint64_t)hz)/(uint64_t)1000))
101
#define USEC_2_TICKS(u) max(1, (uint32_t)((hz == 1000) ? \
102
((u) / 1000) : ((uint64_t)(u) * (uint64_t)hz)/(uint64_t)1000000))
103
104
/* Operations on timevals. */
105
106
#define timevalclear(tvp) ((tvp)->tv_sec = (tvp)->tv_usec = 0)
107
#define timevalisset(tvp) ((tvp)->tv_sec || (tvp)->tv_usec)
108
#define timevalcmp(tvp, uvp, cmp) \
109
110
((tvp)->tv_usec cmp (uvp)->tv_usec) : \
111
112
113
/* timevaladd and timevalsub are not inlined */
114
115
116
* Kernel to clock driver interface.
117
118
void
inittodr(time_t base);
119
void
resettodr(
void
120
121
#define time_second _Timecounter_Time_second
122
#define time_uptime _Timecounter_Time_uptime
123
extern
struct
timeval boottime;
124
extern
struct
bintime tc_tick_bt;
125
extern
sbintime_t tc_tick_sbt;
126
extern
struct
bintime tick_bt;
127
extern
sbintime_t tick_sbt;
128
extern
int
tc_precexp;
129
extern
int
tc_timepercentage;
130
extern
struct
bintime bt_timethreshold;
131
extern
struct
bintime bt_tickthreshold;
132
extern
sbintime_t sbt_timethreshold;
133
extern
sbintime_t sbt_tickthreshold;
134
135
136
* Functions for looking at our clock: [get]{bin,nano,micro}[up]time()
137
138
* Functions without the "get" prefix returns the best timestamp
139
* we can produce in the given format.
140
141
* "bin" == struct bintime == seconds + 64 bit fraction of seconds.
142
* "nano" == struct timespec == seconds + nanoseconds.
143
* "micro" == struct timeval == seconds + microseconds.
144
145
* Functions containing "up" returns time relative to boot and
146
* should be used for calculating time intervals.
147
148
* Functions without "up" returns UTC time.
149
150
* Functions with the "get" prefix returns a less precise result
151
* much faster than the functions without "get" prefix and should
152
* be used where a precision of 1/hz seconds is acceptable or where
153
* performance is priority. (NB: "precision", _not_ "resolution" !)
154
155
156
#define binuptime(_bt) _Timecounter_Binuptime(_bt)
157
#define nanouptime(_tsp) _Timecounter_Nanouptime(_tsp)
158
#define microuptime(_tvp) _Timecounter_Microuptime(_tvp)
159
160
static
__inline sbintime_t
161
sbinuptime(
void
162
163
struct
bintime _bt;
164
165
binuptime(&_bt);
166
return
(bttosbt(_bt));
167
168
169
#define bintime(_bt) _Timecounter_Bintime(_bt)
170
#define nanotime(_tsp) _Timecounter_Nanotime(_tsp)
171
#define microtime(_tvp) _Timecounter_Microtime(_tvp)
172
173
#define getbinuptime(_bt) _Timecounter_Getbinuptime(_bt)
174
#define getnanouptime(_tsp) _Timecounter_Getnanouptime(_tsp)
175
#define getmicrouptime(_tvp) _Timecounter_Getmicrouptime(_tvp)
176
177
static
__inline sbintime_t
178
getsbinuptime(
void
179
180
struct
bintime _bt;
181
182
getbinuptime(&_bt);
183
return
(bttosbt(_bt));
184
185
186
#define getbintime(_bt) _Timecounter_Getbintime(_bt)
187
#define getnanotime(_tsp) _Timecounter_Getnanotime(_tsp)
188
#define getmicrotime(_tvp) _Timecounter_Getmicrotime(_tvp)
189
190
#define getboottime(_tvp) _Timecounter_Getboottime(_tvp)
191
#define getboottimebin(_bt) _Timecounter_Getboottimebin(_bt)
192
193
/* Other functions */
194
int
itimerdecr(
struct
itimerval *itp,
int
usec);
195
int
itimerfix(
struct
timeval *tv);
196
int
ppsratecheck(
struct
timeval *,
int
int
197
int
ratecheck(
struct
timeval *,
const
struct
timeval *);
198
void
timevaladd(
struct
timeval *t1,
const
struct
timeval *t2);
199
void
timevalsub(
struct
timeval *t1,
const
struct
timeval *t2);
200
int
tvtohz(
struct
timeval *tv);
201
202
#define TC_DEFAULTPERC 5
203
204
#define BT2FREQ(bt) \
205
(((uint64_t)0x8000000000000000 + ((bt)->frac >> 2)) / \
206
((bt)->frac >> 1))
207
208
#define SBT2FREQ(sbt) ((SBT_1S + ((sbt) >> 1)) / (sbt))
209
210
#define FREQ2BT(freq, bt) \
211
212
(bt)->sec = 0; \
213
(bt)->frac = ((uint64_t)0x8000000000000000 / (freq)) << 1; \
214
215
216
#define TIMESEL(sbt, sbt2) \
217
(((sbt2) >= sbt_timethreshold) ? \
218
((*(sbt) = getsbinuptime()), 1) : ((*(sbt) = sbinuptime()), 0))
219
220
#else
/* !_SYS_TIME_H_ || !_KERNEL */
221
#error "must be included via <sys/time.h> in kernel space"
222
#endif
/* _SYS_TIME_H_ && _KERNEL */
_timecounter.h
This header file provides timecounter definitions for the kernel space (_KERNEL is defined before inc...
