RTEMS 6.3
genmcf548x Directory Reference
Directories
btimer
clock
config
console
include
irq
mcdma
start
Copyright (c) 2007 embedded brains GmbH & Co. KG
Parts of the code has been derived from the "dBUG source code" package Freescale is providing for M548X EVBs. The usage of the modified or unmodified code and it's integration into the generic mcf548x BSP has been done according to the Freescale license terms.
The Freescale license terms can be reviewed in the file
LICENSE.Freescale
The generic mcf548x BSP has been developed on the basic structures and modules of the av5282 BSP.
The license and distribution terms for this file may be found in the file LICENSE in this distribution or at http://www.rtems.org/license/LICENSE.
Description: Generic mcf548x BSP
The genmcf548x supports several boards based on the Freescale MCF547x/8x ColdFire microcontrollers
Supported Hardware: mcf5484FireEngine
CPU: MCF548x, 200MHz
XLB: 100 MHz, which is the main clock for all onchip peripherals
RAM: 64M (m5484FireEngine)
Boot-Flash: 2M (m5484FireEngine)
Code-Flash: 16M (m5484FireEngine)
Core-SRAM: 8K
Core-SysRAM: 32K
Boot-Monitor:None
Supported Hardware: COBRA5475
CPU: MCF5475, 266MHz
XLB: 132 MHz, which is the main clock for all onchip peripherals
RAM: 128M
Boot-Flash: 32M
Core-SRAM: 8K
Core-SysRAM: 32K
Boot-Monitor:DBug
ACKNOWLEDGEMENTS:
This BSP is based on the
av5282 BSP
and the work of
D. Peter Siddons Brett Swimley Jay Monkman Eric Norum Mike Bertosh
BSP INFO:
BSP NAME: genmcf548x
BOARD: various MCF547x/8x based boards
CPU FAMILY: ColdFire 548x
CPU: MCF5475/MCF5484
FPU: MCF548x FPU, context switch supported by RTEMS multitasking
EMAC: MCF548x EMAC context switch supported by RTEMS multitasking (handeld together with FPU context)
PERIPHERALS
TIMERS: 2 slice timers, 4 general purpose timers (SLT0 is used for RTEMS clock, SLT1 is used for diagnostic pupose)
RESOLUTION: System tick 10 millieconds (via SLT0)
SERIAL PORTS: Internal PSC 0-3
NETWORKING: Internal 10/100MHz FEC on two channels
DRIVER INFORMATION
CLOCK DRIVER: SLT0
TIMER DRIVER: SLT1 (diagnostics)
TTY DRIVER: PSC0-3
STDIO
PORT: PSC0 (UART mode) terminal
ELECTRICAL: RS-232
BAUD: 9600
BITS PER CHARACTER: 8
PARITY: None
STOP BITS: 1
MODES: Interrupt driven (polled mode alternatively)
Memory map
Memory map of m5484FireEngine as set up by BSP initialization:
0000 0000 | 64 MByte SDRAM (external) | 03FF FFFF
m5484FireEngine:
| | 0FFF FFFF
1000 0000 | internal per. registers via MBAR | 1003 FFFF
2000 0000 | 8K core SRAM (internal) | 2000 1FFF
m5484FireEngine:
E000 0000 | 16M code flash (external) | E0FF FFFF
FF80 0000 | External 8 MByte Flash memory | FF9F FFFF
| | FFFF FFFF
Memory map for COBRA5475 as set up by DBug:
F000 0000 | 128 MByte SDRAM (external) |
. (first 256KByte reserved for DBug) .
. . F03F FFFF
F040 0000 | |
| | F7FF FFFF
FC00 0000 | 32M code flash (external) |
| | FDFF FFFF
FE00 0000 | internal per. registers via MBAR |
| | FE03 FFFF
FF00 0000 | 8K core SRAM (internal) |
| | FF00 1FFF
Interrupt map
| | PRIORITY |
|LEVEL| 7 | 6 | 5 | 4 | 3 | 2 | 1 | 0 |
| 7 | | | | | | | | |
| 6 | | | | | | | | |
| 5 | | | | | | | | |
| 4 | | | | | | | | SLT0 |
| 3 | PSC 0 | PSC 1 | PSC 2 | PSC 3 | | | | |
| 2 | | | | | FEC0/1 | MCDMA | | |
| 1 | | | | | | | | |
TIMING TESTS
tbd.
