RTEMS 6.3
Files | |
| __assert.c | |
| Evaluate Assertion. | |
| __getpid.c | |
| Get Process Id. | |
| __gettod.c | |
| Get the Date and Time. | |
| __times.c | |
| Get Process Times. | |
| __usrenv.c | |
| RTEMS File System Location Support. | |
| _calloc_r.c | |
| Allocate Space for Array in Memory. | |
| _free_r.c | |
| Allocate and Free Dynamic Memory. | |
| _realloc_r.c | |
| _realloc_r Implementation | |
| _rename_r.c | |
| Rename a File. | |
| access.c | |
| access() - POSIX 1003.1b 5.6.3 - File Accessibility | |
| assoclocalbyname.c | |
| RTEMS Associate Local by Name. | |
| assoclocalbyremote.c | |
| RTEMS Associate Local by Remote. | |
| assoclocalbyremotebitfield.c | |
| RTEMS Associate Local by Remote Bitfield. | |
| assocnamebad.c | |
| RTEMS Associate Bad Name. | |
| assocnamebylocal.c | |
| RTEMS Associate Name by Local. | |
| assocnamebylocalbitfield.c | |
| RTEMS Associate Name by Local Bitfield. | |
| assocnamebyremote.c | |
| RTEMS Associate Name by Remote. | |
| assocnamebyremotebitfield.c | |
| RTEMS Associate Name by Remote Bitfield. | |
| assocptrbylocal.c | |
| RTEMS Associate Pointer by Local. | |
| assocptrbyname.c | |
| RTEMS Associate Pointer by Name. | |
| assocptrbyremote.c | |
| RTEMS Associate Pointer by Remote. | |
| assocremotebylocal.c | |
| RTEMS Associate Remote by Local. | |
| assocremotebylocalbitfield.c | |
| RTEMS Assoc Routines. | |
| assocremotebyname.c | |
| RTEMS Associate Remote by Name. | |
| base_fs.c | |
| Base File System Initialization. | |
| cachealignedalloc.c | |
| RTEMS Cache Aligned Malloc. | |
| cachecoherentalloc.c | |
| calloc.c | |
| cfgetispeed.c | |
| Baud Rate Functions. | |
| cfgetospeed.c | |
| cfsetispeed.c | |
| cfsetospeed.c | |
| chdir.c | |
| POSIX 1003.1b - 5.2.1 - Change Current Working Directory. | |
| chmod.c | |
| Change File Modes. | |
| chown.c | |
| Change Owner and Group of a File. | |
| chroot.c | |
| Change Root Directory. | |
| clonenode.c | |
| Clones a Node. | |
| close.c | |
| POSIX 1003.1b 6.3.1 - Close a File. | |
| consolesimple.h | |
| ctermid.c | |
| Generate Terminal Pathname. | |
| dup.c | |
| POSIX 1003.1b 6.2.1 Duplicate an Open File Descriptor. | |
| dup2.c | |
| error.c | |
| fchdir.c | |
| Change Directory. | |
| fchmod.c | |
| fchown.c | |
| fcntl.c | |
| POSIX 1003.1b 6.5.2 - File Control. | |
| fdatasync.c | |
| POSIX 1003.1b 6.6.2 - Synchronize the Data of a File. | |
| flockfile.c | |
| Lock File for Stdio. | |
| fpathconf.c | |
| Configurable Pathname Varables. | |
| free.c | |
| calloc() | |
| freenode.c | |
| Releases all Resources of a Location. | |
| fsync.c | |
| Synchronize the State of a File. | |
| ftruncate.c | |
| Truncate a File to the Specified Length. | |
| funlockfile.c | |
| Unlock File for Stdio. | |
| futimens.c | |
| Set file access and modification times based on file descriptor in nanoseconds. | |
| gcovfork.c | |
| This source file contains functions required by GCC if code and branch coverage instrumentation (gcov) is enabled. | |
| getchark.c | |
| This source file contains the implementation of getchark(). | |
| getdents.c | |
| Get Directory Entries. | |
| getegid.c | |
| Get Real User, Effective User, Ral Group, and Effective Group IDs. | |
| geteuid.c | |
| getgid.c | |
| getgrent.c | |
| User Database Access Routines. | |
| getgrnam.c | |
| getgroups.c | |
| Get Supplementary IDs. | |
| getlogin.c | |
| Get User Name. | |
| getpagesize.c | |
| Get System Page Size. | |
| getpgrp.c | |
| Get process group IDs. | |
| getpid.c | |
| Process and Parent Process IDs. | |
| getppid.c | |
| Get Process and Parent Process IDs. | |
| getpwent.c | |
| getuid.c | |
| ioctl.c | |
| ioctl() system call | |
| isatty_r.c | |
| Test for a Terminal Device. | |
| issetugid.c | |
| Dummy Version of BSD Routine. | |
| kill_noposix.c | |
| Kill No POSIX. | |
| libio.c | |
| File Descriptor Routines. | |
| libio_exit.c | |
| libio_init.c | |
| RTEMS LibIO Initialization. | |
| libiozeroiops.c | |
| This source file provides rtems_libio_iops and rtems_libio_number_iops for a zero file descriptor application configuration. | |
| link.c | |
| Create a new link. | |
| lseek.c | |
| lseek() - POSIX 1003.1b 6.5.3 - Reposition Read/Write File Offset | |
| lstat.c | |
| Get File Status. | |
| malloc.c | |
| RTEMS Malloc Family Implementation. | |
| malloc_deferred.c | |
| Malloc Deferred Support. | |
| malloc_dirtier.c | |
| Dirty Memory Function. | |
| malloc_p.h | |
| This header file provides interfaces used by the memory allocator implementation. | |
| malloc_walk.c | |
| Malloc Walk. | |
| mallocfreespace.c | |
| RTEMS Malloc Get Free Information. | |
| mallocgetheapptr.c | |
| RTEMS Malloc Get Heap Pointer. | |
| mallocheap.c | |
| This source file provides the C Program Heap control along with the system initialization handler. | |
| mallocinfo.c | |
| RTEMS Malloc Get Status Information. | |
| mallocsetheapptr.c | |
| RTEMS Malloc Set Heap Pointer. | |
| mkdir.c | |
| Make a Directory. | |
| mkfifo.c | |
| Make a FIFO Special File. | |
| mknod.c | |
| Create a Special or Ordinary File. | |
| mount-mktgt.c | |
| mount_and_make_target_path() implementation. | |
| mount.c | |
| Mounts a File System. | |
| newlibc_reent.c | |
| Newlib Support. | |
| open.c | |
| Open a File. | |
| open_dev_console.c | |
| open_dev_console - open /dev/console | |
| pathconf.c | |
| posix_memalign.c | |
| print_fprintf.c | |
| RTEMS Print Support. | |
| print_printf.c | |
| printf_plugin.c | |
| RTEMS Plugin Printf. | |
| printk.c | |
| This source file contains the implementation of printk(). | |
| printk_plugin.c | |
| This source file contains the implementation of rtems_printk_printer() and rtems_print_printer_printk(). | |
| privateenv.c | |
| Instantiate a Private User Environment. | |
| putk.c | |
| This source file contains the implementation of putk(). | |
| pwdgrp.c | |
| pwdgrp.h | |
| read.c | |
| Read From a File. | |
| readlink.c | |
| Read Value of a Symbolic Link. | |
| readv.c | |
| Read a Vector. | |
| realloc.c | |
| Reallocate Memory Block. | |
| rmdir.c | |
| Remove a Directory. | |
| rtems_heap_extend.c | |
| rtems_heap_extend() implementation. | |
| rtems_heap_extend_via_sbrk.c | |
| RTEMS Extend Heap via Sbrk. | |
| rtems_heap_greedy.c | |
| Greedy Allocate that Empties the Heap. | |
| rtems_heap_sbrk_greedy.c | |
| Greedy Allocate that Empties the sbrk system call. | |
| rtems_memalign.c | |
| RTEMS Variation on Aligned Memory Allocation. | |
| rtems_mkdir.c | |
| rtems_mkdir() implementation. | |
| rtems_put_char.c | |
| This source file contains the implementation of rtems_put_char(). | |
| rtems_putc.c | |
| This source file contains the implementation of rtems_putc(). | |
| rtemscalloc.c | |
| This source file contains the implementation of rtems_calloc(). | |
| setegid.c | |
| seteuid.c | |
| Set Effective User Id. | |
| setgid.c | |
| POSIX sets user and group ids. | |
| setpgid.c | |
| Set Process Group ID for Job Control. | |
| setsid.c | |
| Create Session and Set Process Group ID. | |
| stat.c | |
| sup_fs_check_permissions.c | |
| RTEMS File System Permissions Check Support. | |
| sup_fs_deviceio.c | |
| RTEMS DeviceIO Support. | |
| sup_fs_eval_path.c | |
| RTEMS File Sysyem Path Eval Support. | |
| sup_fs_eval_path_generic.c | |
| RTEMS File System Eval Generic Path. | |
| sup_fs_exist_in_same_instance.c | |
| Checks that the Locations Exist in the Same File System Instance. | |
| sup_fs_location.c | |
| sup_fs_mount_iterate.c | |
| Mount table entry visitor. | |
| sup_fs_next_token.c | |
| RTEMS File System Eval Eat Delimiter Path. | |
| symlink.c | |
| Make a Symbolic Link to a File. | |
| sync.c | |
| This source file contains the implementation of sync(). | |
| tcdrain.c | |
| Line Control Functions. | |
| tcflow.c | |
| tcflush.c | |
| tcflush() - POSIX 1003.1b 7.2.2 - Line Control Functions | |
| tcgetattr.c | |
| Get State. | |
| tcgetpgrp.c | |
| Get Foreground Process Group ID. | |
| tcsendbreak.c | |
| tcsetattr.c | |
| Get and Set State. | |
| tcsetpgrp.c | |
| Set Foreground Process Group ID. | |
| termios.c | |
| termios_baud2index.c | |
| Convert Bxxx Constant to Index. | |
| termios_baud2num.c | |
| Convert Baud Part of Termios control flags to an integral Baud Value. | |
| termios_baudtable.c | |
| RTEMS Termios Baud Table. | |
| termios_num2baud.c | |
| Converts the Integral Baud to Termios Control Flag Representation. | |
| termios_posix_isig_handler.c | |
| termios_setinitialbaud.c | |
| Sets the Initial Baud in the Termios Context. | |
| termiosinitialize.c | |
| This source file contains the implementation of rtems_termios_device_lock_acquire_default() and rtems_termios_device_lock_release_default(). | |
| truncate.c | |
| umask.c | |
| Set File Creation Mask. | |
| unlink.c | |
| Remove an Existing Link. | |
| unmount.c | |
| Unmount a File System. | |
| utime.c | |
| Set file access and modification times in seconds. | |
| utimensat.c | |
| Set file access and modification times in nanoseconds. | |
| utimes.c | |
| Set file access and modification times in milliseconds. | |
| utsname.c | |
| Get System Name. | |
| vprintk.c | |
| This source file contains the implementation of vprintk(). | |
| write.c | |
| Write to a File. | |
| write_r.c | |
| POSIX 1003.1b 6.4.2 - Write to a File. | |
| writev.c | |
| writev() - POSIX 1003.1 - Write a Vector | |
Overview of newlib support (newlib is from CYGNUS) Each task can have its own libc state including: open stdio files strtok multi precision arithmetic state etc.
This is implemented by a reentrancy data structure for each task.
When a task is "started" (in RTEMS sense) the reentrancy structure is allocated.
When task is switched to, the value of global variable _impure_ptr is changed to the value of the new tasks reentrancy structure.
When a task is deleted atexit() processing (for that task) happens task's stdio buffers are flushed
When exit(3) is called calling task's atexit processing done global libc state atexit processing done (this will include any atexit routines installed by drivers) executive is shutdown causes a context switch back to bsp land
NOTE: libc extension are installed by bsp_libc_init() iff we are using clock interrupts. This hack is necessary to allow the tmtests to avoid timing the extensions.
This is a list of cases to consider when implementing a file system:
Where a and b are directories and c is a link to directory b. Consider this sequence:
