RTEMS 6.3
mcf52235 Directory Reference
Directories
btimer
clock
console
include
start
CPU: MCF52235, 60MHz SRAM: 32K FLASH: 256K
This is a Motorola evaluation board that uses the MCF52235 Coldfire CPU. This board is running at 60MHz scaled from a 25MHz oscillator.
NOTES:
Currently this BSP must be configured with most RTEMS features turned off as RAM usage is too high.
Configure as follows:
configure --target=m68k-rtems4.XXX --enable-rtemsbsp=mcf52235 \
To get the tests to compile (but not run) change the linkcmds to specify a larger sram memory region (256K works). This of course will let you compile all tests, but many or most of them wont run.
See testsuites/samples/minumum for an example of what type of config flags you need for this BSP!
In you project before you include confdefs.h, define some or all of the following:
#define CONFIGURE_INIT_TASK_STACK_SIZE x
#define CONFIGURE_MINIMUM_TASK_STACK_SIZE x
#define CONFIGURE_INTERRUPT_STACK_SIZE x
Note that the default stack size is 1K Note that the default number of priorities is 15
TODO:
*) Add drivers for I2C, ADC, FEC *) Support for LWIP *) Recover the 1K stack space reserved in linkcmds used for board startup.
Interrupt map
| | PRIORITY |
|LEVEL| 7 | 6 | 5 | 4 | 3 | 2 | 1 | 0 |
| 7 | | | | | | | | |
| 6 | | | | | | | | |
| 5 | | | | | | | | |
| 4 | | | | | | | | PIT |
| 3 | UART 0 | UART 1 | UART 2 | | | | | |
| 2 | | | | | | | | |
| 1 | | | | | | | | |
Timing tests
*** TIME TEST 1 ***
rtems_semaphore_create 8
rtems_semaphore_delete 10
rtems_semaphore_obtain: available 3
rtems_semaphore_obtain: not available -- NO_WAIT 3
rtems_semaphore_release: no waiting tasks 7
*** END OF TEST 1 ***
*** TIME TEST OVERHEAD ***
rtems_shutdown_executive 0
rtems_task_create 0
rtems_task_ident 0
rtems_task_start 0
rtems_task_restart 0
rtems_task_delete 0
rtems_task_suspend 0
rtems_task_resume 0
rtems_task_set_priority 0
rtems_task_mode 0
rtems_task_wake_when 0
rtems_task_wake_after 0
rtems_interrupt_catch 0
rtems_clock_get 0
rtems_clock_set 0
rtems_clock_tick 0
<pause>
rtems_timer_create 0
rtems_timer_delete 0
rtems_timer_ident 0
rtems_timer_fire_after 0
rtems_timer_fire_when 1
rtems_timer_reset 0
rtems_timer_cancel 0
rtems_semaphore_create 0
rtems_semaphore_delete 0
rtems_semaphore_ident 0
rtems_semaphore_obtain 0
rtems_semaphore_release 0
rtems_message_queue_create 0
rtems_message_queue_ident 0
rtems_message_queue_delete 0
rtems_message_queue_send 0
rtems_message_queue_urgent 0
rtems_message_queue_broadcast 0
rtems_message_queue_receive 0
rtems_message_queue_flush 0
<pause>
rtems_event_send 0
rtems_event_receive 0
rtems_signal_catch 0
rtems_signal_send 0
rtems_partition_create 0
rtems_partition_ident 0
rtems_partition_delete 0
rtems_partition_get_buffer 0
rtems_partition_return_buffer 0
rtems_region_create 0
rtems_region_ident 0
rtems_region_delete 0
rtems_region_get_segment 0
rtems_region_return_segment 0
rtems_port_create 0
rtems_port_ident 0
rtems_port_delete 0
rtems_port_external_to_internal 0
rtems_port_internal_to_external 0
<pause>
rtems_io_initialize 0
rtems_io_open 0
rtems_io_close 0
rtems_io_read 0
rtems_io_write 0
rtems_io_control 0
rtems_fatal_error_occurred 0
rtems_rate_monotonic_create 0
rtems_rate_monotonic_ident 0
rtems_rate_monotonic_delete 0
rtems_rate_monotonic_cancel 0
rtems_rate_monotonic_period 0
rtems_multiprocessing_announce 0
*** END OF TIME OVERHEAD ***
