RTEMS
6.3
Toggle main menu visibility
libfs
src
jffs2
src
debug.h
1
2
* JFFS2 -- Journalling Flash File System, Version 2.
3
4
* Copyright © 2001-2007 Red Hat, Inc.
5
* Copyright © 2004-2010 David Woodhouse <dwmw2@infradead.org>
6
7
* Created by David Woodhouse <dwmw2@infradead.org>
8
9
* For licensing information, see the file 'LICENCE' in this directory.
10
11
12
13
#ifndef _JFFS2_DEBUG_H_
14
#define _JFFS2_DEBUG_H_
15
16
#include <linux/printk.h>
17
#include <linux/sched.h>
18
19
#ifndef CONFIG_JFFS2_FS_DEBUG
20
#define CONFIG_JFFS2_FS_DEBUG 0
21
#endif
22
23
#if CONFIG_JFFS2_FS_DEBUG > 0
24
/* Enable "paranoia" checks and dumps */
25
#define JFFS2_DBG_PARANOIA_CHECKS
26
#define JFFS2_DBG_DUMPS
27
28
29
* By defining/undefining the below macros one may select debugging messages
30
* fro specific JFFS2 subsystems.
31
32
#define JFFS2_DBG_READINODE_MESSAGES
33
#define JFFS2_DBG_FRAGTREE_MESSAGES
34
#define JFFS2_DBG_DENTLIST_MESSAGES
35
#define JFFS2_DBG_NODEREF_MESSAGES
36
#define JFFS2_DBG_INOCACHE_MESSAGES
37
#define JFFS2_DBG_SUMMARY_MESSAGES
38
#define JFFS2_DBG_FSBUILD_MESSAGES
39
#endif
40
41
#if CONFIG_JFFS2_FS_DEBUG > 1
42
#define JFFS2_DBG_FRAGTREE2_MESSAGES
43
#define JFFS2_DBG_READINODE2_MESSAGES
44
#define JFFS2_DBG_MEMALLOC_MESSAGES
45
#endif
46
47
/* Sanity checks are supposed to be light-weight and enabled by default */
48
#define JFFS2_DBG_SANITY_CHECKS
49
50
51
* Dx() are mainly used for debugging messages, they must go away and be
52
* superseded by nicer dbg_xxx() macros...
53
54
55
#define DEBUG
56
#define D1(x) x
57
#else
58
#define D1(x)
59
#endif
60
61
62
#define D2(x) x
63
#else
64
#define D2(x)
65
#endif
66
67
#define jffs2_dbg(level, fmt, ...) \
68
do { \
69
if (CONFIG_JFFS2_FS_DEBUG >= level) \
70
pr_debug(fmt, ##__VA_ARGS__); \
71
} while (0)
72
73
/* The prefixes of JFFS2 messages */
74
#define JFFS2_DBG KERN_DEBUG
75
#define JFFS2_DBG_PREFIX "[JFFS2 DBG]"
76
#define JFFS2_DBG_MSG_PREFIX JFFS2_DBG JFFS2_DBG_PREFIX
77
78
/* JFFS2 message macros */
79
#ifndef __rtems__
80
#define JFFS2_ERROR(fmt, ...) \
81
pr_err("error: (%d) %s: " fmt, \
82
task_pid_nr(current), __func__, ##__VA_ARGS__)
83
84
#define JFFS2_WARNING(fmt, ...) \
85
pr_warn("warning: (%d) %s: " fmt, \
86
87
88
#define JFFS2_NOTICE(fmt, ...) \
89
pr_notice("notice: (%d) %s: " fmt, \
90
91
92
#define JFFS2_DEBUG(fmt, ...) \
93
printk(KERN_DEBUG "[JFFS2 DBG] (%d) %s: " fmt, \
94
95
#else
/* __rtems__ */
96
97
pr_err("error: %s: " fmt, \
98
99
100
101
pr_warn("warning: %s: " fmt, \
102
103
104
105
pr_notice("notice: %s: " fmt, \
106
107
108
109
printk(KERN_DEBUG "[JFFS2 DBG] %s: " fmt, \
110
111
#endif
/* __rtems__ */
112
113
114
* We split our debugging messages on several parts, depending on the JFFS2
115
* subsystem the message belongs to.
116
117
/* Read inode debugging messages */
118
#ifdef JFFS2_DBG_READINODE_MESSAGES
119
#define dbg_readinode(fmt, ...) JFFS2_DEBUG(fmt, ##__VA_ARGS__)
120
#else
121
#define dbg_readinode(fmt, ...) no_printk(fmt, ##__VA_ARGS__)
122
#endif
123
#ifdef JFFS2_DBG_READINODE2_MESSAGES
124
#define dbg_readinode2(fmt, ...) JFFS2_DEBUG(fmt, ##__VA_ARGS__)
125
#else
126
#define dbg_readinode2(fmt, ...) no_printk(fmt, ##__VA_ARGS__)
127
#endif
128
129
/* Fragtree build debugging messages */
130
#ifdef JFFS2_DBG_FRAGTREE_MESSAGES
131
#define dbg_fragtree(fmt, ...) JFFS2_DEBUG(fmt, ##__VA_ARGS__)
132
#else
133
#define dbg_fragtree(fmt, ...) no_printk(fmt, ##__VA_ARGS__)
134
#endif
135
#ifdef JFFS2_DBG_FRAGTREE2_MESSAGES
136
#define dbg_fragtree2(fmt, ...) JFFS2_DEBUG(fmt, ##__VA_ARGS__)
137
#else
138
#define dbg_fragtree2(fmt, ...) no_printk(fmt, ##__VA_ARGS__)
139
#endif
140
141
/* Directory entry list manilulation debugging messages */
142
#ifdef JFFS2_DBG_DENTLIST_MESSAGES
143
#define dbg_dentlist(fmt, ...) JFFS2_DEBUG(fmt, ##__VA_ARGS__)
144
#else
145
#define dbg_dentlist(fmt, ...) no_printk(fmt, ##__VA_ARGS__)
146
#endif
147
148
/* Print the messages about manipulating node_refs */
149
#ifdef JFFS2_DBG_NODEREF_MESSAGES
150
#define dbg_noderef(fmt, ...) JFFS2_DEBUG(fmt, ##__VA_ARGS__)
151
#else
152
#define dbg_noderef(fmt, ...) no_printk(fmt, ##__VA_ARGS__)
153
#endif
154
155
/* Manipulations with the list of inodes (JFFS2 inocache) */
156
#ifdef JFFS2_DBG_INOCACHE_MESSAGES
157
#define dbg_inocache(fmt, ...) JFFS2_DEBUG(fmt, ##__VA_ARGS__)
158
#else
159
#define dbg_inocache(fmt, ...) no_printk(fmt, ##__VA_ARGS__)
160
#endif
161
162
/* Summary debugging messages */
163
#ifdef JFFS2_DBG_SUMMARY_MESSAGES
164
#define dbg_summary(fmt, ...) JFFS2_DEBUG(fmt, ##__VA_ARGS__)
165
#else
166
#define dbg_summary(fmt, ...) no_printk(fmt, ##__VA_ARGS__)
167
#endif
168
169
/* File system build messages */
170
#ifdef JFFS2_DBG_FSBUILD_MESSAGES
171
#define dbg_fsbuild(fmt, ...) JFFS2_DEBUG(fmt, ##__VA_ARGS__)
172
#else
173
#define dbg_fsbuild(fmt, ...) no_printk(fmt, ##__VA_ARGS__)
174
#endif
175
176
/* Watch the object allocations */
177
#ifdef JFFS2_DBG_MEMALLOC_MESSAGES
178
#define dbg_memalloc(fmt, ...) JFFS2_DEBUG(fmt, ##__VA_ARGS__)
179
#else
180
#define dbg_memalloc(fmt, ...) no_printk(fmt, ##__VA_ARGS__)
181
#endif
182
183
/* Watch the XATTR subsystem */
184
#ifdef JFFS2_DBG_XATTR_MESSAGES
185
#define dbg_xattr(fmt, ...) JFFS2_DEBUG(fmt, ##__VA_ARGS__)
186
#else
187
#define dbg_xattr(fmt, ...) no_printk(fmt, ##__VA_ARGS__)
188
#endif
189
190
/* "Sanity" checks */
191
void
192
__jffs2_dbg_acct_sanity_check_nolock(
struct
jffs2_sb_info
*c,
193
struct
jffs2_eraseblock
*jeb);
194
void
195
__jffs2_dbg_acct_sanity_check(
struct
jffs2_sb_info
*c,
196
struct
jffs2_eraseblock
*jeb);
197
198
/* "Paranoia" checks */
199
void
200
__jffs2_dbg_fragtree_paranoia_check(
struct
jffs2_inode_info
*f);
201
void
202
__jffs2_dbg_fragtree_paranoia_check_nolock(
struct
jffs2_inode_info
*f);
203
void
204
__jffs2_dbg_acct_paranoia_check(
struct
jffs2_sb_info
*c,
205
struct
jffs2_eraseblock
*jeb);
206
void
207
__jffs2_dbg_acct_paranoia_check_nolock(
struct
jffs2_sb_info
*c,
208
struct
jffs2_eraseblock
*jeb);
209
void
210
__jffs2_dbg_prewrite_paranoia_check(
struct
jffs2_sb_info
*c,
211
uint32_t ofs,
int
len);
212
213
/* "Dump" functions */
214
void
215
__jffs2_dbg_dump_jeb(
struct
jffs2_sb_info
*c,
struct
jffs2_eraseblock
*jeb);
216
void
217
__jffs2_dbg_dump_jeb_nolock(
struct
jffs2_eraseblock
*jeb);
218
void
219
__jffs2_dbg_dump_block_lists(
struct
jffs2_sb_info
*c);
220
void
221
__jffs2_dbg_dump_block_lists_nolock(
struct
jffs2_sb_info
*c);
222
void
223
__jffs2_dbg_dump_node_refs(
struct
jffs2_sb_info
*c,
224
struct
jffs2_eraseblock
*jeb);
225
void
226
__jffs2_dbg_dump_node_refs_nolock(
struct
jffs2_sb_info
*c,
227
struct
jffs2_eraseblock
*jeb);
228
void
229
__jffs2_dbg_dump_fragtree(
struct
jffs2_inode_info
*f);
230
void
231
__jffs2_dbg_dump_fragtree_nolock(
struct
jffs2_inode_info
*f);
232
void
233
__jffs2_dbg_dump_buffer(
unsigned
char
*buf,
int
len, uint32_t offs);
234
void
235
__jffs2_dbg_dump_node(
struct
jffs2_sb_info
*c, uint32_t ofs);
236
237
#ifdef JFFS2_DBG_PARANOIA_CHECKS
238
#define jffs2_dbg_fragtree_paranoia_check(f) \
239
__jffs2_dbg_fragtree_paranoia_check(f)
240
#define jffs2_dbg_fragtree_paranoia_check_nolock(f) \
241
__jffs2_dbg_fragtree_paranoia_check_nolock(f)
242
#define jffs2_dbg_acct_paranoia_check(c, jeb) \
243
__jffs2_dbg_acct_paranoia_check(c,jeb)
244
#define jffs2_dbg_acct_paranoia_check_nolock(c, jeb) \
245
__jffs2_dbg_acct_paranoia_check_nolock(c,jeb)
246
#define jffs2_dbg_prewrite_paranoia_check(c, ofs, len) \
247
__jffs2_dbg_prewrite_paranoia_check(c, ofs, len)
248
#else
249
250
251
252
253
254
#endif
/* !JFFS2_PARANOIA_CHECKS */
255
256
#ifdef JFFS2_DBG_DUMPS
257
#define jffs2_dbg_dump_jeb(c, jeb) \
258
__jffs2_dbg_dump_jeb(c, jeb);
259
#define jffs2_dbg_dump_jeb_nolock(jeb) \
260
__jffs2_dbg_dump_jeb_nolock(jeb);
261
#define jffs2_dbg_dump_block_lists(c) \
262
__jffs2_dbg_dump_block_lists(c)
263
#define jffs2_dbg_dump_block_lists_nolock(c) \
264
__jffs2_dbg_dump_block_lists_nolock(c)
265
#define jffs2_dbg_dump_fragtree(f) \
266
__jffs2_dbg_dump_fragtree(f);
267
#define jffs2_dbg_dump_fragtree_nolock(f) \
268
__jffs2_dbg_dump_fragtree_nolock(f);
269
#define jffs2_dbg_dump_buffer(buf, len, offs) \
270
__jffs2_dbg_dump_buffer(*buf, len, offs);
271
#define jffs2_dbg_dump_node(c, ofs) \
272
__jffs2_dbg_dump_node(c, ofs);
273
#else
274
275
276
277
278
279
280
281
282
#endif
/* !JFFS2_DBG_DUMPS */
283
284
#ifdef JFFS2_DBG_SANITY_CHECKS
285
#define jffs2_dbg_acct_sanity_check(c, jeb) \
286
__jffs2_dbg_acct_sanity_check(c, jeb)
287
#define jffs2_dbg_acct_sanity_check_nolock(c, jeb) \
288
__jffs2_dbg_acct_sanity_check_nolock(c, jeb)
289
#else
290
291
292
#endif
/* !JFFS2_DBG_SANITY_CHECKS */
293
294
#endif
/* _JFFS2_DEBUG_H_ */
jffs2_eraseblock
Definition
nodelist.h:278
jffs2_inode_info
Definition
jffs2_fs_i.h:20
jffs2_sb_info
Definition
jffs2_fs_sb.h:51
