RTEMS 6.3
Global BSP definitions. More...
#include <bspopts.h>#include <bsp/default-initial-extension.h>#include <rtems.h>#include <erc32.h>#include <rtems/irq-extension.h>Go to the source code of this file.
| #define | BSP_FEATURE_IRQ_EXTENSION |
| #define | BSP_IDLE_TASK_BODY bsp_idle_thread |
| #define | RTEMS_BSP_NETWORK_DRIVER_NAME "sonic1" |
| #define | RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_erc32_sonic_driver_attach |
Typedefs | |
| typedef void(*) | bsp_shared_isr(void *arg) |
| void * | bsp_idle_thread (uintptr_t ignored) |
| Optimized idle task. | |
| int | rtems_erc32_sonic_driver_attach (struct rtems_bsdnet_ifconfig *config) |
| rtems_isr_entry | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
| void | BSP_fatal_exit (uint32_t error) |
| void | rtems_bsp_delay (int usecs) |
| void | console_outbyte_polled (int port, unsigned char ch) |
| int | console_inbyte_nonblocking (int port) |
| int | RAM_START |
| int | RAM_END |
| int | RAM_SIZE |
| int | PROM_START |
| int | PROM_END |
| int | PROM_SIZE |
| int | CLOCK_SPEED |
| int | end |
