RTEMS 6.3
bspimpl.h
2
8
9/*
10 * COPYRIGHT (c) 2016.
11 * On-Line Applications Research Corporation (OAR).
12 *
13 * Redistribution and use in source and binary forms, with or without
14 * modification, are permitted provided that the following conditions
15 * are met:
16 * 1. Redistributions of source code must retain the above copyright
17 * notice, this list of conditions and the following disclaimer.
18 * 2. Redistributions in binary form must reproduce the above copyright
19 * notice, this list of conditions and the following disclaimer in the
20 * documentation and/or other materials provided with the distribution.
21 *
22 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
23 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
24 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
25 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
26 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
27 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
28 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
29 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
30 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
31 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
32 * POSSIBILITY OF SUCH DAMAGE.
33 */
34
35#ifndef __BSPIMPL_h
36#define __BSPIMPL_h
37
38#include <rtems/pci.h>
39
40/*
41 * PCI Support Methods
42 */
43const pci_config_access_functions *pci_bios_initialize(void);
44const pci_config_access_functions *pci_io_initialize(void);
45
46/*
47 * Helper to parse boot command line arguments related to the console driver
48 */
49void pc386_parse_console_arguments(void);
50
51/*
52 * Helper to parse boot command line arguments related to gdb
53 */
54void pc386_parse_gdb_arguments(void);
55
56/*
57 * Dynamically probe for Legacy UARTS
58 */
59void legacy_uart_probe(void);
60
61/*
62 * Dynamically probe for PCI UARTS
63 */
64void pci_uart_probe(void);
65
66#endif
Definition pci.h:1123
