RTEMS
6.3
Toggle main menu visibility
bsps
bfin
include
libcpu
uart.h
1
2
* RTEMS driver for Blackfin UARTs
3
4
* COPYRIGHT (c) 2008 Kallisti Labs, Los Gatos, CA, USA
5
* written by Allan Hessenflow <allanh@kallisti.com>
6
7
* The license and distribution terms for this file may be
8
* found in the file LICENSE in this distribution or at
9
* http://www.rtems.org/license/LICENSE.
10
11
12
13
#ifndef _UART_H_
14
#define _UART_H_
15
16
17
#ifdef __cplusplus
18
extern
"C"
19
#endif
20
23
typedef
struct
24
const
char
*name;
25
uint32_t
uart_baseAddress
26
uint32_t
uart_rxDmaBaseAddress
27
uint32_t
uart_txDmaBaseAddress
28
bool
uart_useInterrupts
29
bool
uart_useDma
30
int
uart_baud
31
32
void
termios
33
uint8_t
volatile
flags
34
uint16_t
length
35
bfin_uart_channel_t
36
37
38
typedef
struct
39
uint32_t freq;
40
int
num_channels;
41
bfin_uart_channel_t
*channels;
42
bfin_uart_config_t
43
49
typedef
struct
50
uint32_t base_address;
51
int
source;
52
bfin_uart_arg_t
53
54
55
56
char
bfin_uart_poll_read(
rtems_device_minor_number
minor);
57
58
void
bfin_uart_poll_write(
int
minor,
char
c);
59
60
67
rtems_status_code
bfin_uart_initialize(
rtems_device_major_number
major,
68
bfin_uart_config_t
*config);
69
70
71
84
rtems_device_driver
bfin_uart_open(
major,
85
minor,
void
*arg);
86
87
88
100
void
bfinUart_txDmaIsr(
void
*_arg);
101
102
103
110
void
bfinUart_rxDmaIsr(
void
*_arg);
111
112
121
void
bfinUart_txIsr(
void
*_arg);
122
123
127
void
bfinUart_rxIsr(
void
*_arg);
128
129
130
#ifdef __cplusplus
131
132
#endif
133
134
#endif
/* _UART_H_ */
135
rtems_device_driver
rtems_status_code rtems_device_driver
This type shall be used in device driver entry declarations and definitions.
Definition
io.h:90
uint32_t rtems_device_major_number
This integer type represents the major number of devices.
Definition
io.h:103
uint32_t rtems_device_minor_number
This integer type represents the minor number of devices.
Definition
io.h:115
rtems_status_code
rtems_status_code
Definition
status.h:85
bfin_uart_arg_t
Definition
uart.h:49
bfin_uart_channel_t
Definition
uart.h:23
bfin_uart_channel_t::length
uint16_t length
Definition
uart.h:34
bfin_uart_channel_t::uart_useInterrupts
bool uart_useInterrupts
Definition
uart.h:28
bfin_uart_channel_t::termios
void * termios
Definition
uart.h:32
bfin_uart_channel_t::uart_baseAddress
uint32_t uart_baseAddress
Definition
uart.h:25
bfin_uart_channel_t::flags
uint8_t volatile flags
Definition
uart.h:33
bfin_uart_channel_t::uart_rxDmaBaseAddress
uint32_t uart_rxDmaBaseAddress
Definition
uart.h:26
bfin_uart_channel_t::uart_useDma
bool uart_useDma
Definition
uart.h:29
bfin_uart_channel_t::uart_baud
int uart_baud
Definition
uart.h:30
bfin_uart_channel_t::uart_txDmaBaseAddress
uint32_t uart_txDmaBaseAddress
Definition
uart.h:27
bfin_uart_config_t
Definition
uart.h:38
