RTEMS
6.3
Toggle main menu visibility
bsps
arm
csb337
include
at91rm9200.h
1
8
9
10
* Atmel AT91RM9200 Register definitions, used in KIT637_V6 (CSB637)
11
12
* Copyright (c) 2003 by Cogent Computer Systems
13
* Written by Mike Kelly <mike@cogcomp.com>
14
15
* Modified by Fernando Nicodemos <fgnicodemos@terra.com.br>
16
* from NCB - Sistemas Embarcados Ltda. (Brazil)
17
18
* The license and distribution terms for this file may be
19
* found in the file LICENSE in this distribution or at
20
* http://www.rtems.org/license/LICENSE.
21
22
23
24
#ifndef __AT91RM9200_H__
25
#define __AT91RM9200_H__
26
27
#include "
bits.h
28
29
typedef
volatile
unsigned
long
vulong;
30
31
/* Source Mode Register - 32 of them */
32
#define AIC_SMR_BASE 0xFFFFF000
33
#define AIC_SMR_REG(_x_) *(vulong *)(AIC_SMR_BASE + (_x_ & 0x7c))
34
35
/* Source Vector Register - 32 of them */
36
#define AIC_SVR_BASE 0xFFFFF080
37
#define AIC_SVR_REG(_x_) *(vulong *)(AIC_SVR_BASE + (_x_ & 0x7c))
38
39
/* Control Register - 32 of them */
40
#define AIC_CTL_BASE 0xFFFFF100
41
#define AIC_CTL_REG(_x_) *(vulong *)(AIC_CTL_BASE + (_x_ & 0x7f))
42
43
/* Register Offsets */
44
/* offsets from AIC_SMR_BASE and AIC_SVR_BASE */
45
#define AIC_SMR_FIQ 0x00
/* Advanced Interrupt Controller FIQ */
46
#define AIC_SMR_SYSIRQ 0x04
/* Advanced Interrupt Controller SYSIRQ */
47
#define AIC_SMR_PIOA 0x08
/* Parallel I/O Controller A */
48
#define AIC_SMR_PIOB 0x0c
/* Parallel I/O Controller B */
49
#define AIC_SMR_PIOC 0x10
/* Parallel I/O Controller C */
50
#define AIC_SMR_PIOD 0x14
/* Parallel I/O Controller D */
51
#define AIC_SMR_US0 0x18
/* USART 0 */
52
#define AIC_SMR_US1 0x1c
/* USART 1 */
53
#define AIC_SMR_US2 0x20
/* USART 2 */
54
#define AIC_SMR_US3 0x24
/* USART 3 */
55
#define AIC_SMR_MCI 0x28
/* Multimedia Card Interface */
56
#define AIC_SMR_UDP 0x2c
/* USB Device Port */
57
#define AIC_SMR_TWI 0x30
/* Two-wire Interface */
58
#define AIC_SMR_SPI 0x34
/* Serial Peripheral Interface */
59
#define AIC_SMR_SSC0 0x38
/* Synchronous Serial Controller 0 */
60
#define AIC_SMR_SSC1 0x3c
/* Synchronous Serial Controller 1 */
61
#define AIC_SMR_SSC2 0x40
/* Synchronous Serial Controller 2 */
62
#define AIC_SMR_TC0 0x44
/* Timer/Counter 0 */
63
#define AIC_SMR_TC1 0x48
/* Timer/Counter 1 */
64
#define AIC_SMR_TC2 0x4c
/* Timer/Counter 2 */
65
#define AIC_SMR_TC3 0x50
/* Timer/Counter 3 */
66
#define AIC_SMR_TC4 0x54
/* Timer/Counter 4 */
67
#define AIC_SMR_TC5 0x58
/* Timer/Counter 5 */
68
#define AIC_SMR_UHP 0x5c
/* USB Host Port */
69
#define AIC_SMR_EMAC 0x60
/* Ethernet MAC */
70
#define AIC_SMR_IRQ0 0x64
/* Advanced Interrupt Controller IRQ0 */
71
#define AIC_SMR_IRQ1 0x68
/* Advanced Interrupt Controller IRQ1 */
72
#define AIC_SMR_IRQ2 0x6c
/* Advanced Interrupt Controller IRQ2 */
73
#define AIC_SMR_IRQ3 0x70
/* Advanced Interrupt Controller IRQ3 */
74
#define AIC_SMR_IRQ4 0x74
/* Advanced Interrupt Controller IRQ4 */
75
#define AIC_SMR_IRQ5 0x78
/* Advanced Interrupt Controller IRQ5 */
76
#define AIC_SMR_IRQ6 0x7c
/* Advanced Interrupt Controller IRQ6 */
77
78
/* from AIC_CTL_BASE */
79
#define AIC_IVR 0x00
/* IRQ Vector Register */
80
#define AIC_FVR 0x04
/* FIQ Vector Register */
81
#define AIC_ISR 0x08
/* Interrupt Status Register */
82
#define AIC_IPR 0x0C
/* Interrupt Pending Register */
83
#define AIC_IMR 0x10
/* Interrupt Mask Register */
84
#define AIC_CISR 0x14
/* Core Interrupt Status Register */
85
#define AIC_IECR 0x20
/* Interrupt Enable Command Register */
86
#define AIC_IDCR 0x24
/* Interrupt Disable Command Register */
87
#define AIC_ICCR 0x28
/* Interrupt Clear Command Register */
88
#define AIC_ISCR 0x2C
/* Interrupt Set Command Register */
89
#define AIC_EOICR 0x30
/* End of Interrupt Command Register */
90
#define AIC_SPU 0x34
/* Spurious Vector Register */
91
#define AIC_DCR 0x38
/* Debug Control Register (Protect) */
92
#define AIC_FFER 0x40
/* Fast Forcing Enable Register */
93
#define AIC_FFDR 0x44
/* Fast Forcing Disable Register */
94
#define AIC_FFSR 0x48
/* Fast Forcing Status Register */
95
96
/* Bit Defines */
97
/* AIC_ISR - Interrupt Status Register */
98
#define AIC_ISR_IRQID_MASK 0x1f
/* current interrupt ID */
99
100
/* AIC_CISR - Core Interrupt Status Register */
101
#define AIC_CISR_IRQ BIT1
/* 1 = Core IRQ is active */
102
#define AIC_CISR_FIQ BIT0
/* 1 = Core FIQ is active */
103
104
/* AIC_DCR - Debug Control Register (Protect) */
105
#define AIC_DCR_GMSK BIT1
/* 0 = AIC controls IRQ and FIQ */
106
#define AIC_DCR_PROT BIT0
/* 1 = enable protection mode */
107
108
/* AIC_SMR */
109
#define AIC_SMR_PRIOR(_x_) ((_x_ & 0x07) << 0)
110
#define AIC_SMR_SRC_LVL_LOW (0 << 5)
/* Are these right? docs don't say which is high/low */
111
#define AIC_SMR_SRC_EDGE_LOW (1 << 5)
112
#define AIC_SMR_SRC_LVL_HI (2 << 5)
113
#define AIC_SMR_SRC_EDGE_HI (3 << 5)
114
115
116
/* Debug Unit */
117
118
#define DBGU_BASE 0xFFFFF200
119
#define DBGU_REG(_x_) *(vulong *)(DBGU_BASE + _x_)
120
121
122
#define DBGU_CR 0x00
/* Control Register */
123
#define DBGU_MR 0x04
/* Mode Register */
124
#define DBGU_IER 0x08
/* Interrupt Enable Register */
125
#define DBGU_IDR 0x0C
/* Interrupt Disable Register */
126
#define DBGU_IMR 0x10
127
#define DBGU_CSR 0x14
/* Channel Status Register */
128
#define DBGU_RHR 0x18
/* Receiver Holding Register */
129
#define DBGU_THR 0x1C
/* Transmitter Holding Register */
130
#define DBGU_BRGR 0x20
/* Baud Rate Generator Register */
131
#define DBGU_C1R 0x40
/* Chip ID1 Register */
132
#define DBGU_C2R 0x44
/* Chip ID2 Register */
133
#define DBGU_FNTR 0x48
/* Force NTRST Register */
134
135
136
/* USART 0-3 */
137
138
#define USART0_BASE 0xFFFC0000
139
#define USART1_BASE 0xFFFC4000
140
#define USART2_BASE 0xFFFC8000
141
#define USART3_BASE 0xFFFCC000
142
143
* WARNING: The USART3_BASE at the AT91RM9200 Manual is wrong!!!
144
* Manual revision: Rev. 1768H-ATARM–16-Jun-09
145
* USART3_BASE is NOT 0xFFECC000
146
147
148
149
/* System Timer */
150
151
#define ST_BASE 0xFFFFFD00
152
#define ST_REG(_x_) *(vulong *)(ST_BASE + _x_)
153
154
155
#define ST_CR 0x00
156
#define ST_PIMR 0x04
/* Period Interval Mode Register */
157
#define ST_WDMR 0x08
/* Watchdog Mode Register */
158
#define ST_RTMR 0x0C
/* Real-time Mode Register */
159
#define ST_SR 0x10
/* Status Register */
160
#define ST_IER 0x14
161
#define ST_IDR 0x18
162
#define ST_IMR 0x1C
163
#define ST_RTAR 0x20
/* Real-time Alarm Register */
164
#define ST_CRTR 0x24
/* Current Real-time Register */
165
166
/* Bit Defines */
167
/* ST_CR - Control Register */
168
#define ST_CR_WDRST BIT0
/* write 1 to reload WD counter */
169
170
/* ST_PIMR - Period Interval Mode Register */
171
#define ST_PIMR_PIV_MASK 0x0000ffff
172
173
/* ST_WDMR - Watchdog Mode Register */
174
#define ST_WDMR_EXTEN BIT17
/* WDOVF is not implemented on AT91RM9200 */
175
#define ST_WDMR_RSTEN BIT16
/* 1 = reset the AT91RM9200 when WD overflows */
176
#define ST_WDMR_WDV_MASK 0x0000ffff
/* WD counter is in the lower 16-bits */
177
178
/* ST_RTMR - Real-time Mode Register */
179
#define ST_RTMR_RTPRES_MASK 0x0000ffff
/* Real-Time Prescaler */
180
181
/* ST_SR - Status Register - Read Only */
182
/* ST_IER - Interrupt Enable Register - Write Only */
183
/* ST_IDR - Interrupt Disable Register - Write Only */
184
/* ST_IMR - Interrupt Mask Register - Read Only */
185
#define ST_SR_ALMS BIT3
186
#define ST_SR_RTTINC BIT2
187
#define ST_SR_WDOVF BIT1
188
#define ST_SR_PITS BIT0
189
190
/* ST_RTAR - Real-time Alarm Register */
191
#define ST_RTAR_ALMV_MASK 0x000fffff
192
193
/* ST_CRTR - Current Real-time Register */
194
#define ST_CRTR_CRTV_MASK 0x000fffff
195
196
197
198
* Peripheral Data Control (DMA)
199
* Note that each of the following peripherals has it's own
200
* set of these registers starting at offset 0x100 from it's
201
* base address: DBGU, SPI, USART and SSC
202
* To access the DMA for a peripheral, use the macro for that
203
* peripheral but with these register offsets
204
205
206
#define PDC_RPR 0x100
/* Receive Pointer Register */
207
#define PDC_RCR 0x104
/* Receive Counter Register */
208
#define PDC_TPR 0x108
/* Transmit Pointer Register */
209
#define PDC_TCR 0x10c
/* Transmit Counter Register */
210
#define PDC_RNPR 0x110
/* Receive Next Pointer Register */
211
#define PDC_RNCR 0x114
/* Receive Next Counter Register */
212
#define PDC_TNPR 0x118
/* Transmit Next Pointer Register */
213
#define PDC_TNCR 0x11c
/* Transmit Next Counter Register */
214
#define PDC_PTCR 0x120
/* PDC Transfer Control Register */
215
#define PDC_PTSR 0x124
/* PDC Transfer Status Register */
216
217
218
* Parallel I/O Unit
219
* There are four PIO blocks - A, B, C and D. They all have the
220
* same register set, but different base addresses
221
222
/* Port A */
223
#define PIOA_BASE 0xFFFFF400
224
#define PIOA_REG(_x_) *(vulong *)(PIOA_BASE + _x_)
225
226
/* Port B */
227
#define PIOB_BASE 0xFFFFF600
228
#define PIOB_REG(_x_) *(vulong *)(PIOB_BASE + _x_)
229
230
/* Port C */
231
#define PIOC_BASE 0xFFFFF800
232
#define PIOC_REG(_x_) *(vulong *)(PIOC_BASE + _x_)
233
234
/* Port D */
235
#define PIOD_BASE 0xFFFFFA00
236
#define PIOD_REG(_x_) *(vulong *)(PIOD_BASE + _x_)
237
238
239
* Power Management and Clock Control
240
241
#define PMC_BASE 0xFFFFFC00
242
#define PMC_REG(_x_) *(vulong *)(PMC_BASE + _x_)
243
244
245
* MAC Unit
246
247
#define EMAC_BASE 0xFFFBC000
248
#define EMAC_REG(_x_) *(vulong *)(EMAC_BASE + _x_)
249
250
251
* Timer/Counter Unit
252
253
#define TC_BASE 0xFFFA0000
254
#define TC_REG(_x_) *(vulong *)(TC_BASE + 0x00 + _x_)
255
#define TC_TC0_REG(_x_) *(vulong *)(TC_BASE + 0x00 + _x_)
256
#define TC_TC1_REG(_x_) *(vulong *)(TC_BASE + 0x40 + _x_)
257
#define TC_TC2_REG(_x_) *(vulong *)(TC_BASE + 0x80 + _x_)
258
259
/* Offsets from TC_TC?_REG */
260
#define TC_CCR 0x00
/* Channel Control Register */
261
#define TC_CMR 0x04
/* Channel Mode Register */
262
#define TC_CV 0x10
/* Counter Value */
263
#define TC_RA 0x14
/* Register A */
264
#define TC_RB 0x18
/* Register B */
265
#define TC_RC 0x1C
/* Register C */
266
#define TC_SR 0x20
267
#define TC_IER 0x24
268
#define TC_IDR 0x28
269
#define TC_IMR 0x2C
270
271
/* Offsets from TC_BASE */
272
#define TC_BCR 0xc0
273
#define TC_BMR 0xc4
274
275
/* Block control register */
276
#define TC_BCR_SYNC BIT1
/* Set to syncronize channels */
277
278
/* Block mode register */
279
#define TC_BMR_TC0(_x_) ((_x_ & 0x3) << 0)
/* TC0 clock source */
280
#define TC_BMR_TC1(_x_) ((_x_ & 0x3) << 2)
/* TC1 clock source */
281
#define TC_BMR_TC2(_x_) ((_x_ & 0x3) << 4)
/* TC2 clock source */
282
283
/* Channel Control register */
284
#define TC_CCR_CLKEN BIT0
/* Enable clock */
285
#define TC_CCR_CLKDIS BIT1
/* Disable clock */
286
#define TC_CCR_SWTRG BIT2
/* Software trigger command */
287
288
/* Channel mode register */
289
#define TC_CMR_TCCLKS(_x_) ((_x_ & 0x7) << 0)
/* Clock source */
290
#define TC_CMR_CLKI BIT3
/* Clock invert */
291
#define TC_BURST(_x_) ((_x_ & 0x3 << 4)
/* Burst signal selection */
292
#define TC_WAVE BIT15
/* 0 for catpure, 1 for wave */
293
294
/* Channel mode register - capture mode (TC_WAVE = 0) */
295
#define TC_CMR_LDBSTOP BIT6
/* Set to stop clock when RB loads */
296
#define TC_CMR_LDBDIS BIT7
/* Set to disable clock when RB loads */
297
#define TC_CMR_ETRGEDG(_x_) ((_x_ & 0x3) << 8)
/* Select edge triggering mode */
298
#define TC_CMR_ABETRG BIT10
/* Select ext trigger source */
299
#define TC_CMR_CPCTRG BIT14
/* RC Compare trigger enable */
300
#define TC_CMR_LDRA(_x_) ((_x_ & 0x3) << 16)
/* RA loading selection */
301
#define TC_CMR_LDRB(_x_) ((_x_ & 0x3) << 18)
/* RB loading selection */
302
303
/* Channel mode register - wave mode (TC_WAVE = 1) */
304
#define TC_CMR_CPCSTOP BIT6
/* Clock stopped w/ RC compare */
305
#define TC_CMR_CPCDIS BIT7
/* Clock disabled w/ RC compare */
306
#define TC_CMR_EEVTEDG(_x_) ((_x_ & 0x3) << 8)
/* Ext event edge selection */
307
#define TC_CMR_EEVT(_x_) ((_x_ & 0x3) << 10)
/* Ext event selection */
308
#define TC_CMR_ENETRG BIT12
/* Ext event trigger enable */
309
#define TC_CMR_WAVESEL(_x_) ((_x_ & 0x3) << 13)
/* Waveform selection */
310
#define TC_CMR_ACPA(_x_) ((_x_ & 0x3) << 16)
/* RA compare effect on TIOA */
311
#define TC_CMR_ACPC(_x_) ((_x_ & 0x3) << 18)
/* RC compare effect on TIOA */
312
#define TC_CMR_AEEVT(_x_) ((_x_ & 0x3) << 20)
/* Ext event effect on TIOA */
313
#define TC_CMR_ASWTRG(_x_) ((_x_ & 0x3) << 22)
/* SW trigger effect on TIOA */
314
#define TC_CMR_BCPB(_x_) ((_x_ & 0x3) << 24)
/* RB compare effect on TIOB */
315
#define TC_CMR_BCPC(_x_) ((_x_ & 0x3) << 26)
/* RC compare effect on TIOB */
316
#define TC_CMR_BEEVT(_x_) ((_x_ & 0x3) << 28)
/* Ext event effect on TIOB */
317
#define TC_CMR_BSWTRG(_x_) ((_x_ & 0x3) << 30)
/* SW trigger effect on TIOB */
318
319
/* Counter value */
320
#define TC_CV_MASK 0xffff
/* Timer counter mask */
321
322
/* Status, Interrupt enable, Interrupt disable, and Interrupt mask registers */
323
#define TC_SR_COVFS BIT0
/* Counter overflow status */
324
#define TC_SR_LOVRS BIT1
/* Load overrun status */
325
#define TC_SR_CPAS BIT2
/* RA compare status */
326
#define TC_SR_CPBS BIT3
/* RB compare status */
327
#define TC_SR_CPCS BIT4
/* RC compare status */
328
#define TC_SR_LDRAS BIT5
/* RA loading status */
329
#define TC_SR_LDRBS BIT6
/* RB loading status */
330
#define TC_SR_ETRGS BIT7
/* External trigger status */
331
#define TC_SR_CLKSTA BIT16
/* Clock enabling status */
332
#define TC_SR_MTIOA BIT17
/* TIOA Mirror */
333
#define TC_SR_MTIOB BIT18
/* TIOB Mirror */
334
335
336
* External Bus Interface Unit
337
338
#define EBI_BASE 0xFFFFFF60
339
#define EBI_REG(_x_) *(vulong *)(EBI_BASE + _x_)
340
341
342
* Static Memory Interface Unit
343
344
#define SMC_REG(_x_) *(vulong *)(EBI_BASE + 0x10 + _x_)
345
346
347
* SDRAM Memory Interface Unit
348
349
#define SDRC_REG(_x_) *(vulong *)(EBI_BASE + 0x30 + _x_)
350
351
#endif
/* __AT91RM9200_H__ */
352
360
bits.h
Contains Defined Bits.
