RTEMS
6.3
Toggle main menu visibility
bsps
include
dev
irq
arm-gic-irq.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
13
* Copyright (C) 2013, 2019 embedded brains GmbH & Co. KG
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
#ifndef LIBBSP_ARM_SHARED_ARM_GIC_IRQ_H
38
#define LIBBSP_ARM_SHARED_ARM_GIC_IRQ_H
39
40
#include <bsp.h>
41
dev/irq/arm-gic.h
42
43
#ifdef __cplusplus
44
extern
"C"
45
#endif
/* __cplusplus */
46
52
53
#define ARM_GIC_IRQ_SGI_0 0
54
#define ARM_GIC_IRQ_SGI_1 1
55
#define ARM_GIC_IRQ_SGI_2 2
56
#define ARM_GIC_IRQ_SGI_3 3
57
#define ARM_GIC_IRQ_SGI_5 5
58
#define ARM_GIC_IRQ_SGI_6 6
59
#define ARM_GIC_IRQ_SGI_7 7
60
#define ARM_GIC_IRQ_SGI_8 8
61
#define ARM_GIC_IRQ_SGI_9 9
62
#define ARM_GIC_IRQ_SGI_10 10
63
#define ARM_GIC_IRQ_SGI_11 11
64
#define ARM_GIC_IRQ_SGI_12 12
65
#define ARM_GIC_IRQ_SGI_13 13
66
#define ARM_GIC_IRQ_SGI_14 14
67
#define ARM_GIC_IRQ_SGI_15 15
68
#define ARM_GIC_IRQ_SGI_LAST 15
69
70
#define ARM_GIC_IRQ_PPI_LAST 31
71
72
#define ARM_GIC_DIST ((volatile gic_dist *) BSP_ARM_GIC_DIST_BASE)
73
74
rtems_status_code
arm_gic_irq_set_group(
75
rtems_vector_number
vector,
76
gic_group group
77
78
79
rtems_status_code
arm_gic_irq_get_group(
80
rtems_vector_number
vector,
81
gic_group *group
82
83
84
void
arm_gic_trigger_sgi(
rtems_vector_number
vector, uint32_t targets);
85
86
#ifdef RTEMS_SMP
87
uint32_t arm_gic_irq_processor_count(
void
88
89
void
arm_gic_irq_initialize_secondary_cpu(
void
90
#endif
91
93
94
#ifdef __cplusplus
95
96
#endif
/* __cplusplus */
97
98
#endif
/* LIBBSP_ARM_SHARED_ARM_GIC_IRQ_H */
arm-gic.h
This header file provides interfaces of the ARM Generic Interrupt Controller (GIC) support.
rtems_vector_number
ISR_Vector_number rtems_vector_number
This integer type represents interrupt vector numbers.
Definition
intr.h:102
rtems_status_code
rtems_status_code
Definition
status.h:85
