RTEMS 6.3
#include <rtems.h>#include <rtems/libio.h>#include <bsp.h>#include <libcpu/cecRegs.h>#include <libcpu/sicRegs.h>#include <string.h>#include <bsp/interrupt.h>Data Structures | |
| struct | [struct].vectors |
| #define | SIC_IAR_COUNT_SET0 4 |
| #define | SIC_IAR_BASE_ADDRESS_0 0xFFC00150 |
| void | bfin_interrupt_init (void) |
| rtems_status_code | bfin_interrupt_register (bfin_isr_t *isr) |
| rtems_status_code | bfin_interrupt_unregister (bfin_isr_t *isr) |
| void | bfin_interrupt_enable (bfin_isr_t *isr, bool enable) |
| void | bfin_interrupt_enable_all (int source, bool enable) |
| void | bfin_interrupt_enable_global (int source, bool enable) |
Target: TLL6527v1-0 Compiler:
COPYRIGHT (c) 2010 by ECE Northeastern University.
The license and distribution terms for this file may be found in the file LICENSE in this distribution or at http://www.rtems.org/license
LastChange:
| void bfin_interrupt_init | ( | void | ) |
Initializes the interrupt module
blackfin interrupt initialization routine. It initializes the bfin ISR dispatcher. It will also create SIC CEC map which will be used for identifying the ISR.
The bf52x has 8 IAR registers but they do not have a constant pitch.
| rtems_status_code bfin_interrupt_register | ( | bfin_isr_t * | isr | ) |
This routine registers a new ISR. It will write a new entry to the IVT table
| isr | contains a callback function and source |
| rtems_status_code bfin_interrupt_unregister | ( | bfin_isr_t * | isr | ) |
This function unregisters a registered interrupt handler.
| isr |
