RTEMS
6.2
bsps
arm
xilinx-zynq
include
dev
spi
zynq-qspi-flashdev.h
1
2
* Copyright (C) 2024 Aaron Nyholm
3
4
5
* modification, are permitted provided that the following conditions
6
* are met:
7
* 1. Redistributions of source code must retain the above copyright
8
* notice, this list of conditions and the following disclaimer.
9
* 2. Redistributions in binary form must reproduce the above copyright
10
* notice, this list of conditions and the following disclaimer in the
11
* documentation and/or other materials provided with the distribution.
12
13
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS AS IS
14
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
15
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
16
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
17
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
18
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
19
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
20
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
21
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
22
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
23
* POSSIBILITY OF SUCH DAMAGE.
24
25
26
#ifndef _ZYNQ_QSPI_FLASHDEV_H
27
#define _ZYNQ_QSPI_FLASHDEV_H
28
29
dev/flash/flashdev.h
30
#include <dev/spi/zynq-qspi-flash.h>
31
32
#define ZQSPI_FLASH_MAX_REGIONS ((size_t)32)
33
34
35
* @brief Initializes a flash device using zynq qspi flash driver.
36
37
* The flash device is not registered in this call. If an rtems_flashdev is
38
* created using zqspi_flash_init and is not registered, it must be destroyed
39
* using rtems_flashdev_destroy.
40
41
* @param[in] zqspiflash A initialised zqspiflash device to wrap.
42
43
* @retval A pointer to the rtems_flashdev.
44
* @retval NULL on failure.
45
46
rtems_flashdev
* zqspi_flashdev_init(
zqspiflash
*bmdriver);
47
48
#endif
/* _ZYNQ_QSPI_FLASHDEV_H */
flashdev.h
Generic Flash API.
rtems_flashdev
Flash device.
Definition:
flashdev.h:358
zqspiflash
Definition:
zynq-qspi-flash.h:113
