RTEMS 6.2
Generic Flash API. More...
| struct | rtems_flashdev_region |
| General definition for on flash device. More... | |
| struct | rtems_flashdev_region_table |
| Struct holding region definitions. More... | |
| struct | rtems_flashdev_ioctl_page_info |
| Page information returned from IOCTL calls. More... | |
| struct | rtems_flashdev_ioctl_sector_info |
| Sector information returned from IOCTL calls. More... | |
| struct | rtems_flashdev_ioctl_sector_health |
| struct | rtems_flashdev_ioctl_oob_rw_info |
| Read/write information used with OOB IOCTL calls. More... | |
| struct | rtems_flashdev |
| Flash device. More... | |
| #define | RTEMS_FLASHDEV_IOCTL_OBTAIN 0 |
| Obtains the flash device. | |
| #define | RTEMS_FLASHDEV_IOCTL_RELEASE 1 |
| Releases the flash device. | |
| #define | RTEMS_FLASHDEV_IOCTL_JEDEC_ID 2 |
| Returns the JEDEC ID of the flash device. This IOCTL call is informational only. | |
| #define | RTEMS_FLASHDEV_IOCTL_ERASE 3 |
| Erases flash device. | |
| #define | RTEMS_FLASHDEV_IOCTL_REGION_SET 4 |
| Set a region that limits read, write and erase calls to within it. Regions are file descriptor specific and limited to a single region per file descriptor and 32 regions total per flash device. Regions can be changed or updated by calling this IOCTL again. | |
| #define | RTEMS_FLASHDEV_IOCTL_REGION_UNSET 5 |
| Removes the set region on the file descriptor. | |
| #define | RTEMS_FLASHDEV_IOCTL_TYPE 6 |
| Returns the type of flash device (e.g. NOR or NAND). | |
| #define | RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_OFFSET 7 |
| Get the size and address of flash page at given offset. | |
| #define | RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_INDEX 8 |
| Get the size and address of nth flash page where n is index passed in. | |
| #define | RTEMS_FLASHDEV_IOCTL_PAGE_COUNT 9 |
| Get the number of pages in flash device. | |
| #define | RTEMS_FLASHDEV_IOCTL_WRITE_BLOCK_SIZE 10 |
| Get the minimum write size supported by the driver. | |
| #define | RTEMS_FLASHDEV_IOCTL_SECTORINFO_BY_OFFSET 11 |
| Get the size and address of flash erase sector at given offset. | |
| #define | RTEMS_FLASHDEV_IOCTL_SECTOR_COUNT 12 |
| Get the number of erase sectors in flash device. | |
| #define | RTEMS_FLASHDEV_IOCTL_REGION_SECTORINFO_BY_OFFSET 13 |
| #define | RTEMS_FLASHDEV_IOCTL_OOB_BYTES_PER_PAGE 14 |
| Get the number of bytes per page of out of band space. | |
| #define | RTEMS_FLASHDEV_IOCTL_REGION_OOB_READ 15 |
| Read bytes from the out of band space. | |
| #define | RTEMS_FLASHDEV_IOCTL_REGION_OOB_WRITE 16 |
| #define | RTEMS_FLASHDEV_IOCTL_REGION_SECTOR_MARK_BAD 17 |
| Mark a sector as bad. | |
| #define | RTEMS_FLASHDEV_IOCTL_REGION_SECTOR_HEALTH 18 |
| Check whether a sector is bad. | |
| #define | RTEMS_FLASHDEV_MAX_REGIONS 32 |
| The maximum number of region limited file descriptors allowed to be open at once. | |
Typedefs | |
| typedef struct rtems_flashdev | rtems_flashdev |
| typedef enum rtems_flashdev_flash_type | rtems_flashdev_flash_type |
| Enum for flash type returned from IOCTL call. | |
| typedef struct rtems_flashdev_region | rtems_flashdev_region |
| General definition for on flash device. | |
| typedef struct rtems_flashdev_region_table | rtems_flashdev_region_table |
| Struct holding region definitions. | |
| typedef struct rtems_flashdev_ioctl_page_info | rtems_flashdev_ioctl_page_info |
| Page information returned from IOCTL calls. | |
| typedef struct rtems_flashdev_ioctl_sector_info | rtems_flashdev_ioctl_sector_info |
| Sector information returned from IOCTL calls. | |
| typedef struct rtems_flashdev_ioctl_sector_health | rtems_flashdev_ioctl_sector_health |
| typedef struct rtems_flashdev_ioctl_oob_rw_info | rtems_flashdev_ioctl_oob_rw_info |
| Read/write information used with OOB IOCTL calls. | |
Enumerations | |
| enum | rtems_flashdev_flash_type { RTEMS_FLASHDEV_NOR , RTEMS_FLASHDEV_NAND } |
| Enum for flash type returned from IOCTL call. More... | |
| rtems_flashdev * | rtems_flashdev_alloc_and_init (size_t size) |
| Allocate and initialize the flash device. | |
| int | rtems_flashdev_init (rtems_flashdev *flash) |
| Initialize the flash device. | |
| int | rtems_flashdev_register (rtems_flashdev *flash, const char *flash_path) |
| Register the flash device. | |
| int | rtems_flashdev_unregister (const char *flash_path) |
| Unregister the flash device. | |
| void | rtems_flashdev_destroy (rtems_flashdev *flash) |
| Destroys the flash device. | |
| void | rtems_flashdev_destroy_and_free (rtems_flashdev *flash) |
| Destroys the flash device and frees its memory. | |
Generic Flash API.
