RTEMS 6.2
_pmu_well_bias_option Union Reference
The union of well bias basic options, such as clock source, power source and so on. More...
#include <fsl_pmu.h>
uint16_t wellBiasData
struct {
   uint16_t   enablePWellOnly: 1U
   uint16_t   reserved1: 1U
   uint16_t   biasAreaSize: 3U
   uint16_t   disableAdaptiveFreq: 1U
   uint16_t   wellBiasFreq: 3U
   uint16_t   clkSource: 1U
   uint16_t   freqReduction: 2U
   uint16_t   enablePowerDownOption: 1U
   uint16_t   reserved2: 1U
   uint16_t   powerSource: 1U
   uint16_t   reserved3: 1U
wellBiasStruct
Field Documentation
◆ biasAreaSize
uint16_t _pmu_well_bias_option::biasAreaSize
Select size of bias area, please refer to pmu_bias_area_size_t
◆ clkSource
uint16_t _pmu_well_bias_option::clkSource
Config the adaptive clock source, please pmu_adaptive_clock_source_t.
◆ disableAdaptiveFreq
uint16_t _pmu_well_bias_option::disableAdaptiveFreq
Enable/Disable adaptive frequency.
  • 1b0 Frequency change after each half cycle minimum frequency determined by typical frequency.
  • 1b1 Adaptive frequency disabled. Frequency determined by typical frequency.
◆ enablePowerDownOption
uint16_t _pmu_well_bias_option::enablePowerDownOption
Enable/Disable pull down option.
  • false Pull down option is disabled.
  • true Pull down option is enabled.
◆ enablePWellOnly
uint16_t _pmu_well_bias_option::enablePWellOnly
Turn on both PWELL and NWELL, or only trun on PWELL.
  • 1b0 PWELL and NEWLL are both turned on.
  • 1b1 PWELL is turned on only.
◆ freqReduction
uint16_t _pmu_well_bias_option::freqReduction
Config the percent of frequency reduction due to cap increment, please refer to pmu_freq_reduction_t.
◆ powerSource
uint16_t _pmu_well_bias_option::powerSource
Set power source, please refer to pmu_well_bias_power_source_t.
◆ reserved1
uint16_t _pmu_well_bias_option::reserved1
Reserved.
◆ reserved2
uint16_t _pmu_well_bias_option::reserved2
Reserved.
◆ reserved3
uint16_t _pmu_well_bias_option::reserved3
Reserved.
◆ wellBiasData
uint16_t _pmu_well_bias_option::wellBiasData
well bias configuration data.
◆ wellBiasFreq
uint16_t _pmu_well_bias_option::wellBiasFreq
Set well bias typical frequency, please refer to pmu_well_bias_typical_freq_t.
The documentation for this union was generated from the following file:
