RTEMS 6.2
rtems_rtl_obj_cache Struct Reference
#include <rtl-obj-cache.h>
int fd
size_t file_size
off_t offset
size_t size
size_t level
uint8_t * buffer
The buffer cache.
Field Documentation
◆ buffer
uint8_t* rtems_rtl_obj_cache::buffer
The buffer
◆ fd
int rtems_rtl_obj_cache::fd
The file descriptor of the data in the cache.
◆ file_size
size_t rtems_rtl_obj_cache::file_size
The size of the file.
◆ level
size_t rtems_rtl_obj_cache::level
The amount of data in the cache. A file can be smaller than the cache file.
◆ offset
off_t rtems_rtl_obj_cache::offset
The base offset of the buffer.
◆ size
size_t rtems_rtl_obj_cache::size
The size of the cache.
