RTEMS 6.2
pci_dev Struct Reference
struct pci_busbus
struct pci_devsibling
struct pci_devnext
void * sysdata
struct proc_dir_entry * procent
unsigned int devfn
unsigned short vendor
unsigned short device
unsigned int class
unsigned int hdr_type
unsigned int master: 1
unsigned int irq
unsigned long base_address [6]
unsigned long rom_address
struct pci_res resources [DEV_RES_CNT]
pci_dev_t busdevfun
uint8_t flags
uint8_t sysirq
uint16_t vendor
uint16_t device
uint16_t subvendor
uint16_t subdevice
uint32_t classrev
uint16_t command
The documentation for this struct was generated from the following files:
