RTEMS 6.2
_sai_transceiver Struct Reference
sai transceiver configurations More...
#include <fsl_sai.h>
sai_serial_data_t serialData
sai_frame_sync_t frameSync
sai_bit_clock_t bitClock
sai_master_slave_t masterSlave
sai_sync_mode_t syncMode
uint8_t startChannel
uint8_t channelMask
uint8_t endChannel
uint8_t channelNums
Field Documentation
◆ bitClock
sai_bit_clock_t _sai_transceiver::bitClock
bit clock configurations
◆ channelMask
uint8_t _sai_transceiver::channelMask
enabled channel mask value, reference _sai_channel_mask
◆ channelNums
uint8_t _sai_transceiver::channelNums
Total enabled channel numbers
◆ endChannel
uint8_t _sai_transceiver::endChannel
end channel number
◆ frameSync
sai_frame_sync_t _sai_transceiver::frameSync
ws configurations
◆ masterSlave
sai_master_slave_t _sai_transceiver::masterSlave
transceiver is master or slave
◆ serialData
sai_serial_data_t _sai_transceiver::serialData
serial data configurations
◆ startChannel
uint8_t _sai_transceiver::startChannel
Transfer start channel
◆ syncMode
sai_sync_mode_t _sai_transceiver::syncMode
transceiver sync mode
