RTEMS 6.2
_dsi_dpi_config Struct Reference
MIPI DSI controller DPI interface configuration. More...
#include <fsl_mipi_dsi.h>
uint16_t pixelPayloadSize
dsi_dpi_color_coding_t dpiColorCoding
dsi_dpi_pixel_packet_t pixelPacket
dsi_dpi_video_mode_t videoMode
dsi_dpi_bllp_mode_t bllpMode
uint8_t polarityFlags
uint16_t hfp
uint16_t hbp
uint16_t hsw
uint8_t vfp
uint8_t vbp
uint16_t panelHeight
uint8_t virtualChannel
Field Documentation
◆ bllpMode
dsi_dpi_bllp_mode_t _dsi_dpi_config::bllpMode
Behavior in BLLP.
◆ dpiColorCoding
dsi_dpi_color_coding_t _dsi_dpi_config::dpiColorCoding
DPI color coding.
◆ hbp
uint16_t _dsi_dpi_config::hbp
Horizontal back porch, in dpi pixel clock.
◆ hfp
uint16_t _dsi_dpi_config::hfp
Horizontal front porch, in dpi pixel clock.
◆ hsw
uint16_t _dsi_dpi_config::hsw
Horizontal sync width, in dpi pixel clock.
◆ panelHeight
uint16_t _dsi_dpi_config::panelHeight
Line number in vertical active area.
◆ pixelPacket
dsi_dpi_pixel_packet_t _dsi_dpi_config::pixelPacket
Pixel packet format.
◆ pixelPayloadSize
uint16_t _dsi_dpi_config::pixelPayloadSize
Maximum number of pixels that should be sent as one DSI packet. Recommended that the line size (in pixels) is evenly divisible by this parameter.
◆ polarityFlags
uint8_t _dsi_dpi_config::polarityFlags
OR'ed value of _dsi_dpi_polarity_flag controls signal polarity.
◆ vbp
uint8_t _dsi_dpi_config::vbp
Number of lines in vertical back porch.
◆ vfp
uint8_t _dsi_dpi_config::vfp
Number of lines in vertical front porch.
◆ videoMode
dsi_dpi_video_mode_t _dsi_dpi_config::videoMode
Video mode.
◆ virtualChannel
uint8_t _dsi_dpi_config::virtualChannel
Virtual channel.
