RTEMS 6.2
asrc channel pair configuation More...
#include <fsl_asrc.h>
| asrc_audio_channel_t _asrc_channel_pair_config::audioDataChannels |
audio data channel numbers
| bool _asrc_channel_pair_config::bufStallWhenFifoEmptyFull |
stall Pair A conversion in case of Buffer near empty full condition
| asrc_clock_source_t _asrc_channel_pair_config::inClockSource |
input clock source, reference the clock source definition in SOC header file
| asrc_data_align_t _asrc_channel_pair_config::inDataAlign |
input data alignment
| asrc_data_width_t _asrc_channel_pair_config::inDataWidth |
input data width
| uint8_t _asrc_channel_pair_config::inFifoThreshold |
input fifo threshold
| uint32_t _asrc_channel_pair_config::inSourceClock_Hz |
input source clock frequency
| asrc_clock_source_t _asrc_channel_pair_config::outClockSource |
output clock source, reference the clock source definition in SOC header file
| asrc_data_align_t _asrc_channel_pair_config::outDataAlign |
output data alignment
| asrc_data_width_t _asrc_channel_pair_config::outDataWidth |
output data width
| uint8_t _asrc_channel_pair_config::outFifoThreshold |
output fifo threshold
| asrc_sign_extension_t _asrc_channel_pair_config::outSignExtension |
output extension
| uint32_t _asrc_channel_pair_config::outSourceClock_Hz |
output source clock frequency
| asrc_ratio_t _asrc_channel_pair_config::sampleRateRatio |
sample rate ratio type
