RTEMS 6.2
Test context for spec:/score/sem/req/seize-wait test case. More...
Data Fields | |
| TQSemContext * | tq_ctx |
| This member contains a copy of the corresponding ScoreSemReqSeizeWait_Run() parameter. | |
| struct { | |
| size_t pcs [1] | |
| This member defines the pre-condition states for the next action. | |
| bool in_action_loop | |
| If this member is true, then the test action loop is executed. | |
| size_t index | |
| This member contains the next transition map index. | |
| ScoreSemReqSeizeWait_Entry entry | |
| This member contains the current transition map entry. | |
| bool skip | |
| If this member is true, then the current transition variant should be skipped. | |
| } | Map |
