RTEMS 6.2
Test context for spec:/score/sched/smp/val/smp test case. More...
rtems_id runner_id
 This member contains the runner identifier.
rtems_id worker_id [WORKER_COUNT]
 This member contains the worker identifiers.
rtems_id mutex_id
 This member contains the mutex identifier.
rtems_id sticky_id
 This member contains the sticky mutex identifier.
volatile bool busy [WORKER_COUNT]
 This member contains the worker busy status.
ISR_lock_Context lock_context
 This member contains an ISR lock context.
uint32_t counter
 This member contains a counter.
volatile bool is_busy [WORKER_COUNT]
 If this member is true, then the worker shall be in the busy loop.
Per_CPU_Job job [2]
 This member contains the per-CPU jobs.
Per_CPU_Job_context job_context [2]
 This member contains the per-CPU job contexts.
CallWithinISRRequest request
 This member contains the call within ISR request.
