RTEMS 6.2
Test context for spec:/rtems/timer/req/initiate-server test case. More...
rtems_task_priority before_priority
 If the Timer Server task exists before the action, its priority before the action.
size_t before_stack_size
 If the Timer Server task exists before the action, its stack size before the action.
bool before_has_floating_point
 If the Timer Server task exists before the action, whether the floating point attribute is set before the action.
rtems_task_priority priority
 The priority parameter for the action.
size_t stack_size
 The stack_size parameter for the action.
rtems_status_code status
 The status value returned by the action rtems_timer_initiate_server().
void * task_objects
 This member is used by the T_seize_objects() and T_surrender_objects() support functions.
struct {
   size_t   pcs [4]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsTimerReqInitiateServer_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
