RTEMS 6.2
Test context for spec:/rtems/task/req/storage-size test case. More...
rtems_id worker_id
 This member contains the identifier of a task.
bool suspend
 If this member is true, then the worker is suspended before the rtems_task_suspend() call.
rtems_status_code status
 This member contains the return value of the rtems_task_suspend() call.
rtems_id id
 This member specifies if the id parameter value.
struct {
   size_t   pci [2]
 This member defines the pre-condition indices for the next action.
   size_t   pcs [2]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsTaskReqStorageSize_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
