RTEMS 6.2
Test context for spec:/rtems/task/req/set-affinity test case. More...
Data Fields | |
| T_scheduler_log_2 | scheduler_log |
| This member provides the scheduler operation records. | |
| cpu_set_t | cpuset_obj [2] |
This member provides the object referenced by the cpuset parameter. | |
| rtems_status_code | status |
| This member contains the return value of the rtems_task_set_affinity() call. | |
| rtems_id | id |
This member specifies if the id parameter value. | |
| size_t | cpusetsize |
This member specifies if the cpusetsize parameter value. | |
| cpu_set_t * | cpuset |
This member specifies if the cpuset parameter value. | |
| struct { | |
| size_t pci [5] | |
| This member defines the pre-condition indices for the next action. | |
| size_t pcs [5] | |
| This member defines the pre-condition states for the next action. | |
| bool in_action_loop | |
| If this member is true, then the test action loop is executed. | |
| size_t index | |
| This member contains the next transition map index. | |
| RtemsTaskReqSetAffinity_Entry entry | |
| This member contains the current transition map entry. | |
| bool skip | |
| If this member is true, then the current transition variant should be skipped. | |
| } | Map |
