RTEMS 6.2
Test context for spec:/rtems/sem/req/flush test case. More...
Data Fields | |
| TQContext | tq_ctx |
| This member contains the thread queue test context. | |
| rtems_attribute | attribute_set |
| This member specifies if the attribute set of the semaphore. | |
| uint32_t | initial_count |
| This member specifies if the initial count of the semaphore. | |
| struct { | |
| size_t pci [3] | |
| This member defines the pre-condition indices for the next action. | |
| size_t pcs [3] | |
| This member defines the pre-condition states for the next action. | |
| bool in_action_loop | |
| If this member is true, then the test action loop is executed. | |
| size_t index | |
| This member contains the next transition map index. | |
| RtemsSemReqFlush_Entry entry | |
| This member contains the current transition map entry. | |
| bool skip | |
| If this member is true, then the current transition variant should be skipped. | |
| } | Map |
