RTEMS 6.2
MPCI_Configuration Struct Reference
uint32_t node
uint32_t maximum_nodes
uint32_t maximum_global_objects
uint32_t maximum_proxies
uint32_t extra_mpci_receive_server_stack
MPCI_ControlUser_mpci_table
Field Documentation
◆ extra_mpci_receive_server_stack
uint32_t MPCI_Configuration::extra_mpci_receive_server_stack
The MPCI Receive server is assumed to have a stack of at least minimum stack size. This field specifies the amount of extra stack this task will be given in bytes.
◆ maximum_global_objects
uint32_t MPCI_Configuration::maximum_global_objects
This is the maximum number of global objects.
◆ maximum_nodes
uint32_t MPCI_Configuration::maximum_nodes
This is the maximum number of nodes in system.
◆ maximum_proxies
uint32_t MPCI_Configuration::maximum_proxies
This is the maximum number of proxies.
◆ node
uint32_t MPCI_Configuration::node
This is the local node number.
◆ User_mpci_table
MPCI_Control* MPCI_Configuration::User_mpci_table
This is a pointer to User/BSP provided MPCI Table.
