RTEMS 6.2
Chain_Iterator Struct Reference
A chain iterator which is updated during node extraction if it is properly registered. More...
#include <chainimpl.h>
Chain_Node Registry_node
 Node for registration.
Chain_Iterator_direction direction
 The direction of this iterator.
Chain_Nodeposition
 The current position of this iterator.
See also
_Chain_Iterator_initialize().
Field Documentation
◆ direction
Chain_Iterator_direction Chain_Iterator::direction
Immutable after initialization via _Chain_Iterator_initialize().
◆ position
Chain_Node* Chain_Iterator::position
The position is initialized via _Chain_Iterator_initialize(). It must be explicitly set after one valid iteration step, e.g. in case a next node in the iterator direction existed. It is updated through the registration in case a node is extracted via _Chain_Iterator_registry_update().
◆ Registry_node
Chain_Node Chain_Iterator::Registry_node
Used during _Chain_Iterator_initialize() and _Chain_Iterator_destroy().
