RTEMS 6.2
Interrupt stack frame (ISF). More...
#include <cpu.h>
uint64_t x0
uint64_t register_lr_original
uint64_t x1
uint64_t x2
uint64_t x3
uint64_t x4
uint64_t x5
uint64_t x6
uint64_t x7
uint64_t x8
uint64_t x9
uint64_t x10
uint64_t x11
uint64_t x12
uint64_t x13
uint64_t x14
uint64_t x15
uint64_t x16
uint64_t x17
uint64_t x18
uint64_t x19
uint64_t x20
uint64_t x21
uint64_t register_elr
uint64_t register_spsr
uint64_t register_fpsr
uint64_t register_fpcr
uint32_t reserved [3]
uint32_t isr_vector
uint32_t ebx
uint32_t ebp
uint32_t esp
uint32_t edx
uint32_t ecx
uint32_t eax
uint32_t eip
uint32_t cs
uint32_t eflags
uint32_t r1
uint32_t r2
uint32_t r3
uint32_t r4
uint32_t r5
uint32_t r6
uint32_t r7
uint32_t r8
uint32_t r9
uint32_t r10
uint32_t ra
uint32_t ba
uint32_t ea
uint32_t vecnum
__MIPS_REGISTER_TYPE r0
__MIPS_REGISTER_TYPE at
__MIPS_REGISTER_TYPE v0
__MIPS_REGISTER_TYPE v1
__MIPS_REGISTER_TYPE a0
__MIPS_REGISTER_TYPE a1
__MIPS_REGISTER_TYPE a2
__MIPS_REGISTER_TYPE a3
__MIPS_REGISTER_TYPE t0
__MIPS_REGISTER_TYPE t1
__MIPS_REGISTER_TYPE t2
__MIPS_REGISTER_TYPE t3
__MIPS_REGISTER_TYPE t4
__MIPS_REGISTER_TYPE t5
__MIPS_REGISTER_TYPE t6
__MIPS_REGISTER_TYPE t7
__MIPS_REGISTER_TYPE s0
__MIPS_REGISTER_TYPE s1
__MIPS_REGISTER_TYPE s2
__MIPS_REGISTER_TYPE s3
__MIPS_REGISTER_TYPE s4
__MIPS_REGISTER_TYPE s5
__MIPS_REGISTER_TYPE s6
__MIPS_REGISTER_TYPE s7
__MIPS_REGISTER_TYPE t8
__MIPS_REGISTER_TYPE t9
__MIPS_REGISTER_TYPE k0
__MIPS_REGISTER_TYPE k1
__MIPS_REGISTER_TYPE gp
__MIPS_REGISTER_TYPE sp
__MIPS_REGISTER_TYPE fp
__MIPS_REGISTER_TYPE ra
__MIPS_REGISTER_TYPE c0_sr
__MIPS_REGISTER_TYPE mdlo
__MIPS_REGISTER_TYPE mdhi
__MIPS_REGISTER_TYPE badvaddr
__MIPS_REGISTER_TYPE cause
__MIPS_REGISTER_TYPE epc
__MIPS_FPU_REGISTER_TYPE f0
__MIPS_FPU_REGISTER_TYPE f1
__MIPS_FPU_REGISTER_TYPE f2
__MIPS_FPU_REGISTER_TYPE f3
__MIPS_FPU_REGISTER_TYPE f4
__MIPS_FPU_REGISTER_TYPE f5
__MIPS_FPU_REGISTER_TYPE f6
__MIPS_FPU_REGISTER_TYPE f7
__MIPS_FPU_REGISTER_TYPE f8
__MIPS_FPU_REGISTER_TYPE f9
__MIPS_FPU_REGISTER_TYPE f10
__MIPS_FPU_REGISTER_TYPE f11
__MIPS_FPU_REGISTER_TYPE f12
__MIPS_FPU_REGISTER_TYPE f13
__MIPS_FPU_REGISTER_TYPE f14
__MIPS_FPU_REGISTER_TYPE f15
__MIPS_FPU_REGISTER_TYPE f16
__MIPS_FPU_REGISTER_TYPE f17
__MIPS_FPU_REGISTER_TYPE f18
__MIPS_FPU_REGISTER_TYPE f19
__MIPS_FPU_REGISTER_TYPE f20
__MIPS_FPU_REGISTER_TYPE f21
__MIPS_FPU_REGISTER_TYPE f22
__MIPS_FPU_REGISTER_TYPE f23
__MIPS_FPU_REGISTER_TYPE f24
__MIPS_FPU_REGISTER_TYPE f25
__MIPS_FPU_REGISTER_TYPE f26
__MIPS_FPU_REGISTER_TYPE f27
__MIPS_FPU_REGISTER_TYPE f28
__MIPS_FPU_REGISTER_TYPE f29
__MIPS_FPU_REGISTER_TYPE f30
__MIPS_FPU_REGISTER_TYPE f31
__MIPS_REGISTER_TYPE fcsr
__MIPS_REGISTER_TYPE feir
__MIPS_REGISTER_TYPE tlbhi
__MIPS_REGISTER_TYPE inx
__MIPS_REGISTER_TYPE rand
__MIPS_REGISTER_TYPE ctxt
__MIPS_REGISTER_TYPE exctype
__MIPS_REGISTER_TYPE mode
__MIPS_REGISTER_TYPE prid
__MIPS_REGISTER_TYPE tar
uint32_t special_interrupt_register
uintptr_t FRAME_SP
uintptr_t FRAME_LR
uintptr_t EXC_SRR0
uintptr_t EXC_SRR1
uint32_t RESERVED_FOR_ALIGNMENT_0
uint32_t EXC_INTERRUPT_ENTRY_INSTANT
uint32_t EXC_CR
uint32_t EXC_XER
uintptr_t EXC_CTR
uintptr_t EXC_LR
uintptr_t EXC_INTERRUPT_FRAME
PPC_GPR_TYPE GPR0
PPC_GPR_TYPE GPR1
PPC_GPR_TYPE GPR2
PPC_GPR_TYPE GPR3
PPC_GPR_TYPE GPR4
PPC_GPR_TYPE GPR5
PPC_GPR_TYPE GPR6
PPC_GPR_TYPE GPR7
PPC_GPR_TYPE GPR8
PPC_GPR_TYPE GPR9
PPC_GPR_TYPE GPR10
PPC_GPR_TYPE GPR11
PPC_GPR_TYPE GPR12
SPARC_Minimum_stack_frame Stack_frame
uint32_t psr
uint32_t pc
uint32_t npc
uint32_t g1
uint32_t g2
uint32_t g3
uint32_t g4
uint32_t g5
uint32_t reserved_for_alignment
uint32_t g7
uint32_t i0
uint32_t i1
uint32_t i2
uint32_t i3
uint32_t i4
uint32_t i5
uint32_t i6_fp
uint32_t i7
uint32_t y
uint32_t tpc
SPARC64_Minimum_stack_frame Stack_frame
uint64_t tstate
uint64_t tpc
uint64_t tnpc
uint64_t pil
uint64_t y
uint64_t g1
uint64_t g2
uint64_t g3
uint64_t g4
uint64_t g5
uint64_t g6
uint64_t g7
uint64_t o0
uint64_t o1
uint64_t o2
uint64_t o3
uint64_t o4
uint64_t o5
uint64_t o6_sp
uint64_t o7
uint64_t tvec
uint64_t error_code
uint64_t rip
uint64_t cs
uint64_t rflags
uint64_t rsp
uint64_t ss
uint64_t rdi
uint64_t rbp
uint64_t rbx
uint8_t sse_state [512]
uint64_t rax
uint64_t rcx
uint64_t rdx
uint64_t rsi
uint64_t r8
uint64_t r9
uint64_t r10
uint64_t r11
uint64_t saved_rsp
uint8_t padding [8]
This defines the set of integer and processor state registers that must be saved during an interrupt. This set does not include any which are in Context_Control.
Context saved on stack for an interrupt.
NOTE: The PSR, PC, and NPC are only saved in this structure for the benefit of the user's handler.
Field Documentation
◆ g1
uint32_t CPU_Interrupt_frame::g1
This is the offset of the g1 register on an ISF.
◆ g2
uint32_t CPU_Interrupt_frame::g2
This is the offset of the g2 register on an ISF.
◆ g3
uint32_t CPU_Interrupt_frame::g3
This is the offset of the g3 register on an ISF.
◆ g4
uint32_t CPU_Interrupt_frame::g4
This is the offset of the g4 register on an ISF.
◆ g5
uint32_t CPU_Interrupt_frame::g5
This is the offset of the g5 register on an ISF.
◆ g7
uint32_t CPU_Interrupt_frame::g7
This is the offset of the g7 register on an ISF.
◆ i0
uint32_t CPU_Interrupt_frame::i0
This is the offset of the i0 register on an ISF.
◆ i1
uint32_t CPU_Interrupt_frame::i1
This is the offset of the i1 register on an ISF.
◆ i2
uint32_t CPU_Interrupt_frame::i2
This is the offset of the i2 register on an ISF.
◆ i3
uint32_t CPU_Interrupt_frame::i3
This is the offset of the i3 register on an ISF.
◆ i4
uint32_t CPU_Interrupt_frame::i4
This is the offset of the i4 register on an ISF.
◆ i5
uint32_t CPU_Interrupt_frame::i5
This is the offset of the i5 register on an ISF.
◆ i6_fp
uint32_t CPU_Interrupt_frame::i6_fp
This is the offset of the i6 register on an ISF.
◆ i7
uint32_t CPU_Interrupt_frame::i7
This is the offset of the i7 register on an ISF.
◆ npc
uint32_t CPU_Interrupt_frame::npc
This is the offset of the XXX on an ISF.
◆ padding
uint8_t CPU_Interrupt_frame::padding[8]
The caller-saved registers needs to start in a 16-byte aligned position on the stack for the FXSAVE instruction. Therefore, we have 8 extra bytes in case the interrupt handler needs to align it.
◆ pc
uint32_t CPU_Interrupt_frame::pc
◆ psr
uint32_t CPU_Interrupt_frame::psr
This is the offset of the PSR on an ISF.
◆ reserved_for_alignment
uint32_t CPU_Interrupt_frame::reserved_for_alignment
This is the offset is reserved for alignment on an ISF.
◆ special_interrupt_register
uint32_t CPU_Interrupt_frame::special_interrupt_register
This field is a hint that a port will have a number of integer registers that need to be saved when an interrupt occurs or when a context switch occurs at the end of an ISR.
◆ Stack_frame
SPARC_Minimum_stack_frame CPU_Interrupt_frame::Stack_frame
On an interrupt, we must save the minimum stack frame.
◆ tpc
uint32_t CPU_Interrupt_frame::tpc
This is the offset of the tpc register on an ISF.
◆ y
uint32_t CPU_Interrupt_frame::y
This is the offset of the y register on an ISF.
The documentation for this struct was generated from the following files:
