RTEMS 6.2
ALT_I2C_MASTER_CONFIG_s Struct Reference
#include <alt_i2c.h>
ALT_I2C_ADDR_MODE_t addr_mode
bool restart_enable
ALT_I2C_SPEED_t speed_mode
uint16_t ss_scl_hcnt
uint16_t ss_scl_lcnt
uint16_t fs_scl_hcnt
uint16_t fs_scl_lcnt
uint8_t fs_spklen
This type defines a structure for configuration of the SCL high and low counts to ensure proper I/O timing with the device interface.
The SCL count values are only relevant if the I2C controller is enabled to as an I2C master. The SCL count values are ignored when the I2C controller is enabled as an I2C slave.
See: Clock Frequency Configuration section of Chapter 20. I2C Controller in the Cyclone V Device Handbook Volume 3: Hard Processor System Technical Reference Manual for a complete discussion of calculation of the proper SCL clock high and low times.
Field Documentation
◆ addr_mode
ALT_I2C_ADDR_MODE_t ALT_I2C_MASTER_CONFIG_s::addr_mode
The address mode (7 or 10 bit) when acting as a master.
◆ fs_scl_hcnt
uint16_t ALT_I2C_MASTER_CONFIG_s::fs_scl_hcnt
The SCL clock high-period count for fast speed.
◆ fs_scl_lcnt
uint16_t ALT_I2C_MASTER_CONFIG_s::fs_scl_lcnt
The SCL clock low-period count for fast speed.
◆ fs_spklen
uint8_t ALT_I2C_MASTER_CONFIG_s::fs_spklen
The duration, measured in ic_clk cycles, of the longest spike that is filtered out by the spike suppression logic when the component is operating in SS or FS modes.
◆ restart_enable
bool ALT_I2C_MASTER_CONFIG_s::restart_enable
This setting determines whether RESTART conditions may be sent when acting as a master. When the restart_enable is false, the I2C controller master is incapable of performing the following functions:
  • Sending a START BYTE
  • Performing any high-speed mode operation
  • Performing direction changes in combined format mode
  • Performing a read operation with a 10-bit address
◆ speed_mode
ALT_I2C_SPEED_t ALT_I2C_MASTER_CONFIG_s::speed_mode
The speed mode of the I2C operation.
◆ ss_scl_hcnt
uint16_t ALT_I2C_MASTER_CONFIG_s::ss_scl_hcnt
The SCL clock high-period count for standard speed.
◆ ss_scl_lcnt
uint16_t ALT_I2C_MASTER_CONFIG_s::ss_scl_lcnt
The SCL clock low-period count for standard speed.
