RTEMS 6.2
Header file of SDMMC HAL module. More...
#include "stm32h7xx_hal_def.h"Go to the source code of this file.
| struct | SDMMC_InitTypeDef |
| SDMMC Configuration Structure definition. More... | |
| struct | SDMMC_CmdInitTypeDef |
| SDMMC Command Control structure. More... | |
| struct | SDMMC_DataInitTypeDef |
| SDMMC Data Control structure. More... | |
| #define | SDMMC_ERROR_NONE ((uint32_t)0x00000000U) |
| #define | SDMMC_ERROR_CMD_CRC_FAIL ((uint32_t)0x00000001U) |
| #define | SDMMC_ERROR_DATA_CRC_FAIL ((uint32_t)0x00000002U) |
| #define | SDMMC_ERROR_CMD_RSP_TIMEOUT ((uint32_t)0x00000004U) |
| #define | SDMMC_ERROR_DATA_TIMEOUT ((uint32_t)0x00000008U) |
| #define | SDMMC_ERROR_TX_UNDERRUN ((uint32_t)0x00000010U) |
| #define | SDMMC_ERROR_RX_OVERRUN ((uint32_t)0x00000020U) |
| #define | SDMMC_ERROR_ADDR_MISALIGNED ((uint32_t)0x00000040U) |
| #define | SDMMC_ERROR_BLOCK_LEN_ERR ((uint32_t)0x00000080U) |
| #define | SDMMC_ERROR_ERASE_SEQ_ERR ((uint32_t)0x00000100U) |
| #define | SDMMC_ERROR_BAD_ERASE_PARAM ((uint32_t)0x00000200U) |
| #define | SDMMC_ERROR_WRITE_PROT_VIOLATION ((uint32_t)0x00000400U) |
| #define | SDMMC_ERROR_LOCK_UNLOCK_FAILED ((uint32_t)0x00000800U) |
| #define | SDMMC_ERROR_COM_CRC_FAILED ((uint32_t)0x00001000U) |
| #define | SDMMC_ERROR_ILLEGAL_CMD ((uint32_t)0x00002000U) |
| #define | SDMMC_ERROR_CARD_ECC_FAILED ((uint32_t)0x00004000U) |
| #define | SDMMC_ERROR_CC_ERR ((uint32_t)0x00008000U) |
| #define | SDMMC_ERROR_GENERAL_UNKNOWN_ERR ((uint32_t)0x00010000U) |
| #define | SDMMC_ERROR_STREAM_READ_UNDERRUN ((uint32_t)0x00020000U) |
| #define | SDMMC_ERROR_STREAM_WRITE_OVERRUN ((uint32_t)0x00040000U) |
| #define | SDMMC_ERROR_CID_CSD_OVERWRITE ((uint32_t)0x00080000U) |
| #define | SDMMC_ERROR_WP_ERASE_SKIP ((uint32_t)0x00100000U) |
| #define | SDMMC_ERROR_CARD_ECC_DISABLED ((uint32_t)0x00200000U) |
| #define | SDMMC_ERROR_ERASE_RESET ((uint32_t)0x00400000U) |
| #define | SDMMC_ERROR_AKE_SEQ_ERR ((uint32_t)0x00800000U) |
| #define | SDMMC_ERROR_INVALID_VOLTRANGE ((uint32_t)0x01000000U) |
| #define | SDMMC_ERROR_ADDR_OUT_OF_RANGE ((uint32_t)0x02000000U) |
| #define | SDMMC_ERROR_REQUEST_NOT_APPLICABLE ((uint32_t)0x04000000U) |
| #define | SDMMC_ERROR_INVALID_PARAMETER ((uint32_t)0x08000000U) |
| #define | SDMMC_ERROR_UNSUPPORTED_FEATURE ((uint32_t)0x10000000U) |
| #define | SDMMC_ERROR_BUSY ((uint32_t)0x20000000U) |
| #define | SDMMC_ERROR_DMA ((uint32_t)0x40000000U) |
| #define | SDMMC_ERROR_TIMEOUT ((uint32_t)0x80000000U) |
| #define | SDMMC_CMD_GO_IDLE_STATE ((uint8_t)0U) |
| SDMMC Commands Index. | |
| #define | SDMMC_CMD_SEND_OP_COND ((uint8_t)1U) |
| #define | SDMMC_CMD_ALL_SEND_CID ((uint8_t)2U) |
| #define | SDMMC_CMD_SET_REL_ADDR ((uint8_t)3U) |
| #define | SDMMC_CMD_SET_DSR ((uint8_t)4U) |
| #define | SDMMC_CMD_SDMMC_SEN_OP_COND ((uint8_t)5U) |
| #define | SDMMC_CMD_HS_SWITCH ((uint8_t)6U) |
| #define | SDMMC_CMD_SEL_DESEL_CARD ((uint8_t)7U) |
| #define | SDMMC_CMD_HS_SEND_EXT_CSD ((uint8_t)8U) |
| #define | SDMMC_CMD_SEND_CSD ((uint8_t)9U) |
| #define | SDMMC_CMD_SEND_CID ((uint8_t)10U) |
| #define | SDMMC_CMD_VOLTAGE_SWITCH ((uint8_t)11U) |
| #define | SDMMC_CMD_STOP_TRANSMISSION ((uint8_t)12U) |
| #define | SDMMC_CMD_SEND_STATUS ((uint8_t)13U) |
| #define | SDMMC_CMD_HS_BUSTEST_READ ((uint8_t)14U) |
| #define | SDMMC_CMD_GO_INACTIVE_STATE ((uint8_t)15U) |
| #define | SDMMC_CMD_SET_BLOCKLEN ((uint8_t)16U) |
| #define | SDMMC_CMD_READ_SINGLE_BLOCK ((uint8_t)17U) |
| #define | SDMMC_CMD_READ_MULT_BLOCK ((uint8_t)18U) |
| #define | SDMMC_CMD_HS_BUSTEST_WRITE ((uint8_t)19U) |
| #define | SDMMC_CMD_WRITE_DAT_UNTIL_STOP ((uint8_t)20U) |
| #define | SDMMC_CMD_SET_BLOCK_COUNT ((uint8_t)23U) |
| #define | SDMMC_CMD_WRITE_SINGLE_BLOCK ((uint8_t)24U) |
| #define | SDMMC_CMD_WRITE_MULT_BLOCK ((uint8_t)25U) |
| #define | SDMMC_CMD_PROG_CID ((uint8_t)26U) |
| #define | SDMMC_CMD_PROG_CSD ((uint8_t)27U) |
| #define | SDMMC_CMD_SET_WRITE_PROT ((uint8_t)28U) |
| #define | SDMMC_CMD_CLR_WRITE_PROT ((uint8_t)29U) |
| #define | SDMMC_CMD_SEND_WRITE_PROT ((uint8_t)30U) |
| #define | SDMMC_CMD_SD_ERASE_GRP_START ((uint8_t)32U) |
| #define | SDMMC_CMD_SD_ERASE_GRP_END ((uint8_t)33U) |
| #define | SDMMC_CMD_ERASE_GRP_START ((uint8_t)35U) |
| #define | SDMMC_CMD_ERASE_GRP_END ((uint8_t)36U) |
| #define | SDMMC_CMD_ERASE ((uint8_t)38U) |
| #define | SDMMC_CMD_FAST_IO ((uint8_t)39U) |
| #define | SDMMC_CMD_GO_IRQ_STATE ((uint8_t)40U) |
| #define | SDMMC_CMD_LOCK_UNLOCK ((uint8_t)42U) |
| #define | SDMMC_CMD_APP_CMD ((uint8_t)55U) |
| #define | SDMMC_CMD_GEN_CMD ((uint8_t)56U) |
| #define | SDMMC_CMD_NO_CMD ((uint8_t)64U) |
| #define | SDMMC_CMD_APP_SD_SET_BUSWIDTH ((uint8_t)6U) |
| Following commands are SD Card Specific commands. SDMMC_APP_CMD should be sent before sending these commands. | |
| #define | SDMMC_CMD_SD_APP_STATUS ((uint8_t)13U) |
| #define | SDMMC_CMD_SD_APP_SEND_NUM_WRITE_BLOCKS ((uint8_t)22U) |
| #define | SDMMC_CMD_SD_APP_OP_COND ((uint8_t)41U) |
| #define | SDMMC_CMD_SD_APP_SET_CLR_CARD_DETECT ((uint8_t)42U) |
| #define | SDMMC_CMD_SD_APP_SEND_SCR ((uint8_t)51U) |
| #define | SDMMC_CMD_SDMMC_RW_DIRECT ((uint8_t)52U) |
| #define | SDMMC_CMD_SDMMC_RW_EXTENDED ((uint8_t)53U) |
| #define | SDMMC_CMD_MMC_SLEEP_AWAKE ((uint8_t)5U) |
| Following commands are MMC Specific commands. | |
| #define | SDMMC_CMD_SD_APP_GET_MKB ((uint8_t)43U) |
| Following commands are SD Card Specific security commands. SDMMC_CMD_APP_CMD should be sent before sending these commands. | |
| #define | SDMMC_CMD_SD_APP_GET_MID ((uint8_t)44U) |
| #define | SDMMC_CMD_SD_APP_SET_CER_RN1 ((uint8_t)45U) |
| #define | SDMMC_CMD_SD_APP_GET_CER_RN2 ((uint8_t)46U) |
| #define | SDMMC_CMD_SD_APP_SET_CER_RES2 ((uint8_t)47U) |
| #define | SDMMC_CMD_SD_APP_GET_CER_RES1 ((uint8_t)48U) |
| #define | SDMMC_CMD_SD_APP_SECURE_READ_MULTIPLE_BLOCK ((uint8_t)18U) |
| #define | SDMMC_CMD_SD_APP_SECURE_WRITE_MULTIPLE_BLOCK ((uint8_t)25U) |
| #define | SDMMC_CMD_SD_APP_SECURE_ERASE ((uint8_t)38U) |
| #define | SDMMC_CMD_SD_APP_CHANGE_SECURE_AREA ((uint8_t)49U) |
| #define | SDMMC_CMD_SD_APP_SECURE_WRITE_MKB ((uint8_t)48U) |
| #define | SDMMC_OCR_ADDR_OUT_OF_RANGE ((uint32_t)0x80000000U) |
| Masks for errors Card Status R1 (OCR Register) | |
| #define | SDMMC_OCR_ADDR_MISALIGNED ((uint32_t)0x40000000U) |
| #define | SDMMC_OCR_BLOCK_LEN_ERR ((uint32_t)0x20000000U) |
| #define | SDMMC_OCR_ERASE_SEQ_ERR ((uint32_t)0x10000000U) |
| #define | SDMMC_OCR_BAD_ERASE_PARAM ((uint32_t)0x08000000U) |
| #define | SDMMC_OCR_WRITE_PROT_VIOLATION ((uint32_t)0x04000000U) |
| #define | SDMMC_OCR_LOCK_UNLOCK_FAILED ((uint32_t)0x01000000U) |
| #define | SDMMC_OCR_COM_CRC_FAILED ((uint32_t)0x00800000U) |
| #define | SDMMC_OCR_ILLEGAL_CMD ((uint32_t)0x00400000U) |
| #define | SDMMC_OCR_CARD_ECC_FAILED ((uint32_t)0x00200000U) |
| #define | SDMMC_OCR_CC_ERROR ((uint32_t)0x00100000U) |
| #define | SDMMC_OCR_GENERAL_UNKNOWN_ERROR ((uint32_t)0x00080000U) |
| #define | SDMMC_OCR_STREAM_READ_UNDERRUN ((uint32_t)0x00040000U) |
| #define | SDMMC_OCR_STREAM_WRITE_OVERRUN ((uint32_t)0x00020000U) |
| #define | SDMMC_OCR_CID_CSD_OVERWRITE ((uint32_t)0x00010000U) |
| #define | SDMMC_OCR_WP_ERASE_SKIP ((uint32_t)0x00008000U) |
| #define | SDMMC_OCR_CARD_ECC_DISABLED ((uint32_t)0x00004000U) |
| #define | SDMMC_OCR_ERASE_RESET ((uint32_t)0x00002000U) |
| #define | SDMMC_OCR_AKE_SEQ_ERROR ((uint32_t)0x00000008U) |
| #define | SDMMC_OCR_ERRORBITS ((uint32_t)0xFDFFE008U) |
| #define | SDMMC_R6_GENERAL_UNKNOWN_ERROR ((uint32_t)0x00002000U) |
| Masks for R6 Response. | |
| #define | SDMMC_R6_ILLEGAL_CMD ((uint32_t)0x00004000U) |
| #define | SDMMC_R6_COM_CRC_FAILED ((uint32_t)0x00008000U) |
| #define | SDMMC_VOLTAGE_WINDOW_SD ((uint32_t)0x80100000U) |
| #define | SDMMC_HIGH_CAPACITY ((uint32_t)0x40000000U) |
| #define | SDMMC_STD_CAPACITY ((uint32_t)0x00000000U) |
| #define | SDMMC_CHECK_PATTERN ((uint32_t)0x000001AAU) |
| #define | SD_SWITCH_1_8V_CAPACITY ((uint32_t)0x01000000U) |
| #define | SDMMC_DDR50_SWITCH_PATTERN ((uint32_t)0x80FFFF04U) |
| #define | SDMMC_SDR104_SWITCH_PATTERN ((uint32_t)0x80FF1F03U) |
| #define | SDMMC_SDR50_SWITCH_PATTERN ((uint32_t)0x80FF1F02U) |
| #define | SDMMC_SDR25_SWITCH_PATTERN ((uint32_t)0x80FFFF01U) |
| #define | SDMMC_SDR12_SWITCH_PATTERN ((uint32_t)0x80FFFF00U) |
| #define | SDMMC_MAX_VOLT_TRIAL ((uint32_t)0x0000FFFFU) |
| #define | SDMMC_MAX_TRIAL ((uint32_t)0x0000FFFFU) |
| #define | SDMMC_ALLZERO ((uint32_t)0x00000000U) |
| #define | SDMMC_WIDE_BUS_SUPPORT ((uint32_t)0x00040000U) |
| #define | SDMMC_SINGLE_BUS_SUPPORT ((uint32_t)0x00010000U) |
| #define | SDMMC_CARD_LOCKED ((uint32_t)0x02000000U) |
| #define | SDMMC_DATATIMEOUT ((uint32_t)0xFFFFFFFFU) |
| #define | SDMMC_0TO7BITS ((uint32_t)0x000000FFU) |
| #define | SDMMC_8TO15BITS ((uint32_t)0x0000FF00U) |
| #define | SDMMC_16TO23BITS ((uint32_t)0x00FF0000U) |
| #define | SDMMC_24TO31BITS ((uint32_t)0xFF000000U) |
| #define | SDMMC_MAX_DATA_LENGTH ((uint32_t)0x01FFFFFFU) |
| #define | SDMMC_HALFFIFO ((uint32_t)0x00000008U) |
| #define | SDMMC_HALFFIFOBYTES ((uint32_t)0x00000020U) |
| #define | SDMMC_CCCC_ERASE ((uint32_t)0x00000020U) |
| Command Class supported. | |
| #define | SDMMC_CMDTIMEOUT ((uint32_t)5000U) /* Command send and response timeout */ |
| #define | SDMMC_MAXERASETIMEOUT ((uint32_t)63000U) /* Max erase Timeout 63 s */ |
| #define | SDMMC_STOPTRANSFERTIMEOUT ((uint32_t)100000000U) /* Timeout for STOP TRANSMISSION command */ |
| #define | SDMMC_CLOCK_EDGE_RISING ((uint32_t)0x00000000U) |
| #define | SDMMC_CLOCK_EDGE_FALLING SDMMC_CLKCR_NEGEDGE |
| #define | IS_SDMMC_CLOCK_EDGE(EDGE) |
| #define | SDMMC_CLOCK_POWER_SAVE_DISABLE ((uint32_t)0x00000000U) |
| #define | SDMMC_CLOCK_POWER_SAVE_ENABLE SDMMC_CLKCR_PWRSAV |
| #define | IS_SDMMC_CLOCK_POWER_SAVE(SAVE) |
| #define | SDMMC_BUS_WIDE_1B ((uint32_t)0x00000000U) |
| #define | SDMMC_BUS_WIDE_4B SDMMC_CLKCR_WIDBUS_0 |
| #define | SDMMC_BUS_WIDE_8B SDMMC_CLKCR_WIDBUS_1 |
| #define | IS_SDMMC_BUS_WIDE(WIDE) |
| #define | SDMMC_SPEED_MODE_AUTO ((uint32_t)0x00000000U) |
| #define | SDMMC_SPEED_MODE_DEFAULT ((uint32_t)0x00000001U) |
| #define | SDMMC_SPEED_MODE_HIGH ((uint32_t)0x00000002U) |
| #define | SDMMC_SPEED_MODE_ULTRA ((uint32_t)0x00000003U) |
| #define | SDMMC_SPEED_MODE_ULTRA_SDR104 SDMMC_SPEED_MODE_ULTRA |
| #define | SDMMC_SPEED_MODE_DDR ((uint32_t)0x00000004U) |
| #define | SDMMC_SPEED_MODE_ULTRA_SDR50 ((uint32_t)0x00000005U) |
| #define | IS_SDMMC_SPEED_MODE(MODE) |
| #define | SDMMC_HARDWARE_FLOW_CONTROL_DISABLE ((uint32_t)0x00000000U) |
| #define | SDMMC_HARDWARE_FLOW_CONTROL_ENABLE SDMMC_CLKCR_HWFC_EN |
| #define | IS_SDMMC_HARDWARE_FLOW_CONTROL(CONTROL) |
| #define | IS_SDMMC_CLKDIV(DIV) ((DIV) < 0x400U) |
| #define | SDMMC_TRANSCEIVER_UNKNOWN ((uint32_t)0x00000000U) |
| #define | SDMMC_TRANSCEIVER_NOT_PRESENT ((uint32_t)0x00000001U) |
| #define | SDMMC_TRANSCEIVER_PRESENT ((uint32_t)0x00000002U) |
| #define | IS_SDMMC_CMD_INDEX(INDEX) ((INDEX) < 0x40U) |
| #define | SDMMC_RESPONSE_NO ((uint32_t)0x00000000U) |
| #define | SDMMC_RESPONSE_SHORT SDMMC_CMD_WAITRESP_0 |
| #define | SDMMC_RESPONSE_LONG SDMMC_CMD_WAITRESP |
| #define | IS_SDMMC_RESPONSE(RESPONSE) |
| #define | SDMMC_WAIT_NO ((uint32_t)0x00000000U) |
| #define | SDMMC_WAIT_IT SDMMC_CMD_WAITINT |
| #define | SDMMC_WAIT_PEND SDMMC_CMD_WAITPEND |
| #define | IS_SDMMC_WAIT(WAIT) |
| #define | SDMMC_CPSM_DISABLE ((uint32_t)0x00000000U) |
| #define | SDMMC_CPSM_ENABLE SDMMC_CMD_CPSMEN |
| #define | IS_SDMMC_CPSM(CPSM) |
| #define | SDMMC_RESP1 ((uint32_t)0x00000000U) |
| #define | SDMMC_RESP2 ((uint32_t)0x00000004U) |
| #define | SDMMC_RESP3 ((uint32_t)0x00000008U) |
| #define | SDMMC_RESP4 ((uint32_t)0x0000000CU) |
| #define | IS_SDMMC_RESP(RESP) |
| #define | SDMMC_DISABLE_IDMA ((uint32_t)0x00000000) |
| #define | SDMMC_ENABLE_IDMA_SINGLE_BUFF (SDMMC_IDMA_IDMAEN) |
| #define | SDMMC_ENABLE_IDMA_DOUBLE_BUFF0 (SDMMC_IDMA_IDMAEN | SDMMC_IDMA_IDMABMODE) |
| #define | SDMMC_ENABLE_IDMA_DOUBLE_BUFF1 (SDMMC_IDMA_IDMAEN | SDMMC_IDMA_IDMABMODE | SDMMC_IDMA_IDMABACT) |
| #define | IS_SDMMC_DATA_LENGTH(LENGTH) ((LENGTH) <= 0x01FFFFFFU) |
| #define | SDMMC_DATABLOCK_SIZE_1B ((uint32_t)0x00000000U) |
| #define | SDMMC_DATABLOCK_SIZE_2B SDMMC_DCTRL_DBLOCKSIZE_0 |
| #define | SDMMC_DATABLOCK_SIZE_4B SDMMC_DCTRL_DBLOCKSIZE_1 |
| #define | SDMMC_DATABLOCK_SIZE_8B (SDMMC_DCTRL_DBLOCKSIZE_0|SDMMC_DCTRL_DBLOCKSIZE_1) |
| #define | SDMMC_DATABLOCK_SIZE_16B SDMMC_DCTRL_DBLOCKSIZE_2 |
| #define | SDMMC_DATABLOCK_SIZE_32B (SDMMC_DCTRL_DBLOCKSIZE_0|SDMMC_DCTRL_DBLOCKSIZE_2) |
| #define | SDMMC_DATABLOCK_SIZE_64B (SDMMC_DCTRL_DBLOCKSIZE_1|SDMMC_DCTRL_DBLOCKSIZE_2) |
| #define | SDMMC_DATABLOCK_SIZE_128B |
| #define | SDMMC_DATABLOCK_SIZE_256B SDMMC_DCTRL_DBLOCKSIZE_3 |
| #define | SDMMC_DATABLOCK_SIZE_512B (SDMMC_DCTRL_DBLOCKSIZE_0|SDMMC_DCTRL_DBLOCKSIZE_3) |
| #define | SDMMC_DATABLOCK_SIZE_1024B (SDMMC_DCTRL_DBLOCKSIZE_1|SDMMC_DCTRL_DBLOCKSIZE_3) |
| #define | SDMMC_DATABLOCK_SIZE_2048B |
| #define | SDMMC_DATABLOCK_SIZE_4096B (SDMMC_DCTRL_DBLOCKSIZE_2|SDMMC_DCTRL_DBLOCKSIZE_3) |
| #define | SDMMC_DATABLOCK_SIZE_8192B |
| #define | SDMMC_DATABLOCK_SIZE_16384B |
| #define | IS_SDMMC_BLOCK_SIZE(SIZE) |
| #define | SDMMC_TRANSFER_DIR_TO_CARD ((uint32_t)0x00000000U) |
| #define | SDMMC_TRANSFER_DIR_TO_SDMMC SDMMC_DCTRL_DTDIR |
| #define | IS_SDMMC_TRANSFER_DIR(DIR) |
| #define | SDMMC_TRANSFER_MODE_BLOCK ((uint32_t)0x00000000U) |
| #define | SDMMC_TRANSFER_MODE_STREAM SDMMC_DCTRL_DTMODE_1 |
| #define | IS_SDMMC_TRANSFER_MODE(MODE) |
| #define | SDMMC_DPSM_DISABLE ((uint32_t)0x00000000U) |
| #define | SDMMC_DPSM_ENABLE SDMMC_DCTRL_DTEN |
| #define | IS_SDMMC_DPSM(DPSM) |
| #define | SDMMC_READ_WAIT_MODE_DATA2 ((uint32_t)0x00000000U) |
| #define | SDMMC_READ_WAIT_MODE_CLK (SDMMC_DCTRL_RWMOD) |
| #define | IS_SDMMC_READWAIT_MODE(MODE) |
| #define | SDMMC_IT_CCRCFAIL SDMMC_MASK_CCRCFAILIE |
| #define | SDMMC_IT_DCRCFAIL SDMMC_MASK_DCRCFAILIE |
| #define | SDMMC_IT_CTIMEOUT SDMMC_MASK_CTIMEOUTIE |
| #define | SDMMC_IT_DTIMEOUT SDMMC_MASK_DTIMEOUTIE |
| #define | SDMMC_IT_TXUNDERR SDMMC_MASK_TXUNDERRIE |
| #define | SDMMC_IT_RXOVERR SDMMC_MASK_RXOVERRIE |
| #define | SDMMC_IT_CMDREND SDMMC_MASK_CMDRENDIE |
| #define | SDMMC_IT_CMDSENT SDMMC_MASK_CMDSENTIE |
| #define | SDMMC_IT_DATAEND SDMMC_MASK_DATAENDIE |
| #define | SDMMC_IT_DHOLD SDMMC_MASK_DHOLDIE |
| #define | SDMMC_IT_DBCKEND SDMMC_MASK_DBCKENDIE |
| #define | SDMMC_IT_DABORT SDMMC_MASK_DABORTIE |
| #define | SDMMC_IT_TXFIFOHE SDMMC_MASK_TXFIFOHEIE |
| #define | SDMMC_IT_RXFIFOHF SDMMC_MASK_RXFIFOHFIE |
| #define | SDMMC_IT_RXFIFOF SDMMC_MASK_RXFIFOFIE |
| #define | SDMMC_IT_TXFIFOE SDMMC_MASK_TXFIFOEIE |
| #define | SDMMC_IT_BUSYD0END SDMMC_MASK_BUSYD0ENDIE |
| #define | SDMMC_IT_SDIOIT SDMMC_MASK_SDIOITIE |
| #define | SDMMC_IT_ACKFAIL SDMMC_MASK_ACKFAILIE |
| #define | SDMMC_IT_ACKTIMEOUT SDMMC_MASK_ACKTIMEOUTIE |
| #define | SDMMC_IT_VSWEND SDMMC_MASK_VSWENDIE |
| #define | SDMMC_IT_CKSTOP SDMMC_MASK_CKSTOPIE |
| #define | SDMMC_IT_IDMABTC SDMMC_MASK_IDMABTCIE |
| #define | SDMMC_FLAG_CCRCFAIL SDMMC_STA_CCRCFAIL |
| #define | SDMMC_FLAG_DCRCFAIL SDMMC_STA_DCRCFAIL |
| #define | SDMMC_FLAG_CTIMEOUT SDMMC_STA_CTIMEOUT |
| #define | SDMMC_FLAG_DTIMEOUT SDMMC_STA_DTIMEOUT |
| #define | SDMMC_FLAG_TXUNDERR SDMMC_STA_TXUNDERR |
| #define | SDMMC_FLAG_RXOVERR SDMMC_STA_RXOVERR |
| #define | SDMMC_FLAG_CMDREND SDMMC_STA_CMDREND |
| #define | SDMMC_FLAG_CMDSENT SDMMC_STA_CMDSENT |
| #define | SDMMC_FLAG_DATAEND SDMMC_STA_DATAEND |
| #define | SDMMC_FLAG_DHOLD SDMMC_STA_DHOLD |
| #define | SDMMC_FLAG_DBCKEND SDMMC_STA_DBCKEND |
| #define | SDMMC_FLAG_DABORT SDMMC_STA_DABORT |
| #define | SDMMC_FLAG_DPSMACT SDMMC_STA_DPSMACT |
| #define | SDMMC_FLAG_CMDACT SDMMC_STA_CPSMACT |
| #define | SDMMC_FLAG_TXFIFOHE SDMMC_STA_TXFIFOHE |
| #define | SDMMC_FLAG_RXFIFOHF SDMMC_STA_RXFIFOHF |
| #define | SDMMC_FLAG_TXFIFOF SDMMC_STA_TXFIFOF |
| #define | SDMMC_FLAG_RXFIFOF SDMMC_STA_RXFIFOF |
| #define | SDMMC_FLAG_TXFIFOE SDMMC_STA_TXFIFOE |
| #define | SDMMC_FLAG_RXFIFOE SDMMC_STA_RXFIFOE |
| #define | SDMMC_FLAG_BUSYD0 SDMMC_STA_BUSYD0 |
| #define | SDMMC_FLAG_BUSYD0END SDMMC_STA_BUSYD0END |
| #define | SDMMC_FLAG_SDIOIT SDMMC_STA_SDIOIT |
| #define | SDMMC_FLAG_ACKFAIL SDMMC_STA_ACKFAIL |
| #define | SDMMC_FLAG_ACKTIMEOUT SDMMC_STA_ACKTIMEOUT |
| #define | SDMMC_FLAG_VSWEND SDMMC_STA_VSWEND |
| #define | SDMMC_FLAG_CKSTOP SDMMC_STA_CKSTOP |
| #define | SDMMC_FLAG_IDMATE SDMMC_STA_IDMATE |
| #define | SDMMC_FLAG_IDMABTC SDMMC_STA_IDMABTC |
| #define | SDMMC_STATIC_FLAGS |
| #define | SDMMC_STATIC_CMD_FLAGS |
| #define | SDMMC_STATIC_DATA_FLAGS |
| #define | CLKCR_CLEAR_MASK |
| #define | DCTRL_CLEAR_MASK |
| #define | CMD_CLEAR_MASK |
| #define | SDMMC_INIT_CLK_DIV ((uint8_t)0xFA) |
| #define | SDMMC_NSPEED_CLK_DIV ((uint8_t)0x4) |
| #define | SDMMC_HSPEED_CLK_DIV ((uint8_t)0x2) |
| #define | __SDMMC_ENABLE_IT(__INSTANCE__, __INTERRUPT__) ((__INSTANCE__)->MASK |= (__INTERRUPT__)) |
| Enable the SDMMC device interrupt. | |
| #define | __SDMMC_DISABLE_IT(__INSTANCE__, __INTERRUPT__) ((__INSTANCE__)->MASK &= ~(__INTERRUPT__)) |
| Disable the SDMMC device interrupt. | |
| #define | __SDMMC_GET_FLAG(__INSTANCE__, __FLAG__) (((__INSTANCE__)->STA &(__FLAG__)) != 0U) |
| Checks whether the specified SDMMC flag is set or not. | |
| #define | __SDMMC_CLEAR_FLAG(__INSTANCE__, __FLAG__) ((__INSTANCE__)->ICR = (__FLAG__)) |
| Clears the SDMMC pending flags. | |
| #define | __SDMMC_GET_IT(__INSTANCE__, __INTERRUPT__) (((__INSTANCE__)->STA &(__INTERRUPT__)) == (__INTERRUPT__)) |
| Checks whether the specified SDMMC interrupt has occurred or not. | |
| #define | __SDMMC_CLEAR_IT(__INSTANCE__, __INTERRUPT__) ((__INSTANCE__)->ICR = (__INTERRUPT__)) |
| Clears the SDMMC's interrupt pending bits. | |
| #define | __SDMMC_START_READWAIT_ENABLE(__INSTANCE__) ((__INSTANCE__)->DCTRL |= SDMMC_DCTRL_RWSTART) |
| Enable Start the SD I/O Read Wait operation. | |
| #define | __SDMMC_START_READWAIT_DISABLE(__INSTANCE__) ((__INSTANCE__)->DCTRL &= ~SDMMC_DCTRL_RWSTART) |
| Disable Start the SD I/O Read Wait operations. | |
| #define | __SDMMC_STOP_READWAIT_ENABLE(__INSTANCE__) ((__INSTANCE__)->DCTRL |= SDMMC_DCTRL_RWSTOP) |
| #define | __SDMMC_STOP_READWAIT_DISABLE(__INSTANCE__) ((__INSTANCE__)->DCTRL &= ~SDMMC_DCTRL_RWSTOP) |
| Disable Stop the SD I/O Read Wait operations. | |
| #define | __SDMMC_OPERATION_ENABLE(__INSTANCE__) ((__INSTANCE__)->DCTRL |= SDMMC_DCTRL_SDIOEN) |
| Enable the SD I/O Mode Operation. | |
| #define | __SDMMC_OPERATION_DISABLE(__INSTANCE__) ((__INSTANCE__)->DCTRL &= ~SDMMC_DCTRL_SDIOEN) |
| Disable the SD I/O Mode Operation. | |
| #define | __SDMMC_SUSPEND_CMD_ENABLE(__INSTANCE__) ((__INSTANCE__)->CMD |= SDMMC_CMD_CMDSUSPEND) |
| Enable the SD I/O Suspend command sending. | |
| #define | __SDMMC_SUSPEND_CMD_DISABLE(__INSTANCE__) ((__INSTANCE__)->CMD &= ~SDMMC_CMD_CMDSUSPEND) |
| Disable the SD I/O Suspend command sending. | |
| #define | __SDMMC_CMDTRANS_ENABLE(__INSTANCE__) ((__INSTANCE__)->CMD |= SDMMC_CMD_CMDTRANS) |
| Enable the CMDTRANS mode. | |
| #define | __SDMMC_CMDTRANS_DISABLE(__INSTANCE__) ((__INSTANCE__)->CMD &= ~SDMMC_CMD_CMDTRANS) |
| Disable the CMDTRANS mode. | |
| #define | __SDMMC_CMDSTOP_ENABLE(__INSTANCE__) ((__INSTANCE__)->CMD |= SDMMC_CMD_CMDSTOP) |
| Enable the CMDSTOP mode. | |
| #define | __SDMMC_CMDSTOP_DISABLE(__INSTANCE__) ((__INSTANCE__)->CMD &= ~SDMMC_CMD_CMDSTOP) |
| Disable the CMDSTOP mode. | |
| HAL_StatusTypeDef | SDMMC_Init (SDMMC_TypeDef *SDMMCx, SDMMC_InitTypeDef Init) |
| uint32_t | SDMMC_ReadFIFO (SDMMC_TypeDef *SDMMCx) |
| HAL_StatusTypeDef | SDMMC_WriteFIFO (SDMMC_TypeDef *SDMMCx, uint32_t *pWriteData) |
| HAL_StatusTypeDef | SDMMC_PowerState_ON (SDMMC_TypeDef *SDMMCx) |
| HAL_StatusTypeDef | SDMMC_PowerState_Cycle (SDMMC_TypeDef *SDMMCx) |
| HAL_StatusTypeDef | SDMMC_PowerState_OFF (SDMMC_TypeDef *SDMMCx) |
| uint32_t | SDMMC_GetPowerState (SDMMC_TypeDef *SDMMCx) |
| HAL_StatusTypeDef | SDMMC_SendCommand (SDMMC_TypeDef *SDMMCx, SDMMC_CmdInitTypeDef *Command) |
| uint8_t | SDMMC_GetCommandResponse (SDMMC_TypeDef *SDMMCx) |
| uint32_t | SDMMC_GetResponse (SDMMC_TypeDef *SDMMCx, uint32_t Response) |
| HAL_StatusTypeDef | SDMMC_ConfigData (SDMMC_TypeDef *SDMMCx, SDMMC_DataInitTypeDef *Data) |
| uint32_t | SDMMC_GetDataCounter (SDMMC_TypeDef *SDMMCx) |
| uint32_t | SDMMC_GetFIFOCount (SDMMC_TypeDef *SDMMCx) |
| HAL_StatusTypeDef | SDMMC_SetSDMMCReadWaitMode (SDMMC_TypeDef *SDMMCx, uint32_t SDMMC_ReadWaitMode) |
| uint32_t | SDMMC_CmdBlockLength (SDMMC_TypeDef *SDMMCx, uint32_t BlockSize) |
| uint32_t | SDMMC_CmdReadSingleBlock (SDMMC_TypeDef *SDMMCx, uint32_t ReadAdd) |
| uint32_t | SDMMC_CmdReadMultiBlock (SDMMC_TypeDef *SDMMCx, uint32_t ReadAdd) |
| uint32_t | SDMMC_CmdWriteSingleBlock (SDMMC_TypeDef *SDMMCx, uint32_t WriteAdd) |
| uint32_t | SDMMC_CmdWriteMultiBlock (SDMMC_TypeDef *SDMMCx, uint32_t WriteAdd) |
| uint32_t | SDMMC_CmdEraseStartAdd (SDMMC_TypeDef *SDMMCx, uint32_t StartAdd) |
| uint32_t | SDMMC_CmdSDEraseStartAdd (SDMMC_TypeDef *SDMMCx, uint32_t StartAdd) |
| uint32_t | SDMMC_CmdEraseEndAdd (SDMMC_TypeDef *SDMMCx, uint32_t EndAdd) |
| uint32_t | SDMMC_CmdSDEraseEndAdd (SDMMC_TypeDef *SDMMCx, uint32_t EndAdd) |
| uint32_t | SDMMC_CmdErase (SDMMC_TypeDef *SDMMCx, uint32_t EraseType) |
| uint32_t | SDMMC_CmdStopTransfer (SDMMC_TypeDef *SDMMCx) |
| uint32_t | SDMMC_CmdSelDesel (SDMMC_TypeDef *SDMMCx, uint32_t Addr) |
| uint32_t | SDMMC_CmdGoIdleState (SDMMC_TypeDef *SDMMCx) |
| uint32_t | SDMMC_CmdOperCond (SDMMC_TypeDef *SDMMCx) |
| uint32_t | SDMMC_CmdAppCommand (SDMMC_TypeDef *SDMMCx, uint32_t Argument) |
| uint32_t | SDMMC_CmdAppOperCommand (SDMMC_TypeDef *SDMMCx, uint32_t Argument) |
| uint32_t | SDMMC_CmdBusWidth (SDMMC_TypeDef *SDMMCx, uint32_t BusWidth) |
| uint32_t | SDMMC_CmdSendSCR (SDMMC_TypeDef *SDMMCx) |
| uint32_t | SDMMC_CmdSendCID (SDMMC_TypeDef *SDMMCx) |
| uint32_t | SDMMC_CmdSendCSD (SDMMC_TypeDef *SDMMCx, uint32_t Argument) |
| uint32_t | SDMMC_CmdSetRelAdd (SDMMC_TypeDef *SDMMCx, uint16_t *pRCA) |
| uint32_t | SDMMC_CmdSetRelAddMmc (SDMMC_TypeDef *SDMMCx, uint16_t RCA) |
| uint32_t | SDMMC_CmdSleepMmc (SDMMC_TypeDef *SDMMCx, uint32_t Argument) |
| uint32_t | SDMMC_CmdSendStatus (SDMMC_TypeDef *SDMMCx, uint32_t Argument) |
| uint32_t | SDMMC_CmdStatusRegister (SDMMC_TypeDef *SDMMCx) |
| uint32_t | SDMMC_CmdVoltageSwitch (SDMMC_TypeDef *SDMMCx) |
| uint32_t | SDMMC_CmdOpCondition (SDMMC_TypeDef *SDMMCx, uint32_t Argument) |
| uint32_t | SDMMC_CmdSwitch (SDMMC_TypeDef *SDMMCx, uint32_t Argument) |
| uint32_t | SDMMC_CmdSendEXTCSD (SDMMC_TypeDef *SDMMCx, uint32_t Argument) |
| uint32_t | SDMMC_GetCmdResp1 (SDMMC_TypeDef *SDMMCx, uint8_t SD_CMD, uint32_t Timeout) |
| uint32_t | SDMMC_GetCmdResp2 (SDMMC_TypeDef *SDMMCx) |
| uint32_t | SDMMC_GetCmdResp3 (SDMMC_TypeDef *SDMMCx) |
| uint32_t | SDMMC_GetCmdResp6 (SDMMC_TypeDef *SDMMCx, uint8_t SD_CMD, uint16_t *pRCA) |
| uint32_t | SDMMC_GetCmdResp7 (SDMMC_TypeDef *SDMMCx) |
