RTEMS 6.2
| #define | SDMMC_ERROR_NONE ((uint32_t)0x00000000U) |
| #define | SDMMC_ERROR_CMD_CRC_FAIL ((uint32_t)0x00000001U) |
| #define | SDMMC_ERROR_DATA_CRC_FAIL ((uint32_t)0x00000002U) |
| #define | SDMMC_ERROR_CMD_RSP_TIMEOUT ((uint32_t)0x00000004U) |
| #define | SDMMC_ERROR_DATA_TIMEOUT ((uint32_t)0x00000008U) |
| #define | SDMMC_ERROR_TX_UNDERRUN ((uint32_t)0x00000010U) |
| #define | SDMMC_ERROR_RX_OVERRUN ((uint32_t)0x00000020U) |
| #define | SDMMC_ERROR_ADDR_MISALIGNED ((uint32_t)0x00000040U) |
| #define | SDMMC_ERROR_BLOCK_LEN_ERR ((uint32_t)0x00000080U) |
| #define | SDMMC_ERROR_ERASE_SEQ_ERR ((uint32_t)0x00000100U) |
| #define | SDMMC_ERROR_BAD_ERASE_PARAM ((uint32_t)0x00000200U) |
| #define | SDMMC_ERROR_WRITE_PROT_VIOLATION ((uint32_t)0x00000400U) |
| #define | SDMMC_ERROR_LOCK_UNLOCK_FAILED ((uint32_t)0x00000800U) |
| #define | SDMMC_ERROR_COM_CRC_FAILED ((uint32_t)0x00001000U) |
| #define | SDMMC_ERROR_ILLEGAL_CMD ((uint32_t)0x00002000U) |
| #define | SDMMC_ERROR_CARD_ECC_FAILED ((uint32_t)0x00004000U) |
| #define | SDMMC_ERROR_CC_ERR ((uint32_t)0x00008000U) |
| #define | SDMMC_ERROR_GENERAL_UNKNOWN_ERR ((uint32_t)0x00010000U) |
| #define | SDMMC_ERROR_STREAM_READ_UNDERRUN ((uint32_t)0x00020000U) |
| #define | SDMMC_ERROR_STREAM_WRITE_OVERRUN ((uint32_t)0x00040000U) |
| #define | SDMMC_ERROR_CID_CSD_OVERWRITE ((uint32_t)0x00080000U) |
| #define | SDMMC_ERROR_WP_ERASE_SKIP ((uint32_t)0x00100000U) |
| #define | SDMMC_ERROR_CARD_ECC_DISABLED ((uint32_t)0x00200000U) |
| #define | SDMMC_ERROR_ERASE_RESET ((uint32_t)0x00400000U) |
| #define | SDMMC_ERROR_AKE_SEQ_ERR ((uint32_t)0x00800000U) |
| #define | SDMMC_ERROR_INVALID_VOLTRANGE ((uint32_t)0x01000000U) |
| #define | SDMMC_ERROR_ADDR_OUT_OF_RANGE ((uint32_t)0x02000000U) |
| #define | SDMMC_ERROR_REQUEST_NOT_APPLICABLE ((uint32_t)0x04000000U) |
| #define | SDMMC_ERROR_INVALID_PARAMETER ((uint32_t)0x08000000U) |
| #define | SDMMC_ERROR_UNSUPPORTED_FEATURE ((uint32_t)0x10000000U) |
| #define | SDMMC_ERROR_BUSY ((uint32_t)0x20000000U) |
| #define | SDMMC_ERROR_DMA ((uint32_t)0x40000000U) |
| #define | SDMMC_ERROR_TIMEOUT ((uint32_t)0x80000000U) |
| #define | SDMMC_CMD_GO_IDLE_STATE ((uint8_t)0U) |
| SDMMC Commands Index. | |
| #define | SDMMC_CMD_SEND_OP_COND ((uint8_t)1U) |
| #define | SDMMC_CMD_ALL_SEND_CID ((uint8_t)2U) |
| #define | SDMMC_CMD_SET_REL_ADDR ((uint8_t)3U) |
| #define | SDMMC_CMD_SET_DSR ((uint8_t)4U) |
| #define | SDMMC_CMD_SDMMC_SEN_OP_COND ((uint8_t)5U) |
| #define | SDMMC_CMD_HS_SWITCH ((uint8_t)6U) |
| #define | SDMMC_CMD_SEL_DESEL_CARD ((uint8_t)7U) |
| #define | SDMMC_CMD_HS_SEND_EXT_CSD ((uint8_t)8U) |
| #define | SDMMC_CMD_SEND_CSD ((uint8_t)9U) |
| #define | SDMMC_CMD_SEND_CID ((uint8_t)10U) |
| #define | SDMMC_CMD_VOLTAGE_SWITCH ((uint8_t)11U) |
| #define | SDMMC_CMD_STOP_TRANSMISSION ((uint8_t)12U) |
| #define | SDMMC_CMD_SEND_STATUS ((uint8_t)13U) |
| #define | SDMMC_CMD_HS_BUSTEST_READ ((uint8_t)14U) |
| #define | SDMMC_CMD_GO_INACTIVE_STATE ((uint8_t)15U) |
| #define | SDMMC_CMD_SET_BLOCKLEN ((uint8_t)16U) |
| #define | SDMMC_CMD_READ_SINGLE_BLOCK ((uint8_t)17U) |
| #define | SDMMC_CMD_READ_MULT_BLOCK ((uint8_t)18U) |
| #define | SDMMC_CMD_HS_BUSTEST_WRITE ((uint8_t)19U) |
| #define | SDMMC_CMD_WRITE_DAT_UNTIL_STOP ((uint8_t)20U) |
| #define | SDMMC_CMD_SET_BLOCK_COUNT ((uint8_t)23U) |
| #define | SDMMC_CMD_WRITE_SINGLE_BLOCK ((uint8_t)24U) |
| #define | SDMMC_CMD_WRITE_MULT_BLOCK ((uint8_t)25U) |
| #define | SDMMC_CMD_PROG_CID ((uint8_t)26U) |
| #define | SDMMC_CMD_PROG_CSD ((uint8_t)27U) |
| #define | SDMMC_CMD_SET_WRITE_PROT ((uint8_t)28U) |
| #define | SDMMC_CMD_CLR_WRITE_PROT ((uint8_t)29U) |
| #define | SDMMC_CMD_SEND_WRITE_PROT ((uint8_t)30U) |
| #define | SDMMC_CMD_SD_ERASE_GRP_START ((uint8_t)32U) |
| #define | SDMMC_CMD_SD_ERASE_GRP_END ((uint8_t)33U) |
| #define | SDMMC_CMD_ERASE_GRP_START ((uint8_t)35U) |
| #define | SDMMC_CMD_ERASE_GRP_END ((uint8_t)36U) |
| #define | SDMMC_CMD_ERASE ((uint8_t)38U) |
| #define | SDMMC_CMD_FAST_IO ((uint8_t)39U) |
| #define | SDMMC_CMD_GO_IRQ_STATE ((uint8_t)40U) |
| #define | SDMMC_CMD_LOCK_UNLOCK ((uint8_t)42U) |
| #define | SDMMC_CMD_APP_CMD ((uint8_t)55U) |
| #define | SDMMC_CMD_GEN_CMD ((uint8_t)56U) |
| #define | SDMMC_CMD_NO_CMD ((uint8_t)64U) |
| #define | SDMMC_CMD_APP_SD_SET_BUSWIDTH ((uint8_t)6U) |
| Following commands are SD Card Specific commands. SDMMC_APP_CMD should be sent before sending these commands. | |
| #define | SDMMC_CMD_SD_APP_STATUS ((uint8_t)13U) |
| #define | SDMMC_CMD_SD_APP_SEND_NUM_WRITE_BLOCKS ((uint8_t)22U) |
| #define | SDMMC_CMD_SD_APP_OP_COND ((uint8_t)41U) |
| #define | SDMMC_CMD_SD_APP_SET_CLR_CARD_DETECT ((uint8_t)42U) |
| #define | SDMMC_CMD_SD_APP_SEND_SCR ((uint8_t)51U) |
| #define | SDMMC_CMD_SDMMC_RW_DIRECT ((uint8_t)52U) |
| #define | SDMMC_CMD_SDMMC_RW_EXTENDED ((uint8_t)53U) |
| #define | SDMMC_CMD_MMC_SLEEP_AWAKE ((uint8_t)5U) |
| Following commands are MMC Specific commands. | |
| #define | SDMMC_CMD_SD_APP_GET_MKB ((uint8_t)43U) |
| Following commands are SD Card Specific security commands. SDMMC_CMD_APP_CMD should be sent before sending these commands. | |
| #define | SDMMC_CMD_SD_APP_GET_MID ((uint8_t)44U) |
| #define | SDMMC_CMD_SD_APP_SET_CER_RN1 ((uint8_t)45U) |
| #define | SDMMC_CMD_SD_APP_GET_CER_RN2 ((uint8_t)46U) |
| #define | SDMMC_CMD_SD_APP_SET_CER_RES2 ((uint8_t)47U) |
| #define | SDMMC_CMD_SD_APP_GET_CER_RES1 ((uint8_t)48U) |
| #define | SDMMC_CMD_SD_APP_SECURE_READ_MULTIPLE_BLOCK ((uint8_t)18U) |
| #define | SDMMC_CMD_SD_APP_SECURE_WRITE_MULTIPLE_BLOCK ((uint8_t)25U) |
| #define | SDMMC_CMD_SD_APP_SECURE_ERASE ((uint8_t)38U) |
| #define | SDMMC_CMD_SD_APP_CHANGE_SECURE_AREA ((uint8_t)49U) |
| #define | SDMMC_CMD_SD_APP_SECURE_WRITE_MKB ((uint8_t)48U) |
| #define | SDMMC_OCR_ADDR_OUT_OF_RANGE ((uint32_t)0x80000000U) |
| Masks for errors Card Status R1 (OCR Register) | |
| #define | SDMMC_OCR_ADDR_MISALIGNED ((uint32_t)0x40000000U) |
| #define | SDMMC_OCR_BLOCK_LEN_ERR ((uint32_t)0x20000000U) |
| #define | SDMMC_OCR_ERASE_SEQ_ERR ((uint32_t)0x10000000U) |
| #define | SDMMC_OCR_BAD_ERASE_PARAM ((uint32_t)0x08000000U) |
| #define | SDMMC_OCR_WRITE_PROT_VIOLATION ((uint32_t)0x04000000U) |
| #define | SDMMC_OCR_LOCK_UNLOCK_FAILED ((uint32_t)0x01000000U) |
| #define | SDMMC_OCR_COM_CRC_FAILED ((uint32_t)0x00800000U) |
| #define | SDMMC_OCR_ILLEGAL_CMD ((uint32_t)0x00400000U) |
| #define | SDMMC_OCR_CARD_ECC_FAILED ((uint32_t)0x00200000U) |
| #define | SDMMC_OCR_CC_ERROR ((uint32_t)0x00100000U) |
| #define | SDMMC_OCR_GENERAL_UNKNOWN_ERROR ((uint32_t)0x00080000U) |
| #define | SDMMC_OCR_STREAM_READ_UNDERRUN ((uint32_t)0x00040000U) |
| #define | SDMMC_OCR_STREAM_WRITE_OVERRUN ((uint32_t)0x00020000U) |
| #define | SDMMC_OCR_CID_CSD_OVERWRITE ((uint32_t)0x00010000U) |
| #define | SDMMC_OCR_WP_ERASE_SKIP ((uint32_t)0x00008000U) |
| #define | SDMMC_OCR_CARD_ECC_DISABLED ((uint32_t)0x00004000U) |
| #define | SDMMC_OCR_ERASE_RESET ((uint32_t)0x00002000U) |
| #define | SDMMC_OCR_AKE_SEQ_ERROR ((uint32_t)0x00000008U) |
| #define | SDMMC_OCR_ERRORBITS ((uint32_t)0xFDFFE008U) |
| #define | SDMMC_R6_GENERAL_UNKNOWN_ERROR ((uint32_t)0x00002000U) |
| Masks for R6 Response. | |
| #define | SDMMC_R6_ILLEGAL_CMD ((uint32_t)0x00004000U) |
| #define | SDMMC_R6_COM_CRC_FAILED ((uint32_t)0x00008000U) |
| #define | SDMMC_VOLTAGE_WINDOW_SD ((uint32_t)0x80100000U) |
| #define | SDMMC_HIGH_CAPACITY ((uint32_t)0x40000000U) |
| #define | SDMMC_STD_CAPACITY ((uint32_t)0x00000000U) |
| #define | SDMMC_CHECK_PATTERN ((uint32_t)0x000001AAU) |
| #define | SD_SWITCH_1_8V_CAPACITY ((uint32_t)0x01000000U) |
| #define | SDMMC_DDR50_SWITCH_PATTERN ((uint32_t)0x80FFFF04U) |
| #define | SDMMC_SDR104_SWITCH_PATTERN ((uint32_t)0x80FF1F03U) |
| #define | SDMMC_SDR50_SWITCH_PATTERN ((uint32_t)0x80FF1F02U) |
| #define | SDMMC_SDR25_SWITCH_PATTERN ((uint32_t)0x80FFFF01U) |
| #define | SDMMC_SDR12_SWITCH_PATTERN ((uint32_t)0x80FFFF00U) |
| #define | SDMMC_MAX_VOLT_TRIAL ((uint32_t)0x0000FFFFU) |
| #define | SDMMC_MAX_TRIAL ((uint32_t)0x0000FFFFU) |
| #define | SDMMC_ALLZERO ((uint32_t)0x00000000U) |
| #define | SDMMC_WIDE_BUS_SUPPORT ((uint32_t)0x00040000U) |
| #define | SDMMC_SINGLE_BUS_SUPPORT ((uint32_t)0x00010000U) |
| #define | SDMMC_CARD_LOCKED ((uint32_t)0x02000000U) |
| #define | SDMMC_DATATIMEOUT ((uint32_t)0xFFFFFFFFU) |
| #define | SDMMC_0TO7BITS ((uint32_t)0x000000FFU) |
| #define | SDMMC_8TO15BITS ((uint32_t)0x0000FF00U) |
| #define | SDMMC_16TO23BITS ((uint32_t)0x00FF0000U) |
| #define | SDMMC_24TO31BITS ((uint32_t)0xFF000000U) |
| #define | SDMMC_MAX_DATA_LENGTH ((uint32_t)0x01FFFFFFU) |
| #define | SDMMC_HALFFIFO ((uint32_t)0x00000008U) |
| #define | SDMMC_HALFFIFOBYTES ((uint32_t)0x00000020U) |
| #define | SDMMC_CCCC_ERASE ((uint32_t)0x00000020U) |
| Command Class supported. | |
| #define | SDMMC_CMDTIMEOUT ((uint32_t)5000U) /* Command send and response timeout */ |
| #define | SDMMC_MAXERASETIMEOUT ((uint32_t)63000U) /* Max erase Timeout 63 s */ |
| #define | SDMMC_STOPTRANSFERTIMEOUT ((uint32_t)100000000U) /* Timeout for STOP TRANSMISSION command */ |
| #define SDMMC_CMD_ALL_SEND_CID ((uint8_t)2U) |
Asks any card connected to the host to send the CID numbers on the CMD line.
| #define SDMMC_CMD_APP_CMD ((uint8_t)55U) |
Indicates to the card that the next command is an application specific command rather than a standard command.
| #define SDMMC_CMD_APP_SD_SET_BUSWIDTH ((uint8_t)6U) |
(ACMD6) Defines the data bus width to be used for data transfer. The allowed data bus widths are given in SCR register.
| #define SDMMC_CMD_CLR_WRITE_PROT ((uint8_t)29U) |
Clears the write protection bit of the addressed group.
| #define SDMMC_CMD_ERASE ((uint8_t)38U) |
Reserved for SD security applications.
| #define SDMMC_CMD_ERASE_GRP_END ((uint8_t)36U) |
Sets the address of the last write block of the continuous range to be erased. Reserved for each command system set by switch function command (CMD6).
| #define SDMMC_CMD_ERASE_GRP_START ((uint8_t)35U) |
Sets the address of the first write block to be erased. Reserved for each command system set by switch function command (CMD6).
| #define SDMMC_CMD_FAST_IO ((uint8_t)39U) |
SD card doesn't support it (Reserved).
| #define SDMMC_CMD_GEN_CMD ((uint8_t)56U) |
Used either to transfer a data block to the card or to get a data block from the card for general purpose/application specific commands.
| #define SDMMC_CMD_GO_IDLE_STATE ((uint8_t)0U) |
Resets the SD memory card.
| #define SDMMC_CMD_GO_INACTIVE_STATE ((uint8_t)15U) |
Sends an addressed card into the inactive state.
| #define SDMMC_CMD_GO_IRQ_STATE ((uint8_t)40U) |
| #define SDMMC_CMD_HS_BUSTEST_READ ((uint8_t)14U) |
Reserved
| #define SDMMC_CMD_HS_BUSTEST_WRITE ((uint8_t)19U) |
64 bytes tuning pattern is sent for SDR50 and SDR104.
| #define SDMMC_CMD_HS_SEND_EXT_CSD ((uint8_t)8U) |
Sends SD Memory Card interface condition, which includes host supply voltage information and asks the card whether card supports voltage.
| #define SDMMC_CMD_HS_SWITCH ((uint8_t)6U) |
Checks switchable function (mode 0) and switch card function (mode 1).
| #define SDMMC_CMD_LOCK_UNLOCK ((uint8_t)42U) |
Sets/resets the password or lock/unlock the card. The size of the data block is set by the SET_BLOCK_LEN command.
| #define SDMMC_CMD_MMC_SLEEP_AWAKE ((uint8_t)5U) |
Toggle the device between Sleep state and Standby state.
| #define SDMMC_CMD_NO_CMD ((uint8_t)64U) |
No command
| #define SDMMC_CMD_PROG_CID ((uint8_t)26U) |
Reserved for manufacturers.
| #define SDMMC_CMD_PROG_CSD ((uint8_t)27U) |
Programming of the programmable bits of the CSD.
| #define SDMMC_CMD_READ_MULT_BLOCK ((uint8_t)18U) |
Continuously transfers data blocks from card to host until interrupted by STOP_TRANSMISSION command.
| #define SDMMC_CMD_READ_SINGLE_BLOCK ((uint8_t)17U) |
Reads single block of size selected by SET_BLOCKLEN in case of SDSC, and a block of fixed 512 bytes in case of SDHC and SDXC.
| #define SDMMC_CMD_SD_APP_OP_COND ((uint8_t)41U) |
(ACMD41) Sends host capacity support information (HCS) and asks the accessed card to send its operating condition register (OCR) content in the response on the CMD line.
| #define SDMMC_CMD_SD_APP_SEND_NUM_WRITE_BLOCKS ((uint8_t)22U) |
(ACMD22) Sends the number of the written (without errors) write blocks. Responds with 32bit+CRC data block.
| #define SDMMC_CMD_SD_APP_SEND_SCR ((uint8_t)51U) |
Reads the SD Configuration Register (SCR).
| #define SDMMC_CMD_SD_APP_SET_CLR_CARD_DETECT ((uint8_t)42U) |
(ACMD42) Connect/Disconnect the 50 KOhm pull-up resistor on CD/DAT3 (pin 1) of the card
| #define SDMMC_CMD_SD_APP_STATUS ((uint8_t)13U) |
(ACMD13) Sends the SD status.
| #define SDMMC_CMD_SD_ERASE_GRP_END ((uint8_t)33U) |
| #define SDMMC_CMD_SD_ERASE_GRP_START ((uint8_t)32U) |
Sets the address of the first write block to be erased. (For SD card only).
| #define SDMMC_CMD_SDMMC_RW_DIRECT ((uint8_t)52U) |
For SD I/O card only, reserved for security specification.
| #define SDMMC_CMD_SDMMC_RW_EXTENDED ((uint8_t)53U) |
| #define SDMMC_CMD_SDMMC_SEN_OP_COND ((uint8_t)5U) |
| #define SDMMC_CMD_SEL_DESEL_CARD ((uint8_t)7U) |
Selects the card by its own relative address and gets deselected by any other address
| #define SDMMC_CMD_SEND_CID ((uint8_t)10U) |
Addressed card sends its card identification (CID) on the CMD line.
| #define SDMMC_CMD_SEND_CSD ((uint8_t)9U) |
Addressed card sends its card specific data (CSD) on the CMD line.
| #define SDMMC_CMD_SEND_OP_COND ((uint8_t)1U) |
Sends host capacity support information and activates the card's initialization process.
| #define SDMMC_CMD_SEND_STATUS ((uint8_t)13U) |
Addressed card sends its status register.
| #define SDMMC_CMD_SEND_WRITE_PROT ((uint8_t)30U) |
Asks the card to send the status of the write protection bits.
| #define SDMMC_CMD_SET_BLOCK_COUNT ((uint8_t)23U) |
Specify block count for CMD18 and CMD25.
| #define SDMMC_CMD_SET_BLOCKLEN ((uint8_t)16U) |
Sets the block length (in bytes for SDSC) for all following block commands (read, write, lock). Default block length is fixed to 512 Bytes. Not effective
for SDHS and SDXC.
| #define SDMMC_CMD_SET_DSR ((uint8_t)4U) |
Programs the DSR of all cards.
| #define SDMMC_CMD_SET_REL_ADDR ((uint8_t)3U) |
Asks the card to publish a new relative address (RCA).
| #define SDMMC_CMD_SET_WRITE_PROT ((uint8_t)28U) |
Sets the write protection bit of the addressed group.
| #define SDMMC_CMD_STOP_TRANSMISSION ((uint8_t)12U) |
Forces the card to stop transmission.
| #define SDMMC_CMD_VOLTAGE_SWITCH ((uint8_t)11U) |
SD card Voltage switch to 1.8V mode.
| #define SDMMC_CMD_WRITE_DAT_UNTIL_STOP ((uint8_t)20U) |
Speed class control command.
| #define SDMMC_CMD_WRITE_MULT_BLOCK ((uint8_t)25U) |
Continuously writes blocks of data until a STOP_TRANSMISSION follows.
| #define SDMMC_CMD_WRITE_SINGLE_BLOCK ((uint8_t)24U) |
Writes single block of size selected by SET_BLOCKLEN in case of SDSC, and a block of fixed 512 bytes in case of SDHC and SDXC.
| #define SDMMC_ERROR_ADDR_MISALIGNED ((uint32_t)0x00000040U) |
Misaligned address
| #define SDMMC_ERROR_ADDR_OUT_OF_RANGE ((uint32_t)0x02000000U) |
Error when addressed block is out of range
| #define SDMMC_ERROR_AKE_SEQ_ERR ((uint32_t)0x00800000U) |
Error in sequence of authentication
| #define SDMMC_ERROR_BAD_ERASE_PARAM ((uint32_t)0x00000200U) |
An invalid selection for erase groups
| #define SDMMC_ERROR_BLOCK_LEN_ERR ((uint32_t)0x00000080U) |
Transferred block length is not allowed for the card or the number of transferred bytes does not match the block length
| #define SDMMC_ERROR_BUSY ((uint32_t)0x20000000U) |
Error when transfer process is busy
| #define SDMMC_ERROR_CARD_ECC_DISABLED ((uint32_t)0x00200000U) |
Command has been executed without using internal ECC
| #define SDMMC_ERROR_CARD_ECC_FAILED ((uint32_t)0x00004000U) |
Card internal ECC was applied but failed to correct the data
| #define SDMMC_ERROR_CC_ERR ((uint32_t)0x00008000U) |
Internal card controller error
| #define SDMMC_ERROR_CID_CSD_OVERWRITE ((uint32_t)0x00080000U) |
CID/CSD overwrite error
| #define SDMMC_ERROR_CMD_CRC_FAIL ((uint32_t)0x00000001U) |
Command response received (but CRC check failed)
| #define SDMMC_ERROR_CMD_RSP_TIMEOUT ((uint32_t)0x00000004U) |
Command response timeout
| #define SDMMC_ERROR_COM_CRC_FAILED ((uint32_t)0x00001000U) |
CRC check of the previous command failed
| #define SDMMC_ERROR_DATA_CRC_FAIL ((uint32_t)0x00000002U) |
Data block sent/received (CRC check failed)
| #define SDMMC_ERROR_DATA_TIMEOUT ((uint32_t)0x00000008U) |
Data timeout
| #define SDMMC_ERROR_DMA ((uint32_t)0x40000000U) |
Error while DMA transfer
| #define SDMMC_ERROR_ERASE_RESET ((uint32_t)0x00400000U) |
Erase sequence was cleared before executing because an out of erase sequence command was received
| #define SDMMC_ERROR_ERASE_SEQ_ERR ((uint32_t)0x00000100U) |
An error in the sequence of erase command occurs
| #define SDMMC_ERROR_GENERAL_UNKNOWN_ERR ((uint32_t)0x00010000U) |
General or unknown error
| #define SDMMC_ERROR_ILLEGAL_CMD ((uint32_t)0x00002000U) |
Command is not legal for the card state
| #define SDMMC_ERROR_INVALID_PARAMETER ((uint32_t)0x08000000U) |
the used parameter is not valid
| #define SDMMC_ERROR_INVALID_VOLTRANGE ((uint32_t)0x01000000U) |
Error in case of invalid voltage range
| #define SDMMC_ERROR_LOCK_UNLOCK_FAILED ((uint32_t)0x00000800U) |
Sequence or password error has been detected in unlock command or if there was an attempt to access a locked card
| #define SDMMC_ERROR_NONE ((uint32_t)0x00000000U) |
No error
| #define SDMMC_ERROR_REQUEST_NOT_APPLICABLE ((uint32_t)0x04000000U) |
Error when command request is not applicable
| #define SDMMC_ERROR_RX_OVERRUN ((uint32_t)0x00000020U) |
Receive FIFO overrun
| #define SDMMC_ERROR_STREAM_READ_UNDERRUN ((uint32_t)0x00020000U) |
The card could not sustain data reading in stream rmode
| #define SDMMC_ERROR_STREAM_WRITE_OVERRUN ((uint32_t)0x00040000U) |
The card could not sustain data programming in stream mode
| #define SDMMC_ERROR_TIMEOUT ((uint32_t)0x80000000U) |
Timeout error
| #define SDMMC_ERROR_TX_UNDERRUN ((uint32_t)0x00000010U) |
Transmit FIFO underrun
| #define SDMMC_ERROR_UNSUPPORTED_FEATURE ((uint32_t)0x10000000U) |
Error when feature is not insupported
| #define SDMMC_ERROR_WP_ERASE_SKIP ((uint32_t)0x00100000U) |
Only partial address space was erased
| #define SDMMC_ERROR_WRITE_PROT_VIOLATION ((uint32_t)0x00000400U) |
Attempt to program a write protect block
