RTEMS 6.2
Data Structures | Macros | Typedefs | Enumerations | Functions
stm32h7xx_hal_mmc.h File Reference
Header file of MMC HAL module. More...
#include "stm32h7xx_ll_sdmmc.h"
#include "stm32h7xx_hal_mmc_ex.h"
struct  HAL_MMC_CardInfoTypeDef
 MMC Card Information Structure definition. More...
struct  MMC_HandleTypeDef
 MMC handle Structure definition. More...
struct  HAL_MMC_CardCSDTypeDef
struct  HAL_MMC_CardCIDTypeDef
#define HAL_MMC_CARD_IDLE   0x00000000U
#define HAL_MMC_CARD_READY   0x00000001U
#define HAL_MMC_CARD_IDENTIFICATION   0x00000002U
#define HAL_MMC_CARD_STANDBY   0x00000003U
#define HAL_MMC_CARD_TRANSFER   0x00000004U
#define HAL_MMC_CARD_SENDING   0x00000005U
#define HAL_MMC_CARD_RECEIVING   0x00000006U
#define HAL_MMC_CARD_PROGRAMMING   0x00000007U
#define HAL_MMC_CARD_DISCONNECTED   0x00000008U
#define HAL_MMC_CARD_BUSTEST   0x00000009U
#define HAL_MMC_CARD_SLEEP   0x0000000AU
#define HAL_MMC_CARD_ERROR   0x000000FFU
#define MMC_InitTypeDef   SDMMC_InitTypeDef
#define MMC_TypeDef   SDMMC_TypeDef
#define MMC_BLOCKSIZE   ((uint32_t)512U)
#define HAL_MMC_ERROR_NONE   SDMMC_ERROR_NONE
#define HAL_MMC_ERROR_CMD_CRC_FAIL   SDMMC_ERROR_CMD_CRC_FAIL
#define HAL_MMC_ERROR_DATA_CRC_FAIL   SDMMC_ERROR_DATA_CRC_FAIL
#define HAL_MMC_ERROR_CMD_RSP_TIMEOUT   SDMMC_ERROR_CMD_RSP_TIMEOUT
#define HAL_MMC_ERROR_DATA_TIMEOUT   SDMMC_ERROR_DATA_TIMEOUT
#define HAL_MMC_ERROR_TX_UNDERRUN   SDMMC_ERROR_TX_UNDERRUN
#define HAL_MMC_ERROR_RX_OVERRUN   SDMMC_ERROR_RX_OVERRUN
#define HAL_MMC_ERROR_ADDR_MISALIGNED   SDMMC_ERROR_ADDR_MISALIGNED
#define HAL_MMC_ERROR_BLOCK_LEN_ERR   SDMMC_ERROR_BLOCK_LEN_ERR
#define HAL_MMC_ERROR_ERASE_SEQ_ERR   SDMMC_ERROR_ERASE_SEQ_ERR
#define HAL_MMC_ERROR_BAD_ERASE_PARAM   SDMMC_ERROR_BAD_ERASE_PARAM
#define HAL_MMC_ERROR_WRITE_PROT_VIOLATION   SDMMC_ERROR_WRITE_PROT_VIOLATION
#define HAL_MMC_ERROR_LOCK_UNLOCK_FAILED   SDMMC_ERROR_LOCK_UNLOCK_FAILED
#define HAL_MMC_ERROR_COM_CRC_FAILED   SDMMC_ERROR_COM_CRC_FAILED
#define HAL_MMC_ERROR_ILLEGAL_CMD   SDMMC_ERROR_ILLEGAL_CMD
#define HAL_MMC_ERROR_CARD_ECC_FAILED   SDMMC_ERROR_CARD_ECC_FAILED
#define HAL_MMC_ERROR_CC_ERR   SDMMC_ERROR_CC_ERR
#define HAL_MMC_ERROR_GENERAL_UNKNOWN_ERR   SDMMC_ERROR_GENERAL_UNKNOWN_ERR
#define HAL_MMC_ERROR_STREAM_READ_UNDERRUN   SDMMC_ERROR_STREAM_READ_UNDERRUN
#define HAL_MMC_ERROR_STREAM_WRITE_OVERRUN   SDMMC_ERROR_STREAM_WRITE_OVERRUN
#define HAL_MMC_ERROR_CID_CSD_OVERWRITE   SDMMC_ERROR_CID_CSD_OVERWRITE
#define HAL_MMC_ERROR_WP_ERASE_SKIP   SDMMC_ERROR_WP_ERASE_SKIP
#define HAL_MMC_ERROR_CARD_ECC_DISABLED   SDMMC_ERROR_CARD_ECC_DISABLED
#define HAL_MMC_ERROR_ERASE_RESET   SDMMC_ERROR_ERASE_RESET
#define HAL_MMC_ERROR_AKE_SEQ_ERR   SDMMC_ERROR_AKE_SEQ_ERR
#define HAL_MMC_ERROR_INVALID_VOLTRANGE   SDMMC_ERROR_INVALID_VOLTRANGE
#define HAL_MMC_ERROR_ADDR_OUT_OF_RANGE   SDMMC_ERROR_ADDR_OUT_OF_RANGE
#define HAL_MMC_ERROR_REQUEST_NOT_APPLICABLE   SDMMC_ERROR_REQUEST_NOT_APPLICABLE
#define HAL_MMC_ERROR_PARAM   SDMMC_ERROR_INVALID_PARAMETER
#define HAL_MMC_ERROR_UNSUPPORTED_FEATURE   SDMMC_ERROR_UNSUPPORTED_FEATURE
#define HAL_MMC_ERROR_BUSY   SDMMC_ERROR_BUSY
#define HAL_MMC_ERROR_DMA   SDMMC_ERROR_DMA
#define HAL_MMC_ERROR_TIMEOUT   SDMMC_ERROR_TIMEOUT
#define MMC_CONTEXT_NONE   ((uint32_t)0x00000000U)
#define MMC_CONTEXT_READ_SINGLE_BLOCK   ((uint32_t)0x00000001U)
#define MMC_CONTEXT_READ_MULTIPLE_BLOCK   ((uint32_t)0x00000002U)
#define MMC_CONTEXT_WRITE_SINGLE_BLOCK   ((uint32_t)0x00000010U)
#define MMC_CONTEXT_WRITE_MULTIPLE_BLOCK   ((uint32_t)0x00000020U)
#define MMC_CONTEXT_IT   ((uint32_t)0x00000008U)
#define MMC_CONTEXT_DMA   ((uint32_t)0x00000080U)
#define MMC_HIGH_VOLTAGE_RANGE   0x80FF8000U
#define MMC_DUAL_VOLTAGE_RANGE   0x80FF8080U
#define MMC_LOW_VOLTAGE_RANGE   0x80000080U
#define EMMC_HIGH_VOLTAGE_RANGE   0xC0FF8000U
#define EMMC_DUAL_VOLTAGE_RANGE   0xC0FF8080U
#define EMMC_LOW_VOLTAGE_RANGE   0xC0000080U
#define MMC_INVALID_VOLTAGE_RANGE   0x0001FF01U
#define MMC_LOW_CAPACITY_CARD   ((uint32_t)0x00000000U)
#define MMC_HIGH_CAPACITY_CARD   ((uint32_t)0x00000001U)
#define HAL_MMC_ERASE   0x00000000U
#define HAL_MMC_TRIM   0x00000001U
#define HAL_MMC_DISCARD   0x00000003U
#define HAL_MMC_SECURE_ERASE   0x80000000U
#define HAL_MMC_SECURE_TRIM_STEP1   0x80000001U
#define HAL_MMC_SECURE_TRIM_STEP2   0x80008000U
#define IS_MMC_ERASE_TYPE(TYPE)
#define HAL_MMC_SRT_ERASE   0x00000001U
#define HAL_MMC_SRT_WRITE_CHAR_ERASE   0x00000002U
#define HAL_MMC_SRT_WRITE_CHAR_COMPL_RANDOM   0x00000004U
#define HAL_MMC_SRT_VENDOR_DEFINED   0x00000008U
#define IS_MMC_SRT_TYPE(TYPE)
#define __HAL_MMC_RESET_HANDLE_STATE(__HANDLE__)   ((__HANDLE__)->State = HAL_MMC_STATE_RESET)
 Reset MMC handle state.
#define __HAL_MMC_ENABLE_IT(__HANDLE__, __INTERRUPT__)   __SDMMC_ENABLE_IT((__HANDLE__)->Instance, (__INTERRUPT__))
 Enable the MMC device interrupt.
#define __HAL_MMC_DISABLE_IT(__HANDLE__, __INTERRUPT__)   __SDMMC_DISABLE_IT((__HANDLE__)->Instance, (__INTERRUPT__))
 Disable the MMC device interrupt.
#define __HAL_MMC_GET_FLAG(__HANDLE__, __FLAG__)   __SDMMC_GET_FLAG((__HANDLE__)->Instance, (__FLAG__))
 Check whether the specified MMC flag is set or not.
#define __HAL_MMC_CLEAR_FLAG(__HANDLE__, __FLAG__)   __SDMMC_CLEAR_FLAG((__HANDLE__)->Instance, (__FLAG__))
 Clear the MMC's pending flags.
#define __HAL_MMC_GET_IT(__HANDLE__, __INTERRUPT__)   __SDMMC_GET_IT((__HANDLE__)->Instance, (__INTERRUPT__))
 Check whether the specified MMC interrupt has occurred or not.
#define __HAL_MMC_CLEAR_IT(__HANDLE__, __INTERRUPT__)   __SDMMC_CLEAR_IT((__HANDLE__)->Instance, (__INTERRUPT__))
 Clear the MMC's interrupt pending bits.
#define MMC_EXT_CSD_DATA_SEC_SIZE_INDEX   61
#define MMC_EXT_CSD_DATA_SEC_SIZE_POS   8
typedef uint32_t HAL_MMC_CardStateTypeDef
enum  HAL_MMC_StateTypeDef {
  HAL_MMC_STATE_RESET = ((uint32_t)0x00000000U) , HAL_MMC_STATE_READY = ((uint32_t)0x00000001U) , HAL_MMC_STATE_TIMEOUT = ((uint32_t)0x00000002U) , HAL_MMC_STATE_BUSY = ((uint32_t)0x00000003U) ,
  HAL_MMC_STATE_PROGRAMMING = ((uint32_t)0x00000004U) , HAL_MMC_STATE_RECEIVING = ((uint32_t)0x00000005U) , HAL_MMC_STATE_TRANSFER = ((uint32_t)0x00000006U) , HAL_MMC_STATE_ERROR = ((uint32_t)0x0000000FU)
HAL_StatusTypeDef HAL_MMC_Init (MMC_HandleTypeDef *hmmc)
HAL_StatusTypeDef HAL_MMC_InitCard (MMC_HandleTypeDef *hmmc)
HAL_StatusTypeDef HAL_MMC_DeInit (MMC_HandleTypeDef *hmmc)
void HAL_MMC_MspInit (MMC_HandleTypeDef *hmmc)
void HAL_MMC_MspDeInit (MMC_HandleTypeDef *hmmc)
HAL_StatusTypeDef HAL_MMC_ReadBlocks (MMC_HandleTypeDef *hmmc, uint8_t *pData, uint32_t BlockAdd, uint32_t NumberOfBlocks, uint32_t Timeout)
HAL_StatusTypeDef HAL_MMC_WriteBlocks (MMC_HandleTypeDef *hmmc, const uint8_t *pData, uint32_t BlockAdd, uint32_t NumberOfBlocks, uint32_t Timeout)
HAL_StatusTypeDef HAL_MMC_Erase (MMC_HandleTypeDef *hmmc, uint32_t BlockStartAdd, uint32_t BlockEndAdd)
HAL_StatusTypeDef HAL_MMC_ReadBlocks_IT (MMC_HandleTypeDef *hmmc, uint8_t *pData, uint32_t BlockAdd, uint32_t NumberOfBlocks)
HAL_StatusTypeDef HAL_MMC_WriteBlocks_IT (MMC_HandleTypeDef *hmmc, const uint8_t *pData, uint32_t BlockAdd, uint32_t NumberOfBlocks)
HAL_StatusTypeDef HAL_MMC_ReadBlocks_DMA (MMC_HandleTypeDef *hmmc, uint8_t *pData, uint32_t BlockAdd, uint32_t NumberOfBlocks)
HAL_StatusTypeDef HAL_MMC_WriteBlocks_DMA (MMC_HandleTypeDef *hmmc, const uint8_t *pData, uint32_t BlockAdd, uint32_t NumberOfBlocks)
void HAL_MMC_IRQHandler (MMC_HandleTypeDef *hmmc)
void HAL_MMC_TxCpltCallback (MMC_HandleTypeDef *hmmc)
void HAL_MMC_RxCpltCallback (MMC_HandleTypeDef *hmmc)
void HAL_MMC_ErrorCallback (MMC_HandleTypeDef *hmmc)
void HAL_MMC_AbortCallback (MMC_HandleTypeDef *hmmc)
HAL_StatusTypeDef HAL_MMC_ConfigWideBusOperation (MMC_HandleTypeDef *hmmc, uint32_t WideMode)
HAL_StatusTypeDef HAL_MMC_ConfigSpeedBusOperation (MMC_HandleTypeDef *hmmc, uint32_t SpeedMode)
HAL_MMC_CardStateTypeDef HAL_MMC_GetCardState (MMC_HandleTypeDef *hmmc)
HAL_StatusTypeDef HAL_MMC_GetCardCID (MMC_HandleTypeDef *hmmc, HAL_MMC_CardCIDTypeDef *pCID)
HAL_StatusTypeDef HAL_MMC_GetCardCSD (MMC_HandleTypeDef *hmmc, HAL_MMC_CardCSDTypeDef *pCSD)
HAL_StatusTypeDef HAL_MMC_GetCardInfo (MMC_HandleTypeDef *hmmc, HAL_MMC_CardInfoTypeDef *pCardInfo)
HAL_StatusTypeDef HAL_MMC_GetCardExtCSD (MMC_HandleTypeDef *hmmc, uint32_t *pExtCSD, uint32_t Timeout)
HAL_MMC_StateTypeDef HAL_MMC_GetState (MMC_HandleTypeDef *hmmc)
uint32_t HAL_MMC_GetError (MMC_HandleTypeDef *hmmc)
HAL_StatusTypeDef HAL_MMC_Abort (MMC_HandleTypeDef *hmmc)
HAL_StatusTypeDef HAL_MMC_Abort_IT (MMC_HandleTypeDef *hmmc)
HAL_StatusTypeDef HAL_MMC_EraseSequence (MMC_HandleTypeDef *hmmc, uint32_t EraseType, uint32_t BlockStartAdd, uint32_t BlockEndAdd)
HAL_StatusTypeDef HAL_MMC_Sanitize (MMC_HandleTypeDef *hmmc)
HAL_StatusTypeDef HAL_MMC_ConfigSecRemovalType (MMC_HandleTypeDef *hmmc, uint32_t SRTMode)
HAL_StatusTypeDef HAL_MMC_GetSupportedSecRemovalType (MMC_HandleTypeDef *hmmc, uint32_t *SupportedSRT)
HAL_StatusTypeDef HAL_MMC_SleepDevice (MMC_HandleTypeDef *hmmc)
HAL_StatusTypeDef HAL_MMC_AwakeDevice (MMC_HandleTypeDef *hmmc)
Author
MCD Application Team
Attention
