RTEMS 6.2
Data Structures | Macros | Enumerations | Functions
stm32h7xx_hal_gpio.h File Reference
Header file of GPIO HAL module. More...
#include "stm32h7xx_hal_def.h"
#include "stm32h7xx_hal_gpio_ex.h"
struct  GPIO_InitTypeDef
 GPIO Init structure definition. More...
#define GPIO_PIN_0   ((uint16_t)0x0001) /* Pin 0 selected */
#define GPIO_PIN_1   ((uint16_t)0x0002) /* Pin 1 selected */
#define GPIO_PIN_2   ((uint16_t)0x0004) /* Pin 2 selected */
#define GPIO_PIN_3   ((uint16_t)0x0008) /* Pin 3 selected */
#define GPIO_PIN_4   ((uint16_t)0x0010) /* Pin 4 selected */
#define GPIO_PIN_5   ((uint16_t)0x0020) /* Pin 5 selected */
#define GPIO_PIN_6   ((uint16_t)0x0040) /* Pin 6 selected */
#define GPIO_PIN_7   ((uint16_t)0x0080) /* Pin 7 selected */
#define GPIO_PIN_8   ((uint16_t)0x0100) /* Pin 8 selected */
#define GPIO_PIN_9   ((uint16_t)0x0200) /* Pin 9 selected */
#define GPIO_PIN_10   ((uint16_t)0x0400) /* Pin 10 selected */
#define GPIO_PIN_11   ((uint16_t)0x0800) /* Pin 11 selected */
#define GPIO_PIN_12   ((uint16_t)0x1000) /* Pin 12 selected */
#define GPIO_PIN_13   ((uint16_t)0x2000) /* Pin 13 selected */
#define GPIO_PIN_14   ((uint16_t)0x4000) /* Pin 14 selected */
#define GPIO_PIN_15   ((uint16_t)0x8000) /* Pin 15 selected */
#define GPIO_PIN_All   ((uint16_t)0xFFFF) /* All pins selected */
#define GPIO_PIN_MASK   (0x0000FFFFU) /* PIN mask for assert test */
#define GPIO_MODE_INPUT   MODE_INPUT
#define GPIO_MODE_OUTPUT_PP   (MODE_OUTPUT | OUTPUT_PP)
#define GPIO_MODE_OUTPUT_OD   (MODE_OUTPUT | OUTPUT_OD)
#define GPIO_MODE_AF_PP   (MODE_AF | OUTPUT_PP)
#define GPIO_MODE_AF_OD   (MODE_AF | OUTPUT_OD)
#define GPIO_MODE_ANALOG   MODE_ANALOG
#define GPIO_MODE_IT_RISING   (MODE_INPUT | EXTI_IT | TRIGGER_RISING)
#define GPIO_MODE_IT_FALLING   (MODE_INPUT | EXTI_IT | TRIGGER_FALLING)
#define GPIO_MODE_IT_RISING_FALLING   (MODE_INPUT | EXTI_IT | TRIGGER_RISING | TRIGGER_FALLING)
#define GPIO_MODE_EVT_RISING   (MODE_INPUT | EXTI_EVT | TRIGGER_RISING)
#define GPIO_MODE_EVT_FALLING   (MODE_INPUT | EXTI_EVT | TRIGGER_FALLING)
#define GPIO_MODE_EVT_RISING_FALLING   (MODE_INPUT | EXTI_EVT | TRIGGER_RISING | TRIGGER_FALLING)
#define GPIO_SPEED_FREQ_LOW   (0x00000000U)
#define GPIO_SPEED_FREQ_MEDIUM   (0x00000001U)
#define GPIO_SPEED_FREQ_HIGH   (0x00000002U)
#define GPIO_SPEED_FREQ_VERY_HIGH   (0x00000003U)
#define GPIO_NOPULL   (0x00000000U)
#define GPIO_PULLUP   (0x00000001U)
#define GPIO_PULLDOWN   (0x00000002U)
#define __HAL_GPIO_EXTI_GET_FLAG(__EXTI_LINE__)   (EXTI->PR1 & (__EXTI_LINE__))
 Checks whether the specified EXTI line flag is set or not.
#define __HAL_GPIO_EXTI_CLEAR_FLAG(__EXTI_LINE__)   (EXTI->PR1 = (__EXTI_LINE__))
 Clears the EXTI's line pending flags.
#define __HAL_GPIO_EXTI_GET_IT(__EXTI_LINE__)   (EXTI->PR1 & (__EXTI_LINE__))
 Checks whether the specified EXTI line is asserted or not.
#define __HAL_GPIO_EXTI_CLEAR_IT(__EXTI_LINE__)   (EXTI->PR1 = (__EXTI_LINE__))
 Clears the EXTI's line pending bits.
#define __HAL_GPIO_EXTI_GENERATE_SWIT(__EXTI_LINE__)   (EXTI->SWIER1 |= (__EXTI_LINE__))
 Generates a Software interrupt on selected EXTI line.
#define GPIO_MODE_Pos   0u
#define GPIO_MODE   (0x3uL << GPIO_MODE_Pos)
#define MODE_INPUT   (0x0uL << GPIO_MODE_Pos)
#define MODE_OUTPUT   (0x1uL << GPIO_MODE_Pos)
#define MODE_AF   (0x2uL << GPIO_MODE_Pos)
#define MODE_ANALOG   (0x3uL << GPIO_MODE_Pos)
#define OUTPUT_TYPE_Pos   4u
#define OUTPUT_TYPE   (0x1uL << OUTPUT_TYPE_Pos)
#define OUTPUT_PP   (0x0uL << OUTPUT_TYPE_Pos)
#define OUTPUT_OD   (0x1uL << OUTPUT_TYPE_Pos)
#define EXTI_MODE_Pos   16u
#define EXTI_MODE   (0x3uL << EXTI_MODE_Pos)
#define EXTI_IT   (0x1uL << EXTI_MODE_Pos)
#define EXTI_EVT   (0x2uL << EXTI_MODE_Pos)
#define TRIGGER_MODE_Pos   20u
#define TRIGGER_MODE   (0x7uL << TRIGGER_MODE_Pos)
#define TRIGGER_RISING   (0x1uL << TRIGGER_MODE_Pos)
#define TRIGGER_FALLING   (0x2uL << TRIGGER_MODE_Pos)
#define TRIGGER_LEVEL   (0x4uL << TRIGGER_MODE_Pos)
#define IS_GPIO_PIN_ACTION(ACTION)   (((ACTION) == GPIO_PIN_RESET) || ((ACTION) == GPIO_PIN_SET))
#define IS_GPIO_PIN(__PIN__)
#define IS_GPIO_MODE(MODE)
#define IS_GPIO_SPEED(SPEED)
#define IS_GPIO_PULL(PULL)
enum  GPIO_PinState { GPIO_PIN_RESET = 0U , GPIO_PIN_SET }
 GPIO Bit SET and Bit RESET enumeration.
void HAL_GPIO_Init (GPIO_TypeDef *GPIOx, GPIO_InitTypeDef *GPIO_Init)
void HAL_GPIO_DeInit (GPIO_TypeDef *GPIOx, uint32_t GPIO_Pin)
GPIO_PinState HAL_GPIO_ReadPin (GPIO_TypeDef *GPIOx, uint16_t GPIO_Pin)
void HAL_GPIO_WritePin (GPIO_TypeDef *GPIOx, uint16_t GPIO_Pin, GPIO_PinState PinState)
void HAL_GPIO_TogglePin (GPIO_TypeDef *GPIOx, uint16_t GPIO_Pin)
HAL_StatusTypeDef HAL_GPIO_LockPin (GPIO_TypeDef *GPIOx, uint16_t GPIO_Pin)
void HAL_GPIO_EXTI_IRQHandler (uint16_t GPIO_Pin)
void HAL_GPIO_EXTI_Callback (uint16_t GPIO_Pin)
Author
MCD Application Team
Attention
