RTEMS 6.2
| #define | __HAL_GPIO_EXTI_GET_FLAG(__EXTI_LINE__) (EXTI->PR1 & (__EXTI_LINE__)) |
| Checks whether the specified EXTI line flag is set or not. | |
| #define | __HAL_GPIO_EXTI_CLEAR_FLAG(__EXTI_LINE__) (EXTI->PR1 = (__EXTI_LINE__)) |
| Clears the EXTI's line pending flags. | |
| #define | __HAL_GPIO_EXTI_GET_IT(__EXTI_LINE__) (EXTI->PR1 & (__EXTI_LINE__)) |
| Checks whether the specified EXTI line is asserted or not. | |
| #define | __HAL_GPIO_EXTI_CLEAR_IT(__EXTI_LINE__) (EXTI->PR1 = (__EXTI_LINE__)) |
| Clears the EXTI's line pending bits. | |
| #define | __HAL_GPIO_EXTI_GENERATE_SWIT(__EXTI_LINE__) (EXTI->SWIER1 |= (__EXTI_LINE__)) |
| Generates a Software interrupt on selected EXTI line. | |
| #define __HAL_GPIO_EXTI_CLEAR_FLAG | ( | __EXTI_LINE__ | ) | (EXTI->PR1 = (__EXTI_LINE__)) |
| __EXTI_LINE__ | specifies the EXTI lines flags to clear. This parameter can be any combination of GPIO_PIN_x where x can be (0..15) |
| None |
| #define __HAL_GPIO_EXTI_CLEAR_IT | ( | __EXTI_LINE__ | ) | (EXTI->PR1 = (__EXTI_LINE__)) |
| __EXTI_LINE__ | specifies the EXTI lines to clear. This parameter can be any combination of GPIO_PIN_x where x can be (0..15) |
| None |
| #define __HAL_GPIO_EXTI_GENERATE_SWIT | ( | __EXTI_LINE__ | ) | (EXTI->SWIER1 |= (__EXTI_LINE__)) |
| __EXTI_LINE__ | specifies the EXTI line to check. This parameter can be GPIO_PIN_x where x can be(0..15) |
| None |
| #define __HAL_GPIO_EXTI_GET_FLAG | ( | __EXTI_LINE__ | ) | (EXTI->PR1 & (__EXTI_LINE__)) |
| __EXTI_LINE__ | specifies the EXTI line flag to check. This parameter can be GPIO_PIN_x where x can be(0..15) |
| The | new state of EXTI_LINE (SET or RESET). |
| #define __HAL_GPIO_EXTI_GET_IT | ( | __EXTI_LINE__ | ) | (EXTI->PR1 & (__EXTI_LINE__)) |
