RTEMS 6.2
Data Structures | Macros | Enumerations
stm32h7a3xx.h File Reference
CMSIS STM32H7A3xx Device Peripheral Access Layer Header File. More...
#include "core_cm7.h"
#include "system_stm32h7xx.h"
#include <stdint.h>
struct  ADC_TypeDef
 Analog to Digital Converter. More...
struct  ADC_Common_TypeDef
struct  VREFBUF_TypeDef
 VREFBUF. More...
struct  FDCAN_GlobalTypeDef
 FD Controller Area Network. More...
struct  TTCAN_TypeDef
 TTFD Controller Area Network. More...
struct  FDCAN_ClockCalibrationUnit_TypeDef
struct  CEC_TypeDef
 Consumer Electronics Control. More...
struct  CRC_TypeDef
 CRC calculation unit. More...
struct  CRS_TypeDef
 Clock Recovery System. More...
struct  DAC_TypeDef
 Digital to Analog Converter. More...
struct  DFSDM_Filter_TypeDef
 DFSDM module registers. More...
struct  DFSDM_Channel_TypeDef
 DFSDM channel configuration registers. More...
struct  DBGMCU_TypeDef
 Debug MCU. More...
struct  DCMI_TypeDef
 DCMI. More...
struct  PSSI_TypeDef
 PSSI. More...
struct  DMA_Stream_TypeDef
 DMA Controller. More...
struct  DMA_TypeDef
struct  BDMA_Channel_TypeDef
struct  BDMA_TypeDef
struct  DMAMUX_Channel_TypeDef
struct  DMAMUX_ChannelStatus_TypeDef
struct  DMAMUX_RequestGen_TypeDef
struct  DMAMUX_RequestGenStatus_TypeDef
struct  MDMA_TypeDef
 MDMA Controller. More...
struct  MDMA_Channel_TypeDef
struct  DMA2D_TypeDef
 DMA2D Controller. More...
struct  EXTI_TypeDef
 External Interrupt/Event Controller. More...
struct  EXTI_Core_TypeDef
 This structure registers corresponds to EXTI_Typdef CPU1/CPU2 registers subset (IMRx, EMRx and PRx), allowing to define EXTI_D1/EXTI_D2 with rapid/common access to these IMRx, EMRx, PRx registers for CPU1 and CPU2. Note that EXTI_D1 and EXTI_D2 bases addresses are calculated to point to CPUx first register: IMR1 in case of EXTI_D1 that is addressing CPU1 (Cortex-M7) C2IMR1 in case of EXTI_D2 that is addressing CPU2 (Cortex-M4) Note: EXTI_D2 and corresponding C2IMRx, C2EMRx and C2PRx registers are available for Dual Core devices only. More...
struct  FLASH_TypeDef
 FLASH Registers. More...
struct  FMC_Bank1_TypeDef
 Flexible Memory Controller. More...
struct  FMC_Bank1E_TypeDef
 Flexible Memory Controller Bank1E. More...
struct  FMC_Bank2_TypeDef
 Flexible Memory Controller Bank2. More...
struct  FMC_Bank3_TypeDef
 Flexible Memory Controller Bank3. More...
struct  FMC_Bank5_6_TypeDef
 Flexible Memory Controller Bank5 and 6. More...
struct  GFXMMU_TypeDef
 GFXMMU registers. More...
struct  GPIO_TypeDef
 General Purpose I/O. More...
struct  OPAMP_TypeDef
 Operational Amplifier (OPAMP) More...
struct  SYSCFG_TypeDef
 System configuration controller. More...
struct  I2C_TypeDef
 Inter-integrated Circuit Interface. More...
struct  IWDG_TypeDef
 Independent WATCHDOG. More...
struct  JPEG_TypeDef
 JPEG Codec. More...
struct  LTDC_TypeDef
 LCD-TFT Display Controller. More...
struct  LTDC_Layer_TypeDef
 LCD-TFT Display layer x Controller. More...
struct  PWR_TypeDef
 Power Control. More...
struct  RCC_TypeDef
 Reset and Clock Control. More...
struct  RTC_TypeDef
 Real-Time Clock. More...
struct  TAMP_TypeDef
 Tamper and backup registers. More...
struct  SAI_TypeDef
 Serial Audio Interface. More...
struct  SAI_Block_TypeDef
struct  SPDIFRX_TypeDef
 SPDIF-RX Interface. More...
struct  SDMMC_TypeDef
 Secure digital input/output Interface. More...
struct  DLYB_TypeDef
 Delay Block DLYB. More...
struct  HSEM_TypeDef
 HW Semaphore HSEM. More...
struct  HSEM_Common_TypeDef
struct  SPI_TypeDef
 Serial Peripheral Interface. More...
struct  DTS_TypeDef
 DTS. More...
struct  TIM_TypeDef
 TIM. More...
struct  LPTIM_TypeDef
 LPTIMIMER. More...
struct  COMPOPT_TypeDef
 Comparator. More...
struct  COMP_TypeDef
struct  COMP_Common_TypeDef
struct  USART_TypeDef
 Universal Synchronous Asynchronous Receiver Transmitter. More...
struct  SWPMI_TypeDef
 Single Wire Protocol Master Interface SPWMI. More...
struct  WWDG_TypeDef
 Window WATCHDOG. More...
struct  RAMECC_MonitorTypeDef
 RAM_ECC_Specific_Registers. More...
struct  RAMECC_TypeDef
struct  RNG_TypeDef
 RNG. More...
struct  MDIOS_TypeDef
 MDIOS. More...
struct  USB_OTG_GlobalTypeDef
 USB_OTG_Core_Registers. More...
struct  USB_OTG_DeviceTypeDef
 USB_OTG_device_Registers. More...
struct  USB_OTG_INEndpointTypeDef
 USB_OTG_IN_Endpoint-Specific_Register. More...
struct  USB_OTG_OUTEndpointTypeDef
 USB_OTG_OUT_Endpoint-Specific_Registers. More...
struct  USB_OTG_HostTypeDef
 USB_OTG_Host_Mode_Register_Structures. More...
struct  USB_OTG_HostChannelTypeDef
 USB_OTG_Host_Channel_Specific_Registers. More...
struct  OCTOSPI_TypeDef
 OCTO Serial Peripheral Interface. More...
struct  OCTOSPIM_TypeDef
 OCTO Serial Peripheral Interface IO Manager. More...
struct  GPV_TypeDef
 Global Programmer View. More...
#define __CM7_REV   0x0110U
 Configuration of the Cortex-M7 Processor and Core Peripherals.
#define __MPU_PRESENT   1U
#define __NVIC_PRIO_BITS   4U
#define __Vendor_SysTickConfig   0U
#define __FPU_PRESENT   1U
#define __ICACHE_PRESENT   1U
#define __DCACHE_PRESENT   1U
#define CD_ITCMRAM_BASE   (0x00000000UL)
#define CD_DTCMRAM_BASE   (0x20000000UL)
#define CD_AXIFLASH_BASE   (0x08000000UL)
#define CD_AXISRAM1_BASE   (0x24000000UL)
#define CD_AXISRAM2_BASE   (0x24040000UL)
#define CD_AXISRAM3_BASE   (0x240A0000UL)
#define CD_AHBSRAM1_BASE   (0x30000000UL)
#define CD_AHBSRAM2_BASE   (0x30010000UL)
#define SRD_BKPSRAM_BASE   (0x38800000UL)
#define SRD_SRAM_BASE   (0x38000000UL)
#define OCTOSPI1_BASE   (0x90000000UL)
#define OCTOSPI2_BASE   (0x70000000UL)
#define FLASH_BANK1_BASE   (0x08000000UL)
#define FLASH_BANK2_BASE   (0x08100000UL)
#define FLASH_END   (0x081FFFFFUL)
#define FLASH_BASE   FLASH_BANK1_BASE
#define D1_AXISRAM_BASE   CD_AXISRAM1_BASE
#define FLASH_OTP_BASE   (0x08FFF000UL)
#define FLASH_OTP_END   (0x08FFF3FFUL)
#define UID_BASE   (0x08FFF800UL)
#define FLASHSIZE_BASE   (0x08FFF80CUL)
#define PACKAGE_BASE   (0x08FFF80EUL)
#define PERIPH_BASE   (0x40000000UL)
#define CD_APB1PERIPH_BASE   PERIPH_BASE
#define CD_APB2PERIPH_BASE   (PERIPH_BASE + 0x00010000UL)
#define CD_AHB1PERIPH_BASE   (PERIPH_BASE + 0x00020000UL)
#define CD_AHB2PERIPH_BASE   (PERIPH_BASE + 0x08020000UL)
#define CD_APB3PERIPH_BASE   (PERIPH_BASE + 0x10000000UL)
#define CD_AHB3PERIPH_BASE   (PERIPH_BASE + 0x12000000UL)
#define SRD_APB4PERIPH_BASE   (PERIPH_BASE + 0x18000000UL)
#define SRD_AHB4PERIPH_BASE   (PERIPH_BASE + 0x18020000UL)
#define APB1PERIPH_BASE   PERIPH_BASE
#define APB2PERIPH_BASE   (PERIPH_BASE + 0x00010000UL)
#define AHB1PERIPH_BASE   (PERIPH_BASE + 0x00020000UL)
#define AHB2PERIPH_BASE   (PERIPH_BASE + 0x08020000UL)
#define MDMA_BASE   (CD_AHB3PERIPH_BASE + 0x0000UL)
#define DMA2D_BASE   (CD_AHB3PERIPH_BASE + 0x1000UL)
#define FLASH_R_BASE   (CD_AHB3PERIPH_BASE + 0x2000UL)
#define JPGDEC_BASE   (CD_AHB3PERIPH_BASE + 0x3000UL)
#define FMC_R_BASE   (CD_AHB3PERIPH_BASE + 0x4000UL)
#define OCTOSPI1_R_BASE   (CD_AHB3PERIPH_BASE + 0x5000UL)
#define DLYB_OCTOSPI1_BASE   (CD_AHB3PERIPH_BASE + 0x6000UL)
#define SDMMC1_BASE   (CD_AHB3PERIPH_BASE + 0x7000UL)
#define DLYB_SDMMC1_BASE   (CD_AHB3PERIPH_BASE + 0x8000UL)
#define RAMECC_BASE   (CD_AHB3PERIPH_BASE + 0x9000UL)
#define OCTOSPI2_R_BASE   (CD_AHB3PERIPH_BASE + 0xA000UL)
#define DLYB_OCTOSPI2_BASE   (CD_AHB3PERIPH_BASE + 0xB000UL)
#define OCTOSPIM_BASE   (CD_AHB3PERIPH_BASE + 0xB400UL)
#define DMA1_BASE   (CD_AHB1PERIPH_BASE + 0x0000UL)
#define DMA2_BASE   (CD_AHB1PERIPH_BASE + 0x0400UL)
#define DMAMUX1_BASE   (CD_AHB1PERIPH_BASE + 0x0800UL)
#define ADC1_BASE   (CD_AHB1PERIPH_BASE + 0x2000UL)
#define ADC2_BASE   (CD_AHB1PERIPH_BASE + 0x2100UL)
#define ADC12_COMMON_BASE   (CD_AHB1PERIPH_BASE + 0x2300UL)
#define CRC_BASE   (CD_AHB1PERIPH_BASE + 0x3000UL)
#define USB1_OTG_HS_PERIPH_BASE   (0x40040000UL)
#define USB_OTG_GLOBAL_BASE   (0x000UL)
#define USB_OTG_DEVICE_BASE   (0x800UL)
#define USB_OTG_IN_ENDPOINT_BASE   (0x900UL)
#define USB_OTG_OUT_ENDPOINT_BASE   (0xB00UL)
#define USB_OTG_EP_REG_SIZE   (0x20UL)
#define USB_OTG_HOST_BASE   (0x400UL)
#define USB_OTG_HOST_PORT_BASE   (0x440UL)
#define USB_OTG_HOST_CHANNEL_BASE   (0x500UL)
#define USB_OTG_HOST_CHANNEL_SIZE   (0x20UL)
#define USB_OTG_PCGCCTL_BASE   (0xE00UL)
#define USB_OTG_FIFO_BASE   (0x1000UL)
#define USB_OTG_FIFO_SIZE   (0x1000UL)
#define DCMI_BASE   (CD_AHB2PERIPH_BASE + 0x0000UL)
#define PSSI_BASE   (CD_AHB2PERIPH_BASE + 0x0400UL)
#define HSEM_BASE   (CD_AHB2PERIPH_BASE + 0x0800UL)
#define RNG_BASE   (CD_AHB2PERIPH_BASE + 0x1800UL)
#define SDMMC2_BASE   (CD_AHB2PERIPH_BASE + 0x2400UL)
#define DLYB_SDMMC2_BASE   (CD_AHB2PERIPH_BASE + 0x2800UL)
#define BDMA1_BASE   (CD_AHB2PERIPH_BASE + 0x2C00UL)
#define GPIOA_BASE   (SRD_AHB4PERIPH_BASE + 0x0000UL)
#define GPIOB_BASE   (SRD_AHB4PERIPH_BASE + 0x0400UL)
#define GPIOC_BASE   (SRD_AHB4PERIPH_BASE + 0x0800UL)
#define GPIOD_BASE   (SRD_AHB4PERIPH_BASE + 0x0C00UL)
#define GPIOE_BASE   (SRD_AHB4PERIPH_BASE + 0x1000UL)
#define GPIOF_BASE   (SRD_AHB4PERIPH_BASE + 0x1400UL)
#define GPIOG_BASE   (SRD_AHB4PERIPH_BASE + 0x1800UL)
#define GPIOH_BASE   (SRD_AHB4PERIPH_BASE + 0x1C00UL)
#define GPIOI_BASE   (SRD_AHB4PERIPH_BASE + 0x2000UL)
#define GPIOJ_BASE   (SRD_AHB4PERIPH_BASE + 0x2400UL)
#define GPIOK_BASE   (SRD_AHB4PERIPH_BASE + 0x2800UL)
#define RCC_BASE   (SRD_AHB4PERIPH_BASE + 0x4400UL)
#define PWR_BASE   (SRD_AHB4PERIPH_BASE + 0x4800UL)
#define BDMA2_BASE   (SRD_AHB4PERIPH_BASE + 0x5400UL)
#define DMAMUX2_BASE   (SRD_AHB4PERIPH_BASE + 0x5800UL)
#define LTDC_BASE   (CD_APB3PERIPH_BASE + 0x1000UL)
#define LTDC_Layer1_BASE   (LTDC_BASE + 0x84UL)
#define LTDC_Layer2_BASE   (LTDC_BASE + 0x104UL)
#define WWDG1_BASE   (CD_APB3PERIPH_BASE + 0x3000UL)
#define TIM2_BASE   (CD_APB1PERIPH_BASE + 0x0000UL)
#define TIM3_BASE   (CD_APB1PERIPH_BASE + 0x0400UL)
#define TIM4_BASE   (CD_APB1PERIPH_BASE + 0x0800UL)
#define TIM5_BASE   (CD_APB1PERIPH_BASE + 0x0C00UL)
#define TIM6_BASE   (CD_APB1PERIPH_BASE + 0x1000UL)
#define TIM7_BASE   (CD_APB1PERIPH_BASE + 0x1400UL)
#define TIM12_BASE   (CD_APB1PERIPH_BASE + 0x1800UL)
#define TIM13_BASE   (CD_APB1PERIPH_BASE + 0x1C00UL)
#define TIM14_BASE   (CD_APB1PERIPH_BASE + 0x2000UL)
#define LPTIM1_BASE   (CD_APB1PERIPH_BASE + 0x2400UL)
#define SPI2_BASE   (CD_APB1PERIPH_BASE + 0x3800UL)
#define SPI3_BASE   (CD_APB1PERIPH_BASE + 0x3C00UL)
#define SPDIFRX_BASE   (CD_APB1PERIPH_BASE + 0x4000UL)
#define USART2_BASE   (CD_APB1PERIPH_BASE + 0x4400UL)
#define USART3_BASE   (CD_APB1PERIPH_BASE + 0x4800UL)
#define UART4_BASE   (CD_APB1PERIPH_BASE + 0x4C00UL)
#define UART5_BASE   (CD_APB1PERIPH_BASE + 0x5000UL)
#define I2C1_BASE   (CD_APB1PERIPH_BASE + 0x5400UL)
#define I2C2_BASE   (CD_APB1PERIPH_BASE + 0x5800UL)
#define I2C3_BASE   (CD_APB1PERIPH_BASE + 0x5C00UL)
#define CEC_BASE   (CD_APB1PERIPH_BASE + 0x6C00UL)
#define DAC1_BASE   (CD_APB1PERIPH_BASE + 0x7400UL)
#define UART7_BASE   (CD_APB1PERIPH_BASE + 0x7800UL)
#define UART8_BASE   (CD_APB1PERIPH_BASE + 0x7C00UL)
#define CRS_BASE   (CD_APB1PERIPH_BASE + 0x8400UL)
#define SWPMI1_BASE   (CD_APB1PERIPH_BASE + 0x8800UL)
#define OPAMP_BASE   (CD_APB1PERIPH_BASE + 0x9000UL)
#define OPAMP1_BASE   (CD_APB1PERIPH_BASE + 0x9000UL)
#define OPAMP2_BASE   (CD_APB1PERIPH_BASE + 0x9010UL)
#define MDIOS_BASE   (CD_APB1PERIPH_BASE + 0x9400UL)
#define FDCAN1_BASE   (CD_APB1PERIPH_BASE + 0xA000UL)
#define FDCAN2_BASE   (CD_APB1PERIPH_BASE + 0xA400UL)
#define FDCAN_CCU_BASE   (CD_APB1PERIPH_BASE + 0xA800UL)
#define SRAMCAN_BASE   (CD_APB1PERIPH_BASE + 0xAC00UL)
#define TIM1_BASE   (CD_APB2PERIPH_BASE + 0x0000UL)
#define TIM8_BASE   (CD_APB2PERIPH_BASE + 0x0400UL)
#define USART1_BASE   (CD_APB2PERIPH_BASE + 0x1000UL)
#define USART6_BASE   (CD_APB2PERIPH_BASE + 0x1400UL)
#define UART9_BASE   (CD_APB2PERIPH_BASE + 0x1800UL)
#define USART10_BASE   (CD_APB2PERIPH_BASE + 0x1C00UL)
#define SPI1_BASE   (CD_APB2PERIPH_BASE + 0x3000UL)
#define SPI4_BASE   (CD_APB2PERIPH_BASE + 0x3400UL)
#define TIM15_BASE   (CD_APB2PERIPH_BASE + 0x4000UL)
#define TIM16_BASE   (CD_APB2PERIPH_BASE + 0x4400UL)
#define TIM17_BASE   (CD_APB2PERIPH_BASE + 0x4800UL)
#define SPI5_BASE   (CD_APB2PERIPH_BASE + 0x5000UL)
#define SAI1_BASE   (CD_APB2PERIPH_BASE + 0x5800UL)
#define SAI1_Block_A_BASE   (SAI1_BASE + 0x004UL)
#define SAI1_Block_B_BASE   (SAI1_BASE + 0x024UL)
#define SAI2_BASE   (CD_APB2PERIPH_BASE + 0x5C00UL)
#define SAI2_Block_A_BASE   (SAI2_BASE + 0x004UL)
#define SAI2_Block_B_BASE   (SAI2_BASE + 0x024UL)
#define DFSDM1_BASE   (CD_APB2PERIPH_BASE + 0x7800UL)
#define DFSDM1_Channel0_BASE   (DFSDM1_BASE + 0x00UL)
#define DFSDM1_Channel1_BASE   (DFSDM1_BASE + 0x20UL)
#define DFSDM1_Channel2_BASE   (DFSDM1_BASE + 0x40UL)
#define DFSDM1_Channel3_BASE   (DFSDM1_BASE + 0x60UL)
#define DFSDM1_Channel4_BASE   (DFSDM1_BASE + 0x80UL)
#define DFSDM1_Channel5_BASE   (DFSDM1_BASE + 0xA0UL)
#define DFSDM1_Channel6_BASE   (DFSDM1_BASE + 0xC0UL)
#define DFSDM1_Channel7_BASE   (DFSDM1_BASE + 0xE0UL)
#define DFSDM1_Filter0_BASE   (DFSDM1_BASE + 0x100UL)
#define DFSDM1_Filter1_BASE   (DFSDM1_BASE + 0x180UL)
#define DFSDM1_Filter2_BASE   (DFSDM1_BASE + 0x200UL)
#define DFSDM1_Filter3_BASE   (DFSDM1_BASE + 0x280UL)
#define DFSDM1_Filter4_BASE   (DFSDM1_BASE + 0x300UL)
#define DFSDM1_Filter5_BASE   (DFSDM1_BASE + 0x380UL)
#define DFSDM1_Filter6_BASE   (DFSDM1_BASE + 0x400UL)
#define DFSDM1_Filter7_BASE   (DFSDM1_BASE + 0x480UL)
#define EXTI_BASE   (SRD_APB4PERIPH_BASE + 0x0000UL)
#define EXTI_D1_BASE   (EXTI_BASE + 0x0080UL)
#define SYSCFG_BASE   (SRD_APB4PERIPH_BASE + 0x0400UL)
#define LPUART1_BASE   (SRD_APB4PERIPH_BASE + 0x0C00UL)
#define SPI6_BASE   (SRD_APB4PERIPH_BASE + 0x1400UL)
#define I2C4_BASE   (SRD_APB4PERIPH_BASE + 0x1C00UL)
#define LPTIM2_BASE   (SRD_APB4PERIPH_BASE + 0x2400UL)
#define LPTIM3_BASE   (SRD_APB4PERIPH_BASE + 0x2800UL)
#define DAC2_BASE   (SRD_APB4PERIPH_BASE + 0x3400UL)
#define COMP12_BASE   (SRD_APB4PERIPH_BASE + 0x3800UL)
#define COMP1_BASE   (COMP12_BASE + 0x0CUL)
#define COMP2_BASE   (COMP12_BASE + 0x10UL)
#define VREFBUF_BASE   (SRD_APB4PERIPH_BASE + 0x3C00UL)
#define RTC_BASE   (SRD_APB4PERIPH_BASE + 0x4000UL)
#define TAMP_BASE   (SRD_APB4PERIPH_BASE + 0x4400UL)
#define IWDG1_BASE   (SRD_APB4PERIPH_BASE + 0x4800UL)
#define DTS_BASE   (SRD_APB4PERIPH_BASE + 0x6800UL)
#define DFSDM2_BASE   (SRD_APB4PERIPH_BASE + 0x6C00UL)
#define DFSDM2_Channel0_BASE   (DFSDM2_BASE + 0x00UL)
#define DFSDM2_Channel1_BASE   (DFSDM2_BASE + 0x20UL)
#define DFSDM2_FLT0_BASE   (DFSDM2_BASE + 0x100UL)
#define GFXMMU_BASE   (CD_AHB3PERIPH_BASE + 0xC000UL)
#define BDMA1_Channel0_BASE   (BDMA1_BASE + 0x0008UL)
#define BDMA1_Channel1_BASE   (BDMA1_BASE + 0x001CUL)
#define BDMA1_Channel2_BASE   (BDMA1_BASE + 0x0030UL)
#define BDMA1_Channel3_BASE   (BDMA1_BASE + 0x0044UL)
#define BDMA1_Channel4_BASE   (BDMA1_BASE + 0x0058UL)
#define BDMA1_Channel5_BASE   (BDMA1_BASE + 0x006CUL)
#define BDMA1_Channel6_BASE   (BDMA1_BASE + 0x0080UL)
#define BDMA1_Channel7_BASE   (BDMA1_BASE + 0x0094UL)
#define BDMA2_Channel0_BASE   (BDMA2_BASE + 0x0008UL)
#define BDMA2_Channel1_BASE   (BDMA2_BASE + 0x001CUL)
#define BDMA2_Channel2_BASE   (BDMA2_BASE + 0x0030UL)
#define BDMA2_Channel3_BASE   (BDMA2_BASE + 0x0044UL)
#define BDMA2_Channel4_BASE   (BDMA2_BASE + 0x0058UL)
#define BDMA2_Channel5_BASE   (BDMA2_BASE + 0x006CUL)
#define BDMA2_Channel6_BASE   (BDMA2_BASE + 0x0080UL)
#define BDMA2_Channel7_BASE   (BDMA2_BASE + 0x0094UL)
#define DMAMUX2_Channel0_BASE   (DMAMUX2_BASE)
#define DMAMUX2_Channel1_BASE   (DMAMUX2_BASE + 0x0004UL)
#define DMAMUX2_Channel2_BASE   (DMAMUX2_BASE + 0x0008UL)
#define DMAMUX2_Channel3_BASE   (DMAMUX2_BASE + 0x000CUL)
#define DMAMUX2_Channel4_BASE   (DMAMUX2_BASE + 0x0010UL)
#define DMAMUX2_Channel5_BASE   (DMAMUX2_BASE + 0x0014UL)
#define DMAMUX2_Channel6_BASE   (DMAMUX2_BASE + 0x0018UL)
#define DMAMUX2_Channel7_BASE   (DMAMUX2_BASE + 0x001CUL)
#define DMAMUX2_RequestGenerator0_BASE   (DMAMUX2_BASE + 0x0100UL)
#define DMAMUX2_RequestGenerator1_BASE   (DMAMUX2_BASE + 0x0104UL)
#define DMAMUX2_RequestGenerator2_BASE   (DMAMUX2_BASE + 0x0108UL)
#define DMAMUX2_RequestGenerator3_BASE   (DMAMUX2_BASE + 0x010CUL)
#define DMAMUX2_RequestGenerator4_BASE   (DMAMUX2_BASE + 0x0110UL)
#define DMAMUX2_RequestGenerator5_BASE   (DMAMUX2_BASE + 0x0114UL)
#define DMAMUX2_RequestGenerator6_BASE   (DMAMUX2_BASE + 0x0118UL)
#define DMAMUX2_RequestGenerator7_BASE   (DMAMUX2_BASE + 0x011CUL)
#define DMAMUX2_ChannelStatus_BASE   (DMAMUX2_BASE + 0x0080UL)
#define DMAMUX2_RequestGenStatus_BASE   (DMAMUX2_BASE + 0x0140UL)
#define DMA1_Stream0_BASE   (DMA1_BASE + 0x010UL)
#define DMA1_Stream1_BASE   (DMA1_BASE + 0x028UL)
#define DMA1_Stream2_BASE   (DMA1_BASE + 0x040UL)
#define DMA1_Stream3_BASE   (DMA1_BASE + 0x058UL)
#define DMA1_Stream4_BASE   (DMA1_BASE + 0x070UL)
#define DMA1_Stream5_BASE   (DMA1_BASE + 0x088UL)
#define DMA1_Stream6_BASE   (DMA1_BASE + 0x0A0UL)
#define DMA1_Stream7_BASE   (DMA1_BASE + 0x0B8UL)
#define DMA2_Stream0_BASE   (DMA2_BASE + 0x010UL)
#define DMA2_Stream1_BASE   (DMA2_BASE + 0x028UL)
#define DMA2_Stream2_BASE   (DMA2_BASE + 0x040UL)
#define DMA2_Stream3_BASE   (DMA2_BASE + 0x058UL)
#define DMA2_Stream4_BASE   (DMA2_BASE + 0x070UL)
#define DMA2_Stream5_BASE   (DMA2_BASE + 0x088UL)
#define DMA2_Stream6_BASE   (DMA2_BASE + 0x0A0UL)
#define DMA2_Stream7_BASE   (DMA2_BASE + 0x0B8UL)
#define DMAMUX1_Channel0_BASE   (DMAMUX1_BASE)
#define DMAMUX1_Channel1_BASE   (DMAMUX1_BASE + 0x0004UL)
#define DMAMUX1_Channel2_BASE   (DMAMUX1_BASE + 0x0008UL)
#define DMAMUX1_Channel3_BASE   (DMAMUX1_BASE + 0x000CUL)
#define DMAMUX1_Channel4_BASE   (DMAMUX1_BASE + 0x0010UL)
#define DMAMUX1_Channel5_BASE   (DMAMUX1_BASE + 0x0014UL)
#define DMAMUX1_Channel6_BASE   (DMAMUX1_BASE + 0x0018UL)
#define DMAMUX1_Channel7_BASE   (DMAMUX1_BASE + 0x001CUL)
#define DMAMUX1_Channel8_BASE   (DMAMUX1_BASE + 0x0020UL)
#define DMAMUX1_Channel9_BASE   (DMAMUX1_BASE + 0x0024UL)
#define DMAMUX1_Channel10_BASE   (DMAMUX1_BASE + 0x0028UL)
#define DMAMUX1_Channel11_BASE   (DMAMUX1_BASE + 0x002CUL)
#define DMAMUX1_Channel12_BASE   (DMAMUX1_BASE + 0x0030UL)
#define DMAMUX1_Channel13_BASE   (DMAMUX1_BASE + 0x0034UL)
#define DMAMUX1_Channel14_BASE   (DMAMUX1_BASE + 0x0038UL)
#define DMAMUX1_Channel15_BASE   (DMAMUX1_BASE + 0x003CUL)
#define DMAMUX1_RequestGenerator0_BASE   (DMAMUX1_BASE + 0x0100UL)
#define DMAMUX1_RequestGenerator1_BASE   (DMAMUX1_BASE + 0x0104UL)
#define DMAMUX1_RequestGenerator2_BASE   (DMAMUX1_BASE + 0x0108UL)
#define DMAMUX1_RequestGenerator3_BASE   (DMAMUX1_BASE + 0x010CUL)
#define DMAMUX1_RequestGenerator4_BASE   (DMAMUX1_BASE + 0x0110UL)
#define DMAMUX1_RequestGenerator5_BASE   (DMAMUX1_BASE + 0x0114UL)
#define DMAMUX1_RequestGenerator6_BASE   (DMAMUX1_BASE + 0x0118UL)
#define DMAMUX1_RequestGenerator7_BASE   (DMAMUX1_BASE + 0x011CUL)
#define DMAMUX1_ChannelStatus_BASE   (DMAMUX1_BASE + 0x0080UL)
#define DMAMUX1_RequestGenStatus_BASE   (DMAMUX1_BASE + 0x0140UL)
#define FMC_Bank1_R_BASE   (FMC_R_BASE + 0x0000UL)
#define FMC_Bank1E_R_BASE   (FMC_R_BASE + 0x0104UL)
#define FMC_Bank2_R_BASE   (FMC_R_BASE + 0x0060UL)
#define FMC_Bank3_R_BASE   (FMC_R_BASE + 0x0080UL)
#define FMC_Bank5_6_R_BASE   (FMC_R_BASE + 0x0140UL)
#define DBGMCU_BASE   (0x5C001000UL)
#define MDMA_Channel0_BASE   (MDMA_BASE + 0x00000040UL)
#define MDMA_Channel1_BASE   (MDMA_BASE + 0x00000080UL)
#define MDMA_Channel2_BASE   (MDMA_BASE + 0x000000C0UL)
#define MDMA_Channel3_BASE   (MDMA_BASE + 0x00000100UL)
#define MDMA_Channel4_BASE   (MDMA_BASE + 0x00000140UL)
#define MDMA_Channel5_BASE   (MDMA_BASE + 0x00000180UL)
#define MDMA_Channel6_BASE   (MDMA_BASE + 0x000001C0UL)
#define MDMA_Channel7_BASE   (MDMA_BASE + 0x00000200UL)
#define MDMA_Channel8_BASE   (MDMA_BASE + 0x00000240UL)
#define MDMA_Channel9_BASE   (MDMA_BASE + 0x00000280UL)
#define MDMA_Channel10_BASE   (MDMA_BASE + 0x000002C0UL)
#define MDMA_Channel11_BASE   (MDMA_BASE + 0x00000300UL)
#define MDMA_Channel12_BASE   (MDMA_BASE + 0x00000340UL)
#define MDMA_Channel13_BASE   (MDMA_BASE + 0x00000380UL)
#define MDMA_Channel14_BASE   (MDMA_BASE + 0x000003C0UL)
#define MDMA_Channel15_BASE   (MDMA_BASE + 0x00000400UL)
#define GFXMMU_VIRTUAL_BUFFERS_BASE   (0x25000000UL)
#define GFXMMU_VIRTUAL_BUFFER0_BASE   (GFXMMU_VIRTUAL_BUFFERS_BASE)
#define GFXMMU_VIRTUAL_BUFFER1_BASE   (GFXMMU_VIRTUAL_BUFFERS_BASE + 0x400000UL)
#define GFXMMU_VIRTUAL_BUFFER2_BASE   (GFXMMU_VIRTUAL_BUFFERS_BASE + 0x800000UL)
#define GFXMMU_VIRTUAL_BUFFER3_BASE   (GFXMMU_VIRTUAL_BUFFERS_BASE + 0xC00000UL)
#define RAMECC_Monitor1_BASE   (RAMECC_BASE + 0x20UL)
#define RAMECC_Monitor2_BASE   (RAMECC_BASE + 0x40UL)
#define RAMECC_Monitor3_BASE   (RAMECC_BASE + 0x60UL)
#define GPV_BASE   (PERIPH_BASE + 0x11000000UL)
#define TIM2   ((TIM_TypeDef *) TIM2_BASE)
#define TIM3   ((TIM_TypeDef *) TIM3_BASE)
#define TIM4   ((TIM_TypeDef *) TIM4_BASE)
#define TIM5   ((TIM_TypeDef *) TIM5_BASE)
#define TIM6   ((TIM_TypeDef *) TIM6_BASE)
#define TIM7   ((TIM_TypeDef *) TIM7_BASE)
#define TIM13   ((TIM_TypeDef *) TIM13_BASE)
#define TIM14   ((TIM_TypeDef *) TIM14_BASE)
#define VREFBUF   ((VREFBUF_TypeDef *) VREFBUF_BASE)
#define RTC   ((RTC_TypeDef *) RTC_BASE)
#define TAMP   ((TAMP_TypeDef *) TAMP_BASE)
#define WWDG1   ((WWDG_TypeDef *) WWDG1_BASE)
#define IWDG1   ((IWDG_TypeDef *) IWDG1_BASE)
#define SPI2   ((SPI_TypeDef *) SPI2_BASE)
#define SPI3   ((SPI_TypeDef *) SPI3_BASE)
#define SPI4   ((SPI_TypeDef *) SPI4_BASE)
#define SPI5   ((SPI_TypeDef *) SPI5_BASE)
#define SPI6   ((SPI_TypeDef *) SPI6_BASE)
#define USART2   ((USART_TypeDef *) USART2_BASE)
#define USART3   ((USART_TypeDef *) USART3_BASE)
#define USART6   ((USART_TypeDef *) USART6_BASE)
#define USART10   ((USART_TypeDef *) USART10_BASE)
#define UART7   ((USART_TypeDef *) UART7_BASE)
#define UART8   ((USART_TypeDef *) UART8_BASE)
#define UART9   ((USART_TypeDef *) UART9_BASE)
#define CRS   ((CRS_TypeDef *) CRS_BASE)
#define UART4   ((USART_TypeDef *) UART4_BASE)
#define UART5   ((USART_TypeDef *) UART5_BASE)
#define I2C1   ((I2C_TypeDef *) I2C1_BASE)
#define I2C2   ((I2C_TypeDef *) I2C2_BASE)
#define I2C3   ((I2C_TypeDef *) I2C3_BASE)
#define I2C4   ((I2C_TypeDef *) I2C4_BASE)
#define FDCAN1   ((FDCAN_GlobalTypeDef *) FDCAN1_BASE)
#define FDCAN2   ((FDCAN_GlobalTypeDef *) FDCAN2_BASE)
#define FDCAN_CCU   ((FDCAN_ClockCalibrationUnit_TypeDef *) FDCAN_CCU_BASE)
#define CEC   ((CEC_TypeDef *) CEC_BASE)
#define LPTIM1   ((LPTIM_TypeDef *) LPTIM1_BASE)
#define PWR   ((PWR_TypeDef *) PWR_BASE)
#define DAC1   ((DAC_TypeDef *) DAC1_BASE)
#define LPUART1   ((USART_TypeDef *) LPUART1_BASE)
#define SWPMI1   ((SWPMI_TypeDef *) SWPMI1_BASE)
#define LPTIM2   ((LPTIM_TypeDef *) LPTIM2_BASE)
#define LPTIM3   ((LPTIM_TypeDef *) LPTIM3_BASE)
#define DTS   ((DTS_TypeDef *) DTS_BASE)
#define SYSCFG   ((SYSCFG_TypeDef *) SYSCFG_BASE)
#define COMP12   ((COMPOPT_TypeDef *) COMP12_BASE)
#define COMP1   ((COMP_TypeDef *) COMP1_BASE)
#define COMP2   ((COMP_TypeDef *) COMP2_BASE)
#define COMP12_COMMON   ((COMP_Common_TypeDef *) COMP2_BASE)
#define OPAMP   ((OPAMP_TypeDef *) OPAMP_BASE)
#define OPAMP1   ((OPAMP_TypeDef *) OPAMP1_BASE)
#define OPAMP2   ((OPAMP_TypeDef *) OPAMP2_BASE)
#define EXTI   ((EXTI_TypeDef *) EXTI_BASE)
#define EXTI_D1   ((EXTI_Core_TypeDef *) EXTI_D1_BASE)
#define TIM1   ((TIM_TypeDef *) TIM1_BASE)
#define SPI1   ((SPI_TypeDef *) SPI1_BASE)
#define TIM8   ((TIM_TypeDef *) TIM8_BASE)
#define USART1   ((USART_TypeDef *) USART1_BASE)
#define TIM12   ((TIM_TypeDef *) TIM12_BASE)
#define TIM15   ((TIM_TypeDef *) TIM15_BASE)
#define TIM16   ((TIM_TypeDef *) TIM16_BASE)
#define TIM17   ((TIM_TypeDef *) TIM17_BASE)
#define SAI1   ((SAI_TypeDef *) SAI1_BASE)
#define SAI1_Block_A   ((SAI_Block_TypeDef *)SAI1_Block_A_BASE)
#define SAI1_Block_B   ((SAI_Block_TypeDef *)SAI1_Block_B_BASE)
#define SAI2   ((SAI_TypeDef *) SAI2_BASE)
#define SAI2_Block_A   ((SAI_Block_TypeDef *)SAI2_Block_A_BASE)
#define SAI2_Block_B   ((SAI_Block_TypeDef *)SAI2_Block_B_BASE)
#define SPDIFRX   ((SPDIFRX_TypeDef *) SPDIFRX_BASE)
#define DFSDM1_Channel0   ((DFSDM_Channel_TypeDef *) DFSDM1_Channel0_BASE)
#define DFSDM1_Channel1   ((DFSDM_Channel_TypeDef *) DFSDM1_Channel1_BASE)
#define DFSDM1_Channel2   ((DFSDM_Channel_TypeDef *) DFSDM1_Channel2_BASE)
#define DFSDM1_Channel3   ((DFSDM_Channel_TypeDef *) DFSDM1_Channel3_BASE)
#define DFSDM1_Channel4   ((DFSDM_Channel_TypeDef *) DFSDM1_Channel4_BASE)
#define DFSDM1_Channel5   ((DFSDM_Channel_TypeDef *) DFSDM1_Channel5_BASE)
#define DFSDM1_Channel6   ((DFSDM_Channel_TypeDef *) DFSDM1_Channel6_BASE)
#define DFSDM1_Channel7   ((DFSDM_Channel_TypeDef *) DFSDM1_Channel7_BASE)
#define DFSDM1_Filter0   ((DFSDM_Filter_TypeDef *) DFSDM1_Filter0_BASE)
#define DFSDM1_Filter1   ((DFSDM_Filter_TypeDef *) DFSDM1_Filter1_BASE)
#define DFSDM1_Filter2   ((DFSDM_Filter_TypeDef *) DFSDM1_Filter2_BASE)
#define DFSDM1_Filter3   ((DFSDM_Filter_TypeDef *) DFSDM1_Filter3_BASE)
#define DFSDM1_Filter4   ((DFSDM_Filter_TypeDef *) DFSDM1_Filter4_BASE)
#define DFSDM1_Filter5   ((DFSDM_Filter_TypeDef *) DFSDM1_Filter5_BASE)
#define DFSDM1_Filter6   ((DFSDM_Filter_TypeDef *) DFSDM1_Filter6_BASE)
#define DFSDM1_Filter7   ((DFSDM_Filter_TypeDef *) DFSDM1_Filter7_BASE)
#define DFSDM2_Channel0   ((DFSDM_Channel_TypeDef *) DFSDM2_Channel0_BASE)
#define DFSDM2_Channel1   ((DFSDM_Channel_TypeDef *) DFSDM2_Channel1_BASE)
#define DFSDM2_Filter0   ((DFSDM_Filter_TypeDef *) DFSDM2_FLT0_BASE)
#define DMA2D   ((DMA2D_TypeDef *) DMA2D_BASE)
#define DCMI   ((DCMI_TypeDef *) DCMI_BASE)
#define PSSI   ((PSSI_TypeDef *) PSSI_BASE)
#define RCC   ((RCC_TypeDef *) RCC_BASE)
#define FLASH   ((FLASH_TypeDef *) FLASH_R_BASE)
#define CRC   ((CRC_TypeDef *) CRC_BASE)
#define GPIOA   ((GPIO_TypeDef *) GPIOA_BASE)
#define GPIOB   ((GPIO_TypeDef *) GPIOB_BASE)
#define GPIOC   ((GPIO_TypeDef *) GPIOC_BASE)
#define GPIOD   ((GPIO_TypeDef *) GPIOD_BASE)
#define GPIOE   ((GPIO_TypeDef *) GPIOE_BASE)
#define GPIOF   ((GPIO_TypeDef *) GPIOF_BASE)
#define GPIOG   ((GPIO_TypeDef *) GPIOG_BASE)
#define GPIOH   ((GPIO_TypeDef *) GPIOH_BASE)
#define GPIOI   ((GPIO_TypeDef *) GPIOI_BASE)
#define GPIOJ   ((GPIO_TypeDef *) GPIOJ_BASE)
#define GPIOK   ((GPIO_TypeDef *) GPIOK_BASE)
#define ADC1   ((ADC_TypeDef *) ADC1_BASE)
#define ADC2   ((ADC_TypeDef *) ADC2_BASE)
#define ADC12_COMMON   ((ADC_Common_TypeDef *) ADC12_COMMON_BASE)
#define RNG   ((RNG_TypeDef *) RNG_BASE)
#define SDMMC2   ((SDMMC_TypeDef *) SDMMC2_BASE)
#define DLYB_SDMMC2   ((DLYB_TypeDef *) DLYB_SDMMC2_BASE)
#define BDMA1   ((BDMA_TypeDef *) BDMA1_BASE)
#define BDMA1_Channel0   ((BDMA_Channel_TypeDef *) BDMA1_Channel0_BASE)
#define BDMA1_Channel1   ((BDMA_Channel_TypeDef *) BDMA1_Channel1_BASE)
#define BDMA1_Channel2   ((BDMA_Channel_TypeDef *) BDMA1_Channel2_BASE)
#define BDMA1_Channel3   ((BDMA_Channel_TypeDef *) BDMA1_Channel3_BASE)
#define BDMA1_Channel4   ((BDMA_Channel_TypeDef *) BDMA1_Channel4_BASE)
#define BDMA1_Channel5   ((BDMA_Channel_TypeDef *) BDMA1_Channel5_BASE)
#define BDMA1_Channel6   ((BDMA_Channel_TypeDef *) BDMA1_Channel6_BASE)
#define BDMA1_Channel7   ((BDMA_Channel_TypeDef *) BDMA1_Channel7_BASE)
#define BDMA2   ((BDMA_TypeDef *) BDMA2_BASE)
#define BDMA2_Channel0   ((BDMA_Channel_TypeDef *) BDMA2_Channel0_BASE)
#define BDMA2_Channel1   ((BDMA_Channel_TypeDef *) BDMA2_Channel1_BASE)
#define BDMA2_Channel2   ((BDMA_Channel_TypeDef *) BDMA2_Channel2_BASE)
#define BDMA2_Channel3   ((BDMA_Channel_TypeDef *) BDMA2_Channel3_BASE)
#define BDMA2_Channel4   ((BDMA_Channel_TypeDef *) BDMA2_Channel4_BASE)
#define BDMA2_Channel5   ((BDMA_Channel_TypeDef *) BDMA2_Channel5_BASE)
#define BDMA2_Channel6   ((BDMA_Channel_TypeDef *) BDMA2_Channel6_BASE)
#define BDMA2_Channel7   ((BDMA_Channel_TypeDef *) BDMA2_Channel7_BASE)
#define RAMECC   ((RAMECC_TypeDef *)RAMECC_BASE)
#define RAMECC_Monitor1   ((RAMECC_MonitorTypeDef *)RAMECC_Monitor1_BASE)
#define RAMECC_Monitor2   ((RAMECC_MonitorTypeDef *)RAMECC_Monitor2_BASE)
#define RAMECC_Monitor3   ((RAMECC_MonitorTypeDef *)RAMECC_Monitor3_BASE)
#define DMAMUX2   ((DMAMUX_Channel_TypeDef *) DMAMUX2_BASE)
#define DMAMUX2_Channel0   ((DMAMUX_Channel_TypeDef *) DMAMUX2_Channel0_BASE)
#define DMAMUX2_Channel1   ((DMAMUX_Channel_TypeDef *) DMAMUX2_Channel1_BASE)
#define DMAMUX2_Channel2   ((DMAMUX_Channel_TypeDef *) DMAMUX2_Channel2_BASE)
#define DMAMUX2_Channel3   ((DMAMUX_Channel_TypeDef *) DMAMUX2_Channel3_BASE)
#define DMAMUX2_Channel4   ((DMAMUX_Channel_TypeDef *) DMAMUX2_Channel4_BASE)
#define DMAMUX2_Channel5   ((DMAMUX_Channel_TypeDef *) DMAMUX2_Channel5_BASE)
#define DMAMUX2_Channel6   ((DMAMUX_Channel_TypeDef *) DMAMUX2_Channel6_BASE)
#define DMAMUX2_Channel7   ((DMAMUX_Channel_TypeDef *) DMAMUX2_Channel7_BASE)
#define DMAMUX2_RequestGenerator0   ((DMAMUX_RequestGen_TypeDef *) DMAMUX2_RequestGenerator0_BASE)
#define DMAMUX2_RequestGenerator1   ((DMAMUX_RequestGen_TypeDef *) DMAMUX2_RequestGenerator1_BASE)
#define DMAMUX2_RequestGenerator2   ((DMAMUX_RequestGen_TypeDef *) DMAMUX2_RequestGenerator2_BASE)
#define DMAMUX2_RequestGenerator3   ((DMAMUX_RequestGen_TypeDef *) DMAMUX2_RequestGenerator3_BASE)
#define DMAMUX2_RequestGenerator4   ((DMAMUX_RequestGen_TypeDef *) DMAMUX2_RequestGenerator4_BASE)
#define DMAMUX2_RequestGenerator5   ((DMAMUX_RequestGen_TypeDef *) DMAMUX2_RequestGenerator5_BASE)
#define DMAMUX2_RequestGenerator6   ((DMAMUX_RequestGen_TypeDef *) DMAMUX2_RequestGenerator6_BASE)
#define DMAMUX2_RequestGenerator7   ((DMAMUX_RequestGen_TypeDef *) DMAMUX2_RequestGenerator7_BASE)
#define DMAMUX2_ChannelStatus   ((DMAMUX_ChannelStatus_TypeDef *) DMAMUX2_ChannelStatus_BASE)
#define DMAMUX2_RequestGenStatus   ((DMAMUX_RequestGenStatus_TypeDef *) DMAMUX2_RequestGenStatus_BASE)
#define DMA2   ((DMA_TypeDef *) DMA2_BASE)
#define DMA2_Stream0   ((DMA_Stream_TypeDef *) DMA2_Stream0_BASE)
#define DMA2_Stream1   ((DMA_Stream_TypeDef *) DMA2_Stream1_BASE)
#define DMA2_Stream2   ((DMA_Stream_TypeDef *) DMA2_Stream2_BASE)
#define DMA2_Stream3   ((DMA_Stream_TypeDef *) DMA2_Stream3_BASE)
#define DMA2_Stream4   ((DMA_Stream_TypeDef *) DMA2_Stream4_BASE)
#define DMA2_Stream5   ((DMA_Stream_TypeDef *) DMA2_Stream5_BASE)
#define DMA2_Stream6   ((DMA_Stream_TypeDef *) DMA2_Stream6_BASE)
#define DMA2_Stream7   ((DMA_Stream_TypeDef *) DMA2_Stream7_BASE)
#define DMA1   ((DMA_TypeDef *) DMA1_BASE)
#define DMA1_Stream0   ((DMA_Stream_TypeDef *) DMA1_Stream0_BASE)
#define DMA1_Stream1   ((DMA_Stream_TypeDef *) DMA1_Stream1_BASE)
#define DMA1_Stream2   ((DMA_Stream_TypeDef *) DMA1_Stream2_BASE)
#define DMA1_Stream3   ((DMA_Stream_TypeDef *) DMA1_Stream3_BASE)
#define DMA1_Stream4   ((DMA_Stream_TypeDef *) DMA1_Stream4_BASE)
#define DMA1_Stream5   ((DMA_Stream_TypeDef *) DMA1_Stream5_BASE)
#define DMA1_Stream6   ((DMA_Stream_TypeDef *) DMA1_Stream6_BASE)
#define DMA1_Stream7   ((DMA_Stream_TypeDef *) DMA1_Stream7_BASE)
#define DMAMUX1   ((DMAMUX_Channel_TypeDef *) DMAMUX1_BASE)
#define DMAMUX1_Channel0   ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel0_BASE)
#define DMAMUX1_Channel1   ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel1_BASE)
#define DMAMUX1_Channel2   ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel2_BASE)
#define DMAMUX1_Channel3   ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel3_BASE)
#define DMAMUX1_Channel4   ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel4_BASE)
#define DMAMUX1_Channel5   ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel5_BASE)
#define DMAMUX1_Channel6   ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel6_BASE)
#define DMAMUX1_Channel7   ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel7_BASE)
#define DMAMUX1_Channel8   ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel8_BASE)
#define DMAMUX1_Channel9   ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel9_BASE)
#define DMAMUX1_Channel10   ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel10_BASE)
#define DMAMUX1_Channel11   ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel11_BASE)
#define DMAMUX1_Channel12   ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel12_BASE)
#define DMAMUX1_Channel13   ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel13_BASE)
#define DMAMUX1_Channel14   ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel14_BASE)
#define DMAMUX1_Channel15   ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel15_BASE)
#define DMAMUX1_RequestGenerator0   ((DMAMUX_RequestGen_TypeDef *) DMAMUX1_RequestGenerator0_BASE)
#define DMAMUX1_RequestGenerator1   ((DMAMUX_RequestGen_TypeDef *) DMAMUX1_RequestGenerator1_BASE)
#define DMAMUX1_RequestGenerator2   ((DMAMUX_RequestGen_TypeDef *) DMAMUX1_RequestGenerator2_BASE)
#define DMAMUX1_RequestGenerator3   ((DMAMUX_RequestGen_TypeDef *) DMAMUX1_RequestGenerator3_BASE)
#define DMAMUX1_RequestGenerator4   ((DMAMUX_RequestGen_TypeDef *) DMAMUX1_RequestGenerator4_BASE)
#define DMAMUX1_RequestGenerator5   ((DMAMUX_RequestGen_TypeDef *) DMAMUX1_RequestGenerator5_BASE)
#define DMAMUX1_RequestGenerator6   ((DMAMUX_RequestGen_TypeDef *) DMAMUX1_RequestGenerator6_BASE)
#define DMAMUX1_RequestGenerator7   ((DMAMUX_RequestGen_TypeDef *) DMAMUX1_RequestGenerator7_BASE)
#define DMAMUX1_ChannelStatus   ((DMAMUX_ChannelStatus_TypeDef *) DMAMUX1_ChannelStatus_BASE)
#define DMAMUX1_RequestGenStatus   ((DMAMUX_RequestGenStatus_TypeDef *) DMAMUX1_RequestGenStatus_BASE)
#define FMC_Bank1_R   ((FMC_Bank1_TypeDef *) FMC_Bank1_R_BASE)
#define FMC_Bank1E_R   ((FMC_Bank1E_TypeDef *) FMC_Bank1E_R_BASE)
#define FMC_Bank2_R   ((FMC_Bank2_TypeDef *) FMC_Bank2_R_BASE)
#define FMC_Bank3_R   ((FMC_Bank3_TypeDef *) FMC_Bank3_R_BASE)
#define FMC_Bank5_6_R   ((FMC_Bank5_6_TypeDef *) FMC_Bank5_6_R_BASE)
#define DAC2   ((DAC_TypeDef *) DAC2_BASE)
#define OCTOSPI1   ((OCTOSPI_TypeDef *) OCTOSPI1_R_BASE)
#define DLYB_OCTOSPI1   ((DLYB_TypeDef *) DLYB_OCTOSPI1_BASE)
#define OCTOSPI2   ((OCTOSPI_TypeDef *) OCTOSPI2_R_BASE)
#define DLYB_OCTOSPI2   ((DLYB_TypeDef *) DLYB_OCTOSPI2_BASE)
#define OCTOSPIM   ((OCTOSPIM_TypeDef *) OCTOSPIM_BASE)
#define GFXMMU   ((GFXMMU_TypeDef *) GFXMMU_BASE)
#define SDMMC1   ((SDMMC_TypeDef *) SDMMC1_BASE)
#define DLYB_SDMMC1   ((DLYB_TypeDef *) DLYB_SDMMC1_BASE)
#define DBGMCU   ((DBGMCU_TypeDef *) DBGMCU_BASE)
#define JPEG   ((JPEG_TypeDef *) JPGDEC_BASE)
#define HSEM   ((HSEM_TypeDef *) HSEM_BASE)
#define HSEM_COMMON   ((HSEM_Common_TypeDef *) (HSEM_BASE + 0x100UL))
#define LTDC   ((LTDC_TypeDef *)LTDC_BASE)
#define LTDC_Layer1   ((LTDC_Layer_TypeDef *)LTDC_Layer1_BASE)
#define LTDC_Layer2   ((LTDC_Layer_TypeDef *)LTDC_Layer2_BASE)
#define MDIOS   ((MDIOS_TypeDef *) MDIOS_BASE)
#define MDMA   ((MDMA_TypeDef *)MDMA_BASE)
#define MDMA_Channel0   ((MDMA_Channel_TypeDef *)MDMA_Channel0_BASE)
#define MDMA_Channel1   ((MDMA_Channel_TypeDef *)MDMA_Channel1_BASE)
#define MDMA_Channel2   ((MDMA_Channel_TypeDef *)MDMA_Channel2_BASE)
#define MDMA_Channel3   ((MDMA_Channel_TypeDef *)MDMA_Channel3_BASE)
#define MDMA_Channel4   ((MDMA_Channel_TypeDef *)MDMA_Channel4_BASE)
#define MDMA_Channel5   ((MDMA_Channel_TypeDef *)MDMA_Channel5_BASE)
#define MDMA_Channel6   ((MDMA_Channel_TypeDef *)MDMA_Channel6_BASE)
#define MDMA_Channel7   ((MDMA_Channel_TypeDef *)MDMA_Channel7_BASE)
#define MDMA_Channel8   ((MDMA_Channel_TypeDef *)MDMA_Channel8_BASE)
#define MDMA_Channel9   ((MDMA_Channel_TypeDef *)MDMA_Channel9_BASE)
#define MDMA_Channel10   ((MDMA_Channel_TypeDef *)MDMA_Channel10_BASE)
#define MDMA_Channel11   ((MDMA_Channel_TypeDef *)MDMA_Channel11_BASE)
#define MDMA_Channel12   ((MDMA_Channel_TypeDef *)MDMA_Channel12_BASE)
#define MDMA_Channel13   ((MDMA_Channel_TypeDef *)MDMA_Channel13_BASE)
#define MDMA_Channel14   ((MDMA_Channel_TypeDef *)MDMA_Channel14_BASE)
#define MDMA_Channel15   ((MDMA_Channel_TypeDef *)MDMA_Channel15_BASE)
#define USB1_OTG_HS   ((USB_OTG_GlobalTypeDef *) USB1_OTG_HS_PERIPH_BASE)
#define USB_OTG_HS   USB1_OTG_HS
#define USB_OTG_HS_PERIPH_BASE   USB1_OTG_HS_PERIPH_BASE
#define GPV   ((GPV_TypeDef *) GPV_BASE)
#define LSI_STARTUP_TIME   130U
#define ADC_VER_V5_3
#define ADC_ISR_ADRDY_Pos   (0U)
#define ADC_ISR_ADRDY_Msk   (0x1UL << ADC_ISR_ADRDY_Pos)
#define ADC_ISR_ADRDY   ADC_ISR_ADRDY_Msk
#define ADC_ISR_EOSMP_Pos   (1U)
#define ADC_ISR_EOSMP_Msk   (0x1UL << ADC_ISR_EOSMP_Pos)
#define ADC_ISR_EOSMP   ADC_ISR_EOSMP_Msk
#define ADC_ISR_EOC_Pos   (2U)
#define ADC_ISR_EOC_Msk   (0x1UL << ADC_ISR_EOC_Pos)
#define ADC_ISR_EOC   ADC_ISR_EOC_Msk
#define ADC_ISR_EOS_Pos   (3U)
#define ADC_ISR_EOS_Msk   (0x1UL << ADC_ISR_EOS_Pos)
#define ADC_ISR_EOS   ADC_ISR_EOS_Msk
#define ADC_ISR_OVR_Pos   (4U)
#define ADC_ISR_OVR_Msk   (0x1UL << ADC_ISR_OVR_Pos)
#define ADC_ISR_OVR   ADC_ISR_OVR_Msk
#define ADC_ISR_JEOC_Pos   (5U)
#define ADC_ISR_JEOC_Msk   (0x1UL << ADC_ISR_JEOC_Pos)
#define ADC_ISR_JEOC   ADC_ISR_JEOC_Msk
#define ADC_ISR_JEOS_Pos   (6U)
#define ADC_ISR_JEOS_Msk   (0x1UL << ADC_ISR_JEOS_Pos)
#define ADC_ISR_JEOS   ADC_ISR_JEOS_Msk
#define ADC_ISR_AWD1_Pos   (7U)
#define ADC_ISR_AWD1_Msk   (0x1UL << ADC_ISR_AWD1_Pos)
#define ADC_ISR_AWD1   ADC_ISR_AWD1_Msk
#define ADC_ISR_AWD2_Pos   (8U)
#define ADC_ISR_AWD2_Msk   (0x1UL << ADC_ISR_AWD2_Pos)
#define ADC_ISR_AWD2   ADC_ISR_AWD2_Msk
#define ADC_ISR_AWD3_Pos   (9U)
#define ADC_ISR_AWD3_Msk   (0x1UL << ADC_ISR_AWD3_Pos)
#define ADC_ISR_AWD3   ADC_ISR_AWD3_Msk
#define ADC_ISR_JQOVF_Pos   (10U)
#define ADC_ISR_JQOVF_Msk   (0x1UL << ADC_ISR_JQOVF_Pos)
#define ADC_ISR_JQOVF   ADC_ISR_JQOVF_Msk
#define ADC_ISR_LDORDY_Pos   (12U)
#define ADC_ISR_LDORDY_Msk   (0x1UL << ADC_ISR_LDORDY_Pos)
#define ADC_ISR_LDORDY   ADC_ISR_LDORDY_Msk
#define ADC_IER_ADRDYIE_Pos   (0U)
#define ADC_IER_ADRDYIE_Msk   (0x1UL << ADC_IER_ADRDYIE_Pos)
#define ADC_IER_ADRDYIE   ADC_IER_ADRDYIE_Msk
#define ADC_IER_EOSMPIE_Pos   (1U)
#define ADC_IER_EOSMPIE_Msk   (0x1UL << ADC_IER_EOSMPIE_Pos)
#define ADC_IER_EOSMPIE   ADC_IER_EOSMPIE_Msk
#define ADC_IER_EOCIE_Pos   (2U)
#define ADC_IER_EOCIE_Msk   (0x1UL << ADC_IER_EOCIE_Pos)
#define ADC_IER_EOCIE   ADC_IER_EOCIE_Msk
#define ADC_IER_EOSIE_Pos   (3U)
#define ADC_IER_EOSIE_Msk   (0x1UL << ADC_IER_EOSIE_Pos)
#define ADC_IER_EOSIE   ADC_IER_EOSIE_Msk
#define ADC_IER_OVRIE_Pos   (4U)
#define ADC_IER_OVRIE_Msk   (0x1UL << ADC_IER_OVRIE_Pos)
#define ADC_IER_OVRIE   ADC_IER_OVRIE_Msk
#define ADC_IER_JEOCIE_Pos   (5U)
#define ADC_IER_JEOCIE_Msk   (0x1UL << ADC_IER_JEOCIE_Pos)
#define ADC_IER_JEOCIE   ADC_IER_JEOCIE_Msk
#define ADC_IER_JEOSIE_Pos   (6U)
#define ADC_IER_JEOSIE_Msk   (0x1UL << ADC_IER_JEOSIE_Pos)
#define ADC_IER_JEOSIE   ADC_IER_JEOSIE_Msk
#define ADC_IER_AWD1IE_Pos   (7U)
#define ADC_IER_AWD1IE_Msk   (0x1UL << ADC_IER_AWD1IE_Pos)
#define ADC_IER_AWD1IE   ADC_IER_AWD1IE_Msk
#define ADC_IER_AWD2IE_Pos   (8U)
#define ADC_IER_AWD2IE_Msk   (0x1UL << ADC_IER_AWD2IE_Pos)
#define ADC_IER_AWD2IE   ADC_IER_AWD2IE_Msk
#define ADC_IER_AWD3IE_Pos   (9U)
#define ADC_IER_AWD3IE_Msk   (0x1UL << ADC_IER_AWD3IE_Pos)
#define ADC_IER_AWD3IE   ADC_IER_AWD3IE_Msk
#define ADC_IER_JQOVFIE_Pos   (10U)
#define ADC_IER_JQOVFIE_Msk   (0x1UL << ADC_IER_JQOVFIE_Pos)
#define ADC_IER_JQOVFIE   ADC_IER_JQOVFIE_Msk
#define ADC_CR_ADEN_Pos   (0U)
#define ADC_CR_ADEN_Msk   (0x1UL << ADC_CR_ADEN_Pos)
#define ADC_CR_ADEN   ADC_CR_ADEN_Msk
#define ADC_CR_ADDIS_Pos   (1U)
#define ADC_CR_ADDIS_Msk   (0x1UL << ADC_CR_ADDIS_Pos)
#define ADC_CR_ADDIS   ADC_CR_ADDIS_Msk
#define ADC_CR_ADSTART_Pos   (2U)
#define ADC_CR_ADSTART_Msk   (0x1UL << ADC_CR_ADSTART_Pos)
#define ADC_CR_ADSTART   ADC_CR_ADSTART_Msk
#define ADC_CR_JADSTART_Pos   (3U)
#define ADC_CR_JADSTART_Msk   (0x1UL << ADC_CR_JADSTART_Pos)
#define ADC_CR_JADSTART   ADC_CR_JADSTART_Msk
#define ADC_CR_ADSTP_Pos   (4U)
#define ADC_CR_ADSTP_Msk   (0x1UL << ADC_CR_ADSTP_Pos)
#define ADC_CR_ADSTP   ADC_CR_ADSTP_Msk
#define ADC_CR_JADSTP_Pos   (5U)
#define ADC_CR_JADSTP_Msk   (0x1UL << ADC_CR_JADSTP_Pos)
#define ADC_CR_JADSTP   ADC_CR_JADSTP_Msk
#define ADC_CR_BOOST_Pos   (8U)
#define ADC_CR_BOOST_Msk   (0x3UL << ADC_CR_BOOST_Pos)
#define ADC_CR_BOOST   ADC_CR_BOOST_Msk
#define ADC_CR_BOOST_0   (0x1UL << ADC_CR_BOOST_Pos)
#define ADC_CR_BOOST_1   (0x2UL << ADC_CR_BOOST_Pos)
#define ADC_CR_ADCALLIN_Pos   (16U)
#define ADC_CR_ADCALLIN_Msk   (0x1UL << ADC_CR_ADCALLIN_Pos)
#define ADC_CR_ADCALLIN   ADC_CR_ADCALLIN_Msk
#define ADC_CR_LINCALRDYW1_Pos   (22U)
#define ADC_CR_LINCALRDYW1_Msk   (0x1UL << ADC_CR_LINCALRDYW1_Pos)
#define ADC_CR_LINCALRDYW1   ADC_CR_LINCALRDYW1_Msk
#define ADC_CR_LINCALRDYW2_Pos   (23U)
#define ADC_CR_LINCALRDYW2_Msk   (0x1UL << ADC_CR_LINCALRDYW2_Pos)
#define ADC_CR_LINCALRDYW2   ADC_CR_LINCALRDYW2_Msk
#define ADC_CR_LINCALRDYW3_Pos   (24U)
#define ADC_CR_LINCALRDYW3_Msk   (0x1UL << ADC_CR_LINCALRDYW3_Pos)
#define ADC_CR_LINCALRDYW3   ADC_CR_LINCALRDYW3_Msk
#define ADC_CR_LINCALRDYW4_Pos   (25U)
#define ADC_CR_LINCALRDYW4_Msk   (0x1UL << ADC_CR_LINCALRDYW4_Pos)
#define ADC_CR_LINCALRDYW4   ADC_CR_LINCALRDYW4_Msk
#define ADC_CR_LINCALRDYW5_Pos   (26U)
#define ADC_CR_LINCALRDYW5_Msk   (0x1UL << ADC_CR_LINCALRDYW5_Pos)
#define ADC_CR_LINCALRDYW5   ADC_CR_LINCALRDYW5_Msk
#define ADC_CR_LINCALRDYW6_Pos   (27U)
#define ADC_CR_LINCALRDYW6_Msk   (0x1UL << ADC_CR_LINCALRDYW6_Pos)
#define ADC_CR_LINCALRDYW6   ADC_CR_LINCALRDYW6_Msk
#define ADC_CR_ADVREGEN_Pos   (28U)
#define ADC_CR_ADVREGEN_Msk   (0x1UL << ADC_CR_ADVREGEN_Pos)
#define ADC_CR_ADVREGEN   ADC_CR_ADVREGEN_Msk
#define ADC_CR_DEEPPWD_Pos   (29U)
#define ADC_CR_DEEPPWD_Msk   (0x1UL << ADC_CR_DEEPPWD_Pos)
#define ADC_CR_DEEPPWD   ADC_CR_DEEPPWD_Msk
#define ADC_CR_ADCALDIF_Pos   (30U)
#define ADC_CR_ADCALDIF_Msk   (0x1UL << ADC_CR_ADCALDIF_Pos)
#define ADC_CR_ADCALDIF   ADC_CR_ADCALDIF_Msk
#define ADC_CR_ADCAL_Pos   (31U)
#define ADC_CR_ADCAL_Msk   (0x1UL << ADC_CR_ADCAL_Pos)
#define ADC_CR_ADCAL   ADC_CR_ADCAL_Msk
#define ADC_CFGR_DMNGT_Pos   (0U)
#define ADC_CFGR_DMNGT_Msk   (0x3UL << ADC_CFGR_DMNGT_Pos)
#define ADC_CFGR_DMNGT   ADC_CFGR_DMNGT_Msk
#define ADC_CFGR_DMNGT_0   (0x1UL << ADC_CFGR_DMNGT_Pos)
#define ADC_CFGR_DMNGT_1   (0x2UL << ADC_CFGR_DMNGT_Pos)
#define ADC_CFGR_RES_Pos   (2U)
#define ADC_CFGR_RES_Msk   (0x7UL << ADC_CFGR_RES_Pos)
#define ADC_CFGR_RES   ADC_CFGR_RES_Msk
#define ADC_CFGR_RES_0   (0x1UL << ADC_CFGR_RES_Pos)
#define ADC_CFGR_RES_1   (0x2UL << ADC_CFGR_RES_Pos)
#define ADC_CFGR_RES_2   (0x4UL << ADC_CFGR_RES_Pos)
#define ADC_CFGR_EXTSEL_Pos   (5U)
#define ADC_CFGR_EXTSEL_Msk   (0x1FUL << ADC_CFGR_EXTSEL_Pos)
#define ADC_CFGR_EXTSEL   ADC_CFGR_EXTSEL_Msk
#define ADC_CFGR_EXTSEL_0   (0x01UL << ADC_CFGR_EXTSEL_Pos)
#define ADC_CFGR_EXTSEL_1   (0x02UL << ADC_CFGR_EXTSEL_Pos)
#define ADC_CFGR_EXTSEL_2   (0x04UL << ADC_CFGR_EXTSEL_Pos)
#define ADC_CFGR_EXTSEL_3   (0x08UL << ADC_CFGR_EXTSEL_Pos)
#define ADC_CFGR_EXTSEL_4   (0x10UL << ADC_CFGR_EXTSEL_Pos)
#define ADC_CFGR_EXTEN_Pos   (10U)
#define ADC_CFGR_EXTEN_Msk   (0x3UL << ADC_CFGR_EXTEN_Pos)
#define ADC_CFGR_EXTEN   ADC_CFGR_EXTEN_Msk
#define ADC_CFGR_EXTEN_0   (0x1UL << ADC_CFGR_EXTEN_Pos)
#define ADC_CFGR_EXTEN_1   (0x2UL << ADC_CFGR_EXTEN_Pos)
#define ADC_CFGR_OVRMOD_Pos   (12U)
#define ADC_CFGR_OVRMOD_Msk   (0x1UL << ADC_CFGR_OVRMOD_Pos)
#define ADC_CFGR_OVRMOD   ADC_CFGR_OVRMOD_Msk
#define ADC_CFGR_CONT_Pos   (13U)
#define ADC_CFGR_CONT_Msk   (0x1UL << ADC_CFGR_CONT_Pos)
#define ADC_CFGR_CONT   ADC_CFGR_CONT_Msk
#define ADC_CFGR_AUTDLY_Pos   (14U)
#define ADC_CFGR_AUTDLY_Msk   (0x1UL << ADC_CFGR_AUTDLY_Pos)
#define ADC_CFGR_AUTDLY   ADC_CFGR_AUTDLY_Msk
#define ADC_CFGR_DISCEN_Pos   (16U)
#define ADC_CFGR_DISCEN_Msk   (0x1UL << ADC_CFGR_DISCEN_Pos)
#define ADC_CFGR_DISCEN   ADC_CFGR_DISCEN_Msk
#define ADC_CFGR_DISCNUM_Pos   (17U)
#define ADC_CFGR_DISCNUM_Msk   (0x7UL << ADC_CFGR_DISCNUM_Pos)
#define ADC_CFGR_DISCNUM   ADC_CFGR_DISCNUM_Msk
#define ADC_CFGR_DISCNUM_0   (0x1UL << ADC_CFGR_DISCNUM_Pos)
#define ADC_CFGR_DISCNUM_1   (0x2UL << ADC_CFGR_DISCNUM_Pos)
#define ADC_CFGR_DISCNUM_2   (0x4UL << ADC_CFGR_DISCNUM_Pos)
#define ADC_CFGR_JDISCEN_Pos   (20U)
#define ADC_CFGR_JDISCEN_Msk   (0x1UL << ADC_CFGR_JDISCEN_Pos)
#define ADC_CFGR_JDISCEN   ADC_CFGR_JDISCEN_Msk
#define ADC_CFGR_JQM_Pos   (21U)
#define ADC_CFGR_JQM_Msk   (0x1UL << ADC_CFGR_JQM_Pos)
#define ADC_CFGR_JQM   ADC_CFGR_JQM_Msk
#define ADC_CFGR_AWD1SGL_Pos   (22U)
#define ADC_CFGR_AWD1SGL_Msk   (0x1UL << ADC_CFGR_AWD1SGL_Pos)
#define ADC_CFGR_AWD1SGL   ADC_CFGR_AWD1SGL_Msk
#define ADC_CFGR_AWD1EN_Pos   (23U)
#define ADC_CFGR_AWD1EN_Msk   (0x1UL << ADC_CFGR_AWD1EN_Pos)
#define ADC_CFGR_AWD1EN   ADC_CFGR_AWD1EN_Msk
#define ADC_CFGR_JAWD1EN_Pos   (24U)
#define ADC_CFGR_JAWD1EN_Msk   (0x1UL << ADC_CFGR_JAWD1EN_Pos)
#define ADC_CFGR_JAWD1EN   ADC_CFGR_JAWD1EN_Msk
#define ADC_CFGR_JAUTO_Pos   (25U)
#define ADC_CFGR_JAUTO_Msk   (0x1UL << ADC_CFGR_JAUTO_Pos)
#define ADC_CFGR_JAUTO   ADC_CFGR_JAUTO_Msk
#define ADC_CFGR_AWD1CH_Pos   (26U)
#define ADC_CFGR_AWD1CH_Msk   (0x1FUL << ADC_CFGR_AWD1CH_Pos)
#define ADC_CFGR_AWD1CH   ADC_CFGR_AWD1CH_Msk
#define ADC_CFGR_AWD1CH_0   (0x01UL << ADC_CFGR_AWD1CH_Pos)
#define ADC_CFGR_AWD1CH_1   (0x02UL << ADC_CFGR_AWD1CH_Pos)
#define ADC_CFGR_AWD1CH_2   (0x04UL << ADC_CFGR_AWD1CH_Pos)
#define ADC_CFGR_AWD1CH_3   (0x08UL << ADC_CFGR_AWD1CH_Pos)
#define ADC_CFGR_AWD1CH_4   (0x10UL << ADC_CFGR_AWD1CH_Pos)
#define ADC_CFGR_JQDIS_Pos   (31U)
#define ADC_CFGR_JQDIS_Msk   (0x1UL << ADC_CFGR_JQDIS_Pos)
#define ADC_CFGR_JQDIS   ADC_CFGR_JQDIS_Msk
#define ADC_CFGR2_ROVSE_Pos   (0U)
#define ADC_CFGR2_ROVSE_Msk   (0x1UL << ADC_CFGR2_ROVSE_Pos)
#define ADC_CFGR2_ROVSE   ADC_CFGR2_ROVSE_Msk
#define ADC_CFGR2_JOVSE_Pos   (1U)
#define ADC_CFGR2_JOVSE_Msk   (0x1UL << ADC_CFGR2_JOVSE_Pos)
#define ADC_CFGR2_JOVSE   ADC_CFGR2_JOVSE_Msk
#define ADC_CFGR2_OVSS_Pos   (5U)
#define ADC_CFGR2_OVSS_Msk   (0xFUL << ADC_CFGR2_OVSS_Pos)
#define ADC_CFGR2_OVSS   ADC_CFGR2_OVSS_Msk
#define ADC_CFGR2_OVSS_0   (0x1UL << ADC_CFGR2_OVSS_Pos)
#define ADC_CFGR2_OVSS_1   (0x2UL << ADC_CFGR2_OVSS_Pos)
#define ADC_CFGR2_OVSS_2   (0x4UL << ADC_CFGR2_OVSS_Pos)
#define ADC_CFGR2_OVSS_3   (0x8UL << ADC_CFGR2_OVSS_Pos)
#define ADC_CFGR2_TROVS_Pos   (9U)
#define ADC_CFGR2_TROVS_Msk   (0x1UL << ADC_CFGR2_TROVS_Pos)
#define ADC_CFGR2_TROVS   ADC_CFGR2_TROVS_Msk
#define ADC_CFGR2_ROVSM_Pos   (10U)
#define ADC_CFGR2_ROVSM_Msk   (0x1UL << ADC_CFGR2_ROVSM_Pos)
#define ADC_CFGR2_ROVSM   ADC_CFGR2_ROVSM_Msk
#define ADC_CFGR2_RSHIFT1_Pos   (11U)
#define ADC_CFGR2_RSHIFT1_Msk   (0x1UL << ADC_CFGR2_RSHIFT1_Pos)
#define ADC_CFGR2_RSHIFT1   ADC_CFGR2_RSHIFT1_Msk
#define ADC_CFGR2_RSHIFT2_Pos   (12U)
#define ADC_CFGR2_RSHIFT2_Msk   (0x1UL << ADC_CFGR2_RSHIFT2_Pos)
#define ADC_CFGR2_RSHIFT2   ADC_CFGR2_RSHIFT2_Msk
#define ADC_CFGR2_RSHIFT3_Pos   (13U)
#define ADC_CFGR2_RSHIFT3_Msk   (0x1UL << ADC_CFGR2_RSHIFT3_Pos)
#define ADC_CFGR2_RSHIFT3   ADC_CFGR2_RSHIFT3_Msk
#define ADC_CFGR2_RSHIFT4_Pos   (14U)
#define ADC_CFGR2_RSHIFT4_Msk   (0x1UL << ADC_CFGR2_RSHIFT4_Pos)
#define ADC_CFGR2_RSHIFT4   ADC_CFGR2_RSHIFT4_Msk
#define ADC_CFGR2_OVSR_Pos   (16U)
#define ADC_CFGR2_OVSR_Msk   (0x3FFUL << ADC_CFGR2_OVSR_Pos)
#define ADC_CFGR2_OVSR   ADC_CFGR2_OVSR_Msk
#define ADC_CFGR2_OVSR_0   (0x001UL << ADC_CFGR2_OVSR_Pos)
#define ADC_CFGR2_OVSR_1   (0x002UL << ADC_CFGR2_OVSR_Pos)
#define ADC_CFGR2_OVSR_2   (0x004UL << ADC_CFGR2_OVSR_Pos)
#define ADC_CFGR2_OVSR_3   (0x008UL << ADC_CFGR2_OVSR_Pos)
#define ADC_CFGR2_OVSR_4   (0x010UL << ADC_CFGR2_OVSR_Pos)
#define ADC_CFGR2_OVSR_5   (0x020UL << ADC_CFGR2_OVSR_Pos)
#define ADC_CFGR2_OVSR_6   (0x040UL << ADC_CFGR2_OVSR_Pos)
#define ADC_CFGR2_OVSR_7   (0x080UL << ADC_CFGR2_OVSR_Pos)
#define ADC_CFGR2_OVSR_8   (0x100UL << ADC_CFGR2_OVSR_Pos)
#define ADC_CFGR2_OVSR_9   (0x200UL << ADC_CFGR2_OVSR_Pos)
#define ADC_CFGR2_LSHIFT_Pos   (28U)
#define ADC_CFGR2_LSHIFT_Msk   (0xFUL << ADC_CFGR2_LSHIFT_Pos)
#define ADC_CFGR2_LSHIFT   ADC_CFGR2_LSHIFT_Msk
#define ADC_CFGR2_LSHIFT_0   (0x1UL << ADC_CFGR2_LSHIFT_Pos)
#define ADC_CFGR2_LSHIFT_1   (0x2UL << ADC_CFGR2_LSHIFT_Pos)
#define ADC_CFGR2_LSHIFT_2   (0x4UL << ADC_CFGR2_LSHIFT_Pos)
#define ADC_CFGR2_LSHIFT_3   (0x8UL << ADC_CFGR2_LSHIFT_Pos)
#define ADC_SMPR1_SMP0_Pos   (0U)
#define ADC_SMPR1_SMP0_Msk   (0x7UL << ADC_SMPR1_SMP0_Pos)
#define ADC_SMPR1_SMP0   ADC_SMPR1_SMP0_Msk
#define ADC_SMPR1_SMP0_0   (0x1UL << ADC_SMPR1_SMP0_Pos)
#define ADC_SMPR1_SMP0_1   (0x2UL << ADC_SMPR1_SMP0_Pos)
#define ADC_SMPR1_SMP0_2   (0x4UL << ADC_SMPR1_SMP0_Pos)
#define ADC_SMPR1_SMP1_Pos   (3U)
#define ADC_SMPR1_SMP1_Msk   (0x7UL << ADC_SMPR1_SMP1_Pos)
#define ADC_SMPR1_SMP1   ADC_SMPR1_SMP1_Msk
#define ADC_SMPR1_SMP1_0   (0x1UL << ADC_SMPR1_SMP1_Pos)
#define ADC_SMPR1_SMP1_1   (0x2UL << ADC_SMPR1_SMP1_Pos)
#define ADC_SMPR1_SMP1_2   (0x4UL << ADC_SMPR1_SMP1_Pos)
#define ADC_SMPR1_SMP2_Pos   (6U)
#define ADC_SMPR1_SMP2_Msk   (0x7UL << ADC_SMPR1_SMP2_Pos)
#define ADC_SMPR1_SMP2   ADC_SMPR1_SMP2_Msk
#define ADC_SMPR1_SMP2_0   (0x1UL << ADC_SMPR1_SMP2_Pos)
#define ADC_SMPR1_SMP2_1   (0x2UL << ADC_SMPR1_SMP2_Pos)
#define ADC_SMPR1_SMP2_2   (0x4UL << ADC_SMPR1_SMP2_Pos)
#define ADC_SMPR1_SMP3_Pos   (9U)
#define ADC_SMPR1_SMP3_Msk   (0x7UL << ADC_SMPR1_SMP3_Pos)
#define ADC_SMPR1_SMP3   ADC_SMPR1_SMP3_Msk
#define ADC_SMPR1_SMP3_0   (0x1UL << ADC_SMPR1_SMP3_Pos)
#define ADC_SMPR1_SMP3_1   (0x2UL << ADC_SMPR1_SMP3_Pos)
#define ADC_SMPR1_SMP3_2   (0x4UL << ADC_SMPR1_SMP3_Pos)
#define ADC_SMPR1_SMP4_Pos   (12U)
#define ADC_SMPR1_SMP4_Msk   (0x7UL << ADC_SMPR1_SMP4_Pos)
#define ADC_SMPR1_SMP4   ADC_SMPR1_SMP4_Msk
#define ADC_SMPR1_SMP4_0   (0x1UL << ADC_SMPR1_SMP4_Pos)
#define ADC_SMPR1_SMP4_1   (0x2UL << ADC_SMPR1_SMP4_Pos)
#define ADC_SMPR1_SMP4_2   (0x4UL << ADC_SMPR1_SMP4_Pos)
#define ADC_SMPR1_SMP5_Pos   (15U)
#define ADC_SMPR1_SMP5_Msk   (0x7UL << ADC_SMPR1_SMP5_Pos)
#define ADC_SMPR1_SMP5   ADC_SMPR1_SMP5_Msk
#define ADC_SMPR1_SMP5_0   (0x1UL << ADC_SMPR1_SMP5_Pos)
#define ADC_SMPR1_SMP5_1   (0x2UL << ADC_SMPR1_SMP5_Pos)
#define ADC_SMPR1_SMP5_2   (0x4UL << ADC_SMPR1_SMP5_Pos)
#define ADC_SMPR1_SMP6_Pos   (18U)
#define ADC_SMPR1_SMP6_Msk   (0x7UL << ADC_SMPR1_SMP6_Pos)
#define ADC_SMPR1_SMP6   ADC_SMPR1_SMP6_Msk
#define ADC_SMPR1_SMP6_0   (0x1UL << ADC_SMPR1_SMP6_Pos)
#define ADC_SMPR1_SMP6_1   (0x2UL << ADC_SMPR1_SMP6_Pos)
#define ADC_SMPR1_SMP6_2   (0x4UL << ADC_SMPR1_SMP6_Pos)
#define ADC_SMPR1_SMP7_Pos   (21U)
#define ADC_SMPR1_SMP7_Msk   (0x7UL << ADC_SMPR1_SMP7_Pos)
#define ADC_SMPR1_SMP7   ADC_SMPR1_SMP7_Msk
#define ADC_SMPR1_SMP7_0   (0x1UL << ADC_SMPR1_SMP7_Pos)
#define ADC_SMPR1_SMP7_1   (0x2UL << ADC_SMPR1_SMP7_Pos)
#define ADC_SMPR1_SMP7_2   (0x4UL << ADC_SMPR1_SMP7_Pos)
#define ADC_SMPR1_SMP8_Pos   (24U)
#define ADC_SMPR1_SMP8_Msk   (0x7UL << ADC_SMPR1_SMP8_Pos)
#define ADC_SMPR1_SMP8   ADC_SMPR1_SMP8_Msk
#define ADC_SMPR1_SMP8_0   (0x1UL << ADC_SMPR1_SMP8_Pos)
#define ADC_SMPR1_SMP8_1   (0x2UL << ADC_SMPR1_SMP8_Pos)
#define ADC_SMPR1_SMP8_2   (0x4UL << ADC_SMPR1_SMP8_Pos)
#define ADC_SMPR1_SMP9_Pos   (27U)
#define ADC_SMPR1_SMP9_Msk   (0x7UL << ADC_SMPR1_SMP9_Pos)
#define ADC_SMPR1_SMP9   ADC_SMPR1_SMP9_Msk
#define ADC_SMPR1_SMP9_0   (0x1UL << ADC_SMPR1_SMP9_Pos)
#define ADC_SMPR1_SMP9_1   (0x2UL << ADC_SMPR1_SMP9_Pos)
#define ADC_SMPR1_SMP9_2   (0x4UL << ADC_SMPR1_SMP9_Pos)
#define ADC_SMPR2_SMP10_Pos   (0U)
#define ADC_SMPR2_SMP10_Msk   (0x7UL << ADC_SMPR2_SMP10_Pos)
#define ADC_SMPR2_SMP10   ADC_SMPR2_SMP10_Msk
#define ADC_SMPR2_SMP10_0   (0x1UL << ADC_SMPR2_SMP10_Pos)
#define ADC_SMPR2_SMP10_1   (0x2UL << ADC_SMPR2_SMP10_Pos)
#define ADC_SMPR2_SMP10_2   (0x4UL << ADC_SMPR2_SMP10_Pos)
#define ADC_SMPR2_SMP11_Pos   (3U)
#define ADC_SMPR2_SMP11_Msk   (0x7UL << ADC_SMPR2_SMP11_Pos)
#define ADC_SMPR2_SMP11   ADC_SMPR2_SMP11_Msk
#define ADC_SMPR2_SMP11_0   (0x1UL << ADC_SMPR2_SMP11_Pos)
#define ADC_SMPR2_SMP11_1   (0x2UL << ADC_SMPR2_SMP11_Pos)
#define ADC_SMPR2_SMP11_2   (0x4UL << ADC_SMPR2_SMP11_Pos)
#define ADC_SMPR2_SMP12_Pos   (6U)
#define ADC_SMPR2_SMP12_Msk   (0x7UL << ADC_SMPR2_SMP12_Pos)
#define ADC_SMPR2_SMP12   ADC_SMPR2_SMP12_Msk
#define ADC_SMPR2_SMP12_0   (0x1UL << ADC_SMPR2_SMP12_Pos)
#define ADC_SMPR2_SMP12_1   (0x2UL << ADC_SMPR2_SMP12_Pos)
#define ADC_SMPR2_SMP12_2   (0x4UL << ADC_SMPR2_SMP12_Pos)
#define ADC_SMPR2_SMP13_Pos   (9U)
#define ADC_SMPR2_SMP13_Msk   (0x7UL << ADC_SMPR2_SMP13_Pos)
#define ADC_SMPR2_SMP13   ADC_SMPR2_SMP13_Msk
#define ADC_SMPR2_SMP13_0   (0x1UL << ADC_SMPR2_SMP13_Pos)
#define ADC_SMPR2_SMP13_1   (0x2UL << ADC_SMPR2_SMP13_Pos)
#define ADC_SMPR2_SMP13_2   (0x4UL << ADC_SMPR2_SMP13_Pos)
#define ADC_SMPR2_SMP14_Pos   (12U)
#define ADC_SMPR2_SMP14_Msk   (0x7UL << ADC_SMPR2_SMP14_Pos)
#define ADC_SMPR2_SMP14   ADC_SMPR2_SMP14_Msk
#define ADC_SMPR2_SMP14_0   (0x1UL << ADC_SMPR2_SMP14_Pos)
#define ADC_SMPR2_SMP14_1   (0x2UL << ADC_SMPR2_SMP14_Pos)
#define ADC_SMPR2_SMP14_2   (0x4UL << ADC_SMPR2_SMP14_Pos)
#define ADC_SMPR2_SMP15_Pos   (15U)
#define ADC_SMPR2_SMP15_Msk   (0x7UL << ADC_SMPR2_SMP15_Pos)
#define ADC_SMPR2_SMP15   ADC_SMPR2_SMP15_Msk
#define ADC_SMPR2_SMP15_0   (0x1UL << ADC_SMPR2_SMP15_Pos)
#define ADC_SMPR2_SMP15_1   (0x2UL << ADC_SMPR2_SMP15_Pos)
#define ADC_SMPR2_SMP15_2   (0x4UL << ADC_SMPR2_SMP15_Pos)
#define ADC_SMPR2_SMP16_Pos   (18U)
#define ADC_SMPR2_SMP16_Msk   (0x7UL << ADC_SMPR2_SMP16_Pos)
#define ADC_SMPR2_SMP16   ADC_SMPR2_SMP16_Msk
#define ADC_SMPR2_SMP16_0   (0x1UL << ADC_SMPR2_SMP16_Pos)
#define ADC_SMPR2_SMP16_1   (0x2UL << ADC_SMPR2_SMP16_Pos)
#define ADC_SMPR2_SMP16_2   (0x4UL << ADC_SMPR2_SMP16_Pos)
#define ADC_SMPR2_SMP17_Pos   (21U)
#define ADC_SMPR2_SMP17_Msk   (0x7UL << ADC_SMPR2_SMP17_Pos)
#define ADC_SMPR2_SMP17   ADC_SMPR2_SMP17_Msk
#define ADC_SMPR2_SMP17_0   (0x1UL << ADC_SMPR2_SMP17_Pos)
#define ADC_SMPR2_SMP17_1   (0x2UL << ADC_SMPR2_SMP17_Pos)
#define ADC_SMPR2_SMP17_2   (0x4UL << ADC_SMPR2_SMP17_Pos)
#define ADC_SMPR2_SMP18_Pos   (24U)
#define ADC_SMPR2_SMP18_Msk   (0x7UL << ADC_SMPR2_SMP18_Pos)
#define ADC_SMPR2_SMP18   ADC_SMPR2_SMP18_Msk
#define ADC_SMPR2_SMP18_0   (0x1UL << ADC_SMPR2_SMP18_Pos)
#define ADC_SMPR2_SMP18_1   (0x2UL << ADC_SMPR2_SMP18_Pos)
#define ADC_SMPR2_SMP18_2   (0x4UL << ADC_SMPR2_SMP18_Pos)
#define ADC_SMPR2_SMP19_Pos   (27U)
#define ADC_SMPR2_SMP19_Msk   (0x7UL << ADC_SMPR2_SMP19_Pos)
#define ADC_SMPR2_SMP19   ADC_SMPR2_SMP19_Msk
#define ADC_SMPR2_SMP19_0   (0x1UL << ADC_SMPR2_SMP19_Pos)
#define ADC_SMPR2_SMP19_1   (0x2UL << ADC_SMPR2_SMP19_Pos)
#define ADC_SMPR2_SMP19_2   (0x4UL << ADC_SMPR2_SMP19_Pos)
#define ADC_PCSEL_PCSEL_Pos   (0U)
#define ADC_PCSEL_PCSEL_Msk   (0xFFFFFUL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL   ADC_PCSEL_PCSEL_Msk
#define ADC_PCSEL_PCSEL_0   (0x00001UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_1   (0x00002UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_2   (0x00004UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_3   (0x00008UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_4   (0x00010UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_5   (0x00020UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_6   (0x00040UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_7   (0x00080UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_8   (0x00100UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_9   (0x00200UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_10   (0x00400UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_11   (0x00800UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_12   (0x01000UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_13   (0x02000UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_14   (0x04000UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_15   (0x08000UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_16   (0x10000UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_17   (0x20000UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_18   (0x40000UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_PCSEL_PCSEL_19   (0x80000UL << ADC_PCSEL_PCSEL_Pos)
#define ADC_LTR_LT_Pos   (0U)
#define ADC_LTR_LT_Msk   (0x3FFFFFFUL << ADC_LTR_LT_Pos)
#define ADC_LTR_LT   ADC_LTR_LT_Msk
#define ADC_HTR_HT_Pos   (0U)
#define ADC_HTR_HT_Msk   (0x3FFFFFFUL << ADC_HTR_HT_Pos)
#define ADC_HTR_HT   ADC_HTR_HT_Msk
#define ADC_SQR1_L_Pos   (0U)
#define ADC_SQR1_L_Msk   (0xFUL << ADC_SQR1_L_Pos)
#define ADC_SQR1_L   ADC_SQR1_L_Msk
#define ADC_SQR1_L_0   (0x1UL << ADC_SQR1_L_Pos)
#define ADC_SQR1_L_1   (0x2UL << ADC_SQR1_L_Pos)
#define ADC_SQR1_L_2   (0x4UL << ADC_SQR1_L_Pos)
#define ADC_SQR1_L_3   (0x8UL << ADC_SQR1_L_Pos)
#define ADC_SQR1_SQ1_Pos   (6U)
#define ADC_SQR1_SQ1_Msk   (0x1FUL << ADC_SQR1_SQ1_Pos)
#define ADC_SQR1_SQ1   ADC_SQR1_SQ1_Msk
#define ADC_SQR1_SQ1_0   (0x01UL << ADC_SQR1_SQ1_Pos)
#define ADC_SQR1_SQ1_1   (0x02UL << ADC_SQR1_SQ1_Pos)
#define ADC_SQR1_SQ1_2   (0x04UL << ADC_SQR1_SQ1_Pos)
#define ADC_SQR1_SQ1_3   (0x08UL << ADC_SQR1_SQ1_Pos)
#define ADC_SQR1_SQ1_4   (0x10UL << ADC_SQR1_SQ1_Pos)
#define ADC_SQR1_SQ2_Pos   (12U)
#define ADC_SQR1_SQ2_Msk   (0x1FUL << ADC_SQR1_SQ2_Pos)
#define ADC_SQR1_SQ2   ADC_SQR1_SQ2_Msk
#define ADC_SQR1_SQ2_0   (0x01UL << ADC_SQR1_SQ2_Pos)
#define ADC_SQR1_SQ2_1   (0x02UL << ADC_SQR1_SQ2_Pos)
#define ADC_SQR1_SQ2_2   (0x04UL << ADC_SQR1_SQ2_Pos)
#define ADC_SQR1_SQ2_3   (0x08UL << ADC_SQR1_SQ2_Pos)
#define ADC_SQR1_SQ2_4   (0x10UL << ADC_SQR1_SQ2_Pos)
#define ADC_SQR1_SQ3_Pos   (18U)
#define ADC_SQR1_SQ3_Msk   (0x1FUL << ADC_SQR1_SQ3_Pos)
#define ADC_SQR1_SQ3   ADC_SQR1_SQ3_Msk
#define ADC_SQR1_SQ3_0   (0x01UL << ADC_SQR1_SQ3_Pos)
#define ADC_SQR1_SQ3_1   (0x02UL << ADC_SQR1_SQ3_Pos)
#define ADC_SQR1_SQ3_2   (0x04UL << ADC_SQR1_SQ3_Pos)
#define ADC_SQR1_SQ3_3   (0x08UL << ADC_SQR1_SQ3_Pos)
#define ADC_SQR1_SQ3_4   (0x10UL << ADC_SQR1_SQ3_Pos)
#define ADC_SQR1_SQ4_Pos   (24U)
#define ADC_SQR1_SQ4_Msk   (0x1FUL << ADC_SQR1_SQ4_Pos)
#define ADC_SQR1_SQ4   ADC_SQR1_SQ4_Msk
#define ADC_SQR1_SQ4_0   (0x01UL << ADC_SQR1_SQ4_Pos)
#define ADC_SQR1_SQ4_1   (0x02UL << ADC_SQR1_SQ4_Pos)
#define ADC_SQR1_SQ4_2   (0x04UL << ADC_SQR1_SQ4_Pos)
#define ADC_SQR1_SQ4_3   (0x08UL << ADC_SQR1_SQ4_Pos)
#define ADC_SQR1_SQ4_4   (0x10UL << ADC_SQR1_SQ4_Pos)
#define ADC_SQR2_SQ5_Pos   (0U)
#define ADC_SQR2_SQ5_Msk   (0x1FUL << ADC_SQR2_SQ5_Pos)
#define ADC_SQR2_SQ5   ADC_SQR2_SQ5_Msk
#define ADC_SQR2_SQ5_0   (0x01UL << ADC_SQR2_SQ5_Pos)
#define ADC_SQR2_SQ5_1   (0x02UL << ADC_SQR2_SQ5_Pos)
#define ADC_SQR2_SQ5_2   (0x04UL << ADC_SQR2_SQ5_Pos)
#define ADC_SQR2_SQ5_3   (0x08UL << ADC_SQR2_SQ5_Pos)
#define ADC_SQR2_SQ5_4   (0x10UL << ADC_SQR2_SQ5_Pos)
#define ADC_SQR2_SQ6_Pos   (6U)
#define ADC_SQR2_SQ6_Msk   (0x1FUL << ADC_SQR2_SQ6_Pos)
#define ADC_SQR2_SQ6   ADC_SQR2_SQ6_Msk
#define ADC_SQR2_SQ6_0   (0x01UL << ADC_SQR2_SQ6_Pos)
#define ADC_SQR2_SQ6_1   (0x02UL << ADC_SQR2_SQ6_Pos)
#define ADC_SQR2_SQ6_2   (0x04UL << ADC_SQR2_SQ6_Pos)
#define ADC_SQR2_SQ6_3   (0x08UL << ADC_SQR2_SQ6_Pos)
#define ADC_SQR2_SQ6_4   (0x10UL << ADC_SQR2_SQ6_Pos)
#define ADC_SQR2_SQ7_Pos   (12U)
#define ADC_SQR2_SQ7_Msk   (0x1FUL << ADC_SQR2_SQ7_Pos)
#define ADC_SQR2_SQ7   ADC_SQR2_SQ7_Msk
#define ADC_SQR2_SQ7_0   (0x01UL << ADC_SQR2_SQ7_Pos)
#define ADC_SQR2_SQ7_1   (0x02UL << ADC_SQR2_SQ7_Pos)
#define ADC_SQR2_SQ7_2   (0x04UL << ADC_SQR2_SQ7_Pos)
#define ADC_SQR2_SQ7_3   (0x08UL << ADC_SQR2_SQ7_Pos)
#define ADC_SQR2_SQ7_4   (0x10UL << ADC_SQR2_SQ7_Pos)
#define ADC_SQR2_SQ8_Pos   (18U)
#define ADC_SQR2_SQ8_Msk   (0x1FUL << ADC_SQR2_SQ8_Pos)
#define ADC_SQR2_SQ8   ADC_SQR2_SQ8_Msk
#define ADC_SQR2_SQ8_0   (0x01UL << ADC_SQR2_SQ8_Pos)
#define ADC_SQR2_SQ8_1   (0x02UL << ADC_SQR2_SQ8_Pos)
#define ADC_SQR2_SQ8_2   (0x04UL << ADC_SQR2_SQ8_Pos)
#define ADC_SQR2_SQ8_3   (0x08UL << ADC_SQR2_SQ8_Pos)
#define ADC_SQR2_SQ8_4   (0x10UL << ADC_SQR2_SQ8_Pos)
#define ADC_SQR2_SQ9_Pos   (24U)
#define ADC_SQR2_SQ9_Msk   (0x1FUL << ADC_SQR2_SQ9_Pos)
#define ADC_SQR2_SQ9   ADC_SQR2_SQ9_Msk
#define ADC_SQR2_SQ9_0   (0x01UL << ADC_SQR2_SQ9_Pos)
#define ADC_SQR2_SQ9_1   (0x02UL << ADC_SQR2_SQ9_Pos)
#define ADC_SQR2_SQ9_2   (0x04UL << ADC_SQR2_SQ9_Pos)
#define ADC_SQR2_SQ9_3   (0x08UL << ADC_SQR2_SQ9_Pos)
#define ADC_SQR2_SQ9_4   (0x10UL << ADC_SQR2_SQ9_Pos)
#define ADC_SQR3_SQ10_Pos   (0U)
#define ADC_SQR3_SQ10_Msk   (0x1FUL << ADC_SQR3_SQ10_Pos)
#define ADC_SQR3_SQ10   ADC_SQR3_SQ10_Msk
#define ADC_SQR3_SQ10_0   (0x01UL << ADC_SQR3_SQ10_Pos)
#define ADC_SQR3_SQ10_1   (0x02UL << ADC_SQR3_SQ10_Pos)
#define ADC_SQR3_SQ10_2   (0x04UL << ADC_SQR3_SQ10_Pos)
#define ADC_SQR3_SQ10_3   (0x08UL << ADC_SQR3_SQ10_Pos)
#define ADC_SQR3_SQ10_4   (0x10UL << ADC_SQR3_SQ10_Pos)
#define ADC_SQR3_SQ11_Pos   (6U)
#define ADC_SQR3_SQ11_Msk   (0x1FUL << ADC_SQR3_SQ11_Pos)
#define ADC_SQR3_SQ11   ADC_SQR3_SQ11_Msk
#define ADC_SQR3_SQ11_0   (0x01UL << ADC_SQR3_SQ11_Pos)
#define ADC_SQR3_SQ11_1   (0x02UL << ADC_SQR3_SQ11_Pos)
#define ADC_SQR3_SQ11_2   (0x04UL << ADC_SQR3_SQ11_Pos)
#define ADC_SQR3_SQ11_3   (0x08UL << ADC_SQR3_SQ11_Pos)
#define ADC_SQR3_SQ11_4   (0x10UL << ADC_SQR3_SQ11_Pos)
#define ADC_SQR3_SQ12_Pos   (12U)
#define ADC_SQR3_SQ12_Msk   (0x1FUL << ADC_SQR3_SQ12_Pos)
#define ADC_SQR3_SQ12   ADC_SQR3_SQ12_Msk
#define ADC_SQR3_SQ12_0   (0x01UL << ADC_SQR3_SQ12_Pos)
#define ADC_SQR3_SQ12_1   (0x02UL << ADC_SQR3_SQ12_Pos)
#define ADC_SQR3_SQ12_2   (0x04UL << ADC_SQR3_SQ12_Pos)
#define ADC_SQR3_SQ12_3   (0x08UL << ADC_SQR3_SQ12_Pos)
#define ADC_SQR3_SQ12_4   (0x10UL << ADC_SQR3_SQ12_Pos)
#define ADC_SQR3_SQ13_Pos   (18U)
#define ADC_SQR3_SQ13_Msk   (0x1FUL << ADC_SQR3_SQ13_Pos)
#define ADC_SQR3_SQ13   ADC_SQR3_SQ13_Msk
#define ADC_SQR3_SQ13_0   (0x01UL << ADC_SQR3_SQ13_Pos)
#define ADC_SQR3_SQ13_1   (0x02UL << ADC_SQR3_SQ13_Pos)
#define ADC_SQR3_SQ13_2   (0x04UL << ADC_SQR3_SQ13_Pos)
#define ADC_SQR3_SQ13_3   (0x08UL << ADC_SQR3_SQ13_Pos)
#define ADC_SQR3_SQ13_4   (0x10UL << ADC_SQR3_SQ13_Pos)
#define ADC_SQR3_SQ14_Pos   (24U)
#define ADC_SQR3_SQ14_Msk   (0x1FUL << ADC_SQR3_SQ14_Pos)
#define ADC_SQR3_SQ14   ADC_SQR3_SQ14_Msk
#define ADC_SQR3_SQ14_0   (0x01UL << ADC_SQR3_SQ14_Pos)
#define ADC_SQR3_SQ14_1   (0x02UL << ADC_SQR3_SQ14_Pos)
#define ADC_SQR3_SQ14_2   (0x04UL << ADC_SQR3_SQ14_Pos)
#define ADC_SQR3_SQ14_3   (0x08UL << ADC_SQR3_SQ14_Pos)
#define ADC_SQR3_SQ14_4   (0x10UL << ADC_SQR3_SQ14_Pos)
#define ADC_SQR4_SQ15_Pos   (0U)
#define ADC_SQR4_SQ15_Msk   (0x1FUL << ADC_SQR4_SQ15_Pos)
#define ADC_SQR4_SQ15   ADC_SQR4_SQ15_Msk
#define ADC_SQR4_SQ15_0   (0x01UL << ADC_SQR4_SQ15_Pos)
#define ADC_SQR4_SQ15_1   (0x02UL << ADC_SQR4_SQ15_Pos)
#define ADC_SQR4_SQ15_2   (0x04UL << ADC_SQR4_SQ15_Pos)
#define ADC_SQR4_SQ15_3   (0x08UL << ADC_SQR4_SQ15_Pos)
#define ADC_SQR4_SQ15_4   (0x10UL << ADC_SQR4_SQ15_Pos)
#define ADC_SQR4_SQ16_Pos   (6U)
#define ADC_SQR4_SQ16_Msk   (0x1FUL << ADC_SQR4_SQ16_Pos)
#define ADC_SQR4_SQ16   ADC_SQR4_SQ16_Msk
#define ADC_SQR4_SQ16_0   (0x01UL << ADC_SQR4_SQ16_Pos)
#define ADC_SQR4_SQ16_1   (0x02UL << ADC_SQR4_SQ16_Pos)
#define ADC_SQR4_SQ16_2   (0x04UL << ADC_SQR4_SQ16_Pos)
#define ADC_SQR4_SQ16_3   (0x08UL << ADC_SQR4_SQ16_Pos)
#define ADC_SQR4_SQ16_4   (0x10UL << ADC_SQR4_SQ16_Pos)
#define ADC_DR_RDATA_Pos   (0U)
#define ADC_DR_RDATA_Msk   (0xFFFFFFFFUL << ADC_DR_RDATA_Pos)
#define ADC_DR_RDATA   ADC_DR_RDATA_Msk
#define ADC_JSQR_JL_Pos   (0U)
#define ADC_JSQR_JL_Msk   (0x3UL << ADC_JSQR_JL_Pos)
#define ADC_JSQR_JL   ADC_JSQR_JL_Msk
#define ADC_JSQR_JL_0   (0x1UL << ADC_JSQR_JL_Pos)
#define ADC_JSQR_JL_1   (0x2UL << ADC_JSQR_JL_Pos)
#define ADC_JSQR_JEXTSEL_Pos   (2U)
#define ADC_JSQR_JEXTSEL_Msk   (0x1FUL << ADC_JSQR_JEXTSEL_Pos)
#define ADC_JSQR_JEXTSEL   ADC_JSQR_JEXTSEL_Msk
#define ADC_JSQR_JEXTSEL_0   (0x01UL << ADC_JSQR_JEXTSEL_Pos)
#define ADC_JSQR_JEXTSEL_1   (0x02UL << ADC_JSQR_JEXTSEL_Pos)
#define ADC_JSQR_JEXTSEL_2   (0x04UL << ADC_JSQR_JEXTSEL_Pos)
#define ADC_JSQR_JEXTSEL_3   (0x08UL << ADC_JSQR_JEXTSEL_Pos)
#define ADC_JSQR_JEXTSEL_4   (0x10UL << ADC_JSQR_JEXTSEL_Pos)
#define ADC_JSQR_JEXTEN_Pos   (7U)
#define ADC_JSQR_JEXTEN_Msk   (0x3UL << ADC_JSQR_JEXTEN_Pos)
#define ADC_JSQR_JEXTEN   ADC_JSQR_JEXTEN_Msk
#define ADC_JSQR_JEXTEN_0   (0x1UL << ADC_JSQR_JEXTEN_Pos)
#define ADC_JSQR_JEXTEN_1   (0x2UL << ADC_JSQR_JEXTEN_Pos)
#define ADC_JSQR_JSQ1_Pos   (9U)
#define ADC_JSQR_JSQ1_Msk   (0x1FUL << ADC_JSQR_JSQ1_Pos)
#define ADC_JSQR_JSQ1   ADC_JSQR_JSQ1_Msk
#define ADC_JSQR_JSQ1_0   (0x01UL << ADC_JSQR_JSQ1_Pos)
#define ADC_JSQR_JSQ1_1   (0x02UL << ADC_JSQR_JSQ1_Pos)
#define ADC_JSQR_JSQ1_2   (0x04UL << ADC_JSQR_JSQ1_Pos)
#define ADC_JSQR_JSQ1_3   (0x08UL << ADC_JSQR_JSQ1_Pos)
#define ADC_JSQR_JSQ1_4   (0x10UL << ADC_JSQR_JSQ1_Pos)
#define ADC_JSQR_JSQ2_Pos   (15U)
#define ADC_JSQR_JSQ2_Msk   (0x1FUL << ADC_JSQR_JSQ2_Pos)
#define ADC_JSQR_JSQ2   ADC_JSQR_JSQ2_Msk
#define ADC_JSQR_JSQ2_0   (0x01UL << ADC_JSQR_JSQ2_Pos)
#define ADC_JSQR_JSQ2_1   (0x02UL << ADC_JSQR_JSQ2_Pos)
#define ADC_JSQR_JSQ2_2   (0x04UL << ADC_JSQR_JSQ2_Pos)
#define ADC_JSQR_JSQ2_3   (0x08UL << ADC_JSQR_JSQ2_Pos)
#define ADC_JSQR_JSQ2_4   (0x10UL << ADC_JSQR_JSQ2_Pos)
#define ADC_JSQR_JSQ3_Pos   (21U)
#define ADC_JSQR_JSQ3_Msk   (0x1FUL << ADC_JSQR_JSQ3_Pos)
#define ADC_JSQR_JSQ3   ADC_JSQR_JSQ3_Msk
#define ADC_JSQR_JSQ3_0   (0x01UL << ADC_JSQR_JSQ3_Pos)
#define ADC_JSQR_JSQ3_1   (0x02UL << ADC_JSQR_JSQ3_Pos)
#define ADC_JSQR_JSQ3_2   (0x04UL << ADC_JSQR_JSQ3_Pos)
#define ADC_JSQR_JSQ3_3   (0x08UL << ADC_JSQR_JSQ3_Pos)
#define ADC_JSQR_JSQ3_4   (0x10UL << ADC_JSQR_JSQ3_Pos)
#define ADC_JSQR_JSQ4_Pos   (27U)
#define ADC_JSQR_JSQ4_Msk   (0x1FUL << ADC_JSQR_JSQ4_Pos)
#define ADC_JSQR_JSQ4   ADC_JSQR_JSQ4_Msk
#define ADC_JSQR_JSQ4_0   (0x01UL << ADC_JSQR_JSQ4_Pos)
#define ADC_JSQR_JSQ4_1   (0x02UL << ADC_JSQR_JSQ4_Pos)
#define ADC_JSQR_JSQ4_2   (0x04UL << ADC_JSQR_JSQ4_Pos)
#define ADC_JSQR_JSQ4_3   (0x08UL << ADC_JSQR_JSQ4_Pos)
#define ADC_JSQR_JSQ4_4   (0x10UL << ADC_JSQR_JSQ4_Pos)
#define ADC_OFR1_OFFSET1_Pos   (0U)
#define ADC_OFR1_OFFSET1_Msk   (0x3FFFFFFUL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1   ADC_OFR1_OFFSET1_Msk
#define ADC_OFR1_OFFSET1_0   (0x0000001UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_1   (0x0000002UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_2   (0x0000004UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_3   (0x0000008UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_4   (0x0000010UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_5   (0x0000020UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_6   (0x0000040UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_7   (0x0000080UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_8   (0x0000100UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_9   (0x0000200UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_10   (0x0000400UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_11   (0x0000800UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_12   (0x0001000UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_13   (0x0002000UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_14   (0x0004000UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_15   (0x0008000UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_16   (0x0010000UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_17   (0x0020000UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_18   (0x0040000UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_19   (0x0080000UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_20   (0x0100000UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_21   (0x0200000UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_22   (0x0400000UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_23   (0x0800000UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_24   (0x1000000UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_25   (0x2000000UL << ADC_OFR1_OFFSET1_Pos)
#define ADC_OFR1_OFFSET1_CH_Pos   (26U)
#define ADC_OFR1_OFFSET1_CH_Msk   (0x1FUL << ADC_OFR1_OFFSET1_CH_Pos)
#define ADC_OFR1_OFFSET1_CH   ADC_OFR1_OFFSET1_CH_Msk
#define ADC_OFR1_OFFSET1_CH_0   (0x01UL << ADC_OFR1_OFFSET1_CH_Pos)
#define ADC_OFR1_OFFSET1_CH_1   (0x02UL << ADC_OFR1_OFFSET1_CH_Pos)
#define ADC_OFR1_OFFSET1_CH_2   (0x04UL << ADC_OFR1_OFFSET1_CH_Pos)
#define ADC_OFR1_OFFSET1_CH_3   (0x08UL << ADC_OFR1_OFFSET1_CH_Pos)
#define ADC_OFR1_OFFSET1_CH_4   (0x10UL << ADC_OFR1_OFFSET1_CH_Pos)
#define ADC_OFR1_SSATE_Pos   (31U)
#define ADC_OFR1_SSATE_Msk   (0x1UL << ADC_OFR1_SSATE_Pos)
#define ADC_OFR1_SSATE   ADC_OFR1_SSATE_Msk
#define ADC_OFR2_OFFSET2_Pos   (0U)
#define ADC_OFR2_OFFSET2_Msk   (0x3FFFFFFUL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2   ADC_OFR2_OFFSET2_Msk
#define ADC_OFR2_OFFSET2_0   (0x0000001UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_1   (0x0000002UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_2   (0x0000004UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_3   (0x0000008UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_4   (0x0000010UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_5   (0x0000020UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_6   (0x0000040UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_7   (0x0000080UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_8   (0x0000100UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_9   (0x0000200UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_10   (0x0000400UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_11   (0x0000800UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_12   (0x0001000UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_13   (0x0002000UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_14   (0x0004000UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_15   (0x0008000UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_16   (0x0010000UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_17   (0x0020000UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_18   (0x0040000UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_19   (0x0080000UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_20   (0x0100000UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_21   (0x0200000UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_22   (0x0400000UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_23   (0x0800000UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_24   (0x1000000UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_25   (0x2000000UL << ADC_OFR2_OFFSET2_Pos)
#define ADC_OFR2_OFFSET2_CH_Pos   (26U)
#define ADC_OFR2_OFFSET2_CH_Msk   (0x1FUL << ADC_OFR2_OFFSET2_CH_Pos)
#define ADC_OFR2_OFFSET2_CH   ADC_OFR2_OFFSET2_CH_Msk
#define ADC_OFR2_OFFSET2_CH_0   (0x01UL << ADC_OFR2_OFFSET2_CH_Pos)
#define ADC_OFR2_OFFSET2_CH_1   (0x02UL << ADC_OFR2_OFFSET2_CH_Pos)
#define ADC_OFR2_OFFSET2_CH_2   (0x04UL << ADC_OFR2_OFFSET2_CH_Pos)
#define ADC_OFR2_OFFSET2_CH_3   (0x08UL << ADC_OFR2_OFFSET2_CH_Pos)
#define ADC_OFR2_OFFSET2_CH_4   (0x10UL << ADC_OFR2_OFFSET2_CH_Pos)
#define ADC_OFR2_SSATE_Pos   (31U)
#define ADC_OFR2_SSATE_Msk   (0x1UL << ADC_OFR2_SSATE_Pos)
#define ADC_OFR2_SSATE   ADC_OFR2_SSATE_Msk
#define ADC_OFR3_OFFSET3_Pos   (0U)
#define ADC_OFR3_OFFSET3_Msk   (0x3FFFFFFUL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3   ADC_OFR3_OFFSET3_Msk
#define ADC_OFR3_OFFSET3_0   (0x0000001UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_1   (0x0000002UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_2   (0x0000004UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_3   (0x0000008UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_4   (0x0000010UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_5   (0x0000020UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_6   (0x0000040UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_7   (0x0000080UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_8   (0x0000100UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_9   (0x0000200UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_10   (0x0000400UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_11   (0x0000800UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_12   (0x0001000UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_13   (0x0002000UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_14   (0x0004000UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_15   (0x0008000UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_16   (0x0010000UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_17   (0x0020000UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_18   (0x0040000UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_19   (0x0080000UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_20   (0x0100000UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_21   (0x0200000UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_22   (0x0400000UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_23   (0x0800000UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_24   (0x1000000UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_25   (0x2000000UL << ADC_OFR3_OFFSET3_Pos)
#define ADC_OFR3_OFFSET3_CH_Pos   (26U)
#define ADC_OFR3_OFFSET3_CH_Msk   (0x1FUL << ADC_OFR3_OFFSET3_CH_Pos)
#define ADC_OFR3_OFFSET3_CH   ADC_OFR3_OFFSET3_CH_Msk
#define ADC_OFR3_OFFSET3_CH_0   (0x01UL << ADC_OFR3_OFFSET3_CH_Pos)
#define ADC_OFR3_OFFSET3_CH_1   (0x02UL << ADC_OFR3_OFFSET3_CH_Pos)
#define ADC_OFR3_OFFSET3_CH_2   (0x04UL << ADC_OFR3_OFFSET3_CH_Pos)
#define ADC_OFR3_OFFSET3_CH_3   (0x08UL << ADC_OFR3_OFFSET3_CH_Pos)
#define ADC_OFR3_OFFSET3_CH_4   (0x10UL << ADC_OFR3_OFFSET3_CH_Pos)
#define ADC_OFR3_SSATE_Pos   (31U)
#define ADC_OFR3_SSATE_Msk   (0x1UL << ADC_OFR3_SSATE_Pos)
#define ADC_OFR3_SSATE   ADC_OFR3_SSATE_Msk
#define ADC_OFR4_OFFSET4_Pos   (0U)
#define ADC_OFR4_OFFSET4_Msk   (0x3FFFFFFUL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4   ADC_OFR4_OFFSET4_Msk
#define ADC_OFR4_OFFSET4_0   (0x0000001UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_1   (0x0000002UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_2   (0x0000004UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_3   (0x0000008UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_4   (0x0000010UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_5   (0x0000020UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_6   (0x0000040UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_7   (0x0000080UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_8   (0x0000100UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_9   (0x0000200UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_10   (0x0000400UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_11   (0x0000800UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_12   (0x0001000UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_13   (0x0002000UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_14   (0x0004000UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_15   (0x0008000UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_16   (0x0010000UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_17   (0x0020000UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_18   (0x0040000UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_19   (0x0080000UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_20   (0x0100000UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_21   (0x0200000UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_22   (0x0400000UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_23   (0x0800000UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_24   (0x1000000UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_25   (0x2000000UL << ADC_OFR4_OFFSET4_Pos)
#define ADC_OFR4_OFFSET4_CH_Pos   (26U)
#define ADC_OFR4_OFFSET4_CH_Msk   (0x1FUL << ADC_OFR4_OFFSET4_CH_Pos)
#define ADC_OFR4_OFFSET4_CH   ADC_OFR4_OFFSET4_CH_Msk
#define ADC_OFR4_OFFSET4_CH_0   (0x01UL << ADC_OFR4_OFFSET4_CH_Pos)
#define ADC_OFR4_OFFSET4_CH_1   (0x02UL << ADC_OFR4_OFFSET4_CH_Pos)
#define ADC_OFR4_OFFSET4_CH_2   (0x04UL << ADC_OFR4_OFFSET4_CH_Pos)
#define ADC_OFR4_OFFSET4_CH_3   (0x08UL << ADC_OFR4_OFFSET4_CH_Pos)
#define ADC_OFR4_OFFSET4_CH_4   (0x10UL << ADC_OFR4_OFFSET4_CH_Pos)
#define ADC_OFR4_SSATE_Pos   (31U)
#define ADC_OFR4_SSATE_Msk   (0x1UL << ADC_OFR4_SSATE_Pos)
#define ADC_OFR4_SSATE   ADC_OFR4_SSATE_Msk
#define ADC_JDR1_JDATA_Pos   (0U)
#define ADC_JDR1_JDATA_Msk   (0xFFFFFFFFUL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA   ADC_JDR1_JDATA_Msk
#define ADC_JDR1_JDATA_0   (0x00000001UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_1   (0x00000002UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_2   (0x00000004UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_3   (0x00000008UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_4   (0x00000010UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_5   (0x00000020UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_6   (0x00000040UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_7   (0x00000080UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_8   (0x00000100UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_9   (0x00000200UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_10   (0x00000400UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_11   (0x00000800UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_12   (0x00001000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_13   (0x00002000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_14   (0x00004000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_15   (0x00008000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_16   (0x00010000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_17   (0x00020000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_18   (0x00040000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_19   (0x00080000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_20   (0x00100000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_21   (0x00200000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_22   (0x00400000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_23   (0x00800000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_24   (0x01000000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_25   (0x02000000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_26   (0x04000000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_27   (0x08000000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_28   (0x10000000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_29   (0x20000000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_30   (0x40000000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR1_JDATA_31   (0x80000000UL << ADC_JDR1_JDATA_Pos)
#define ADC_JDR2_JDATA_Pos   (0U)
#define ADC_JDR2_JDATA_Msk   (0xFFFFFFFFUL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA   ADC_JDR2_JDATA_Msk
#define ADC_JDR2_JDATA_0   (0x00000001UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_1   (0x00000002UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_2   (0x00000004UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_3   (0x00000008UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_4   (0x00000010UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_5   (0x00000020UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_6   (0x00000040UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_7   (0x00000080UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_8   (0x00000100UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_9   (0x00000200UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_10   (0x00000400UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_11   (0x00000800UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_12   (0x00001000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_13   (0x00002000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_14   (0x00004000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_15   (0x00008000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_16   (0x00010000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_17   (0x00020000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_18   (0x00040000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_19   (0x00080000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_20   (0x00100000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_21   (0x00200000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_22   (0x00400000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_23   (0x00800000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_24   (0x01000000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_25   (0x02000000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_26   (0x04000000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_27   (0x08000000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_28   (0x10000000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_29   (0x20000000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_30   (0x40000000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR2_JDATA_31   (0x80000000UL << ADC_JDR2_JDATA_Pos)
#define ADC_JDR3_JDATA_Pos   (0U)
#define ADC_JDR3_JDATA_Msk   (0xFFFFFFFFUL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA   ADC_JDR3_JDATA_Msk
#define ADC_JDR3_JDATA_0   (0x00000001UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_1   (0x00000002UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_2   (0x00000004UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_3   (0x00000008UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_4   (0x00000010UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_5   (0x00000020UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_6   (0x00000040UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_7   (0x00000080UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_8   (0x00000100UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_9   (0x00000200UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_10   (0x00000400UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_11   (0x00000800UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_12   (0x00001000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_13   (0x00002000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_14   (0x00004000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_15   (0x00008000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_16   (0x00010000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_17   (0x00020000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_18   (0x00040000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_19   (0x00080000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_20   (0x00100000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_21   (0x00200000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_22   (0x00400000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_23   (0x00800000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_24   (0x01000000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_25   (0x02000000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_26   (0x04000000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_27   (0x08000000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_28   (0x10000000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_29   (0x20000000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_30   (0x40000000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR3_JDATA_31   (0x80000000UL << ADC_JDR3_JDATA_Pos)
#define ADC_JDR4_JDATA_Pos   (0U)
#define ADC_JDR4_JDATA_Msk   (0xFFFFFFFFUL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA   ADC_JDR4_JDATA_Msk
#define ADC_JDR4_JDATA_0   (0x00000001UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_1   (0x00000002UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_2   (0x00000004UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_3   (0x00000008UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_4   (0x00000010UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_5   (0x00000020UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_6   (0x00000040UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_7   (0x00000080UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_8   (0x00000100UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_9   (0x00000200UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_10   (0x00000400UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_11   (0x00000800UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_12   (0x00001000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_13   (0x00002000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_14   (0x00004000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_15   (0x00008000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_16   (0x00010000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_17   (0x00020000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_18   (0x00040000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_19   (0x00080000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_20   (0x00100000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_21   (0x00200000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_22   (0x00400000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_23   (0x00800000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_24   (0x01000000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_25   (0x02000000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_26   (0x04000000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_27   (0x08000000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_28   (0x10000000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_29   (0x20000000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_30   (0x40000000UL << ADC_JDR4_JDATA_Pos)
#define ADC_JDR4_JDATA_31   (0x80000000UL << ADC_JDR4_JDATA_Pos)
#define ADC_AWD2CR_AWD2CH_Pos   (0U)
#define ADC_AWD2CR_AWD2CH_Msk   (0xFFFFFUL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH   ADC_AWD2CR_AWD2CH_Msk
#define ADC_AWD2CR_AWD2CH_0   (0x00001UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_1   (0x00002UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_2   (0x00004UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_3   (0x00008UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_4   (0x00010UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_5   (0x00020UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_6   (0x00040UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_7   (0x00080UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_8   (0x00100UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_9   (0x00200UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_10   (0x00400UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_11   (0x00800UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_12   (0x01000UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_13   (0x02000UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_14   (0x04000UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_15   (0x08000UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_16   (0x10000UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_17   (0x20000UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_18   (0x40000UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD2CR_AWD2CH_19   (0x80000UL << ADC_AWD2CR_AWD2CH_Pos)
#define ADC_AWD3CR_AWD3CH_Pos   (0U)
#define ADC_AWD3CR_AWD3CH_Msk   (0xFFFFFUL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH   ADC_AWD3CR_AWD3CH_Msk
#define ADC_AWD3CR_AWD3CH_0   (0x00001UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_1   (0x00002UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_2   (0x00004UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_3   (0x00008UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_4   (0x00010UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_5   (0x00020UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_6   (0x00040UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_7   (0x00080UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_8   (0x00100UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_9   (0x00200UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_10   (0x00400UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_11   (0x00800UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_12   (0x01000UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_13   (0x02000UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_14   (0x04000UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_15   (0x08000UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_16   (0x10000UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_17   (0x20000UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_18   (0x40000UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_AWD3CR_AWD3CH_19   (0x80000UL << ADC_AWD3CR_AWD3CH_Pos)
#define ADC_DIFSEL_DIFSEL_Pos   (0U)
#define ADC_DIFSEL_DIFSEL_Msk   (0xFFFFFUL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL   ADC_DIFSEL_DIFSEL_Msk
#define ADC_DIFSEL_DIFSEL_0   (0x00001UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_1   (0x00002UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_2   (0x00004UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_3   (0x00008UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_4   (0x00010UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_5   (0x00020UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_6   (0x00040UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_7   (0x00080UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_8   (0x00100UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_9   (0x00200UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_10   (0x00400UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_11   (0x00800UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_12   (0x01000UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_13   (0x02000UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_14   (0x04000UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_15   (0x08000UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_16   (0x10000UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_17   (0x20000UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_18   (0x40000UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_DIFSEL_DIFSEL_19   (0x80000UL << ADC_DIFSEL_DIFSEL_Pos)
#define ADC_CALFACT_CALFACT_S_Pos   (0U)
#define ADC_CALFACT_CALFACT_S_Msk   (0x7FFUL << ADC_CALFACT_CALFACT_S_Pos)
#define ADC_CALFACT_CALFACT_S   ADC_CALFACT_CALFACT_S_Msk
#define ADC_CALFACT_CALFACT_S_0   (0x001UL << ADC_CALFACT_CALFACT_S_Pos)
#define ADC_CALFACT_CALFACT_S_1   (0x002UL << ADC_CALFACT_CALFACT_S_Pos)
#define ADC_CALFACT_CALFACT_S_2   (0x004UL << ADC_CALFACT_CALFACT_S_Pos)
#define ADC_CALFACT_CALFACT_S_3   (0x008UL << ADC_CALFACT_CALFACT_S_Pos)
#define ADC_CALFACT_CALFACT_S_4   (0x010UL << ADC_CALFACT_CALFACT_S_Pos)
#define ADC_CALFACT_CALFACT_S_5   (0x020UL << ADC_CALFACT_CALFACT_S_Pos)
#define ADC_CALFACT_CALFACT_S_6   (0x040UL << ADC_CALFACT_CALFACT_S_Pos)
#define ADC_CALFACT_CALFACT_S_7   (0x080UL << ADC_CALFACT_CALFACT_S_Pos)
#define ADC_CALFACT_CALFACT_S_8   (0x100UL << ADC_CALFACT_CALFACT_S_Pos)
#define ADC_CALFACT_CALFACT_S_9   (0x200UL << ADC_CALFACT_CALFACT_S_Pos)
#define ADC_CALFACT_CALFACT_S_10   (0x400UL << ADC_CALFACT_CALFACT_S_Pos)
#define ADC_CALFACT_CALFACT_D_Pos   (16U)
#define ADC_CALFACT_CALFACT_D_Msk   (0x7FFUL << ADC_CALFACT_CALFACT_D_Pos)
#define ADC_CALFACT_CALFACT_D   ADC_CALFACT_CALFACT_D_Msk
#define ADC_CALFACT_CALFACT_D_0   (0x001UL << ADC_CALFACT_CALFACT_D_Pos)
#define ADC_CALFACT_CALFACT_D_1   (0x002UL << ADC_CALFACT_CALFACT_D_Pos)
#define ADC_CALFACT_CALFACT_D_2   (0x004UL << ADC_CALFACT_CALFACT_D_Pos)
#define ADC_CALFACT_CALFACT_D_3   (0x008UL << ADC_CALFACT_CALFACT_D_Pos)
#define ADC_CALFACT_CALFACT_D_4   (0x010UL << ADC_CALFACT_CALFACT_D_Pos)
#define ADC_CALFACT_CALFACT_D_5   (0x020UL << ADC_CALFACT_CALFACT_D_Pos)
#define ADC_CALFACT_CALFACT_D_6   (0x040UL << ADC_CALFACT_CALFACT_D_Pos)
#define ADC_CALFACT_CALFACT_D_7   (0x080UL << ADC_CALFACT_CALFACT_D_Pos)
#define ADC_CALFACT_CALFACT_D_8   (0x100UL << ADC_CALFACT_CALFACT_D_Pos)
#define ADC_CALFACT_CALFACT_D_9   (0x200UL << ADC_CALFACT_CALFACT_D_Pos)
#define ADC_CALFACT_CALFACT_D_10   (0x400UL << ADC_CALFACT_CALFACT_D_Pos)
#define ADC_CALFACT2_LINCALFACT_Pos   (0U)
#define ADC_CALFACT2_LINCALFACT_Msk   (0x3FFFFFFFUL << ADC_CALFACT2_LINCALFACT_Pos)
#define ADC_CALFACT2_LINCALFACT   ADC_CALFACT2_LINCALFACT_Msk
#define ADC_CALFACT2_LINCALFACT_0   (0x00000001UL << ADC_CALFACT2_LINCALFACT_Pos)
#define ADC_CALFACT2_LINCALFACT_1   (0x00000002UL << ADC_CALFACT2_LINCALFACT_Pos)
#define ADC_CALFACT2_LINCALFACT_2   (0x00000004UL << ADC_CALFACT2_LINCALFACT_Pos)
#define ADC_CALFACT2_LINCALFACT_3   (0x00000008UL << ADC_CALFACT2_LINCALFACT_Pos)
#define ADC_CALFACT2_LINCALFACT_4   (0x00000010UL << ADC_CALFACT2_LINCALFACT_Pos)
#define ADC_CALFACT2_LINCALFACT_5   (0x00000020UL << ADC_CALFACT2_LINCALFACT_Pos)
#define ADC_CALFACT2_LINCALFACT_6   (0x00000040UL << ADC_CALFACT2_LINCALFACT_Pos)
#define ADC_CALFACT2_LINCALFACT_7   (0x00000080UL << ADC_CALFACT2_LINCALFACT_Pos)
#define ADC_CALFACT2_LINCALFACT_8   (0x00000100UL << ADC_CALFACT2_LINCALFACT_Pos)
#define ADC_CALFACT2_LINCALFACT_9   (0x00000200UL << ADC_CALFACT2_LINCALFACT_Pos)
#define ADC_CALFACT2_LINCALFACT_10   (0x00000400UL << ADC_CALFACT2_LINCALFACT_Pos)
#define ADC_CALFACT2_LINCALFACT_11   (0x00000800UL << ADC_CALFACT2_LINCALFACT_Pos)
#define ADC_CALFACT2_LINCALFACT_12   (0x00001000UL << ADC_CALFACT2_LINCALFACT_Pos)
#define ADC_CALFACT2_LINCALFACT_13   (0x00002000UL << ADC_CALFACT2_LINCALFACT_Pos)
#define ADC_CALFACT2_LINCALFACT_14   (0x00004000UL << ADC_CALFACT2_LINCALFACT_Pos)
#define ADC_CALFACT2_LINCALFACT_15   (0x00008000UL << ADC_CALFACT2_LINCALFACT_Pos)
#define ADC_CALFACT2_LINCALFACT_16   (0x00010000UL << ADC_CALFACT2_LINCALFACT_Pos)
#define ADC_CALFACT2_LINCALFACT_17   (0x00020000UL << ADC_CALFACT2_LINCALFACT_Pos)
#define ADC_CALFACT2_LINCALFACT_18   (0x00040000UL << ADC_CALFACT2_LINCALFACT_Pos)
#define ADC_CALFACT2_LINCALFACT_19   (0x00080000UL << ADC_CALFACT2_LINCALFACT_Pos)
#define ADC_CALFACT2_LINCALFACT_20   (0x00100000UL << ADC_CALFACT2_LINCALFACT_Pos)
#define ADC_CALFACT2_LINCALFACT_21   (0x00200000UL << ADC_CALFACT2_LINCALFACT_Pos)
#define ADC_CALFACT2_LINCALFACT_22   (0x00400000UL << ADC_CALFACT2_LINCALFACT_Pos)
#define ADC_CALFACT2_LINCALFACT_23   (0x00800000UL << ADC_CALFACT2_LINCALFACT_Pos)
#define ADC_CALFACT2_LINCALFACT_24   (0x01000000UL << ADC_CALFACT2_LINCALFACT_Pos)
#define ADC_CALFACT2_LINCALFACT_25   (0x02000000UL << ADC_CALFACT2_LINCALFACT_Pos)
#define ADC_CALFACT2_LINCALFACT_26   (0x04000000UL << ADC_CALFACT2_LINCALFACT_Pos)
#define ADC_CALFACT2_LINCALFACT_27   (0x08000000UL << ADC_CALFACT2_LINCALFACT_Pos)
#define ADC_CALFACT2_LINCALFACT_28   (0x10000000UL << ADC_CALFACT2_LINCALFACT_Pos)
#define ADC_CALFACT2_LINCALFACT_29   (0x20000000UL << ADC_CALFACT2_LINCALFACT_Pos)
#define ADC_CSR_ADRDY_MST_Pos   (0U)
#define ADC_CSR_ADRDY_MST_Msk   (0x1UL << ADC_CSR_ADRDY_MST_Pos)
#define ADC_CSR_ADRDY_MST   ADC_CSR_ADRDY_MST_Msk
#define ADC_CSR_EOSMP_MST_Pos   (1U)
#define ADC_CSR_EOSMP_MST_Msk   (0x1UL << ADC_CSR_EOSMP_MST_Pos)
#define ADC_CSR_EOSMP_MST   ADC_CSR_EOSMP_MST_Msk
#define ADC_CSR_EOC_MST_Pos   (2U)
#define ADC_CSR_EOC_MST_Msk   (0x1UL << ADC_CSR_EOC_MST_Pos)
#define ADC_CSR_EOC_MST   ADC_CSR_EOC_MST_Msk
#define ADC_CSR_EOS_MST_Pos   (3U)
#define ADC_CSR_EOS_MST_Msk   (0x1UL << ADC_CSR_EOS_MST_Pos)
#define ADC_CSR_EOS_MST   ADC_CSR_EOS_MST_Msk
#define ADC_CSR_OVR_MST_Pos   (4U)
#define ADC_CSR_OVR_MST_Msk   (0x1UL << ADC_CSR_OVR_MST_Pos)
#define ADC_CSR_OVR_MST   ADC_CSR_OVR_MST_Msk
#define ADC_CSR_JEOC_MST_Pos   (5U)
#define ADC_CSR_JEOC_MST_Msk   (0x1UL << ADC_CSR_JEOC_MST_Pos)
#define ADC_CSR_JEOC_MST   ADC_CSR_JEOC_MST_Msk
#define ADC_CSR_JEOS_MST_Pos   (6U)
#define ADC_CSR_JEOS_MST_Msk   (0x1UL << ADC_CSR_JEOS_MST_Pos)
#define ADC_CSR_JEOS_MST   ADC_CSR_JEOS_MST_Msk
#define ADC_CSR_AWD1_MST_Pos   (7U)
#define ADC_CSR_AWD1_MST_Msk   (0x1UL << ADC_CSR_AWD1_MST_Pos)
#define ADC_CSR_AWD1_MST   ADC_CSR_AWD1_MST_Msk
#define ADC_CSR_AWD2_MST_Pos   (8U)
#define ADC_CSR_AWD2_MST_Msk   (0x1UL << ADC_CSR_AWD2_MST_Pos)
#define ADC_CSR_AWD2_MST   ADC_CSR_AWD2_MST_Msk
#define ADC_CSR_AWD3_MST_Pos   (9U)
#define ADC_CSR_AWD3_MST_Msk   (0x1UL << ADC_CSR_AWD3_MST_Pos)
#define ADC_CSR_AWD3_MST   ADC_CSR_AWD3_MST_Msk
#define ADC_CSR_JQOVF_MST_Pos   (10U)
#define ADC_CSR_JQOVF_MST_Msk   (0x1UL << ADC_CSR_JQOVF_MST_Pos)
#define ADC_CSR_JQOVF_MST   ADC_CSR_JQOVF_MST_Msk
#define ADC_CSR_ADRDY_SLV_Pos   (16U)
#define ADC_CSR_ADRDY_SLV_Msk   (0x1UL << ADC_CSR_ADRDY_SLV_Pos)
#define ADC_CSR_ADRDY_SLV   ADC_CSR_ADRDY_SLV_Msk
#define ADC_CSR_EOSMP_SLV_Pos   (17U)
#define ADC_CSR_EOSMP_SLV_Msk   (0x1UL << ADC_CSR_EOSMP_SLV_Pos)
#define ADC_CSR_EOSMP_SLV   ADC_CSR_EOSMP_SLV_Msk
#define ADC_CSR_EOC_SLV_Pos   (18U)
#define ADC_CSR_EOC_SLV_Msk   (0x1UL << ADC_CSR_EOC_SLV_Pos)
#define ADC_CSR_EOC_SLV   ADC_CSR_EOC_SLV_Msk
#define ADC_CSR_EOS_SLV_Pos   (19U)
#define ADC_CSR_EOS_SLV_Msk   (0x1UL << ADC_CSR_EOS_SLV_Pos)
#define ADC_CSR_EOS_SLV   ADC_CSR_EOS_SLV_Msk
#define ADC_CSR_OVR_SLV_Pos   (20U)
#define ADC_CSR_OVR_SLV_Msk   (0x1UL << ADC_CSR_OVR_SLV_Pos)
#define ADC_CSR_OVR_SLV   ADC_CSR_OVR_SLV_Msk
#define ADC_CSR_JEOC_SLV_Pos   (21U)
#define ADC_CSR_JEOC_SLV_Msk   (0x1UL << ADC_CSR_JEOC_SLV_Pos)
#define ADC_CSR_JEOC_SLV   ADC_CSR_JEOC_SLV_Msk
#define ADC_CSR_JEOS_SLV_Pos   (22U)
#define ADC_CSR_JEOS_SLV_Msk   (0x1UL << ADC_CSR_JEOS_SLV_Pos)
#define ADC_CSR_JEOS_SLV   ADC_CSR_JEOS_SLV_Msk
#define ADC_CSR_AWD1_SLV_Pos   (23U)
#define ADC_CSR_AWD1_SLV_Msk   (0x1UL << ADC_CSR_AWD1_SLV_Pos)
#define ADC_CSR_AWD1_SLV   ADC_CSR_AWD1_SLV_Msk
#define ADC_CSR_AWD2_SLV_Pos   (24U)
#define ADC_CSR_AWD2_SLV_Msk   (0x1UL << ADC_CSR_AWD2_SLV_Pos)
#define ADC_CSR_AWD2_SLV   ADC_CSR_AWD2_SLV_Msk
#define ADC_CSR_AWD3_SLV_Pos   (25U)
#define ADC_CSR_AWD3_SLV_Msk   (0x1UL << ADC_CSR_AWD3_SLV_Pos)
#define ADC_CSR_AWD3_SLV   ADC_CSR_AWD3_SLV_Msk
#define ADC_CSR_JQOVF_SLV_Pos   (26U)
#define ADC_CSR_JQOVF_SLV_Msk   (0x1UL << ADC_CSR_JQOVF_SLV_Pos)
#define ADC_CSR_JQOVF_SLV   ADC_CSR_JQOVF_SLV_Msk
#define ADC_CCR_DUAL_Pos   (0U)
#define ADC_CCR_DUAL_Msk   (0x1FUL << ADC_CCR_DUAL_Pos)
#define ADC_CCR_DUAL   ADC_CCR_DUAL_Msk
#define ADC_CCR_DUAL_0   (0x01UL << ADC_CCR_DUAL_Pos)
#define ADC_CCR_DUAL_1   (0x02UL << ADC_CCR_DUAL_Pos)
#define ADC_CCR_DUAL_2   (0x04UL << ADC_CCR_DUAL_Pos)
#define ADC_CCR_DUAL_3   (0x08UL << ADC_CCR_DUAL_Pos)
#define ADC_CCR_DUAL_4   (0x10UL << ADC_CCR_DUAL_Pos)
#define ADC_CCR_DELAY_Pos   (8U)
#define ADC_CCR_DELAY_Msk   (0xFUL << ADC_CCR_DELAY_Pos)
#define ADC_CCR_DELAY   ADC_CCR_DELAY_Msk
#define ADC_CCR_DELAY_0   (0x1UL << ADC_CCR_DELAY_Pos)
#define ADC_CCR_DELAY_1   (0x2UL << ADC_CCR_DELAY_Pos)
#define ADC_CCR_DELAY_2   (0x4UL << ADC_CCR_DELAY_Pos)
#define ADC_CCR_DELAY_3   (0x8UL << ADC_CCR_DELAY_Pos)
#define ADC_CCR_DAMDF_Pos   (14U)
#define ADC_CCR_DAMDF_Msk   (0x3UL << ADC_CCR_DAMDF_Pos)
#define ADC_CCR_DAMDF   ADC_CCR_DAMDF_Msk
#define ADC_CCR_DAMDF_0   (0x1UL << ADC_CCR_DAMDF_Pos)
#define ADC_CCR_DAMDF_1   (0x2UL << ADC_CCR_DAMDF_Pos)
#define ADC_CCR_CKMODE_Pos   (16U)
#define ADC_CCR_CKMODE_Msk   (0x3UL << ADC_CCR_CKMODE_Pos)
#define ADC_CCR_CKMODE   ADC_CCR_CKMODE_Msk
#define ADC_CCR_CKMODE_0   (0x1UL << ADC_CCR_CKMODE_Pos)
#define ADC_CCR_CKMODE_1   (0x2UL << ADC_CCR_CKMODE_Pos)
#define ADC_CCR_PRESC_Pos   (18U)
#define ADC_CCR_PRESC_Msk   (0xFUL << ADC_CCR_PRESC_Pos)
#define ADC_CCR_PRESC   ADC_CCR_PRESC_Msk
#define ADC_CCR_PRESC_0   (0x1UL << ADC_CCR_PRESC_Pos)
#define ADC_CCR_PRESC_1   (0x2UL << ADC_CCR_PRESC_Pos)
#define ADC_CCR_PRESC_2   (0x4UL << ADC_CCR_PRESC_Pos)
#define ADC_CCR_PRESC_3   (0x8UL << ADC_CCR_PRESC_Pos)
#define ADC_CCR_VREFEN_Pos   (22U)
#define ADC_CCR_VREFEN_Msk   (0x1UL << ADC_CCR_VREFEN_Pos)
#define ADC_CCR_VREFEN   ADC_CCR_VREFEN_Msk
#define ADC_CCR_TSEN_Pos   (23U)
#define ADC_CCR_TSEN_Msk   (0x1UL << ADC_CCR_TSEN_Pos)
#define ADC_CCR_TSEN   ADC_CCR_TSEN_Msk
#define ADC_CCR_VBATEN_Pos   (24U)
#define ADC_CCR_VBATEN_Msk   (0x1UL << ADC_CCR_VBATEN_Pos)
#define ADC_CCR_VBATEN   ADC_CCR_VBATEN_Msk
#define ADC_CDR_RDATA_MST_Pos   (0U)
#define ADC_CDR_RDATA_MST_Msk   (0xFFFFUL << ADC_CDR_RDATA_MST_Pos)
#define ADC_CDR_RDATA_MST   ADC_CDR_RDATA_MST_Msk
#define ADC_CDR_RDATA_SLV_Pos   (16U)
#define ADC_CDR_RDATA_SLV_Msk   (0xFFFFUL << ADC_CDR_RDATA_SLV_Pos)
#define ADC_CDR_RDATA_SLV   ADC_CDR_RDATA_SLV_Msk
#define ADC_CDR2_RDATA_ALT_Pos   (0U)
#define ADC_CDR2_RDATA_ALT_Msk   (0xFFFFFFFFUL << ADC_CDR2_RDATA_ALT_Pos)
#define ADC_CDR2_RDATA_ALT   ADC_CDR2_RDATA_ALT_Msk
#define VREFBUF_CSR_ENVR_Pos   (0U)
#define VREFBUF_CSR_ENVR_Msk   (0x1UL << VREFBUF_CSR_ENVR_Pos)
#define VREFBUF_CSR_ENVR   VREFBUF_CSR_ENVR_Msk
#define VREFBUF_CSR_HIZ_Pos   (1U)
#define VREFBUF_CSR_HIZ_Msk   (0x1UL << VREFBUF_CSR_HIZ_Pos)
#define VREFBUF_CSR_HIZ   VREFBUF_CSR_HIZ_Msk
#define VREFBUF_CSR_VRR_Pos   (3U)
#define VREFBUF_CSR_VRR_Msk   (0x1UL << VREFBUF_CSR_VRR_Pos)
#define VREFBUF_CSR_VRR   VREFBUF_CSR_VRR_Msk
#define VREFBUF_CSR_VRS_Pos   (4U)
#define VREFBUF_CSR_VRS_Msk   (0x7UL << VREFBUF_CSR_VRS_Pos)
#define VREFBUF_CSR_VRS   VREFBUF_CSR_VRS_Msk
#define VREFBUF_CSR_VRS_OUT1   (0U)
#define VREFBUF_CSR_VRS_OUT2_Pos   (4U)
#define VREFBUF_CSR_VRS_OUT2_Msk   (0x1UL << VREFBUF_CSR_VRS_OUT2_Pos)
#define VREFBUF_CSR_VRS_OUT2   VREFBUF_CSR_VRS_OUT2_Msk
#define VREFBUF_CSR_VRS_OUT3_Pos   (5U)
#define VREFBUF_CSR_VRS_OUT3_Msk   (0x1UL << VREFBUF_CSR_VRS_OUT3_Pos)
#define VREFBUF_CSR_VRS_OUT3   VREFBUF_CSR_VRS_OUT3_Msk
#define VREFBUF_CSR_VRS_OUT4_Pos   (4U)
#define VREFBUF_CSR_VRS_OUT4_Msk   (0x3UL << VREFBUF_CSR_VRS_OUT4_Pos)
#define VREFBUF_CSR_VRS_OUT4   VREFBUF_CSR_VRS_OUT4_Msk
#define VREFBUF_CCR_TRIM_Pos   (0U)
#define VREFBUF_CCR_TRIM_Msk   (0x3FUL << VREFBUF_CCR_TRIM_Pos)
#define VREFBUF_CCR_TRIM   VREFBUF_CCR_TRIM_Msk
#define FDCAN_CREL_DAY_Pos   (0U)
#define FDCAN_CREL_DAY_Msk   (0xFFUL << FDCAN_CREL_DAY_Pos)
#define FDCAN_CREL_DAY   FDCAN_CREL_DAY_Msk
#define FDCAN_CREL_MON_Pos   (8U)
#define FDCAN_CREL_MON_Msk   (0xFFUL << FDCAN_CREL_MON_Pos)
#define FDCAN_CREL_MON   FDCAN_CREL_MON_Msk
#define FDCAN_CREL_YEAR_Pos   (16U)
#define FDCAN_CREL_YEAR_Msk   (0xFUL << FDCAN_CREL_YEAR_Pos)
#define FDCAN_CREL_YEAR   FDCAN_CREL_YEAR_Msk
#define FDCAN_CREL_SUBSTEP_Pos   (20U)
#define FDCAN_CREL_SUBSTEP_Msk   (0xFUL << FDCAN_CREL_SUBSTEP_Pos)
#define FDCAN_CREL_SUBSTEP   FDCAN_CREL_SUBSTEP_Msk
#define FDCAN_CREL_STEP_Pos   (24U)
#define FDCAN_CREL_STEP_Msk   (0xFUL << FDCAN_CREL_STEP_Pos)
#define FDCAN_CREL_STEP   FDCAN_CREL_STEP_Msk
#define FDCAN_CREL_REL_Pos   (28U)
#define FDCAN_CREL_REL_Msk   (0xFUL << FDCAN_CREL_REL_Pos)
#define FDCAN_CREL_REL   FDCAN_CREL_REL_Msk
#define FDCAN_ENDN_ETV_Pos   (0U)
#define FDCAN_ENDN_ETV_Msk   (0xFFFFFFFFUL << FDCAN_ENDN_ETV_Pos)
#define FDCAN_ENDN_ETV   FDCAN_ENDN_ETV_Msk
#define FDCAN_DBTP_DSJW_Pos   (0U)
#define FDCAN_DBTP_DSJW_Msk   (0xFUL << FDCAN_DBTP_DSJW_Pos)
#define FDCAN_DBTP_DSJW   FDCAN_DBTP_DSJW_Msk
#define FDCAN_DBTP_DTSEG2_Pos   (4U)
#define FDCAN_DBTP_DTSEG2_Msk   (0xFUL << FDCAN_DBTP_DTSEG2_Pos)
#define FDCAN_DBTP_DTSEG2   FDCAN_DBTP_DTSEG2_Msk
#define FDCAN_DBTP_DTSEG1_Pos   (8U)
#define FDCAN_DBTP_DTSEG1_Msk   (0x1FUL << FDCAN_DBTP_DTSEG1_Pos)
#define FDCAN_DBTP_DTSEG1   FDCAN_DBTP_DTSEG1_Msk
#define FDCAN_DBTP_DBRP_Pos   (16U)
#define FDCAN_DBTP_DBRP_Msk   (0x1FUL << FDCAN_DBTP_DBRP_Pos)
#define FDCAN_DBTP_DBRP   FDCAN_DBTP_DBRP_Msk
#define FDCAN_DBTP_TDC_Pos   (23U)
#define FDCAN_DBTP_TDC_Msk   (0x1UL << FDCAN_DBTP_TDC_Pos)
#define FDCAN_DBTP_TDC   FDCAN_DBTP_TDC_Msk
#define FDCAN_TEST_LBCK_Pos   (4U)
#define FDCAN_TEST_LBCK_Msk   (0x1UL << FDCAN_TEST_LBCK_Pos)
#define FDCAN_TEST_LBCK   FDCAN_TEST_LBCK_Msk
#define FDCAN_TEST_TX_Pos   (5U)
#define FDCAN_TEST_TX_Msk   (0x3UL << FDCAN_TEST_TX_Pos)
#define FDCAN_TEST_TX   FDCAN_TEST_TX_Msk
#define FDCAN_TEST_RX_Pos   (7U)
#define FDCAN_TEST_RX_Msk   (0x1UL << FDCAN_TEST_RX_Pos)
#define FDCAN_TEST_RX   FDCAN_TEST_RX_Msk
#define FDCAN_RWD_WDC_Pos   (0U)
#define FDCAN_RWD_WDC_Msk   (0xFFUL << FDCAN_RWD_WDC_Pos)
#define FDCAN_RWD_WDC   FDCAN_RWD_WDC_Msk
#define FDCAN_RWD_WDV_Pos   (8U)
#define FDCAN_RWD_WDV_Msk   (0xFFUL << FDCAN_RWD_WDV_Pos)
#define FDCAN_RWD_WDV   FDCAN_RWD_WDV_Msk
#define FDCAN_CCCR_INIT_Pos   (0U)
#define FDCAN_CCCR_INIT_Msk   (0x1UL << FDCAN_CCCR_INIT_Pos)
#define FDCAN_CCCR_INIT   FDCAN_CCCR_INIT_Msk
#define FDCAN_CCCR_CCE_Pos   (1U)
#define FDCAN_CCCR_CCE_Msk   (0x1UL << FDCAN_CCCR_CCE_Pos)
#define FDCAN_CCCR_CCE   FDCAN_CCCR_CCE_Msk
#define FDCAN_CCCR_ASM_Pos   (2U)
#define FDCAN_CCCR_ASM_Msk   (0x1UL << FDCAN_CCCR_ASM_Pos)
#define FDCAN_CCCR_ASM   FDCAN_CCCR_ASM_Msk
#define FDCAN_CCCR_CSA_Pos   (3U)
#define FDCAN_CCCR_CSA_Msk   (0x1UL << FDCAN_CCCR_CSA_Pos)
#define FDCAN_CCCR_CSA   FDCAN_CCCR_CSA_Msk
#define FDCAN_CCCR_CSR_Pos   (4U)
#define FDCAN_CCCR_CSR_Msk   (0x1UL << FDCAN_CCCR_CSR_Pos)
#define FDCAN_CCCR_CSR   FDCAN_CCCR_CSR_Msk
#define FDCAN_CCCR_MON_Pos   (5U)
#define FDCAN_CCCR_MON_Msk   (0x1UL << FDCAN_CCCR_MON_Pos)
#define FDCAN_CCCR_MON   FDCAN_CCCR_MON_Msk
#define FDCAN_CCCR_DAR_Pos   (6U)
#define FDCAN_CCCR_DAR_Msk   (0x1UL << FDCAN_CCCR_DAR_Pos)
#define FDCAN_CCCR_DAR   FDCAN_CCCR_DAR_Msk
#define FDCAN_CCCR_TEST_Pos   (7U)
#define FDCAN_CCCR_TEST_Msk   (0x1UL << FDCAN_CCCR_TEST_Pos)
#define FDCAN_CCCR_TEST   FDCAN_CCCR_TEST_Msk
#define FDCAN_CCCR_FDOE_Pos   (8U)
#define FDCAN_CCCR_FDOE_Msk   (0x1UL << FDCAN_CCCR_FDOE_Pos)
#define FDCAN_CCCR_FDOE   FDCAN_CCCR_FDOE_Msk
#define FDCAN_CCCR_BRSE_Pos   (9U)
#define FDCAN_CCCR_BRSE_Msk   (0x1UL << FDCAN_CCCR_BRSE_Pos)
#define FDCAN_CCCR_BRSE   FDCAN_CCCR_BRSE_Msk
#define FDCAN_CCCR_PXHD_Pos   (12U)
#define FDCAN_CCCR_PXHD_Msk   (0x1UL << FDCAN_CCCR_PXHD_Pos)
#define FDCAN_CCCR_PXHD   FDCAN_CCCR_PXHD_Msk
#define FDCAN_CCCR_EFBI_Pos   (13U)
#define FDCAN_CCCR_EFBI_Msk   (0x1UL << FDCAN_CCCR_EFBI_Pos)
#define FDCAN_CCCR_EFBI   FDCAN_CCCR_EFBI_Msk
#define FDCAN_CCCR_TXP_Pos   (14U)
#define FDCAN_CCCR_TXP_Msk   (0x1UL << FDCAN_CCCR_TXP_Pos)
#define FDCAN_CCCR_TXP   FDCAN_CCCR_TXP_Msk
#define FDCAN_CCCR_NISO_Pos   (15U)
#define FDCAN_CCCR_NISO_Msk   (0x1UL << FDCAN_CCCR_NISO_Pos)
#define FDCAN_CCCR_NISO   FDCAN_CCCR_NISO_Msk
#define FDCAN_NBTP_NTSEG2_Pos   (0U)
#define FDCAN_NBTP_NTSEG2_Msk   (0x7FUL << FDCAN_NBTP_NTSEG2_Pos)
#define FDCAN_NBTP_NTSEG2   FDCAN_NBTP_NTSEG2_Msk
#define FDCAN_NBTP_NTSEG1_Pos   (8U)
#define FDCAN_NBTP_NTSEG1_Msk   (0xFFUL << FDCAN_NBTP_NTSEG1_Pos)
#define FDCAN_NBTP_NTSEG1   FDCAN_NBTP_NTSEG1_Msk
#define FDCAN_NBTP_NBRP_Pos   (16U)
#define FDCAN_NBTP_NBRP_Msk   (0x1FFUL << FDCAN_NBTP_NBRP_Pos)
#define FDCAN_NBTP_NBRP   FDCAN_NBTP_NBRP_Msk
#define FDCAN_NBTP_NSJW_Pos   (25U)
#define FDCAN_NBTP_NSJW_Msk   (0x7FUL << FDCAN_NBTP_NSJW_Pos)
#define FDCAN_NBTP_NSJW   FDCAN_NBTP_NSJW_Msk
#define FDCAN_TSCC_TSS_Pos   (0U)
#define FDCAN_TSCC_TSS_Msk   (0x3UL << FDCAN_TSCC_TSS_Pos)
#define FDCAN_TSCC_TSS   FDCAN_TSCC_TSS_Msk
#define FDCAN_TSCC_TCP_Pos   (16U)
#define FDCAN_TSCC_TCP_Msk   (0xFUL << FDCAN_TSCC_TCP_Pos)
#define FDCAN_TSCC_TCP   FDCAN_TSCC_TCP_Msk
#define FDCAN_TSCV_TSC_Pos   (0U)
#define FDCAN_TSCV_TSC_Msk   (0xFFFFUL << FDCAN_TSCV_TSC_Pos)
#define FDCAN_TSCV_TSC   FDCAN_TSCV_TSC_Msk
#define FDCAN_TOCC_ETOC_Pos   (0U)
#define FDCAN_TOCC_ETOC_Msk   (0x1UL << FDCAN_TOCC_ETOC_Pos)
#define FDCAN_TOCC_ETOC   FDCAN_TOCC_ETOC_Msk
#define FDCAN_TOCC_TOS_Pos   (1U)
#define FDCAN_TOCC_TOS_Msk   (0x3UL << FDCAN_TOCC_TOS_Pos)
#define FDCAN_TOCC_TOS   FDCAN_TOCC_TOS_Msk
#define FDCAN_TOCC_TOP_Pos   (16U)
#define FDCAN_TOCC_TOP_Msk   (0xFFFFUL << FDCAN_TOCC_TOP_Pos)
#define FDCAN_TOCC_TOP   FDCAN_TOCC_TOP_Msk
#define FDCAN_TOCV_TOC_Pos   (0U)
#define FDCAN_TOCV_TOC_Msk   (0xFFFFUL << FDCAN_TOCV_TOC_Pos)
#define FDCAN_TOCV_TOC   FDCAN_TOCV_TOC_Msk
#define FDCAN_ECR_TEC_Pos   (0U)
#define FDCAN_ECR_TEC_Msk   (0xFFUL << FDCAN_ECR_TEC_Pos)
#define FDCAN_ECR_TEC   FDCAN_ECR_TEC_Msk
#define FDCAN_ECR_REC_Pos   (8U)
#define FDCAN_ECR_REC_Msk   (0x7FUL << FDCAN_ECR_REC_Pos)
#define FDCAN_ECR_REC   FDCAN_ECR_REC_Msk
#define FDCAN_ECR_RP_Pos   (15U)
#define FDCAN_ECR_RP_Msk   (0x1UL << FDCAN_ECR_RP_Pos)
#define FDCAN_ECR_RP   FDCAN_ECR_RP_Msk
#define FDCAN_ECR_CEL_Pos   (16U)
#define FDCAN_ECR_CEL_Msk   (0xFFUL << FDCAN_ECR_CEL_Pos)
#define FDCAN_ECR_CEL   FDCAN_ECR_CEL_Msk
#define FDCAN_PSR_LEC_Pos   (0U)
#define FDCAN_PSR_LEC_Msk   (0x7UL << FDCAN_PSR_LEC_Pos)
#define FDCAN_PSR_LEC   FDCAN_PSR_LEC_Msk
#define FDCAN_PSR_ACT_Pos   (3U)
#define FDCAN_PSR_ACT_Msk   (0x3UL << FDCAN_PSR_ACT_Pos)
#define FDCAN_PSR_ACT   FDCAN_PSR_ACT_Msk
#define FDCAN_PSR_EP_Pos   (5U)
#define FDCAN_PSR_EP_Msk   (0x1UL << FDCAN_PSR_EP_Pos)
#define FDCAN_PSR_EP   FDCAN_PSR_EP_Msk
#define FDCAN_PSR_EW_Pos   (6U)
#define FDCAN_PSR_EW_Msk   (0x1UL << FDCAN_PSR_EW_Pos)
#define FDCAN_PSR_EW   FDCAN_PSR_EW_Msk
#define FDCAN_PSR_BO_Pos   (7U)
#define FDCAN_PSR_BO_Msk   (0x1UL << FDCAN_PSR_BO_Pos)
#define FDCAN_PSR_BO   FDCAN_PSR_BO_Msk
#define FDCAN_PSR_DLEC_Pos   (8U)
#define FDCAN_PSR_DLEC_Msk   (0x7UL << FDCAN_PSR_DLEC_Pos)
#define FDCAN_PSR_DLEC   FDCAN_PSR_DLEC_Msk
#define FDCAN_PSR_RESI_Pos   (11U)
#define FDCAN_PSR_RESI_Msk   (0x1UL << FDCAN_PSR_RESI_Pos)
#define FDCAN_PSR_RESI   FDCAN_PSR_RESI_Msk
#define FDCAN_PSR_RBRS_Pos   (12U)
#define FDCAN_PSR_RBRS_Msk   (0x1UL << FDCAN_PSR_RBRS_Pos)
#define FDCAN_PSR_RBRS   FDCAN_PSR_RBRS_Msk
#define FDCAN_PSR_REDL_Pos   (13U)
#define FDCAN_PSR_REDL_Msk   (0x1UL << FDCAN_PSR_REDL_Pos)
#define FDCAN_PSR_REDL   FDCAN_PSR_REDL_Msk
#define FDCAN_PSR_PXE_Pos   (14U)
#define FDCAN_PSR_PXE_Msk   (0x1UL << FDCAN_PSR_PXE_Pos)
#define FDCAN_PSR_PXE   FDCAN_PSR_PXE_Msk
#define FDCAN_PSR_TDCV_Pos   (16U)
#define FDCAN_PSR_TDCV_Msk   (0x7FUL << FDCAN_PSR_TDCV_Pos)
#define FDCAN_PSR_TDCV   FDCAN_PSR_TDCV_Msk
#define FDCAN_TDCR_TDCF_Pos   (0U)
#define FDCAN_TDCR_TDCF_Msk   (0x7FUL << FDCAN_TDCR_TDCF_Pos)
#define FDCAN_TDCR_TDCF   FDCAN_TDCR_TDCF_Msk
#define FDCAN_TDCR_TDCO_Pos   (8U)
#define FDCAN_TDCR_TDCO_Msk   (0x7FUL << FDCAN_TDCR_TDCO_Pos)
#define FDCAN_TDCR_TDCO   FDCAN_TDCR_TDCO_Msk
#define FDCAN_IR_RF0N_Pos   (0U)
#define FDCAN_IR_RF0N_Msk   (0x1UL << FDCAN_IR_RF0N_Pos)
#define FDCAN_IR_RF0N   FDCAN_IR_RF0N_Msk
#define FDCAN_IR_RF0W_Pos   (1U)
#define FDCAN_IR_RF0W_Msk   (0x1UL << FDCAN_IR_RF0W_Pos)
#define FDCAN_IR_RF0W   FDCAN_IR_RF0W_Msk
#define FDCAN_IR_RF0F_Pos   (2U)
#define FDCAN_IR_RF0F_Msk   (0x1UL << FDCAN_IR_RF0F_Pos)
#define FDCAN_IR_RF0F   FDCAN_IR_RF0F_Msk
#define FDCAN_IR_RF0L_Pos   (3U)
#define FDCAN_IR_RF0L_Msk   (0x1UL << FDCAN_IR_RF0L_Pos)
#define FDCAN_IR_RF0L   FDCAN_IR_RF0L_Msk
#define FDCAN_IR_RF1N_Pos   (4U)
#define FDCAN_IR_RF1N_Msk   (0x1UL << FDCAN_IR_RF1N_Pos)
#define FDCAN_IR_RF1N   FDCAN_IR_RF1N_Msk
#define FDCAN_IR_RF1W_Pos   (5U)
#define FDCAN_IR_RF1W_Msk   (0x1UL << FDCAN_IR_RF1W_Pos)
#define FDCAN_IR_RF1W   FDCAN_IR_RF1W_Msk
#define FDCAN_IR_RF1F_Pos   (6U)
#define FDCAN_IR_RF1F_Msk   (0x1UL << FDCAN_IR_RF1F_Pos)
#define FDCAN_IR_RF1F   FDCAN_IR_RF1F_Msk
#define FDCAN_IR_RF1L_Pos   (7U)
#define FDCAN_IR_RF1L_Msk   (0x1UL << FDCAN_IR_RF1L_Pos)
#define FDCAN_IR_RF1L   FDCAN_IR_RF1L_Msk
#define FDCAN_IR_HPM_Pos   (8U)
#define FDCAN_IR_HPM_Msk   (0x1UL << FDCAN_IR_HPM_Pos)
#define FDCAN_IR_HPM   FDCAN_IR_HPM_Msk
#define FDCAN_IR_TC_Pos   (9U)
#define FDCAN_IR_TC_Msk   (0x1UL << FDCAN_IR_TC_Pos)
#define FDCAN_IR_TC   FDCAN_IR_TC_Msk
#define FDCAN_IR_TCF_Pos   (10U)
#define FDCAN_IR_TCF_Msk   (0x1UL << FDCAN_IR_TCF_Pos)
#define FDCAN_IR_TCF   FDCAN_IR_TCF_Msk
#define FDCAN_IR_TFE_Pos   (11U)
#define FDCAN_IR_TFE_Msk   (0x1UL << FDCAN_IR_TFE_Pos)
#define FDCAN_IR_TFE   FDCAN_IR_TFE_Msk
#define FDCAN_IR_TEFN_Pos   (12U)
#define FDCAN_IR_TEFN_Msk   (0x1UL << FDCAN_IR_TEFN_Pos)
#define FDCAN_IR_TEFN   FDCAN_IR_TEFN_Msk
#define FDCAN_IR_TEFW_Pos   (13U)
#define FDCAN_IR_TEFW_Msk   (0x1UL << FDCAN_IR_TEFW_Pos)
#define FDCAN_IR_TEFW   FDCAN_IR_TEFW_Msk
#define FDCAN_IR_TEFF_Pos   (14U)
#define FDCAN_IR_TEFF_Msk   (0x1UL << FDCAN_IR_TEFF_Pos)
#define FDCAN_IR_TEFF   FDCAN_IR_TEFF_Msk
#define FDCAN_IR_TEFL_Pos   (15U)
#define FDCAN_IR_TEFL_Msk   (0x1UL << FDCAN_IR_TEFL_Pos)
#define FDCAN_IR_TEFL   FDCAN_IR_TEFL_Msk
#define FDCAN_IR_TSW_Pos   (16U)
#define FDCAN_IR_TSW_Msk   (0x1UL << FDCAN_IR_TSW_Pos)
#define FDCAN_IR_TSW   FDCAN_IR_TSW_Msk
#define FDCAN_IR_MRAF_Pos   (17U)
#define FDCAN_IR_MRAF_Msk   (0x1UL << FDCAN_IR_MRAF_Pos)
#define FDCAN_IR_MRAF   FDCAN_IR_MRAF_Msk
#define FDCAN_IR_TOO_Pos   (18U)
#define FDCAN_IR_TOO_Msk   (0x1UL << FDCAN_IR_TOO_Pos)
#define FDCAN_IR_TOO   FDCAN_IR_TOO_Msk
#define FDCAN_IR_DRX_Pos   (19U)
#define FDCAN_IR_DRX_Msk   (0x1UL << FDCAN_IR_DRX_Pos)
#define FDCAN_IR_DRX   FDCAN_IR_DRX_Msk
#define FDCAN_IR_ELO_Pos   (22U)
#define FDCAN_IR_ELO_Msk   (0x1UL << FDCAN_IR_ELO_Pos)
#define FDCAN_IR_ELO   FDCAN_IR_ELO_Msk
#define FDCAN_IR_EP_Pos   (23U)
#define FDCAN_IR_EP_Msk   (0x1UL << FDCAN_IR_EP_Pos)
#define FDCAN_IR_EP   FDCAN_IR_EP_Msk
#define FDCAN_IR_EW_Pos   (24U)
#define FDCAN_IR_EW_Msk   (0x1UL << FDCAN_IR_EW_Pos)
#define FDCAN_IR_EW   FDCAN_IR_EW_Msk
#define FDCAN_IR_BO_Pos   (25U)
#define FDCAN_IR_BO_Msk   (0x1UL << FDCAN_IR_BO_Pos)
#define FDCAN_IR_BO   FDCAN_IR_BO_Msk
#define FDCAN_IR_WDI_Pos   (26U)
#define FDCAN_IR_WDI_Msk   (0x1UL << FDCAN_IR_WDI_Pos)
#define FDCAN_IR_WDI   FDCAN_IR_WDI_Msk
#define FDCAN_IR_PEA_Pos   (27U)
#define FDCAN_IR_PEA_Msk   (0x1UL << FDCAN_IR_PEA_Pos)
#define FDCAN_IR_PEA   FDCAN_IR_PEA_Msk
#define FDCAN_IR_PED_Pos   (28U)
#define FDCAN_IR_PED_Msk   (0x1UL << FDCAN_IR_PED_Pos)
#define FDCAN_IR_PED   FDCAN_IR_PED_Msk
#define FDCAN_IR_ARA_Pos   (29U)
#define FDCAN_IR_ARA_Msk   (0x1UL << FDCAN_IR_ARA_Pos)
#define FDCAN_IR_ARA   FDCAN_IR_ARA_Msk
#define FDCAN_IE_RF0NE_Pos   (0U)
#define FDCAN_IE_RF0NE_Msk   (0x1UL << FDCAN_IE_RF0NE_Pos)
#define FDCAN_IE_RF0NE   FDCAN_IE_RF0NE_Msk
#define FDCAN_IE_RF0WE_Pos   (1U)
#define FDCAN_IE_RF0WE_Msk   (0x1UL << FDCAN_IE_RF0WE_Pos)
#define FDCAN_IE_RF0WE   FDCAN_IE_RF0WE_Msk
#define FDCAN_IE_RF0FE_Pos   (2U)
#define FDCAN_IE_RF0FE_Msk   (0x1UL << FDCAN_IE_RF0FE_Pos)
#define FDCAN_IE_RF0FE   FDCAN_IE_RF0FE_Msk
#define FDCAN_IE_RF0LE_Pos   (3U)
#define FDCAN_IE_RF0LE_Msk   (0x1UL << FDCAN_IE_RF0LE_Pos)
#define FDCAN_IE_RF0LE   FDCAN_IE_RF0LE_Msk
#define FDCAN_IE_RF1NE_Pos   (4U)
#define FDCAN_IE_RF1NE_Msk   (0x1UL << FDCAN_IE_RF1NE_Pos)
#define FDCAN_IE_RF1NE   FDCAN_IE_RF1NE_Msk
#define FDCAN_IE_RF1WE_Pos   (5U)
#define FDCAN_IE_RF1WE_Msk   (0x1UL << FDCAN_IE_RF1WE_Pos)
#define FDCAN_IE_RF1WE   FDCAN_IE_RF1WE_Msk
#define FDCAN_IE_RF1FE_Pos   (6U)
#define FDCAN_IE_RF1FE_Msk   (0x1UL << FDCAN_IE_RF1FE_Pos)
#define FDCAN_IE_RF1FE   FDCAN_IE_RF1FE_Msk
#define FDCAN_IE_RF1LE_Pos   (7U)
#define FDCAN_IE_RF1LE_Msk   (0x1UL << FDCAN_IE_RF1LE_Pos)
#define FDCAN_IE_RF1LE   FDCAN_IE_RF1LE_Msk
#define FDCAN_IE_HPME_Pos   (8U)
#define FDCAN_IE_HPME_Msk   (0x1UL << FDCAN_IE_HPME_Pos)
#define FDCAN_IE_HPME   FDCAN_IE_HPME_Msk
#define FDCAN_IE_TCE_Pos   (9U)
#define FDCAN_IE_TCE_Msk   (0x1UL << FDCAN_IE_TCE_Pos)
#define FDCAN_IE_TCE   FDCAN_IE_TCE_Msk
#define FDCAN_IE_TCFE_Pos   (10U)
#define FDCAN_IE_TCFE_Msk   (0x1UL << FDCAN_IE_TCFE_Pos)
#define FDCAN_IE_TCFE   FDCAN_IE_TCFE_Msk
#define FDCAN_IE_TFEE_Pos   (11U)
#define FDCAN_IE_TFEE_Msk   (0x1UL << FDCAN_IE_TFEE_Pos)
#define FDCAN_IE_TFEE   FDCAN_IE_TFEE_Msk
#define FDCAN_IE_TEFNE_Pos   (12U)
#define FDCAN_IE_TEFNE_Msk   (0x1UL << FDCAN_IE_TEFNE_Pos)
#define FDCAN_IE_TEFNE   FDCAN_IE_TEFNE_Msk
#define FDCAN_IE_TEFWE_Pos   (13U)
#define FDCAN_IE_TEFWE_Msk   (0x1UL << FDCAN_IE_TEFWE_Pos)
#define FDCAN_IE_TEFWE   FDCAN_IE_TEFWE_Msk
#define FDCAN_IE_TEFFE_Pos   (14U)
#define FDCAN_IE_TEFFE_Msk   (0x1UL << FDCAN_IE_TEFFE_Pos)
#define FDCAN_IE_TEFFE   FDCAN_IE_TEFFE_Msk
#define FDCAN_IE_TEFLE_Pos   (15U)
#define FDCAN_IE_TEFLE_Msk   (0x1UL << FDCAN_IE_TEFLE_Pos)
#define FDCAN_IE_TEFLE   FDCAN_IE_TEFLE_Msk
#define FDCAN_IE_TSWE_Pos   (16U)
#define FDCAN_IE_TSWE_Msk   (0x1UL << FDCAN_IE_TSWE_Pos)
#define FDCAN_IE_TSWE   FDCAN_IE_TSWE_Msk
#define FDCAN_IE_MRAFE_Pos   (17U)
#define FDCAN_IE_MRAFE_Msk   (0x1UL << FDCAN_IE_MRAFE_Pos)
#define FDCAN_IE_MRAFE   FDCAN_IE_MRAFE_Msk
#define FDCAN_IE_TOOE_Pos   (18U)
#define FDCAN_IE_TOOE_Msk   (0x1UL << FDCAN_IE_TOOE_Pos)
#define FDCAN_IE_TOOE   FDCAN_IE_TOOE_Msk
#define FDCAN_IE_DRXE_Pos   (19U)
#define FDCAN_IE_DRXE_Msk   (0x1UL << FDCAN_IE_DRXE_Pos)
#define FDCAN_IE_DRXE   FDCAN_IE_DRXE_Msk
#define FDCAN_IE_BECE_Pos   (20U)
#define FDCAN_IE_BECE_Msk   (0x1UL << FDCAN_IE_BECE_Pos)
#define FDCAN_IE_BECE   FDCAN_IE_BECE_Msk
#define FDCAN_IE_BEUE_Pos   (21U)
#define FDCAN_IE_BEUE_Msk   (0x1UL << FDCAN_IE_BEUE_Pos)
#define FDCAN_IE_BEUE   FDCAN_IE_BEUE_Msk
#define FDCAN_IE_ELOE_Pos   (22U)
#define FDCAN_IE_ELOE_Msk   (0x1UL << FDCAN_IE_ELOE_Pos)
#define FDCAN_IE_ELOE   FDCAN_IE_ELOE_Msk
#define FDCAN_IE_EPE_Pos   (23U)
#define FDCAN_IE_EPE_Msk   (0x1UL << FDCAN_IE_EPE_Pos)
#define FDCAN_IE_EPE   FDCAN_IE_EPE_Msk
#define FDCAN_IE_EWE_Pos   (24U)
#define FDCAN_IE_EWE_Msk   (0x1UL << FDCAN_IE_EWE_Pos)
#define FDCAN_IE_EWE   FDCAN_IE_EWE_Msk
#define FDCAN_IE_BOE_Pos   (25U)
#define FDCAN_IE_BOE_Msk   (0x1UL << FDCAN_IE_BOE_Pos)
#define FDCAN_IE_BOE   FDCAN_IE_BOE_Msk
#define FDCAN_IE_WDIE_Pos   (26U)
#define FDCAN_IE_WDIE_Msk   (0x1UL << FDCAN_IE_WDIE_Pos)
#define FDCAN_IE_WDIE   FDCAN_IE_WDIE_Msk
#define FDCAN_IE_PEAE_Pos   (27U)
#define FDCAN_IE_PEAE_Msk   (0x1UL << FDCAN_IE_PEAE_Pos)
#define FDCAN_IE_PEAE   FDCAN_IE_PEAE_Msk
#define FDCAN_IE_PEDE_Pos   (28U)
#define FDCAN_IE_PEDE_Msk   (0x1UL << FDCAN_IE_PEDE_Pos)
#define FDCAN_IE_PEDE   FDCAN_IE_PEDE_Msk
#define FDCAN_IE_ARAE_Pos   (29U)
#define FDCAN_IE_ARAE_Msk   (0x1UL << FDCAN_IE_ARAE_Pos)
#define FDCAN_IE_ARAE   FDCAN_IE_ARAE_Msk
#define FDCAN_ILS_RF0NL_Pos   (0U)
#define FDCAN_ILS_RF0NL_Msk   (0x1UL << FDCAN_ILS_RF0NL_Pos)
#define FDCAN_ILS_RF0NL   FDCAN_ILS_RF0NL_Msk
#define FDCAN_ILS_RF0WL_Pos   (1U)
#define FDCAN_ILS_RF0WL_Msk   (0x1UL << FDCAN_ILS_RF0WL_Pos)
#define FDCAN_ILS_RF0WL   FDCAN_ILS_RF0WL_Msk
#define FDCAN_ILS_RF0FL_Pos   (2U)
#define FDCAN_ILS_RF0FL_Msk   (0x1UL << FDCAN_ILS_RF0FL_Pos)
#define FDCAN_ILS_RF0FL   FDCAN_ILS_RF0FL_Msk
#define FDCAN_ILS_RF0LL_Pos   (3U)
#define FDCAN_ILS_RF0LL_Msk   (0x1UL << FDCAN_ILS_RF0LL_Pos)
#define FDCAN_ILS_RF0LL   FDCAN_ILS_RF0LL_Msk
#define FDCAN_ILS_RF1NL_Pos   (4U)
#define FDCAN_ILS_RF1NL_Msk   (0x1UL << FDCAN_ILS_RF1NL_Pos)
#define FDCAN_ILS_RF1NL   FDCAN_ILS_RF1NL_Msk
#define FDCAN_ILS_RF1WL_Pos   (5U)
#define FDCAN_ILS_RF1WL_Msk   (0x1UL << FDCAN_ILS_RF1WL_Pos)
#define FDCAN_ILS_RF1WL   FDCAN_ILS_RF1WL_Msk
#define FDCAN_ILS_RF1FL_Pos   (6U)
#define FDCAN_ILS_RF1FL_Msk   (0x1UL << FDCAN_ILS_RF1FL_Pos)
#define FDCAN_ILS_RF1FL   FDCAN_ILS_RF1FL_Msk
#define FDCAN_ILS_RF1LL_Pos   (7U)
#define FDCAN_ILS_RF1LL_Msk   (0x1UL << FDCAN_ILS_RF1LL_Pos)
#define FDCAN_ILS_RF1LL   FDCAN_ILS_RF1LL_Msk
#define FDCAN_ILS_HPML_Pos   (8U)
#define FDCAN_ILS_HPML_Msk   (0x1UL << FDCAN_ILS_HPML_Pos)
#define FDCAN_ILS_HPML   FDCAN_ILS_HPML_Msk
#define FDCAN_ILS_TCL_Pos   (9U)
#define FDCAN_ILS_TCL_Msk   (0x1UL << FDCAN_ILS_TCL_Pos)
#define FDCAN_ILS_TCL   FDCAN_ILS_TCL_Msk
#define FDCAN_ILS_TCFL_Pos   (10U)
#define FDCAN_ILS_TCFL_Msk   (0x1UL << FDCAN_ILS_TCFL_Pos)
#define FDCAN_ILS_TCFL   FDCAN_ILS_TCFL_Msk
#define FDCAN_ILS_TFEL_Pos   (11U)
#define FDCAN_ILS_TFEL_Msk   (0x1UL << FDCAN_ILS_TFEL_Pos)
#define FDCAN_ILS_TFEL   FDCAN_ILS_TFEL_Msk
#define FDCAN_ILS_TEFNL_Pos   (12U)
#define FDCAN_ILS_TEFNL_Msk   (0x1UL << FDCAN_ILS_TEFNL_Pos)
#define FDCAN_ILS_TEFNL   FDCAN_ILS_TEFNL_Msk
#define FDCAN_ILS_TEFWL_Pos   (13U)
#define FDCAN_ILS_TEFWL_Msk   (0x1UL << FDCAN_ILS_TEFWL_Pos)
#define FDCAN_ILS_TEFWL   FDCAN_ILS_TEFWL_Msk
#define FDCAN_ILS_TEFFL_Pos   (14U)
#define FDCAN_ILS_TEFFL_Msk   (0x1UL << FDCAN_ILS_TEFFL_Pos)
#define FDCAN_ILS_TEFFL   FDCAN_ILS_TEFFL_Msk
#define FDCAN_ILS_TEFLL_Pos   (15U)
#define FDCAN_ILS_TEFLL_Msk   (0x1UL << FDCAN_ILS_TEFLL_Pos)
#define FDCAN_ILS_TEFLL   FDCAN_ILS_TEFLL_Msk
#define FDCAN_ILS_TSWL_Pos   (16U)
#define FDCAN_ILS_TSWL_Msk   (0x1UL << FDCAN_ILS_TSWL_Pos)
#define FDCAN_ILS_TSWL   FDCAN_ILS_TSWL_Msk
#define FDCAN_ILS_MRAFE_Pos   (17U)
#define FDCAN_ILS_MRAFE_Msk   (0x1UL << FDCAN_ILS_MRAFE_Pos)
#define FDCAN_ILS_MRAFE   FDCAN_ILS_MRAFE_Msk
#define FDCAN_ILS_TOOE_Pos   (18U)
#define FDCAN_ILS_TOOE_Msk   (0x1UL << FDCAN_ILS_TOOE_Pos)
#define FDCAN_ILS_TOOE   FDCAN_ILS_TOOE_Msk
#define FDCAN_ILS_DRXE_Pos   (19U)
#define FDCAN_ILS_DRXE_Msk   (0x1UL << FDCAN_ILS_DRXE_Pos)
#define FDCAN_ILS_DRXE   FDCAN_ILS_DRXE_Msk
#define FDCAN_ILS_BECE_Pos   (20U)
#define FDCAN_ILS_BECE_Msk   (0x1UL << FDCAN_ILS_BECE_Pos)
#define FDCAN_ILS_BECE   FDCAN_ILS_BECE_Msk
#define FDCAN_ILS_BEUE_Pos   (21U)
#define FDCAN_ILS_BEUE_Msk   (0x1UL << FDCAN_ILS_BEUE_Pos)
#define FDCAN_ILS_BEUE   FDCAN_ILS_BEUE_Msk
#define FDCAN_ILS_ELOE_Pos   (22U)
#define FDCAN_ILS_ELOE_Msk   (0x1UL << FDCAN_ILS_ELOE_Pos)
#define FDCAN_ILS_ELOE   FDCAN_ILS_ELOE_Msk
#define FDCAN_ILS_EPE_Pos   (23U)
#define FDCAN_ILS_EPE_Msk   (0x1UL << FDCAN_ILS_EPE_Pos)
#define FDCAN_ILS_EPE   FDCAN_ILS_EPE_Msk
#define FDCAN_ILS_EWE_Pos   (24U)
#define FDCAN_ILS_EWE_Msk   (0x1UL << FDCAN_ILS_EWE_Pos)
#define FDCAN_ILS_EWE   FDCAN_ILS_EWE_Msk
#define FDCAN_ILS_BOE_Pos   (25U)
#define FDCAN_ILS_BOE_Msk   (0x1UL << FDCAN_ILS_BOE_Pos)
#define FDCAN_ILS_BOE   FDCAN_ILS_BOE_Msk
#define FDCAN_ILS_WDIE_Pos   (26U)
#define FDCAN_ILS_WDIE_Msk   (0x1UL << FDCAN_ILS_WDIE_Pos)
#define FDCAN_ILS_WDIE   FDCAN_ILS_WDIE_Msk
#define FDCAN_ILS_PEAE_Pos   (27U)
#define FDCAN_ILS_PEAE_Msk   (0x1UL << FDCAN_ILS_PEAE_Pos)
#define FDCAN_ILS_PEAE   FDCAN_ILS_PEAE_Msk
#define FDCAN_ILS_PEDE_Pos   (28U)
#define FDCAN_ILS_PEDE_Msk   (0x1UL << FDCAN_ILS_PEDE_Pos)
#define FDCAN_ILS_PEDE   FDCAN_ILS_PEDE_Msk
#define FDCAN_ILS_ARAE_Pos   (29U)
#define FDCAN_ILS_ARAE_Msk   (0x1UL << FDCAN_ILS_ARAE_Pos)
#define FDCAN_ILS_ARAE   FDCAN_ILS_ARAE_Msk
#define FDCAN_ILE_EINT0_Pos   (0U)
#define FDCAN_ILE_EINT0_Msk   (0x1UL << FDCAN_ILE_EINT0_Pos)
#define FDCAN_ILE_EINT0   FDCAN_ILE_EINT0_Msk
#define FDCAN_ILE_EINT1_Pos   (1U)
#define FDCAN_ILE_EINT1_Msk   (0x1UL << FDCAN_ILE_EINT1_Pos)
#define FDCAN_ILE_EINT1   FDCAN_ILE_EINT1_Msk
#define FDCAN_GFC_RRFE_Pos   (0U)
#define FDCAN_GFC_RRFE_Msk   (0x1UL << FDCAN_GFC_RRFE_Pos)
#define FDCAN_GFC_RRFE   FDCAN_GFC_RRFE_Msk
#define FDCAN_GFC_RRFS_Pos   (1U)
#define FDCAN_GFC_RRFS_Msk   (0x1UL << FDCAN_GFC_RRFS_Pos)
#define FDCAN_GFC_RRFS   FDCAN_GFC_RRFS_Msk
#define FDCAN_GFC_ANFE_Pos   (2U)
#define FDCAN_GFC_ANFE_Msk   (0x3UL << FDCAN_GFC_ANFE_Pos)
#define FDCAN_GFC_ANFE   FDCAN_GFC_ANFE_Msk
#define FDCAN_GFC_ANFS_Pos   (4U)
#define FDCAN_GFC_ANFS_Msk   (0x3UL << FDCAN_GFC_ANFS_Pos)
#define FDCAN_GFC_ANFS   FDCAN_GFC_ANFS_Msk
#define FDCAN_SIDFC_FLSSA_Pos   (2U)
#define FDCAN_SIDFC_FLSSA_Msk   (0x3FFFUL << FDCAN_SIDFC_FLSSA_Pos)
#define FDCAN_SIDFC_FLSSA   FDCAN_SIDFC_FLSSA_Msk
#define FDCAN_SIDFC_LSS_Pos   (16U)
#define FDCAN_SIDFC_LSS_Msk   (0xFFUL << FDCAN_SIDFC_LSS_Pos)
#define FDCAN_SIDFC_LSS   FDCAN_SIDFC_LSS_Msk
#define FDCAN_XIDFC_FLESA_Pos   (2U)
#define FDCAN_XIDFC_FLESA_Msk   (0x3FFFUL << FDCAN_XIDFC_FLESA_Pos)
#define FDCAN_XIDFC_FLESA   FDCAN_XIDFC_FLESA_Msk
#define FDCAN_XIDFC_LSE_Pos   (16U)
#define FDCAN_XIDFC_LSE_Msk   (0x7FUL << FDCAN_XIDFC_LSE_Pos)
#define FDCAN_XIDFC_LSE   FDCAN_XIDFC_LSE_Msk
#define FDCAN_XIDAM_EIDM_Pos   (0U)
#define FDCAN_XIDAM_EIDM_Msk   (0x1FFFFFFFUL << FDCAN_XIDAM_EIDM_Pos)
#define FDCAN_XIDAM_EIDM   FDCAN_XIDAM_EIDM_Msk
#define FDCAN_HPMS_BIDX_Pos   (0U)
#define FDCAN_HPMS_BIDX_Msk   (0x3FUL << FDCAN_HPMS_BIDX_Pos)
#define FDCAN_HPMS_BIDX   FDCAN_HPMS_BIDX_Msk
#define FDCAN_HPMS_MSI_Pos   (6U)
#define FDCAN_HPMS_MSI_Msk   (0x3UL << FDCAN_HPMS_MSI_Pos)
#define FDCAN_HPMS_MSI   FDCAN_HPMS_MSI_Msk
#define FDCAN_HPMS_FIDX_Pos   (8U)
#define FDCAN_HPMS_FIDX_Msk   (0x7FUL << FDCAN_HPMS_FIDX_Pos)
#define FDCAN_HPMS_FIDX   FDCAN_HPMS_FIDX_Msk
#define FDCAN_HPMS_FLST_Pos   (15U)
#define FDCAN_HPMS_FLST_Msk   (0x1UL << FDCAN_HPMS_FLST_Pos)
#define FDCAN_HPMS_FLST   FDCAN_HPMS_FLST_Msk
#define FDCAN_NDAT1_ND0_Pos   (0U)
#define FDCAN_NDAT1_ND0_Msk   (0x1UL << FDCAN_NDAT1_ND0_Pos)
#define FDCAN_NDAT1_ND0   FDCAN_NDAT1_ND0_Msk
#define FDCAN_NDAT1_ND1_Pos   (1U)
#define FDCAN_NDAT1_ND1_Msk   (0x1UL << FDCAN_NDAT1_ND1_Pos)
#define FDCAN_NDAT1_ND1   FDCAN_NDAT1_ND1_Msk
#define FDCAN_NDAT1_ND2_Pos   (2U)
#define FDCAN_NDAT1_ND2_Msk   (0x1UL << FDCAN_NDAT1_ND2_Pos)
#define FDCAN_NDAT1_ND2   FDCAN_NDAT1_ND2_Msk
#define FDCAN_NDAT1_ND3_Pos   (3U)
#define FDCAN_NDAT1_ND3_Msk   (0x1UL << FDCAN_NDAT1_ND3_Pos)
#define FDCAN_NDAT1_ND3   FDCAN_NDAT1_ND3_Msk
#define FDCAN_NDAT1_ND4_Pos   (4U)
#define FDCAN_NDAT1_ND4_Msk   (0x1UL << FDCAN_NDAT1_ND4_Pos)
#define FDCAN_NDAT1_ND4   FDCAN_NDAT1_ND4_Msk
#define FDCAN_NDAT1_ND5_Pos   (5U)
#define FDCAN_NDAT1_ND5_Msk   (0x1UL << FDCAN_NDAT1_ND5_Pos)
#define FDCAN_NDAT1_ND5   FDCAN_NDAT1_ND5_Msk
#define FDCAN_NDAT1_ND6_Pos   (6U)
#define FDCAN_NDAT1_ND6_Msk   (0x1UL << FDCAN_NDAT1_ND6_Pos)
#define FDCAN_NDAT1_ND6   FDCAN_NDAT1_ND6_Msk
#define FDCAN_NDAT1_ND7_Pos   (7U)
#define FDCAN_NDAT1_ND7_Msk   (0x1UL << FDCAN_NDAT1_ND7_Pos)
#define FDCAN_NDAT1_ND7   FDCAN_NDAT1_ND7_Msk
#define FDCAN_NDAT1_ND8_Pos   (8U)
#define FDCAN_NDAT1_ND8_Msk   (0x1UL << FDCAN_NDAT1_ND8_Pos)
#define FDCAN_NDAT1_ND8   FDCAN_NDAT1_ND8_Msk
#define FDCAN_NDAT1_ND9_Pos   (9U)
#define FDCAN_NDAT1_ND9_Msk   (0x1UL << FDCAN_NDAT1_ND9_Pos)
#define FDCAN_NDAT1_ND9   FDCAN_NDAT1_ND9_Msk
#define FDCAN_NDAT1_ND10_Pos   (10U)
#define FDCAN_NDAT1_ND10_Msk   (0x1UL << FDCAN_NDAT1_ND10_Pos)
#define FDCAN_NDAT1_ND10   FDCAN_NDAT1_ND10_Msk
#define FDCAN_NDAT1_ND11_Pos   (11U)
#define FDCAN_NDAT1_ND11_Msk   (0x1UL << FDCAN_NDAT1_ND11_Pos)
#define FDCAN_NDAT1_ND11   FDCAN_NDAT1_ND11_Msk
#define FDCAN_NDAT1_ND12_Pos   (12U)
#define FDCAN_NDAT1_ND12_Msk   (0x1UL << FDCAN_NDAT1_ND12_Pos)
#define FDCAN_NDAT1_ND12   FDCAN_NDAT1_ND12_Msk
#define FDCAN_NDAT1_ND13_Pos   (13U)
#define FDCAN_NDAT1_ND13_Msk   (0x1UL << FDCAN_NDAT1_ND13_Pos)
#define FDCAN_NDAT1_ND13   FDCAN_NDAT1_ND13_Msk
#define FDCAN_NDAT1_ND14_Pos   (14U)
#define FDCAN_NDAT1_ND14_Msk   (0x1UL << FDCAN_NDAT1_ND14_Pos)
#define FDCAN_NDAT1_ND14   FDCAN_NDAT1_ND14_Msk
#define FDCAN_NDAT1_ND15_Pos   (15U)
#define FDCAN_NDAT1_ND15_Msk   (0x1UL << FDCAN_NDAT1_ND15_Pos)
#define FDCAN_NDAT1_ND15   FDCAN_NDAT1_ND15_Msk
#define FDCAN_NDAT1_ND16_Pos   (16U)
#define FDCAN_NDAT1_ND16_Msk   (0x1UL << FDCAN_NDAT1_ND16_Pos)
#define FDCAN_NDAT1_ND16   FDCAN_NDAT1_ND16_Msk
#define FDCAN_NDAT1_ND17_Pos   (17U)
#define FDCAN_NDAT1_ND17_Msk   (0x1UL << FDCAN_NDAT1_ND17_Pos)
#define FDCAN_NDAT1_ND17   FDCAN_NDAT1_ND17_Msk
#define FDCAN_NDAT1_ND18_Pos   (18U)
#define FDCAN_NDAT1_ND18_Msk   (0x1UL << FDCAN_NDAT1_ND18_Pos)
#define FDCAN_NDAT1_ND18   FDCAN_NDAT1_ND18_Msk
#define FDCAN_NDAT1_ND19_Pos   (19U)
#define FDCAN_NDAT1_ND19_Msk   (0x1UL << FDCAN_NDAT1_ND19_Pos)
#define FDCAN_NDAT1_ND19   FDCAN_NDAT1_ND19_Msk
#define FDCAN_NDAT1_ND20_Pos   (20U)
#define FDCAN_NDAT1_ND20_Msk   (0x1UL << FDCAN_NDAT1_ND20_Pos)
#define FDCAN_NDAT1_ND20   FDCAN_NDAT1_ND20_Msk
#define FDCAN_NDAT1_ND21_Pos   (21U)
#define FDCAN_NDAT1_ND21_Msk   (0x1UL << FDCAN_NDAT1_ND21_Pos)
#define FDCAN_NDAT1_ND21   FDCAN_NDAT1_ND21_Msk
#define FDCAN_NDAT1_ND22_Pos   (22U)
#define FDCAN_NDAT1_ND22_Msk   (0x1UL << FDCAN_NDAT1_ND22_Pos)
#define FDCAN_NDAT1_ND22   FDCAN_NDAT1_ND22_Msk
#define FDCAN_NDAT1_ND23_Pos   (23U)
#define FDCAN_NDAT1_ND23_Msk   (0x1UL << FDCAN_NDAT1_ND23_Pos)
#define FDCAN_NDAT1_ND23   FDCAN_NDAT1_ND23_Msk
#define FDCAN_NDAT1_ND24_Pos   (24U)
#define FDCAN_NDAT1_ND24_Msk   (0x1UL << FDCAN_NDAT1_ND24_Pos)
#define FDCAN_NDAT1_ND24   FDCAN_NDAT1_ND24_Msk
#define FDCAN_NDAT1_ND25_Pos   (25U)
#define FDCAN_NDAT1_ND25_Msk   (0x1UL << FDCAN_NDAT1_ND25_Pos)
#define FDCAN_NDAT1_ND25   FDCAN_NDAT1_ND25_Msk
#define FDCAN_NDAT1_ND26_Pos   (26U)
#define FDCAN_NDAT1_ND26_Msk   (0x1UL << FDCAN_NDAT1_ND26_Pos)
#define FDCAN_NDAT1_ND26   FDCAN_NDAT1_ND26_Msk
#define FDCAN_NDAT1_ND27_Pos   (27U)
#define FDCAN_NDAT1_ND27_Msk   (0x1UL << FDCAN_NDAT1_ND27_Pos)
#define FDCAN_NDAT1_ND27   FDCAN_NDAT1_ND27_Msk
#define FDCAN_NDAT1_ND28_Pos   (28U)
#define FDCAN_NDAT1_ND28_Msk   (0x1UL << FDCAN_NDAT1_ND28_Pos)
#define FDCAN_NDAT1_ND28   FDCAN_NDAT1_ND28_Msk
#define FDCAN_NDAT1_ND29_Pos   (29U)
#define FDCAN_NDAT1_ND29_Msk   (0x1UL << FDCAN_NDAT1_ND29_Pos)
#define FDCAN_NDAT1_ND29   FDCAN_NDAT1_ND29_Msk
#define FDCAN_NDAT1_ND30_Pos   (30U)
#define FDCAN_NDAT1_ND30_Msk   (0x1UL << FDCAN_NDAT1_ND30_Pos)
#define FDCAN_NDAT1_ND30   FDCAN_NDAT1_ND30_Msk
#define FDCAN_NDAT1_ND31_Pos   (31U)
#define FDCAN_NDAT1_ND31_Msk   (0x1UL << FDCAN_NDAT1_ND31_Pos)
#define FDCAN_NDAT1_ND31   FDCAN_NDAT1_ND31_Msk
#define FDCAN_NDAT2_ND32_Pos   (0U)
#define FDCAN_NDAT2_ND32_Msk   (0x1UL << FDCAN_NDAT2_ND32_Pos)
#define FDCAN_NDAT2_ND32   FDCAN_NDAT2_ND32_Msk
#define FDCAN_NDAT2_ND33_Pos   (1U)
#define FDCAN_NDAT2_ND33_Msk   (0x1UL << FDCAN_NDAT2_ND33_Pos)
#define FDCAN_NDAT2_ND33   FDCAN_NDAT2_ND33_Msk
#define FDCAN_NDAT2_ND34_Pos   (2U)
#define FDCAN_NDAT2_ND34_Msk   (0x1UL << FDCAN_NDAT2_ND34_Pos)
#define FDCAN_NDAT2_ND34   FDCAN_NDAT2_ND34_Msk
#define FDCAN_NDAT2_ND35_Pos   (3U)
#define FDCAN_NDAT2_ND35_Msk   (0x1UL << FDCAN_NDAT2_ND35_Pos)
#define FDCAN_NDAT2_ND35   FDCAN_NDAT2_ND35_Msk
#define FDCAN_NDAT2_ND36_Pos   (4U)
#define FDCAN_NDAT2_ND36_Msk   (0x1UL << FDCAN_NDAT2_ND36_Pos)
#define FDCAN_NDAT2_ND36   FDCAN_NDAT2_ND36_Msk
#define FDCAN_NDAT2_ND37_Pos   (5U)
#define FDCAN_NDAT2_ND37_Msk   (0x1UL << FDCAN_NDAT2_ND37_Pos)
#define FDCAN_NDAT2_ND37   FDCAN_NDAT2_ND37_Msk
#define FDCAN_NDAT2_ND38_Pos   (6U)
#define FDCAN_NDAT2_ND38_Msk   (0x1UL << FDCAN_NDAT2_ND38_Pos)
#define FDCAN_NDAT2_ND38   FDCAN_NDAT2_ND38_Msk
#define FDCAN_NDAT2_ND39_Pos   (7U)
#define FDCAN_NDAT2_ND39_Msk   (0x1UL << FDCAN_NDAT2_ND39_Pos)
#define FDCAN_NDAT2_ND39   FDCAN_NDAT2_ND39_Msk
#define FDCAN_NDAT2_ND40_Pos   (8U)
#define FDCAN_NDAT2_ND40_Msk   (0x1UL << FDCAN_NDAT2_ND40_Pos)
#define FDCAN_NDAT2_ND40   FDCAN_NDAT2_ND40_Msk
#define FDCAN_NDAT2_ND41_Pos   (9U)
#define FDCAN_NDAT2_ND41_Msk   (0x1UL << FDCAN_NDAT2_ND41_Pos)
#define FDCAN_NDAT2_ND41   FDCAN_NDAT2_ND41_Msk
#define FDCAN_NDAT2_ND42_Pos   (10U)
#define FDCAN_NDAT2_ND42_Msk   (0x1UL << FDCAN_NDAT2_ND42_Pos)
#define FDCAN_NDAT2_ND42   FDCAN_NDAT2_ND42_Msk
#define FDCAN_NDAT2_ND43_Pos   (11U)
#define FDCAN_NDAT2_ND43_Msk   (0x1UL << FDCAN_NDAT2_ND43_Pos)
#define FDCAN_NDAT2_ND43   FDCAN_NDAT2_ND43_Msk
#define FDCAN_NDAT2_ND44_Pos   (12U)
#define FDCAN_NDAT2_ND44_Msk   (0x1UL << FDCAN_NDAT2_ND44_Pos)
#define FDCAN_NDAT2_ND44   FDCAN_NDAT2_ND44_Msk
#define FDCAN_NDAT2_ND45_Pos   (13U)
#define FDCAN_NDAT2_ND45_Msk   (0x1UL << FDCAN_NDAT2_ND45_Pos)
#define FDCAN_NDAT2_ND45   FDCAN_NDAT2_ND45_Msk
#define FDCAN_NDAT2_ND46_Pos   (14U)
#define FDCAN_NDAT2_ND46_Msk   (0x1UL << FDCAN_NDAT2_ND46_Pos)
#define FDCAN_NDAT2_ND46   FDCAN_NDAT2_ND46_Msk
#define FDCAN_NDAT2_ND47_Pos   (15U)
#define FDCAN_NDAT2_ND47_Msk   (0x1UL << FDCAN_NDAT2_ND47_Pos)
#define FDCAN_NDAT2_ND47   FDCAN_NDAT2_ND47_Msk
#define FDCAN_NDAT2_ND48_Pos   (16U)
#define FDCAN_NDAT2_ND48_Msk   (0x1UL << FDCAN_NDAT2_ND48_Pos)
#define FDCAN_NDAT2_ND48   FDCAN_NDAT2_ND48_Msk
#define FDCAN_NDAT2_ND49_Pos   (17U)
#define FDCAN_NDAT2_ND49_Msk   (0x1UL << FDCAN_NDAT2_ND49_Pos)
#define FDCAN_NDAT2_ND49   FDCAN_NDAT2_ND49_Msk
#define FDCAN_NDAT2_ND50_Pos   (18U)
#define FDCAN_NDAT2_ND50_Msk   (0x1UL << FDCAN_NDAT2_ND50_Pos)
#define FDCAN_NDAT2_ND50   FDCAN_NDAT2_ND50_Msk
#define FDCAN_NDAT2_ND51_Pos   (19U)
#define FDCAN_NDAT2_ND51_Msk   (0x1UL << FDCAN_NDAT2_ND51_Pos)
#define FDCAN_NDAT2_ND51   FDCAN_NDAT2_ND51_Msk
#define FDCAN_NDAT2_ND52_Pos   (20U)
#define FDCAN_NDAT2_ND52_Msk   (0x1UL << FDCAN_NDAT2_ND52_Pos)
#define FDCAN_NDAT2_ND52   FDCAN_NDAT2_ND52_Msk
#define FDCAN_NDAT2_ND53_Pos   (21U)
#define FDCAN_NDAT2_ND53_Msk   (0x1UL << FDCAN_NDAT2_ND53_Pos)
#define FDCAN_NDAT2_ND53   FDCAN_NDAT2_ND53_Msk
#define FDCAN_NDAT2_ND54_Pos   (22U)
#define FDCAN_NDAT2_ND54_Msk   (0x1UL << FDCAN_NDAT2_ND54_Pos)
#define FDCAN_NDAT2_ND54   FDCAN_NDAT2_ND54_Msk
#define FDCAN_NDAT2_ND55_Pos   (23U)
#define FDCAN_NDAT2_ND55_Msk   (0x1UL << FDCAN_NDAT2_ND55_Pos)
#define FDCAN_NDAT2_ND55   FDCAN_NDAT2_ND55_Msk
#define FDCAN_NDAT2_ND56_Pos   (24U)
#define FDCAN_NDAT2_ND56_Msk   (0x1UL << FDCAN_NDAT2_ND56_Pos)
#define FDCAN_NDAT2_ND56   FDCAN_NDAT2_ND56_Msk
#define FDCAN_NDAT2_ND57_Pos   (25U)
#define FDCAN_NDAT2_ND57_Msk   (0x1UL << FDCAN_NDAT2_ND57_Pos)
#define FDCAN_NDAT2_ND57   FDCAN_NDAT2_ND57_Msk
#define FDCAN_NDAT2_ND58_Pos   (26U)
#define FDCAN_NDAT2_ND58_Msk   (0x1UL << FDCAN_NDAT2_ND58_Pos)
#define FDCAN_NDAT2_ND58   FDCAN_NDAT2_ND58_Msk
#define FDCAN_NDAT2_ND59_Pos   (27U)
#define FDCAN_NDAT2_ND59_Msk   (0x1UL << FDCAN_NDAT2_ND59_Pos)
#define FDCAN_NDAT2_ND59   FDCAN_NDAT2_ND59_Msk
#define FDCAN_NDAT2_ND60_Pos   (28U)
#define FDCAN_NDAT2_ND60_Msk   (0x1UL << FDCAN_NDAT2_ND60_Pos)
#define FDCAN_NDAT2_ND60   FDCAN_NDAT2_ND60_Msk
#define FDCAN_NDAT2_ND61_Pos   (29U)
#define FDCAN_NDAT2_ND61_Msk   (0x1UL << FDCAN_NDAT2_ND61_Pos)
#define FDCAN_NDAT2_ND61   FDCAN_NDAT2_ND61_Msk
#define FDCAN_NDAT2_ND62_Pos   (30U)
#define FDCAN_NDAT2_ND62_Msk   (0x1UL << FDCAN_NDAT2_ND62_Pos)
#define FDCAN_NDAT2_ND62   FDCAN_NDAT2_ND62_Msk
#define FDCAN_NDAT2_ND63_Pos   (31U)
#define FDCAN_NDAT2_ND63_Msk   (0x1UL << FDCAN_NDAT2_ND63_Pos)
#define FDCAN_NDAT2_ND63   FDCAN_NDAT2_ND63_Msk
#define FDCAN_RXF0C_F0SA_Pos   (2U)
#define FDCAN_RXF0C_F0SA_Msk   (0x3FFFUL << FDCAN_RXF0C_F0SA_Pos)
#define FDCAN_RXF0C_F0SA   FDCAN_RXF0C_F0SA_Msk
#define FDCAN_RXF0C_F0S_Pos   (16U)
#define FDCAN_RXF0C_F0S_Msk   (0x7FUL << FDCAN_RXF0C_F0S_Pos)
#define FDCAN_RXF0C_F0S   FDCAN_RXF0C_F0S_Msk
#define FDCAN_RXF0C_F0WM_Pos   (24U)
#define FDCAN_RXF0C_F0WM_Msk   (0x7FUL << FDCAN_RXF0C_F0WM_Pos)
#define FDCAN_RXF0C_F0WM   FDCAN_RXF0C_F0WM_Msk
#define FDCAN_RXF0C_F0OM_Pos   (31U)
#define FDCAN_RXF0C_F0OM_Msk   (0x1UL << FDCAN_RXF0C_F0OM_Pos)
#define FDCAN_RXF0C_F0OM   FDCAN_RXF0C_F0OM_Msk
#define FDCAN_RXF0S_F0FL_Pos   (0U)
#define FDCAN_RXF0S_F0FL_Msk   (0x7FUL << FDCAN_RXF0S_F0FL_Pos)
#define FDCAN_RXF0S_F0FL   FDCAN_RXF0S_F0FL_Msk
#define FDCAN_RXF0S_F0GI_Pos   (8U)
#define FDCAN_RXF0S_F0GI_Msk   (0x3FUL << FDCAN_RXF0S_F0GI_Pos)
#define FDCAN_RXF0S_F0GI   FDCAN_RXF0S_F0GI_Msk
#define FDCAN_RXF0S_F0PI_Pos   (16U)
#define FDCAN_RXF0S_F0PI_Msk   (0x3FUL << FDCAN_RXF0S_F0PI_Pos)
#define FDCAN_RXF0S_F0PI   FDCAN_RXF0S_F0PI_Msk
#define FDCAN_RXF0S_F0F_Pos   (24U)
#define FDCAN_RXF0S_F0F_Msk   (0x1UL << FDCAN_RXF0S_F0F_Pos)
#define FDCAN_RXF0S_F0F   FDCAN_RXF0S_F0F_Msk
#define FDCAN_RXF0S_RF0L_Pos   (25U)
#define FDCAN_RXF0S_RF0L_Msk   (0x1UL << FDCAN_RXF0S_RF0L_Pos)
#define FDCAN_RXF0S_RF0L   FDCAN_RXF0S_RF0L_Msk
#define FDCAN_RXF0A_F0AI_Pos   (0U)
#define FDCAN_RXF0A_F0AI_Msk   (0x3FUL << FDCAN_RXF0A_F0AI_Pos)
#define FDCAN_RXF0A_F0AI   FDCAN_RXF0A_F0AI_Msk
#define FDCAN_RXBC_RBSA_Pos   (2U)
#define FDCAN_RXBC_RBSA_Msk   (0x3FFFUL << FDCAN_RXBC_RBSA_Pos)
#define FDCAN_RXBC_RBSA   FDCAN_RXBC_RBSA_Msk
#define FDCAN_RXF1C_F1SA_Pos   (2U)
#define FDCAN_RXF1C_F1SA_Msk   (0x3FFFUL << FDCAN_RXF1C_F1SA_Pos)
#define FDCAN_RXF1C_F1SA   FDCAN_RXF1C_F1SA_Msk
#define FDCAN_RXF1C_F1S_Pos   (16U)
#define FDCAN_RXF1C_F1S_Msk   (0x7FUL << FDCAN_RXF1C_F1S_Pos)
#define FDCAN_RXF1C_F1S   FDCAN_RXF1C_F1S_Msk
#define FDCAN_RXF1C_F1WM_Pos   (24U)
#define FDCAN_RXF1C_F1WM_Msk   (0x7FUL << FDCAN_RXF1C_F1WM_Pos)
#define FDCAN_RXF1C_F1WM   FDCAN_RXF1C_F1WM_Msk
#define FDCAN_RXF1C_F1OM_Pos   (31U)
#define FDCAN_RXF1C_F1OM_Msk   (0x1UL << FDCAN_RXF1C_F1OM_Pos)
#define FDCAN_RXF1C_F1OM   FDCAN_RXF1C_F1OM_Msk
#define FDCAN_RXF1S_F1FL_Pos   (0U)
#define FDCAN_RXF1S_F1FL_Msk   (0x7FUL << FDCAN_RXF1S_F1FL_Pos)
#define FDCAN_RXF1S_F1FL   FDCAN_RXF1S_F1FL_Msk
#define FDCAN_RXF1S_F1GI_Pos   (8U)
#define FDCAN_RXF1S_F1GI_Msk   (0x3FUL << FDCAN_RXF1S_F1GI_Pos)
#define FDCAN_RXF1S_F1GI   FDCAN_RXF1S_F1GI_Msk
#define FDCAN_RXF1S_F1PI_Pos   (16U)
#define FDCAN_RXF1S_F1PI_Msk   (0x3FUL << FDCAN_RXF1S_F1PI_Pos)
#define FDCAN_RXF1S_F1PI   FDCAN_RXF1S_F1PI_Msk
#define FDCAN_RXF1S_F1F_Pos   (24U)
#define FDCAN_RXF1S_F1F_Msk   (0x1UL << FDCAN_RXF1S_F1F_Pos)
#define FDCAN_RXF1S_F1F   FDCAN_RXF1S_F1F_Msk
#define FDCAN_RXF1S_RF1L_Pos   (25U)
#define FDCAN_RXF1S_RF1L_Msk   (0x1UL << FDCAN_RXF1S_RF1L_Pos)
#define FDCAN_RXF1S_RF1L   FDCAN_RXF1S_RF1L_Msk
#define FDCAN_RXF1A_F1AI_Pos   (0U)
#define FDCAN_RXF1A_F1AI_Msk   (0x3FUL << FDCAN_RXF1A_F1AI_Pos)
#define FDCAN_RXF1A_F1AI   FDCAN_RXF1A_F1AI_Msk
#define FDCAN_RXESC_F0DS_Pos   (0U)
#define FDCAN_RXESC_F0DS_Msk   (0x7UL << FDCAN_RXESC_F0DS_Pos)
#define FDCAN_RXESC_F0DS   FDCAN_RXESC_F0DS_Msk
#define FDCAN_RXESC_F1DS_Pos   (4U)
#define FDCAN_RXESC_F1DS_Msk   (0x7UL << FDCAN_RXESC_F1DS_Pos)
#define FDCAN_RXESC_F1DS   FDCAN_RXESC_F1DS_Msk
#define FDCAN_RXESC_RBDS_Pos   (8U)
#define FDCAN_RXESC_RBDS_Msk   (0x7UL << FDCAN_RXESC_RBDS_Pos)
#define FDCAN_RXESC_RBDS   FDCAN_RXESC_RBDS_Msk
#define FDCAN_TXBC_TBSA_Pos   (2U)
#define FDCAN_TXBC_TBSA_Msk   (0x3FFFUL << FDCAN_TXBC_TBSA_Pos)
#define FDCAN_TXBC_TBSA   FDCAN_TXBC_TBSA_Msk
#define FDCAN_TXBC_NDTB_Pos   (16U)
#define FDCAN_TXBC_NDTB_Msk   (0x3FUL << FDCAN_TXBC_NDTB_Pos)
#define FDCAN_TXBC_NDTB   FDCAN_TXBC_NDTB_Msk
#define FDCAN_TXBC_TFQS_Pos   (24U)
#define FDCAN_TXBC_TFQS_Msk   (0x3FUL << FDCAN_TXBC_TFQS_Pos)
#define FDCAN_TXBC_TFQS   FDCAN_TXBC_TFQS_Msk
#define FDCAN_TXBC_TFQM_Pos   (30U)
#define FDCAN_TXBC_TFQM_Msk   (0x1UL << FDCAN_TXBC_TFQM_Pos)
#define FDCAN_TXBC_TFQM   FDCAN_TXBC_TFQM_Msk
#define FDCAN_TXFQS_TFFL_Pos   (0U)
#define FDCAN_TXFQS_TFFL_Msk   (0x3FUL << FDCAN_TXFQS_TFFL_Pos)
#define FDCAN_TXFQS_TFFL   FDCAN_TXFQS_TFFL_Msk
#define FDCAN_TXFQS_TFGI_Pos   (8U)
#define FDCAN_TXFQS_TFGI_Msk   (0x1FUL << FDCAN_TXFQS_TFGI_Pos)
#define FDCAN_TXFQS_TFGI   FDCAN_TXFQS_TFGI_Msk
#define FDCAN_TXFQS_TFQPI_Pos   (16U)
#define FDCAN_TXFQS_TFQPI_Msk   (0x1FUL << FDCAN_TXFQS_TFQPI_Pos)
#define FDCAN_TXFQS_TFQPI   FDCAN_TXFQS_TFQPI_Msk
#define FDCAN_TXFQS_TFQF_Pos   (21U)
#define FDCAN_TXFQS_TFQF_Msk   (0x1UL << FDCAN_TXFQS_TFQF_Pos)
#define FDCAN_TXFQS_TFQF   FDCAN_TXFQS_TFQF_Msk
#define FDCAN_TXESC_TBDS_Pos   (0U)
#define FDCAN_TXESC_TBDS_Msk   (0x7UL << FDCAN_TXESC_TBDS_Pos)
#define FDCAN_TXESC_TBDS   FDCAN_TXESC_TBDS_Msk
#define FDCAN_TXBRP_TRP_Pos   (0U)
#define FDCAN_TXBRP_TRP_Msk   (0xFFFFFFFFUL << FDCAN_TXBRP_TRP_Pos)
#define FDCAN_TXBRP_TRP   FDCAN_TXBRP_TRP_Msk
#define FDCAN_TXBAR_AR_Pos   (0U)
#define FDCAN_TXBAR_AR_Msk   (0xFFFFFFFFUL << FDCAN_TXBAR_AR_Pos)
#define FDCAN_TXBAR_AR   FDCAN_TXBAR_AR_Msk
#define FDCAN_TXBCR_CR_Pos   (0U)
#define FDCAN_TXBCR_CR_Msk   (0xFFFFFFFFUL << FDCAN_TXBCR_CR_Pos)
#define FDCAN_TXBCR_CR   FDCAN_TXBCR_CR_Msk
#define FDCAN_TXBTO_TO_Pos   (0U)
#define FDCAN_TXBTO_TO_Msk   (0xFFFFFFFFUL << FDCAN_TXBTO_TO_Pos)
#define FDCAN_TXBTO_TO   FDCAN_TXBTO_TO_Msk
#define FDCAN_TXBCF_CF_Pos   (0U)
#define FDCAN_TXBCF_CF_Msk   (0xFFFFFFFFUL << FDCAN_TXBCF_CF_Pos)
#define FDCAN_TXBCF_CF   FDCAN_TXBCF_CF_Msk
#define FDCAN_TXBTIE_TIE_Pos   (0U)
#define FDCAN_TXBTIE_TIE_Msk   (0xFFFFFFFFUL << FDCAN_TXBTIE_TIE_Pos)
#define FDCAN_TXBTIE_TIE   FDCAN_TXBTIE_TIE_Msk
#define FDCAN_TXBCIE_CFIE_Pos   (0U)
#define FDCAN_TXBCIE_CFIE_Msk   (0xFFFFFFFFUL << FDCAN_TXBCIE_CFIE_Pos)
#define FDCAN_TXBCIE_CFIE   FDCAN_TXBCIE_CFIE_Msk
#define FDCAN_TXEFC_EFSA_Pos   (2U)
#define FDCAN_TXEFC_EFSA_Msk   (0x3FFFUL << FDCAN_TXEFC_EFSA_Pos)
#define FDCAN_TXEFC_EFSA   FDCAN_TXEFC_EFSA_Msk
#define FDCAN_TXEFC_EFS_Pos   (16U)
#define FDCAN_TXEFC_EFS_Msk   (0x3FUL << FDCAN_TXEFC_EFS_Pos)
#define FDCAN_TXEFC_EFS   FDCAN_TXEFC_EFS_Msk
#define FDCAN_TXEFC_EFWM_Pos   (24U)
#define FDCAN_TXEFC_EFWM_Msk   (0x3FUL << FDCAN_TXEFC_EFWM_Pos)
#define FDCAN_TXEFC_EFWM   FDCAN_TXEFC_EFWM_Msk
#define FDCAN_TXEFS_EFFL_Pos   (0U)
#define FDCAN_TXEFS_EFFL_Msk   (0x3FUL << FDCAN_TXEFS_EFFL_Pos)
#define FDCAN_TXEFS_EFFL   FDCAN_TXEFS_EFFL_Msk
#define FDCAN_TXEFS_EFGI_Pos   (8U)
#define FDCAN_TXEFS_EFGI_Msk   (0x1FUL << FDCAN_TXEFS_EFGI_Pos)
#define FDCAN_TXEFS_EFGI   FDCAN_TXEFS_EFGI_Msk
#define FDCAN_TXEFS_EFPI_Pos   (16U)
#define FDCAN_TXEFS_EFPI_Msk   (0x1FUL << FDCAN_TXEFS_EFPI_Pos)
#define FDCAN_TXEFS_EFPI   FDCAN_TXEFS_EFPI_Msk
#define FDCAN_TXEFS_EFF_Pos   (24U)
#define FDCAN_TXEFS_EFF_Msk   (0x1UL << FDCAN_TXEFS_EFF_Pos)
#define FDCAN_TXEFS_EFF   FDCAN_TXEFS_EFF_Msk
#define FDCAN_TXEFS_TEFL_Pos   (25U)
#define FDCAN_TXEFS_TEFL_Msk   (0x1UL << FDCAN_TXEFS_TEFL_Pos)
#define FDCAN_TXEFS_TEFL   FDCAN_TXEFS_TEFL_Msk
#define FDCAN_TXEFA_EFAI_Pos   (0U)
#define FDCAN_TXEFA_EFAI_Msk   (0x1FUL << FDCAN_TXEFA_EFAI_Pos)
#define FDCAN_TXEFA_EFAI   FDCAN_TXEFA_EFAI_Msk
#define FDCAN_TTTMC_TMSA_Pos   (2U)
#define FDCAN_TTTMC_TMSA_Msk   (0x3FFFUL << FDCAN_TTTMC_TMSA_Pos)
#define FDCAN_TTTMC_TMSA   FDCAN_TTTMC_TMSA_Msk
#define FDCAN_TTTMC_TME_Pos   (16U)
#define FDCAN_TTTMC_TME_Msk   (0x7FUL << FDCAN_TTTMC_TME_Pos)
#define FDCAN_TTTMC_TME   FDCAN_TTTMC_TME_Msk
#define FDCAN_TTRMC_RID_Pos   (0U)
#define FDCAN_TTRMC_RID_Msk   (0x1FFFFFFFUL << FDCAN_TTRMC_RID_Pos)
#define FDCAN_TTRMC_RID   FDCAN_TTRMC_RID_Msk
#define FDCAN_TTRMC_XTD_Pos   (30U)
#define FDCAN_TTRMC_XTD_Msk   (0x1UL << FDCAN_TTRMC_XTD_Pos)
#define FDCAN_TTRMC_XTD   FDCAN_TTRMC_XTD_Msk
#define FDCAN_TTRMC_RMPS_Pos   (31U)
#define FDCAN_TTRMC_RMPS_Msk   (0x1UL << FDCAN_TTRMC_RMPS_Pos)
#define FDCAN_TTRMC_RMPS   FDCAN_TTRMC_RMPS_Msk
#define FDCAN_TTOCF_OM_Pos   (0U)
#define FDCAN_TTOCF_OM_Msk   (0x3UL << FDCAN_TTOCF_OM_Pos)
#define FDCAN_TTOCF_OM   FDCAN_TTOCF_OM_Msk
#define FDCAN_TTOCF_GEN_Pos   (3U)
#define FDCAN_TTOCF_GEN_Msk   (0x1UL << FDCAN_TTOCF_GEN_Pos)
#define FDCAN_TTOCF_GEN   FDCAN_TTOCF_GEN_Msk
#define FDCAN_TTOCF_TM_Pos   (4U)
#define FDCAN_TTOCF_TM_Msk   (0x1UL << FDCAN_TTOCF_TM_Pos)
#define FDCAN_TTOCF_TM   FDCAN_TTOCF_TM_Msk
#define FDCAN_TTOCF_LDSDL_Pos   (5U)
#define FDCAN_TTOCF_LDSDL_Msk   (0x7UL << FDCAN_TTOCF_LDSDL_Pos)
#define FDCAN_TTOCF_LDSDL   FDCAN_TTOCF_LDSDL_Msk
#define FDCAN_TTOCF_IRTO_Pos   (8U)
#define FDCAN_TTOCF_IRTO_Msk   (0x7FUL << FDCAN_TTOCF_IRTO_Pos)
#define FDCAN_TTOCF_IRTO   FDCAN_TTOCF_IRTO_Msk
#define FDCAN_TTOCF_EECS_Pos   (15U)
#define FDCAN_TTOCF_EECS_Msk   (0x1UL << FDCAN_TTOCF_EECS_Pos)
#define FDCAN_TTOCF_EECS   FDCAN_TTOCF_EECS_Msk
#define FDCAN_TTOCF_AWL_Pos   (16U)
#define FDCAN_TTOCF_AWL_Msk   (0xFFUL << FDCAN_TTOCF_AWL_Pos)
#define FDCAN_TTOCF_AWL   FDCAN_TTOCF_AWL_Msk
#define FDCAN_TTOCF_EGTF_Pos   (24U)
#define FDCAN_TTOCF_EGTF_Msk   (0x1UL << FDCAN_TTOCF_EGTF_Pos)
#define FDCAN_TTOCF_EGTF   FDCAN_TTOCF_EGTF_Msk
#define FDCAN_TTOCF_ECC_Pos   (25U)
#define FDCAN_TTOCF_ECC_Msk   (0x1UL << FDCAN_TTOCF_ECC_Pos)
#define FDCAN_TTOCF_ECC   FDCAN_TTOCF_ECC_Msk
#define FDCAN_TTOCF_EVTP_Pos   (26U)
#define FDCAN_TTOCF_EVTP_Msk   (0x1UL << FDCAN_TTOCF_EVTP_Pos)
#define FDCAN_TTOCF_EVTP   FDCAN_TTOCF_EVTP_Msk
#define FDCAN_TTMLM_CCM_Pos   (0U)
#define FDCAN_TTMLM_CCM_Msk   (0x3FUL << FDCAN_TTMLM_CCM_Pos)
#define FDCAN_TTMLM_CCM   FDCAN_TTMLM_CCM_Msk
#define FDCAN_TTMLM_CSS_Pos   (6U)
#define FDCAN_TTMLM_CSS_Msk   (0x3UL << FDCAN_TTMLM_CSS_Pos)
#define FDCAN_TTMLM_CSS   FDCAN_TTMLM_CSS_Msk
#define FDCAN_TTMLM_TXEW_Pos   (8U)
#define FDCAN_TTMLM_TXEW_Msk   (0xFUL << FDCAN_TTMLM_TXEW_Pos)
#define FDCAN_TTMLM_TXEW   FDCAN_TTMLM_TXEW_Msk
#define FDCAN_TTMLM_ENTT_Pos   (16U)
#define FDCAN_TTMLM_ENTT_Msk   (0xFFFUL << FDCAN_TTMLM_ENTT_Pos)
#define FDCAN_TTMLM_ENTT   FDCAN_TTMLM_ENTT_Msk
#define FDCAN_TURCF_NCL_Pos   (0U)
#define FDCAN_TURCF_NCL_Msk   (0xFFFFUL << FDCAN_TURCF_NCL_Pos)
#define FDCAN_TURCF_NCL   FDCAN_TURCF_NCL_Msk
#define FDCAN_TURCF_DC_Pos   (16U)
#define FDCAN_TURCF_DC_Msk   (0x3FFFUL << FDCAN_TURCF_DC_Pos)
#define FDCAN_TURCF_DC   FDCAN_TURCF_DC_Msk
#define FDCAN_TURCF_ELT_Pos   (31U)
#define FDCAN_TURCF_ELT_Msk   (0x1UL << FDCAN_TURCF_ELT_Pos)
#define FDCAN_TURCF_ELT   FDCAN_TURCF_ELT_Msk
#define FDCAN_TTOCN_SGT_Pos   (0U)
#define FDCAN_TTOCN_SGT_Msk   (0x1UL << FDCAN_TTOCN_SGT_Pos)
#define FDCAN_TTOCN_SGT   FDCAN_TTOCN_SGT_Msk
#define FDCAN_TTOCN_ECS_Pos   (1U)
#define FDCAN_TTOCN_ECS_Msk   (0x1UL << FDCAN_TTOCN_ECS_Pos)
#define FDCAN_TTOCN_ECS   FDCAN_TTOCN_ECS_Msk
#define FDCAN_TTOCN_SWP_Pos   (2U)
#define FDCAN_TTOCN_SWP_Msk   (0x1UL << FDCAN_TTOCN_SWP_Pos)
#define FDCAN_TTOCN_SWP   FDCAN_TTOCN_SWP_Msk
#define FDCAN_TTOCN_SWS_Pos   (3U)
#define FDCAN_TTOCN_SWS_Msk   (0x3UL << FDCAN_TTOCN_SWS_Pos)
#define FDCAN_TTOCN_SWS   FDCAN_TTOCN_SWS_Msk
#define FDCAN_TTOCN_RTIE_Pos   (5U)
#define FDCAN_TTOCN_RTIE_Msk   (0x1UL << FDCAN_TTOCN_RTIE_Pos)
#define FDCAN_TTOCN_RTIE   FDCAN_TTOCN_RTIE_Msk
#define FDCAN_TTOCN_TMC_Pos   (6U)
#define FDCAN_TTOCN_TMC_Msk   (0x3UL << FDCAN_TTOCN_TMC_Pos)
#define FDCAN_TTOCN_TMC   FDCAN_TTOCN_TMC_Msk
#define FDCAN_TTOCN_TTIE_Pos   (8U)
#define FDCAN_TTOCN_TTIE_Msk   (0x1UL << FDCAN_TTOCN_TTIE_Pos)
#define FDCAN_TTOCN_TTIE   FDCAN_TTOCN_TTIE_Msk
#define FDCAN_TTOCN_GCS_Pos   (9U)
#define FDCAN_TTOCN_GCS_Msk   (0x1UL << FDCAN_TTOCN_GCS_Pos)
#define FDCAN_TTOCN_GCS   FDCAN_TTOCN_GCS_Msk
#define FDCAN_TTOCN_FGP_Pos   (10U)
#define FDCAN_TTOCN_FGP_Msk   (0x1UL << FDCAN_TTOCN_FGP_Pos)
#define FDCAN_TTOCN_FGP   FDCAN_TTOCN_FGP_Msk
#define FDCAN_TTOCN_TMG_Pos   (11U)
#define FDCAN_TTOCN_TMG_Msk   (0x1UL << FDCAN_TTOCN_TMG_Pos)
#define FDCAN_TTOCN_TMG   FDCAN_TTOCN_TMG_Msk
#define FDCAN_TTOCN_NIG_Pos   (12U)
#define FDCAN_TTOCN_NIG_Msk   (0x1UL << FDCAN_TTOCN_NIG_Pos)
#define FDCAN_TTOCN_NIG   FDCAN_TTOCN_NIG_Msk
#define FDCAN_TTOCN_ESCN_Pos   (13U)
#define FDCAN_TTOCN_ESCN_Msk   (0x1UL << FDCAN_TTOCN_ESCN_Pos)
#define FDCAN_TTOCN_ESCN   FDCAN_TTOCN_ESCN_Msk
#define FDCAN_TTOCN_LCKC_Pos   (15U)
#define FDCAN_TTOCN_LCKC_Msk   (0x1UL << FDCAN_TTOCN_LCKC_Pos)
#define FDCAN_TTOCN_LCKC   FDCAN_TTOCN_LCKC_Msk
#define FDCAN_TTGTP_TP_Pos   (0U)
#define FDCAN_TTGTP_TP_Msk   (0xFFFFUL << FDCAN_TTGTP_TP_Pos)
#define FDCAN_TTGTP_TP   FDCAN_TTGTP_TP_Msk
#define FDCAN_TTGTP_CTP_Pos   (16U)
#define FDCAN_TTGTP_CTP_Msk   (0xFFFFUL << FDCAN_TTGTP_CTP_Pos)
#define FDCAN_TTGTP_CTP   FDCAN_TTGTP_CTP_Msk
#define FDCAN_TTTMK_TM_Pos   (0U)
#define FDCAN_TTTMK_TM_Msk   (0xFFFFUL << FDCAN_TTTMK_TM_Pos)
#define FDCAN_TTTMK_TM   FDCAN_TTTMK_TM_Msk
#define FDCAN_TTTMK_TICC_Pos   (16U)
#define FDCAN_TTTMK_TICC_Msk   (0x7FUL << FDCAN_TTTMK_TICC_Pos)
#define FDCAN_TTTMK_TICC   FDCAN_TTTMK_TICC_Msk
#define FDCAN_TTTMK_LCKM_Pos   (31U)
#define FDCAN_TTTMK_LCKM_Msk   (0x1UL << FDCAN_TTTMK_LCKM_Pos)
#define FDCAN_TTTMK_LCKM   FDCAN_TTTMK_LCKM_Msk
#define FDCAN_TTIR_SBC_Pos   (0U)
#define FDCAN_TTIR_SBC_Msk   (0x1UL << FDCAN_TTIR_SBC_Pos)
#define FDCAN_TTIR_SBC   FDCAN_TTIR_SBC_Msk
#define FDCAN_TTIR_SMC_Pos   (1U)
#define FDCAN_TTIR_SMC_Msk   (0x1UL << FDCAN_TTIR_SMC_Pos)
#define FDCAN_TTIR_SMC   FDCAN_TTIR_SMC_Msk
#define FDCAN_TTIR_CSM_Pos   (2U)
#define FDCAN_TTIR_CSM_Msk   (0x1UL << FDCAN_TTIR_CSM_Pos)
#define FDCAN_TTIR_CSM   FDCAN_TTIR_CSM_Msk
#define FDCAN_TTIR_SOG_Pos   (3U)
#define FDCAN_TTIR_SOG_Msk   (0x1UL << FDCAN_TTIR_SOG_Pos)
#define FDCAN_TTIR_SOG   FDCAN_TTIR_SOG_Msk
#define FDCAN_TTIR_RTMI_Pos   (4U)
#define FDCAN_TTIR_RTMI_Msk   (0x1UL << FDCAN_TTIR_RTMI_Pos)
#define FDCAN_TTIR_RTMI   FDCAN_TTIR_RTMI_Msk
#define FDCAN_TTIR_TTMI_Pos   (5U)
#define FDCAN_TTIR_TTMI_Msk   (0x1UL << FDCAN_TTIR_TTMI_Pos)
#define FDCAN_TTIR_TTMI   FDCAN_TTIR_TTMI_Msk
#define FDCAN_TTIR_SWE_Pos   (6U)
#define FDCAN_TTIR_SWE_Msk   (0x1UL << FDCAN_TTIR_SWE_Pos)
#define FDCAN_TTIR_SWE   FDCAN_TTIR_SWE_Msk
#define FDCAN_TTIR_GTW_Pos   (7U)
#define FDCAN_TTIR_GTW_Msk   (0x1UL << FDCAN_TTIR_GTW_Pos)
#define FDCAN_TTIR_GTW   FDCAN_TTIR_GTW_Msk
#define FDCAN_TTIR_GTD_Pos   (8U)
#define FDCAN_TTIR_GTD_Msk   (0x1UL << FDCAN_TTIR_GTD_Pos)
#define FDCAN_TTIR_GTD   FDCAN_TTIR_GTD_Msk
#define FDCAN_TTIR_GTE_Pos   (9U)
#define FDCAN_TTIR_GTE_Msk   (0x1UL << FDCAN_TTIR_GTE_Pos)
#define FDCAN_TTIR_GTE   FDCAN_TTIR_GTE_Msk
#define FDCAN_TTIR_TXU_Pos   (10U)
#define FDCAN_TTIR_TXU_Msk   (0x1UL << FDCAN_TTIR_TXU_Pos)
#define FDCAN_TTIR_TXU   FDCAN_TTIR_TXU_Msk
#define FDCAN_TTIR_TXO_Pos   (11U)
#define FDCAN_TTIR_TXO_Msk   (0x1UL << FDCAN_TTIR_TXO_Pos)
#define FDCAN_TTIR_TXO   FDCAN_TTIR_TXO_Msk
#define FDCAN_TTIR_SE1_Pos   (12U)
#define FDCAN_TTIR_SE1_Msk   (0x1UL << FDCAN_TTIR_SE1_Pos)
#define FDCAN_TTIR_SE1   FDCAN_TTIR_SE1_Msk
#define FDCAN_TTIR_SE2_Pos   (13U)
#define FDCAN_TTIR_SE2_Msk   (0x1UL << FDCAN_TTIR_SE2_Pos)
#define FDCAN_TTIR_SE2   FDCAN_TTIR_SE2_Msk
#define FDCAN_TTIR_ELC_Pos   (14U)
#define FDCAN_TTIR_ELC_Msk   (0x1UL << FDCAN_TTIR_ELC_Pos)
#define FDCAN_TTIR_ELC   FDCAN_TTIR_ELC_Msk
#define FDCAN_TTIR_IWT_Pos   (15U)
#define FDCAN_TTIR_IWT_Msk   (0x1UL << FDCAN_TTIR_IWT_Pos)
#define FDCAN_TTIR_IWT   FDCAN_TTIR_IWT_Msk
#define FDCAN_TTIR_WT_Pos   (16U)
#define FDCAN_TTIR_WT_Msk   (0x1UL << FDCAN_TTIR_WT_Pos)
#define FDCAN_TTIR_WT   FDCAN_TTIR_WT_Msk
#define FDCAN_TTIR_AW_Pos   (17U)
#define FDCAN_TTIR_AW_Msk   (0x1UL << FDCAN_TTIR_AW_Pos)
#define FDCAN_TTIR_AW   FDCAN_TTIR_AW_Msk
#define FDCAN_TTIR_CER_Pos   (18U)
#define FDCAN_TTIR_CER_Msk   (0x1UL << FDCAN_TTIR_CER_Pos)
#define FDCAN_TTIR_CER   FDCAN_TTIR_CER_Msk
#define FDCAN_TTIE_SBCE_Pos   (0U)
#define FDCAN_TTIE_SBCE_Msk   (0x1UL << FDCAN_TTIE_SBCE_Pos)
#define FDCAN_TTIE_SBCE   FDCAN_TTIE_SBCE_Msk
#define FDCAN_TTIE_SMCE_Pos   (1U)
#define FDCAN_TTIE_SMCE_Msk   (0x1UL << FDCAN_TTIE_SMCE_Pos)
#define FDCAN_TTIE_SMCE   FDCAN_TTIE_SMCE_Msk
#define FDCAN_TTIE_CSME_Pos   (2U)
#define FDCAN_TTIE_CSME_Msk   (0x1UL << FDCAN_TTIE_CSME_Pos)
#define FDCAN_TTIE_CSME   FDCAN_TTIE_CSME_Msk
#define FDCAN_TTIE_SOGE_Pos   (3U)
#define FDCAN_TTIE_SOGE_Msk   (0x1UL << FDCAN_TTIE_SOGE_Pos)
#define FDCAN_TTIE_SOGE   FDCAN_TTIE_SOGE_Msk
#define FDCAN_TTIE_RTMIE_Pos   (4U)
#define FDCAN_TTIE_RTMIE_Msk   (0x1UL << FDCAN_TTIE_RTMIE_Pos)
#define FDCAN_TTIE_RTMIE   FDCAN_TTIE_RTMIE_Msk
#define FDCAN_TTIE_TTMIE_Pos   (5U)
#define FDCAN_TTIE_TTMIE_Msk   (0x1UL << FDCAN_TTIE_TTMIE_Pos)
#define FDCAN_TTIE_TTMIE   FDCAN_TTIE_TTMIE_Msk
#define FDCAN_TTIE_SWEE_Pos   (6U)
#define FDCAN_TTIE_SWEE_Msk   (0x1UL << FDCAN_TTIE_SWEE_Pos)
#define FDCAN_TTIE_SWEE   FDCAN_TTIE_SWEE_Msk
#define FDCAN_TTIE_GTWE_Pos   (7U)
#define FDCAN_TTIE_GTWE_Msk   (0x1UL << FDCAN_TTIE_GTWE_Pos)
#define FDCAN_TTIE_GTWE   FDCAN_TTIE_GTWE_Msk
#define FDCAN_TTIE_GTDE_Pos   (8U)
#define FDCAN_TTIE_GTDE_Msk   (0x1UL << FDCAN_TTIE_GTDE_Pos)
#define FDCAN_TTIE_GTDE   FDCAN_TTIE_GTDE_Msk
#define FDCAN_TTIE_GTEE_Pos   (9U)
#define FDCAN_TTIE_GTEE_Msk   (0x1UL << FDCAN_TTIE_GTEE_Pos)
#define FDCAN_TTIE_GTEE   FDCAN_TTIE_GTEE_Msk
#define FDCAN_TTIE_TXUE_Pos   (10U)
#define FDCAN_TTIE_TXUE_Msk   (0x1UL << FDCAN_TTIE_TXUE_Pos)
#define FDCAN_TTIE_TXUE   FDCAN_TTIE_TXUE_Msk
#define FDCAN_TTIE_TXOE_Pos   (11U)
#define FDCAN_TTIE_TXOE_Msk   (0x1UL << FDCAN_TTIE_TXOE_Pos)
#define FDCAN_TTIE_TXOE   FDCAN_TTIE_TXOE_Msk
#define FDCAN_TTIE_SE1E_Pos   (12U)
#define FDCAN_TTIE_SE1E_Msk   (0x1UL << FDCAN_TTIE_SE1E_Pos)
#define FDCAN_TTIE_SE1E   FDCAN_TTIE_SE1E_Msk
#define FDCAN_TTIE_SE2E_Pos   (13U)
#define FDCAN_TTIE_SE2E_Msk   (0x1UL << FDCAN_TTIE_SE2E_Pos)
#define FDCAN_TTIE_SE2E   FDCAN_TTIE_SE2E_Msk
#define FDCAN_TTIE_ELCE_Pos   (14U)
#define FDCAN_TTIE_ELCE_Msk   (0x1UL << FDCAN_TTIE_ELCE_Pos)
#define FDCAN_TTIE_ELCE   FDCAN_TTIE_ELCE_Msk
#define FDCAN_TTIE_IWTE_Pos   (15U)
#define FDCAN_TTIE_IWTE_Msk   (0x1UL << FDCAN_TTIE_IWTE_Pos)
#define FDCAN_TTIE_IWTE   FDCAN_TTIE_IWTE_Msk
#define FDCAN_TTIE_WTE_Pos   (16U)
#define FDCAN_TTIE_WTE_Msk   (0x1UL << FDCAN_TTIE_WTE_Pos)
#define FDCAN_TTIE_WTE   FDCAN_TTIE_WTE_Msk
#define FDCAN_TTIE_AWE_Pos   (17U)
#define FDCAN_TTIE_AWE_Msk   (0x1UL << FDCAN_TTIE_AWE_Pos)
#define FDCAN_TTIE_AWE   FDCAN_TTIE_AWE_Msk
#define FDCAN_TTIE_CERE_Pos   (18U)
#define FDCAN_TTIE_CERE_Msk   (0x1UL << FDCAN_TTIE_CERE_Pos)
#define FDCAN_TTIE_CERE   FDCAN_TTIE_CERE_Msk
#define FDCAN_TTILS_SBCS_Pos   (0U)
#define FDCAN_TTILS_SBCS_Msk   (0x1UL << FDCAN_TTILS_SBCS_Pos)
#define FDCAN_TTILS_SBCS   FDCAN_TTILS_SBCS_Msk
#define FDCAN_TTILS_SMCS_Pos   (1U)
#define FDCAN_TTILS_SMCS_Msk   (0x1UL << FDCAN_TTILS_SMCS_Pos)
#define FDCAN_TTILS_SMCS   FDCAN_TTILS_SMCS_Msk
#define FDCAN_TTILS_CSMS_Pos   (2U)
#define FDCAN_TTILS_CSMS_Msk   (0x1UL << FDCAN_TTILS_CSMS_Pos)
#define FDCAN_TTILS_CSMS   FDCAN_TTILS_CSMS_Msk
#define FDCAN_TTILS_SOGS_Pos   (3U)
#define FDCAN_TTILS_SOGS_Msk   (0x1UL << FDCAN_TTILS_SOGS_Pos)
#define FDCAN_TTILS_SOGS   FDCAN_TTILS_SOGS_Msk
#define FDCAN_TTILS_RTMIS_Pos   (4U)
#define FDCAN_TTILS_RTMIS_Msk   (0x1UL << FDCAN_TTILS_RTMIS_Pos)
#define FDCAN_TTILS_RTMIS   FDCAN_TTILS_RTMIS_Msk
#define FDCAN_TTILS_TTMIS_Pos   (5U)
#define FDCAN_TTILS_TTMIS_Msk   (0x1UL << FDCAN_TTILS_TTMIS_Pos)
#define FDCAN_TTILS_TTMIS   FDCAN_TTILS_TTMIS_Msk
#define FDCAN_TTILS_SWES_Pos   (6U)
#define FDCAN_TTILS_SWES_Msk   (0x1UL << FDCAN_TTILS_SWES_Pos)
#define FDCAN_TTILS_SWES   FDCAN_TTILS_SWES_Msk
#define FDCAN_TTILS_GTWS_Pos   (7U)
#define FDCAN_TTILS_GTWS_Msk   (0x1UL << FDCAN_TTILS_GTWS_Pos)
#define FDCAN_TTILS_GTWS   FDCAN_TTILS_GTWS_Msk
#define FDCAN_TTILS_GTDS_Pos   (8U)
#define FDCAN_TTILS_GTDS_Msk   (0x1UL << FDCAN_TTILS_GTDS_Pos)
#define FDCAN_TTILS_GTDS   FDCAN_TTILS_GTDS_Msk
#define FDCAN_TTILS_GTES_Pos   (9U)
#define FDCAN_TTILS_GTES_Msk   (0x1UL << FDCAN_TTILS_GTES_Pos)
#define FDCAN_TTILS_GTES   FDCAN_TTILS_GTES_Msk
#define FDCAN_TTILS_TXUS_Pos   (10U)
#define FDCAN_TTILS_TXUS_Msk   (0x1UL << FDCAN_TTILS_TXUS_Pos)
#define FDCAN_TTILS_TXUS   FDCAN_TTILS_TXUS_Msk
#define FDCAN_TTILS_TXOS_Pos   (11U)
#define FDCAN_TTILS_TXOS_Msk   (0x1UL << FDCAN_TTILS_TXOS_Pos)
#define FDCAN_TTILS_TXOS   FDCAN_TTILS_TXOS_Msk
#define FDCAN_TTILS_SE1S_Pos   (12U)
#define FDCAN_TTILS_SE1S_Msk   (0x1UL << FDCAN_TTILS_SE1S_Pos)
#define FDCAN_TTILS_SE1S   FDCAN_TTILS_SE1S_Msk
#define FDCAN_TTILS_SE2S_Pos   (13U)
#define FDCAN_TTILS_SE2S_Msk   (0x1UL << FDCAN_TTILS_SE2S_Pos)
#define FDCAN_TTILS_SE2S   FDCAN_TTILS_SE2S_Msk
#define FDCAN_TTILS_ELCS_Pos   (14U)
#define FDCAN_TTILS_ELCS_Msk   (0x1UL << FDCAN_TTILS_ELCS_Pos)
#define FDCAN_TTILS_ELCS   FDCAN_TTILS_ELCS_Msk
#define FDCAN_TTILS_IWTS_Pos   (15U)
#define FDCAN_TTILS_IWTS_Msk   (0x1UL << FDCAN_TTILS_IWTS_Pos)
#define FDCAN_TTILS_IWTS   FDCAN_TTILS_IWTS_Msk
#define FDCAN_TTILS_WTS_Pos   (16U)
#define FDCAN_TTILS_WTS_Msk   (0x1UL << FDCAN_TTILS_WTS_Pos)
#define FDCAN_TTILS_WTS   FDCAN_TTILS_WTS_Msk
#define FDCAN_TTILS_AWS_Pos   (17U)
#define FDCAN_TTILS_AWS_Msk   (0x1UL << FDCAN_TTILS_AWS_Pos)
#define FDCAN_TTILS_AWS   FDCAN_TTILS_AWS_Msk
#define FDCAN_TTILS_CERS_Pos   (18U)
#define FDCAN_TTILS_CERS_Msk   (0x1UL << FDCAN_TTILS_CERS_Pos)
#define FDCAN_TTILS_CERS   FDCAN_TTILS_CERS_Msk
#define FDCAN_TTOST_EL_Pos   (0U)
#define FDCAN_TTOST_EL_Msk   (0x3UL << FDCAN_TTOST_EL_Pos)
#define FDCAN_TTOST_EL   FDCAN_TTOST_EL_Msk
#define FDCAN_TTOST_MS_Pos   (2U)
#define FDCAN_TTOST_MS_Msk   (0x3UL << FDCAN_TTOST_MS_Pos)
#define FDCAN_TTOST_MS   FDCAN_TTOST_MS_Msk
#define FDCAN_TTOST_SYS_Pos   (4U)
#define FDCAN_TTOST_SYS_Msk   (0x3UL << FDCAN_TTOST_SYS_Pos)
#define FDCAN_TTOST_SYS   FDCAN_TTOST_SYS_Msk
#define FDCAN_TTOST_QGTP_Pos   (6U)
#define FDCAN_TTOST_QGTP_Msk   (0x1UL << FDCAN_TTOST_QGTP_Pos)
#define FDCAN_TTOST_QGTP   FDCAN_TTOST_QGTP_Msk
#define FDCAN_TTOST_QCS_Pos   (7U)
#define FDCAN_TTOST_QCS_Msk   (0x1UL << FDCAN_TTOST_QCS_Pos)
#define FDCAN_TTOST_QCS   FDCAN_TTOST_QCS_Msk
#define FDCAN_TTOST_RTO_Pos   (8U)
#define FDCAN_TTOST_RTO_Msk   (0xFFUL << FDCAN_TTOST_RTO_Pos)
#define FDCAN_TTOST_RTO   FDCAN_TTOST_RTO_Msk
#define FDCAN_TTOST_WGTD_Pos   (22U)
#define FDCAN_TTOST_WGTD_Msk   (0x1UL << FDCAN_TTOST_WGTD_Pos)
#define FDCAN_TTOST_WGTD   FDCAN_TTOST_WGTD_Msk
#define FDCAN_TTOST_GFI_Pos   (23U)
#define FDCAN_TTOST_GFI_Msk   (0x1UL << FDCAN_TTOST_GFI_Pos)
#define FDCAN_TTOST_GFI   FDCAN_TTOST_GFI_Msk
#define FDCAN_TTOST_TMP_Pos   (24U)
#define FDCAN_TTOST_TMP_Msk   (0x7UL << FDCAN_TTOST_TMP_Pos)
#define FDCAN_TTOST_TMP   FDCAN_TTOST_TMP_Msk
#define FDCAN_TTOST_GSI_Pos   (27U)
#define FDCAN_TTOST_GSI_Msk   (0x1UL << FDCAN_TTOST_GSI_Pos)
#define FDCAN_TTOST_GSI   FDCAN_TTOST_GSI_Msk
#define FDCAN_TTOST_WFE_Pos   (28U)
#define FDCAN_TTOST_WFE_Msk   (0x1UL << FDCAN_TTOST_WFE_Pos)
#define FDCAN_TTOST_WFE   FDCAN_TTOST_WFE_Msk
#define FDCAN_TTOST_AWE_Pos   (29U)
#define FDCAN_TTOST_AWE_Msk   (0x1UL << FDCAN_TTOST_AWE_Pos)
#define FDCAN_TTOST_AWE   FDCAN_TTOST_AWE_Msk
#define FDCAN_TTOST_WECS_Pos   (30U)
#define FDCAN_TTOST_WECS_Msk   (0x1UL << FDCAN_TTOST_WECS_Pos)
#define FDCAN_TTOST_WECS   FDCAN_TTOST_WECS_Msk
#define FDCAN_TTOST_SPL_Pos   (31U)
#define FDCAN_TTOST_SPL_Msk   (0x1UL << FDCAN_TTOST_SPL_Pos)
#define FDCAN_TTOST_SPL   FDCAN_TTOST_SPL_Msk
#define FDCAN_TURNA_NAV_Pos   (0U)
#define FDCAN_TURNA_NAV_Msk   (0x3FFFFUL << FDCAN_TURNA_NAV_Pos)
#define FDCAN_TURNA_NAV   FDCAN_TURNA_NAV_Msk
#define FDCAN_TTLGT_LT_Pos   (0U)
#define FDCAN_TTLGT_LT_Msk   (0xFFFFUL << FDCAN_TTLGT_LT_Pos)
#define FDCAN_TTLGT_LT   FDCAN_TTLGT_LT_Msk
#define FDCAN_TTLGT_GT_Pos   (16U)
#define FDCAN_TTLGT_GT_Msk   (0xFFFFUL << FDCAN_TTLGT_GT_Pos)
#define FDCAN_TTLGT_GT   FDCAN_TTLGT_GT_Msk
#define FDCAN_TTCTC_CT_Pos   (0U)
#define FDCAN_TTCTC_CT_Msk   (0xFFFFUL << FDCAN_TTCTC_CT_Pos)
#define FDCAN_TTCTC_CT   FDCAN_TTCTC_CT_Msk
#define FDCAN_TTCTC_CC_Pos   (16U)
#define FDCAN_TTCTC_CC_Msk   (0x3FUL << FDCAN_TTCTC_CC_Pos)
#define FDCAN_TTCTC_CC   FDCAN_TTCTC_CC_Msk
#define FDCAN_TTCPT_CCV_Pos   (0U)
#define FDCAN_TTCPT_CCV_Msk   (0x3FUL << FDCAN_TTCPT_CCV_Pos)
#define FDCAN_TTCPT_CCV   FDCAN_TTCPT_CCV_Msk
#define FDCAN_TTCPT_SWV_Pos   (16U)
#define FDCAN_TTCPT_SWV_Msk   (0xFFFFUL << FDCAN_TTCPT_SWV_Pos)
#define FDCAN_TTCPT_SWV   FDCAN_TTCPT_SWV_Msk
#define FDCAN_TTCSM_CSM_Pos   (0U)
#define FDCAN_TTCSM_CSM_Msk   (0xFFFFUL << FDCAN_TTCSM_CSM_Pos)
#define FDCAN_TTCSM_CSM   FDCAN_TTCSM_CSM_Msk
#define FDCAN_TTTS_SWTSEL_Pos   (0U)
#define FDCAN_TTTS_SWTSEL_Msk   (0x3UL << FDCAN_TTTS_SWTSEL_Pos)
#define FDCAN_TTTS_SWTSEL   FDCAN_TTTS_SWTSEL_Msk
#define FDCAN_TTTS_EVTSEL_Pos   (4U)
#define FDCAN_TTTS_EVTSEL_Msk   (0x3UL << FDCAN_TTTS_EVTSEL_Pos)
#define FDCAN_TTTS_EVTSEL   FDCAN_TTTS_EVTSEL_Msk
#define FDCANCCU_CREL_DAY_Pos   (0U)
#define FDCANCCU_CREL_DAY_Msk   (0xFFUL << FDCANCCU_CREL_DAY_Pos)
#define FDCANCCU_CREL_DAY   FDCANCCU_CREL_DAY_Msk
#define FDCANCCU_CREL_MON_Pos   (8U)
#define FDCANCCU_CREL_MON_Msk   (0xFFUL << FDCANCCU_CREL_MON_Pos)
#define FDCANCCU_CREL_MON   FDCANCCU_CREL_MON_Msk
#define FDCANCCU_CREL_YEAR_Pos   (16U)
#define FDCANCCU_CREL_YEAR_Msk   (0xFUL << FDCANCCU_CREL_YEAR_Pos)
#define FDCANCCU_CREL_YEAR   FDCANCCU_CREL_YEAR_Msk
#define FDCANCCU_CREL_SUBSTEP_Pos   (20U)
#define FDCANCCU_CREL_SUBSTEP_Msk   (0xFUL << FDCANCCU_CREL_SUBSTEP_Pos)
#define FDCANCCU_CREL_SUBSTEP   FDCANCCU_CREL_SUBSTEP_Msk
#define FDCANCCU_CREL_STEP_Pos   (24U)
#define FDCANCCU_CREL_STEP_Msk   (0xFUL << FDCANCCU_CREL_STEP_Pos)
#define FDCANCCU_CREL_STEP   FDCANCCU_CREL_STEP_Msk
#define FDCANCCU_CREL_REL_Pos   (28U)
#define FDCANCCU_CREL_REL_Msk   (0xFUL << FDCANCCU_CREL_REL_Pos)
#define FDCANCCU_CREL_REL   FDCANCCU_CREL_REL_Msk
#define FDCANCCU_CCFG_TQBT_Pos   (0U)
#define FDCANCCU_CCFG_TQBT_Msk   (0x1FUL << FDCANCCU_CCFG_TQBT_Pos)
#define FDCANCCU_CCFG_TQBT   FDCANCCU_CCFG_TQBT_Msk
#define FDCANCCU_CCFG_BCC_Pos   (6U)
#define FDCANCCU_CCFG_BCC_Msk   (0x1UL << FDCANCCU_CCFG_BCC_Pos)
#define FDCANCCU_CCFG_BCC   FDCANCCU_CCFG_BCC_Msk
#define FDCANCCU_CCFG_CFL_Pos   (7U)
#define FDCANCCU_CCFG_CFL_Msk   (0x1UL << FDCANCCU_CCFG_CFL_Pos)
#define FDCANCCU_CCFG_CFL   FDCANCCU_CCFG_CFL_Msk
#define FDCANCCU_CCFG_OCPM_Pos   (8U)
#define FDCANCCU_CCFG_OCPM_Msk   (0xFFUL << FDCANCCU_CCFG_OCPM_Pos)
#define FDCANCCU_CCFG_OCPM   FDCANCCU_CCFG_OCPM_Msk
#define FDCANCCU_CCFG_CDIV_Pos   (16U)
#define FDCANCCU_CCFG_CDIV_Msk   (0xFUL << FDCANCCU_CCFG_CDIV_Pos)
#define FDCANCCU_CCFG_CDIV   FDCANCCU_CCFG_CDIV_Msk
#define FDCANCCU_CCFG_SWR_Pos   (31U)
#define FDCANCCU_CCFG_SWR_Msk   (0x1UL << FDCANCCU_CCFG_SWR_Pos)
#define FDCANCCU_CCFG_SWR   FDCANCCU_CCFG_SWR_Msk
#define FDCANCCU_CSTAT_OCPC_Pos   (0U)
#define FDCANCCU_CSTAT_OCPC_Msk   (0x3FFFFUL << FDCANCCU_CSTAT_OCPC_Pos)
#define FDCANCCU_CSTAT_OCPC   FDCANCCU_CSTAT_OCPC_Msk
#define FDCANCCU_CSTAT_TQC_Pos   (18U)
#define FDCANCCU_CSTAT_TQC_Msk   (0x7FFUL << FDCANCCU_CSTAT_TQC_Pos)
#define FDCANCCU_CSTAT_TQC   FDCANCCU_CSTAT_TQC_Msk
#define FDCANCCU_CSTAT_CALS_Pos   (30U)
#define FDCANCCU_CSTAT_CALS_Msk   (0x3UL << FDCANCCU_CSTAT_CALS_Pos)
#define FDCANCCU_CSTAT_CALS   FDCANCCU_CSTAT_CALS_Msk
#define FDCANCCU_CWD_WDC_Pos   (0U)
#define FDCANCCU_CWD_WDC_Msk   (0xFFFFUL << FDCANCCU_CWD_WDC_Pos)
#define FDCANCCU_CWD_WDC   FDCANCCU_CWD_WDC_Msk
#define FDCANCCU_CWD_WDV_Pos   (16U)
#define FDCANCCU_CWD_WDV_Msk   (0xFFFFUL << FDCANCCU_CWD_WDV_Pos)
#define FDCANCCU_CWD_WDV   FDCANCCU_CWD_WDV_Msk
#define FDCANCCU_IR_CWE_Pos   (0U)
#define FDCANCCU_IR_CWE_Msk   (0x1UL << FDCANCCU_IR_CWE_Pos)
#define FDCANCCU_IR_CWE   FDCANCCU_IR_CWE_Msk
#define FDCANCCU_IR_CSC_Pos   (1U)
#define FDCANCCU_IR_CSC_Msk   (0x1UL << FDCANCCU_IR_CSC_Pos)
#define FDCANCCU_IR_CSC   FDCANCCU_IR_CSC_Msk
#define FDCANCCU_IE_CWEE_Pos   (0U)
#define FDCANCCU_IE_CWEE_Msk   (0x1UL << FDCANCCU_IE_CWEE_Pos)
#define FDCANCCU_IE_CWEE   FDCANCCU_IE_CWEE_Msk
#define FDCANCCU_IE_CSCE_Pos   (1U)
#define FDCANCCU_IE_CSCE_Msk   (0x1UL << FDCANCCU_IE_CSCE_Pos)
#define FDCANCCU_IE_CSCE   FDCANCCU_IE_CSCE_Msk
#define CEC_CR_CECEN_Pos   (0U)
#define CEC_CR_CECEN_Msk   (0x1UL << CEC_CR_CECEN_Pos)
#define CEC_CR_CECEN   CEC_CR_CECEN_Msk
#define CEC_CR_TXSOM_Pos   (1U)
#define CEC_CR_TXSOM_Msk   (0x1UL << CEC_CR_TXSOM_Pos)
#define CEC_CR_TXSOM   CEC_CR_TXSOM_Msk
#define CEC_CR_TXEOM_Pos   (2U)
#define CEC_CR_TXEOM_Msk   (0x1UL << CEC_CR_TXEOM_Pos)
#define CEC_CR_TXEOM   CEC_CR_TXEOM_Msk
#define CEC_CFGR_SFT_Pos   (0U)
#define CEC_CFGR_SFT_Msk   (0x7UL << CEC_CFGR_SFT_Pos)
#define CEC_CFGR_SFT   CEC_CFGR_SFT_Msk
#define CEC_CFGR_RXTOL_Pos   (3U)
#define CEC_CFGR_RXTOL_Msk   (0x1UL << CEC_CFGR_RXTOL_Pos)
#define CEC_CFGR_RXTOL   CEC_CFGR_RXTOL_Msk
#define CEC_CFGR_BRESTP_Pos   (4U)
#define CEC_CFGR_BRESTP_Msk   (0x1UL << CEC_CFGR_BRESTP_Pos)
#define CEC_CFGR_BRESTP   CEC_CFGR_BRESTP_Msk
#define CEC_CFGR_BREGEN_Pos   (5U)
#define CEC_CFGR_BREGEN_Msk   (0x1UL << CEC_CFGR_BREGEN_Pos)
#define CEC_CFGR_BREGEN   CEC_CFGR_BREGEN_Msk
#define CEC_CFGR_LBPEGEN_Pos   (6U)
#define CEC_CFGR_LBPEGEN_Msk   (0x1UL << CEC_CFGR_LBPEGEN_Pos)
#define CEC_CFGR_LBPEGEN   CEC_CFGR_LBPEGEN_Msk
#define CEC_CFGR_SFTOPT_Pos   (8U)
#define CEC_CFGR_SFTOPT_Msk   (0x1UL << CEC_CFGR_SFTOPT_Pos)
#define CEC_CFGR_SFTOPT   CEC_CFGR_SFTOPT_Msk
#define CEC_CFGR_BRDNOGEN_Pos   (7U)
#define CEC_CFGR_BRDNOGEN_Msk   (0x1UL << CEC_CFGR_BRDNOGEN_Pos)
#define CEC_CFGR_BRDNOGEN   CEC_CFGR_BRDNOGEN_Msk
#define CEC_CFGR_OAR_Pos   (16U)
#define CEC_CFGR_OAR_Msk   (0x7FFFUL << CEC_CFGR_OAR_Pos)
#define CEC_CFGR_OAR   CEC_CFGR_OAR_Msk
#define CEC_CFGR_LSTN_Pos   (31U)
#define CEC_CFGR_LSTN_Msk   (0x1UL << CEC_CFGR_LSTN_Pos)
#define CEC_CFGR_LSTN   CEC_CFGR_LSTN_Msk
#define CEC_TXDR_TXD_Pos   (0U)
#define CEC_TXDR_TXD_Msk   (0xFFUL << CEC_TXDR_TXD_Pos)
#define CEC_TXDR_TXD   CEC_TXDR_TXD_Msk
#define CEC_RXDR_RXD_Pos   (0U)
#define CEC_RXDR_RXD_Msk   (0xFFUL << CEC_RXDR_RXD_Pos)
#define CEC_RXDR_RXD   CEC_RXDR_RXD_Msk
#define CEC_ISR_RXBR_Pos   (0U)
#define CEC_ISR_RXBR_Msk   (0x1UL << CEC_ISR_RXBR_Pos)
#define CEC_ISR_RXBR   CEC_ISR_RXBR_Msk
#define CEC_ISR_RXEND_Pos   (1U)
#define CEC_ISR_RXEND_Msk   (0x1UL << CEC_ISR_RXEND_Pos)
#define CEC_ISR_RXEND   CEC_ISR_RXEND_Msk
#define CEC_ISR_RXOVR_Pos   (2U)
#define CEC_ISR_RXOVR_Msk   (0x1UL << CEC_ISR_RXOVR_Pos)
#define CEC_ISR_RXOVR   CEC_ISR_RXOVR_Msk
#define CEC_ISR_BRE_Pos   (3U)
#define CEC_ISR_BRE_Msk   (0x1UL << CEC_ISR_BRE_Pos)
#define CEC_ISR_BRE   CEC_ISR_BRE_Msk
#define CEC_ISR_SBPE_Pos   (4U)
#define CEC_ISR_SBPE_Msk   (0x1UL << CEC_ISR_SBPE_Pos)
#define CEC_ISR_SBPE   CEC_ISR_SBPE_Msk
#define CEC_ISR_LBPE_Pos   (5U)
#define CEC_ISR_LBPE_Msk   (0x1UL << CEC_ISR_LBPE_Pos)
#define CEC_ISR_LBPE   CEC_ISR_LBPE_Msk
#define CEC_ISR_RXACKE_Pos   (6U)
#define CEC_ISR_RXACKE_Msk   (0x1UL << CEC_ISR_RXACKE_Pos)
#define CEC_ISR_RXACKE   CEC_ISR_RXACKE_Msk
#define CEC_ISR_ARBLST_Pos   (7U)
#define CEC_ISR_ARBLST_Msk   (0x1UL << CEC_ISR_ARBLST_Pos)
#define CEC_ISR_ARBLST   CEC_ISR_ARBLST_Msk
#define CEC_ISR_TXBR_Pos   (8U)
#define CEC_ISR_TXBR_Msk   (0x1UL << CEC_ISR_TXBR_Pos)
#define CEC_ISR_TXBR   CEC_ISR_TXBR_Msk
#define CEC_ISR_TXEND_Pos   (9U)
#define CEC_ISR_TXEND_Msk   (0x1UL << CEC_ISR_TXEND_Pos)
#define CEC_ISR_TXEND   CEC_ISR_TXEND_Msk
#define CEC_ISR_TXUDR_Pos   (10U)
#define CEC_ISR_TXUDR_Msk   (0x1UL << CEC_ISR_TXUDR_Pos)
#define CEC_ISR_TXUDR   CEC_ISR_TXUDR_Msk
#define CEC_ISR_TXERR_Pos   (11U)
#define CEC_ISR_TXERR_Msk   (0x1UL << CEC_ISR_TXERR_Pos)
#define CEC_ISR_TXERR   CEC_ISR_TXERR_Msk
#define CEC_ISR_TXACKE_Pos   (12U)
#define CEC_ISR_TXACKE_Msk   (0x1UL << CEC_ISR_TXACKE_Pos)
#define CEC_ISR_TXACKE   CEC_ISR_TXACKE_Msk
#define CEC_IER_RXBRIE_Pos   (0U)
#define CEC_IER_RXBRIE_Msk   (0x1UL << CEC_IER_RXBRIE_Pos)
#define CEC_IER_RXBRIE   CEC_IER_RXBRIE_Msk
#define CEC_IER_RXENDIE_Pos   (1U)
#define CEC_IER_RXENDIE_Msk   (0x1UL << CEC_IER_RXENDIE_Pos)
#define CEC_IER_RXENDIE   CEC_IER_RXENDIE_Msk
#define CEC_IER_RXOVRIE_Pos   (2U)
#define CEC_IER_RXOVRIE_Msk   (0x1UL << CEC_IER_RXOVRIE_Pos)
#define CEC_IER_RXOVRIE   CEC_IER_RXOVRIE_Msk
#define CEC_IER_BREIE_Pos   (3U)
#define CEC_IER_BREIE_Msk   (0x1UL << CEC_IER_BREIE_Pos)
#define CEC_IER_BREIE   CEC_IER_BREIE_Msk
#define CEC_IER_SBPEIE_Pos   (4U)
#define CEC_IER_SBPEIE_Msk   (0x1UL << CEC_IER_SBPEIE_Pos)
#define CEC_IER_SBPEIE   CEC_IER_SBPEIE_Msk
#define CEC_IER_LBPEIE_Pos   (5U)
#define CEC_IER_LBPEIE_Msk   (0x1UL << CEC_IER_LBPEIE_Pos)
#define CEC_IER_LBPEIE   CEC_IER_LBPEIE_Msk
#define CEC_IER_RXACKEIE_Pos   (6U)
#define CEC_IER_RXACKEIE_Msk   (0x1UL << CEC_IER_RXACKEIE_Pos)
#define CEC_IER_RXACKEIE   CEC_IER_RXACKEIE_Msk
#define CEC_IER_ARBLSTIE_Pos   (7U)
#define CEC_IER_ARBLSTIE_Msk   (0x1UL << CEC_IER_ARBLSTIE_Pos)
#define CEC_IER_ARBLSTIE   CEC_IER_ARBLSTIE_Msk
#define CEC_IER_TXBRIE_Pos   (8U)
#define CEC_IER_TXBRIE_Msk   (0x1UL << CEC_IER_TXBRIE_Pos)
#define CEC_IER_TXBRIE   CEC_IER_TXBRIE_Msk
#define CEC_IER_TXENDIE_Pos   (9U)
#define CEC_IER_TXENDIE_Msk   (0x1UL << CEC_IER_TXENDIE_Pos)
#define CEC_IER_TXENDIE   CEC_IER_TXENDIE_Msk
#define CEC_IER_TXUDRIE_Pos   (10U)
#define CEC_IER_TXUDRIE_Msk   (0x1UL << CEC_IER_TXUDRIE_Pos)
#define CEC_IER_TXUDRIE   CEC_IER_TXUDRIE_Msk
#define CEC_IER_TXERRIE_Pos   (11U)
#define CEC_IER_TXERRIE_Msk   (0x1UL << CEC_IER_TXERRIE_Pos)
#define CEC_IER_TXERRIE   CEC_IER_TXERRIE_Msk
#define CEC_IER_TXACKEIE_Pos   (12U)
#define CEC_IER_TXACKEIE_Msk   (0x1UL << CEC_IER_TXACKEIE_Pos)
#define CEC_IER_TXACKEIE   CEC_IER_TXACKEIE_Msk
#define CRC_DR_DR_Pos   (0U)
#define CRC_DR_DR_Msk   (0xFFFFFFFFUL << CRC_DR_DR_Pos)
#define CRC_DR_DR   CRC_DR_DR_Msk
#define CRC_IDR_IDR_Pos   (0U)
#define CRC_IDR_IDR_Msk   (0xFFFFFFFFUL << CRC_IDR_IDR_Pos)
#define CRC_IDR_IDR   CRC_IDR_IDR_Msk
#define CRC_CR_RESET_Pos   (0U)
#define CRC_CR_RESET_Msk   (0x1UL << CRC_CR_RESET_Pos)
#define CRC_CR_RESET   CRC_CR_RESET_Msk
#define CRC_CR_POLYSIZE_Pos   (3U)
#define CRC_CR_POLYSIZE_Msk   (0x3UL << CRC_CR_POLYSIZE_Pos)
#define CRC_CR_POLYSIZE   CRC_CR_POLYSIZE_Msk
#define CRC_CR_POLYSIZE_0   (0x1UL << CRC_CR_POLYSIZE_Pos)
#define CRC_CR_POLYSIZE_1   (0x2UL << CRC_CR_POLYSIZE_Pos)
#define CRC_CR_REV_IN_Pos   (5U)
#define CRC_CR_REV_IN_Msk   (0x3UL << CRC_CR_REV_IN_Pos)
#define CRC_CR_REV_IN   CRC_CR_REV_IN_Msk
#define CRC_CR_REV_IN_0   (0x1UL << CRC_CR_REV_IN_Pos)
#define CRC_CR_REV_IN_1   (0x2UL << CRC_CR_REV_IN_Pos)
#define CRC_CR_REV_OUT_Pos   (7U)
#define CRC_CR_REV_OUT_Msk   (0x1UL << CRC_CR_REV_OUT_Pos)
#define CRC_CR_REV_OUT   CRC_CR_REV_OUT_Msk
#define CRC_INIT_INIT_Pos   (0U)
#define CRC_INIT_INIT_Msk   (0xFFFFFFFFUL << CRC_INIT_INIT_Pos)
#define CRC_INIT_INIT   CRC_INIT_INIT_Msk
#define CRC_POL_POL_Pos   (0U)
#define CRC_POL_POL_Msk   (0xFFFFFFFFUL << CRC_POL_POL_Pos)
#define CRC_POL_POL   CRC_POL_POL_Msk
#define CRS_CR_SYNCOKIE_Pos   (0U)
#define CRS_CR_SYNCOKIE_Msk   (0x1UL << CRS_CR_SYNCOKIE_Pos)
#define CRS_CR_SYNCOKIE   CRS_CR_SYNCOKIE_Msk
#define CRS_CR_SYNCWARNIE_Pos   (1U)
#define CRS_CR_SYNCWARNIE_Msk   (0x1UL << CRS_CR_SYNCWARNIE_Pos)
#define CRS_CR_SYNCWARNIE   CRS_CR_SYNCWARNIE_Msk
#define CRS_CR_ERRIE_Pos   (2U)
#define CRS_CR_ERRIE_Msk   (0x1UL << CRS_CR_ERRIE_Pos)
#define CRS_CR_ERRIE   CRS_CR_ERRIE_Msk
#define CRS_CR_ESYNCIE_Pos   (3U)
#define CRS_CR_ESYNCIE_Msk   (0x1UL << CRS_CR_ESYNCIE_Pos)
#define CRS_CR_ESYNCIE   CRS_CR_ESYNCIE_Msk
#define CRS_CR_CEN_Pos   (5U)
#define CRS_CR_CEN_Msk   (0x1UL << CRS_CR_CEN_Pos)
#define CRS_CR_CEN   CRS_CR_CEN_Msk
#define CRS_CR_AUTOTRIMEN_Pos   (6U)
#define CRS_CR_AUTOTRIMEN_Msk   (0x1UL << CRS_CR_AUTOTRIMEN_Pos)
#define CRS_CR_AUTOTRIMEN   CRS_CR_AUTOTRIMEN_Msk
#define CRS_CR_SWSYNC_Pos   (7U)
#define CRS_CR_SWSYNC_Msk   (0x1UL << CRS_CR_SWSYNC_Pos)
#define CRS_CR_SWSYNC   CRS_CR_SWSYNC_Msk
#define CRS_CR_TRIM_Pos   (8U)
#define CRS_CR_TRIM_Msk   (0x3FUL << CRS_CR_TRIM_Pos)
#define CRS_CR_TRIM   CRS_CR_TRIM_Msk
#define CRS_CFGR_RELOAD_Pos   (0U)
#define CRS_CFGR_RELOAD_Msk   (0xFFFFUL << CRS_CFGR_RELOAD_Pos)
#define CRS_CFGR_RELOAD   CRS_CFGR_RELOAD_Msk
#define CRS_CFGR_FELIM_Pos   (16U)
#define CRS_CFGR_FELIM_Msk   (0xFFUL << CRS_CFGR_FELIM_Pos)
#define CRS_CFGR_FELIM   CRS_CFGR_FELIM_Msk
#define CRS_CFGR_SYNCDIV_Pos   (24U)
#define CRS_CFGR_SYNCDIV_Msk   (0x7UL << CRS_CFGR_SYNCDIV_Pos)
#define CRS_CFGR_SYNCDIV   CRS_CFGR_SYNCDIV_Msk
#define CRS_CFGR_SYNCDIV_0   (0x1UL << CRS_CFGR_SYNCDIV_Pos)
#define CRS_CFGR_SYNCDIV_1   (0x2UL << CRS_CFGR_SYNCDIV_Pos)
#define CRS_CFGR_SYNCDIV_2   (0x4UL << CRS_CFGR_SYNCDIV_Pos)
#define CRS_CFGR_SYNCSRC_Pos   (28U)
#define CRS_CFGR_SYNCSRC_Msk   (0x3UL << CRS_CFGR_SYNCSRC_Pos)
#define CRS_CFGR_SYNCSRC   CRS_CFGR_SYNCSRC_Msk
#define CRS_CFGR_SYNCSRC_0   (0x1UL << CRS_CFGR_SYNCSRC_Pos)
#define CRS_CFGR_SYNCSRC_1   (0x2UL << CRS_CFGR_SYNCSRC_Pos)
#define CRS_CFGR_SYNCPOL_Pos   (31U)
#define CRS_CFGR_SYNCPOL_Msk   (0x1UL << CRS_CFGR_SYNCPOL_Pos)
#define CRS_CFGR_SYNCPOL   CRS_CFGR_SYNCPOL_Msk
#define CRS_ISR_SYNCOKF_Pos   (0U)
#define CRS_ISR_SYNCOKF_Msk   (0x1UL << CRS_ISR_SYNCOKF_Pos)
#define CRS_ISR_SYNCOKF   CRS_ISR_SYNCOKF_Msk
#define CRS_ISR_SYNCWARNF_Pos   (1U)
#define CRS_ISR_SYNCWARNF_Msk   (0x1UL << CRS_ISR_SYNCWARNF_Pos)
#define CRS_ISR_SYNCWARNF   CRS_ISR_SYNCWARNF_Msk
#define CRS_ISR_ERRF_Pos   (2U)
#define CRS_ISR_ERRF_Msk   (0x1UL << CRS_ISR_ERRF_Pos)
#define CRS_ISR_ERRF   CRS_ISR_ERRF_Msk
#define CRS_ISR_ESYNCF_Pos   (3U)
#define CRS_ISR_ESYNCF_Msk   (0x1UL << CRS_ISR_ESYNCF_Pos)
#define CRS_ISR_ESYNCF   CRS_ISR_ESYNCF_Msk
#define CRS_ISR_SYNCERR_Pos   (8U)
#define CRS_ISR_SYNCERR_Msk   (0x1UL << CRS_ISR_SYNCERR_Pos)
#define CRS_ISR_SYNCERR   CRS_ISR_SYNCERR_Msk
#define CRS_ISR_SYNCMISS_Pos   (9U)
#define CRS_ISR_SYNCMISS_Msk   (0x1UL << CRS_ISR_SYNCMISS_Pos)
#define CRS_ISR_SYNCMISS   CRS_ISR_SYNCMISS_Msk
#define CRS_ISR_TRIMOVF_Pos   (10U)
#define CRS_ISR_TRIMOVF_Msk   (0x1UL << CRS_ISR_TRIMOVF_Pos)
#define CRS_ISR_TRIMOVF   CRS_ISR_TRIMOVF_Msk
#define CRS_ISR_FEDIR_Pos   (15U)
#define CRS_ISR_FEDIR_Msk   (0x1UL << CRS_ISR_FEDIR_Pos)
#define CRS_ISR_FEDIR   CRS_ISR_FEDIR_Msk
#define CRS_ISR_FECAP_Pos   (16U)
#define CRS_ISR_FECAP_Msk   (0xFFFFUL << CRS_ISR_FECAP_Pos)
#define CRS_ISR_FECAP   CRS_ISR_FECAP_Msk
#define CRS_ICR_SYNCOKC_Pos   (0U)
#define CRS_ICR_SYNCOKC_Msk   (0x1UL << CRS_ICR_SYNCOKC_Pos)
#define CRS_ICR_SYNCOKC   CRS_ICR_SYNCOKC_Msk
#define CRS_ICR_SYNCWARNC_Pos   (1U)
#define CRS_ICR_SYNCWARNC_Msk   (0x1UL << CRS_ICR_SYNCWARNC_Pos)
#define CRS_ICR_SYNCWARNC   CRS_ICR_SYNCWARNC_Msk
#define CRS_ICR_ERRC_Pos   (2U)
#define CRS_ICR_ERRC_Msk   (0x1UL << CRS_ICR_ERRC_Pos)
#define CRS_ICR_ERRC   CRS_ICR_ERRC_Msk
#define CRS_ICR_ESYNCC_Pos   (3U)
#define CRS_ICR_ESYNCC_Msk   (0x1UL << CRS_ICR_ESYNCC_Pos)
#define CRS_ICR_ESYNCC   CRS_ICR_ESYNCC_Msk
#define DAC_CR_EN1_Pos   (0U)
#define DAC_CR_EN1_Msk   (0x1UL << DAC_CR_EN1_Pos)
#define DAC_CR_EN1   DAC_CR_EN1_Msk
#define DAC_CR_TEN1_Pos   (1U)
#define DAC_CR_TEN1_Msk   (0x1UL << DAC_CR_TEN1_Pos)
#define DAC_CR_TEN1   DAC_CR_TEN1_Msk
#define DAC_CR_TSEL1_Pos   (2U)
#define DAC_CR_TSEL1_Msk   (0xFUL << DAC_CR_TSEL1_Pos)
#define DAC_CR_TSEL1   DAC_CR_TSEL1_Msk
#define DAC_CR_TSEL1_0   (0x1UL << DAC_CR_TSEL1_Pos)
#define DAC_CR_TSEL1_1   (0x2UL << DAC_CR_TSEL1_Pos)
#define DAC_CR_TSEL1_2   (0x4UL << DAC_CR_TSEL1_Pos)
#define DAC_CR_TSEL1_3   (0x8UL << DAC_CR_TSEL1_Pos)
#define DAC_CR_WAVE1_Pos   (6U)
#define DAC_CR_WAVE1_Msk   (0x3UL << DAC_CR_WAVE1_Pos)
#define DAC_CR_WAVE1   DAC_CR_WAVE1_Msk
#define DAC_CR_WAVE1_0   (0x1UL << DAC_CR_WAVE1_Pos)
#define DAC_CR_WAVE1_1   (0x2UL << DAC_CR_WAVE1_Pos)
#define DAC_CR_MAMP1_Pos   (8U)
#define DAC_CR_MAMP1_Msk   (0xFUL << DAC_CR_MAMP1_Pos)
#define DAC_CR_MAMP1   DAC_CR_MAMP1_Msk
#define DAC_CR_MAMP1_0   (0x1UL << DAC_CR_MAMP1_Pos)
#define DAC_CR_MAMP1_1   (0x2UL << DAC_CR_MAMP1_Pos)
#define DAC_CR_MAMP1_2   (0x4UL << DAC_CR_MAMP1_Pos)
#define DAC_CR_MAMP1_3   (0x8UL << DAC_CR_MAMP1_Pos)
#define DAC_CR_DMAEN1_Pos   (12U)
#define DAC_CR_DMAEN1_Msk   (0x1UL << DAC_CR_DMAEN1_Pos)
#define DAC_CR_DMAEN1   DAC_CR_DMAEN1_Msk
#define DAC_CR_DMAUDRIE1_Pos   (13U)
#define DAC_CR_DMAUDRIE1_Msk   (0x1UL << DAC_CR_DMAUDRIE1_Pos)
#define DAC_CR_DMAUDRIE1   DAC_CR_DMAUDRIE1_Msk
#define DAC_CR_CEN1_Pos   (14U)
#define DAC_CR_CEN1_Msk   (0x1UL << DAC_CR_CEN1_Pos)
#define DAC_CR_CEN1   DAC_CR_CEN1_Msk
#define DAC_CR_EN2_Pos   (16U)
#define DAC_CR_EN2_Msk   (0x1UL << DAC_CR_EN2_Pos)
#define DAC_CR_EN2   DAC_CR_EN2_Msk
#define DAC_CR_TEN2_Pos   (17U)
#define DAC_CR_TEN2_Msk   (0x1UL << DAC_CR_TEN2_Pos)
#define DAC_CR_TEN2   DAC_CR_TEN2_Msk
#define DAC_CR_TSEL2_Pos   (18U)
#define DAC_CR_TSEL2_Msk   (0xFUL << DAC_CR_TSEL2_Pos)
#define DAC_CR_TSEL2   DAC_CR_TSEL2_Msk
#define DAC_CR_TSEL2_0   (0x1UL << DAC_CR_TSEL2_Pos)
#define DAC_CR_TSEL2_1   (0x2UL << DAC_CR_TSEL2_Pos)
#define DAC_CR_TSEL2_2   (0x4UL << DAC_CR_TSEL2_Pos)
#define DAC_CR_TSEL2_3   (0x8UL << DAC_CR_TSEL2_Pos)
#define DAC_CR_WAVE2_Pos   (22U)
#define DAC_CR_WAVE2_Msk   (0x3UL << DAC_CR_WAVE2_Pos)
#define DAC_CR_WAVE2   DAC_CR_WAVE2_Msk
#define DAC_CR_WAVE2_0   (0x1UL << DAC_CR_WAVE2_Pos)
#define DAC_CR_WAVE2_1   (0x2UL << DAC_CR_WAVE2_Pos)
#define DAC_CR_MAMP2_Pos   (24U)
#define DAC_CR_MAMP2_Msk   (0xFUL << DAC_CR_MAMP2_Pos)
#define DAC_CR_MAMP2   DAC_CR_MAMP2_Msk
#define DAC_CR_MAMP2_0   (0x1UL << DAC_CR_MAMP2_Pos)
#define DAC_CR_MAMP2_1   (0x2UL << DAC_CR_MAMP2_Pos)
#define DAC_CR_MAMP2_2   (0x4UL << DAC_CR_MAMP2_Pos)
#define DAC_CR_MAMP2_3   (0x8UL << DAC_CR_MAMP2_Pos)
#define DAC_CR_DMAEN2_Pos   (28U)
#define DAC_CR_DMAEN2_Msk   (0x1UL << DAC_CR_DMAEN2_Pos)
#define DAC_CR_DMAEN2   DAC_CR_DMAEN2_Msk
#define DAC_CR_DMAUDRIE2_Pos   (29U)
#define DAC_CR_DMAUDRIE2_Msk   (0x1UL << DAC_CR_DMAUDRIE2_Pos)
#define DAC_CR_DMAUDRIE2   DAC_CR_DMAUDRIE2_Msk
#define DAC_CR_CEN2_Pos   (30U)
#define DAC_CR_CEN2_Msk   (0x1UL << DAC_CR_CEN2_Pos)
#define DAC_CR_CEN2   DAC_CR_CEN2_Msk
#define DAC_SWTRIGR_SWTRIG1_Pos   (0U)
#define DAC_SWTRIGR_SWTRIG1_Msk   (0x1UL << DAC_SWTRIGR_SWTRIG1_Pos)
#define DAC_SWTRIGR_SWTRIG1   DAC_SWTRIGR_SWTRIG1_Msk
#define DAC_SWTRIGR_SWTRIG2_Pos   (1U)
#define DAC_SWTRIGR_SWTRIG2_Msk   (0x1UL << DAC_SWTRIGR_SWTRIG2_Pos)
#define DAC_SWTRIGR_SWTRIG2   DAC_SWTRIGR_SWTRIG2_Msk
#define DAC_DHR12R1_DACC1DHR_Pos   (0U)
#define DAC_DHR12R1_DACC1DHR_Msk   (0xFFFUL << DAC_DHR12R1_DACC1DHR_Pos)
#define DAC_DHR12R1_DACC1DHR   DAC_DHR12R1_DACC1DHR_Msk
#define DAC_DHR12L1_DACC1DHR_Pos   (4U)
#define DAC_DHR12L1_DACC1DHR_Msk   (0xFFFUL << DAC_DHR12L1_DACC1DHR_Pos)
#define DAC_DHR12L1_DACC1DHR   DAC_DHR12L1_DACC1DHR_Msk
#define DAC_DHR8R1_DACC1DHR_Pos   (0U)
#define DAC_DHR8R1_DACC1DHR_Msk   (0xFFUL << DAC_DHR8R1_DACC1DHR_Pos)
#define DAC_DHR8R1_DACC1DHR   DAC_DHR8R1_DACC1DHR_Msk
#define DAC_DHR12R2_DACC2DHR_Pos   (0U)
#define DAC_DHR12R2_DACC2DHR_Msk   (0xFFFUL << DAC_DHR12R2_DACC2DHR_Pos)
#define DAC_DHR12R2_DACC2DHR   DAC_DHR12R2_DACC2DHR_Msk
#define DAC_DHR12L2_DACC2DHR_Pos   (4U)
#define DAC_DHR12L2_DACC2DHR_Msk   (0xFFFUL << DAC_DHR12L2_DACC2DHR_Pos)
#define DAC_DHR12L2_DACC2DHR   DAC_DHR12L2_DACC2DHR_Msk
#define DAC_DHR8R2_DACC2DHR_Pos   (0U)
#define DAC_DHR8R2_DACC2DHR_Msk   (0xFFUL << DAC_DHR8R2_DACC2DHR_Pos)
#define DAC_DHR8R2_DACC2DHR   DAC_DHR8R2_DACC2DHR_Msk
#define DAC_DHR12RD_DACC1DHR_Pos   (0U)
#define DAC_DHR12RD_DACC1DHR_Msk   (0xFFFUL << DAC_DHR12RD_DACC1DHR_Pos)
#define DAC_DHR12RD_DACC1DHR   DAC_DHR12RD_DACC1DHR_Msk
#define DAC_DHR12RD_DACC2DHR_Pos   (16U)
#define DAC_DHR12RD_DACC2DHR_Msk   (0xFFFUL << DAC_DHR12RD_DACC2DHR_Pos)
#define DAC_DHR12RD_DACC2DHR   DAC_DHR12RD_DACC2DHR_Msk
#define DAC_DHR12LD_DACC1DHR_Pos   (4U)
#define DAC_DHR12LD_DACC1DHR_Msk   (0xFFFUL << DAC_DHR12LD_DACC1DHR_Pos)
#define DAC_DHR12LD_DACC1DHR   DAC_DHR12LD_DACC1DHR_Msk
#define DAC_DHR12LD_DACC2DHR_Pos   (20U)
#define DAC_DHR12LD_DACC2DHR_Msk   (0xFFFUL << DAC_DHR12LD_DACC2DHR_Pos)
#define DAC_DHR12LD_DACC2DHR   DAC_DHR12LD_DACC2DHR_Msk
#define DAC_DHR8RD_DACC1DHR_Pos   (0U)
#define DAC_DHR8RD_DACC1DHR_Msk   (0xFFUL << DAC_DHR8RD_DACC1DHR_Pos)
#define DAC_DHR8RD_DACC1DHR   DAC_DHR8RD_DACC1DHR_Msk
#define DAC_DHR8RD_DACC2DHR_Pos   (8U)
#define DAC_DHR8RD_DACC2DHR_Msk   (0xFFUL << DAC_DHR8RD_DACC2DHR_Pos)
#define DAC_DHR8RD_DACC2DHR   DAC_DHR8RD_DACC2DHR_Msk
#define DAC_DOR1_DACC1DOR_Pos   (0U)
#define DAC_DOR1_DACC1DOR_Msk   (0xFFFUL << DAC_DOR1_DACC1DOR_Pos)
#define DAC_DOR1_DACC1DOR   DAC_DOR1_DACC1DOR_Msk
#define DAC_DOR2_DACC2DOR_Pos   (0U)
#define DAC_DOR2_DACC2DOR_Msk   (0xFFFUL << DAC_DOR2_DACC2DOR_Pos)
#define DAC_DOR2_DACC2DOR   DAC_DOR2_DACC2DOR_Msk
#define DAC_SR_DMAUDR1_Pos   (13U)
#define DAC_SR_DMAUDR1_Msk   (0x1UL << DAC_SR_DMAUDR1_Pos)
#define DAC_SR_DMAUDR1   DAC_SR_DMAUDR1_Msk
#define DAC_SR_CAL_FLAG1_Pos   (14U)
#define DAC_SR_CAL_FLAG1_Msk   (0x1UL << DAC_SR_CAL_FLAG1_Pos)
#define DAC_SR_CAL_FLAG1   DAC_SR_CAL_FLAG1_Msk
#define DAC_SR_BWST1_Pos   (15U)
#define DAC_SR_BWST1_Msk   (0x4001UL << DAC_SR_BWST1_Pos)
#define DAC_SR_BWST1   DAC_SR_BWST1_Msk
#define DAC_SR_DMAUDR2_Pos   (29U)
#define DAC_SR_DMAUDR2_Msk   (0x1UL << DAC_SR_DMAUDR2_Pos)
#define DAC_SR_DMAUDR2   DAC_SR_DMAUDR2_Msk
#define DAC_SR_CAL_FLAG2_Pos   (30U)
#define DAC_SR_CAL_FLAG2_Msk   (0x1UL << DAC_SR_CAL_FLAG2_Pos)
#define DAC_SR_CAL_FLAG2   DAC_SR_CAL_FLAG2_Msk
#define DAC_SR_BWST2_Pos   (31U)
#define DAC_SR_BWST2_Msk   (0x1UL << DAC_SR_BWST2_Pos)
#define DAC_SR_BWST2   DAC_SR_BWST2_Msk
#define DAC_CCR_OTRIM1_Pos   (0U)
#define DAC_CCR_OTRIM1_Msk   (0x1FUL << DAC_CCR_OTRIM1_Pos)
#define DAC_CCR_OTRIM1   DAC_CCR_OTRIM1_Msk
#define DAC_CCR_OTRIM2_Pos   (16U)
#define DAC_CCR_OTRIM2_Msk   (0x1FUL << DAC_CCR_OTRIM2_Pos)
#define DAC_CCR_OTRIM2   DAC_CCR_OTRIM2_Msk
#define DAC_MCR_MODE1_Pos   (0U)
#define DAC_MCR_MODE1_Msk   (0x7UL << DAC_MCR_MODE1_Pos)
#define DAC_MCR_MODE1   DAC_MCR_MODE1_Msk
#define DAC_MCR_MODE1_0   (0x1UL << DAC_MCR_MODE1_Pos)
#define DAC_MCR_MODE1_1   (0x2UL << DAC_MCR_MODE1_Pos)
#define DAC_MCR_MODE1_2   (0x4UL << DAC_MCR_MODE1_Pos)
#define DAC_MCR_MODE2_Pos   (16U)
#define DAC_MCR_MODE2_Msk   (0x7UL << DAC_MCR_MODE2_Pos)
#define DAC_MCR_MODE2   DAC_MCR_MODE2_Msk
#define DAC_MCR_MODE2_0   (0x1UL << DAC_MCR_MODE2_Pos)
#define DAC_MCR_MODE2_1   (0x2UL << DAC_MCR_MODE2_Pos)
#define DAC_MCR_MODE2_2   (0x4UL << DAC_MCR_MODE2_Pos)
#define DAC_SHSR1_TSAMPLE1_Pos   (0U)
#define DAC_SHSR1_TSAMPLE1_Msk   (0x3FFUL << DAC_SHSR1_TSAMPLE1_Pos)
#define DAC_SHSR1_TSAMPLE1   DAC_SHSR1_TSAMPLE1_Msk
#define DAC_SHSR2_TSAMPLE2_Pos   (0U)
#define DAC_SHSR2_TSAMPLE2_Msk   (0x3FFUL << DAC_SHSR2_TSAMPLE2_Pos)
#define DAC_SHSR2_TSAMPLE2   DAC_SHSR2_TSAMPLE2_Msk
#define DAC_SHHR_THOLD1_Pos   (0U)
#define DAC_SHHR_THOLD1_Msk   (0x3FFUL << DAC_SHHR_THOLD1_Pos)
#define DAC_SHHR_THOLD1   DAC_SHHR_THOLD1_Msk
#define DAC_SHHR_THOLD2_Pos   (16U)
#define DAC_SHHR_THOLD2_Msk   (0x3FFUL << DAC_SHHR_THOLD2_Pos)
#define DAC_SHHR_THOLD2   DAC_SHHR_THOLD2_Msk
#define DAC_SHRR_TREFRESH1_Pos   (0U)
#define DAC_SHRR_TREFRESH1_Msk   (0xFFUL << DAC_SHRR_TREFRESH1_Pos)
#define DAC_SHRR_TREFRESH1   DAC_SHRR_TREFRESH1_Msk
#define DAC_SHRR_TREFRESH2_Pos   (16U)
#define DAC_SHRR_TREFRESH2_Msk   (0xFFUL << DAC_SHRR_TREFRESH2_Pos)
#define DAC_SHRR_TREFRESH2   DAC_SHRR_TREFRESH2_Msk
#define DCMI_CR_CAPTURE_Pos   (0U)
#define DCMI_CR_CAPTURE_Msk   (0x1UL << DCMI_CR_CAPTURE_Pos)
#define DCMI_CR_CAPTURE   DCMI_CR_CAPTURE_Msk
#define DCMI_CR_CM_Pos   (1U)
#define DCMI_CR_CM_Msk   (0x1UL << DCMI_CR_CM_Pos)
#define DCMI_CR_CM   DCMI_CR_CM_Msk
#define DCMI_CR_CROP_Pos   (2U)
#define DCMI_CR_CROP_Msk   (0x1UL << DCMI_CR_CROP_Pos)
#define DCMI_CR_CROP   DCMI_CR_CROP_Msk
#define DCMI_CR_JPEG_Pos   (3U)
#define DCMI_CR_JPEG_Msk   (0x1UL << DCMI_CR_JPEG_Pos)
#define DCMI_CR_JPEG   DCMI_CR_JPEG_Msk
#define DCMI_CR_ESS_Pos   (4U)
#define DCMI_CR_ESS_Msk   (0x1UL << DCMI_CR_ESS_Pos)
#define DCMI_CR_ESS   DCMI_CR_ESS_Msk
#define DCMI_CR_PCKPOL_Pos   (5U)
#define DCMI_CR_PCKPOL_Msk   (0x1UL << DCMI_CR_PCKPOL_Pos)
#define DCMI_CR_PCKPOL   DCMI_CR_PCKPOL_Msk
#define DCMI_CR_HSPOL_Pos   (6U)
#define DCMI_CR_HSPOL_Msk   (0x1UL << DCMI_CR_HSPOL_Pos)
#define DCMI_CR_HSPOL   DCMI_CR_HSPOL_Msk
#define DCMI_CR_VSPOL_Pos   (7U)
#define DCMI_CR_VSPOL_Msk   (0x1UL << DCMI_CR_VSPOL_Pos)
#define DCMI_CR_VSPOL   DCMI_CR_VSPOL_Msk
#define DCMI_CR_FCRC_0   (0x00000100U)
#define DCMI_CR_FCRC_1   (0x00000200U)
#define DCMI_CR_EDM_0   (0x00000400U)
#define DCMI_CR_EDM_1   (0x00000800U)
#define DCMI_CR_CRE_Pos   (12U)
#define DCMI_CR_CRE_Msk   (0x1UL << DCMI_CR_CRE_Pos)
#define DCMI_CR_CRE   DCMI_CR_CRE_Msk
#define DCMI_CR_ENABLE_Pos   (14U)
#define DCMI_CR_ENABLE_Msk   (0x1UL << DCMI_CR_ENABLE_Pos)
#define DCMI_CR_ENABLE   DCMI_CR_ENABLE_Msk
#define DCMI_CR_BSM_Pos   (16U)
#define DCMI_CR_BSM_Msk   (0x3UL << DCMI_CR_BSM_Pos)
#define DCMI_CR_BSM   DCMI_CR_BSM_Msk
#define DCMI_CR_BSM_0   (0x1UL << DCMI_CR_BSM_Pos)
#define DCMI_CR_BSM_1   (0x2UL << DCMI_CR_BSM_Pos)
#define DCMI_CR_OEBS_Pos   (18U)
#define DCMI_CR_OEBS_Msk   (0x1UL << DCMI_CR_OEBS_Pos)
#define DCMI_CR_OEBS   DCMI_CR_OEBS_Msk
#define DCMI_CR_LSM_Pos   (19U)
#define DCMI_CR_LSM_Msk   (0x1UL << DCMI_CR_LSM_Pos)
#define DCMI_CR_LSM   DCMI_CR_LSM_Msk
#define DCMI_CR_OELS_Pos   (20U)
#define DCMI_CR_OELS_Msk   (0x1UL << DCMI_CR_OELS_Pos)
#define DCMI_CR_OELS   DCMI_CR_OELS_Msk
#define DCMI_SR_HSYNC_Pos   (0U)
#define DCMI_SR_HSYNC_Msk   (0x1UL << DCMI_SR_HSYNC_Pos)
#define DCMI_SR_HSYNC   DCMI_SR_HSYNC_Msk
#define DCMI_SR_VSYNC_Pos   (1U)
#define DCMI_SR_VSYNC_Msk   (0x1UL << DCMI_SR_VSYNC_Pos)
#define DCMI_SR_VSYNC   DCMI_SR_VSYNC_Msk
#define DCMI_SR_FNE_Pos   (2U)
#define DCMI_SR_FNE_Msk   (0x1UL << DCMI_SR_FNE_Pos)
#define DCMI_SR_FNE   DCMI_SR_FNE_Msk
#define DCMI_RIS_FRAME_RIS_Pos   (0U)
#define DCMI_RIS_FRAME_RIS_Msk   (0x1UL << DCMI_RIS_FRAME_RIS_Pos)
#define DCMI_RIS_FRAME_RIS   DCMI_RIS_FRAME_RIS_Msk
#define DCMI_RIS_OVR_RIS_Pos   (1U)
#define DCMI_RIS_OVR_RIS_Msk   (0x1UL << DCMI_RIS_OVR_RIS_Pos)
#define DCMI_RIS_OVR_RIS   DCMI_RIS_OVR_RIS_Msk
#define DCMI_RIS_ERR_RIS_Pos   (2U)
#define DCMI_RIS_ERR_RIS_Msk   (0x1UL << DCMI_RIS_ERR_RIS_Pos)
#define DCMI_RIS_ERR_RIS   DCMI_RIS_ERR_RIS_Msk
#define DCMI_RIS_VSYNC_RIS_Pos   (3U)
#define DCMI_RIS_VSYNC_RIS_Msk   (0x1UL << DCMI_RIS_VSYNC_RIS_Pos)
#define DCMI_RIS_VSYNC_RIS   DCMI_RIS_VSYNC_RIS_Msk
#define DCMI_RIS_LINE_RIS_Pos   (4U)
#define DCMI_RIS_LINE_RIS_Msk   (0x1UL << DCMI_RIS_LINE_RIS_Pos)
#define DCMI_RIS_LINE_RIS   DCMI_RIS_LINE_RIS_Msk
#define DCMI_IER_FRAME_IE_Pos   (0U)
#define DCMI_IER_FRAME_IE_Msk   (0x1UL << DCMI_IER_FRAME_IE_Pos)
#define DCMI_IER_FRAME_IE   DCMI_IER_FRAME_IE_Msk
#define DCMI_IER_OVR_IE_Pos   (1U)
#define DCMI_IER_OVR_IE_Msk   (0x1UL << DCMI_IER_OVR_IE_Pos)
#define DCMI_IER_OVR_IE   DCMI_IER_OVR_IE_Msk
#define DCMI_IER_ERR_IE_Pos   (2U)
#define DCMI_IER_ERR_IE_Msk   (0x1UL << DCMI_IER_ERR_IE_Pos)
#define DCMI_IER_ERR_IE   DCMI_IER_ERR_IE_Msk
#define DCMI_IER_VSYNC_IE_Pos   (3U)
#define DCMI_IER_VSYNC_IE_Msk   (0x1UL << DCMI_IER_VSYNC_IE_Pos)
#define DCMI_IER_VSYNC_IE   DCMI_IER_VSYNC_IE_Msk
#define DCMI_IER_LINE_IE_Pos   (4U)
#define DCMI_IER_LINE_IE_Msk   (0x1UL << DCMI_IER_LINE_IE_Pos)
#define DCMI_IER_LINE_IE   DCMI_IER_LINE_IE_Msk
#define DCMI_MIS_FRAME_MIS_Pos   (0U)
#define DCMI_MIS_FRAME_MIS_Msk   (0x1UL << DCMI_MIS_FRAME_MIS_Pos)
#define DCMI_MIS_FRAME_MIS   DCMI_MIS_FRAME_MIS_Msk
#define DCMI_MIS_OVR_MIS_Pos   (1U)
#define DCMI_MIS_OVR_MIS_Msk   (0x1UL << DCMI_MIS_OVR_MIS_Pos)
#define DCMI_MIS_OVR_MIS   DCMI_MIS_OVR_MIS_Msk
#define DCMI_MIS_ERR_MIS_Pos   (2U)
#define DCMI_MIS_ERR_MIS_Msk   (0x1UL << DCMI_MIS_ERR_MIS_Pos)
#define DCMI_MIS_ERR_MIS   DCMI_MIS_ERR_MIS_Msk
#define DCMI_MIS_VSYNC_MIS_Pos   (3U)
#define DCMI_MIS_VSYNC_MIS_Msk   (0x1UL << DCMI_MIS_VSYNC_MIS_Pos)
#define DCMI_MIS_VSYNC_MIS   DCMI_MIS_VSYNC_MIS_Msk
#define DCMI_MIS_LINE_MIS_Pos   (4U)
#define DCMI_MIS_LINE_MIS_Msk   (0x1UL << DCMI_MIS_LINE_MIS_Pos)
#define DCMI_MIS_LINE_MIS   DCMI_MIS_LINE_MIS_Msk
#define DCMI_ICR_FRAME_ISC_Pos   (0U)
#define DCMI_ICR_FRAME_ISC_Msk   (0x1UL << DCMI_ICR_FRAME_ISC_Pos)
#define DCMI_ICR_FRAME_ISC   DCMI_ICR_FRAME_ISC_Msk
#define DCMI_ICR_OVR_ISC_Pos   (1U)
#define DCMI_ICR_OVR_ISC_Msk   (0x1UL << DCMI_ICR_OVR_ISC_Pos)
#define DCMI_ICR_OVR_ISC   DCMI_ICR_OVR_ISC_Msk
#define DCMI_ICR_ERR_ISC_Pos   (2U)
#define DCMI_ICR_ERR_ISC_Msk   (0x1UL << DCMI_ICR_ERR_ISC_Pos)
#define DCMI_ICR_ERR_ISC   DCMI_ICR_ERR_ISC_Msk
#define DCMI_ICR_VSYNC_ISC_Pos   (3U)
#define DCMI_ICR_VSYNC_ISC_Msk   (0x1UL << DCMI_ICR_VSYNC_ISC_Pos)
#define DCMI_ICR_VSYNC_ISC   DCMI_ICR_VSYNC_ISC_Msk
#define DCMI_ICR_LINE_ISC_Pos   (4U)
#define DCMI_ICR_LINE_ISC_Msk   (0x1UL << DCMI_ICR_LINE_ISC_Pos)
#define DCMI_ICR_LINE_ISC   DCMI_ICR_LINE_ISC_Msk
#define DCMI_ESCR_FSC_Pos   (0U)
#define DCMI_ESCR_FSC_Msk   (0xFFUL << DCMI_ESCR_FSC_Pos)
#define DCMI_ESCR_FSC   DCMI_ESCR_FSC_Msk
#define DCMI_ESCR_LSC_Pos   (8U)
#define DCMI_ESCR_LSC_Msk   (0xFFUL << DCMI_ESCR_LSC_Pos)
#define DCMI_ESCR_LSC   DCMI_ESCR_LSC_Msk
#define DCMI_ESCR_LEC_Pos   (16U)
#define DCMI_ESCR_LEC_Msk   (0xFFUL << DCMI_ESCR_LEC_Pos)
#define DCMI_ESCR_LEC   DCMI_ESCR_LEC_Msk
#define DCMI_ESCR_FEC_Pos   (24U)
#define DCMI_ESCR_FEC_Msk   (0xFFUL << DCMI_ESCR_FEC_Pos)
#define DCMI_ESCR_FEC   DCMI_ESCR_FEC_Msk
#define DCMI_ESUR_FSU_Pos   (0U)
#define DCMI_ESUR_FSU_Msk   (0xFFUL << DCMI_ESUR_FSU_Pos)
#define DCMI_ESUR_FSU   DCMI_ESUR_FSU_Msk
#define DCMI_ESUR_LSU_Pos   (8U)
#define DCMI_ESUR_LSU_Msk   (0xFFUL << DCMI_ESUR_LSU_Pos)
#define DCMI_ESUR_LSU   DCMI_ESUR_LSU_Msk
#define DCMI_ESUR_LEU_Pos   (16U)
#define DCMI_ESUR_LEU_Msk   (0xFFUL << DCMI_ESUR_LEU_Pos)
#define DCMI_ESUR_LEU   DCMI_ESUR_LEU_Msk
#define DCMI_ESUR_FEU_Pos   (24U)
#define DCMI_ESUR_FEU_Msk   (0xFFUL << DCMI_ESUR_FEU_Pos)
#define DCMI_ESUR_FEU   DCMI_ESUR_FEU_Msk
#define DCMI_CWSTRT_HOFFCNT_Pos   (0U)
#define DCMI_CWSTRT_HOFFCNT_Msk   (0x3FFFUL << DCMI_CWSTRT_HOFFCNT_Pos)
#define DCMI_CWSTRT_HOFFCNT   DCMI_CWSTRT_HOFFCNT_Msk
#define DCMI_CWSTRT_VST_Pos   (16U)
#define DCMI_CWSTRT_VST_Msk   (0x1FFFUL << DCMI_CWSTRT_VST_Pos)
#define DCMI_CWSTRT_VST   DCMI_CWSTRT_VST_Msk
#define DCMI_CWSIZE_CAPCNT_Pos   (0U)
#define DCMI_CWSIZE_CAPCNT_Msk   (0x3FFFUL << DCMI_CWSIZE_CAPCNT_Pos)
#define DCMI_CWSIZE_CAPCNT   DCMI_CWSIZE_CAPCNT_Msk
#define DCMI_CWSIZE_VLINE_Pos   (16U)
#define DCMI_CWSIZE_VLINE_Msk   (0x3FFFUL << DCMI_CWSIZE_VLINE_Pos)
#define DCMI_CWSIZE_VLINE   DCMI_CWSIZE_VLINE_Msk
#define DCMI_DR_BYTE0_Pos   (0U)
#define DCMI_DR_BYTE0_Msk   (0xFFUL << DCMI_DR_BYTE0_Pos)
#define DCMI_DR_BYTE0   DCMI_DR_BYTE0_Msk
#define DCMI_DR_BYTE1_Pos   (8U)
#define DCMI_DR_BYTE1_Msk   (0xFFUL << DCMI_DR_BYTE1_Pos)
#define DCMI_DR_BYTE1   DCMI_DR_BYTE1_Msk
#define DCMI_DR_BYTE2_Pos   (16U)
#define DCMI_DR_BYTE2_Msk   (0xFFUL << DCMI_DR_BYTE2_Pos)
#define DCMI_DR_BYTE2   DCMI_DR_BYTE2_Msk
#define DCMI_DR_BYTE3_Pos   (24U)
#define DCMI_DR_BYTE3_Msk   (0xFFUL << DCMI_DR_BYTE3_Pos)
#define DCMI_DR_BYTE3   DCMI_DR_BYTE3_Msk
#define DFSDM_CHCFGR1_DFSDMEN_Pos   (31U)
#define DFSDM_CHCFGR1_DFSDMEN_Msk   (0x1UL << DFSDM_CHCFGR1_DFSDMEN_Pos)
#define DFSDM_CHCFGR1_DFSDMEN   DFSDM_CHCFGR1_DFSDMEN_Msk
#define DFSDM_CHCFGR1_CKOUTSRC_Pos   (30U)
#define DFSDM_CHCFGR1_CKOUTSRC_Msk   (0x1UL << DFSDM_CHCFGR1_CKOUTSRC_Pos)
#define DFSDM_CHCFGR1_CKOUTSRC   DFSDM_CHCFGR1_CKOUTSRC_Msk
#define DFSDM_CHCFGR1_CKOUTDIV_Pos   (16U)
#define DFSDM_CHCFGR1_CKOUTDIV_Msk   (0xFFUL << DFSDM_CHCFGR1_CKOUTDIV_Pos)
#define DFSDM_CHCFGR1_CKOUTDIV   DFSDM_CHCFGR1_CKOUTDIV_Msk
#define DFSDM_CHCFGR1_DATPACK_Pos   (14U)
#define DFSDM_CHCFGR1_DATPACK_Msk   (0x3UL << DFSDM_CHCFGR1_DATPACK_Pos)
#define DFSDM_CHCFGR1_DATPACK   DFSDM_CHCFGR1_DATPACK_Msk
#define DFSDM_CHCFGR1_DATPACK_1   (0x2UL << DFSDM_CHCFGR1_DATPACK_Pos)
#define DFSDM_CHCFGR1_DATPACK_0   (0x1UL << DFSDM_CHCFGR1_DATPACK_Pos)
#define DFSDM_CHCFGR1_DATMPX_Pos   (12U)
#define DFSDM_CHCFGR1_DATMPX_Msk   (0x3UL << DFSDM_CHCFGR1_DATMPX_Pos)
#define DFSDM_CHCFGR1_DATMPX   DFSDM_CHCFGR1_DATMPX_Msk
#define DFSDM_CHCFGR1_DATMPX_1   (0x2UL << DFSDM_CHCFGR1_DATMPX_Pos)
#define DFSDM_CHCFGR1_DATMPX_0   (0x1UL << DFSDM_CHCFGR1_DATMPX_Pos)
#define DFSDM_CHCFGR1_CHINSEL_Pos   (8U)
#define DFSDM_CHCFGR1_CHINSEL_Msk   (0x1UL << DFSDM_CHCFGR1_CHINSEL_Pos)
#define DFSDM_CHCFGR1_CHINSEL   DFSDM_CHCFGR1_CHINSEL_Msk
#define DFSDM_CHCFGR1_CHEN_Pos   (7U)
#define DFSDM_CHCFGR1_CHEN_Msk   (0x1UL << DFSDM_CHCFGR1_CHEN_Pos)
#define DFSDM_CHCFGR1_CHEN   DFSDM_CHCFGR1_CHEN_Msk
#define DFSDM_CHCFGR1_CKABEN_Pos   (6U)
#define DFSDM_CHCFGR1_CKABEN_Msk   (0x1UL << DFSDM_CHCFGR1_CKABEN_Pos)
#define DFSDM_CHCFGR1_CKABEN   DFSDM_CHCFGR1_CKABEN_Msk
#define DFSDM_CHCFGR1_SCDEN_Pos   (5U)
#define DFSDM_CHCFGR1_SCDEN_Msk   (0x1UL << DFSDM_CHCFGR1_SCDEN_Pos)
#define DFSDM_CHCFGR1_SCDEN   DFSDM_CHCFGR1_SCDEN_Msk
#define DFSDM_CHCFGR1_SPICKSEL_Pos   (2U)
#define DFSDM_CHCFGR1_SPICKSEL_Msk   (0x3UL << DFSDM_CHCFGR1_SPICKSEL_Pos)
#define DFSDM_CHCFGR1_SPICKSEL   DFSDM_CHCFGR1_SPICKSEL_Msk
#define DFSDM_CHCFGR1_SPICKSEL_1   (0x2UL << DFSDM_CHCFGR1_SPICKSEL_Pos)
#define DFSDM_CHCFGR1_SPICKSEL_0   (0x1UL << DFSDM_CHCFGR1_SPICKSEL_Pos)
#define DFSDM_CHCFGR1_SITP_Pos   (0U)
#define DFSDM_CHCFGR1_SITP_Msk   (0x3UL << DFSDM_CHCFGR1_SITP_Pos)
#define DFSDM_CHCFGR1_SITP   DFSDM_CHCFGR1_SITP_Msk
#define DFSDM_CHCFGR1_SITP_1   (0x2UL << DFSDM_CHCFGR1_SITP_Pos)
#define DFSDM_CHCFGR1_SITP_0   (0x1UL << DFSDM_CHCFGR1_SITP_Pos)
#define DFSDM_CHCFGR2_OFFSET_Pos   (8U)
#define DFSDM_CHCFGR2_OFFSET_Msk   (0xFFFFFFUL << DFSDM_CHCFGR2_OFFSET_Pos)
#define DFSDM_CHCFGR2_OFFSET   DFSDM_CHCFGR2_OFFSET_Msk
#define DFSDM_CHCFGR2_DTRBS_Pos   (3U)
#define DFSDM_CHCFGR2_DTRBS_Msk   (0x1FUL << DFSDM_CHCFGR2_DTRBS_Pos)
#define DFSDM_CHCFGR2_DTRBS   DFSDM_CHCFGR2_DTRBS_Msk
#define DFSDM_CHAWSCDR_AWFORD_Pos   (22U)
#define DFSDM_CHAWSCDR_AWFORD_Msk   (0x3UL << DFSDM_CHAWSCDR_AWFORD_Pos)
#define DFSDM_CHAWSCDR_AWFORD   DFSDM_CHAWSCDR_AWFORD_Msk
#define DFSDM_CHAWSCDR_AWFORD_1   (0x2UL << DFSDM_CHAWSCDR_AWFORD_Pos)
#define DFSDM_CHAWSCDR_AWFORD_0   (0x1UL << DFSDM_CHAWSCDR_AWFORD_Pos)
#define DFSDM_CHAWSCDR_AWFOSR_Pos   (16U)
#define DFSDM_CHAWSCDR_AWFOSR_Msk   (0x1FUL << DFSDM_CHAWSCDR_AWFOSR_Pos)
#define DFSDM_CHAWSCDR_AWFOSR   DFSDM_CHAWSCDR_AWFOSR_Msk
#define DFSDM_CHAWSCDR_BKSCD_Pos   (12U)
#define DFSDM_CHAWSCDR_BKSCD_Msk   (0xFUL << DFSDM_CHAWSCDR_BKSCD_Pos)
#define DFSDM_CHAWSCDR_BKSCD   DFSDM_CHAWSCDR_BKSCD_Msk
#define DFSDM_CHAWSCDR_SCDT_Pos   (0U)
#define DFSDM_CHAWSCDR_SCDT_Msk   (0xFFUL << DFSDM_CHAWSCDR_SCDT_Pos)
#define DFSDM_CHAWSCDR_SCDT   DFSDM_CHAWSCDR_SCDT_Msk
#define DFSDM_CHWDATR_WDATA_Pos   (0U)
#define DFSDM_CHWDATR_WDATA_Msk   (0xFFFFUL << DFSDM_CHWDATR_WDATA_Pos)
#define DFSDM_CHWDATR_WDATA   DFSDM_CHWDATR_WDATA_Msk
#define DFSDM_CHDATINR_INDAT0_Pos   (0U)
#define DFSDM_CHDATINR_INDAT0_Msk   (0xFFFFUL << DFSDM_CHDATINR_INDAT0_Pos)
#define DFSDM_CHDATINR_INDAT0   DFSDM_CHDATINR_INDAT0_Msk
#define DFSDM_CHDATINR_INDAT1_Pos   (16U)
#define DFSDM_CHDATINR_INDAT1_Msk   (0xFFFFUL << DFSDM_CHDATINR_INDAT1_Pos)
#define DFSDM_CHDATINR_INDAT1   DFSDM_CHDATINR_INDAT1_Msk
#define DFSDM_CHDLYR_PLSSKP_Pos   (0U)
#define DFSDM_CHDLYR_PLSSKP_Msk   (0x3FUL << DFSDM_CHDLYR_PLSSKP_Pos)
#define DFSDM_CHDLYR_PLSSKP   DFSDM_CHDLYR_PLSSKP_Msk
#define DFSDM_FLTCR1_AWFSEL_Pos   (30U)
#define DFSDM_FLTCR1_AWFSEL_Msk   (0x1UL << DFSDM_FLTCR1_AWFSEL_Pos)
#define DFSDM_FLTCR1_AWFSEL   DFSDM_FLTCR1_AWFSEL_Msk
#define DFSDM_FLTCR1_FAST_Pos   (29U)
#define DFSDM_FLTCR1_FAST_Msk   (0x1UL << DFSDM_FLTCR1_FAST_Pos)
#define DFSDM_FLTCR1_FAST   DFSDM_FLTCR1_FAST_Msk
#define DFSDM_FLTCR1_RCH_Pos   (24U)
#define DFSDM_FLTCR1_RCH_Msk   (0x7UL << DFSDM_FLTCR1_RCH_Pos)
#define DFSDM_FLTCR1_RCH   DFSDM_FLTCR1_RCH_Msk
#define DFSDM_FLTCR1_RDMAEN_Pos   (21U)
#define DFSDM_FLTCR1_RDMAEN_Msk   (0x1UL << DFSDM_FLTCR1_RDMAEN_Pos)
#define DFSDM_FLTCR1_RDMAEN   DFSDM_FLTCR1_RDMAEN_Msk
#define DFSDM_FLTCR1_RSYNC_Pos   (19U)
#define DFSDM_FLTCR1_RSYNC_Msk   (0x1UL << DFSDM_FLTCR1_RSYNC_Pos)
#define DFSDM_FLTCR1_RSYNC   DFSDM_FLTCR1_RSYNC_Msk
#define DFSDM_FLTCR1_RCONT_Pos   (18U)
#define DFSDM_FLTCR1_RCONT_Msk   (0x1UL << DFSDM_FLTCR1_RCONT_Pos)
#define DFSDM_FLTCR1_RCONT   DFSDM_FLTCR1_RCONT_Msk
#define DFSDM_FLTCR1_RSWSTART_Pos   (17U)
#define DFSDM_FLTCR1_RSWSTART_Msk   (0x1UL << DFSDM_FLTCR1_RSWSTART_Pos)
#define DFSDM_FLTCR1_RSWSTART   DFSDM_FLTCR1_RSWSTART_Msk
#define DFSDM_FLTCR1_JEXTEN_Pos   (13U)
#define DFSDM_FLTCR1_JEXTEN_Msk   (0x3UL << DFSDM_FLTCR1_JEXTEN_Pos)
#define DFSDM_FLTCR1_JEXTEN   DFSDM_FLTCR1_JEXTEN_Msk
#define DFSDM_FLTCR1_JEXTEN_1   (0x2UL << DFSDM_FLTCR1_JEXTEN_Pos)
#define DFSDM_FLTCR1_JEXTEN_0   (0x1UL << DFSDM_FLTCR1_JEXTEN_Pos)
#define DFSDM_FLTCR1_JEXTSEL_Pos   (8U)
#define DFSDM_FLTCR1_JEXTSEL_Msk   (0x1FUL << DFSDM_FLTCR1_JEXTSEL_Pos)
#define DFSDM_FLTCR1_JEXTSEL   DFSDM_FLTCR1_JEXTSEL_Msk
#define DFSDM_FLTCR1_JEXTSEL_0   (0x01UL << DFSDM_FLTCR1_JEXTSEL_Pos)
#define DFSDM_FLTCR1_JEXTSEL_1   (0x02UL << DFSDM_FLTCR1_JEXTSEL_Pos)
#define DFSDM_FLTCR1_JEXTSEL_2   (0x04UL << DFSDM_FLTCR1_JEXTSEL_Pos)
#define DFSDM_FLTCR1_JEXTSEL_3   (0x08UL << DFSDM_FLTCR1_JEXTSEL_Pos)
#define DFSDM_FLTCR1_JEXTSEL_4   (0x10UL << DFSDM_FLTCR1_JEXTSEL_Pos)
#define DFSDM_FLTCR1_JDMAEN_Pos   (5U)
#define DFSDM_FLTCR1_JDMAEN_Msk   (0x1UL << DFSDM_FLTCR1_JDMAEN_Pos)
#define DFSDM_FLTCR1_JDMAEN   DFSDM_FLTCR1_JDMAEN_Msk
#define DFSDM_FLTCR1_JSCAN_Pos   (4U)
#define DFSDM_FLTCR1_JSCAN_Msk   (0x1UL << DFSDM_FLTCR1_JSCAN_Pos)
#define DFSDM_FLTCR1_JSCAN   DFSDM_FLTCR1_JSCAN_Msk
#define DFSDM_FLTCR1_JSYNC_Pos   (3U)
#define DFSDM_FLTCR1_JSYNC_Msk   (0x1UL << DFSDM_FLTCR1_JSYNC_Pos)
#define DFSDM_FLTCR1_JSYNC   DFSDM_FLTCR1_JSYNC_Msk
#define DFSDM_FLTCR1_JSWSTART_Pos   (1U)
#define DFSDM_FLTCR1_JSWSTART_Msk   (0x1UL << DFSDM_FLTCR1_JSWSTART_Pos)
#define DFSDM_FLTCR1_JSWSTART   DFSDM_FLTCR1_JSWSTART_Msk
#define DFSDM_FLTCR1_DFEN_Pos   (0U)
#define DFSDM_FLTCR1_DFEN_Msk   (0x1UL << DFSDM_FLTCR1_DFEN_Pos)
#define DFSDM_FLTCR1_DFEN   DFSDM_FLTCR1_DFEN_Msk
#define DFSDM_FLTCR2_AWDCH_Pos   (16U)
#define DFSDM_FLTCR2_AWDCH_Msk   (0xFFUL << DFSDM_FLTCR2_AWDCH_Pos)
#define DFSDM_FLTCR2_AWDCH   DFSDM_FLTCR2_AWDCH_Msk
#define DFSDM_FLTCR2_EXCH_Pos   (8U)
#define DFSDM_FLTCR2_EXCH_Msk   (0xFFUL << DFSDM_FLTCR2_EXCH_Pos)
#define DFSDM_FLTCR2_EXCH   DFSDM_FLTCR2_EXCH_Msk
#define DFSDM_FLTCR2_CKABIE_Pos   (6U)
#define DFSDM_FLTCR2_CKABIE_Msk   (0x1UL << DFSDM_FLTCR2_CKABIE_Pos)
#define DFSDM_FLTCR2_CKABIE   DFSDM_FLTCR2_CKABIE_Msk
#define DFSDM_FLTCR2_SCDIE_Pos   (5U)
#define DFSDM_FLTCR2_SCDIE_Msk   (0x1UL << DFSDM_FLTCR2_SCDIE_Pos)
#define DFSDM_FLTCR2_SCDIE   DFSDM_FLTCR2_SCDIE_Msk
#define DFSDM_FLTCR2_AWDIE_Pos   (4U)
#define DFSDM_FLTCR2_AWDIE_Msk   (0x1UL << DFSDM_FLTCR2_AWDIE_Pos)
#define DFSDM_FLTCR2_AWDIE   DFSDM_FLTCR2_AWDIE_Msk
#define DFSDM_FLTCR2_ROVRIE_Pos   (3U)
#define DFSDM_FLTCR2_ROVRIE_Msk   (0x1UL << DFSDM_FLTCR2_ROVRIE_Pos)
#define DFSDM_FLTCR2_ROVRIE   DFSDM_FLTCR2_ROVRIE_Msk
#define DFSDM_FLTCR2_JOVRIE_Pos   (2U)
#define DFSDM_FLTCR2_JOVRIE_Msk   (0x1UL << DFSDM_FLTCR2_JOVRIE_Pos)
#define DFSDM_FLTCR2_JOVRIE   DFSDM_FLTCR2_JOVRIE_Msk
#define DFSDM_FLTCR2_REOCIE_Pos   (1U)
#define DFSDM_FLTCR2_REOCIE_Msk   (0x1UL << DFSDM_FLTCR2_REOCIE_Pos)
#define DFSDM_FLTCR2_REOCIE   DFSDM_FLTCR2_REOCIE_Msk
#define DFSDM_FLTCR2_JEOCIE_Pos   (0U)
#define DFSDM_FLTCR2_JEOCIE_Msk   (0x1UL << DFSDM_FLTCR2_JEOCIE_Pos)
#define DFSDM_FLTCR2_JEOCIE   DFSDM_FLTCR2_JEOCIE_Msk
#define DFSDM_FLTISR_SCDF_Pos   (24U)
#define DFSDM_FLTISR_SCDF_Msk   (0xFFUL << DFSDM_FLTISR_SCDF_Pos)
#define DFSDM_FLTISR_SCDF   DFSDM_FLTISR_SCDF_Msk
#define DFSDM_FLTISR_CKABF_Pos   (16U)
#define DFSDM_FLTISR_CKABF_Msk   (0xFFUL << DFSDM_FLTISR_CKABF_Pos)
#define DFSDM_FLTISR_CKABF   DFSDM_FLTISR_CKABF_Msk
#define DFSDM_FLTISR_RCIP_Pos   (14U)
#define DFSDM_FLTISR_RCIP_Msk   (0x1UL << DFSDM_FLTISR_RCIP_Pos)
#define DFSDM_FLTISR_RCIP   DFSDM_FLTISR_RCIP_Msk
#define DFSDM_FLTISR_JCIP_Pos   (13U)
#define DFSDM_FLTISR_JCIP_Msk   (0x1UL << DFSDM_FLTISR_JCIP_Pos)
#define DFSDM_FLTISR_JCIP   DFSDM_FLTISR_JCIP_Msk
#define DFSDM_FLTISR_AWDF_Pos   (4U)
#define DFSDM_FLTISR_AWDF_Msk   (0x1UL << DFSDM_FLTISR_AWDF_Pos)
#define DFSDM_FLTISR_AWDF   DFSDM_FLTISR_AWDF_Msk
#define DFSDM_FLTISR_ROVRF_Pos   (3U)
#define DFSDM_FLTISR_ROVRF_Msk   (0x1UL << DFSDM_FLTISR_ROVRF_Pos)
#define DFSDM_FLTISR_ROVRF   DFSDM_FLTISR_ROVRF_Msk
#define DFSDM_FLTISR_JOVRF_Pos   (2U)
#define DFSDM_FLTISR_JOVRF_Msk   (0x1UL << DFSDM_FLTISR_JOVRF_Pos)
#define DFSDM_FLTISR_JOVRF   DFSDM_FLTISR_JOVRF_Msk
#define DFSDM_FLTISR_REOCF_Pos   (1U)
#define DFSDM_FLTISR_REOCF_Msk   (0x1UL << DFSDM_FLTISR_REOCF_Pos)
#define DFSDM_FLTISR_REOCF   DFSDM_FLTISR_REOCF_Msk
#define DFSDM_FLTISR_JEOCF_Pos   (0U)
#define DFSDM_FLTISR_JEOCF_Msk   (0x1UL << DFSDM_FLTISR_JEOCF_Pos)
#define DFSDM_FLTISR_JEOCF   DFSDM_FLTISR_JEOCF_Msk
#define DFSDM_FLTICR_CLRSCDF_Pos   (24U)
#define DFSDM_FLTICR_CLRSCDF_Msk   (0xFFUL << DFSDM_FLTICR_CLRSCDF_Pos)
#define DFSDM_FLTICR_CLRSCDF   DFSDM_FLTICR_CLRSCDF_Msk
#define DFSDM_FLTICR_CLRCKABF_Pos   (16U)
#define DFSDM_FLTICR_CLRCKABF_Msk   (0xFFUL << DFSDM_FLTICR_CLRCKABF_Pos)
#define DFSDM_FLTICR_CLRCKABF   DFSDM_FLTICR_CLRCKABF_Msk
#define DFSDM_FLTICR_CLRROVRF_Pos   (3U)
#define DFSDM_FLTICR_CLRROVRF_Msk   (0x1UL << DFSDM_FLTICR_CLRROVRF_Pos)
#define DFSDM_FLTICR_CLRROVRF   DFSDM_FLTICR_CLRROVRF_Msk
#define DFSDM_FLTICR_CLRJOVRF_Pos   (2U)
#define DFSDM_FLTICR_CLRJOVRF_Msk   (0x1UL << DFSDM_FLTICR_CLRJOVRF_Pos)
#define DFSDM_FLTICR_CLRJOVRF   DFSDM_FLTICR_CLRJOVRF_Msk
#define DFSDM_FLTJCHGR_JCHG_Pos   (0U)
#define DFSDM_FLTJCHGR_JCHG_Msk   (0xFFUL << DFSDM_FLTJCHGR_JCHG_Pos)
#define DFSDM_FLTJCHGR_JCHG   DFSDM_FLTJCHGR_JCHG_Msk
#define DFSDM_FLTFCR_FORD_Pos   (29U)
#define DFSDM_FLTFCR_FORD_Msk   (0x7UL << DFSDM_FLTFCR_FORD_Pos)
#define DFSDM_FLTFCR_FORD   DFSDM_FLTFCR_FORD_Msk
#define DFSDM_FLTFCR_FORD_2   (0x4UL << DFSDM_FLTFCR_FORD_Pos)
#define DFSDM_FLTFCR_FORD_1   (0x2UL << DFSDM_FLTFCR_FORD_Pos)
#define DFSDM_FLTFCR_FORD_0   (0x1UL << DFSDM_FLTFCR_FORD_Pos)
#define DFSDM_FLTFCR_FOSR_Pos   (16U)
#define DFSDM_FLTFCR_FOSR_Msk   (0x3FFUL << DFSDM_FLTFCR_FOSR_Pos)
#define DFSDM_FLTFCR_FOSR   DFSDM_FLTFCR_FOSR_Msk
#define DFSDM_FLTFCR_IOSR_Pos   (0U)
#define DFSDM_FLTFCR_IOSR_Msk   (0xFFUL << DFSDM_FLTFCR_IOSR_Pos)
#define DFSDM_FLTFCR_IOSR   DFSDM_FLTFCR_IOSR_Msk
#define DFSDM_FLTJDATAR_JDATA_Pos   (8U)
#define DFSDM_FLTJDATAR_JDATA_Msk   (0xFFFFFFUL << DFSDM_FLTJDATAR_JDATA_Pos)
#define DFSDM_FLTJDATAR_JDATA   DFSDM_FLTJDATAR_JDATA_Msk
#define DFSDM_FLTJDATAR_JDATACH_Pos   (0U)
#define DFSDM_FLTJDATAR_JDATACH_Msk   (0x7UL << DFSDM_FLTJDATAR_JDATACH_Pos)
#define DFSDM_FLTJDATAR_JDATACH   DFSDM_FLTJDATAR_JDATACH_Msk
#define DFSDM_FLTRDATAR_RDATA_Pos   (8U)
#define DFSDM_FLTRDATAR_RDATA_Msk   (0xFFFFFFUL << DFSDM_FLTRDATAR_RDATA_Pos)
#define DFSDM_FLTRDATAR_RDATA   DFSDM_FLTRDATAR_RDATA_Msk
#define DFSDM_FLTRDATAR_RPEND_Pos   (4U)
#define DFSDM_FLTRDATAR_RPEND_Msk   (0x1UL << DFSDM_FLTRDATAR_RPEND_Pos)
#define DFSDM_FLTRDATAR_RPEND   DFSDM_FLTRDATAR_RPEND_Msk
#define DFSDM_FLTRDATAR_RDATACH_Pos   (0U)
#define DFSDM_FLTRDATAR_RDATACH_Msk   (0x7UL << DFSDM_FLTRDATAR_RDATACH_Pos)
#define DFSDM_FLTRDATAR_RDATACH   DFSDM_FLTRDATAR_RDATACH_Msk
#define DFSDM_FLTAWHTR_AWHT_Pos   (8U)
#define DFSDM_FLTAWHTR_AWHT_Msk   (0xFFFFFFUL << DFSDM_FLTAWHTR_AWHT_Pos)
#define DFSDM_FLTAWHTR_AWHT   DFSDM_FLTAWHTR_AWHT_Msk
#define DFSDM_FLTAWHTR_BKAWH_Pos   (0U)
#define DFSDM_FLTAWHTR_BKAWH_Msk   (0xFUL << DFSDM_FLTAWHTR_BKAWH_Pos)
#define DFSDM_FLTAWHTR_BKAWH   DFSDM_FLTAWHTR_BKAWH_Msk
#define DFSDM_FLTAWLTR_AWLT_Pos   (8U)
#define DFSDM_FLTAWLTR_AWLT_Msk   (0xFFFFFFUL << DFSDM_FLTAWLTR_AWLT_Pos)
#define DFSDM_FLTAWLTR_AWLT   DFSDM_FLTAWLTR_AWLT_Msk
#define DFSDM_FLTAWLTR_BKAWL_Pos   (0U)
#define DFSDM_FLTAWLTR_BKAWL_Msk   (0xFUL << DFSDM_FLTAWLTR_BKAWL_Pos)
#define DFSDM_FLTAWLTR_BKAWL   DFSDM_FLTAWLTR_BKAWL_Msk
#define DFSDM_FLTAWSR_AWHTF_Pos   (8U)
#define DFSDM_FLTAWSR_AWHTF_Msk   (0xFFUL << DFSDM_FLTAWSR_AWHTF_Pos)
#define DFSDM_FLTAWSR_AWHTF   DFSDM_FLTAWSR_AWHTF_Msk
#define DFSDM_FLTAWSR_AWLTF_Pos   (0U)
#define DFSDM_FLTAWSR_AWLTF_Msk   (0xFFUL << DFSDM_FLTAWSR_AWLTF_Pos)
#define DFSDM_FLTAWSR_AWLTF   DFSDM_FLTAWSR_AWLTF_Msk
#define DFSDM_FLTAWCFR_CLRAWHTF_Pos   (8U)
#define DFSDM_FLTAWCFR_CLRAWHTF_Msk   (0xFFUL << DFSDM_FLTAWCFR_CLRAWHTF_Pos)
#define DFSDM_FLTAWCFR_CLRAWHTF   DFSDM_FLTAWCFR_CLRAWHTF_Msk
#define DFSDM_FLTAWCFR_CLRAWLTF_Pos   (0U)
#define DFSDM_FLTAWCFR_CLRAWLTF_Msk   (0xFFUL << DFSDM_FLTAWCFR_CLRAWLTF_Pos)
#define DFSDM_FLTAWCFR_CLRAWLTF   DFSDM_FLTAWCFR_CLRAWLTF_Msk
#define DFSDM_FLTEXMAX_EXMAX_Pos   (8U)
#define DFSDM_FLTEXMAX_EXMAX_Msk   (0xFFFFFFUL << DFSDM_FLTEXMAX_EXMAX_Pos)
#define DFSDM_FLTEXMAX_EXMAX   DFSDM_FLTEXMAX_EXMAX_Msk
#define DFSDM_FLTEXMAX_EXMAXCH_Pos   (0U)
#define DFSDM_FLTEXMAX_EXMAXCH_Msk   (0x7UL << DFSDM_FLTEXMAX_EXMAXCH_Pos)
#define DFSDM_FLTEXMAX_EXMAXCH   DFSDM_FLTEXMAX_EXMAXCH_Msk
#define DFSDM_FLTEXMIN_EXMIN_Pos   (8U)
#define DFSDM_FLTEXMIN_EXMIN_Msk   (0xFFFFFFUL << DFSDM_FLTEXMIN_EXMIN_Pos)
#define DFSDM_FLTEXMIN_EXMIN   DFSDM_FLTEXMIN_EXMIN_Msk
#define DFSDM_FLTEXMIN_EXMINCH_Pos   (0U)
#define DFSDM_FLTEXMIN_EXMINCH_Msk   (0x7UL << DFSDM_FLTEXMIN_EXMINCH_Pos)
#define DFSDM_FLTEXMIN_EXMINCH   DFSDM_FLTEXMIN_EXMINCH_Msk
#define DFSDM_FLTCNVTIMR_CNVCNT_Pos   (4U)
#define DFSDM_FLTCNVTIMR_CNVCNT_Msk   (0xFFFFFFFUL << DFSDM_FLTCNVTIMR_CNVCNT_Pos)
#define DFSDM_FLTCNVTIMR_CNVCNT   DFSDM_FLTCNVTIMR_CNVCNT_Msk
#define BDMA_ISR_GIF0_Pos   (0U)
#define BDMA_ISR_GIF0_Msk   (0x1UL << BDMA_ISR_GIF0_Pos)
#define BDMA_ISR_GIF0   BDMA_ISR_GIF0_Msk
#define BDMA_ISR_TCIF0_Pos   (1U)
#define BDMA_ISR_TCIF0_Msk   (0x1UL << BDMA_ISR_TCIF0_Pos)
#define BDMA_ISR_TCIF0   BDMA_ISR_TCIF0_Msk
#define BDMA_ISR_HTIF0_Pos   (2U)
#define BDMA_ISR_HTIF0_Msk   (0x1UL << BDMA_ISR_HTIF0_Pos)
#define BDMA_ISR_HTIF0   BDMA_ISR_HTIF0_Msk
#define BDMA_ISR_TEIF0_Pos   (3U)
#define BDMA_ISR_TEIF0_Msk   (0x1UL << BDMA_ISR_TEIF0_Pos)
#define BDMA_ISR_TEIF0   BDMA_ISR_TEIF0_Msk
#define BDMA_ISR_GIF1_Pos   (4U)
#define BDMA_ISR_GIF1_Msk   (0x1UL << BDMA_ISR_GIF1_Pos)
#define BDMA_ISR_GIF1   BDMA_ISR_GIF1_Msk
#define BDMA_ISR_TCIF1_Pos   (5U)
#define BDMA_ISR_TCIF1_Msk   (0x1UL << BDMA_ISR_TCIF1_Pos)
#define BDMA_ISR_TCIF1   BDMA_ISR_TCIF1_Msk
#define BDMA_ISR_HTIF1_Pos   (6U)
#define BDMA_ISR_HTIF1_Msk   (0x1UL << BDMA_ISR_HTIF1_Pos)
#define BDMA_ISR_HTIF1   BDMA_ISR_HTIF1_Msk
#define BDMA_ISR_TEIF1_Pos   (7U)
#define BDMA_ISR_TEIF1_Msk   (0x1UL << BDMA_ISR_TEIF1_Pos)
#define BDMA_ISR_TEIF1   BDMA_ISR_TEIF1_Msk
#define BDMA_ISR_GIF2_Pos   (8U)
#define BDMA_ISR_GIF2_Msk   (0x1UL << BDMA_ISR_GIF2_Pos)
#define BDMA_ISR_GIF2   BDMA_ISR_GIF2_Msk
#define BDMA_ISR_TCIF2_Pos   (9U)
#define BDMA_ISR_TCIF2_Msk   (0x1UL << BDMA_ISR_TCIF2_Pos)
#define BDMA_ISR_TCIF2   BDMA_ISR_TCIF2_Msk
#define BDMA_ISR_HTIF2_Pos   (10U)
#define BDMA_ISR_HTIF2_Msk   (0x1UL << BDMA_ISR_HTIF2_Pos)
#define BDMA_ISR_HTIF2   BDMA_ISR_HTIF2_Msk
#define BDMA_ISR_TEIF2_Pos   (11U)
#define BDMA_ISR_TEIF2_Msk   (0x1UL << BDMA_ISR_TEIF2_Pos)
#define BDMA_ISR_TEIF2   BDMA_ISR_TEIF2_Msk
#define BDMA_ISR_GIF3_Pos   (12U)
#define BDMA_ISR_GIF3_Msk   (0x1UL << BDMA_ISR_GIF3_Pos)
#define BDMA_ISR_GIF3   BDMA_ISR_GIF3_Msk
#define BDMA_ISR_TCIF3_Pos   (13U)
#define BDMA_ISR_TCIF3_Msk   (0x1UL << BDMA_ISR_TCIF3_Pos)
#define BDMA_ISR_TCIF3   BDMA_ISR_TCIF3_Msk
#define BDMA_ISR_HTIF3_Pos   (14U)
#define BDMA_ISR_HTIF3_Msk   (0x1UL << BDMA_ISR_HTIF3_Pos)
#define BDMA_ISR_HTIF3   BDMA_ISR_HTIF3_Msk
#define BDMA_ISR_TEIF3_Pos   (15U)
#define BDMA_ISR_TEIF3_Msk   (0x1UL << BDMA_ISR_TEIF3_Pos)
#define BDMA_ISR_TEIF3   BDMA_ISR_TEIF3_Msk
#define BDMA_ISR_GIF4_Pos   (16U)
#define BDMA_ISR_GIF4_Msk   (0x1UL << BDMA_ISR_GIF4_Pos)
#define BDMA_ISR_GIF4   BDMA_ISR_GIF4_Msk
#define BDMA_ISR_TCIF4_Pos   (17U)
#define BDMA_ISR_TCIF4_Msk   (0x1UL << BDMA_ISR_TCIF4_Pos)
#define BDMA_ISR_TCIF4   BDMA_ISR_TCIF4_Msk
#define BDMA_ISR_HTIF4_Pos   (18U)
#define BDMA_ISR_HTIF4_Msk   (0x1UL << BDMA_ISR_HTIF4_Pos)
#define BDMA_ISR_HTIF4   BDMA_ISR_HTIF4_Msk
#define BDMA_ISR_TEIF4_Pos   (19U)
#define BDMA_ISR_TEIF4_Msk   (0x1UL << BDMA_ISR_TEIF4_Pos)
#define BDMA_ISR_TEIF4   BDMA_ISR_TEIF4_Msk
#define BDMA_ISR_GIF5_Pos   (20U)
#define BDMA_ISR_GIF5_Msk   (0x1UL << BDMA_ISR_GIF5_Pos)
#define BDMA_ISR_GIF5   BDMA_ISR_GIF5_Msk
#define BDMA_ISR_TCIF5_Pos   (21U)
#define BDMA_ISR_TCIF5_Msk   (0x1UL << BDMA_ISR_TCIF5_Pos)
#define BDMA_ISR_TCIF5   BDMA_ISR_TCIF5_Msk
#define BDMA_ISR_HTIF5_Pos   (22U)
#define BDMA_ISR_HTIF5_Msk   (0x1UL << BDMA_ISR_HTIF5_Pos)
#define BDMA_ISR_HTIF5   BDMA_ISR_HTIF5_Msk
#define BDMA_ISR_TEIF5_Pos   (23U)
#define BDMA_ISR_TEIF5_Msk   (0x1UL << BDMA_ISR_TEIF5_Pos)
#define BDMA_ISR_TEIF5   BDMA_ISR_TEIF5_Msk
#define BDMA_ISR_GIF6_Pos   (24U)
#define BDMA_ISR_GIF6_Msk   (0x1UL << BDMA_ISR_GIF6_Pos)
#define BDMA_ISR_GIF6   BDMA_ISR_GIF6_Msk
#define BDMA_ISR_TCIF6_Pos   (25U)
#define BDMA_ISR_TCIF6_Msk   (0x1UL << BDMA_ISR_TCIF6_Pos)
#define BDMA_ISR_TCIF6   BDMA_ISR_TCIF6_Msk
#define BDMA_ISR_HTIF6_Pos   (26U)
#define BDMA_ISR_HTIF6_Msk   (0x1UL << BDMA_ISR_HTIF6_Pos)
#define BDMA_ISR_HTIF6   BDMA_ISR_HTIF6_Msk
#define BDMA_ISR_TEIF6_Pos   (27U)
#define BDMA_ISR_TEIF6_Msk   (0x1UL << BDMA_ISR_TEIF6_Pos)
#define BDMA_ISR_TEIF6   BDMA_ISR_TEIF6_Msk
#define BDMA_ISR_GIF7_Pos   (28U)
#define BDMA_ISR_GIF7_Msk   (0x1UL << BDMA_ISR_GIF7_Pos)
#define BDMA_ISR_GIF7   BDMA_ISR_GIF7_Msk
#define BDMA_ISR_TCIF7_Pos   (29U)
#define BDMA_ISR_TCIF7_Msk   (0x1UL << BDMA_ISR_TCIF7_Pos)
#define BDMA_ISR_TCIF7   BDMA_ISR_TCIF7_Msk
#define BDMA_ISR_HTIF7_Pos   (30U)
#define BDMA_ISR_HTIF7_Msk   (0x1UL << BDMA_ISR_HTIF7_Pos)
#define BDMA_ISR_HTIF7   BDMA_ISR_HTIF7_Msk
#define BDMA_ISR_TEIF7_Pos   (31U)
#define BDMA_ISR_TEIF7_Msk   (0x1UL << BDMA_ISR_TEIF7_Pos)
#define BDMA_ISR_TEIF7   BDMA_ISR_TEIF7_Msk
#define BDMA_IFCR_CGIF0_Pos   (0U)
#define BDMA_IFCR_CGIF0_Msk   (0x1UL << BDMA_IFCR_CGIF0_Pos)
#define BDMA_IFCR_CGIF0   BDMA_IFCR_CGIF0_Msk
#define BDMA_IFCR_CTCIF0_Pos   (1U)
#define BDMA_IFCR_CTCIF0_Msk   (0x1UL << BDMA_IFCR_CTCIF0_Pos)
#define BDMA_IFCR_CTCIF0   BDMA_IFCR_CTCIF0_Msk
#define BDMA_IFCR_CHTIF0_Pos   (2U)
#define BDMA_IFCR_CHTIF0_Msk   (0x1UL << BDMA_IFCR_CHTIF0_Pos)
#define BDMA_IFCR_CHTIF0   BDMA_IFCR_CHTIF0_Msk
#define BDMA_IFCR_CTEIF0_Pos   (3U)
#define BDMA_IFCR_CTEIF0_Msk   (0x1UL << BDMA_IFCR_CTEIF0_Pos)
#define BDMA_IFCR_CTEIF0   BDMA_IFCR_CTEIF0_Msk
#define BDMA_IFCR_CGIF1_Pos   (4U)
#define BDMA_IFCR_CGIF1_Msk   (0x1UL << BDMA_IFCR_CGIF1_Pos)
#define BDMA_IFCR_CGIF1   BDMA_IFCR_CGIF1_Msk
#define BDMA_IFCR_CTCIF1_Pos   (5U)
#define BDMA_IFCR_CTCIF1_Msk   (0x1UL << BDMA_IFCR_CTCIF1_Pos)
#define BDMA_IFCR_CTCIF1   BDMA_IFCR_CTCIF1_Msk
#define BDMA_IFCR_CHTIF1_Pos   (6U)
#define BDMA_IFCR_CHTIF1_Msk   (0x1UL << BDMA_IFCR_CHTIF1_Pos)
#define BDMA_IFCR_CHTIF1   BDMA_IFCR_CHTIF1_Msk
#define BDMA_IFCR_CTEIF1_Pos   (7U)
#define BDMA_IFCR_CTEIF1_Msk   (0x1UL << BDMA_IFCR_CTEIF1_Pos)
#define BDMA_IFCR_CTEIF1   BDMA_IFCR_CTEIF1_Msk
#define BDMA_IFCR_CGIF2_Pos   (8U)
#define BDMA_IFCR_CGIF2_Msk   (0x1UL << BDMA_IFCR_CGIF2_Pos)
#define BDMA_IFCR_CGIF2   BDMA_IFCR_CGIF2_Msk
#define BDMA_IFCR_CTCIF2_Pos   (9U)
#define BDMA_IFCR_CTCIF2_Msk   (0x1UL << BDMA_IFCR_CTCIF2_Pos)
#define BDMA_IFCR_CTCIF2   BDMA_IFCR_CTCIF2_Msk
#define BDMA_IFCR_CHTIF2_Pos   (10U)
#define BDMA_IFCR_CHTIF2_Msk   (0x1UL << BDMA_IFCR_CHTIF2_Pos)
#define BDMA_IFCR_CHTIF2   BDMA_IFCR_CHTIF2_Msk
#define BDMA_IFCR_CTEIF2_Pos   (11U)
#define BDMA_IFCR_CTEIF2_Msk   (0x1UL << BDMA_IFCR_CTEIF2_Pos)
#define BDMA_IFCR_CTEIF2   BDMA_IFCR_CTEIF2_Msk
#define BDMA_IFCR_CGIF3_Pos   (12U)
#define BDMA_IFCR_CGIF3_Msk   (0x1UL << BDMA_IFCR_CGIF3_Pos)
#define BDMA_IFCR_CGIF3   BDMA_IFCR_CGIF3_Msk
#define BDMA_IFCR_CTCIF3_Pos   (13U)
#define BDMA_IFCR_CTCIF3_Msk   (0x1UL << BDMA_IFCR_CTCIF3_Pos)
#define BDMA_IFCR_CTCIF3   BDMA_IFCR_CTCIF3_Msk
#define BDMA_IFCR_CHTIF3_Pos   (14U)
#define BDMA_IFCR_CHTIF3_Msk   (0x1UL << BDMA_IFCR_CHTIF3_Pos)
#define BDMA_IFCR_CHTIF3   BDMA_IFCR_CHTIF3_Msk
#define BDMA_IFCR_CTEIF3_Pos   (15U)
#define BDMA_IFCR_CTEIF3_Msk   (0x1UL << BDMA_IFCR_CTEIF3_Pos)
#define BDMA_IFCR_CTEIF3   BDMA_IFCR_CTEIF3_Msk
#define BDMA_IFCR_CGIF4_Pos   (16U)
#define BDMA_IFCR_CGIF4_Msk   (0x1UL << BDMA_IFCR_CGIF4_Pos)
#define BDMA_IFCR_CGIF4   BDMA_IFCR_CGIF4_Msk
#define BDMA_IFCR_CTCIF4_Pos   (17U)
#define BDMA_IFCR_CTCIF4_Msk   (0x1UL << BDMA_IFCR_CTCIF4_Pos)
#define BDMA_IFCR_CTCIF4   BDMA_IFCR_CTCIF4_Msk
#define BDMA_IFCR_CHTIF4_Pos   (18U)
#define BDMA_IFCR_CHTIF4_Msk   (0x1UL << BDMA_IFCR_CHTIF4_Pos)
#define BDMA_IFCR_CHTIF4   BDMA_IFCR_CHTIF4_Msk
#define BDMA_IFCR_CTEIF4_Pos   (19U)
#define BDMA_IFCR_CTEIF4_Msk   (0x1UL << BDMA_IFCR_CTEIF4_Pos)
#define BDMA_IFCR_CTEIF4   BDMA_IFCR_CTEIF4_Msk
#define BDMA_IFCR_CGIF5_Pos   (20U)
#define BDMA_IFCR_CGIF5_Msk   (0x1UL << BDMA_IFCR_CGIF5_Pos)
#define BDMA_IFCR_CGIF5   BDMA_IFCR_CGIF5_Msk
#define BDMA_IFCR_CTCIF5_Pos   (21U)
#define BDMA_IFCR_CTCIF5_Msk   (0x1UL << BDMA_IFCR_CTCIF5_Pos)
#define BDMA_IFCR_CTCIF5   BDMA_IFCR_CTCIF5_Msk
#define BDMA_IFCR_CHTIF5_Pos   (22U)
#define BDMA_IFCR_CHTIF5_Msk   (0x1UL << BDMA_IFCR_CHTIF5_Pos)
#define BDMA_IFCR_CHTIF5   BDMA_IFCR_CHTIF5_Msk
#define BDMA_IFCR_CTEIF5_Pos   (23U)
#define BDMA_IFCR_CTEIF5_Msk   (0x1UL << BDMA_IFCR_CTEIF5_Pos)
#define BDMA_IFCR_CTEIF5   BDMA_IFCR_CTEIF5_Msk
#define BDMA_IFCR_CGIF6_Pos   (24U)
#define BDMA_IFCR_CGIF6_Msk   (0x1UL << BDMA_IFCR_CGIF6_Pos)
#define BDMA_IFCR_CGIF6   BDMA_IFCR_CGIF6_Msk
#define BDMA_IFCR_CTCIF6_Pos   (25U)
#define BDMA_IFCR_CTCIF6_Msk   (0x1UL << BDMA_IFCR_CTCIF6_Pos)
#define BDMA_IFCR_CTCIF6   BDMA_IFCR_CTCIF6_Msk
#define BDMA_IFCR_CHTIF6_Pos   (26U)
#define BDMA_IFCR_CHTIF6_Msk   (0x1UL << BDMA_IFCR_CHTIF6_Pos)
#define BDMA_IFCR_CHTIF6   BDMA_IFCR_CHTIF6_Msk
#define BDMA_IFCR_CTEIF6_Pos   (27U)
#define BDMA_IFCR_CTEIF6_Msk   (0x1UL << BDMA_IFCR_CTEIF6_Pos)
#define BDMA_IFCR_CTEIF6   BDMA_IFCR_CTEIF6_Msk
#define BDMA_IFCR_CGIF7_Pos   (28U)
#define BDMA_IFCR_CGIF7_Msk   (0x1UL << BDMA_IFCR_CGIF7_Pos)
#define BDMA_IFCR_CGIF7   BDMA_IFCR_CGIF7_Msk
#define BDMA_IFCR_CTCIF7_Pos   (29U)
#define BDMA_IFCR_CTCIF7_Msk   (0x1UL << BDMA_IFCR_CTCIF7_Pos)
#define BDMA_IFCR_CTCIF7   BDMA_IFCR_CTCIF7_Msk
#define BDMA_IFCR_CHTIF7_Pos   (30U)
#define BDMA_IFCR_CHTIF7_Msk   (0x1UL << BDMA_IFCR_CHTIF7_Pos)
#define BDMA_IFCR_CHTIF7   BDMA_IFCR_CHTIF7_Msk
#define BDMA_IFCR_CTEIF7_Pos   (31U)
#define BDMA_IFCR_CTEIF7_Msk   (0x1UL << BDMA_IFCR_CTEIF7_Pos)
#define BDMA_IFCR_CTEIF7   BDMA_IFCR_CTEIF7_Msk
#define BDMA_CCR_EN_Pos   (0U)
#define BDMA_CCR_EN_Msk   (0x1UL << BDMA_CCR_EN_Pos)
#define BDMA_CCR_EN   BDMA_CCR_EN_Msk
#define BDMA_CCR_TCIE_Pos   (1U)
#define BDMA_CCR_TCIE_Msk   (0x1UL << BDMA_CCR_TCIE_Pos)
#define BDMA_CCR_TCIE   BDMA_CCR_TCIE_Msk
#define BDMA_CCR_HTIE_Pos   (2U)
#define BDMA_CCR_HTIE_Msk   (0x1UL << BDMA_CCR_HTIE_Pos)
#define BDMA_CCR_HTIE   BDMA_CCR_HTIE_Msk
#define BDMA_CCR_TEIE_Pos   (3U)
#define BDMA_CCR_TEIE_Msk   (0x1UL << BDMA_CCR_TEIE_Pos)
#define BDMA_CCR_TEIE   BDMA_CCR_TEIE_Msk
#define BDMA_CCR_DIR_Pos   (4U)
#define BDMA_CCR_DIR_Msk   (0x1UL << BDMA_CCR_DIR_Pos)
#define BDMA_CCR_DIR   BDMA_CCR_DIR_Msk
#define BDMA_CCR_CIRC_Pos   (5U)
#define BDMA_CCR_CIRC_Msk   (0x1UL << BDMA_CCR_CIRC_Pos)
#define BDMA_CCR_CIRC   BDMA_CCR_CIRC_Msk
#define BDMA_CCR_PINC_Pos   (6U)
#define BDMA_CCR_PINC_Msk   (0x1UL << BDMA_CCR_PINC_Pos)
#define BDMA_CCR_PINC   BDMA_CCR_PINC_Msk
#define BDMA_CCR_MINC_Pos   (7U)
#define BDMA_CCR_MINC_Msk   (0x1UL << BDMA_CCR_MINC_Pos)
#define BDMA_CCR_MINC   BDMA_CCR_MINC_Msk
#define BDMA_CCR_PSIZE_Pos   (8U)
#define BDMA_CCR_PSIZE_Msk   (0x3UL << BDMA_CCR_PSIZE_Pos)
#define BDMA_CCR_PSIZE   BDMA_CCR_PSIZE_Msk
#define BDMA_CCR_PSIZE_0   (0x1UL << BDMA_CCR_PSIZE_Pos)
#define BDMA_CCR_PSIZE_1   (0x2UL << BDMA_CCR_PSIZE_Pos)
#define BDMA_CCR_MSIZE_Pos   (10U)
#define BDMA_CCR_MSIZE_Msk   (0x3UL << BDMA_CCR_MSIZE_Pos)
#define BDMA_CCR_MSIZE   BDMA_CCR_MSIZE_Msk
#define BDMA_CCR_MSIZE_0   (0x1UL << BDMA_CCR_MSIZE_Pos)
#define BDMA_CCR_MSIZE_1   (0x2UL << BDMA_CCR_MSIZE_Pos)
#define BDMA_CCR_PL_Pos   (12U)
#define BDMA_CCR_PL_Msk   (0x3UL << BDMA_CCR_PL_Pos)
#define BDMA_CCR_PL   BDMA_CCR_PL_Msk
#define BDMA_CCR_PL_0   (0x1UL << BDMA_CCR_PL_Pos)
#define BDMA_CCR_PL_1   (0x2UL << BDMA_CCR_PL_Pos)
#define BDMA_CCR_MEM2MEM_Pos   (14U)
#define BDMA_CCR_MEM2MEM_Msk   (0x1UL << BDMA_CCR_MEM2MEM_Pos)
#define BDMA_CCR_MEM2MEM   BDMA_CCR_MEM2MEM_Msk
#define BDMA_CCR_DBM_Pos   (15U)
#define BDMA_CCR_DBM_Msk   (0x1UL << BDMA_CCR_DBM_Pos)
#define BDMA_CCR_DBM   BDMA_CCR_DBM_Msk
#define BDMA_CCR_CT_Pos   (16U)
#define BDMA_CCR_CT_Msk   (0x1UL << BDMA_CCR_CT_Pos)
#define BDMA_CCR_CT   BDMA_CCR_CT_Msk
#define BDMA_CNDTR_NDT_Pos   (0U)
#define BDMA_CNDTR_NDT_Msk   (0xFFFFUL << BDMA_CNDTR_NDT_Pos)
#define BDMA_CNDTR_NDT   BDMA_CNDTR_NDT_Msk
#define BDMA_CPAR_PA_Pos   (0U)
#define BDMA_CPAR_PA_Msk   (0xFFFFFFFFUL << BDMA_CPAR_PA_Pos)
#define BDMA_CPAR_PA   BDMA_CPAR_PA_Msk
#define BDMA_CM0AR_MA_Pos   (0U)
#define BDMA_CM0AR_MA_Msk   (0xFFFFFFFFUL << BDMA_CM0AR_MA_Pos)
#define BDMA_CM0AR_MA   BDMA_CM0AR_MA_Msk
#define BDMA_CM1AR_MA_Pos   (0U)
#define BDMA_CM1AR_MA_Msk   (0xFFFFFFFFUL << BDMA_CM1AR_MA_Pos)
#define BDMA_CM1AR_MA   BDMA_CM1AR_MA_Msk
#define DMA_SxCR_MBURST_Pos   (23U)
#define DMA_SxCR_MBURST_Msk   (0x3UL << DMA_SxCR_MBURST_Pos)
#define DMA_SxCR_MBURST   DMA_SxCR_MBURST_Msk
#define DMA_SxCR_MBURST_0   (0x1UL << DMA_SxCR_MBURST_Pos)
#define DMA_SxCR_MBURST_1   (0x2UL << DMA_SxCR_MBURST_Pos)
#define DMA_SxCR_PBURST_Pos   (21U)
#define DMA_SxCR_PBURST_Msk   (0x3UL << DMA_SxCR_PBURST_Pos)
#define DMA_SxCR_PBURST   DMA_SxCR_PBURST_Msk
#define DMA_SxCR_PBURST_0   (0x1UL << DMA_SxCR_PBURST_Pos)
#define DMA_SxCR_PBURST_1   (0x2UL << DMA_SxCR_PBURST_Pos)
#define DMA_SxCR_TRBUFF_Pos   (20U)
#define DMA_SxCR_TRBUFF_Msk   (0x1UL << DMA_SxCR_TRBUFF_Pos)
#define DMA_SxCR_TRBUFF   DMA_SxCR_TRBUFF_Msk
#define DMA_SxCR_CT_Pos   (19U)
#define DMA_SxCR_CT_Msk   (0x1UL << DMA_SxCR_CT_Pos)
#define DMA_SxCR_CT   DMA_SxCR_CT_Msk
#define DMA_SxCR_DBM_Pos   (18U)
#define DMA_SxCR_DBM_Msk   (0x1UL << DMA_SxCR_DBM_Pos)
#define DMA_SxCR_DBM   DMA_SxCR_DBM_Msk
#define DMA_SxCR_PL_Pos   (16U)
#define DMA_SxCR_PL_Msk   (0x3UL << DMA_SxCR_PL_Pos)
#define DMA_SxCR_PL   DMA_SxCR_PL_Msk
#define DMA_SxCR_PL_0   (0x1UL << DMA_SxCR_PL_Pos)
#define DMA_SxCR_PL_1   (0x2UL << DMA_SxCR_PL_Pos)
#define DMA_SxCR_PINCOS_Pos   (15U)
#define DMA_SxCR_PINCOS_Msk   (0x1UL << DMA_SxCR_PINCOS_Pos)
#define DMA_SxCR_PINCOS   DMA_SxCR_PINCOS_Msk
#define DMA_SxCR_MSIZE_Pos   (13U)
#define DMA_SxCR_MSIZE_Msk   (0x3UL << DMA_SxCR_MSIZE_Pos)
#define DMA_SxCR_MSIZE   DMA_SxCR_MSIZE_Msk
#define DMA_SxCR_MSIZE_0   (0x1UL << DMA_SxCR_MSIZE_Pos)
#define DMA_SxCR_MSIZE_1   (0x2UL << DMA_SxCR_MSIZE_Pos)
#define DMA_SxCR_PSIZE_Pos   (11U)
#define DMA_SxCR_PSIZE_Msk   (0x3UL << DMA_SxCR_PSIZE_Pos)
#define DMA_SxCR_PSIZE   DMA_SxCR_PSIZE_Msk /*< Peripheral data size */
#define DMA_SxCR_PSIZE_0   (0x1UL << DMA_SxCR_PSIZE_Pos)
#define DMA_SxCR_PSIZE_1   (0x2UL << DMA_SxCR_PSIZE_Pos)
#define DMA_SxCR_MINC_Pos   (10U)
#define DMA_SxCR_MINC_Msk   (0x1UL << DMA_SxCR_MINC_Pos)
#define DMA_SxCR_MINC   DMA_SxCR_MINC_Msk
#define DMA_SxCR_PINC_Pos   (9U)
#define DMA_SxCR_PINC_Msk   (0x1UL << DMA_SxCR_PINC_Pos)
#define DMA_SxCR_PINC   DMA_SxCR_PINC_Msk
#define DMA_SxCR_CIRC_Pos   (8U)
#define DMA_SxCR_CIRC_Msk   (0x1UL << DMA_SxCR_CIRC_Pos)
#define DMA_SxCR_CIRC   DMA_SxCR_CIRC_Msk
#define DMA_SxCR_DIR_Pos   (6U)
#define DMA_SxCR_DIR_Msk   (0x3UL << DMA_SxCR_DIR_Pos)
#define DMA_SxCR_DIR   DMA_SxCR_DIR_Msk
#define DMA_SxCR_DIR_0   (0x1UL << DMA_SxCR_DIR_Pos)
#define DMA_SxCR_DIR_1   (0x2UL << DMA_SxCR_DIR_Pos)
#define DMA_SxCR_PFCTRL_Pos   (5U)
#define DMA_SxCR_PFCTRL_Msk   (0x1UL << DMA_SxCR_PFCTRL_Pos)
#define DMA_SxCR_PFCTRL   DMA_SxCR_PFCTRL_Msk
#define DMA_SxCR_TCIE_Pos   (4U)
#define DMA_SxCR_TCIE_Msk   (0x1UL << DMA_SxCR_TCIE_Pos)
#define DMA_SxCR_TCIE   DMA_SxCR_TCIE_Msk
#define DMA_SxCR_HTIE_Pos   (3U)
#define DMA_SxCR_HTIE_Msk   (0x1UL << DMA_SxCR_HTIE_Pos)
#define DMA_SxCR_HTIE   DMA_SxCR_HTIE_Msk
#define DMA_SxCR_TEIE_Pos   (2U)
#define DMA_SxCR_TEIE_Msk   (0x1UL << DMA_SxCR_TEIE_Pos)
#define DMA_SxCR_TEIE   DMA_SxCR_TEIE_Msk
#define DMA_SxCR_DMEIE_Pos   (1U)
#define DMA_SxCR_DMEIE_Msk   (0x1UL << DMA_SxCR_DMEIE_Pos)
#define DMA_SxCR_DMEIE   DMA_SxCR_DMEIE_Msk
#define DMA_SxCR_EN_Pos   (0U)
#define DMA_SxCR_EN_Msk   (0x1UL << DMA_SxCR_EN_Pos)
#define DMA_SxCR_EN   DMA_SxCR_EN_Msk
#define DMA_SxNDT_Pos   (0U)
#define DMA_SxNDT_Msk   (0xFFFFUL << DMA_SxNDT_Pos)
#define DMA_SxNDT   DMA_SxNDT_Msk
#define DMA_SxNDT_0   (0x0001UL << DMA_SxNDT_Pos)
#define DMA_SxNDT_1   (0x0002UL << DMA_SxNDT_Pos)
#define DMA_SxNDT_2   (0x0004UL << DMA_SxNDT_Pos)
#define DMA_SxNDT_3   (0x0008UL << DMA_SxNDT_Pos)
#define DMA_SxNDT_4   (0x0010UL << DMA_SxNDT_Pos)
#define DMA_SxNDT_5   (0x0020UL << DMA_SxNDT_Pos)
#define DMA_SxNDT_6   (0x0040UL << DMA_SxNDT_Pos)
#define DMA_SxNDT_7   (0x0080UL << DMA_SxNDT_Pos)
#define DMA_SxNDT_8   (0x0100UL << DMA_SxNDT_Pos)
#define DMA_SxNDT_9   (0x0200UL << DMA_SxNDT_Pos)
#define DMA_SxNDT_10   (0x0400UL << DMA_SxNDT_Pos)
#define DMA_SxNDT_11   (0x0800UL << DMA_SxNDT_Pos)
#define DMA_SxNDT_12   (0x1000UL << DMA_SxNDT_Pos)
#define DMA_SxNDT_13   (0x2000UL << DMA_SxNDT_Pos)
#define DMA_SxNDT_14   (0x4000UL << DMA_SxNDT_Pos)
#define DMA_SxNDT_15   (0x8000UL << DMA_SxNDT_Pos)
#define DMA_SxFCR_FEIE_Pos   (7U)
#define DMA_SxFCR_FEIE_Msk   (0x1UL << DMA_SxFCR_FEIE_Pos)
#define DMA_SxFCR_FEIE   DMA_SxFCR_FEIE_Msk
#define DMA_SxFCR_FS_Pos   (3U)
#define DMA_SxFCR_FS_Msk   (0x7UL << DMA_SxFCR_FS_Pos)
#define DMA_SxFCR_FS   DMA_SxFCR_FS_Msk
#define DMA_SxFCR_FS_0   (0x1UL << DMA_SxFCR_FS_Pos)
#define DMA_SxFCR_FS_1   (0x2UL << DMA_SxFCR_FS_Pos)
#define DMA_SxFCR_FS_2   (0x4UL << DMA_SxFCR_FS_Pos)
#define DMA_SxFCR_DMDIS_Pos   (2U)
#define DMA_SxFCR_DMDIS_Msk   (0x1UL << DMA_SxFCR_DMDIS_Pos)
#define DMA_SxFCR_DMDIS   DMA_SxFCR_DMDIS_Msk
#define DMA_SxFCR_FTH_Pos   (0U)
#define DMA_SxFCR_FTH_Msk   (0x3UL << DMA_SxFCR_FTH_Pos)
#define DMA_SxFCR_FTH   DMA_SxFCR_FTH_Msk
#define DMA_SxFCR_FTH_0   (0x1UL << DMA_SxFCR_FTH_Pos)
#define DMA_SxFCR_FTH_1   (0x2UL << DMA_SxFCR_FTH_Pos)
#define DMA_LISR_TCIF3_Pos   (27U)
#define DMA_LISR_TCIF3_Msk   (0x1UL << DMA_LISR_TCIF3_Pos)
#define DMA_LISR_TCIF3   DMA_LISR_TCIF3_Msk
#define DMA_LISR_HTIF3_Pos   (26U)
#define DMA_LISR_HTIF3_Msk   (0x1UL << DMA_LISR_HTIF3_Pos)
#define DMA_LISR_HTIF3   DMA_LISR_HTIF3_Msk
#define DMA_LISR_TEIF3_Pos   (25U)
#define DMA_LISR_TEIF3_Msk   (0x1UL << DMA_LISR_TEIF3_Pos)
#define DMA_LISR_TEIF3   DMA_LISR_TEIF3_Msk
#define DMA_LISR_DMEIF3_Pos   (24U)
#define DMA_LISR_DMEIF3_Msk   (0x1UL << DMA_LISR_DMEIF3_Pos)
#define DMA_LISR_DMEIF3   DMA_LISR_DMEIF3_Msk
#define DMA_LISR_FEIF3_Pos   (22U)
#define DMA_LISR_FEIF3_Msk   (0x1UL << DMA_LISR_FEIF3_Pos)
#define DMA_LISR_FEIF3   DMA_LISR_FEIF3_Msk
#define DMA_LISR_TCIF2_Pos   (21U)
#define DMA_LISR_TCIF2_Msk   (0x1UL << DMA_LISR_TCIF2_Pos)
#define DMA_LISR_TCIF2   DMA_LISR_TCIF2_Msk
#define DMA_LISR_HTIF2_Pos   (20U)
#define DMA_LISR_HTIF2_Msk   (0x1UL << DMA_LISR_HTIF2_Pos)
#define DMA_LISR_HTIF2   DMA_LISR_HTIF2_Msk
#define DMA_LISR_TEIF2_Pos   (19U)
#define DMA_LISR_TEIF2_Msk   (0x1UL << DMA_LISR_TEIF2_Pos)
#define DMA_LISR_TEIF2   DMA_LISR_TEIF2_Msk
#define DMA_LISR_DMEIF2_Pos   (18U)
#define DMA_LISR_DMEIF2_Msk   (0x1UL << DMA_LISR_DMEIF2_Pos)
#define DMA_LISR_DMEIF2   DMA_LISR_DMEIF2_Msk
#define DMA_LISR_FEIF2_Pos   (16U)
#define DMA_LISR_FEIF2_Msk   (0x1UL << DMA_LISR_FEIF2_Pos)
#define DMA_LISR_FEIF2   DMA_LISR_FEIF2_Msk
#define DMA_LISR_TCIF1_Pos   (11U)
#define DMA_LISR_TCIF1_Msk   (0x1UL << DMA_LISR_TCIF1_Pos)
#define DMA_LISR_TCIF1   DMA_LISR_TCIF1_Msk
#define DMA_LISR_HTIF1_Pos   (10U)
#define DMA_LISR_HTIF1_Msk   (0x1UL << DMA_LISR_HTIF1_Pos)
#define DMA_LISR_HTIF1   DMA_LISR_HTIF1_Msk
#define DMA_LISR_TEIF1_Pos   (9U)
#define DMA_LISR_TEIF1_Msk   (0x1UL << DMA_LISR_TEIF1_Pos)
#define DMA_LISR_TEIF1   DMA_LISR_TEIF1_Msk
#define DMA_LISR_DMEIF1_Pos   (8U)
#define DMA_LISR_DMEIF1_Msk   (0x1UL << DMA_LISR_DMEIF1_Pos)
#define DMA_LISR_DMEIF1   DMA_LISR_DMEIF1_Msk
#define DMA_LISR_FEIF1_Pos   (6U)
#define DMA_LISR_FEIF1_Msk   (0x1UL << DMA_LISR_FEIF1_Pos)
#define DMA_LISR_FEIF1   DMA_LISR_FEIF1_Msk
#define DMA_LISR_TCIF0_Pos   (5U)
#define DMA_LISR_TCIF0_Msk   (0x1UL << DMA_LISR_TCIF0_Pos)
#define DMA_LISR_TCIF0   DMA_LISR_TCIF0_Msk
#define DMA_LISR_HTIF0_Pos   (4U)
#define DMA_LISR_HTIF0_Msk   (0x1UL << DMA_LISR_HTIF0_Pos)
#define DMA_LISR_HTIF0   DMA_LISR_HTIF0_Msk
#define DMA_LISR_TEIF0_Pos   (3U)
#define DMA_LISR_TEIF0_Msk   (0x1UL << DMA_LISR_TEIF0_Pos)
#define DMA_LISR_TEIF0   DMA_LISR_TEIF0_Msk
#define DMA_LISR_DMEIF0_Pos   (2U)
#define DMA_LISR_DMEIF0_Msk   (0x1UL << DMA_LISR_DMEIF0_Pos)
#define DMA_LISR_DMEIF0   DMA_LISR_DMEIF0_Msk
#define DMA_LISR_FEIF0_Pos   (0U)
#define DMA_LISR_FEIF0_Msk   (0x1UL << DMA_LISR_FEIF0_Pos)
#define DMA_LISR_FEIF0   DMA_LISR_FEIF0_Msk
#define DMA_HISR_TCIF7_Pos   (27U)
#define DMA_HISR_TCIF7_Msk   (0x1UL << DMA_HISR_TCIF7_Pos)
#define DMA_HISR_TCIF7   DMA_HISR_TCIF7_Msk
#define DMA_HISR_HTIF7_Pos   (26U)
#define DMA_HISR_HTIF7_Msk   (0x1UL << DMA_HISR_HTIF7_Pos)
#define DMA_HISR_HTIF7   DMA_HISR_HTIF7_Msk
#define DMA_HISR_TEIF7_Pos   (25U)
#define DMA_HISR_TEIF7_Msk   (0x1UL << DMA_HISR_TEIF7_Pos)
#define DMA_HISR_TEIF7   DMA_HISR_TEIF7_Msk
#define DMA_HISR_DMEIF7_Pos   (24U)
#define DMA_HISR_DMEIF7_Msk   (0x1UL << DMA_HISR_DMEIF7_Pos)
#define DMA_HISR_DMEIF7   DMA_HISR_DMEIF7_Msk
#define DMA_HISR_FEIF7_Pos   (22U)
#define DMA_HISR_FEIF7_Msk   (0x1UL << DMA_HISR_FEIF7_Pos)
#define DMA_HISR_FEIF7   DMA_HISR_FEIF7_Msk
#define DMA_HISR_TCIF6_Pos   (21U)
#define DMA_HISR_TCIF6_Msk   (0x1UL << DMA_HISR_TCIF6_Pos)
#define DMA_HISR_TCIF6   DMA_HISR_TCIF6_Msk
#define DMA_HISR_HTIF6_Pos   (20U)
#define DMA_HISR_HTIF6_Msk   (0x1UL << DMA_HISR_HTIF6_Pos)
#define DMA_HISR_HTIF6   DMA_HISR_HTIF6_Msk
#define DMA_HISR_TEIF6_Pos   (19U)
#define DMA_HISR_TEIF6_Msk   (0x1UL << DMA_HISR_TEIF6_Pos)
#define DMA_HISR_TEIF6   DMA_HISR_TEIF6_Msk
#define DMA_HISR_DMEIF6_Pos   (18U)
#define DMA_HISR_DMEIF6_Msk   (0x1UL << DMA_HISR_DMEIF6_Pos)
#define DMA_HISR_DMEIF6   DMA_HISR_DMEIF6_Msk
#define DMA_HISR_FEIF6_Pos   (16U)
#define DMA_HISR_FEIF6_Msk   (0x1UL << DMA_HISR_FEIF6_Pos)
#define DMA_HISR_FEIF6   DMA_HISR_FEIF6_Msk
#define DMA_HISR_TCIF5_Pos   (11U)
#define DMA_HISR_TCIF5_Msk   (0x1UL << DMA_HISR_TCIF5_Pos)
#define DMA_HISR_TCIF5   DMA_HISR_TCIF5_Msk
#define DMA_HISR_HTIF5_Pos   (10U)
#define DMA_HISR_HTIF5_Msk   (0x1UL << DMA_HISR_HTIF5_Pos)
#define DMA_HISR_HTIF5   DMA_HISR_HTIF5_Msk
#define DMA_HISR_TEIF5_Pos   (9U)
#define DMA_HISR_TEIF5_Msk   (0x1UL << DMA_HISR_TEIF5_Pos)
#define DMA_HISR_TEIF5   DMA_HISR_TEIF5_Msk
#define DMA_HISR_DMEIF5_Pos   (8U)
#define DMA_HISR_DMEIF5_Msk   (0x1UL << DMA_HISR_DMEIF5_Pos)
#define DMA_HISR_DMEIF5   DMA_HISR_DMEIF5_Msk
#define DMA_HISR_FEIF5_Pos   (6U)
#define DMA_HISR_FEIF5_Msk   (0x1UL << DMA_HISR_FEIF5_Pos)
#define DMA_HISR_FEIF5   DMA_HISR_FEIF5_Msk
#define DMA_HISR_TCIF4_Pos   (5U)
#define DMA_HISR_TCIF4_Msk   (0x1UL << DMA_HISR_TCIF4_Pos)
#define DMA_HISR_TCIF4   DMA_HISR_TCIF4_Msk
#define DMA_HISR_HTIF4_Pos   (4U)
#define DMA_HISR_HTIF4_Msk   (0x1UL << DMA_HISR_HTIF4_Pos)
#define DMA_HISR_HTIF4   DMA_HISR_HTIF4_Msk
#define DMA_HISR_TEIF4_Pos   (3U)
#define DMA_HISR_TEIF4_Msk   (0x1UL << DMA_HISR_TEIF4_Pos)
#define DMA_HISR_TEIF4   DMA_HISR_TEIF4_Msk
#define DMA_HISR_DMEIF4_Pos   (2U)
#define DMA_HISR_DMEIF4_Msk   (0x1UL << DMA_HISR_DMEIF4_Pos)
#define DMA_HISR_DMEIF4   DMA_HISR_DMEIF4_Msk
#define DMA_HISR_FEIF4_Pos   (0U)
#define DMA_HISR_FEIF4_Msk   (0x1UL << DMA_HISR_FEIF4_Pos)
#define DMA_HISR_FEIF4   DMA_HISR_FEIF4_Msk
#define DMA_LIFCR_CTCIF3_Pos   (27U)
#define DMA_LIFCR_CTCIF3_Msk   (0x1UL << DMA_LIFCR_CTCIF3_Pos)
#define DMA_LIFCR_CTCIF3   DMA_LIFCR_CTCIF3_Msk
#define DMA_LIFCR_CHTIF3_Pos   (26U)
#define DMA_LIFCR_CHTIF3_Msk   (0x1UL << DMA_LIFCR_CHTIF3_Pos)
#define DMA_LIFCR_CHTIF3   DMA_LIFCR_CHTIF3_Msk
#define DMA_LIFCR_CTEIF3_Pos   (25U)
#define DMA_LIFCR_CTEIF3_Msk   (0x1UL << DMA_LIFCR_CTEIF3_Pos)
#define DMA_LIFCR_CTEIF3   DMA_LIFCR_CTEIF3_Msk
#define DMA_LIFCR_CDMEIF3_Pos   (24U)
#define DMA_LIFCR_CDMEIF3_Msk   (0x1UL << DMA_LIFCR_CDMEIF3_Pos)
#define DMA_LIFCR_CDMEIF3   DMA_LIFCR_CDMEIF3_Msk
#define DMA_LIFCR_CFEIF3_Pos   (22U)
#define DMA_LIFCR_CFEIF3_Msk   (0x1UL << DMA_LIFCR_CFEIF3_Pos)
#define DMA_LIFCR_CFEIF3   DMA_LIFCR_CFEIF3_Msk
#define DMA_LIFCR_CTCIF2_Pos   (21U)
#define DMA_LIFCR_CTCIF2_Msk   (0x1UL << DMA_LIFCR_CTCIF2_Pos)
#define DMA_LIFCR_CTCIF2   DMA_LIFCR_CTCIF2_Msk
#define DMA_LIFCR_CHTIF2_Pos   (20U)
#define DMA_LIFCR_CHTIF2_Msk   (0x1UL << DMA_LIFCR_CHTIF2_Pos)
#define DMA_LIFCR_CHTIF2   DMA_LIFCR_CHTIF2_Msk
#define DMA_LIFCR_CTEIF2_Pos   (19U)
#define DMA_LIFCR_CTEIF2_Msk   (0x1UL << DMA_LIFCR_CTEIF2_Pos)
#define DMA_LIFCR_CTEIF2   DMA_LIFCR_CTEIF2_Msk
#define DMA_LIFCR_CDMEIF2_Pos   (18U)
#define DMA_LIFCR_CDMEIF2_Msk   (0x1UL << DMA_LIFCR_CDMEIF2_Pos)
#define DMA_LIFCR_CDMEIF2   DMA_LIFCR_CDMEIF2_Msk
#define DMA_LIFCR_CFEIF2_Pos   (16U)
#define DMA_LIFCR_CFEIF2_Msk   (0x1UL << DMA_LIFCR_CFEIF2_Pos)
#define DMA_LIFCR_CFEIF2   DMA_LIFCR_CFEIF2_Msk
#define DMA_LIFCR_CTCIF1_Pos   (11U)
#define DMA_LIFCR_CTCIF1_Msk   (0x1UL << DMA_LIFCR_CTCIF1_Pos)
#define DMA_LIFCR_CTCIF1   DMA_LIFCR_CTCIF1_Msk
#define DMA_LIFCR_CHTIF1_Pos   (10U)
#define DMA_LIFCR_CHTIF1_Msk   (0x1UL << DMA_LIFCR_CHTIF1_Pos)
#define DMA_LIFCR_CHTIF1   DMA_LIFCR_CHTIF1_Msk
#define DMA_LIFCR_CTEIF1_Pos   (9U)
#define DMA_LIFCR_CTEIF1_Msk   (0x1UL << DMA_LIFCR_CTEIF1_Pos)
#define DMA_LIFCR_CTEIF1   DMA_LIFCR_CTEIF1_Msk
#define DMA_LIFCR_CDMEIF1_Pos   (8U)
#define DMA_LIFCR_CDMEIF1_Msk   (0x1UL << DMA_LIFCR_CDMEIF1_Pos)
#define DMA_LIFCR_CDMEIF1   DMA_LIFCR_CDMEIF1_Msk
#define DMA_LIFCR_CFEIF1_Pos   (6U)
#define DMA_LIFCR_CFEIF1_Msk   (0x1UL << DMA_LIFCR_CFEIF1_Pos)
#define DMA_LIFCR_CFEIF1   DMA_LIFCR_CFEIF1_Msk
#define DMA_LIFCR_CTCIF0_Pos   (5U)
#define DMA_LIFCR_CTCIF0_Msk   (0x1UL << DMA_LIFCR_CTCIF0_Pos)
#define DMA_LIFCR_CTCIF0   DMA_LIFCR_CTCIF0_Msk
#define DMA_LIFCR_CHTIF0_Pos   (4U)
#define DMA_LIFCR_CHTIF0_Msk   (0x1UL << DMA_LIFCR_CHTIF0_Pos)
#define DMA_LIFCR_CHTIF0   DMA_LIFCR_CHTIF0_Msk
#define DMA_LIFCR_CTEIF0_Pos   (3U)
#define DMA_LIFCR_CTEIF0_Msk   (0x1UL << DMA_LIFCR_CTEIF0_Pos)
#define DMA_LIFCR_CTEIF0   DMA_LIFCR_CTEIF0_Msk
#define DMA_LIFCR_CDMEIF0_Pos   (2U)
#define DMA_LIFCR_CDMEIF0_Msk   (0x1UL << DMA_LIFCR_CDMEIF0_Pos)
#define DMA_LIFCR_CDMEIF0   DMA_LIFCR_CDMEIF0_Msk
#define DMA_LIFCR_CFEIF0_Pos   (0U)
#define DMA_LIFCR_CFEIF0_Msk   (0x1UL << DMA_LIFCR_CFEIF0_Pos)
#define DMA_LIFCR_CFEIF0   DMA_LIFCR_CFEIF0_Msk
#define DMA_HIFCR_CTCIF7_Pos   (27U)
#define DMA_HIFCR_CTCIF7_Msk   (0x1UL << DMA_HIFCR_CTCIF7_Pos)
#define DMA_HIFCR_CTCIF7   DMA_HIFCR_CTCIF7_Msk
#define DMA_HIFCR_CHTIF7_Pos   (26U)
#define DMA_HIFCR_CHTIF7_Msk   (0x1UL << DMA_HIFCR_CHTIF7_Pos)
#define DMA_HIFCR_CHTIF7   DMA_HIFCR_CHTIF7_Msk
#define DMA_HIFCR_CTEIF7_Pos   (25U)
#define DMA_HIFCR_CTEIF7_Msk   (0x1UL << DMA_HIFCR_CTEIF7_Pos)
#define DMA_HIFCR_CTEIF7   DMA_HIFCR_CTEIF7_Msk
#define DMA_HIFCR_CDMEIF7_Pos   (24U)
#define DMA_HIFCR_CDMEIF7_Msk   (0x1UL << DMA_HIFCR_CDMEIF7_Pos)
#define DMA_HIFCR_CDMEIF7   DMA_HIFCR_CDMEIF7_Msk
#define DMA_HIFCR_CFEIF7_Pos   (22U)
#define DMA_HIFCR_CFEIF7_Msk   (0x1UL << DMA_HIFCR_CFEIF7_Pos)
#define DMA_HIFCR_CFEIF7   DMA_HIFCR_CFEIF7_Msk
#define DMA_HIFCR_CTCIF6_Pos   (21U)
#define DMA_HIFCR_CTCIF6_Msk   (0x1UL << DMA_HIFCR_CTCIF6_Pos)
#define DMA_HIFCR_CTCIF6   DMA_HIFCR_CTCIF6_Msk
#define DMA_HIFCR_CHTIF6_Pos   (20U)
#define DMA_HIFCR_CHTIF6_Msk   (0x1UL << DMA_HIFCR_CHTIF6_Pos)
#define DMA_HIFCR_CHTIF6   DMA_HIFCR_CHTIF6_Msk
#define DMA_HIFCR_CTEIF6_Pos   (19U)
#define DMA_HIFCR_CTEIF6_Msk   (0x1UL << DMA_HIFCR_CTEIF6_Pos)
#define DMA_HIFCR_CTEIF6   DMA_HIFCR_CTEIF6_Msk
#define DMA_HIFCR_CDMEIF6_Pos   (18U)
#define DMA_HIFCR_CDMEIF6_Msk   (0x1UL << DMA_HIFCR_CDMEIF6_Pos)
#define DMA_HIFCR_CDMEIF6   DMA_HIFCR_CDMEIF6_Msk
#define DMA_HIFCR_CFEIF6_Pos   (16U)
#define DMA_HIFCR_CFEIF6_Msk   (0x1UL << DMA_HIFCR_CFEIF6_Pos)
#define DMA_HIFCR_CFEIF6   DMA_HIFCR_CFEIF6_Msk
#define DMA_HIFCR_CTCIF5_Pos   (11U)
#define DMA_HIFCR_CTCIF5_Msk   (0x1UL << DMA_HIFCR_CTCIF5_Pos)
#define DMA_HIFCR_CTCIF5   DMA_HIFCR_CTCIF5_Msk
#define DMA_HIFCR_CHTIF5_Pos   (10U)
#define DMA_HIFCR_CHTIF5_Msk   (0x1UL << DMA_HIFCR_CHTIF5_Pos)
#define DMA_HIFCR_CHTIF5   DMA_HIFCR_CHTIF5_Msk
#define DMA_HIFCR_CTEIF5_Pos   (9U)
#define DMA_HIFCR_CTEIF5_Msk   (0x1UL << DMA_HIFCR_CTEIF5_Pos)
#define DMA_HIFCR_CTEIF5   DMA_HIFCR_CTEIF5_Msk
#define DMA_HIFCR_CDMEIF5_Pos   (8U)
#define DMA_HIFCR_CDMEIF5_Msk   (0x1UL << DMA_HIFCR_CDMEIF5_Pos)
#define DMA_HIFCR_CDMEIF5   DMA_HIFCR_CDMEIF5_Msk
#define DMA_HIFCR_CFEIF5_Pos   (6U)
#define DMA_HIFCR_CFEIF5_Msk   (0x1UL << DMA_HIFCR_CFEIF5_Pos)
#define DMA_HIFCR_CFEIF5   DMA_HIFCR_CFEIF5_Msk
#define DMA_HIFCR_CTCIF4_Pos   (5U)
#define DMA_HIFCR_CTCIF4_Msk   (0x1UL << DMA_HIFCR_CTCIF4_Pos)
#define DMA_HIFCR_CTCIF4   DMA_HIFCR_CTCIF4_Msk
#define DMA_HIFCR_CHTIF4_Pos   (4U)
#define DMA_HIFCR_CHTIF4_Msk   (0x1UL << DMA_HIFCR_CHTIF4_Pos)
#define DMA_HIFCR_CHTIF4   DMA_HIFCR_CHTIF4_Msk
#define DMA_HIFCR_CTEIF4_Pos   (3U)
#define DMA_HIFCR_CTEIF4_Msk   (0x1UL << DMA_HIFCR_CTEIF4_Pos)
#define DMA_HIFCR_CTEIF4   DMA_HIFCR_CTEIF4_Msk
#define DMA_HIFCR_CDMEIF4_Pos   (2U)
#define DMA_HIFCR_CDMEIF4_Msk   (0x1UL << DMA_HIFCR_CDMEIF4_Pos)
#define DMA_HIFCR_CDMEIF4   DMA_HIFCR_CDMEIF4_Msk
#define DMA_HIFCR_CFEIF4_Pos   (0U)
#define DMA_HIFCR_CFEIF4_Msk   (0x1UL << DMA_HIFCR_CFEIF4_Pos)
#define DMA_HIFCR_CFEIF4   DMA_HIFCR_CFEIF4_Msk
#define DMA_SxPAR_PA_Pos   (0U)
#define DMA_SxPAR_PA_Msk   (0xFFFFFFFFUL << DMA_SxPAR_PA_Pos)
#define DMA_SxPAR_PA   DMA_SxPAR_PA_Msk
#define DMA_SxM0AR_M0A_Pos   (0U)
#define DMA_SxM0AR_M0A_Msk   (0xFFFFFFFFUL << DMA_SxM0AR_M0A_Pos)
#define DMA_SxM0AR_M0A   DMA_SxM0AR_M0A_Msk
#define DMA_SxM1AR_M1A_Pos   (0U)
#define DMA_SxM1AR_M1A_Msk   (0xFFFFFFFFUL << DMA_SxM1AR_M1A_Pos)
#define DMA_SxM1AR_M1A   DMA_SxM1AR_M1A_Msk
#define DMAMUX_CxCR_DMAREQ_ID_Pos   (0U)
#define DMAMUX_CxCR_DMAREQ_ID_Msk   (0xFFUL << DMAMUX_CxCR_DMAREQ_ID_Pos)
#define DMAMUX_CxCR_DMAREQ_ID   DMAMUX_CxCR_DMAREQ_ID_Msk
#define DMAMUX_CxCR_DMAREQ_ID_0   (0x01UL << DMAMUX_CxCR_DMAREQ_ID_Pos)
#define DMAMUX_CxCR_DMAREQ_ID_1   (0x02UL << DMAMUX_CxCR_DMAREQ_ID_Pos)
#define DMAMUX_CxCR_DMAREQ_ID_2   (0x04UL << DMAMUX_CxCR_DMAREQ_ID_Pos)
#define DMAMUX_CxCR_DMAREQ_ID_3   (0x08UL << DMAMUX_CxCR_DMAREQ_ID_Pos)
#define DMAMUX_CxCR_DMAREQ_ID_4   (0x10UL << DMAMUX_CxCR_DMAREQ_ID_Pos)
#define DMAMUX_CxCR_DMAREQ_ID_5   (0x20UL << DMAMUX_CxCR_DMAREQ_ID_Pos)
#define DMAMUX_CxCR_DMAREQ_ID_6   (0x40UL << DMAMUX_CxCR_DMAREQ_ID_Pos)
#define DMAMUX_CxCR_DMAREQ_ID_7   (0x80UL << DMAMUX_CxCR_DMAREQ_ID_Pos)
#define DMAMUX_CxCR_SOIE_Pos   (8U)
#define DMAMUX_CxCR_SOIE_Msk   (0x1UL << DMAMUX_CxCR_SOIE_Pos)
#define DMAMUX_CxCR_SOIE   DMAMUX_CxCR_SOIE_Msk
#define DMAMUX_CxCR_EGE_Pos   (9U)
#define DMAMUX_CxCR_EGE_Msk   (0x1UL << DMAMUX_CxCR_EGE_Pos)
#define DMAMUX_CxCR_EGE   DMAMUX_CxCR_EGE_Msk
#define DMAMUX_CxCR_SE_Pos   (16U)
#define DMAMUX_CxCR_SE_Msk   (0x1UL << DMAMUX_CxCR_SE_Pos)
#define DMAMUX_CxCR_SE   DMAMUX_CxCR_SE_Msk
#define DMAMUX_CxCR_SPOL_Pos   (17U)
#define DMAMUX_CxCR_SPOL_Msk   (0x3UL << DMAMUX_CxCR_SPOL_Pos)
#define DMAMUX_CxCR_SPOL   DMAMUX_CxCR_SPOL_Msk
#define DMAMUX_CxCR_SPOL_0   (0x1UL << DMAMUX_CxCR_SPOL_Pos)
#define DMAMUX_CxCR_SPOL_1   (0x2UL << DMAMUX_CxCR_SPOL_Pos)
#define DMAMUX_CxCR_NBREQ_Pos   (19U)
#define DMAMUX_CxCR_NBREQ_Msk   (0x1FUL << DMAMUX_CxCR_NBREQ_Pos)
#define DMAMUX_CxCR_NBREQ   DMAMUX_CxCR_NBREQ_Msk
#define DMAMUX_CxCR_NBREQ_0   (0x01UL << DMAMUX_CxCR_NBREQ_Pos)
#define DMAMUX_CxCR_NBREQ_1   (0x02UL << DMAMUX_CxCR_NBREQ_Pos)
#define DMAMUX_CxCR_NBREQ_2   (0x04UL << DMAMUX_CxCR_NBREQ_Pos)
#define DMAMUX_CxCR_NBREQ_3   (0x08UL << DMAMUX_CxCR_NBREQ_Pos)
#define DMAMUX_CxCR_NBREQ_4   (0x10UL << DMAMUX_CxCR_NBREQ_Pos)
#define DMAMUX_CxCR_SYNC_ID_Pos   (24U)
#define DMAMUX_CxCR_SYNC_ID_Msk   (0x1FUL << DMAMUX_CxCR_SYNC_ID_Pos)
#define DMAMUX_CxCR_SYNC_ID   DMAMUX_CxCR_SYNC_ID_Msk
#define DMAMUX_CxCR_SYNC_ID_0   (0x01UL << DMAMUX_CxCR_SYNC_ID_Pos)
#define DMAMUX_CxCR_SYNC_ID_1   (0x02UL << DMAMUX_CxCR_SYNC_ID_Pos)
#define DMAMUX_CxCR_SYNC_ID_2   (0x04UL << DMAMUX_CxCR_SYNC_ID_Pos)
#define DMAMUX_CxCR_SYNC_ID_3   (0x08UL << DMAMUX_CxCR_SYNC_ID_Pos)
#define DMAMUX_CxCR_SYNC_ID_4   (0x10UL << DMAMUX_CxCR_SYNC_ID_Pos)
#define DMAMUX_CSR_SOF0_Pos   (0U)
#define DMAMUX_CSR_SOF0_Msk   (0x1UL << DMAMUX_CSR_SOF0_Pos)
#define DMAMUX_CSR_SOF0   DMAMUX_CSR_SOF0_Msk
#define DMAMUX_CSR_SOF1_Pos   (1U)
#define DMAMUX_CSR_SOF1_Msk   (0x1UL << DMAMUX_CSR_SOF1_Pos)
#define DMAMUX_CSR_SOF1   DMAMUX_CSR_SOF1_Msk
#define DMAMUX_CSR_SOF2_Pos   (2U)
#define DMAMUX_CSR_SOF2_Msk   (0x1UL << DMAMUX_CSR_SOF2_Pos)
#define DMAMUX_CSR_SOF2   DMAMUX_CSR_SOF2_Msk
#define DMAMUX_CSR_SOF3_Pos   (3U)
#define DMAMUX_CSR_SOF3_Msk   (0x1UL << DMAMUX_CSR_SOF3_Pos)
#define DMAMUX_CSR_SOF3   DMAMUX_CSR_SOF3_Msk
#define DMAMUX_CSR_SOF4_Pos   (4U)
#define DMAMUX_CSR_SOF4_Msk   (0x1UL << DMAMUX_CSR_SOF4_Pos)
#define DMAMUX_CSR_SOF4   DMAMUX_CSR_SOF4_Msk
#define DMAMUX_CSR_SOF5_Pos   (5U)
#define DMAMUX_CSR_SOF5_Msk   (0x1UL << DMAMUX_CSR_SOF5_Pos)
#define DMAMUX_CSR_SOF5   DMAMUX_CSR_SOF5_Msk
#define DMAMUX_CSR_SOF6_Pos   (6U)
#define DMAMUX_CSR_SOF6_Msk   (0x1UL << DMAMUX_CSR_SOF6_Pos)
#define DMAMUX_CSR_SOF6   DMAMUX_CSR_SOF6_Msk
#define DMAMUX_CSR_SOF7_Pos   (7U)
#define DMAMUX_CSR_SOF7_Msk   (0x1UL << DMAMUX_CSR_SOF7_Pos)
#define DMAMUX_CSR_SOF7   DMAMUX_CSR_SOF7_Msk
#define DMAMUX_CSR_SOF8_Pos   (8U)
#define DMAMUX_CSR_SOF8_Msk   (0x1UL << DMAMUX_CSR_SOF8_Pos)
#define DMAMUX_CSR_SOF8   DMAMUX_CSR_SOF8_Msk
#define DMAMUX_CSR_SOF9_Pos   (9U)
#define DMAMUX_CSR_SOF9_Msk   (0x1UL << DMAMUX_CSR_SOF9_Pos)
#define DMAMUX_CSR_SOF9   DMAMUX_CSR_SOF9_Msk
#define DMAMUX_CSR_SOF10_Pos   (10U)
#define DMAMUX_CSR_SOF10_Msk   (0x1UL << DMAMUX_CSR_SOF10_Pos)
#define DMAMUX_CSR_SOF10   DMAMUX_CSR_SOF10_Msk
#define DMAMUX_CSR_SOF11_Pos   (11U)
#define DMAMUX_CSR_SOF11_Msk   (0x1UL << DMAMUX_CSR_SOF11_Pos)
#define DMAMUX_CSR_SOF11   DMAMUX_CSR_SOF11_Msk
#define DMAMUX_CSR_SOF12_Pos   (12U)
#define DMAMUX_CSR_SOF12_Msk   (0x1UL << DMAMUX_CSR_SOF12_Pos)
#define DMAMUX_CSR_SOF12   DMAMUX_CSR_SOF12_Msk
#define DMAMUX_CSR_SOF13_Pos   (13U)
#define DMAMUX_CSR_SOF13_Msk   (0x1UL << DMAMUX_CSR_SOF13_Pos)
#define DMAMUX_CSR_SOF13   DMAMUX_CSR_SOF13_Msk
#define DMAMUX_CSR_SOF14_Pos   (14U)
#define DMAMUX_CSR_SOF14_Msk   (0x1UL << DMAMUX_CSR_SOF14_Pos)
#define DMAMUX_CSR_SOF14   DMAMUX_CSR_SOF14_Msk
#define DMAMUX_CSR_SOF15_Pos   (15U)
#define DMAMUX_CSR_SOF15_Msk   (0x1UL << DMAMUX_CSR_SOF15_Pos)
#define DMAMUX_CSR_SOF15   DMAMUX_CSR_SOF15_Msk
#define DMAMUX_CFR_CSOF0_Pos   (0U)
#define DMAMUX_CFR_CSOF0_Msk   (0x1UL << DMAMUX_CFR_CSOF0_Pos)
#define DMAMUX_CFR_CSOF0   DMAMUX_CFR_CSOF0_Msk
#define DMAMUX_CFR_CSOF1_Pos   (1U)
#define DMAMUX_CFR_CSOF1_Msk   (0x1UL << DMAMUX_CFR_CSOF1_Pos)
#define DMAMUX_CFR_CSOF1   DMAMUX_CFR_CSOF1_Msk
#define DMAMUX_CFR_CSOF2_Pos   (2U)
#define DMAMUX_CFR_CSOF2_Msk   (0x1UL << DMAMUX_CFR_CSOF2_Pos)
#define DMAMUX_CFR_CSOF2   DMAMUX_CFR_CSOF2_Msk
#define DMAMUX_CFR_CSOF3_Pos   (3U)
#define DMAMUX_CFR_CSOF3_Msk   (0x1UL << DMAMUX_CFR_CSOF3_Pos)
#define DMAMUX_CFR_CSOF3   DMAMUX_CFR_CSOF3_Msk
#define DMAMUX_CFR_CSOF4_Pos   (4U)
#define DMAMUX_CFR_CSOF4_Msk   (0x1UL << DMAMUX_CFR_CSOF4_Pos)
#define DMAMUX_CFR_CSOF4   DMAMUX_CFR_CSOF4_Msk
#define DMAMUX_CFR_CSOF5_Pos   (5U)
#define DMAMUX_CFR_CSOF5_Msk   (0x1UL << DMAMUX_CFR_CSOF5_Pos)
#define DMAMUX_CFR_CSOF5   DMAMUX_CFR_CSOF5_Msk
#define DMAMUX_CFR_CSOF6_Pos   (6U)
#define DMAMUX_CFR_CSOF6_Msk   (0x1UL << DMAMUX_CFR_CSOF6_Pos)
#define DMAMUX_CFR_CSOF6   DMAMUX_CFR_CSOF6_Msk
#define DMAMUX_CFR_CSOF7_Pos   (7U)
#define DMAMUX_CFR_CSOF7_Msk   (0x1UL << DMAMUX_CFR_CSOF7_Pos)
#define DMAMUX_CFR_CSOF7   DMAMUX_CFR_CSOF7_Msk
#define DMAMUX_CFR_CSOF8_Pos   (8U)
#define DMAMUX_CFR_CSOF8_Msk   (0x1UL << DMAMUX_CFR_CSOF8_Pos)
#define DMAMUX_CFR_CSOF8   DMAMUX_CFR_CSOF8_Msk
#define DMAMUX_CFR_CSOF9_Pos   (9U)
#define DMAMUX_CFR_CSOF9_Msk   (0x1UL << DMAMUX_CFR_CSOF9_Pos)
#define DMAMUX_CFR_CSOF9   DMAMUX_CFR_CSOF9_Msk
#define DMAMUX_CFR_CSOF10_Pos   (10U)
#define DMAMUX_CFR_CSOF10_Msk   (0x1UL << DMAMUX_CFR_CSOF10_Pos)
#define DMAMUX_CFR_CSOF10   DMAMUX_CFR_CSOF10_Msk
#define DMAMUX_CFR_CSOF11_Pos   (11U)
#define DMAMUX_CFR_CSOF11_Msk   (0x1UL << DMAMUX_CFR_CSOF11_Pos)
#define DMAMUX_CFR_CSOF11   DMAMUX_CFR_CSOF11_Msk
#define DMAMUX_CFR_CSOF12_Pos   (12U)
#define DMAMUX_CFR_CSOF12_Msk   (0x1UL << DMAMUX_CFR_CSOF12_Pos)
#define DMAMUX_CFR_CSOF12   DMAMUX_CFR_CSOF12_Msk
#define DMAMUX_CFR_CSOF13_Pos   (13U)
#define DMAMUX_CFR_CSOF13_Msk   (0x1UL << DMAMUX_CFR_CSOF13_Pos)
#define DMAMUX_CFR_CSOF13   DMAMUX_CFR_CSOF13_Msk
#define DMAMUX_CFR_CSOF14_Pos   (14U)
#define DMAMUX_CFR_CSOF14_Msk   (0x1UL << DMAMUX_CFR_CSOF14_Pos)
#define DMAMUX_CFR_CSOF14   DMAMUX_CFR_CSOF14_Msk
#define DMAMUX_CFR_CSOF15_Pos   (15U)
#define DMAMUX_CFR_CSOF15_Msk   (0x1UL << DMAMUX_CFR_CSOF15_Pos)
#define DMAMUX_CFR_CSOF15   DMAMUX_CFR_CSOF15_Msk
#define DMAMUX_RGxCR_SIG_ID_Pos   (0U)
#define DMAMUX_RGxCR_SIG_ID_Msk   (0x1FUL << DMAMUX_RGxCR_SIG_ID_Pos)
#define DMAMUX_RGxCR_SIG_ID   DMAMUX_RGxCR_SIG_ID_Msk
#define DMAMUX_RGxCR_SIG_ID_0   (0x01UL << DMAMUX_RGxCR_SIG_ID_Pos)
#define DMAMUX_RGxCR_SIG_ID_1   (0x02UL << DMAMUX_RGxCR_SIG_ID_Pos)
#define DMAMUX_RGxCR_SIG_ID_2   (0x04UL << DMAMUX_RGxCR_SIG_ID_Pos)
#define DMAMUX_RGxCR_SIG_ID_3   (0x08UL << DMAMUX_RGxCR_SIG_ID_Pos)
#define DMAMUX_RGxCR_SIG_ID_4   (0x10UL << DMAMUX_RGxCR_SIG_ID_Pos)
#define DMAMUX_RGxCR_OIE_Pos   (8U)
#define DMAMUX_RGxCR_OIE_Msk   (0x1UL << DMAMUX_RGxCR_OIE_Pos)
#define DMAMUX_RGxCR_OIE   DMAMUX_RGxCR_OIE_Msk
#define DMAMUX_RGxCR_GE_Pos   (16U)
#define DMAMUX_RGxCR_GE_Msk   (0x1UL << DMAMUX_RGxCR_GE_Pos)
#define DMAMUX_RGxCR_GE   DMAMUX_RGxCR_GE_Msk
#define DMAMUX_RGxCR_GPOL_Pos   (17U)
#define DMAMUX_RGxCR_GPOL_Msk   (0x3UL << DMAMUX_RGxCR_GPOL_Pos)
#define DMAMUX_RGxCR_GPOL   DMAMUX_RGxCR_GPOL_Msk
#define DMAMUX_RGxCR_GPOL_0   (0x1UL << DMAMUX_RGxCR_GPOL_Pos)
#define DMAMUX_RGxCR_GPOL_1   (0x2UL << DMAMUX_RGxCR_GPOL_Pos)
#define DMAMUX_RGxCR_GNBREQ_Pos   (19U)
#define DMAMUX_RGxCR_GNBREQ_Msk   (0x1FUL << DMAMUX_RGxCR_GNBREQ_Pos)
#define DMAMUX_RGxCR_GNBREQ   DMAMUX_RGxCR_GNBREQ_Msk
#define DMAMUX_RGxCR_GNBREQ_0   (0x01UL << DMAMUX_RGxCR_GNBREQ_Pos)
#define DMAMUX_RGxCR_GNBREQ_1   (0x02UL << DMAMUX_RGxCR_GNBREQ_Pos)
#define DMAMUX_RGxCR_GNBREQ_2   (0x04UL << DMAMUX_RGxCR_GNBREQ_Pos)
#define DMAMUX_RGxCR_GNBREQ_3   (0x08UL << DMAMUX_RGxCR_GNBREQ_Pos)
#define DMAMUX_RGxCR_GNBREQ_4   (0x10UL << DMAMUX_RGxCR_GNBREQ_Pos)
#define DMAMUX_RGSR_OF0_Pos   (0U)
#define DMAMUX_RGSR_OF0_Msk   (0x1UL << DMAMUX_RGSR_OF0_Pos)
#define DMAMUX_RGSR_OF0   DMAMUX_RGSR_OF0_Msk
#define DMAMUX_RGSR_OF1_Pos   (1U)
#define DMAMUX_RGSR_OF1_Msk   (0x1UL << DMAMUX_RGSR_OF1_Pos)
#define DMAMUX_RGSR_OF1   DMAMUX_RGSR_OF1_Msk
#define DMAMUX_RGSR_OF2_Pos   (2U)
#define DMAMUX_RGSR_OF2_Msk   (0x1UL << DMAMUX_RGSR_OF2_Pos)
#define DMAMUX_RGSR_OF2   DMAMUX_RGSR_OF2_Msk
#define DMAMUX_RGSR_OF3_Pos   (3U)
#define DMAMUX_RGSR_OF3_Msk   (0x1UL << DMAMUX_RGSR_OF3_Pos)
#define DMAMUX_RGSR_OF3   DMAMUX_RGSR_OF3_Msk
#define DMAMUX_RGSR_OF4_Pos   (4U)
#define DMAMUX_RGSR_OF4_Msk   (0x1UL << DMAMUX_RGSR_OF4_Pos)
#define DMAMUX_RGSR_OF4   DMAMUX_RGSR_OF4_Msk
#define DMAMUX_RGSR_OF5_Pos   (5U)
#define DMAMUX_RGSR_OF5_Msk   (0x1UL << DMAMUX_RGSR_OF5_Pos)
#define DMAMUX_RGSR_OF5   DMAMUX_RGSR_OF5_Msk
#define DMAMUX_RGSR_OF6_Pos   (6U)
#define DMAMUX_RGSR_OF6_Msk   (0x1UL << DMAMUX_RGSR_OF6_Pos)
#define DMAMUX_RGSR_OF6   DMAMUX_RGSR_OF6_Msk
#define DMAMUX_RGSR_OF7_Pos   (7U)
#define DMAMUX_RGSR_OF7_Msk   (0x1UL << DMAMUX_RGSR_OF7_Pos)
#define DMAMUX_RGSR_OF7   DMAMUX_RGSR_OF7_Msk
#define DMAMUX_RGCFR_COF0_Pos   (0U)
#define DMAMUX_RGCFR_COF0_Msk   (0x1UL << DMAMUX_RGCFR_COF0_Pos)
#define DMAMUX_RGCFR_COF0   DMAMUX_RGCFR_COF0_Msk
#define DMAMUX_RGCFR_COF1_Pos   (1U)
#define DMAMUX_RGCFR_COF1_Msk   (0x1UL << DMAMUX_RGCFR_COF1_Pos)
#define DMAMUX_RGCFR_COF1   DMAMUX_RGCFR_COF1_Msk
#define DMAMUX_RGCFR_COF2_Pos   (2U)
#define DMAMUX_RGCFR_COF2_Msk   (0x1UL << DMAMUX_RGCFR_COF2_Pos)
#define DMAMUX_RGCFR_COF2   DMAMUX_RGCFR_COF2_Msk
#define DMAMUX_RGCFR_COF3_Pos   (3U)
#define DMAMUX_RGCFR_COF3_Msk   (0x1UL << DMAMUX_RGCFR_COF3_Pos)
#define DMAMUX_RGCFR_COF3   DMAMUX_RGCFR_COF3_Msk
#define DMAMUX_RGCFR_COF4_Pos   (4U)
#define DMAMUX_RGCFR_COF4_Msk   (0x1UL << DMAMUX_RGCFR_COF4_Pos)
#define DMAMUX_RGCFR_COF4   DMAMUX_RGCFR_COF4_Msk
#define DMAMUX_RGCFR_COF5_Pos   (5U)
#define DMAMUX_RGCFR_COF5_Msk   (0x1UL << DMAMUX_RGCFR_COF5_Pos)
#define DMAMUX_RGCFR_COF5   DMAMUX_RGCFR_COF5_Msk
#define DMAMUX_RGCFR_COF6_Pos   (6U)
#define DMAMUX_RGCFR_COF6_Msk   (0x1UL << DMAMUX_RGCFR_COF6_Pos)
#define DMAMUX_RGCFR_COF6   DMAMUX_RGCFR_COF6_Msk
#define DMAMUX_RGCFR_COF7_Pos   (7U)
#define DMAMUX_RGCFR_COF7_Msk   (0x1UL << DMAMUX_RGCFR_COF7_Pos)
#define DMAMUX_RGCFR_COF7   DMAMUX_RGCFR_COF7_Msk
#define DMA2D_CR_START_Pos   (0U)
#define DMA2D_CR_START_Msk   (0x1UL << DMA2D_CR_START_Pos)
#define DMA2D_CR_START   DMA2D_CR_START_Msk
#define DMA2D_CR_SUSP_Pos   (1U)
#define DMA2D_CR_SUSP_Msk   (0x1UL << DMA2D_CR_SUSP_Pos)
#define DMA2D_CR_SUSP   DMA2D_CR_SUSP_Msk
#define DMA2D_CR_ABORT_Pos   (2U)
#define DMA2D_CR_ABORT_Msk   (0x1UL << DMA2D_CR_ABORT_Pos)
#define DMA2D_CR_ABORT   DMA2D_CR_ABORT_Msk
#define DMA2D_CR_LOM_Pos   (6U)
#define DMA2D_CR_LOM_Msk   (0x1UL << DMA2D_CR_LOM_Pos)
#define DMA2D_CR_LOM   DMA2D_CR_LOM_Msk
#define DMA2D_CR_TEIE_Pos   (8U)
#define DMA2D_CR_TEIE_Msk   (0x1UL << DMA2D_CR_TEIE_Pos)
#define DMA2D_CR_TEIE   DMA2D_CR_TEIE_Msk
#define DMA2D_CR_TCIE_Pos   (9U)
#define DMA2D_CR_TCIE_Msk   (0x1UL << DMA2D_CR_TCIE_Pos)
#define DMA2D_CR_TCIE   DMA2D_CR_TCIE_Msk
#define DMA2D_CR_TWIE_Pos   (10U)
#define DMA2D_CR_TWIE_Msk   (0x1UL << DMA2D_CR_TWIE_Pos)
#define DMA2D_CR_TWIE   DMA2D_CR_TWIE_Msk
#define DMA2D_CR_CAEIE_Pos   (11U)
#define DMA2D_CR_CAEIE_Msk   (0x1UL << DMA2D_CR_CAEIE_Pos)
#define DMA2D_CR_CAEIE   DMA2D_CR_CAEIE_Msk
#define DMA2D_CR_CTCIE_Pos   (12U)
#define DMA2D_CR_CTCIE_Msk   (0x1UL << DMA2D_CR_CTCIE_Pos)
#define DMA2D_CR_CTCIE   DMA2D_CR_CTCIE_Msk
#define DMA2D_CR_CEIE_Pos   (13U)
#define DMA2D_CR_CEIE_Msk   (0x1UL << DMA2D_CR_CEIE_Pos)
#define DMA2D_CR_CEIE   DMA2D_CR_CEIE_Msk
#define DMA2D_CR_MODE_Pos   (16U)
#define DMA2D_CR_MODE_Msk   (0x7UL << DMA2D_CR_MODE_Pos)
#define DMA2D_CR_MODE   DMA2D_CR_MODE_Msk
#define DMA2D_CR_MODE_0   (0x1UL << DMA2D_CR_MODE_Pos)
#define DMA2D_CR_MODE_1   (0x2UL << DMA2D_CR_MODE_Pos)
#define DMA2D_CR_MODE_2   (0x4UL << DMA2D_CR_MODE_Pos)
#define DMA2D_ISR_TEIF_Pos   (0U)
#define DMA2D_ISR_TEIF_Msk   (0x1UL << DMA2D_ISR_TEIF_Pos)
#define DMA2D_ISR_TEIF   DMA2D_ISR_TEIF_Msk
#define DMA2D_ISR_TCIF_Pos   (1U)
#define DMA2D_ISR_TCIF_Msk   (0x1UL << DMA2D_ISR_TCIF_Pos)
#define DMA2D_ISR_TCIF   DMA2D_ISR_TCIF_Msk
#define DMA2D_ISR_TWIF_Pos   (2U)
#define DMA2D_ISR_TWIF_Msk   (0x1UL << DMA2D_ISR_TWIF_Pos)
#define DMA2D_ISR_TWIF   DMA2D_ISR_TWIF_Msk
#define DMA2D_ISR_CAEIF_Pos   (3U)
#define DMA2D_ISR_CAEIF_Msk   (0x1UL << DMA2D_ISR_CAEIF_Pos)
#define DMA2D_ISR_CAEIF   DMA2D_ISR_CAEIF_Msk
#define DMA2D_ISR_CTCIF_Pos   (4U)
#define DMA2D_ISR_CTCIF_Msk   (0x1UL << DMA2D_ISR_CTCIF_Pos)
#define DMA2D_ISR_CTCIF   DMA2D_ISR_CTCIF_Msk
#define DMA2D_ISR_CEIF_Pos   (5U)
#define DMA2D_ISR_CEIF_Msk   (0x1UL << DMA2D_ISR_CEIF_Pos)
#define DMA2D_ISR_CEIF   DMA2D_ISR_CEIF_Msk
#define DMA2D_IFCR_CTEIF_Pos   (0U)
#define DMA2D_IFCR_CTEIF_Msk   (0x1UL << DMA2D_IFCR_CTEIF_Pos)
#define DMA2D_IFCR_CTEIF   DMA2D_IFCR_CTEIF_Msk
#define DMA2D_IFCR_CTCIF_Pos   (1U)
#define DMA2D_IFCR_CTCIF_Msk   (0x1UL << DMA2D_IFCR_CTCIF_Pos)
#define DMA2D_IFCR_CTCIF   DMA2D_IFCR_CTCIF_Msk
#define DMA2D_IFCR_CTWIF_Pos   (2U)
#define DMA2D_IFCR_CTWIF_Msk   (0x1UL << DMA2D_IFCR_CTWIF_Pos)
#define DMA2D_IFCR_CTWIF   DMA2D_IFCR_CTWIF_Msk
#define DMA2D_IFCR_CAECIF_Pos   (3U)
#define DMA2D_IFCR_CAECIF_Msk   (0x1UL << DMA2D_IFCR_CAECIF_Pos)
#define DMA2D_IFCR_CAECIF   DMA2D_IFCR_CAECIF_Msk
#define DMA2D_IFCR_CCTCIF_Pos   (4U)
#define DMA2D_IFCR_CCTCIF_Msk   (0x1UL << DMA2D_IFCR_CCTCIF_Pos)
#define DMA2D_IFCR_CCTCIF   DMA2D_IFCR_CCTCIF_Msk
#define DMA2D_IFCR_CCEIF_Pos   (5U)
#define DMA2D_IFCR_CCEIF_Msk   (0x1UL << DMA2D_IFCR_CCEIF_Pos)
#define DMA2D_IFCR_CCEIF   DMA2D_IFCR_CCEIF_Msk
#define DMA2D_FGMAR_MA_Pos   (0U)
#define DMA2D_FGMAR_MA_Msk   (0xFFFFFFFFUL << DMA2D_FGMAR_MA_Pos)
#define DMA2D_FGMAR_MA   DMA2D_FGMAR_MA_Msk
#define DMA2D_FGOR_LO_Pos   (0U)
#define DMA2D_FGOR_LO_Msk   (0xFFFFUL << DMA2D_FGOR_LO_Pos)
#define DMA2D_FGOR_LO   DMA2D_FGOR_LO_Msk
#define DMA2D_BGMAR_MA_Pos   (0U)
#define DMA2D_BGMAR_MA_Msk   (0xFFFFFFFFUL << DMA2D_BGMAR_MA_Pos)
#define DMA2D_BGMAR_MA   DMA2D_BGMAR_MA_Msk
#define DMA2D_BGOR_LO_Pos   (0U)
#define DMA2D_BGOR_LO_Msk   (0xFFFFUL << DMA2D_BGOR_LO_Pos)
#define DMA2D_BGOR_LO   DMA2D_BGOR_LO_Msk
#define DMA2D_FGPFCCR_CM_Pos   (0U)
#define DMA2D_FGPFCCR_CM_Msk   (0xFUL << DMA2D_FGPFCCR_CM_Pos)
#define DMA2D_FGPFCCR_CM   DMA2D_FGPFCCR_CM_Msk
#define DMA2D_FGPFCCR_CM_0   (0x1UL << DMA2D_FGPFCCR_CM_Pos)
#define DMA2D_FGPFCCR_CM_1   (0x2UL << DMA2D_FGPFCCR_CM_Pos)
#define DMA2D_FGPFCCR_CM_2   (0x4UL << DMA2D_FGPFCCR_CM_Pos)
#define DMA2D_FGPFCCR_CM_3   (0x8UL << DMA2D_FGPFCCR_CM_Pos)
#define DMA2D_FGPFCCR_CCM_Pos   (4U)
#define DMA2D_FGPFCCR_CCM_Msk   (0x1UL << DMA2D_FGPFCCR_CCM_Pos)
#define DMA2D_FGPFCCR_CCM   DMA2D_FGPFCCR_CCM_Msk
#define DMA2D_FGPFCCR_START_Pos   (5U)
#define DMA2D_FGPFCCR_START_Msk   (0x1UL << DMA2D_FGPFCCR_START_Pos)
#define DMA2D_FGPFCCR_START   DMA2D_FGPFCCR_START_Msk
#define DMA2D_FGPFCCR_CS_Pos   (8U)
#define DMA2D_FGPFCCR_CS_Msk   (0xFFUL << DMA2D_FGPFCCR_CS_Pos)
#define DMA2D_FGPFCCR_CS   DMA2D_FGPFCCR_CS_Msk
#define DMA2D_FGPFCCR_AM_Pos   (16U)
#define DMA2D_FGPFCCR_AM_Msk   (0x3UL << DMA2D_FGPFCCR_AM_Pos)
#define DMA2D_FGPFCCR_AM   DMA2D_FGPFCCR_AM_Msk
#define DMA2D_FGPFCCR_AM_0   (0x1UL << DMA2D_FGPFCCR_AM_Pos)
#define DMA2D_FGPFCCR_AM_1   (0x2UL << DMA2D_FGPFCCR_AM_Pos)
#define DMA2D_FGPFCCR_CSS_Pos   (18U)
#define DMA2D_FGPFCCR_CSS_Msk   (0x3UL << DMA2D_FGPFCCR_CSS_Pos)
#define DMA2D_FGPFCCR_CSS   DMA2D_FGPFCCR_CSS_Msk /* !< Chroma Sub-Sampling */
#define DMA2D_FGPFCCR_CSS_0   (0x1UL << DMA2D_FGPFCCR_CSS_Pos)
#define DMA2D_FGPFCCR_CSS_1   (0x2UL << DMA2D_FGPFCCR_CSS_Pos)
#define DMA2D_FGPFCCR_AI_Pos   (20U)
#define DMA2D_FGPFCCR_AI_Msk   (0x1UL << DMA2D_FGPFCCR_AI_Pos)
#define DMA2D_FGPFCCR_AI   DMA2D_FGPFCCR_AI_Msk
#define DMA2D_FGPFCCR_RBS_Pos   (21U)
#define DMA2D_FGPFCCR_RBS_Msk   (0x1UL << DMA2D_FGPFCCR_RBS_Pos)
#define DMA2D_FGPFCCR_RBS   DMA2D_FGPFCCR_RBS_Msk
#define DMA2D_FGPFCCR_ALPHA_Pos   (24U)
#define DMA2D_FGPFCCR_ALPHA_Msk   (0xFFUL << DMA2D_FGPFCCR_ALPHA_Pos)
#define DMA2D_FGPFCCR_ALPHA   DMA2D_FGPFCCR_ALPHA_Msk
#define DMA2D_FGCOLR_BLUE_Pos   (0U)
#define DMA2D_FGCOLR_BLUE_Msk   (0xFFUL << DMA2D_FGCOLR_BLUE_Pos)
#define DMA2D_FGCOLR_BLUE   DMA2D_FGCOLR_BLUE_Msk
#define DMA2D_FGCOLR_GREEN_Pos   (8U)
#define DMA2D_FGCOLR_GREEN_Msk   (0xFFUL << DMA2D_FGCOLR_GREEN_Pos)
#define DMA2D_FGCOLR_GREEN   DMA2D_FGCOLR_GREEN_Msk
#define DMA2D_FGCOLR_RED_Pos   (16U)
#define DMA2D_FGCOLR_RED_Msk   (0xFFUL << DMA2D_FGCOLR_RED_Pos)
#define DMA2D_FGCOLR_RED   DMA2D_FGCOLR_RED_Msk
#define DMA2D_BGPFCCR_CM_Pos   (0U)
#define DMA2D_BGPFCCR_CM_Msk   (0xFUL << DMA2D_BGPFCCR_CM_Pos)
#define DMA2D_BGPFCCR_CM   DMA2D_BGPFCCR_CM_Msk
#define DMA2D_BGPFCCR_CM_0   (0x1UL << DMA2D_BGPFCCR_CM_Pos)
#define DMA2D_BGPFCCR_CM_1   (0x2UL << DMA2D_BGPFCCR_CM_Pos)
#define DMA2D_BGPFCCR_CM_2   (0x4UL << DMA2D_BGPFCCR_CM_Pos)
#define DMA2D_BGPFCCR_CM_3   (0x8UL << DMA2D_BGPFCCR_CM_Pos)
#define DMA2D_BGPFCCR_CCM_Pos   (4U)
#define DMA2D_BGPFCCR_CCM_Msk   (0x1UL << DMA2D_BGPFCCR_CCM_Pos)
#define DMA2D_BGPFCCR_CCM   DMA2D_BGPFCCR_CCM_Msk
#define DMA2D_BGPFCCR_START_Pos   (5U)
#define DMA2D_BGPFCCR_START_Msk   (0x1UL << DMA2D_BGPFCCR_START_Pos)
#define DMA2D_BGPFCCR_START   DMA2D_BGPFCCR_START_Msk
#define DMA2D_BGPFCCR_CS_Pos   (8U)
#define DMA2D_BGPFCCR_CS_Msk   (0xFFUL << DMA2D_BGPFCCR_CS_Pos)
#define DMA2D_BGPFCCR_CS   DMA2D_BGPFCCR_CS_Msk
#define DMA2D_BGPFCCR_AM_Pos   (16U)
#define DMA2D_BGPFCCR_AM_Msk   (0x3UL << DMA2D_BGPFCCR_AM_Pos)
#define DMA2D_BGPFCCR_AM   DMA2D_BGPFCCR_AM_Msk
#define DMA2D_BGPFCCR_AM_0   (0x1UL << DMA2D_BGPFCCR_AM_Pos)
#define DMA2D_BGPFCCR_AM_1   (0x2UL << DMA2D_BGPFCCR_AM_Pos)
#define DMA2D_BGPFCCR_AI_Pos   (20U)
#define DMA2D_BGPFCCR_AI_Msk   (0x1UL << DMA2D_BGPFCCR_AI_Pos)
#define DMA2D_BGPFCCR_AI   DMA2D_BGPFCCR_AI_Msk
#define DMA2D_BGPFCCR_RBS_Pos   (21U)
#define DMA2D_BGPFCCR_RBS_Msk   (0x1UL << DMA2D_BGPFCCR_RBS_Pos)
#define DMA2D_BGPFCCR_RBS   DMA2D_BGPFCCR_RBS_Msk
#define DMA2D_BGPFCCR_ALPHA_Pos   (24U)
#define DMA2D_BGPFCCR_ALPHA_Msk   (0xFFUL << DMA2D_BGPFCCR_ALPHA_Pos)
#define DMA2D_BGPFCCR_ALPHA   DMA2D_BGPFCCR_ALPHA_Msk
#define DMA2D_BGCOLR_BLUE_Pos   (0U)
#define DMA2D_BGCOLR_BLUE_Msk   (0xFFUL << DMA2D_BGCOLR_BLUE_Pos)
#define DMA2D_BGCOLR_BLUE   DMA2D_BGCOLR_BLUE_Msk
#define DMA2D_BGCOLR_GREEN_Pos   (8U)
#define DMA2D_BGCOLR_GREEN_Msk   (0xFFUL << DMA2D_BGCOLR_GREEN_Pos)
#define DMA2D_BGCOLR_GREEN   DMA2D_BGCOLR_GREEN_Msk
#define DMA2D_BGCOLR_RED_Pos   (16U)
#define DMA2D_BGCOLR_RED_Msk   (0xFFUL << DMA2D_BGCOLR_RED_Pos)
#define DMA2D_BGCOLR_RED   DMA2D_BGCOLR_RED_Msk
#define DMA2D_FGCMAR_MA_Pos   (0U)
#define DMA2D_FGCMAR_MA_Msk   (0xFFFFFFFFUL << DMA2D_FGCMAR_MA_Pos)
#define DMA2D_FGCMAR_MA   DMA2D_FGCMAR_MA_Msk
#define DMA2D_BGCMAR_MA_Pos   (0U)
#define DMA2D_BGCMAR_MA_Msk   (0xFFFFFFFFUL << DMA2D_BGCMAR_MA_Pos)
#define DMA2D_BGCMAR_MA   DMA2D_BGCMAR_MA_Msk
#define DMA2D_OPFCCR_CM_Pos   (0U)
#define DMA2D_OPFCCR_CM_Msk   (0x7UL << DMA2D_OPFCCR_CM_Pos)
#define DMA2D_OPFCCR_CM   DMA2D_OPFCCR_CM_Msk
#define DMA2D_OPFCCR_CM_0   (0x1UL << DMA2D_OPFCCR_CM_Pos)
#define DMA2D_OPFCCR_CM_1   (0x2UL << DMA2D_OPFCCR_CM_Pos)
#define DMA2D_OPFCCR_CM_2   (0x4UL << DMA2D_OPFCCR_CM_Pos)
#define DMA2D_OPFCCR_SB_Pos   (8U)
#define DMA2D_OPFCCR_SB_Msk   (0x1UL << DMA2D_OPFCCR_SB_Pos)
#define DMA2D_OPFCCR_SB   DMA2D_OPFCCR_SB_Msk
#define DMA2D_OPFCCR_AI_Pos   (20U)
#define DMA2D_OPFCCR_AI_Msk   (0x1UL << DMA2D_OPFCCR_AI_Pos)
#define DMA2D_OPFCCR_AI   DMA2D_OPFCCR_AI_Msk
#define DMA2D_OPFCCR_RBS_Pos   (21U)
#define DMA2D_OPFCCR_RBS_Msk   (0x1UL << DMA2D_OPFCCR_RBS_Pos)
#define DMA2D_OPFCCR_RBS   DMA2D_OPFCCR_RBS_Msk
#define DMA2D_OCOLR_BLUE_1_Pos   (0U)
#define DMA2D_OCOLR_BLUE_1_Msk   (0xFFUL <<DMA2D_OCOLR_BLUE_1_Pos) /*0x000000FFU*/
#define DMA2D_OCOLR_BLUE_1   DMA2D_OCOLR_BLUE_1_Msk
#define DMA2D_OCOLR_GREEN_1_Pos   (8U)
#define DMA2D_OCOLR_GREEN_1_Msk   (0xFFUL<<DMA2D_OCOLR_GREEN_1_Pos) /*0x0000FF00U)*/
#define DMA2D_OCOLR_GREEN_1   DMA2D_OCOLR_GREEN_1_Msk
#define DMA2D_OCOLR_RED_1_Pos   (16U)
#define DMA2D_OCOLR_RED_1_Msk   (0xFFUL << DMA2D_OCOLR_RED_1_Pos) /*0x00FF0000U */
#define DMA2D_OCOLR_RED_1   DMA2D_OCOLR_RED_1_Msk
#define DMA2D_OCOLR_ALPHA_1_Pos   (24U)
#define DMA2D_OCOLR_ALPHA_1_Msk   (0xFFUL << DMA2D_OCOLR_ALPHA_1_Pos) /*0xFF000000U*/
#define DMA2D_OCOLR_ALPHA_1   DMA2D_OCOLR_ALPHA_1_Msk
#define DMA2D_OCOLR_BLUE_2_Pos   (0U)
#define DMA2D_OCOLR_BLUE_2_Msk   (0x1FUL <<DMA2D_OCOLR_BLUE_2_Pos) /*0x0000001FU*/
#define DMA2D_OCOLR_BLUE_2   DMA2D_OCOLR_BLUE_2_Msk
#define DMA2D_OCOLR_GREEN_2_Pos   (5U)
#define DMA2D_OCOLR_GREEN_2_Msk   (0x7EUL << DMA2D_OCOLR_GREEN_2_Pos) /* 0x000007E0U */
#define DMA2D_OCOLR_GREEN_2   DMA2D_OCOLR_GREEN_2_Msk
#define DMA2D_OCOLR_RED_2_Pos   (11U)
#define DMA2D_OCOLR_RED_2_Msk   (0xF8UL<<DMA2D_OCOLR_RED_2_Pos) /*0x0000F800U*/
#define DMA2D_OCOLR_RED_2   DMA2D_OCOLR_RED_2_Msk
#define DMA2D_OCOLR_BLUE_3_Pos   (0U)
#define DMA2D_OCOLR_BLUE_3_Msk   (0x1FUL << DMA2D_OCOLR_BLUE_3_Pos) /*0x0000001FU*/
#define DMA2D_OCOLR_BLUE_3   DMA2D_OCOLR_BLUE_3_Msk
#define DMA2D_OCOLR_GREEN_3_Pos   (5U)
#define DMA2D_OCOLR_GREEN_3_Msk   (0x3EUL << DMA2D_OCOLR_GREEN_3_Pos) /*0x000003E0U*/
#define DMA2D_OCOLR_GREEN_3   DMA2D_OCOLR_GREEN_3_Msk
#define DMA2D_OCOLR_RED_3_Pos   (10U)
#define DMA2D_OCOLR_RED_3_Msk   (0x7CUL << DMA2D_OCOLR_RED_3_Pos) /* 0x00007C00U*/
#define DMA2D_OCOLR_RED_3   DMA2D_OCOLR_RED_3_Msk
#define DMA2D_OCOLR_ALPHA_3_Pos   (15U)
#define DMA2D_OCOLR_ALPHA_3_Msk   (0x1UL << DMA2D_OCOLR_ALPHA_3_Pos) /*0x00008000U*/
#define DMA2D_OCOLR_ALPHA_3   DMA2D_OCOLR_ALPHA_3_Msk
#define DMA2D_OCOLR_BLUE_4_Pos   (0U)
#define DMA2D_OCOLR_BLUE_4_Msk   (0xFUL << DMA2D_OCOLR_BLUE_4_Pos) /*0x0000000FU*/
#define DMA2D_OCOLR_BLUE_4   DMA2D_OCOLR_BLUE_4_Msk
#define DMA2D_OCOLR_GREEN_4_Pos   (4U)
#define DMA2D_OCOLR_GREEN_4_Msk   (0xFUL << DMA2D_OCOLR_GREEN_4_Pos) /*0x000000F0U*/
#define DMA2D_OCOLR_GREEN_4   DMA2D_OCOLR_GREEN_4_Msk
#define DMA2D_OCOLR_RED_4_Pos   (8U)
#define DMA2D_OCOLR_RED_4_Msk   (0xFUL << DMA2D_OCOLR_RED_4_Pos) /*0x00000F00U*/
#define DMA2D_OCOLR_RED_4   DMA2D_OCOLR_RED_4_Msk
#define DMA2D_OCOLR_ALPHA_4_Pos   (12U)
#define DMA2D_OCOLR_ALPHA_4_Msk   (0xFUL << DMA2D_OCOLR_ALPHA_4_Pos) /*0x0000F000U*/
#define DMA2D_OCOLR_ALPHA_4   DMA2D_OCOLR_ALPHA_4_Msk
#define DMA2D_OMAR_MA_Pos   (0U)
#define DMA2D_OMAR_MA_Msk   (0xFFFFFFFFUL << DMA2D_OMAR_MA_Pos)
#define DMA2D_OMAR_MA   DMA2D_OMAR_MA_Msk
#define DMA2D_OOR_LO_Pos   (0U)
#define DMA2D_OOR_LO_Msk   (0xFFFFUL << DMA2D_OOR_LO_Pos)
#define DMA2D_OOR_LO   DMA2D_OOR_LO_Msk
#define DMA2D_NLR_NL_Pos   (0U)
#define DMA2D_NLR_NL_Msk   (0xFFFFUL << DMA2D_NLR_NL_Pos)
#define DMA2D_NLR_NL   DMA2D_NLR_NL_Msk
#define DMA2D_NLR_PL_Pos   (16U)
#define DMA2D_NLR_PL_Msk   (0x3FFFUL << DMA2D_NLR_PL_Pos)
#define DMA2D_NLR_PL   DMA2D_NLR_PL_Msk
#define DMA2D_LWR_LW_Pos   (0U)
#define DMA2D_LWR_LW_Msk   (0xFFFFUL << DMA2D_LWR_LW_Pos)
#define DMA2D_LWR_LW   DMA2D_LWR_LW_Msk
#define DMA2D_AMTCR_EN_Pos   (0U)
#define DMA2D_AMTCR_EN_Msk   (0x1UL << DMA2D_AMTCR_EN_Pos)
#define DMA2D_AMTCR_EN   DMA2D_AMTCR_EN_Msk
#define DMA2D_AMTCR_DT_Pos   (8U)
#define DMA2D_AMTCR_DT_Msk   (0xFFUL << DMA2D_AMTCR_DT_Pos)
#define DMA2D_AMTCR_DT   DMA2D_AMTCR_DT_Msk
#define EXTI_RTSR1_TR_Pos   (0U)
#define EXTI_RTSR1_TR_Msk   (0x3FFFFFUL << EXTI_RTSR1_TR_Pos)
#define EXTI_RTSR1_TR   EXTI_RTSR1_TR_Msk
#define EXTI_RTSR1_TR0_Pos   (0U)
#define EXTI_RTSR1_TR0_Msk   (0x1UL << EXTI_RTSR1_TR0_Pos)
#define EXTI_RTSR1_TR0   EXTI_RTSR1_TR0_Msk
#define EXTI_RTSR1_TR1_Pos   (1U)
#define EXTI_RTSR1_TR1_Msk   (0x1UL << EXTI_RTSR1_TR1_Pos)
#define EXTI_RTSR1_TR1   EXTI_RTSR1_TR1_Msk
#define EXTI_RTSR1_TR2_Pos   (2U)
#define EXTI_RTSR1_TR2_Msk   (0x1UL << EXTI_RTSR1_TR2_Pos)
#define EXTI_RTSR1_TR2   EXTI_RTSR1_TR2_Msk
#define EXTI_RTSR1_TR3_Pos   (3U)
#define EXTI_RTSR1_TR3_Msk   (0x1UL << EXTI_RTSR1_TR3_Pos)
#define EXTI_RTSR1_TR3   EXTI_RTSR1_TR3_Msk
#define EXTI_RTSR1_TR4_Pos   (4U)
#define EXTI_RTSR1_TR4_Msk   (0x1UL << EXTI_RTSR1_TR4_Pos)
#define EXTI_RTSR1_TR4   EXTI_RTSR1_TR4_Msk
#define EXTI_RTSR1_TR5_Pos   (5U)
#define EXTI_RTSR1_TR5_Msk   (0x1UL << EXTI_RTSR1_TR5_Pos)
#define EXTI_RTSR1_TR5   EXTI_RTSR1_TR5_Msk
#define EXTI_RTSR1_TR6_Pos   (6U)
#define EXTI_RTSR1_TR6_Msk   (0x1UL << EXTI_RTSR1_TR6_Pos)
#define EXTI_RTSR1_TR6   EXTI_RTSR1_TR6_Msk
#define EXTI_RTSR1_TR7_Pos   (7U)
#define EXTI_RTSR1_TR7_Msk   (0x1UL << EXTI_RTSR1_TR7_Pos)
#define EXTI_RTSR1_TR7   EXTI_RTSR1_TR7_Msk
#define EXTI_RTSR1_TR8_Pos   (8U)
#define EXTI_RTSR1_TR8_Msk   (0x1UL << EXTI_RTSR1_TR8_Pos)
#define EXTI_RTSR1_TR8   EXTI_RTSR1_TR8_Msk
#define EXTI_RTSR1_TR9_Pos   (9U)
#define EXTI_RTSR1_TR9_Msk   (0x1UL << EXTI_RTSR1_TR9_Pos)
#define EXTI_RTSR1_TR9   EXTI_RTSR1_TR9_Msk
#define EXTI_RTSR1_TR10_Pos   (10U)
#define EXTI_RTSR1_TR10_Msk   (0x1UL << EXTI_RTSR1_TR10_Pos)
#define EXTI_RTSR1_TR10   EXTI_RTSR1_TR10_Msk
#define EXTI_RTSR1_TR11_Pos   (11U)
#define EXTI_RTSR1_TR11_Msk   (0x1UL << EXTI_RTSR1_TR11_Pos)
#define EXTI_RTSR1_TR11   EXTI_RTSR1_TR11_Msk
#define EXTI_RTSR1_TR12_Pos   (12U)
#define EXTI_RTSR1_TR12_Msk   (0x1UL << EXTI_RTSR1_TR12_Pos)
#define EXTI_RTSR1_TR12   EXTI_RTSR1_TR12_Msk
#define EXTI_RTSR1_TR13_Pos   (13U)
#define EXTI_RTSR1_TR13_Msk   (0x1UL << EXTI_RTSR1_TR13_Pos)
#define EXTI_RTSR1_TR13   EXTI_RTSR1_TR13_Msk
#define EXTI_RTSR1_TR14_Pos   (14U)
#define EXTI_RTSR1_TR14_Msk   (0x1UL << EXTI_RTSR1_TR14_Pos)
#define EXTI_RTSR1_TR14   EXTI_RTSR1_TR14_Msk
#define EXTI_RTSR1_TR15_Pos   (15U)
#define EXTI_RTSR1_TR15_Msk   (0x1UL << EXTI_RTSR1_TR15_Pos)
#define EXTI_RTSR1_TR15   EXTI_RTSR1_TR15_Msk
#define EXTI_RTSR1_TR16_Pos   (16U)
#define EXTI_RTSR1_TR16_Msk   (0x1UL << EXTI_RTSR1_TR16_Pos)
#define EXTI_RTSR1_TR16   EXTI_RTSR1_TR16_Msk
#define EXTI_RTSR1_TR17_Pos   (17U)
#define EXTI_RTSR1_TR17_Msk   (0x1UL << EXTI_RTSR1_TR17_Pos)
#define EXTI_RTSR1_TR17   EXTI_RTSR1_TR17_Msk
#define EXTI_RTSR1_TR18_Pos   (18U)
#define EXTI_RTSR1_TR18_Msk   (0x1UL << EXTI_RTSR1_TR18_Pos)
#define EXTI_RTSR1_TR18   EXTI_RTSR1_TR18_Msk
#define EXTI_RTSR1_TR19_Pos   (19U)
#define EXTI_RTSR1_TR19_Msk   (0x1UL << EXTI_RTSR1_TR19_Pos)
#define EXTI_RTSR1_TR19   EXTI_RTSR1_TR19_Msk
#define EXTI_RTSR1_TR20_Pos   (20U)
#define EXTI_RTSR1_TR20_Msk   (0x1UL << EXTI_RTSR1_TR20_Pos)
#define EXTI_RTSR1_TR20   EXTI_RTSR1_TR20_Msk
#define EXTI_RTSR1_TR21_Pos   (21U)
#define EXTI_RTSR1_TR21_Msk   (0x1UL << EXTI_RTSR1_TR21_Pos)
#define EXTI_RTSR1_TR21   EXTI_RTSR1_TR21_Msk
#define EXTI_FTSR1_TR_Pos   (0U)
#define EXTI_FTSR1_TR_Msk   (0x3FFFFFUL << EXTI_FTSR1_TR_Pos)
#define EXTI_FTSR1_TR   EXTI_FTSR1_TR_Msk
#define EXTI_FTSR1_TR0_Pos   (0U)
#define EXTI_FTSR1_TR0_Msk   (0x1UL << EXTI_FTSR1_TR0_Pos)
#define EXTI_FTSR1_TR0   EXTI_FTSR1_TR0_Msk
#define EXTI_FTSR1_TR1_Pos   (1U)
#define EXTI_FTSR1_TR1_Msk   (0x1UL << EXTI_FTSR1_TR1_Pos)
#define EXTI_FTSR1_TR1   EXTI_FTSR1_TR1_Msk
#define EXTI_FTSR1_TR2_Pos   (2U)
#define EXTI_FTSR1_TR2_Msk   (0x1UL << EXTI_FTSR1_TR2_Pos)
#define EXTI_FTSR1_TR2   EXTI_FTSR1_TR2_Msk
#define EXTI_FTSR1_TR3_Pos   (3U)
#define EXTI_FTSR1_TR3_Msk   (0x1UL << EXTI_FTSR1_TR3_Pos)
#define EXTI_FTSR1_TR3   EXTI_FTSR1_TR3_Msk
#define EXTI_FTSR1_TR4_Pos   (4U)
#define EXTI_FTSR1_TR4_Msk   (0x1UL << EXTI_FTSR1_TR4_Pos)
#define EXTI_FTSR1_TR4   EXTI_FTSR1_TR4_Msk
#define EXTI_FTSR1_TR5_Pos   (5U)
#define EXTI_FTSR1_TR5_Msk   (0x1UL << EXTI_FTSR1_TR5_Pos)
#define EXTI_FTSR1_TR5   EXTI_FTSR1_TR5_Msk
#define EXTI_FTSR1_TR6_Pos   (6U)
#define EXTI_FTSR1_TR6_Msk   (0x1UL << EXTI_FTSR1_TR6_Pos)
#define EXTI_FTSR1_TR6   EXTI_FTSR1_TR6_Msk
#define EXTI_FTSR1_TR7_Pos   (7U)
#define EXTI_FTSR1_TR7_Msk   (0x1UL << EXTI_FTSR1_TR7_Pos)
#define EXTI_FTSR1_TR7   EXTI_FTSR1_TR7_Msk
#define EXTI_FTSR1_TR8_Pos   (8U)
#define EXTI_FTSR1_TR8_Msk   (0x1UL << EXTI_FTSR1_TR8_Pos)
#define EXTI_FTSR1_TR8   EXTI_FTSR1_TR8_Msk
#define EXTI_FTSR1_TR9_Pos   (9U)
#define EXTI_FTSR1_TR9_Msk   (0x1UL << EXTI_FTSR1_TR9_Pos)
#define EXTI_FTSR1_TR9   EXTI_FTSR1_TR9_Msk
#define EXTI_FTSR1_TR10_Pos   (10U)
#define EXTI_FTSR1_TR10_Msk   (0x1UL << EXTI_FTSR1_TR10_Pos)
#define EXTI_FTSR1_TR10   EXTI_FTSR1_TR10_Msk
#define EXTI_FTSR1_TR11_Pos   (11U)
#define EXTI_FTSR1_TR11_Msk   (0x1UL << EXTI_FTSR1_TR11_Pos)
#define EXTI_FTSR1_TR11   EXTI_FTSR1_TR11_Msk
#define EXTI_FTSR1_TR12_Pos   (12U)
#define EXTI_FTSR1_TR12_Msk   (0x1UL << EXTI_FTSR1_TR12_Pos)
#define EXTI_FTSR1_TR12   EXTI_FTSR1_TR12_Msk
#define EXTI_FTSR1_TR13_Pos   (13U)
#define EXTI_FTSR1_TR13_Msk   (0x1UL << EXTI_FTSR1_TR13_Pos)
#define EXTI_FTSR1_TR13   EXTI_FTSR1_TR13_Msk
#define EXTI_FTSR1_TR14_Pos   (14U)
#define EXTI_FTSR1_TR14_Msk   (0x1UL << EXTI_FTSR1_TR14_Pos)
#define EXTI_FTSR1_TR14   EXTI_FTSR1_TR14_Msk
#define EXTI_FTSR1_TR15_Pos   (15U)
#define EXTI_FTSR1_TR15_Msk   (0x1UL << EXTI_FTSR1_TR15_Pos)
#define EXTI_FTSR1_TR15   EXTI_FTSR1_TR15_Msk
#define EXTI_FTSR1_TR16_Pos   (16U)
#define EXTI_FTSR1_TR16_Msk   (0x1UL << EXTI_FTSR1_TR16_Pos)
#define EXTI_FTSR1_TR16   EXTI_FTSR1_TR16_Msk
#define EXTI_FTSR1_TR17_Pos   (17U)
#define EXTI_FTSR1_TR17_Msk   (0x1UL << EXTI_FTSR1_TR17_Pos)
#define EXTI_FTSR1_TR17   EXTI_FTSR1_TR17_Msk
#define EXTI_FTSR1_TR18_Pos   (18U)
#define EXTI_FTSR1_TR18_Msk   (0x1UL << EXTI_FTSR1_TR18_Pos)
#define EXTI_FTSR1_TR18   EXTI_FTSR1_TR18_Msk
#define EXTI_FTSR1_TR19_Pos   (19U)
#define EXTI_FTSR1_TR19_Msk   (0x1UL << EXTI_FTSR1_TR19_Pos)
#define EXTI_FTSR1_TR19   EXTI_FTSR1_TR19_Msk
#define EXTI_FTSR1_TR20_Pos   (20U)
#define EXTI_FTSR1_TR20_Msk   (0x1UL << EXTI_FTSR1_TR20_Pos)
#define EXTI_FTSR1_TR20   EXTI_FTSR1_TR20_Msk
#define EXTI_FTSR1_TR21_Pos   (21U)
#define EXTI_FTSR1_TR21_Msk   (0x1UL << EXTI_FTSR1_TR21_Pos)
#define EXTI_FTSR1_TR21   EXTI_FTSR1_TR21_Msk
#define EXTI_SWIER1_SWIER0_Pos   (0U)
#define EXTI_SWIER1_SWIER0_Msk   (0x1UL << EXTI_SWIER1_SWIER0_Pos)
#define EXTI_SWIER1_SWIER0   EXTI_SWIER1_SWIER0_Msk
#define EXTI_SWIER1_SWIER1_Pos   (1U)
#define EXTI_SWIER1_SWIER1_Msk   (0x1UL << EXTI_SWIER1_SWIER1_Pos)
#define EXTI_SWIER1_SWIER1   EXTI_SWIER1_SWIER1_Msk
#define EXTI_SWIER1_SWIER2_Pos   (2U)
#define EXTI_SWIER1_SWIER2_Msk   (0x1UL << EXTI_SWIER1_SWIER2_Pos)
#define EXTI_SWIER1_SWIER2   EXTI_SWIER1_SWIER2_Msk
#define EXTI_SWIER1_SWIER3_Pos   (3U)
#define EXTI_SWIER1_SWIER3_Msk   (0x1UL << EXTI_SWIER1_SWIER3_Pos)
#define EXTI_SWIER1_SWIER3   EXTI_SWIER1_SWIER3_Msk
#define EXTI_SWIER1_SWIER4_Pos   (4U)
#define EXTI_SWIER1_SWIER4_Msk   (0x1UL << EXTI_SWIER1_SWIER4_Pos)
#define EXTI_SWIER1_SWIER4   EXTI_SWIER1_SWIER4_Msk
#define EXTI_SWIER1_SWIER5_Pos   (5U)
#define EXTI_SWIER1_SWIER5_Msk   (0x1UL << EXTI_SWIER1_SWIER5_Pos)
#define EXTI_SWIER1_SWIER5   EXTI_SWIER1_SWIER5_Msk
#define EXTI_SWIER1_SWIER6_Pos   (6U)
#define EXTI_SWIER1_SWIER6_Msk   (0x1UL << EXTI_SWIER1_SWIER6_Pos)
#define EXTI_SWIER1_SWIER6   EXTI_SWIER1_SWIER6_Msk
#define EXTI_SWIER1_SWIER7_Pos   (7U)
#define EXTI_SWIER1_SWIER7_Msk   (0x1UL << EXTI_SWIER1_SWIER7_Pos)
#define EXTI_SWIER1_SWIER7   EXTI_SWIER1_SWIER7_Msk
#define EXTI_SWIER1_SWIER8_Pos   (8U)
#define EXTI_SWIER1_SWIER8_Msk   (0x1UL << EXTI_SWIER1_SWIER8_Pos)
#define EXTI_SWIER1_SWIER8   EXTI_SWIER1_SWIER8_Msk
#define EXTI_SWIER1_SWIER9_Pos   (9U)
#define EXTI_SWIER1_SWIER9_Msk   (0x1UL << EXTI_SWIER1_SWIER9_Pos)
#define EXTI_SWIER1_SWIER9   EXTI_SWIER1_SWIER9_Msk
#define EXTI_SWIER1_SWIER10_Pos   (10U)
#define EXTI_SWIER1_SWIER10_Msk   (0x1UL << EXTI_SWIER1_SWIER10_Pos)
#define EXTI_SWIER1_SWIER10   EXTI_SWIER1_SWIER10_Msk
#define EXTI_SWIER1_SWIER11_Pos   (11U)
#define EXTI_SWIER1_SWIER11_Msk   (0x1UL << EXTI_SWIER1_SWIER11_Pos)
#define EXTI_SWIER1_SWIER11   EXTI_SWIER1_SWIER11_Msk
#define EXTI_SWIER1_SWIER12_Pos   (12U)
#define EXTI_SWIER1_SWIER12_Msk   (0x1UL << EXTI_SWIER1_SWIER12_Pos)
#define EXTI_SWIER1_SWIER12   EXTI_SWIER1_SWIER12_Msk
#define EXTI_SWIER1_SWIER13_Pos   (13U)
#define EXTI_SWIER1_SWIER13_Msk   (0x1UL << EXTI_SWIER1_SWIER13_Pos)
#define EXTI_SWIER1_SWIER13   EXTI_SWIER1_SWIER13_Msk
#define EXTI_SWIER1_SWIER14_Pos   (14U)
#define EXTI_SWIER1_SWIER14_Msk   (0x1UL << EXTI_SWIER1_SWIER14_Pos)
#define EXTI_SWIER1_SWIER14   EXTI_SWIER1_SWIER14_Msk
#define EXTI_SWIER1_SWIER15_Pos   (15U)
#define EXTI_SWIER1_SWIER15_Msk   (0x1UL << EXTI_SWIER1_SWIER15_Pos)
#define EXTI_SWIER1_SWIER15   EXTI_SWIER1_SWIER15_Msk
#define EXTI_SWIER1_SWIER16_Pos   (16U)
#define EXTI_SWIER1_SWIER16_Msk   (0x1UL << EXTI_SWIER1_SWIER16_Pos)
#define EXTI_SWIER1_SWIER16   EXTI_SWIER1_SWIER16_Msk
#define EXTI_SWIER1_SWIER17_Pos   (17U)
#define EXTI_SWIER1_SWIER17_Msk   (0x1UL << EXTI_SWIER1_SWIER17_Pos)
#define EXTI_SWIER1_SWIER17   EXTI_SWIER1_SWIER17_Msk
#define EXTI_SWIER1_SWIER18_Pos   (18U)
#define EXTI_SWIER1_SWIER18_Msk   (0x1UL << EXTI_SWIER1_SWIER18_Pos)
#define EXTI_SWIER1_SWIER18   EXTI_SWIER1_SWIER18_Msk
#define EXTI_SWIER1_SWIER19_Pos   (19U)
#define EXTI_SWIER1_SWIER19_Msk   (0x1UL << EXTI_SWIER1_SWIER19_Pos)
#define EXTI_SWIER1_SWIER19   EXTI_SWIER1_SWIER19_Msk
#define EXTI_SWIER1_SWIER20_Pos   (20U)
#define EXTI_SWIER1_SWIER20_Msk   (0x1UL << EXTI_SWIER1_SWIER20_Pos)
#define EXTI_SWIER1_SWIER20   EXTI_SWIER1_SWIER20_Msk
#define EXTI_SWIER1_SWIER21_Pos   (21U)
#define EXTI_SWIER1_SWIER21_Msk   (0x1UL << EXTI_SWIER1_SWIER21_Pos)
#define EXTI_SWIER1_SWIER21   EXTI_SWIER1_SWIER21_Msk
#define EXTI_D3PMR1_MR0_Pos   (0U)
#define EXTI_D3PMR1_MR0_Msk   (0x1UL << EXTI_D3PMR1_MR0_Pos)
#define EXTI_D3PMR1_MR0   EXTI_D3PMR1_MR0_Msk
#define EXTI_D3PMR1_MR1_Pos   (1U)
#define EXTI_D3PMR1_MR1_Msk   (0x1UL << EXTI_D3PMR1_MR1_Pos)
#define EXTI_D3PMR1_MR1   EXTI_D3PMR1_MR1_Msk
#define EXTI_D3PMR1_MR2_Pos   (2U)
#define EXTI_D3PMR1_MR2_Msk   (0x1UL << EXTI_D3PMR1_MR2_Pos)
#define EXTI_D3PMR1_MR2   EXTI_D3PMR1_MR2_Msk
#define EXTI_D3PMR1_MR3_Pos   (3U)
#define EXTI_D3PMR1_MR3_Msk   (0x1UL << EXTI_D3PMR1_MR3_Pos)
#define EXTI_D3PMR1_MR3   EXTI_D3PMR1_MR3_Msk
#define EXTI_D3PMR1_MR4_Pos   (4U)
#define EXTI_D3PMR1_MR4_Msk   (0x1UL << EXTI_D3PMR1_MR4_Pos)
#define EXTI_D3PMR1_MR4   EXTI_D3PMR1_MR4_Msk
#define EXTI_D3PMR1_MR5_Pos   (5U)
#define EXTI_D3PMR1_MR5_Msk   (0x1UL << EXTI_D3PMR1_MR5_Pos)
#define EXTI_D3PMR1_MR5   EXTI_D3PMR1_MR5_Msk
#define EXTI_D3PMR1_MR6_Pos   (6U)
#define EXTI_D3PMR1_MR6_Msk   (0x1UL << EXTI_D3PMR1_MR6_Pos)
#define EXTI_D3PMR1_MR6   EXTI_D3PMR1_MR6_Msk
#define EXTI_D3PMR1_MR7_Pos   (7U)
#define EXTI_D3PMR1_MR7_Msk   (0x1UL << EXTI_D3PMR1_MR7_Pos)
#define EXTI_D3PMR1_MR7   EXTI_D3PMR1_MR7_Msk
#define EXTI_D3PMR1_MR8_Pos   (8U)
#define EXTI_D3PMR1_MR8_Msk   (0x1UL << EXTI_D3PMR1_MR8_Pos)
#define EXTI_D3PMR1_MR8   EXTI_D3PMR1_MR8_Msk
#define EXTI_D3PMR1_MR9_Pos   (9U)
#define EXTI_D3PMR1_MR9_Msk   (0x1UL << EXTI_D3PMR1_MR9_Pos)
#define EXTI_D3PMR1_MR9   EXTI_D3PMR1_MR9_Msk
#define EXTI_D3PMR1_MR10_Pos   (10U)
#define EXTI_D3PMR1_MR10_Msk   (0x1UL << EXTI_D3PMR1_MR10_Pos)
#define EXTI_D3PMR1_MR10   EXTI_D3PMR1_MR10_Msk
#define EXTI_D3PMR1_MR11_Pos   (11U)
#define EXTI_D3PMR1_MR11_Msk   (0x1UL << EXTI_D3PMR1_MR11_Pos)
#define EXTI_D3PMR1_MR11   EXTI_D3PMR1_MR11_Msk
#define EXTI_D3PMR1_MR12_Pos   (12U)
#define EXTI_D3PMR1_MR12_Msk   (0x1UL << EXTI_D3PMR1_MR12_Pos)
#define EXTI_D3PMR1_MR12   EXTI_D3PMR1_MR12_Msk
#define EXTI_D3PMR1_MR13_Pos   (13U)
#define EXTI_D3PMR1_MR13_Msk   (0x1UL << EXTI_D3PMR1_MR13_Pos)
#define EXTI_D3PMR1_MR13   EXTI_D3PMR1_MR13_Msk
#define EXTI_D3PMR1_MR14_Pos   (14U)
#define EXTI_D3PMR1_MR14_Msk   (0x1UL << EXTI_D3PMR1_MR14_Pos)
#define EXTI_D3PMR1_MR14   EXTI_D3PMR1_MR14_Msk
#define EXTI_D3PMR1_MR15_Pos   (15U)
#define EXTI_D3PMR1_MR15_Msk   (0x1UL << EXTI_D3PMR1_MR15_Pos)
#define EXTI_D3PMR1_MR15   EXTI_D3PMR1_MR15_Msk
#define EXTI_D3PMR1_MR19_Pos   (19U)
#define EXTI_D3PMR1_MR19_Msk   (0x1UL << EXTI_D3PMR1_MR19_Pos)
#define EXTI_D3PMR1_MR19   EXTI_D3PMR1_MR19_Msk
#define EXTI_D3PMR1_MR20_Pos   (20U)
#define EXTI_D3PMR1_MR20_Msk   (0x1UL << EXTI_D3PMR1_MR20_Pos)
#define EXTI_D3PMR1_MR20   EXTI_D3PMR1_MR20_Msk
#define EXTI_D3PMR1_MR21_Pos   (21U)
#define EXTI_D3PMR1_MR21_Msk   (0x1UL << EXTI_D3PMR1_MR21_Pos)
#define EXTI_D3PMR1_MR21   EXTI_D3PMR1_MR21_Msk
#define EXTI_D3PMR1_MR25_Pos   (24U)
#define EXTI_D3PMR1_MR25_Msk   (0x1UL << EXTI_D3PMR1_MR25_Pos)
#define EXTI_D3PMR1_MR25   EXTI_D3PMR1_MR25_Msk
#define EXTI_D3PCR1L_PCS0_Pos   (0U)
#define EXTI_D3PCR1L_PCS0_Msk   (0x3UL << EXTI_D3PCR1L_PCS0_Pos)
#define EXTI_D3PCR1L_PCS0   EXTI_D3PCR1L_PCS0_Msk
#define EXTI_D3PCR1L_PCS1_Pos   (2U)
#define EXTI_D3PCR1L_PCS1_Msk   (0x3UL << EXTI_D3PCR1L_PCS1_Pos)
#define EXTI_D3PCR1L_PCS1   EXTI_D3PCR1L_PCS1_Msk
#define EXTI_D3PCR1L_PCS2_Pos   (4U)
#define EXTI_D3PCR1L_PCS2_Msk   (0x3UL << EXTI_D3PCR1L_PCS2_Pos)
#define EXTI_D3PCR1L_PCS2   EXTI_D3PCR1L_PCS2_Msk
#define EXTI_D3PCR1L_PCS3_Pos   (6U)
#define EXTI_D3PCR1L_PCS3_Msk   (0x3UL << EXTI_D3PCR1L_PCS3_Pos)
#define EXTI_D3PCR1L_PCS3   EXTI_D3PCR1L_PCS3_Msk
#define EXTI_D3PCR1L_PCS4_Pos   (8U)
#define EXTI_D3PCR1L_PCS4_Msk   (0x3UL << EXTI_D3PCR1L_PCS4_Pos)
#define EXTI_D3PCR1L_PCS4   EXTI_D3PCR1L_PCS4_Msk
#define EXTI_D3PCR1L_PCS5_Pos   (10U)
#define EXTI_D3PCR1L_PCS5_Msk   (0x3UL << EXTI_D3PCR1L_PCS5_Pos)
#define EXTI_D3PCR1L_PCS5   EXTI_D3PCR1L_PCS5_Msk
#define EXTI_D3PCR1L_PCS6_Pos   (12U)
#define EXTI_D3PCR1L_PCS6_Msk   (0x3UL << EXTI_D3PCR1L_PCS6_Pos)
#define EXTI_D3PCR1L_PCS6   EXTI_D3PCR1L_PCS6_Msk
#define EXTI_D3PCR1L_PCS7_Pos   (14U)
#define EXTI_D3PCR1L_PCS7_Msk   (0x3UL << EXTI_D3PCR1L_PCS7_Pos)
#define EXTI_D3PCR1L_PCS7   EXTI_D3PCR1L_PCS7_Msk
#define EXTI_D3PCR1L_PCS8_Pos   (16U)
#define EXTI_D3PCR1L_PCS8_Msk   (0x3UL << EXTI_D3PCR1L_PCS8_Pos)
#define EXTI_D3PCR1L_PCS8   EXTI_D3PCR1L_PCS8_Msk
#define EXTI_D3PCR1L_PCS9_Pos   (18U)
#define EXTI_D3PCR1L_PCS9_Msk   (0x3UL << EXTI_D3PCR1L_PCS9_Pos)
#define EXTI_D3PCR1L_PCS9   EXTI_D3PCR1L_PCS9_Msk
#define EXTI_D3PCR1L_PCS10_Pos   (20U)
#define EXTI_D3PCR1L_PCS10_Msk   (0x3UL << EXTI_D3PCR1L_PCS10_Pos)
#define EXTI_D3PCR1L_PCS10   EXTI_D3PCR1L_PCS10_Msk
#define EXTI_D3PCR1L_PCS11_Pos   (22U)
#define EXTI_D3PCR1L_PCS11_Msk   (0x3UL << EXTI_D3PCR1L_PCS11_Pos)
#define EXTI_D3PCR1L_PCS11   EXTI_D3PCR1L_PCS11_Msk
#define EXTI_D3PCR1L_PCS12_Pos   (24U)
#define EXTI_D3PCR1L_PCS12_Msk   (0x3UL << EXTI_D3PCR1L_PCS12_Pos)
#define EXTI_D3PCR1L_PCS12   EXTI_D3PCR1L_PCS12_Msk
#define EXTI_D3PCR1L_PCS13_Pos   (26U)
#define EXTI_D3PCR1L_PCS13_Msk   (0x3UL << EXTI_D3PCR1L_PCS13_Pos)
#define EXTI_D3PCR1L_PCS13   EXTI_D3PCR1L_PCS13_Msk
#define EXTI_D3PCR1L_PCS14_Pos   (28U)
#define EXTI_D3PCR1L_PCS14_Msk   (0x3UL << EXTI_D3PCR1L_PCS14_Pos)
#define EXTI_D3PCR1L_PCS14   EXTI_D3PCR1L_PCS14_Msk
#define EXTI_D3PCR1L_PCS15_Pos   (30U)
#define EXTI_D3PCR1L_PCS15_Msk   (0x3UL << EXTI_D3PCR1L_PCS15_Pos)
#define EXTI_D3PCR1L_PCS15   EXTI_D3PCR1L_PCS15_Msk
#define EXTI_D3PCR1H_PCS19_Pos   (6U)
#define EXTI_D3PCR1H_PCS19_Msk   (0x3UL << EXTI_D3PCR1H_PCS19_Pos)
#define EXTI_D3PCR1H_PCS19   EXTI_D3PCR1H_PCS19_Msk
#define EXTI_D3PCR1H_PCS20_Pos   (8U)
#define EXTI_D3PCR1H_PCS20_Msk   (0x3UL << EXTI_D3PCR1H_PCS20_Pos)
#define EXTI_D3PCR1H_PCS20   EXTI_D3PCR1H_PCS20_Msk
#define EXTI_D3PCR1H_PCS21_Pos   (10U)
#define EXTI_D3PCR1H_PCS21_Msk   (0x3UL << EXTI_D3PCR1H_PCS21_Pos)
#define EXTI_D3PCR1H_PCS21   EXTI_D3PCR1H_PCS21_Msk
#define EXTI_D3PCR1H_PCS25_Pos   (18U)
#define EXTI_D3PCR1H_PCS25_Msk   (0x3UL << EXTI_D3PCR1H_PCS25_Pos)
#define EXTI_D3PCR1H_PCS25   EXTI_D3PCR1H_PCS25_Msk
#define EXTI_RTSR2_TR_Pos   (17U)
#define EXTI_RTSR2_TR_Msk   (0x5UL << EXTI_RTSR2_TR_Pos)
#define EXTI_RTSR2_TR   EXTI_RTSR2_TR_Msk
#define EXTI_RTSR2_TR49_Pos   (17U)
#define EXTI_RTSR2_TR49_Msk   (0x1UL << EXTI_RTSR2_TR49_Pos)
#define EXTI_RTSR2_TR49   EXTI_RTSR2_TR49_Msk
#define EXTI_RTSR2_TR51_Pos   (19U)
#define EXTI_RTSR2_TR51_Msk   (0x1UL << EXTI_RTSR2_TR51_Pos)
#define EXTI_RTSR2_TR51   EXTI_RTSR2_TR51_Msk
#define EXTI_FTSR2_TR_Pos   (17U)
#define EXTI_FTSR2_TR_Msk   (0x5UL << EXTI_FTSR2_TR_Pos)
#define EXTI_FTSR2_TR   EXTI_FTSR2_TR_Msk
#define EXTI_FTSR2_TR49_Pos   (17U)
#define EXTI_FTSR2_TR49_Msk   (0x1UL << EXTI_FTSR2_TR49_Pos)
#define EXTI_FTSR2_TR49   EXTI_FTSR2_TR49_Msk
#define EXTI_FTSR2_TR51_Pos   (19U)
#define EXTI_FTSR2_TR51_Msk   (0x1UL << EXTI_FTSR2_TR51_Pos)
#define EXTI_FTSR2_TR51   EXTI_FTSR2_TR51_Msk
#define EXTI_SWIER2_SWIER49_Pos   (17U)
#define EXTI_SWIER2_SWIER49_Msk   (0x1UL << EXTI_SWIER2_SWIER49_Pos)
#define EXTI_SWIER2_SWIER49   EXTI_SWIER2_SWIER49_Msk
#define EXTI_SWIER2_SWIER51_Pos   (19U)
#define EXTI_SWIER2_SWIER51_Msk   (0x1UL << EXTI_SWIER2_SWIER51_Pos)
#define EXTI_SWIER2_SWIER51   EXTI_SWIER2_SWIER51_Msk
#define EXTI_D3PMR2_MR34_Pos   (2U)
#define EXTI_D3PMR2_MR34_Msk   (0x1UL << EXTI_D3PMR2_MR34_Pos)
#define EXTI_D3PMR2_MR34   EXTI_D3PMR2_MR34_Msk
#define EXTI_D3PMR2_MR35_Pos   (3U)
#define EXTI_D3PMR2_MR35_Msk   (0x1UL << EXTI_D3PMR2_MR35_Pos)
#define EXTI_D3PMR2_MR35   EXTI_D3PMR2_MR35_Msk
#define EXTI_D3PMR2_MR41_Pos   (9U)
#define EXTI_D3PMR2_MR41_Msk   (0x1UL << EXTI_D3PMR2_MR41_Pos)
#define EXTI_D3PMR2_MR41   EXTI_D3PMR2_MR41_Msk
#define EXTI_D3PMR2_MR48_Pos   (16U)
#define EXTI_D3PMR2_MR48_Msk   (0x1UL << EXTI_D3PMR2_MR48_Pos)
#define EXTI_D3PMR2_MR48   EXTI_D3PMR2_MR48_Msk
#define EXTI_D3PMR2_MR49_Pos   (17U)
#define EXTI_D3PMR2_MR49_Msk   (0x1UL << EXTI_D3PMR2_MR49_Pos)
#define EXTI_D3PMR2_MR49   EXTI_D3PMR2_MR49_Msk
#define EXTI_D3PMR2_MR50_Pos   (18U)
#define EXTI_D3PMR2_MR50_Msk   (0x1UL << EXTI_D3PMR2_MR50_Pos)
#define EXTI_D3PMR2_MR50   EXTI_D3PMR2_MR50_Msk
#define EXTI_D3PMR2_MR51_Pos   (19U)
#define EXTI_D3PMR2_MR51_Msk   (0x1UL << EXTI_D3PMR2_MR51_Pos)
#define EXTI_D3PMR2_MR51   EXTI_D3PMR2_MR51_Msk
#define EXTI_D3PCR2L_PCS34_Pos   (4U)
#define EXTI_D3PCR2L_PCS34_Msk   (0x3UL << EXTI_D3PCR2L_PCS34_Pos)
#define EXTI_D3PCR2L_PCS34   EXTI_D3PCR2L_PCS34_Msk
#define EXTI_D3PCR2L_PCS35_Pos   (6U)
#define EXTI_D3PCR2L_PCS35_Msk   (0x3UL << EXTI_D3PCR2L_PCS35_Pos)
#define EXTI_D3PCR2L_PCS35   EXTI_D3PCR2L_PCS35_Msk
#define EXTI_D3PCR2L_PCS41_Pos   (18U)
#define EXTI_D3PCR2L_PCS41_Msk   (0x3UL << EXTI_D3PCR2L_PCS41_Pos)
#define EXTI_D3PCR2L_PCS41   EXTI_D3PCR2L_PCS41_Msk
#define EXTI_D3PCR2H_PCS48_Pos   (0U)
#define EXTI_D3PCR2H_PCS48_Msk   (0x3UL << EXTI_D3PCR2H_PCS48_Pos)
#define EXTI_D3PCR2H_PCS48   EXTI_D3PCR2H_PCS48_Msk
#define EXTI_D3PCR2H_PCS49_Pos   (2U)
#define EXTI_D3PCR2H_PCS49_Msk   (0x3UL << EXTI_D3PCR2H_PCS49_Pos)
#define EXTI_D3PCR2H_PCS49   EXTI_D3PCR2H_PCS49_Msk
#define EXTI_D3PCR2H_PCS50_Pos   (4U)
#define EXTI_D3PCR2H_PCS50_Msk   (0x3UL << EXTI_D3PCR2H_PCS50_Pos)
#define EXTI_D3PCR2H_PCS50   EXTI_D3PCR2H_PCS50_Msk
#define EXTI_D3PCR2H_PCS51_Pos   (6U)
#define EXTI_D3PCR2H_PCS51_Msk   (0x3UL << EXTI_D3PCR2H_PCS51_Pos)
#define EXTI_D3PCR2H_PCS51   EXTI_D3PCR2H_PCS51_Msk
#define EXTI_RTSR3_TR_Pos   (18U)
#define EXTI_RTSR3_TR_Msk   (0x9UL << EXTI_RTSR3_TR_Pos)
#define EXTI_RTSR3_TR   EXTI_RTSR3_TR_Msk
#define EXTI_RTSR3_TR82_Pos   (18U)
#define EXTI_RTSR3_TR82_Msk   (0x1UL << EXTI_RTSR3_TR82_Pos)
#define EXTI_RTSR3_TR82   EXTI_RTSR3_TR82_Msk
#define EXTI_RTSR3_TR85_Pos   (21U)
#define EXTI_RTSR3_TR85_Msk   (0x1UL << EXTI_RTSR3_TR85_Pos)
#define EXTI_RTSR3_TR85   EXTI_RTSR3_TR85_Msk
#define EXTI_FTSR3_TR_Pos   (18U)
#define EXTI_FTSR3_TR_Msk   (0x9UL << EXTI_FTSR3_TR_Pos)
#define EXTI_FTSR3_TR   EXTI_FTSR3_TR_Msk
#define EXTI_FTSR3_TR82_Pos   (18U)
#define EXTI_FTSR3_TR82_Msk   (0x1UL << EXTI_FTSR3_TR82_Pos)
#define EXTI_FTSR3_TR82   EXTI_FTSR3_TR82_Msk
#define EXTI_FTSR3_TR85_Pos   (21U)
#define EXTI_FTSR3_TR85_Msk   (0x1UL << EXTI_FTSR3_TR85_Pos)
#define EXTI_FTSR3_TR85   EXTI_FTSR3_TR85_Msk
#define EXTI_SWIER3_SWI_Pos   (18U)
#define EXTI_SWIER3_SWI_Msk   (0x9UL << EXTI_SWIER3_SWI_Pos)
#define EXTI_SWIER3_SWI   EXTI_SWIER3_SWI_Msk
#define EXTI_SWIER3_SWIER82_Pos   (18U)
#define EXTI_SWIER3_SWIER82_Msk   (0x1UL << EXTI_SWIER3_SWIER82_Pos)
#define EXTI_SWIER3_SWIER82   EXTI_SWIER3_SWIER82_Msk
#define EXTI_SWIER3_SWIER85_Pos   (21U)
#define EXTI_SWIER3_SWIER85_Msk   (0x1UL << EXTI_SWIER3_SWIER85_Pos)
#define EXTI_SWIER3_SWIER85   EXTI_SWIER3_SWIER85_Msk
#define EXTI_D3PMR3_MR88_Pos   (24U)
#define EXTI_D3PMR3_MR88_Msk   (0x1UL << EXTI_D3PMR3_MR88_Pos)
#define EXTI_D3PMR3_MR88   EXTI_D3PMR3_MR88_Msk
#define EXTI_D3PCR3H_PCS88_Pos   (16U)
#define EXTI_D3PCR3H_PCS88_Msk   (0x3UL << EXTI_D3PCR3H_PCS88_Pos)
#define EXTI_D3PCR3H_PCS88   EXTI_D3PCR3H_PCS88_Msk
#define EXTI_IMR1_IM_Pos   (0U)
#define EXTI_IMR1_IM_Msk   (0xFFFFFFFFUL << EXTI_IMR1_IM_Pos)
#define EXTI_IMR1_IM   EXTI_IMR1_IM_Msk
#define EXTI_IMR1_IM0_Pos   (0U)
#define EXTI_IMR1_IM0_Msk   (0x1UL << EXTI_IMR1_IM0_Pos)
#define EXTI_IMR1_IM0   EXTI_IMR1_IM0_Msk
#define EXTI_IMR1_IM1_Pos   (1U)
#define EXTI_IMR1_IM1_Msk   (0x1UL << EXTI_IMR1_IM1_Pos)
#define EXTI_IMR1_IM1   EXTI_IMR1_IM1_Msk
#define EXTI_IMR1_IM2_Pos   (2U)
#define EXTI_IMR1_IM2_Msk   (0x1UL << EXTI_IMR1_IM2_Pos)
#define EXTI_IMR1_IM2   EXTI_IMR1_IM2_Msk
#define EXTI_IMR1_IM3_Pos   (3U)
#define EXTI_IMR1_IM3_Msk   (0x1UL << EXTI_IMR1_IM3_Pos)
#define EXTI_IMR1_IM3   EXTI_IMR1_IM3_Msk
#define EXTI_IMR1_IM4_Pos   (4U)
#define EXTI_IMR1_IM4_Msk   (0x1UL << EXTI_IMR1_IM4_Pos)
#define EXTI_IMR1_IM4   EXTI_IMR1_IM4_Msk
#define EXTI_IMR1_IM5_Pos   (5U)
#define EXTI_IMR1_IM5_Msk   (0x1UL << EXTI_IMR1_IM5_Pos)
#define EXTI_IMR1_IM5   EXTI_IMR1_IM5_Msk
#define EXTI_IMR1_IM6_Pos   (6U)
#define EXTI_IMR1_IM6_Msk   (0x1UL << EXTI_IMR1_IM6_Pos)
#define EXTI_IMR1_IM6   EXTI_IMR1_IM6_Msk
#define EXTI_IMR1_IM7_Pos   (7U)
#define EXTI_IMR1_IM7_Msk   (0x1UL << EXTI_IMR1_IM7_Pos)
#define EXTI_IMR1_IM7   EXTI_IMR1_IM7_Msk
#define EXTI_IMR1_IM8_Pos   (8U)
#define EXTI_IMR1_IM8_Msk   (0x1UL << EXTI_IMR1_IM8_Pos)
#define EXTI_IMR1_IM8   EXTI_IMR1_IM8_Msk
#define EXTI_IMR1_IM9_Pos   (9U)
#define EXTI_IMR1_IM9_Msk   (0x1UL << EXTI_IMR1_IM9_Pos)
#define EXTI_IMR1_IM9   EXTI_IMR1_IM9_Msk
#define EXTI_IMR1_IM10_Pos   (10U)
#define EXTI_IMR1_IM10_Msk   (0x1UL << EXTI_IMR1_IM10_Pos)
#define EXTI_IMR1_IM10   EXTI_IMR1_IM10_Msk
#define EXTI_IMR1_IM11_Pos   (11U)
#define EXTI_IMR1_IM11_Msk   (0x1UL << EXTI_IMR1_IM11_Pos)
#define EXTI_IMR1_IM11   EXTI_IMR1_IM11_Msk
#define EXTI_IMR1_IM12_Pos   (12U)
#define EXTI_IMR1_IM12_Msk   (0x1UL << EXTI_IMR1_IM12_Pos)
#define EXTI_IMR1_IM12   EXTI_IMR1_IM12_Msk
#define EXTI_IMR1_IM13_Pos   (13U)
#define EXTI_IMR1_IM13_Msk   (0x1UL << EXTI_IMR1_IM13_Pos)
#define EXTI_IMR1_IM13   EXTI_IMR1_IM13_Msk
#define EXTI_IMR1_IM14_Pos   (14U)
#define EXTI_IMR1_IM14_Msk   (0x1UL << EXTI_IMR1_IM14_Pos)
#define EXTI_IMR1_IM14   EXTI_IMR1_IM14_Msk
#define EXTI_IMR1_IM15_Pos   (15U)
#define EXTI_IMR1_IM15_Msk   (0x1UL << EXTI_IMR1_IM15_Pos)
#define EXTI_IMR1_IM15   EXTI_IMR1_IM15_Msk
#define EXTI_IMR1_IM16_Pos   (16U)
#define EXTI_IMR1_IM16_Msk   (0x1UL << EXTI_IMR1_IM16_Pos)
#define EXTI_IMR1_IM16   EXTI_IMR1_IM16_Msk
#define EXTI_IMR1_IM17_Pos   (17U)
#define EXTI_IMR1_IM17_Msk   (0x1UL << EXTI_IMR1_IM17_Pos)
#define EXTI_IMR1_IM17   EXTI_IMR1_IM17_Msk
#define EXTI_IMR1_IM18_Pos   (18U)
#define EXTI_IMR1_IM18_Msk   (0x1UL << EXTI_IMR1_IM18_Pos)
#define EXTI_IMR1_IM18   EXTI_IMR1_IM18_Msk
#define EXTI_IMR1_IM19_Pos   (19U)
#define EXTI_IMR1_IM19_Msk   (0x1UL << EXTI_IMR1_IM19_Pos)
#define EXTI_IMR1_IM19   EXTI_IMR1_IM19_Msk
#define EXTI_IMR1_IM20_Pos   (20U)
#define EXTI_IMR1_IM20_Msk   (0x1UL << EXTI_IMR1_IM20_Pos)
#define EXTI_IMR1_IM20   EXTI_IMR1_IM20_Msk
#define EXTI_IMR1_IM21_Pos   (21U)
#define EXTI_IMR1_IM21_Msk   (0x1UL << EXTI_IMR1_IM21_Pos)
#define EXTI_IMR1_IM21   EXTI_IMR1_IM21_Msk
#define EXTI_IMR1_IM22_Pos   (22U)
#define EXTI_IMR1_IM22_Msk   (0x1UL << EXTI_IMR1_IM22_Pos)
#define EXTI_IMR1_IM22   EXTI_IMR1_IM22_Msk
#define EXTI_IMR1_IM23_Pos   (23U)
#define EXTI_IMR1_IM23_Msk   (0x1UL << EXTI_IMR1_IM23_Pos)
#define EXTI_IMR1_IM23   EXTI_IMR1_IM23_Msk
#define EXTI_IMR1_IM24_Pos   (24U)
#define EXTI_IMR1_IM24_Msk   (0x1UL << EXTI_IMR1_IM24_Pos)
#define EXTI_IMR1_IM24   EXTI_IMR1_IM24_Msk
#define EXTI_IMR1_IM25_Pos   (25U)
#define EXTI_IMR1_IM25_Msk   (0x1UL << EXTI_IMR1_IM25_Pos)
#define EXTI_IMR1_IM25   EXTI_IMR1_IM25_Msk
#define EXTI_IMR1_IM26_Pos   (26U)
#define EXTI_IMR1_IM26_Msk   (0x1UL << EXTI_IMR1_IM26_Pos)
#define EXTI_IMR1_IM26   EXTI_IMR1_IM26_Msk
#define EXTI_IMR1_IM27_Pos   (27U)
#define EXTI_IMR1_IM27_Msk   (0x1UL << EXTI_IMR1_IM27_Pos)
#define EXTI_IMR1_IM27   EXTI_IMR1_IM27_Msk
#define EXTI_IMR1_IM28_Pos   (28U)
#define EXTI_IMR1_IM28_Msk   (0x1UL << EXTI_IMR1_IM28_Pos)
#define EXTI_IMR1_IM28   EXTI_IMR1_IM28_Msk
#define EXTI_IMR1_IM29_Pos   (29U)
#define EXTI_IMR1_IM29_Msk   (0x1UL << EXTI_IMR1_IM29_Pos)
#define EXTI_IMR1_IM29   EXTI_IMR1_IM29_Msk
#define EXTI_IMR1_IM30_Pos   (30U)
#define EXTI_IMR1_IM30_Msk   (0x1UL << EXTI_IMR1_IM30_Pos)
#define EXTI_IMR1_IM30   EXTI_IMR1_IM30_Msk
#define EXTI_IMR1_IM31_Pos   (31U)
#define EXTI_IMR1_IM31_Msk   (0x1UL << EXTI_IMR1_IM31_Pos)
#define EXTI_IMR1_IM31   EXTI_IMR1_IM31_Msk
#define EXTI_EMR1_EM_Pos   (0U)
#define EXTI_EMR1_EM_Msk   (0xFFFFFFFFUL << EXTI_EMR1_EM_Pos)
#define EXTI_EMR1_EM   EXTI_EMR1_EM_Msk
#define EXTI_EMR1_EM0_Pos   (0U)
#define EXTI_EMR1_EM0_Msk   (0x1UL << EXTI_EMR1_EM0_Pos)
#define EXTI_EMR1_EM0   EXTI_EMR1_EM0_Msk
#define EXTI_EMR1_EM1_Pos   (1U)
#define EXTI_EMR1_EM1_Msk   (0x1UL << EXTI_EMR1_EM1_Pos)
#define EXTI_EMR1_EM1   EXTI_EMR1_EM1_Msk
#define EXTI_EMR1_EM2_Pos   (2U)
#define EXTI_EMR1_EM2_Msk   (0x1UL << EXTI_EMR1_EM2_Pos)
#define EXTI_EMR1_EM2   EXTI_EMR1_EM2_Msk
#define EXTI_EMR1_EM3_Pos   (3U)
#define EXTI_EMR1_EM3_Msk   (0x1UL << EXTI_EMR1_EM3_Pos)
#define EXTI_EMR1_EM3   EXTI_EMR1_EM3_Msk
#define EXTI_EMR1_EM4_Pos   (4U)
#define EXTI_EMR1_EM4_Msk   (0x1UL << EXTI_EMR1_EM4_Pos)
#define EXTI_EMR1_EM4   EXTI_EMR1_EM4_Msk
#define EXTI_EMR1_EM5_Pos   (5U)
#define EXTI_EMR1_EM5_Msk   (0x1UL << EXTI_EMR1_EM5_Pos)
#define EXTI_EMR1_EM5   EXTI_EMR1_EM5_Msk
#define EXTI_EMR1_EM6_Pos   (6U)
#define EXTI_EMR1_EM6_Msk   (0x1UL << EXTI_EMR1_EM6_Pos)
#define EXTI_EMR1_EM6   EXTI_EMR1_EM6_Msk
#define EXTI_EMR1_EM7_Pos   (7U)
#define EXTI_EMR1_EM7_Msk   (0x1UL << EXTI_EMR1_EM7_Pos)
#define EXTI_EMR1_EM7   EXTI_EMR1_EM7_Msk
#define EXTI_EMR1_EM8_Pos   (8U)
#define EXTI_EMR1_EM8_Msk   (0x1UL << EXTI_EMR1_EM8_Pos)
#define EXTI_EMR1_EM8   EXTI_EMR1_EM8_Msk
#define EXTI_EMR1_EM9_Pos   (9U)
#define EXTI_EMR1_EM9_Msk   (0x1UL << EXTI_EMR1_EM9_Pos)
#define EXTI_EMR1_EM9   EXTI_EMR1_EM9_Msk
#define EXTI_EMR1_EM10_Pos   (10U)
#define EXTI_EMR1_EM10_Msk   (0x1UL << EXTI_EMR1_EM10_Pos)
#define EXTI_EMR1_EM10   EXTI_EMR1_EM10_Msk
#define EXTI_EMR1_EM11_Pos   (11U)
#define EXTI_EMR1_EM11_Msk   (0x1UL << EXTI_EMR1_EM11_Pos)
#define EXTI_EMR1_EM11   EXTI_EMR1_EM11_Msk
#define EXTI_EMR1_EM12_Pos   (12U)
#define EXTI_EMR1_EM12_Msk   (0x1UL << EXTI_EMR1_EM12_Pos)
#define EXTI_EMR1_EM12   EXTI_EMR1_EM12_Msk
#define EXTI_EMR1_EM13_Pos   (13U)
#define EXTI_EMR1_EM13_Msk   (0x1UL << EXTI_EMR1_EM13_Pos)
#define EXTI_EMR1_EM13   EXTI_EMR1_EM13_Msk
#define EXTI_EMR1_EM14_Pos   (14U)
#define EXTI_EMR1_EM14_Msk   (0x1UL << EXTI_EMR1_EM14_Pos)
#define EXTI_EMR1_EM14   EXTI_EMR1_EM14_Msk
#define EXTI_EMR1_EM15_Pos   (15U)
#define EXTI_EMR1_EM15_Msk   (0x1UL << EXTI_EMR1_EM15_Pos)
#define EXTI_EMR1_EM15   EXTI_EMR1_EM15_Msk
#define EXTI_EMR1_EM16_Pos   (16U)
#define EXTI_EMR1_EM16_Msk   (0x1UL << EXTI_EMR1_EM16_Pos)
#define EXTI_EMR1_EM16   EXTI_EMR1_EM16_Msk
#define EXTI_EMR1_EM17_Pos   (17U)
#define EXTI_EMR1_EM17_Msk   (0x1UL << EXTI_EMR1_EM17_Pos)
#define EXTI_EMR1_EM17   EXTI_EMR1_EM17_Msk
#define EXTI_EMR1_EM18_Pos   (18U)
#define EXTI_EMR1_EM18_Msk   (0x1UL << EXTI_EMR1_EM18_Pos)
#define EXTI_EMR1_EM18   EXTI_EMR1_EM18_Msk
#define EXTI_EMR1_EM20_Pos   (20U)
#define EXTI_EMR1_EM20_Msk   (0x1UL << EXTI_EMR1_EM20_Pos)
#define EXTI_EMR1_EM20   EXTI_EMR1_EM20_Msk
#define EXTI_EMR1_EM21_Pos   (21U)
#define EXTI_EMR1_EM21_Msk   (0x1UL << EXTI_EMR1_EM21_Pos)
#define EXTI_EMR1_EM21   EXTI_EMR1_EM21_Msk
#define EXTI_EMR1_EM22_Pos   (22U)
#define EXTI_EMR1_EM22_Msk   (0x1UL << EXTI_EMR1_EM22_Pos)
#define EXTI_EMR1_EM22   EXTI_EMR1_EM22_Msk
#define EXTI_EMR1_EM23_Pos   (23U)
#define EXTI_EMR1_EM23_Msk   (0x1UL << EXTI_EMR1_EM23_Pos)
#define EXTI_EMR1_EM23   EXTI_EMR1_EM23_Msk
#define EXTI_EMR1_EM24_Pos   (24U)
#define EXTI_EMR1_EM24_Msk   (0x1UL << EXTI_EMR1_EM24_Pos)
#define EXTI_EMR1_EM24   EXTI_EMR1_EM24_Msk
#define EXTI_EMR1_EM25_Pos   (25U)
#define EXTI_EMR1_EM25_Msk   (0x1UL << EXTI_EMR1_EM25_Pos)
#define EXTI_EMR1_EM25   EXTI_EMR1_EM25_Msk
#define EXTI_EMR1_EM26_Pos   (26U)
#define EXTI_EMR1_EM26_Msk   (0x1UL << EXTI_EMR1_EM26_Pos)
#define EXTI_EMR1_EM26   EXTI_EMR1_EM26_Msk
#define EXTI_EMR1_EM27_Pos   (27U)
#define EXTI_EMR1_EM27_Msk   (0x1UL << EXTI_EMR1_EM27_Pos)
#define EXTI_EMR1_EM27   EXTI_EMR1_EM27_Msk
#define EXTI_EMR1_EM28_Pos   (28U)
#define EXTI_EMR1_EM28_Msk   (0x1UL << EXTI_EMR1_EM28_Pos)
#define EXTI_EMR1_EM28   EXTI_EMR1_EM28_Msk
#define EXTI_EMR1_EM29_Pos   (29U)
#define EXTI_EMR1_EM29_Msk   (0x1UL << EXTI_EMR1_EM29_Pos)
#define EXTI_EMR1_EM29   EXTI_EMR1_EM29_Msk
#define EXTI_EMR1_EM30_Pos   (30U)
#define EXTI_EMR1_EM30_Msk   (0x1UL << EXTI_EMR1_EM30_Pos)
#define EXTI_EMR1_EM30   EXTI_EMR1_EM30_Msk
#define EXTI_EMR1_EM31_Pos   (31U)
#define EXTI_EMR1_EM31_Msk   (0x1UL << EXTI_EMR1_EM31_Pos)
#define EXTI_EMR1_EM31   EXTI_EMR1_EM31_Msk
#define EXTI_PR1_PR_Pos   (0U)
#define EXTI_PR1_PR_Msk   (0x3FFFFFUL << EXTI_PR1_PR_Pos)
#define EXTI_PR1_PR   EXTI_PR1_PR_Msk
#define EXTI_PR1_PR0_Pos   (0U)
#define EXTI_PR1_PR0_Msk   (0x1UL << EXTI_PR1_PR0_Pos)
#define EXTI_PR1_PR0   EXTI_PR1_PR0_Msk
#define EXTI_PR1_PR1_Pos   (1U)
#define EXTI_PR1_PR1_Msk   (0x1UL << EXTI_PR1_PR1_Pos)
#define EXTI_PR1_PR1   EXTI_PR1_PR1_Msk
#define EXTI_PR1_PR2_Pos   (2U)
#define EXTI_PR1_PR2_Msk   (0x1UL << EXTI_PR1_PR2_Pos)
#define EXTI_PR1_PR2   EXTI_PR1_PR2_Msk
#define EXTI_PR1_PR3_Pos   (3U)
#define EXTI_PR1_PR3_Msk   (0x1UL << EXTI_PR1_PR3_Pos)
#define EXTI_PR1_PR3   EXTI_PR1_PR3_Msk
#define EXTI_PR1_PR4_Pos   (4U)
#define EXTI_PR1_PR4_Msk   (0x1UL << EXTI_PR1_PR4_Pos)
#define EXTI_PR1_PR4   EXTI_PR1_PR4_Msk
#define EXTI_PR1_PR5_Pos   (5U)
#define EXTI_PR1_PR5_Msk   (0x1UL << EXTI_PR1_PR5_Pos)
#define EXTI_PR1_PR5   EXTI_PR1_PR5_Msk
#define EXTI_PR1_PR6_Pos   (6U)
#define EXTI_PR1_PR6_Msk   (0x1UL << EXTI_PR1_PR6_Pos)
#define EXTI_PR1_PR6   EXTI_PR1_PR6_Msk
#define EXTI_PR1_PR7_Pos   (7U)
#define EXTI_PR1_PR7_Msk   (0x1UL << EXTI_PR1_PR7_Pos)
#define EXTI_PR1_PR7   EXTI_PR1_PR7_Msk
#define EXTI_PR1_PR8_Pos   (8U)
#define EXTI_PR1_PR8_Msk   (0x1UL << EXTI_PR1_PR8_Pos)
#define EXTI_PR1_PR8   EXTI_PR1_PR8_Msk
#define EXTI_PR1_PR9_Pos   (9U)
#define EXTI_PR1_PR9_Msk   (0x1UL << EXTI_PR1_PR9_Pos)
#define EXTI_PR1_PR9   EXTI_PR1_PR9_Msk
#define EXTI_PR1_PR10_Pos   (10U)
#define EXTI_PR1_PR10_Msk   (0x1UL << EXTI_PR1_PR10_Pos)
#define EXTI_PR1_PR10   EXTI_PR1_PR10_Msk
#define EXTI_PR1_PR11_Pos   (11U)
#define EXTI_PR1_PR11_Msk   (0x1UL << EXTI_PR1_PR11_Pos)
#define EXTI_PR1_PR11   EXTI_PR1_PR11_Msk
#define EXTI_PR1_PR12_Pos   (12U)
#define EXTI_PR1_PR12_Msk   (0x1UL << EXTI_PR1_PR12_Pos)
#define EXTI_PR1_PR12   EXTI_PR1_PR12_Msk
#define EXTI_PR1_PR13_Pos   (13U)
#define EXTI_PR1_PR13_Msk   (0x1UL << EXTI_PR1_PR13_Pos)
#define EXTI_PR1_PR13   EXTI_PR1_PR13_Msk
#define EXTI_PR1_PR14_Pos   (14U)
#define EXTI_PR1_PR14_Msk   (0x1UL << EXTI_PR1_PR14_Pos)
#define EXTI_PR1_PR14   EXTI_PR1_PR14_Msk
#define EXTI_PR1_PR15_Pos   (15U)
#define EXTI_PR1_PR15_Msk   (0x1UL << EXTI_PR1_PR15_Pos)
#define EXTI_PR1_PR15   EXTI_PR1_PR15_Msk
#define EXTI_PR1_PR16_Pos   (16U)
#define EXTI_PR1_PR16_Msk   (0x1UL << EXTI_PR1_PR16_Pos)
#define EXTI_PR1_PR16   EXTI_PR1_PR16_Msk
#define EXTI_PR1_PR17_Pos   (17U)
#define EXTI_PR1_PR17_Msk   (0x1UL << EXTI_PR1_PR17_Pos)
#define EXTI_PR1_PR17   EXTI_PR1_PR17_Msk
#define EXTI_PR1_PR18_Pos   (18U)
#define EXTI_PR1_PR18_Msk   (0x1UL << EXTI_PR1_PR18_Pos)
#define EXTI_PR1_PR18   EXTI_PR1_PR18_Msk
#define EXTI_PR1_PR19_Pos   (19U)
#define EXTI_PR1_PR19_Msk   (0x1UL << EXTI_PR1_PR19_Pos)
#define EXTI_PR1_PR19   EXTI_PR1_PR19_Msk
#define EXTI_PR1_PR20_Pos   (20U)
#define EXTI_PR1_PR20_Msk   (0x1UL << EXTI_PR1_PR20_Pos)
#define EXTI_PR1_PR20   EXTI_PR1_PR20_Msk
#define EXTI_PR1_PR21_Pos   (21U)
#define EXTI_PR1_PR21_Msk   (0x1UL << EXTI_PR1_PR21_Pos)
#define EXTI_PR1_PR21   EXTI_PR1_PR21_Msk
#define EXTI_IMR2_IM_Pos   (0U)
#define EXTI_IMR2_IM_Msk   (0xFFFF8FFFUL << EXTI_IMR2_IM_Pos)
#define EXTI_IMR2_IM   EXTI_IMR2_IM_Msk
#define EXTI_IMR2_IM32_Pos   (0U)
#define EXTI_IMR2_IM32_Msk   (0x1UL << EXTI_IMR2_IM32_Pos)
#define EXTI_IMR2_IM32   EXTI_IMR2_IM32_Msk
#define EXTI_IMR2_IM33_Pos   (1U)
#define EXTI_IMR2_IM33_Msk   (0x1UL << EXTI_IMR2_IM33_Pos)
#define EXTI_IMR2_IM33   EXTI_IMR2_IM33_Msk
#define EXTI_IMR2_IM34_Pos   (2U)
#define EXTI_IMR2_IM34_Msk   (0x1UL << EXTI_IMR2_IM34_Pos)
#define EXTI_IMR2_IM34   EXTI_IMR2_IM34_Msk
#define EXTI_IMR2_IM35_Pos   (3U)
#define EXTI_IMR2_IM35_Msk   (0x1UL << EXTI_IMR2_IM35_Pos)
#define EXTI_IMR2_IM35   EXTI_IMR2_IM35_Msk
#define EXTI_IMR2_IM36_Pos   (4U)
#define EXTI_IMR2_IM36_Msk   (0x1UL << EXTI_IMR2_IM36_Pos)
#define EXTI_IMR2_IM36   EXTI_IMR2_IM36_Msk
#define EXTI_IMR2_IM37_Pos   (5U)
#define EXTI_IMR2_IM37_Msk   (0x1UL << EXTI_IMR2_IM37_Pos)
#define EXTI_IMR2_IM37   EXTI_IMR2_IM37_Msk
#define EXTI_IMR2_IM38_Pos   (6U)
#define EXTI_IMR2_IM38_Msk   (0x1UL << EXTI_IMR2_IM38_Pos)
#define EXTI_IMR2_IM38   EXTI_IMR2_IM38_Msk
#define EXTI_IMR2_IM39_Pos   (7U)
#define EXTI_IMR2_IM39_Msk   (0x1UL << EXTI_IMR2_IM39_Pos)
#define EXTI_IMR2_IM39   EXTI_IMR2_IM39_Msk
#define EXTI_IMR2_IM40_Pos   (8U)
#define EXTI_IMR2_IM40_Msk   (0x1UL << EXTI_IMR2_IM40_Pos)
#define EXTI_IMR2_IM40   EXTI_IMR2_IM40_Msk
#define EXTI_IMR2_IM41_Pos   (9U)
#define EXTI_IMR2_IM41_Msk   (0x1UL << EXTI_IMR2_IM41_Pos)
#define EXTI_IMR2_IM41   EXTI_IMR2_IM41_Msk
#define EXTI_IMR2_IM42_Pos   (10U)
#define EXTI_IMR2_IM42_Msk   (0x1UL << EXTI_IMR2_IM42_Pos)
#define EXTI_IMR2_IM42   EXTI_IMR2_IM42_Msk
#define EXTI_IMR2_IM43_Pos   (11U)
#define EXTI_IMR2_IM43_Msk   (0x1UL << EXTI_IMR2_IM43_Pos)
#define EXTI_IMR2_IM43   EXTI_IMR2_IM43_Msk
#define EXTI_IMR2_IM47_Pos   (15U)
#define EXTI_IMR2_IM47_Msk   (0x1UL << EXTI_IMR2_IM47_Pos)
#define EXTI_IMR2_IM47   EXTI_IMR2_IM47_Msk
#define EXTI_IMR2_IM48_Pos   (16U)
#define EXTI_IMR2_IM48_Msk   (0x1UL << EXTI_IMR2_IM48_Pos)
#define EXTI_IMR2_IM48   EXTI_IMR2_IM48_Msk
#define EXTI_IMR2_IM49_Pos   (17U)
#define EXTI_IMR2_IM49_Msk   (0x1UL << EXTI_IMR2_IM49_Pos)
#define EXTI_IMR2_IM49   EXTI_IMR2_IM49_Msk
#define EXTI_IMR2_IM50_Pos   (18U)
#define EXTI_IMR2_IM50_Msk   (0x1UL << EXTI_IMR2_IM50_Pos)
#define EXTI_IMR2_IM50   EXTI_IMR2_IM50_Msk
#define EXTI_IMR2_IM51_Pos   (19U)
#define EXTI_IMR2_IM51_Msk   (0x1UL << EXTI_IMR2_IM51_Pos)
#define EXTI_IMR2_IM51   EXTI_IMR2_IM51_Msk
#define EXTI_IMR2_IM52_Pos   (20U)
#define EXTI_IMR2_IM52_Msk   (0x1UL << EXTI_IMR2_IM52_Pos)
#define EXTI_IMR2_IM52   EXTI_IMR2_IM52_Msk
#define EXTI_IMR2_IM53_Pos   (21U)
#define EXTI_IMR2_IM53_Msk   (0x1UL << EXTI_IMR2_IM53_Pos)
#define EXTI_IMR2_IM53   EXTI_IMR2_IM53_Msk
#define EXTI_IMR2_IM54_Pos   (22U)
#define EXTI_IMR2_IM54_Msk   (0x1UL << EXTI_IMR2_IM54_Pos)
#define EXTI_IMR2_IM54   EXTI_IMR2_IM54_Msk
#define EXTI_IMR2_IM55_Pos   (23U)
#define EXTI_IMR2_IM55_Msk   (0x1UL << EXTI_IMR2_IM55_Pos)
#define EXTI_IMR2_IM55   EXTI_IMR2_IM55_Msk
#define EXTI_IMR2_IM56_Pos   (24U)
#define EXTI_IMR2_IM56_Msk   (0x1UL << EXTI_IMR2_IM56_Pos)
#define EXTI_IMR2_IM56   EXTI_IMR2_IM56_Msk
#define EXTI_IMR2_IM57_Pos   (25U)
#define EXTI_IMR2_IM57_Msk   (0x1UL << EXTI_IMR2_IM57_Pos)
#define EXTI_IMR2_IM57   EXTI_IMR2_IM57_Msk
#define EXTI_IMR2_IM58_Pos   (26U)
#define EXTI_IMR2_IM58_Msk   (0x1UL << EXTI_IMR2_IM58_Pos)
#define EXTI_IMR2_IM58   EXTI_IMR2_IM58_Msk
#define EXTI_IMR2_IM59_Pos   (27U)
#define EXTI_IMR2_IM59_Msk   (0x1UL << EXTI_IMR2_IM59_Pos)
#define EXTI_IMR2_IM59   EXTI_IMR2_IM59_Msk
#define EXTI_IMR2_IM60_Pos   (28U)
#define EXTI_IMR2_IM60_Msk   (0x1UL << EXTI_IMR2_IM60_Pos)
#define EXTI_IMR2_IM60   EXTI_IMR2_IM60_Msk
#define EXTI_IMR2_IM61_Pos   (29U)
#define EXTI_IMR2_IM61_Msk   (0x1UL << EXTI_IMR2_IM61_Pos)
#define EXTI_IMR2_IM61   EXTI_IMR2_IM61_Msk
#define EXTI_IMR2_IM62_Pos   (30U)
#define EXTI_IMR2_IM62_Msk   (0x1UL << EXTI_IMR2_IM62_Pos)
#define EXTI_IMR2_IM62   EXTI_IMR2_IM62_Msk
#define EXTI_IMR2_IM63_Pos   (31U)
#define EXTI_IMR2_IM63_Msk   (0x1UL << EXTI_IMR2_IM63_Pos)
#define EXTI_IMR2_IM63   EXTI_IMR2_IM63_Msk
#define EXTI_EMR2_EM_Pos   (0U)
#define EXTI_EMR2_EM_Msk   (0xFFFF8FFFUL << EXTI_EMR2_EM_Pos)
#define EXTI_EMR2_EM   EXTI_EMR2_EM_Msk
#define EXTI_EMR2_EM32_Pos   (0U)
#define EXTI_EMR2_EM32_Msk   (0x1UL << EXTI_EMR2_EM32_Pos)
#define EXTI_EMR2_EM32   EXTI_EMR2_EM32_Msk
#define EXTI_EMR2_EM33_Pos   (1U)
#define EXTI_EMR2_EM33_Msk   (0x1UL << EXTI_EMR2_EM33_Pos)
#define EXTI_EMR2_EM33   EXTI_EMR2_EM33_Msk
#define EXTI_EMR2_EM34_Pos   (2U)
#define EXTI_EMR2_EM34_Msk   (0x1UL << EXTI_EMR2_EM34_Pos)
#define EXTI_EMR2_EM34   EXTI_EMR2_EM34_Msk
#define EXTI_EMR2_EM35_Pos   (3U)
#define EXTI_EMR2_EM35_Msk   (0x1UL << EXTI_EMR2_EM35_Pos)
#define EXTI_EMR2_EM35   EXTI_EMR2_EM35_Msk
#define EXTI_EMR2_EM36_Pos   (4U)
#define EXTI_EMR2_EM36_Msk   (0x1UL << EXTI_EMR2_EM36_Pos)
#define EXTI_EMR2_EM36   EXTI_EMR2_EM36_Msk
#define EXTI_EMR2_EM37_Pos   (5U)
#define EXTI_EMR2_EM37_Msk   (0x1UL << EXTI_EMR2_EM37_Pos)
#define EXTI_EMR2_EM37   EXTI_EMR2_EM37_Msk
#define EXTI_EMR2_EM38_Pos   (6U)
#define EXTI_EMR2_EM38_Msk   (0x1UL << EXTI_EMR2_EM38_Pos)
#define EXTI_EMR2_EM38   EXTI_EMR2_EM38_Msk
#define EXTI_EMR2_EM39_Pos   (7U)
#define EXTI_EMR2_EM39_Msk   (0x1UL << EXTI_EMR2_EM39_Pos)
#define EXTI_EMR2_EM39   EXTI_EMR2_EM39_Msk
#define EXTI_EMR2_EM40_Pos   (8U)
#define EXTI_EMR2_EM40_Msk   (0x1UL << EXTI_EMR2_EM40_Pos)
#define EXTI_EMR2_EM40   EXTI_EMR2_EM40_Msk
#define EXTI_EMR2_EM41_Pos   (9U)
#define EXTI_EMR2_EM41_Msk   (0x1UL << EXTI_EMR2_EM41_Pos)
#define EXTI_EMR2_EM41   EXTI_EMR2_EM41_Msk
#define EXTI_EMR2_EM42_Pos   (10U)
#define EXTI_EMR2_EM42_Msk   (0x1UL << EXTI_EMR2_EM42_Pos)
#define EXTI_EMR2_EM42   EXTI_EMR2_EM42_Msk
#define EXTI_EMR2_EM43_Pos   (11U)
#define EXTI_EMR2_EM43_Msk   (0x1UL << EXTI_EMR2_EM43_Pos)
#define EXTI_EMR2_EM43   EXTI_EMR2_EM43_Msk
#define EXTI_EMR2_EM47_Pos   (15U)
#define EXTI_EMR2_EM47_Msk   (0x1UL << EXTI_EMR2_EM47_Pos)
#define EXTI_EMR2_EM47   EXTI_EMR2_EM47_Msk
#define EXTI_EMR2_EM48_Pos   (16U)
#define EXTI_EMR2_EM48_Msk   (0x1UL << EXTI_EMR2_EM48_Pos)
#define EXTI_EMR2_EM48   EXTI_EMR2_EM48_Msk
#define EXTI_EMR2_EM49_Pos   (17U)
#define EXTI_EMR2_EM49_Msk   (0x1UL << EXTI_EMR2_EM49_Pos)
#define EXTI_EMR2_EM49   EXTI_EMR2_EM49_Msk
#define EXTI_EMR2_EM50_Pos   (18U)
#define EXTI_EMR2_EM50_Msk   (0x1UL << EXTI_EMR2_EM50_Pos)
#define EXTI_EMR2_EM50   EXTI_EMR2_EM50_Msk
#define EXTI_EMR2_EM51_Pos   (19U)
#define EXTI_EMR2_EM51_Msk   (0x1UL << EXTI_EMR2_EM51_Pos)
#define EXTI_EMR2_EM51   EXTI_EMR2_EM51_Msk
#define EXTI_EMR2_EM52_Pos   (20U)
#define EXTI_EMR2_EM52_Msk   (0x1UL << EXTI_EMR2_EM52_Pos)
#define EXTI_EMR2_EM52   EXTI_EMR2_EM52_Msk
#define EXTI_EMR2_EM53_Pos   (21U)
#define EXTI_EMR2_EM53_Msk   (0x1UL << EXTI_EMR2_EM53_Pos)
#define EXTI_EMR2_EM53   EXTI_EMR2_EM53_Msk
#define EXTI_EMR2_EM54_Pos   (22U)
#define EXTI_EMR2_EM54_Msk   (0x1UL << EXTI_EMR2_EM54_Pos)
#define EXTI_EMR2_EM54   EXTI_EMR2_EM54_Msk
#define EXTI_EMR2_EM55_Pos   (23U)
#define EXTI_EMR2_EM55_Msk   (0x1UL << EXTI_EMR2_EM55_Pos)
#define EXTI_EMR2_EM55   EXTI_EMR2_EM55_Msk
#define EXTI_EMR2_EM56_Pos   (24U)
#define EXTI_EMR2_EM56_Msk   (0x1UL << EXTI_EMR2_EM56_Pos)
#define EXTI_EMR2_EM56   EXTI_EMR2_EM56_Msk
#define EXTI_EMR2_EM57_Pos   (25U)
#define EXTI_EMR2_EM57_Msk   (0x1UL << EXTI_EMR2_EM57_Pos)
#define EXTI_EMR2_EM57   EXTI_EMR2_EM57_Msk
#define EXTI_EMR2_EM58_Pos   (26U)
#define EXTI_EMR2_EM58_Msk   (0x1UL << EXTI_EMR2_EM58_Pos)
#define EXTI_EMR2_EM58   EXTI_EMR2_EM58_Msk
#define EXTI_EMR2_EM59_Pos   (27U)
#define EXTI_EMR2_EM59_Msk   (0x1UL << EXTI_EMR2_EM59_Pos)
#define EXTI_EMR2_EM59   EXTI_EMR2_EM59_Msk
#define EXTI_EMR2_EM60_Pos   (28U)
#define EXTI_EMR2_EM60_Msk   (0x1UL << EXTI_EMR2_EM60_Pos)
#define EXTI_EMR2_EM60   EXTI_EMR2_EM60_Msk
#define EXTI_EMR2_EM61_Pos   (29U)
#define EXTI_EMR2_EM61_Msk   (0x1UL << EXTI_EMR2_EM61_Pos)
#define EXTI_EMR2_EM61   EXTI_EMR2_EM61_Msk
#define EXTI_EMR2_EM62_Pos   (30U)
#define EXTI_EMR2_EM62_Msk   (0x1UL << EXTI_EMR2_EM62_Pos)
#define EXTI_EMR2_EM62   EXTI_EMR2_EM62_Msk
#define EXTI_EMR2_EM63_Pos   (31U)
#define EXTI_EMR2_EM63_Msk   (0x1UL << EXTI_EMR2_EM63_Pos)
#define EXTI_EMR2_EM63   EXTI_EMR2_EM63_Msk
#define EXTI_PR2_PR_Pos   (17U)
#define EXTI_PR2_PR_Msk   (0x5UL << EXTI_PR2_PR_Pos)
#define EXTI_PR2_PR   EXTI_PR2_PR_Msk
#define EXTI_PR2_PR49_Pos   (17U)
#define EXTI_PR2_PR49_Msk   (0x1UL << EXTI_PR2_PR49_Pos)
#define EXTI_PR2_PR49   EXTI_PR2_PR49_Msk
#define EXTI_PR2_PR51_Pos   (19U)
#define EXTI_PR2_PR51_Msk   (0x1UL << EXTI_PR2_PR51_Pos)
#define EXTI_PR2_PR51   EXTI_PR2_PR51_Msk
#define EXTI_IMR3_IM_Pos   (0U)
#define EXTI_IMR3_IM_Msk   (0x01A527FFUL << EXTI_IMR3_IM_Pos)
#define EXTI_IMR3_IM   EXTI_IMR3_IM_Msk
#define EXTI_IMR3_IM64_Pos   (0U)
#define EXTI_IMR3_IM64_Msk   (0x1UL << EXTI_IMR3_IM64_Pos)
#define EXTI_IMR3_IM64   EXTI_IMR3_IM64_Msk
#define EXTI_IMR3_IM65_Pos   (1U)
#define EXTI_IMR3_IM65_Msk   (0x1UL << EXTI_IMR3_IM65_Pos)
#define EXTI_IMR3_IM65   EXTI_IMR3_IM65_Msk
#define EXTI_IMR3_IM66_Pos   (2U)
#define EXTI_IMR3_IM66_Msk   (0x1UL << EXTI_IMR3_IM66_Pos)
#define EXTI_IMR3_IM66   EXTI_IMR3_IM66_Msk
#define EXTI_IMR3_IM67_Pos   (3U)
#define EXTI_IMR3_IM67_Msk   (0x1UL << EXTI_IMR3_IM67_Pos)
#define EXTI_IMR3_IM67   EXTI_IMR3_IM67_Msk
#define EXTI_IMR3_IM68_Pos   (4U)
#define EXTI_IMR3_IM68_Msk   (0x1UL << EXTI_IMR3_IM68_Pos)
#define EXTI_IMR3_IM68   EXTI_IMR3_IM68_Msk
#define EXTI_IMR3_IM69_Pos   (5U)
#define EXTI_IMR3_IM69_Msk   (0x1UL << EXTI_IMR3_IM69_Pos)
#define EXTI_IMR3_IM69   EXTI_IMR3_IM69_Msk
#define EXTI_IMR3_IM70_Pos   (6U)
#define EXTI_IMR3_IM70_Msk   (0x1UL << EXTI_IMR3_IM70_Pos)
#define EXTI_IMR3_IM70   EXTI_IMR3_IM70_Msk
#define EXTI_IMR3_IM71_Pos   (7U)
#define EXTI_IMR3_IM71_Msk   (0x1UL << EXTI_IMR3_IM71_Pos)
#define EXTI_IMR3_IM71   EXTI_IMR3_IM71_Msk
#define EXTI_IMR3_IM72_Pos   (8U)
#define EXTI_IMR3_IM72_Msk   (0x1UL << EXTI_IMR3_IM72_Pos)
#define EXTI_IMR3_IM72   EXTI_IMR3_IM72_Msk
#define EXTI_IMR3_IM73_Pos   (9U)
#define EXTI_IMR3_IM73_Msk   (0x1UL << EXTI_IMR3_IM73_Pos)
#define EXTI_IMR3_IM73   EXTI_IMR3_IM73_Msk
#define EXTI_IMR3_IM74_Pos   (10U)
#define EXTI_IMR3_IM74_Msk   (0x1UL << EXTI_IMR3_IM74_Pos)
#define EXTI_IMR3_IM74   EXTI_IMR3_IM74_Msk
#define EXTI_IMR3_IM77_Pos   (13U)
#define EXTI_IMR3_IM77_Msk   (0x1UL << EXTI_IMR3_IM77_Pos)
#define EXTI_IMR3_IM77   EXTI_IMR3_IM77_Msk
#define EXTI_IMR3_IM80_Pos   (16U)
#define EXTI_IMR3_IM80_Msk   (0x1UL << EXTI_IMR3_IM80_Pos)
#define EXTI_IMR3_IM80   EXTI_IMR3_IM80_Msk
#define EXTI_IMR3_IM82_Pos   (18U)
#define EXTI_IMR3_IM82_Msk   (0x1UL << EXTI_IMR3_IM82_Pos)
#define EXTI_IMR3_IM82   EXTI_IMR3_IM82_Msk
#define EXTI_IMR3_IM85_Pos   (21U)
#define EXTI_IMR3_IM85_Msk   (0x1UL << EXTI_IMR3_IM85_Pos)
#define EXTI_IMR3_IM85   EXTI_IMR3_IM85_Msk
#define EXTI_IMR3_IM87_Pos   (23U)
#define EXTI_IMR3_IM87_Msk   (0x1UL << EXTI_IMR3_IM87_Pos)
#define EXTI_IMR3_IM87   EXTI_IMR3_IM87_Msk
#define EXTI_IMR3_IM88_Pos   (24U)
#define EXTI_IMR3_IM88_Msk   (0x1UL << EXTI_IMR3_IM88_Pos)
#define EXTI_IMR3_IM88   EXTI_IMR3_IM88_Msk
#define EXTI_EMR3_EM_Pos   (0U)
#define EXTI_EMR3_EM_Msk   (0x01A527FFUL << EXTI_EMR3_EM_Pos)
#define EXTI_EMR3_EM   EXTI_EMR3_EM_Msk
#define EXTI_EMR3_EM64_Pos   (0U)
#define EXTI_EMR3_EM64_Msk   (0x1UL << EXTI_EMR3_EM64_Pos)
#define EXTI_EMR3_EM64   EXTI_EMR3_EM64_Msk
#define EXTI_EMR3_EM65_Pos   (1U)
#define EXTI_EMR3_EM65_Msk   (0x1UL << EXTI_EMR3_EM65_Pos)
#define EXTI_EMR3_EM65   EXTI_EMR3_EM65_Msk
#define EXTI_EMR3_EM66_Pos   (2U)
#define EXTI_EMR3_EM66_Msk   (0x1UL << EXTI_EMR3_EM66_Pos)
#define EXTI_EMR3_EM66   EXTI_EMR3_EM66_Msk
#define EXTI_EMR3_EM67_Pos   (3U)
#define EXTI_EMR3_EM67_Msk   (0x1UL << EXTI_EMR3_EM67_Pos)
#define EXTI_EMR3_EM67   EXTI_EMR3_EM67_Msk
#define EXTI_EMR3_EM68_Pos   (4U)
#define EXTI_EMR3_EM68_Msk   (0x1UL << EXTI_EMR3_EM68_Pos)
#define EXTI_EMR3_EM68   EXTI_EMR3_EM68_Msk
#define EXTI_EMR3_EM69_Pos   (5U)
#define EXTI_EMR3_EM69_Msk   (0x1UL << EXTI_EMR3_EM69_Pos)
#define EXTI_EMR3_EM69   EXTI_EMR3_EM69_Msk
#define EXTI_EMR3_EM70_Pos   (6U)
#define EXTI_EMR3_EM70_Msk   (0x1UL << EXTI_EMR3_EM70_Pos)
#define EXTI_EMR3_EM70   EXTI_EMR3_EM70_Msk
#define EXTI_EMR3_EM71_Pos   (7U)
#define EXTI_EMR3_EM71_Msk   (0x1UL << EXTI_EMR3_EM71_Pos)
#define EXTI_EMR3_EM71   EXTI_EMR3_EM71_Msk
#define EXTI_EMR3_EM72_Pos   (8U)
#define EXTI_EMR3_EM72_Msk   (0x1UL << EXTI_EMR3_EM72_Pos)
#define EXTI_EMR3_EM72   EXTI_EMR3_EM72_Msk
#define EXTI_EMR3_EM73_Pos   (9U)
#define EXTI_EMR3_EM73_Msk   (0x1UL << EXTI_EMR3_EM73_Pos)
#define EXTI_EMR3_EM73   EXTI_EMR3_EM73_Msk
#define EXTI_EMR3_EM74_Pos   (10U)
#define EXTI_EMR3_EM74_Msk   (0x1UL << EXTI_EMR3_EM74_Pos)
#define EXTI_EMR3_EM74   EXTI_EMR3_EM74_Msk
#define EXTI_EMR3_EM77_Pos   (13U)
#define EXTI_EMR3_EM77_Msk   (0x1UL << EXTI_EMR3_EM77_Pos)
#define EXTI_EMR3_EM77   EXTI_EMR3_EM77_Msk
#define EXTI_EMR3_EM80_Pos   (16U)
#define EXTI_EMR3_EM80_Msk   (0x1UL << EXTI_EMR3_EM80_Pos)
#define EXTI_EMR3_EM80   EXTI_EMR3_EM80_Msk
#define EXTI_EMR3_EM81_Pos   (17U)
#define EXTI_EMR3_EM81_Msk   (0x1UL << EXTI_EMR3_EM81_Pos)
#define EXTI_EMR3_EM81   EXTI_EMR3_EM81_Msk
#define EXTI_EMR3_EM82_Pos   (18U)
#define EXTI_EMR3_EM82_Msk   (0x1UL << EXTI_EMR3_EM82_Pos)
#define EXTI_EMR3_EM82   EXTI_EMR3_EM82_Msk
#define EXTI_EMR3_EM85_Pos   (21U)
#define EXTI_EMR3_EM85_Msk   (0x1UL << EXTI_EMR3_EM85_Pos)
#define EXTI_EMR3_EM85   EXTI_EMR3_EM85_Msk
#define EXTI_EMR3_EM87_Pos   (23U)
#define EXTI_EMR3_EM87_Msk   (0x1UL << EXTI_EMR3_EM87_Pos)
#define EXTI_EMR3_EM87   EXTI_EMR3_EM87_Msk
#define EXTI_EMR3_EM88_Pos   (24U)
#define EXTI_EMR3_EM88_Msk   (0x1UL << EXTI_EMR3_EM88_Pos)
#define EXTI_EMR3_EM88   EXTI_EMR3_EM88_Msk
#define EXTI_PR3_PR_Pos   (18U)
#define EXTI_PR3_PR_Msk   (0x9UL << EXTI_PR3_PR_Pos)
#define EXTI_PR3_PR   EXTI_PR3_PR_Msk
#define EXTI_PR3_PR82_Pos   (18U)
#define EXTI_PR3_PR82_Msk   (0x1UL << EXTI_PR3_PR82_Pos)
#define EXTI_PR3_PR82   EXTI_PR3_PR82_Msk
#define EXTI_PR3_PR85_Pos   (21U)
#define EXTI_PR3_PR85_Msk   (0x1UL << EXTI_PR3_PR85_Pos)
#define EXTI_PR3_PR85   EXTI_PR3_PR85_Msk
#define FLASH_SIZE_DATA_REGISTER   0x08FFF80CU
#define FLASH_SECTOR_TOTAL   128U /* 128 sectors */
#define FLASH_SIZE
#define FLASH_BANK_SIZE   (FLASH_SIZE >> 1) /* 1 MB */
#define FLASH_SECTOR_SIZE   0x00002000UL /* 8 KB */
#define FLASH_LATENCY_DEFAULT   FLASH_ACR_LATENCY_3WS /* FLASH Three Latency cycles */
#define FLASH_NB_32BITWORD_IN_FLASHWORD   4U /* 128 bits */
#define DUAL_BANK   /* Dual-bank Flash */
#define FLASH_ACR_LATENCY_Pos   (0U)
#define FLASH_ACR_LATENCY_Msk   (0xFUL << FLASH_ACR_LATENCY_Pos)
#define FLASH_ACR_LATENCY   FLASH_ACR_LATENCY_Msk
#define FLASH_ACR_LATENCY_0WS   (0x00000000UL)
#define FLASH_ACR_LATENCY_1WS   (0x00000001UL)
#define FLASH_ACR_LATENCY_2WS   (0x00000002UL)
#define FLASH_ACR_LATENCY_3WS   (0x00000003UL)
#define FLASH_ACR_LATENCY_4WS   (0x00000004UL)
#define FLASH_ACR_LATENCY_5WS   (0x00000005UL)
#define FLASH_ACR_LATENCY_6WS   (0x00000006UL)
#define FLASH_ACR_LATENCY_7WS   (0x00000007UL)
#define FLASH_ACR_WRHIGHFREQ_Pos   (4U)
#define FLASH_ACR_WRHIGHFREQ_Msk   (0x3UL << FLASH_ACR_WRHIGHFREQ_Pos)
#define FLASH_ACR_WRHIGHFREQ   FLASH_ACR_WRHIGHFREQ_Msk
#define FLASH_ACR_WRHIGHFREQ_0   (0x1UL << FLASH_ACR_WRHIGHFREQ_Pos)
#define FLASH_ACR_WRHIGHFREQ_1   (0x2UL << FLASH_ACR_WRHIGHFREQ_Pos)
#define FLASH_ACR_LATENCY_8WS   (0x00000008UL)
#define FLASH_ACR_LATENCY_9WS   (0x00000009UL)
#define FLASH_ACR_LATENCY_10WS   (0x0000000AUL)
#define FLASH_ACR_LATENCY_11WS   (0x0000000BUL)
#define FLASH_ACR_LATENCY_12WS   (0x0000000CUL)
#define FLASH_ACR_LATENCY_13WS   (0x0000000DUL)
#define FLASH_ACR_LATENCY_14WS   (0x0000000EUL)
#define FLASH_ACR_LATENCY_15WS   (0x0000000FUL)
#define FLASH_CR_LOCK_Pos   (0U)
#define FLASH_CR_LOCK_Msk   (0x1UL << FLASH_CR_LOCK_Pos)
#define FLASH_CR_LOCK   FLASH_CR_LOCK_Msk
#define FLASH_CR_PG_Pos   (1U)
#define FLASH_CR_PG_Msk   (0x1UL << FLASH_CR_PG_Pos)
#define FLASH_CR_PG   FLASH_CR_PG_Msk
#define FLASH_CR_SER_Pos   (2U)
#define FLASH_CR_SER_Msk   (0x1UL << FLASH_CR_SER_Pos)
#define FLASH_CR_SER   FLASH_CR_SER_Msk
#define FLASH_CR_BER_Pos   (3U)
#define FLASH_CR_BER_Msk   (0x1UL << FLASH_CR_BER_Pos)
#define FLASH_CR_BER   FLASH_CR_BER_Msk
#define FLASH_CR_FW_Pos   (4U)
#define FLASH_CR_FW_Msk   (0x1UL << FLASH_CR_FW_Pos)
#define FLASH_CR_FW   FLASH_CR_FW_Msk
#define FLASH_CR_START_Pos   (5U)
#define FLASH_CR_START_Msk   (0x1UL << FLASH_CR_START_Pos)
#define FLASH_CR_START   FLASH_CR_START_Msk
#define FLASH_CR_SNB_Pos   (6U)
#define FLASH_CR_SNB_Msk   (0x7FUL << FLASH_CR_SNB_Pos)
#define FLASH_CR_SNB   FLASH_CR_SNB_Msk
#define FLASH_CR_SNB_0   (0x01UL << FLASH_CR_SNB_Pos)
#define FLASH_CR_SNB_1   (0x02UL << FLASH_CR_SNB_Pos)
#define FLASH_CR_SNB_2   (0x04UL << FLASH_CR_SNB_Pos)
#define FLASH_CR_SNB_3   (0x08UL << FLASH_CR_SNB_Pos)
#define FLASH_CR_SNB_4   (0x10UL << FLASH_CR_SNB_Pos)
#define FLASH_CR_SNB_5   (0x20UL << FLASH_CR_SNB_Pos)
#define FLASH_CR_SNB_6   (0x40UL << FLASH_CR_SNB_Pos)
#define FLASH_CR_CRC_EN_Pos   (15U)
#define FLASH_CR_CRC_EN_Msk   (0x1UL << FLASH_CR_CRC_EN_Pos)
#define FLASH_CR_CRC_EN   FLASH_CR_CRC_EN_Msk
#define FLASH_CR_EOPIE_Pos   (16U)
#define FLASH_CR_EOPIE_Msk   (0x1UL << FLASH_CR_EOPIE_Pos)
#define FLASH_CR_EOPIE   FLASH_CR_EOPIE_Msk
#define FLASH_CR_WRPERRIE_Pos   (17U)
#define FLASH_CR_WRPERRIE_Msk   (0x1UL << FLASH_CR_WRPERRIE_Pos)
#define FLASH_CR_WRPERRIE   FLASH_CR_WRPERRIE_Msk
#define FLASH_CR_PGSERRIE_Pos   (18U)
#define FLASH_CR_PGSERRIE_Msk   (0x1UL << FLASH_CR_PGSERRIE_Pos)
#define FLASH_CR_PGSERRIE   FLASH_CR_PGSERRIE_Msk
#define FLASH_CR_STRBERRIE_Pos   (19U)
#define FLASH_CR_STRBERRIE_Msk   (0x1UL << FLASH_CR_STRBERRIE_Pos)
#define FLASH_CR_STRBERRIE   FLASH_CR_STRBERRIE_Msk
#define FLASH_CR_INCERRIE_Pos   (21U)
#define FLASH_CR_INCERRIE_Msk   (0x1UL << FLASH_CR_INCERRIE_Pos)
#define FLASH_CR_INCERRIE   FLASH_CR_INCERRIE_Msk
#define FLASH_CR_RDPERRIE_Pos   (23U)
#define FLASH_CR_RDPERRIE_Msk   (0x1UL << FLASH_CR_RDPERRIE_Pos)
#define FLASH_CR_RDPERRIE   FLASH_CR_RDPERRIE_Msk
#define FLASH_CR_RDSERRIE_Pos   (24U)
#define FLASH_CR_RDSERRIE_Msk   (0x1UL << FLASH_CR_RDSERRIE_Pos)
#define FLASH_CR_RDSERRIE   FLASH_CR_RDSERRIE_Msk
#define FLASH_CR_SNECCERRIE_Pos   (25U)
#define FLASH_CR_SNECCERRIE_Msk   (0x1UL << FLASH_CR_SNECCERRIE_Pos)
#define FLASH_CR_SNECCERRIE   FLASH_CR_SNECCERRIE_Msk
#define FLASH_CR_DBECCERRIE_Pos   (26U)
#define FLASH_CR_DBECCERRIE_Msk   (0x1UL << FLASH_CR_DBECCERRIE_Pos)
#define FLASH_CR_DBECCERRIE   FLASH_CR_DBECCERRIE_Msk
#define FLASH_CR_CRCENDIE_Pos   (27U)
#define FLASH_CR_CRCENDIE_Msk   (0x1UL << FLASH_CR_CRCENDIE_Pos)
#define FLASH_CR_CRCENDIE   FLASH_CR_CRCENDIE_Msk
#define FLASH_CR_CRCRDERRIE_Pos   (28U)
#define FLASH_CR_CRCRDERRIE_Msk   (0x1UL << FLASH_CR_CRCRDERRIE_Pos)
#define FLASH_CR_CRCRDERRIE   FLASH_CR_CRCRDERRIE_Msk
#define FLASH_SR_BSY_Pos   (0U)
#define FLASH_SR_BSY_Msk   (0x1UL << FLASH_SR_BSY_Pos)
#define FLASH_SR_BSY   FLASH_SR_BSY_Msk
#define FLASH_SR_WBNE_Pos   (1U)
#define FLASH_SR_WBNE_Msk   (0x1UL << FLASH_SR_WBNE_Pos)
#define FLASH_SR_WBNE   FLASH_SR_WBNE_Msk
#define FLASH_SR_QW_Pos   (2U)
#define FLASH_SR_QW_Msk   (0x1UL << FLASH_SR_QW_Pos)
#define FLASH_SR_QW   FLASH_SR_QW_Msk
#define FLASH_SR_CRC_BUSY_Pos   (3U)
#define FLASH_SR_CRC_BUSY_Msk   (0x1UL << FLASH_SR_CRC_BUSY_Pos)
#define FLASH_SR_CRC_BUSY   FLASH_SR_CRC_BUSY_Msk
#define FLASH_SR_EOP_Pos   (16U)
#define FLASH_SR_EOP_Msk   (0x1UL << FLASH_SR_EOP_Pos)
#define FLASH_SR_EOP   FLASH_SR_EOP_Msk
#define FLASH_SR_WRPERR_Pos   (17U)
#define FLASH_SR_WRPERR_Msk   (0x1UL << FLASH_SR_WRPERR_Pos)
#define FLASH_SR_WRPERR   FLASH_SR_WRPERR_Msk
#define FLASH_SR_PGSERR_Pos   (18U)
#define FLASH_SR_PGSERR_Msk   (0x1UL << FLASH_SR_PGSERR_Pos)
#define FLASH_SR_PGSERR   FLASH_SR_PGSERR_Msk
#define FLASH_SR_STRBERR_Pos   (19U)
#define FLASH_SR_STRBERR_Msk   (0x1UL << FLASH_SR_STRBERR_Pos)
#define FLASH_SR_STRBERR   FLASH_SR_STRBERR_Msk
#define FLASH_SR_INCERR_Pos   (21U)
#define FLASH_SR_INCERR_Msk   (0x1UL << FLASH_SR_INCERR_Pos)
#define FLASH_SR_INCERR   FLASH_SR_INCERR_Msk
#define FLASH_SR_RDPERR_Pos   (23U)
#define FLASH_SR_RDPERR_Msk   (0x1UL << FLASH_SR_RDPERR_Pos)
#define FLASH_SR_RDPERR   FLASH_SR_RDPERR_Msk
#define FLASH_SR_RDSERR_Pos   (24U)
#define FLASH_SR_RDSERR_Msk   (0x1UL << FLASH_SR_RDSERR_Pos)
#define FLASH_SR_RDSERR   FLASH_SR_RDSERR_Msk
#define FLASH_SR_SNECCERR_Pos   (25U)
#define FLASH_SR_SNECCERR_Msk   (0x1UL << FLASH_SR_SNECCERR_Pos)
#define FLASH_SR_SNECCERR   FLASH_SR_SNECCERR_Msk
#define FLASH_SR_DBECCERR_Pos   (26U)
#define FLASH_SR_DBECCERR_Msk   (0x1UL << FLASH_SR_DBECCERR_Pos)
#define FLASH_SR_DBECCERR   FLASH_SR_DBECCERR_Msk
#define FLASH_SR_CRCEND_Pos   (27U)
#define FLASH_SR_CRCEND_Msk   (0x1UL << FLASH_SR_CRCEND_Pos)
#define FLASH_SR_CRCEND   FLASH_SR_CRCEND_Msk
#define FLASH_SR_CRCRDERR_Pos   (28U)
#define FLASH_SR_CRCRDERR_Msk   (0x1UL << FLASH_SR_CRCRDERR_Pos)
#define FLASH_SR_CRCRDERR   FLASH_SR_CRCRDERR_Msk
#define FLASH_CCR_CLR_EOP_Pos   (16U)
#define FLASH_CCR_CLR_EOP_Msk   (0x1UL << FLASH_CCR_CLR_EOP_Pos)
#define FLASH_CCR_CLR_EOP   FLASH_CCR_CLR_EOP_Msk
#define FLASH_CCR_CLR_WRPERR_Pos   (17U)
#define FLASH_CCR_CLR_WRPERR_Msk   (0x1UL << FLASH_CCR_CLR_WRPERR_Pos)
#define FLASH_CCR_CLR_WRPERR   FLASH_CCR_CLR_WRPERR_Msk
#define FLASH_CCR_CLR_PGSERR_Pos   (18U)
#define FLASH_CCR_CLR_PGSERR_Msk   (0x1UL << FLASH_CCR_CLR_PGSERR_Pos)
#define FLASH_CCR_CLR_PGSERR   FLASH_CCR_CLR_PGSERR_Msk
#define FLASH_CCR_CLR_STRBERR_Pos   (19U)
#define FLASH_CCR_CLR_STRBERR_Msk   (0x1UL << FLASH_CCR_CLR_STRBERR_Pos)
#define FLASH_CCR_CLR_STRBERR   FLASH_CCR_CLR_STRBERR_Msk
#define FLASH_CCR_CLR_INCERR_Pos   (21U)
#define FLASH_CCR_CLR_INCERR_Msk   (0x1UL << FLASH_CCR_CLR_INCERR_Pos)
#define FLASH_CCR_CLR_INCERR   FLASH_CCR_CLR_INCERR_Msk
#define FLASH_CCR_CLR_RDPERR_Pos   (23U)
#define FLASH_CCR_CLR_RDPERR_Msk   (0x1UL << FLASH_CCR_CLR_RDPERR_Pos)
#define FLASH_CCR_CLR_RDPERR   FLASH_CCR_CLR_RDPERR_Msk
#define FLASH_CCR_CLR_RDSERR_Pos   (24U)
#define FLASH_CCR_CLR_RDSERR_Msk   (0x1UL << FLASH_CCR_CLR_RDSERR_Pos)
#define FLASH_CCR_CLR_RDSERR   FLASH_CCR_CLR_RDSERR_Msk
#define FLASH_CCR_CLR_SNECCERR_Pos   (25U)
#define FLASH_CCR_CLR_SNECCERR_Msk   (0x1UL << FLASH_CCR_CLR_SNECCERR_Pos)
#define FLASH_CCR_CLR_SNECCERR   FLASH_CCR_CLR_SNECCERR_Msk
#define FLASH_CCR_CLR_DBECCERR_Pos   (26U)
#define FLASH_CCR_CLR_DBECCERR_Msk   (0x1UL << FLASH_CCR_CLR_DBECCERR_Pos)
#define FLASH_CCR_CLR_DBECCERR   FLASH_CCR_CLR_DBECCERR_Msk
#define FLASH_CCR_CLR_CRCEND_Pos   (27U)
#define FLASH_CCR_CLR_CRCEND_Msk   (0x1UL << FLASH_CCR_CLR_CRCEND_Pos)
#define FLASH_CCR_CLR_CRCEND   FLASH_CCR_CLR_CRCEND_Msk
#define FLASH_CCR_CLR_CRCRDERR_Pos   (28U)
#define FLASH_CCR_CLR_CRCRDERR_Msk   (0x1UL << FLASH_CCR_CLR_CRCRDERR_Pos)
#define FLASH_CCR_CLR_CRCRDERR   FLASH_CCR_CLR_CRCRDERR_Msk
#define FLASH_OPTCR_OPTLOCK_Pos   (0U)
#define FLASH_OPTCR_OPTLOCK_Msk   (0x1UL << FLASH_OPTCR_OPTLOCK_Pos)
#define FLASH_OPTCR_OPTLOCK   FLASH_OPTCR_OPTLOCK_Msk
#define FLASH_OPTCR_OPTSTART_Pos   (1U)
#define FLASH_OPTCR_OPTSTART_Msk   (0x1UL << FLASH_OPTCR_OPTSTART_Pos)
#define FLASH_OPTCR_OPTSTART   FLASH_OPTCR_OPTSTART_Msk
#define FLASH_OPTCR_MER_Pos   (4U)
#define FLASH_OPTCR_MER_Msk   (0x1UL << FLASH_OPTCR_MER_Pos)
#define FLASH_OPTCR_MER   FLASH_OPTCR_MER_Msk
#define FLASH_OPTCR_PG_OTP_Pos   (5U)
#define FLASH_OPTCR_PG_OTP_Msk   (0x1UL << FLASH_OPTCR_PG_OTP_Pos)
#define FLASH_OPTCR_PG_OTP   FLASH_OPTCR_PG_OTP_Msk
#define FLASH_OPTCR_OPTCHANGEERRIE_Pos   (30U)
#define FLASH_OPTCR_OPTCHANGEERRIE_Msk   (0x1UL << FLASH_OPTCR_OPTCHANGEERRIE_Pos)
#define FLASH_OPTCR_OPTCHANGEERRIE   FLASH_OPTCR_OPTCHANGEERRIE_Msk
#define FLASH_OPTCR_SWAP_BANK_Pos   (31U)
#define FLASH_OPTCR_SWAP_BANK_Msk   (0x1UL << FLASH_OPTCR_SWAP_BANK_Pos)
#define FLASH_OPTCR_SWAP_BANK   FLASH_OPTCR_SWAP_BANK_Msk
#define FLASH_OPTSR_OPT_BUSY_Pos   (0U)
#define FLASH_OPTSR_OPT_BUSY_Msk   (0x1UL << FLASH_OPTSR_OPT_BUSY_Pos)
#define FLASH_OPTSR_OPT_BUSY   FLASH_OPTSR_OPT_BUSY_Msk
#define FLASH_OPTSR_BOR_LEV_Pos   (2U)
#define FLASH_OPTSR_BOR_LEV_Msk   (0x3UL << FLASH_OPTSR_BOR_LEV_Pos)
#define FLASH_OPTSR_BOR_LEV   FLASH_OPTSR_BOR_LEV_Msk
#define FLASH_OPTSR_BOR_LEV_0   (0x1UL << FLASH_OPTSR_BOR_LEV_Pos)
#define FLASH_OPTSR_BOR_LEV_1   (0x2UL << FLASH_OPTSR_BOR_LEV_Pos)
#define FLASH_OPTSR_IWDG1_SW_Pos   (4U)
#define FLASH_OPTSR_IWDG1_SW_Msk   (0x1UL << FLASH_OPTSR_IWDG1_SW_Pos)
#define FLASH_OPTSR_IWDG1_SW   FLASH_OPTSR_IWDG1_SW_Msk
#define FLASH_OPTSR_NRST_STOP_D1_Pos   (6U)
#define FLASH_OPTSR_NRST_STOP_D1_Msk   (0x1UL << FLASH_OPTSR_NRST_STOP_D1_Pos)
#define FLASH_OPTSR_NRST_STOP_D1   FLASH_OPTSR_NRST_STOP_D1_Msk
#define FLASH_OPTSR_NRST_STBY_D1_Pos   (7U)
#define FLASH_OPTSR_NRST_STBY_D1_Msk   (0x1UL << FLASH_OPTSR_NRST_STBY_D1_Pos)
#define FLASH_OPTSR_NRST_STBY_D1   FLASH_OPTSR_NRST_STBY_D1_Msk
#define FLASH_OPTSR_RDP_Pos   (8U)
#define FLASH_OPTSR_RDP_Msk   (0xFFUL << FLASH_OPTSR_RDP_Pos)
#define FLASH_OPTSR_RDP   FLASH_OPTSR_RDP_Msk
#define FLASH_OPTSR_VDDMMC_HSLV_Pos   (16U)
#define FLASH_OPTSR_VDDMMC_HSLV_Msk   (0x1UL << FLASH_OPTSR_VDDMMC_HSLV_Pos)
#define FLASH_OPTSR_VDDMMC_HSLV   FLASH_OPTSR_VDDMMC_HSLV_Msk
#define FLASH_OPTSR_FZ_IWDG_STOP_Pos   (17U)
#define FLASH_OPTSR_FZ_IWDG_STOP_Msk   (0x1UL << FLASH_OPTSR_FZ_IWDG_STOP_Pos)
#define FLASH_OPTSR_FZ_IWDG_STOP   FLASH_OPTSR_FZ_IWDG_STOP_Msk
#define FLASH_OPTSR_FZ_IWDG_SDBY_Pos   (18U)
#define FLASH_OPTSR_FZ_IWDG_SDBY_Msk   (0x1UL << FLASH_OPTSR_FZ_IWDG_SDBY_Pos)
#define FLASH_OPTSR_FZ_IWDG_SDBY   FLASH_OPTSR_FZ_IWDG_SDBY_Msk
#define FLASH_OPTSR_ST_RAM_SIZE_Pos   (19U)
#define FLASH_OPTSR_ST_RAM_SIZE_Msk   (0x3UL << FLASH_OPTSR_ST_RAM_SIZE_Pos)
#define FLASH_OPTSR_ST_RAM_SIZE   FLASH_OPTSR_ST_RAM_SIZE_Msk
#define FLASH_OPTSR_ST_RAM_SIZE_0   (0x1UL << FLASH_OPTSR_ST_RAM_SIZE_Pos)
#define FLASH_OPTSR_ST_RAM_SIZE_1   (0x2UL << FLASH_OPTSR_ST_RAM_SIZE_Pos)
#define FLASH_OPTSR_SECURITY_Pos   (21U)
#define FLASH_OPTSR_SECURITY_Msk   (0x1UL << FLASH_OPTSR_SECURITY_Pos)
#define FLASH_OPTSR_SECURITY   FLASH_OPTSR_SECURITY_Msk
#define FLASH_OPTSR_IO_HSLV_Pos   (29U)
#define FLASH_OPTSR_IO_HSLV_Msk   (0x1UL << FLASH_OPTSR_IO_HSLV_Pos)
#define FLASH_OPTSR_IO_HSLV   FLASH_OPTSR_IO_HSLV_Msk
#define FLASH_OPTSR_OPTCHANGEERR_Pos   (30U)
#define FLASH_OPTSR_OPTCHANGEERR_Msk   (0x1UL << FLASH_OPTSR_OPTCHANGEERR_Pos)
#define FLASH_OPTSR_OPTCHANGEERR   FLASH_OPTSR_OPTCHANGEERR_Msk
#define FLASH_OPTSR_SWAP_BANK_OPT_Pos   (31U)
#define FLASH_OPTSR_SWAP_BANK_OPT_Msk   (0x1UL << FLASH_OPTSR_SWAP_BANK_OPT_Pos)
#define FLASH_OPTSR_SWAP_BANK_OPT   FLASH_OPTSR_SWAP_BANK_OPT_Msk
#define FLASH_OPTCCR_CLR_OPTCHANGEERR_Pos   (30U)
#define FLASH_OPTCCR_CLR_OPTCHANGEERR_Msk   (0x1UL << FLASH_OPTCCR_CLR_OPTCHANGEERR_Pos)
#define FLASH_OPTCCR_CLR_OPTCHANGEERR   FLASH_OPTCCR_CLR_OPTCHANGEERR_Msk
#define FLASH_PRAR_PROT_AREA_START_Pos   (0U)
#define FLASH_PRAR_PROT_AREA_START_Msk   (0xFFFUL << FLASH_PRAR_PROT_AREA_START_Pos)
#define FLASH_PRAR_PROT_AREA_START   FLASH_PRAR_PROT_AREA_START_Msk
#define FLASH_PRAR_PROT_AREA_END_Pos   (16U)
#define FLASH_PRAR_PROT_AREA_END_Msk   (0xFFFUL << FLASH_PRAR_PROT_AREA_END_Pos)
#define FLASH_PRAR_PROT_AREA_END   FLASH_PRAR_PROT_AREA_END_Msk
#define FLASH_PRAR_DMEP_Pos   (31U)
#define FLASH_PRAR_DMEP_Msk   (0x1UL << FLASH_PRAR_DMEP_Pos)
#define FLASH_PRAR_DMEP   FLASH_PRAR_DMEP_Msk
#define FLASH_SCAR_SEC_AREA_START_Pos   (0U)
#define FLASH_SCAR_SEC_AREA_START_Msk   (0xFFFUL << FLASH_SCAR_SEC_AREA_START_Pos)
#define FLASH_SCAR_SEC_AREA_START   FLASH_SCAR_SEC_AREA_START_Msk
#define FLASH_SCAR_SEC_AREA_END_Pos   (16U)
#define FLASH_SCAR_SEC_AREA_END_Msk   (0xFFFUL << FLASH_SCAR_SEC_AREA_END_Pos)
#define FLASH_SCAR_SEC_AREA_END   FLASH_SCAR_SEC_AREA_END_Msk
#define FLASH_SCAR_DMES_Pos   (31U)
#define FLASH_SCAR_DMES_Msk   (0x1UL << FLASH_SCAR_DMES_Pos)
#define FLASH_SCAR_DMES   FLASH_SCAR_DMES_Msk
#define FLASH_WPSN_WRPSN_Pos   (0U)
#define FLASH_WPSN_WRPSN_Msk   (0xFFFFFFFFUL << FLASH_WPSN_WRPSN_Pos)
#define FLASH_WPSN_WRPSN   FLASH_WPSN_WRPSN_Msk
#define FLASH_BOOT_ADD0_Pos   (0U)
#define FLASH_BOOT_ADD0_Msk   (0xFFFFUL << FLASH_BOOT_ADD0_Pos)
#define FLASH_BOOT_ADD0   FLASH_BOOT_ADD0_Msk
#define FLASH_BOOT_ADD1_Pos   (16U)
#define FLASH_BOOT_ADD1_Msk   (0xFFFFUL << FLASH_BOOT_ADD1_Pos)
#define FLASH_BOOT_ADD1   FLASH_BOOT_ADD1_Msk
#define FLASH_CRCCR_CRC_SECT_Pos   (0U)
#define FLASH_CRCCR_CRC_SECT_Msk   (0x3FUL << FLASH_CRCCR_CRC_SECT_Pos)
#define FLASH_CRCCR_CRC_SECT   FLASH_CRCCR_CRC_SECT_Msk
#define FLASH_CRCCR_CRC_BY_SECT_Pos   (8U)
#define FLASH_CRCCR_CRC_BY_SECT_Msk   (0x1UL << FLASH_CRCCR_CRC_BY_SECT_Pos)
#define FLASH_CRCCR_CRC_BY_SECT   FLASH_CRCCR_CRC_BY_SECT_Msk
#define FLASH_CRCCR_ADD_SECT_Pos   (9U)
#define FLASH_CRCCR_ADD_SECT_Msk   (0x1UL << FLASH_CRCCR_ADD_SECT_Pos)
#define FLASH_CRCCR_ADD_SECT   FLASH_CRCCR_ADD_SECT_Msk
#define FLASH_CRCCR_CLEAN_SECT_Pos   (10U)
#define FLASH_CRCCR_CLEAN_SECT_Msk   (0x1UL << FLASH_CRCCR_CLEAN_SECT_Pos)
#define FLASH_CRCCR_CLEAN_SECT   FLASH_CRCCR_CLEAN_SECT_Msk
#define FLASH_CRCCR_START_CRC_Pos   (16U)
#define FLASH_CRCCR_START_CRC_Msk   (0x1UL << FLASH_CRCCR_START_CRC_Pos)
#define FLASH_CRCCR_START_CRC   FLASH_CRCCR_START_CRC_Msk
#define FLASH_CRCCR_CLEAN_CRC_Pos   (17U)
#define FLASH_CRCCR_CLEAN_CRC_Msk   (0x1UL << FLASH_CRCCR_CLEAN_CRC_Pos)
#define FLASH_CRCCR_CLEAN_CRC   FLASH_CRCCR_CLEAN_CRC_Msk
#define FLASH_CRCCR_CRC_BURST_Pos   (20U)
#define FLASH_CRCCR_CRC_BURST_Msk   (0x3UL << FLASH_CRCCR_CRC_BURST_Pos)
#define FLASH_CRCCR_CRC_BURST   FLASH_CRCCR_CRC_BURST_Msk
#define FLASH_CRCCR_CRC_BURST_0   (0x1UL << FLASH_CRCCR_CRC_BURST_Pos)
#define FLASH_CRCCR_CRC_BURST_1   (0x2UL << FLASH_CRCCR_CRC_BURST_Pos)
#define FLASH_CRCCR_ALL_BANK_Pos   (22U)
#define FLASH_CRCCR_ALL_BANK_Msk   (0x1UL << FLASH_CRCCR_ALL_BANK_Pos)
#define FLASH_CRCCR_ALL_BANK   FLASH_CRCCR_ALL_BANK_Msk
#define FLASH_CRCSADD_CRC_START_ADDR_Pos   (0U)
#define FLASH_CRCSADD_CRC_START_ADDR_Msk   (0xFFFFFFFFUL << FLASH_CRCSADD_CRC_START_ADDR_Pos)
#define FLASH_CRCSADD_CRC_START_ADDR   FLASH_CRCSADD_CRC_START_ADDR_Msk
#define FLASH_CRCEADD_CRC_END_ADDR_Pos   (0U)
#define FLASH_CRCEADD_CRC_END_ADDR_Msk   (0xFFFFFFFFUL << FLASH_CRCEADD_CRC_END_ADDR_Pos)
#define FLASH_CRCEADD_CRC_END_ADDR   FLASH_CRCEADD_CRC_END_ADDR_Msk
#define FLASH_CRCDATA_CRC_DATA_Pos   (0U)
#define FLASH_CRCDATA_CRC_DATA_Msk   (0xFFFFFFFFUL << FLASH_CRCDATA_CRC_DATA_Pos)
#define FLASH_CRCDATA_CRC_DATA   FLASH_CRCDATA_CRC_DATA_Msk
#define FLASH_ECC_FA_FAIL_ECC_ADDR_Pos   (0U)
#define FLASH_ECC_FA_FAIL_ECC_ADDR_Msk   (0xFFFFUL << FLASH_ECC_FA_FAIL_ECC_ADDR_Pos)
#define FLASH_ECC_FA_FAIL_ECC_ADDR   FLASH_ECC_FA_FAIL_ECC_ADDR_Msk
#define FLASH_ECC_FA_OTP_FAIL_ECC_Pos   (31U)
#define FLASH_ECC_FA_OTP_FAIL_ECC_Msk   (0x1UL << FLASH_ECC_FA_OTP_FAIL_ECC_Pos)
#define FLASH_ECC_FA_OTP_FAIL_ECC   FLASH_ECC_FA_OTP_FAIL_ECC_Msk
#define FLASH_OTPBL_LOCKBL_Pos   (0U)
#define FLASH_OTPBL_LOCKBL_Msk   (0xFFFFUL << FLASH_OTPBL_LOCKBL_Pos)
#define FLASH_OTPBL_LOCKBL   FLASH_OTPBL_LOCKBL_Msk
#define FMC_BCR1_CCLKEN_Pos   (20U)
#define FMC_BCR1_CCLKEN_Msk   (0x1UL << FMC_BCR1_CCLKEN_Pos)
#define FMC_BCR1_CCLKEN   FMC_BCR1_CCLKEN_Msk
#define FMC_BCR1_WFDIS_Pos   (21U)
#define FMC_BCR1_WFDIS_Msk   (0x1UL << FMC_BCR1_WFDIS_Pos)
#define FMC_BCR1_WFDIS   FMC_BCR1_WFDIS_Msk
#define FMC_BCR1_BMAP_Pos   (24U)
#define FMC_BCR1_BMAP_Msk   (0x3UL << FMC_BCR1_BMAP_Pos)
#define FMC_BCR1_BMAP   FMC_BCR1_BMAP_Msk
#define FMC_BCR1_BMAP_0   (0x1UL << FMC_BCR1_BMAP_Pos)
#define FMC_BCR1_BMAP_1   (0x2UL << FMC_BCR1_BMAP_Pos)
#define FMC_BCR1_FMCEN_Pos   (31U)
#define FMC_BCR1_FMCEN_Msk   (0x1UL << FMC_BCR1_FMCEN_Pos)
#define FMC_BCR1_FMCEN   FMC_BCR1_FMCEN_Msk
#define FMC_BCRx_MBKEN_Pos   (0U)
#define FMC_BCRx_MBKEN_Msk   (0x1UL << FMC_BCRx_MBKEN_Pos)
#define FMC_BCRx_MBKEN   FMC_BCRx_MBKEN_Msk
#define FMC_BCRx_MUXEN_Pos   (1U)
#define FMC_BCRx_MUXEN_Msk   (0x1UL << FMC_BCRx_MUXEN_Pos)
#define FMC_BCRx_MUXEN   FMC_BCRx_MUXEN_Msk
#define FMC_BCRx_MTYP_Pos   (2U)
#define FMC_BCRx_MTYP_Msk   (0x3UL << FMC_BCRx_MTYP_Pos)
#define FMC_BCRx_MTYP   FMC_BCRx_MTYP_Msk
#define FMC_BCRx_MTYP_0   (0x1UL << FMC_BCRx_MTYP_Pos)
#define FMC_BCRx_MTYP_1   (0x2UL << FMC_BCRx_MTYP_Pos)
#define FMC_BCRx_MWID_Pos   (4U)
#define FMC_BCRx_MWID_Msk   (0x3UL << FMC_BCRx_MWID_Pos)
#define FMC_BCRx_MWID   FMC_BCRx_MWID_Msk
#define FMC_BCRx_MWID_0   (0x1UL << FMC_BCRx_MWID_Pos)
#define FMC_BCRx_MWID_1   (0x2UL << FMC_BCRx_MWID_Pos)
#define FMC_BCRx_FACCEN_Pos   (6U)
#define FMC_BCRx_FACCEN_Msk   (0x1UL << FMC_BCRx_FACCEN_Pos)
#define FMC_BCRx_FACCEN   FMC_BCRx_FACCEN_Msk
#define FMC_BCRx_BURSTEN_Pos   (8U)
#define FMC_BCRx_BURSTEN_Msk   (0x1UL << FMC_BCRx_BURSTEN_Pos)
#define FMC_BCRx_BURSTEN   FMC_BCRx_BURSTEN_Msk
#define FMC_BCRx_WAITPOL_Pos   (9U)
#define FMC_BCRx_WAITPOL_Msk   (0x1UL << FMC_BCRx_WAITPOL_Pos)
#define FMC_BCRx_WAITPOL   FMC_BCRx_WAITPOL_Msk
#define FMC_BCRx_WAITCFG_Pos   (11U)
#define FMC_BCRx_WAITCFG_Msk   (0x1UL << FMC_BCRx_WAITCFG_Pos)
#define FMC_BCRx_WAITCFG   FMC_BCRx_WAITCFG_Msk
#define FMC_BCRx_WREN_Pos   (12U)
#define FMC_BCRx_WREN_Msk   (0x1UL << FMC_BCRx_WREN_Pos)
#define FMC_BCRx_WREN   FMC_BCRx_WREN_Msk
#define FMC_BCRx_WAITEN_Pos   (13U)
#define FMC_BCRx_WAITEN_Msk   (0x1UL << FMC_BCRx_WAITEN_Pos)
#define FMC_BCRx_WAITEN   FMC_BCRx_WAITEN_Msk
#define FMC_BCRx_EXTMOD_Pos   (14U)
#define FMC_BCRx_EXTMOD_Msk   (0x1UL << FMC_BCRx_EXTMOD_Pos)
#define FMC_BCRx_EXTMOD   FMC_BCRx_EXTMOD_Msk
#define FMC_BCRx_ASYNCWAIT_Pos   (15U)
#define FMC_BCRx_ASYNCWAIT_Msk   (0x1UL << FMC_BCRx_ASYNCWAIT_Pos)
#define FMC_BCRx_ASYNCWAIT   FMC_BCRx_ASYNCWAIT_Msk
#define FMC_BCRx_CPSIZE_Pos   (16U)
#define FMC_BCRx_CPSIZE_Msk   (0x7UL << FMC_BCRx_CPSIZE_Pos)
#define FMC_BCRx_CPSIZE   FMC_BCRx_CPSIZE_Msk
#define FMC_BCRx_CPSIZE_0   (0x1UL << FMC_BCRx_CPSIZE_Pos)
#define FMC_BCRx_CPSIZE_1   (0x2UL << FMC_BCRx_CPSIZE_Pos)
#define FMC_BCRx_CPSIZE_2   (0x4UL << FMC_BCRx_CPSIZE_Pos)
#define FMC_BCRx_CBURSTRW_Pos   (19U)
#define FMC_BCRx_CBURSTRW_Msk   (0x1UL << FMC_BCRx_CBURSTRW_Pos)
#define FMC_BCRx_CBURSTRW   FMC_BCRx_CBURSTRW_Msk
#define FMC_BTRx_ADDSET_Pos   (0U)
#define FMC_BTRx_ADDSET_Msk   (0xFUL << FMC_BTRx_ADDSET_Pos)
#define FMC_BTRx_ADDSET   FMC_BTRx_ADDSET_Msk
#define FMC_BTRx_ADDSET_0   (0x1UL << FMC_BTRx_ADDSET_Pos)
#define FMC_BTRx_ADDSET_1   (0x2UL << FMC_BTRx_ADDSET_Pos)
#define FMC_BTRx_ADDSET_2   (0x4UL << FMC_BTRx_ADDSET_Pos)
#define FMC_BTRx_ADDSET_3   (0x8UL << FMC_BTRx_ADDSET_Pos)
#define FMC_BTRx_ADDHLD_Pos   (4U)
#define FMC_BTRx_ADDHLD_Msk   (0xFUL << FMC_BTRx_ADDHLD_Pos)
#define FMC_BTRx_ADDHLD   FMC_BTRx_ADDHLD_Msk
#define FMC_BTRx_ADDHLD_0   (0x1UL << FMC_BTRx_ADDHLD_Pos)
#define FMC_BTRx_ADDHLD_1   (0x2UL << FMC_BTRx_ADDHLD_Pos)
#define FMC_BTRx_ADDHLD_2   (0x4UL << FMC_BTRx_ADDHLD_Pos)
#define FMC_BTRx_ADDHLD_3   (0x8UL << FMC_BTRx_ADDHLD_Pos)
#define FMC_BTRx_DATAST_Pos   (8U)
#define FMC_BTRx_DATAST_Msk   (0xFFUL << FMC_BTRx_DATAST_Pos)
#define FMC_BTRx_DATAST   FMC_BTRx_DATAST_Msk
#define FMC_BTRx_DATAST_0   (0x01UL << FMC_BTRx_DATAST_Pos)
#define FMC_BTRx_DATAST_1   (0x02UL << FMC_BTRx_DATAST_Pos)
#define FMC_BTRx_DATAST_2   (0x04UL << FMC_BTRx_DATAST_Pos)
#define FMC_BTRx_DATAST_3   (0x08UL << FMC_BTRx_DATAST_Pos)
#define FMC_BTRx_DATAST_4   (0x10UL << FMC_BTRx_DATAST_Pos)
#define FMC_BTRx_DATAST_5   (0x20UL << FMC_BTRx_DATAST_Pos)
#define FMC_BTRx_DATAST_6   (0x40UL << FMC_BTRx_DATAST_Pos)
#define FMC_BTRx_DATAST_7   (0x80UL << FMC_BTRx_DATAST_Pos)
#define FMC_BTRx_BUSTURN_Pos   (16U)
#define FMC_BTRx_BUSTURN_Msk   (0xFUL << FMC_BTRx_BUSTURN_Pos)
#define FMC_BTRx_BUSTURN   FMC_BTRx_BUSTURN_Msk
#define FMC_BTRx_BUSTURN_0   (0x1UL << FMC_BTRx_BUSTURN_Pos)
#define FMC_BTRx_BUSTURN_1   (0x2UL << FMC_BTRx_BUSTURN_Pos)
#define FMC_BTRx_BUSTURN_2   (0x4UL << FMC_BTRx_BUSTURN_Pos)
#define FMC_BTRx_BUSTURN_3   (0x8UL << FMC_BTRx_BUSTURN_Pos)
#define FMC_BTRx_CLKDIV_Pos   (20U)
#define FMC_BTRx_CLKDIV_Msk   (0xFUL << FMC_BTRx_CLKDIV_Pos)
#define FMC_BTRx_CLKDIV   FMC_BTRx_CLKDIV_Msk
#define FMC_BTRx_CLKDIV_0   (0x1UL << FMC_BTRx_CLKDIV_Pos)
#define FMC_BTRx_CLKDIV_1   (0x2UL << FMC_BTRx_CLKDIV_Pos)
#define FMC_BTRx_CLKDIV_2   (0x4UL << FMC_BTRx_CLKDIV_Pos)
#define FMC_BTRx_CLKDIV_3   (0x8UL << FMC_BTRx_CLKDIV_Pos)
#define FMC_BTRx_DATLAT_Pos   (24U)
#define FMC_BTRx_DATLAT_Msk   (0xFUL << FMC_BTRx_DATLAT_Pos)
#define FMC_BTRx_DATLAT   FMC_BTRx_DATLAT_Msk
#define FMC_BTRx_DATLAT_0   (0x1UL << FMC_BTRx_DATLAT_Pos)
#define FMC_BTRx_DATLAT_1   (0x2UL << FMC_BTRx_DATLAT_Pos)
#define FMC_BTRx_DATLAT_2   (0x4UL << FMC_BTRx_DATLAT_Pos)
#define FMC_BTRx_DATLAT_3   (0x8UL << FMC_BTRx_DATLAT_Pos)
#define FMC_BTRx_ACCMOD_Pos   (28U)
#define FMC_BTRx_ACCMOD_Msk   (0x3UL << FMC_BTRx_ACCMOD_Pos)
#define FMC_BTRx_ACCMOD   FMC_BTRx_ACCMOD_Msk
#define FMC_BTRx_ACCMOD_0   (0x1UL << FMC_BTRx_ACCMOD_Pos)
#define FMC_BTRx_ACCMOD_1   (0x2UL << FMC_BTRx_ACCMOD_Pos)
#define FMC_BWTRx_ADDSET_Pos   (0U)
#define FMC_BWTRx_ADDSET_Msk   (0xFUL << FMC_BWTRx_ADDSET_Pos)
#define FMC_BWTRx_ADDSET   FMC_BWTRx_ADDSET_Msk
#define FMC_BWTRx_ADDSET_0   (0x1UL << FMC_BWTRx_ADDSET_Pos)
#define FMC_BWTRx_ADDSET_1   (0x2UL << FMC_BWTRx_ADDSET_Pos)
#define FMC_BWTRx_ADDSET_2   (0x4UL << FMC_BWTRx_ADDSET_Pos)
#define FMC_BWTRx_ADDSET_3   (0x8UL << FMC_BWTRx_ADDSET_Pos)
#define FMC_BWTRx_ADDHLD_Pos   (4U)
#define FMC_BWTRx_ADDHLD_Msk   (0xFUL << FMC_BWTRx_ADDHLD_Pos)
#define FMC_BWTRx_ADDHLD   FMC_BWTRx_ADDHLD_Msk
#define FMC_BWTRx_ADDHLD_0   (0x1UL << FMC_BWTRx_ADDHLD_Pos)
#define FMC_BWTRx_ADDHLD_1   (0x2UL << FMC_BWTRx_ADDHLD_Pos)
#define FMC_BWTRx_ADDHLD_2   (0x4UL << FMC_BWTRx_ADDHLD_Pos)
#define FMC_BWTRx_ADDHLD_3   (0x8UL << FMC_BWTRx_ADDHLD_Pos)
#define FMC_BWTRx_DATAST_Pos   (8U)
#define FMC_BWTRx_DATAST_Msk   (0xFFUL << FMC_BWTRx_DATAST_Pos)
#define FMC_BWTRx_DATAST   FMC_BWTRx_DATAST_Msk
#define FMC_BWTRx_DATAST_0   (0x01UL << FMC_BWTRx_DATAST_Pos)
#define FMC_BWTRx_DATAST_1   (0x02UL << FMC_BWTRx_DATAST_Pos)
#define FMC_BWTRx_DATAST_2   (0x04UL << FMC_BWTRx_DATAST_Pos)
#define FMC_BWTRx_DATAST_3   (0x08UL << FMC_BWTRx_DATAST_Pos)
#define FMC_BWTRx_DATAST_4   (0x10UL << FMC_BWTRx_DATAST_Pos)
#define FMC_BWTRx_DATAST_5   (0x20UL << FMC_BWTRx_DATAST_Pos)
#define FMC_BWTRx_DATAST_6   (0x40UL << FMC_BWTRx_DATAST_Pos)
#define FMC_BWTRx_DATAST_7   (0x80UL << FMC_BWTRx_DATAST_Pos)
#define FMC_BWTRx_BUSTURN_Pos   (16U)
#define FMC_BWTRx_BUSTURN_Msk   (0xFUL << FMC_BWTRx_BUSTURN_Pos)
#define FMC_BWTRx_BUSTURN   FMC_BWTRx_BUSTURN_Msk
#define FMC_BWTRx_BUSTURN_0   (0x1UL << FMC_BWTRx_BUSTURN_Pos)
#define FMC_BWTRx_BUSTURN_1   (0x2UL << FMC_BWTRx_BUSTURN_Pos)
#define FMC_BWTRx_BUSTURN_2   (0x4UL << FMC_BWTRx_BUSTURN_Pos)
#define FMC_BWTRx_BUSTURN_3   (0x8UL << FMC_BWTRx_BUSTURN_Pos)
#define FMC_BWTRx_ACCMOD_Pos   (28U)
#define FMC_BWTRx_ACCMOD_Msk   (0x3UL << FMC_BWTRx_ACCMOD_Pos)
#define FMC_BWTRx_ACCMOD   FMC_BWTRx_ACCMOD_Msk
#define FMC_BWTRx_ACCMOD_0   (0x1UL << FMC_BWTRx_ACCMOD_Pos)
#define FMC_BWTRx_ACCMOD_1   (0x2UL << FMC_BWTRx_ACCMOD_Pos)
#define FMC_PCR_PWAITEN_Pos   (1U)
#define FMC_PCR_PWAITEN_Msk   (0x1UL << FMC_PCR_PWAITEN_Pos)
#define FMC_PCR_PWAITEN   FMC_PCR_PWAITEN_Msk
#define FMC_PCR_PBKEN_Pos   (2U)
#define FMC_PCR_PBKEN_Msk   (0x1UL << FMC_PCR_PBKEN_Pos)
#define FMC_PCR_PBKEN   FMC_PCR_PBKEN_Msk
#define FMC_PCR_PWID_Pos   (4U)
#define FMC_PCR_PWID_Msk   (0x3UL << FMC_PCR_PWID_Pos)
#define FMC_PCR_PWID   FMC_PCR_PWID_Msk
#define FMC_PCR_PWID_0   (0x1UL << FMC_PCR_PWID_Pos)
#define FMC_PCR_PWID_1   (0x2UL << FMC_PCR_PWID_Pos)
#define FMC_PCR_ECCEN_Pos   (6U)
#define FMC_PCR_ECCEN_Msk   (0x1UL << FMC_PCR_ECCEN_Pos)
#define FMC_PCR_ECCEN   FMC_PCR_ECCEN_Msk
#define FMC_PCR_TCLR_Pos   (9U)
#define FMC_PCR_TCLR_Msk   (0xFUL << FMC_PCR_TCLR_Pos)
#define FMC_PCR_TCLR   FMC_PCR_TCLR_Msk
#define FMC_PCR_TCLR_0   (0x1UL << FMC_PCR_TCLR_Pos)
#define FMC_PCR_TCLR_1   (0x2UL << FMC_PCR_TCLR_Pos)
#define FMC_PCR_TCLR_2   (0x4UL << FMC_PCR_TCLR_Pos)
#define FMC_PCR_TCLR_3   (0x8UL << FMC_PCR_TCLR_Pos)
#define FMC_PCR_TAR_Pos   (13U)
#define FMC_PCR_TAR_Msk   (0xFUL << FMC_PCR_TAR_Pos)
#define FMC_PCR_TAR   FMC_PCR_TAR_Msk
#define FMC_PCR_TAR_0   (0x1UL << FMC_PCR_TAR_Pos)
#define FMC_PCR_TAR_1   (0x2UL << FMC_PCR_TAR_Pos)
#define FMC_PCR_TAR_2   (0x4UL << FMC_PCR_TAR_Pos)
#define FMC_PCR_TAR_3   (0x8UL << FMC_PCR_TAR_Pos)
#define FMC_PCR_ECCPS_Pos   (17U)
#define FMC_PCR_ECCPS_Msk   (0x7UL << FMC_PCR_ECCPS_Pos)
#define FMC_PCR_ECCPS   FMC_PCR_ECCPS_Msk
#define FMC_PCR_ECCPS_0   (0x1UL << FMC_PCR_ECCPS_Pos)
#define FMC_PCR_ECCPS_1   (0x2UL << FMC_PCR_ECCPS_Pos)
#define FMC_PCR_ECCPS_2   (0x4UL << FMC_PCR_ECCPS_Pos)
#define FMC_SR_IRS_Pos   (0U)
#define FMC_SR_IRS_Msk   (0x1UL << FMC_SR_IRS_Pos)
#define FMC_SR_IRS   FMC_SR_IRS_Msk
#define FMC_SR_ILS_Pos   (1U)
#define FMC_SR_ILS_Msk   (0x1UL << FMC_SR_ILS_Pos)
#define FMC_SR_ILS   FMC_SR_ILS_Msk
#define FMC_SR_IFS_Pos   (2U)
#define FMC_SR_IFS_Msk   (0x1UL << FMC_SR_IFS_Pos)
#define FMC_SR_IFS   FMC_SR_IFS_Msk
#define FMC_SR_IREN_Pos   (3U)
#define FMC_SR_IREN_Msk   (0x1UL << FMC_SR_IREN_Pos)
#define FMC_SR_IREN   FMC_SR_IREN_Msk
#define FMC_SR_ILEN_Pos   (4U)
#define FMC_SR_ILEN_Msk   (0x1UL << FMC_SR_ILEN_Pos)
#define FMC_SR_ILEN   FMC_SR_ILEN_Msk
#define FMC_SR_IFEN_Pos   (5U)
#define FMC_SR_IFEN_Msk   (0x1UL << FMC_SR_IFEN_Pos)
#define FMC_SR_IFEN   FMC_SR_IFEN_Msk
#define FMC_SR_FEMPT_Pos   (6U)
#define FMC_SR_FEMPT_Msk   (0x1UL << FMC_SR_FEMPT_Pos)
#define FMC_SR_FEMPT   FMC_SR_FEMPT_Msk
#define FMC_PMEM_MEMSET_Pos   (0U)
#define FMC_PMEM_MEMSET_Msk   (0xFFUL << FMC_PMEM_MEMSET_Pos)
#define FMC_PMEM_MEMSET   FMC_PMEM_MEMSET_Msk
#define FMC_PMEM_MEMSET_0   (0x01UL << FMC_PMEM_MEMSET_Pos)
#define FMC_PMEM_MEMSET_1   (0x02UL << FMC_PMEM_MEMSET_Pos)
#define FMC_PMEM_MEMSET_2   (0x04UL << FMC_PMEM_MEMSET_Pos)
#define FMC_PMEM_MEMSET_3   (0x08UL << FMC_PMEM_MEMSET_Pos)
#define FMC_PMEM_MEMSET_4   (0x10UL << FMC_PMEM_MEMSET_Pos)
#define FMC_PMEM_MEMSET_5   (0x20UL << FMC_PMEM_MEMSET_Pos)
#define FMC_PMEM_MEMSET_6   (0x40UL << FMC_PMEM_MEMSET_Pos)
#define FMC_PMEM_MEMSET_7   (0x80UL << FMC_PMEM_MEMSET_Pos)
#define FMC_PMEM_MEMWAIT_Pos   (8U)
#define FMC_PMEM_MEMWAIT_Msk   (0xFFUL << FMC_PMEM_MEMWAIT_Pos)
#define FMC_PMEM_MEMWAIT   FMC_PMEM_MEMWAIT_Msk
#define FMC_PMEM_MEMWAIT_0   (0x01UL << FMC_PMEM_MEMWAIT_Pos)
#define FMC_PMEM_MEMWAIT_1   (0x02UL << FMC_PMEM_MEMWAIT_Pos)
#define FMC_PMEM_MEMWAIT_2   (0x04UL << FMC_PMEM_MEMWAIT_Pos)
#define FMC_PMEM_MEMWAIT_3   (0x08UL << FMC_PMEM_MEMWAIT_Pos)
#define FMC_PMEM_MEMWAIT_4   (0x10UL << FMC_PMEM_MEMWAIT_Pos)
#define FMC_PMEM_MEMWAIT_5   (0x20UL << FMC_PMEM_MEMWAIT_Pos)
#define FMC_PMEM_MEMWAIT_6   (0x40UL << FMC_PMEM_MEMWAIT_Pos)
#define FMC_PMEM_MEMWAIT_7   (0x80UL << FMC_PMEM_MEMWAIT_Pos)
#define FMC_PMEM_MEMHOLD_Pos   (16U)
#define FMC_PMEM_MEMHOLD_Msk   (0xFFUL << FMC_PMEM_MEMHOLD_Pos)
#define FMC_PMEM_MEMHOLD   FMC_PMEM_MEMHOLD_Msk
#define FMC_PMEM_MEMHOLD_0   (0x01UL << FMC_PMEM_MEMHOLD_Pos)
#define FMC_PMEM_MEMHOLD_1   (0x02UL << FMC_PMEM_MEMHOLD_Pos)
#define FMC_PMEM_MEMHOLD_2   (0x04UL << FMC_PMEM_MEMHOLD_Pos)
#define FMC_PMEM_MEMHOLD_3   (0x08UL << FMC_PMEM_MEMHOLD_Pos)
#define FMC_PMEM_MEMHOLD_4   (0x10UL << FMC_PMEM_MEMHOLD_Pos)
#define FMC_PMEM_MEMHOLD_5   (0x20UL << FMC_PMEM_MEMHOLD_Pos)
#define FMC_PMEM_MEMHOLD_6   (0x40UL << FMC_PMEM_MEMHOLD_Pos)
#define FMC_PMEM_MEMHOLD_7   (0x80UL << FMC_PMEM_MEMHOLD_Pos)
#define FMC_PMEM_MEMHIZ_Pos   (24U)
#define FMC_PMEM_MEMHIZ_Msk   (0xFFUL << FMC_PMEM_MEMHIZ_Pos)
#define FMC_PMEM_MEMHIZ   FMC_PMEM_MEMHIZ_Msk
#define FMC_PMEM_MEMHIZ_0   (0x01UL << FMC_PMEM_MEMHIZ_Pos)
#define FMC_PMEM_MEMHIZ_1   (0x02UL << FMC_PMEM_MEMHIZ_Pos)
#define FMC_PMEM_MEMHIZ_2   (0x04UL << FMC_PMEM_MEMHIZ_Pos)
#define FMC_PMEM_MEMHIZ_3   (0x08UL << FMC_PMEM_MEMHIZ_Pos)
#define FMC_PMEM_MEMHIZ_4   (0x10UL << FMC_PMEM_MEMHIZ_Pos)
#define FMC_PMEM_MEMHIZ_5   (0x20UL << FMC_PMEM_MEMHIZ_Pos)
#define FMC_PMEM_MEMHIZ_6   (0x40UL << FMC_PMEM_MEMHIZ_Pos)
#define FMC_PMEM_MEMHIZ_7   (0x80UL << FMC_PMEM_MEMHIZ_Pos)
#define FMC_PATT_ATTSET_Pos   (0U)
#define FMC_PATT_ATTSET_Msk   (0xFFUL << FMC_PATT_ATTSET_Pos)
#define FMC_PATT_ATTSET   FMC_PATT_ATTSET_Msk
#define FMC_PATT_ATTSET_0   (0x01UL << FMC_PATT_ATTSET_Pos)
#define FMC_PATT_ATTSET_1   (0x02UL << FMC_PATT_ATTSET_Pos)
#define FMC_PATT_ATTSET_2   (0x04UL << FMC_PATT_ATTSET_Pos)
#define FMC_PATT_ATTSET_3   (0x08UL << FMC_PATT_ATTSET_Pos)
#define FMC_PATT_ATTSET_4   (0x10UL << FMC_PATT_ATTSET_Pos)
#define FMC_PATT_ATTSET_5   (0x20UL << FMC_PATT_ATTSET_Pos)
#define FMC_PATT_ATTSET_6   (0x40UL << FMC_PATT_ATTSET_Pos)
#define FMC_PATT_ATTSET_7   (0x80UL << FMC_PATT_ATTSET_Pos)
#define FMC_PATT_ATTWAIT_Pos   (8U)
#define FMC_PATT_ATTWAIT_Msk   (0xFFUL << FMC_PATT_ATTWAIT_Pos)
#define FMC_PATT_ATTWAIT   FMC_PATT_ATTWAIT_Msk
#define FMC_PATT_ATTWAIT_0   (0x01UL << FMC_PATT_ATTWAIT_Pos)
#define FMC_PATT_ATTWAIT_1   (0x02UL << FMC_PATT_ATTWAIT_Pos)
#define FMC_PATT_ATTWAIT_2   (0x04UL << FMC_PATT_ATTWAIT_Pos)
#define FMC_PATT_ATTWAIT_3   (0x08UL << FMC_PATT_ATTWAIT_Pos)
#define FMC_PATT_ATTWAIT_4   (0x10UL << FMC_PATT_ATTWAIT_Pos)
#define FMC_PATT_ATTWAIT_5   (0x20UL << FMC_PATT_ATTWAIT_Pos)
#define FMC_PATT_ATTWAIT_6   (0x40UL << FMC_PATT_ATTWAIT_Pos)
#define FMC_PATT_ATTWAIT_7   (0x80UL << FMC_PATT_ATTWAIT_Pos)
#define FMC_PATT_ATTHOLD_Pos   (16U)
#define FMC_PATT_ATTHOLD_Msk   (0xFFUL << FMC_PATT_ATTHOLD_Pos)
#define FMC_PATT_ATTHOLD   FMC_PATT_ATTHOLD_Msk
#define FMC_PATT_ATTHOLD_0   (0x01UL << FMC_PATT_ATTHOLD_Pos)
#define FMC_PATT_ATTHOLD_1   (0x02UL << FMC_PATT_ATTHOLD_Pos)
#define FMC_PATT_ATTHOLD_2   (0x04UL << FMC_PATT_ATTHOLD_Pos)
#define FMC_PATT_ATTHOLD_3   (0x08UL << FMC_PATT_ATTHOLD_Pos)
#define FMC_PATT_ATTHOLD_4   (0x10UL << FMC_PATT_ATTHOLD_Pos)
#define FMC_PATT_ATTHOLD_5   (0x20UL << FMC_PATT_ATTHOLD_Pos)
#define FMC_PATT_ATTHOLD_6   (0x40UL << FMC_PATT_ATTHOLD_Pos)
#define FMC_PATT_ATTHOLD_7   (0x80UL << FMC_PATT_ATTHOLD_Pos)
#define FMC_PATT_ATTHIZ_Pos   (24U)
#define FMC_PATT_ATTHIZ_Msk   (0xFFUL << FMC_PATT_ATTHIZ_Pos)
#define FMC_PATT_ATTHIZ   FMC_PATT_ATTHIZ_Msk
#define FMC_PATT_ATTHIZ_0   (0x01UL << FMC_PATT_ATTHIZ_Pos)
#define FMC_PATT_ATTHIZ_1   (0x02UL << FMC_PATT_ATTHIZ_Pos)
#define FMC_PATT_ATTHIZ_2   (0x04UL << FMC_PATT_ATTHIZ_Pos)
#define FMC_PATT_ATTHIZ_3   (0x08UL << FMC_PATT_ATTHIZ_Pos)
#define FMC_PATT_ATTHIZ_4   (0x10UL << FMC_PATT_ATTHIZ_Pos)
#define FMC_PATT_ATTHIZ_5   (0x20UL << FMC_PATT_ATTHIZ_Pos)
#define FMC_PATT_ATTHIZ_6   (0x40UL << FMC_PATT_ATTHIZ_Pos)
#define FMC_PATT_ATTHIZ_7   (0x80UL << FMC_PATT_ATTHIZ_Pos)
#define FMC_ECCR3_ECC3_Pos   (0U)
#define FMC_ECCR3_ECC3_Msk   (0xFFFFFFFFUL << FMC_ECCR3_ECC3_Pos)
#define FMC_ECCR3_ECC3   FMC_ECCR3_ECC3_Msk
#define FMC_SDCRx_NC_Pos   (0U)
#define FMC_SDCRx_NC_Msk   (0x3UL << FMC_SDCRx_NC_Pos)
#define FMC_SDCRx_NC   FMC_SDCRx_NC_Msk
#define FMC_SDCRx_NC_0   (0x1UL << FMC_SDCRx_NC_Pos)
#define FMC_SDCRx_NC_1   (0x2UL << FMC_SDCRx_NC_Pos)
#define FMC_SDCRx_NR_Pos   (2U)
#define FMC_SDCRx_NR_Msk   (0x3UL << FMC_SDCRx_NR_Pos)
#define FMC_SDCRx_NR   FMC_SDCRx_NR_Msk
#define FMC_SDCRx_NR_0   (0x1UL << FMC_SDCRx_NR_Pos)
#define FMC_SDCRx_NR_1   (0x2UL << FMC_SDCRx_NR_Pos)
#define FMC_SDCRx_MWID_Pos   (4U)
#define FMC_SDCRx_MWID_Msk   (0x3UL << FMC_SDCRx_MWID_Pos)
#define FMC_SDCRx_MWID   FMC_SDCRx_MWID_Msk
#define FMC_SDCRx_MWID_0   (0x1UL << FMC_SDCRx_MWID_Pos)
#define FMC_SDCRx_MWID_1   (0x2UL << FMC_SDCRx_MWID_Pos)
#define FMC_SDCRx_NB_Pos   (6U)
#define FMC_SDCRx_NB_Msk   (0x1UL << FMC_SDCRx_NB_Pos)
#define FMC_SDCRx_NB   FMC_SDCRx_NB_Msk
#define FMC_SDCRx_CAS_Pos   (7U)
#define FMC_SDCRx_CAS_Msk   (0x3UL << FMC_SDCRx_CAS_Pos)
#define FMC_SDCRx_CAS   FMC_SDCRx_CAS_Msk
#define FMC_SDCRx_CAS_0   (0x1UL << FMC_SDCRx_CAS_Pos)
#define FMC_SDCRx_CAS_1   (0x2UL << FMC_SDCRx_CAS_Pos)
#define FMC_SDCRx_WP_Pos   (9U)
#define FMC_SDCRx_WP_Msk   (0x1UL << FMC_SDCRx_WP_Pos)
#define FMC_SDCRx_WP   FMC_SDCRx_WP_Msk
#define FMC_SDCRx_SDCLK_Pos   (10U)
#define FMC_SDCRx_SDCLK_Msk   (0x3UL << FMC_SDCRx_SDCLK_Pos)
#define FMC_SDCRx_SDCLK   FMC_SDCRx_SDCLK_Msk
#define FMC_SDCRx_SDCLK_0   (0x1UL << FMC_SDCRx_SDCLK_Pos)
#define FMC_SDCRx_SDCLK_1   (0x2UL << FMC_SDCRx_SDCLK_Pos)
#define FMC_SDCRx_RBURST_Pos   (12U)
#define FMC_SDCRx_RBURST_Msk   (0x1UL << FMC_SDCRx_RBURST_Pos)
#define FMC_SDCRx_RBURST   FMC_SDCRx_RBURST_Msk
#define FMC_SDCRx_RPIPE_Pos   (13U)
#define FMC_SDCRx_RPIPE_Msk   (0x3UL << FMC_SDCRx_RPIPE_Pos)
#define FMC_SDCRx_RPIPE   FMC_SDCRx_RPIPE_Msk
#define FMC_SDCRx_RPIPE_0   (0x1UL << FMC_SDCRx_RPIPE_Pos)
#define FMC_SDCRx_RPIPE_1   (0x2UL << FMC_SDCRx_RPIPE_Pos)
#define FMC_SDTRx_TMRD_Pos   (0U)
#define FMC_SDTRx_TMRD_Msk   (0xFUL << FMC_SDTRx_TMRD_Pos)
#define FMC_SDTRx_TMRD   FMC_SDTRx_TMRD_Msk
#define FMC_SDTRx_TMRD_0   (0x1UL << FMC_SDTRx_TMRD_Pos)
#define FMC_SDTRx_TMRD_1   (0x2UL << FMC_SDTRx_TMRD_Pos)
#define FMC_SDTRx_TMRD_2   (0x4UL << FMC_SDTRx_TMRD_Pos)
#define FMC_SDTRx_TMRD_3   (0x8UL << FMC_SDTRx_TMRD_Pos)
#define FMC_SDTRx_TXSR_Pos   (4U)
#define FMC_SDTRx_TXSR_Msk   (0xFUL << FMC_SDTRx_TXSR_Pos)
#define FMC_SDTRx_TXSR   FMC_SDTRx_TXSR_Msk
#define FMC_SDTRx_TXSR_0   (0x1UL << FMC_SDTRx_TXSR_Pos)
#define FMC_SDTRx_TXSR_1   (0x2UL << FMC_SDTRx_TXSR_Pos)
#define FMC_SDTRx_TXSR_2   (0x4UL << FMC_SDTRx_TXSR_Pos)
#define FMC_SDTRx_TXSR_3   (0x8UL << FMC_SDTRx_TXSR_Pos)
#define FMC_SDTRx_TRAS_Pos   (8U)
#define FMC_SDTRx_TRAS_Msk   (0xFUL << FMC_SDTRx_TRAS_Pos)
#define FMC_SDTRx_TRAS   FMC_SDTRx_TRAS_Msk
#define FMC_SDTRx_TRAS_0   (0x1UL << FMC_SDTRx_TRAS_Pos)
#define FMC_SDTRx_TRAS_1   (0x2UL << FMC_SDTRx_TRAS_Pos)
#define FMC_SDTRx_TRAS_2   (0x4UL << FMC_SDTRx_TRAS_Pos)
#define FMC_SDTRx_TRAS_3   (0x8UL << FMC_SDTRx_TRAS_Pos)
#define FMC_SDTRx_TRC_Pos   (12U)
#define FMC_SDTRx_TRC_Msk   (0xFUL << FMC_SDTRx_TRC_Pos)
#define FMC_SDTRx_TRC   FMC_SDTRx_TRC_Msk
#define FMC_SDTRx_TRC_0   (0x1UL << FMC_SDTRx_TRC_Pos)
#define FMC_SDTRx_TRC_1   (0x2UL << FMC_SDTRx_TRC_Pos)
#define FMC_SDTRx_TRC_2   (0x4UL << FMC_SDTRx_TRC_Pos)
#define FMC_SDTRx_TWR_Pos   (16U)
#define FMC_SDTRx_TWR_Msk   (0xFUL << FMC_SDTRx_TWR_Pos)
#define FMC_SDTRx_TWR   FMC_SDTRx_TWR_Msk
#define FMC_SDTRx_TWR_0   (0x1UL << FMC_SDTRx_TWR_Pos)
#define FMC_SDTRx_TWR_1   (0x2UL << FMC_SDTRx_TWR_Pos)
#define FMC_SDTRx_TWR_2   (0x4UL << FMC_SDTRx_TWR_Pos)
#define FMC_SDTRx_TRP_Pos   (20U)
#define FMC_SDTRx_TRP_Msk   (0xFUL << FMC_SDTRx_TRP_Pos)
#define FMC_SDTRx_TRP   FMC_SDTRx_TRP_Msk
#define FMC_SDTRx_TRP_0   (0x1UL << FMC_SDTRx_TRP_Pos)
#define FMC_SDTRx_TRP_1   (0x2UL << FMC_SDTRx_TRP_Pos)
#define FMC_SDTRx_TRP_2   (0x4UL << FMC_SDTRx_TRP_Pos)
#define FMC_SDTRx_TRCD_Pos   (24U)
#define FMC_SDTRx_TRCD_Msk   (0xFUL << FMC_SDTRx_TRCD_Pos)
#define FMC_SDTRx_TRCD   FMC_SDTRx_TRCD_Msk
#define FMC_SDTRx_TRCD_0   (0x1UL << FMC_SDTRx_TRCD_Pos)
#define FMC_SDTRx_TRCD_1   (0x2UL << FMC_SDTRx_TRCD_Pos)
#define FMC_SDTRx_TRCD_2   (0x4UL << FMC_SDTRx_TRCD_Pos)
#define FMC_SDCMR_MODE_Pos   (0U)
#define FMC_SDCMR_MODE_Msk   (0x7UL << FMC_SDCMR_MODE_Pos)
#define FMC_SDCMR_MODE   FMC_SDCMR_MODE_Msk
#define FMC_SDCMR_MODE_0   (0x1UL << FMC_SDCMR_MODE_Pos)
#define FMC_SDCMR_MODE_1   (0x2UL << FMC_SDCMR_MODE_Pos)
#define FMC_SDCMR_MODE_2   (0x4UL << FMC_SDCMR_MODE_Pos)
#define FMC_SDCMR_CTB2_Pos   (3U)
#define FMC_SDCMR_CTB2_Msk   (0x1UL << FMC_SDCMR_CTB2_Pos)
#define FMC_SDCMR_CTB2   FMC_SDCMR_CTB2_Msk
#define FMC_SDCMR_CTB1_Pos   (4U)
#define FMC_SDCMR_CTB1_Msk   (0x1UL << FMC_SDCMR_CTB1_Pos)
#define FMC_SDCMR_CTB1   FMC_SDCMR_CTB1_Msk
#define FMC_SDCMR_NRFS_Pos   (5U)
#define FMC_SDCMR_NRFS_Msk   (0xFUL << FMC_SDCMR_NRFS_Pos)
#define FMC_SDCMR_NRFS   FMC_SDCMR_NRFS_Msk
#define FMC_SDCMR_NRFS_0   (0x1UL << FMC_SDCMR_NRFS_Pos)
#define FMC_SDCMR_NRFS_1   (0x2UL << FMC_SDCMR_NRFS_Pos)
#define FMC_SDCMR_NRFS_2   (0x4UL << FMC_SDCMR_NRFS_Pos)
#define FMC_SDCMR_NRFS_3   (0x8UL << FMC_SDCMR_NRFS_Pos)
#define FMC_SDCMR_MRD_Pos   (9U)
#define FMC_SDCMR_MRD_Msk   (0x1FFFUL << FMC_SDCMR_MRD_Pos)
#define FMC_SDCMR_MRD   FMC_SDCMR_MRD_Msk
#define FMC_SDRTR_CRE_Pos   (0U)
#define FMC_SDRTR_CRE_Msk   (0x1UL << FMC_SDRTR_CRE_Pos)
#define FMC_SDRTR_CRE   FMC_SDRTR_CRE_Msk
#define FMC_SDRTR_COUNT_Pos   (1U)
#define FMC_SDRTR_COUNT_Msk   (0x1FFFUL << FMC_SDRTR_COUNT_Pos)
#define FMC_SDRTR_COUNT   FMC_SDRTR_COUNT_Msk
#define FMC_SDRTR_REIE_Pos   (14U)
#define FMC_SDRTR_REIE_Msk   (0x1UL << FMC_SDRTR_REIE_Pos)
#define FMC_SDRTR_REIE   FMC_SDRTR_REIE_Msk
#define FMC_SDSR_RE_Pos   (0U)
#define FMC_SDSR_RE_Msk   (0x1UL << FMC_SDSR_RE_Pos)
#define FMC_SDSR_RE   FMC_SDSR_RE_Msk
#define FMC_SDSR_MODES1_Pos   (1U)
#define FMC_SDSR_MODES1_Msk   (0x3UL << FMC_SDSR_MODES1_Pos)
#define FMC_SDSR_MODES1   FMC_SDSR_MODES1_Msk
#define FMC_SDSR_MODES1_0   (0x1UL << FMC_SDSR_MODES1_Pos)
#define FMC_SDSR_MODES1_1   (0x2UL << FMC_SDSR_MODES1_Pos)
#define FMC_SDSR_MODES2_Pos   (3U)
#define FMC_SDSR_MODES2_Msk   (0x3UL << FMC_SDSR_MODES2_Pos)
#define FMC_SDSR_MODES2   FMC_SDSR_MODES2_Msk
#define FMC_SDSR_MODES2_0   (0x1UL << FMC_SDSR_MODES2_Pos)
#define FMC_SDSR_MODES2_1   (0x2UL << FMC_SDSR_MODES2_Pos)
#define GFXMMU_CR_B0OIE_Pos   (0U)
#define GFXMMU_CR_B0OIE_Msk   (0x1UL << GFXMMU_CR_B0OIE_Pos)
#define GFXMMU_CR_B0OIE   GFXMMU_CR_B0OIE_Msk
#define GFXMMU_CR_B1OIE_Pos   (1U)
#define GFXMMU_CR_B1OIE_Msk   (0x1UL << GFXMMU_CR_B1OIE_Pos)
#define GFXMMU_CR_B1OIE   GFXMMU_CR_B1OIE_Msk
#define GFXMMU_CR_B2OIE_Pos   (2U)
#define GFXMMU_CR_B2OIE_Msk   (0x1UL << GFXMMU_CR_B2OIE_Pos)
#define GFXMMU_CR_B2OIE   GFXMMU_CR_B2OIE_Msk
#define GFXMMU_CR_B3OIE_Pos   (3U)
#define GFXMMU_CR_B3OIE_Msk   (0x1UL << GFXMMU_CR_B3OIE_Pos)
#define GFXMMU_CR_B3OIE   GFXMMU_CR_B3OIE_Msk
#define GFXMMU_CR_AMEIE_Pos   (4U)
#define GFXMMU_CR_AMEIE_Msk   (0x1UL << GFXMMU_CR_AMEIE_Pos)
#define GFXMMU_CR_AMEIE   GFXMMU_CR_AMEIE_Msk
#define GFXMMU_CR_192BM_Pos   (6U)
#define GFXMMU_CR_192BM_Msk   (0x1UL << GFXMMU_CR_192BM_Pos)
#define GFXMMU_CR_192BM   GFXMMU_CR_192BM_Msk
#define GFXMMU_CR_CE_Pos   (7U)
#define GFXMMU_CR_CE_Msk   (0x1UL << GFXMMU_CR_CE_Pos)
#define GFXMMU_CR_CE   GFXMMU_CR_CE_Msk
#define GFXMMU_CR_CL_Pos   (8U)
#define GFXMMU_CR_CL_Msk   (0x1UL << GFXMMU_CR_CL_Pos)
#define GFXMMU_CR_CL   GFXMMU_CR_CL_Msk
#define GFXMMU_CR_CLB_Pos   (9U)
#define GFXMMU_CR_CLB_Msk   (0x3UL << GFXMMU_CR_CLB_Pos)
#define GFXMMU_CR_CLB   GFXMMU_CR_CLB_Msk
#define GFXMMU_CR_CLB_0   (0x1UL << GFXMMU_CR_CLB_Pos)
#define GFXMMU_CR_CLB_1   (0x2UL << GFXMMU_CR_CLB_Pos)
#define GFXMMU_CR_FC_Pos   (11U)
#define GFXMMU_CR_FC_Msk   (0x1UL << GFXMMU_CR_FC_Pos)
#define GFXMMU_CR_FC   GFXMMU_CR_FC_Msk
#define GFXMMU_CR_PD_Pos   (12U)
#define GFXMMU_CR_PD_Msk   (0x1UL << GFXMMU_CR_PD_Pos)
#define GFXMMU_CR_PD   GFXMMU_CR_PD_Msk
#define GFXMMU_CR_OC_Pos   (16U)
#define GFXMMU_CR_OC_Msk   (0x1UL << GFXMMU_CR_OC_Pos)
#define GFXMMU_CR_OC   GFXMMU_CR_OC_Msk
#define GFXMMU_CR_OB_Pos   (17U)
#define GFXMMU_CR_OB_Msk   (0x1UL << GFXMMU_CR_OB_Pos)
#define GFXMMU_CR_OB   GFXMMU_CR_OB_Msk
#define GFXMMU_SR_B0OF_Pos   (0U)
#define GFXMMU_SR_B0OF_Msk   (0x1UL << GFXMMU_SR_B0OF_Pos)
#define GFXMMU_SR_B0OF   GFXMMU_SR_B0OF_Msk
#define GFXMMU_SR_B1OF_Pos   (1U)
#define GFXMMU_SR_B1OF_Msk   (0x1UL << GFXMMU_SR_B1OF_Pos)
#define GFXMMU_SR_B1OF   GFXMMU_SR_B1OF_Msk
#define GFXMMU_SR_B2OF_Pos   (2U)
#define GFXMMU_SR_B2OF_Msk   (0x1UL << GFXMMU_SR_B2OF_Pos)
#define GFXMMU_SR_B2OF   GFXMMU_SR_B2OF_Msk
#define GFXMMU_SR_B3OF_Pos   (3U)
#define GFXMMU_SR_B3OF_Msk   (0x1UL << GFXMMU_SR_B3OF_Pos)
#define GFXMMU_SR_B3OF   GFXMMU_SR_B3OF_Msk
#define GFXMMU_SR_AMEF_Pos   (4U)
#define GFXMMU_SR_AMEF_Msk   (0x1UL << GFXMMU_SR_AMEF_Pos)
#define GFXMMU_SR_AMEF   GFXMMU_SR_AMEF_Msk
#define GFXMMU_FCR_CB0OF_Pos   (0U)
#define GFXMMU_FCR_CB0OF_Msk   (0x1UL << GFXMMU_FCR_CB0OF_Pos)
#define GFXMMU_FCR_CB0OF   GFXMMU_FCR_CB0OF_Msk
#define GFXMMU_FCR_CB1OF_Pos   (1U)
#define GFXMMU_FCR_CB1OF_Msk   (0x1UL << GFXMMU_FCR_CB1OF_Pos)
#define GFXMMU_FCR_CB1OF   GFXMMU_FCR_CB1OF_Msk
#define GFXMMU_FCR_CB2OF_Pos   (2U)
#define GFXMMU_FCR_CB2OF_Msk   (0x1UL << GFXMMU_FCR_CB2OF_Pos)
#define GFXMMU_FCR_CB2OF   GFXMMU_FCR_CB2OF_Msk
#define GFXMMU_FCR_CB3OF_Pos   (3U)
#define GFXMMU_FCR_CB3OF_Msk   (0x1UL << GFXMMU_FCR_CB3OF_Pos)
#define GFXMMU_FCR_CB3OF   GFXMMU_FCR_CB3OF_Msk
#define GFXMMU_FCR_CAMEF_Pos   (4U)
#define GFXMMU_FCR_CAMEF_Msk   (0x1UL << GFXMMU_FCR_CAMEF_Pos)
#define GFXMMU_FCR_CAMEF   GFXMMU_FCR_CAMEF_Msk
#define GFXMMU_CCR_FF_Pos   (0U)
#define GFXMMU_CCR_FF_Msk   (0x1UL << GFXMMU_CCR_FF_Pos)
#define GFXMMU_CCR_FF   GFXMMU_CCR_FF_Msk
#define GFXMMU_CCR_FI_Pos   (1U)
#define GFXMMU_CCR_FI_Msk   (0x1UL << GFXMMU_CCR_FI_Pos)
#define GFXMMU_CCR_FI   GFXMMU_CCR_FI_Msk
#define GFXMMU_DVR_DV_Pos   (0U)
#define GFXMMU_DVR_DV_Msk   (0xFFFFFFFFUL << GFXMMU_DVR_DV_Pos)
#define GFXMMU_DVR_DV   GFXMMU_DVR_DV_Msk
#define GFXMMU_B0CR_PBO_Pos   (4U)
#define GFXMMU_B0CR_PBO_Msk   (0x7FFFFUL << GFXMMU_B0CR_PBO_Pos)
#define GFXMMU_B0CR_PBO   GFXMMU_B0CR_PBO_Msk
#define GFXMMU_B0CR_PBBA_Pos   (23U)
#define GFXMMU_B0CR_PBBA_Msk   (0x1FFUL << GFXMMU_B0CR_PBBA_Pos)
#define GFXMMU_B0CR_PBBA   GFXMMU_B0CR_PBBA_Msk
#define GFXMMU_B1CR_PBO_Pos   (4U)
#define GFXMMU_B1CR_PBO_Msk   (0x7FFFFUL << GFXMMU_B1CR_PBO_Pos)
#define GFXMMU_B1CR_PBO   GFXMMU_B1CR_PBO_Msk
#define GFXMMU_B1CR_PBBA_Pos   (23U)
#define GFXMMU_B1CR_PBBA_Msk   (0x1FFUL << GFXMMU_B1CR_PBBA_Pos)
#define GFXMMU_B1CR_PBBA   GFXMMU_B1CR_PBBA_Msk
#define GFXMMU_B2CR_PBO_Pos   (4U)
#define GFXMMU_B2CR_PBO_Msk   (0x7FFFFUL << GFXMMU_B2CR_PBO_Pos)
#define GFXMMU_B2CR_PBO   GFXMMU_B2CR_PBO_Msk
#define GFXMMU_B2CR_PBBA_Pos   (23U)
#define GFXMMU_B2CR_PBBA_Msk   (0x1FFUL << GFXMMU_B2CR_PBBA_Pos)
#define GFXMMU_B2CR_PBBA   GFXMMU_B2CR_PBBA_Msk
#define GFXMMU_B3CR_PBO_Pos   (4U)
#define GFXMMU_B3CR_PBO_Msk   (0x7FFFFUL << GFXMMU_B3CR_PBO_Pos)
#define GFXMMU_B3CR_PBO   GFXMMU_B3CR_PBO_Msk
#define GFXMMU_B3CR_PBBA_Pos   (23U)
#define GFXMMU_B3CR_PBBA_Msk   (0x1FFUL << GFXMMU_B3CR_PBBA_Pos)
#define GFXMMU_B3CR_PBBA   GFXMMU_B3CR_PBBA_Msk
#define GFXMMU_LUTxL_EN_Pos   (0U)
#define GFXMMU_LUTxL_EN_Msk   (0x1UL << GFXMMU_LUTxL_EN_Pos)
#define GFXMMU_LUTxL_EN   GFXMMU_LUTxL_EN_Msk
#define GFXMMU_LUTxL_FVB_Pos   (8U)
#define GFXMMU_LUTxL_FVB_Msk   (0xFFUL << GFXMMU_LUTxL_FVB_Pos)
#define GFXMMU_LUTxL_FVB   GFXMMU_LUTxL_FVB_Msk
#define GFXMMU_LUTxL_LVB_Pos   (16U)
#define GFXMMU_LUTxL_LVB_Msk   (0xFFUL << GFXMMU_LUTxL_LVB_Pos)
#define GFXMMU_LUTxL_LVB   GFXMMU_LUTxL_LVB_Msk
#define GFXMMU_LUTxH_LO_Pos   (4U)
#define GFXMMU_LUTxH_LO_Msk   (0x3FFFFUL << GFXMMU_LUTxH_LO_Pos)
#define GFXMMU_LUTxH_LO   GFXMMU_LUTxH_LO_Msk
#define GPIO_MODER_MODE0_Pos   (0U)
#define GPIO_MODER_MODE0_Msk   (0x3UL << GPIO_MODER_MODE0_Pos)
#define GPIO_MODER_MODE0   GPIO_MODER_MODE0_Msk
#define GPIO_MODER_MODE0_0   (0x1UL << GPIO_MODER_MODE0_Pos)
#define GPIO_MODER_MODE0_1   (0x2UL << GPIO_MODER_MODE0_Pos)
#define GPIO_MODER_MODE1_Pos   (2U)
#define GPIO_MODER_MODE1_Msk   (0x3UL << GPIO_MODER_MODE1_Pos)
#define GPIO_MODER_MODE1   GPIO_MODER_MODE1_Msk
#define GPIO_MODER_MODE1_0   (0x1UL << GPIO_MODER_MODE1_Pos)
#define GPIO_MODER_MODE1_1   (0x2UL << GPIO_MODER_MODE1_Pos)
#define GPIO_MODER_MODE2_Pos   (4U)
#define GPIO_MODER_MODE2_Msk   (0x3UL << GPIO_MODER_MODE2_Pos)
#define GPIO_MODER_MODE2   GPIO_MODER_MODE2_Msk
#define GPIO_MODER_MODE2_0   (0x1UL << GPIO_MODER_MODE2_Pos)
#define GPIO_MODER_MODE2_1   (0x2UL << GPIO_MODER_MODE2_Pos)
#define GPIO_MODER_MODE3_Pos   (6U)
#define GPIO_MODER_MODE3_Msk   (0x3UL << GPIO_MODER_MODE3_Pos)
#define GPIO_MODER_MODE3   GPIO_MODER_MODE3_Msk
#define GPIO_MODER_MODE3_0   (0x1UL << GPIO_MODER_MODE3_Pos)
#define GPIO_MODER_MODE3_1   (0x2UL << GPIO_MODER_MODE3_Pos)
#define GPIO_MODER_MODE4_Pos   (8U)
#define GPIO_MODER_MODE4_Msk   (0x3UL << GPIO_MODER_MODE4_Pos)
#define GPIO_MODER_MODE4   GPIO_MODER_MODE4_Msk
#define GPIO_MODER_MODE4_0   (0x1UL << GPIO_MODER_MODE4_Pos)
#define GPIO_MODER_MODE4_1   (0x2UL << GPIO_MODER_MODE4_Pos)
#define GPIO_MODER_MODE5_Pos   (10U)
#define GPIO_MODER_MODE5_Msk   (0x3UL << GPIO_MODER_MODE5_Pos)
#define GPIO_MODER_MODE5   GPIO_MODER_MODE5_Msk
#define GPIO_MODER_MODE5_0   (0x1UL << GPIO_MODER_MODE5_Pos)
#define GPIO_MODER_MODE5_1   (0x2UL << GPIO_MODER_MODE5_Pos)
#define GPIO_MODER_MODE6_Pos   (12U)
#define GPIO_MODER_MODE6_Msk   (0x3UL << GPIO_MODER_MODE6_Pos)
#define GPIO_MODER_MODE6   GPIO_MODER_MODE6_Msk
#define GPIO_MODER_MODE6_0   (0x1UL << GPIO_MODER_MODE6_Pos)
#define GPIO_MODER_MODE6_1   (0x2UL << GPIO_MODER_MODE6_Pos)
#define GPIO_MODER_MODE7_Pos   (14U)
#define GPIO_MODER_MODE7_Msk   (0x3UL << GPIO_MODER_MODE7_Pos)
#define GPIO_MODER_MODE7   GPIO_MODER_MODE7_Msk
#define GPIO_MODER_MODE7_0   (0x1UL << GPIO_MODER_MODE7_Pos)
#define GPIO_MODER_MODE7_1   (0x2UL << GPIO_MODER_MODE7_Pos)
#define GPIO_MODER_MODE8_Pos   (16U)
#define GPIO_MODER_MODE8_Msk   (0x3UL << GPIO_MODER_MODE8_Pos)
#define GPIO_MODER_MODE8   GPIO_MODER_MODE8_Msk
#define GPIO_MODER_MODE8_0   (0x1UL << GPIO_MODER_MODE8_Pos)
#define GPIO_MODER_MODE8_1   (0x2UL << GPIO_MODER_MODE8_Pos)
#define GPIO_MODER_MODE9_Pos   (18U)
#define GPIO_MODER_MODE9_Msk   (0x3UL << GPIO_MODER_MODE9_Pos)
#define GPIO_MODER_MODE9   GPIO_MODER_MODE9_Msk
#define GPIO_MODER_MODE9_0   (0x1UL << GPIO_MODER_MODE9_Pos)
#define GPIO_MODER_MODE9_1   (0x2UL << GPIO_MODER_MODE9_Pos)
#define GPIO_MODER_MODE10_Pos   (20U)
#define GPIO_MODER_MODE10_Msk   (0x3UL << GPIO_MODER_MODE10_Pos)
#define GPIO_MODER_MODE10   GPIO_MODER_MODE10_Msk
#define GPIO_MODER_MODE10_0   (0x1UL << GPIO_MODER_MODE10_Pos)
#define GPIO_MODER_MODE10_1   (0x2UL << GPIO_MODER_MODE10_Pos)
#define GPIO_MODER_MODE11_Pos   (22U)
#define GPIO_MODER_MODE11_Msk   (0x3UL << GPIO_MODER_MODE11_Pos)
#define GPIO_MODER_MODE11   GPIO_MODER_MODE11_Msk
#define GPIO_MODER_MODE11_0   (0x1UL << GPIO_MODER_MODE11_Pos)
#define GPIO_MODER_MODE11_1   (0x2UL << GPIO_MODER_MODE11_Pos)
#define GPIO_MODER_MODE12_Pos   (24U)
#define GPIO_MODER_MODE12_Msk   (0x3UL << GPIO_MODER_MODE12_Pos)
#define GPIO_MODER_MODE12   GPIO_MODER_MODE12_Msk
#define GPIO_MODER_MODE12_0   (0x1UL << GPIO_MODER_MODE12_Pos)
#define GPIO_MODER_MODE12_1   (0x2UL << GPIO_MODER_MODE12_Pos)
#define GPIO_MODER_MODE13_Pos   (26U)
#define GPIO_MODER_MODE13_Msk   (0x3UL << GPIO_MODER_MODE13_Pos)
#define GPIO_MODER_MODE13   GPIO_MODER_MODE13_Msk
#define GPIO_MODER_MODE13_0   (0x1UL << GPIO_MODER_MODE13_Pos)
#define GPIO_MODER_MODE13_1   (0x2UL << GPIO_MODER_MODE13_Pos)
#define GPIO_MODER_MODE14_Pos   (28U)
#define GPIO_MODER_MODE14_Msk   (0x3UL << GPIO_MODER_MODE14_Pos)
#define GPIO_MODER_MODE14   GPIO_MODER_MODE14_Msk
#define GPIO_MODER_MODE14_0   (0x1UL << GPIO_MODER_MODE14_Pos)
#define GPIO_MODER_MODE14_1   (0x2UL << GPIO_MODER_MODE14_Pos)
#define GPIO_MODER_MODE15_Pos   (30U)
#define GPIO_MODER_MODE15_Msk   (0x3UL << GPIO_MODER_MODE15_Pos)
#define GPIO_MODER_MODE15   GPIO_MODER_MODE15_Msk
#define GPIO_MODER_MODE15_0   (0x1UL << GPIO_MODER_MODE15_Pos)
#define GPIO_MODER_MODE15_1   (0x2UL << GPIO_MODER_MODE15_Pos)
#define GPIO_OTYPER_OT0_Pos   (0U)
#define GPIO_OTYPER_OT0_Msk   (0x1UL << GPIO_OTYPER_OT0_Pos)
#define GPIO_OTYPER_OT0   GPIO_OTYPER_OT0_Msk
#define GPIO_OTYPER_OT1_Pos   (1U)
#define GPIO_OTYPER_OT1_Msk   (0x1UL << GPIO_OTYPER_OT1_Pos)
#define GPIO_OTYPER_OT1   GPIO_OTYPER_OT1_Msk
#define GPIO_OTYPER_OT2_Pos   (2U)
#define GPIO_OTYPER_OT2_Msk   (0x1UL << GPIO_OTYPER_OT2_Pos)
#define GPIO_OTYPER_OT2   GPIO_OTYPER_OT2_Msk
#define GPIO_OTYPER_OT3_Pos   (3U)
#define GPIO_OTYPER_OT3_Msk   (0x1UL << GPIO_OTYPER_OT3_Pos)
#define GPIO_OTYPER_OT3   GPIO_OTYPER_OT3_Msk
#define GPIO_OTYPER_OT4_Pos   (4U)
#define GPIO_OTYPER_OT4_Msk   (0x1UL << GPIO_OTYPER_OT4_Pos)
#define GPIO_OTYPER_OT4   GPIO_OTYPER_OT4_Msk
#define GPIO_OTYPER_OT5_Pos   (5U)
#define GPIO_OTYPER_OT5_Msk   (0x1UL << GPIO_OTYPER_OT5_Pos)
#define GPIO_OTYPER_OT5   GPIO_OTYPER_OT5_Msk
#define GPIO_OTYPER_OT6_Pos   (6U)
#define GPIO_OTYPER_OT6_Msk   (0x1UL << GPIO_OTYPER_OT6_Pos)
#define GPIO_OTYPER_OT6   GPIO_OTYPER_OT6_Msk
#define GPIO_OTYPER_OT7_Pos   (7U)
#define GPIO_OTYPER_OT7_Msk   (0x1UL << GPIO_OTYPER_OT7_Pos)
#define GPIO_OTYPER_OT7   GPIO_OTYPER_OT7_Msk
#define GPIO_OTYPER_OT8_Pos   (8U)
#define GPIO_OTYPER_OT8_Msk   (0x1UL << GPIO_OTYPER_OT8_Pos)
#define GPIO_OTYPER_OT8   GPIO_OTYPER_OT8_Msk
#define GPIO_OTYPER_OT9_Pos   (9U)
#define GPIO_OTYPER_OT9_Msk   (0x1UL << GPIO_OTYPER_OT9_Pos)
#define GPIO_OTYPER_OT9   GPIO_OTYPER_OT9_Msk
#define GPIO_OTYPER_OT10_Pos   (10U)
#define GPIO_OTYPER_OT10_Msk   (0x1UL << GPIO_OTYPER_OT10_Pos)
#define GPIO_OTYPER_OT10   GPIO_OTYPER_OT10_Msk
#define GPIO_OTYPER_OT11_Pos   (11U)
#define GPIO_OTYPER_OT11_Msk   (0x1UL << GPIO_OTYPER_OT11_Pos)
#define GPIO_OTYPER_OT11   GPIO_OTYPER_OT11_Msk
#define GPIO_OTYPER_OT12_Pos   (12U)
#define GPIO_OTYPER_OT12_Msk   (0x1UL << GPIO_OTYPER_OT12_Pos)
#define GPIO_OTYPER_OT12   GPIO_OTYPER_OT12_Msk
#define GPIO_OTYPER_OT13_Pos   (13U)
#define GPIO_OTYPER_OT13_Msk   (0x1UL << GPIO_OTYPER_OT13_Pos)
#define GPIO_OTYPER_OT13   GPIO_OTYPER_OT13_Msk
#define GPIO_OTYPER_OT14_Pos   (14U)
#define GPIO_OTYPER_OT14_Msk   (0x1UL << GPIO_OTYPER_OT14_Pos)
#define GPIO_OTYPER_OT14   GPIO_OTYPER_OT14_Msk
#define GPIO_OTYPER_OT15_Pos   (15U)
#define GPIO_OTYPER_OT15_Msk   (0x1UL << GPIO_OTYPER_OT15_Pos)
#define GPIO_OTYPER_OT15   GPIO_OTYPER_OT15_Msk
#define GPIO_OSPEEDR_OSPEED0_Pos   (0U)
#define GPIO_OSPEEDR_OSPEED0_Msk   (0x3UL << GPIO_OSPEEDR_OSPEED0_Pos)
#define GPIO_OSPEEDR_OSPEED0   GPIO_OSPEEDR_OSPEED0_Msk
#define GPIO_OSPEEDR_OSPEED0_0   (0x1UL << GPIO_OSPEEDR_OSPEED0_Pos)
#define GPIO_OSPEEDR_OSPEED0_1   (0x2UL << GPIO_OSPEEDR_OSPEED0_Pos)
#define GPIO_OSPEEDR_OSPEED1_Pos   (2U)
#define GPIO_OSPEEDR_OSPEED1_Msk   (0x3UL << GPIO_OSPEEDR_OSPEED1_Pos)
#define GPIO_OSPEEDR_OSPEED1   GPIO_OSPEEDR_OSPEED1_Msk
#define GPIO_OSPEEDR_OSPEED1_0   (0x1UL << GPIO_OSPEEDR_OSPEED1_Pos)
#define GPIO_OSPEEDR_OSPEED1_1   (0x2UL << GPIO_OSPEEDR_OSPEED1_Pos)
#define GPIO_OSPEEDR_OSPEED2_Pos   (4U)
#define GPIO_OSPEEDR_OSPEED2_Msk   (0x3UL << GPIO_OSPEEDR_OSPEED2_Pos)
#define GPIO_OSPEEDR_OSPEED2   GPIO_OSPEEDR_OSPEED2_Msk
#define GPIO_OSPEEDR_OSPEED2_0   (0x1UL << GPIO_OSPEEDR_OSPEED2_Pos)
#define GPIO_OSPEEDR_OSPEED2_1   (0x2UL << GPIO_OSPEEDR_OSPEED2_Pos)
#define GPIO_OSPEEDR_OSPEED3_Pos   (6U)
#define GPIO_OSPEEDR_OSPEED3_Msk   (0x3UL << GPIO_OSPEEDR_OSPEED3_Pos)
#define GPIO_OSPEEDR_OSPEED3   GPIO_OSPEEDR_OSPEED3_Msk
#define GPIO_OSPEEDR_OSPEED3_0   (0x1UL << GPIO_OSPEEDR_OSPEED3_Pos)
#define GPIO_OSPEEDR_OSPEED3_1   (0x2UL << GPIO_OSPEEDR_OSPEED3_Pos)
#define GPIO_OSPEEDR_OSPEED4_Pos   (8U)
#define GPIO_OSPEEDR_OSPEED4_Msk   (0x3UL << GPIO_OSPEEDR_OSPEED4_Pos)
#define GPIO_OSPEEDR_OSPEED4   GPIO_OSPEEDR_OSPEED4_Msk
#define GPIO_OSPEEDR_OSPEED4_0   (0x1UL << GPIO_OSPEEDR_OSPEED4_Pos)
#define GPIO_OSPEEDR_OSPEED4_1   (0x2UL << GPIO_OSPEEDR_OSPEED4_Pos)
#define GPIO_OSPEEDR_OSPEED5_Pos   (10U)
#define GPIO_OSPEEDR_OSPEED5_Msk   (0x3UL << GPIO_OSPEEDR_OSPEED5_Pos)
#define GPIO_OSPEEDR_OSPEED5   GPIO_OSPEEDR_OSPEED5_Msk
#define GPIO_OSPEEDR_OSPEED5_0   (0x1UL << GPIO_OSPEEDR_OSPEED5_Pos)
#define GPIO_OSPEEDR_OSPEED5_1   (0x2UL << GPIO_OSPEEDR_OSPEED5_Pos)
#define GPIO_OSPEEDR_OSPEED6_Pos   (12U)
#define GPIO_OSPEEDR_OSPEED6_Msk   (0x3UL << GPIO_OSPEEDR_OSPEED6_Pos)
#define GPIO_OSPEEDR_OSPEED6   GPIO_OSPEEDR_OSPEED6_Msk
#define GPIO_OSPEEDR_OSPEED6_0   (0x1UL << GPIO_OSPEEDR_OSPEED6_Pos)
#define GPIO_OSPEEDR_OSPEED6_1   (0x2UL << GPIO_OSPEEDR_OSPEED6_Pos)
#define GPIO_OSPEEDR_OSPEED7_Pos   (14U)
#define GPIO_OSPEEDR_OSPEED7_Msk   (0x3UL << GPIO_OSPEEDR_OSPEED7_Pos)
#define GPIO_OSPEEDR_OSPEED7   GPIO_OSPEEDR_OSPEED7_Msk
#define GPIO_OSPEEDR_OSPEED7_0   (0x1UL << GPIO_OSPEEDR_OSPEED7_Pos)
#define GPIO_OSPEEDR_OSPEED7_1   (0x2UL << GPIO_OSPEEDR_OSPEED7_Pos)
#define GPIO_OSPEEDR_OSPEED8_Pos   (16U)
#define GPIO_OSPEEDR_OSPEED8_Msk   (0x3UL << GPIO_OSPEEDR_OSPEED8_Pos)
#define GPIO_OSPEEDR_OSPEED8   GPIO_OSPEEDR_OSPEED8_Msk
#define GPIO_OSPEEDR_OSPEED8_0   (0x1UL << GPIO_OSPEEDR_OSPEED8_Pos)
#define GPIO_OSPEEDR_OSPEED8_1   (0x2UL << GPIO_OSPEEDR_OSPEED8_Pos)
#define GPIO_OSPEEDR_OSPEED9_Pos   (18U)
#define GPIO_OSPEEDR_OSPEED9_Msk   (0x3UL << GPIO_OSPEEDR_OSPEED9_Pos)
#define GPIO_OSPEEDR_OSPEED9   GPIO_OSPEEDR_OSPEED9_Msk
#define GPIO_OSPEEDR_OSPEED9_0   (0x1UL << GPIO_OSPEEDR_OSPEED9_Pos)
#define GPIO_OSPEEDR_OSPEED9_1   (0x2UL << GPIO_OSPEEDR_OSPEED9_Pos)
#define GPIO_OSPEEDR_OSPEED10_Pos   (20U)
#define GPIO_OSPEEDR_OSPEED10_Msk   (0x3UL << GPIO_OSPEEDR_OSPEED10_Pos)
#define GPIO_OSPEEDR_OSPEED10   GPIO_OSPEEDR_OSPEED10_Msk
#define GPIO_OSPEEDR_OSPEED10_0   (0x1UL << GPIO_OSPEEDR_OSPEED10_Pos)
#define GPIO_OSPEEDR_OSPEED10_1   (0x2UL << GPIO_OSPEEDR_OSPEED10_Pos)
#define GPIO_OSPEEDR_OSPEED11_Pos   (22U)
#define GPIO_OSPEEDR_OSPEED11_Msk   (0x3UL << GPIO_OSPEEDR_OSPEED11_Pos)
#define GPIO_OSPEEDR_OSPEED11   GPIO_OSPEEDR_OSPEED11_Msk
#define GPIO_OSPEEDR_OSPEED11_0   (0x1UL << GPIO_OSPEEDR_OSPEED11_Pos)
#define GPIO_OSPEEDR_OSPEED11_1   (0x2UL << GPIO_OSPEEDR_OSPEED11_Pos)
#define GPIO_OSPEEDR_OSPEED12_Pos   (24U)
#define GPIO_OSPEEDR_OSPEED12_Msk   (0x3UL << GPIO_OSPEEDR_OSPEED12_Pos)
#define GPIO_OSPEEDR_OSPEED12   GPIO_OSPEEDR_OSPEED12_Msk
#define GPIO_OSPEEDR_OSPEED12_0   (0x1UL << GPIO_OSPEEDR_OSPEED12_Pos)
#define GPIO_OSPEEDR_OSPEED12_1   (0x2UL << GPIO_OSPEEDR_OSPEED12_Pos)
#define GPIO_OSPEEDR_OSPEED13_Pos   (26U)
#define GPIO_OSPEEDR_OSPEED13_Msk   (0x3UL << GPIO_OSPEEDR_OSPEED13_Pos)
#define GPIO_OSPEEDR_OSPEED13   GPIO_OSPEEDR_OSPEED13_Msk
#define GPIO_OSPEEDR_OSPEED13_0   (0x1UL << GPIO_OSPEEDR_OSPEED13_Pos)
#define GPIO_OSPEEDR_OSPEED13_1   (0x2UL << GPIO_OSPEEDR_OSPEED13_Pos)
#define GPIO_OSPEEDR_OSPEED14_Pos   (28U)
#define GPIO_OSPEEDR_OSPEED14_Msk   (0x3UL << GPIO_OSPEEDR_OSPEED14_Pos)
#define GPIO_OSPEEDR_OSPEED14   GPIO_OSPEEDR_OSPEED14_Msk
#define GPIO_OSPEEDR_OSPEED14_0   (0x1UL << GPIO_OSPEEDR_OSPEED14_Pos)
#define GPIO_OSPEEDR_OSPEED14_1   (0x2UL << GPIO_OSPEEDR_OSPEED14_Pos)
#define GPIO_OSPEEDR_OSPEED15_Pos   (30U)
#define GPIO_OSPEEDR_OSPEED15_Msk   (0x3UL << GPIO_OSPEEDR_OSPEED15_Pos)
#define GPIO_OSPEEDR_OSPEED15   GPIO_OSPEEDR_OSPEED15_Msk
#define GPIO_OSPEEDR_OSPEED15_0   (0x1UL << GPIO_OSPEEDR_OSPEED15_Pos)
#define GPIO_OSPEEDR_OSPEED15_1   (0x2UL << GPIO_OSPEEDR_OSPEED15_Pos)
#define GPIO_PUPDR_PUPD0_Pos   (0U)
#define GPIO_PUPDR_PUPD0_Msk   (0x3UL << GPIO_PUPDR_PUPD0_Pos)
#define GPIO_PUPDR_PUPD0   GPIO_PUPDR_PUPD0_Msk
#define GPIO_PUPDR_PUPD0_0   (0x1UL << GPIO_PUPDR_PUPD0_Pos)
#define GPIO_PUPDR_PUPD0_1   (0x2UL << GPIO_PUPDR_PUPD0_Pos)
#define GPIO_PUPDR_PUPD1_Pos   (2U)
#define GPIO_PUPDR_PUPD1_Msk   (0x3UL << GPIO_PUPDR_PUPD1_Pos)
#define GPIO_PUPDR_PUPD1   GPIO_PUPDR_PUPD1_Msk
#define GPIO_PUPDR_PUPD1_0   (0x1UL << GPIO_PUPDR_PUPD1_Pos)
#define GPIO_PUPDR_PUPD1_1   (0x2UL << GPIO_PUPDR_PUPD1_Pos)
#define GPIO_PUPDR_PUPD2_Pos   (4U)
#define GPIO_PUPDR_PUPD2_Msk   (0x3UL << GPIO_PUPDR_PUPD2_Pos)
#define GPIO_PUPDR_PUPD2   GPIO_PUPDR_PUPD2_Msk
#define GPIO_PUPDR_PUPD2_0   (0x1UL << GPIO_PUPDR_PUPD2_Pos)
#define GPIO_PUPDR_PUPD2_1   (0x2UL << GPIO_PUPDR_PUPD2_Pos)
#define GPIO_PUPDR_PUPD3_Pos   (6U)
#define GPIO_PUPDR_PUPD3_Msk   (0x3UL << GPIO_PUPDR_PUPD3_Pos)
#define GPIO_PUPDR_PUPD3   GPIO_PUPDR_PUPD3_Msk
#define GPIO_PUPDR_PUPD3_0   (0x1UL << GPIO_PUPDR_PUPD3_Pos)
#define GPIO_PUPDR_PUPD3_1   (0x2UL << GPIO_PUPDR_PUPD3_Pos)
#define GPIO_PUPDR_PUPD4_Pos   (8U)
#define GPIO_PUPDR_PUPD4_Msk   (0x3UL << GPIO_PUPDR_PUPD4_Pos)
#define GPIO_PUPDR_PUPD4   GPIO_PUPDR_PUPD4_Msk
#define GPIO_PUPDR_PUPD4_0   (0x1UL << GPIO_PUPDR_PUPD4_Pos)
#define GPIO_PUPDR_PUPD4_1   (0x2UL << GPIO_PUPDR_PUPD4_Pos)
#define GPIO_PUPDR_PUPD5_Pos   (10U)
#define GPIO_PUPDR_PUPD5_Msk   (0x3UL << GPIO_PUPDR_PUPD5_Pos)
#define GPIO_PUPDR_PUPD5   GPIO_PUPDR_PUPD5_Msk
#define GPIO_PUPDR_PUPD5_0   (0x1UL << GPIO_PUPDR_PUPD5_Pos)
#define GPIO_PUPDR_PUPD5_1   (0x2UL << GPIO_PUPDR_PUPD5_Pos)
#define GPIO_PUPDR_PUPD6_Pos   (12U)
#define GPIO_PUPDR_PUPD6_Msk   (0x3UL << GPIO_PUPDR_PUPD6_Pos)
#define GPIO_PUPDR_PUPD6   GPIO_PUPDR_PUPD6_Msk
#define GPIO_PUPDR_PUPD6_0   (0x1UL << GPIO_PUPDR_PUPD6_Pos)
#define GPIO_PUPDR_PUPD6_1   (0x2UL << GPIO_PUPDR_PUPD6_Pos)
#define GPIO_PUPDR_PUPD7_Pos   (14U)
#define GPIO_PUPDR_PUPD7_Msk   (0x3UL << GPIO_PUPDR_PUPD7_Pos)
#define GPIO_PUPDR_PUPD7   GPIO_PUPDR_PUPD7_Msk
#define GPIO_PUPDR_PUPD7_0   (0x1UL << GPIO_PUPDR_PUPD7_Pos)
#define GPIO_PUPDR_PUPD7_1   (0x2UL << GPIO_PUPDR_PUPD7_Pos)
#define GPIO_PUPDR_PUPD8_Pos   (16U)
#define GPIO_PUPDR_PUPD8_Msk   (0x3UL << GPIO_PUPDR_PUPD8_Pos)
#define GPIO_PUPDR_PUPD8   GPIO_PUPDR_PUPD8_Msk
#define GPIO_PUPDR_PUPD8_0   (0x1UL << GPIO_PUPDR_PUPD8_Pos)
#define GPIO_PUPDR_PUPD8_1   (0x2UL << GPIO_PUPDR_PUPD8_Pos)
#define GPIO_PUPDR_PUPD9_Pos   (18U)
#define GPIO_PUPDR_PUPD9_Msk   (0x3UL << GPIO_PUPDR_PUPD9_Pos)
#define GPIO_PUPDR_PUPD9   GPIO_PUPDR_PUPD9_Msk
#define GPIO_PUPDR_PUPD9_0   (0x1UL << GPIO_PUPDR_PUPD9_Pos)
#define GPIO_PUPDR_PUPD9_1   (0x2UL << GPIO_PUPDR_PUPD9_Pos)
#define GPIO_PUPDR_PUPD10_Pos   (20U)
#define GPIO_PUPDR_PUPD10_Msk   (0x3UL << GPIO_PUPDR_PUPD10_Pos)
#define GPIO_PUPDR_PUPD10   GPIO_PUPDR_PUPD10_Msk
#define GPIO_PUPDR_PUPD10_0   (0x1UL << GPIO_PUPDR_PUPD10_Pos)
#define GPIO_PUPDR_PUPD10_1   (0x2UL << GPIO_PUPDR_PUPD10_Pos)
#define GPIO_PUPDR_PUPD11_Pos   (22U)
#define GPIO_PUPDR_PUPD11_Msk   (0x3UL << GPIO_PUPDR_PUPD11_Pos)
#define GPIO_PUPDR_PUPD11   GPIO_PUPDR_PUPD11_Msk
#define GPIO_PUPDR_PUPD11_0   (0x1UL << GPIO_PUPDR_PUPD11_Pos)
#define GPIO_PUPDR_PUPD11_1   (0x2UL << GPIO_PUPDR_PUPD11_Pos)
#define GPIO_PUPDR_PUPD12_Pos   (24U)
#define GPIO_PUPDR_PUPD12_Msk   (0x3UL << GPIO_PUPDR_PUPD12_Pos)
#define GPIO_PUPDR_PUPD12   GPIO_PUPDR_PUPD12_Msk
#define GPIO_PUPDR_PUPD12_0   (0x1UL << GPIO_PUPDR_PUPD12_Pos)
#define GPIO_PUPDR_PUPD12_1   (0x2UL << GPIO_PUPDR_PUPD12_Pos)
#define GPIO_PUPDR_PUPD13_Pos   (26U)
#define GPIO_PUPDR_PUPD13_Msk   (0x3UL << GPIO_PUPDR_PUPD13_Pos)
#define GPIO_PUPDR_PUPD13   GPIO_PUPDR_PUPD13_Msk
#define GPIO_PUPDR_PUPD13_0   (0x1UL << GPIO_PUPDR_PUPD13_Pos)
#define GPIO_PUPDR_PUPD13_1   (0x2UL << GPIO_PUPDR_PUPD13_Pos)
#define GPIO_PUPDR_PUPD14_Pos   (28U)
#define GPIO_PUPDR_PUPD14_Msk   (0x3UL << GPIO_PUPDR_PUPD14_Pos)
#define GPIO_PUPDR_PUPD14   GPIO_PUPDR_PUPD14_Msk
#define GPIO_PUPDR_PUPD14_0   (0x1UL << GPIO_PUPDR_PUPD14_Pos)
#define GPIO_PUPDR_PUPD14_1   (0x2UL << GPIO_PUPDR_PUPD14_Pos)
#define GPIO_PUPDR_PUPD15_Pos   (30U)
#define GPIO_PUPDR_PUPD15_Msk   (0x3UL << GPIO_PUPDR_PUPD15_Pos)
#define GPIO_PUPDR_PUPD15   GPIO_PUPDR_PUPD15_Msk
#define GPIO_PUPDR_PUPD15_0   (0x1UL << GPIO_PUPDR_PUPD15_Pos)
#define GPIO_PUPDR_PUPD15_1   (0x2UL << GPIO_PUPDR_PUPD15_Pos)
#define GPIO_IDR_ID0_Pos   (0U)
#define GPIO_IDR_ID0_Msk   (0x1UL << GPIO_IDR_ID0_Pos)
#define GPIO_IDR_ID0   GPIO_IDR_ID0_Msk
#define GPIO_IDR_ID1_Pos   (1U)
#define GPIO_IDR_ID1_Msk   (0x1UL << GPIO_IDR_ID1_Pos)
#define GPIO_IDR_ID1   GPIO_IDR_ID1_Msk
#define GPIO_IDR_ID2_Pos   (2U)
#define GPIO_IDR_ID2_Msk   (0x1UL << GPIO_IDR_ID2_Pos)
#define GPIO_IDR_ID2   GPIO_IDR_ID2_Msk
#define GPIO_IDR_ID3_Pos   (3U)
#define GPIO_IDR_ID3_Msk   (0x1UL << GPIO_IDR_ID3_Pos)
#define GPIO_IDR_ID3   GPIO_IDR_ID3_Msk
#define GPIO_IDR_ID4_Pos   (4U)
#define GPIO_IDR_ID4_Msk   (0x1UL << GPIO_IDR_ID4_Pos)
#define GPIO_IDR_ID4   GPIO_IDR_ID4_Msk
#define GPIO_IDR_ID5_Pos   (5U)
#define GPIO_IDR_ID5_Msk   (0x1UL << GPIO_IDR_ID5_Pos)
#define GPIO_IDR_ID5   GPIO_IDR_ID5_Msk
#define GPIO_IDR_ID6_Pos   (6U)
#define GPIO_IDR_ID6_Msk   (0x1UL << GPIO_IDR_ID6_Pos)
#define GPIO_IDR_ID6   GPIO_IDR_ID6_Msk
#define GPIO_IDR_ID7_Pos   (7U)
#define GPIO_IDR_ID7_Msk   (0x1UL << GPIO_IDR_ID7_Pos)
#define GPIO_IDR_ID7   GPIO_IDR_ID7_Msk
#define GPIO_IDR_ID8_Pos   (8U)
#define GPIO_IDR_ID8_Msk   (0x1UL << GPIO_IDR_ID8_Pos)
#define GPIO_IDR_ID8   GPIO_IDR_ID8_Msk
#define GPIO_IDR_ID9_Pos   (9U)
#define GPIO_IDR_ID9_Msk   (0x1UL << GPIO_IDR_ID9_Pos)
#define GPIO_IDR_ID9   GPIO_IDR_ID9_Msk
#define GPIO_IDR_ID10_Pos   (10U)
#define GPIO_IDR_ID10_Msk   (0x1UL << GPIO_IDR_ID10_Pos)
#define GPIO_IDR_ID10   GPIO_IDR_ID10_Msk
#define GPIO_IDR_ID11_Pos   (11U)
#define GPIO_IDR_ID11_Msk   (0x1UL << GPIO_IDR_ID11_Pos)
#define GPIO_IDR_ID11   GPIO_IDR_ID11_Msk
#define GPIO_IDR_ID12_Pos   (12U)
#define GPIO_IDR_ID12_Msk   (0x1UL << GPIO_IDR_ID12_Pos)
#define GPIO_IDR_ID12   GPIO_IDR_ID12_Msk
#define GPIO_IDR_ID13_Pos   (13U)
#define GPIO_IDR_ID13_Msk   (0x1UL << GPIO_IDR_ID13_Pos)
#define GPIO_IDR_ID13   GPIO_IDR_ID13_Msk
#define GPIO_IDR_ID14_Pos   (14U)
#define GPIO_IDR_ID14_Msk   (0x1UL << GPIO_IDR_ID14_Pos)
#define GPIO_IDR_ID14   GPIO_IDR_ID14_Msk
#define GPIO_IDR_ID15_Pos   (15U)
#define GPIO_IDR_ID15_Msk   (0x1UL << GPIO_IDR_ID15_Pos)
#define GPIO_IDR_ID15   GPIO_IDR_ID15_Msk
#define GPIO_ODR_OD0_Pos   (0U)
#define GPIO_ODR_OD0_Msk   (0x1UL << GPIO_ODR_OD0_Pos)
#define GPIO_ODR_OD0   GPIO_ODR_OD0_Msk
#define GPIO_ODR_OD1_Pos   (1U)
#define GPIO_ODR_OD1_Msk   (0x1UL << GPIO_ODR_OD1_Pos)
#define GPIO_ODR_OD1   GPIO_ODR_OD1_Msk
#define GPIO_ODR_OD2_Pos   (2U)
#define GPIO_ODR_OD2_Msk   (0x1UL << GPIO_ODR_OD2_Pos)
#define GPIO_ODR_OD2   GPIO_ODR_OD2_Msk
#define GPIO_ODR_OD3_Pos   (3U)
#define GPIO_ODR_OD3_Msk   (0x1UL << GPIO_ODR_OD3_Pos)
#define GPIO_ODR_OD3   GPIO_ODR_OD3_Msk
#define GPIO_ODR_OD4_Pos   (4U)
#define GPIO_ODR_OD4_Msk   (0x1UL << GPIO_ODR_OD4_Pos)
#define GPIO_ODR_OD4   GPIO_ODR_OD4_Msk
#define GPIO_ODR_OD5_Pos   (5U)
#define GPIO_ODR_OD5_Msk   (0x1UL << GPIO_ODR_OD5_Pos)
#define GPIO_ODR_OD5   GPIO_ODR_OD5_Msk
#define GPIO_ODR_OD6_Pos   (6U)
#define GPIO_ODR_OD6_Msk   (0x1UL << GPIO_ODR_OD6_Pos)
#define GPIO_ODR_OD6   GPIO_ODR_OD6_Msk
#define GPIO_ODR_OD7_Pos   (7U)
#define GPIO_ODR_OD7_Msk   (0x1UL << GPIO_ODR_OD7_Pos)
#define GPIO_ODR_OD7   GPIO_ODR_OD7_Msk
#define GPIO_ODR_OD8_Pos   (8U)
#define GPIO_ODR_OD8_Msk   (0x1UL << GPIO_ODR_OD8_Pos)
#define GPIO_ODR_OD8   GPIO_ODR_OD8_Msk
#define GPIO_ODR_OD9_Pos   (9U)
#define GPIO_ODR_OD9_Msk   (0x1UL << GPIO_ODR_OD9_Pos)
#define GPIO_ODR_OD9   GPIO_ODR_OD9_Msk
#define GPIO_ODR_OD10_Pos   (10U)
#define GPIO_ODR_OD10_Msk   (0x1UL << GPIO_ODR_OD10_Pos)
#define GPIO_ODR_OD10   GPIO_ODR_OD10_Msk
#define GPIO_ODR_OD11_Pos   (11U)
#define GPIO_ODR_OD11_Msk   (0x1UL << GPIO_ODR_OD11_Pos)
#define GPIO_ODR_OD11   GPIO_ODR_OD11_Msk
#define GPIO_ODR_OD12_Pos   (12U)
#define GPIO_ODR_OD12_Msk   (0x1UL << GPIO_ODR_OD12_Pos)
#define GPIO_ODR_OD12   GPIO_ODR_OD12_Msk
#define GPIO_ODR_OD13_Pos   (13U)
#define GPIO_ODR_OD13_Msk   (0x1UL << GPIO_ODR_OD13_Pos)
#define GPIO_ODR_OD13   GPIO_ODR_OD13_Msk
#define GPIO_ODR_OD14_Pos   (14U)
#define GPIO_ODR_OD14_Msk   (0x1UL << GPIO_ODR_OD14_Pos)
#define GPIO_ODR_OD14   GPIO_ODR_OD14_Msk
#define GPIO_ODR_OD15_Pos   (15U)
#define GPIO_ODR_OD15_Msk   (0x1UL << GPIO_ODR_OD15_Pos)
#define GPIO_ODR_OD15   GPIO_ODR_OD15_Msk
#define GPIO_BSRR_BS0_Pos   (0U)
#define GPIO_BSRR_BS0_Msk   (0x1UL << GPIO_BSRR_BS0_Pos)
#define GPIO_BSRR_BS0   GPIO_BSRR_BS0_Msk
#define GPIO_BSRR_BS1_Pos   (1U)
#define GPIO_BSRR_BS1_Msk   (0x1UL << GPIO_BSRR_BS1_Pos)
#define GPIO_BSRR_BS1   GPIO_BSRR_BS1_Msk
#define GPIO_BSRR_BS2_Pos   (2U)
#define GPIO_BSRR_BS2_Msk   (0x1UL << GPIO_BSRR_BS2_Pos)
#define GPIO_BSRR_BS2   GPIO_BSRR_BS2_Msk
#define GPIO_BSRR_BS3_Pos   (3U)
#define GPIO_BSRR_BS3_Msk   (0x1UL << GPIO_BSRR_BS3_Pos)
#define GPIO_BSRR_BS3   GPIO_BSRR_BS3_Msk
#define GPIO_BSRR_BS4_Pos   (4U)
#define GPIO_BSRR_BS4_Msk   (0x1UL << GPIO_BSRR_BS4_Pos)
#define GPIO_BSRR_BS4   GPIO_BSRR_BS4_Msk
#define GPIO_BSRR_BS5_Pos   (5U)
#define GPIO_BSRR_BS5_Msk   (0x1UL << GPIO_BSRR_BS5_Pos)
#define GPIO_BSRR_BS5   GPIO_BSRR_BS5_Msk
#define GPIO_BSRR_BS6_Pos   (6U)
#define GPIO_BSRR_BS6_Msk   (0x1UL << GPIO_BSRR_BS6_Pos)
#define GPIO_BSRR_BS6   GPIO_BSRR_BS6_Msk
#define GPIO_BSRR_BS7_Pos   (7U)
#define GPIO_BSRR_BS7_Msk   (0x1UL << GPIO_BSRR_BS7_Pos)
#define GPIO_BSRR_BS7   GPIO_BSRR_BS7_Msk
#define GPIO_BSRR_BS8_Pos   (8U)
#define GPIO_BSRR_BS8_Msk   (0x1UL << GPIO_BSRR_BS8_Pos)
#define GPIO_BSRR_BS8   GPIO_BSRR_BS8_Msk
#define GPIO_BSRR_BS9_Pos   (9U)
#define GPIO_BSRR_BS9_Msk   (0x1UL << GPIO_BSRR_BS9_Pos)
#define GPIO_BSRR_BS9   GPIO_BSRR_BS9_Msk
#define GPIO_BSRR_BS10_Pos   (10U)
#define GPIO_BSRR_BS10_Msk   (0x1UL << GPIO_BSRR_BS10_Pos)
#define GPIO_BSRR_BS10   GPIO_BSRR_BS10_Msk
#define GPIO_BSRR_BS11_Pos   (11U)
#define GPIO_BSRR_BS11_Msk   (0x1UL << GPIO_BSRR_BS11_Pos)
#define GPIO_BSRR_BS11   GPIO_BSRR_BS11_Msk
#define GPIO_BSRR_BS12_Pos   (12U)
#define GPIO_BSRR_BS12_Msk   (0x1UL << GPIO_BSRR_BS12_Pos)
#define GPIO_BSRR_BS12   GPIO_BSRR_BS12_Msk
#define GPIO_BSRR_BS13_Pos   (13U)
#define GPIO_BSRR_BS13_Msk   (0x1UL << GPIO_BSRR_BS13_Pos)
#define GPIO_BSRR_BS13   GPIO_BSRR_BS13_Msk
#define GPIO_BSRR_BS14_Pos   (14U)
#define GPIO_BSRR_BS14_Msk   (0x1UL << GPIO_BSRR_BS14_Pos)
#define GPIO_BSRR_BS14   GPIO_BSRR_BS14_Msk
#define GPIO_BSRR_BS15_Pos   (15U)
#define GPIO_BSRR_BS15_Msk   (0x1UL << GPIO_BSRR_BS15_Pos)
#define GPIO_BSRR_BS15   GPIO_BSRR_BS15_Msk
#define GPIO_BSRR_BR0_Pos   (16U)
#define GPIO_BSRR_BR0_Msk   (0x1UL << GPIO_BSRR_BR0_Pos)
#define GPIO_BSRR_BR0   GPIO_BSRR_BR0_Msk
#define GPIO_BSRR_BR1_Pos   (17U)
#define GPIO_BSRR_BR1_Msk   (0x1UL << GPIO_BSRR_BR1_Pos)
#define GPIO_BSRR_BR1   GPIO_BSRR_BR1_Msk
#define GPIO_BSRR_BR2_Pos   (18U)
#define GPIO_BSRR_BR2_Msk   (0x1UL << GPIO_BSRR_BR2_Pos)
#define GPIO_BSRR_BR2   GPIO_BSRR_BR2_Msk
#define GPIO_BSRR_BR3_Pos   (19U)
#define GPIO_BSRR_BR3_Msk   (0x1UL << GPIO_BSRR_BR3_Pos)
#define GPIO_BSRR_BR3   GPIO_BSRR_BR3_Msk
#define GPIO_BSRR_BR4_Pos   (20U)
#define GPIO_BSRR_BR4_Msk   (0x1UL << GPIO_BSRR_BR4_Pos)
#define GPIO_BSRR_BR4   GPIO_BSRR_BR4_Msk
#define GPIO_BSRR_BR5_Pos   (21U)
#define GPIO_BSRR_BR5_Msk   (0x1UL << GPIO_BSRR_BR5_Pos)
#define GPIO_BSRR_BR5   GPIO_BSRR_BR5_Msk
#define GPIO_BSRR_BR6_Pos   (22U)
#define GPIO_BSRR_BR6_Msk   (0x1UL << GPIO_BSRR_BR6_Pos)
#define GPIO_BSRR_BR6   GPIO_BSRR_BR6_Msk
#define GPIO_BSRR_BR7_Pos   (23U)
#define GPIO_BSRR_BR7_Msk   (0x1UL << GPIO_BSRR_BR7_Pos)
#define GPIO_BSRR_BR7   GPIO_BSRR_BR7_Msk
#define GPIO_BSRR_BR8_Pos   (24U)
#define GPIO_BSRR_BR8_Msk   (0x1UL << GPIO_BSRR_BR8_Pos)
#define GPIO_BSRR_BR8   GPIO_BSRR_BR8_Msk
#define GPIO_BSRR_BR9_Pos   (25U)
#define GPIO_BSRR_BR9_Msk   (0x1UL << GPIO_BSRR_BR9_Pos)
#define GPIO_BSRR_BR9   GPIO_BSRR_BR9_Msk
#define GPIO_BSRR_BR10_Pos   (26U)
#define GPIO_BSRR_BR10_Msk   (0x1UL << GPIO_BSRR_BR10_Pos)
#define GPIO_BSRR_BR10   GPIO_BSRR_BR10_Msk
#define GPIO_BSRR_BR11_Pos   (27U)
#define GPIO_BSRR_BR11_Msk   (0x1UL << GPIO_BSRR_BR11_Pos)
#define GPIO_BSRR_BR11   GPIO_BSRR_BR11_Msk
#define GPIO_BSRR_BR12_Pos   (28U)
#define GPIO_BSRR_BR12_Msk   (0x1UL << GPIO_BSRR_BR12_Pos)
#define GPIO_BSRR_BR12   GPIO_BSRR_BR12_Msk
#define GPIO_BSRR_BR13_Pos   (29U)
#define GPIO_BSRR_BR13_Msk   (0x1UL << GPIO_BSRR_BR13_Pos)
#define GPIO_BSRR_BR13   GPIO_BSRR_BR13_Msk
#define GPIO_BSRR_BR14_Pos   (30U)
#define GPIO_BSRR_BR14_Msk   (0x1UL << GPIO_BSRR_BR14_Pos)
#define GPIO_BSRR_BR14   GPIO_BSRR_BR14_Msk
#define GPIO_BSRR_BR15_Pos   (31U)
#define GPIO_BSRR_BR15_Msk   (0x1UL << GPIO_BSRR_BR15_Pos)
#define GPIO_BSRR_BR15   GPIO_BSRR_BR15_Msk
#define GPIO_LCKR_LCK0_Pos   (0U)
#define GPIO_LCKR_LCK0_Msk   (0x1UL << GPIO_LCKR_LCK0_Pos)
#define GPIO_LCKR_LCK0   GPIO_LCKR_LCK0_Msk
#define GPIO_LCKR_LCK1_Pos   (1U)
#define GPIO_LCKR_LCK1_Msk   (0x1UL << GPIO_LCKR_LCK1_Pos)
#define GPIO_LCKR_LCK1   GPIO_LCKR_LCK1_Msk
#define GPIO_LCKR_LCK2_Pos   (2U)
#define GPIO_LCKR_LCK2_Msk   (0x1UL << GPIO_LCKR_LCK2_Pos)
#define GPIO_LCKR_LCK2   GPIO_LCKR_LCK2_Msk
#define GPIO_LCKR_LCK3_Pos   (3U)
#define GPIO_LCKR_LCK3_Msk   (0x1UL << GPIO_LCKR_LCK3_Pos)
#define GPIO_LCKR_LCK3   GPIO_LCKR_LCK3_Msk
#define GPIO_LCKR_LCK4_Pos   (4U)
#define GPIO_LCKR_LCK4_Msk   (0x1UL << GPIO_LCKR_LCK4_Pos)
#define GPIO_LCKR_LCK4   GPIO_LCKR_LCK4_Msk
#define GPIO_LCKR_LCK5_Pos   (5U)
#define GPIO_LCKR_LCK5_Msk   (0x1UL << GPIO_LCKR_LCK5_Pos)
#define GPIO_LCKR_LCK5   GPIO_LCKR_LCK5_Msk
#define GPIO_LCKR_LCK6_Pos   (6U)
#define GPIO_LCKR_LCK6_Msk   (0x1UL << GPIO_LCKR_LCK6_Pos)
#define GPIO_LCKR_LCK6   GPIO_LCKR_LCK6_Msk
#define GPIO_LCKR_LCK7_Pos   (7U)
#define GPIO_LCKR_LCK7_Msk   (0x1UL << GPIO_LCKR_LCK7_Pos)
#define GPIO_LCKR_LCK7   GPIO_LCKR_LCK7_Msk
#define GPIO_LCKR_LCK8_Pos   (8U)
#define GPIO_LCKR_LCK8_Msk   (0x1UL << GPIO_LCKR_LCK8_Pos)
#define GPIO_LCKR_LCK8   GPIO_LCKR_LCK8_Msk
#define GPIO_LCKR_LCK9_Pos   (9U)
#define GPIO_LCKR_LCK9_Msk   (0x1UL << GPIO_LCKR_LCK9_Pos)
#define GPIO_LCKR_LCK9   GPIO_LCKR_LCK9_Msk
#define GPIO_LCKR_LCK10_Pos   (10U)
#define GPIO_LCKR_LCK10_Msk   (0x1UL << GPIO_LCKR_LCK10_Pos)
#define GPIO_LCKR_LCK10   GPIO_LCKR_LCK10_Msk
#define GPIO_LCKR_LCK11_Pos   (11U)
#define GPIO_LCKR_LCK11_Msk   (0x1UL << GPIO_LCKR_LCK11_Pos)
#define GPIO_LCKR_LCK11   GPIO_LCKR_LCK11_Msk
#define GPIO_LCKR_LCK12_Pos   (12U)
#define GPIO_LCKR_LCK12_Msk   (0x1UL << GPIO_LCKR_LCK12_Pos)
#define GPIO_LCKR_LCK12   GPIO_LCKR_LCK12_Msk
#define GPIO_LCKR_LCK13_Pos   (13U)
#define GPIO_LCKR_LCK13_Msk   (0x1UL << GPIO_LCKR_LCK13_Pos)
#define GPIO_LCKR_LCK13   GPIO_LCKR_LCK13_Msk
#define GPIO_LCKR_LCK14_Pos   (14U)
#define GPIO_LCKR_LCK14_Msk   (0x1UL << GPIO_LCKR_LCK14_Pos)
#define GPIO_LCKR_LCK14   GPIO_LCKR_LCK14_Msk
#define GPIO_LCKR_LCK15_Pos   (15U)
#define GPIO_LCKR_LCK15_Msk   (0x1UL << GPIO_LCKR_LCK15_Pos)
#define GPIO_LCKR_LCK15   GPIO_LCKR_LCK15_Msk
#define GPIO_LCKR_LCKK_Pos   (16U)
#define GPIO_LCKR_LCKK_Msk   (0x1UL << GPIO_LCKR_LCKK_Pos)
#define GPIO_LCKR_LCKK   GPIO_LCKR_LCKK_Msk
#define GPIO_AFRL_AFSEL0_Pos   (0U)
#define GPIO_AFRL_AFSEL0_Msk   (0xFUL << GPIO_AFRL_AFSEL0_Pos)
#define GPIO_AFRL_AFSEL0   GPIO_AFRL_AFSEL0_Msk
#define GPIO_AFRL_AFSEL0_0   (0x1UL << GPIO_AFRL_AFSEL0_Pos)
#define GPIO_AFRL_AFSEL0_1   (0x2UL << GPIO_AFRL_AFSEL0_Pos)
#define GPIO_AFRL_AFSEL0_2   (0x4UL << GPIO_AFRL_AFSEL0_Pos)
#define GPIO_AFRL_AFSEL0_3   (0x8UL << GPIO_AFRL_AFSEL0_Pos)
#define GPIO_AFRL_AFSEL1_Pos   (4U)
#define GPIO_AFRL_AFSEL1_Msk   (0xFUL << GPIO_AFRL_AFSEL1_Pos)
#define GPIO_AFRL_AFSEL1   GPIO_AFRL_AFSEL1_Msk
#define GPIO_AFRL_AFSEL1_0   (0x1UL << GPIO_AFRL_AFSEL1_Pos)
#define GPIO_AFRL_AFSEL1_1   (0x2UL << GPIO_AFRL_AFSEL1_Pos)
#define GPIO_AFRL_AFSEL1_2   (0x4UL << GPIO_AFRL_AFSEL1_Pos)
#define GPIO_AFRL_AFSEL1_3   (0x8UL << GPIO_AFRL_AFSEL1_Pos)
#define GPIO_AFRL_AFSEL2_Pos   (8U)
#define GPIO_AFRL_AFSEL2_Msk   (0xFUL << GPIO_AFRL_AFSEL2_Pos)
#define GPIO_AFRL_AFSEL2   GPIO_AFRL_AFSEL2_Msk
#define GPIO_AFRL_AFSEL2_0   (0x1UL << GPIO_AFRL_AFSEL2_Pos)
#define GPIO_AFRL_AFSEL2_1   (0x2UL << GPIO_AFRL_AFSEL2_Pos)
#define GPIO_AFRL_AFSEL2_2   (0x4UL << GPIO_AFRL_AFSEL2_Pos)
#define GPIO_AFRL_AFSEL2_3   (0x8UL << GPIO_AFRL_AFSEL2_Pos)
#define GPIO_AFRL_AFSEL3_Pos   (12U)
#define GPIO_AFRL_AFSEL3_Msk   (0xFUL << GPIO_AFRL_AFSEL3_Pos)
#define GPIO_AFRL_AFSEL3   GPIO_AFRL_AFSEL3_Msk
#define GPIO_AFRL_AFSEL3_0   (0x1UL << GPIO_AFRL_AFSEL3_Pos)
#define GPIO_AFRL_AFSEL3_1   (0x2UL << GPIO_AFRL_AFSEL3_Pos)
#define GPIO_AFRL_AFSEL3_2   (0x4UL << GPIO_AFRL_AFSEL3_Pos)
#define GPIO_AFRL_AFSEL3_3   (0x8UL << GPIO_AFRL_AFSEL3_Pos)
#define GPIO_AFRL_AFSEL4_Pos   (16U)
#define GPIO_AFRL_AFSEL4_Msk   (0xFUL << GPIO_AFRL_AFSEL4_Pos)
#define GPIO_AFRL_AFSEL4   GPIO_AFRL_AFSEL4_Msk
#define GPIO_AFRL_AFSEL4_0   (0x1UL << GPIO_AFRL_AFSEL4_Pos)
#define GPIO_AFRL_AFSEL4_1   (0x2UL << GPIO_AFRL_AFSEL4_Pos)
#define GPIO_AFRL_AFSEL4_2   (0x4UL << GPIO_AFRL_AFSEL4_Pos)
#define GPIO_AFRL_AFSEL4_3   (0x8UL << GPIO_AFRL_AFSEL4_Pos)
#define GPIO_AFRL_AFSEL5_Pos   (20U)
#define GPIO_AFRL_AFSEL5_Msk   (0xFUL << GPIO_AFRL_AFSEL5_Pos)
#define GPIO_AFRL_AFSEL5   GPIO_AFRL_AFSEL5_Msk
#define GPIO_AFRL_AFSEL5_0   (0x1UL << GPIO_AFRL_AFSEL5_Pos)
#define GPIO_AFRL_AFSEL5_1   (0x2UL << GPIO_AFRL_AFSEL5_Pos)
#define GPIO_AFRL_AFSEL5_2   (0x4UL << GPIO_AFRL_AFSEL5_Pos)
#define GPIO_AFRL_AFSEL5_3   (0x8UL << GPIO_AFRL_AFSEL5_Pos)
#define GPIO_AFRL_AFSEL6_Pos   (24U)
#define GPIO_AFRL_AFSEL6_Msk   (0xFUL << GPIO_AFRL_AFSEL6_Pos)
#define GPIO_AFRL_AFSEL6   GPIO_AFRL_AFSEL6_Msk
#define GPIO_AFRL_AFSEL6_0   (0x1UL << GPIO_AFRL_AFSEL6_Pos)
#define GPIO_AFRL_AFSEL6_1   (0x2UL << GPIO_AFRL_AFSEL6_Pos)
#define GPIO_AFRL_AFSEL6_2   (0x4UL << GPIO_AFRL_AFSEL6_Pos)
#define GPIO_AFRL_AFSEL6_3   (0x8UL << GPIO_AFRL_AFSEL6_Pos)
#define GPIO_AFRL_AFSEL7_Pos   (28U)
#define GPIO_AFRL_AFSEL7_Msk   (0xFUL << GPIO_AFRL_AFSEL7_Pos)
#define GPIO_AFRL_AFSEL7   GPIO_AFRL_AFSEL7_Msk
#define GPIO_AFRL_AFSEL7_0   (0x1UL << GPIO_AFRL_AFSEL7_Pos)
#define GPIO_AFRL_AFSEL7_1   (0x2UL << GPIO_AFRL_AFSEL7_Pos)
#define GPIO_AFRL_AFSEL7_2   (0x4UL << GPIO_AFRL_AFSEL7_Pos)
#define GPIO_AFRL_AFSEL7_3   (0x8UL << GPIO_AFRL_AFSEL7_Pos)
#define GPIO_AFRL_AFRL0   GPIO_AFRL_AFSEL0
#define GPIO_AFRL_AFRL1   GPIO_AFRL_AFSEL1
#define GPIO_AFRL_AFRL2   GPIO_AFRL_AFSEL2
#define GPIO_AFRL_AFRL3   GPIO_AFRL_AFSEL3
#define GPIO_AFRL_AFRL4   GPIO_AFRL_AFSEL4
#define GPIO_AFRL_AFRL5   GPIO_AFRL_AFSEL5
#define GPIO_AFRL_AFRL6   GPIO_AFRL_AFSEL6
#define GPIO_AFRL_AFRL7   GPIO_AFRL_AFSEL7
#define GPIO_AFRH_AFSEL8_Pos   (0U)
#define GPIO_AFRH_AFSEL8_Msk   (0xFUL << GPIO_AFRH_AFSEL8_Pos)
#define GPIO_AFRH_AFSEL8   GPIO_AFRH_AFSEL8_Msk
#define GPIO_AFRH_AFSEL8_0   (0x1UL << GPIO_AFRH_AFSEL8_Pos)
#define GPIO_AFRH_AFSEL8_1   (0x2UL << GPIO_AFRH_AFSEL8_Pos)
#define GPIO_AFRH_AFSEL8_2   (0x4UL << GPIO_AFRH_AFSEL8_Pos)
#define GPIO_AFRH_AFSEL8_3   (0x8UL << GPIO_AFRH_AFSEL8_Pos)
#define GPIO_AFRH_AFSEL9_Pos   (4U)
#define GPIO_AFRH_AFSEL9_Msk   (0xFUL << GPIO_AFRH_AFSEL9_Pos)
#define GPIO_AFRH_AFSEL9   GPIO_AFRH_AFSEL9_Msk
#define GPIO_AFRH_AFSEL9_0   (0x1UL << GPIO_AFRH_AFSEL9_Pos)
#define GPIO_AFRH_AFSEL9_1   (0x2UL << GPIO_AFRH_AFSEL9_Pos)
#define GPIO_AFRH_AFSEL9_2   (0x4UL << GPIO_AFRH_AFSEL9_Pos)
#define GPIO_AFRH_AFSEL9_3   (0x8UL << GPIO_AFRH_AFSEL9_Pos)
#define GPIO_AFRH_AFSEL10_Pos   (8U)
#define GPIO_AFRH_AFSEL10_Msk   (0xFUL << GPIO_AFRH_AFSEL10_Pos)
#define GPIO_AFRH_AFSEL10   GPIO_AFRH_AFSEL10_Msk
#define GPIO_AFRH_AFSEL10_0   (0x1UL << GPIO_AFRH_AFSEL10_Pos)
#define GPIO_AFRH_AFSEL10_1   (0x2UL << GPIO_AFRH_AFSEL10_Pos)
#define GPIO_AFRH_AFSEL10_2   (0x4UL << GPIO_AFRH_AFSEL10_Pos)
#define GPIO_AFRH_AFSEL10_3   (0x8UL << GPIO_AFRH_AFSEL10_Pos)
#define GPIO_AFRH_AFSEL11_Pos   (12U)
#define GPIO_AFRH_AFSEL11_Msk   (0xFUL << GPIO_AFRH_AFSEL11_Pos)
#define GPIO_AFRH_AFSEL11   GPIO_AFRH_AFSEL11_Msk
#define GPIO_AFRH_AFSEL11_0   (0x1UL << GPIO_AFRH_AFSEL11_Pos)
#define GPIO_AFRH_AFSEL11_1   (0x2UL << GPIO_AFRH_AFSEL11_Pos)
#define GPIO_AFRH_AFSEL11_2   (0x4UL << GPIO_AFRH_AFSEL11_Pos)
#define GPIO_AFRH_AFSEL11_3   (0x8UL << GPIO_AFRH_AFSEL11_Pos)
#define GPIO_AFRH_AFSEL12_Pos   (16U)
#define GPIO_AFRH_AFSEL12_Msk   (0xFUL << GPIO_AFRH_AFSEL12_Pos)
#define GPIO_AFRH_AFSEL12   GPIO_AFRH_AFSEL12_Msk
#define GPIO_AFRH_AFSEL12_0   (0x1UL << GPIO_AFRH_AFSEL12_Pos)
#define GPIO_AFRH_AFSEL12_1   (0x2UL << GPIO_AFRH_AFSEL12_Pos)
#define GPIO_AFRH_AFSEL12_2   (0x4UL << GPIO_AFRH_AFSEL12_Pos)
#define GPIO_AFRH_AFSEL12_3   (0x8UL << GPIO_AFRH_AFSEL12_Pos)
#define GPIO_AFRH_AFSEL13_Pos   (20U)
#define GPIO_AFRH_AFSEL13_Msk   (0xFUL << GPIO_AFRH_AFSEL13_Pos)
#define GPIO_AFRH_AFSEL13   GPIO_AFRH_AFSEL13_Msk
#define GPIO_AFRH_AFSEL13_0   (0x1UL << GPIO_AFRH_AFSEL13_Pos)
#define GPIO_AFRH_AFSEL13_1   (0x2UL << GPIO_AFRH_AFSEL13_Pos)
#define GPIO_AFRH_AFSEL13_2   (0x4UL << GPIO_AFRH_AFSEL13_Pos)
#define GPIO_AFRH_AFSEL13_3   (0x8UL << GPIO_AFRH_AFSEL13_Pos)
#define GPIO_AFRH_AFSEL14_Pos   (24U)
#define GPIO_AFRH_AFSEL14_Msk   (0xFUL << GPIO_AFRH_AFSEL14_Pos)
#define GPIO_AFRH_AFSEL14   GPIO_AFRH_AFSEL14_Msk
#define GPIO_AFRH_AFSEL14_0   (0x1UL << GPIO_AFRH_AFSEL14_Pos)
#define GPIO_AFRH_AFSEL14_1   (0x2UL << GPIO_AFRH_AFSEL14_Pos)
#define GPIO_AFRH_AFSEL14_2   (0x4UL << GPIO_AFRH_AFSEL14_Pos)
#define GPIO_AFRH_AFSEL14_3   (0x8UL << GPIO_AFRH_AFSEL14_Pos)
#define GPIO_AFRH_AFSEL15_Pos   (28U)
#define GPIO_AFRH_AFSEL15_Msk   (0xFUL << GPIO_AFRH_AFSEL15_Pos)
#define GPIO_AFRH_AFSEL15   GPIO_AFRH_AFSEL15_Msk
#define GPIO_AFRH_AFSEL15_0   (0x1UL << GPIO_AFRH_AFSEL15_Pos)
#define GPIO_AFRH_AFSEL15_1   (0x2UL << GPIO_AFRH_AFSEL15_Pos)
#define GPIO_AFRH_AFSEL15_2   (0x4UL << GPIO_AFRH_AFSEL15_Pos)
#define GPIO_AFRH_AFSEL15_3   (0x8UL << GPIO_AFRH_AFSEL15_Pos)
#define GPIO_AFRH_AFRH0   GPIO_AFRH_AFSEL8
#define GPIO_AFRH_AFRH1   GPIO_AFRH_AFSEL9
#define GPIO_AFRH_AFRH2   GPIO_AFRH_AFSEL10
#define GPIO_AFRH_AFRH3   GPIO_AFRH_AFSEL11
#define GPIO_AFRH_AFRH4   GPIO_AFRH_AFSEL12
#define GPIO_AFRH_AFRH5   GPIO_AFRH_AFSEL13
#define GPIO_AFRH_AFRH6   GPIO_AFRH_AFSEL14
#define GPIO_AFRH_AFRH7   GPIO_AFRH_AFSEL15
#define HSEM_R_PROCID_Pos   (0U)
#define HSEM_R_PROCID_Msk   (0xFFUL << HSEM_R_PROCID_Pos)
#define HSEM_R_PROCID   HSEM_R_PROCID_Msk
#define HSEM_R_COREID_Pos   (8U)
#define HSEM_R_COREID_Msk   (0xFFUL << HSEM_R_COREID_Pos)
#define HSEM_R_COREID   HSEM_R_COREID_Msk
#define HSEM_R_LOCK_Pos   (31U)
#define HSEM_R_LOCK_Msk   (0x1UL << HSEM_R_LOCK_Pos)
#define HSEM_R_LOCK   HSEM_R_LOCK_Msk
#define HSEM_RLR_PROCID_Pos   (0U)
#define HSEM_RLR_PROCID_Msk   (0xFFUL << HSEM_RLR_PROCID_Pos)
#define HSEM_RLR_PROCID   HSEM_RLR_PROCID_Msk
#define HSEM_RLR_COREID_Pos   (8U)
#define HSEM_RLR_COREID_Msk   (0xFFUL << HSEM_RLR_COREID_Pos)
#define HSEM_RLR_COREID   HSEM_RLR_COREID_Msk
#define HSEM_RLR_LOCK_Pos   (31U)
#define HSEM_RLR_LOCK_Msk   (0x1UL << HSEM_RLR_LOCK_Pos)
#define HSEM_RLR_LOCK   HSEM_RLR_LOCK_Msk
#define HSEM_C1IER_ISE0_Pos   (0U)
#define HSEM_C1IER_ISE0_Msk   (0x1UL << HSEM_C1IER_ISE0_Pos)
#define HSEM_C1IER_ISE0   HSEM_C1IER_ISE0_Msk
#define HSEM_C1IER_ISE1_Pos   (1U)
#define HSEM_C1IER_ISE1_Msk   (0x1UL << HSEM_C1IER_ISE1_Pos)
#define HSEM_C1IER_ISE1   HSEM_C1IER_ISE1_Msk
#define HSEM_C1IER_ISE2_Pos   (2U)
#define HSEM_C1IER_ISE2_Msk   (0x1UL << HSEM_C1IER_ISE2_Pos)
#define HSEM_C1IER_ISE2   HSEM_C1IER_ISE2_Msk
#define HSEM_C1IER_ISE3_Pos   (3U)
#define HSEM_C1IER_ISE3_Msk   (0x1UL << HSEM_C1IER_ISE3_Pos)
#define HSEM_C1IER_ISE3   HSEM_C1IER_ISE3_Msk
#define HSEM_C1IER_ISE4_Pos   (4U)
#define HSEM_C1IER_ISE4_Msk   (0x1UL << HSEM_C1IER_ISE4_Pos)
#define HSEM_C1IER_ISE4   HSEM_C1IER_ISE4_Msk
#define HSEM_C1IER_ISE5_Pos   (5U)
#define HSEM_C1IER_ISE5_Msk   (0x1UL << HSEM_C1IER_ISE5_Pos)
#define HSEM_C1IER_ISE5   HSEM_C1IER_ISE5_Msk
#define HSEM_C1IER_ISE6_Pos   (6U)
#define HSEM_C1IER_ISE6_Msk   (0x1UL << HSEM_C1IER_ISE6_Pos)
#define HSEM_C1IER_ISE6   HSEM_C1IER_ISE6_Msk
#define HSEM_C1IER_ISE7_Pos   (7U)
#define HSEM_C1IER_ISE7_Msk   (0x1UL << HSEM_C1IER_ISE7_Pos)
#define HSEM_C1IER_ISE7   HSEM_C1IER_ISE7_Msk
#define HSEM_C1IER_ISE8_Pos   (8U)
#define HSEM_C1IER_ISE8_Msk   (0x1UL << HSEM_C1IER_ISE8_Pos)
#define HSEM_C1IER_ISE8   HSEM_C1IER_ISE8_Msk
#define HSEM_C1IER_ISE9_Pos   (9U)
#define HSEM_C1IER_ISE9_Msk   (0x1UL << HSEM_C1IER_ISE9_Pos)
#define HSEM_C1IER_ISE9   HSEM_C1IER_ISE9_Msk
#define HSEM_C1IER_ISE10_Pos   (10U)
#define HSEM_C1IER_ISE10_Msk   (0x1UL << HSEM_C1IER_ISE10_Pos)
#define HSEM_C1IER_ISE10   HSEM_C1IER_ISE10_Msk
#define HSEM_C1IER_ISE11_Pos   (11U)
#define HSEM_C1IER_ISE11_Msk   (0x1UL << HSEM_C1IER_ISE11_Pos)
#define HSEM_C1IER_ISE11   HSEM_C1IER_ISE11_Msk
#define HSEM_C1IER_ISE12_Pos   (12U)
#define HSEM_C1IER_ISE12_Msk   (0x1UL << HSEM_C1IER_ISE12_Pos)
#define HSEM_C1IER_ISE12   HSEM_C1IER_ISE12_Msk
#define HSEM_C1IER_ISE13_Pos   (13U)
#define HSEM_C1IER_ISE13_Msk   (0x1UL << HSEM_C1IER_ISE13_Pos)
#define HSEM_C1IER_ISE13   HSEM_C1IER_ISE13_Msk
#define HSEM_C1IER_ISE14_Pos   (14U)
#define HSEM_C1IER_ISE14_Msk   (0x1UL << HSEM_C1IER_ISE14_Pos)
#define HSEM_C1IER_ISE14   HSEM_C1IER_ISE14_Msk
#define HSEM_C1IER_ISE15_Pos   (15U)
#define HSEM_C1IER_ISE15_Msk   (0x1UL << HSEM_C1IER_ISE15_Pos)
#define HSEM_C1IER_ISE15   HSEM_C1IER_ISE15_Msk
#define HSEM_C1IER_ISE16_Pos   (16U)
#define HSEM_C1IER_ISE16_Msk   (0x1UL << HSEM_C1IER_ISE16_Pos)
#define HSEM_C1IER_ISE16   HSEM_C1IER_ISE16_Msk
#define HSEM_C1IER_ISE17_Pos   (17U)
#define HSEM_C1IER_ISE17_Msk   (0x1UL << HSEM_C1IER_ISE17_Pos)
#define HSEM_C1IER_ISE17   HSEM_C1IER_ISE17_Msk
#define HSEM_C1IER_ISE18_Pos   (18U)
#define HSEM_C1IER_ISE18_Msk   (0x1UL << HSEM_C1IER_ISE18_Pos)
#define HSEM_C1IER_ISE18   HSEM_C1IER_ISE18_Msk
#define HSEM_C1IER_ISE19_Pos   (19U)
#define HSEM_C1IER_ISE19_Msk   (0x1UL << HSEM_C1IER_ISE19_Pos)
#define HSEM_C1IER_ISE19   HSEM_C1IER_ISE19_Msk
#define HSEM_C1IER_ISE20_Pos   (20U)
#define HSEM_C1IER_ISE20_Msk   (0x1UL << HSEM_C1IER_ISE20_Pos)
#define HSEM_C1IER_ISE20   HSEM_C1IER_ISE20_Msk
#define HSEM_C1IER_ISE21_Pos   (21U)
#define HSEM_C1IER_ISE21_Msk   (0x1UL << HSEM_C1IER_ISE21_Pos)
#define HSEM_C1IER_ISE21   HSEM_C1IER_ISE21_Msk
#define HSEM_C1IER_ISE22_Pos   (22U)
#define HSEM_C1IER_ISE22_Msk   (0x1UL << HSEM_C1IER_ISE22_Pos)
#define HSEM_C1IER_ISE22   HSEM_C1IER_ISE22_Msk
#define HSEM_C1IER_ISE23_Pos   (23U)
#define HSEM_C1IER_ISE23_Msk   (0x1UL << HSEM_C1IER_ISE23_Pos)
#define HSEM_C1IER_ISE23   HSEM_C1IER_ISE23_Msk
#define HSEM_C1IER_ISE24_Pos   (24U)
#define HSEM_C1IER_ISE24_Msk   (0x1UL << HSEM_C1IER_ISE24_Pos)
#define HSEM_C1IER_ISE24   HSEM_C1IER_ISE24_Msk
#define HSEM_C1IER_ISE25_Pos   (25U)
#define HSEM_C1IER_ISE25_Msk   (0x1UL << HSEM_C1IER_ISE25_Pos)
#define HSEM_C1IER_ISE25   HSEM_C1IER_ISE25_Msk
#define HSEM_C1IER_ISE26_Pos   (26U)
#define HSEM_C1IER_ISE26_Msk   (0x1UL << HSEM_C1IER_ISE26_Pos)
#define HSEM_C1IER_ISE26   HSEM_C1IER_ISE26_Msk
#define HSEM_C1IER_ISE27_Pos   (27U)
#define HSEM_C1IER_ISE27_Msk   (0x1UL << HSEM_C1IER_ISE27_Pos)
#define HSEM_C1IER_ISE27   HSEM_C1IER_ISE27_Msk
#define HSEM_C1IER_ISE28_Pos   (28U)
#define HSEM_C1IER_ISE28_Msk   (0x1UL << HSEM_C1IER_ISE28_Pos)
#define HSEM_C1IER_ISE28   HSEM_C1IER_ISE28_Msk
#define HSEM_C1IER_ISE29_Pos   (29U)
#define HSEM_C1IER_ISE29_Msk   (0x1UL << HSEM_C1IER_ISE29_Pos)
#define HSEM_C1IER_ISE29   HSEM_C1IER_ISE29_Msk
#define HSEM_C1IER_ISE30_Pos   (30U)
#define HSEM_C1IER_ISE30_Msk   (0x1UL << HSEM_C1IER_ISE30_Pos)
#define HSEM_C1IER_ISE30   HSEM_C1IER_ISE30_Msk
#define HSEM_C1IER_ISE31_Pos   (31U)
#define HSEM_C1IER_ISE31_Msk   (0x1UL << HSEM_C1IER_ISE31_Pos)
#define HSEM_C1IER_ISE31   HSEM_C1IER_ISE31_Msk
#define HSEM_C1ICR_ISC0_Pos   (0U)
#define HSEM_C1ICR_ISC0_Msk   (0x1UL << HSEM_C1ICR_ISC0_Pos)
#define HSEM_C1ICR_ISC0   HSEM_C1ICR_ISC0_Msk
#define HSEM_C1ICR_ISC1_Pos   (1U)
#define HSEM_C1ICR_ISC1_Msk   (0x1UL << HSEM_C1ICR_ISC1_Pos)
#define HSEM_C1ICR_ISC1   HSEM_C1ICR_ISC1_Msk
#define HSEM_C1ICR_ISC2_Pos   (2U)
#define HSEM_C1ICR_ISC2_Msk   (0x1UL << HSEM_C1ICR_ISC2_Pos)
#define HSEM_C1ICR_ISC2   HSEM_C1ICR_ISC2_Msk
#define HSEM_C1ICR_ISC3_Pos   (3U)
#define HSEM_C1ICR_ISC3_Msk   (0x1UL << HSEM_C1ICR_ISC3_Pos)
#define HSEM_C1ICR_ISC3   HSEM_C1ICR_ISC3_Msk
#define HSEM_C1ICR_ISC4_Pos   (4U)
#define HSEM_C1ICR_ISC4_Msk   (0x1UL << HSEM_C1ICR_ISC4_Pos)
#define HSEM_C1ICR_ISC4   HSEM_C1ICR_ISC4_Msk
#define HSEM_C1ICR_ISC5_Pos   (5U)
#define HSEM_C1ICR_ISC5_Msk   (0x1UL << HSEM_C1ICR_ISC5_Pos)
#define HSEM_C1ICR_ISC5   HSEM_C1ICR_ISC5_Msk
#define HSEM_C1ICR_ISC6_Pos   (6U)
#define HSEM_C1ICR_ISC6_Msk   (0x1UL << HSEM_C1ICR_ISC6_Pos)
#define HSEM_C1ICR_ISC6   HSEM_C1ICR_ISC6_Msk
#define HSEM_C1ICR_ISC7_Pos   (7U)
#define HSEM_C1ICR_ISC7_Msk   (0x1UL << HSEM_C1ICR_ISC7_Pos)
#define HSEM_C1ICR_ISC7   HSEM_C1ICR_ISC7_Msk
#define HSEM_C1ICR_ISC8_Pos   (8U)
#define HSEM_C1ICR_ISC8_Msk   (0x1UL << HSEM_C1ICR_ISC8_Pos)
#define HSEM_C1ICR_ISC8   HSEM_C1ICR_ISC8_Msk
#define HSEM_C1ICR_ISC9_Pos   (9U)
#define HSEM_C1ICR_ISC9_Msk   (0x1UL << HSEM_C1ICR_ISC9_Pos)
#define HSEM_C1ICR_ISC9   HSEM_C1ICR_ISC9_Msk
#define HSEM_C1ICR_ISC10_Pos   (10U)
#define HSEM_C1ICR_ISC10_Msk   (0x1UL << HSEM_C1ICR_ISC10_Pos)
#define HSEM_C1ICR_ISC10   HSEM_C1ICR_ISC10_Msk
#define HSEM_C1ICR_ISC11_Pos   (11U)
#define HSEM_C1ICR_ISC11_Msk   (0x1UL << HSEM_C1ICR_ISC11_Pos)
#define HSEM_C1ICR_ISC11   HSEM_C1ICR_ISC11_Msk
#define HSEM_C1ICR_ISC12_Pos   (12U)
#define HSEM_C1ICR_ISC12_Msk   (0x1UL << HSEM_C1ICR_ISC12_Pos)
#define HSEM_C1ICR_ISC12   HSEM_C1ICR_ISC12_Msk
#define HSEM_C1ICR_ISC13_Pos   (13U)
#define HSEM_C1ICR_ISC13_Msk   (0x1UL << HSEM_C1ICR_ISC13_Pos)
#define HSEM_C1ICR_ISC13   HSEM_C1ICR_ISC13_Msk
#define HSEM_C1ICR_ISC14_Pos   (14U)
#define HSEM_C1ICR_ISC14_Msk   (0x1UL << HSEM_C1ICR_ISC14_Pos)
#define HSEM_C1ICR_ISC14   HSEM_C1ICR_ISC14_Msk
#define HSEM_C1ICR_ISC15_Pos   (15U)
#define HSEM_C1ICR_ISC15_Msk   (0x1UL << HSEM_C1ICR_ISC15_Pos)
#define HSEM_C1ICR_ISC15   HSEM_C1ICR_ISC15_Msk
#define HSEM_C1ICR_ISC16_Pos   (16U)
#define HSEM_C1ICR_ISC16_Msk   (0x1UL << HSEM_C1ICR_ISC16_Pos)
#define HSEM_C1ICR_ISC16   HSEM_C1ICR_ISC16_Msk
#define HSEM_C1ICR_ISC17_Pos   (17U)
#define HSEM_C1ICR_ISC17_Msk   (0x1UL << HSEM_C1ICR_ISC17_Pos)
#define HSEM_C1ICR_ISC17   HSEM_C1ICR_ISC17_Msk
#define HSEM_C1ICR_ISC18_Pos   (18U)
#define HSEM_C1ICR_ISC18_Msk   (0x1UL << HSEM_C1ICR_ISC18_Pos)
#define HSEM_C1ICR_ISC18   HSEM_C1ICR_ISC18_Msk
#define HSEM_C1ICR_ISC19_Pos   (19U)
#define HSEM_C1ICR_ISC19_Msk   (0x1UL << HSEM_C1ICR_ISC19_Pos)
#define HSEM_C1ICR_ISC19   HSEM_C1ICR_ISC19_Msk
#define HSEM_C1ICR_ISC20_Pos   (20U)
#define HSEM_C1ICR_ISC20_Msk   (0x1UL << HSEM_C1ICR_ISC20_Pos)
#define HSEM_C1ICR_ISC20   HSEM_C1ICR_ISC20_Msk
#define HSEM_C1ICR_ISC21_Pos   (21U)
#define HSEM_C1ICR_ISC21_Msk   (0x1UL << HSEM_C1ICR_ISC21_Pos)
#define HSEM_C1ICR_ISC21   HSEM_C1ICR_ISC21_Msk
#define HSEM_C1ICR_ISC22_Pos   (22U)
#define HSEM_C1ICR_ISC22_Msk   (0x1UL << HSEM_C1ICR_ISC22_Pos)
#define HSEM_C1ICR_ISC22   HSEM_C1ICR_ISC22_Msk
#define HSEM_C1ICR_ISC23_Pos   (23U)
#define HSEM_C1ICR_ISC23_Msk   (0x1UL << HSEM_C1ICR_ISC23_Pos)
#define HSEM_C1ICR_ISC23   HSEM_C1ICR_ISC23_Msk
#define HSEM_C1ICR_ISC24_Pos   (24U)
#define HSEM_C1ICR_ISC24_Msk   (0x1UL << HSEM_C1ICR_ISC24_Pos)
#define HSEM_C1ICR_ISC24   HSEM_C1ICR_ISC24_Msk
#define HSEM_C1ICR_ISC25_Pos   (25U)
#define HSEM_C1ICR_ISC25_Msk   (0x1UL << HSEM_C1ICR_ISC25_Pos)
#define HSEM_C1ICR_ISC25   HSEM_C1ICR_ISC25_Msk
#define HSEM_C1ICR_ISC26_Pos   (26U)
#define HSEM_C1ICR_ISC26_Msk   (0x1UL << HSEM_C1ICR_ISC26_Pos)
#define HSEM_C1ICR_ISC26   HSEM_C1ICR_ISC26_Msk
#define HSEM_C1ICR_ISC27_Pos   (27U)
#define HSEM_C1ICR_ISC27_Msk   (0x1UL << HSEM_C1ICR_ISC27_Pos)
#define HSEM_C1ICR_ISC27   HSEM_C1ICR_ISC27_Msk
#define HSEM_C1ICR_ISC28_Pos   (28U)
#define HSEM_C1ICR_ISC28_Msk   (0x1UL << HSEM_C1ICR_ISC28_Pos)
#define HSEM_C1ICR_ISC28   HSEM_C1ICR_ISC28_Msk
#define HSEM_C1ICR_ISC29_Pos   (29U)
#define HSEM_C1ICR_ISC29_Msk   (0x1UL << HSEM_C1ICR_ISC29_Pos)
#define HSEM_C1ICR_ISC29   HSEM_C1ICR_ISC29_Msk
#define HSEM_C1ICR_ISC30_Pos   (30U)
#define HSEM_C1ICR_ISC30_Msk   (0x1UL << HSEM_C1ICR_ISC30_Pos)
#define HSEM_C1ICR_ISC30   HSEM_C1ICR_ISC30_Msk
#define HSEM_C1ICR_ISC31_Pos   (31U)
#define HSEM_C1ICR_ISC31_Msk   (0x1UL << HSEM_C1ICR_ISC31_Pos)
#define HSEM_C1ICR_ISC31   HSEM_C1ICR_ISC31_Msk
#define HSEM_C1ISR_ISF0_Pos   (0U)
#define HSEM_C1ISR_ISF0_Msk   (0x1UL << HSEM_C1ISR_ISF0_Pos)
#define HSEM_C1ISR_ISF0   HSEM_C1ISR_ISF0_Msk
#define HSEM_C1ISR_ISF1_Pos   (1U)
#define HSEM_C1ISR_ISF1_Msk   (0x1UL << HSEM_C1ISR_ISF1_Pos)
#define HSEM_C1ISR_ISF1   HSEM_C1ISR_ISF1_Msk
#define HSEM_C1ISR_ISF2_Pos   (2U)
#define HSEM_C1ISR_ISF2_Msk   (0x1UL << HSEM_C1ISR_ISF2_Pos)
#define HSEM_C1ISR_ISF2   HSEM_C1ISR_ISF2_Msk
#define HSEM_C1ISR_ISF3_Pos   (3U)
#define HSEM_C1ISR_ISF3_Msk   (0x1UL << HSEM_C1ISR_ISF3_Pos)
#define HSEM_C1ISR_ISF3   HSEM_C1ISR_ISF3_Msk
#define HSEM_C1ISR_ISF4_Pos   (4U)
#define HSEM_C1ISR_ISF4_Msk   (0x1UL << HSEM_C1ISR_ISF4_Pos)
#define HSEM_C1ISR_ISF4   HSEM_C1ISR_ISF4_Msk
#define HSEM_C1ISR_ISF5_Pos   (5U)
#define HSEM_C1ISR_ISF5_Msk   (0x1UL << HSEM_C1ISR_ISF5_Pos)
#define HSEM_C1ISR_ISF5   HSEM_C1ISR_ISF5_Msk
#define HSEM_C1ISR_ISF6_Pos   (6U)
#define HSEM_C1ISR_ISF6_Msk   (0x1UL << HSEM_C1ISR_ISF6_Pos)
#define HSEM_C1ISR_ISF6   HSEM_C1ISR_ISF6_Msk
#define HSEM_C1ISR_ISF7_Pos   (7U)
#define HSEM_C1ISR_ISF7_Msk   (0x1UL << HSEM_C1ISR_ISF7_Pos)
#define HSEM_C1ISR_ISF7   HSEM_C1ISR_ISF7_Msk
#define HSEM_C1ISR_ISF8_Pos   (8U)
#define HSEM_C1ISR_ISF8_Msk   (0x1UL << HSEM_C1ISR_ISF8_Pos)
#define HSEM_C1ISR_ISF8   HSEM_C1ISR_ISF8_Msk
#define HSEM_C1ISR_ISF9_Pos   (9U)
#define HSEM_C1ISR_ISF9_Msk   (0x1UL << HSEM_C1ISR_ISF9_Pos)
#define HSEM_C1ISR_ISF9   HSEM_C1ISR_ISF9_Msk
#define HSEM_C1ISR_ISF10_Pos   (10U)
#define HSEM_C1ISR_ISF10_Msk   (0x1UL << HSEM_C1ISR_ISF10_Pos)
#define HSEM_C1ISR_ISF10   HSEM_C1ISR_ISF10_Msk
#define HSEM_C1ISR_ISF11_Pos   (11U)
#define HSEM_C1ISR_ISF11_Msk   (0x1UL << HSEM_C1ISR_ISF11_Pos)
#define HSEM_C1ISR_ISF11   HSEM_C1ISR_ISF11_Msk
#define HSEM_C1ISR_ISF12_Pos   (12U)
#define HSEM_C1ISR_ISF12_Msk   (0x1UL << HSEM_C1ISR_ISF12_Pos)
#define HSEM_C1ISR_ISF12   HSEM_C1ISR_ISF12_Msk
#define HSEM_C1ISR_ISF13_Pos   (13U)
#define HSEM_C1ISR_ISF13_Msk   (0x1UL << HSEM_C1ISR_ISF13_Pos)
#define HSEM_C1ISR_ISF13   HSEM_C1ISR_ISF13_Msk
#define HSEM_C1ISR_ISF14_Pos   (14U)
#define HSEM_C1ISR_ISF14_Msk   (0x1UL << HSEM_C1ISR_ISF14_Pos)
#define HSEM_C1ISR_ISF14   HSEM_C1ISR_ISF14_Msk
#define HSEM_C1ISR_ISF15_Pos   (15U)
#define HSEM_C1ISR_ISF15_Msk   (0x1UL << HSEM_C1ISR_ISF15_Pos)
#define HSEM_C1ISR_ISF15   HSEM_C1ISR_ISF15_Msk
#define HSEM_C1ISR_ISF16_Pos   (16U)
#define HSEM_C1ISR_ISF16_Msk   (0x1UL << HSEM_C1ISR_ISF16_Pos)
#define HSEM_C1ISR_ISF16   HSEM_C1ISR_ISF16_Msk
#define HSEM_C1ISR_ISF17_Pos   (17U)
#define HSEM_C1ISR_ISF17_Msk   (0x1UL << HSEM_C1ISR_ISF17_Pos)
#define HSEM_C1ISR_ISF17   HSEM_C1ISR_ISF17_Msk
#define HSEM_C1ISR_ISF18_Pos   (18U)
#define HSEM_C1ISR_ISF18_Msk   (0x1UL << HSEM_C1ISR_ISF18_Pos)
#define HSEM_C1ISR_ISF18   HSEM_C1ISR_ISF18_Msk
#define HSEM_C1ISR_ISF19_Pos   (19U)
#define HSEM_C1ISR_ISF19_Msk   (0x1UL << HSEM_C1ISR_ISF19_Pos)
#define HSEM_C1ISR_ISF19   HSEM_C1ISR_ISF19_Msk
#define HSEM_C1ISR_ISF20_Pos   (20U)
#define HSEM_C1ISR_ISF20_Msk   (0x1UL << HSEM_C1ISR_ISF20_Pos)
#define HSEM_C1ISR_ISF20   HSEM_C1ISR_ISF20_Msk
#define HSEM_C1ISR_ISF21_Pos   (21U)
#define HSEM_C1ISR_ISF21_Msk   (0x1UL << HSEM_C1ISR_ISF21_Pos)
#define HSEM_C1ISR_ISF21   HSEM_C1ISR_ISF21_Msk
#define HSEM_C1ISR_ISF22_Pos   (22U)
#define HSEM_C1ISR_ISF22_Msk   (0x1UL << HSEM_C1ISR_ISF22_Pos)
#define HSEM_C1ISR_ISF22   HSEM_C1ISR_ISF22_Msk
#define HSEM_C1ISR_ISF23_Pos   (23U)
#define HSEM_C1ISR_ISF23_Msk   (0x1UL << HSEM_C1ISR_ISF23_Pos)
#define HSEM_C1ISR_ISF23   HSEM_C1ISR_ISF23_Msk
#define HSEM_C1ISR_ISF24_Pos   (24U)
#define HSEM_C1ISR_ISF24_Msk   (0x1UL << HSEM_C1ISR_ISF24_Pos)
#define HSEM_C1ISR_ISF24   HSEM_C1ISR_ISF24_Msk
#define HSEM_C1ISR_ISF25_Pos   (25U)
#define HSEM_C1ISR_ISF25_Msk   (0x1UL << HSEM_C1ISR_ISF25_Pos)
#define HSEM_C1ISR_ISF25   HSEM_C1ISR_ISF25_Msk
#define HSEM_C1ISR_ISF26_Pos   (26U)
#define HSEM_C1ISR_ISF26_Msk   (0x1UL << HSEM_C1ISR_ISF26_Pos)
#define HSEM_C1ISR_ISF26   HSEM_C1ISR_ISF26_Msk
#define HSEM_C1ISR_ISF27_Pos   (27U)
#define HSEM_C1ISR_ISF27_Msk   (0x1UL << HSEM_C1ISR_ISF27_Pos)
#define HSEM_C1ISR_ISF27   HSEM_C1ISR_ISF27_Msk
#define HSEM_C1ISR_ISF28_Pos   (28U)
#define HSEM_C1ISR_ISF28_Msk   (0x1UL << HSEM_C1ISR_ISF28_Pos)
#define HSEM_C1ISR_ISF28   HSEM_C1ISR_ISF28_Msk
#define HSEM_C1ISR_ISF29_Pos   (29U)
#define HSEM_C1ISR_ISF29_Msk   (0x1UL << HSEM_C1ISR_ISF29_Pos)
#define HSEM_C1ISR_ISF29   HSEM_C1ISR_ISF29_Msk
#define HSEM_C1ISR_ISF30_Pos   (30U)
#define HSEM_C1ISR_ISF30_Msk   (0x1UL << HSEM_C1ISR_ISF30_Pos)
#define HSEM_C1ISR_ISF30   HSEM_C1ISR_ISF30_Msk
#define HSEM_C1ISR_ISF31_Pos   (31U)
#define HSEM_C1ISR_ISF31_Msk   (0x1UL << HSEM_C1ISR_ISF31_Pos)
#define HSEM_C1ISR_ISF31   HSEM_C1ISR_ISF31_Msk
#define HSEM_C1MISR_MISF0_Pos   (0U)
#define HSEM_C1MISR_MISF0_Msk   (0x1UL << HSEM_C1MISR_MISF0_Pos)
#define HSEM_C1MISR_MISF0   HSEM_C1MISR_MISF0_Msk
#define HSEM_C1MISR_MISF1_Pos   (1U)
#define HSEM_C1MISR_MISF1_Msk   (0x1UL << HSEM_C1MISR_MISF1_Pos)
#define HSEM_C1MISR_MISF1   HSEM_C1MISR_MISF1_Msk
#define HSEM_C1MISR_MISF2_Pos   (2U)
#define HSEM_C1MISR_MISF2_Msk   (0x1UL << HSEM_C1MISR_MISF2_Pos)
#define HSEM_C1MISR_MISF2   HSEM_C1MISR_MISF2_Msk
#define HSEM_C1MISR_MISF3_Pos   (3U)
#define HSEM_C1MISR_MISF3_Msk   (0x1UL << HSEM_C1MISR_MISF3_Pos)
#define HSEM_C1MISR_MISF3   HSEM_C1MISR_MISF3_Msk
#define HSEM_C1MISR_MISF4_Pos   (4U)
#define HSEM_C1MISR_MISF4_Msk   (0x1UL << HSEM_C1MISR_MISF4_Pos)
#define HSEM_C1MISR_MISF4   HSEM_C1MISR_MISF4_Msk
#define HSEM_C1MISR_MISF5_Pos   (5U)
#define HSEM_C1MISR_MISF5_Msk   (0x1UL << HSEM_C1MISR_MISF5_Pos)
#define HSEM_C1MISR_MISF5   HSEM_C1MISR_MISF5_Msk
#define HSEM_C1MISR_MISF6_Pos   (6U)
#define HSEM_C1MISR_MISF6_Msk   (0x1UL << HSEM_C1MISR_MISF6_Pos)
#define HSEM_C1MISR_MISF6   HSEM_C1MISR_MISF6_Msk
#define HSEM_C1MISR_MISF7_Pos   (7U)
#define HSEM_C1MISR_MISF7_Msk   (0x1UL << HSEM_C1MISR_MISF7_Pos)
#define HSEM_C1MISR_MISF7   HSEM_C1MISR_MISF7_Msk
#define HSEM_C1MISR_MISF8_Pos   (8U)
#define HSEM_C1MISR_MISF8_Msk   (0x1UL << HSEM_C1MISR_MISF8_Pos)
#define HSEM_C1MISR_MISF8   HSEM_C1MISR_MISF8_Msk
#define HSEM_C1MISR_MISF9_Pos   (9U)
#define HSEM_C1MISR_MISF9_Msk   (0x1UL << HSEM_C1MISR_MISF9_Pos)
#define HSEM_C1MISR_MISF9   HSEM_C1MISR_MISF9_Msk
#define HSEM_C1MISR_MISF10_Pos   (10U)
#define HSEM_C1MISR_MISF10_Msk   (0x1UL << HSEM_C1MISR_MISF10_Pos)
#define HSEM_C1MISR_MISF10   HSEM_C1MISR_MISF10_Msk
#define HSEM_C1MISR_MISF11_Pos   (11U)
#define HSEM_C1MISR_MISF11_Msk   (0x1UL << HSEM_C1MISR_MISF11_Pos)
#define HSEM_C1MISR_MISF11   HSEM_C1MISR_MISF11_Msk
#define HSEM_C1MISR_MISF12_Pos   (12U)
#define HSEM_C1MISR_MISF12_Msk   (0x1UL << HSEM_C1MISR_MISF12_Pos)
#define HSEM_C1MISR_MISF12   HSEM_C1MISR_MISF12_Msk
#define HSEM_C1MISR_MISF13_Pos   (13U)
#define HSEM_C1MISR_MISF13_Msk   (0x1UL << HSEM_C1MISR_MISF13_Pos)
#define HSEM_C1MISR_MISF13   HSEM_C1MISR_MISF13_Msk
#define HSEM_C1MISR_MISF14_Pos   (14U)
#define HSEM_C1MISR_MISF14_Msk   (0x1UL << HSEM_C1MISR_MISF14_Pos)
#define HSEM_C1MISR_MISF14   HSEM_C1MISR_MISF14_Msk
#define HSEM_C1MISR_MISF15_Pos   (15U)
#define HSEM_C1MISR_MISF15_Msk   (0x1UL << HSEM_C1MISR_MISF15_Pos)
#define HSEM_C1MISR_MISF15   HSEM_C1MISR_MISF15_Msk
#define HSEM_C1MISR_MISF16_Pos   (16U)
#define HSEM_C1MISR_MISF16_Msk   (0x1UL << HSEM_C1MISR_MISF16_Pos)
#define HSEM_C1MISR_MISF16   HSEM_C1MISR_MISF16_Msk
#define HSEM_C1MISR_MISF17_Pos   (17U)
#define HSEM_C1MISR_MISF17_Msk   (0x1UL << HSEM_C1MISR_MISF17_Pos)
#define HSEM_C1MISR_MISF17   HSEM_C1MISR_MISF17_Msk
#define HSEM_C1MISR_MISF18_Pos   (18U)
#define HSEM_C1MISR_MISF18_Msk   (0x1UL << HSEM_C1MISR_MISF18_Pos)
#define HSEM_C1MISR_MISF18   HSEM_C1MISR_MISF18_Msk
#define HSEM_C1MISR_MISF19_Pos   (19U)
#define HSEM_C1MISR_MISF19_Msk   (0x1UL << HSEM_C1MISR_MISF19_Pos)
#define HSEM_C1MISR_MISF19   HSEM_C1MISR_MISF19_Msk
#define HSEM_C1MISR_MISF20_Pos   (20U)
#define HSEM_C1MISR_MISF20_Msk   (0x1UL << HSEM_C1MISR_MISF20_Pos)
#define HSEM_C1MISR_MISF20   HSEM_C1MISR_MISF20_Msk
#define HSEM_C1MISR_MISF21_Pos   (21U)
#define HSEM_C1MISR_MISF21_Msk   (0x1UL << HSEM_C1MISR_MISF21_Pos)
#define HSEM_C1MISR_MISF21   HSEM_C1MISR_MISF21_Msk
#define HSEM_C1MISR_MISF22_Pos   (22U)
#define HSEM_C1MISR_MISF22_Msk   (0x1UL << HSEM_C1MISR_MISF22_Pos)
#define HSEM_C1MISR_MISF22   HSEM_C1MISR_MISF22_Msk
#define HSEM_C1MISR_MISF23_Pos   (23U)
#define HSEM_C1MISR_MISF23_Msk   (0x1UL << HSEM_C1MISR_MISF23_Pos)
#define HSEM_C1MISR_MISF23   HSEM_C1MISR_MISF23_Msk
#define HSEM_C1MISR_MISF24_Pos   (24U)
#define HSEM_C1MISR_MISF24_Msk   (0x1UL << HSEM_C1MISR_MISF24_Pos)
#define HSEM_C1MISR_MISF24   HSEM_C1MISR_MISF24_Msk
#define HSEM_C1MISR_MISF25_Pos   (25U)
#define HSEM_C1MISR_MISF25_Msk   (0x1UL << HSEM_C1MISR_MISF25_Pos)
#define HSEM_C1MISR_MISF25   HSEM_C1MISR_MISF25_Msk
#define HSEM_C1MISR_MISF26_Pos   (26U)
#define HSEM_C1MISR_MISF26_Msk   (0x1UL << HSEM_C1MISR_MISF26_Pos)
#define HSEM_C1MISR_MISF26   HSEM_C1MISR_MISF26_Msk
#define HSEM_C1MISR_MISF27_Pos   (27U)
#define HSEM_C1MISR_MISF27_Msk   (0x1UL << HSEM_C1MISR_MISF27_Pos)
#define HSEM_C1MISR_MISF27   HSEM_C1MISR_MISF27_Msk
#define HSEM_C1MISR_MISF28_Pos   (28U)
#define HSEM_C1MISR_MISF28_Msk   (0x1UL << HSEM_C1MISR_MISF28_Pos)
#define HSEM_C1MISR_MISF28   HSEM_C1MISR_MISF28_Msk
#define HSEM_C1MISR_MISF29_Pos   (29U)
#define HSEM_C1MISR_MISF29_Msk   (0x1UL << HSEM_C1MISR_MISF29_Pos)
#define HSEM_C1MISR_MISF29   HSEM_C1MISR_MISF29_Msk
#define HSEM_C1MISR_MISF30_Pos   (30U)
#define HSEM_C1MISR_MISF30_Msk   (0x1UL << HSEM_C1MISR_MISF30_Pos)
#define HSEM_C1MISR_MISF30   HSEM_C1MISR_MISF30_Msk
#define HSEM_C1MISR_MISF31_Pos   (31U)
#define HSEM_C1MISR_MISF31_Msk   (0x1UL << HSEM_C1MISR_MISF31_Pos)
#define HSEM_C1MISR_MISF31   HSEM_C1MISR_MISF31_Msk
#define HSEM_CR_COREID_Pos   (8U)
#define HSEM_CR_COREID_Msk   (0xFFUL << HSEM_CR_COREID_Pos)
#define HSEM_CR_COREID   HSEM_CR_COREID_Msk
#define HSEM_CR_KEY_Pos   (16U)
#define HSEM_CR_KEY_Msk   (0xFFFFUL << HSEM_CR_KEY_Pos)
#define HSEM_CR_KEY   HSEM_CR_KEY_Msk
#define HSEM_KEYR_KEY_Pos   (16U)
#define HSEM_KEYR_KEY_Msk   (0xFFFFUL << HSEM_KEYR_KEY_Pos)
#define HSEM_KEYR_KEY   HSEM_KEYR_KEY_Msk
#define I2C_CR1_PE_Pos   (0U)
#define I2C_CR1_PE_Msk   (0x1UL << I2C_CR1_PE_Pos)
#define I2C_CR1_PE   I2C_CR1_PE_Msk
#define I2C_CR1_TXIE_Pos   (1U)
#define I2C_CR1_TXIE_Msk   (0x1UL << I2C_CR1_TXIE_Pos)
#define I2C_CR1_TXIE   I2C_CR1_TXIE_Msk
#define I2C_CR1_RXIE_Pos   (2U)
#define I2C_CR1_RXIE_Msk   (0x1UL << I2C_CR1_RXIE_Pos)
#define I2C_CR1_RXIE   I2C_CR1_RXIE_Msk
#define I2C_CR1_ADDRIE_Pos   (3U)
#define I2C_CR1_ADDRIE_Msk   (0x1UL << I2C_CR1_ADDRIE_Pos)
#define I2C_CR1_ADDRIE   I2C_CR1_ADDRIE_Msk
#define I2C_CR1_NACKIE_Pos   (4U)
#define I2C_CR1_NACKIE_Msk   (0x1UL << I2C_CR1_NACKIE_Pos)
#define I2C_CR1_NACKIE   I2C_CR1_NACKIE_Msk
#define I2C_CR1_STOPIE_Pos   (5U)
#define I2C_CR1_STOPIE_Msk   (0x1UL << I2C_CR1_STOPIE_Pos)
#define I2C_CR1_STOPIE   I2C_CR1_STOPIE_Msk
#define I2C_CR1_TCIE_Pos   (6U)
#define I2C_CR1_TCIE_Msk   (0x1UL << I2C_CR1_TCIE_Pos)
#define I2C_CR1_TCIE   I2C_CR1_TCIE_Msk
#define I2C_CR1_ERRIE_Pos   (7U)
#define I2C_CR1_ERRIE_Msk   (0x1UL << I2C_CR1_ERRIE_Pos)
#define I2C_CR1_ERRIE   I2C_CR1_ERRIE_Msk
#define I2C_CR1_DNF_Pos   (8U)
#define I2C_CR1_DNF_Msk   (0xFUL << I2C_CR1_DNF_Pos)
#define I2C_CR1_DNF   I2C_CR1_DNF_Msk
#define I2C_CR1_ANFOFF_Pos   (12U)
#define I2C_CR1_ANFOFF_Msk   (0x1UL << I2C_CR1_ANFOFF_Pos)
#define I2C_CR1_ANFOFF   I2C_CR1_ANFOFF_Msk
#define I2C_CR1_TXDMAEN_Pos   (14U)
#define I2C_CR1_TXDMAEN_Msk   (0x1UL << I2C_CR1_TXDMAEN_Pos)
#define I2C_CR1_TXDMAEN   I2C_CR1_TXDMAEN_Msk
#define I2C_CR1_RXDMAEN_Pos   (15U)
#define I2C_CR1_RXDMAEN_Msk   (0x1UL << I2C_CR1_RXDMAEN_Pos)
#define I2C_CR1_RXDMAEN   I2C_CR1_RXDMAEN_Msk
#define I2C_CR1_SBC_Pos   (16U)
#define I2C_CR1_SBC_Msk   (0x1UL << I2C_CR1_SBC_Pos)
#define I2C_CR1_SBC   I2C_CR1_SBC_Msk
#define I2C_CR1_NOSTRETCH_Pos   (17U)
#define I2C_CR1_NOSTRETCH_Msk   (0x1UL << I2C_CR1_NOSTRETCH_Pos)
#define I2C_CR1_NOSTRETCH   I2C_CR1_NOSTRETCH_Msk
#define I2C_CR1_WUPEN_Pos   (18U)
#define I2C_CR1_WUPEN_Msk   (0x1UL << I2C_CR1_WUPEN_Pos)
#define I2C_CR1_WUPEN   I2C_CR1_WUPEN_Msk
#define I2C_CR1_GCEN_Pos   (19U)
#define I2C_CR1_GCEN_Msk   (0x1UL << I2C_CR1_GCEN_Pos)
#define I2C_CR1_GCEN   I2C_CR1_GCEN_Msk
#define I2C_CR1_SMBHEN_Pos   (20U)
#define I2C_CR1_SMBHEN_Msk   (0x1UL << I2C_CR1_SMBHEN_Pos)
#define I2C_CR1_SMBHEN   I2C_CR1_SMBHEN_Msk
#define I2C_CR1_SMBDEN_Pos   (21U)
#define I2C_CR1_SMBDEN_Msk   (0x1UL << I2C_CR1_SMBDEN_Pos)
#define I2C_CR1_SMBDEN   I2C_CR1_SMBDEN_Msk
#define I2C_CR1_ALERTEN_Pos   (22U)
#define I2C_CR1_ALERTEN_Msk   (0x1UL << I2C_CR1_ALERTEN_Pos)
#define I2C_CR1_ALERTEN   I2C_CR1_ALERTEN_Msk
#define I2C_CR1_PECEN_Pos   (23U)
#define I2C_CR1_PECEN_Msk   (0x1UL << I2C_CR1_PECEN_Pos)
#define I2C_CR1_PECEN   I2C_CR1_PECEN_Msk
#define I2C_CR2_SADD_Pos   (0U)
#define I2C_CR2_SADD_Msk   (0x3FFUL << I2C_CR2_SADD_Pos)
#define I2C_CR2_SADD   I2C_CR2_SADD_Msk
#define I2C_CR2_RD_WRN_Pos   (10U)
#define I2C_CR2_RD_WRN_Msk   (0x1UL << I2C_CR2_RD_WRN_Pos)
#define I2C_CR2_RD_WRN   I2C_CR2_RD_WRN_Msk
#define I2C_CR2_ADD10_Pos   (11U)
#define I2C_CR2_ADD10_Msk   (0x1UL << I2C_CR2_ADD10_Pos)
#define I2C_CR2_ADD10   I2C_CR2_ADD10_Msk
#define I2C_CR2_HEAD10R_Pos   (12U)
#define I2C_CR2_HEAD10R_Msk   (0x1UL << I2C_CR2_HEAD10R_Pos)
#define I2C_CR2_HEAD10R   I2C_CR2_HEAD10R_Msk
#define I2C_CR2_START_Pos   (13U)
#define I2C_CR2_START_Msk   (0x1UL << I2C_CR2_START_Pos)
#define I2C_CR2_START   I2C_CR2_START_Msk
#define I2C_CR2_STOP_Pos   (14U)
#define I2C_CR2_STOP_Msk   (0x1UL << I2C_CR2_STOP_Pos)
#define I2C_CR2_STOP   I2C_CR2_STOP_Msk
#define I2C_CR2_NACK_Pos   (15U)
#define I2C_CR2_NACK_Msk   (0x1UL << I2C_CR2_NACK_Pos)
#define I2C_CR2_NACK   I2C_CR2_NACK_Msk
#define I2C_CR2_NBYTES_Pos   (16U)
#define I2C_CR2_NBYTES_Msk   (0xFFUL << I2C_CR2_NBYTES_Pos)
#define I2C_CR2_NBYTES   I2C_CR2_NBYTES_Msk
#define I2C_CR2_RELOAD_Pos   (24U)
#define I2C_CR2_RELOAD_Msk   (0x1UL << I2C_CR2_RELOAD_Pos)
#define I2C_CR2_RELOAD   I2C_CR2_RELOAD_Msk
#define I2C_CR2_AUTOEND_Pos   (25U)
#define I2C_CR2_AUTOEND_Msk   (0x1UL << I2C_CR2_AUTOEND_Pos)
#define I2C_CR2_AUTOEND   I2C_CR2_AUTOEND_Msk
#define I2C_CR2_PECBYTE_Pos   (26U)
#define I2C_CR2_PECBYTE_Msk   (0x1UL << I2C_CR2_PECBYTE_Pos)
#define I2C_CR2_PECBYTE   I2C_CR2_PECBYTE_Msk
#define I2C_OAR1_OA1_Pos   (0U)
#define I2C_OAR1_OA1_Msk   (0x3FFUL << I2C_OAR1_OA1_Pos)
#define I2C_OAR1_OA1   I2C_OAR1_OA1_Msk
#define I2C_OAR1_OA1MODE_Pos   (10U)
#define I2C_OAR1_OA1MODE_Msk   (0x1UL << I2C_OAR1_OA1MODE_Pos)
#define I2C_OAR1_OA1MODE   I2C_OAR1_OA1MODE_Msk
#define I2C_OAR1_OA1EN_Pos   (15U)
#define I2C_OAR1_OA1EN_Msk   (0x1UL << I2C_OAR1_OA1EN_Pos)
#define I2C_OAR1_OA1EN   I2C_OAR1_OA1EN_Msk
#define I2C_OAR2_OA2_Pos   (1U)
#define I2C_OAR2_OA2_Msk   (0x7FUL << I2C_OAR2_OA2_Pos)
#define I2C_OAR2_OA2   I2C_OAR2_OA2_Msk
#define I2C_OAR2_OA2MSK_Pos   (8U)
#define I2C_OAR2_OA2MSK_Msk   (0x7UL << I2C_OAR2_OA2MSK_Pos)
#define I2C_OAR2_OA2MSK   I2C_OAR2_OA2MSK_Msk
#define I2C_OAR2_OA2NOMASK   0x00000000UL
#define I2C_OAR2_OA2MASK01_Pos   (8U)
#define I2C_OAR2_OA2MASK01_Msk   (0x1UL << I2C_OAR2_OA2MASK01_Pos)
#define I2C_OAR2_OA2MASK01   I2C_OAR2_OA2MASK01_Msk
#define I2C_OAR2_OA2MASK02_Pos   (9U)
#define I2C_OAR2_OA2MASK02_Msk   (0x1UL << I2C_OAR2_OA2MASK02_Pos)
#define I2C_OAR2_OA2MASK02   I2C_OAR2_OA2MASK02_Msk
#define I2C_OAR2_OA2MASK03_Pos   (8U)
#define I2C_OAR2_OA2MASK03_Msk   (0x3UL << I2C_OAR2_OA2MASK03_Pos)
#define I2C_OAR2_OA2MASK03   I2C_OAR2_OA2MASK03_Msk
#define I2C_OAR2_OA2MASK04_Pos   (10U)
#define I2C_OAR2_OA2MASK04_Msk   (0x1UL << I2C_OAR2_OA2MASK04_Pos)
#define I2C_OAR2_OA2MASK04   I2C_OAR2_OA2MASK04_Msk
#define I2C_OAR2_OA2MASK05_Pos   (8U)
#define I2C_OAR2_OA2MASK05_Msk   (0x5UL << I2C_OAR2_OA2MASK05_Pos)
#define I2C_OAR2_OA2MASK05   I2C_OAR2_OA2MASK05_Msk
#define I2C_OAR2_OA2MASK06_Pos   (9U)
#define I2C_OAR2_OA2MASK06_Msk   (0x3UL << I2C_OAR2_OA2MASK06_Pos)
#define I2C_OAR2_OA2MASK06   I2C_OAR2_OA2MASK06_Msk
#define I2C_OAR2_OA2MASK07_Pos   (8U)
#define I2C_OAR2_OA2MASK07_Msk   (0x7UL << I2C_OAR2_OA2MASK07_Pos)
#define I2C_OAR2_OA2MASK07   I2C_OAR2_OA2MASK07_Msk
#define I2C_OAR2_OA2EN_Pos   (15U)
#define I2C_OAR2_OA2EN_Msk   (0x1UL << I2C_OAR2_OA2EN_Pos)
#define I2C_OAR2_OA2EN   I2C_OAR2_OA2EN_Msk
#define I2C_TIMINGR_SCLL_Pos   (0U)
#define I2C_TIMINGR_SCLL_Msk   (0xFFUL << I2C_TIMINGR_SCLL_Pos)
#define I2C_TIMINGR_SCLL   I2C_TIMINGR_SCLL_Msk
#define I2C_TIMINGR_SCLH_Pos   (8U)
#define I2C_TIMINGR_SCLH_Msk   (0xFFUL << I2C_TIMINGR_SCLH_Pos)
#define I2C_TIMINGR_SCLH   I2C_TIMINGR_SCLH_Msk
#define I2C_TIMINGR_SDADEL_Pos   (16U)
#define I2C_TIMINGR_SDADEL_Msk   (0xFUL << I2C_TIMINGR_SDADEL_Pos)
#define I2C_TIMINGR_SDADEL   I2C_TIMINGR_SDADEL_Msk
#define I2C_TIMINGR_SCLDEL_Pos   (20U)
#define I2C_TIMINGR_SCLDEL_Msk   (0xFUL << I2C_TIMINGR_SCLDEL_Pos)
#define I2C_TIMINGR_SCLDEL   I2C_TIMINGR_SCLDEL_Msk
#define I2C_TIMINGR_PRESC_Pos   (28U)
#define I2C_TIMINGR_PRESC_Msk   (0xFUL << I2C_TIMINGR_PRESC_Pos)
#define I2C_TIMINGR_PRESC   I2C_TIMINGR_PRESC_Msk
#define I2C_TIMEOUTR_TIMEOUTA_Pos   (0U)
#define I2C_TIMEOUTR_TIMEOUTA_Msk   (0xFFFUL << I2C_TIMEOUTR_TIMEOUTA_Pos)
#define I2C_TIMEOUTR_TIMEOUTA   I2C_TIMEOUTR_TIMEOUTA_Msk
#define I2C_TIMEOUTR_TIDLE_Pos   (12U)
#define I2C_TIMEOUTR_TIDLE_Msk   (0x1UL << I2C_TIMEOUTR_TIDLE_Pos)
#define I2C_TIMEOUTR_TIDLE   I2C_TIMEOUTR_TIDLE_Msk
#define I2C_TIMEOUTR_TIMOUTEN_Pos   (15U)
#define I2C_TIMEOUTR_TIMOUTEN_Msk   (0x1UL << I2C_TIMEOUTR_TIMOUTEN_Pos)
#define I2C_TIMEOUTR_TIMOUTEN   I2C_TIMEOUTR_TIMOUTEN_Msk
#define I2C_TIMEOUTR_TIMEOUTB_Pos   (16U)
#define I2C_TIMEOUTR_TIMEOUTB_Msk   (0xFFFUL << I2C_TIMEOUTR_TIMEOUTB_Pos)
#define I2C_TIMEOUTR_TIMEOUTB   I2C_TIMEOUTR_TIMEOUTB_Msk
#define I2C_TIMEOUTR_TEXTEN_Pos   (31U)
#define I2C_TIMEOUTR_TEXTEN_Msk   (0x1UL << I2C_TIMEOUTR_TEXTEN_Pos)
#define I2C_TIMEOUTR_TEXTEN   I2C_TIMEOUTR_TEXTEN_Msk
#define I2C_ISR_TXE_Pos   (0U)
#define I2C_ISR_TXE_Msk   (0x1UL << I2C_ISR_TXE_Pos)
#define I2C_ISR_TXE   I2C_ISR_TXE_Msk
#define I2C_ISR_TXIS_Pos   (1U)
#define I2C_ISR_TXIS_Msk   (0x1UL << I2C_ISR_TXIS_Pos)
#define I2C_ISR_TXIS   I2C_ISR_TXIS_Msk
#define I2C_ISR_RXNE_Pos   (2U)
#define I2C_ISR_RXNE_Msk   (0x1UL << I2C_ISR_RXNE_Pos)
#define I2C_ISR_RXNE   I2C_ISR_RXNE_Msk
#define I2C_ISR_ADDR_Pos   (3U)
#define I2C_ISR_ADDR_Msk   (0x1UL << I2C_ISR_ADDR_Pos)
#define I2C_ISR_ADDR   I2C_ISR_ADDR_Msk
#define I2C_ISR_NACKF_Pos   (4U)
#define I2C_ISR_NACKF_Msk   (0x1UL << I2C_ISR_NACKF_Pos)
#define I2C_ISR_NACKF   I2C_ISR_NACKF_Msk
#define I2C_ISR_STOPF_Pos   (5U)
#define I2C_ISR_STOPF_Msk   (0x1UL << I2C_ISR_STOPF_Pos)
#define I2C_ISR_STOPF   I2C_ISR_STOPF_Msk
#define I2C_ISR_TC_Pos   (6U)
#define I2C_ISR_TC_Msk   (0x1UL << I2C_ISR_TC_Pos)
#define I2C_ISR_TC   I2C_ISR_TC_Msk
#define I2C_ISR_TCR_Pos   (7U)
#define I2C_ISR_TCR_Msk   (0x1UL << I2C_ISR_TCR_Pos)
#define I2C_ISR_TCR   I2C_ISR_TCR_Msk
#define I2C_ISR_BERR_Pos   (8U)
#define I2C_ISR_BERR_Msk   (0x1UL << I2C_ISR_BERR_Pos)
#define I2C_ISR_BERR   I2C_ISR_BERR_Msk
#define I2C_ISR_ARLO_Pos   (9U)
#define I2C_ISR_ARLO_Msk   (0x1UL << I2C_ISR_ARLO_Pos)
#define I2C_ISR_ARLO   I2C_ISR_ARLO_Msk
#define I2C_ISR_OVR_Pos   (10U)
#define I2C_ISR_OVR_Msk   (0x1UL << I2C_ISR_OVR_Pos)
#define I2C_ISR_OVR   I2C_ISR_OVR_Msk
#define I2C_ISR_PECERR_Pos   (11U)
#define I2C_ISR_PECERR_Msk   (0x1UL << I2C_ISR_PECERR_Pos)
#define I2C_ISR_PECERR   I2C_ISR_PECERR_Msk
#define I2C_ISR_TIMEOUT_Pos   (12U)
#define I2C_ISR_TIMEOUT_Msk   (0x1UL << I2C_ISR_TIMEOUT_Pos)
#define I2C_ISR_TIMEOUT   I2C_ISR_TIMEOUT_Msk
#define I2C_ISR_ALERT_Pos   (13U)
#define I2C_ISR_ALERT_Msk   (0x1UL << I2C_ISR_ALERT_Pos)
#define I2C_ISR_ALERT   I2C_ISR_ALERT_Msk
#define I2C_ISR_BUSY_Pos   (15U)
#define I2C_ISR_BUSY_Msk   (0x1UL << I2C_ISR_BUSY_Pos)
#define I2C_ISR_BUSY   I2C_ISR_BUSY_Msk
#define I2C_ISR_DIR_Pos   (16U)
#define I2C_ISR_DIR_Msk   (0x1UL << I2C_ISR_DIR_Pos)
#define I2C_ISR_DIR   I2C_ISR_DIR_Msk
#define I2C_ISR_ADDCODE_Pos   (17U)
#define I2C_ISR_ADDCODE_Msk   (0x7FUL << I2C_ISR_ADDCODE_Pos)
#define I2C_ISR_ADDCODE   I2C_ISR_ADDCODE_Msk
#define I2C_ICR_ADDRCF_Pos   (3U)
#define I2C_ICR_ADDRCF_Msk   (0x1UL << I2C_ICR_ADDRCF_Pos)
#define I2C_ICR_ADDRCF   I2C_ICR_ADDRCF_Msk
#define I2C_ICR_NACKCF_Pos   (4U)
#define I2C_ICR_NACKCF_Msk   (0x1UL << I2C_ICR_NACKCF_Pos)
#define I2C_ICR_NACKCF   I2C_ICR_NACKCF_Msk
#define I2C_ICR_STOPCF_Pos   (5U)
#define I2C_ICR_STOPCF_Msk   (0x1UL << I2C_ICR_STOPCF_Pos)
#define I2C_ICR_STOPCF   I2C_ICR_STOPCF_Msk
#define I2C_ICR_BERRCF_Pos   (8U)
#define I2C_ICR_BERRCF_Msk   (0x1UL << I2C_ICR_BERRCF_Pos)
#define I2C_ICR_BERRCF   I2C_ICR_BERRCF_Msk
#define I2C_ICR_ARLOCF_Pos   (9U)
#define I2C_ICR_ARLOCF_Msk   (0x1UL << I2C_ICR_ARLOCF_Pos)
#define I2C_ICR_ARLOCF   I2C_ICR_ARLOCF_Msk
#define I2C_ICR_OVRCF_Pos   (10U)
#define I2C_ICR_OVRCF_Msk   (0x1UL << I2C_ICR_OVRCF_Pos)
#define I2C_ICR_OVRCF   I2C_ICR_OVRCF_Msk
#define I2C_ICR_PECCF_Pos   (11U)
#define I2C_ICR_PECCF_Msk   (0x1UL << I2C_ICR_PECCF_Pos)
#define I2C_ICR_PECCF   I2C_ICR_PECCF_Msk
#define I2C_ICR_TIMOUTCF_Pos   (12U)
#define I2C_ICR_TIMOUTCF_Msk   (0x1UL << I2C_ICR_TIMOUTCF_Pos)
#define I2C_ICR_TIMOUTCF   I2C_ICR_TIMOUTCF_Msk
#define I2C_ICR_ALERTCF_Pos   (13U)
#define I2C_ICR_ALERTCF_Msk   (0x1UL << I2C_ICR_ALERTCF_Pos)
#define I2C_ICR_ALERTCF   I2C_ICR_ALERTCF_Msk
#define I2C_PECR_PEC_Pos   (0U)
#define I2C_PECR_PEC_Msk   (0xFFUL << I2C_PECR_PEC_Pos)
#define I2C_PECR_PEC   I2C_PECR_PEC_Msk
#define I2C_RXDR_RXDATA_Pos   (0U)
#define I2C_RXDR_RXDATA_Msk   (0xFFUL << I2C_RXDR_RXDATA_Pos)
#define I2C_RXDR_RXDATA   I2C_RXDR_RXDATA_Msk
#define I2C_TXDR_TXDATA_Pos   (0U)
#define I2C_TXDR_TXDATA_Msk   (0xFFUL << I2C_TXDR_TXDATA_Pos)
#define I2C_TXDR_TXDATA   I2C_TXDR_TXDATA_Msk
#define IWDG_KR_KEY_Pos   (0U)
#define IWDG_KR_KEY_Msk   (0xFFFFUL << IWDG_KR_KEY_Pos)
#define IWDG_KR_KEY   IWDG_KR_KEY_Msk
#define IWDG_PR_PR_Pos   (0U)
#define IWDG_PR_PR_Msk   (0x7UL << IWDG_PR_PR_Pos)
#define IWDG_PR_PR   IWDG_PR_PR_Msk
#define IWDG_PR_PR_0   (0x1UL << IWDG_PR_PR_Pos)
#define IWDG_PR_PR_1   (0x2UL << IWDG_PR_PR_Pos)
#define IWDG_PR_PR_2   (0x4UL << IWDG_PR_PR_Pos)
#define IWDG_RLR_RL_Pos   (0U)
#define IWDG_RLR_RL_Msk   (0xFFFUL << IWDG_RLR_RL_Pos)
#define IWDG_RLR_RL   IWDG_RLR_RL_Msk
#define IWDG_SR_PVU_Pos   (0U)
#define IWDG_SR_PVU_Msk   (0x1UL << IWDG_SR_PVU_Pos)
#define IWDG_SR_PVU   IWDG_SR_PVU_Msk
#define IWDG_SR_RVU_Pos   (1U)
#define IWDG_SR_RVU_Msk   (0x1UL << IWDG_SR_RVU_Pos)
#define IWDG_SR_RVU   IWDG_SR_RVU_Msk
#define IWDG_SR_WVU_Pos   (2U)
#define IWDG_SR_WVU_Msk   (0x1UL << IWDG_SR_WVU_Pos)
#define IWDG_SR_WVU   IWDG_SR_WVU_Msk
#define IWDG_WINR_WIN_Pos   (0U)
#define IWDG_WINR_WIN_Msk   (0xFFFUL << IWDG_WINR_WIN_Pos)
#define IWDG_WINR_WIN   IWDG_WINR_WIN_Msk
#define JPEG_CONFR0_START_Pos   (0U)
#define JPEG_CONFR0_START_Msk   (0x1UL << JPEG_CONFR0_START_Pos)
#define JPEG_CONFR0_START   JPEG_CONFR0_START_Msk
#define JPEG_CONFR1_NF_Pos   (0U)
#define JPEG_CONFR1_NF_Msk   (0x3UL << JPEG_CONFR1_NF_Pos)
#define JPEG_CONFR1_NF   JPEG_CONFR1_NF_Msk
#define JPEG_CONFR1_NF_0   (0x1UL << JPEG_CONFR1_NF_Pos)
#define JPEG_CONFR1_NF_1   (0x2UL << JPEG_CONFR1_NF_Pos)
#define JPEG_CONFR1_DE_Pos   (3U)
#define JPEG_CONFR1_DE_Msk   (0x1UL << JPEG_CONFR1_DE_Pos)
#define JPEG_CONFR1_DE   JPEG_CONFR1_DE_Msk
#define JPEG_CONFR1_COLORSPACE_Pos   (4U)
#define JPEG_CONFR1_COLORSPACE_Msk   (0x3UL << JPEG_CONFR1_COLORSPACE_Pos)
#define JPEG_CONFR1_COLORSPACE   JPEG_CONFR1_COLORSPACE_Msk
#define JPEG_CONFR1_COLORSPACE_0   (0x1UL << JPEG_CONFR1_COLORSPACE_Pos)
#define JPEG_CONFR1_COLORSPACE_1   (0x2UL << JPEG_CONFR1_COLORSPACE_Pos)
#define JPEG_CONFR1_NS_Pos   (6U)
#define JPEG_CONFR1_NS_Msk   (0x3UL << JPEG_CONFR1_NS_Pos)
#define JPEG_CONFR1_NS   JPEG_CONFR1_NS_Msk
#define JPEG_CONFR1_NS_0   (0x1UL << JPEG_CONFR1_NS_Pos)
#define JPEG_CONFR1_NS_1   (0x2UL << JPEG_CONFR1_NS_Pos)
#define JPEG_CONFR1_HDR_Pos   (8U)
#define JPEG_CONFR1_HDR_Msk   (0x1UL << JPEG_CONFR1_HDR_Pos)
#define JPEG_CONFR1_HDR   JPEG_CONFR1_HDR_Msk
#define JPEG_CONFR1_YSIZE_Pos   (16U)
#define JPEG_CONFR1_YSIZE_Msk   (0xFFFFUL << JPEG_CONFR1_YSIZE_Pos)
#define JPEG_CONFR1_YSIZE   JPEG_CONFR1_YSIZE_Msk
#define JPEG_CONFR2_NMCU_Pos   (0U)
#define JPEG_CONFR2_NMCU_Msk   (0x3FFFFFFUL << JPEG_CONFR2_NMCU_Pos)
#define JPEG_CONFR2_NMCU   JPEG_CONFR2_NMCU_Msk
#define JPEG_CONFR3_XSIZE_Pos   (16U)
#define JPEG_CONFR3_XSIZE_Msk   (0xFFFFUL << JPEG_CONFR3_XSIZE_Pos)
#define JPEG_CONFR3_XSIZE   JPEG_CONFR3_XSIZE_Msk
#define JPEG_CONFR4_HD_Pos   (0U)
#define JPEG_CONFR4_HD_Msk   (0x1UL << JPEG_CONFR4_HD_Pos)
#define JPEG_CONFR4_HD   JPEG_CONFR4_HD_Msk
#define JPEG_CONFR4_HA_Pos   (1U)
#define JPEG_CONFR4_HA_Msk   (0x1UL << JPEG_CONFR4_HA_Pos)
#define JPEG_CONFR4_HA   JPEG_CONFR4_HA_Msk
#define JPEG_CONFR4_QT_Pos   (2U)
#define JPEG_CONFR4_QT_Msk   (0x3UL << JPEG_CONFR4_QT_Pos)
#define JPEG_CONFR4_QT   JPEG_CONFR4_QT_Msk
#define JPEG_CONFR4_QT_0   (0x1UL << JPEG_CONFR4_QT_Pos)
#define JPEG_CONFR4_QT_1   (0x2UL << JPEG_CONFR4_QT_Pos)
#define JPEG_CONFR4_NB_Pos   (4U)
#define JPEG_CONFR4_NB_Msk   (0xFUL << JPEG_CONFR4_NB_Pos)
#define JPEG_CONFR4_NB   JPEG_CONFR4_NB_Msk
#define JPEG_CONFR4_NB_0   (0x1UL << JPEG_CONFR4_NB_Pos)
#define JPEG_CONFR4_NB_1   (0x2UL << JPEG_CONFR4_NB_Pos)
#define JPEG_CONFR4_NB_2   (0x4UL << JPEG_CONFR4_NB_Pos)
#define JPEG_CONFR4_NB_3   (0x8UL << JPEG_CONFR4_NB_Pos)
#define JPEG_CONFR4_VSF_Pos   (8U)
#define JPEG_CONFR4_VSF_Msk   (0xFUL << JPEG_CONFR4_VSF_Pos)
#define JPEG_CONFR4_VSF   JPEG_CONFR4_VSF_Msk
#define JPEG_CONFR4_VSF_0   (0x1UL << JPEG_CONFR4_VSF_Pos)
#define JPEG_CONFR4_VSF_1   (0x2UL << JPEG_CONFR4_VSF_Pos)
#define JPEG_CONFR4_VSF_2   (0x4UL << JPEG_CONFR4_VSF_Pos)
#define JPEG_CONFR4_VSF_3   (0x8UL << JPEG_CONFR4_VSF_Pos)
#define JPEG_CONFR4_HSF_Pos   (12U)
#define JPEG_CONFR4_HSF_Msk   (0xFUL << JPEG_CONFR4_HSF_Pos)
#define JPEG_CONFR4_HSF   JPEG_CONFR4_HSF_Msk
#define JPEG_CONFR4_HSF_0   (0x1UL << JPEG_CONFR4_HSF_Pos)
#define JPEG_CONFR4_HSF_1   (0x2UL << JPEG_CONFR4_HSF_Pos)
#define JPEG_CONFR4_HSF_2   (0x4UL << JPEG_CONFR4_HSF_Pos)
#define JPEG_CONFR4_HSF_3   (0x8UL << JPEG_CONFR4_HSF_Pos)
#define JPEG_CONFR5_HD_Pos   (0U)
#define JPEG_CONFR5_HD_Msk   (0x1UL << JPEG_CONFR5_HD_Pos)
#define JPEG_CONFR5_HD   JPEG_CONFR5_HD_Msk
#define JPEG_CONFR5_HA_Pos   (1U)
#define JPEG_CONFR5_HA_Msk   (0x1UL << JPEG_CONFR5_HA_Pos)
#define JPEG_CONFR5_HA   JPEG_CONFR5_HA_Msk
#define JPEG_CONFR5_QT_Pos   (2U)
#define JPEG_CONFR5_QT_Msk   (0x3UL << JPEG_CONFR5_QT_Pos)
#define JPEG_CONFR5_QT   JPEG_CONFR5_QT_Msk
#define JPEG_CONFR5_QT_0   (0x1UL << JPEG_CONFR5_QT_Pos)
#define JPEG_CONFR5_QT_1   (0x2UL << JPEG_CONFR5_QT_Pos)
#define JPEG_CONFR5_NB_Pos   (4U)
#define JPEG_CONFR5_NB_Msk   (0xFUL << JPEG_CONFR5_NB_Pos)
#define JPEG_CONFR5_NB   JPEG_CONFR5_NB_Msk
#define JPEG_CONFR5_NB_0   (0x1UL << JPEG_CONFR5_NB_Pos)
#define JPEG_CONFR5_NB_1   (0x2UL << JPEG_CONFR5_NB_Pos)
#define JPEG_CONFR5_NB_2   (0x4UL << JPEG_CONFR5_NB_Pos)
#define JPEG_CONFR5_NB_3   (0x8UL << JPEG_CONFR5_NB_Pos)
#define JPEG_CONFR5_VSF_Pos   (8U)
#define JPEG_CONFR5_VSF_Msk   (0xFUL << JPEG_CONFR5_VSF_Pos)
#define JPEG_CONFR5_VSF   JPEG_CONFR5_VSF_Msk
#define JPEG_CONFR5_VSF_0   (0x1UL << JPEG_CONFR5_VSF_Pos)
#define JPEG_CONFR5_VSF_1   (0x2UL << JPEG_CONFR5_VSF_Pos)
#define JPEG_CONFR5_VSF_2   (0x4UL << JPEG_CONFR5_VSF_Pos)
#define JPEG_CONFR5_VSF_3   (0x8UL << JPEG_CONFR5_VSF_Pos)
#define JPEG_CONFR5_HSF_Pos   (12U)
#define JPEG_CONFR5_HSF_Msk   (0xFUL << JPEG_CONFR5_HSF_Pos)
#define JPEG_CONFR5_HSF   JPEG_CONFR5_HSF_Msk
#define JPEG_CONFR5_HSF_0   (0x1UL << JPEG_CONFR5_HSF_Pos)
#define JPEG_CONFR5_HSF_1   (0x2UL << JPEG_CONFR5_HSF_Pos)
#define JPEG_CONFR5_HSF_2   (0x4UL << JPEG_CONFR5_HSF_Pos)
#define JPEG_CONFR5_HSF_3   (0x8UL << JPEG_CONFR5_HSF_Pos)
#define JPEG_CONFR6_HD_Pos   (0U)
#define JPEG_CONFR6_HD_Msk   (0x1UL << JPEG_CONFR6_HD_Pos)
#define JPEG_CONFR6_HD   JPEG_CONFR6_HD_Msk
#define JPEG_CONFR6_HA_Pos   (1U)
#define JPEG_CONFR6_HA_Msk   (0x1UL << JPEG_CONFR6_HA_Pos)
#define JPEG_CONFR6_HA   JPEG_CONFR6_HA_Msk
#define JPEG_CONFR6_QT_Pos   (2U)
#define JPEG_CONFR6_QT_Msk   (0x3UL << JPEG_CONFR6_QT_Pos)
#define JPEG_CONFR6_QT   JPEG_CONFR6_QT_Msk
#define JPEG_CONFR6_QT_0   (0x1UL << JPEG_CONFR6_QT_Pos)
#define JPEG_CONFR6_QT_1   (0x2UL << JPEG_CONFR6_QT_Pos)
#define JPEG_CONFR6_NB_Pos   (4U)
#define JPEG_CONFR6_NB_Msk   (0xFUL << JPEG_CONFR6_NB_Pos)
#define JPEG_CONFR6_NB   JPEG_CONFR6_NB_Msk
#define JPEG_CONFR6_NB_0   (0x1UL << JPEG_CONFR6_NB_Pos)
#define JPEG_CONFR6_NB_1   (0x2UL << JPEG_CONFR6_NB_Pos)
#define JPEG_CONFR6_NB_2   (0x4UL << JPEG_CONFR6_NB_Pos)
#define JPEG_CONFR6_NB_3   (0x8UL << JPEG_CONFR6_NB_Pos)
#define JPEG_CONFR6_VSF_Pos   (8U)
#define JPEG_CONFR6_VSF_Msk   (0xFUL << JPEG_CONFR6_VSF_Pos)
#define JPEG_CONFR6_VSF   JPEG_CONFR6_VSF_Msk
#define JPEG_CONFR6_VSF_0   (0x1UL << JPEG_CONFR6_VSF_Pos)
#define JPEG_CONFR6_VSF_1   (0x2UL << JPEG_CONFR6_VSF_Pos)
#define JPEG_CONFR6_VSF_2   (0x4UL << JPEG_CONFR6_VSF_Pos)
#define JPEG_CONFR6_VSF_3   (0x8UL << JPEG_CONFR6_VSF_Pos)
#define JPEG_CONFR6_HSF_Pos   (12U)
#define JPEG_CONFR6_HSF_Msk   (0xFUL << JPEG_CONFR6_HSF_Pos)
#define JPEG_CONFR6_HSF   JPEG_CONFR6_HSF_Msk
#define JPEG_CONFR6_HSF_0   (0x1UL << JPEG_CONFR6_HSF_Pos)
#define JPEG_CONFR6_HSF_1   (0x2UL << JPEG_CONFR6_HSF_Pos)
#define JPEG_CONFR6_HSF_2   (0x4UL << JPEG_CONFR6_HSF_Pos)
#define JPEG_CONFR6_HSF_3   (0x8UL << JPEG_CONFR6_HSF_Pos)
#define JPEG_CONFR7_HD_Pos   (0U)
#define JPEG_CONFR7_HD_Msk   (0x1UL << JPEG_CONFR7_HD_Pos)
#define JPEG_CONFR7_HD   JPEG_CONFR7_HD_Msk
#define JPEG_CONFR7_HA_Pos   (1U)
#define JPEG_CONFR7_HA_Msk   (0x1UL << JPEG_CONFR7_HA_Pos)
#define JPEG_CONFR7_HA   JPEG_CONFR7_HA_Msk
#define JPEG_CONFR7_QT_Pos   (2U)
#define JPEG_CONFR7_QT_Msk   (0x3UL << JPEG_CONFR7_QT_Pos)
#define JPEG_CONFR7_QT   JPEG_CONFR7_QT_Msk
#define JPEG_CONFR7_QT_0   (0x1UL << JPEG_CONFR7_QT_Pos)
#define JPEG_CONFR7_QT_1   (0x2UL << JPEG_CONFR7_QT_Pos)
#define JPEG_CONFR7_NB_Pos   (4U)
#define JPEG_CONFR7_NB_Msk   (0xFUL << JPEG_CONFR7_NB_Pos)
#define JPEG_CONFR7_NB   JPEG_CONFR7_NB_Msk
#define JPEG_CONFR7_NB_0   (0x1UL << JPEG_CONFR7_NB_Pos)
#define JPEG_CONFR7_NB_1   (0x2UL << JPEG_CONFR7_NB_Pos)
#define JPEG_CONFR7_NB_2   (0x4UL << JPEG_CONFR7_NB_Pos)
#define JPEG_CONFR7_NB_3   (0x8UL << JPEG_CONFR7_NB_Pos)
#define JPEG_CONFR7_VSF_Pos   (8U)
#define JPEG_CONFR7_VSF_Msk   (0xFUL << JPEG_CONFR7_VSF_Pos)
#define JPEG_CONFR7_VSF   JPEG_CONFR7_VSF_Msk
#define JPEG_CONFR7_VSF_0   (0x1UL << JPEG_CONFR7_VSF_Pos)
#define JPEG_CONFR7_VSF_1   (0x2UL << JPEG_CONFR7_VSF_Pos)
#define JPEG_CONFR7_VSF_2   (0x4UL << JPEG_CONFR7_VSF_Pos)
#define JPEG_CONFR7_VSF_3   (0x8UL << JPEG_CONFR7_VSF_Pos)
#define JPEG_CONFR7_HSF_Pos   (12U)
#define JPEG_CONFR7_HSF_Msk   (0xFUL << JPEG_CONFR7_HSF_Pos)
#define JPEG_CONFR7_HSF   JPEG_CONFR7_HSF_Msk
#define JPEG_CONFR7_HSF_0   (0x1UL << JPEG_CONFR7_HSF_Pos)
#define JPEG_CONFR7_HSF_1   (0x2UL << JPEG_CONFR7_HSF_Pos)
#define JPEG_CONFR7_HSF_2   (0x4UL << JPEG_CONFR7_HSF_Pos)
#define JPEG_CONFR7_HSF_3   (0x8UL << JPEG_CONFR7_HSF_Pos)
#define JPEG_CR_JCEN_Pos   (0U)
#define JPEG_CR_JCEN_Msk   (0x1UL << JPEG_CR_JCEN_Pos)
#define JPEG_CR_JCEN   JPEG_CR_JCEN_Msk
#define JPEG_CR_IFTIE_Pos   (1U)
#define JPEG_CR_IFTIE_Msk   (0x1UL << JPEG_CR_IFTIE_Pos)
#define JPEG_CR_IFTIE   JPEG_CR_IFTIE_Msk
#define JPEG_CR_IFNFIE_Pos   (2U)
#define JPEG_CR_IFNFIE_Msk   (0x1UL << JPEG_CR_IFNFIE_Pos)
#define JPEG_CR_IFNFIE   JPEG_CR_IFNFIE_Msk
#define JPEG_CR_OFTIE_Pos   (3U)
#define JPEG_CR_OFTIE_Msk   (0x1UL << JPEG_CR_OFTIE_Pos)
#define JPEG_CR_OFTIE   JPEG_CR_OFTIE_Msk
#define JPEG_CR_OFNEIE_Pos   (4U)
#define JPEG_CR_OFNEIE_Msk   (0x1UL << JPEG_CR_OFNEIE_Pos)
#define JPEG_CR_OFNEIE   JPEG_CR_OFNEIE_Msk
#define JPEG_CR_EOCIE_Pos   (5U)
#define JPEG_CR_EOCIE_Msk   (0x1UL << JPEG_CR_EOCIE_Pos)
#define JPEG_CR_EOCIE   JPEG_CR_EOCIE_Msk
#define JPEG_CR_HPDIE_Pos   (6U)
#define JPEG_CR_HPDIE_Msk   (0x1UL << JPEG_CR_HPDIE_Pos)
#define JPEG_CR_HPDIE   JPEG_CR_HPDIE_Msk
#define JPEG_CR_IFF_Pos   (13U)
#define JPEG_CR_IFF_Msk   (0x1UL << JPEG_CR_IFF_Pos)
#define JPEG_CR_IFF   JPEG_CR_IFF_Msk
#define JPEG_CR_OFF_Pos   (14U)
#define JPEG_CR_OFF_Msk   (0x1UL << JPEG_CR_OFF_Pos)
#define JPEG_CR_OFF   JPEG_CR_OFF_Msk
#define JPEG_SR_IFTF_Pos   (1U)
#define JPEG_SR_IFTF_Msk   (0x1UL << JPEG_SR_IFTF_Pos)
#define JPEG_SR_IFTF   JPEG_SR_IFTF_Msk
#define JPEG_SR_IFNFF_Pos   (2U)
#define JPEG_SR_IFNFF_Msk   (0x1UL << JPEG_SR_IFNFF_Pos)
#define JPEG_SR_IFNFF   JPEG_SR_IFNFF_Msk
#define JPEG_SR_OFTF_Pos   (3U)
#define JPEG_SR_OFTF_Msk   (0x1UL << JPEG_SR_OFTF_Pos)
#define JPEG_SR_OFTF   JPEG_SR_OFTF_Msk
#define JPEG_SR_OFNEF_Pos   (4U)
#define JPEG_SR_OFNEF_Msk   (0x1UL << JPEG_SR_OFNEF_Pos)
#define JPEG_SR_OFNEF   JPEG_SR_OFNEF_Msk
#define JPEG_SR_EOCF_Pos   (5U)
#define JPEG_SR_EOCF_Msk   (0x1UL << JPEG_SR_EOCF_Pos)
#define JPEG_SR_EOCF   JPEG_SR_EOCF_Msk
#define JPEG_SR_HPDF_Pos   (6U)
#define JPEG_SR_HPDF_Msk   (0x1UL << JPEG_SR_HPDF_Pos)
#define JPEG_SR_HPDF   JPEG_SR_HPDF_Msk
#define JPEG_SR_COF_Pos   (7U)
#define JPEG_SR_COF_Msk   (0x1UL << JPEG_SR_COF_Pos)
#define JPEG_SR_COF   JPEG_SR_COF_Msk
#define JPEG_CFR_CEOCF_Pos   (4U)
#define JPEG_CFR_CEOCF_Msk   (0x1UL << JPEG_CFR_CEOCF_Pos)
#define JPEG_CFR_CEOCF   JPEG_CFR_CEOCF_Msk
#define JPEG_CFR_CHPDF_Pos   (5U)
#define JPEG_CFR_CHPDF_Msk   (0x1UL << JPEG_CFR_CHPDF_Pos)
#define JPEG_CFR_CHPDF   JPEG_CFR_CHPDF_Msk
#define JPEG_DIR_DATAIN_Pos   (0U)
#define JPEG_DIR_DATAIN_Msk   (0xFFFFFFFFUL << JPEG_DIR_DATAIN_Pos)
#define JPEG_DIR_DATAIN   JPEG_DIR_DATAIN_Msk
#define JPEG_DOR_DATAOUT_Pos   (0U)
#define JPEG_DOR_DATAOUT_Msk   (0xFFFFFFFFUL << JPEG_DOR_DATAOUT_Pos)
#define JPEG_DOR_DATAOUT   JPEG_DOR_DATAOUT_Msk
#define LTDC_SSCR_VSH_Pos   (0U)
#define LTDC_SSCR_VSH_Msk   (0x7FFUL << LTDC_SSCR_VSH_Pos)
#define LTDC_SSCR_VSH   LTDC_SSCR_VSH_Msk
#define LTDC_SSCR_HSW_Pos   (16U)
#define LTDC_SSCR_HSW_Msk   (0xFFFUL << LTDC_SSCR_HSW_Pos)
#define LTDC_SSCR_HSW   LTDC_SSCR_HSW_Msk
#define LTDC_BPCR_AVBP_Pos   (0U)
#define LTDC_BPCR_AVBP_Msk   (0x7FFUL << LTDC_BPCR_AVBP_Pos)
#define LTDC_BPCR_AVBP   LTDC_BPCR_AVBP_Msk
#define LTDC_BPCR_AHBP_Pos   (16U)
#define LTDC_BPCR_AHBP_Msk   (0xFFFUL << LTDC_BPCR_AHBP_Pos)
#define LTDC_BPCR_AHBP   LTDC_BPCR_AHBP_Msk
#define LTDC_AWCR_AAH_Pos   (0U)
#define LTDC_AWCR_AAH_Msk   (0x7FFUL << LTDC_AWCR_AAH_Pos)
#define LTDC_AWCR_AAH   LTDC_AWCR_AAH_Msk
#define LTDC_AWCR_AAW_Pos   (16U)
#define LTDC_AWCR_AAW_Msk   (0xFFFUL << LTDC_AWCR_AAW_Pos)
#define LTDC_AWCR_AAW   LTDC_AWCR_AAW_Msk
#define LTDC_TWCR_TOTALH_Pos   (0U)
#define LTDC_TWCR_TOTALH_Msk   (0x7FFUL << LTDC_TWCR_TOTALH_Pos)
#define LTDC_TWCR_TOTALH   LTDC_TWCR_TOTALH_Msk
#define LTDC_TWCR_TOTALW_Pos   (16U)
#define LTDC_TWCR_TOTALW_Msk   (0xFFFUL << LTDC_TWCR_TOTALW_Pos)
#define LTDC_TWCR_TOTALW   LTDC_TWCR_TOTALW_Msk
#define LTDC_GCR_LTDCEN_Pos   (0U)
#define LTDC_GCR_LTDCEN_Msk   (0x1UL << LTDC_GCR_LTDCEN_Pos)
#define LTDC_GCR_LTDCEN   LTDC_GCR_LTDCEN_Msk
#define LTDC_GCR_DBW_Pos   (4U)
#define LTDC_GCR_DBW_Msk   (0x7UL << LTDC_GCR_DBW_Pos)
#define LTDC_GCR_DBW   LTDC_GCR_DBW_Msk
#define LTDC_GCR_DGW_Pos   (8U)
#define LTDC_GCR_DGW_Msk   (0x7UL << LTDC_GCR_DGW_Pos)
#define LTDC_GCR_DGW   LTDC_GCR_DGW_Msk
#define LTDC_GCR_DRW_Pos   (12U)
#define LTDC_GCR_DRW_Msk   (0x7UL << LTDC_GCR_DRW_Pos)
#define LTDC_GCR_DRW   LTDC_GCR_DRW_Msk
#define LTDC_GCR_DEN_Pos   (16U)
#define LTDC_GCR_DEN_Msk   (0x1UL << LTDC_GCR_DEN_Pos)
#define LTDC_GCR_DEN   LTDC_GCR_DEN_Msk
#define LTDC_GCR_PCPOL_Pos   (28U)
#define LTDC_GCR_PCPOL_Msk   (0x1UL << LTDC_GCR_PCPOL_Pos)
#define LTDC_GCR_PCPOL   LTDC_GCR_PCPOL_Msk
#define LTDC_GCR_DEPOL_Pos   (29U)
#define LTDC_GCR_DEPOL_Msk   (0x1UL << LTDC_GCR_DEPOL_Pos)
#define LTDC_GCR_DEPOL   LTDC_GCR_DEPOL_Msk
#define LTDC_GCR_VSPOL_Pos   (30U)
#define LTDC_GCR_VSPOL_Msk   (0x1UL << LTDC_GCR_VSPOL_Pos)
#define LTDC_GCR_VSPOL   LTDC_GCR_VSPOL_Msk
#define LTDC_GCR_HSPOL_Pos   (31U)
#define LTDC_GCR_HSPOL_Msk   (0x1UL << LTDC_GCR_HSPOL_Pos)
#define LTDC_GCR_HSPOL   LTDC_GCR_HSPOL_Msk
#define LTDC_SRCR_IMR_Pos   (0U)
#define LTDC_SRCR_IMR_Msk   (0x1UL << LTDC_SRCR_IMR_Pos)
#define LTDC_SRCR_IMR   LTDC_SRCR_IMR_Msk
#define LTDC_SRCR_VBR_Pos   (1U)
#define LTDC_SRCR_VBR_Msk   (0x1UL << LTDC_SRCR_VBR_Pos)
#define LTDC_SRCR_VBR   LTDC_SRCR_VBR_Msk
#define LTDC_BCCR_BCBLUE_Pos   (0U)
#define LTDC_BCCR_BCBLUE_Msk   (0xFFUL << LTDC_BCCR_BCBLUE_Pos)
#define LTDC_BCCR_BCBLUE   LTDC_BCCR_BCBLUE_Msk
#define LTDC_BCCR_BCGREEN_Pos   (8U)
#define LTDC_BCCR_BCGREEN_Msk   (0xFFUL << LTDC_BCCR_BCGREEN_Pos)
#define LTDC_BCCR_BCGREEN   LTDC_BCCR_BCGREEN_Msk
#define LTDC_BCCR_BCRED_Pos   (16U)
#define LTDC_BCCR_BCRED_Msk   (0xFFUL << LTDC_BCCR_BCRED_Pos)
#define LTDC_BCCR_BCRED   LTDC_BCCR_BCRED_Msk
#define LTDC_IER_LIE_Pos   (0U)
#define LTDC_IER_LIE_Msk   (0x1UL << LTDC_IER_LIE_Pos)
#define LTDC_IER_LIE   LTDC_IER_LIE_Msk
#define LTDC_IER_FUIE_Pos   (1U)
#define LTDC_IER_FUIE_Msk   (0x1UL << LTDC_IER_FUIE_Pos)
#define LTDC_IER_FUIE   LTDC_IER_FUIE_Msk
#define LTDC_IER_TERRIE_Pos   (2U)
#define LTDC_IER_TERRIE_Msk   (0x1UL << LTDC_IER_TERRIE_Pos)
#define LTDC_IER_TERRIE   LTDC_IER_TERRIE_Msk
#define LTDC_IER_RRIE_Pos   (3U)
#define LTDC_IER_RRIE_Msk   (0x1UL << LTDC_IER_RRIE_Pos)
#define LTDC_IER_RRIE   LTDC_IER_RRIE_Msk
#define LTDC_ISR_LIF_Pos   (0U)
#define LTDC_ISR_LIF_Msk   (0x1UL << LTDC_ISR_LIF_Pos)
#define LTDC_ISR_LIF   LTDC_ISR_LIF_Msk
#define LTDC_ISR_FUIF_Pos   (1U)
#define LTDC_ISR_FUIF_Msk   (0x1UL << LTDC_ISR_FUIF_Pos)
#define LTDC_ISR_FUIF   LTDC_ISR_FUIF_Msk
#define LTDC_ISR_TERRIF_Pos   (2U)
#define LTDC_ISR_TERRIF_Msk   (0x1UL << LTDC_ISR_TERRIF_Pos)
#define LTDC_ISR_TERRIF   LTDC_ISR_TERRIF_Msk
#define LTDC_ISR_RRIF_Pos   (3U)
#define LTDC_ISR_RRIF_Msk   (0x1UL << LTDC_ISR_RRIF_Pos)
#define LTDC_ISR_RRIF   LTDC_ISR_RRIF_Msk
#define LTDC_ICR_CLIF_Pos   (0U)
#define LTDC_ICR_CLIF_Msk   (0x1UL << LTDC_ICR_CLIF_Pos)
#define LTDC_ICR_CLIF   LTDC_ICR_CLIF_Msk
#define LTDC_ICR_CFUIF_Pos   (1U)
#define LTDC_ICR_CFUIF_Msk   (0x1UL << LTDC_ICR_CFUIF_Pos)
#define LTDC_ICR_CFUIF   LTDC_ICR_CFUIF_Msk
#define LTDC_ICR_CTERRIF_Pos   (2U)
#define LTDC_ICR_CTERRIF_Msk   (0x1UL << LTDC_ICR_CTERRIF_Pos)
#define LTDC_ICR_CTERRIF   LTDC_ICR_CTERRIF_Msk
#define LTDC_ICR_CRRIF_Pos   (3U)
#define LTDC_ICR_CRRIF_Msk   (0x1UL << LTDC_ICR_CRRIF_Pos)
#define LTDC_ICR_CRRIF   LTDC_ICR_CRRIF_Msk
#define LTDC_LIPCR_LIPOS_Pos   (0U)
#define LTDC_LIPCR_LIPOS_Msk   (0x7FFUL << LTDC_LIPCR_LIPOS_Pos)
#define LTDC_LIPCR_LIPOS   LTDC_LIPCR_LIPOS_Msk
#define LTDC_CPSR_CYPOS_Pos   (0U)
#define LTDC_CPSR_CYPOS_Msk   (0xFFFFUL << LTDC_CPSR_CYPOS_Pos)
#define LTDC_CPSR_CYPOS   LTDC_CPSR_CYPOS_Msk
#define LTDC_CPSR_CXPOS_Pos   (16U)
#define LTDC_CPSR_CXPOS_Msk   (0xFFFFUL << LTDC_CPSR_CXPOS_Pos)
#define LTDC_CPSR_CXPOS   LTDC_CPSR_CXPOS_Msk
#define LTDC_CDSR_VDES_Pos   (0U)
#define LTDC_CDSR_VDES_Msk   (0x1UL << LTDC_CDSR_VDES_Pos)
#define LTDC_CDSR_VDES   LTDC_CDSR_VDES_Msk
#define LTDC_CDSR_HDES_Pos   (1U)
#define LTDC_CDSR_HDES_Msk   (0x1UL << LTDC_CDSR_HDES_Pos)
#define LTDC_CDSR_HDES   LTDC_CDSR_HDES_Msk
#define LTDC_CDSR_VSYNCS_Pos   (2U)
#define LTDC_CDSR_VSYNCS_Msk   (0x1UL << LTDC_CDSR_VSYNCS_Pos)
#define LTDC_CDSR_VSYNCS   LTDC_CDSR_VSYNCS_Msk
#define LTDC_CDSR_HSYNCS_Pos   (3U)
#define LTDC_CDSR_HSYNCS_Msk   (0x1UL << LTDC_CDSR_HSYNCS_Pos)
#define LTDC_CDSR_HSYNCS   LTDC_CDSR_HSYNCS_Msk
#define LTDC_LxCR_LEN_Pos   (0U)
#define LTDC_LxCR_LEN_Msk   (0x1UL << LTDC_LxCR_LEN_Pos)
#define LTDC_LxCR_LEN   LTDC_LxCR_LEN_Msk
#define LTDC_LxCR_COLKEN_Pos   (1U)
#define LTDC_LxCR_COLKEN_Msk   (0x1UL << LTDC_LxCR_COLKEN_Pos)
#define LTDC_LxCR_COLKEN   LTDC_LxCR_COLKEN_Msk
#define LTDC_LxCR_CLUTEN_Pos   (4U)
#define LTDC_LxCR_CLUTEN_Msk   (0x1UL << LTDC_LxCR_CLUTEN_Pos)
#define LTDC_LxCR_CLUTEN   LTDC_LxCR_CLUTEN_Msk
#define LTDC_LxWHPCR_WHSTPOS_Pos   (0U)
#define LTDC_LxWHPCR_WHSTPOS_Msk   (0xFFFUL << LTDC_LxWHPCR_WHSTPOS_Pos)
#define LTDC_LxWHPCR_WHSTPOS   LTDC_LxWHPCR_WHSTPOS_Msk
#define LTDC_LxWHPCR_WHSPPOS_Pos   (16U)
#define LTDC_LxWHPCR_WHSPPOS_Msk   (0xFFFFUL << LTDC_LxWHPCR_WHSPPOS_Pos)
#define LTDC_LxWHPCR_WHSPPOS   LTDC_LxWHPCR_WHSPPOS_Msk
#define LTDC_LxWVPCR_WVSTPOS_Pos   (0U)
#define LTDC_LxWVPCR_WVSTPOS_Msk   (0xFFFUL << LTDC_LxWVPCR_WVSTPOS_Pos)
#define LTDC_LxWVPCR_WVSTPOS   LTDC_LxWVPCR_WVSTPOS_Msk
#define LTDC_LxWVPCR_WVSPPOS_Pos   (16U)
#define LTDC_LxWVPCR_WVSPPOS_Msk   (0xFFFFUL << LTDC_LxWVPCR_WVSPPOS_Pos)
#define LTDC_LxWVPCR_WVSPPOS   LTDC_LxWVPCR_WVSPPOS_Msk
#define LTDC_LxCKCR_CKBLUE_Pos   (0U)
#define LTDC_LxCKCR_CKBLUE_Msk   (0xFFUL << LTDC_LxCKCR_CKBLUE_Pos)
#define LTDC_LxCKCR_CKBLUE   LTDC_LxCKCR_CKBLUE_Msk
#define LTDC_LxCKCR_CKGREEN_Pos   (8U)
#define LTDC_LxCKCR_CKGREEN_Msk   (0xFFUL << LTDC_LxCKCR_CKGREEN_Pos)
#define LTDC_LxCKCR_CKGREEN   LTDC_LxCKCR_CKGREEN_Msk
#define LTDC_LxCKCR_CKRED_Pos   (16U)
#define LTDC_LxCKCR_CKRED_Msk   (0xFFUL << LTDC_LxCKCR_CKRED_Pos)
#define LTDC_LxCKCR_CKRED   LTDC_LxCKCR_CKRED_Msk
#define LTDC_LxPFCR_PF_Pos   (0U)
#define LTDC_LxPFCR_PF_Msk   (0x7UL << LTDC_LxPFCR_PF_Pos)
#define LTDC_LxPFCR_PF   LTDC_LxPFCR_PF_Msk
#define LTDC_LxCACR_CONSTA_Pos   (0U)
#define LTDC_LxCACR_CONSTA_Msk   (0xFFUL << LTDC_LxCACR_CONSTA_Pos)
#define LTDC_LxCACR_CONSTA   LTDC_LxCACR_CONSTA_Msk
#define LTDC_LxDCCR_DCBLUE_Pos   (0U)
#define LTDC_LxDCCR_DCBLUE_Msk   (0xFFUL << LTDC_LxDCCR_DCBLUE_Pos)
#define LTDC_LxDCCR_DCBLUE   LTDC_LxDCCR_DCBLUE_Msk
#define LTDC_LxDCCR_DCGREEN_Pos   (8U)
#define LTDC_LxDCCR_DCGREEN_Msk   (0xFFUL << LTDC_LxDCCR_DCGREEN_Pos)
#define LTDC_LxDCCR_DCGREEN   LTDC_LxDCCR_DCGREEN_Msk
#define LTDC_LxDCCR_DCRED_Pos   (16U)
#define LTDC_LxDCCR_DCRED_Msk   (0xFFUL << LTDC_LxDCCR_DCRED_Pos)
#define LTDC_LxDCCR_DCRED   LTDC_LxDCCR_DCRED_Msk
#define LTDC_LxDCCR_DCALPHA_Pos   (24U)
#define LTDC_LxDCCR_DCALPHA_Msk   (0xFFUL << LTDC_LxDCCR_DCALPHA_Pos)
#define LTDC_LxDCCR_DCALPHA   LTDC_LxDCCR_DCALPHA_Msk
#define LTDC_LxBFCR_BF2_Pos   (0U)
#define LTDC_LxBFCR_BF2_Msk   (0x7UL << LTDC_LxBFCR_BF2_Pos)
#define LTDC_LxBFCR_BF2   LTDC_LxBFCR_BF2_Msk
#define LTDC_LxBFCR_BF1_Pos   (8U)
#define LTDC_LxBFCR_BF1_Msk   (0x7UL << LTDC_LxBFCR_BF1_Pos)
#define LTDC_LxBFCR_BF1   LTDC_LxBFCR_BF1_Msk
#define LTDC_LxCFBAR_CFBADD_Pos   (0U)
#define LTDC_LxCFBAR_CFBADD_Msk   (0xFFFFFFFFUL << LTDC_LxCFBAR_CFBADD_Pos)
#define LTDC_LxCFBAR_CFBADD   LTDC_LxCFBAR_CFBADD_Msk
#define LTDC_LxCFBLR_CFBLL_Pos   (0U)
#define LTDC_LxCFBLR_CFBLL_Msk   (0x1FFFUL << LTDC_LxCFBLR_CFBLL_Pos)
#define LTDC_LxCFBLR_CFBLL   LTDC_LxCFBLR_CFBLL_Msk
#define LTDC_LxCFBLR_CFBP_Pos   (16U)
#define LTDC_LxCFBLR_CFBP_Msk   (0x1FFFUL << LTDC_LxCFBLR_CFBP_Pos)
#define LTDC_LxCFBLR_CFBP   LTDC_LxCFBLR_CFBP_Msk
#define LTDC_LxCFBLNR_CFBLNBR_Pos   (0U)
#define LTDC_LxCFBLNR_CFBLNBR_Msk   (0x7FFUL << LTDC_LxCFBLNR_CFBLNBR_Pos)
#define LTDC_LxCFBLNR_CFBLNBR   LTDC_LxCFBLNR_CFBLNBR_Msk
#define LTDC_LxCLUTWR_BLUE_Pos   (0U)
#define LTDC_LxCLUTWR_BLUE_Msk   (0xFFUL << LTDC_LxCLUTWR_BLUE_Pos)
#define LTDC_LxCLUTWR_BLUE   LTDC_LxCLUTWR_BLUE_Msk
#define LTDC_LxCLUTWR_GREEN_Pos   (8U)
#define LTDC_LxCLUTWR_GREEN_Msk   (0xFFUL << LTDC_LxCLUTWR_GREEN_Pos)
#define LTDC_LxCLUTWR_GREEN   LTDC_LxCLUTWR_GREEN_Msk
#define LTDC_LxCLUTWR_RED_Pos   (16U)
#define LTDC_LxCLUTWR_RED_Msk   (0xFFUL << LTDC_LxCLUTWR_RED_Pos)
#define LTDC_LxCLUTWR_RED   LTDC_LxCLUTWR_RED_Msk
#define LTDC_LxCLUTWR_CLUTADD_Pos   (24U)
#define LTDC_LxCLUTWR_CLUTADD_Msk   (0xFFUL << LTDC_LxCLUTWR_CLUTADD_Pos)
#define LTDC_LxCLUTWR_CLUTADD   LTDC_LxCLUTWR_CLUTADD_Msk
#define MDMA_GISR0_GIF0_Pos   (0U)
#define MDMA_GISR0_GIF0_Msk   (0x1UL << MDMA_GISR0_GIF0_Pos)
#define MDMA_GISR0_GIF0   MDMA_GISR0_GIF0_Msk
#define MDMA_GISR0_GIF1_Pos   (1U)
#define MDMA_GISR0_GIF1_Msk   (0x1UL << MDMA_GISR0_GIF1_Pos)
#define MDMA_GISR0_GIF1   MDMA_GISR0_GIF1_Msk
#define MDMA_GISR0_GIF2_Pos   (2U)
#define MDMA_GISR0_GIF2_Msk   (0x1UL << MDMA_GISR0_GIF2_Pos)
#define MDMA_GISR0_GIF2   MDMA_GISR0_GIF2_Msk
#define MDMA_GISR0_GIF3_Pos   (3U)
#define MDMA_GISR0_GIF3_Msk   (0x1UL << MDMA_GISR0_GIF3_Pos)
#define MDMA_GISR0_GIF3   MDMA_GISR0_GIF3_Msk
#define MDMA_GISR0_GIF4_Pos   (4U)
#define MDMA_GISR0_GIF4_Msk   (0x1UL << MDMA_GISR0_GIF4_Pos)
#define MDMA_GISR0_GIF4   MDMA_GISR0_GIF4_Msk
#define MDMA_GISR0_GIF5_Pos   (5U)
#define MDMA_GISR0_GIF5_Msk   (0x1UL << MDMA_GISR0_GIF5_Pos)
#define MDMA_GISR0_GIF5   MDMA_GISR0_GIF5_Msk
#define MDMA_GISR0_GIF6_Pos   (6U)
#define MDMA_GISR0_GIF6_Msk   (0x1UL << MDMA_GISR0_GIF6_Pos)
#define MDMA_GISR0_GIF6   MDMA_GISR0_GIF6_Msk
#define MDMA_GISR0_GIF7_Pos   (7U)
#define MDMA_GISR0_GIF7_Msk   (0x1UL << MDMA_GISR0_GIF7_Pos)
#define MDMA_GISR0_GIF7   MDMA_GISR0_GIF7_Msk
#define MDMA_GISR0_GIF8_Pos   (8U)
#define MDMA_GISR0_GIF8_Msk   (0x1UL << MDMA_GISR0_GIF8_Pos)
#define MDMA_GISR0_GIF8   MDMA_GISR0_GIF8_Msk
#define MDMA_GISR0_GIF9_Pos   (9U)
#define MDMA_GISR0_GIF9_Msk   (0x1UL << MDMA_GISR0_GIF9_Pos)
#define MDMA_GISR0_GIF9   MDMA_GISR0_GIF9_Msk
#define MDMA_GISR0_GIF10_Pos   (10U)
#define MDMA_GISR0_GIF10_Msk   (0x1UL << MDMA_GISR0_GIF10_Pos)
#define MDMA_GISR0_GIF10   MDMA_GISR0_GIF10_Msk
#define MDMA_GISR0_GIF11_Pos   (11U)
#define MDMA_GISR0_GIF11_Msk   (0x1UL << MDMA_GISR0_GIF11_Pos)
#define MDMA_GISR0_GIF11   MDMA_GISR0_GIF11_Msk
#define MDMA_GISR0_GIF12_Pos   (12U)
#define MDMA_GISR0_GIF12_Msk   (0x1UL << MDMA_GISR0_GIF12_Pos)
#define MDMA_GISR0_GIF12   MDMA_GISR0_GIF12_Msk
#define MDMA_GISR0_GIF13_Pos   (13U)
#define MDMA_GISR0_GIF13_Msk   (0x1UL << MDMA_GISR0_GIF13_Pos)
#define MDMA_GISR0_GIF13   MDMA_GISR0_GIF13_Msk
#define MDMA_GISR0_GIF14_Pos   (14U)
#define MDMA_GISR0_GIF14_Msk   (0x1UL << MDMA_GISR0_GIF14_Pos)
#define MDMA_GISR0_GIF14   MDMA_GISR0_GIF14_Msk
#define MDMA_GISR0_GIF15_Pos   (15U)
#define MDMA_GISR0_GIF15_Msk   (0x1UL << MDMA_GISR0_GIF15_Pos)
#define MDMA_GISR0_GIF15   MDMA_GISR0_GIF15_Msk
#define MDMA_CISR_TEIF_Pos   (0U)
#define MDMA_CISR_TEIF_Msk   (0x1UL << MDMA_CISR_TEIF_Pos)
#define MDMA_CISR_TEIF   MDMA_CISR_TEIF_Msk
#define MDMA_CISR_CTCIF_Pos   (1U)
#define MDMA_CISR_CTCIF_Msk   (0x1UL << MDMA_CISR_CTCIF_Pos)
#define MDMA_CISR_CTCIF   MDMA_CISR_CTCIF_Msk
#define MDMA_CISR_BRTIF_Pos   (2U)
#define MDMA_CISR_BRTIF_Msk   (0x1UL << MDMA_CISR_BRTIF_Pos)
#define MDMA_CISR_BRTIF   MDMA_CISR_BRTIF_Msk
#define MDMA_CISR_BTIF_Pos   (3U)
#define MDMA_CISR_BTIF_Msk   (0x1UL << MDMA_CISR_BTIF_Pos)
#define MDMA_CISR_BTIF   MDMA_CISR_BTIF_Msk
#define MDMA_CISR_TCIF_Pos   (4U)
#define MDMA_CISR_TCIF_Msk   (0x1UL << MDMA_CISR_TCIF_Pos)
#define MDMA_CISR_TCIF   MDMA_CISR_TCIF_Msk
#define MDMA_CISR_CRQA_Pos   (16U)
#define MDMA_CISR_CRQA_Msk   (0x1UL << MDMA_CISR_CRQA_Pos)
#define MDMA_CISR_CRQA   MDMA_CISR_CRQA_Msk
#define MDMA_CIFCR_CTEIF_Pos   (0U)
#define MDMA_CIFCR_CTEIF_Msk   (0x1UL << MDMA_CIFCR_CTEIF_Pos)
#define MDMA_CIFCR_CTEIF   MDMA_CIFCR_CTEIF_Msk
#define MDMA_CIFCR_CCTCIF_Pos   (1U)
#define MDMA_CIFCR_CCTCIF_Msk   (0x1UL << MDMA_CIFCR_CCTCIF_Pos)
#define MDMA_CIFCR_CCTCIF   MDMA_CIFCR_CCTCIF_Msk
#define MDMA_CIFCR_CBRTIF_Pos   (2U)
#define MDMA_CIFCR_CBRTIF_Msk   (0x1UL << MDMA_CIFCR_CBRTIF_Pos)
#define MDMA_CIFCR_CBRTIF   MDMA_CIFCR_CBRTIF_Msk
#define MDMA_CIFCR_CBTIF_Pos   (3U)
#define MDMA_CIFCR_CBTIF_Msk   (0x1UL << MDMA_CIFCR_CBTIF_Pos)
#define MDMA_CIFCR_CBTIF   MDMA_CIFCR_CBTIF_Msk
#define MDMA_CIFCR_CLTCIF_Pos   (4U)
#define MDMA_CIFCR_CLTCIF_Msk   (0x1UL << MDMA_CIFCR_CLTCIF_Pos)
#define MDMA_CIFCR_CLTCIF   MDMA_CIFCR_CLTCIF_Msk
#define MDMA_CESR_TEA_Pos   (0U)
#define MDMA_CESR_TEA_Msk   (0x7FUL << MDMA_CESR_TEA_Pos)
#define MDMA_CESR_TEA   MDMA_CESR_TEA_Msk
#define MDMA_CESR_TED_Pos   (7U)
#define MDMA_CESR_TED_Msk   (0x1UL << MDMA_CESR_TED_Pos)
#define MDMA_CESR_TED   MDMA_CESR_TED_Msk
#define MDMA_CESR_TELD_Pos   (8U)
#define MDMA_CESR_TELD_Msk   (0x1UL << MDMA_CESR_TELD_Pos)
#define MDMA_CESR_TELD   MDMA_CESR_TELD_Msk
#define MDMA_CESR_TEMD_Pos   (9U)
#define MDMA_CESR_TEMD_Msk   (0x1UL << MDMA_CESR_TEMD_Pos)
#define MDMA_CESR_TEMD   MDMA_CESR_TEMD_Msk
#define MDMA_CESR_ASE_Pos   (10U)
#define MDMA_CESR_ASE_Msk   (0x1UL << MDMA_CESR_ASE_Pos)
#define MDMA_CESR_ASE   MDMA_CESR_ASE_Msk
#define MDMA_CESR_BSE_Pos   (11U)
#define MDMA_CESR_BSE_Msk   (0x1UL << MDMA_CESR_BSE_Pos)
#define MDMA_CESR_BSE   MDMA_CESR_BSE_Msk
#define MDMA_CCR_EN_Pos   (0U)
#define MDMA_CCR_EN_Msk   (0x1UL << MDMA_CCR_EN_Pos)
#define MDMA_CCR_EN   MDMA_CCR_EN_Msk
#define MDMA_CCR_TEIE_Pos   (1U)
#define MDMA_CCR_TEIE_Msk   (0x1UL << MDMA_CCR_TEIE_Pos)
#define MDMA_CCR_TEIE   MDMA_CCR_TEIE_Msk
#define MDMA_CCR_CTCIE_Pos   (2U)
#define MDMA_CCR_CTCIE_Msk   (0x1UL << MDMA_CCR_CTCIE_Pos)
#define MDMA_CCR_CTCIE   MDMA_CCR_CTCIE_Msk
#define MDMA_CCR_BRTIE_Pos   (3U)
#define MDMA_CCR_BRTIE_Msk   (0x1UL << MDMA_CCR_BRTIE_Pos)
#define MDMA_CCR_BRTIE   MDMA_CCR_BRTIE_Msk
#define MDMA_CCR_BTIE_Pos   (4U)
#define MDMA_CCR_BTIE_Msk   (0x1UL << MDMA_CCR_BTIE_Pos)
#define MDMA_CCR_BTIE   MDMA_CCR_BTIE_Msk
#define MDMA_CCR_TCIE_Pos   (5U)
#define MDMA_CCR_TCIE_Msk   (0x1UL << MDMA_CCR_TCIE_Pos)
#define MDMA_CCR_TCIE   MDMA_CCR_TCIE_Msk
#define MDMA_CCR_PL_Pos   (6U)
#define MDMA_CCR_PL_Msk   (0x3UL << MDMA_CCR_PL_Pos)
#define MDMA_CCR_PL   MDMA_CCR_PL_Msk
#define MDMA_CCR_PL_0   (0x1UL << MDMA_CCR_PL_Pos)
#define MDMA_CCR_PL_1   (0x2UL << MDMA_CCR_PL_Pos)
#define MDMA_CCR_BEX_Pos   (12U)
#define MDMA_CCR_BEX_Msk   (0x1UL << MDMA_CCR_BEX_Pos)
#define MDMA_CCR_BEX   MDMA_CCR_BEX_Msk
#define MDMA_CCR_HEX_Pos   (13U)
#define MDMA_CCR_HEX_Msk   (0x1UL << MDMA_CCR_HEX_Pos)
#define MDMA_CCR_HEX   MDMA_CCR_HEX_Msk
#define MDMA_CCR_WEX_Pos   (14U)
#define MDMA_CCR_WEX_Msk   (0x1UL << MDMA_CCR_WEX_Pos)
#define MDMA_CCR_WEX   MDMA_CCR_WEX_Msk
#define MDMA_CCR_SWRQ_Pos   (16U)
#define MDMA_CCR_SWRQ_Msk   (0x1UL << MDMA_CCR_SWRQ_Pos)
#define MDMA_CCR_SWRQ   MDMA_CCR_SWRQ_Msk
#define MDMA_CTCR_SINC_Pos   (0U)
#define MDMA_CTCR_SINC_Msk   (0x3UL << MDMA_CTCR_SINC_Pos)
#define MDMA_CTCR_SINC   MDMA_CTCR_SINC_Msk
#define MDMA_CTCR_SINC_0   (0x1UL << MDMA_CTCR_SINC_Pos)
#define MDMA_CTCR_SINC_1   (0x2UL << MDMA_CTCR_SINC_Pos)
#define MDMA_CTCR_DINC_Pos   (2U)
#define MDMA_CTCR_DINC_Msk   (0x3UL << MDMA_CTCR_DINC_Pos)
#define MDMA_CTCR_DINC   MDMA_CTCR_DINC_Msk
#define MDMA_CTCR_DINC_0   (0x1UL << MDMA_CTCR_DINC_Pos)
#define MDMA_CTCR_DINC_1   (0x2UL << MDMA_CTCR_DINC_Pos)
#define MDMA_CTCR_SSIZE_Pos   (4U)
#define MDMA_CTCR_SSIZE_Msk   (0x3UL << MDMA_CTCR_SSIZE_Pos)
#define MDMA_CTCR_SSIZE   MDMA_CTCR_SSIZE_Msk
#define MDMA_CTCR_SSIZE_0   (0x1UL << MDMA_CTCR_SSIZE_Pos)
#define MDMA_CTCR_SSIZE_1   (0x2UL << MDMA_CTCR_SSIZE_Pos)
#define MDMA_CTCR_DSIZE_Pos   (6U)
#define MDMA_CTCR_DSIZE_Msk   (0x3UL << MDMA_CTCR_DSIZE_Pos)
#define MDMA_CTCR_DSIZE   MDMA_CTCR_DSIZE_Msk
#define MDMA_CTCR_DSIZE_0   (0x1UL << MDMA_CTCR_DSIZE_Pos)
#define MDMA_CTCR_DSIZE_1   (0x2UL << MDMA_CTCR_DSIZE_Pos)
#define MDMA_CTCR_SINCOS_Pos   (8U)
#define MDMA_CTCR_SINCOS_Msk   (0x3UL << MDMA_CTCR_SINCOS_Pos)
#define MDMA_CTCR_SINCOS   MDMA_CTCR_SINCOS_Msk
#define MDMA_CTCR_SINCOS_0   (0x1UL << MDMA_CTCR_SINCOS_Pos)
#define MDMA_CTCR_SINCOS_1   (0x2UL << MDMA_CTCR_SINCOS_Pos)
#define MDMA_CTCR_DINCOS_Pos   (10U)
#define MDMA_CTCR_DINCOS_Msk   (0x3UL << MDMA_CTCR_DINCOS_Pos)
#define MDMA_CTCR_DINCOS   MDMA_CTCR_DINCOS_Msk
#define MDMA_CTCR_DINCOS_0   (0x1UL << MDMA_CTCR_DINCOS_Pos)
#define MDMA_CTCR_DINCOS_1   (0x2UL << MDMA_CTCR_DINCOS_Pos)
#define MDMA_CTCR_SBURST_Pos   (12U)
#define MDMA_CTCR_SBURST_Msk   (0x7UL << MDMA_CTCR_SBURST_Pos)
#define MDMA_CTCR_SBURST   MDMA_CTCR_SBURST_Msk
#define MDMA_CTCR_SBURST_0   (0x1UL << MDMA_CTCR_SBURST_Pos)
#define MDMA_CTCR_SBURST_1   (0x2UL << MDMA_CTCR_SBURST_Pos)
#define MDMA_CTCR_SBURST_2   (0x4UL << MDMA_CTCR_SBURST_Pos)
#define MDMA_CTCR_DBURST_Pos   (15U)
#define MDMA_CTCR_DBURST_Msk   (0x7UL << MDMA_CTCR_DBURST_Pos)
#define MDMA_CTCR_DBURST   MDMA_CTCR_DBURST_Msk
#define MDMA_CTCR_DBURST_0   (0x1UL << MDMA_CTCR_DBURST_Pos)
#define MDMA_CTCR_DBURST_1   (0x2UL << MDMA_CTCR_DBURST_Pos)
#define MDMA_CTCR_DBURST_2   (0x4UL << MDMA_CTCR_DBURST_Pos)
#define MDMA_CTCR_TLEN_Pos   (18U)
#define MDMA_CTCR_TLEN_Msk   (0x7FUL << MDMA_CTCR_TLEN_Pos)
#define MDMA_CTCR_TLEN   MDMA_CTCR_TLEN_Msk
#define MDMA_CTCR_PKE_Pos   (25U)
#define MDMA_CTCR_PKE_Msk   (0x1UL << MDMA_CTCR_PKE_Pos)
#define MDMA_CTCR_PKE   MDMA_CTCR_PKE_Msk
#define MDMA_CTCR_PAM_Pos   (26U)
#define MDMA_CTCR_PAM_Msk   (0x3UL << MDMA_CTCR_PAM_Pos)
#define MDMA_CTCR_PAM   MDMA_CTCR_PAM_Msk
#define MDMA_CTCR_PAM_0   (0x1UL << MDMA_CTCR_PAM_Pos)
#define MDMA_CTCR_PAM_1   (0x2UL << MDMA_CTCR_PAM_Pos)
#define MDMA_CTCR_TRGM_Pos   (28U)
#define MDMA_CTCR_TRGM_Msk   (0x3UL << MDMA_CTCR_TRGM_Pos)
#define MDMA_CTCR_TRGM   MDMA_CTCR_TRGM_Msk
#define MDMA_CTCR_TRGM_0   (0x1UL << MDMA_CTCR_TRGM_Pos)
#define MDMA_CTCR_TRGM_1   (0x2UL << MDMA_CTCR_TRGM_Pos)
#define MDMA_CTCR_SWRM_Pos   (30U)
#define MDMA_CTCR_SWRM_Msk   (0x1UL << MDMA_CTCR_SWRM_Pos)
#define MDMA_CTCR_SWRM   MDMA_CTCR_SWRM_Msk
#define MDMA_CTCR_BWM_Pos   (31U)
#define MDMA_CTCR_BWM_Msk   (0x1UL << MDMA_CTCR_BWM_Pos)
#define MDMA_CTCR_BWM   MDMA_CTCR_BWM_Msk
#define MDMA_CBNDTR_BNDT_Pos   (0U)
#define MDMA_CBNDTR_BNDT_Msk   (0x1FFFFUL << MDMA_CBNDTR_BNDT_Pos)
#define MDMA_CBNDTR_BNDT   MDMA_CBNDTR_BNDT_Msk
#define MDMA_CBNDTR_BRSUM_Pos   (18U)
#define MDMA_CBNDTR_BRSUM_Msk   (0x1UL << MDMA_CBNDTR_BRSUM_Pos)
#define MDMA_CBNDTR_BRSUM   MDMA_CBNDTR_BRSUM_Msk
#define MDMA_CBNDTR_BRDUM_Pos   (19U)
#define MDMA_CBNDTR_BRDUM_Msk   (0x1UL << MDMA_CBNDTR_BRDUM_Pos)
#define MDMA_CBNDTR_BRDUM   MDMA_CBNDTR_BRDUM_Msk
#define MDMA_CBNDTR_BRC_Pos   (20U)
#define MDMA_CBNDTR_BRC_Msk   (0xFFFUL << MDMA_CBNDTR_BRC_Pos)
#define MDMA_CBNDTR_BRC   MDMA_CBNDTR_BRC_Msk
#define MDMA_CSAR_SAR_Pos   (0U)
#define MDMA_CSAR_SAR_Msk   (0xFFFFFFFFUL << MDMA_CSAR_SAR_Pos)
#define MDMA_CSAR_SAR   MDMA_CSAR_SAR_Msk
#define MDMA_CDAR_DAR_Pos   (0U)
#define MDMA_CDAR_DAR_Msk   (0xFFFFFFFFUL << MDMA_CDAR_DAR_Pos)
#define MDMA_CDAR_DAR   MDMA_CDAR_DAR_Msk
#define MDMA_CBRUR_SUV_Pos   (0U)
#define MDMA_CBRUR_SUV_Msk   (0xFFFFUL << MDMA_CBRUR_SUV_Pos)
#define MDMA_CBRUR_SUV   MDMA_CBRUR_SUV_Msk
#define MDMA_CBRUR_DUV_Pos   (16U)
#define MDMA_CBRUR_DUV_Msk   (0xFFFFUL << MDMA_CBRUR_DUV_Pos)
#define MDMA_CBRUR_DUV   MDMA_CBRUR_DUV_Msk
#define MDMA_CLAR_LAR_Pos   (0U)
#define MDMA_CLAR_LAR_Msk   (0xFFFFFFFFUL << MDMA_CLAR_LAR_Pos)
#define MDMA_CLAR_LAR   MDMA_CLAR_LAR_Msk
#define MDMA_CTBR_TSEL_Pos   (0U)
#define MDMA_CTBR_TSEL_Msk   (0xFFUL << MDMA_CTBR_TSEL_Pos)
#define MDMA_CTBR_TSEL   MDMA_CTBR_TSEL_Msk
#define MDMA_CTBR_SBUS_Pos   (16U)
#define MDMA_CTBR_SBUS_Msk   (0x1UL << MDMA_CTBR_SBUS_Pos)
#define MDMA_CTBR_SBUS   MDMA_CTBR_SBUS_Msk
#define MDMA_CTBR_DBUS_Pos   (17U)
#define MDMA_CTBR_DBUS_Msk   (0x1UL << MDMA_CTBR_DBUS_Pos)
#define MDMA_CTBR_DBUS   MDMA_CTBR_DBUS_Msk
#define MDMA_CMAR_MAR_Pos   (0U)
#define MDMA_CMAR_MAR_Msk   (0xFFFFFFFFUL << MDMA_CMAR_MAR_Pos)
#define MDMA_CMAR_MAR   MDMA_CMAR_MAR_Msk
#define MDMA_CMDR_MDR_Pos   (0U)
#define MDMA_CMDR_MDR_Msk   (0xFFFFFFFFUL << MDMA_CMDR_MDR_Pos)
#define MDMA_CMDR_MDR   MDMA_CMDR_MDR_Msk
#define OPAMP_CSR_OPAMPxEN_Pos   (0U)
#define OPAMP_CSR_OPAMPxEN_Msk   (0x1UL << OPAMP_CSR_OPAMPxEN_Pos)
#define OPAMP_CSR_OPAMPxEN   OPAMP_CSR_OPAMPxEN_Msk
#define OPAMP_CSR_FORCEVP_Pos   (1U)
#define OPAMP_CSR_FORCEVP_Msk   (0x1UL << OPAMP_CSR_FORCEVP_Pos)
#define OPAMP_CSR_FORCEVP   OPAMP_CSR_FORCEVP_Msk
#define OPAMP_CSR_VPSEL_Pos   (2U)
#define OPAMP_CSR_VPSEL_Msk   (0x3UL << OPAMP_CSR_VPSEL_Pos)
#define OPAMP_CSR_VPSEL   OPAMP_CSR_VPSEL_Msk
#define OPAMP_CSR_VPSEL_0   (0x1UL << OPAMP_CSR_VPSEL_Pos)
#define OPAMP_CSR_VPSEL_1   (0x2UL << OPAMP_CSR_VPSEL_Pos)
#define OPAMP_CSR_VMSEL_Pos   (5U)
#define OPAMP_CSR_VMSEL_Msk   (0x3UL << OPAMP_CSR_VMSEL_Pos)
#define OPAMP_CSR_VMSEL   OPAMP_CSR_VMSEL_Msk
#define OPAMP_CSR_VMSEL_0   (0x1UL << OPAMP_CSR_VMSEL_Pos)
#define OPAMP_CSR_VMSEL_1   (0x2UL << OPAMP_CSR_VMSEL_Pos)
#define OPAMP_CSR_OPAHSM_Pos   (8U)
#define OPAMP_CSR_OPAHSM_Msk   (0x1UL << OPAMP_CSR_OPAHSM_Pos)
#define OPAMP_CSR_OPAHSM   OPAMP_CSR_OPAHSM_Msk
#define OPAMP_CSR_CALON_Pos   (11U)
#define OPAMP_CSR_CALON_Msk   (0x1UL << OPAMP_CSR_CALON_Pos)
#define OPAMP_CSR_CALON   OPAMP_CSR_CALON_Msk
#define OPAMP_CSR_CALSEL_Pos   (12U)
#define OPAMP_CSR_CALSEL_Msk   (0x3UL << OPAMP_CSR_CALSEL_Pos)
#define OPAMP_CSR_CALSEL   OPAMP_CSR_CALSEL_Msk
#define OPAMP_CSR_CALSEL_0   (0x1UL << OPAMP_CSR_CALSEL_Pos)
#define OPAMP_CSR_CALSEL_1   (0x2UL << OPAMP_CSR_CALSEL_Pos)
#define OPAMP_CSR_PGGAIN_Pos   (14U)
#define OPAMP_CSR_PGGAIN_Msk   (0xFUL << OPAMP_CSR_PGGAIN_Pos)
#define OPAMP_CSR_PGGAIN   OPAMP_CSR_PGGAIN_Msk
#define OPAMP_CSR_PGGAIN_0   (0x1UL << OPAMP_CSR_PGGAIN_Pos)
#define OPAMP_CSR_PGGAIN_1   (0x2UL << OPAMP_CSR_PGGAIN_Pos)
#define OPAMP_CSR_PGGAIN_2   (0x4UL << OPAMP_CSR_PGGAIN_Pos)
#define OPAMP_CSR_PGGAIN_3   (0x8UL << OPAMP_CSR_PGGAIN_Pos)
#define OPAMP_CSR_USERTRIM_Pos   (18U)
#define OPAMP_CSR_USERTRIM_Msk   (0x1UL << OPAMP_CSR_USERTRIM_Pos)
#define OPAMP_CSR_USERTRIM   OPAMP_CSR_USERTRIM_Msk
#define OPAMP_CSR_TSTREF_Pos   (29U)
#define OPAMP_CSR_TSTREF_Msk   (0x1UL << OPAMP_CSR_TSTREF_Pos)
#define OPAMP_CSR_TSTREF   OPAMP_CSR_TSTREF_Msk
#define OPAMP_CSR_CALOUT_Pos   (30U)
#define OPAMP_CSR_CALOUT_Msk   (0x1UL << OPAMP_CSR_CALOUT_Pos)
#define OPAMP_CSR_CALOUT   OPAMP_CSR_CALOUT_Msk
#define OPAMP1_CSR_OPAEN_Pos   (0U)
#define OPAMP1_CSR_OPAEN_Msk   (0x1UL << OPAMP1_CSR_OPAEN_Pos)
#define OPAMP1_CSR_OPAEN   OPAMP1_CSR_OPAEN_Msk
#define OPAMP1_CSR_FORCEVP_Pos   (1U)
#define OPAMP1_CSR_FORCEVP_Msk   (0x1UL << OPAMP1_CSR_FORCEVP_Pos)
#define OPAMP1_CSR_FORCEVP   OPAMP1_CSR_FORCEVP_Msk
#define OPAMP1_CSR_VPSEL_Pos   (2U)
#define OPAMP1_CSR_VPSEL_Msk   (0x3UL << OPAMP1_CSR_VPSEL_Pos)
#define OPAMP1_CSR_VPSEL   OPAMP1_CSR_VPSEL_Msk
#define OPAMP1_CSR_VPSEL_0   (0x1UL << OPAMP1_CSR_VPSEL_Pos)
#define OPAMP1_CSR_VPSEL_1   (0x2UL << OPAMP1_CSR_VPSEL_Pos)
#define OPAMP1_CSR_VMSEL_Pos   (5U)
#define OPAMP1_CSR_VMSEL_Msk   (0x3UL << OPAMP1_CSR_VMSEL_Pos)
#define OPAMP1_CSR_VMSEL   OPAMP1_CSR_VMSEL_Msk
#define OPAMP1_CSR_VMSEL_0   (0x1UL << OPAMP1_CSR_VMSEL_Pos)
#define OPAMP1_CSR_VMSEL_1   (0x2UL << OPAMP1_CSR_VMSEL_Pos)
#define OPAMP1_CSR_OPAHSM_Pos   (8U)
#define OPAMP1_CSR_OPAHSM_Msk   (0x1UL << OPAMP1_CSR_OPAHSM_Pos)
#define OPAMP1_CSR_OPAHSM   OPAMP1_CSR_OPAHSM_Msk
#define OPAMP1_CSR_CALON_Pos   (11U)
#define OPAMP1_CSR_CALON_Msk   (0x1UL << OPAMP1_CSR_CALON_Pos)
#define OPAMP1_CSR_CALON   OPAMP1_CSR_CALON_Msk
#define OPAMP1_CSR_CALSEL_Pos   (12U)
#define OPAMP1_CSR_CALSEL_Msk   (0x3UL << OPAMP1_CSR_CALSEL_Pos)
#define OPAMP1_CSR_CALSEL   OPAMP1_CSR_CALSEL_Msk
#define OPAMP1_CSR_CALSEL_0   (0x1UL << OPAMP1_CSR_CALSEL_Pos)
#define OPAMP1_CSR_CALSEL_1   (0x2UL << OPAMP1_CSR_CALSEL_Pos)
#define OPAMP1_CSR_PGGAIN_Pos   (14U)
#define OPAMP1_CSR_PGGAIN_Msk   (0xFUL << OPAMP1_CSR_PGGAIN_Pos)
#define OPAMP1_CSR_PGGAIN   OPAMP1_CSR_PGGAIN_Msk
#define OPAMP1_CSR_PGGAIN_0   (0x1UL << OPAMP1_CSR_PGGAIN_Pos)
#define OPAMP1_CSR_PGGAIN_1   (0x2UL << OPAMP1_CSR_PGGAIN_Pos)
#define OPAMP1_CSR_PGGAIN_2   (0x4UL << OPAMP1_CSR_PGGAIN_Pos)
#define OPAMP1_CSR_PGGAIN_3   (0x8UL << OPAMP1_CSR_PGGAIN_Pos)
#define OPAMP1_CSR_USERTRIM_Pos   (18U)
#define OPAMP1_CSR_USERTRIM_Msk   (0x1UL << OPAMP1_CSR_USERTRIM_Pos)
#define OPAMP1_CSR_USERTRIM   OPAMP1_CSR_USERTRIM_Msk
#define OPAMP1_CSR_TSTREF_Pos   (29U)
#define OPAMP1_CSR_TSTREF_Msk   (0x1UL << OPAMP1_CSR_TSTREF_Pos)
#define OPAMP1_CSR_TSTREF   OPAMP1_CSR_TSTREF_Msk
#define OPAMP1_CSR_CALOUT_Pos   (30U)
#define OPAMP1_CSR_CALOUT_Msk   (0x1UL << OPAMP1_CSR_CALOUT_Pos)
#define OPAMP1_CSR_CALOUT   OPAMP1_CSR_CALOUT_Msk
#define OPAMP2_CSR_OPAEN_Pos   (0U)
#define OPAMP2_CSR_OPAEN_Msk   (0x1UL << OPAMP2_CSR_OPAEN_Pos)
#define OPAMP2_CSR_OPAEN   OPAMP2_CSR_OPAEN_Msk
#define OPAMP2_CSR_FORCEVP_Pos   (1U)
#define OPAMP2_CSR_FORCEVP_Msk   (0x1UL << OPAMP2_CSR_FORCEVP_Pos)
#define OPAMP2_CSR_FORCEVP   OPAMP2_CSR_FORCEVP_Msk
#define OPAMP2_CSR_VPSEL_Pos   (2U)
#define OPAMP2_CSR_VPSEL_Msk   (0x3UL << OPAMP2_CSR_VPSEL_Pos)
#define OPAMP2_CSR_VPSEL   OPAMP2_CSR_VPSEL_Msk
#define OPAMP2_CSR_VPSEL_0   (0x1UL << OPAMP2_CSR_VPSEL_Pos)
#define OPAMP2_CSR_VPSEL_1   (0x2UL << OPAMP2_CSR_VPSEL_Pos)
#define OPAMP2_CSR_VMSEL_Pos   (5U)
#define OPAMP2_CSR_VMSEL_Msk   (0x3UL << OPAMP2_CSR_VMSEL_Pos)
#define OPAMP2_CSR_VMSEL   OPAMP2_CSR_VMSEL_Msk
#define OPAMP2_CSR_VMSEL_0   (0x1UL << OPAMP2_CSR_VMSEL_Pos)
#define OPAMP2_CSR_VMSEL_1   (0x2UL << OPAMP2_CSR_VMSEL_Pos)
#define OPAMP2_CSR_OPAHSM_Pos   (8U)
#define OPAMP2_CSR_OPAHSM_Msk   (0x1UL << OPAMP2_CSR_OPAHSM_Pos)
#define OPAMP2_CSR_OPAHSM   OPAMP2_CSR_OPAHSM_Msk
#define OPAMP2_CSR_CALON_Pos   (11U)
#define OPAMP2_CSR_CALON_Msk   (0x1UL << OPAMP2_CSR_CALON_Pos)
#define OPAMP2_CSR_CALON   OPAMP2_CSR_CALON_Msk
#define OPAMP2_CSR_CALSEL_Pos   (12U)
#define OPAMP2_CSR_CALSEL_Msk   (0x3UL << OPAMP2_CSR_CALSEL_Pos)
#define OPAMP2_CSR_CALSEL   OPAMP2_CSR_CALSEL_Msk
#define OPAMP2_CSR_CALSEL_0   (0x1UL << OPAMP2_CSR_CALSEL_Pos)
#define OPAMP2_CSR_CALSEL_1   (0x2UL << OPAMP2_CSR_CALSEL_Pos)
#define OPAMP2_CSR_PGGAIN_Pos   (14U)
#define OPAMP2_CSR_PGGAIN_Msk   (0xFUL << OPAMP2_CSR_PGGAIN_Pos)
#define OPAMP2_CSR_PGGAIN   OPAMP2_CSR_PGGAIN_Msk
#define OPAMP2_CSR_PGGAIN_0   (0x1UL << OPAMP2_CSR_PGGAIN_Pos)
#define OPAMP2_CSR_PGGAIN_1   (0x2UL << OPAMP2_CSR_PGGAIN_Pos)
#define OPAMP2_CSR_PGGAIN_2   (0x4UL << OPAMP2_CSR_PGGAIN_Pos)
#define OPAMP2_CSR_PGGAIN_3   (0x8UL << OPAMP2_CSR_PGGAIN_Pos)
#define OPAMP2_CSR_USERTRIM_Pos   (18U)
#define OPAMP2_CSR_USERTRIM_Msk   (0x1UL << OPAMP2_CSR_USERTRIM_Pos)
#define OPAMP2_CSR_USERTRIM   OPAMP2_CSR_USERTRIM_Msk
#define OPAMP2_CSR_TSTREF_Pos   (29U)
#define OPAMP2_CSR_TSTREF_Msk   (0x1UL << OPAMP2_CSR_TSTREF_Pos)
#define OPAMP2_CSR_TSTREF   OPAMP2_CSR_TSTREF_Msk
#define OPAMP2_CSR_CALOUT_Pos   (30U)
#define OPAMP2_CSR_CALOUT_Msk   (0x1UL << OPAMP2_CSR_CALOUT_Pos)
#define OPAMP2_CSR_CALOUT   OPAMP2_CSR_CALOUT_Msk
#define OPAMP_OTR_TRIMOFFSETN_Pos   (0U)
#define OPAMP_OTR_TRIMOFFSETN_Msk   (0x1FUL << OPAMP_OTR_TRIMOFFSETN_Pos)
#define OPAMP_OTR_TRIMOFFSETN   OPAMP_OTR_TRIMOFFSETN_Msk
#define OPAMP_OTR_TRIMOFFSETP_Pos   (8U)
#define OPAMP_OTR_TRIMOFFSETP_Msk   (0x1FUL << OPAMP_OTR_TRIMOFFSETP_Pos)
#define OPAMP_OTR_TRIMOFFSETP   OPAMP_OTR_TRIMOFFSETP_Msk
#define OPAMP1_OTR_TRIMOFFSETN_Pos   (0U)
#define OPAMP1_OTR_TRIMOFFSETN_Msk   (0x1FUL << OPAMP1_OTR_TRIMOFFSETN_Pos)
#define OPAMP1_OTR_TRIMOFFSETN   OPAMP1_OTR_TRIMOFFSETN_Msk
#define OPAMP1_OTR_TRIMOFFSETP_Pos   (8U)
#define OPAMP1_OTR_TRIMOFFSETP_Msk   (0x1FUL << OPAMP1_OTR_TRIMOFFSETP_Pos)
#define OPAMP1_OTR_TRIMOFFSETP   OPAMP1_OTR_TRIMOFFSETP_Msk
#define OPAMP2_OTR_TRIMOFFSETN_Pos   (0U)
#define OPAMP2_OTR_TRIMOFFSETN_Msk   (0x1FUL << OPAMP2_OTR_TRIMOFFSETN_Pos)
#define OPAMP2_OTR_TRIMOFFSETN   OPAMP2_OTR_TRIMOFFSETN_Msk
#define OPAMP2_OTR_TRIMOFFSETP_Pos   (8U)
#define OPAMP2_OTR_TRIMOFFSETP_Msk   (0x1FUL << OPAMP2_OTR_TRIMOFFSETP_Pos)
#define OPAMP2_OTR_TRIMOFFSETP   OPAMP2_OTR_TRIMOFFSETP_Msk
#define OPAMP_HSOTR_TRIMHSOFFSETN_Pos   (0U)
#define OPAMP_HSOTR_TRIMHSOFFSETN_Msk   (0x1FUL << OPAMP_HSOTR_TRIMHSOFFSETN_Pos)
#define OPAMP_HSOTR_TRIMHSOFFSETN   OPAMP_HSOTR_TRIMHSOFFSETN_Msk
#define OPAMP_HSOTR_TRIMHSOFFSETP_Pos   (8U)
#define OPAMP_HSOTR_TRIMHSOFFSETP_Msk   (0x1FUL << OPAMP_HSOTR_TRIMHSOFFSETP_Pos)
#define OPAMP_HSOTR_TRIMHSOFFSETP   OPAMP_HSOTR_TRIMHSOFFSETP_Msk
#define OPAMP1_HSOTR_TRIMHSOFFSETN_Pos   (0U)
#define OPAMP1_HSOTR_TRIMHSOFFSETN_Msk   (0x1FUL << OPAMP1_HSOTR_TRIMHSOFFSETN_Pos)
#define OPAMP1_HSOTR_TRIMHSOFFSETN   OPAMP1_HSOTR_TRIMHSOFFSETN_Msk
#define OPAMP1_HSOTR_TRIMHSOFFSETP_Pos   (8U)
#define OPAMP1_HSOTR_TRIMHSOFFSETP_Msk   (0x1FUL << OPAMP1_HSOTR_TRIMHSOFFSETP_Pos)
#define OPAMP1_HSOTR_TRIMHSOFFSETP   OPAMP1_HSOTR_TRIMHSOFFSETP_Msk
#define OPAMP2_HSOTR_TRIMHSOFFSETN_Pos   (0U)
#define OPAMP2_HSOTR_TRIMHSOFFSETN_Msk   (0x1FUL << OPAMP2_HSOTR_TRIMHSOFFSETN_Pos)
#define OPAMP2_HSOTR_TRIMHSOFFSETN   OPAMP2_HSOTR_TRIMHSOFFSETN_Msk
#define OPAMP2_HSOTR_TRIMHSOFFSETP_Pos   (8U)
#define OPAMP2_HSOTR_TRIMHSOFFSETP_Msk   (0x1FUL << OPAMP2_HSOTR_TRIMHSOFFSETP_Pos)
#define OPAMP2_HSOTR_TRIMHSOFFSETP   OPAMP2_HSOTR_TRIMHSOFFSETP_Msk
#define PSSI_CR_OUTEN_Pos   (31U)
#define PSSI_CR_OUTEN_Msk   (0x1UL << PSSI_CR_OUTEN_Pos)
#define PSSI_CR_OUTEN   PSSI_CR_OUTEN_Msk
#define PSSI_CR_DMAEN_Pos   (30U)
#define PSSI_CR_DMAEN_Msk   (0x1UL << PSSI_CR_DMAEN_Pos)
#define PSSI_CR_DMAEN   PSSI_CR_DMAEN_Msk
#define PSSI_CR_DERDYCFG_Pos   (18U)
#define PSSI_CR_DERDYCFG_Msk   (0x7UL << PSSI_CR_DERDYCFG_Pos)
#define PSSI_CR_DERDYCFG   PSSI_CR_DERDYCFG_Msk
#define PSSI_CR_ENABLE_Pos   (14U)
#define PSSI_CR_ENABLE_Msk   (0x1UL << PSSI_CR_ENABLE_Pos)
#define PSSI_CR_ENABLE   PSSI_CR_ENABLE_Msk
#define PSSI_CR_EDM_Pos   (10U)
#define PSSI_CR_EDM_Msk   (0x3UL << PSSI_CR_EDM_Pos)
#define PSSI_CR_EDM   PSSI_CR_EDM_Msk
#define PSSI_CR_RDYPOL_Pos   (8U)
#define PSSI_CR_RDYPOL_Msk   (0x1UL << PSSI_CR_RDYPOL_Pos)
#define PSSI_CR_RDYPOL   PSSI_CR_RDYPOL_Msk
#define PSSI_CR_DEPOL_Pos   (6U)
#define PSSI_CR_DEPOL_Msk   (0x1UL << PSSI_CR_DEPOL_Pos)
#define PSSI_CR_DEPOL   PSSI_CR_DEPOL_Msk
#define PSSI_CR_CKPOL_Pos   (5U)
#define PSSI_CR_CKPOL_Msk   (0x1UL << PSSI_CR_CKPOL_Pos)
#define PSSI_CR_CKPOL   PSSI_CR_CKPOL_Msk
#define PSSI_SR_RTT1B_Pos   (3U)
#define PSSI_SR_RTT1B_Msk   (0x1UL << PSSI_SR_RTT1B_Pos)
#define PSSI_SR_RTT1B   PSSI_SR_RTT1B_Msk
#define PSSI_SR_RTT4B_Pos   (2U)
#define PSSI_SR_RTT4B_Msk   (0x1UL << PSSI_SR_RTT4B_Pos)
#define PSSI_SR_RTT4B   PSSI_SR_RTT4B_Msk
#define PSSI_RIS_OVR_RIS_Pos   (1U)
#define PSSI_RIS_OVR_RIS_Msk   (0x1UL << PSSI_RIS_OVR_RIS_Pos)
#define PSSI_RIS_OVR_RIS   PSSI_RIS_OVR_RIS_Msk
#define PSSI_IER_OVR_IE_Pos   (1U)
#define PSSI_IER_OVR_IE_Msk   (0x1UL << PSSI_IER_OVR_IE_Pos)
#define PSSI_IER_OVR_IE   PSSI_IER_OVR_IE_Msk
#define PSSI_MIS_OVR_MIS_Pos   (1U)
#define PSSI_MIS_OVR_MIS_Msk   (0x1UL << PSSI_MIS_OVR_MIS_Pos)
#define PSSI_MIS_OVR_MIS   PSSI_MIS_OVR_MIS_Msk
#define PSSI_ICR_OVR_ISC_Pos   (1U)
#define PSSI_ICR_OVR_ISC_Msk   (0x1UL << PSSI_ICR_OVR_ISC_Pos)
#define PSSI_ICR_OVR_ISC   PSSI_ICR_OVR_ISC_Msk
#define PSSI_DR_DR_Pos   (0U)
#define PSSI_DR_DR_Msk   (0xFFFFFFFFUL << PSSI_DR_DR_Pos)
#define PSSI_DR_DR   PSSI_DR_DR_Msk
#define POWER_DOMAINS_NUMBER   2U
#define PWR_CR1_SRDRAMSO_Pos   (27U)
#define PWR_CR1_SRDRAMSO_Msk   (0x1UL << PWR_CR1_SRDRAMSO_Pos)
#define PWR_CR1_SRDRAMSO   PWR_CR1_SRDRAMSO_Msk
#define PWR_CR1_HSITFSO_Pos   (26U)
#define PWR_CR1_HSITFSO_Msk   (0x1UL << PWR_CR1_HSITFSO_Pos)
#define PWR_CR1_HSITFSO   PWR_CR1_HSITFSO_Msk
#define PWR_CR1_GFXSO_Pos   (25U)
#define PWR_CR1_GFXSO_Msk   (0x1UL << PWR_CR1_GFXSO_Pos)
#define PWR_CR1_GFXSO   PWR_CR1_GFXSO_Msk
#define PWR_CR1_ITCMSO_Pos   (24U)
#define PWR_CR1_ITCMSO_Msk   (0x1UL << PWR_CR1_ITCMSO_Pos)
#define PWR_CR1_ITCMSO   PWR_CR1_ITCMSO_Msk
#define PWR_CR1_AHBRAM2SO_Pos   (23U)
#define PWR_CR1_AHBRAM2SO_Msk   (0x1UL << PWR_CR1_AHBRAM2SO_Pos)
#define PWR_CR1_AHBRAM2SO   PWR_CR1_AHBRAM2SO_Msk
#define PWR_CR1_AHBRAM1SO_Pos   (22U)
#define PWR_CR1_AHBRAM1SO_Msk   (0x1UL << PWR_CR1_AHBRAM1SO_Pos)
#define PWR_CR1_AHBRAM1SO   PWR_CR1_AHBRAM1SO_Msk
#define PWR_CR1_AXIRAM3SO_Pos   (21U)
#define PWR_CR1_AXIRAM3SO_Msk   (0x1UL << PWR_CR1_AXIRAM3SO_Pos)
#define PWR_CR1_AXIRAM3SO   PWR_CR1_AXIRAM3SO_Msk
#define PWR_CR1_AXIRAM2SO_Pos   (20U)
#define PWR_CR1_AXIRAM2SO_Msk   (0x1UL << PWR_CR1_AXIRAM2SO_Pos)
#define PWR_CR1_AXIRAM2SO   PWR_CR1_AXIRAM2SO_Msk
#define PWR_CR1_AXIRAM1SO_Pos   (19U)
#define PWR_CR1_AXIRAM1SO_Msk   (0x1UL << PWR_CR1_AXIRAM1SO_Pos)
#define PWR_CR1_AXIRAM1SO   PWR_CR1_AXIRAM1SO_Msk
#define PWR_CR1_ALS_Pos   (17U)
#define PWR_CR1_ALS_Msk   (0x3UL << PWR_CR1_ALS_Pos)
#define PWR_CR1_ALS   PWR_CR1_ALS_Msk
#define PWR_CR1_ALS_0   (0x1UL << PWR_CR1_ALS_Pos)
#define PWR_CR1_ALS_1   (0x2UL << PWR_CR1_ALS_Pos)
#define PWR_CR1_AVDEN_Pos   (16U)
#define PWR_CR1_AVDEN_Msk   (0x1UL << PWR_CR1_AVDEN_Pos)
#define PWR_CR1_AVDEN   PWR_CR1_AVDEN_Msk
#define PWR_CR1_SVOS_Pos   (14U)
#define PWR_CR1_SVOS_Msk   (0x3UL << PWR_CR1_SVOS_Pos)
#define PWR_CR1_SVOS   PWR_CR1_SVOS_Msk
#define PWR_CR1_SVOS_0   (0x1UL << PWR_CR1_SVOS_Pos)
#define PWR_CR1_SVOS_1   (0x2UL << PWR_CR1_SVOS_Pos)
#define PWR_CR1_AVD_READY_Pos   (13U)
#define PWR_CR1_AVD_READY_Msk   (0x1UL << PWR_CR1_AVD_READY_Pos)
#define PWR_CR1_AVD_READY   PWR_CR1_AVD_READY_Msk
#define PWR_CR1_BOOSTE_Pos   (12U)
#define PWR_CR1_BOOSTE_Msk   (0x1UL << PWR_CR1_BOOSTE_Pos)
#define PWR_CR1_BOOSTE   PWR_CR1_BOOSTE_Msk
#define PWR_CR1_FLPS_Pos   (9U)
#define PWR_CR1_FLPS_Msk   (0x1UL << PWR_CR1_FLPS_Pos)
#define PWR_CR1_FLPS   PWR_CR1_FLPS_Msk
#define PWR_CR1_DBP_Pos   (8U)
#define PWR_CR1_DBP_Msk   (0x1UL << PWR_CR1_DBP_Pos)
#define PWR_CR1_DBP   PWR_CR1_DBP_Msk
#define PWR_CR1_PLS_Pos   (5U)
#define PWR_CR1_PLS_Msk   (0x7UL << PWR_CR1_PLS_Pos)
#define PWR_CR1_PLS   PWR_CR1_PLS_Msk
#define PWR_CR1_PLS_0   (0x1UL << PWR_CR1_PLS_Pos)
#define PWR_CR1_PLS_1   (0x2UL << PWR_CR1_PLS_Pos)
#define PWR_CR1_PLS_2   (0x4UL << PWR_CR1_PLS_Pos)
#define PWR_CR1_PVDEN_Pos   (4U)
#define PWR_CR1_PVDEN_Msk   (0x1UL << PWR_CR1_PVDEN_Pos)
#define PWR_CR1_PVDEN   PWR_CR1_PVDEN_Msk
#define PWR_CR1_LPDS_Pos   (0U)
#define PWR_CR1_LPDS_Msk   (0x1UL << PWR_CR1_LPDS_Pos)
#define PWR_CR1_LPDS   PWR_CR1_LPDS_Msk
#define PWR_CR1_PLS_LEV0   (0UL)
#define PWR_CR1_PLS_LEV1_Pos   (5U)
#define PWR_CR1_PLS_LEV1_Msk   (0x1UL << PWR_CR1_PLS_LEV1_Pos)
#define PWR_CR1_PLS_LEV1   PWR_CR1_PLS_LEV1_Msk
#define PWR_CR1_PLS_LEV2_Pos   (6U)
#define PWR_CR1_PLS_LEV2_Msk   (0x1UL << PWR_CR1_PLS_LEV2_Pos)
#define PWR_CR1_PLS_LEV2   PWR_CR1_PLS_LEV2_Msk
#define PWR_CR1_PLS_LEV3_Pos   (5U)
#define PWR_CR1_PLS_LEV3_Msk   (0x3UL << PWR_CR1_PLS_LEV3_Pos)
#define PWR_CR1_PLS_LEV3   PWR_CR1_PLS_LEV3_Msk
#define PWR_CR1_PLS_LEV4_Pos   (7U)
#define PWR_CR1_PLS_LEV4_Msk   (0x1UL << PWR_CR1_PLS_LEV4_Pos)
#define PWR_CR1_PLS_LEV4   PWR_CR1_PLS_LEV4_Msk
#define PWR_CR1_PLS_LEV5_Pos   (5U)
#define PWR_CR1_PLS_LEV5_Msk   (0x5UL << PWR_CR1_PLS_LEV5_Pos)
#define PWR_CR1_PLS_LEV5   PWR_CR1_PLS_LEV5_Msk
#define PWR_CR1_PLS_LEV6_Pos   (6U)
#define PWR_CR1_PLS_LEV6_Msk   (0x3UL << PWR_CR1_PLS_LEV6_Pos)
#define PWR_CR1_PLS_LEV6   PWR_CR1_PLS_LEV6_Msk
#define PWR_CR1_PLS_LEV7_Pos   (5U)
#define PWR_CR1_PLS_LEV7_Msk   (0x7UL << PWR_CR1_PLS_LEV7_Pos)
#define PWR_CR1_PLS_LEV7   PWR_CR1_PLS_LEV7_Msk
#define PWR_CR1_ALS_LEV0   (0UL)
#define PWR_CR1_ALS_LEV1_Pos   (17U)
#define PWR_CR1_ALS_LEV1_Msk   (0x1UL << PWR_CR1_ALS_LEV1_Pos)
#define PWR_CR1_ALS_LEV1   PWR_CR1_ALS_LEV1_Msk
#define PWR_CR1_ALS_LEV2_Pos   (18U)
#define PWR_CR1_ALS_LEV2_Msk   (0x1UL << PWR_CR1_ALS_LEV2_Pos)
#define PWR_CR1_ALS_LEV2   PWR_CR1_ALS_LEV2_Msk
#define PWR_CR1_ALS_LEV3_Pos   (17U)
#define PWR_CR1_ALS_LEV3_Msk   (0x3UL << PWR_CR1_ALS_LEV3_Pos)
#define PWR_CR1_ALS_LEV3   PWR_CR1_ALS_LEV3_Msk
#define PWR_CSR1_MMCVDO_Pos   (17U)
#define PWR_CSR1_MMCVDO_Msk   (0x1UL << PWR_CSR1_MMCVDO_Pos)
#define PWR_CSR1_MMCVDO   PWR_CSR1_MMCVDO_Msk
#define PWR_CSR1_AVDO_Pos   (16U)
#define PWR_CSR1_AVDO_Msk   (0x1UL << PWR_CSR1_AVDO_Pos)
#define PWR_CSR1_AVDO   PWR_CSR1_AVDO_Msk
#define PWR_CSR1_ACTVOS_Pos   (14U)
#define PWR_CSR1_ACTVOS_Msk   (0x3UL << PWR_CSR1_ACTVOS_Pos)
#define PWR_CSR1_ACTVOS   PWR_CSR1_ACTVOS_Msk
#define PWR_CSR1_ACTVOS_0   (0x1UL << PWR_CSR1_ACTVOS_Pos)
#define PWR_CSR1_ACTVOS_1   (0x2UL << PWR_CSR1_ACTVOS_Pos)
#define PWR_CSR1_ACTVOSRDY_Pos   (13U)
#define PWR_CSR1_ACTVOSRDY_Msk   (0x1UL << PWR_CSR1_ACTVOSRDY_Pos)
#define PWR_CSR1_ACTVOSRDY   PWR_CSR1_ACTVOSRDY_Msk
#define PWR_CSR1_PVDO_Pos   (4U)
#define PWR_CSR1_PVDO_Msk   (0x1UL << PWR_CSR1_PVDO_Pos)
#define PWR_CSR1_PVDO   PWR_CSR1_PVDO_Msk
#define PWR_CR2_TEMPH_Pos   (23U)
#define PWR_CR2_TEMPH_Msk   (0x1UL << PWR_CR2_TEMPH_Pos)
#define PWR_CR2_TEMPH   PWR_CR2_TEMPH_Msk
#define PWR_CR2_TEMPL_Pos   (22U)
#define PWR_CR2_TEMPL_Msk   (0x1UL << PWR_CR2_TEMPL_Pos)
#define PWR_CR2_TEMPL   PWR_CR2_TEMPL_Msk
#define PWR_CR2_VBATH_Pos   (21U)
#define PWR_CR2_VBATH_Msk   (0x1UL << PWR_CR2_VBATH_Pos)
#define PWR_CR2_VBATH   PWR_CR2_VBATH_Msk
#define PWR_CR2_VBATL_Pos   (20U)
#define PWR_CR2_VBATL_Msk   (0x1UL << PWR_CR2_VBATL_Pos)
#define PWR_CR2_VBATL   PWR_CR2_VBATL_Msk
#define PWR_CR2_BRRDY_Pos   (16U)
#define PWR_CR2_BRRDY_Msk   (0x1UL << PWR_CR2_BRRDY_Pos)
#define PWR_CR2_BRRDY   PWR_CR2_BRRDY_Msk
#define PWR_CR2_MONEN_Pos   (4U)
#define PWR_CR2_MONEN_Msk   (0x1UL << PWR_CR2_MONEN_Pos)
#define PWR_CR2_MONEN   PWR_CR2_MONEN_Msk
#define PWR_CR2_BREN_Pos   (0U)
#define PWR_CR2_BREN_Msk   (0x1UL << PWR_CR2_BREN_Pos)
#define PWR_CR2_BREN   PWR_CR2_BREN_Msk
#define PWR_CR3_USB33RDY_Pos   (26U)
#define PWR_CR3_USB33RDY_Msk   (0x1UL << PWR_CR3_USB33RDY_Pos)
#define PWR_CR3_USB33RDY   PWR_CR3_USB33RDY_Msk
#define PWR_CR3_USBREGEN_Pos   (25U)
#define PWR_CR3_USBREGEN_Msk   (0x1UL << PWR_CR3_USBREGEN_Pos)
#define PWR_CR3_USBREGEN   PWR_CR3_USBREGEN_Msk
#define PWR_CR3_USB33DEN_Pos   (24U)
#define PWR_CR3_USB33DEN_Msk   (0x1UL << PWR_CR3_USB33DEN_Pos)
#define PWR_CR3_USB33DEN   PWR_CR3_USB33DEN_Msk
#define PWR_CR3_VBRS_Pos   (9U)
#define PWR_CR3_VBRS_Msk   (0x1UL << PWR_CR3_VBRS_Pos)
#define PWR_CR3_VBRS   PWR_CR3_VBRS_Msk
#define PWR_CR3_VBE_Pos   (8U)
#define PWR_CR3_VBE_Msk   (0x1UL << PWR_CR3_VBE_Pos)
#define PWR_CR3_VBE   PWR_CR3_VBE_Msk
#define PWR_CR3_SCUEN_Pos   (2U)
#define PWR_CR3_SCUEN_Msk   (0x1UL << PWR_CR3_SCUEN_Pos)
#define PWR_CR3_SCUEN   PWR_CR3_SCUEN_Msk
#define PWR_CR3_LDOEN_Pos   (1U)
#define PWR_CR3_LDOEN_Msk   (0x1UL << PWR_CR3_LDOEN_Pos)
#define PWR_CR3_LDOEN   PWR_CR3_LDOEN_Msk
#define PWR_CR3_BYPASS_Pos   (0U)
#define PWR_CR3_BYPASS_Msk   (0x1UL << PWR_CR3_BYPASS_Pos)
#define PWR_CR3_BYPASS   PWR_CR3_BYPASS_Msk
#define PWR_CPUCR_RUN_SRD_Pos   (11U)
#define PWR_CPUCR_RUN_SRD_Msk   (0x1UL << PWR_CPUCR_RUN_SRD_Pos)
#define PWR_CPUCR_RUN_SRD   PWR_CPUCR_RUN_SRD_Msk
#define PWR_CPUCR_CSSF_Pos   (9U)
#define PWR_CPUCR_CSSF_Msk   (0x1UL << PWR_CPUCR_CSSF_Pos)
#define PWR_CPUCR_CSSF   PWR_CPUCR_CSSF_Msk
#define PWR_CPUCR_SBF_Pos   (6U)
#define PWR_CPUCR_SBF_Msk   (0x1UL << PWR_CPUCR_SBF_Pos)
#define PWR_CPUCR_SBF   PWR_CPUCR_SBF_Msk
#define PWR_CPUCR_STOPF_Pos   (5U)
#define PWR_CPUCR_STOPF_Msk   (0x1UL << PWR_CPUCR_STOPF_Pos)
#define PWR_CPUCR_STOPF   PWR_CPUCR_STOPF_Msk
#define PWR_CPUCR_PDDS_SRD_Pos   (2U)
#define PWR_CPUCR_PDDS_SRD_Msk   (0x1UL << PWR_CPUCR_PDDS_SRD_Pos)
#define PWR_CPUCR_PDDS_SRD   PWR_CPUCR_PDDS_SRD_Msk
#define PWR_CPUCR_RETDS_CD_Pos   (0U)
#define PWR_CPUCR_RETDS_CD_Msk   (0x1UL << PWR_CPUCR_RETDS_CD_Pos)
#define PWR_CPUCR_RETDS_CD   PWR_CPUCR_RETDS_CD_Msk
#define PWR_SRDCR_VOS_Pos   (14U)
#define PWR_SRDCR_VOS_Msk   (0x3UL << PWR_SRDCR_VOS_Pos)
#define PWR_SRDCR_VOS   PWR_SRDCR_VOS_Msk
#define PWR_SRDCR_VOS_0   (0x1UL << PWR_SRDCR_VOS_Pos)
#define PWR_SRDCR_VOS_1   (0x2UL << PWR_SRDCR_VOS_Pos)
#define PWR_SRDCR_VOSRDY_Pos   (13U)
#define PWR_SRDCR_VOSRDY_Msk   (0x1UL << PWR_SRDCR_VOSRDY_Pos)
#define PWR_SRDCR_VOSRDY   PWR_SRDCR_VOSRDY_Msk
#define PWR_WKUPCR_WKUPC6_Pos   (5U)
#define PWR_WKUPCR_WKUPC6_Msk   (0x1UL << PWR_WKUPCR_WKUPC6_Pos)
#define PWR_WKUPCR_WKUPC6   PWR_WKUPCR_WKUPC6_Msk
#define PWR_WKUPCR_WKUPC5_Pos   (4U)
#define PWR_WKUPCR_WKUPC5_Msk   (0x1UL << PWR_WKUPCR_WKUPC5_Pos)
#define PWR_WKUPCR_WKUPC5   PWR_WKUPCR_WKUPC5_Msk
#define PWR_WKUPCR_WKUPC4_Pos   (3U)
#define PWR_WKUPCR_WKUPC4_Msk   (0x1UL << PWR_WKUPCR_WKUPC4_Pos)
#define PWR_WKUPCR_WKUPC4   PWR_WKUPCR_WKUPC4_Msk
#define PWR_WKUPCR_WKUPC3_Pos   (2U)
#define PWR_WKUPCR_WKUPC3_Msk   (0x1UL << PWR_WKUPCR_WKUPC3_Pos)
#define PWR_WKUPCR_WKUPC3   PWR_WKUPCR_WKUPC3_Msk
#define PWR_WKUPCR_WKUPC2_Pos   (1U)
#define PWR_WKUPCR_WKUPC2_Msk   (0x1UL << PWR_WKUPCR_WKUPC2_Pos)
#define PWR_WKUPCR_WKUPC2   PWR_WKUPCR_WKUPC2_Msk
#define PWR_WKUPCR_WKUPC1_Pos   (0U)
#define PWR_WKUPCR_WKUPC1_Msk   (0x1UL << PWR_WKUPCR_WKUPC1_Pos)
#define PWR_WKUPCR_WKUPC1   PWR_WKUPCR_WKUPC1_Msk
#define PWR_WKUPFR_WKUPF6_Pos   (5U)
#define PWR_WKUPFR_WKUPF6_Msk   (0x1UL << PWR_WKUPFR_WKUPF6_Pos)
#define PWR_WKUPFR_WKUPF6   PWR_WKUPFR_WKUPF6_Msk
#define PWR_WKUPFR_WKUPF5_Pos   (4U)
#define PWR_WKUPFR_WKUPF5_Msk   (0x1UL << PWR_WKUPFR_WKUPF5_Pos)
#define PWR_WKUPFR_WKUPF5   PWR_WKUPFR_WKUPF5_Msk
#define PWR_WKUPFR_WKUPF4_Pos   (3U)
#define PWR_WKUPFR_WKUPF4_Msk   (0x1UL << PWR_WKUPFR_WKUPF4_Pos)
#define PWR_WKUPFR_WKUPF4   PWR_WKUPFR_WKUPF4_Msk
#define PWR_WKUPFR_WKUPF3_Pos   (2U)
#define PWR_WKUPFR_WKUPF3_Msk   (0x1UL << PWR_WKUPFR_WKUPF3_Pos)
#define PWR_WKUPFR_WKUPF3   PWR_WKUPFR_WKUPF3_Msk
#define PWR_WKUPFR_WKUPF2_Pos   (1U)
#define PWR_WKUPFR_WKUPF2_Msk   (0x1UL << PWR_WKUPFR_WKUPF2_Pos)
#define PWR_WKUPFR_WKUPF2   PWR_WKUPFR_WKUPF2_Msk
#define PWR_WKUPFR_WKUPF1_Pos   (0U)
#define PWR_WKUPFR_WKUPF1_Msk   (0x1UL << PWR_WKUPFR_WKUPF1_Pos)
#define PWR_WKUPFR_WKUPF1   PWR_WKUPFR_WKUPF1_Msk
#define PWR_WKUPEPR_WKUPPUPD6_Pos   (26U)
#define PWR_WKUPEPR_WKUPPUPD6_Msk   (0x3UL << PWR_WKUPEPR_WKUPPUPD6_Pos)
#define PWR_WKUPEPR_WKUPPUPD6   PWR_WKUPEPR_WKUPPUPD6_Msk
#define PWR_WKUPEPR_WKUPPUPD6_0   (0x1UL << PWR_WKUPEPR_WKUPPUPD6_Pos)
#define PWR_WKUPEPR_WKUPPUPD6_1   (0x2UL << PWR_WKUPEPR_WKUPPUPD6_Pos)
#define PWR_WKUPEPR_WKUPPUPD5_Pos   (24U)
#define PWR_WKUPEPR_WKUPPUPD5_Msk   (0x3UL << PWR_WKUPEPR_WKUPPUPD5_Pos)
#define PWR_WKUPEPR_WKUPPUPD5   PWR_WKUPEPR_WKUPPUPD5_Msk
#define PWR_WKUPEPR_WKUPPUPD5_0   (0x1UL << PWR_WKUPEPR_WKUPPUPD5_Pos)
#define PWR_WKUPEPR_WKUPPUPD5_1   (0x2UL << PWR_WKUPEPR_WKUPPUPD5_Pos)
#define PWR_WKUPEPR_WKUPPUPD4_Pos   (22U)
#define PWR_WKUPEPR_WKUPPUPD4_Msk   (0x3UL << PWR_WKUPEPR_WKUPPUPD4_Pos)
#define PWR_WKUPEPR_WKUPPUPD4   PWR_WKUPEPR_WKUPPUPD4_Msk
#define PWR_WKUPEPR_WKUPPUPD4_0   (0x1UL << PWR_WKUPEPR_WKUPPUPD4_Pos)
#define PWR_WKUPEPR_WKUPPUPD4_1   (0x2UL << PWR_WKUPEPR_WKUPPUPD4_Pos)
#define PWR_WKUPEPR_WKUPPUPD3_Pos   (20U)
#define PWR_WKUPEPR_WKUPPUPD3_Msk   (0x3UL << PWR_WKUPEPR_WKUPPUPD3_Pos)
#define PWR_WKUPEPR_WKUPPUPD3   PWR_WKUPEPR_WKUPPUPD3_Msk
#define PWR_WKUPEPR_WKUPPUPD3_0   (0x1UL << PWR_WKUPEPR_WKUPPUPD3_Pos)
#define PWR_WKUPEPR_WKUPPUPD3_1   (0x2UL << PWR_WKUPEPR_WKUPPUPD3_Pos)
#define PWR_WKUPEPR_WKUPPUPD2_Pos   (18U)
#define PWR_WKUPEPR_WKUPPUPD2_Msk   (0x3UL << PWR_WKUPEPR_WKUPPUPD2_Pos)
#define PWR_WKUPEPR_WKUPPUPD2   PWR_WKUPEPR_WKUPPUPD2_Msk
#define PWR_WKUPEPR_WKUPPUPD2_0   (0x1UL << PWR_WKUPEPR_WKUPPUPD2_Pos)
#define PWR_WKUPEPR_WKUPPUPD2_1   (0x2UL << PWR_WKUPEPR_WKUPPUPD2_Pos)
#define PWR_WKUPEPR_WKUPPUPD1_Pos   (16U)
#define PWR_WKUPEPR_WKUPPUPD1_Msk   (0x3UL << PWR_WKUPEPR_WKUPPUPD1_Pos)
#define PWR_WKUPEPR_WKUPPUPD1   PWR_WKUPEPR_WKUPPUPD1_Msk
#define PWR_WKUPEPR_WKUPPUPD1_0   (0x1UL << PWR_WKUPEPR_WKUPPUPD1_Pos)
#define PWR_WKUPEPR_WKUPPUPD1_1   (0x2UL << PWR_WKUPEPR_WKUPPUPD1_Pos)
#define PWR_WKUPEPR_WKUPP6_Pos   (13U)
#define PWR_WKUPEPR_WKUPP6_Msk   (0x1UL << PWR_WKUPEPR_WKUPP6_Pos)
#define PWR_WKUPEPR_WKUPP6   PWR_WKUPEPR_WKUPP6_Msk
#define PWR_WKUPEPR_WKUPP5_Pos   (12U)
#define PWR_WKUPEPR_WKUPP5_Msk   (0x1UL << PWR_WKUPEPR_WKUPP5_Pos)
#define PWR_WKUPEPR_WKUPP5   PWR_WKUPEPR_WKUPP5_Msk
#define PWR_WKUPEPR_WKUPP4_Pos   (11U)
#define PWR_WKUPEPR_WKUPP4_Msk   (0x1UL << PWR_WKUPEPR_WKUPP4_Pos)
#define PWR_WKUPEPR_WKUPP4   PWR_WKUPEPR_WKUPP4_Msk
#define PWR_WKUPEPR_WKUPP3_Pos   (10U)
#define PWR_WKUPEPR_WKUPP3_Msk   (0x1UL << PWR_WKUPEPR_WKUPP3_Pos)
#define PWR_WKUPEPR_WKUPP3   PWR_WKUPEPR_WKUPP3_Msk
#define PWR_WKUPEPR_WKUPP2_Pos   (9U)
#define PWR_WKUPEPR_WKUPP2_Msk   (0x1UL << PWR_WKUPEPR_WKUPP2_Pos)
#define PWR_WKUPEPR_WKUPP2   PWR_WKUPEPR_WKUPP2_Msk
#define PWR_WKUPEPR_WKUPP1_Pos   (8U)
#define PWR_WKUPEPR_WKUPP1_Msk   (0x1UL << PWR_WKUPEPR_WKUPP1_Pos)
#define PWR_WKUPEPR_WKUPP1   PWR_WKUPEPR_WKUPP1_Msk
#define PWR_WKUPEPR_WKUPEN6_Pos   (5U)
#define PWR_WKUPEPR_WKUPEN6_Msk   (0x1UL << PWR_WKUPEPR_WKUPEN6_Pos)
#define PWR_WKUPEPR_WKUPEN6   PWR_WKUPEPR_WKUPEN6_Msk
#define PWR_WKUPEPR_WKUPEN5_Pos   (4U)
#define PWR_WKUPEPR_WKUPEN5_Msk   (0x1UL << PWR_WKUPEPR_WKUPEN5_Pos)
#define PWR_WKUPEPR_WKUPEN5   PWR_WKUPEPR_WKUPEN5_Msk
#define PWR_WKUPEPR_WKUPEN4_Pos   (3U)
#define PWR_WKUPEPR_WKUPEN4_Msk   (0x1UL << PWR_WKUPEPR_WKUPEN4_Pos)
#define PWR_WKUPEPR_WKUPEN4   PWR_WKUPEPR_WKUPEN4_Msk
#define PWR_WKUPEPR_WKUPEN3_Pos   (2U)
#define PWR_WKUPEPR_WKUPEN3_Msk   (0x1UL << PWR_WKUPEPR_WKUPEN3_Pos)
#define PWR_WKUPEPR_WKUPEN3   PWR_WKUPEPR_WKUPEN3_Msk
#define PWR_WKUPEPR_WKUPEN2_Pos   (1U)
#define PWR_WKUPEPR_WKUPEN2_Msk   (0x1UL << PWR_WKUPEPR_WKUPEN2_Pos)
#define PWR_WKUPEPR_WKUPEN2   PWR_WKUPEPR_WKUPEN2_Msk
#define PWR_WKUPEPR_WKUPEN1_Pos   (0U)
#define PWR_WKUPEPR_WKUPEN1_Msk   (0x1UL << PWR_WKUPEPR_WKUPEN1_Pos)
#define PWR_WKUPEPR_WKUPEN1   PWR_WKUPEPR_WKUPEN1_Msk
#define PWR_WKUPEPR_WKUPEN_Pos   (0U)
#define PWR_WKUPEPR_WKUPEN_Msk   (0x3FUL << PWR_WKUPEPR_WKUPEN_Pos)
#define PWR_WKUPEPR_WKUPEN   PWR_WKUPEPR_WKUPEN_Msk
#define RCC_VER_2_0
#define RCC_CR_HSION_Pos   (0U)
#define RCC_CR_HSION_Msk   (0x1UL << RCC_CR_HSION_Pos)
#define RCC_CR_HSION   RCC_CR_HSION_Msk
#define RCC_CR_HSIKERON_Pos   (1U)
#define RCC_CR_HSIKERON_Msk   (0x1UL << RCC_CR_HSIKERON_Pos)
#define RCC_CR_HSIKERON   RCC_CR_HSIKERON_Msk
#define RCC_CR_HSIRDY_Pos   (2U)
#define RCC_CR_HSIRDY_Msk   (0x1UL << RCC_CR_HSIRDY_Pos)
#define RCC_CR_HSIRDY   RCC_CR_HSIRDY_Msk
#define RCC_CR_HSIDIV_Pos   (3U)
#define RCC_CR_HSIDIV_Msk   (0x3UL << RCC_CR_HSIDIV_Pos)
#define RCC_CR_HSIDIV   RCC_CR_HSIDIV_Msk
#define RCC_CR_HSIDIV_1   (0x0UL << RCC_CR_HSIDIV_Pos)
#define RCC_CR_HSIDIV_2   (0x1UL << RCC_CR_HSIDIV_Pos)
#define RCC_CR_HSIDIV_4   (0x2UL << RCC_CR_HSIDIV_Pos)
#define RCC_CR_HSIDIV_8   (0x3UL << RCC_CR_HSIDIV_Pos)
#define RCC_CR_HSIDIVF_Pos   (5U)
#define RCC_CR_HSIDIVF_Msk   (0x1UL << RCC_CR_HSIDIVF_Pos)
#define RCC_CR_HSIDIVF   RCC_CR_HSIDIVF_Msk
#define RCC_CR_CSION_Pos   (7U)
#define RCC_CR_CSION_Msk   (0x1UL << RCC_CR_CSION_Pos)
#define RCC_CR_CSION   RCC_CR_CSION_Msk
#define RCC_CR_CSIRDY_Pos   (8U)
#define RCC_CR_CSIRDY_Msk   (0x1UL << RCC_CR_CSIRDY_Pos)
#define RCC_CR_CSIRDY   RCC_CR_CSIRDY_Msk
#define RCC_CR_CSIKERON_Pos   (9U)
#define RCC_CR_CSIKERON_Msk   (0x1UL << RCC_CR_CSIKERON_Pos)
#define RCC_CR_CSIKERON   RCC_CR_CSIKERON_Msk
#define RCC_CR_HSI48ON_Pos   (12U)
#define RCC_CR_HSI48ON_Msk   (0x1UL << RCC_CR_HSI48ON_Pos)
#define RCC_CR_HSI48ON   RCC_CR_HSI48ON_Msk
#define RCC_CR_HSI48RDY_Pos   (13U)
#define RCC_CR_HSI48RDY_Msk   (0x1UL << RCC_CR_HSI48RDY_Pos)
#define RCC_CR_HSI48RDY   RCC_CR_HSI48RDY_Msk
#define RCC_CR_CPUCKRDY_Pos   (14U)
#define RCC_CR_CPUCKRDY_Msk   (0x1UL << RCC_CR_CPUCKRDY_Pos)
#define RCC_CR_CPUCKRDY   RCC_CR_CPUCKRDY_Msk
#define RCC_CR_CDCKRDY_Pos   (15U)
#define RCC_CR_CDCKRDY_Msk   (0x1UL << RCC_CR_CDCKRDY_Pos)
#define RCC_CR_CDCKRDY   RCC_CR_CDCKRDY_Msk
#define RCC_CR_HSEON_Pos   (16U)
#define RCC_CR_HSEON_Msk   (0x1UL << RCC_CR_HSEON_Pos)
#define RCC_CR_HSEON   RCC_CR_HSEON_Msk
#define RCC_CR_HSERDY_Pos   (17U)
#define RCC_CR_HSERDY_Msk   (0x1UL << RCC_CR_HSERDY_Pos)
#define RCC_CR_HSERDY   RCC_CR_HSERDY_Msk
#define RCC_CR_HSEBYP_Pos   (18U)
#define RCC_CR_HSEBYP_Msk   (0x1UL << RCC_CR_HSEBYP_Pos)
#define RCC_CR_HSEBYP   RCC_CR_HSEBYP_Msk
#define RCC_CR_CSSHSEON_Pos   (19U)
#define RCC_CR_CSSHSEON_Msk   (0x1UL << RCC_CR_CSSHSEON_Pos)
#define RCC_CR_CSSHSEON   RCC_CR_CSSHSEON_Msk
#define RCC_CR_HSEEXT_Pos   (20U)
#define RCC_CR_HSEEXT_Msk   (0x1UL << RCC_CR_HSEEXT_Pos)
#define RCC_CR_HSEEXT   RCC_CR_HSEEXT_Msk
#define RCC_CR_PLL1ON_Pos   (24U)
#define RCC_CR_PLL1ON_Msk   (0x1UL << RCC_CR_PLL1ON_Pos)
#define RCC_CR_PLL1ON   RCC_CR_PLL1ON_Msk
#define RCC_CR_PLL1RDY_Pos   (25U)
#define RCC_CR_PLL1RDY_Msk   (0x1UL << RCC_CR_PLL1RDY_Pos)
#define RCC_CR_PLL1RDY   RCC_CR_PLL1RDY_Msk
#define RCC_CR_PLL2ON_Pos   (26U)
#define RCC_CR_PLL2ON_Msk   (0x1UL << RCC_CR_PLL2ON_Pos)
#define RCC_CR_PLL2ON   RCC_CR_PLL2ON_Msk
#define RCC_CR_PLL2RDY_Pos   (27U)
#define RCC_CR_PLL2RDY_Msk   (0x1UL << RCC_CR_PLL2RDY_Pos)
#define RCC_CR_PLL2RDY   RCC_CR_PLL2RDY_Msk
#define RCC_CR_PLL3ON_Pos   (28U)
#define RCC_CR_PLL3ON_Msk   (0x1UL << RCC_CR_PLL3ON_Pos)
#define RCC_CR_PLL3ON   RCC_CR_PLL3ON_Msk
#define RCC_CR_PLL3RDY_Pos   (29U)
#define RCC_CR_PLL3RDY_Msk   (0x1UL << RCC_CR_PLL3RDY_Pos)
#define RCC_CR_PLL3RDY   RCC_CR_PLL3RDY_Msk
#define RCC_CR_PLLON_Pos   (24U)
#define RCC_CR_PLLON_Msk   (0x1UL << RCC_CR_PLLON_Pos)
#define RCC_CR_PLLON   RCC_CR_PLLON_Msk
#define RCC_CR_PLLRDY_Pos   (25U)
#define RCC_CR_PLLRDY_Msk   (0x1UL << RCC_CR_PLLRDY_Pos)
#define RCC_CR_PLLRDY   RCC_CR_PLLRDY_Msk
#define RCC_HSICFGR_HSICAL_Pos   (0U)
#define RCC_HSICFGR_HSICAL_Msk   (0xFFFUL << RCC_HSICFGR_HSICAL_Pos)
#define RCC_HSICFGR_HSICAL   RCC_HSICFGR_HSICAL_Msk
#define RCC_HSICFGR_HSICAL_0   (0x001UL << RCC_HSICFGR_HSICAL_Pos)
#define RCC_HSICFGR_HSICAL_1   (0x002UL << RCC_HSICFGR_HSICAL_Pos)
#define RCC_HSICFGR_HSICAL_2   (0x004UL << RCC_HSICFGR_HSICAL_Pos)
#define RCC_HSICFGR_HSICAL_3   (0x008UL << RCC_HSICFGR_HSICAL_Pos)
#define RCC_HSICFGR_HSICAL_4   (0x010UL << RCC_HSICFGR_HSICAL_Pos)
#define RCC_HSICFGR_HSICAL_5   (0x020UL << RCC_HSICFGR_HSICAL_Pos)
#define RCC_HSICFGR_HSICAL_6   (0x040UL << RCC_HSICFGR_HSICAL_Pos)
#define RCC_HSICFGR_HSICAL_7   (0x080UL << RCC_HSICFGR_HSICAL_Pos)
#define RCC_HSICFGR_HSICAL_8   (0x100UL << RCC_HSICFGR_HSICAL_Pos)
#define RCC_HSICFGR_HSICAL_9   (0x200UL << RCC_HSICFGR_HSICAL_Pos)
#define RCC_HSICFGR_HSICAL_10   (0x400UL << RCC_HSICFGR_HSICAL_Pos)
#define RCC_HSICFGR_HSICAL_11   (0x800UL << RCC_HSICFGR_HSICAL_Pos)
#define RCC_HSICFGR_HSITRIM_Pos   (24U)
#define RCC_HSICFGR_HSITRIM_Msk   (0x7FUL << RCC_HSICFGR_HSITRIM_Pos)
#define RCC_HSICFGR_HSITRIM   RCC_HSICFGR_HSITRIM_Msk
#define RCC_HSICFGR_HSITRIM_0   (0x01UL << RCC_HSICFGR_HSITRIM_Pos)
#define RCC_HSICFGR_HSITRIM_1   (0x02UL << RCC_HSICFGR_HSITRIM_Pos)
#define RCC_HSICFGR_HSITRIM_2   (0x04UL << RCC_HSICFGR_HSITRIM_Pos)
#define RCC_HSICFGR_HSITRIM_3   (0x08UL << RCC_HSICFGR_HSITRIM_Pos)
#define RCC_HSICFGR_HSITRIM_4   (0x10UL << RCC_HSICFGR_HSITRIM_Pos)
#define RCC_HSICFGR_HSITRIM_5   (0x20UL << RCC_HSICFGR_HSITRIM_Pos)
#define RCC_HSICFGR_HSITRIM_6   (0x40UL << RCC_HSICFGR_HSITRIM_Pos)
#define RCC_CRRCR_HSI48CAL_Pos   (0U)
#define RCC_CRRCR_HSI48CAL_Msk   (0x3FFUL << RCC_CRRCR_HSI48CAL_Pos)
#define RCC_CRRCR_HSI48CAL   RCC_CRRCR_HSI48CAL_Msk
#define RCC_CRRCR_HSI48CAL_0   (0x001UL << RCC_CRRCR_HSI48CAL_Pos)
#define RCC_CRRCR_HSI48CAL_1   (0x002UL << RCC_CRRCR_HSI48CAL_Pos)
#define RCC_CRRCR_HSI48CAL_2   (0x004UL << RCC_CRRCR_HSI48CAL_Pos)
#define RCC_CRRCR_HSI48CAL_3   (0x008UL << RCC_CRRCR_HSI48CAL_Pos)
#define RCC_CRRCR_HSI48CAL_4   (0x010UL << RCC_CRRCR_HSI48CAL_Pos)
#define RCC_CRRCR_HSI48CAL_5   (0x020UL << RCC_CRRCR_HSI48CAL_Pos)
#define RCC_CRRCR_HSI48CAL_6   (0x040UL << RCC_CRRCR_HSI48CAL_Pos)
#define RCC_CRRCR_HSI48CAL_7   (0x080UL << RCC_CRRCR_HSI48CAL_Pos)
#define RCC_CRRCR_HSI48CAL_8   (0x100UL << RCC_CRRCR_HSI48CAL_Pos)
#define RCC_CRRCR_HSI48CAL_9   (0x200UL << RCC_CRRCR_HSI48CAL_Pos)
#define RCC_CSICFGR_CSICAL_Pos   (0U)
#define RCC_CSICFGR_CSICAL_Msk   (0xFFUL << RCC_CSICFGR_CSICAL_Pos)
#define RCC_CSICFGR_CSICAL   RCC_CSICFGR_CSICAL_Msk
#define RCC_CSICFGR_CSICAL_0   (0x01UL << RCC_CSICFGR_CSICAL_Pos)
#define RCC_CSICFGR_CSICAL_1   (0x02UL << RCC_CSICFGR_CSICAL_Pos)
#define RCC_CSICFGR_CSICAL_2   (0x04UL << RCC_CSICFGR_CSICAL_Pos)
#define RCC_CSICFGR_CSICAL_3   (0x08UL << RCC_CSICFGR_CSICAL_Pos)
#define RCC_CSICFGR_CSICAL_4   (0x10UL << RCC_CSICFGR_CSICAL_Pos)
#define RCC_CSICFGR_CSICAL_5   (0x20UL << RCC_CSICFGR_CSICAL_Pos)
#define RCC_CSICFGR_CSICAL_6   (0x40UL << RCC_CSICFGR_CSICAL_Pos)
#define RCC_CSICFGR_CSICAL_7   (0x80UL << RCC_CSICFGR_CSICAL_Pos)
#define RCC_CSICFGR_CSITRIM_Pos   (24U)
#define RCC_CSICFGR_CSITRIM_Msk   (0x3FUL << RCC_CSICFGR_CSITRIM_Pos)
#define RCC_CSICFGR_CSITRIM   RCC_CSICFGR_CSITRIM_Msk
#define RCC_CSICFGR_CSITRIM_0   (0x01UL << RCC_CSICFGR_CSITRIM_Pos)
#define RCC_CSICFGR_CSITRIM_1   (0x02UL << RCC_CSICFGR_CSITRIM_Pos)
#define RCC_CSICFGR_CSITRIM_2   (0x04UL << RCC_CSICFGR_CSITRIM_Pos)
#define RCC_CSICFGR_CSITRIM_3   (0x08UL << RCC_CSICFGR_CSITRIM_Pos)
#define RCC_CSICFGR_CSITRIM_4   (0x10UL << RCC_CSICFGR_CSITRIM_Pos)
#define RCC_CSICFGR_CSITRIM_5   (0x20UL << RCC_CSICFGR_CSITRIM_Pos)
#define RCC_CFGR_SW_Pos   (0U)
#define RCC_CFGR_SW_Msk   (0x7UL << RCC_CFGR_SW_Pos)
#define RCC_CFGR_SW   RCC_CFGR_SW_Msk
#define RCC_CFGR_SW_0   (0x1UL << RCC_CFGR_SW_Pos)
#define RCC_CFGR_SW_1   (0x2UL << RCC_CFGR_SW_Pos)
#define RCC_CFGR_SW_2   (0x4UL << RCC_CFGR_SW_Pos)
#define RCC_CFGR_SW_HSI   (0x00000000UL)
#define RCC_CFGR_SW_CSI   (0x00000001UL)
#define RCC_CFGR_SW_HSE   (0x00000002UL)
#define RCC_CFGR_SW_PLL1   (0x00000003UL)
#define RCC_CFGR_SWS_Pos   (3U)
#define RCC_CFGR_SWS_Msk   (0x7UL << RCC_CFGR_SWS_Pos)
#define RCC_CFGR_SWS   RCC_CFGR_SWS_Msk
#define RCC_CFGR_SWS_0   (0x1UL << RCC_CFGR_SWS_Pos)
#define RCC_CFGR_SWS_1   (0x2UL << RCC_CFGR_SWS_Pos)
#define RCC_CFGR_SWS_2   (0x4UL << RCC_CFGR_SWS_Pos)
#define RCC_CFGR_SWS_HSI   (0x00000000UL)
#define RCC_CFGR_SWS_CSI   (0x00000008UL)
#define RCC_CFGR_SWS_HSE   (0x00000010UL)
#define RCC_CFGR_SWS_PLL1   (0x00000018UL)
#define RCC_CFGR_STOPWUCK_Pos   (6U)
#define RCC_CFGR_STOPWUCK_Msk   (0x1UL << RCC_CFGR_STOPWUCK_Pos)
#define RCC_CFGR_STOPWUCK   RCC_CFGR_STOPWUCK_Msk
#define RCC_CFGR_STOPKERWUCK_Pos   (7U)
#define RCC_CFGR_STOPKERWUCK_Msk   (0x1UL << RCC_CFGR_STOPKERWUCK_Pos)
#define RCC_CFGR_STOPKERWUCK   RCC_CFGR_STOPKERWUCK_Msk
#define RCC_CFGR_RTCPRE_Pos   (8U)
#define RCC_CFGR_RTCPRE_Msk   (0x3FUL << RCC_CFGR_RTCPRE_Pos)
#define RCC_CFGR_RTCPRE   RCC_CFGR_RTCPRE_Msk
#define RCC_CFGR_RTCPRE_0   (0x1UL << RCC_CFGR_RTCPRE_Pos)
#define RCC_CFGR_RTCPRE_1   (0x2UL << RCC_CFGR_RTCPRE_Pos)
#define RCC_CFGR_RTCPRE_2   (0x4UL << RCC_CFGR_RTCPRE_Pos)
#define RCC_CFGR_RTCPRE_3   (0x8UL << RCC_CFGR_RTCPRE_Pos)
#define RCC_CFGR_RTCPRE_4   (0x10UL << RCC_CFGR_RTCPRE_Pos)
#define RCC_CFGR_RTCPRE_5   (0x20UL << RCC_CFGR_RTCPRE_Pos)
#define RCC_CFGR_TIMPRE_Pos   (15U)
#define RCC_CFGR_TIMPRE_Msk   (0x1UL << RCC_CFGR_TIMPRE_Pos)
#define RCC_CFGR_TIMPRE   RCC_CFGR_TIMPRE_Msk
#define RCC_CFGR_MCO1_Pos   (22U)
#define RCC_CFGR_MCO1_Msk   (0x7UL << RCC_CFGR_MCO1_Pos)
#define RCC_CFGR_MCO1   RCC_CFGR_MCO1_Msk
#define RCC_CFGR_MCO1_0   (0x1UL << RCC_CFGR_MCO1_Pos)
#define RCC_CFGR_MCO1_1   (0x2UL << RCC_CFGR_MCO1_Pos)
#define RCC_CFGR_MCO1_2   (0x4UL << RCC_CFGR_MCO1_Pos)
#define RCC_CFGR_MCO1PRE_Pos   (18U)
#define RCC_CFGR_MCO1PRE_Msk   (0xFUL << RCC_CFGR_MCO1PRE_Pos)
#define RCC_CFGR_MCO1PRE   RCC_CFGR_MCO1PRE_Msk
#define RCC_CFGR_MCO1PRE_0   (0x1UL << RCC_CFGR_MCO1PRE_Pos)
#define RCC_CFGR_MCO1PRE_1   (0x2UL << RCC_CFGR_MCO1PRE_Pos)
#define RCC_CFGR_MCO1PRE_2   (0x4UL << RCC_CFGR_MCO1PRE_Pos)
#define RCC_CFGR_MCO1PRE_3   (0x8UL << RCC_CFGR_MCO1PRE_Pos)
#define RCC_CFGR_MCO2PRE_Pos   (25U)
#define RCC_CFGR_MCO2PRE_Msk   (0xFUL << RCC_CFGR_MCO2PRE_Pos)
#define RCC_CFGR_MCO2PRE   RCC_CFGR_MCO2PRE_Msk
#define RCC_CFGR_MCO2PRE_0   (0x1UL << RCC_CFGR_MCO2PRE_Pos)
#define RCC_CFGR_MCO2PRE_1   (0x2UL << RCC_CFGR_MCO2PRE_Pos)
#define RCC_CFGR_MCO2PRE_2   (0x4UL << RCC_CFGR_MCO2PRE_Pos)
#define RCC_CFGR_MCO2PRE_3   (0x8UL << RCC_CFGR_MCO2PRE_Pos)
#define RCC_CFGR_MCO2_Pos   (29U)
#define RCC_CFGR_MCO2_Msk   (0x7UL << RCC_CFGR_MCO2_Pos)
#define RCC_CFGR_MCO2   RCC_CFGR_MCO2_Msk
#define RCC_CFGR_MCO2_0   (0x1UL << RCC_CFGR_MCO2_Pos)
#define RCC_CFGR_MCO2_1   (0x2UL << RCC_CFGR_MCO2_Pos)
#define RCC_CFGR_MCO2_2   (0x4UL << RCC_CFGR_MCO2_Pos)
#define RCC_CDCFGR1_HPRE_Pos   (0U)
#define RCC_CDCFGR1_HPRE_Msk   (0xFUL << RCC_CDCFGR1_HPRE_Pos)
#define RCC_CDCFGR1_HPRE   RCC_CDCFGR1_HPRE_Msk
#define RCC_CDCFGR1_HPRE_0   (0x1UL << RCC_CDCFGR1_HPRE_Pos)
#define RCC_CDCFGR1_HPRE_1   (0x2UL << RCC_CDCFGR1_HPRE_Pos)
#define RCC_CDCFGR1_HPRE_2   (0x4UL << RCC_CDCFGR1_HPRE_Pos)
#define RCC_CDCFGR1_HPRE_3   (0x8UL << RCC_CDCFGR1_HPRE_Pos)
#define RCC_CDCFGR1_HPRE_DIV1   (0U)
#define RCC_CDCFGR1_HPRE_DIV2_Pos   (3U)
#define RCC_CDCFGR1_HPRE_DIV2_Msk   (0x1UL << RCC_CDCFGR1_HPRE_DIV2_Pos)
#define RCC_CDCFGR1_HPRE_DIV2   RCC_CDCFGR1_HPRE_DIV2_Msk
#define RCC_CDCFGR1_HPRE_DIV4_Pos   (0U)
#define RCC_CDCFGR1_HPRE_DIV4_Msk   (0x9UL << RCC_CDCFGR1_HPRE_DIV4_Pos)
#define RCC_CDCFGR1_HPRE_DIV4   RCC_CDCFGR1_HPRE_DIV4_Msk
#define RCC_CDCFGR1_HPRE_DIV8_Pos   (1U)
#define RCC_CDCFGR1_HPRE_DIV8_Msk   (0x5UL << RCC_CDCFGR1_HPRE_DIV8_Pos)
#define RCC_CDCFGR1_HPRE_DIV8   RCC_CDCFGR1_HPRE_DIV8_Msk
#define RCC_CDCFGR1_HPRE_DIV16_Pos   (0U)
#define RCC_CDCFGR1_HPRE_DIV16_Msk   (0xBUL << RCC_CDCFGR1_HPRE_DIV16_Pos)
#define RCC_CDCFGR1_HPRE_DIV16   RCC_CDCFGR1_HPRE_DIV16_Msk
#define RCC_CDCFGR1_HPRE_DIV64_Pos   (2U)
#define RCC_CDCFGR1_HPRE_DIV64_Msk   (0x3UL << RCC_CDCFGR1_HPRE_DIV64_Pos)
#define RCC_CDCFGR1_HPRE_DIV64   RCC_CDCFGR1_HPRE_DIV64_Msk
#define RCC_CDCFGR1_HPRE_DIV128_Pos   (0U)
#define RCC_CDCFGR1_HPRE_DIV128_Msk   (0xDUL << RCC_CDCFGR1_HPRE_DIV128_Pos)
#define RCC_CDCFGR1_HPRE_DIV128   RCC_CDCFGR1_HPRE_DIV128_Msk
#define RCC_CDCFGR1_HPRE_DIV256_Pos   (1U)
#define RCC_CDCFGR1_HPRE_DIV256_Msk   (0x7UL << RCC_CDCFGR1_HPRE_DIV256_Pos)
#define RCC_CDCFGR1_HPRE_DIV256   RCC_CDCFGR1_HPRE_DIV256_Msk
#define RCC_CDCFGR1_HPRE_DIV512_Pos   (0U)
#define RCC_CDCFGR1_HPRE_DIV512_Msk   (0xFUL << RCC_CDCFGR1_HPRE_DIV512_Pos)
#define RCC_CDCFGR1_HPRE_DIV512   RCC_CDCFGR1_HPRE_DIV512_Msk
#define RCC_CDCFGR1_CDPPRE_Pos   (4U)
#define RCC_CDCFGR1_CDPPRE_Msk   (0x7UL << RCC_CDCFGR1_CDPPRE_Pos)
#define RCC_CDCFGR1_CDPPRE   RCC_CDCFGR1_CDPPRE_Msk
#define RCC_CDCFGR1_CDPPRE_0   (0x1UL << RCC_CDCFGR1_CDPPRE_Pos)
#define RCC_CDCFGR1_CDPPRE_1   (0x2UL << RCC_CDCFGR1_CDPPRE_Pos)
#define RCC_CDCFGR1_CDPPRE_2   (0x4UL << RCC_CDCFGR1_CDPPRE_Pos)
#define RCC_CDCFGR1_CDPPRE_DIV1   (0U)
#define RCC_CDCFGR1_CDPPRE_DIV2_Pos   (6U)
#define RCC_CDCFGR1_CDPPRE_DIV2_Msk   (0x1UL << RCC_CDCFGR1_CDPPRE_DIV2_Pos)
#define RCC_CDCFGR1_CDPPRE_DIV2   RCC_CDCFGR1_CDPPRE_DIV2_Msk
#define RCC_CDCFGR1_CDPPRE_DIV4_Pos   (4U)
#define RCC_CDCFGR1_CDPPRE_DIV4_Msk   (0x5UL << RCC_CDCFGR1_CDPPRE_DIV4_Pos)
#define RCC_CDCFGR1_CDPPRE_DIV4   RCC_CDCFGR1_CDPPRE_DIV4_Msk
#define RCC_CDCFGR1_CDPPRE_DIV8_Pos   (5U)
#define RCC_CDCFGR1_CDPPRE_DIV8_Msk   (0x3UL << RCC_CDCFGR1_CDPPRE_DIV8_Pos)
#define RCC_CDCFGR1_CDPPRE_DIV8   RCC_CDCFGR1_CDPPRE_DIV8_Msk
#define RCC_CDCFGR1_CDPPRE_DIV16_Pos   (4U)
#define RCC_CDCFGR1_CDPPRE_DIV16_Msk   (0x7UL << RCC_CDCFGR1_CDPPRE_DIV16_Pos)
#define RCC_CDCFGR1_CDPPRE_DIV16   RCC_CDCFGR1_CDPPRE_DIV16_Msk
#define RCC_CDCFGR1_CDCPRE_Pos   (8U)
#define RCC_CDCFGR1_CDCPRE_Msk   (0xFUL << RCC_CDCFGR1_CDCPRE_Pos)
#define RCC_CDCFGR1_CDCPRE   RCC_CDCFGR1_CDCPRE_Msk
#define RCC_CDCFGR1_CDCPRE_0   (0x1UL << RCC_CDCFGR1_CDCPRE_Pos)
#define RCC_CDCFGR1_CDCPRE_1   (0x2UL << RCC_CDCFGR1_CDCPRE_Pos)
#define RCC_CDCFGR1_CDCPRE_2   (0x4UL << RCC_CDCFGR1_CDCPRE_Pos)
#define RCC_CDCFGR1_CDCPRE_3   (0x8UL << RCC_CDCFGR1_CDCPRE_Pos)
#define RCC_CDCFGR1_CDCPRE_DIV1   (0U)
#define RCC_CDCFGR1_CDCPRE_DIV2_Pos   (11U)
#define RCC_CDCFGR1_CDCPRE_DIV2_Msk   (0x1UL << RCC_CDCFGR1_CDCPRE_DIV2_Pos)
#define RCC_CDCFGR1_CDCPRE_DIV2   RCC_CDCFGR1_CDCPRE_DIV2_Msk
#define RCC_CDCFGR1_CDCPRE_DIV4_Pos   (8U)
#define RCC_CDCFGR1_CDCPRE_DIV4_Msk   (0x9UL << RCC_CDCFGR1_CDCPRE_DIV4_Pos)
#define RCC_CDCFGR1_CDCPRE_DIV4   RCC_CDCFGR1_CDCPRE_DIV4_Msk
#define RCC_CDCFGR1_CDCPRE_DIV8_Pos   (9U)
#define RCC_CDCFGR1_CDCPRE_DIV8_Msk   (0x5UL << RCC_CDCFGR1_CDCPRE_DIV8_Pos)
#define RCC_CDCFGR1_CDCPRE_DIV8   RCC_CDCFGR1_CDCPRE_DIV8_Msk
#define RCC_CDCFGR1_CDCPRE_DIV16_Pos   (8U)
#define RCC_CDCFGR1_CDCPRE_DIV16_Msk   (0xBUL << RCC_CDCFGR1_CDCPRE_DIV16_Pos)
#define RCC_CDCFGR1_CDCPRE_DIV16   RCC_CDCFGR1_CDCPRE_DIV16_Msk
#define RCC_CDCFGR1_CDCPRE_DIV64_Pos   (10U)
#define RCC_CDCFGR1_CDCPRE_DIV64_Msk   (0x3UL << RCC_CDCFGR1_CDCPRE_DIV64_Pos)
#define RCC_CDCFGR1_CDCPRE_DIV64   RCC_CDCFGR1_CDCPRE_DIV64_Msk
#define RCC_CDCFGR1_CDCPRE_DIV128_Pos   (8U)
#define RCC_CDCFGR1_CDCPRE_DIV128_Msk   (0xDUL << RCC_CDCFGR1_CDCPRE_DIV128_Pos)
#define RCC_CDCFGR1_CDCPRE_DIV128   RCC_CDCFGR1_CDCPRE_DIV128_Msk
#define RCC_CDCFGR1_CDCPRE_DIV256_Pos   (9U)
#define RCC_CDCFGR1_CDCPRE_DIV256_Msk   (0x7UL << RCC_CDCFGR1_CDCPRE_DIV256_Pos)
#define RCC_CDCFGR1_CDCPRE_DIV256   RCC_CDCFGR1_CDCPRE_DIV256_Msk
#define RCC_CDCFGR1_CDCPRE_DIV512_Pos   (8U)
#define RCC_CDCFGR1_CDCPRE_DIV512_Msk   (0xFUL << RCC_CDCFGR1_CDCPRE_DIV512_Pos)
#define RCC_CDCFGR1_CDCPRE_DIV512   RCC_CDCFGR1_CDCPRE_DIV512_Msk
#define RCC_CDCFGR2_CDPPRE1_Pos   (4U)
#define RCC_CDCFGR2_CDPPRE1_Msk   (0x7UL << RCC_CDCFGR2_CDPPRE1_Pos)
#define RCC_CDCFGR2_CDPPRE1   RCC_CDCFGR2_CDPPRE1_Msk
#define RCC_CDCFGR2_CDPPRE1_0   (0x1UL << RCC_CDCFGR2_CDPPRE1_Pos)
#define RCC_CDCFGR2_CDPPRE1_1   (0x2UL << RCC_CDCFGR2_CDPPRE1_Pos)
#define RCC_CDCFGR2_CDPPRE1_2   (0x4UL << RCC_CDCFGR2_CDPPRE1_Pos)
#define RCC_CDCFGR2_CDPPRE1_DIV1   (0U)
#define RCC_CDCFGR2_CDPPRE1_DIV2_Pos   (6U)
#define RCC_CDCFGR2_CDPPRE1_DIV2_Msk   (0x1UL << RCC_CDCFGR2_CDPPRE1_DIV2_Pos)
#define RCC_CDCFGR2_CDPPRE1_DIV2   RCC_CDCFGR2_CDPPRE1_DIV2_Msk
#define RCC_CDCFGR2_CDPPRE1_DIV4_Pos   (4U)
#define RCC_CDCFGR2_CDPPRE1_DIV4_Msk   (0x5UL << RCC_CDCFGR2_CDPPRE1_DIV4_Pos)
#define RCC_CDCFGR2_CDPPRE1_DIV4   RCC_CDCFGR2_CDPPRE1_DIV4_Msk
#define RCC_CDCFGR2_CDPPRE1_DIV8_Pos   (5U)
#define RCC_CDCFGR2_CDPPRE1_DIV8_Msk   (0x3UL << RCC_CDCFGR2_CDPPRE1_DIV8_Pos)
#define RCC_CDCFGR2_CDPPRE1_DIV8   RCC_CDCFGR2_CDPPRE1_DIV8_Msk
#define RCC_CDCFGR2_CDPPRE1_DIV16_Pos   (4U)
#define RCC_CDCFGR2_CDPPRE1_DIV16_Msk   (0x7UL << RCC_CDCFGR2_CDPPRE1_DIV16_Pos)
#define RCC_CDCFGR2_CDPPRE1_DIV16   RCC_CDCFGR2_CDPPRE1_DIV16_Msk
#define RCC_CDCFGR2_CDPPRE2_Pos   (8U)
#define RCC_CDCFGR2_CDPPRE2_Msk   (0x7UL << RCC_CDCFGR2_CDPPRE2_Pos)
#define RCC_CDCFGR2_CDPPRE2   RCC_CDCFGR2_CDPPRE2_Msk
#define RCC_CDCFGR2_CDPPRE2_0   (0x1UL << RCC_CDCFGR2_CDPPRE2_Pos)
#define RCC_CDCFGR2_CDPPRE2_1   (0x2UL << RCC_CDCFGR2_CDPPRE2_Pos)
#define RCC_CDCFGR2_CDPPRE2_2   (0x4UL << RCC_CDCFGR2_CDPPRE2_Pos)
#define RCC_CDCFGR2_CDPPRE2_DIV1   (0U)
#define RCC_CDCFGR2_CDPPRE2_DIV2_Pos   (10U)
#define RCC_CDCFGR2_CDPPRE2_DIV2_Msk   (0x1UL << RCC_CDCFGR2_CDPPRE2_DIV2_Pos)
#define RCC_CDCFGR2_CDPPRE2_DIV2   RCC_CDCFGR2_CDPPRE2_DIV2_Msk
#define RCC_CDCFGR2_CDPPRE2_DIV4_Pos   (8U)
#define RCC_CDCFGR2_CDPPRE2_DIV4_Msk   (0x5UL << RCC_CDCFGR2_CDPPRE2_DIV4_Pos)
#define RCC_CDCFGR2_CDPPRE2_DIV4   RCC_CDCFGR2_CDPPRE2_DIV4_Msk
#define RCC_CDCFGR2_CDPPRE2_DIV8_Pos   (9U)
#define RCC_CDCFGR2_CDPPRE2_DIV8_Msk   (0x3UL << RCC_CDCFGR2_CDPPRE2_DIV8_Pos)
#define RCC_CDCFGR2_CDPPRE2_DIV8   RCC_CDCFGR2_CDPPRE2_DIV8_Msk
#define RCC_CDCFGR2_CDPPRE2_DIV16_Pos   (8U)
#define RCC_CDCFGR2_CDPPRE2_DIV16_Msk   (0x7UL << RCC_CDCFGR2_CDPPRE2_DIV16_Pos)
#define RCC_CDCFGR2_CDPPRE2_DIV16   RCC_CDCFGR2_CDPPRE2_DIV16_Msk
#define RCC_SRDCFGR_SRDPPRE_Pos   (4U)
#define RCC_SRDCFGR_SRDPPRE_Msk   (0x7UL << RCC_SRDCFGR_SRDPPRE_Pos)
#define RCC_SRDCFGR_SRDPPRE   RCC_SRDCFGR_SRDPPRE_Msk
#define RCC_SRDCFGR_SRDPPRE_0   (0x1UL << RCC_SRDCFGR_SRDPPRE_Pos)
#define RCC_SRDCFGR_SRDPPRE_1   (0x2UL << RCC_SRDCFGR_SRDPPRE_Pos)
#define RCC_SRDCFGR_SRDPPRE_2   (0x4UL << RCC_SRDCFGR_SRDPPRE_Pos)
#define RCC_SRDCFGR_SRDPPRE_DIV1   (0U)
#define RCC_SRDCFGR_SRDPPRE_DIV2_Pos   (6U)
#define RCC_SRDCFGR_SRDPPRE_DIV2_Msk   (0x1UL << RCC_SRDCFGR_SRDPPRE_DIV2_Pos)
#define RCC_SRDCFGR_SRDPPRE_DIV2   RCC_SRDCFGR_SRDPPRE_DIV2_Msk
#define RCC_SRDCFGR_SRDPPRE_DIV4_Pos   (4U)
#define RCC_SRDCFGR_SRDPPRE_DIV4_Msk   (0x5UL << RCC_SRDCFGR_SRDPPRE_DIV4_Pos)
#define RCC_SRDCFGR_SRDPPRE_DIV4   RCC_SRDCFGR_SRDPPRE_DIV4_Msk
#define RCC_SRDCFGR_SRDPPRE_DIV8_Pos   (5U)
#define RCC_SRDCFGR_SRDPPRE_DIV8_Msk   (0x3UL << RCC_SRDCFGR_SRDPPRE_DIV8_Pos)
#define RCC_SRDCFGR_SRDPPRE_DIV8   RCC_SRDCFGR_SRDPPRE_DIV8_Msk
#define RCC_SRDCFGR_SRDPPRE_DIV16_Pos   (4U)
#define RCC_SRDCFGR_SRDPPRE_DIV16_Msk   (0x7UL << RCC_SRDCFGR_SRDPPRE_DIV16_Pos)
#define RCC_SRDCFGR_SRDPPRE_DIV16   RCC_SRDCFGR_SRDPPRE_DIV16_Msk
#define RCC_PLLCKSELR_PLLSRC_Pos   (0U)
#define RCC_PLLCKSELR_PLLSRC_Msk   (0x3UL << RCC_PLLCKSELR_PLLSRC_Pos)
#define RCC_PLLCKSELR_PLLSRC   RCC_PLLCKSELR_PLLSRC_Msk
#define RCC_PLLCKSELR_PLLSRC_HSI   (0U)
#define RCC_PLLCKSELR_PLLSRC_CSI_Pos   (0U)
#define RCC_PLLCKSELR_PLLSRC_CSI_Msk   (0x1UL << RCC_PLLCKSELR_PLLSRC_CSI_Pos)
#define RCC_PLLCKSELR_PLLSRC_CSI   RCC_PLLCKSELR_PLLSRC_CSI_Msk
#define RCC_PLLCKSELR_PLLSRC_HSE_Pos   (1U)
#define RCC_PLLCKSELR_PLLSRC_HSE_Msk   (0x1UL << RCC_PLLCKSELR_PLLSRC_HSE_Pos)
#define RCC_PLLCKSELR_PLLSRC_HSE   RCC_PLLCKSELR_PLLSRC_HSE_Msk
#define RCC_PLLCKSELR_PLLSRC_NONE_Pos   (0U)
#define RCC_PLLCKSELR_PLLSRC_NONE_Msk   (0x3UL << RCC_PLLCKSELR_PLLSRC_NONE_Pos)
#define RCC_PLLCKSELR_PLLSRC_NONE   RCC_PLLCKSELR_PLLSRC_NONE_Msk
#define RCC_PLLCKSELR_DIVM1_Pos   (4U)
#define RCC_PLLCKSELR_DIVM1_Msk   (0x3FUL << RCC_PLLCKSELR_DIVM1_Pos)
#define RCC_PLLCKSELR_DIVM1   RCC_PLLCKSELR_DIVM1_Msk
#define RCC_PLLCKSELR_DIVM1_0   (0x01UL << RCC_PLLCKSELR_DIVM1_Pos)
#define RCC_PLLCKSELR_DIVM1_1   (0x02UL << RCC_PLLCKSELR_DIVM1_Pos)
#define RCC_PLLCKSELR_DIVM1_2   (0x04UL << RCC_PLLCKSELR_DIVM1_Pos)
#define RCC_PLLCKSELR_DIVM1_3   (0x08UL << RCC_PLLCKSELR_DIVM1_Pos)
#define RCC_PLLCKSELR_DIVM1_4   (0x10UL << RCC_PLLCKSELR_DIVM1_Pos)
#define RCC_PLLCKSELR_DIVM1_5   (0x20UL << RCC_PLLCKSELR_DIVM1_Pos)
#define RCC_PLLCKSELR_DIVM2_Pos   (12U)
#define RCC_PLLCKSELR_DIVM2_Msk   (0x3FUL << RCC_PLLCKSELR_DIVM2_Pos)
#define RCC_PLLCKSELR_DIVM2   RCC_PLLCKSELR_DIVM2_Msk
#define RCC_PLLCKSELR_DIVM2_0   (0x01UL << RCC_PLLCKSELR_DIVM2_Pos)
#define RCC_PLLCKSELR_DIVM2_1   (0x02UL << RCC_PLLCKSELR_DIVM2_Pos)
#define RCC_PLLCKSELR_DIVM2_2   (0x04UL << RCC_PLLCKSELR_DIVM2_Pos)
#define RCC_PLLCKSELR_DIVM2_3   (0x08UL << RCC_PLLCKSELR_DIVM2_Pos)
#define RCC_PLLCKSELR_DIVM2_4   (0x10UL << RCC_PLLCKSELR_DIVM2_Pos)
#define RCC_PLLCKSELR_DIVM2_5   (0x20UL << RCC_PLLCKSELR_DIVM2_Pos)
#define RCC_PLLCKSELR_DIVM3_Pos   (20U)
#define RCC_PLLCKSELR_DIVM3_Msk   (0x3FUL << RCC_PLLCKSELR_DIVM3_Pos)
#define RCC_PLLCKSELR_DIVM3   RCC_PLLCKSELR_DIVM3_Msk
#define RCC_PLLCKSELR_DIVM3_0   (0x01UL << RCC_PLLCKSELR_DIVM3_Pos)
#define RCC_PLLCKSELR_DIVM3_1   (0x02UL << RCC_PLLCKSELR_DIVM3_Pos)
#define RCC_PLLCKSELR_DIVM3_2   (0x04UL << RCC_PLLCKSELR_DIVM3_Pos)
#define RCC_PLLCKSELR_DIVM3_3   (0x08UL << RCC_PLLCKSELR_DIVM3_Pos)
#define RCC_PLLCKSELR_DIVM3_4   (0x10UL << RCC_PLLCKSELR_DIVM3_Pos)
#define RCC_PLLCKSELR_DIVM3_5   (0x20UL << RCC_PLLCKSELR_DIVM3_Pos)
#define RCC_PLLCFGR_PLL1FRACEN_Pos   (0U)
#define RCC_PLLCFGR_PLL1FRACEN_Msk   (0x1UL << RCC_PLLCFGR_PLL1FRACEN_Pos)
#define RCC_PLLCFGR_PLL1FRACEN   RCC_PLLCFGR_PLL1FRACEN_Msk
#define RCC_PLLCFGR_PLL1VCOSEL_Pos   (1U)
#define RCC_PLLCFGR_PLL1VCOSEL_Msk   (0x1UL << RCC_PLLCFGR_PLL1VCOSEL_Pos)
#define RCC_PLLCFGR_PLL1VCOSEL   RCC_PLLCFGR_PLL1VCOSEL_Msk
#define RCC_PLLCFGR_PLL1RGE_Pos   (2U)
#define RCC_PLLCFGR_PLL1RGE_Msk   (0x3UL << RCC_PLLCFGR_PLL1RGE_Pos)
#define RCC_PLLCFGR_PLL1RGE   RCC_PLLCFGR_PLL1RGE_Msk
#define RCC_PLLCFGR_PLL1RGE_0   (0x0UL << RCC_PLLCFGR_PLL1RGE_Pos)
#define RCC_PLLCFGR_PLL1RGE_1   (0x1UL << RCC_PLLCFGR_PLL1RGE_Pos)
#define RCC_PLLCFGR_PLL1RGE_2   (0x2UL << RCC_PLLCFGR_PLL1RGE_Pos)
#define RCC_PLLCFGR_PLL1RGE_3   (0x3UL << RCC_PLLCFGR_PLL1RGE_Pos)
#define RCC_PLLCFGR_PLL2FRACEN_Pos   (4U)
#define RCC_PLLCFGR_PLL2FRACEN_Msk   (0x1UL << RCC_PLLCFGR_PLL2FRACEN_Pos)
#define RCC_PLLCFGR_PLL2FRACEN   RCC_PLLCFGR_PLL2FRACEN_Msk
#define RCC_PLLCFGR_PLL2VCOSEL_Pos   (5U)
#define RCC_PLLCFGR_PLL2VCOSEL_Msk   (0x1UL << RCC_PLLCFGR_PLL2VCOSEL_Pos)
#define RCC_PLLCFGR_PLL2VCOSEL   RCC_PLLCFGR_PLL2VCOSEL_Msk
#define RCC_PLLCFGR_PLL2RGE_Pos   (6U)
#define RCC_PLLCFGR_PLL2RGE_Msk   (0x3UL << RCC_PLLCFGR_PLL2RGE_Pos)
#define RCC_PLLCFGR_PLL2RGE   RCC_PLLCFGR_PLL2RGE_Msk
#define RCC_PLLCFGR_PLL2RGE_0   (0x0UL << RCC_PLLCFGR_PLL2RGE_Pos)
#define RCC_PLLCFGR_PLL2RGE_1   (0x1UL << RCC_PLLCFGR_PLL2RGE_Pos)
#define RCC_PLLCFGR_PLL2RGE_2   (0x2UL << RCC_PLLCFGR_PLL2RGE_Pos)
#define RCC_PLLCFGR_PLL2RGE_3   (0x3UL << RCC_PLLCFGR_PLL2RGE_Pos)
#define RCC_PLLCFGR_PLL3FRACEN_Pos   (8U)
#define RCC_PLLCFGR_PLL3FRACEN_Msk   (0x1UL << RCC_PLLCFGR_PLL3FRACEN_Pos)
#define RCC_PLLCFGR_PLL3FRACEN   RCC_PLLCFGR_PLL3FRACEN_Msk
#define RCC_PLLCFGR_PLL3VCOSEL_Pos   (9U)
#define RCC_PLLCFGR_PLL3VCOSEL_Msk   (0x1UL << RCC_PLLCFGR_PLL3VCOSEL_Pos)
#define RCC_PLLCFGR_PLL3VCOSEL   RCC_PLLCFGR_PLL3VCOSEL_Msk
#define RCC_PLLCFGR_PLL3RGE_Pos   (10U)
#define RCC_PLLCFGR_PLL3RGE_Msk   (0x3UL << RCC_PLLCFGR_PLL3RGE_Pos)
#define RCC_PLLCFGR_PLL3RGE   RCC_PLLCFGR_PLL3RGE_Msk
#define RCC_PLLCFGR_PLL3RGE_0   (0x0UL << RCC_PLLCFGR_PLL3RGE_Pos)
#define RCC_PLLCFGR_PLL3RGE_1   (0x1UL << RCC_PLLCFGR_PLL3RGE_Pos)
#define RCC_PLLCFGR_PLL3RGE_2   (0x2UL << RCC_PLLCFGR_PLL3RGE_Pos)
#define RCC_PLLCFGR_PLL3RGE_3   (0x3UL << RCC_PLLCFGR_PLL3RGE_Pos)
#define RCC_PLLCFGR_DIVP1EN_Pos   (16U)
#define RCC_PLLCFGR_DIVP1EN_Msk   (0x1UL << RCC_PLLCFGR_DIVP1EN_Pos)
#define RCC_PLLCFGR_DIVP1EN   RCC_PLLCFGR_DIVP1EN_Msk
#define RCC_PLLCFGR_DIVQ1EN_Pos   (17U)
#define RCC_PLLCFGR_DIVQ1EN_Msk   (0x1UL << RCC_PLLCFGR_DIVQ1EN_Pos)
#define RCC_PLLCFGR_DIVQ1EN   RCC_PLLCFGR_DIVQ1EN_Msk
#define RCC_PLLCFGR_DIVR1EN_Pos   (18U)
#define RCC_PLLCFGR_DIVR1EN_Msk   (0x1UL << RCC_PLLCFGR_DIVR1EN_Pos)
#define RCC_PLLCFGR_DIVR1EN   RCC_PLLCFGR_DIVR1EN_Msk
#define RCC_PLLCFGR_DIVP2EN_Pos   (19U)
#define RCC_PLLCFGR_DIVP2EN_Msk   (0x1UL << RCC_PLLCFGR_DIVP2EN_Pos)
#define RCC_PLLCFGR_DIVP2EN   RCC_PLLCFGR_DIVP2EN_Msk
#define RCC_PLLCFGR_DIVQ2EN_Pos   (20U)
#define RCC_PLLCFGR_DIVQ2EN_Msk   (0x1UL << RCC_PLLCFGR_DIVQ2EN_Pos)
#define RCC_PLLCFGR_DIVQ2EN   RCC_PLLCFGR_DIVQ2EN_Msk
#define RCC_PLLCFGR_DIVR2EN_Pos   (21U)
#define RCC_PLLCFGR_DIVR2EN_Msk   (0x1UL << RCC_PLLCFGR_DIVR2EN_Pos)
#define RCC_PLLCFGR_DIVR2EN   RCC_PLLCFGR_DIVR2EN_Msk
#define RCC_PLLCFGR_DIVP3EN_Pos   (22U)
#define RCC_PLLCFGR_DIVP3EN_Msk   (0x1UL << RCC_PLLCFGR_DIVP3EN_Pos)
#define RCC_PLLCFGR_DIVP3EN   RCC_PLLCFGR_DIVP3EN_Msk
#define RCC_PLLCFGR_DIVQ3EN_Pos   (23U)
#define RCC_PLLCFGR_DIVQ3EN_Msk   (0x1UL << RCC_PLLCFGR_DIVQ3EN_Pos)
#define RCC_PLLCFGR_DIVQ3EN   RCC_PLLCFGR_DIVQ3EN_Msk
#define RCC_PLLCFGR_DIVR3EN_Pos   (24U)
#define RCC_PLLCFGR_DIVR3EN_Msk   (0x1UL << RCC_PLLCFGR_DIVR3EN_Pos)
#define RCC_PLLCFGR_DIVR3EN   RCC_PLLCFGR_DIVR3EN_Msk
#define RCC_PLL1DIVR_N1_Pos   (0U)
#define RCC_PLL1DIVR_N1_Msk   (0x1FFUL << RCC_PLL1DIVR_N1_Pos)
#define RCC_PLL1DIVR_N1   RCC_PLL1DIVR_N1_Msk
#define RCC_PLL1DIVR_P1_Pos   (9U)
#define RCC_PLL1DIVR_P1_Msk   (0x7FUL << RCC_PLL1DIVR_P1_Pos)
#define RCC_PLL1DIVR_P1   RCC_PLL1DIVR_P1_Msk
#define RCC_PLL1DIVR_Q1_Pos   (16U)
#define RCC_PLL1DIVR_Q1_Msk   (0x7FUL << RCC_PLL1DIVR_Q1_Pos)
#define RCC_PLL1DIVR_Q1   RCC_PLL1DIVR_Q1_Msk
#define RCC_PLL1DIVR_R1_Pos   (24U)
#define RCC_PLL1DIVR_R1_Msk   (0x7FUL << RCC_PLL1DIVR_R1_Pos)
#define RCC_PLL1DIVR_R1   RCC_PLL1DIVR_R1_Msk
#define RCC_PLL1FRACR_FRACN1_Pos   (3U)
#define RCC_PLL1FRACR_FRACN1_Msk   (0x1FFFUL << RCC_PLL1FRACR_FRACN1_Pos)
#define RCC_PLL1FRACR_FRACN1   RCC_PLL1FRACR_FRACN1_Msk
#define RCC_PLL2DIVR_N2_Pos   (0U)
#define RCC_PLL2DIVR_N2_Msk   (0x1FFUL << RCC_PLL2DIVR_N2_Pos)
#define RCC_PLL2DIVR_N2   RCC_PLL2DIVR_N2_Msk
#define RCC_PLL2DIVR_P2_Pos   (9U)
#define RCC_PLL2DIVR_P2_Msk   (0x7FUL << RCC_PLL2DIVR_P2_Pos)
#define RCC_PLL2DIVR_P2   RCC_PLL2DIVR_P2_Msk
#define RCC_PLL2DIVR_Q2_Pos   (16U)
#define RCC_PLL2DIVR_Q2_Msk   (0x7FUL << RCC_PLL2DIVR_Q2_Pos)
#define RCC_PLL2DIVR_Q2   RCC_PLL2DIVR_Q2_Msk
#define RCC_PLL2DIVR_R2_Pos   (24U)
#define RCC_PLL2DIVR_R2_Msk   (0x7FUL << RCC_PLL2DIVR_R2_Pos)
#define RCC_PLL2DIVR_R2   RCC_PLL2DIVR_R2_Msk
#define RCC_PLL2FRACR_FRACN2_Pos   (3U)
#define RCC_PLL2FRACR_FRACN2_Msk   (0x1FFFUL << RCC_PLL2FRACR_FRACN2_Pos)
#define RCC_PLL2FRACR_FRACN2   RCC_PLL2FRACR_FRACN2_Msk
#define RCC_PLL3DIVR_N3_Pos   (0U)
#define RCC_PLL3DIVR_N3_Msk   (0x1FFUL << RCC_PLL3DIVR_N3_Pos)
#define RCC_PLL3DIVR_N3   RCC_PLL3DIVR_N3_Msk
#define RCC_PLL3DIVR_P3_Pos   (9U)
#define RCC_PLL3DIVR_P3_Msk   (0x7FUL << RCC_PLL3DIVR_P3_Pos)
#define RCC_PLL3DIVR_P3   RCC_PLL3DIVR_P3_Msk
#define RCC_PLL3DIVR_Q3_Pos   (16U)
#define RCC_PLL3DIVR_Q3_Msk   (0x7FUL << RCC_PLL3DIVR_Q3_Pos)
#define RCC_PLL3DIVR_Q3   RCC_PLL3DIVR_Q3_Msk
#define RCC_PLL3DIVR_R3_Pos   (24U)
#define RCC_PLL3DIVR_R3_Msk   (0x7FUL << RCC_PLL3DIVR_R3_Pos)
#define RCC_PLL3DIVR_R3   RCC_PLL3DIVR_R3_Msk
#define RCC_PLL3FRACR_FRACN3_Pos   (3U)
#define RCC_PLL3FRACR_FRACN3_Msk   (0x1FFFUL << RCC_PLL3FRACR_FRACN3_Pos)
#define RCC_PLL3FRACR_FRACN3   RCC_PLL3FRACR_FRACN3_Msk
#define RCC_CDCCIPR_FMCSEL_Pos   (0U)
#define RCC_CDCCIPR_FMCSEL_Msk   (0x3UL << RCC_CDCCIPR_FMCSEL_Pos)
#define RCC_CDCCIPR_FMCSEL   RCC_CDCCIPR_FMCSEL_Msk
#define RCC_CDCCIPR_FMCSEL_0   (0x1UL << RCC_CDCCIPR_FMCSEL_Pos)
#define RCC_CDCCIPR_FMCSEL_1   (0x2UL << RCC_CDCCIPR_FMCSEL_Pos)
#define RCC_CDCCIPR_OCTOSPISEL_Pos   (4U)
#define RCC_CDCCIPR_OCTOSPISEL_Msk   (0x3UL << RCC_CDCCIPR_OCTOSPISEL_Pos)
#define RCC_CDCCIPR_OCTOSPISEL   RCC_CDCCIPR_OCTOSPISEL_Msk
#define RCC_CDCCIPR_OCTOSPISEL_0   (0x1UL << RCC_CDCCIPR_OCTOSPISEL_Pos)
#define RCC_CDCCIPR_OCTOSPISEL_1   (0x2UL << RCC_CDCCIPR_OCTOSPISEL_Pos)
#define RCC_CDCCIPR_SDMMCSEL_Pos   (16U)
#define RCC_CDCCIPR_SDMMCSEL_Msk   (0x1UL << RCC_CDCCIPR_SDMMCSEL_Pos)
#define RCC_CDCCIPR_SDMMCSEL   RCC_CDCCIPR_SDMMCSEL_Msk
#define RCC_CDCCIPR_CKPERSEL_Pos   (28U)
#define RCC_CDCCIPR_CKPERSEL_Msk   (0x3UL << RCC_CDCCIPR_CKPERSEL_Pos)
#define RCC_CDCCIPR_CKPERSEL   RCC_CDCCIPR_CKPERSEL_Msk
#define RCC_CDCCIPR_CKPERSEL_0   (0x1UL << RCC_CDCCIPR_CKPERSEL_Pos)
#define RCC_CDCCIPR_CKPERSEL_1   (0x2UL << RCC_CDCCIPR_CKPERSEL_Pos)
#define RCC_CDCCIP1R_SAI1SEL_Pos   (0U)
#define RCC_CDCCIP1R_SAI1SEL_Msk   (0x7UL << RCC_CDCCIP1R_SAI1SEL_Pos)
#define RCC_CDCCIP1R_SAI1SEL   RCC_CDCCIP1R_SAI1SEL_Msk
#define RCC_CDCCIP1R_SAI1SEL_0   (0x1UL << RCC_CDCCIP1R_SAI1SEL_Pos)
#define RCC_CDCCIP1R_SAI1SEL_1   (0x2UL << RCC_CDCCIP1R_SAI1SEL_Pos)
#define RCC_CDCCIP1R_SAI1SEL_2   (0x4UL << RCC_CDCCIP1R_SAI1SEL_Pos)
#define RCC_CDCCIP1R_SAI2ASEL_Pos   (6U)
#define RCC_CDCCIP1R_SAI2ASEL_Msk   (0x7UL << RCC_CDCCIP1R_SAI2ASEL_Pos)
#define RCC_CDCCIP1R_SAI2ASEL   RCC_CDCCIP1R_SAI2ASEL_Msk
#define RCC_CDCCIP1R_SAI2ASEL_0   (0x1UL << RCC_CDCCIP1R_SAI2ASEL_Pos)
#define RCC_CDCCIP1R_SAI2ASEL_1   (0x2UL << RCC_CDCCIP1R_SAI2ASEL_Pos)
#define RCC_CDCCIP1R_SAI2ASEL_2   (0x4UL << RCC_CDCCIP1R_SAI2ASEL_Pos)
#define RCC_CDCCIP1R_SAI2BSEL_Pos   (9U)
#define RCC_CDCCIP1R_SAI2BSEL_Msk   (0x7UL << RCC_CDCCIP1R_SAI2BSEL_Pos)
#define RCC_CDCCIP1R_SAI2BSEL   RCC_CDCCIP1R_SAI2BSEL_Msk
#define RCC_CDCCIP1R_SAI2BSEL_0   (0x1UL << RCC_CDCCIP1R_SAI2BSEL_Pos)
#define RCC_CDCCIP1R_SAI2BSEL_1   (0x2UL << RCC_CDCCIP1R_SAI2BSEL_Pos)
#define RCC_CDCCIP1R_SAI2BSEL_2   (0x4UL << RCC_CDCCIP1R_SAI2BSEL_Pos)
#define RCC_CDCCIP1R_SPI123SEL_Pos   (12U)
#define RCC_CDCCIP1R_SPI123SEL_Msk   (0x7UL << RCC_CDCCIP1R_SPI123SEL_Pos)
#define RCC_CDCCIP1R_SPI123SEL   RCC_CDCCIP1R_SPI123SEL_Msk
#define RCC_CDCCIP1R_SPI123SEL_0   (0x1UL << RCC_CDCCIP1R_SPI123SEL_Pos)
#define RCC_CDCCIP1R_SPI123SEL_1   (0x2UL << RCC_CDCCIP1R_SPI123SEL_Pos)
#define RCC_CDCCIP1R_SPI123SEL_2   (0x4UL << RCC_CDCCIP1R_SPI123SEL_Pos)
#define RCC_CDCCIP1R_SPI45SEL_Pos   (16U)
#define RCC_CDCCIP1R_SPI45SEL_Msk   (0x7UL << RCC_CDCCIP1R_SPI45SEL_Pos)
#define RCC_CDCCIP1R_SPI45SEL   RCC_CDCCIP1R_SPI45SEL_Msk
#define RCC_CDCCIP1R_SPI45SEL_0   (0x1UL << RCC_CDCCIP1R_SPI45SEL_Pos)
#define RCC_CDCCIP1R_SPI45SEL_1   (0x2UL << RCC_CDCCIP1R_SPI45SEL_Pos)
#define RCC_CDCCIP1R_SPI45SEL_2   (0x4UL << RCC_CDCCIP1R_SPI45SEL_Pos)
#define RCC_CDCCIP1R_SPDIFSEL_Pos   (20U)
#define RCC_CDCCIP1R_SPDIFSEL_Msk   (0x3UL << RCC_CDCCIP1R_SPDIFSEL_Pos)
#define RCC_CDCCIP1R_SPDIFSEL   RCC_CDCCIP1R_SPDIFSEL_Msk
#define RCC_CDCCIP1R_SPDIFSEL_0   (0x1UL << RCC_CDCCIP1R_SPDIFSEL_Pos)
#define RCC_CDCCIP1R_SPDIFSEL_1   (0x2UL << RCC_CDCCIP1R_SPDIFSEL_Pos)
#define RCC_CDCCIP1R_DFSDM1SEL_Pos   (24U)
#define RCC_CDCCIP1R_DFSDM1SEL_Msk   (0x1UL << RCC_CDCCIP1R_DFSDM1SEL_Pos)
#define RCC_CDCCIP1R_DFSDM1SEL   RCC_CDCCIP1R_DFSDM1SEL_Msk
#define RCC_CDCCIP1R_FDCANSEL_Pos   (28U)
#define RCC_CDCCIP1R_FDCANSEL_Msk   (0x3UL << RCC_CDCCIP1R_FDCANSEL_Pos)
#define RCC_CDCCIP1R_FDCANSEL   RCC_CDCCIP1R_FDCANSEL_Msk
#define RCC_CDCCIP1R_FDCANSEL_0   (0x1UL << RCC_CDCCIP1R_FDCANSEL_Pos)
#define RCC_CDCCIP1R_FDCANSEL_1   (0x2UL << RCC_CDCCIP1R_FDCANSEL_Pos)
#define RCC_CDCCIP1R_SWPSEL_Pos   (31U)
#define RCC_CDCCIP1R_SWPSEL_Msk   (0x1UL << RCC_CDCCIP1R_SWPSEL_Pos)
#define RCC_CDCCIP1R_SWPSEL   RCC_CDCCIP1R_SWPSEL_Msk
#define RCC_CDCCIP2R_USART234578SEL_Pos   (0U)
#define RCC_CDCCIP2R_USART234578SEL_Msk   (0x7UL << RCC_CDCCIP2R_USART234578SEL_Pos)
#define RCC_CDCCIP2R_USART234578SEL   RCC_CDCCIP2R_USART234578SEL_Msk
#define RCC_CDCCIP2R_USART234578SEL_0   (0x1UL << RCC_CDCCIP2R_USART234578SEL_Pos)
#define RCC_CDCCIP2R_USART234578SEL_1   (0x2UL << RCC_CDCCIP2R_USART234578SEL_Pos)
#define RCC_CDCCIP2R_USART234578SEL_2   (0x4UL << RCC_CDCCIP2R_USART234578SEL_Pos)
#define RCC_CDCCIP2R_USART16910SEL_Pos   (3U)
#define RCC_CDCCIP2R_USART16910SEL_Msk   (0x7UL << RCC_CDCCIP2R_USART16910SEL_Pos)
#define RCC_CDCCIP2R_USART16910SEL   RCC_CDCCIP2R_USART16910SEL_Msk
#define RCC_CDCCIP2R_USART16910SEL_0   (0x1UL << RCC_CDCCIP2R_USART16910SEL_Pos)
#define RCC_CDCCIP2R_USART16910SEL_1   (0x2UL << RCC_CDCCIP2R_USART16910SEL_Pos)
#define RCC_CDCCIP2R_USART16910SEL_2   (0x4UL << RCC_CDCCIP2R_USART16910SEL_Pos)
#define RCC_CDCCIP2R_RNGSEL_Pos   (8U)
#define RCC_CDCCIP2R_RNGSEL_Msk   (0x3UL << RCC_CDCCIP2R_RNGSEL_Pos)
#define RCC_CDCCIP2R_RNGSEL   RCC_CDCCIP2R_RNGSEL_Msk
#define RCC_CDCCIP2R_RNGSEL_0   (0x1UL << RCC_CDCCIP2R_RNGSEL_Pos)
#define RCC_CDCCIP2R_RNGSEL_1   (0x2UL << RCC_CDCCIP2R_RNGSEL_Pos)
#define RCC_CDCCIP2R_I2C123SEL_Pos   (12U)
#define RCC_CDCCIP2R_I2C123SEL_Msk   (0x3UL << RCC_CDCCIP2R_I2C123SEL_Pos)
#define RCC_CDCCIP2R_I2C123SEL   RCC_CDCCIP2R_I2C123SEL_Msk
#define RCC_CDCCIP2R_I2C123SEL_0   (0x1UL << RCC_CDCCIP2R_I2C123SEL_Pos)
#define RCC_CDCCIP2R_I2C123SEL_1   (0x2UL << RCC_CDCCIP2R_I2C123SEL_Pos)
#define RCC_CDCCIP2R_USBSEL_Pos   (20U)
#define RCC_CDCCIP2R_USBSEL_Msk   (0x3UL << RCC_CDCCIP2R_USBSEL_Pos)
#define RCC_CDCCIP2R_USBSEL   RCC_CDCCIP2R_USBSEL_Msk
#define RCC_CDCCIP2R_USBSEL_0   (0x1UL << RCC_CDCCIP2R_USBSEL_Pos)
#define RCC_CDCCIP2R_USBSEL_1   (0x2UL << RCC_CDCCIP2R_USBSEL_Pos)
#define RCC_CDCCIP2R_CECSEL_Pos   (22U)
#define RCC_CDCCIP2R_CECSEL_Msk   (0x3UL << RCC_CDCCIP2R_CECSEL_Pos)
#define RCC_CDCCIP2R_CECSEL   RCC_CDCCIP2R_CECSEL_Msk
#define RCC_CDCCIP2R_CECSEL_0   (0x1UL << RCC_CDCCIP2R_CECSEL_Pos)
#define RCC_CDCCIP2R_CECSEL_1   (0x2UL << RCC_CDCCIP2R_CECSEL_Pos)
#define RCC_CDCCIP2R_LPTIM1SEL_Pos   (28U)
#define RCC_CDCCIP2R_LPTIM1SEL_Msk   (0x7UL << RCC_CDCCIP2R_LPTIM1SEL_Pos)
#define RCC_CDCCIP2R_LPTIM1SEL   RCC_CDCCIP2R_LPTIM1SEL_Msk
#define RCC_CDCCIP2R_LPTIM1SEL_0   (0x1UL << RCC_CDCCIP2R_LPTIM1SEL_Pos)
#define RCC_CDCCIP2R_LPTIM1SEL_1   (0x2UL << RCC_CDCCIP2R_LPTIM1SEL_Pos)
#define RCC_CDCCIP2R_LPTIM1SEL_2   (0x4UL << RCC_CDCCIP2R_LPTIM1SEL_Pos)
#define RCC_SRDCCIPR_LPUART1SEL_Pos   (0U)
#define RCC_SRDCCIPR_LPUART1SEL_Msk   (0x7UL << RCC_SRDCCIPR_LPUART1SEL_Pos)
#define RCC_SRDCCIPR_LPUART1SEL   RCC_SRDCCIPR_LPUART1SEL_Msk
#define RCC_SRDCCIPR_LPUART1SEL_0   (0x1UL << RCC_SRDCCIPR_LPUART1SEL_Pos)
#define RCC_SRDCCIPR_LPUART1SEL_1   (0x2UL << RCC_SRDCCIPR_LPUART1SEL_Pos)
#define RCC_SRDCCIPR_LPUART1SEL_2   (0x4UL << RCC_SRDCCIPR_LPUART1SEL_Pos)
#define RCC_SRDCCIPR_I2C4SEL_Pos   (8U)
#define RCC_SRDCCIPR_I2C4SEL_Msk   (0x3UL << RCC_SRDCCIPR_I2C4SEL_Pos)
#define RCC_SRDCCIPR_I2C4SEL   RCC_SRDCCIPR_I2C4SEL_Msk
#define RCC_SRDCCIPR_I2C4SEL_0   (0x1UL << RCC_SRDCCIPR_I2C4SEL_Pos)
#define RCC_SRDCCIPR_I2C4SEL_1   (0x2UL << RCC_SRDCCIPR_I2C4SEL_Pos)
#define RCC_SRDCCIPR_LPTIM2SEL_Pos   (10U)
#define RCC_SRDCCIPR_LPTIM2SEL_Msk   (0x7UL << RCC_SRDCCIPR_LPTIM2SEL_Pos)
#define RCC_SRDCCIPR_LPTIM2SEL   RCC_SRDCCIPR_LPTIM2SEL_Msk
#define RCC_SRDCCIPR_LPTIM2SEL_0   (0x1UL << RCC_SRDCCIPR_LPTIM2SEL_Pos)
#define RCC_SRDCCIPR_LPTIM2SEL_1   (0x2UL << RCC_SRDCCIPR_LPTIM2SEL_Pos)
#define RCC_SRDCCIPR_LPTIM2SEL_2   (0x4UL << RCC_SRDCCIPR_LPTIM2SEL_Pos)
#define RCC_SRDCCIPR_LPTIM3SEL_Pos   (13U)
#define RCC_SRDCCIPR_LPTIM3SEL_Msk   (0x7UL << RCC_SRDCCIPR_LPTIM3SEL_Pos)
#define RCC_SRDCCIPR_LPTIM3SEL   RCC_SRDCCIPR_LPTIM3SEL_Msk
#define RCC_SRDCCIPR_LPTIM3SEL_0   (0x1UL << RCC_SRDCCIPR_LPTIM3SEL_Pos)
#define RCC_SRDCCIPR_LPTIM3SEL_1   (0x2UL << RCC_SRDCCIPR_LPTIM3SEL_Pos)
#define RCC_SRDCCIPR_LPTIM3SEL_2   (0x4UL << RCC_SRDCCIPR_LPTIM3SEL_Pos)
#define RCC_SRDCCIPR_ADCSEL_Pos   (16U)
#define RCC_SRDCCIPR_ADCSEL_Msk   (0x3UL << RCC_SRDCCIPR_ADCSEL_Pos)
#define RCC_SRDCCIPR_ADCSEL   RCC_SRDCCIPR_ADCSEL_Msk
#define RCC_SRDCCIPR_ADCSEL_0   (0x1UL << RCC_SRDCCIPR_ADCSEL_Pos)
#define RCC_SRDCCIPR_ADCSEL_1   (0x2UL << RCC_SRDCCIPR_ADCSEL_Pos)
#define RCC_SRDCCIPR_DFSDM2SEL_Pos   (27U)
#define RCC_SRDCCIPR_DFSDM2SEL_Msk   (0x1UL << RCC_SRDCCIPR_DFSDM2SEL_Pos)
#define RCC_SRDCCIPR_DFSDM2SEL   RCC_SRDCCIPR_DFSDM2SEL_Msk
#define RCC_SRDCCIPR_SPI6SEL_Pos   (28U)
#define RCC_SRDCCIPR_SPI6SEL_Msk   (0x7UL << RCC_SRDCCIPR_SPI6SEL_Pos)
#define RCC_SRDCCIPR_SPI6SEL   RCC_SRDCCIPR_SPI6SEL_Msk
#define RCC_SRDCCIPR_SPI6SEL_0   (0x1UL << RCC_SRDCCIPR_SPI6SEL_Pos)
#define RCC_SRDCCIPR_SPI6SEL_1   (0x2UL << RCC_SRDCCIPR_SPI6SEL_Pos)
#define RCC_SRDCCIPR_SPI6SEL_2   (0x4UL << RCC_SRDCCIPR_SPI6SEL_Pos)
#define RCC_CIER_LSIRDYIE_Pos   (0U)
#define RCC_CIER_LSIRDYIE_Msk   (0x1UL << RCC_CIER_LSIRDYIE_Pos)
#define RCC_CIER_LSIRDYIE   RCC_CIER_LSIRDYIE_Msk
#define RCC_CIER_LSERDYIE_Pos   (1U)
#define RCC_CIER_LSERDYIE_Msk   (0x1UL << RCC_CIER_LSERDYIE_Pos)
#define RCC_CIER_LSERDYIE   RCC_CIER_LSERDYIE_Msk
#define RCC_CIER_HSIRDYIE_Pos   (2U)
#define RCC_CIER_HSIRDYIE_Msk   (0x1UL << RCC_CIER_HSIRDYIE_Pos)
#define RCC_CIER_HSIRDYIE   RCC_CIER_HSIRDYIE_Msk
#define RCC_CIER_HSERDYIE_Pos   (3U)
#define RCC_CIER_HSERDYIE_Msk   (0x1UL << RCC_CIER_HSERDYIE_Pos)
#define RCC_CIER_HSERDYIE   RCC_CIER_HSERDYIE_Msk
#define RCC_CIER_CSIRDYIE_Pos   (4U)
#define RCC_CIER_CSIRDYIE_Msk   (0x1UL << RCC_CIER_CSIRDYIE_Pos)
#define RCC_CIER_CSIRDYIE   RCC_CIER_CSIRDYIE_Msk
#define RCC_CIER_HSI48RDYIE_Pos   (5U)
#define RCC_CIER_HSI48RDYIE_Msk   (0x1UL << RCC_CIER_HSI48RDYIE_Pos)
#define RCC_CIER_HSI48RDYIE   RCC_CIER_HSI48RDYIE_Msk
#define RCC_CIER_PLL1RDYIE_Pos   (6U)
#define RCC_CIER_PLL1RDYIE_Msk   (0x1UL << RCC_CIER_PLL1RDYIE_Pos)
#define RCC_CIER_PLL1RDYIE   RCC_CIER_PLL1RDYIE_Msk
#define RCC_CIER_PLL2RDYIE_Pos   (7U)
#define RCC_CIER_PLL2RDYIE_Msk   (0x1UL << RCC_CIER_PLL2RDYIE_Pos)
#define RCC_CIER_PLL2RDYIE   RCC_CIER_PLL2RDYIE_Msk
#define RCC_CIER_PLL3RDYIE_Pos   (8U)
#define RCC_CIER_PLL3RDYIE_Msk   (0x1UL << RCC_CIER_PLL3RDYIE_Pos)
#define RCC_CIER_PLL3RDYIE   RCC_CIER_PLL3RDYIE_Msk
#define RCC_CIER_LSECSSIE_Pos   (9U)
#define RCC_CIER_LSECSSIE_Msk   (0x1UL << RCC_CIER_LSECSSIE_Pos)
#define RCC_CIER_LSECSSIE   RCC_CIER_LSECSSIE_Msk
#define RCC_CIFR_LSIRDYF_Pos   (0U)
#define RCC_CIFR_LSIRDYF_Msk   (0x1UL << RCC_CIFR_LSIRDYF_Pos)
#define RCC_CIFR_LSIRDYF   RCC_CIFR_LSIRDYF_Msk
#define RCC_CIFR_LSERDYF_Pos   (1U)
#define RCC_CIFR_LSERDYF_Msk   (0x1UL << RCC_CIFR_LSERDYF_Pos)
#define RCC_CIFR_LSERDYF   RCC_CIFR_LSERDYF_Msk
#define RCC_CIFR_HSIRDYF_Pos   (2U)
#define RCC_CIFR_HSIRDYF_Msk   (0x1UL << RCC_CIFR_HSIRDYF_Pos)
#define RCC_CIFR_HSIRDYF   RCC_CIFR_HSIRDYF_Msk
#define RCC_CIFR_HSERDYF_Pos   (3U)
#define RCC_CIFR_HSERDYF_Msk   (0x1UL << RCC_CIFR_HSERDYF_Pos)
#define RCC_CIFR_HSERDYF   RCC_CIFR_HSERDYF_Msk
#define RCC_CIFR_CSIRDYF_Pos   (4U)
#define RCC_CIFR_CSIRDYF_Msk   (0x1UL << RCC_CIFR_CSIRDYF_Pos)
#define RCC_CIFR_CSIRDYF   RCC_CIFR_CSIRDYF_Msk
#define RCC_CIFR_HSI48RDYF_Pos   (5U)
#define RCC_CIFR_HSI48RDYF_Msk   (0x1UL << RCC_CIFR_HSI48RDYF_Pos)
#define RCC_CIFR_HSI48RDYF   RCC_CIFR_HSI48RDYF_Msk
#define RCC_CIFR_PLLRDYF_Pos   (6U)
#define RCC_CIFR_PLLRDYF_Msk   (0x1UL << RCC_CIFR_PLLRDYF_Pos)
#define RCC_CIFR_PLLRDYF   RCC_CIFR_PLLRDYF_Msk
#define RCC_CIFR_PLL2RDYF_Pos   (7U)
#define RCC_CIFR_PLL2RDYF_Msk   (0x1UL << RCC_CIFR_PLL2RDYF_Pos)
#define RCC_CIFR_PLL2RDYF   RCC_CIFR_PLL2RDYF_Msk
#define RCC_CIFR_PLL3RDYF_Pos   (8U)
#define RCC_CIFR_PLL3RDYF_Msk   (0x1UL << RCC_CIFR_PLL3RDYF_Pos)
#define RCC_CIFR_PLL3RDYF   RCC_CIFR_PLL3RDYF_Msk
#define RCC_CIFR_LSECSSF_Pos   (9U)
#define RCC_CIFR_LSECSSF_Msk   (0x1UL << RCC_CIFR_LSECSSF_Pos)
#define RCC_CIFR_LSECSSF   RCC_CIFR_LSECSSF_Msk
#define RCC_CIFR_HSECSSF_Pos   (10U)
#define RCC_CIFR_HSECSSF_Msk   (0x1UL << RCC_CIFR_HSECSSF_Pos)
#define RCC_CIFR_HSECSSF   RCC_CIFR_HSECSSF_Msk
#define RCC_CICR_LSIRDYC_Pos   (0U)
#define RCC_CICR_LSIRDYC_Msk   (0x1UL << RCC_CICR_LSIRDYC_Pos)
#define RCC_CICR_LSIRDYC   RCC_CICR_LSIRDYC_Msk
#define RCC_CICR_LSERDYC_Pos   (1U)
#define RCC_CICR_LSERDYC_Msk   (0x1UL << RCC_CICR_LSERDYC_Pos)
#define RCC_CICR_LSERDYC   RCC_CICR_LSERDYC_Msk
#define RCC_CICR_HSIRDYC_Pos   (2U)
#define RCC_CICR_HSIRDYC_Msk   (0x1UL << RCC_CICR_HSIRDYC_Pos)
#define RCC_CICR_HSIRDYC   RCC_CICR_HSIRDYC_Msk
#define RCC_CICR_HSERDYC_Pos   (3U)
#define RCC_CICR_HSERDYC_Msk   (0x1UL << RCC_CICR_HSERDYC_Pos)
#define RCC_CICR_HSERDYC   RCC_CICR_HSERDYC_Msk
#define RCC_CICR_CSIRDYC_Pos   (4U)
#define RCC_CICR_CSIRDYC_Msk   (0x1UL << RCC_CICR_CSIRDYC_Pos)
#define RCC_CICR_CSIRDYC   RCC_CICR_CSIRDYC_Msk
#define RCC_CICR_HSI48RDYC_Pos   (5U)
#define RCC_CICR_HSI48RDYC_Msk   (0x1UL << RCC_CICR_HSI48RDYC_Pos)
#define RCC_CICR_HSI48RDYC   RCC_CICR_HSI48RDYC_Msk
#define RCC_CICR_PLLRDYC_Pos   (6U)
#define RCC_CICR_PLLRDYC_Msk   (0x1UL << RCC_CICR_PLLRDYC_Pos)
#define RCC_CICR_PLLRDYC   RCC_CICR_PLLRDYC_Msk
#define RCC_CICR_PLL2RDYC_Pos   (7U)
#define RCC_CICR_PLL2RDYC_Msk   (0x1UL << RCC_CICR_PLL2RDYC_Pos)
#define RCC_CICR_PLL2RDYC   RCC_CICR_PLL2RDYC_Msk
#define RCC_CICR_PLL3RDYC_Pos   (8U)
#define RCC_CICR_PLL3RDYC_Msk   (0x1UL << RCC_CICR_PLL3RDYC_Pos)
#define RCC_CICR_PLL3RDYC   RCC_CICR_PLL3RDYC_Msk
#define RCC_CICR_LSECSSC_Pos   (9U)
#define RCC_CICR_LSECSSC_Msk   (0x1UL << RCC_CICR_LSECSSC_Pos)
#define RCC_CICR_LSECSSC   RCC_CICR_LSECSSC_Msk
#define RCC_CICR_HSECSSC_Pos   (10U)
#define RCC_CICR_HSECSSC_Msk   (0x1UL << RCC_CICR_HSECSSC_Pos)
#define RCC_CICR_HSECSSC   RCC_CICR_HSECSSC_Msk
#define RCC_BDCR_LSEON_Pos   (0U)
#define RCC_BDCR_LSEON_Msk   (0x1UL << RCC_BDCR_LSEON_Pos)
#define RCC_BDCR_LSEON   RCC_BDCR_LSEON_Msk
#define RCC_BDCR_LSERDY_Pos   (1U)
#define RCC_BDCR_LSERDY_Msk   (0x1UL << RCC_BDCR_LSERDY_Pos)
#define RCC_BDCR_LSERDY   RCC_BDCR_LSERDY_Msk
#define RCC_BDCR_LSEBYP_Pos   (2U)
#define RCC_BDCR_LSEBYP_Msk   (0x1UL << RCC_BDCR_LSEBYP_Pos)
#define RCC_BDCR_LSEBYP   RCC_BDCR_LSEBYP_Msk
#define RCC_BDCR_LSEDRV_Pos   (3U)
#define RCC_BDCR_LSEDRV_Msk   (0x3UL << RCC_BDCR_LSEDRV_Pos)
#define RCC_BDCR_LSEDRV   RCC_BDCR_LSEDRV_Msk
#define RCC_BDCR_LSEDRV_0   (0x1UL << RCC_BDCR_LSEDRV_Pos)
#define RCC_BDCR_LSEDRV_1   (0x2UL << RCC_BDCR_LSEDRV_Pos)
#define RCC_BDCR_LSECSSON_Pos   (5U)
#define RCC_BDCR_LSECSSON_Msk   (0x1UL << RCC_BDCR_LSECSSON_Pos)
#define RCC_BDCR_LSECSSON   RCC_BDCR_LSECSSON_Msk
#define RCC_BDCR_LSECSSD_Pos   (6U)
#define RCC_BDCR_LSECSSD_Msk   (0x1UL << RCC_BDCR_LSECSSD_Pos)
#define RCC_BDCR_LSECSSD   RCC_BDCR_LSECSSD_Msk
#define RCC_BDCR_LSEEXT_Pos   (7U)
#define RCC_BDCR_LSEEXT_Msk   (0x1UL << RCC_BDCR_LSEEXT_Pos)
#define RCC_BDCR_LSEEXT   RCC_BDCR_LSEEXT_Msk
#define RCC_BDCR_RTCSEL_Pos   (8U)
#define RCC_BDCR_RTCSEL_Msk   (0x3UL << RCC_BDCR_RTCSEL_Pos)
#define RCC_BDCR_RTCSEL   RCC_BDCR_RTCSEL_Msk
#define RCC_BDCR_RTCSEL_0   (0x1UL << RCC_BDCR_RTCSEL_Pos)
#define RCC_BDCR_RTCSEL_1   (0x2UL << RCC_BDCR_RTCSEL_Pos)
#define RCC_BDCR_RTCEN_Pos   (15U)
#define RCC_BDCR_RTCEN_Msk   (0x1UL << RCC_BDCR_RTCEN_Pos)
#define RCC_BDCR_RTCEN   RCC_BDCR_RTCEN_Msk
#define RCC_BDCR_VSWRST_Pos   (16U)
#define RCC_BDCR_VSWRST_Msk   (0x1UL << RCC_BDCR_VSWRST_Pos)
#define RCC_BDCR_VSWRST   RCC_BDCR_VSWRST_Msk
#define RCC_BDCR_BDRST_Pos   RCC_BDCR_VSWRST_Pos
#define RCC_BDCR_BDRST_Msk   RCC_BDCR_VSWRST_Msk
#define RCC_BDCR_BDRST   RCC_BDCR_VSWRST
#define RCC_CSR_LSION_Pos   (0U)
#define RCC_CSR_LSION_Msk   (0x1UL << RCC_CSR_LSION_Pos)
#define RCC_CSR_LSION   RCC_CSR_LSION_Msk
#define RCC_CSR_LSIRDY_Pos   (1U)
#define RCC_CSR_LSIRDY_Msk   (0x1UL << RCC_CSR_LSIRDY_Pos)
#define RCC_CSR_LSIRDY   RCC_CSR_LSIRDY_Msk
#define RCC_AHB3ENR_MDMAEN_Pos   (0U)
#define RCC_AHB3ENR_MDMAEN_Msk   (0x1UL << RCC_AHB3ENR_MDMAEN_Pos)
#define RCC_AHB3ENR_MDMAEN   RCC_AHB3ENR_MDMAEN_Msk
#define RCC_AHB3ENR_DMA2DEN_Pos   (4U)
#define RCC_AHB3ENR_DMA2DEN_Msk   (0x1UL << RCC_AHB3ENR_DMA2DEN_Pos)
#define RCC_AHB3ENR_DMA2DEN   RCC_AHB3ENR_DMA2DEN_Msk
#define RCC_AHB3ENR_JPGDECEN_Pos   (5U)
#define RCC_AHB3ENR_JPGDECEN_Msk   (0x1UL << RCC_AHB3ENR_JPGDECEN_Pos)
#define RCC_AHB3ENR_JPGDECEN   RCC_AHB3ENR_JPGDECEN_Msk
#define RCC_AHB3ENR_FMCEN_Pos   (12U)
#define RCC_AHB3ENR_FMCEN_Msk   (0x1UL << RCC_AHB3ENR_FMCEN_Pos)
#define RCC_AHB3ENR_FMCEN   RCC_AHB3ENR_FMCEN_Msk
#define RCC_AHB3ENR_OSPI1EN_Pos   (14U)
#define RCC_AHB3ENR_OSPI1EN_Msk   (0x1UL << RCC_AHB3ENR_OSPI1EN_Pos)
#define RCC_AHB3ENR_OSPI1EN   RCC_AHB3ENR_OSPI1EN_Msk
#define RCC_AHB3ENR_SDMMC1EN_Pos   (16U)
#define RCC_AHB3ENR_SDMMC1EN_Msk   (0x1UL << RCC_AHB3ENR_SDMMC1EN_Pos)
#define RCC_AHB3ENR_SDMMC1EN   RCC_AHB3ENR_SDMMC1EN_Msk
#define RCC_AHB3ENR_OSPI2EN_Pos   (19U)
#define RCC_AHB3ENR_OSPI2EN_Msk   (0x1UL << RCC_AHB3ENR_OSPI2EN_Pos)
#define RCC_AHB3ENR_OSPI2EN   RCC_AHB3ENR_OSPI2EN_Msk
#define RCC_AHB3ENR_IOMNGREN_Pos   (21U)
#define RCC_AHB3ENR_IOMNGREN_Msk   (0x1UL << RCC_AHB3ENR_IOMNGREN_Pos)
#define RCC_AHB3ENR_IOMNGREN   RCC_AHB3ENR_IOMNGREN_Msk
#define RCC_AHB3ENR_GFXMMUEN_Pos   (24U)
#define RCC_AHB3ENR_GFXMMUEN_Msk   (0x1UL << RCC_AHB3ENR_GFXMMUEN_Pos)
#define RCC_AHB3ENR_GFXMMUEN   RCC_AHB3ENR_GFXMMUEN_Msk
#define RCC_AHB1ENR_DMA1EN_Pos   (0U)
#define RCC_AHB1ENR_DMA1EN_Msk   (0x1UL << RCC_AHB1ENR_DMA1EN_Pos)
#define RCC_AHB1ENR_DMA1EN   RCC_AHB1ENR_DMA1EN_Msk
#define RCC_AHB1ENR_DMA2EN_Pos   (1U)
#define RCC_AHB1ENR_DMA2EN_Msk   (0x1UL << RCC_AHB1ENR_DMA2EN_Pos)
#define RCC_AHB1ENR_DMA2EN   RCC_AHB1ENR_DMA2EN_Msk
#define RCC_AHB1ENR_ADC12EN_Pos   (5U)
#define RCC_AHB1ENR_ADC12EN_Msk   (0x1UL << RCC_AHB1ENR_ADC12EN_Pos)
#define RCC_AHB1ENR_ADC12EN   RCC_AHB1ENR_ADC12EN_Msk
#define RCC_AHB1ENR_CRCEN_Pos   (9U)
#define RCC_AHB1ENR_CRCEN_Msk   (0x1UL << RCC_AHB1ENR_CRCEN_Pos)
#define RCC_AHB1ENR_CRCEN   RCC_AHB1ENR_CRCEN_Msk
#define RCC_AHB1ENR_USB1OTGHSEN_Pos   (25U)
#define RCC_AHB1ENR_USB1OTGHSEN_Msk   (0x1UL << RCC_AHB1ENR_USB1OTGHSEN_Pos)
#define RCC_AHB1ENR_USB1OTGHSEN   RCC_AHB1ENR_USB1OTGHSEN_Msk
#define RCC_AHB1ENR_USB1OTGHSULPIEN_Pos   (26U)
#define RCC_AHB1ENR_USB1OTGHSULPIEN_Msk   (0x1UL << RCC_AHB1ENR_USB1OTGHSULPIEN_Pos)
#define RCC_AHB1ENR_USB1OTGHSULPIEN   RCC_AHB1ENR_USB1OTGHSULPIEN_Msk
#define RCC_AHB2ENR_DCMI_PSSIEN_Pos   (0U)
#define RCC_AHB2ENR_DCMI_PSSIEN_Msk   (0x1UL << RCC_AHB2ENR_DCMI_PSSIEN_Pos)
#define RCC_AHB2ENR_DCMI_PSSIEN   RCC_AHB2ENR_DCMI_PSSIEN_Msk
#define RCC_AHB2ENR_HSEMEN_Pos   (2U)
#define RCC_AHB2ENR_HSEMEN_Msk   (0x1UL << RCC_AHB2ENR_HSEMEN_Pos)
#define RCC_AHB2ENR_HSEMEN   RCC_AHB2ENR_HSEMEN_Msk
#define RCC_AHB2ENR_RNGEN_Pos   (6U)
#define RCC_AHB2ENR_RNGEN_Msk   (0x1UL << RCC_AHB2ENR_RNGEN_Pos)
#define RCC_AHB2ENR_RNGEN   RCC_AHB2ENR_RNGEN_Msk
#define RCC_AHB2ENR_SDMMC2EN_Pos   (9U)
#define RCC_AHB2ENR_SDMMC2EN_Msk   (0x1UL << RCC_AHB2ENR_SDMMC2EN_Pos)
#define RCC_AHB2ENR_SDMMC2EN   RCC_AHB2ENR_SDMMC2EN_Msk
#define RCC_AHB2ENR_BDMA1EN_Pos   (11U)
#define RCC_AHB2ENR_BDMA1EN_Msk   (0x1UL << RCC_AHB2ENR_BDMA1EN_Pos)
#define RCC_AHB2ENR_BDMA1EN   RCC_AHB2ENR_BDMA1EN_Msk
#define RCC_AHB2ENR_AHBSRAM1EN_Pos   (29U)
#define RCC_AHB2ENR_AHBSRAM1EN_Msk   (0x1UL << RCC_AHB2ENR_AHBSRAM1EN_Pos)
#define RCC_AHB2ENR_AHBSRAM1EN   RCC_AHB2ENR_AHBSRAM1EN_Msk
#define RCC_AHB2ENR_AHBSRAM2EN_Pos   (30U)
#define RCC_AHB2ENR_AHBSRAM2EN_Msk   (0x1UL << RCC_AHB2ENR_AHBSRAM2EN_Pos)
#define RCC_AHB2ENR_AHBSRAM2EN   RCC_AHB2ENR_AHBSRAM2EN_Msk
#define RCC_AHB2ENR_DCMIEN_Pos   RCC_AHB2ENR_DCMI_PSSIEN_Pos
#define RCC_AHB2ENR_DCMIEN_Msk   RCC_AHB2ENR_DCMI_PSSIEN_Msk
#define RCC_AHB2ENR_DCMIEN   RCC_AHB2ENR_DCMI_PSSIEN
#define RCC_AHB4ENR_GPIOAEN_Pos   (0U)
#define RCC_AHB4ENR_GPIOAEN_Msk   (0x1UL << RCC_AHB4ENR_GPIOAEN_Pos)
#define RCC_AHB4ENR_GPIOAEN   RCC_AHB4ENR_GPIOAEN_Msk
#define RCC_AHB4ENR_GPIOBEN_Pos   (1U)
#define RCC_AHB4ENR_GPIOBEN_Msk   (0x1UL << RCC_AHB4ENR_GPIOBEN_Pos)
#define RCC_AHB4ENR_GPIOBEN   RCC_AHB4ENR_GPIOBEN_Msk
#define RCC_AHB4ENR_GPIOCEN_Pos   (2U)
#define RCC_AHB4ENR_GPIOCEN_Msk   (0x1UL << RCC_AHB4ENR_GPIOCEN_Pos)
#define RCC_AHB4ENR_GPIOCEN   RCC_AHB4ENR_GPIOCEN_Msk
#define RCC_AHB4ENR_GPIODEN_Pos   (3U)
#define RCC_AHB4ENR_GPIODEN_Msk   (0x1UL << RCC_AHB4ENR_GPIODEN_Pos)
#define RCC_AHB4ENR_GPIODEN   RCC_AHB4ENR_GPIODEN_Msk
#define RCC_AHB4ENR_GPIOEEN_Pos   (4U)
#define RCC_AHB4ENR_GPIOEEN_Msk   (0x1UL << RCC_AHB4ENR_GPIOEEN_Pos)
#define RCC_AHB4ENR_GPIOEEN   RCC_AHB4ENR_GPIOEEN_Msk
#define RCC_AHB4ENR_GPIOFEN_Pos   (5U)
#define RCC_AHB4ENR_GPIOFEN_Msk   (0x1UL << RCC_AHB4ENR_GPIOFEN_Pos)
#define RCC_AHB4ENR_GPIOFEN   RCC_AHB4ENR_GPIOFEN_Msk
#define RCC_AHB4ENR_GPIOGEN_Pos   (6U)
#define RCC_AHB4ENR_GPIOGEN_Msk   (0x1UL << RCC_AHB4ENR_GPIOGEN_Pos)
#define RCC_AHB4ENR_GPIOGEN   RCC_AHB4ENR_GPIOGEN_Msk
#define RCC_AHB4ENR_GPIOHEN_Pos   (7U)
#define RCC_AHB4ENR_GPIOHEN_Msk   (0x1UL << RCC_AHB4ENR_GPIOHEN_Pos)
#define RCC_AHB4ENR_GPIOHEN   RCC_AHB4ENR_GPIOHEN_Msk
#define RCC_AHB4ENR_GPIOIEN_Pos   (8U)
#define RCC_AHB4ENR_GPIOIEN_Msk   (0x1UL << RCC_AHB4ENR_GPIOIEN_Pos)
#define RCC_AHB4ENR_GPIOIEN   RCC_AHB4ENR_GPIOIEN_Msk
#define RCC_AHB4ENR_GPIOJEN_Pos   (9U)
#define RCC_AHB4ENR_GPIOJEN_Msk   (0x1UL << RCC_AHB4ENR_GPIOJEN_Pos)
#define RCC_AHB4ENR_GPIOJEN   RCC_AHB4ENR_GPIOJEN_Msk
#define RCC_AHB4ENR_GPIOKEN_Pos   (10U)
#define RCC_AHB4ENR_GPIOKEN_Msk   (0x1UL << RCC_AHB4ENR_GPIOKEN_Pos)
#define RCC_AHB4ENR_GPIOKEN   RCC_AHB4ENR_GPIOKEN_Msk
#define RCC_AHB4ENR_BDMA2EN_Pos   (21U)
#define RCC_AHB4ENR_BDMA2EN_Msk   (0x1UL << RCC_AHB4ENR_BDMA2EN_Pos)
#define RCC_AHB4ENR_BDMA2EN   RCC_AHB4ENR_BDMA2EN_Msk
#define RCC_AHB4ENR_BKPRAMEN_Pos   (28U)
#define RCC_AHB4ENR_BKPRAMEN_Msk   (0x1UL << RCC_AHB4ENR_BKPRAMEN_Pos)
#define RCC_AHB4ENR_BKPRAMEN   RCC_AHB4ENR_BKPRAMEN_Msk
#define RCC_AHB4ENR_SRDSRAMEN_Pos   (29U)
#define RCC_AHB4ENR_SRDSRAMEN_Msk   (0x1UL << RCC_AHB4ENR_SRDSRAMEN_Pos)
#define RCC_AHB4ENR_SRDSRAMEN   RCC_AHB4ENR_SRDSRAMEN_Msk
#define RCC_APB3ENR_LTDCEN_Pos   (3U)
#define RCC_APB3ENR_LTDCEN_Msk   (0x1UL << RCC_APB3ENR_LTDCEN_Pos)
#define RCC_APB3ENR_LTDCEN   RCC_APB3ENR_LTDCEN_Msk
#define RCC_APB3ENR_WWDGEN_Pos   (6U)
#define RCC_APB3ENR_WWDGEN_Msk   (0x1UL << RCC_APB3ENR_WWDGEN_Pos)
#define RCC_APB3ENR_WWDGEN   RCC_APB3ENR_WWDGEN_Msk
#define RCC_APB3ENR_WWDG1EN_Pos   RCC_APB3ENR_WWDGEN_Pos
#define RCC_APB3ENR_WWDG1EN_Msk   RCC_APB3ENR_WWDGEN_Msk
#define RCC_APB3ENR_WWDG1EN   RCC_APB3ENR_WWDGEN
#define RCC_APB1LENR_TIM2EN_Pos   (0U)
#define RCC_APB1LENR_TIM2EN_Msk   (0x1UL << RCC_APB1LENR_TIM2EN_Pos)
#define RCC_APB1LENR_TIM2EN   RCC_APB1LENR_TIM2EN_Msk
#define RCC_APB1LENR_TIM3EN_Pos   (1U)
#define RCC_APB1LENR_TIM3EN_Msk   (0x1UL << RCC_APB1LENR_TIM3EN_Pos)
#define RCC_APB1LENR_TIM3EN   RCC_APB1LENR_TIM3EN_Msk
#define RCC_APB1LENR_TIM4EN_Pos   (2U)
#define RCC_APB1LENR_TIM4EN_Msk   (0x1UL << RCC_APB1LENR_TIM4EN_Pos)
#define RCC_APB1LENR_TIM4EN   RCC_APB1LENR_TIM4EN_Msk
#define RCC_APB1LENR_TIM5EN_Pos   (3U)
#define RCC_APB1LENR_TIM5EN_Msk   (0x1UL << RCC_APB1LENR_TIM5EN_Pos)
#define RCC_APB1LENR_TIM5EN   RCC_APB1LENR_TIM5EN_Msk
#define RCC_APB1LENR_TIM6EN_Pos   (4U)
#define RCC_APB1LENR_TIM6EN_Msk   (0x1UL << RCC_APB1LENR_TIM6EN_Pos)
#define RCC_APB1LENR_TIM6EN   RCC_APB1LENR_TIM6EN_Msk
#define RCC_APB1LENR_TIM7EN_Pos   (5U)
#define RCC_APB1LENR_TIM7EN_Msk   (0x1UL << RCC_APB1LENR_TIM7EN_Pos)
#define RCC_APB1LENR_TIM7EN   RCC_APB1LENR_TIM7EN_Msk
#define RCC_APB1LENR_TIM12EN_Pos   (6U)
#define RCC_APB1LENR_TIM12EN_Msk   (0x1UL << RCC_APB1LENR_TIM12EN_Pos)
#define RCC_APB1LENR_TIM12EN   RCC_APB1LENR_TIM12EN_Msk
#define RCC_APB1LENR_TIM13EN_Pos   (7U)
#define RCC_APB1LENR_TIM13EN_Msk   (0x1UL << RCC_APB1LENR_TIM13EN_Pos)
#define RCC_APB1LENR_TIM13EN   RCC_APB1LENR_TIM13EN_Msk
#define RCC_APB1LENR_TIM14EN_Pos   (8U)
#define RCC_APB1LENR_TIM14EN_Msk   (0x1UL << RCC_APB1LENR_TIM14EN_Pos)
#define RCC_APB1LENR_TIM14EN   RCC_APB1LENR_TIM14EN_Msk
#define RCC_APB1LENR_LPTIM1EN_Pos   (9U)
#define RCC_APB1LENR_LPTIM1EN_Msk   (0x1UL << RCC_APB1LENR_LPTIM1EN_Pos)
#define RCC_APB1LENR_LPTIM1EN   RCC_APB1LENR_LPTIM1EN_Msk
#define RCC_APB1LENR_SPI2EN_Pos   (14U)
#define RCC_APB1LENR_SPI2EN_Msk   (0x1UL << RCC_APB1LENR_SPI2EN_Pos)
#define RCC_APB1LENR_SPI2EN   RCC_APB1LENR_SPI2EN_Msk
#define RCC_APB1LENR_SPI3EN_Pos   (15U)
#define RCC_APB1LENR_SPI3EN_Msk   (0x1UL << RCC_APB1LENR_SPI3EN_Pos)
#define RCC_APB1LENR_SPI3EN   RCC_APB1LENR_SPI3EN_Msk
#define RCC_APB1LENR_SPDIFRXEN_Pos   (16U)
#define RCC_APB1LENR_SPDIFRXEN_Msk   (0x1UL << RCC_APB1LENR_SPDIFRXEN_Pos)
#define RCC_APB1LENR_SPDIFRXEN   RCC_APB1LENR_SPDIFRXEN_Msk
#define RCC_APB1LENR_USART2EN_Pos   (17U)
#define RCC_APB1LENR_USART2EN_Msk   (0x1UL << RCC_APB1LENR_USART2EN_Pos)
#define RCC_APB1LENR_USART2EN   RCC_APB1LENR_USART2EN_Msk
#define RCC_APB1LENR_USART3EN_Pos   (18U)
#define RCC_APB1LENR_USART3EN_Msk   (0x1UL << RCC_APB1LENR_USART3EN_Pos)
#define RCC_APB1LENR_USART3EN   RCC_APB1LENR_USART3EN_Msk
#define RCC_APB1LENR_UART4EN_Pos   (19U)
#define RCC_APB1LENR_UART4EN_Msk   (0x1UL << RCC_APB1LENR_UART4EN_Pos)
#define RCC_APB1LENR_UART4EN   RCC_APB1LENR_UART4EN_Msk
#define RCC_APB1LENR_UART5EN_Pos   (20U)
#define RCC_APB1LENR_UART5EN_Msk   (0x1UL << RCC_APB1LENR_UART5EN_Pos)
#define RCC_APB1LENR_UART5EN   RCC_APB1LENR_UART5EN_Msk
#define RCC_APB1LENR_I2C1EN_Pos   (21U)
#define RCC_APB1LENR_I2C1EN_Msk   (0x1UL << RCC_APB1LENR_I2C1EN_Pos)
#define RCC_APB1LENR_I2C1EN   RCC_APB1LENR_I2C1EN_Msk
#define RCC_APB1LENR_I2C2EN_Pos   (22U)
#define RCC_APB1LENR_I2C2EN_Msk   (0x1UL << RCC_APB1LENR_I2C2EN_Pos)
#define RCC_APB1LENR_I2C2EN   RCC_APB1LENR_I2C2EN_Msk
#define RCC_APB1LENR_I2C3EN_Pos   (23U)
#define RCC_APB1LENR_I2C3EN_Msk   (0x1UL << RCC_APB1LENR_I2C3EN_Pos)
#define RCC_APB1LENR_I2C3EN   RCC_APB1LENR_I2C3EN_Msk
#define RCC_APB1LENR_CECEN_Pos   (27U)
#define RCC_APB1LENR_CECEN_Msk   (0x1UL << RCC_APB1LENR_CECEN_Pos)
#define RCC_APB1LENR_CECEN   RCC_APB1LENR_CECEN_Msk
#define RCC_APB1LENR_DAC12EN_Pos   (29U)
#define RCC_APB1LENR_DAC12EN_Msk   (0x1UL << RCC_APB1LENR_DAC12EN_Pos)
#define RCC_APB1LENR_DAC12EN   RCC_APB1LENR_DAC12EN_Msk
#define RCC_APB1LENR_UART7EN_Pos   (30U)
#define RCC_APB1LENR_UART7EN_Msk   (0x1UL << RCC_APB1LENR_UART7EN_Pos)
#define RCC_APB1LENR_UART7EN   RCC_APB1LENR_UART7EN_Msk
#define RCC_APB1LENR_UART8EN_Pos   (31U)
#define RCC_APB1LENR_UART8EN_Msk   (0x1UL << RCC_APB1LENR_UART8EN_Pos)
#define RCC_APB1LENR_UART8EN   RCC_APB1LENR_UART8EN_Msk
#define RCC_APB1LENR_HDMICECEN_Pos   RCC_APB1LENR_CECEN_Pos
#define RCC_APB1LENR_HDMICECEN_Msk   RCC_APB1LENR_CECEN_Msk
#define RCC_APB1LENR_HDMICECEN   RCC_APB1LENR_CECEN
#define RCC_APB1HENR_CRSEN_Pos   (1U)
#define RCC_APB1HENR_CRSEN_Msk   (0x1UL << RCC_APB1HENR_CRSEN_Pos)
#define RCC_APB1HENR_CRSEN   RCC_APB1HENR_CRSEN_Msk
#define RCC_APB1HENR_SWPMIEN_Pos   (2U)
#define RCC_APB1HENR_SWPMIEN_Msk   (0x1UL << RCC_APB1HENR_SWPMIEN_Pos)
#define RCC_APB1HENR_SWPMIEN   RCC_APB1HENR_SWPMIEN_Msk
#define RCC_APB1HENR_OPAMPEN_Pos   (4U)
#define RCC_APB1HENR_OPAMPEN_Msk   (0x1UL << RCC_APB1HENR_OPAMPEN_Pos)
#define RCC_APB1HENR_OPAMPEN   RCC_APB1HENR_OPAMPEN_Msk
#define RCC_APB1HENR_MDIOSEN_Pos   (5U)
#define RCC_APB1HENR_MDIOSEN_Msk   (0x1UL << RCC_APB1HENR_MDIOSEN_Pos)
#define RCC_APB1HENR_MDIOSEN   RCC_APB1HENR_MDIOSEN_Msk
#define RCC_APB1HENR_FDCANEN_Pos   (8U)
#define RCC_APB1HENR_FDCANEN_Msk   (0x1UL << RCC_APB1HENR_FDCANEN_Pos)
#define RCC_APB1HENR_FDCANEN   RCC_APB1HENR_FDCANEN_Msk
#define RCC_APB2ENR_TIM1EN_Pos   (0U)
#define RCC_APB2ENR_TIM1EN_Msk   (0x1UL << RCC_APB2ENR_TIM1EN_Pos)
#define RCC_APB2ENR_TIM1EN   RCC_APB2ENR_TIM1EN_Msk
#define RCC_APB2ENR_TIM8EN_Pos   (1U)
#define RCC_APB2ENR_TIM8EN_Msk   (0x1UL << RCC_APB2ENR_TIM8EN_Pos)
#define RCC_APB2ENR_TIM8EN   RCC_APB2ENR_TIM8EN_Msk
#define RCC_APB2ENR_USART1EN_Pos   (4U)
#define RCC_APB2ENR_USART1EN_Msk   (0x1UL << RCC_APB2ENR_USART1EN_Pos)
#define RCC_APB2ENR_USART1EN   RCC_APB2ENR_USART1EN_Msk
#define RCC_APB2ENR_USART6EN_Pos   (5U)
#define RCC_APB2ENR_USART6EN_Msk   (0x1UL << RCC_APB2ENR_USART6EN_Pos)
#define RCC_APB2ENR_USART6EN   RCC_APB2ENR_USART6EN_Msk
#define RCC_APB2ENR_UART9EN_Pos   (6U)
#define RCC_APB2ENR_UART9EN_Msk   (0x1UL << RCC_APB2ENR_UART9EN_Pos)
#define RCC_APB2ENR_UART9EN   RCC_APB2ENR_UART9EN_Msk
#define RCC_APB2ENR_USART10EN_Pos   (7U)
#define RCC_APB2ENR_USART10EN_Msk   (0x1UL << RCC_APB2ENR_USART10EN_Pos)
#define RCC_APB2ENR_USART10EN   RCC_APB2ENR_USART10EN_Msk
#define RCC_APB2ENR_SPI1EN_Pos   (12U)
#define RCC_APB2ENR_SPI1EN_Msk   (0x1UL << RCC_APB2ENR_SPI1EN_Pos)
#define RCC_APB2ENR_SPI1EN   RCC_APB2ENR_SPI1EN_Msk
#define RCC_APB2ENR_SPI4EN_Pos   (13U)
#define RCC_APB2ENR_SPI4EN_Msk   (0x1UL << RCC_APB2ENR_SPI4EN_Pos)
#define RCC_APB2ENR_SPI4EN   RCC_APB2ENR_SPI4EN_Msk
#define RCC_APB2ENR_TIM15EN_Pos   (16U)
#define RCC_APB2ENR_TIM15EN_Msk   (0x1UL << RCC_APB2ENR_TIM15EN_Pos)
#define RCC_APB2ENR_TIM15EN   RCC_APB2ENR_TIM15EN_Msk
#define RCC_APB2ENR_TIM16EN_Pos   (17U)
#define RCC_APB2ENR_TIM16EN_Msk   (0x1UL << RCC_APB2ENR_TIM16EN_Pos)
#define RCC_APB2ENR_TIM16EN   RCC_APB2ENR_TIM16EN_Msk
#define RCC_APB2ENR_TIM17EN_Pos   (18U)
#define RCC_APB2ENR_TIM17EN_Msk   (0x1UL << RCC_APB2ENR_TIM17EN_Pos)
#define RCC_APB2ENR_TIM17EN   RCC_APB2ENR_TIM17EN_Msk
#define RCC_APB2ENR_SPI5EN_Pos   (20U)
#define RCC_APB2ENR_SPI5EN_Msk   (0x1UL << RCC_APB2ENR_SPI5EN_Pos)
#define RCC_APB2ENR_SPI5EN   RCC_APB2ENR_SPI5EN_Msk
#define RCC_APB2ENR_SAI1EN_Pos   (22U)
#define RCC_APB2ENR_SAI1EN_Msk   (0x1UL << RCC_APB2ENR_SAI1EN_Pos)
#define RCC_APB2ENR_SAI1EN   RCC_APB2ENR_SAI1EN_Msk
#define RCC_APB2ENR_SAI2EN_Pos   (23U)
#define RCC_APB2ENR_SAI2EN_Msk   (0x1UL << RCC_APB2ENR_SAI2EN_Pos)
#define RCC_APB2ENR_SAI2EN   RCC_APB2ENR_SAI2EN_Msk
#define RCC_APB2ENR_DFSDM1EN_Pos   (30U)
#define RCC_APB2ENR_DFSDM1EN_Msk   (0x1UL << RCC_APB2ENR_DFSDM1EN_Pos)
#define RCC_APB2ENR_DFSDM1EN   RCC_APB2ENR_DFSDM1EN_Msk
#define RCC_APB4ENR_SYSCFGEN_Pos   (1U)
#define RCC_APB4ENR_SYSCFGEN_Msk   (0x1UL << RCC_APB4ENR_SYSCFGEN_Pos)
#define RCC_APB4ENR_SYSCFGEN   RCC_APB4ENR_SYSCFGEN_Msk
#define RCC_APB4ENR_LPUART1EN_Pos   (3U)
#define RCC_APB4ENR_LPUART1EN_Msk   (0x1UL << RCC_APB4ENR_LPUART1EN_Pos)
#define RCC_APB4ENR_LPUART1EN   RCC_APB4ENR_LPUART1EN_Msk
#define RCC_APB4ENR_SPI6EN_Pos   (5U)
#define RCC_APB4ENR_SPI6EN_Msk   (0x1UL << RCC_APB4ENR_SPI6EN_Pos)
#define RCC_APB4ENR_SPI6EN   RCC_APB4ENR_SPI6EN_Msk
#define RCC_APB4ENR_I2C4EN_Pos   (7U)
#define RCC_APB4ENR_I2C4EN_Msk   (0x1UL << RCC_APB4ENR_I2C4EN_Pos)
#define RCC_APB4ENR_I2C4EN   RCC_APB4ENR_I2C4EN_Msk
#define RCC_APB4ENR_LPTIM2EN_Pos   (9U)
#define RCC_APB4ENR_LPTIM2EN_Msk   (0x1UL << RCC_APB4ENR_LPTIM2EN_Pos)
#define RCC_APB4ENR_LPTIM2EN   RCC_APB4ENR_LPTIM2EN_Msk
#define RCC_APB4ENR_LPTIM3EN_Pos   (10U)
#define RCC_APB4ENR_LPTIM3EN_Msk   (0x1UL << RCC_APB4ENR_LPTIM3EN_Pos)
#define RCC_APB4ENR_LPTIM3EN   RCC_APB4ENR_LPTIM3EN_Msk
#define RCC_APB4ENR_DAC2EN_Pos   (13U)
#define RCC_APB4ENR_DAC2EN_Msk   (0x1UL << RCC_APB4ENR_DAC2EN_Pos)
#define RCC_APB4ENR_DAC2EN   RCC_APB4ENR_DAC2EN_Msk
#define RCC_APB4ENR_COMP12EN_Pos   (14U)
#define RCC_APB4ENR_COMP12EN_Msk   (0x1UL << RCC_APB4ENR_COMP12EN_Pos)
#define RCC_APB4ENR_COMP12EN   RCC_APB4ENR_COMP12EN_Msk
#define RCC_APB4ENR_VREFEN_Pos   (15U)
#define RCC_APB4ENR_VREFEN_Msk   (0x1UL << RCC_APB4ENR_VREFEN_Pos)
#define RCC_APB4ENR_VREFEN   RCC_APB4ENR_VREFEN_Msk
#define RCC_APB4ENR_RTCAPBEN_Pos   (16U)
#define RCC_APB4ENR_RTCAPBEN_Msk   (0x1UL << RCC_APB4ENR_RTCAPBEN_Pos)
#define RCC_APB4ENR_RTCAPBEN   RCC_APB4ENR_RTCAPBEN_Msk
#define RCC_APB4ENR_DTSEN_Pos   (26U)
#define RCC_APB4ENR_DTSEN_Msk   (0x1UL << RCC_APB4ENR_DTSEN_Pos)
#define RCC_APB4ENR_DTSEN   RCC_APB4ENR_DTSEN_Msk
#define RCC_APB4ENR_DFSDM2EN_Pos   (27U)
#define RCC_APB4ENR_DFSDM2EN_Msk   (0x1UL << RCC_APB4ENR_DFSDM2EN_Pos)
#define RCC_APB4ENR_DFSDM2EN   RCC_APB4ENR_DFSDM2EN_Msk
#define RCC_AHB3RSTR_MDMARST_Pos   (0U)
#define RCC_AHB3RSTR_MDMARST_Msk   (0x1UL << RCC_AHB3RSTR_MDMARST_Pos)
#define RCC_AHB3RSTR_MDMARST   RCC_AHB3RSTR_MDMARST_Msk
#define RCC_AHB3RSTR_DMA2DRST_Pos   (4U)
#define RCC_AHB3RSTR_DMA2DRST_Msk   (0x1UL << RCC_AHB3RSTR_DMA2DRST_Pos)
#define RCC_AHB3RSTR_DMA2DRST   RCC_AHB3RSTR_DMA2DRST_Msk
#define RCC_AHB3RSTR_JPGDECRST_Pos   (5U)
#define RCC_AHB3RSTR_JPGDECRST_Msk   (0x1UL << RCC_AHB3RSTR_JPGDECRST_Pos)
#define RCC_AHB3RSTR_JPGDECRST   RCC_AHB3RSTR_JPGDECRST_Msk
#define RCC_AHB3RSTR_FMCRST_Pos   (12U)
#define RCC_AHB3RSTR_FMCRST_Msk   (0x1UL << RCC_AHB3RSTR_FMCRST_Pos)
#define RCC_AHB3RSTR_FMCRST   RCC_AHB3RSTR_FMCRST_Msk
#define RCC_AHB3RSTR_OSPI1RST_Pos   (14U)
#define RCC_AHB3RSTR_OSPI1RST_Msk   (0x1UL << RCC_AHB3RSTR_OSPI1RST_Pos)
#define RCC_AHB3RSTR_OSPI1RST   RCC_AHB3RSTR_OSPI1RST_Msk
#define RCC_AHB3RSTR_SDMMC1RST_Pos   (16U)
#define RCC_AHB3RSTR_SDMMC1RST_Msk   (0x1UL << RCC_AHB3RSTR_SDMMC1RST_Pos)
#define RCC_AHB3RSTR_SDMMC1RST   RCC_AHB3RSTR_SDMMC1RST_Msk
#define RCC_AHB3RSTR_OSPI2RST_Pos   (19U)
#define RCC_AHB3RSTR_OSPI2RST_Msk   (0x1UL << RCC_AHB3RSTR_OSPI2RST_Pos)
#define RCC_AHB3RSTR_OSPI2RST   RCC_AHB3RSTR_OSPI2RST_Msk
#define RCC_AHB3RSTR_IOMNGRRST_Pos   (21U)
#define RCC_AHB3RSTR_IOMNGRRST_Msk   (0x1UL << RCC_AHB3RSTR_IOMNGRRST_Pos)
#define RCC_AHB3RSTR_IOMNGRRST   RCC_AHB3RSTR_IOMNGRRST_Msk
#define RCC_AHB3RSTR_GFXMMURST_Pos   (24U)
#define RCC_AHB3RSTR_GFXMMURST_Msk   (0x1UL << RCC_AHB3RSTR_GFXMMURST_Pos)
#define RCC_AHB3RSTR_GFXMMURST   RCC_AHB3RSTR_GFXMMURST_Msk
#define RCC_AHB1RSTR_DMA1RST_Pos   (0U)
#define RCC_AHB1RSTR_DMA1RST_Msk   (0x1UL << RCC_AHB1RSTR_DMA1RST_Pos)
#define RCC_AHB1RSTR_DMA1RST   RCC_AHB1RSTR_DMA1RST_Msk
#define RCC_AHB1RSTR_DMA2RST_Pos   (1U)
#define RCC_AHB1RSTR_DMA2RST_Msk   (0x1UL << RCC_AHB1RSTR_DMA2RST_Pos)
#define RCC_AHB1RSTR_DMA2RST   RCC_AHB1RSTR_DMA2RST_Msk
#define RCC_AHB1RSTR_ADC12RST_Pos   (5U)
#define RCC_AHB1RSTR_ADC12RST_Msk   (0x1UL << RCC_AHB1RSTR_ADC12RST_Pos)
#define RCC_AHB1RSTR_ADC12RST   RCC_AHB1RSTR_ADC12RST_Msk
#define RCC_AHB1RSTR_CRCRST_Pos   (9U)
#define RCC_AHB1RSTR_CRCRST_Msk   (0x1UL << RCC_AHB1RSTR_CRCRST_Pos)
#define RCC_AHB1RSTR_CRCRST   RCC_AHB1RSTR_CRCRST_Msk
#define RCC_AHB1RSTR_USB1OTGHSRST_Pos   (25U)
#define RCC_AHB1RSTR_USB1OTGHSRST_Msk   (0x1UL << RCC_AHB1RSTR_USB1OTGHSRST_Pos)
#define RCC_AHB1RSTR_USB1OTGHSRST   RCC_AHB1RSTR_USB1OTGHSRST_Msk
#define RCC_AHB2RSTR_DCMI_PSSIRST_Pos   (0U)
#define RCC_AHB2RSTR_DCMI_PSSIRST_Msk   (0x1UL << RCC_AHB2RSTR_DCMI_PSSIRST_Pos)
#define RCC_AHB2RSTR_DCMI_PSSIRST   RCC_AHB2RSTR_DCMI_PSSIRST_Msk
#define RCC_AHB2RSTR_HSEMRST_Pos   (2U)
#define RCC_AHB2RSTR_HSEMRST_Msk   (0x1UL << RCC_AHB2RSTR_HSEMRST_Pos)
#define RCC_AHB2RSTR_HSEMRST   RCC_AHB2RSTR_HSEMRST_Msk
#define RCC_AHB2RSTR_RNGRST_Pos   (6U)
#define RCC_AHB2RSTR_RNGRST_Msk   (0x1UL << RCC_AHB2RSTR_RNGRST_Pos)
#define RCC_AHB2RSTR_RNGRST   RCC_AHB2RSTR_RNGRST_Msk
#define RCC_AHB2RSTR_SDMMC2RST_Pos   (9U)
#define RCC_AHB2RSTR_SDMMC2RST_Msk   (0x1UL << RCC_AHB2RSTR_SDMMC2RST_Pos)
#define RCC_AHB2RSTR_SDMMC2RST   RCC_AHB2RSTR_SDMMC2RST_Msk
#define RCC_AHB2RSTR_BDMA1RST_Pos   (11U)
#define RCC_AHB2RSTR_BDMA1RST_Msk   (0x1UL << RCC_AHB2RSTR_BDMA1RST_Pos)
#define RCC_AHB2RSTR_BDMA1RST   RCC_AHB2RSTR_BDMA1RST_Msk
#define RCC_AHB2RSTR_DCMIRST_Pos   RCC_AHB2RSTR_DCMI_PSSIRST_Pos
#define RCC_AHB2RSTR_DCMIRST_Msk   RCC_AHB2RSTR_DCMI_PSSIRST_Msk
#define RCC_AHB2RSTR_DCMIRST   RCC_AHB2RSTR_DCMI_PSSIRST
#define RCC_AHB4RSTR_GPIOARST_Pos   (0U)
#define RCC_AHB4RSTR_GPIOARST_Msk   (0x1UL << RCC_AHB4RSTR_GPIOARST_Pos)
#define RCC_AHB4RSTR_GPIOARST   RCC_AHB4RSTR_GPIOARST_Msk
#define RCC_AHB4RSTR_GPIOBRST_Pos   (1U)
#define RCC_AHB4RSTR_GPIOBRST_Msk   (0x1UL << RCC_AHB4RSTR_GPIOBRST_Pos)
#define RCC_AHB4RSTR_GPIOBRST   RCC_AHB4RSTR_GPIOBRST_Msk
#define RCC_AHB4RSTR_GPIOCRST_Pos   (2U)
#define RCC_AHB4RSTR_GPIOCRST_Msk   (0x1UL << RCC_AHB4RSTR_GPIOCRST_Pos)
#define RCC_AHB4RSTR_GPIOCRST   RCC_AHB4RSTR_GPIOCRST_Msk
#define RCC_AHB4RSTR_GPIODRST_Pos   (3U)
#define RCC_AHB4RSTR_GPIODRST_Msk   (0x1UL << RCC_AHB4RSTR_GPIODRST_Pos)
#define RCC_AHB4RSTR_GPIODRST   RCC_AHB4RSTR_GPIODRST_Msk
#define RCC_AHB4RSTR_GPIOERST_Pos   (4U)
#define RCC_AHB4RSTR_GPIOERST_Msk   (0x1UL << RCC_AHB4RSTR_GPIOERST_Pos)
#define RCC_AHB4RSTR_GPIOERST   RCC_AHB4RSTR_GPIOERST_Msk
#define RCC_AHB4RSTR_GPIOFRST_Pos   (5U)
#define RCC_AHB4RSTR_GPIOFRST_Msk   (0x1UL << RCC_AHB4RSTR_GPIOFRST_Pos)
#define RCC_AHB4RSTR_GPIOFRST   RCC_AHB4RSTR_GPIOFRST_Msk
#define RCC_AHB4RSTR_GPIOGRST_Pos   (6U)
#define RCC_AHB4RSTR_GPIOGRST_Msk   (0x1UL << RCC_AHB4RSTR_GPIOGRST_Pos)
#define RCC_AHB4RSTR_GPIOGRST   RCC_AHB4RSTR_GPIOGRST_Msk
#define RCC_AHB4RSTR_GPIOHRST_Pos   (7U)
#define RCC_AHB4RSTR_GPIOHRST_Msk   (0x1UL << RCC_AHB4RSTR_GPIOHRST_Pos)
#define RCC_AHB4RSTR_GPIOHRST   RCC_AHB4RSTR_GPIOHRST_Msk
#define RCC_AHB4RSTR_GPIOIRST_Pos   (8U)
#define RCC_AHB4RSTR_GPIOIRST_Msk   (0x1UL << RCC_AHB4RSTR_GPIOIRST_Pos)
#define RCC_AHB4RSTR_GPIOIRST   RCC_AHB4RSTR_GPIOIRST_Msk
#define RCC_AHB4RSTR_GPIOJRST_Pos   (9U)
#define RCC_AHB4RSTR_GPIOJRST_Msk   (0x1UL << RCC_AHB4RSTR_GPIOJRST_Pos)
#define RCC_AHB4RSTR_GPIOJRST   RCC_AHB4RSTR_GPIOJRST_Msk
#define RCC_AHB4RSTR_GPIOKRST_Pos   (10U)
#define RCC_AHB4RSTR_GPIOKRST_Msk   (0x1UL << RCC_AHB4RSTR_GPIOKRST_Pos)
#define RCC_AHB4RSTR_GPIOKRST   RCC_AHB4RSTR_GPIOKRST_Msk
#define RCC_AHB4RSTR_BDMA2RST_Pos   (21U)
#define RCC_AHB4RSTR_BDMA2RST_Msk   (0x1UL << RCC_AHB4RSTR_BDMA2RST_Pos)
#define RCC_AHB4RSTR_BDMA2RST   RCC_AHB4RSTR_BDMA2RST_Msk
#define RCC_APB3RSTR_LTDCRST_Pos   (3U)
#define RCC_APB3RSTR_LTDCRST_Msk   (0x1UL << RCC_APB3RSTR_LTDCRST_Pos)
#define RCC_APB3RSTR_LTDCRST   RCC_APB3RSTR_LTDCRST_Msk
#define RCC_APB1LRSTR_TIM2RST_Pos   (0U)
#define RCC_APB1LRSTR_TIM2RST_Msk   (0x1UL << RCC_APB1LRSTR_TIM2RST_Pos)
#define RCC_APB1LRSTR_TIM2RST   RCC_APB1LRSTR_TIM2RST_Msk
#define RCC_APB1LRSTR_TIM3RST_Pos   (1U)
#define RCC_APB1LRSTR_TIM3RST_Msk   (0x1UL << RCC_APB1LRSTR_TIM3RST_Pos)
#define RCC_APB1LRSTR_TIM3RST   RCC_APB1LRSTR_TIM3RST_Msk
#define RCC_APB1LRSTR_TIM4RST_Pos   (2U)
#define RCC_APB1LRSTR_TIM4RST_Msk   (0x1UL << RCC_APB1LRSTR_TIM4RST_Pos)
#define RCC_APB1LRSTR_TIM4RST   RCC_APB1LRSTR_TIM4RST_Msk
#define RCC_APB1LRSTR_TIM5RST_Pos   (3U)
#define RCC_APB1LRSTR_TIM5RST_Msk   (0x1UL << RCC_APB1LRSTR_TIM5RST_Pos)
#define RCC_APB1LRSTR_TIM5RST   RCC_APB1LRSTR_TIM5RST_Msk
#define RCC_APB1LRSTR_TIM6RST_Pos   (4U)
#define RCC_APB1LRSTR_TIM6RST_Msk   (0x1UL << RCC_APB1LRSTR_TIM6RST_Pos)
#define RCC_APB1LRSTR_TIM6RST   RCC_APB1LRSTR_TIM6RST_Msk
#define RCC_APB1LRSTR_TIM7RST_Pos   (5U)
#define RCC_APB1LRSTR_TIM7RST_Msk   (0x1UL << RCC_APB1LRSTR_TIM7RST_Pos)
#define RCC_APB1LRSTR_TIM7RST   RCC_APB1LRSTR_TIM7RST_Msk
#define RCC_APB1LRSTR_TIM12RST_Pos   (6U)
#define RCC_APB1LRSTR_TIM12RST_Msk   (0x1UL << RCC_APB1LRSTR_TIM12RST_Pos)
#define RCC_APB1LRSTR_TIM12RST   RCC_APB1LRSTR_TIM12RST_Msk
#define RCC_APB1LRSTR_TIM13RST_Pos   (7U)
#define RCC_APB1LRSTR_TIM13RST_Msk   (0x1UL << RCC_APB1LRSTR_TIM13RST_Pos)
#define RCC_APB1LRSTR_TIM13RST   RCC_APB1LRSTR_TIM13RST_Msk
#define RCC_APB1LRSTR_TIM14RST_Pos   (8U)
#define RCC_APB1LRSTR_TIM14RST_Msk   (0x1UL << RCC_APB1LRSTR_TIM14RST_Pos)
#define RCC_APB1LRSTR_TIM14RST   RCC_APB1LRSTR_TIM14RST_Msk
#define RCC_APB1LRSTR_LPTIM1RST_Pos   (9U)
#define RCC_APB1LRSTR_LPTIM1RST_Msk   (0x1UL << RCC_APB1LRSTR_LPTIM1RST_Pos)
#define RCC_APB1LRSTR_LPTIM1RST   RCC_APB1LRSTR_LPTIM1RST_Msk
#define RCC_APB1LRSTR_SPI2RST_Pos   (14U)
#define RCC_APB1LRSTR_SPI2RST_Msk   (0x1UL << RCC_APB1LRSTR_SPI2RST_Pos)
#define RCC_APB1LRSTR_SPI2RST   RCC_APB1LRSTR_SPI2RST_Msk
#define RCC_APB1LRSTR_SPI3RST_Pos   (15U)
#define RCC_APB1LRSTR_SPI3RST_Msk   (0x1UL << RCC_APB1LRSTR_SPI3RST_Pos)
#define RCC_APB1LRSTR_SPI3RST   RCC_APB1LRSTR_SPI3RST_Msk
#define RCC_APB1LRSTR_SPDIFRXRST_Pos   (16U)
#define RCC_APB1LRSTR_SPDIFRXRST_Msk   (0x1UL << RCC_APB1LRSTR_SPDIFRXRST_Pos)
#define RCC_APB1LRSTR_SPDIFRXRST   RCC_APB1LRSTR_SPDIFRXRST_Msk
#define RCC_APB1LRSTR_USART2RST_Pos   (17U)
#define RCC_APB1LRSTR_USART2RST_Msk   (0x1UL << RCC_APB1LRSTR_USART2RST_Pos)
#define RCC_APB1LRSTR_USART2RST   RCC_APB1LRSTR_USART2RST_Msk
#define RCC_APB1LRSTR_USART3RST_Pos   (18U)
#define RCC_APB1LRSTR_USART3RST_Msk   (0x1UL << RCC_APB1LRSTR_USART3RST_Pos)
#define RCC_APB1LRSTR_USART3RST   RCC_APB1LRSTR_USART3RST_Msk
#define RCC_APB1LRSTR_UART4RST_Pos   (19U)
#define RCC_APB1LRSTR_UART4RST_Msk   (0x1UL << RCC_APB1LRSTR_UART4RST_Pos)
#define RCC_APB1LRSTR_UART4RST   RCC_APB1LRSTR_UART4RST_Msk
#define RCC_APB1LRSTR_UART5RST_Pos   (20U)
#define RCC_APB1LRSTR_UART5RST_Msk   (0x1UL << RCC_APB1LRSTR_UART5RST_Pos)
#define RCC_APB1LRSTR_UART5RST   RCC_APB1LRSTR_UART5RST_Msk
#define RCC_APB1LRSTR_I2C1RST_Pos   (21U)
#define RCC_APB1LRSTR_I2C1RST_Msk   (0x1UL << RCC_APB1LRSTR_I2C1RST_Pos)
#define RCC_APB1LRSTR_I2C1RST   RCC_APB1LRSTR_I2C1RST_Msk
#define RCC_APB1LRSTR_I2C2RST_Pos   (22U)
#define RCC_APB1LRSTR_I2C2RST_Msk   (0x1UL << RCC_APB1LRSTR_I2C2RST_Pos)
#define RCC_APB1LRSTR_I2C2RST   RCC_APB1LRSTR_I2C2RST_Msk
#define RCC_APB1LRSTR_I2C3RST_Pos   (23U)
#define RCC_APB1LRSTR_I2C3RST_Msk   (0x1UL << RCC_APB1LRSTR_I2C3RST_Pos)
#define RCC_APB1LRSTR_I2C3RST   RCC_APB1LRSTR_I2C3RST_Msk
#define RCC_APB1LRSTR_CECRST_Pos   (27U)
#define RCC_APB1LRSTR_CECRST_Msk   (0x1UL << RCC_APB1LRSTR_CECRST_Pos)
#define RCC_APB1LRSTR_CECRST   RCC_APB1LRSTR_CECRST_Msk
#define RCC_APB1LRSTR_DAC12RST_Pos   (29U)
#define RCC_APB1LRSTR_DAC12RST_Msk   (0x1UL << RCC_APB1LRSTR_DAC12RST_Pos)
#define RCC_APB1LRSTR_DAC12RST   RCC_APB1LRSTR_DAC12RST_Msk
#define RCC_APB1LRSTR_UART7RST_Pos   (30U)
#define RCC_APB1LRSTR_UART7RST_Msk   (0x1UL << RCC_APB1LRSTR_UART7RST_Pos)
#define RCC_APB1LRSTR_UART7RST   RCC_APB1LRSTR_UART7RST_Msk
#define RCC_APB1LRSTR_UART8RST_Pos   (31U)
#define RCC_APB1LRSTR_UART8RST_Msk   (0x1UL << RCC_APB1LRSTR_UART8RST_Pos)
#define RCC_APB1LRSTR_UART8RST   RCC_APB1LRSTR_UART8RST_Msk
#define RCC_APB1LRSTR_HDMICECRST_Pos   RCC_APB1LRSTR_CECRST_Pos
#define RCC_APB1LRSTR_HDMICECRST_Msk   RCC_APB1LRSTR_CECRST_Msk
#define RCC_APB1LRSTR_HDMICECRST   RCC_APB1LRSTR_CECRST
#define RCC_APB1HRSTR_CRSRST_Pos   (1U)
#define RCC_APB1HRSTR_CRSRST_Msk   (0x1UL << RCC_APB1HRSTR_CRSRST_Pos)
#define RCC_APB1HRSTR_CRSRST   RCC_APB1HRSTR_CRSRST_Msk
#define RCC_APB1HRSTR_SWPMIRST_Pos   (2U)
#define RCC_APB1HRSTR_SWPMIRST_Msk   (0x1UL << RCC_APB1HRSTR_SWPMIRST_Pos)
#define RCC_APB1HRSTR_SWPMIRST   RCC_APB1HRSTR_SWPMIRST_Msk
#define RCC_APB1HRSTR_OPAMPRST_Pos   (4U)
#define RCC_APB1HRSTR_OPAMPRST_Msk   (0x1UL << RCC_APB1HRSTR_OPAMPRST_Pos)
#define RCC_APB1HRSTR_OPAMPRST   RCC_APB1HRSTR_OPAMPRST_Msk
#define RCC_APB1HRSTR_MDIOSRST_Pos   (5U)
#define RCC_APB1HRSTR_MDIOSRST_Msk   (0x1UL << RCC_APB1HRSTR_MDIOSRST_Pos)
#define RCC_APB1HRSTR_MDIOSRST   RCC_APB1HRSTR_MDIOSRST_Msk
#define RCC_APB1HRSTR_FDCANRST_Pos   (8U)
#define RCC_APB1HRSTR_FDCANRST_Msk   (0x1UL << RCC_APB1HRSTR_FDCANRST_Pos)
#define RCC_APB1HRSTR_FDCANRST   RCC_APB1HRSTR_FDCANRST_Msk
#define RCC_APB2RSTR_TIM1RST_Pos   (0U)
#define RCC_APB2RSTR_TIM1RST_Msk   (0x1UL << RCC_APB2RSTR_TIM1RST_Pos)
#define RCC_APB2RSTR_TIM1RST   RCC_APB2RSTR_TIM1RST_Msk
#define RCC_APB2RSTR_TIM8RST_Pos   (1U)
#define RCC_APB2RSTR_TIM8RST_Msk   (0x1UL << RCC_APB2RSTR_TIM8RST_Pos)
#define RCC_APB2RSTR_TIM8RST   RCC_APB2RSTR_TIM8RST_Msk
#define RCC_APB2RSTR_USART1RST_Pos   (4U)
#define RCC_APB2RSTR_USART1RST_Msk   (0x1UL << RCC_APB2RSTR_USART1RST_Pos)
#define RCC_APB2RSTR_USART1RST   RCC_APB2RSTR_USART1RST_Msk
#define RCC_APB2RSTR_USART6RST_Pos   (5U)
#define RCC_APB2RSTR_USART6RST_Msk   (0x1UL << RCC_APB2RSTR_USART6RST_Pos)
#define RCC_APB2RSTR_USART6RST   RCC_APB2RSTR_USART6RST_Msk
#define RCC_APB2RSTR_UART9RST_Pos   (6U)
#define RCC_APB2RSTR_UART9RST_Msk   (0x1UL << RCC_APB2RSTR_UART9RST_Pos)
#define RCC_APB2RSTR_UART9RST   RCC_APB2RSTR_UART9RST_Msk
#define RCC_APB2RSTR_USART10RST_Pos   (7U)
#define RCC_APB2RSTR_USART10RST_Msk   (0x1UL << RCC_APB2RSTR_USART10RST_Pos)
#define RCC_APB2RSTR_USART10RST   RCC_APB2RSTR_USART10RST_Msk
#define RCC_APB2RSTR_SPI1RST_Pos   (12U)
#define RCC_APB2RSTR_SPI1RST_Msk   (0x1UL << RCC_APB2RSTR_SPI1RST_Pos)
#define RCC_APB2RSTR_SPI1RST   RCC_APB2RSTR_SPI1RST_Msk
#define RCC_APB2RSTR_SPI4RST_Pos   (13U)
#define RCC_APB2RSTR_SPI4RST_Msk   (0x1UL << RCC_APB2RSTR_SPI4RST_Pos)
#define RCC_APB2RSTR_SPI4RST   RCC_APB2RSTR_SPI4RST_Msk
#define RCC_APB2RSTR_TIM15RST_Pos   (16U)
#define RCC_APB2RSTR_TIM15RST_Msk   (0x1UL << RCC_APB2RSTR_TIM15RST_Pos)
#define RCC_APB2RSTR_TIM15RST   RCC_APB2RSTR_TIM15RST_Msk
#define RCC_APB2RSTR_TIM16RST_Pos   (17U)
#define RCC_APB2RSTR_TIM16RST_Msk   (0x1UL << RCC_APB2RSTR_TIM16RST_Pos)
#define RCC_APB2RSTR_TIM16RST   RCC_APB2RSTR_TIM16RST_Msk
#define RCC_APB2RSTR_TIM17RST_Pos   (18U)
#define RCC_APB2RSTR_TIM17RST_Msk   (0x1UL << RCC_APB2RSTR_TIM17RST_Pos)
#define RCC_APB2RSTR_TIM17RST   RCC_APB2RSTR_TIM17RST_Msk
#define RCC_APB2RSTR_SPI5RST_Pos   (20U)
#define RCC_APB2RSTR_SPI5RST_Msk   (0x1UL << RCC_APB2RSTR_SPI5RST_Pos)
#define RCC_APB2RSTR_SPI5RST   RCC_APB2RSTR_SPI5RST_Msk
#define RCC_APB2RSTR_SAI1RST_Pos   (22U)
#define RCC_APB2RSTR_SAI1RST_Msk   (0x1UL << RCC_APB2RSTR_SAI1RST_Pos)
#define RCC_APB2RSTR_SAI1RST   RCC_APB2RSTR_SAI1RST_Msk
#define RCC_APB2RSTR_SAI2RST_Pos   (23U)
#define RCC_APB2RSTR_SAI2RST_Msk   (0x1UL << RCC_APB2RSTR_SAI2RST_Pos)
#define RCC_APB2RSTR_SAI2RST   RCC_APB2RSTR_SAI2RST_Msk
#define RCC_APB2RSTR_DFSDM1RST_Pos   (30U)
#define RCC_APB2RSTR_DFSDM1RST_Msk   (0x1UL << RCC_APB2RSTR_DFSDM1RST_Pos)
#define RCC_APB2RSTR_DFSDM1RST   RCC_APB2RSTR_DFSDM1RST_Msk
#define RCC_APB4RSTR_SYSCFGRST_Pos   (1U)
#define RCC_APB4RSTR_SYSCFGRST_Msk   (0x1UL << RCC_APB4RSTR_SYSCFGRST_Pos)
#define RCC_APB4RSTR_SYSCFGRST   RCC_APB4RSTR_SYSCFGRST_Msk
#define RCC_APB4RSTR_LPUART1RST_Pos   (3U)
#define RCC_APB4RSTR_LPUART1RST_Msk   (0x1UL << RCC_APB4RSTR_LPUART1RST_Pos)
#define RCC_APB4RSTR_LPUART1RST   RCC_APB4RSTR_LPUART1RST_Msk
#define RCC_APB4RSTR_SPI6RST_Pos   (5U)
#define RCC_APB4RSTR_SPI6RST_Msk   (0x1UL << RCC_APB4RSTR_SPI6RST_Pos)
#define RCC_APB4RSTR_SPI6RST   RCC_APB4RSTR_SPI6RST_Msk
#define RCC_APB4RSTR_I2C4RST_Pos   (7U)
#define RCC_APB4RSTR_I2C4RST_Msk   (0x1UL << RCC_APB4RSTR_I2C4RST_Pos)
#define RCC_APB4RSTR_I2C4RST   RCC_APB4RSTR_I2C4RST_Msk
#define RCC_APB4RSTR_LPTIM2RST_Pos   (9U)
#define RCC_APB4RSTR_LPTIM2RST_Msk   (0x1UL << RCC_APB4RSTR_LPTIM2RST_Pos)
#define RCC_APB4RSTR_LPTIM2RST   RCC_APB4RSTR_LPTIM2RST_Msk
#define RCC_APB4RSTR_LPTIM3RST_Pos   (10U)
#define RCC_APB4RSTR_LPTIM3RST_Msk   (0x1UL << RCC_APB4RSTR_LPTIM3RST_Pos)
#define RCC_APB4RSTR_LPTIM3RST   RCC_APB4RSTR_LPTIM3RST_Msk
#define RCC_APB4RSTR_DAC2RST_Pos   (13U)
#define RCC_APB4RSTR_DAC2RST_Msk   (0x1UL << RCC_APB4RSTR_DAC2RST_Pos)
#define RCC_APB4RSTR_DAC2RST   RCC_APB4RSTR_DAC2RST_Msk
#define RCC_APB4RSTR_COMP12RST_Pos   (14U)
#define RCC_APB4RSTR_COMP12RST_Msk   (0x1UL << RCC_APB4RSTR_COMP12RST_Pos)
#define RCC_APB4RSTR_COMP12RST   RCC_APB4RSTR_COMP12RST_Msk
#define RCC_APB4RSTR_VREFRST_Pos   (15U)
#define RCC_APB4RSTR_VREFRST_Msk   (0x1UL << RCC_APB4RSTR_VREFRST_Pos)
#define RCC_APB4RSTR_VREFRST   RCC_APB4RSTR_VREFRST_Msk
#define RCC_APB4RSTR_DTSRST_Pos   (26U)
#define RCC_APB4RSTR_DTSRST_Msk   (0x1UL << RCC_APB4RSTR_DTSRST_Pos)
#define RCC_APB4RSTR_DTSRST   RCC_APB4RSTR_DTSRST_Msk
#define RCC_APB4RSTR_DFSDM2RST_Pos   (27U)
#define RCC_APB4RSTR_DFSDM2RST_Msk   (0x1UL << RCC_APB4RSTR_DFSDM2RST_Pos)
#define RCC_APB4RSTR_DFSDM2RST   RCC_APB4RSTR_DFSDM2RST_Msk
#define RCC_SRDAMR_BDMA2AMEN_Pos   (0U)
#define RCC_SRDAMR_BDMA2AMEN_Msk   (0x1UL << RCC_SRDAMR_BDMA2AMEN_Pos)
#define RCC_SRDAMR_BDMA2AMEN   RCC_SRDAMR_BDMA2AMEN_Msk
#define RCC_SRDAMR_GPIOAMEN_Pos   (1U)
#define RCC_SRDAMR_GPIOAMEN_Msk   (0x1UL << RCC_SRDAMR_GPIOAMEN_Pos)
#define RCC_SRDAMR_GPIOAMEN   RCC_SRDAMR_GPIOAMEN_Msk
#define RCC_SRDAMR_LPUART1AMEN_Pos   (3U)
#define RCC_SRDAMR_LPUART1AMEN_Msk   (0x1UL << RCC_SRDAMR_LPUART1AMEN_Pos)
#define RCC_SRDAMR_LPUART1AMEN   RCC_SRDAMR_LPUART1AMEN_Msk
#define RCC_SRDAMR_SPI6AMEN_Pos   (5U)
#define RCC_SRDAMR_SPI6AMEN_Msk   (0x1UL << RCC_SRDAMR_SPI6AMEN_Pos)
#define RCC_SRDAMR_SPI6AMEN   RCC_SRDAMR_SPI6AMEN_Msk
#define RCC_SRDAMR_I2C4AMEN_Pos   (7U)
#define RCC_SRDAMR_I2C4AMEN_Msk   (0x1UL << RCC_SRDAMR_I2C4AMEN_Pos)
#define RCC_SRDAMR_I2C4AMEN   RCC_SRDAMR_I2C4AMEN_Msk
#define RCC_SRDAMR_LPTIM2AMEN_Pos   (9U)
#define RCC_SRDAMR_LPTIM2AMEN_Msk   (0x1UL << RCC_SRDAMR_LPTIM2AMEN_Pos)
#define RCC_SRDAMR_LPTIM2AMEN   RCC_SRDAMR_LPTIM2AMEN_Msk
#define RCC_SRDAMR_LPTIM3AMEN_Pos   (10U)
#define RCC_SRDAMR_LPTIM3AMEN_Msk   (0x1UL << RCC_SRDAMR_LPTIM3AMEN_Pos)
#define RCC_SRDAMR_LPTIM3AMEN   RCC_SRDAMR_LPTIM3AMEN_Msk
#define RCC_SRDAMR_DAC2AMEN_Pos   (13U)
#define RCC_SRDAMR_DAC2AMEN_Msk   (0x1UL << RCC_SRDAMR_DAC2AMEN_Pos)
#define RCC_SRDAMR_DAC2AMEN   RCC_SRDAMR_DAC2AMEN_Msk
#define RCC_SRDAMR_COMP12AMEN_Pos   (14U)
#define RCC_SRDAMR_COMP12AMEN_Msk   (0x1UL << RCC_SRDAMR_COMP12AMEN_Pos)
#define RCC_SRDAMR_COMP12AMEN   RCC_SRDAMR_COMP12AMEN_Msk
#define RCC_SRDAMR_VREFAMEN_Pos   (15U)
#define RCC_SRDAMR_VREFAMEN_Msk   (0x1UL << RCC_SRDAMR_VREFAMEN_Pos)
#define RCC_SRDAMR_VREFAMEN   RCC_SRDAMR_VREFAMEN_Msk
#define RCC_SRDAMR_RTCAMEN_Pos   (16U)
#define RCC_SRDAMR_RTCAMEN_Msk   (0x1UL << RCC_SRDAMR_RTCAMEN_Pos)
#define RCC_SRDAMR_RTCAMEN   RCC_SRDAMR_RTCAMEN_Msk
#define RCC_SRDAMR_DTSAMEN_Pos   (26U)
#define RCC_SRDAMR_DTSAMEN_Msk   (0x1UL << RCC_SRDAMR_DTSAMEN_Pos)
#define RCC_SRDAMR_DTSAMEN   RCC_SRDAMR_DTSAMEN_Msk
#define RCC_SRDAMR_DFSDM2AMEN_Pos   (27U)
#define RCC_SRDAMR_DFSDM2AMEN_Msk   (0x1UL << RCC_SRDAMR_DFSDM2AMEN_Pos)
#define RCC_SRDAMR_DFSDM2AMEN   RCC_SRDAMR_DFSDM2AMEN_Msk
#define RCC_SRDAMR_BKPRAMAMEN_Pos   (28U)
#define RCC_SRDAMR_BKPRAMAMEN_Msk   (0x1UL << RCC_SRDAMR_BKPRAMAMEN_Pos)
#define RCC_SRDAMR_BKPRAMAMEN   RCC_SRDAMR_BKPRAMAMEN_Msk
#define RCC_SRDAMR_SRDSRAMAMEN_Pos   (29U)
#define RCC_SRDAMR_SRDSRAMAMEN_Msk   (0x1UL << RCC_SRDAMR_SRDSRAMAMEN_Pos)
#define RCC_SRDAMR_SRDSRAMAMEN   RCC_SRDAMR_SRDSRAMAMEN_Msk
#define RCC_CKGAENR_AXICKG_Pos   (0U)
#define RCC_CKGAENR_AXICKG_Msk   (0x1UL << RCC_CKGAENR_AXICKG_Pos)
#define RCC_CKGAENR_AXICKG   RCC_CKGAENR_AXICKG_Msk
#define RCC_CKGAENR_AHBCKG_Pos   (1U)
#define RCC_CKGAENR_AHBCKG_Msk   (0x1UL << RCC_CKGAENR_AHBCKG_Pos)
#define RCC_CKGAENR_AHBCKG   RCC_CKGAENR_AHBCKG_Msk
#define RCC_CKGAENR_CPUCKG_Pos   (2U)
#define RCC_CKGAENR_CPUCKG_Msk   (0x1UL << RCC_CKGAENR_CPUCKG_Pos)
#define RCC_CKGAENR_CPUCKG   RCC_CKGAENR_CPUCKG_Msk
#define RCC_CKGAENR_SDMMCCKG_Pos   (3U)
#define RCC_CKGAENR_SDMMCCKG_Msk   (0x1UL << RCC_CKGAENR_SDMMCCKG_Pos)
#define RCC_CKGAENR_SDMMCCKG   RCC_CKGAENR_SDMMCCKG_Msk
#define RCC_CKGAENR_MDMACKG_Pos   (4U)
#define RCC_CKGAENR_MDMACKG_Msk   (0x1UL << RCC_CKGAENR_MDMACKG_Pos)
#define RCC_CKGAENR_MDMACKG   RCC_CKGAENR_MDMACKG_Msk
#define RCC_CKGAENR_DMA2DCKG_Pos   (5U)
#define RCC_CKGAENR_DMA2DCKG_Msk   (0x1UL << RCC_CKGAENR_DMA2DCKG_Pos)
#define RCC_CKGAENR_DMA2DCKG   RCC_CKGAENR_DMA2DCKG_Msk
#define RCC_CKGAENR_LTDCCKG_Pos   (6U)
#define RCC_CKGAENR_LTDCCKG_Msk   (0x1UL << RCC_CKGAENR_LTDCCKG_Pos)
#define RCC_CKGAENR_LTDCCKG   RCC_CKGAENR_LTDCCKG_Msk
#define RCC_CKGAENR_GFXMMUMCKG_Pos   (7U)
#define RCC_CKGAENR_GFXMMUMCKG_Msk   (0x1UL << RCC_CKGAENR_GFXMMUMCKG_Pos)
#define RCC_CKGAENR_GFXMMUMCKG   RCC_CKGAENR_GFXMMUMCKG_Msk
#define RCC_CKGAENR_AHB12CKG_Pos   (8U)
#define RCC_CKGAENR_AHB12CKG_Msk   (0x1UL << RCC_CKGAENR_AHB12CKG_Pos)
#define RCC_CKGAENR_AHB12CKG   RCC_CKGAENR_AHB12CKG_Msk
#define RCC_CKGAENR_AHB34CKG_Pos   (9U)
#define RCC_CKGAENR_AHB34CKG_Msk   (0x1UL << RCC_CKGAENR_AHB34CKG_Pos)
#define RCC_CKGAENR_AHB34CKG   RCC_CKGAENR_AHB34CKG_Msk
#define RCC_CKGAENR_FLIFTCKG_Pos   (10U)
#define RCC_CKGAENR_FLIFTCKG_Msk   (0x1UL << RCC_CKGAENR_FLIFTCKG_Pos)
#define RCC_CKGAENR_FLIFTCKG   RCC_CKGAENR_FLIFTCKG_Msk
#define RCC_CKGAENR_OCTOSPI2CKG_Pos   (11U)
#define RCC_CKGAENR_OCTOSPI2CKG_Msk   (0x1UL << RCC_CKGAENR_OCTOSPI2CKG_Pos)
#define RCC_CKGAENR_OCTOSPI2CKG   RCC_CKGAENR_OCTOSPI2CKG_Msk
#define RCC_CKGAENR_FMCCKG_Pos   (12U)
#define RCC_CKGAENR_FMCCKG_Msk   (0x1UL << RCC_CKGAENR_FMCCKG_Pos)
#define RCC_CKGAENR_FMCCKG   RCC_CKGAENR_FMCCKG_Msk
#define RCC_CKGAENR_OCTOSPI1CKG_Pos   (13U)
#define RCC_CKGAENR_OCTOSPI1CKG_Msk   (0x1UL << RCC_CKGAENR_OCTOSPI1CKG_Pos)
#define RCC_CKGAENR_OCTOSPI1CKG   RCC_CKGAENR_OCTOSPI1CKG_Msk
#define RCC_CKGAENR_AXIRAM1CKG_Pos   (14U)
#define RCC_CKGAENR_AXIRAM1CKG_Msk   (0x1UL << RCC_CKGAENR_AXIRAM1CKG_Pos)
#define RCC_CKGAENR_AXIRAM1CKG   RCC_CKGAENR_AXIRAM1CKG_Msk
#define RCC_CKGAENR_AXIRAM2CKG_Pos   (15U)
#define RCC_CKGAENR_AXIRAM2CKG_Msk   (0x1UL << RCC_CKGAENR_AXIRAM2CKG_Pos)
#define RCC_CKGAENR_AXIRAM2CKG   RCC_CKGAENR_AXIRAM2CKG_Msk
#define RCC_CKGAENR_AXIRAM3CKG_Pos   (16U)
#define RCC_CKGAENR_AXIRAM3CKG_Msk   (0x1UL << RCC_CKGAENR_AXIRAM3CKG_Pos)
#define RCC_CKGAENR_AXIRAM3CKG   RCC_CKGAENR_AXIRAM3CKG_Msk
#define RCC_CKGAENR_GFXMMUSCKG_Pos   (17U)
#define RCC_CKGAENR_GFXMMUSCKG_Msk   (0x1UL << RCC_CKGAENR_GFXMMUSCKG_Pos)
#define RCC_CKGAENR_GFXMMUSCKG   RCC_CKGAENR_GFXMMUSCKG_Msk
#define RCC_CKGAENR_ECCRAMCKG_Pos   (29U)
#define RCC_CKGAENR_ECCRAMCKG_Msk   (0x1UL << RCC_CKGAENR_ECCRAMCKG_Pos)
#define RCC_CKGAENR_ECCRAMCKG   RCC_CKGAENR_ECCRAMCKG_Msk
#define RCC_CKGAENR_EXTICKG_Pos   (30U)
#define RCC_CKGAENR_EXTICKG_Msk   (0x1UL << RCC_CKGAENR_EXTICKG_Pos)
#define RCC_CKGAENR_EXTICKG   RCC_CKGAENR_EXTICKG_Msk
#define RCC_CKGAENR_JTAGCKG_Pos   (31U)
#define RCC_CKGAENR_JTAGCKG_Msk   (0x1UL << RCC_CKGAENR_JTAGCKG_Pos)
#define RCC_CKGAENR_JTAGCKG   RCC_CKGAENR_JTAGCKG_Msk
#define RCC_AHB3LPENR_MDMALPEN_Pos   (0U)
#define RCC_AHB3LPENR_MDMALPEN_Msk   (0x1UL << RCC_AHB3LPENR_MDMALPEN_Pos)
#define RCC_AHB3LPENR_MDMALPEN   RCC_AHB3LPENR_MDMALPEN_Msk
#define RCC_AHB3LPENR_DMA2DLPEN_Pos   (4U)
#define RCC_AHB3LPENR_DMA2DLPEN_Msk   (0x1UL << RCC_AHB3LPENR_DMA2DLPEN_Pos)
#define RCC_AHB3LPENR_DMA2DLPEN   RCC_AHB3LPENR_DMA2DLPEN_Msk
#define RCC_AHB3LPENR_JPGDECLPEN_Pos   (5U)
#define RCC_AHB3LPENR_JPGDECLPEN_Msk   (0x1UL << RCC_AHB3LPENR_JPGDECLPEN_Pos)
#define RCC_AHB3LPENR_JPGDECLPEN   RCC_AHB3LPENR_JPGDECLPEN_Msk
#define RCC_AHB3LPENR_FLASHLPEN_Pos   (8U)
#define RCC_AHB3LPENR_FLASHLPEN_Msk   (0x1UL << RCC_AHB3LPENR_FLASHLPEN_Pos)
#define RCC_AHB3LPENR_FLASHLPEN   RCC_AHB3LPENR_FLASHLPEN_Msk
#define RCC_AHB3LPENR_FMCLPEN_Pos   (12U)
#define RCC_AHB3LPENR_FMCLPEN_Msk   (0x1UL << RCC_AHB3LPENR_FMCLPEN_Pos)
#define RCC_AHB3LPENR_FMCLPEN   RCC_AHB3LPENR_FMCLPEN_Msk
#define RCC_AHB3LPENR_OSPI1LPEN_Pos   (14U)
#define RCC_AHB3LPENR_OSPI1LPEN_Msk   (0x1UL << RCC_AHB3LPENR_OSPI1LPEN_Pos)
#define RCC_AHB3LPENR_OSPI1LPEN   RCC_AHB3LPENR_OSPI1LPEN_Msk
#define RCC_AHB3LPENR_SDMMC1LPEN_Pos   (16U)
#define RCC_AHB3LPENR_SDMMC1LPEN_Msk   (0x1UL << RCC_AHB3LPENR_SDMMC1LPEN_Pos)
#define RCC_AHB3LPENR_SDMMC1LPEN   RCC_AHB3LPENR_SDMMC1LPEN_Msk
#define RCC_AHB3LPENR_OSPI2LPEN_Pos   (19U)
#define RCC_AHB3LPENR_OSPI2LPEN_Msk   (0x1UL << RCC_AHB3LPENR_OSPI2LPEN_Pos)
#define RCC_AHB3LPENR_OSPI2LPEN   RCC_AHB3LPENR_OSPI2LPEN_Msk
#define RCC_AHB3LPENR_IOMNGRLPEN_Pos   (21U)
#define RCC_AHB3LPENR_IOMNGRLPEN_Msk   (0x1UL << RCC_AHB3LPENR_IOMNGRLPEN_Pos)
#define RCC_AHB3LPENR_IOMNGRLPEN   RCC_AHB3LPENR_IOMNGRLPEN_Msk
#define RCC_AHB3LPENR_GFXMMULPEN_Pos   (24U)
#define RCC_AHB3LPENR_GFXMMULPEN_Msk   (0x1UL << RCC_AHB3LPENR_GFXMMULPEN_Pos)
#define RCC_AHB3LPENR_GFXMMULPEN   RCC_AHB3LPENR_GFXMMULPEN_Msk
#define RCC_AHB3LPENR_AXISRAM2LPEN_Pos   (26U)
#define RCC_AHB3LPENR_AXISRAM2LPEN_Msk   (0x1UL << RCC_AHB3LPENR_AXISRAM2LPEN_Pos)
#define RCC_AHB3LPENR_AXISRAM2LPEN   RCC_AHB3LPENR_AXISRAM2LPEN_Msk
#define RCC_AHB3LPENR_AXISRAM3LPEN_Pos   (27U)
#define RCC_AHB3LPENR_AXISRAM3LPEN_Msk   (0x1UL << RCC_AHB3LPENR_AXISRAM3LPEN_Pos)
#define RCC_AHB3LPENR_AXISRAM3LPEN   RCC_AHB3LPENR_AXISRAM3LPEN_Msk
#define RCC_AHB3LPENR_DTCM1LPEN_Pos   (28U)
#define RCC_AHB3LPENR_DTCM1LPEN_Msk   (0x1UL << RCC_AHB3LPENR_DTCM1LPEN_Pos)
#define RCC_AHB3LPENR_DTCM1LPEN   RCC_AHB3LPENR_DTCM1LPEN_Msk
#define RCC_AHB3LPENR_DTCM2LPEN_Pos   (29U)
#define RCC_AHB3LPENR_DTCM2LPEN_Msk   (0x1UL << RCC_AHB3LPENR_DTCM2LPEN_Pos)
#define RCC_AHB3LPENR_DTCM2LPEN   RCC_AHB3LPENR_DTCM2LPEN_Msk
#define RCC_AHB3LPENR_ITCMLPEN_Pos   (30U)
#define RCC_AHB3LPENR_ITCMLPEN_Msk   (0x1UL << RCC_AHB3LPENR_ITCMLPEN_Pos)
#define RCC_AHB3LPENR_ITCMLPEN   RCC_AHB3LPENR_ITCMLPEN_Msk
#define RCC_AHB3LPENR_AXISRAM1LPEN_Pos   (31U)
#define RCC_AHB3LPENR_AXISRAM1LPEN_Msk   (0x1UL << RCC_AHB3LPENR_AXISRAM1LPEN_Pos)
#define RCC_AHB3LPENR_AXISRAM1LPEN   RCC_AHB3LPENR_AXISRAM1LPEN_Msk
#define RCC_AHB3LPENR_AXISRAMLPEN_Pos   RCC_AHB3LPENR_AXISRAM1LPEN_Pos
#define RCC_AHB3LPENR_AXISRAMLPEN_Msk   RCC_AHB3LPENR_AXISRAM1LPEN_Msk
#define RCC_AHB3LPENR_AXISRAMLPEN   RCC_AHB3LPENR_AXISRAM1LPEN
#define RCC_AHB1LPENR_DMA1LPEN_Pos   (0U)
#define RCC_AHB1LPENR_DMA1LPEN_Msk   (0x1UL << RCC_AHB1LPENR_DMA1LPEN_Pos)
#define RCC_AHB1LPENR_DMA1LPEN   RCC_AHB1LPENR_DMA1LPEN_Msk
#define RCC_AHB1LPENR_DMA2LPEN_Pos   (1U)
#define RCC_AHB1LPENR_DMA2LPEN_Msk   (0x1UL << RCC_AHB1LPENR_DMA2LPEN_Pos)
#define RCC_AHB1LPENR_DMA2LPEN   RCC_AHB1LPENR_DMA2LPEN_Msk
#define RCC_AHB1LPENR_ADC12LPEN_Pos   (5U)
#define RCC_AHB1LPENR_ADC12LPEN_Msk   (0x1UL << RCC_AHB1LPENR_ADC12LPEN_Pos)
#define RCC_AHB1LPENR_ADC12LPEN   RCC_AHB1LPENR_ADC12LPEN_Msk
#define RCC_AHB1LPENR_CRCLPEN_Pos   (9U)
#define RCC_AHB1LPENR_CRCLPEN_Msk   (0x1UL << RCC_AHB1LPENR_CRCLPEN_Pos)
#define RCC_AHB1LPENR_CRCLPEN   RCC_AHB1LPENR_CRCLPEN_Msk
#define RCC_AHB1LPENR_USB1OTGHSLPEN_Pos   (25U)
#define RCC_AHB1LPENR_USB1OTGHSLPEN_Msk   (0x1UL << RCC_AHB1LPENR_USB1OTGHSLPEN_Pos)
#define RCC_AHB1LPENR_USB1OTGHSLPEN   RCC_AHB1LPENR_USB1OTGHSLPEN_Msk
#define RCC_AHB1LPENR_USB1OTGHSULPILPEN_Pos   (26U)
#define RCC_AHB1LPENR_USB1OTGHSULPILPEN_Msk   (0x1UL << RCC_AHB1LPENR_USB1OTGHSULPILPEN_Pos)
#define RCC_AHB1LPENR_USB1OTGHSULPILPEN   RCC_AHB1LPENR_USB1OTGHSULPILPEN_Msk
#define RCC_AHB2LPENR_DCMI_PSSILPEN_Pos   (0U)
#define RCC_AHB2LPENR_DCMI_PSSILPEN_Msk   (0x1UL << RCC_AHB2LPENR_DCMI_PSSILPEN_Pos)
#define RCC_AHB2LPENR_DCMI_PSSILPEN   RCC_AHB2LPENR_DCMI_PSSILPEN_Msk
#define RCC_AHB2LPENR_RNGLPEN_Pos   (6U)
#define RCC_AHB2LPENR_RNGLPEN_Msk   (0x1UL << RCC_AHB2LPENR_RNGLPEN_Pos)
#define RCC_AHB2LPENR_RNGLPEN   RCC_AHB2LPENR_RNGLPEN_Msk
#define RCC_AHB2LPENR_SDMMC2LPEN_Pos   (9U)
#define RCC_AHB2LPENR_SDMMC2LPEN_Msk   (0x1UL << RCC_AHB2LPENR_SDMMC2LPEN_Pos)
#define RCC_AHB2LPENR_SDMMC2LPEN   RCC_AHB2LPENR_SDMMC2LPEN_Msk
#define RCC_AHB2LPENR_BDMA1LPEN_Pos   (11U)
#define RCC_AHB2LPENR_BDMA1LPEN_Msk   (0x1UL << RCC_AHB2LPENR_BDMA1LPEN_Pos)
#define RCC_AHB2LPENR_BDMA1LPEN   RCC_AHB2LPENR_BDMA1LPEN_Msk
#define RCC_AHB2LPENR_AHBSRAM1LPEN_Pos   (29U)
#define RCC_AHB2LPENR_AHBSRAM1LPEN_Msk   (0x1UL << RCC_AHB2LPENR_AHBSRAM1LPEN_Pos)
#define RCC_AHB2LPENR_AHBSRAM1LPEN   RCC_AHB2LPENR_AHBSRAM1LPEN_Msk
#define RCC_AHB2LPENR_AHBSRAM2LPEN_Pos   (30U)
#define RCC_AHB2LPENR_AHBSRAM2LPEN_Msk   (0x1UL << RCC_AHB2LPENR_AHBSRAM2LPEN_Pos)
#define RCC_AHB2LPENR_AHBSRAM2LPEN   RCC_AHB2LPENR_AHBSRAM2LPEN_Msk
#define RCC_AHB2LPENR_DFSDMDMALPEN_Pos   RCC_AHB2LPENR_BDMA1LPEN_Pos
#define RCC_AHB2LPENR_DFSDMDMALPEN_Msk   RCC_AHB2LPENR_BDMA1LPEN_Msk
#define RCC_AHB2LPENR_DFSDMDMALPEN   RCC_AHB2LPENR_BDMA1LPEN
#define RCC_AHB2LPENR_DCMILPEN_Pos   RCC_AHB2LPENR_DCMI_PSSILPEN_Pos
#define RCC_AHB2LPENR_DCMILPEN_Msk   RCC_AHB2LPENR_DCMI_PSSILPEN_Msk
#define RCC_AHB2LPENR_DCMILPEN   RCC_AHB2LPENR_DCMI_PSSILPEN
#define RCC_AHB4LPENR_GPIOALPEN_Pos   (0U)
#define RCC_AHB4LPENR_GPIOALPEN_Msk   (0x1UL << RCC_AHB4LPENR_GPIOALPEN_Pos)
#define RCC_AHB4LPENR_GPIOALPEN   RCC_AHB4LPENR_GPIOALPEN_Msk
#define RCC_AHB4LPENR_GPIOBLPEN_Pos   (1U)
#define RCC_AHB4LPENR_GPIOBLPEN_Msk   (0x1UL << RCC_AHB4LPENR_GPIOBLPEN_Pos)
#define RCC_AHB4LPENR_GPIOBLPEN   RCC_AHB4LPENR_GPIOBLPEN_Msk
#define RCC_AHB4LPENR_GPIOCLPEN_Pos   (2U)
#define RCC_AHB4LPENR_GPIOCLPEN_Msk   (0x1UL << RCC_AHB4LPENR_GPIOCLPEN_Pos)
#define RCC_AHB4LPENR_GPIOCLPEN   RCC_AHB4LPENR_GPIOCLPEN_Msk
#define RCC_AHB4LPENR_GPIODLPEN_Pos   (3U)
#define RCC_AHB4LPENR_GPIODLPEN_Msk   (0x1UL << RCC_AHB4LPENR_GPIODLPEN_Pos)
#define RCC_AHB4LPENR_GPIODLPEN   RCC_AHB4LPENR_GPIODLPEN_Msk
#define RCC_AHB4LPENR_GPIOELPEN_Pos   (4U)
#define RCC_AHB4LPENR_GPIOELPEN_Msk   (0x1UL << RCC_AHB4LPENR_GPIOELPEN_Pos)
#define RCC_AHB4LPENR_GPIOELPEN   RCC_AHB4LPENR_GPIOELPEN_Msk
#define RCC_AHB4LPENR_GPIOFLPEN_Pos   (5U)
#define RCC_AHB4LPENR_GPIOFLPEN_Msk   (0x1UL << RCC_AHB4LPENR_GPIOFLPEN_Pos)
#define RCC_AHB4LPENR_GPIOFLPEN   RCC_AHB4LPENR_GPIOFLPEN_Msk
#define RCC_AHB4LPENR_GPIOGLPEN_Pos   (6U)
#define RCC_AHB4LPENR_GPIOGLPEN_Msk   (0x1UL << RCC_AHB4LPENR_GPIOGLPEN_Pos)
#define RCC_AHB4LPENR_GPIOGLPEN   RCC_AHB4LPENR_GPIOGLPEN_Msk
#define RCC_AHB4LPENR_GPIOHLPEN_Pos   (7U)
#define RCC_AHB4LPENR_GPIOHLPEN_Msk   (0x1UL << RCC_AHB4LPENR_GPIOHLPEN_Pos)
#define RCC_AHB4LPENR_GPIOHLPEN   RCC_AHB4LPENR_GPIOHLPEN_Msk
#define RCC_AHB4LPENR_GPIOILPEN_Pos   (8U)
#define RCC_AHB4LPENR_GPIOILPEN_Msk   (0x1UL << RCC_AHB4LPENR_GPIOILPEN_Pos)
#define RCC_AHB4LPENR_GPIOILPEN   RCC_AHB4LPENR_GPIOILPEN_Msk
#define RCC_AHB4LPENR_GPIOJLPEN_Pos   (9U)
#define RCC_AHB4LPENR_GPIOJLPEN_Msk   (0x1UL << RCC_AHB4LPENR_GPIOJLPEN_Pos)
#define RCC_AHB4LPENR_GPIOJLPEN   RCC_AHB4LPENR_GPIOJLPEN_Msk
#define RCC_AHB4LPENR_GPIOKLPEN_Pos   (10U)
#define RCC_AHB4LPENR_GPIOKLPEN_Msk   (0x1UL << RCC_AHB4LPENR_GPIOKLPEN_Pos)
#define RCC_AHB4LPENR_GPIOKLPEN   RCC_AHB4LPENR_GPIOKLPEN_Msk
#define RCC_AHB4LPENR_BDMA2LPEN_Pos   (21U)
#define RCC_AHB4LPENR_BDMA2LPEN_Msk   (0x1UL << RCC_AHB4LPENR_BDMA2LPEN_Pos)
#define RCC_AHB4LPENR_BDMA2LPEN   RCC_AHB4LPENR_BDMA2LPEN_Msk
#define RCC_AHB4LPENR_BKPRAMLPEN_Pos   (28U)
#define RCC_AHB4LPENR_BKPRAMLPEN_Msk   (0x1UL << RCC_AHB4LPENR_BKPRAMLPEN_Pos)
#define RCC_AHB4LPENR_BKPRAMLPEN   RCC_AHB4LPENR_BKPRAMLPEN_Msk
#define RCC_AHB4LPENR_SRDSRAMLPEN_Pos   (29U)
#define RCC_AHB4LPENR_SRDSRAMLPEN_Msk   (0x1UL << RCC_AHB4LPENR_SRDSRAMLPEN_Pos)
#define RCC_AHB4LPENR_SRDSRAMLPEN   RCC_AHB4LPENR_SRDSRAMLPEN_Msk
#define RCC_APB3LPENR_LTDCLPEN_Pos   (3U)
#define RCC_APB3LPENR_LTDCLPEN_Msk   (0x1UL << RCC_APB3LPENR_LTDCLPEN_Pos)
#define RCC_APB3LPENR_LTDCLPEN   RCC_APB3LPENR_LTDCLPEN_Msk
#define RCC_APB3LPENR_WWDGLPEN_Pos   (6U)
#define RCC_APB3LPENR_WWDGLPEN_Msk   (0x1UL << RCC_APB3LPENR_WWDGLPEN_Pos)
#define RCC_APB3LPENR_WWDGLPEN   RCC_APB3LPENR_WWDGLPEN_Msk
#define RCC_APB3LPENR_WWDG1LPEN_Pos   RCC_APB3LPENR_WWDGLPEN_Pos
#define RCC_APB3LPENR_WWDG1LPEN_Msk   RCC_APB3LPENR_WWDGLPEN_Msk
#define RCC_APB3LPENR_WWDG1LPEN   RCC_APB3LPENR_WWDGLPEN
#define RCC_APB1LLPENR_TIM2LPEN_Pos   (0U)
#define RCC_APB1LLPENR_TIM2LPEN_Msk   (0x1UL << RCC_APB1LLPENR_TIM2LPEN_Pos)
#define RCC_APB1LLPENR_TIM2LPEN   RCC_APB1LLPENR_TIM2LPEN_Msk
#define RCC_APB1LLPENR_TIM3LPEN_Pos   (1U)
#define RCC_APB1LLPENR_TIM3LPEN_Msk   (0x1UL << RCC_APB1LLPENR_TIM3LPEN_Pos)
#define RCC_APB1LLPENR_TIM3LPEN   RCC_APB1LLPENR_TIM3LPEN_Msk
#define RCC_APB1LLPENR_TIM4LPEN_Pos   (2U)
#define RCC_APB1LLPENR_TIM4LPEN_Msk   (0x1UL << RCC_APB1LLPENR_TIM4LPEN_Pos)
#define RCC_APB1LLPENR_TIM4LPEN   RCC_APB1LLPENR_TIM4LPEN_Msk
#define RCC_APB1LLPENR_TIM5LPEN_Pos   (3U)
#define RCC_APB1LLPENR_TIM5LPEN_Msk   (0x1UL << RCC_APB1LLPENR_TIM5LPEN_Pos)
#define RCC_APB1LLPENR_TIM5LPEN   RCC_APB1LLPENR_TIM5LPEN_Msk
#define RCC_APB1LLPENR_TIM6LPEN_Pos   (4U)
#define RCC_APB1LLPENR_TIM6LPEN_Msk   (0x1UL << RCC_APB1LLPENR_TIM6LPEN_Pos)
#define RCC_APB1LLPENR_TIM6LPEN   RCC_APB1LLPENR_TIM6LPEN_Msk
#define RCC_APB1LLPENR_TIM7LPEN_Pos   (5U)
#define RCC_APB1LLPENR_TIM7LPEN_Msk   (0x1UL << RCC_APB1LLPENR_TIM7LPEN_Pos)
#define RCC_APB1LLPENR_TIM7LPEN   RCC_APB1LLPENR_TIM7LPEN_Msk
#define RCC_APB1LLPENR_TIM12LPEN_Pos   (6U)
#define RCC_APB1LLPENR_TIM12LPEN_Msk   (0x1UL << RCC_APB1LLPENR_TIM12LPEN_Pos)
#define RCC_APB1LLPENR_TIM12LPEN   RCC_APB1LLPENR_TIM12LPEN_Msk
#define RCC_APB1LLPENR_TIM13LPEN_Pos   (7U)
#define RCC_APB1LLPENR_TIM13LPEN_Msk   (0x1UL << RCC_APB1LLPENR_TIM13LPEN_Pos)
#define RCC_APB1LLPENR_TIM13LPEN   RCC_APB1LLPENR_TIM13LPEN_Msk
#define RCC_APB1LLPENR_TIM14LPEN_Pos   (8U)
#define RCC_APB1LLPENR_TIM14LPEN_Msk   (0x1UL << RCC_APB1LLPENR_TIM14LPEN_Pos)
#define RCC_APB1LLPENR_TIM14LPEN   RCC_APB1LLPENR_TIM14LPEN_Msk
#define RCC_APB1LLPENR_LPTIM1LPEN_Pos   (9U)
#define RCC_APB1LLPENR_LPTIM1LPEN_Msk   (0x1UL << RCC_APB1LLPENR_LPTIM1LPEN_Pos)
#define RCC_APB1LLPENR_LPTIM1LPEN   RCC_APB1LLPENR_LPTIM1LPEN_Msk
#define RCC_APB1LLPENR_SPI2LPEN_Pos   (14U)
#define RCC_APB1LLPENR_SPI2LPEN_Msk   (0x1UL << RCC_APB1LLPENR_SPI2LPEN_Pos)
#define RCC_APB1LLPENR_SPI2LPEN   RCC_APB1LLPENR_SPI2LPEN_Msk
#define RCC_APB1LLPENR_SPI3LPEN_Pos   (15U)
#define RCC_APB1LLPENR_SPI3LPEN_Msk   (0x1UL << RCC_APB1LLPENR_SPI3LPEN_Pos)
#define RCC_APB1LLPENR_SPI3LPEN   RCC_APB1LLPENR_SPI3LPEN_Msk
#define RCC_APB1LLPENR_SPDIFRXLPEN_Pos   (16U)
#define RCC_APB1LLPENR_SPDIFRXLPEN_Msk   (0x1UL << RCC_APB1LLPENR_SPDIFRXLPEN_Pos)
#define RCC_APB1LLPENR_SPDIFRXLPEN   RCC_APB1LLPENR_SPDIFRXLPEN_Msk
#define RCC_APB1LLPENR_USART2LPEN_Pos   (17U)
#define RCC_APB1LLPENR_USART2LPEN_Msk   (0x1UL << RCC_APB1LLPENR_USART2LPEN_Pos)
#define RCC_APB1LLPENR_USART2LPEN   RCC_APB1LLPENR_USART2LPEN_Msk
#define RCC_APB1LLPENR_USART3LPEN_Pos   (18U)
#define RCC_APB1LLPENR_USART3LPEN_Msk   (0x1UL << RCC_APB1LLPENR_USART3LPEN_Pos)
#define RCC_APB1LLPENR_USART3LPEN   RCC_APB1LLPENR_USART3LPEN_Msk
#define RCC_APB1LLPENR_UART4LPEN_Pos   (19U)
#define RCC_APB1LLPENR_UART4LPEN_Msk   (0x1UL << RCC_APB1LLPENR_UART4LPEN_Pos)
#define RCC_APB1LLPENR_UART4LPEN   RCC_APB1LLPENR_UART4LPEN_Msk
#define RCC_APB1LLPENR_UART5LPEN_Pos   (20U)
#define RCC_APB1LLPENR_UART5LPEN_Msk   (0x1UL << RCC_APB1LLPENR_UART5LPEN_Pos)
#define RCC_APB1LLPENR_UART5LPEN   RCC_APB1LLPENR_UART5LPEN_Msk
#define RCC_APB1LLPENR_I2C1LPEN_Pos   (21U)
#define RCC_APB1LLPENR_I2C1LPEN_Msk   (0x1UL << RCC_APB1LLPENR_I2C1LPEN_Pos)
#define RCC_APB1LLPENR_I2C1LPEN   RCC_APB1LLPENR_I2C1LPEN_Msk
#define RCC_APB1LLPENR_I2C2LPEN_Pos   (22U)
#define RCC_APB1LLPENR_I2C2LPEN_Msk   (0x1UL << RCC_APB1LLPENR_I2C2LPEN_Pos)
#define RCC_APB1LLPENR_I2C2LPEN   RCC_APB1LLPENR_I2C2LPEN_Msk
#define RCC_APB1LLPENR_I2C3LPEN_Pos   (23U)
#define RCC_APB1LLPENR_I2C3LPEN_Msk   (0x1UL << RCC_APB1LLPENR_I2C3LPEN_Pos)
#define RCC_APB1LLPENR_I2C3LPEN   RCC_APB1LLPENR_I2C3LPEN_Msk
#define RCC_APB1LLPENR_CECLPEN_Pos   (27U)
#define RCC_APB1LLPENR_CECLPEN_Msk   (0x1UL << RCC_APB1LLPENR_CECLPEN_Pos)
#define RCC_APB1LLPENR_CECLPEN   RCC_APB1LLPENR_CECLPEN_Msk
#define RCC_APB1LLPENR_DAC12LPEN_Pos   (29U)
#define RCC_APB1LLPENR_DAC12LPEN_Msk   (0x1UL << RCC_APB1LLPENR_DAC12LPEN_Pos)
#define RCC_APB1LLPENR_DAC12LPEN   RCC_APB1LLPENR_DAC12LPEN_Msk
#define RCC_APB1LLPENR_UART7LPEN_Pos   (30U)
#define RCC_APB1LLPENR_UART7LPEN_Msk   (0x1UL << RCC_APB1LLPENR_UART7LPEN_Pos)
#define RCC_APB1LLPENR_UART7LPEN   RCC_APB1LLPENR_UART7LPEN_Msk
#define RCC_APB1LLPENR_UART8LPEN_Pos   (31U)
#define RCC_APB1LLPENR_UART8LPEN_Msk   (0x1UL << RCC_APB1LLPENR_UART8LPEN_Pos)
#define RCC_APB1LLPENR_UART8LPEN   RCC_APB1LLPENR_UART8LPEN_Msk
#define RCC_APB1LLPENR_HDMICECEN_Pos   RCC_APB1LLPENR_CECLPEN_Pos
#define RCC_APB1LLPENR_HDMICECEN_Msk   RCC_APB1LLPENR_CECLPEN_Msk
#define RCC_APB1LLPENR_HDMICECEN   RCC_APB1LLPENR_CECLPEN
#define RCC_APB1HLPENR_CRSLPEN_Pos   (1U)
#define RCC_APB1HLPENR_CRSLPEN_Msk   (0x1UL << RCC_APB1HLPENR_CRSLPEN_Pos)
#define RCC_APB1HLPENR_CRSLPEN   RCC_APB1HLPENR_CRSLPEN_Msk
#define RCC_APB1HLPENR_SWPMILPEN_Pos   (2U)
#define RCC_APB1HLPENR_SWPMILPEN_Msk   (0x1UL << RCC_APB1HLPENR_SWPMILPEN_Pos)
#define RCC_APB1HLPENR_SWPMILPEN   RCC_APB1HLPENR_SWPMILPEN_Msk
#define RCC_APB1HLPENR_OPAMPLPEN_Pos   (4U)
#define RCC_APB1HLPENR_OPAMPLPEN_Msk   (0x1UL << RCC_APB1HLPENR_OPAMPLPEN_Pos)
#define RCC_APB1HLPENR_OPAMPLPEN   RCC_APB1HLPENR_OPAMPLPEN_Msk
#define RCC_APB1HLPENR_MDIOSLPEN_Pos   (5U)
#define RCC_APB1HLPENR_MDIOSLPEN_Msk   (0x1UL << RCC_APB1HLPENR_MDIOSLPEN_Pos)
#define RCC_APB1HLPENR_MDIOSLPEN   RCC_APB1HLPENR_MDIOSLPEN_Msk
#define RCC_APB1HLPENR_FDCANLPEN_Pos   (8U)
#define RCC_APB1HLPENR_FDCANLPEN_Msk   (0x1UL << RCC_APB1HLPENR_FDCANLPEN_Pos)
#define RCC_APB1HLPENR_FDCANLPEN   RCC_APB1HLPENR_FDCANLPEN_Msk
#define RCC_APB2LPENR_TIM1LPEN_Pos   (0U)
#define RCC_APB2LPENR_TIM1LPEN_Msk   (0x1UL << RCC_APB2LPENR_TIM1LPEN_Pos)
#define RCC_APB2LPENR_TIM1LPEN   RCC_APB2LPENR_TIM1LPEN_Msk
#define RCC_APB2LPENR_TIM8LPEN_Pos   (1U)
#define RCC_APB2LPENR_TIM8LPEN_Msk   (0x1UL << RCC_APB2LPENR_TIM8LPEN_Pos)
#define RCC_APB2LPENR_TIM8LPEN   RCC_APB2LPENR_TIM8LPEN_Msk
#define RCC_APB2LPENR_USART1LPEN_Pos   (4U)
#define RCC_APB2LPENR_USART1LPEN_Msk   (0x1UL << RCC_APB2LPENR_USART1LPEN_Pos)
#define RCC_APB2LPENR_USART1LPEN   RCC_APB2LPENR_USART1LPEN_Msk
#define RCC_APB2LPENR_USART6LPEN_Pos   (5U)
#define RCC_APB2LPENR_USART6LPEN_Msk   (0x1UL << RCC_APB2LPENR_USART6LPEN_Pos)
#define RCC_APB2LPENR_USART6LPEN   RCC_APB2LPENR_USART6LPEN_Msk
#define RCC_APB2LPENR_UART9LPEN_Pos   (6U)
#define RCC_APB2LPENR_UART9LPEN_Msk   (0x1UL << RCC_APB2LPENR_UART9LPEN_Pos)
#define RCC_APB2LPENR_UART9LPEN   RCC_APB2LPENR_UART9LPEN_Msk
#define RCC_APB2LPENR_USART10LPEN_Pos   (7U)
#define RCC_APB2LPENR_USART10LPEN_Msk   (0x1UL << RCC_APB2LPENR_USART10LPEN_Pos)
#define RCC_APB2LPENR_USART10LPEN   RCC_APB2LPENR_USART10LPEN_Msk
#define RCC_APB2LPENR_SPI1LPEN_Pos   (12U)
#define RCC_APB2LPENR_SPI1LPEN_Msk   (0x1UL << RCC_APB2LPENR_SPI1LPEN_Pos)
#define RCC_APB2LPENR_SPI1LPEN   RCC_APB2LPENR_SPI1LPEN_Msk
#define RCC_APB2LPENR_SPI4LPEN_Pos   (13U)
#define RCC_APB2LPENR_SPI4LPEN_Msk   (0x1UL << RCC_APB2LPENR_SPI4LPEN_Pos)
#define RCC_APB2LPENR_SPI4LPEN   RCC_APB2LPENR_SPI4LPEN_Msk
#define RCC_APB2LPENR_TIM15LPEN_Pos   (16U)
#define RCC_APB2LPENR_TIM15LPEN_Msk   (0x1UL << RCC_APB2LPENR_TIM15LPEN_Pos)
#define RCC_APB2LPENR_TIM15LPEN   RCC_APB2LPENR_TIM15LPEN_Msk
#define RCC_APB2LPENR_TIM16LPEN_Pos   (17U)
#define RCC_APB2LPENR_TIM16LPEN_Msk   (0x1UL << RCC_APB2LPENR_TIM16LPEN_Pos)
#define RCC_APB2LPENR_TIM16LPEN   RCC_APB2LPENR_TIM16LPEN_Msk
#define RCC_APB2LPENR_TIM17LPEN_Pos   (18U)
#define RCC_APB2LPENR_TIM17LPEN_Msk   (0x1UL << RCC_APB2LPENR_TIM17LPEN_Pos)
#define RCC_APB2LPENR_TIM17LPEN   RCC_APB2LPENR_TIM17LPEN_Msk
#define RCC_APB2LPENR_SPI5LPEN_Pos   (20U)
#define RCC_APB2LPENR_SPI5LPEN_Msk   (0x1UL << RCC_APB2LPENR_SPI5LPEN_Pos)
#define RCC_APB2LPENR_SPI5LPEN   RCC_APB2LPENR_SPI5LPEN_Msk
#define RCC_APB2LPENR_SAI1LPEN_Pos   (22U)
#define RCC_APB2LPENR_SAI1LPEN_Msk   (0x1UL << RCC_APB2LPENR_SAI1LPEN_Pos)
#define RCC_APB2LPENR_SAI1LPEN   RCC_APB2LPENR_SAI1LPEN_Msk
#define RCC_APB2LPENR_SAI2LPEN_Pos   (23U)
#define RCC_APB2LPENR_SAI2LPEN_Msk   (0x1UL << RCC_APB2LPENR_SAI2LPEN_Pos)
#define RCC_APB2LPENR_SAI2LPEN   RCC_APB2LPENR_SAI2LPEN_Msk
#define RCC_APB2LPENR_DFSDM1LPEN_Pos   (30U)
#define RCC_APB2LPENR_DFSDM1LPEN_Msk   (0x1UL << RCC_APB2LPENR_DFSDM1LPEN_Pos)
#define RCC_APB2LPENR_DFSDM1LPEN   RCC_APB2LPENR_DFSDM1LPEN_Msk
#define RCC_APB4LPENR_SYSCFGLPEN_Pos   (1U)
#define RCC_APB4LPENR_SYSCFGLPEN_Msk   (0x1UL << RCC_APB4LPENR_SYSCFGLPEN_Pos)
#define RCC_APB4LPENR_SYSCFGLPEN   RCC_APB4LPENR_SYSCFGLPEN_Msk
#define RCC_APB4LPENR_LPUART1LPEN_Pos   (3U)
#define RCC_APB4LPENR_LPUART1LPEN_Msk   (0x1UL << RCC_APB4LPENR_LPUART1LPEN_Pos)
#define RCC_APB4LPENR_LPUART1LPEN   RCC_APB4LPENR_LPUART1LPEN_Msk
#define RCC_APB4LPENR_SPI6LPEN_Pos   (5U)
#define RCC_APB4LPENR_SPI6LPEN_Msk   (0x1UL << RCC_APB4LPENR_SPI6LPEN_Pos)
#define RCC_APB4LPENR_SPI6LPEN   RCC_APB4LPENR_SPI6LPEN_Msk
#define RCC_APB4LPENR_I2C4LPEN_Pos   (7U)
#define RCC_APB4LPENR_I2C4LPEN_Msk   (0x1UL << RCC_APB4LPENR_I2C4LPEN_Pos)
#define RCC_APB4LPENR_I2C4LPEN   RCC_APB4LPENR_I2C4LPEN_Msk
#define RCC_APB4LPENR_LPTIM2LPEN_Pos   (9U)
#define RCC_APB4LPENR_LPTIM2LPEN_Msk   (0x1UL << RCC_APB4LPENR_LPTIM2LPEN_Pos)
#define RCC_APB4LPENR_LPTIM2LPEN   RCC_APB4LPENR_LPTIM2LPEN_Msk
#define RCC_APB4LPENR_LPTIM3LPEN_Pos   (10U)
#define RCC_APB4LPENR_LPTIM3LPEN_Msk   (0x1UL << RCC_APB4LPENR_LPTIM3LPEN_Pos)
#define RCC_APB4LPENR_LPTIM3LPEN   RCC_APB4LPENR_LPTIM3LPEN_Msk
#define RCC_APB4LPENR_DAC2LPEN_Pos   (13U)
#define RCC_APB4LPENR_DAC2LPEN_Msk   (0x1UL << RCC_APB4LPENR_DAC2LPEN_Pos)
#define RCC_APB4LPENR_DAC2LPEN   RCC_APB4LPENR_DAC2LPEN_Msk
#define RCC_APB4LPENR_COMP12LPEN_Pos   (14U)
#define RCC_APB4LPENR_COMP12LPEN_Msk   (0x1UL << RCC_APB4LPENR_COMP12LPEN_Pos)
#define RCC_APB4LPENR_COMP12LPEN   RCC_APB4LPENR_COMP12LPEN_Msk
#define RCC_APB4LPENR_VREFLPEN_Pos   (15U)
#define RCC_APB4LPENR_VREFLPEN_Msk   (0x1UL << RCC_APB4LPENR_VREFLPEN_Pos)
#define RCC_APB4LPENR_VREFLPEN   RCC_APB4LPENR_VREFLPEN_Msk
#define RCC_APB4LPENR_RTCAPBLPEN_Pos   (16U)
#define RCC_APB4LPENR_RTCAPBLPEN_Msk   (0x1UL << RCC_APB4LPENR_RTCAPBLPEN_Pos)
#define RCC_APB4LPENR_RTCAPBLPEN   RCC_APB4LPENR_RTCAPBLPEN_Msk
#define RCC_APB4LPENR_DTSLPEN_Pos   (26U)
#define RCC_APB4LPENR_DTSLPEN_Msk   (0x1UL << RCC_APB4LPENR_DTSLPEN_Pos)
#define RCC_APB4LPENR_DTSLPEN   RCC_APB4LPENR_DTSLPEN_Msk
#define RCC_APB4LPENR_DFSDM2LPEN_Pos   (27U)
#define RCC_APB4LPENR_DFSDM2LPEN_Msk   (0x1UL << RCC_APB4LPENR_DFSDM2LPEN_Pos)
#define RCC_APB4LPENR_DFSDM2LPEN   RCC_APB4LPENR_DFSDM2LPEN_Msk
#define RCC_RSR_RMVF_Pos   (16U)
#define RCC_RSR_RMVF_Msk   (0x1UL << RCC_RSR_RMVF_Pos)
#define RCC_RSR_RMVF   RCC_RSR_RMVF_Msk
#define RCC_RSR_CDRSTF_Pos   (19U)
#define RCC_RSR_CDRSTF_Msk   (0x1UL << RCC_RSR_CDRSTF_Pos)
#define RCC_RSR_CDRSTF   RCC_RSR_CDRSTF_Msk
#define RCC_RSR_BORRSTF_Pos   (21U)
#define RCC_RSR_BORRSTF_Msk   (0x1UL << RCC_RSR_BORRSTF_Pos)
#define RCC_RSR_BORRSTF   RCC_RSR_BORRSTF_Msk
#define RCC_RSR_PINRSTF_Pos   (22U)
#define RCC_RSR_PINRSTF_Msk   (0x1UL << RCC_RSR_PINRSTF_Pos)
#define RCC_RSR_PINRSTF   RCC_RSR_PINRSTF_Msk
#define RCC_RSR_PORRSTF_Pos   (23U)
#define RCC_RSR_PORRSTF_Msk   (0x1UL << RCC_RSR_PORRSTF_Pos)
#define RCC_RSR_PORRSTF   RCC_RSR_PORRSTF_Msk
#define RCC_RSR_SFTRSTF_Pos   (24U)
#define RCC_RSR_SFTRSTF_Msk   (0x1UL << RCC_RSR_SFTRSTF_Pos)
#define RCC_RSR_SFTRSTF   RCC_RSR_SFTRSTF_Msk
#define RCC_RSR_IWDGRSTF_Pos   (26U)
#define RCC_RSR_IWDGRSTF_Msk   (0x1UL << RCC_RSR_IWDGRSTF_Pos)
#define RCC_RSR_IWDGRSTF   RCC_RSR_IWDGRSTF_Msk
#define RCC_RSR_WWDGRSTF_Pos   (28U)
#define RCC_RSR_WWDGRSTF_Msk   (0x1UL << RCC_RSR_WWDGRSTF_Pos)
#define RCC_RSR_WWDGRSTF   RCC_RSR_WWDGRSTF_Msk
#define RCC_RSR_LPWRRSTF_Pos   (30U)
#define RCC_RSR_LPWRRSTF_Msk   (0x1UL << RCC_RSR_LPWRRSTF_Pos)
#define RCC_RSR_LPWRRSTF   RCC_RSR_LPWRRSTF_Msk
#define RCC_RSR_IWDG1RSTF_Pos   RCC_RSR_IWDGRSTF_Pos
#define RCC_RSR_IWDG1RSTF_Msk   RCC_RSR_IWDGRSTF_Msk
#define RCC_RSR_IWDG1RSTF   RCC_RSR_IWDGRSTF
#define RCC_RSR_WWDG1RSTF_Pos   RCC_RSR_WWDGRSTF_Pos
#define RCC_RSR_WWDG1RSTF_Msk   RCC_RSR_WWDGRSTF_Msk
#define RCC_RSR_WWDG1RSTF   RCC_RSR_WWDGRSTF
#define RNG_VER_3_1
#define RNG_CR_RNGEN_Pos   (2U)
#define RNG_CR_RNGEN_Msk   (0x1UL << RNG_CR_RNGEN_Pos)
#define RNG_CR_RNGEN   RNG_CR_RNGEN_Msk
#define RNG_CR_IE_Pos   (3U)
#define RNG_CR_IE_Msk   (0x1UL << RNG_CR_IE_Pos)
#define RNG_CR_IE   RNG_CR_IE_Msk
#define RNG_CR_CED_Pos   (5U)
#define RNG_CR_CED_Msk   (0x1UL << RNG_CR_CED_Pos)
#define RNG_CR_CED   RNG_CR_CED_Msk
#define RNG_CR_RNG_CONFIG3_Pos   (8U)
#define RNG_CR_RNG_CONFIG3_Msk   (0xFUL << RNG_CR_RNG_CONFIG3_Pos)
#define RNG_CR_RNG_CONFIG3   RNG_CR_RNG_CONFIG3_Msk
#define RNG_CR_NISTC_Pos   (12U)
#define RNG_CR_NISTC_Msk   (0x1UL << RNG_CR_NISTC_Pos)
#define RNG_CR_NISTC   RNG_CR_NISTC_Msk
#define RNG_CR_RNG_CONFIG2_Pos   (13U)
#define RNG_CR_RNG_CONFIG2_Msk   (0x7UL << RNG_CR_RNG_CONFIG2_Pos)
#define RNG_CR_RNG_CONFIG2   RNG_CR_RNG_CONFIG2_Msk
#define RNG_CR_CLKDIV_Pos   (16U)
#define RNG_CR_CLKDIV_Msk   (0xFUL << RNG_CR_CLKDIV_Pos)
#define RNG_CR_CLKDIV   RNG_CR_CLKDIV_Msk
#define RNG_CR_CLKDIV_0   (0x1U << RNG_CR_CLKDIV_Pos)
#define RNG_CR_CLKDIV_1   (0x2U << RNG_CR_CLKDIV_Pos)
#define RNG_CR_CLKDIV_2   (0x4U << RNG_CR_CLKDIV_Pos)
#define RNG_CR_CLKDIV_3   (0x8U << RNG_CR_CLKDIV_Pos)
#define RNG_CR_RNG_CONFIG1_Pos   (20U)
#define RNG_CR_RNG_CONFIG1_Msk   (0x3FUL << RNG_CR_RNG_CONFIG1_Pos)
#define RNG_CR_RNG_CONFIG1   RNG_CR_RNG_CONFIG1_Msk
#define RNG_CR_CONDRST_Pos   (30U)
#define RNG_CR_CONDRST_Msk   (0x1UL << RNG_CR_CONDRST_Pos)
#define RNG_CR_CONDRST   RNG_CR_CONDRST_Msk
#define RNG_CR_CONFIGLOCK_Pos   (31U)
#define RNG_CR_CONFIGLOCK_Msk   (0x1UL << RNG_CR_CONFIGLOCK_Pos)
#define RNG_CR_CONFIGLOCK   RNG_CR_CONFIGLOCK_Msk
#define RNG_SR_DRDY_Pos   (0U)
#define RNG_SR_DRDY_Msk   (0x1UL << RNG_SR_DRDY_Pos)
#define RNG_SR_DRDY   RNG_SR_DRDY_Msk
#define RNG_SR_CECS_Pos   (1U)
#define RNG_SR_CECS_Msk   (0x1UL << RNG_SR_CECS_Pos)
#define RNG_SR_CECS   RNG_SR_CECS_Msk
#define RNG_SR_SECS_Pos   (2U)
#define RNG_SR_SECS_Msk   (0x1UL << RNG_SR_SECS_Pos)
#define RNG_SR_SECS   RNG_SR_SECS_Msk
#define RNG_SR_CEIS_Pos   (5U)
#define RNG_SR_CEIS_Msk   (0x1UL << RNG_SR_CEIS_Pos)
#define RNG_SR_CEIS   RNG_SR_CEIS_Msk
#define RNG_SR_SEIS_Pos   (6U)
#define RNG_SR_SEIS_Msk   (0x1UL << RNG_SR_SEIS_Pos)
#define RNG_SR_SEIS   RNG_SR_SEIS_Msk
#define RTC_TR_PM_Pos   (22U)
#define RTC_TR_PM_Msk   (0x1UL << RTC_TR_PM_Pos)
#define RTC_TR_PM   RTC_TR_PM_Msk
#define RTC_TR_HT_Pos   (20U)
#define RTC_TR_HT_Msk   (0x3UL << RTC_TR_HT_Pos)
#define RTC_TR_HT   RTC_TR_HT_Msk
#define RTC_TR_HT_0   (0x1UL << RTC_TR_HT_Pos)
#define RTC_TR_HT_1   (0x2UL << RTC_TR_HT_Pos)
#define RTC_TR_HU_Pos   (16U)
#define RTC_TR_HU_Msk   (0xFUL << RTC_TR_HU_Pos)
#define RTC_TR_HU   RTC_TR_HU_Msk
#define RTC_TR_HU_0   (0x1UL << RTC_TR_HU_Pos)
#define RTC_TR_HU_1   (0x2UL << RTC_TR_HU_Pos)
#define RTC_TR_HU_2   (0x4UL << RTC_TR_HU_Pos)
#define RTC_TR_HU_3   (0x8UL << RTC_TR_HU_Pos)
#define RTC_TR_MNT_Pos   (12U)
#define RTC_TR_MNT_Msk   (0x7UL << RTC_TR_MNT_Pos)
#define RTC_TR_MNT   RTC_TR_MNT_Msk
#define RTC_TR_MNT_0   (0x1UL << RTC_TR_MNT_Pos)
#define RTC_TR_MNT_1   (0x2UL << RTC_TR_MNT_Pos)
#define RTC_TR_MNT_2   (0x4UL << RTC_TR_MNT_Pos)
#define RTC_TR_MNU_Pos   (8U)
#define RTC_TR_MNU_Msk   (0xFUL << RTC_TR_MNU_Pos)
#define RTC_TR_MNU   RTC_TR_MNU_Msk
#define RTC_TR_MNU_0   (0x1UL << RTC_TR_MNU_Pos)
#define RTC_TR_MNU_1   (0x2UL << RTC_TR_MNU_Pos)
#define RTC_TR_MNU_2   (0x4UL << RTC_TR_MNU_Pos)
#define RTC_TR_MNU_3   (0x8UL << RTC_TR_MNU_Pos)
#define RTC_TR_ST_Pos   (4U)
#define RTC_TR_ST_Msk   (0x7UL << RTC_TR_ST_Pos)
#define RTC_TR_ST   RTC_TR_ST_Msk
#define RTC_TR_ST_0   (0x1UL << RTC_TR_ST_Pos)
#define RTC_TR_ST_1   (0x2UL << RTC_TR_ST_Pos)
#define RTC_TR_ST_2   (0x4UL << RTC_TR_ST_Pos)
#define RTC_TR_SU_Pos   (0U)
#define RTC_TR_SU_Msk   (0xFUL << RTC_TR_SU_Pos)
#define RTC_TR_SU   RTC_TR_SU_Msk
#define RTC_TR_SU_0   (0x1UL << RTC_TR_SU_Pos)
#define RTC_TR_SU_1   (0x2UL << RTC_TR_SU_Pos)
#define RTC_TR_SU_2   (0x4UL << RTC_TR_SU_Pos)
#define RTC_TR_SU_3   (0x8UL << RTC_TR_SU_Pos)
#define RTC_DR_YT_Pos   (20U)
#define RTC_DR_YT_Msk   (0xFUL << RTC_DR_YT_Pos)
#define RTC_DR_YT   RTC_DR_YT_Msk
#define RTC_DR_YT_0   (0x1UL << RTC_DR_YT_Pos)
#define RTC_DR_YT_1   (0x2UL << RTC_DR_YT_Pos)
#define RTC_DR_YT_2   (0x4UL << RTC_DR_YT_Pos)
#define RTC_DR_YT_3   (0x8UL << RTC_DR_YT_Pos)
#define RTC_DR_YU_Pos   (16U)
#define RTC_DR_YU_Msk   (0xFUL << RTC_DR_YU_Pos)
#define RTC_DR_YU   RTC_DR_YU_Msk
#define RTC_DR_YU_0   (0x1UL << RTC_DR_YU_Pos)
#define RTC_DR_YU_1   (0x2UL << RTC_DR_YU_Pos)
#define RTC_DR_YU_2   (0x4UL << RTC_DR_YU_Pos)
#define RTC_DR_YU_3   (0x8UL << RTC_DR_YU_Pos)
#define RTC_DR_WDU_Pos   (13U)
#define RTC_DR_WDU_Msk   (0x7UL << RTC_DR_WDU_Pos)
#define RTC_DR_WDU   RTC_DR_WDU_Msk
#define RTC_DR_WDU_0   (0x1UL << RTC_DR_WDU_Pos)
#define RTC_DR_WDU_1   (0x2UL << RTC_DR_WDU_Pos)
#define RTC_DR_WDU_2   (0x4UL << RTC_DR_WDU_Pos)
#define RTC_DR_MT_Pos   (12U)
#define RTC_DR_MT_Msk   (0x1UL << RTC_DR_MT_Pos)
#define RTC_DR_MT   RTC_DR_MT_Msk
#define RTC_DR_MU_Pos   (8U)
#define RTC_DR_MU_Msk   (0xFUL << RTC_DR_MU_Pos)
#define RTC_DR_MU   RTC_DR_MU_Msk
#define RTC_DR_MU_0   (0x1UL << RTC_DR_MU_Pos)
#define RTC_DR_MU_1   (0x2UL << RTC_DR_MU_Pos)
#define RTC_DR_MU_2   (0x4UL << RTC_DR_MU_Pos)
#define RTC_DR_MU_3   (0x8UL << RTC_DR_MU_Pos)
#define RTC_DR_DT_Pos   (4U)
#define RTC_DR_DT_Msk   (0x3UL << RTC_DR_DT_Pos)
#define RTC_DR_DT   RTC_DR_DT_Msk
#define RTC_DR_DT_0   (0x1UL << RTC_DR_DT_Pos)
#define RTC_DR_DT_1   (0x2UL << RTC_DR_DT_Pos)
#define RTC_DR_DU_Pos   (0U)
#define RTC_DR_DU_Msk   (0xFUL << RTC_DR_DU_Pos)
#define RTC_DR_DU   RTC_DR_DU_Msk
#define RTC_DR_DU_0   (0x1UL << RTC_DR_DU_Pos)
#define RTC_DR_DU_1   (0x2UL << RTC_DR_DU_Pos)
#define RTC_DR_DU_2   (0x4UL << RTC_DR_DU_Pos)
#define RTC_DR_DU_3   (0x8UL << RTC_DR_DU_Pos)
#define RTC_CR_OUT2EN_Pos   (31U)
#define RTC_CR_OUT2EN_Msk   (0x1UL << RTC_CR_OUT2EN_Pos)
#define RTC_CR_OUT2EN   RTC_CR_OUT2EN_Msk
#define RTC_CR_TAMPALRM_TYPE_Pos   (30U)
#define RTC_CR_TAMPALRM_TYPE_Msk   (0x1UL << RTC_CR_TAMPALRM_TYPE_Pos)
#define RTC_CR_TAMPALRM_TYPE   RTC_CR_TAMPALRM_TYPE_Msk
#define RTC_CR_TAMPALRM_PU_Pos   (29U)
#define RTC_CR_TAMPALRM_PU_Msk   (0x1UL << RTC_CR_TAMPALRM_PU_Pos)
#define RTC_CR_TAMPALRM_PU   RTC_CR_TAMPALRM_PU_Msk
#define RTC_CR_TAMPOE_Pos   (26U)
#define RTC_CR_TAMPOE_Msk   (0x1UL << RTC_CR_TAMPOE_Pos)
#define RTC_CR_TAMPOE   RTC_CR_TAMPOE_Msk
#define RTC_CR_TAMPTS_Pos   (25U)
#define RTC_CR_TAMPTS_Msk   (0x1UL << RTC_CR_TAMPTS_Pos)
#define RTC_CR_TAMPTS   RTC_CR_TAMPTS_Msk
#define RTC_CR_ITSE_Pos   (24U)
#define RTC_CR_ITSE_Msk   (0x1UL << RTC_CR_ITSE_Pos)
#define RTC_CR_ITSE   RTC_CR_ITSE_Msk
#define RTC_CR_COE_Pos   (23U)
#define RTC_CR_COE_Msk   (0x1UL << RTC_CR_COE_Pos)
#define RTC_CR_COE   RTC_CR_COE_Msk
#define RTC_CR_OSEL_Pos   (21U)
#define RTC_CR_OSEL_Msk   (0x3UL << RTC_CR_OSEL_Pos)
#define RTC_CR_OSEL   RTC_CR_OSEL_Msk
#define RTC_CR_OSEL_0   (0x1UL << RTC_CR_OSEL_Pos)
#define RTC_CR_OSEL_1   (0x2UL << RTC_CR_OSEL_Pos)
#define RTC_CR_POL_Pos   (20U)
#define RTC_CR_POL_Msk   (0x1UL << RTC_CR_POL_Pos)
#define RTC_CR_POL   RTC_CR_POL_Msk
#define RTC_CR_COSEL_Pos   (19U)
#define RTC_CR_COSEL_Msk   (0x1UL << RTC_CR_COSEL_Pos)
#define RTC_CR_COSEL   RTC_CR_COSEL_Msk
#define RTC_CR_BKP_Pos   (18U)
#define RTC_CR_BKP_Msk   (0x1UL << RTC_CR_BKP_Pos)
#define RTC_CR_BKP   RTC_CR_BKP_Msk
#define RTC_CR_SUB1H_Pos   (17U)
#define RTC_CR_SUB1H_Msk   (0x1UL << RTC_CR_SUB1H_Pos)
#define RTC_CR_SUB1H   RTC_CR_SUB1H_Msk
#define RTC_CR_ADD1H_Pos   (16U)
#define RTC_CR_ADD1H_Msk   (0x1UL << RTC_CR_ADD1H_Pos)
#define RTC_CR_ADD1H   RTC_CR_ADD1H_Msk
#define RTC_CR_TSIE_Pos   (15U)
#define RTC_CR_TSIE_Msk   (0x1UL << RTC_CR_TSIE_Pos)
#define RTC_CR_TSIE   RTC_CR_TSIE_Msk
#define RTC_CR_WUTIE_Pos   (14U)
#define RTC_CR_WUTIE_Msk   (0x1UL << RTC_CR_WUTIE_Pos)
#define RTC_CR_WUTIE   RTC_CR_WUTIE_Msk
#define RTC_CR_ALRBIE_Pos   (13U)
#define RTC_CR_ALRBIE_Msk   (0x1UL << RTC_CR_ALRBIE_Pos)
#define RTC_CR_ALRBIE   RTC_CR_ALRBIE_Msk
#define RTC_CR_ALRAIE_Pos   (12U)
#define RTC_CR_ALRAIE_Msk   (0x1UL << RTC_CR_ALRAIE_Pos)
#define RTC_CR_ALRAIE   RTC_CR_ALRAIE_Msk
#define RTC_CR_TSE_Pos   (11U)
#define RTC_CR_TSE_Msk   (0x1UL << RTC_CR_TSE_Pos)
#define RTC_CR_TSE   RTC_CR_TSE_Msk
#define RTC_CR_WUTE_Pos   (10U)
#define RTC_CR_WUTE_Msk   (0x1UL << RTC_CR_WUTE_Pos)
#define RTC_CR_WUTE   RTC_CR_WUTE_Msk
#define RTC_CR_ALRBE_Pos   (9U)
#define RTC_CR_ALRBE_Msk   (0x1UL << RTC_CR_ALRBE_Pos)
#define RTC_CR_ALRBE   RTC_CR_ALRBE_Msk
#define RTC_CR_ALRAE_Pos   (8U)
#define RTC_CR_ALRAE_Msk   (0x1UL << RTC_CR_ALRAE_Pos)
#define RTC_CR_ALRAE   RTC_CR_ALRAE_Msk
#define RTC_CR_FMT_Pos   (6U)
#define RTC_CR_FMT_Msk   (0x1UL << RTC_CR_FMT_Pos)
#define RTC_CR_FMT   RTC_CR_FMT_Msk
#define RTC_CR_BYPSHAD_Pos   (5U)
#define RTC_CR_BYPSHAD_Msk   (0x1UL << RTC_CR_BYPSHAD_Pos)
#define RTC_CR_BYPSHAD   RTC_CR_BYPSHAD_Msk
#define RTC_CR_REFCKON_Pos   (4U)
#define RTC_CR_REFCKON_Msk   (0x1UL << RTC_CR_REFCKON_Pos)
#define RTC_CR_REFCKON   RTC_CR_REFCKON_Msk
#define RTC_CR_TSEDGE_Pos   (3U)
#define RTC_CR_TSEDGE_Msk   (0x1UL << RTC_CR_TSEDGE_Pos)
#define RTC_CR_TSEDGE   RTC_CR_TSEDGE_Msk
#define RTC_CR_WUCKSEL_Pos   (0U)
#define RTC_CR_WUCKSEL_Msk   (0x7UL << RTC_CR_WUCKSEL_Pos)
#define RTC_CR_WUCKSEL   RTC_CR_WUCKSEL_Msk
#define RTC_CR_WUCKSEL_0   (0x1UL << RTC_CR_WUCKSEL_Pos)
#define RTC_CR_WUCKSEL_1   (0x2UL << RTC_CR_WUCKSEL_Pos)
#define RTC_CR_WUCKSEL_2   (0x4UL << RTC_CR_WUCKSEL_Pos)
#define RTC_ICSR_RECALPF_Pos   (16U)
#define RTC_ICSR_RECALPF_Msk   (0x1UL << RTC_ICSR_RECALPF_Pos)
#define RTC_ICSR_RECALPF   RTC_ICSR_RECALPF_Msk
#define RTC_ICSR_INIT_Pos   (7U)
#define RTC_ICSR_INIT_Msk   (0x1UL << RTC_ICSR_INIT_Pos)
#define RTC_ICSR_INIT   RTC_ICSR_INIT_Msk
#define RTC_ICSR_INITF_Pos   (6U)
#define RTC_ICSR_INITF_Msk   (0x1UL << RTC_ICSR_INITF_Pos)
#define RTC_ICSR_INITF   RTC_ICSR_INITF_Msk
#define RTC_ICSR_RSF_Pos   (5U)
#define RTC_ICSR_RSF_Msk   (0x1UL << RTC_ICSR_RSF_Pos)
#define RTC_ICSR_RSF   RTC_ICSR_RSF_Msk
#define RTC_ICSR_INITS_Pos   (4U)
#define RTC_ICSR_INITS_Msk   (0x1UL << RTC_ICSR_INITS_Pos)
#define RTC_ICSR_INITS   RTC_ICSR_INITS_Msk
#define RTC_ICSR_SHPF_Pos   (3U)
#define RTC_ICSR_SHPF_Msk   (0x1UL << RTC_ICSR_SHPF_Pos)
#define RTC_ICSR_SHPF   RTC_ICSR_SHPF_Msk
#define RTC_ICSR_WUTWF_Pos   (2U)
#define RTC_ICSR_WUTWF_Msk   (0x1UL << RTC_ICSR_WUTWF_Pos)
#define RTC_ICSR_WUTWF   RTC_ICSR_WUTWF_Msk
#define RTC_ICSR_ALRBWF_Pos   (1U)
#define RTC_ICSR_ALRBWF_Msk   (0x1UL << RTC_ICSR_ALRBWF_Pos)
#define RTC_ICSR_ALRBWF   RTC_ICSR_ALRBWF_Msk
#define RTC_ICSR_ALRAWF_Pos   (0U)
#define RTC_ICSR_ALRAWF_Msk   (0x1UL << RTC_ICSR_ALRAWF_Pos)
#define RTC_ICSR_ALRAWF   RTC_ICSR_ALRAWF_Msk
#define RTC_PRER_PREDIV_A_Pos   (16U)
#define RTC_PRER_PREDIV_A_Msk   (0x7FUL << RTC_PRER_PREDIV_A_Pos)
#define RTC_PRER_PREDIV_A   RTC_PRER_PREDIV_A_Msk
#define RTC_PRER_PREDIV_S_Pos   (0U)
#define RTC_PRER_PREDIV_S_Msk   (0x7FFFUL << RTC_PRER_PREDIV_S_Pos)
#define RTC_PRER_PREDIV_S   RTC_PRER_PREDIV_S_Msk
#define RTC_WUTR_WUT_Pos   (0U)
#define RTC_WUTR_WUT_Msk   (0xFFFFUL << RTC_WUTR_WUT_Pos)
#define RTC_WUTR_WUT   RTC_WUTR_WUT_Msk
#define RTC_ALRMAR_MSK4_Pos   (31U)
#define RTC_ALRMAR_MSK4_Msk   (0x1UL << RTC_ALRMAR_MSK4_Pos)
#define RTC_ALRMAR_MSK4   RTC_ALRMAR_MSK4_Msk
#define RTC_ALRMAR_WDSEL_Pos   (30U)
#define RTC_ALRMAR_WDSEL_Msk   (0x1UL << RTC_ALRMAR_WDSEL_Pos)
#define RTC_ALRMAR_WDSEL   RTC_ALRMAR_WDSEL_Msk
#define RTC_ALRMAR_DT_Pos   (28U)
#define RTC_ALRMAR_DT_Msk   (0x3UL << RTC_ALRMAR_DT_Pos)
#define RTC_ALRMAR_DT   RTC_ALRMAR_DT_Msk
#define RTC_ALRMAR_DT_0   (0x1UL << RTC_ALRMAR_DT_Pos)
#define RTC_ALRMAR_DT_1   (0x2UL << RTC_ALRMAR_DT_Pos)
#define RTC_ALRMAR_DU_Pos   (24U)
#define RTC_ALRMAR_DU_Msk   (0xFUL << RTC_ALRMAR_DU_Pos)
#define RTC_ALRMAR_DU   RTC_ALRMAR_DU_Msk
#define RTC_ALRMAR_DU_0   (0x1UL << RTC_ALRMAR_DU_Pos)
#define RTC_ALRMAR_DU_1   (0x2UL << RTC_ALRMAR_DU_Pos)
#define RTC_ALRMAR_DU_2   (0x4UL << RTC_ALRMAR_DU_Pos)
#define RTC_ALRMAR_DU_3   (0x8UL << RTC_ALRMAR_DU_Pos)
#define RTC_ALRMAR_MSK3_Pos   (23U)
#define RTC_ALRMAR_MSK3_Msk   (0x1UL << RTC_ALRMAR_MSK3_Pos)
#define RTC_ALRMAR_MSK3   RTC_ALRMAR_MSK3_Msk
#define RTC_ALRMAR_PM_Pos   (22U)
#define RTC_ALRMAR_PM_Msk   (0x1UL << RTC_ALRMAR_PM_Pos)
#define RTC_ALRMAR_PM   RTC_ALRMAR_PM_Msk
#define RTC_ALRMAR_HT_Pos   (20U)
#define RTC_ALRMAR_HT_Msk   (0x3UL << RTC_ALRMAR_HT_Pos)
#define RTC_ALRMAR_HT   RTC_ALRMAR_HT_Msk
#define RTC_ALRMAR_HT_0   (0x1UL << RTC_ALRMAR_HT_Pos)
#define RTC_ALRMAR_HT_1   (0x2UL << RTC_ALRMAR_HT_Pos)
#define RTC_ALRMAR_HU_Pos   (16U)
#define RTC_ALRMAR_HU_Msk   (0xFUL << RTC_ALRMAR_HU_Pos)
#define RTC_ALRMAR_HU   RTC_ALRMAR_HU_Msk
#define RTC_ALRMAR_HU_0   (0x1UL << RTC_ALRMAR_HU_Pos)
#define RTC_ALRMAR_HU_1   (0x2UL << RTC_ALRMAR_HU_Pos)
#define RTC_ALRMAR_HU_2   (0x4UL << RTC_ALRMAR_HU_Pos)
#define RTC_ALRMAR_HU_3   (0x8UL << RTC_ALRMAR_HU_Pos)
#define RTC_ALRMAR_MSK2_Pos   (15U)
#define RTC_ALRMAR_MSK2_Msk   (0x1UL << RTC_ALRMAR_MSK2_Pos)
#define RTC_ALRMAR_MSK2   RTC_ALRMAR_MSK2_Msk
#define RTC_ALRMAR_MNT_Pos   (12U)
#define RTC_ALRMAR_MNT_Msk   (0x7UL << RTC_ALRMAR_MNT_Pos)
#define RTC_ALRMAR_MNT   RTC_ALRMAR_MNT_Msk
#define RTC_ALRMAR_MNT_0   (0x1UL << RTC_ALRMAR_MNT_Pos)
#define RTC_ALRMAR_MNT_1   (0x2UL << RTC_ALRMAR_MNT_Pos)
#define RTC_ALRMAR_MNT_2   (0x4UL << RTC_ALRMAR_MNT_Pos)
#define RTC_ALRMAR_MNU_Pos   (8U)
#define RTC_ALRMAR_MNU_Msk   (0xFUL << RTC_ALRMAR_MNU_Pos)
#define RTC_ALRMAR_MNU   RTC_ALRMAR_MNU_Msk
#define RTC_ALRMAR_MNU_0   (0x1UL << RTC_ALRMAR_MNU_Pos)
#define RTC_ALRMAR_MNU_1   (0x2UL << RTC_ALRMAR_MNU_Pos)
#define RTC_ALRMAR_MNU_2   (0x4UL << RTC_ALRMAR_MNU_Pos)
#define RTC_ALRMAR_MNU_3   (0x8UL << RTC_ALRMAR_MNU_Pos)
#define RTC_ALRMAR_MSK1_Pos   (7U)
#define RTC_ALRMAR_MSK1_Msk   (0x1UL << RTC_ALRMAR_MSK1_Pos)
#define RTC_ALRMAR_MSK1   RTC_ALRMAR_MSK1_Msk
#define RTC_ALRMAR_ST_Pos   (4U)
#define RTC_ALRMAR_ST_Msk   (0x7UL << RTC_ALRMAR_ST_Pos)
#define RTC_ALRMAR_ST   RTC_ALRMAR_ST_Msk
#define RTC_ALRMAR_ST_0   (0x1UL << RTC_ALRMAR_ST_Pos)
#define RTC_ALRMAR_ST_1   (0x2UL << RTC_ALRMAR_ST_Pos)
#define RTC_ALRMAR_ST_2   (0x4UL << RTC_ALRMAR_ST_Pos)
#define RTC_ALRMAR_SU_Pos   (0U)
#define RTC_ALRMAR_SU_Msk   (0xFUL << RTC_ALRMAR_SU_Pos)
#define RTC_ALRMAR_SU   RTC_ALRMAR_SU_Msk
#define RTC_ALRMAR_SU_0   (0x1UL << RTC_ALRMAR_SU_Pos)
#define RTC_ALRMAR_SU_1   (0x2UL << RTC_ALRMAR_SU_Pos)
#define RTC_ALRMAR_SU_2   (0x4UL << RTC_ALRMAR_SU_Pos)
#define RTC_ALRMAR_SU_3   (0x8UL << RTC_ALRMAR_SU_Pos)
#define RTC_ALRMBR_MSK4_Pos   (31U)
#define RTC_ALRMBR_MSK4_Msk   (0x1UL << RTC_ALRMBR_MSK4_Pos)
#define RTC_ALRMBR_MSK4   RTC_ALRMBR_MSK4_Msk
#define RTC_ALRMBR_WDSEL_Pos   (30U)
#define RTC_ALRMBR_WDSEL_Msk   (0x1UL << RTC_ALRMBR_WDSEL_Pos)
#define RTC_ALRMBR_WDSEL   RTC_ALRMBR_WDSEL_Msk
#define RTC_ALRMBR_DT_Pos   (28U)
#define RTC_ALRMBR_DT_Msk   (0x3UL << RTC_ALRMBR_DT_Pos)
#define RTC_ALRMBR_DT   RTC_ALRMBR_DT_Msk
#define RTC_ALRMBR_DT_0   (0x1UL << RTC_ALRMBR_DT_Pos)
#define RTC_ALRMBR_DT_1   (0x2UL << RTC_ALRMBR_DT_Pos)
#define RTC_ALRMBR_DU_Pos   (24U)
#define RTC_ALRMBR_DU_Msk   (0xFUL << RTC_ALRMBR_DU_Pos)
#define RTC_ALRMBR_DU   RTC_ALRMBR_DU_Msk
#define RTC_ALRMBR_DU_0   (0x1UL << RTC_ALRMBR_DU_Pos)
#define RTC_ALRMBR_DU_1   (0x2UL << RTC_ALRMBR_DU_Pos)
#define RTC_ALRMBR_DU_2   (0x4UL << RTC_ALRMBR_DU_Pos)
#define RTC_ALRMBR_DU_3   (0x8UL << RTC_ALRMBR_DU_Pos)
#define RTC_ALRMBR_MSK3_Pos   (23U)
#define RTC_ALRMBR_MSK3_Msk   (0x1UL << RTC_ALRMBR_MSK3_Pos)
#define RTC_ALRMBR_MSK3   RTC_ALRMBR_MSK3_Msk
#define RTC_ALRMBR_PM_Pos   (22U)
#define RTC_ALRMBR_PM_Msk   (0x1UL << RTC_ALRMBR_PM_Pos)
#define RTC_ALRMBR_PM   RTC_ALRMBR_PM_Msk
#define RTC_ALRMBR_HT_Pos   (20U)
#define RTC_ALRMBR_HT_Msk   (0x3UL << RTC_ALRMBR_HT_Pos)
#define RTC_ALRMBR_HT   RTC_ALRMBR_HT_Msk
#define RTC_ALRMBR_HT_0   (0x1UL << RTC_ALRMBR_HT_Pos)
#define RTC_ALRMBR_HT_1   (0x2UL << RTC_ALRMBR_HT_Pos)
#define RTC_ALRMBR_HU_Pos   (16U)
#define RTC_ALRMBR_HU_Msk   (0xFUL << RTC_ALRMBR_HU_Pos)
#define RTC_ALRMBR_HU   RTC_ALRMBR_HU_Msk
#define RTC_ALRMBR_HU_0   (0x1UL << RTC_ALRMBR_HU_Pos)
#define RTC_ALRMBR_HU_1   (0x2UL << RTC_ALRMBR_HU_Pos)
#define RTC_ALRMBR_HU_2   (0x4UL << RTC_ALRMBR_HU_Pos)
#define RTC_ALRMBR_HU_3   (0x8UL << RTC_ALRMBR_HU_Pos)
#define RTC_ALRMBR_MSK2_Pos   (15U)
#define RTC_ALRMBR_MSK2_Msk   (0x1UL << RTC_ALRMBR_MSK2_Pos)
#define RTC_ALRMBR_MSK2   RTC_ALRMBR_MSK2_Msk
#define RTC_ALRMBR_MNT_Pos   (12U)
#define RTC_ALRMBR_MNT_Msk   (0x7UL << RTC_ALRMBR_MNT_Pos)
#define RTC_ALRMBR_MNT   RTC_ALRMBR_MNT_Msk
#define RTC_ALRMBR_MNT_0   (0x1UL << RTC_ALRMBR_MNT_Pos)
#define RTC_ALRMBR_MNT_1   (0x2UL << RTC_ALRMBR_MNT_Pos)
#define RTC_ALRMBR_MNT_2   (0x4UL << RTC_ALRMBR_MNT_Pos)
#define RTC_ALRMBR_MNU_Pos   (8U)
#define RTC_ALRMBR_MNU_Msk   (0xFUL << RTC_ALRMBR_MNU_Pos)
#define RTC_ALRMBR_MNU   RTC_ALRMBR_MNU_Msk
#define RTC_ALRMBR_MNU_0   (0x1UL << RTC_ALRMBR_MNU_Pos)
#define RTC_ALRMBR_MNU_1   (0x2UL << RTC_ALRMBR_MNU_Pos)
#define RTC_ALRMBR_MNU_2   (0x4UL << RTC_ALRMBR_MNU_Pos)
#define RTC_ALRMBR_MNU_3   (0x8UL << RTC_ALRMBR_MNU_Pos)
#define RTC_ALRMBR_MSK1_Pos   (7U)
#define RTC_ALRMBR_MSK1_Msk   (0x1UL << RTC_ALRMBR_MSK1_Pos)
#define RTC_ALRMBR_MSK1   RTC_ALRMBR_MSK1_Msk
#define RTC_ALRMBR_ST_Pos   (4U)
#define RTC_ALRMBR_ST_Msk   (0x7UL << RTC_ALRMBR_ST_Pos)
#define RTC_ALRMBR_ST   RTC_ALRMBR_ST_Msk
#define RTC_ALRMBR_ST_0   (0x1UL << RTC_ALRMBR_ST_Pos)
#define RTC_ALRMBR_ST_1   (0x2UL << RTC_ALRMBR_ST_Pos)
#define RTC_ALRMBR_ST_2   (0x4UL << RTC_ALRMBR_ST_Pos)
#define RTC_ALRMBR_SU_Pos   (0U)
#define RTC_ALRMBR_SU_Msk   (0xFUL << RTC_ALRMBR_SU_Pos)
#define RTC_ALRMBR_SU   RTC_ALRMBR_SU_Msk
#define RTC_ALRMBR_SU_0   (0x1UL << RTC_ALRMBR_SU_Pos)
#define RTC_ALRMBR_SU_1   (0x2UL << RTC_ALRMBR_SU_Pos)
#define RTC_ALRMBR_SU_2   (0x4UL << RTC_ALRMBR_SU_Pos)
#define RTC_ALRMBR_SU_3   (0x8UL << RTC_ALRMBR_SU_Pos)
#define RTC_WPR_KEY_Pos   (0U)
#define RTC_WPR_KEY_Msk   (0xFFUL << RTC_WPR_KEY_Pos)
#define RTC_WPR_KEY   RTC_WPR_KEY_Msk
#define RTC_SSR_SS_Pos   (0U)
#define RTC_SSR_SS_Msk   (0xFFFFUL << RTC_SSR_SS_Pos)
#define RTC_SSR_SS   RTC_SSR_SS_Msk
#define RTC_SHIFTR_SUBFS_Pos   (0U)
#define RTC_SHIFTR_SUBFS_Msk   (0x7FFFUL << RTC_SHIFTR_SUBFS_Pos)
#define RTC_SHIFTR_SUBFS   RTC_SHIFTR_SUBFS_Msk
#define RTC_SHIFTR_ADD1S_Pos   (31U)
#define RTC_SHIFTR_ADD1S_Msk   (0x1UL << RTC_SHIFTR_ADD1S_Pos)
#define RTC_SHIFTR_ADD1S   RTC_SHIFTR_ADD1S_Msk
#define RTC_TSTR_PM_Pos   (22U)
#define RTC_TSTR_PM_Msk   (0x1UL << RTC_TSTR_PM_Pos)
#define RTC_TSTR_PM   RTC_TSTR_PM_Msk
#define RTC_TSTR_HT_Pos   (20U)
#define RTC_TSTR_HT_Msk   (0x3UL << RTC_TSTR_HT_Pos)
#define RTC_TSTR_HT   RTC_TSTR_HT_Msk
#define RTC_TSTR_HT_0   (0x1UL << RTC_TSTR_HT_Pos)
#define RTC_TSTR_HT_1   (0x2UL << RTC_TSTR_HT_Pos)
#define RTC_TSTR_HU_Pos   (16U)
#define RTC_TSTR_HU_Msk   (0xFUL << RTC_TSTR_HU_Pos)
#define RTC_TSTR_HU   RTC_TSTR_HU_Msk
#define RTC_TSTR_HU_0   (0x1UL << RTC_TSTR_HU_Pos)
#define RTC_TSTR_HU_1   (0x2UL << RTC_TSTR_HU_Pos)
#define RTC_TSTR_HU_2   (0x4UL << RTC_TSTR_HU_Pos)
#define RTC_TSTR_HU_3   (0x8UL << RTC_TSTR_HU_Pos)
#define RTC_TSTR_MNT_Pos   (12U)
#define RTC_TSTR_MNT_Msk   (0x7UL << RTC_TSTR_MNT_Pos)
#define RTC_TSTR_MNT   RTC_TSTR_MNT_Msk
#define RTC_TSTR_MNT_0   (0x1UL << RTC_TSTR_MNT_Pos)
#define RTC_TSTR_MNT_1   (0x2UL << RTC_TSTR_MNT_Pos)
#define RTC_TSTR_MNT_2   (0x4UL << RTC_TSTR_MNT_Pos)
#define RTC_TSTR_MNU_Pos   (8U)
#define RTC_TSTR_MNU_Msk   (0xFUL << RTC_TSTR_MNU_Pos)
#define RTC_TSTR_MNU   RTC_TSTR_MNU_Msk
#define RTC_TSTR_MNU_0   (0x1UL << RTC_TSTR_MNU_Pos)
#define RTC_TSTR_MNU_1   (0x2UL << RTC_TSTR_MNU_Pos)
#define RTC_TSTR_MNU_2   (0x4UL << RTC_TSTR_MNU_Pos)
#define RTC_TSTR_MNU_3   (0x8UL << RTC_TSTR_MNU_Pos)
#define RTC_TSTR_ST_Pos   (4U)
#define RTC_TSTR_ST_Msk   (0x7UL << RTC_TSTR_ST_Pos)
#define RTC_TSTR_ST   RTC_TSTR_ST_Msk
#define RTC_TSTR_ST_0   (0x1UL << RTC_TSTR_ST_Pos)
#define RTC_TSTR_ST_1   (0x2UL << RTC_TSTR_ST_Pos)
#define RTC_TSTR_ST_2   (0x4UL << RTC_TSTR_ST_Pos)
#define RTC_TSTR_SU_Pos   (0U)
#define RTC_TSTR_SU_Msk   (0xFUL << RTC_TSTR_SU_Pos)
#define RTC_TSTR_SU   RTC_TSTR_SU_Msk
#define RTC_TSTR_SU_0   (0x1UL << RTC_TSTR_SU_Pos)
#define RTC_TSTR_SU_1   (0x2UL << RTC_TSTR_SU_Pos)
#define RTC_TSTR_SU_2   (0x4UL << RTC_TSTR_SU_Pos)
#define RTC_TSTR_SU_3   (0x8UL << RTC_TSTR_SU_Pos)
#define RTC_TSDR_WDU_Pos   (13U)
#define RTC_TSDR_WDU_Msk   (0x7UL << RTC_TSDR_WDU_Pos)
#define RTC_TSDR_WDU   RTC_TSDR_WDU_Msk
#define RTC_TSDR_WDU_0   (0x1UL << RTC_TSDR_WDU_Pos)
#define RTC_TSDR_WDU_1   (0x2UL << RTC_TSDR_WDU_Pos)
#define RTC_TSDR_WDU_2   (0x4UL << RTC_TSDR_WDU_Pos)
#define RTC_TSDR_MT_Pos   (12U)
#define RTC_TSDR_MT_Msk   (0x1UL << RTC_TSDR_MT_Pos)
#define RTC_TSDR_MT   RTC_TSDR_MT_Msk
#define RTC_TSDR_MU_Pos   (8U)
#define RTC_TSDR_MU_Msk   (0xFUL << RTC_TSDR_MU_Pos)
#define RTC_TSDR_MU   RTC_TSDR_MU_Msk
#define RTC_TSDR_MU_0   (0x1UL << RTC_TSDR_MU_Pos)
#define RTC_TSDR_MU_1   (0x2UL << RTC_TSDR_MU_Pos)
#define RTC_TSDR_MU_2   (0x4UL << RTC_TSDR_MU_Pos)
#define RTC_TSDR_MU_3   (0x8UL << RTC_TSDR_MU_Pos)
#define RTC_TSDR_DT_Pos   (4U)
#define RTC_TSDR_DT_Msk   (0x3UL << RTC_TSDR_DT_Pos)
#define RTC_TSDR_DT   RTC_TSDR_DT_Msk
#define RTC_TSDR_DT_0   (0x1UL << RTC_TSDR_DT_Pos)
#define RTC_TSDR_DT_1   (0x2UL << RTC_TSDR_DT_Pos)
#define RTC_TSDR_DU_Pos   (0U)
#define RTC_TSDR_DU_Msk   (0xFUL << RTC_TSDR_DU_Pos)
#define RTC_TSDR_DU   RTC_TSDR_DU_Msk
#define RTC_TSDR_DU_0   (0x1UL << RTC_TSDR_DU_Pos)
#define RTC_TSDR_DU_1   (0x2UL << RTC_TSDR_DU_Pos)
#define RTC_TSDR_DU_2   (0x4UL << RTC_TSDR_DU_Pos)
#define RTC_TSDR_DU_3   (0x8UL << RTC_TSDR_DU_Pos)
#define RTC_TSSSR_SS_Pos   (0U)
#define RTC_TSSSR_SS_Msk   (0xFFFFUL << RTC_TSSSR_SS_Pos)
#define RTC_TSSSR_SS   RTC_TSSSR_SS_Msk
#define RTC_CALR_CALP_Pos   (15U)
#define RTC_CALR_CALP_Msk   (0x1UL << RTC_CALR_CALP_Pos)
#define RTC_CALR_CALP   RTC_CALR_CALP_Msk
#define RTC_CALR_CALW8_Pos   (14U)
#define RTC_CALR_CALW8_Msk   (0x1UL << RTC_CALR_CALW8_Pos)
#define RTC_CALR_CALW8   RTC_CALR_CALW8_Msk
#define RTC_CALR_CALW16_Pos   (13U)
#define RTC_CALR_CALW16_Msk   (0x1UL << RTC_CALR_CALW16_Pos)
#define RTC_CALR_CALW16   RTC_CALR_CALW16_Msk
#define RTC_CALR_CALM_Pos   (0U)
#define RTC_CALR_CALM_Msk   (0x1FFUL << RTC_CALR_CALM_Pos)
#define RTC_CALR_CALM   RTC_CALR_CALM_Msk
#define RTC_CALR_CALM_0   (0x001UL << RTC_CALR_CALM_Pos)
#define RTC_CALR_CALM_1   (0x002UL << RTC_CALR_CALM_Pos)
#define RTC_CALR_CALM_2   (0x004UL << RTC_CALR_CALM_Pos)
#define RTC_CALR_CALM_3   (0x008UL << RTC_CALR_CALM_Pos)
#define RTC_CALR_CALM_4   (0x010UL << RTC_CALR_CALM_Pos)
#define RTC_CALR_CALM_5   (0x020UL << RTC_CALR_CALM_Pos)
#define RTC_CALR_CALM_6   (0x040UL << RTC_CALR_CALM_Pos)
#define RTC_CALR_CALM_7   (0x080UL << RTC_CALR_CALM_Pos)
#define RTC_CALR_CALM_8   (0x100UL << RTC_CALR_CALM_Pos)
#define RTC_ALRMASSR_MASKSS_Pos   (24U)
#define RTC_ALRMASSR_MASKSS_Msk   (0xFUL << RTC_ALRMASSR_MASKSS_Pos)
#define RTC_ALRMASSR_MASKSS   RTC_ALRMASSR_MASKSS_Msk
#define RTC_ALRMASSR_MASKSS_0   (0x1UL << RTC_ALRMASSR_MASKSS_Pos)
#define RTC_ALRMASSR_MASKSS_1   (0x2UL << RTC_ALRMASSR_MASKSS_Pos)
#define RTC_ALRMASSR_MASKSS_2   (0x4UL << RTC_ALRMASSR_MASKSS_Pos)
#define RTC_ALRMASSR_MASKSS_3   (0x8UL << RTC_ALRMASSR_MASKSS_Pos)
#define RTC_ALRMASSR_SS_Pos   (0U)
#define RTC_ALRMASSR_SS_Msk   (0x7FFFUL << RTC_ALRMASSR_SS_Pos)
#define RTC_ALRMASSR_SS   RTC_ALRMASSR_SS_Msk
#define RTC_ALRMBSSR_MASKSS_Pos   (24U)
#define RTC_ALRMBSSR_MASKSS_Msk   (0xFUL << RTC_ALRMBSSR_MASKSS_Pos)
#define RTC_ALRMBSSR_MASKSS   RTC_ALRMBSSR_MASKSS_Msk
#define RTC_ALRMBSSR_MASKSS_0   (0x1UL << RTC_ALRMBSSR_MASKSS_Pos)
#define RTC_ALRMBSSR_MASKSS_1   (0x2UL << RTC_ALRMBSSR_MASKSS_Pos)
#define RTC_ALRMBSSR_MASKSS_2   (0x4UL << RTC_ALRMBSSR_MASKSS_Pos)
#define RTC_ALRMBSSR_MASKSS_3   (0x8UL << RTC_ALRMBSSR_MASKSS_Pos)
#define RTC_ALRMBSSR_SS_Pos   (0U)
#define RTC_ALRMBSSR_SS_Msk   (0x7FFFUL << RTC_ALRMBSSR_SS_Pos)
#define RTC_ALRMBSSR_SS   RTC_ALRMBSSR_SS_Msk
#define RTC_SR_ITSF_Pos   (5U)
#define RTC_SR_ITSF_Msk   (0x1UL << RTC_SR_ITSF_Pos)
#define RTC_SR_ITSF   RTC_SR_ITSF_Msk
#define RTC_SR_TSOVF_Pos   (4U)
#define RTC_SR_TSOVF_Msk   (0x1UL << RTC_SR_TSOVF_Pos)
#define RTC_SR_TSOVF   RTC_SR_TSOVF_Msk
#define RTC_SR_TSF_Pos   (3U)
#define RTC_SR_TSF_Msk   (0x1UL << RTC_SR_TSF_Pos)
#define RTC_SR_TSF   RTC_SR_TSF_Msk
#define RTC_SR_WUTF_Pos   (2U)
#define RTC_SR_WUTF_Msk   (0x1UL << RTC_SR_WUTF_Pos)
#define RTC_SR_WUTF   RTC_SR_WUTF_Msk
#define RTC_SR_ALRBF_Pos   (1U)
#define RTC_SR_ALRBF_Msk   (0x1UL << RTC_SR_ALRBF_Pos)
#define RTC_SR_ALRBF   RTC_SR_ALRBF_Msk
#define RTC_SR_ALRAF_Pos   (0U)
#define RTC_SR_ALRAF_Msk   (0x1UL << RTC_SR_ALRAF_Pos)
#define RTC_SR_ALRAF   RTC_SR_ALRAF_Msk
#define RTC_MISR_ITSMF_Pos   (5U)
#define RTC_MISR_ITSMF_Msk   (0x1UL << RTC_MISR_ITSMF_Pos)
#define RTC_MISR_ITSMF   RTC_MISR_ITSMF_Msk
#define RTC_MISR_TSOVMF_Pos   (4U)
#define RTC_MISR_TSOVMF_Msk   (0x1UL << RTC_MISR_TSOVMF_Pos)
#define RTC_MISR_TSOVMF   RTC_MISR_TSOVMF_Msk
#define RTC_MISR_TSMF_Pos   (3U)
#define RTC_MISR_TSMF_Msk   (0x1UL << RTC_MISR_TSMF_Pos)
#define RTC_MISR_TSMF   RTC_MISR_TSMF_Msk
#define RTC_MISR_WUTMF_Pos   (2U)
#define RTC_MISR_WUTMF_Msk   (0x1UL << RTC_MISR_WUTMF_Pos)
#define RTC_MISR_WUTMF   RTC_MISR_WUTMF_Msk
#define RTC_MISR_ALRBMF_Pos   (1U)
#define RTC_MISR_ALRBMF_Msk   (0x1UL << RTC_MISR_ALRBMF_Pos)
#define RTC_MISR_ALRBMF   RTC_MISR_ALRBMF_Msk
#define RTC_MISR_ALRAMF_Pos   (0U)
#define RTC_MISR_ALRAMF_Msk   (0x1UL << RTC_MISR_ALRAMF_Pos)
#define RTC_MISR_ALRAMF   RTC_MISR_ALRAMF_Msk
#define RTC_SCR_CITSF_Pos   (5U)
#define RTC_SCR_CITSF_Msk   (0x1UL << RTC_SCR_CITSF_Pos)
#define RTC_SCR_CITSF   RTC_SCR_CITSF_Msk
#define RTC_SCR_CTSOVF_Pos   (4U)
#define RTC_SCR_CTSOVF_Msk   (0x1UL << RTC_SCR_CTSOVF_Pos)
#define RTC_SCR_CTSOVF   RTC_SCR_CTSOVF_Msk
#define RTC_SCR_CTSF_Pos   (3U)
#define RTC_SCR_CTSF_Msk   (0x1UL << RTC_SCR_CTSF_Pos)
#define RTC_SCR_CTSF   RTC_SCR_CTSF_Msk
#define RTC_SCR_CWUTF_Pos   (2U)
#define RTC_SCR_CWUTF_Msk   (0x1UL << RTC_SCR_CWUTF_Pos)
#define RTC_SCR_CWUTF   RTC_SCR_CWUTF_Msk
#define RTC_SCR_CALRBF_Pos   (1U)
#define RTC_SCR_CALRBF_Msk   (0x1UL << RTC_SCR_CALRBF_Pos)
#define RTC_SCR_CALRBF   RTC_SCR_CALRBF_Msk
#define RTC_SCR_CALRAF_Pos   (0U)
#define RTC_SCR_CALRAF_Msk   (0x1UL << RTC_SCR_CALRAF_Pos)
#define RTC_SCR_CALRAF   RTC_SCR_CALRAF_Msk
#define TAMP_CR1_TAMP1E_Pos   (0U)
#define TAMP_CR1_TAMP1E_Msk   (0x1UL << TAMP_CR1_TAMP1E_Pos)
#define TAMP_CR1_TAMP1E   TAMP_CR1_TAMP1E_Msk
#define TAMP_CR1_TAMP2E_Pos   (1U)
#define TAMP_CR1_TAMP2E_Msk   (0x1UL << TAMP_CR1_TAMP2E_Pos)
#define TAMP_CR1_TAMP2E   TAMP_CR1_TAMP2E_Msk
#define TAMP_CR1_TAMP3E_Pos   (2U)
#define TAMP_CR1_TAMP3E_Msk   (0x1UL << TAMP_CR1_TAMP3E_Pos)
#define TAMP_CR1_TAMP3E   TAMP_CR1_TAMP3E_Msk
#define TAMP_CR1_ITAMP1E_Pos   (16U)
#define TAMP_CR1_ITAMP1E_Msk   (0x1UL << TAMP_CR1_ITAMP1E_Pos)
#define TAMP_CR1_ITAMP1E   TAMP_CR1_ITAMP1E_Msk
#define TAMP_CR1_ITAMP2E_Pos   (17U)
#define TAMP_CR1_ITAMP2E_Msk   (0x1UL << TAMP_CR1_ITAMP2E_Pos)
#define TAMP_CR1_ITAMP2E   TAMP_CR1_ITAMP2E_Msk
#define TAMP_CR1_ITAMP3E_Pos   (18U)
#define TAMP_CR1_ITAMP3E_Msk   (0x1UL << TAMP_CR1_ITAMP3E_Pos)
#define TAMP_CR1_ITAMP3E   TAMP_CR1_ITAMP3E_Msk
#define TAMP_CR1_ITAMP4E_Pos   (19U)
#define TAMP_CR1_ITAMP4E_Msk   (0x1UL << TAMP_CR1_ITAMP4E_Pos)
#define TAMP_CR1_ITAMP4E   TAMP_CR1_ITAMP4E_Msk
#define TAMP_CR1_ITAMP5E_Pos   (20U)
#define TAMP_CR1_ITAMP5E_Msk   (0x1UL << TAMP_CR1_ITAMP5E_Pos)
#define TAMP_CR1_ITAMP5E   TAMP_CR1_ITAMP5E_Msk
#define TAMP_CR1_ITAMP6E_Pos   (21U)
#define TAMP_CR1_ITAMP6E_Msk   (0x1UL << TAMP_CR1_ITAMP6E_Pos)
#define TAMP_CR1_ITAMP6E   TAMP_CR1_ITAMP6E_Msk
#define TAMP_CR1_ITAMP8E_Pos   (23U)
#define TAMP_CR1_ITAMP8E_Msk   (0x1UL << TAMP_CR1_ITAMP8E_Pos)
#define TAMP_CR1_ITAMP8E   TAMP_CR1_ITAMP8E_Msk
#define TAMP_CR2_TAMP1NOERASE_Pos   (0U)
#define TAMP_CR2_TAMP1NOERASE_Msk   (0x1UL << TAMP_CR2_TAMP1NOERASE_Pos)
#define TAMP_CR2_TAMP1NOERASE   TAMP_CR2_TAMP1NOERASE_Msk
#define TAMP_CR2_TAMP2NOERASE_Pos   (1U)
#define TAMP_CR2_TAMP2NOERASE_Msk   (0x1UL << TAMP_CR2_TAMP2NOERASE_Pos)
#define TAMP_CR2_TAMP2NOERASE   TAMP_CR2_TAMP2NOERASE_Msk
#define TAMP_CR2_TAMP3NOERASE_Pos   (2U)
#define TAMP_CR2_TAMP3NOERASE_Msk   (0x1UL << TAMP_CR2_TAMP3NOERASE_Pos)
#define TAMP_CR2_TAMP3NOERASE   TAMP_CR2_TAMP3NOERASE_Msk
#define TAMP_CR2_TAMP1MSK_Pos   (16U)
#define TAMP_CR2_TAMP1MSK_Msk   (0x1UL << TAMP_CR2_TAMP1MSK_Pos)
#define TAMP_CR2_TAMP1MSK   TAMP_CR2_TAMP1MSK_Msk
#define TAMP_CR2_TAMP2MSK_Pos   (17U)
#define TAMP_CR2_TAMP2MSK_Msk   (0x1UL << TAMP_CR2_TAMP2MSK_Pos)
#define TAMP_CR2_TAMP2MSK   TAMP_CR2_TAMP2MSK_Msk
#define TAMP_CR2_TAMP3MSK_Pos   (18U)
#define TAMP_CR2_TAMP3MSK_Msk   (0x1UL << TAMP_CR2_TAMP3MSK_Pos)
#define TAMP_CR2_TAMP3MSK   TAMP_CR2_TAMP3MSK_Msk
#define TAMP_CR2_TAMP1TRG_Pos   (24U)
#define TAMP_CR2_TAMP1TRG_Msk   (0x1UL << TAMP_CR2_TAMP1TRG_Pos)
#define TAMP_CR2_TAMP1TRG   TAMP_CR2_TAMP1TRG_Msk
#define TAMP_CR2_TAMP2TRG_Pos   (25U)
#define TAMP_CR2_TAMP2TRG_Msk   (0x1UL << TAMP_CR2_TAMP2TRG_Pos)
#define TAMP_CR2_TAMP2TRG   TAMP_CR2_TAMP2TRG_Msk
#define TAMP_CR2_TAMP3TRG_Pos   (26U)
#define TAMP_CR2_TAMP3TRG_Msk   (0x1UL << TAMP_CR2_TAMP3TRG_Pos)
#define TAMP_CR2_TAMP3TRG   TAMP_CR2_TAMP3TRG_Msk
#define TAMP_FLTCR_TAMPFREQ_Pos   (0U)
#define TAMP_FLTCR_TAMPFREQ_Msk   (0x7UL << TAMP_FLTCR_TAMPFREQ_Pos)
#define TAMP_FLTCR_TAMPFREQ   TAMP_FLTCR_TAMPFREQ_Msk
#define TAMP_FLTCR_TAMPFREQ_0   (0x1UL << TAMP_FLTCR_TAMPFREQ_Pos)
#define TAMP_FLTCR_TAMPFREQ_1   (0x2UL << TAMP_FLTCR_TAMPFREQ_Pos)
#define TAMP_FLTCR_TAMPFREQ_2   (0x4UL << TAMP_FLTCR_TAMPFREQ_Pos)
#define TAMP_FLTCR_TAMPFLT_Pos   (3U)
#define TAMP_FLTCR_TAMPFLT_Msk   (0x3UL << TAMP_FLTCR_TAMPFLT_Pos)
#define TAMP_FLTCR_TAMPFLT   TAMP_FLTCR_TAMPFLT_Msk
#define TAMP_FLTCR_TAMPFLT_0   (0x1UL << TAMP_FLTCR_TAMPFLT_Pos)
#define TAMP_FLTCR_TAMPFLT_1   (0x2UL << TAMP_FLTCR_TAMPFLT_Pos)
#define TAMP_FLTCR_TAMPPRCH_Pos   (5U)
#define TAMP_FLTCR_TAMPPRCH_Msk   (0x3UL << TAMP_FLTCR_TAMPPRCH_Pos)
#define TAMP_FLTCR_TAMPPRCH   TAMP_FLTCR_TAMPPRCH_Msk
#define TAMP_FLTCR_TAMPPRCH_0   (0x1UL << TAMP_FLTCR_TAMPPRCH_Pos)
#define TAMP_FLTCR_TAMPPRCH_1   (0x2UL << TAMP_FLTCR_TAMPPRCH_Pos)
#define TAMP_FLTCR_TAMPPUDIS_Pos   (7U)
#define TAMP_FLTCR_TAMPPUDIS_Msk   (0x1UL << TAMP_FLTCR_TAMPPUDIS_Pos)
#define TAMP_FLTCR_TAMPPUDIS   TAMP_FLTCR_TAMPPUDIS_Msk
#define TAMP_ATCR1_TAMP1AM_Pos   (0U)
#define TAMP_ATCR1_TAMP1AM_Msk   (0x1UL << TAMP_ATCR1_TAMP1AM_Pos)
#define TAMP_ATCR1_TAMP1AM   TAMP_ATCR1_TAMP1AM_Msk
#define TAMP_ATCR1_TAMP2AM_Pos   (1U)
#define TAMP_ATCR1_TAMP2AM_Msk   (0x1UL << TAMP_ATCR1_TAMP2AM_Pos)
#define TAMP_ATCR1_TAMP2AM   TAMP_ATCR1_TAMP2AM_Msk
#define TAMP_ATCR1_TAMP3AM_Pos   (2U)
#define TAMP_ATCR1_TAMP3AM_Msk   (0x1UL << TAMP_ATCR1_TAMP3AM_Pos)
#define TAMP_ATCR1_TAMP3AM   TAMP_ATCR1_TAMP3AM_Msk
#define TAMP_ATCR1_ATOSEL1_Pos   (8U)
#define TAMP_ATCR1_ATOSEL1_Msk   (0x3UL << TAMP_ATCR1_ATOSEL1_Pos)
#define TAMP_ATCR1_ATOSEL1   TAMP_ATCR1_ATOSEL1_Msk
#define TAMP_ATCR1_ATOSEL1_0   (0x1UL << TAMP_ATCR1_ATOSEL1_Pos)
#define TAMP_ATCR1_ATOSEL1_1   (0x2UL << TAMP_ATCR1_ATOSEL1_Pos)
#define TAMP_ATCR1_ATOSEL2_Pos   (10U)
#define TAMP_ATCR1_ATOSEL2_Msk   (0x3UL << TAMP_ATCR1_ATOSEL2_Pos)
#define TAMP_ATCR1_ATOSEL2   TAMP_ATCR1_ATOSEL2_Msk
#define TAMP_ATCR1_ATOSEL2_0   (0x1UL << TAMP_ATCR1_ATOSEL2_Pos)
#define TAMP_ATCR1_ATOSEL2_1   (0x2UL << TAMP_ATCR1_ATOSEL2_Pos)
#define TAMP_ATCR1_ATOSEL3_Pos   (12U)
#define TAMP_ATCR1_ATOSEL3_Msk   (0x3UL << TAMP_ATCR1_ATOSEL3_Pos)
#define TAMP_ATCR1_ATOSEL3   TAMP_ATCR1_ATOSEL3_Msk
#define TAMP_ATCR1_ATOSEL3_0   (0x1UL << TAMP_ATCR1_ATOSEL3_Pos)
#define TAMP_ATCR1_ATOSEL3_1   (0x2UL << TAMP_ATCR1_ATOSEL3_Pos)
#define TAMP_ATCR1_ATOSEL4_Pos   (14U)
#define TAMP_ATCR1_ATOSEL4_Msk   (0x3UL << TAMP_ATCR1_ATOSEL4_Pos)
#define TAMP_ATCR1_ATOSEL4   TAMP_ATCR1_ATOSEL4_Msk
#define TAMP_ATCR1_ATOSEL4_0   (0x1UL << TAMP_ATCR1_ATOSEL4_Pos)
#define TAMP_ATCR1_ATOSEL4_1   (0x2UL << TAMP_ATCR1_ATOSEL4_Pos)
#define TAMP_ATCR1_ATCKSEL_Pos   (16U)
#define TAMP_ATCR1_ATCKSEL_Msk   (0x7UL << TAMP_ATCR1_ATCKSEL_Pos)
#define TAMP_ATCR1_ATCKSEL   TAMP_ATCR1_ATCKSEL_Msk
#define TAMP_ATCR1_ATCKSEL_0   (0x1UL << TAMP_ATCR1_ATCKSEL_Pos)
#define TAMP_ATCR1_ATCKSEL_1   (0x2UL << TAMP_ATCR1_ATCKSEL_Pos)
#define TAMP_ATCR1_ATCKSEL_2   (0x4UL << TAMP_ATCR1_ATCKSEL_Pos)
#define TAMP_ATCR1_ATPER_Pos   (24U)
#define TAMP_ATCR1_ATPER_Msk   (0x7UL << TAMP_ATCR1_ATPER_Pos)
#define TAMP_ATCR1_ATPER   TAMP_ATCR1_ATPER_Msk
#define TAMP_ATCR1_ATOSHARE_Pos   (30U)
#define TAMP_ATCR1_ATOSHARE_Msk   (0x1UL << TAMP_ATCR1_ATOSHARE_Pos)
#define TAMP_ATCR1_ATOSHARE   TAMP_ATCR1_ATOSHARE_Msk
#define TAMP_ATCR1_FLTEN_Pos   (31U)
#define TAMP_ATCR1_FLTEN_Msk   (0x1UL << TAMP_ATCR1_FLTEN_Pos)
#define TAMP_ATCR1_FLTEN   TAMP_ATCR1_FLTEN_Msk
#define TAMP_ATSEEDR_SEED_Pos   (0U)
#define TAMP_ATSEEDR_SEED_Msk   (0xFFFFFFFFUL << TAMP_ATSEEDR_SEED_Pos)
#define TAMP_ATSEEDR_SEED   TAMP_ATSEEDR_SEED_Msk
#define TAMP_ATOR_PRNG_Pos   (0U)
#define TAMP_ATOR_PRNG_Msk   (0x000000FFUL << TAMP_ATOR_PRNG_Pos)
#define TAMP_ATOR_PRNG   TAMP_ATOR_PRNG_Msk
#define TAMP_ATOR_SEEDF_Pos   (14U)
#define TAMP_ATOR_SEEDF_Msk   (0x01UL << TAMP_ATOR_SEEDF_Pos)
#define TAMP_ATOR_SEEDF   TAMP_ATOR_SEEDF_Msk
#define TAMP_ATOR_INITS_Pos   (15U)
#define TAMP_ATOR_INITS_Msk   (0x01UL << TAMP_ATOR_INITS_Pos)
#define TAMP_ATOR_INITS   TAMP_ATOR_INITS_Msk
#define TAMP_IER_TAMP1IE_Pos   (0U)
#define TAMP_IER_TAMP1IE_Msk   (0x1UL << TAMP_IER_TAMP1IE_Pos)
#define TAMP_IER_TAMP1IE   TAMP_IER_TAMP1IE_Msk
#define TAMP_IER_TAMP2IE_Pos   (1U)
#define TAMP_IER_TAMP2IE_Msk   (0x1UL << TAMP_IER_TAMP2IE_Pos)
#define TAMP_IER_TAMP2IE   TAMP_IER_TAMP2IE_Msk
#define TAMP_IER_TAMP3IE_Pos   (2U)
#define TAMP_IER_TAMP3IE_Msk   (0x1UL << TAMP_IER_TAMP3IE_Pos)
#define TAMP_IER_TAMP3IE   TAMP_IER_TAMP3IE_Msk
#define TAMP_IER_ITAMP1IE_Pos   (16U)
#define TAMP_IER_ITAMP1IE_Msk   (0x1UL << TAMP_IER_ITAMP1IE_Pos)
#define TAMP_IER_ITAMP1IE   TAMP_IER_ITAMP1IE_Msk
#define TAMP_IER_ITAMP2IE_Pos   (17U)
#define TAMP_IER_ITAMP2IE_Msk   (0x1UL << TAMP_IER_ITAMP2IE_Pos)
#define TAMP_IER_ITAMP2IE   TAMP_IER_ITAMP2IE_Msk
#define TAMP_IER_ITAMP3IE_Pos   (18U)
#define TAMP_IER_ITAMP3IE_Msk   (0x1UL << TAMP_IER_ITAMP3IE_Pos)
#define TAMP_IER_ITAMP3IE   TAMP_IER_ITAMP3IE_Msk
#define TAMP_IER_ITAMP4IE_Pos   (19U)
#define TAMP_IER_ITAMP4IE_Msk   (0x1UL << TAMP_IER_ITAMP4IE_Pos)
#define TAMP_IER_ITAMP4IE   TAMP_IER_ITAMP4IE_Msk
#define TAMP_IER_ITAMP5IE_Pos   (20U)
#define TAMP_IER_ITAMP5IE_Msk   (0x1UL << TAMP_IER_ITAMP5IE_Pos)
#define TAMP_IER_ITAMP5IE   TAMP_IER_ITAMP5IE_Msk
#define TAMP_IER_ITAMP6IE_Pos   (21U)
#define TAMP_IER_ITAMP6IE_Msk   (0x1UL << TAMP_IER_ITAMP6IE_Pos)
#define TAMP_IER_ITAMP6IE   TAMP_IER_ITAMP6IE_Msk
#define TAMP_IER_ITAMP8IE_Pos   (23U)
#define TAMP_IER_ITAMP8IE_Msk   (0x1UL << TAMP_IER_ITAMP8IE_Pos)
#define TAMP_IER_ITAMP8IE   TAMP_IER_ITAMP8IE_Msk
#define TAMP_SR_TAMP1F_Pos   (0U)
#define TAMP_SR_TAMP1F_Msk   (0x1UL << TAMP_SR_TAMP1F_Pos)
#define TAMP_SR_TAMP1F   TAMP_SR_TAMP1F_Msk
#define TAMP_SR_TAMP2F_Pos   (1U)
#define TAMP_SR_TAMP2F_Msk   (0x1UL << TAMP_SR_TAMP2F_Pos)
#define TAMP_SR_TAMP2F   TAMP_SR_TAMP2F_Msk
#define TAMP_SR_TAMP3F_Pos   (2U)
#define TAMP_SR_TAMP3F_Msk   (0x1UL << TAMP_SR_TAMP3F_Pos)
#define TAMP_SR_TAMP3F   TAMP_SR_TAMP3F_Msk
#define TAMP_SR_ITAMP1F_Pos   (16U)
#define TAMP_SR_ITAMP1F_Msk   (0x1UL << TAMP_SR_ITAMP1F_Pos)
#define TAMP_SR_ITAMP1F   TAMP_SR_ITAMP1F_Msk
#define TAMP_SR_ITAMP2F_Pos   (17U)
#define TAMP_SR_ITAMP2F_Msk   (0x1UL << TAMP_SR_ITAMP2F_Pos)
#define TAMP_SR_ITAMP2F   TAMP_SR_ITAMP2F_Msk
#define TAMP_SR_ITAMP3F_Pos   (18U)
#define TAMP_SR_ITAMP3F_Msk   (0x1UL << TAMP_SR_ITAMP3F_Pos)
#define TAMP_SR_ITAMP3F   TAMP_SR_ITAMP3F_Msk
#define TAMP_SR_ITAMP4F_Pos   (19U)
#define TAMP_SR_ITAMP4F_Msk   (0x1UL << TAMP_SR_ITAMP4F_Pos)
#define TAMP_SR_ITAMP4F   TAMP_SR_ITAMP4F_Msk
#define TAMP_SR_ITAMP5F_Pos   (20U)
#define TAMP_SR_ITAMP5F_Msk   (0x1UL << TAMP_SR_ITAMP5F_Pos)
#define TAMP_SR_ITAMP5F   TAMP_SR_ITAMP5F_Msk
#define TAMP_SR_ITAMP6F_Pos   (21U)
#define TAMP_SR_ITAMP6F_Msk   (0x1UL << TAMP_SR_ITAMP6F_Pos)
#define TAMP_SR_ITAMP6F   TAMP_SR_ITAMP6F_Msk
#define TAMP_SR_ITAMP8F_Pos   (23U)
#define TAMP_SR_ITAMP8F_Msk   (0x1UL << TAMP_SR_ITAMP8F_Pos)
#define TAMP_SR_ITAMP8F   TAMP_SR_ITAMP8F_Msk
#define TAMP_MISR_TAMP1MF_Pos   (0U)
#define TAMP_MISR_TAMP1MF_Msk   (0x1UL << TAMP_MISR_TAMP1MF_Pos)
#define TAMP_MISR_TAMP1MF   TAMP_MISR_TAMP1MF_Msk
#define TAMP_MISR_TAMP2MF_Pos   (1U)
#define TAMP_MISR_TAMP2MF_Msk   (0x1UL << TAMP_MISR_TAMP2MF_Pos)
#define TAMP_MISR_TAMP2MF   TAMP_MISR_TAMP2MF_Msk
#define TAMP_MISR_TAMP3MF_Pos   (2U)
#define TAMP_MISR_TAMP3MF_Msk   (0x1UL << TAMP_MISR_TAMP3MF_Pos)
#define TAMP_MISR_TAMP3MF   TAMP_MISR_TAMP3MF_Msk
#define TAMP_MISR_ITAMP1MF_Pos   (16U)
#define TAMP_MISR_ITAMP1MF_Msk   (0x1UL << TAMP_MISR_ITAMP1MF_Pos)
#define TAMP_MISR_ITAMP1MF   TAMP_MISR_ITAMP1MF_Msk
#define TAMP_MISR_ITAMP2MF_Pos   (17U)
#define TAMP_MISR_ITAMP2MF_Msk   (0x1UL << TAMP_MISR_ITAMP2MF_Pos)
#define TAMP_MISR_ITAMP2MF   TAMP_MISR_ITAMP2MF_Msk
#define TAMP_MISR_ITAMP3MF_Pos   (18U)
#define TAMP_MISR_ITAMP3MF_Msk   (0x1UL << TAMP_MISR_ITAMP3MF_Pos)
#define TAMP_MISR_ITAMP3MF   TAMP_MISR_ITAMP3MF_Msk
#define TAMP_MISR_ITAMP4MF_Pos   (19U)
#define TAMP_MISR_ITAMP4MF_Msk   (0x1UL << TAMP_MISR_ITAMP4MF_Pos)
#define TAMP_MISR_ITAMP4MF   TAMP_MISR_ITAMP4MF_Msk
#define TAMP_MISR_ITAMP5MF_Pos   (20U)
#define TAMP_MISR_ITAMP5MF_Msk   (0x1UL << TAMP_MISR_ITAMP5MF_Pos)
#define TAMP_MISR_ITAMP5MF   TAMP_MISR_ITAMP5MF_Msk
#define TAMP_MISR_ITAMP6MF_Pos   (21U)
#define TAMP_MISR_ITAMP6MF_Msk   (0x1UL << TAMP_MISR_ITAMP6MF_Pos)
#define TAMP_MISR_ITAMP6MF   TAMP_MISR_ITAMP6MF_Msk
#define TAMP_MISR_ITAMP8MF_Pos   (23U)
#define TAMP_MISR_ITAMP8MF_Msk   (0x1UL << TAMP_MISR_ITAMP8MF_Pos)
#define TAMP_MISR_ITAMP8MF   TAMP_MISR_ITAMP8MF_Msk
#define TAMP_SCR_CTAMP1F_Pos   (0U)
#define TAMP_SCR_CTAMP1F_Msk   (0x1UL << TAMP_SCR_CTAMP1F_Pos)
#define TAMP_SCR_CTAMP1F   TAMP_SCR_CTAMP1F_Msk
#define TAMP_SCR_CTAMP2F_Pos   (1U)
#define TAMP_SCR_CTAMP2F_Msk   (0x1UL << TAMP_SCR_CTAMP2F_Pos)
#define TAMP_SCR_CTAMP2F   TAMP_SCR_CTAMP2F_Msk
#define TAMP_SCR_CTAMP3F_Pos   (2U)
#define TAMP_SCR_CTAMP3F_Msk   (0x1UL << TAMP_SCR_CTAMP3F_Pos)
#define TAMP_SCR_CTAMP3F   TAMP_SCR_CTAMP3F_Msk
#define TAMP_SCR_CITAMP1F_Pos   (16U)
#define TAMP_SCR_CITAMP1F_Msk   (0x1UL << TAMP_SCR_CITAMP1F_Pos)
#define TAMP_SCR_CITAMP1F   TAMP_SCR_CITAMP1F_Msk
#define TAMP_SCR_CITAMP2F_Pos   (17U)
#define TAMP_SCR_CITAMP2F_Msk   (0x1UL << TAMP_SCR_CITAMP2F_Pos)
#define TAMP_SCR_CITAMP2F   TAMP_SCR_CITAMP2F_Msk
#define TAMP_SCR_CITAMP3F_Pos   (18U)
#define TAMP_SCR_CITAMP3F_Msk   (0x1UL << TAMP_SCR_CITAMP3F_Pos)
#define TAMP_SCR_CITAMP3F   TAMP_SCR_CITAMP3F_Msk
#define TAMP_SCR_CITAMP4F_Pos   (19U)
#define TAMP_SCR_CITAMP4F_Msk   (0x1UL << TAMP_SCR_CITAMP4F_Pos)
#define TAMP_SCR_CITAMP4F   TAMP_SCR_CITAMP4F_Msk
#define TAMP_SCR_CITAMP5F_Pos   (20U)
#define TAMP_SCR_CITAMP5F_Msk   (0x1UL << TAMP_SCR_CITAMP5F_Pos)
#define TAMP_SCR_CITAMP5F   TAMP_SCR_CITAMP5F_Msk
#define TAMP_SCR_CITAMP6F_Pos   (21U)
#define TAMP_SCR_CITAMP6F_Msk   (0x1UL << TAMP_SCR_CITAMP6F_Pos)
#define TAMP_SCR_CITAMP6F   TAMP_SCR_CITAMP6F_Msk
#define TAMP_SCR_CITAMP8F_Pos   (23U)
#define TAMP_SCR_CITAMP8F_Msk   (0x1UL << TAMP_SCR_CITAMP8F_Pos)
#define TAMP_SCR_CITAMP8F   TAMP_SCR_CITAMP8F_Msk
#define TAMP_COUNTR_Pos   (16U)
#define TAMP_COUNTR_Msk   (0xFFFFUL << TAMP_COUNTR_Pos)
#define TAMP_COUNTR   TAMP_COUNTR_Msk
#define TAMP_OR_OUT3_RMP_Pos   (0U)
#define TAMP_OR_OUT3_RMP_Msk   (0x1UL << TAMP_OR_OUT3_RMP_Pos)
#define TAMP_OR_OUT3_RMP   TAMP_OR_OUT3_RMP_Msk
#define TAMP_BKP0R_Pos   (0U)
#define TAMP_BKP0R_Msk   (0xFFFFFFFFUL << TAMP_BKP0R_Pos)
#define TAMP_BKP0R   TAMP_BKP0R_Msk
#define TAMP_BKP1R_Pos   (0U)
#define TAMP_BKP1R_Msk   (0xFFFFFFFFUL << TAMP_BKP1R_Pos)
#define TAMP_BKP1R   TAMP_BKP1R_Msk
#define TAMP_BKP2R_Pos   (0U)
#define TAMP_BKP2R_Msk   (0xFFFFFFFFUL << TAMP_BKP2R_Pos)
#define TAMP_BKP2R   TAMP_BKP2R_Msk
#define TAMP_BKP3R_Pos   (0U)
#define TAMP_BKP3R_Msk   (0xFFFFFFFFUL << TAMP_BKP3R_Pos)
#define TAMP_BKP3R   TAMP_BKP3R_Msk
#define TAMP_BKP4R_Pos   (0U)
#define TAMP_BKP4R_Msk   (0xFFFFFFFFUL << TAMP_BKP4R_Pos)
#define TAMP_BKP4R   TAMP_BKP4R_Msk
#define TAMP_BKP5R_Pos   (0U)
#define TAMP_BKP5R_Msk   (0xFFFFFFFFUL << TAMP_BKP5R_Pos)
#define TAMP_BKP5R   TAMP_BKP5R_Msk
#define TAMP_BKP6R_Pos   (0U)
#define TAMP_BKP6R_Msk   (0xFFFFFFFFUL << TAMP_BKP6R_Pos)
#define TAMP_BKP6R   TAMP_BKP6R_Msk
#define TAMP_BKP7R_Pos   (0U)
#define TAMP_BKP7R_Msk   (0xFFFFFFFFUL << TAMP_BKP7R_Pos)
#define TAMP_BKP7R   TAMP_BKP7R_Msk
#define TAMP_BKP8R_Pos   (0U)
#define TAMP_BKP8R_Msk   (0xFFFFFFFFUL << TAMP_BKP8R_Pos)
#define TAMP_BKP8R   TAMP_BKP8R_Msk
#define TAMP_BKP9R_Pos   (0U)
#define TAMP_BKP9R_Msk   (0xFFFFFFFFUL << TAMP_BKP9R_Pos)
#define TAMP_BKP9R   TAMP_BKP9R_Msk
#define TAMP_BKP10R_Pos   (0U)
#define TAMP_BKP10R_Msk   (0xFFFFFFFFUL << TAMP_BKP10R_Pos)
#define TAMP_BKP10R   TAMP_BKP10R_Msk
#define TAMP_BKP11R_Pos   (0U)
#define TAMP_BKP11R_Msk   (0xFFFFFFFFUL << TAMP_BKP11R_Pos)
#define TAMP_BKP11R   TAMP_BKP11R_Msk
#define TAMP_BKP12R_Pos   (0U)
#define TAMP_BKP12R_Msk   (0xFFFFFFFFUL << TAMP_BKP12R_Pos)
#define TAMP_BKP12R   TAMP_BKP12R_Msk
#define TAMP_BKP13R_Pos   (0U)
#define TAMP_BKP13R_Msk   (0xFFFFFFFFUL << TAMP_BKP13R_Pos)
#define TAMP_BKP13R   TAMP_BKP13R_Msk
#define TAMP_BKP14R_Pos   (0U)
#define TAMP_BKP14R_Msk   (0xFFFFFFFFUL << TAMP_BKP14R_Pos)
#define TAMP_BKP14R   TAMP_BKP14R_Msk
#define TAMP_BKP15R_Pos   (0U)
#define TAMP_BKP15R_Msk   (0xFFFFFFFFUL << TAMP_BKP15R_Pos)
#define TAMP_BKP15R   TAMP_BKP15R_Msk
#define TAMP_BKP16R_Pos   (0U)
#define TAMP_BKP16R_Msk   (0xFFFFFFFFUL << TAMP_BKP16R_Pos)
#define TAMP_BKP16R   TAMP_BKP16R_Msk
#define TAMP_BKP17R_Pos   (0U)
#define TAMP_BKP17R_Msk   (0xFFFFFFFFUL << TAMP_BKP17R_Pos)
#define TAMP_BKP17R   TAMP_BKP17R_Msk
#define TAMP_BKP18R_Pos   (0U)
#define TAMP_BKP18R_Msk   (0xFFFFFFFFUL << TAMP_BKP18R_Pos)
#define TAMP_BKP18R   TAMP_BKP18R_Msk
#define TAMP_BKP19R_Pos   (0U)
#define TAMP_BKP19R_Msk   (0xFFFFFFFFUL << TAMP_BKP19R_Pos)
#define TAMP_BKP19R   TAMP_BKP19R_Msk
#define TAMP_BKP20R_Pos   (0U)
#define TAMP_BKP20R_Msk   (0xFFFFFFFFUL << TAMP_BKP20R_Pos)
#define TAMP_BKP20R   TAMP_BKP20R_Msk
#define TAMP_BKP21R_Pos   (0U)
#define TAMP_BKP21R_Msk   (0xFFFFFFFFUL << TAMP_BKP21R_Pos)
#define TAMP_BKP21R   TAMP_BKP21R_Msk
#define TAMP_BKP22R_Pos   (0U)
#define TAMP_BKP22R_Msk   (0xFFFFFFFFUL << TAMP_BKP22R_Pos)
#define TAMP_BKP22R   TAMP_BKP22R_Msk
#define TAMP_BKP23R_Pos   (0U)
#define TAMP_BKP23R_Msk   (0xFFFFFFFFUL << TAMP_BKP23R_Pos)
#define TAMP_BKP23R   TAMP_BKP23R_Msk
#define TAMP_BKP24R_Pos   (0U)
#define TAMP_BKP24R_Msk   (0xFFFFFFFFUL << TAMP_BKP24R_Pos)
#define TAMP_BKP24R   TAMP_BKP24R_Msk
#define TAMP_BKP25R_Pos   (0U)
#define TAMP_BKP25R_Msk   (0xFFFFFFFFUL << TAMP_BKP25R_Pos)
#define TAMP_BKP25R   TAMP_BKP25R_Msk
#define TAMP_BKP26R_Pos   (0U)
#define TAMP_BKP26R_Msk   (0xFFFFFFFFUL << TAMP_BKP26R_Pos)
#define TAMP_BKP26R   TAMP_BKP26R_Msk
#define TAMP_BKP27R_Pos   (0U)
#define TAMP_BKP27R_Msk   (0xFFFFFFFFUL << TAMP_BKP27R_Pos)
#define TAMP_BKP27R   TAMP_BKP27R_Msk
#define TAMP_BKP28R_Pos   (0U)
#define TAMP_BKP28R_Msk   (0xFFFFFFFFUL << TAMP_BKP28R_Pos)
#define TAMP_BKP28R   TAMP_BKP28R_Msk
#define TAMP_BKP29R_Pos   (0U)
#define TAMP_BKP29R_Msk   (0xFFFFFFFFUL << TAMP_BKP29R_Pos)
#define TAMP_BKP29R   TAMP_BKP29R_Msk
#define TAMP_BKP30R_Pos   (0U)
#define TAMP_BKP30R_Msk   (0xFFFFFFFFUL << TAMP_BKP30R_Pos)
#define TAMP_BKP30R   TAMP_BKP30R_Msk
#define TAMP_BKP31R_Pos   (0U)
#define TAMP_BKP31R_Msk   (0xFFFFFFFFUL << TAMP_BKP31R_Pos)
#define TAMP_BKP31R   TAMP_BKP31R_Msk
#define TAMP_BKP_NUMBER_Pos   (5U)
#define TAMP_BKP_NUMBER_Msk   (0x1UL << TAMP_BKP_NUMBER_Pos)
#define TAMP_BKP_NUMBER   TAMP_BKP_NUMBER_Msk
#define SPDIFRX_CR_SPDIFEN_Pos   (0U)
#define SPDIFRX_CR_SPDIFEN_Msk   (0x3UL << SPDIFRX_CR_SPDIFEN_Pos)
#define SPDIFRX_CR_SPDIFEN   SPDIFRX_CR_SPDIFEN_Msk
#define SPDIFRX_CR_RXDMAEN_Pos   (2U)
#define SPDIFRX_CR_RXDMAEN_Msk   (0x1UL << SPDIFRX_CR_RXDMAEN_Pos)
#define SPDIFRX_CR_RXDMAEN   SPDIFRX_CR_RXDMAEN_Msk
#define SPDIFRX_CR_RXSTEO_Pos   (3U)
#define SPDIFRX_CR_RXSTEO_Msk   (0x1UL << SPDIFRX_CR_RXSTEO_Pos)
#define SPDIFRX_CR_RXSTEO   SPDIFRX_CR_RXSTEO_Msk
#define SPDIFRX_CR_DRFMT_Pos   (4U)
#define SPDIFRX_CR_DRFMT_Msk   (0x3UL << SPDIFRX_CR_DRFMT_Pos)
#define SPDIFRX_CR_DRFMT   SPDIFRX_CR_DRFMT_Msk
#define SPDIFRX_CR_PMSK_Pos   (6U)
#define SPDIFRX_CR_PMSK_Msk   (0x1UL << SPDIFRX_CR_PMSK_Pos)
#define SPDIFRX_CR_PMSK   SPDIFRX_CR_PMSK_Msk
#define SPDIFRX_CR_VMSK_Pos   (7U)
#define SPDIFRX_CR_VMSK_Msk   (0x1UL << SPDIFRX_CR_VMSK_Pos)
#define SPDIFRX_CR_VMSK   SPDIFRX_CR_VMSK_Msk
#define SPDIFRX_CR_CUMSK_Pos   (8U)
#define SPDIFRX_CR_CUMSK_Msk   (0x1UL << SPDIFRX_CR_CUMSK_Pos)
#define SPDIFRX_CR_CUMSK   SPDIFRX_CR_CUMSK_Msk
#define SPDIFRX_CR_PTMSK_Pos   (9U)
#define SPDIFRX_CR_PTMSK_Msk   (0x1UL << SPDIFRX_CR_PTMSK_Pos)
#define SPDIFRX_CR_PTMSK   SPDIFRX_CR_PTMSK_Msk
#define SPDIFRX_CR_CBDMAEN_Pos   (10U)
#define SPDIFRX_CR_CBDMAEN_Msk   (0x1UL << SPDIFRX_CR_CBDMAEN_Pos)
#define SPDIFRX_CR_CBDMAEN   SPDIFRX_CR_CBDMAEN_Msk
#define SPDIFRX_CR_CHSEL_Pos   (11U)
#define SPDIFRX_CR_CHSEL_Msk   (0x1UL << SPDIFRX_CR_CHSEL_Pos)
#define SPDIFRX_CR_CHSEL   SPDIFRX_CR_CHSEL_Msk
#define SPDIFRX_CR_NBTR_Pos   (12U)
#define SPDIFRX_CR_NBTR_Msk   (0x3UL << SPDIFRX_CR_NBTR_Pos)
#define SPDIFRX_CR_NBTR   SPDIFRX_CR_NBTR_Msk
#define SPDIFRX_CR_WFA_Pos   (14U)
#define SPDIFRX_CR_WFA_Msk   (0x1UL << SPDIFRX_CR_WFA_Pos)
#define SPDIFRX_CR_WFA   SPDIFRX_CR_WFA_Msk
#define SPDIFRX_CR_INSEL_Pos   (16U)
#define SPDIFRX_CR_INSEL_Msk   (0x7UL << SPDIFRX_CR_INSEL_Pos)
#define SPDIFRX_CR_INSEL   SPDIFRX_CR_INSEL_Msk
#define SPDIFRX_CR_CKSEN_Pos   (20U)
#define SPDIFRX_CR_CKSEN_Msk   (0x1UL << SPDIFRX_CR_CKSEN_Pos)
#define SPDIFRX_CR_CKSEN   SPDIFRX_CR_CKSEN_Msk
#define SPDIFRX_CR_CKSBKPEN_Pos   (21U)
#define SPDIFRX_CR_CKSBKPEN_Msk   (0x1UL << SPDIFRX_CR_CKSBKPEN_Pos)
#define SPDIFRX_CR_CKSBKPEN   SPDIFRX_CR_CKSBKPEN_Msk
#define SPDIFRX_IMR_RXNEIE_Pos   (0U)
#define SPDIFRX_IMR_RXNEIE_Msk   (0x1UL << SPDIFRX_IMR_RXNEIE_Pos)
#define SPDIFRX_IMR_RXNEIE   SPDIFRX_IMR_RXNEIE_Msk
#define SPDIFRX_IMR_CSRNEIE_Pos   (1U)
#define SPDIFRX_IMR_CSRNEIE_Msk   (0x1UL << SPDIFRX_IMR_CSRNEIE_Pos)
#define SPDIFRX_IMR_CSRNEIE   SPDIFRX_IMR_CSRNEIE_Msk
#define SPDIFRX_IMR_PERRIE_Pos   (2U)
#define SPDIFRX_IMR_PERRIE_Msk   (0x1UL << SPDIFRX_IMR_PERRIE_Pos)
#define SPDIFRX_IMR_PERRIE   SPDIFRX_IMR_PERRIE_Msk
#define SPDIFRX_IMR_OVRIE_Pos   (3U)
#define SPDIFRX_IMR_OVRIE_Msk   (0x1UL << SPDIFRX_IMR_OVRIE_Pos)
#define SPDIFRX_IMR_OVRIE   SPDIFRX_IMR_OVRIE_Msk
#define SPDIFRX_IMR_SBLKIE_Pos   (4U)
#define SPDIFRX_IMR_SBLKIE_Msk   (0x1UL << SPDIFRX_IMR_SBLKIE_Pos)
#define SPDIFRX_IMR_SBLKIE   SPDIFRX_IMR_SBLKIE_Msk
#define SPDIFRX_IMR_SYNCDIE_Pos   (5U)
#define SPDIFRX_IMR_SYNCDIE_Msk   (0x1UL << SPDIFRX_IMR_SYNCDIE_Pos)
#define SPDIFRX_IMR_SYNCDIE   SPDIFRX_IMR_SYNCDIE_Msk
#define SPDIFRX_IMR_IFEIE_Pos   (6U)
#define SPDIFRX_IMR_IFEIE_Msk   (0x1UL << SPDIFRX_IMR_IFEIE_Pos)
#define SPDIFRX_IMR_IFEIE   SPDIFRX_IMR_IFEIE_Msk
#define SPDIFRX_SR_RXNE_Pos   (0U)
#define SPDIFRX_SR_RXNE_Msk   (0x1UL << SPDIFRX_SR_RXNE_Pos)
#define SPDIFRX_SR_RXNE   SPDIFRX_SR_RXNE_Msk
#define SPDIFRX_SR_CSRNE_Pos   (1U)
#define SPDIFRX_SR_CSRNE_Msk   (0x1UL << SPDIFRX_SR_CSRNE_Pos)
#define SPDIFRX_SR_CSRNE   SPDIFRX_SR_CSRNE_Msk
#define SPDIFRX_SR_PERR_Pos   (2U)
#define SPDIFRX_SR_PERR_Msk   (0x1UL << SPDIFRX_SR_PERR_Pos)
#define SPDIFRX_SR_PERR   SPDIFRX_SR_PERR_Msk
#define SPDIFRX_SR_OVR_Pos   (3U)
#define SPDIFRX_SR_OVR_Msk   (0x1UL << SPDIFRX_SR_OVR_Pos)
#define SPDIFRX_SR_OVR   SPDIFRX_SR_OVR_Msk
#define SPDIFRX_SR_SBD_Pos   (4U)
#define SPDIFRX_SR_SBD_Msk   (0x1UL << SPDIFRX_SR_SBD_Pos)
#define SPDIFRX_SR_SBD   SPDIFRX_SR_SBD_Msk
#define SPDIFRX_SR_SYNCD_Pos   (5U)
#define SPDIFRX_SR_SYNCD_Msk   (0x1UL << SPDIFRX_SR_SYNCD_Pos)
#define SPDIFRX_SR_SYNCD   SPDIFRX_SR_SYNCD_Msk
#define SPDIFRX_SR_FERR_Pos   (6U)
#define SPDIFRX_SR_FERR_Msk   (0x1UL << SPDIFRX_SR_FERR_Pos)
#define SPDIFRX_SR_FERR   SPDIFRX_SR_FERR_Msk
#define SPDIFRX_SR_SERR_Pos   (7U)
#define SPDIFRX_SR_SERR_Msk   (0x1UL << SPDIFRX_SR_SERR_Pos)
#define SPDIFRX_SR_SERR   SPDIFRX_SR_SERR_Msk
#define SPDIFRX_SR_TERR_Pos   (8U)
#define SPDIFRX_SR_TERR_Msk   (0x1UL << SPDIFRX_SR_TERR_Pos)
#define SPDIFRX_SR_TERR   SPDIFRX_SR_TERR_Msk
#define SPDIFRX_SR_WIDTH5_Pos   (16U)
#define SPDIFRX_SR_WIDTH5_Msk   (0x7FFFUL << SPDIFRX_SR_WIDTH5_Pos)
#define SPDIFRX_SR_WIDTH5   SPDIFRX_SR_WIDTH5_Msk
#define SPDIFRX_IFCR_PERRCF_Pos   (2U)
#define SPDIFRX_IFCR_PERRCF_Msk   (0x1UL << SPDIFRX_IFCR_PERRCF_Pos)
#define SPDIFRX_IFCR_PERRCF   SPDIFRX_IFCR_PERRCF_Msk
#define SPDIFRX_IFCR_OVRCF_Pos   (3U)
#define SPDIFRX_IFCR_OVRCF_Msk   (0x1UL << SPDIFRX_IFCR_OVRCF_Pos)
#define SPDIFRX_IFCR_OVRCF   SPDIFRX_IFCR_OVRCF_Msk
#define SPDIFRX_IFCR_SBDCF_Pos   (4U)
#define SPDIFRX_IFCR_SBDCF_Msk   (0x1UL << SPDIFRX_IFCR_SBDCF_Pos)
#define SPDIFRX_IFCR_SBDCF   SPDIFRX_IFCR_SBDCF_Msk
#define SPDIFRX_IFCR_SYNCDCF_Pos   (5U)
#define SPDIFRX_IFCR_SYNCDCF_Msk   (0x1UL << SPDIFRX_IFCR_SYNCDCF_Pos)
#define SPDIFRX_IFCR_SYNCDCF   SPDIFRX_IFCR_SYNCDCF_Msk
#define SPDIFRX_DR0_DR_Pos   (0U)
#define SPDIFRX_DR0_DR_Msk   (0xFFFFFFUL << SPDIFRX_DR0_DR_Pos)
#define SPDIFRX_DR0_DR   SPDIFRX_DR0_DR_Msk
#define SPDIFRX_DR0_PE_Pos   (24U)
#define SPDIFRX_DR0_PE_Msk   (0x1UL << SPDIFRX_DR0_PE_Pos)
#define SPDIFRX_DR0_PE   SPDIFRX_DR0_PE_Msk
#define SPDIFRX_DR0_V_Pos   (25U)
#define SPDIFRX_DR0_V_Msk   (0x1UL << SPDIFRX_DR0_V_Pos)
#define SPDIFRX_DR0_V   SPDIFRX_DR0_V_Msk
#define SPDIFRX_DR0_U_Pos   (26U)
#define SPDIFRX_DR0_U_Msk   (0x1UL << SPDIFRX_DR0_U_Pos)
#define SPDIFRX_DR0_U   SPDIFRX_DR0_U_Msk
#define SPDIFRX_DR0_C_Pos   (27U)
#define SPDIFRX_DR0_C_Msk   (0x1UL << SPDIFRX_DR0_C_Pos)
#define SPDIFRX_DR0_C   SPDIFRX_DR0_C_Msk
#define SPDIFRX_DR0_PT_Pos   (28U)
#define SPDIFRX_DR0_PT_Msk   (0x3UL << SPDIFRX_DR0_PT_Pos)
#define SPDIFRX_DR0_PT   SPDIFRX_DR0_PT_Msk
#define SPDIFRX_DR1_DR_Pos   (8U)
#define SPDIFRX_DR1_DR_Msk   (0xFFFFFFUL << SPDIFRX_DR1_DR_Pos)
#define SPDIFRX_DR1_DR   SPDIFRX_DR1_DR_Msk
#define SPDIFRX_DR1_PT_Pos   (4U)
#define SPDIFRX_DR1_PT_Msk   (0x3UL << SPDIFRX_DR1_PT_Pos)
#define SPDIFRX_DR1_PT   SPDIFRX_DR1_PT_Msk
#define SPDIFRX_DR1_C_Pos   (3U)
#define SPDIFRX_DR1_C_Msk   (0x1UL << SPDIFRX_DR1_C_Pos)
#define SPDIFRX_DR1_C   SPDIFRX_DR1_C_Msk
#define SPDIFRX_DR1_U_Pos   (2U)
#define SPDIFRX_DR1_U_Msk   (0x1UL << SPDIFRX_DR1_U_Pos)
#define SPDIFRX_DR1_U   SPDIFRX_DR1_U_Msk
#define SPDIFRX_DR1_V_Pos   (1U)
#define SPDIFRX_DR1_V_Msk   (0x1UL << SPDIFRX_DR1_V_Pos)
#define SPDIFRX_DR1_V   SPDIFRX_DR1_V_Msk
#define SPDIFRX_DR1_PE_Pos   (0U)
#define SPDIFRX_DR1_PE_Msk   (0x1UL << SPDIFRX_DR1_PE_Pos)
#define SPDIFRX_DR1_PE   SPDIFRX_DR1_PE_Msk
#define SPDIFRX_DR1_DRNL1_Pos   (16U)
#define SPDIFRX_DR1_DRNL1_Msk   (0xFFFFUL << SPDIFRX_DR1_DRNL1_Pos)
#define SPDIFRX_DR1_DRNL1   SPDIFRX_DR1_DRNL1_Msk
#define SPDIFRX_DR1_DRNL2_Pos   (0U)
#define SPDIFRX_DR1_DRNL2_Msk   (0xFFFFUL << SPDIFRX_DR1_DRNL2_Pos)
#define SPDIFRX_DR1_DRNL2   SPDIFRX_DR1_DRNL2_Msk
#define SPDIFRX_CSR_USR_Pos   (0U)
#define SPDIFRX_CSR_USR_Msk   (0xFFFFUL << SPDIFRX_CSR_USR_Pos)
#define SPDIFRX_CSR_USR   SPDIFRX_CSR_USR_Msk
#define SPDIFRX_CSR_CS_Pos   (16U)
#define SPDIFRX_CSR_CS_Msk   (0xFFUL << SPDIFRX_CSR_CS_Pos)
#define SPDIFRX_CSR_CS   SPDIFRX_CSR_CS_Msk
#define SPDIFRX_CSR_SOB_Pos   (24U)
#define SPDIFRX_CSR_SOB_Msk   (0x1UL << SPDIFRX_CSR_SOB_Pos)
#define SPDIFRX_CSR_SOB   SPDIFRX_CSR_SOB_Msk
#define SPDIFRX_DIR_THI_Pos   (0U)
#define SPDIFRX_DIR_THI_Msk   (0x1FFFUL << SPDIFRX_DIR_THI_Pos)
#define SPDIFRX_DIR_THI   SPDIFRX_DIR_THI_Msk
#define SPDIFRX_DIR_TLO_Pos   (16U)
#define SPDIFRX_DIR_TLO_Msk   (0x1FFFUL << SPDIFRX_DIR_TLO_Pos)
#define SPDIFRX_DIR_TLO   SPDIFRX_DIR_TLO_Msk
#define SPDIFRX_VERR_MINREV_Pos   (0U)
#define SPDIFRX_VERR_MINREV_Msk   (0xFUL << SPDIFRX_VERR_MINREV_Pos)
#define SPDIFRX_VERR_MINREV   SPDIFRX_VERR_MINREV_Msk
#define SPDIFRX_VERR_MAJREV_Pos   (4U)
#define SPDIFRX_VERR_MAJREV_Msk   (0xFUL << SPDIFRX_VERR_MAJREV_Pos)
#define SPDIFRX_VERR_MAJREV   SPDIFRX_VERR_MAJREV_Msk
#define SPDIFRX_IDR_ID_Pos   (0U)
#define SPDIFRX_IDR_ID_Msk   (0xFFFFFFFFUL << SPDIFRX_IDR_ID_Pos)
#define SPDIFRX_IDR_ID   SPDIFRX_IDR_ID_Msk
#define SPDIFRX_SIDR_SID_Pos   (0U)
#define SPDIFRX_SIDR_SID_Msk   (0xFFFFFFFFUL << SPDIFRX_SIDR_SID_Pos)
#define SPDIFRX_SIDR_SID   SPDIFRX_SIDR_SID_Msk
#define SAI_VER_V2_1
#define SAI_GCR_SYNCIN_Pos   (0U)
#define SAI_GCR_SYNCIN_Msk   (0x3UL << SAI_GCR_SYNCIN_Pos)
#define SAI_GCR_SYNCIN   SAI_GCR_SYNCIN_Msk
#define SAI_GCR_SYNCIN_0   (0x1UL << SAI_GCR_SYNCIN_Pos)
#define SAI_GCR_SYNCIN_1   (0x2UL << SAI_GCR_SYNCIN_Pos)
#define SAI_GCR_SYNCOUT_Pos   (4U)
#define SAI_GCR_SYNCOUT_Msk   (0x3UL << SAI_GCR_SYNCOUT_Pos)
#define SAI_GCR_SYNCOUT   SAI_GCR_SYNCOUT_Msk
#define SAI_GCR_SYNCOUT_0   (0x1UL << SAI_GCR_SYNCOUT_Pos)
#define SAI_GCR_SYNCOUT_1   (0x2UL << SAI_GCR_SYNCOUT_Pos)
#define SAI_xCR1_MODE_Pos   (0U)
#define SAI_xCR1_MODE_Msk   (0x3UL << SAI_xCR1_MODE_Pos)
#define SAI_xCR1_MODE   SAI_xCR1_MODE_Msk
#define SAI_xCR1_MODE_0   (0x1UL << SAI_xCR1_MODE_Pos)
#define SAI_xCR1_MODE_1   (0x2UL << SAI_xCR1_MODE_Pos)
#define SAI_xCR1_PRTCFG_Pos   (2U)
#define SAI_xCR1_PRTCFG_Msk   (0x3UL << SAI_xCR1_PRTCFG_Pos)
#define SAI_xCR1_PRTCFG   SAI_xCR1_PRTCFG_Msk
#define SAI_xCR1_PRTCFG_0   (0x1UL << SAI_xCR1_PRTCFG_Pos)
#define SAI_xCR1_PRTCFG_1   (0x2UL << SAI_xCR1_PRTCFG_Pos)
#define SAI_xCR1_DS_Pos   (5U)
#define SAI_xCR1_DS_Msk   (0x7UL << SAI_xCR1_DS_Pos)
#define SAI_xCR1_DS   SAI_xCR1_DS_Msk
#define SAI_xCR1_DS_0   (0x1UL << SAI_xCR1_DS_Pos)
#define SAI_xCR1_DS_1   (0x2UL << SAI_xCR1_DS_Pos)
#define SAI_xCR1_DS_2   (0x4UL << SAI_xCR1_DS_Pos)
#define SAI_xCR1_LSBFIRST_Pos   (8U)
#define SAI_xCR1_LSBFIRST_Msk   (0x1UL << SAI_xCR1_LSBFIRST_Pos)
#define SAI_xCR1_LSBFIRST   SAI_xCR1_LSBFIRST_Msk
#define SAI_xCR1_CKSTR_Pos   (9U)
#define SAI_xCR1_CKSTR_Msk   (0x1UL << SAI_xCR1_CKSTR_Pos)
#define SAI_xCR1_CKSTR   SAI_xCR1_CKSTR_Msk
#define SAI_xCR1_SYNCEN_Pos   (10U)
#define SAI_xCR1_SYNCEN_Msk   (0x3UL << SAI_xCR1_SYNCEN_Pos)
#define SAI_xCR1_SYNCEN   SAI_xCR1_SYNCEN_Msk
#define SAI_xCR1_SYNCEN_0   (0x1UL << SAI_xCR1_SYNCEN_Pos)
#define SAI_xCR1_SYNCEN_1   (0x2UL << SAI_xCR1_SYNCEN_Pos)
#define SAI_xCR1_MONO_Pos   (12U)
#define SAI_xCR1_MONO_Msk   (0x1UL << SAI_xCR1_MONO_Pos)
#define SAI_xCR1_MONO   SAI_xCR1_MONO_Msk
#define SAI_xCR1_OUTDRIV_Pos   (13U)
#define SAI_xCR1_OUTDRIV_Msk   (0x1UL << SAI_xCR1_OUTDRIV_Pos)
#define SAI_xCR1_OUTDRIV   SAI_xCR1_OUTDRIV_Msk
#define SAI_xCR1_SAIEN_Pos   (16U)
#define SAI_xCR1_SAIEN_Msk   (0x1UL << SAI_xCR1_SAIEN_Pos)
#define SAI_xCR1_SAIEN   SAI_xCR1_SAIEN_Msk
#define SAI_xCR1_DMAEN_Pos   (17U)
#define SAI_xCR1_DMAEN_Msk   (0x1UL << SAI_xCR1_DMAEN_Pos)
#define SAI_xCR1_DMAEN   SAI_xCR1_DMAEN_Msk
#define SAI_xCR1_NODIV_Pos   (19U)
#define SAI_xCR1_NODIV_Msk   (0x1UL << SAI_xCR1_NODIV_Pos)
#define SAI_xCR1_NODIV   SAI_xCR1_NODIV_Msk
#define SAI_xCR1_MCKDIV_Pos   (20U)
#define SAI_xCR1_MCKDIV_Msk   (0x3FUL << SAI_xCR1_MCKDIV_Pos)
#define SAI_xCR1_MCKDIV   SAI_xCR1_MCKDIV_Msk
#define SAI_xCR1_MCKDIV_0   (0x01UL << SAI_xCR1_MCKDIV_Pos)
#define SAI_xCR1_MCKDIV_1   (0x02UL << SAI_xCR1_MCKDIV_Pos)
#define SAI_xCR1_MCKDIV_2   (0x04UL << SAI_xCR1_MCKDIV_Pos)
#define SAI_xCR1_MCKDIV_3   (0x08UL << SAI_xCR1_MCKDIV_Pos)
#define SAI_xCR1_MCKDIV_4   (0x10UL << SAI_xCR1_MCKDIV_Pos)
#define SAI_xCR1_MCKDIV_5   (0x20UL << SAI_xCR1_MCKDIV_Pos)
#define SAI_xCR1_MCKEN_Pos   (27U)
#define SAI_xCR1_MCKEN_Msk   (0x1UL << SAI_xCR1_MCKEN_Pos)
#define SAI_xCR1_MCKEN   SAI_xCR1_MCKEN_Msk
#define SAI_xCR1_OSR_Pos   (26U)
#define SAI_xCR1_OSR_Msk   (0x1UL << SAI_xCR1_OSR_Pos)
#define SAI_xCR1_OSR   SAI_xCR1_OSR_Msk
#define SAI_xCR1_NOMCK   SAI_xCR1_NODIV
#define SAI_xCR2_FTH_Pos   (0U)
#define SAI_xCR2_FTH_Msk   (0x7UL << SAI_xCR2_FTH_Pos)
#define SAI_xCR2_FTH   SAI_xCR2_FTH_Msk
#define SAI_xCR2_FTH_0   (0x1UL << SAI_xCR2_FTH_Pos)
#define SAI_xCR2_FTH_1   (0x2UL << SAI_xCR2_FTH_Pos)
#define SAI_xCR2_FTH_2   (0x4UL << SAI_xCR2_FTH_Pos)
#define SAI_xCR2_FFLUSH_Pos   (3U)
#define SAI_xCR2_FFLUSH_Msk   (0x1UL << SAI_xCR2_FFLUSH_Pos)
#define SAI_xCR2_FFLUSH   SAI_xCR2_FFLUSH_Msk
#define SAI_xCR2_TRIS_Pos   (4U)
#define SAI_xCR2_TRIS_Msk   (0x1UL << SAI_xCR2_TRIS_Pos)
#define SAI_xCR2_TRIS   SAI_xCR2_TRIS_Msk
#define SAI_xCR2_MUTE_Pos   (5U)
#define SAI_xCR2_MUTE_Msk   (0x1UL << SAI_xCR2_MUTE_Pos)
#define SAI_xCR2_MUTE   SAI_xCR2_MUTE_Msk
#define SAI_xCR2_MUTEVAL_Pos   (6U)
#define SAI_xCR2_MUTEVAL_Msk   (0x1UL << SAI_xCR2_MUTEVAL_Pos)
#define SAI_xCR2_MUTEVAL   SAI_xCR2_MUTEVAL_Msk
#define SAI_xCR2_MUTECNT_Pos   (7U)
#define SAI_xCR2_MUTECNT_Msk   (0x3FUL << SAI_xCR2_MUTECNT_Pos)
#define SAI_xCR2_MUTECNT   SAI_xCR2_MUTECNT_Msk
#define SAI_xCR2_MUTECNT_0   (0x01UL << SAI_xCR2_MUTECNT_Pos)
#define SAI_xCR2_MUTECNT_1   (0x02UL << SAI_xCR2_MUTECNT_Pos)
#define SAI_xCR2_MUTECNT_2   (0x04UL << SAI_xCR2_MUTECNT_Pos)
#define SAI_xCR2_MUTECNT_3   (0x08UL << SAI_xCR2_MUTECNT_Pos)
#define SAI_xCR2_MUTECNT_4   (0x10UL << SAI_xCR2_MUTECNT_Pos)
#define SAI_xCR2_MUTECNT_5   (0x20UL << SAI_xCR2_MUTECNT_Pos)
#define SAI_xCR2_CPL_Pos   (13U)
#define SAI_xCR2_CPL_Msk   (0x1UL << SAI_xCR2_CPL_Pos)
#define SAI_xCR2_CPL   SAI_xCR2_CPL_Msk
#define SAI_xCR2_COMP_Pos   (14U)
#define SAI_xCR2_COMP_Msk   (0x3UL << SAI_xCR2_COMP_Pos)
#define SAI_xCR2_COMP   SAI_xCR2_COMP_Msk
#define SAI_xCR2_COMP_0   (0x1UL << SAI_xCR2_COMP_Pos)
#define SAI_xCR2_COMP_1   (0x2UL << SAI_xCR2_COMP_Pos)
#define SAI_xFRCR_FRL_Pos   (0U)
#define SAI_xFRCR_FRL_Msk   (0xFFUL << SAI_xFRCR_FRL_Pos)
#define SAI_xFRCR_FRL   SAI_xFRCR_FRL_Msk
#define SAI_xFRCR_FRL_0   (0x01UL << SAI_xFRCR_FRL_Pos)
#define SAI_xFRCR_FRL_1   (0x02UL << SAI_xFRCR_FRL_Pos)
#define SAI_xFRCR_FRL_2   (0x04UL << SAI_xFRCR_FRL_Pos)
#define SAI_xFRCR_FRL_3   (0x08UL << SAI_xFRCR_FRL_Pos)
#define SAI_xFRCR_FRL_4   (0x10UL << SAI_xFRCR_FRL_Pos)
#define SAI_xFRCR_FRL_5   (0x20UL << SAI_xFRCR_FRL_Pos)
#define SAI_xFRCR_FRL_6   (0x40UL << SAI_xFRCR_FRL_Pos)
#define SAI_xFRCR_FRL_7   (0x80UL << SAI_xFRCR_FRL_Pos)
#define SAI_xFRCR_FSALL_Pos   (8U)
#define SAI_xFRCR_FSALL_Msk   (0x7FUL << SAI_xFRCR_FSALL_Pos)
#define SAI_xFRCR_FSALL   SAI_xFRCR_FSALL_Msk
#define SAI_xFRCR_FSALL_0   (0x01UL << SAI_xFRCR_FSALL_Pos)
#define SAI_xFRCR_FSALL_1   (0x02UL << SAI_xFRCR_FSALL_Pos)
#define SAI_xFRCR_FSALL_2   (0x04UL << SAI_xFRCR_FSALL_Pos)
#define SAI_xFRCR_FSALL_3   (0x08UL << SAI_xFRCR_FSALL_Pos)
#define SAI_xFRCR_FSALL_4   (0x10UL << SAI_xFRCR_FSALL_Pos)
#define SAI_xFRCR_FSALL_5   (0x20UL << SAI_xFRCR_FSALL_Pos)
#define SAI_xFRCR_FSALL_6   (0x40UL << SAI_xFRCR_FSALL_Pos)
#define SAI_xFRCR_FSDEF_Pos   (16U)
#define SAI_xFRCR_FSDEF_Msk   (0x1UL << SAI_xFRCR_FSDEF_Pos)
#define SAI_xFRCR_FSDEF   SAI_xFRCR_FSDEF_Msk
#define SAI_xFRCR_FSPOL_Pos   (17U)
#define SAI_xFRCR_FSPOL_Msk   (0x1UL << SAI_xFRCR_FSPOL_Pos)
#define SAI_xFRCR_FSPOL   SAI_xFRCR_FSPOL_Msk
#define SAI_xFRCR_FSOFF_Pos   (18U)
#define SAI_xFRCR_FSOFF_Msk   (0x1UL << SAI_xFRCR_FSOFF_Pos)
#define SAI_xFRCR_FSOFF   SAI_xFRCR_FSOFF_Msk
#define SAI_xFRCR_FSPO   SAI_xFRCR_FSPOL
#define SAI_xSLOTR_FBOFF_Pos   (0U)
#define SAI_xSLOTR_FBOFF_Msk   (0x1FUL << SAI_xSLOTR_FBOFF_Pos)
#define SAI_xSLOTR_FBOFF   SAI_xSLOTR_FBOFF_Msk
#define SAI_xSLOTR_FBOFF_0   (0x01UL << SAI_xSLOTR_FBOFF_Pos)
#define SAI_xSLOTR_FBOFF_1   (0x02UL << SAI_xSLOTR_FBOFF_Pos)
#define SAI_xSLOTR_FBOFF_2   (0x04UL << SAI_xSLOTR_FBOFF_Pos)
#define SAI_xSLOTR_FBOFF_3   (0x08UL << SAI_xSLOTR_FBOFF_Pos)
#define SAI_xSLOTR_FBOFF_4   (0x10UL << SAI_xSLOTR_FBOFF_Pos)
#define SAI_xSLOTR_SLOTSZ_Pos   (6U)
#define SAI_xSLOTR_SLOTSZ_Msk   (0x3UL << SAI_xSLOTR_SLOTSZ_Pos)
#define SAI_xSLOTR_SLOTSZ   SAI_xSLOTR_SLOTSZ_Msk
#define SAI_xSLOTR_SLOTSZ_0   (0x1UL << SAI_xSLOTR_SLOTSZ_Pos)
#define SAI_xSLOTR_SLOTSZ_1   (0x2UL << SAI_xSLOTR_SLOTSZ_Pos)
#define SAI_xSLOTR_NBSLOT_Pos   (8U)
#define SAI_xSLOTR_NBSLOT_Msk   (0xFUL << SAI_xSLOTR_NBSLOT_Pos)
#define SAI_xSLOTR_NBSLOT   SAI_xSLOTR_NBSLOT_Msk
#define SAI_xSLOTR_NBSLOT_0   (0x1UL << SAI_xSLOTR_NBSLOT_Pos)
#define SAI_xSLOTR_NBSLOT_1   (0x2UL << SAI_xSLOTR_NBSLOT_Pos)
#define SAI_xSLOTR_NBSLOT_2   (0x4UL << SAI_xSLOTR_NBSLOT_Pos)
#define SAI_xSLOTR_NBSLOT_3   (0x8UL << SAI_xSLOTR_NBSLOT_Pos)
#define SAI_xSLOTR_SLOTEN_Pos   (16U)
#define SAI_xSLOTR_SLOTEN_Msk   (0xFFFFUL << SAI_xSLOTR_SLOTEN_Pos)
#define SAI_xSLOTR_SLOTEN   SAI_xSLOTR_SLOTEN_Msk
#define SAI_xIMR_OVRUDRIE_Pos   (0U)
#define SAI_xIMR_OVRUDRIE_Msk   (0x1UL << SAI_xIMR_OVRUDRIE_Pos)
#define SAI_xIMR_OVRUDRIE   SAI_xIMR_OVRUDRIE_Msk
#define SAI_xIMR_MUTEDETIE_Pos   (1U)
#define SAI_xIMR_MUTEDETIE_Msk   (0x1UL << SAI_xIMR_MUTEDETIE_Pos)
#define SAI_xIMR_MUTEDETIE   SAI_xIMR_MUTEDETIE_Msk
#define SAI_xIMR_WCKCFGIE_Pos   (2U)
#define SAI_xIMR_WCKCFGIE_Msk   (0x1UL << SAI_xIMR_WCKCFGIE_Pos)
#define SAI_xIMR_WCKCFGIE   SAI_xIMR_WCKCFGIE_Msk
#define SAI_xIMR_FREQIE_Pos   (3U)
#define SAI_xIMR_FREQIE_Msk   (0x1UL << SAI_xIMR_FREQIE_Pos)
#define SAI_xIMR_FREQIE   SAI_xIMR_FREQIE_Msk
#define SAI_xIMR_CNRDYIE_Pos   (4U)
#define SAI_xIMR_CNRDYIE_Msk   (0x1UL << SAI_xIMR_CNRDYIE_Pos)
#define SAI_xIMR_CNRDYIE   SAI_xIMR_CNRDYIE_Msk
#define SAI_xIMR_AFSDETIE_Pos   (5U)
#define SAI_xIMR_AFSDETIE_Msk   (0x1UL << SAI_xIMR_AFSDETIE_Pos)
#define SAI_xIMR_AFSDETIE   SAI_xIMR_AFSDETIE_Msk
#define SAI_xIMR_LFSDETIE_Pos   (6U)
#define SAI_xIMR_LFSDETIE_Msk   (0x1UL << SAI_xIMR_LFSDETIE_Pos)
#define SAI_xIMR_LFSDETIE   SAI_xIMR_LFSDETIE_Msk
#define SAI_xSR_OVRUDR_Pos   (0U)
#define SAI_xSR_OVRUDR_Msk   (0x1UL << SAI_xSR_OVRUDR_Pos)
#define SAI_xSR_OVRUDR   SAI_xSR_OVRUDR_Msk
#define SAI_xSR_MUTEDET_Pos   (1U)
#define SAI_xSR_MUTEDET_Msk   (0x1UL << SAI_xSR_MUTEDET_Pos)
#define SAI_xSR_MUTEDET   SAI_xSR_MUTEDET_Msk
#define SAI_xSR_WCKCFG_Pos   (2U)
#define SAI_xSR_WCKCFG_Msk   (0x1UL << SAI_xSR_WCKCFG_Pos)
#define SAI_xSR_WCKCFG   SAI_xSR_WCKCFG_Msk
#define SAI_xSR_FREQ_Pos   (3U)
#define SAI_xSR_FREQ_Msk   (0x1UL << SAI_xSR_FREQ_Pos)
#define SAI_xSR_FREQ   SAI_xSR_FREQ_Msk
#define SAI_xSR_CNRDY_Pos   (4U)
#define SAI_xSR_CNRDY_Msk   (0x1UL << SAI_xSR_CNRDY_Pos)
#define SAI_xSR_CNRDY   SAI_xSR_CNRDY_Msk
#define SAI_xSR_AFSDET_Pos   (5U)
#define SAI_xSR_AFSDET_Msk   (0x1UL << SAI_xSR_AFSDET_Pos)
#define SAI_xSR_AFSDET   SAI_xSR_AFSDET_Msk
#define SAI_xSR_LFSDET_Pos   (6U)
#define SAI_xSR_LFSDET_Msk   (0x1UL << SAI_xSR_LFSDET_Pos)
#define SAI_xSR_LFSDET   SAI_xSR_LFSDET_Msk
#define SAI_xSR_FLVL_Pos   (16U)
#define SAI_xSR_FLVL_Msk   (0x7UL << SAI_xSR_FLVL_Pos)
#define SAI_xSR_FLVL   SAI_xSR_FLVL_Msk
#define SAI_xSR_FLVL_0   (0x1UL << SAI_xSR_FLVL_Pos)
#define SAI_xSR_FLVL_1   (0x2UL << SAI_xSR_FLVL_Pos)
#define SAI_xSR_FLVL_2   (0x4UL << SAI_xSR_FLVL_Pos)
#define SAI_xCLRFR_COVRUDR_Pos   (0U)
#define SAI_xCLRFR_COVRUDR_Msk   (0x1UL << SAI_xCLRFR_COVRUDR_Pos)
#define SAI_xCLRFR_COVRUDR   SAI_xCLRFR_COVRUDR_Msk
#define SAI_xCLRFR_CMUTEDET_Pos   (1U)
#define SAI_xCLRFR_CMUTEDET_Msk   (0x1UL << SAI_xCLRFR_CMUTEDET_Pos)
#define SAI_xCLRFR_CMUTEDET   SAI_xCLRFR_CMUTEDET_Msk
#define SAI_xCLRFR_CWCKCFG_Pos   (2U)
#define SAI_xCLRFR_CWCKCFG_Msk   (0x1UL << SAI_xCLRFR_CWCKCFG_Pos)
#define SAI_xCLRFR_CWCKCFG   SAI_xCLRFR_CWCKCFG_Msk
#define SAI_xCLRFR_CFREQ_Pos   (3U)
#define SAI_xCLRFR_CFREQ_Msk   (0x1UL << SAI_xCLRFR_CFREQ_Pos)
#define SAI_xCLRFR_CFREQ   SAI_xCLRFR_CFREQ_Msk
#define SAI_xCLRFR_CCNRDY_Pos   (4U)
#define SAI_xCLRFR_CCNRDY_Msk   (0x1UL << SAI_xCLRFR_CCNRDY_Pos)
#define SAI_xCLRFR_CCNRDY   SAI_xCLRFR_CCNRDY_Msk
#define SAI_xCLRFR_CAFSDET_Pos   (5U)
#define SAI_xCLRFR_CAFSDET_Msk   (0x1UL << SAI_xCLRFR_CAFSDET_Pos)
#define SAI_xCLRFR_CAFSDET   SAI_xCLRFR_CAFSDET_Msk
#define SAI_xCLRFR_CLFSDET_Pos   (6U)
#define SAI_xCLRFR_CLFSDET_Msk   (0x1UL << SAI_xCLRFR_CLFSDET_Pos)
#define SAI_xCLRFR_CLFSDET   SAI_xCLRFR_CLFSDET_Msk
#define SAI_xDR_DATA_Pos   (0U)
#define SAI_xDR_DATA_Msk   (0xFFFFFFFFUL << SAI_xDR_DATA_Pos)
#define SAI_xDR_DATA   SAI_xDR_DATA_Msk
#define SAI_PDMCR_PDMEN_Pos   (0U)
#define SAI_PDMCR_PDMEN_Msk   (0x1UL << SAI_PDMCR_PDMEN_Pos)
#define SAI_PDMCR_PDMEN   SAI_PDMCR_PDMEN_Msk
#define SAI_PDMCR_MICNBR_Pos   (4U)
#define SAI_PDMCR_MICNBR_Msk   (0x3UL << SAI_PDMCR_MICNBR_Pos)
#define SAI_PDMCR_MICNBR   SAI_PDMCR_MICNBR_Msk
#define SAI_PDMCR_MICNBR_0   (0x1UL << SAI_PDMCR_MICNBR_Pos)
#define SAI_PDMCR_MICNBR_1   (0x2UL << SAI_PDMCR_MICNBR_Pos)
#define SAI_PDMCR_CKEN1_Pos   (8U)
#define SAI_PDMCR_CKEN1_Msk   (0x1UL << SAI_PDMCR_CKEN1_Pos)
#define SAI_PDMCR_CKEN1   SAI_PDMCR_CKEN1_Msk
#define SAI_PDMCR_CKEN2_Pos   (9U)
#define SAI_PDMCR_CKEN2_Msk   (0x1UL << SAI_PDMCR_CKEN2_Pos)
#define SAI_PDMCR_CKEN2   SAI_PDMCR_CKEN2_Msk
#define SAI_PDMCR_CKEN3_Pos   (10U)
#define SAI_PDMCR_CKEN3_Msk   (0x1UL << SAI_PDMCR_CKEN3_Pos)
#define SAI_PDMCR_CKEN3   SAI_PDMCR_CKEN3_Msk
#define SAI_PDMCR_CKEN4_Pos   (11U)
#define SAI_PDMCR_CKEN4_Msk   (0x1UL << SAI_PDMCR_CKEN4_Pos)
#define SAI_PDMCR_CKEN4   SAI_PDMCR_CKEN4_Msk
#define SAI_PDMDLY_DLYM1L_Pos   (0U)
#define SAI_PDMDLY_DLYM1L_Msk   (0x7UL << SAI_PDMDLY_DLYM1L_Pos)
#define SAI_PDMDLY_DLYM1L   SAI_PDMDLY_DLYM1L_Msk
#define SAI_PDMDLY_DLYM1L_0   (0x1UL << SAI_PDMDLY_DLYM1L_Pos)
#define SAI_PDMDLY_DLYM1L_1   (0x2UL << SAI_PDMDLY_DLYM1L_Pos)
#define SAI_PDMDLY_DLYM1L_2   (0x4UL << SAI_PDMDLY_DLYM1L_Pos)
#define SAI_PDMDLY_DLYM1R_Pos   (4U)
#define SAI_PDMDLY_DLYM1R_Msk   (0x7UL << SAI_PDMDLY_DLYM1R_Pos)
#define SAI_PDMDLY_DLYM1R   SAI_PDMDLY_DLYM1R_Msk
#define SAI_PDMDLY_DLYM1R_0   (0x1UL << SAI_PDMDLY_DLYM1R_Pos)
#define SAI_PDMDLY_DLYM1R_1   (0x2UL << SAI_PDMDLY_DLYM1R_Pos)
#define SAI_PDMDLY_DLYM1R_2   (0x4UL << SAI_PDMDLY_DLYM1R_Pos)
#define SAI_PDMDLY_DLYM2L_Pos   (8U)
#define SAI_PDMDLY_DLYM2L_Msk   (0x7UL << SAI_PDMDLY_DLYM2L_Pos)
#define SAI_PDMDLY_DLYM2L   SAI_PDMDLY_DLYM2L_Msk
#define SAI_PDMDLY_DLYM2L_0   (0x1UL << SAI_PDMDLY_DLYM2L_Pos)
#define SAI_PDMDLY_DLYM2L_1   (0x2UL << SAI_PDMDLY_DLYM2L_Pos)
#define SAI_PDMDLY_DLYM2L_2   (0x4UL << SAI_PDMDLY_DLYM2L_Pos)
#define SAI_PDMDLY_DLYM2R_Pos   (12U)
#define SAI_PDMDLY_DLYM2R_Msk   (0x7UL << SAI_PDMDLY_DLYM2R_Pos)
#define SAI_PDMDLY_DLYM2R   SAI_PDMDLY_DLYM2R_Msk
#define SAI_PDMDLY_DLYM2R_0   (0x1UL << SAI_PDMDLY_DLYM2R_Pos)
#define SAI_PDMDLY_DLYM2R_1   (0x2UL << SAI_PDMDLY_DLYM2R_Pos)
#define SAI_PDMDLY_DLYM2R_2   (0x4UL << SAI_PDMDLY_DLYM2R_Pos)
#define SAI_PDMDLY_DLYM3L_Pos   (16U)
#define SAI_PDMDLY_DLYM3L_Msk   (0x7UL << SAI_PDMDLY_DLYM3L_Pos)
#define SAI_PDMDLY_DLYM3L   SAI_PDMDLY_DLYM3L_Msk
#define SAI_PDMDLY_DLYM3L_0   (0x1UL << SAI_PDMDLY_DLYM3L_Pos)
#define SAI_PDMDLY_DLYM3L_1   (0x2UL << SAI_PDMDLY_DLYM3L_Pos)
#define SAI_PDMDLY_DLYM3L_2   (0x4UL << SAI_PDMDLY_DLYM3L_Pos)
#define SAI_PDMDLY_DLYM3R_Pos   (20U)
#define SAI_PDMDLY_DLYM3R_Msk   (0x7UL << SAI_PDMDLY_DLYM3R_Pos)
#define SAI_PDMDLY_DLYM3R   SAI_PDMDLY_DLYM3R_Msk
#define SAI_PDMDLY_DLYM3R_0   (0x1UL << SAI_PDMDLY_DLYM3R_Pos)
#define SAI_PDMDLY_DLYM3R_1   (0x2UL << SAI_PDMDLY_DLYM3R_Pos)
#define SAI_PDMDLY_DLYM3R_2   (0x4UL << SAI_PDMDLY_DLYM3R_Pos)
#define SAI_PDMDLY_DLYM4L_Pos   (24U)
#define SAI_PDMDLY_DLYM4L_Msk   (0x7UL << SAI_PDMDLY_DLYM4L_Pos)
#define SAI_PDMDLY_DLYM4L   SAI_PDMDLY_DLYM4L_Msk
#define SAI_PDMDLY_DLYM4L_0   (0x1UL << SAI_PDMDLY_DLYM4L_Pos)
#define SAI_PDMDLY_DLYM4L_1   (0x2UL << SAI_PDMDLY_DLYM4L_Pos)
#define SAI_PDMDLY_DLYM4L_2   (0x4UL << SAI_PDMDLY_DLYM4L_Pos)
#define SAI_PDMDLY_DLYM4R_Pos   (28U)
#define SAI_PDMDLY_DLYM4R_Msk   (0x7UL << SAI_PDMDLY_DLYM4R_Pos)
#define SAI_PDMDLY_DLYM4R   SAI_PDMDLY_DLYM4R_Msk
#define SAI_PDMDLY_DLYM4R_0   (0x1UL << SAI_PDMDLY_DLYM4R_Pos)
#define SAI_PDMDLY_DLYM4R_1   (0x2UL << SAI_PDMDLY_DLYM4R_Pos)
#define SAI_PDMDLY_DLYM4R_2   (0x4UL << SAI_PDMDLY_DLYM4R_Pos)
#define SDMMC_POWER_PWRCTRL_Pos   (0U)
#define SDMMC_POWER_PWRCTRL_Msk   (0x3UL << SDMMC_POWER_PWRCTRL_Pos)
#define SDMMC_POWER_PWRCTRL   SDMMC_POWER_PWRCTRL_Msk
#define SDMMC_POWER_PWRCTRL_0   (0x1UL << SDMMC_POWER_PWRCTRL_Pos)
#define SDMMC_POWER_PWRCTRL_1   (0x2UL << SDMMC_POWER_PWRCTRL_Pos)
#define SDMMC_POWER_VSWITCH_Pos   (2U)
#define SDMMC_POWER_VSWITCH_Msk   (0x1UL << SDMMC_POWER_VSWITCH_Pos)
#define SDMMC_POWER_VSWITCH   SDMMC_POWER_VSWITCH_Msk
#define SDMMC_POWER_VSWITCHEN_Pos   (3U)
#define SDMMC_POWER_VSWITCHEN_Msk   (0x1UL << SDMMC_POWER_VSWITCHEN_Pos)
#define SDMMC_POWER_VSWITCHEN   SDMMC_POWER_VSWITCHEN_Msk
#define SDMMC_POWER_DIRPOL_Pos   (4U)
#define SDMMC_POWER_DIRPOL_Msk   (0x1UL << SDMMC_POWER_DIRPOL_Pos)
#define SDMMC_POWER_DIRPOL   SDMMC_POWER_DIRPOL_Msk
#define SDMMC_CLKCR_CLKDIV_Pos   (0U)
#define SDMMC_CLKCR_CLKDIV_Msk   (0x3FFUL << SDMMC_CLKCR_CLKDIV_Pos)
#define SDMMC_CLKCR_CLKDIV   SDMMC_CLKCR_CLKDIV_Msk
#define SDMMC_CLKCR_PWRSAV_Pos   (12U)
#define SDMMC_CLKCR_PWRSAV_Msk   (0x1UL << SDMMC_CLKCR_PWRSAV_Pos)
#define SDMMC_CLKCR_PWRSAV   SDMMC_CLKCR_PWRSAV_Msk
#define SDMMC_CLKCR_WIDBUS_Pos   (14U)
#define SDMMC_CLKCR_WIDBUS_Msk   (0x3UL << SDMMC_CLKCR_WIDBUS_Pos)
#define SDMMC_CLKCR_WIDBUS   SDMMC_CLKCR_WIDBUS_Msk
#define SDMMC_CLKCR_WIDBUS_0   (0x1UL << SDMMC_CLKCR_WIDBUS_Pos)
#define SDMMC_CLKCR_WIDBUS_1   (0x2UL << SDMMC_CLKCR_WIDBUS_Pos)
#define SDMMC_CLKCR_NEGEDGE_Pos   (16U)
#define SDMMC_CLKCR_NEGEDGE_Msk   (0x1UL << SDMMC_CLKCR_NEGEDGE_Pos)
#define SDMMC_CLKCR_NEGEDGE   SDMMC_CLKCR_NEGEDGE_Msk
#define SDMMC_CLKCR_HWFC_EN_Pos   (17U)
#define SDMMC_CLKCR_HWFC_EN_Msk   (0x1UL << SDMMC_CLKCR_HWFC_EN_Pos)
#define SDMMC_CLKCR_HWFC_EN   SDMMC_CLKCR_HWFC_EN_Msk
#define SDMMC_CLKCR_DDR_Pos   (18U)
#define SDMMC_CLKCR_DDR_Msk   (0x1UL << SDMMC_CLKCR_DDR_Pos)
#define SDMMC_CLKCR_DDR   SDMMC_CLKCR_DDR_Msk
#define SDMMC_CLKCR_BUSSPEED_Pos   (19U)
#define SDMMC_CLKCR_BUSSPEED_Msk   (0x1UL << SDMMC_CLKCR_BUSSPEED_Pos)
#define SDMMC_CLKCR_BUSSPEED   SDMMC_CLKCR_BUSSPEED_Msk
#define SDMMC_CLKCR_SELCLKRX_Pos   (20U)
#define SDMMC_CLKCR_SELCLKRX_Msk   (0x3UL << SDMMC_CLKCR_SELCLKRX_Pos)
#define SDMMC_CLKCR_SELCLKRX   SDMMC_CLKCR_SELCLKRX_Msk
#define SDMMC_CLKCR_SELCLKRX_0   (0x1UL << SDMMC_CLKCR_SELCLKRX_Pos)
#define SDMMC_CLKCR_SELCLKRX_1   (0x2UL << SDMMC_CLKCR_SELCLKRX_Pos)
#define SDMMC_ARG_CMDARG_Pos   (0U)
#define SDMMC_ARG_CMDARG_Msk   (0xFFFFFFFFUL << SDMMC_ARG_CMDARG_Pos)
#define SDMMC_ARG_CMDARG   SDMMC_ARG_CMDARG_Msk
#define SDMMC_CMD_CMDINDEX_Pos   (0U)
#define SDMMC_CMD_CMDINDEX_Msk   (0x3FUL << SDMMC_CMD_CMDINDEX_Pos)
#define SDMMC_CMD_CMDINDEX   SDMMC_CMD_CMDINDEX_Msk
#define SDMMC_CMD_CMDTRANS_Pos   (6U)
#define SDMMC_CMD_CMDTRANS_Msk   (0x1UL << SDMMC_CMD_CMDTRANS_Pos)
#define SDMMC_CMD_CMDTRANS   SDMMC_CMD_CMDTRANS_Msk
#define SDMMC_CMD_CMDSTOP_Pos   (7U)
#define SDMMC_CMD_CMDSTOP_Msk   (0x1UL << SDMMC_CMD_CMDSTOP_Pos)
#define SDMMC_CMD_CMDSTOP   SDMMC_CMD_CMDSTOP_Msk
#define SDMMC_CMD_WAITRESP_Pos   (8U)
#define SDMMC_CMD_WAITRESP_Msk   (0x3UL << SDMMC_CMD_WAITRESP_Pos)
#define SDMMC_CMD_WAITRESP   SDMMC_CMD_WAITRESP_Msk
#define SDMMC_CMD_WAITRESP_0   (0x1UL << SDMMC_CMD_WAITRESP_Pos)
#define SDMMC_CMD_WAITRESP_1   (0x2UL << SDMMC_CMD_WAITRESP_Pos)
#define SDMMC_CMD_WAITINT_Pos   (10U)
#define SDMMC_CMD_WAITINT_Msk   (0x1UL << SDMMC_CMD_WAITINT_Pos)
#define SDMMC_CMD_WAITINT   SDMMC_CMD_WAITINT_Msk
#define SDMMC_CMD_WAITPEND_Pos   (11U)
#define SDMMC_CMD_WAITPEND_Msk   (0x1UL << SDMMC_CMD_WAITPEND_Pos)
#define SDMMC_CMD_WAITPEND   SDMMC_CMD_WAITPEND_Msk
#define SDMMC_CMD_CPSMEN_Pos   (12U)
#define SDMMC_CMD_CPSMEN_Msk   (0x1UL << SDMMC_CMD_CPSMEN_Pos)
#define SDMMC_CMD_CPSMEN   SDMMC_CMD_CPSMEN_Msk
#define SDMMC_CMD_DTHOLD_Pos   (13U)
#define SDMMC_CMD_DTHOLD_Msk   (0x1UL << SDMMC_CMD_DTHOLD_Pos)
#define SDMMC_CMD_DTHOLD   SDMMC_CMD_DTHOLD_Msk
#define SDMMC_CMD_BOOTMODE_Pos   (14U)
#define SDMMC_CMD_BOOTMODE_Msk   (0x1UL << SDMMC_CMD_BOOTMODE_Pos)
#define SDMMC_CMD_BOOTMODE   SDMMC_CMD_BOOTMODE_Msk
#define SDMMC_CMD_BOOTEN_Pos   (15U)
#define SDMMC_CMD_BOOTEN_Msk   (0x1UL << SDMMC_CMD_BOOTEN_Pos)
#define SDMMC_CMD_BOOTEN   SDMMC_CMD_BOOTEN_Msk
#define SDMMC_CMD_CMDSUSPEND_Pos   (16U)
#define SDMMC_CMD_CMDSUSPEND_Msk   (0x1UL << SDMMC_CMD_CMDSUSPEND_Pos)
#define SDMMC_CMD_CMDSUSPEND   SDMMC_CMD_CMDSUSPEND_Msk
#define SDMMC_RESPCMD_RESPCMD_Pos   (0U)
#define SDMMC_RESPCMD_RESPCMD_Msk   (0x3FUL << SDMMC_RESPCMD_RESPCMD_Pos)
#define SDMMC_RESPCMD_RESPCMD   SDMMC_RESPCMD_RESPCMD_Msk
#define SDMMC_RESP0_CARDSTATUS0_Pos   (0U)
#define SDMMC_RESP0_CARDSTATUS0_Msk   (0xFFFFFFFFUL << SDMMC_RESP0_CARDSTATUS0_Pos)
#define SDMMC_RESP0_CARDSTATUS0   SDMMC_RESP0_CARDSTATUS0_Msk
#define SDMMC_RESP1_CARDSTATUS1_Pos   (0U)
#define SDMMC_RESP1_CARDSTATUS1_Msk   (0xFFFFFFFFUL << SDMMC_RESP1_CARDSTATUS1_Pos)
#define SDMMC_RESP1_CARDSTATUS1   SDMMC_RESP1_CARDSTATUS1_Msk
#define SDMMC_RESP2_CARDSTATUS2_Pos   (0U)
#define SDMMC_RESP2_CARDSTATUS2_Msk   (0xFFFFFFFFUL << SDMMC_RESP2_CARDSTATUS2_Pos)
#define SDMMC_RESP2_CARDSTATUS2   SDMMC_RESP2_CARDSTATUS2_Msk
#define SDMMC_RESP3_CARDSTATUS3_Pos   (0U)
#define SDMMC_RESP3_CARDSTATUS3_Msk   (0xFFFFFFFFUL << SDMMC_RESP3_CARDSTATUS3_Pos)
#define SDMMC_RESP3_CARDSTATUS3   SDMMC_RESP3_CARDSTATUS3_Msk
#define SDMMC_RESP4_CARDSTATUS4_Pos   (0U)
#define SDMMC_RESP4_CARDSTATUS4_Msk   (0xFFFFFFFFUL << SDMMC_RESP4_CARDSTATUS4_Pos)
#define SDMMC_RESP4_CARDSTATUS4   SDMMC_RESP4_CARDSTATUS4_Msk
#define SDMMC_DTIMER_DATATIME_Pos   (0U)
#define SDMMC_DTIMER_DATATIME_Msk   (0xFFFFFFFFUL << SDMMC_DTIMER_DATATIME_Pos)
#define SDMMC_DTIMER_DATATIME   SDMMC_DTIMER_DATATIME_Msk
#define SDMMC_DLEN_DATALENGTH_Pos   (0U)
#define SDMMC_DLEN_DATALENGTH_Msk   (0x1FFFFFFUL << SDMMC_DLEN_DATALENGTH_Pos)
#define SDMMC_DLEN_DATALENGTH   SDMMC_DLEN_DATALENGTH_Msk
#define SDMMC_DCTRL_DTEN_Pos   (0U)
#define SDMMC_DCTRL_DTEN_Msk   (0x1UL << SDMMC_DCTRL_DTEN_Pos)
#define SDMMC_DCTRL_DTEN   SDMMC_DCTRL_DTEN_Msk
#define SDMMC_DCTRL_DTDIR_Pos   (1U)
#define SDMMC_DCTRL_DTDIR_Msk   (0x1UL << SDMMC_DCTRL_DTDIR_Pos)
#define SDMMC_DCTRL_DTDIR   SDMMC_DCTRL_DTDIR_Msk
#define SDMMC_DCTRL_DTMODE_Pos   (2U)
#define SDMMC_DCTRL_DTMODE_Msk   (0x3UL << SDMMC_DCTRL_DTMODE_Pos)
#define SDMMC_DCTRL_DTMODE   SDMMC_DCTRL_DTMODE_Msk
#define SDMMC_DCTRL_DTMODE_0   (0x1UL << SDMMC_DCTRL_DTMODE_Pos)
#define SDMMC_DCTRL_DTMODE_1   (0x2UL << SDMMC_DCTRL_DTMODE_Pos)
#define SDMMC_DCTRL_DBLOCKSIZE_Pos   (4U)
#define SDMMC_DCTRL_DBLOCKSIZE_Msk   (0xFUL << SDMMC_DCTRL_DBLOCKSIZE_Pos)
#define SDMMC_DCTRL_DBLOCKSIZE   SDMMC_DCTRL_DBLOCKSIZE_Msk
#define SDMMC_DCTRL_DBLOCKSIZE_0   (0x1UL << SDMMC_DCTRL_DBLOCKSIZE_Pos)
#define SDMMC_DCTRL_DBLOCKSIZE_1   (0x2UL << SDMMC_DCTRL_DBLOCKSIZE_Pos)
#define SDMMC_DCTRL_DBLOCKSIZE_2   (0x4UL << SDMMC_DCTRL_DBLOCKSIZE_Pos)
#define SDMMC_DCTRL_DBLOCKSIZE_3   (0x8UL << SDMMC_DCTRL_DBLOCKSIZE_Pos)
#define SDMMC_DCTRL_RWSTART_Pos   (8U)
#define SDMMC_DCTRL_RWSTART_Msk   (0x1UL << SDMMC_DCTRL_RWSTART_Pos)
#define SDMMC_DCTRL_RWSTART   SDMMC_DCTRL_RWSTART_Msk
#define SDMMC_DCTRL_RWSTOP_Pos   (9U)
#define SDMMC_DCTRL_RWSTOP_Msk   (0x1UL << SDMMC_DCTRL_RWSTOP_Pos)
#define SDMMC_DCTRL_RWSTOP   SDMMC_DCTRL_RWSTOP_Msk
#define SDMMC_DCTRL_RWMOD_Pos   (10U)
#define SDMMC_DCTRL_RWMOD_Msk   (0x1UL << SDMMC_DCTRL_RWMOD_Pos)
#define SDMMC_DCTRL_RWMOD   SDMMC_DCTRL_RWMOD_Msk
#define SDMMC_DCTRL_SDIOEN_Pos   (11U)
#define SDMMC_DCTRL_SDIOEN_Msk   (0x1UL << SDMMC_DCTRL_SDIOEN_Pos)
#define SDMMC_DCTRL_SDIOEN   SDMMC_DCTRL_SDIOEN_Msk
#define SDMMC_DCTRL_BOOTACKEN_Pos   (12U)
#define SDMMC_DCTRL_BOOTACKEN_Msk   (0x1UL << SDMMC_DCTRL_BOOTACKEN_Pos)
#define SDMMC_DCTRL_BOOTACKEN   SDMMC_DCTRL_BOOTACKEN_Msk
#define SDMMC_DCTRL_FIFORST_Pos   (13U)
#define SDMMC_DCTRL_FIFORST_Msk   (0x1UL << SDMMC_DCTRL_FIFORST_Pos)
#define SDMMC_DCTRL_FIFORST   SDMMC_DCTRL_FIFORST_Msk
#define SDMMC_DCOUNT_DATACOUNT_Pos   (0U)
#define SDMMC_DCOUNT_DATACOUNT_Msk   (0x1FFFFFFUL << SDMMC_DCOUNT_DATACOUNT_Pos)
#define SDMMC_DCOUNT_DATACOUNT   SDMMC_DCOUNT_DATACOUNT_Msk
#define SDMMC_STA_CCRCFAIL_Pos   (0U)
#define SDMMC_STA_CCRCFAIL_Msk   (0x1UL << SDMMC_STA_CCRCFAIL_Pos)
#define SDMMC_STA_CCRCFAIL   SDMMC_STA_CCRCFAIL_Msk
#define SDMMC_STA_DCRCFAIL_Pos   (1U)
#define SDMMC_STA_DCRCFAIL_Msk   (0x1UL << SDMMC_STA_DCRCFAIL_Pos)
#define SDMMC_STA_DCRCFAIL   SDMMC_STA_DCRCFAIL_Msk
#define SDMMC_STA_CTIMEOUT_Pos   (2U)
#define SDMMC_STA_CTIMEOUT_Msk   (0x1UL << SDMMC_STA_CTIMEOUT_Pos)
#define SDMMC_STA_CTIMEOUT   SDMMC_STA_CTIMEOUT_Msk
#define SDMMC_STA_DTIMEOUT_Pos   (3U)
#define SDMMC_STA_DTIMEOUT_Msk   (0x1UL << SDMMC_STA_DTIMEOUT_Pos)
#define SDMMC_STA_DTIMEOUT   SDMMC_STA_DTIMEOUT_Msk
#define SDMMC_STA_TXUNDERR_Pos   (4U)
#define SDMMC_STA_TXUNDERR_Msk   (0x1UL << SDMMC_STA_TXUNDERR_Pos)
#define SDMMC_STA_TXUNDERR   SDMMC_STA_TXUNDERR_Msk
#define SDMMC_STA_RXOVERR_Pos   (5U)
#define SDMMC_STA_RXOVERR_Msk   (0x1UL << SDMMC_STA_RXOVERR_Pos)
#define SDMMC_STA_RXOVERR   SDMMC_STA_RXOVERR_Msk
#define SDMMC_STA_CMDREND_Pos   (6U)
#define SDMMC_STA_CMDREND_Msk   (0x1UL << SDMMC_STA_CMDREND_Pos)
#define SDMMC_STA_CMDREND   SDMMC_STA_CMDREND_Msk
#define SDMMC_STA_CMDSENT_Pos   (7U)
#define SDMMC_STA_CMDSENT_Msk   (0x1UL << SDMMC_STA_CMDSENT_Pos)
#define SDMMC_STA_CMDSENT   SDMMC_STA_CMDSENT_Msk
#define SDMMC_STA_DATAEND_Pos   (8U)
#define SDMMC_STA_DATAEND_Msk   (0x1UL << SDMMC_STA_DATAEND_Pos)
#define SDMMC_STA_DATAEND   SDMMC_STA_DATAEND_Msk
#define SDMMC_STA_DHOLD_Pos   (9U)
#define SDMMC_STA_DHOLD_Msk   (0x1UL << SDMMC_STA_DHOLD_Pos)
#define SDMMC_STA_DHOLD   SDMMC_STA_DHOLD_Msk
#define SDMMC_STA_DBCKEND_Pos   (10U)
#define SDMMC_STA_DBCKEND_Msk   (0x1UL << SDMMC_STA_DBCKEND_Pos)
#define SDMMC_STA_DBCKEND   SDMMC_STA_DBCKEND_Msk
#define SDMMC_STA_DABORT_Pos   (11U)
#define SDMMC_STA_DABORT_Msk   (0x1UL << SDMMC_STA_DABORT_Pos)
#define SDMMC_STA_DABORT   SDMMC_STA_DABORT_Msk
#define SDMMC_STA_DPSMACT_Pos   (12U)
#define SDMMC_STA_DPSMACT_Msk   (0x1UL << SDMMC_STA_DPSMACT_Pos)
#define SDMMC_STA_DPSMACT   SDMMC_STA_DPSMACT_Msk
#define SDMMC_STA_CPSMACT_Pos   (13U)
#define SDMMC_STA_CPSMACT_Msk   (0x1UL << SDMMC_STA_CPSMACT_Pos)
#define SDMMC_STA_CPSMACT   SDMMC_STA_CPSMACT_Msk
#define SDMMC_STA_TXFIFOHE_Pos   (14U)
#define SDMMC_STA_TXFIFOHE_Msk   (0x1UL << SDMMC_STA_TXFIFOHE_Pos)
#define SDMMC_STA_TXFIFOHE   SDMMC_STA_TXFIFOHE_Msk
#define SDMMC_STA_RXFIFOHF_Pos   (15U)
#define SDMMC_STA_RXFIFOHF_Msk   (0x1UL << SDMMC_STA_RXFIFOHF_Pos)
#define SDMMC_STA_RXFIFOHF   SDMMC_STA_RXFIFOHF_Msk
#define SDMMC_STA_TXFIFOF_Pos   (16U)
#define SDMMC_STA_TXFIFOF_Msk   (0x1UL << SDMMC_STA_TXFIFOF_Pos)
#define SDMMC_STA_TXFIFOF   SDMMC_STA_TXFIFOF_Msk
#define SDMMC_STA_RXFIFOF_Pos   (17U)
#define SDMMC_STA_RXFIFOF_Msk   (0x1UL << SDMMC_STA_RXFIFOF_Pos)
#define SDMMC_STA_RXFIFOF   SDMMC_STA_RXFIFOF_Msk
#define SDMMC_STA_TXFIFOE_Pos   (18U)
#define SDMMC_STA_TXFIFOE_Msk   (0x1UL << SDMMC_STA_TXFIFOE_Pos)
#define SDMMC_STA_TXFIFOE   SDMMC_STA_TXFIFOE_Msk
#define SDMMC_STA_RXFIFOE_Pos   (19U)
#define SDMMC_STA_RXFIFOE_Msk   (0x1UL << SDMMC_STA_RXFIFOE_Pos)
#define SDMMC_STA_RXFIFOE   SDMMC_STA_RXFIFOE_Msk
#define SDMMC_STA_BUSYD0_Pos   (20U)
#define SDMMC_STA_BUSYD0_Msk   (0x1UL << SDMMC_STA_BUSYD0_Pos)
#define SDMMC_STA_BUSYD0   SDMMC_STA_BUSYD0_Msk
#define SDMMC_STA_BUSYD0END_Pos   (21U)
#define SDMMC_STA_BUSYD0END_Msk   (0x1UL << SDMMC_STA_BUSYD0END_Pos)
#define SDMMC_STA_BUSYD0END   SDMMC_STA_BUSYD0END_Msk
#define SDMMC_STA_SDIOIT_Pos   (22U)
#define SDMMC_STA_SDIOIT_Msk   (0x1UL << SDMMC_STA_SDIOIT_Pos)
#define SDMMC_STA_SDIOIT   SDMMC_STA_SDIOIT_Msk
#define SDMMC_STA_ACKFAIL_Pos   (23U)
#define SDMMC_STA_ACKFAIL_Msk   (0x1UL << SDMMC_STA_ACKFAIL_Pos)
#define SDMMC_STA_ACKFAIL   SDMMC_STA_ACKFAIL_Msk
#define SDMMC_STA_ACKTIMEOUT_Pos   (24U)
#define SDMMC_STA_ACKTIMEOUT_Msk   (0x1UL << SDMMC_STA_ACKTIMEOUT_Pos)
#define SDMMC_STA_ACKTIMEOUT   SDMMC_STA_ACKTIMEOUT_Msk
#define SDMMC_STA_VSWEND_Pos   (25U)
#define SDMMC_STA_VSWEND_Msk   (0x1UL << SDMMC_STA_VSWEND_Pos)
#define SDMMC_STA_VSWEND   SDMMC_STA_VSWEND_Msk
#define SDMMC_STA_CKSTOP_Pos   (26U)
#define SDMMC_STA_CKSTOP_Msk   (0x1UL << SDMMC_STA_CKSTOP_Pos)
#define SDMMC_STA_CKSTOP   SDMMC_STA_CKSTOP_Msk
#define SDMMC_STA_IDMATE_Pos   (27U)
#define SDMMC_STA_IDMATE_Msk   (0x1UL << SDMMC_STA_IDMATE_Pos)
#define SDMMC_STA_IDMATE   SDMMC_STA_IDMATE_Msk
#define SDMMC_STA_IDMABTC_Pos   (28U)
#define SDMMC_STA_IDMABTC_Msk   (0x1UL << SDMMC_STA_IDMABTC_Pos)
#define SDMMC_STA_IDMABTC   SDMMC_STA_IDMABTC_Msk
#define SDMMC_ICR_CCRCFAILC_Pos   (0U)
#define SDMMC_ICR_CCRCFAILC_Msk   (0x1UL << SDMMC_ICR_CCRCFAILC_Pos)
#define SDMMC_ICR_CCRCFAILC   SDMMC_ICR_CCRCFAILC_Msk
#define SDMMC_ICR_DCRCFAILC_Pos   (1U)
#define SDMMC_ICR_DCRCFAILC_Msk   (0x1UL << SDMMC_ICR_DCRCFAILC_Pos)
#define SDMMC_ICR_DCRCFAILC   SDMMC_ICR_DCRCFAILC_Msk
#define SDMMC_ICR_CTIMEOUTC_Pos   (2U)
#define SDMMC_ICR_CTIMEOUTC_Msk   (0x1UL << SDMMC_ICR_CTIMEOUTC_Pos)
#define SDMMC_ICR_CTIMEOUTC   SDMMC_ICR_CTIMEOUTC_Msk
#define SDMMC_ICR_DTIMEOUTC_Pos   (3U)
#define SDMMC_ICR_DTIMEOUTC_Msk   (0x1UL << SDMMC_ICR_DTIMEOUTC_Pos)
#define SDMMC_ICR_DTIMEOUTC   SDMMC_ICR_DTIMEOUTC_Msk
#define SDMMC_ICR_TXUNDERRC_Pos   (4U)
#define SDMMC_ICR_TXUNDERRC_Msk   (0x1UL << SDMMC_ICR_TXUNDERRC_Pos)
#define SDMMC_ICR_TXUNDERRC   SDMMC_ICR_TXUNDERRC_Msk
#define SDMMC_ICR_RXOVERRC_Pos   (5U)
#define SDMMC_ICR_RXOVERRC_Msk   (0x1UL << SDMMC_ICR_RXOVERRC_Pos)
#define SDMMC_ICR_RXOVERRC   SDMMC_ICR_RXOVERRC_Msk
#define SDMMC_ICR_CMDRENDC_Pos   (6U)
#define SDMMC_ICR_CMDRENDC_Msk   (0x1UL << SDMMC_ICR_CMDRENDC_Pos)
#define SDMMC_ICR_CMDRENDC   SDMMC_ICR_CMDRENDC_Msk
#define SDMMC_ICR_CMDSENTC_Pos   (7U)
#define SDMMC_ICR_CMDSENTC_Msk   (0x1UL << SDMMC_ICR_CMDSENTC_Pos)
#define SDMMC_ICR_CMDSENTC   SDMMC_ICR_CMDSENTC_Msk
#define SDMMC_ICR_DATAENDC_Pos   (8U)
#define SDMMC_ICR_DATAENDC_Msk   (0x1UL << SDMMC_ICR_DATAENDC_Pos)
#define SDMMC_ICR_DATAENDC   SDMMC_ICR_DATAENDC_Msk
#define SDMMC_ICR_DHOLDC_Pos   (9U)
#define SDMMC_ICR_DHOLDC_Msk   (0x1UL << SDMMC_ICR_DHOLDC_Pos)
#define SDMMC_ICR_DHOLDC   SDMMC_ICR_DHOLDC_Msk
#define SDMMC_ICR_DBCKENDC_Pos   (10U)
#define SDMMC_ICR_DBCKENDC_Msk   (0x1UL << SDMMC_ICR_DBCKENDC_Pos)
#define SDMMC_ICR_DBCKENDC   SDMMC_ICR_DBCKENDC_Msk
#define SDMMC_ICR_DABORTC_Pos   (11U)
#define SDMMC_ICR_DABORTC_Msk   (0x1UL << SDMMC_ICR_DABORTC_Pos)
#define SDMMC_ICR_DABORTC   SDMMC_ICR_DABORTC_Msk
#define SDMMC_ICR_BUSYD0ENDC_Pos   (21U)
#define SDMMC_ICR_BUSYD0ENDC_Msk   (0x1UL << SDMMC_ICR_BUSYD0ENDC_Pos)
#define SDMMC_ICR_BUSYD0ENDC   SDMMC_ICR_BUSYD0ENDC_Msk
#define SDMMC_ICR_SDIOITC_Pos   (22U)
#define SDMMC_ICR_SDIOITC_Msk   (0x1UL << SDMMC_ICR_SDIOITC_Pos)
#define SDMMC_ICR_SDIOITC   SDMMC_ICR_SDIOITC_Msk
#define SDMMC_ICR_ACKFAILC_Pos   (23U)
#define SDMMC_ICR_ACKFAILC_Msk   (0x1UL << SDMMC_ICR_ACKFAILC_Pos)
#define SDMMC_ICR_ACKFAILC   SDMMC_ICR_ACKFAILC_Msk
#define SDMMC_ICR_ACKTIMEOUTC_Pos   (24U)
#define SDMMC_ICR_ACKTIMEOUTC_Msk   (0x1UL << SDMMC_ICR_ACKTIMEOUTC_Pos)
#define SDMMC_ICR_ACKTIMEOUTC   SDMMC_ICR_ACKTIMEOUTC_Msk
#define SDMMC_ICR_VSWENDC_Pos   (25U)
#define SDMMC_ICR_VSWENDC_Msk   (0x1UL << SDMMC_ICR_VSWENDC_Pos)
#define SDMMC_ICR_VSWENDC   SDMMC_ICR_VSWENDC_Msk
#define SDMMC_ICR_CKSTOPC_Pos   (26U)
#define SDMMC_ICR_CKSTOPC_Msk   (0x1UL << SDMMC_ICR_CKSTOPC_Pos)
#define SDMMC_ICR_CKSTOPC   SDMMC_ICR_CKSTOPC_Msk
#define SDMMC_ICR_IDMATEC_Pos   (27U)
#define SDMMC_ICR_IDMATEC_Msk   (0x1UL << SDMMC_ICR_IDMATEC_Pos)
#define SDMMC_ICR_IDMATEC   SDMMC_ICR_IDMATEC_Msk
#define SDMMC_ICR_IDMABTCC_Pos   (28U)
#define SDMMC_ICR_IDMABTCC_Msk   (0x1UL << SDMMC_ICR_IDMABTCC_Pos)
#define SDMMC_ICR_IDMABTCC   SDMMC_ICR_IDMABTCC_Msk
#define SDMMC_MASK_CCRCFAILIE_Pos   (0U)
#define SDMMC_MASK_CCRCFAILIE_Msk   (0x1UL << SDMMC_MASK_CCRCFAILIE_Pos)
#define SDMMC_MASK_CCRCFAILIE   SDMMC_MASK_CCRCFAILIE_Msk
#define SDMMC_MASK_DCRCFAILIE_Pos   (1U)
#define SDMMC_MASK_DCRCFAILIE_Msk   (0x1UL << SDMMC_MASK_DCRCFAILIE_Pos)
#define SDMMC_MASK_DCRCFAILIE   SDMMC_MASK_DCRCFAILIE_Msk
#define SDMMC_MASK_CTIMEOUTIE_Pos   (2U)
#define SDMMC_MASK_CTIMEOUTIE_Msk   (0x1UL << SDMMC_MASK_CTIMEOUTIE_Pos)
#define SDMMC_MASK_CTIMEOUTIE   SDMMC_MASK_CTIMEOUTIE_Msk
#define SDMMC_MASK_DTIMEOUTIE_Pos   (3U)
#define SDMMC_MASK_DTIMEOUTIE_Msk   (0x1UL << SDMMC_MASK_DTIMEOUTIE_Pos)
#define SDMMC_MASK_DTIMEOUTIE   SDMMC_MASK_DTIMEOUTIE_Msk
#define SDMMC_MASK_TXUNDERRIE_Pos   (4U)
#define SDMMC_MASK_TXUNDERRIE_Msk   (0x1UL << SDMMC_MASK_TXUNDERRIE_Pos)
#define SDMMC_MASK_TXUNDERRIE   SDMMC_MASK_TXUNDERRIE_Msk
#define SDMMC_MASK_RXOVERRIE_Pos   (5U)
#define SDMMC_MASK_RXOVERRIE_Msk   (0x1UL << SDMMC_MASK_RXOVERRIE_Pos)
#define SDMMC_MASK_RXOVERRIE   SDMMC_MASK_RXOVERRIE_Msk
#define SDMMC_MASK_CMDRENDIE_Pos   (6U)
#define SDMMC_MASK_CMDRENDIE_Msk   (0x1UL << SDMMC_MASK_CMDRENDIE_Pos)
#define SDMMC_MASK_CMDRENDIE   SDMMC_MASK_CMDRENDIE_Msk
#define SDMMC_MASK_CMDSENTIE_Pos   (7U)
#define SDMMC_MASK_CMDSENTIE_Msk   (0x1UL << SDMMC_MASK_CMDSENTIE_Pos)
#define SDMMC_MASK_CMDSENTIE   SDMMC_MASK_CMDSENTIE_Msk
#define SDMMC_MASK_DATAENDIE_Pos   (8U)
#define SDMMC_MASK_DATAENDIE_Msk   (0x1UL << SDMMC_MASK_DATAENDIE_Pos)
#define SDMMC_MASK_DATAENDIE   SDMMC_MASK_DATAENDIE_Msk
#define SDMMC_MASK_DHOLDIE_Pos   (9U)
#define SDMMC_MASK_DHOLDIE_Msk   (0x1UL << SDMMC_MASK_DHOLDIE_Pos)
#define SDMMC_MASK_DHOLDIE   SDMMC_MASK_DHOLDIE_Msk
#define SDMMC_MASK_DBCKENDIE_Pos   (10U)
#define SDMMC_MASK_DBCKENDIE_Msk   (0x1UL << SDMMC_MASK_DBCKENDIE_Pos)
#define SDMMC_MASK_DBCKENDIE   SDMMC_MASK_DBCKENDIE_Msk
#define SDMMC_MASK_DABORTIE_Pos   (11U)
#define SDMMC_MASK_DABORTIE_Msk   (0x1UL << SDMMC_MASK_DABORTIE_Pos)
#define SDMMC_MASK_DABORTIE   SDMMC_MASK_DABORTIE_Msk
#define SDMMC_MASK_TXFIFOHEIE_Pos   (14U)
#define SDMMC_MASK_TXFIFOHEIE_Msk   (0x1UL << SDMMC_MASK_TXFIFOHEIE_Pos)
#define SDMMC_MASK_TXFIFOHEIE   SDMMC_MASK_TXFIFOHEIE_Msk
#define SDMMC_MASK_RXFIFOHFIE_Pos   (15U)
#define SDMMC_MASK_RXFIFOHFIE_Msk   (0x1UL << SDMMC_MASK_RXFIFOHFIE_Pos)
#define SDMMC_MASK_RXFIFOHFIE   SDMMC_MASK_RXFIFOHFIE_Msk
#define SDMMC_MASK_RXFIFOFIE_Pos   (17U)
#define SDMMC_MASK_RXFIFOFIE_Msk   (0x1UL << SDMMC_MASK_RXFIFOFIE_Pos)
#define SDMMC_MASK_RXFIFOFIE   SDMMC_MASK_RXFIFOFIE_Msk
#define SDMMC_MASK_TXFIFOEIE_Pos   (18U)
#define SDMMC_MASK_TXFIFOEIE_Msk   (0x1UL << SDMMC_MASK_TXFIFOEIE_Pos)
#define SDMMC_MASK_TXFIFOEIE   SDMMC_MASK_TXFIFOEIE_Msk
#define SDMMC_MASK_BUSYD0ENDIE_Pos   (21U)
#define SDMMC_MASK_BUSYD0ENDIE_Msk   (0x1UL << SDMMC_MASK_BUSYD0ENDIE_Pos)
#define SDMMC_MASK_BUSYD0ENDIE   SDMMC_MASK_BUSYD0ENDIE_Msk
#define SDMMC_MASK_SDIOITIE_Pos   (22U)
#define SDMMC_MASK_SDIOITIE_Msk   (0x1UL << SDMMC_MASK_SDIOITIE_Pos)
#define SDMMC_MASK_SDIOITIE   SDMMC_MASK_SDIOITIE_Msk
#define SDMMC_MASK_ACKFAILIE_Pos   (23U)
#define SDMMC_MASK_ACKFAILIE_Msk   (0x1UL << SDMMC_MASK_ACKFAILIE_Pos)
#define SDMMC_MASK_ACKFAILIE   SDMMC_MASK_ACKFAILIE_Msk
#define SDMMC_MASK_ACKTIMEOUTIE_Pos   (24U)
#define SDMMC_MASK_ACKTIMEOUTIE_Msk   (0x1UL << SDMMC_MASK_ACKTIMEOUTIE_Pos)
#define SDMMC_MASK_ACKTIMEOUTIE   SDMMC_MASK_ACKTIMEOUTIE_Msk
#define SDMMC_MASK_VSWENDIE_Pos   (25U)
#define SDMMC_MASK_VSWENDIE_Msk   (0x1UL << SDMMC_MASK_VSWENDIE_Pos)
#define SDMMC_MASK_VSWENDIE   SDMMC_MASK_VSWENDIE_Msk
#define SDMMC_MASK_CKSTOPIE_Pos   (26U)
#define SDMMC_MASK_CKSTOPIE_Msk   (0x1UL << SDMMC_MASK_CKSTOPIE_Pos)
#define SDMMC_MASK_CKSTOPIE   SDMMC_MASK_CKSTOPIE_Msk
#define SDMMC_MASK_IDMABTCIE_Pos   (28U)
#define SDMMC_MASK_IDMABTCIE_Msk   (0x1UL << SDMMC_MASK_IDMABTCIE_Pos)
#define SDMMC_MASK_IDMABTCIE   SDMMC_MASK_IDMABTCIE_Msk
#define SDMMC_ACKTIME_ACKTIME_Pos   (0U)
#define SDMMC_ACKTIME_ACKTIME_Msk   (0x1FFFFFFUL << SDMMC_ACKTIME_ACKTIME_Pos)
#define SDMMC_ACKTIME_ACKTIME   SDMMC_ACKTIME_ACKTIME_Msk
#define SDMMC_FIFO_FIFODATA_Pos   (0U)
#define SDMMC_FIFO_FIFODATA_Msk   (0xFFFFFFFFUL << SDMMC_FIFO_FIFODATA_Pos)
#define SDMMC_FIFO_FIFODATA   SDMMC_FIFO_FIFODATA_Msk
#define SDMMC_IDMA_IDMAEN_Pos   (0U)
#define SDMMC_IDMA_IDMAEN_Msk   (0x1UL << SDMMC_IDMA_IDMAEN_Pos)
#define SDMMC_IDMA_IDMAEN   SDMMC_IDMA_IDMAEN_Msk
#define SDMMC_IDMA_IDMABMODE_Pos   (1U)
#define SDMMC_IDMA_IDMABMODE_Msk   (0x1UL << SDMMC_IDMA_IDMABMODE_Pos)
#define SDMMC_IDMA_IDMABMODE   SDMMC_IDMA_IDMABMODE_Msk
#define SDMMC_IDMA_IDMABACT_Pos   (2U)
#define SDMMC_IDMA_IDMABACT_Msk   (0x1UL << SDMMC_IDMA_IDMABACT_Pos)
#define SDMMC_IDMA_IDMABACT   SDMMC_IDMA_IDMABACT_Msk
#define SDMMC_IDMABSIZE_IDMABNDT_Pos   (5U)
#define SDMMC_IDMABSIZE_IDMABNDT_Msk   (0xFFUL << SDMMC_IDMABSIZE_IDMABNDT_Pos)
#define SDMMC_IDMABSIZE_IDMABNDT   SDMMC_IDMABSIZE_IDMABNDT_Msk
#define SDMMC_IDMABASE0_IDMABASE0   (0xFFFFFFFFU)
#define SDMMC_IDMABASE1_IDMABASE1   (0xFFFFFFFFU)
#define DLYB_CR_DEN_Pos   (0U)
#define DLYB_CR_DEN_Msk   (0x1UL << DLYB_CR_DEN_Pos)
#define DLYB_CR_DEN   DLYB_CR_DEN_Msk
#define DLYB_CR_SEN_Pos   (1U)
#define DLYB_CR_SEN_Msk   (0x1UL << DLYB_CR_SEN_Pos)
#define DLYB_CR_SEN   DLYB_CR_SEN_Msk
#define DLYB_CFGR_SEL_Pos   (0U)
#define DLYB_CFGR_SEL_Msk   (0xFUL << DLYB_CFGR_SEL_Pos)
#define DLYB_CFGR_SEL   DLYB_CFGR_SEL_Msk
#define DLYB_CFGR_SEL_0   (0x1UL << DLYB_CFGR_SEL_Pos)
#define DLYB_CFGR_SEL_1   (0x2UL << DLYB_CFGR_SEL_Pos)
#define DLYB_CFGR_SEL_2   (0x3UL << DLYB_CFGR_SEL_Pos)
#define DLYB_CFGR_SEL_3   (0x8UL << DLYB_CFGR_SEL_Pos)
#define DLYB_CFGR_UNIT_Pos   (8U)
#define DLYB_CFGR_UNIT_Msk   (0x7FUL << DLYB_CFGR_UNIT_Pos)
#define DLYB_CFGR_UNIT   DLYB_CFGR_UNIT_Msk
#define DLYB_CFGR_UNIT_0   (0x01UL << DLYB_CFGR_UNIT_Pos)
#define DLYB_CFGR_UNIT_1   (0x02UL << DLYB_CFGR_UNIT_Pos)
#define DLYB_CFGR_UNIT_2   (0x04UL << DLYB_CFGR_UNIT_Pos)
#define DLYB_CFGR_UNIT_3   (0x08UL << DLYB_CFGR_UNIT_Pos)
#define DLYB_CFGR_UNIT_4   (0x10UL << DLYB_CFGR_UNIT_Pos)
#define DLYB_CFGR_UNIT_5   (0x20UL << DLYB_CFGR_UNIT_Pos)
#define DLYB_CFGR_UNIT_6   (0x40UL << DLYB_CFGR_UNIT_Pos)
#define DLYB_CFGR_LNG_Pos   (16U)
#define DLYB_CFGR_LNG_Msk   (0xFFFUL << DLYB_CFGR_LNG_Pos)
#define DLYB_CFGR_LNG   DLYB_CFGR_LNG_Msk
#define DLYB_CFGR_LNG_0   (0x001UL << DLYB_CFGR_LNG_Pos)
#define DLYB_CFGR_LNG_1   (0x002UL << DLYB_CFGR_LNG_Pos)
#define DLYB_CFGR_LNG_2   (0x004UL << DLYB_CFGR_LNG_Pos)
#define DLYB_CFGR_LNG_3   (0x008UL << DLYB_CFGR_LNG_Pos)
#define DLYB_CFGR_LNG_4   (0x010UL << DLYB_CFGR_LNG_Pos)
#define DLYB_CFGR_LNG_5   (0x020UL << DLYB_CFGR_LNG_Pos)
#define DLYB_CFGR_LNG_6   (0x040UL << DLYB_CFGR_LNG_Pos)
#define DLYB_CFGR_LNG_7   (0x080UL << DLYB_CFGR_LNG_Pos)
#define DLYB_CFGR_LNG_8   (0x100UL << DLYB_CFGR_LNG_Pos)
#define DLYB_CFGR_LNG_9   (0x200UL << DLYB_CFGR_LNG_Pos)
#define DLYB_CFGR_LNG_10   (0x400UL << DLYB_CFGR_LNG_Pos)
#define DLYB_CFGR_LNG_11   (0x800UL << DLYB_CFGR_LNG_Pos)
#define DLYB_CFGR_LNGF_Pos   (31U)
#define DLYB_CFGR_LNGF_Msk   (0x1UL << DLYB_CFGR_LNGF_Pos)
#define DLYB_CFGR_LNGF   DLYB_CFGR_LNGF_Msk
#define SPI_SPI6I2S_SUPPORT
#define SPI_CR1_SPE_Pos   (0U)
#define SPI_CR1_SPE_Msk   (0x1UL << SPI_CR1_SPE_Pos)
#define SPI_CR1_SPE   SPI_CR1_SPE_Msk
#define SPI_CR1_MASRX_Pos   (8U)
#define SPI_CR1_MASRX_Msk   (0x1UL << SPI_CR1_MASRX_Pos)
#define SPI_CR1_MASRX   SPI_CR1_MASRX_Msk
#define SPI_CR1_CSTART_Pos   (9U)
#define SPI_CR1_CSTART_Msk   (0x1UL << SPI_CR1_CSTART_Pos)
#define SPI_CR1_CSTART   SPI_CR1_CSTART_Msk
#define SPI_CR1_CSUSP_Pos   (10U)
#define SPI_CR1_CSUSP_Msk   (0x1UL << SPI_CR1_CSUSP_Pos)
#define SPI_CR1_CSUSP   SPI_CR1_CSUSP_Msk
#define SPI_CR1_HDDIR_Pos   (11U)
#define SPI_CR1_HDDIR_Msk   (0x1UL << SPI_CR1_HDDIR_Pos)
#define SPI_CR1_HDDIR   SPI_CR1_HDDIR_Msk
#define SPI_CR1_SSI_Pos   (12U)
#define SPI_CR1_SSI_Msk   (0x1UL << SPI_CR1_SSI_Pos)
#define SPI_CR1_SSI   SPI_CR1_SSI_Msk
#define SPI_CR1_CRC33_17_Pos   (13U)
#define SPI_CR1_CRC33_17_Msk   (0x1UL << SPI_CR1_CRC33_17_Pos)
#define SPI_CR1_CRC33_17   SPI_CR1_CRC33_17_Msk
#define SPI_CR1_RCRCINI_Pos   (14U)
#define SPI_CR1_RCRCINI_Msk   (0x1UL << SPI_CR1_RCRCINI_Pos)
#define SPI_CR1_RCRCINI   SPI_CR1_RCRCINI_Msk
#define SPI_CR1_TCRCINI_Pos   (15U)
#define SPI_CR1_TCRCINI_Msk   (0x1UL << SPI_CR1_TCRCINI_Pos)
#define SPI_CR1_TCRCINI   SPI_CR1_TCRCINI_Msk
#define SPI_CR1_IOLOCK_Pos   (16U)
#define SPI_CR1_IOLOCK_Msk   (0x1UL << SPI_CR1_IOLOCK_Pos)
#define SPI_CR1_IOLOCK   SPI_CR1_IOLOCK_Msk
#define SPI_CR2_TSER_Pos   (16U)
#define SPI_CR2_TSER_Msk   (0xFFFFUL << SPI_CR2_TSER_Pos)
#define SPI_CR2_TSER   SPI_CR2_TSER_Msk
#define SPI_CR2_TSIZE_Pos   (0U)
#define SPI_CR2_TSIZE_Msk   (0xFFFFUL << SPI_CR2_TSIZE_Pos)
#define SPI_CR2_TSIZE   SPI_CR2_TSIZE_Msk
#define SPI_CFG1_DSIZE_Pos   (0U)
#define SPI_CFG1_DSIZE_Msk   (0x1FUL << SPI_CFG1_DSIZE_Pos)
#define SPI_CFG1_DSIZE   SPI_CFG1_DSIZE_Msk
#define SPI_CFG1_DSIZE_0   (0x01UL << SPI_CFG1_DSIZE_Pos)
#define SPI_CFG1_DSIZE_1   (0x02UL << SPI_CFG1_DSIZE_Pos)
#define SPI_CFG1_DSIZE_2   (0x04UL << SPI_CFG1_DSIZE_Pos)
#define SPI_CFG1_DSIZE_3   (0x08UL << SPI_CFG1_DSIZE_Pos)
#define SPI_CFG1_DSIZE_4   (0x10UL << SPI_CFG1_DSIZE_Pos)
#define SPI_CFG1_FTHLV_Pos   (5U)
#define SPI_CFG1_FTHLV_Msk   (0xFUL << SPI_CFG1_FTHLV_Pos)
#define SPI_CFG1_FTHLV   SPI_CFG1_FTHLV_Msk
#define SPI_CFG1_FTHLV_0   (0x1UL << SPI_CFG1_FTHLV_Pos)
#define SPI_CFG1_FTHLV_1   (0x2UL << SPI_CFG1_FTHLV_Pos)
#define SPI_CFG1_FTHLV_2   (0x4UL << SPI_CFG1_FTHLV_Pos)
#define SPI_CFG1_FTHLV_3   (0x8UL << SPI_CFG1_FTHLV_Pos)
#define SPI_CFG1_UDRCFG_Pos   (9U)
#define SPI_CFG1_UDRCFG_Msk   (0x3UL << SPI_CFG1_UDRCFG_Pos)
#define SPI_CFG1_UDRCFG   SPI_CFG1_UDRCFG_Msk
#define SPI_CFG1_UDRCFG_0   (0x1UL << SPI_CFG1_UDRCFG_Pos)
#define SPI_CFG1_UDRCFG_1   (0x2UL << SPI_CFG1_UDRCFG_Pos)
#define SPI_CFG1_UDRDET_Pos   (11U)
#define SPI_CFG1_UDRDET_Msk   (0x3UL << SPI_CFG1_UDRDET_Pos)
#define SPI_CFG1_UDRDET   SPI_CFG1_UDRDET_Msk
#define SPI_CFG1_UDRDET_0   (0x1UL << SPI_CFG1_UDRDET_Pos)
#define SPI_CFG1_UDRDET_1   (0x2UL << SPI_CFG1_UDRDET_Pos)
#define SPI_CFG1_RXDMAEN_Pos   (14U)
#define SPI_CFG1_RXDMAEN_Msk   (0x1UL << SPI_CFG1_RXDMAEN_Pos)
#define SPI_CFG1_RXDMAEN   SPI_CFG1_RXDMAEN_Msk
#define SPI_CFG1_TXDMAEN_Pos   (15U)
#define SPI_CFG1_TXDMAEN_Msk   (0x1UL << SPI_CFG1_TXDMAEN_Pos)
#define SPI_CFG1_TXDMAEN   SPI_CFG1_TXDMAEN_Msk
#define SPI_CFG1_CRCSIZE_Pos   (16U)
#define SPI_CFG1_CRCSIZE_Msk   (0x1FUL << SPI_CFG1_CRCSIZE_Pos)
#define SPI_CFG1_CRCSIZE   SPI_CFG1_CRCSIZE_Msk
#define SPI_CFG1_CRCSIZE_0   (0x01UL << SPI_CFG1_CRCSIZE_Pos)
#define SPI_CFG1_CRCSIZE_1   (0x02UL << SPI_CFG1_CRCSIZE_Pos)
#define SPI_CFG1_CRCSIZE_2   (0x04UL << SPI_CFG1_CRCSIZE_Pos)
#define SPI_CFG1_CRCSIZE_3   (0x08UL << SPI_CFG1_CRCSIZE_Pos)
#define SPI_CFG1_CRCSIZE_4   (0x10UL << SPI_CFG1_CRCSIZE_Pos)
#define SPI_CFG1_CRCEN_Pos   (22U)
#define SPI_CFG1_CRCEN_Msk   (0x1UL << SPI_CFG1_CRCEN_Pos)
#define SPI_CFG1_CRCEN   SPI_CFG1_CRCEN_Msk
#define SPI_CFG1_MBR_Pos   (28U)
#define SPI_CFG1_MBR_Msk   (0x7UL << SPI_CFG1_MBR_Pos)
#define SPI_CFG1_MBR   SPI_CFG1_MBR_Msk
#define SPI_CFG1_MBR_0   (0x1UL << SPI_CFG1_MBR_Pos)
#define SPI_CFG1_MBR_1   (0x2UL << SPI_CFG1_MBR_Pos)
#define SPI_CFG1_MBR_2   (0x4UL << SPI_CFG1_MBR_Pos)
#define SPI_CFG2_MSSI_Pos   (0U)
#define SPI_CFG2_MSSI_Msk   (0xFUL << SPI_CFG2_MSSI_Pos)
#define SPI_CFG2_MSSI   SPI_CFG2_MSSI_Msk
#define SPI_CFG2_MSSI_0   (0x1UL << SPI_CFG2_MSSI_Pos)
#define SPI_CFG2_MSSI_1   (0x2UL << SPI_CFG2_MSSI_Pos)
#define SPI_CFG2_MSSI_2   (0x4UL << SPI_CFG2_MSSI_Pos)
#define SPI_CFG2_MSSI_3   (0x8UL << SPI_CFG2_MSSI_Pos)
#define SPI_CFG2_MIDI_Pos   (4U)
#define SPI_CFG2_MIDI_Msk   (0xFUL << SPI_CFG2_MIDI_Pos)
#define SPI_CFG2_MIDI   SPI_CFG2_MIDI_Msk
#define SPI_CFG2_MIDI_0   (0x1UL << SPI_CFG2_MIDI_Pos)
#define SPI_CFG2_MIDI_1   (0x2UL << SPI_CFG2_MIDI_Pos)
#define SPI_CFG2_MIDI_2   (0x4UL << SPI_CFG2_MIDI_Pos)
#define SPI_CFG2_MIDI_3   (0x8UL << SPI_CFG2_MIDI_Pos)
#define SPI_CFG2_IOSWP_Pos   (15U)
#define SPI_CFG2_IOSWP_Msk   (0x1UL << SPI_CFG2_IOSWP_Pos)
#define SPI_CFG2_IOSWP   SPI_CFG2_IOSWP_Msk
#define SPI_CFG2_COMM_Pos   (17U)
#define SPI_CFG2_COMM_Msk   (0x3UL << SPI_CFG2_COMM_Pos)
#define SPI_CFG2_COMM   SPI_CFG2_COMM_Msk
#define SPI_CFG2_COMM_0   (0x1UL << SPI_CFG2_COMM_Pos)
#define SPI_CFG2_COMM_1   (0x2UL << SPI_CFG2_COMM_Pos)
#define SPI_CFG2_SP_Pos   (19U)
#define SPI_CFG2_SP_Msk   (0x7UL << SPI_CFG2_SP_Pos)
#define SPI_CFG2_SP   SPI_CFG2_SP_Msk
#define SPI_CFG2_SP_0   (0x1UL << SPI_CFG2_SP_Pos)
#define SPI_CFG2_SP_1   (0x2UL << SPI_CFG2_SP_Pos)
#define SPI_CFG2_SP_2   (0x4UL << SPI_CFG2_SP_Pos)
#define SPI_CFG2_MASTER_Pos   (22U)
#define SPI_CFG2_MASTER_Msk   (0x1UL << SPI_CFG2_MASTER_Pos)
#define SPI_CFG2_MASTER   SPI_CFG2_MASTER_Msk
#define SPI_CFG2_LSBFRST_Pos   (23U)
#define SPI_CFG2_LSBFRST_Msk   (0x1UL << SPI_CFG2_LSBFRST_Pos)
#define SPI_CFG2_LSBFRST   SPI_CFG2_LSBFRST_Msk
#define SPI_CFG2_CPHA_Pos   (24U)
#define SPI_CFG2_CPHA_Msk   (0x1UL << SPI_CFG2_CPHA_Pos)
#define SPI_CFG2_CPHA   SPI_CFG2_CPHA_Msk
#define SPI_CFG2_CPOL_Pos   (25U)
#define SPI_CFG2_CPOL_Msk   (0x1UL << SPI_CFG2_CPOL_Pos)
#define SPI_CFG2_CPOL   SPI_CFG2_CPOL_Msk
#define SPI_CFG2_SSM_Pos   (26U)
#define SPI_CFG2_SSM_Msk   (0x1UL << SPI_CFG2_SSM_Pos)
#define SPI_CFG2_SSM   SPI_CFG2_SSM_Msk
#define SPI_CFG2_SSIOP_Pos   (28U)
#define SPI_CFG2_SSIOP_Msk   (0x1UL << SPI_CFG2_SSIOP_Pos)
#define SPI_CFG2_SSIOP   SPI_CFG2_SSIOP_Msk
#define SPI_CFG2_SSOE_Pos   (29U)
#define SPI_CFG2_SSOE_Msk   (0x1UL << SPI_CFG2_SSOE_Pos)
#define SPI_CFG2_SSOE   SPI_CFG2_SSOE_Msk
#define SPI_CFG2_SSOM_Pos   (30U)
#define SPI_CFG2_SSOM_Msk   (0x1UL << SPI_CFG2_SSOM_Pos)
#define SPI_CFG2_SSOM   SPI_CFG2_SSOM_Msk
#define SPI_CFG2_AFCNTR_Pos   (31U)
#define SPI_CFG2_AFCNTR_Msk   (0x1UL << SPI_CFG2_AFCNTR_Pos)
#define SPI_CFG2_AFCNTR   SPI_CFG2_AFCNTR_Msk
#define SPI_IER_RXPIE_Pos   (0U)
#define SPI_IER_RXPIE_Msk   (0x1UL << SPI_IER_RXPIE_Pos)
#define SPI_IER_RXPIE   SPI_IER_RXPIE_Msk
#define SPI_IER_TXPIE_Pos   (1U)
#define SPI_IER_TXPIE_Msk   (0x1UL << SPI_IER_TXPIE_Pos)
#define SPI_IER_TXPIE   SPI_IER_TXPIE_Msk
#define SPI_IER_DXPIE_Pos   (2U)
#define SPI_IER_DXPIE_Msk   (0x1UL << SPI_IER_DXPIE_Pos)
#define SPI_IER_DXPIE   SPI_IER_DXPIE_Msk
#define SPI_IER_EOTIE_Pos   (3U)
#define SPI_IER_EOTIE_Msk   (0x1UL << SPI_IER_EOTIE_Pos)
#define SPI_IER_EOTIE   SPI_IER_EOTIE_Msk
#define SPI_IER_TXTFIE_Pos   (4U)
#define SPI_IER_TXTFIE_Msk   (0x1UL << SPI_IER_TXTFIE_Pos)
#define SPI_IER_TXTFIE   SPI_IER_TXTFIE_Msk
#define SPI_IER_UDRIE_Pos   (5U)
#define SPI_IER_UDRIE_Msk   (0x1UL << SPI_IER_UDRIE_Pos)
#define SPI_IER_UDRIE   SPI_IER_UDRIE_Msk
#define SPI_IER_OVRIE_Pos   (6U)
#define SPI_IER_OVRIE_Msk   (0x1UL << SPI_IER_OVRIE_Pos)
#define SPI_IER_OVRIE   SPI_IER_OVRIE_Msk
#define SPI_IER_CRCEIE_Pos   (7U)
#define SPI_IER_CRCEIE_Msk   (0x1UL << SPI_IER_CRCEIE_Pos)
#define SPI_IER_CRCEIE   SPI_IER_CRCEIE_Msk
#define SPI_IER_TIFREIE_Pos   (8U)
#define SPI_IER_TIFREIE_Msk   (0x1UL << SPI_IER_TIFREIE_Pos)
#define SPI_IER_TIFREIE   SPI_IER_TIFREIE_Msk
#define SPI_IER_MODFIE_Pos   (9U)
#define SPI_IER_MODFIE_Msk   (0x1UL << SPI_IER_MODFIE_Pos)
#define SPI_IER_MODFIE   SPI_IER_MODFIE_Msk
#define SPI_IER_TSERFIE_Pos   (10U)
#define SPI_IER_TSERFIE_Msk   (0x1UL << SPI_IER_TSERFIE_Pos)
#define SPI_IER_TSERFIE   SPI_IER_TSERFIE_Msk
#define SPI_SR_RXP_Pos   (0U)
#define SPI_SR_RXP_Msk   (0x1UL << SPI_SR_RXP_Pos)
#define SPI_SR_RXP   SPI_SR_RXP_Msk
#define SPI_SR_TXP_Pos   (1U)
#define SPI_SR_TXP_Msk   (0x1UL << SPI_SR_TXP_Pos)
#define SPI_SR_TXP   SPI_SR_TXP_Msk
#define SPI_SR_DXP_Pos   (2U)
#define SPI_SR_DXP_Msk   (0x1UL << SPI_SR_DXP_Pos)
#define SPI_SR_DXP   SPI_SR_DXP_Msk
#define SPI_SR_EOT_Pos   (3U)
#define SPI_SR_EOT_Msk   (0x1UL << SPI_SR_EOT_Pos)
#define SPI_SR_EOT   SPI_SR_EOT_Msk
#define SPI_SR_TXTF_Pos   (4U)
#define SPI_SR_TXTF_Msk   (0x1UL << SPI_SR_TXTF_Pos)
#define SPI_SR_TXTF   SPI_SR_TXTF_Msk
#define SPI_SR_UDR_Pos   (5U)
#define SPI_SR_UDR_Msk   (0x1UL << SPI_SR_UDR_Pos)
#define SPI_SR_UDR   SPI_SR_UDR_Msk
#define SPI_SR_OVR_Pos   (6U)
#define SPI_SR_OVR_Msk   (0x1UL << SPI_SR_OVR_Pos)
#define SPI_SR_OVR   SPI_SR_OVR_Msk
#define SPI_SR_CRCE_Pos   (7U)
#define SPI_SR_CRCE_Msk   (0x1UL << SPI_SR_CRCE_Pos)
#define SPI_SR_CRCE   SPI_SR_CRCE_Msk
#define SPI_SR_TIFRE_Pos   (8U)
#define SPI_SR_TIFRE_Msk   (0x1UL << SPI_SR_TIFRE_Pos)
#define SPI_SR_TIFRE   SPI_SR_TIFRE_Msk
#define SPI_SR_MODF_Pos   (9U)
#define SPI_SR_MODF_Msk   (0x1UL << SPI_SR_MODF_Pos)
#define SPI_SR_MODF   SPI_SR_MODF_Msk
#define SPI_SR_TSERF_Pos   (10U)
#define SPI_SR_TSERF_Msk   (0x1UL << SPI_SR_TSERF_Pos)
#define SPI_SR_TSERF   SPI_SR_TSERF_Msk
#define SPI_SR_SUSP_Pos   (11U)
#define SPI_SR_SUSP_Msk   (0x1UL << SPI_SR_SUSP_Pos)
#define SPI_SR_SUSP   SPI_SR_SUSP_Msk
#define SPI_SR_TXC_Pos   (12U)
#define SPI_SR_TXC_Msk   (0x1UL << SPI_SR_TXC_Pos)
#define SPI_SR_TXC   SPI_SR_TXC_Msk
#define SPI_SR_RXPLVL_Pos   (13U)
#define SPI_SR_RXPLVL_Msk   (0x3UL << SPI_SR_RXPLVL_Pos)
#define SPI_SR_RXPLVL   SPI_SR_RXPLVL_Msk
#define SPI_SR_RXPLVL_0   (0x1UL << SPI_SR_RXPLVL_Pos)
#define SPI_SR_RXPLVL_1   (0x2UL << SPI_SR_RXPLVL_Pos)
#define SPI_SR_RXWNE_Pos   (15U)
#define SPI_SR_RXWNE_Msk   (0x1UL << SPI_SR_RXWNE_Pos)
#define SPI_SR_RXWNE   SPI_SR_RXWNE_Msk
#define SPI_SR_CTSIZE_Pos   (16U)
#define SPI_SR_CTSIZE_Msk   (0xFFFFUL << SPI_SR_CTSIZE_Pos)
#define SPI_SR_CTSIZE   SPI_SR_CTSIZE_Msk
#define SPI_IFCR_EOTC_Pos   (3U)
#define SPI_IFCR_EOTC_Msk   (0x1UL << SPI_IFCR_EOTC_Pos)
#define SPI_IFCR_EOTC   SPI_IFCR_EOTC_Msk
#define SPI_IFCR_TXTFC_Pos   (4U)
#define SPI_IFCR_TXTFC_Msk   (0x1UL << SPI_IFCR_TXTFC_Pos)
#define SPI_IFCR_TXTFC   SPI_IFCR_TXTFC_Msk
#define SPI_IFCR_UDRC_Pos   (5U)
#define SPI_IFCR_UDRC_Msk   (0x1UL << SPI_IFCR_UDRC_Pos)
#define SPI_IFCR_UDRC   SPI_IFCR_UDRC_Msk
#define SPI_IFCR_OVRC_Pos   (6U)
#define SPI_IFCR_OVRC_Msk   (0x1UL << SPI_IFCR_OVRC_Pos)
#define SPI_IFCR_OVRC   SPI_IFCR_OVRC_Msk
#define SPI_IFCR_CRCEC_Pos   (7U)
#define SPI_IFCR_CRCEC_Msk   (0x1UL << SPI_IFCR_CRCEC_Pos)
#define SPI_IFCR_CRCEC   SPI_IFCR_CRCEC_Msk
#define SPI_IFCR_TIFREC_Pos   (8U)
#define SPI_IFCR_TIFREC_Msk   (0x1UL << SPI_IFCR_TIFREC_Pos)
#define SPI_IFCR_TIFREC   SPI_IFCR_TIFREC_Msk
#define SPI_IFCR_MODFC_Pos   (9U)
#define SPI_IFCR_MODFC_Msk   (0x1UL << SPI_IFCR_MODFC_Pos)
#define SPI_IFCR_MODFC   SPI_IFCR_MODFC_Msk
#define SPI_IFCR_TSERFC_Pos   (10U)
#define SPI_IFCR_TSERFC_Msk   (0x1UL << SPI_IFCR_TSERFC_Pos)
#define SPI_IFCR_TSERFC   SPI_IFCR_TSERFC_Msk
#define SPI_IFCR_SUSPC_Pos   (11U)
#define SPI_IFCR_SUSPC_Msk   (0x1UL << SPI_IFCR_SUSPC_Pos)
#define SPI_IFCR_SUSPC   SPI_IFCR_SUSPC_Msk
#define SPI_TXDR_TXDR_Pos   (0U)
#define SPI_TXDR_TXDR_Msk   (0xFFFFFFFFUL << SPI_TXDR_TXDR_Pos)
#define SPI_TXDR_TXDR   SPI_TXDR_TXDR_Msk /* Transmit Data Register */
#define SPI_RXDR_RXDR_Pos   (0U)
#define SPI_RXDR_RXDR_Msk   (0xFFFFFFFFUL << SPI_RXDR_RXDR_Pos)
#define SPI_RXDR_RXDR   SPI_RXDR_RXDR_Msk /* Receive Data Register */
#define SPI_CRCPOLY_CRCPOLY_Pos   (0U)
#define SPI_CRCPOLY_CRCPOLY_Msk   (0xFFFFFFFFUL << SPI_CRCPOLY_CRCPOLY_Pos)
#define SPI_CRCPOLY_CRCPOLY   SPI_CRCPOLY_CRCPOLY_Msk /* CRC Polynomial register */
#define SPI_TXCRC_TXCRC_Pos   (0U)
#define SPI_TXCRC_TXCRC_Msk   (0xFFFFFFFFUL << SPI_TXCRC_TXCRC_Pos)
#define SPI_TXCRC_TXCRC   SPI_TXCRC_TXCRC_Msk /* CRCRegister for transmitter */
#define SPI_RXCRC_RXCRC_Pos   (0U)
#define SPI_RXCRC_RXCRC_Msk   (0xFFFFFFFFUL << SPI_RXCRC_RXCRC_Pos)
#define SPI_RXCRC_RXCRC   SPI_RXCRC_RXCRC_Msk /* CRCRegister for receiver */
#define SPI_UDRDR_UDRDR_Pos   (0U)
#define SPI_UDRDR_UDRDR_Msk   (0xFFFFFFFFUL << SPI_UDRDR_UDRDR_Pos)
#define SPI_UDRDR_UDRDR   SPI_UDRDR_UDRDR_Msk /* Data at slave underrun condition */
#define SPI_I2SCFGR_I2SMOD_Pos   (0U)
#define SPI_I2SCFGR_I2SMOD_Msk   (0x1UL << SPI_I2SCFGR_I2SMOD_Pos)
#define SPI_I2SCFGR_I2SMOD   SPI_I2SCFGR_I2SMOD_Msk
#define SPI_I2SCFGR_I2SCFG_Pos   (1U)
#define SPI_I2SCFGR_I2SCFG_Msk   (0x7UL << SPI_I2SCFGR_I2SCFG_Pos)
#define SPI_I2SCFGR_I2SCFG   SPI_I2SCFGR_I2SCFG_Msk
#define SPI_I2SCFGR_I2SCFG_0   (0x1UL << SPI_I2SCFGR_I2SCFG_Pos)
#define SPI_I2SCFGR_I2SCFG_1   (0x2UL << SPI_I2SCFGR_I2SCFG_Pos)
#define SPI_I2SCFGR_I2SCFG_2   (0x4UL << SPI_I2SCFGR_I2SCFG_Pos)
#define SPI_I2SCFGR_I2SSTD_Pos   (4U)
#define SPI_I2SCFGR_I2SSTD_Msk   (0x3UL << SPI_I2SCFGR_I2SSTD_Pos)
#define SPI_I2SCFGR_I2SSTD   SPI_I2SCFGR_I2SSTD_Msk
#define SPI_I2SCFGR_I2SSTD_0   (0x1UL << SPI_I2SCFGR_I2SSTD_Pos)
#define SPI_I2SCFGR_I2SSTD_1   (0x2UL << SPI_I2SCFGR_I2SSTD_Pos)
#define SPI_I2SCFGR_PCMSYNC_Pos   (7U)
#define SPI_I2SCFGR_PCMSYNC_Msk   (0x1UL << SPI_I2SCFGR_PCMSYNC_Pos)
#define SPI_I2SCFGR_PCMSYNC   SPI_I2SCFGR_PCMSYNC_Msk
#define SPI_I2SCFGR_DATLEN_Pos   (8U)
#define SPI_I2SCFGR_DATLEN_Msk   (0x3UL << SPI_I2SCFGR_DATLEN_Pos)
#define SPI_I2SCFGR_DATLEN   SPI_I2SCFGR_DATLEN_Msk
#define SPI_I2SCFGR_DATLEN_0   (0x1UL << SPI_I2SCFGR_DATLEN_Pos)
#define SPI_I2SCFGR_DATLEN_1   (0x2UL << SPI_I2SCFGR_DATLEN_Pos)
#define SPI_I2SCFGR_CHLEN_Pos   (10U)
#define SPI_I2SCFGR_CHLEN_Msk   (0x1UL << SPI_I2SCFGR_CHLEN_Pos)
#define SPI_I2SCFGR_CHLEN   SPI_I2SCFGR_CHLEN_Msk
#define SPI_I2SCFGR_CKPOL_Pos   (11U)
#define SPI_I2SCFGR_CKPOL_Msk   (0x1UL << SPI_I2SCFGR_CKPOL_Pos)
#define SPI_I2SCFGR_CKPOL   SPI_I2SCFGR_CKPOL_Msk
#define SPI_I2SCFGR_FIXCH_Pos   (12U)
#define SPI_I2SCFGR_FIXCH_Msk   (0x1UL << SPI_I2SCFGR_FIXCH_Pos)
#define SPI_I2SCFGR_FIXCH   SPI_I2SCFGR_FIXCH_Msk
#define SPI_I2SCFGR_WSINV_Pos   (13U)
#define SPI_I2SCFGR_WSINV_Msk   (0x1UL << SPI_I2SCFGR_WSINV_Pos)
#define SPI_I2SCFGR_WSINV   SPI_I2SCFGR_WSINV_Msk
#define SPI_I2SCFGR_DATFMT_Pos   (14U)
#define SPI_I2SCFGR_DATFMT_Msk   (0x1UL << SPI_I2SCFGR_DATFMT_Pos)
#define SPI_I2SCFGR_DATFMT   SPI_I2SCFGR_DATFMT_Msk
#define SPI_I2SCFGR_I2SDIV_Pos   (16U)
#define SPI_I2SCFGR_I2SDIV_Msk   (0xFFUL << SPI_I2SCFGR_I2SDIV_Pos)
#define SPI_I2SCFGR_I2SDIV   SPI_I2SCFGR_I2SDIV_Msk
#define SPI_I2SCFGR_ODD_Pos   (24U)
#define SPI_I2SCFGR_ODD_Msk   (0x1UL << SPI_I2SCFGR_ODD_Pos)
#define SPI_I2SCFGR_ODD   SPI_I2SCFGR_ODD_Msk
#define SPI_I2SCFGR_MCKOE_Pos   (25U)
#define SPI_I2SCFGR_MCKOE_Msk   (0x1UL << SPI_I2SCFGR_MCKOE_Pos)
#define SPI_I2SCFGR_MCKOE   SPI_I2SCFGR_MCKOE_Msk
#define SYSCFG_PMCR_I2C1_FMP_Pos   (0U)
#define SYSCFG_PMCR_I2C1_FMP_Msk   (0x1UL << SYSCFG_PMCR_I2C1_FMP_Pos)
#define SYSCFG_PMCR_I2C1_FMP   SYSCFG_PMCR_I2C1_FMP_Msk
#define SYSCFG_PMCR_I2C2_FMP_Pos   (1U)
#define SYSCFG_PMCR_I2C2_FMP_Msk   (0x1UL << SYSCFG_PMCR_I2C2_FMP_Pos)
#define SYSCFG_PMCR_I2C2_FMP   SYSCFG_PMCR_I2C2_FMP_Msk
#define SYSCFG_PMCR_I2C3_FMP_Pos   (2U)
#define SYSCFG_PMCR_I2C3_FMP_Msk   (0x1UL << SYSCFG_PMCR_I2C3_FMP_Pos)
#define SYSCFG_PMCR_I2C3_FMP   SYSCFG_PMCR_I2C3_FMP_Msk
#define SYSCFG_PMCR_I2C4_FMP_Pos   (3U)
#define SYSCFG_PMCR_I2C4_FMP_Msk   (0x1UL << SYSCFG_PMCR_I2C4_FMP_Pos)
#define SYSCFG_PMCR_I2C4_FMP   SYSCFG_PMCR_I2C4_FMP_Msk
#define SYSCFG_PMCR_I2C_PB6_FMP_Pos   (4U)
#define SYSCFG_PMCR_I2C_PB6_FMP_Msk   (0x1UL << SYSCFG_PMCR_I2C_PB6_FMP_Pos)
#define SYSCFG_PMCR_I2C_PB6_FMP   SYSCFG_PMCR_I2C_PB6_FMP_Msk
#define SYSCFG_PMCR_I2C_PB7_FMP_Pos   (5U)
#define SYSCFG_PMCR_I2C_PB7_FMP_Msk   (0x1UL << SYSCFG_PMCR_I2C_PB7_FMP_Pos)
#define SYSCFG_PMCR_I2C_PB7_FMP   SYSCFG_PMCR_I2C_PB7_FMP_Msk
#define SYSCFG_PMCR_I2C_PB8_FMP_Pos   (6U)
#define SYSCFG_PMCR_I2C_PB8_FMP_Msk   (0x1UL << SYSCFG_PMCR_I2C_PB8_FMP_Pos)
#define SYSCFG_PMCR_I2C_PB8_FMP   SYSCFG_PMCR_I2C_PB8_FMP_Msk
#define SYSCFG_PMCR_I2C_PB9_FMP_Pos   (7U)
#define SYSCFG_PMCR_I2C_PB9_FMP_Msk   (0x1UL << SYSCFG_PMCR_I2C_PB9_FMP_Pos)
#define SYSCFG_PMCR_I2C_PB9_FMP   SYSCFG_PMCR_I2C_PB9_FMP_Msk
#define SYSCFG_PMCR_PA0SO_Pos   (24U)
#define SYSCFG_PMCR_PA0SO_Msk   (0x1UL << SYSCFG_PMCR_PA0SO_Pos)
#define SYSCFG_PMCR_PA0SO   SYSCFG_PMCR_PA0SO_Msk
#define SYSCFG_PMCR_PA1SO_Pos   (25U)
#define SYSCFG_PMCR_PA1SO_Msk   (0x1UL << SYSCFG_PMCR_PA1SO_Pos)
#define SYSCFG_PMCR_PA1SO   SYSCFG_PMCR_PA1SO_Msk
#define SYSCFG_PMCR_PC2SO_Pos   (26U)
#define SYSCFG_PMCR_PC2SO_Msk   (0x1UL << SYSCFG_PMCR_PC2SO_Pos)
#define SYSCFG_PMCR_PC2SO   SYSCFG_PMCR_PC2SO_Msk
#define SYSCFG_PMCR_PC3SO_Pos   (27U)
#define SYSCFG_PMCR_PC3SO_Msk   (0x1UL << SYSCFG_PMCR_PC3SO_Pos)
#define SYSCFG_PMCR_PC3SO   SYSCFG_PMCR_PC3SO_Msk
#define SYSCFG_EXTICR1_EXTI0_Pos   (0U)
#define SYSCFG_EXTICR1_EXTI0_Msk   (0xFUL << SYSCFG_EXTICR1_EXTI0_Pos)
#define SYSCFG_EXTICR1_EXTI0   SYSCFG_EXTICR1_EXTI0_Msk
#define SYSCFG_EXTICR1_EXTI1_Pos   (4U)
#define SYSCFG_EXTICR1_EXTI1_Msk   (0xFUL << SYSCFG_EXTICR1_EXTI1_Pos)
#define SYSCFG_EXTICR1_EXTI1   SYSCFG_EXTICR1_EXTI1_Msk
#define SYSCFG_EXTICR1_EXTI2_Pos   (8U)
#define SYSCFG_EXTICR1_EXTI2_Msk   (0xFUL << SYSCFG_EXTICR1_EXTI2_Pos)
#define SYSCFG_EXTICR1_EXTI2   SYSCFG_EXTICR1_EXTI2_Msk
#define SYSCFG_EXTICR1_EXTI3_Pos   (12U)
#define SYSCFG_EXTICR1_EXTI3_Msk   (0xFUL << SYSCFG_EXTICR1_EXTI3_Pos)
#define SYSCFG_EXTICR1_EXTI3   SYSCFG_EXTICR1_EXTI3_Msk
#define SYSCFG_EXTICR1_EXTI0_PA   (0U)
 EXTI0 configuration.
#define SYSCFG_EXTICR1_EXTI0_PB   (0x00000001U)
#define SYSCFG_EXTICR1_EXTI0_PC   (0x00000002U)
#define SYSCFG_EXTICR1_EXTI0_PD   (0x00000003U)
#define SYSCFG_EXTICR1_EXTI0_PE   (0x00000004U)
#define SYSCFG_EXTICR1_EXTI0_PF   (0x00000005U)
#define SYSCFG_EXTICR1_EXTI0_PG   (0x00000006U)
#define SYSCFG_EXTICR1_EXTI0_PH   (0x00000007U)
#define SYSCFG_EXTICR1_EXTI0_PI   (0x00000008U)
#define SYSCFG_EXTICR1_EXTI0_PJ   (0x00000009U)
#define SYSCFG_EXTICR1_EXTI0_PK   (0x0000000AU)
#define SYSCFG_EXTICR1_EXTI1_PA   (0U)
 EXTI1 configuration.
#define SYSCFG_EXTICR1_EXTI1_PB   (0x00000010U)
#define SYSCFG_EXTICR1_EXTI1_PC   (0x00000020U)
#define SYSCFG_EXTICR1_EXTI1_PD   (0x00000030U)
#define SYSCFG_EXTICR1_EXTI1_PE   (0x00000040U)
#define SYSCFG_EXTICR1_EXTI1_PF   (0x00000050U)
#define SYSCFG_EXTICR1_EXTI1_PG   (0x00000060U)
#define SYSCFG_EXTICR1_EXTI1_PH   (0x00000070U)
#define SYSCFG_EXTICR1_EXTI1_PI   (0x00000080U)
#define SYSCFG_EXTICR1_EXTI1_PJ   (0x00000090U)
#define SYSCFG_EXTICR1_EXTI1_PK   (0x000000A0U)
#define SYSCFG_EXTICR1_EXTI2_PA   (0U)
 EXTI2 configuration.
#define SYSCFG_EXTICR1_EXTI2_PB   (0x00000100U)
#define SYSCFG_EXTICR1_EXTI2_PC   (0x00000200U)
#define SYSCFG_EXTICR1_EXTI2_PD   (0x00000300U)
#define SYSCFG_EXTICR1_EXTI2_PE   (0x00000400U)
#define SYSCFG_EXTICR1_EXTI2_PF   (0x00000500U)
#define SYSCFG_EXTICR1_EXTI2_PG   (0x00000600U)
#define SYSCFG_EXTICR1_EXTI2_PH   (0x00000700U)
#define SYSCFG_EXTICR1_EXTI2_PI   (0x00000800U)
#define SYSCFG_EXTICR1_EXTI2_PJ   (0x00000900U)
#define SYSCFG_EXTICR1_EXTI2_PK   (0x00000A00U)
#define SYSCFG_EXTICR1_EXTI3_PA   (0U)
 EXTI3 configuration.
#define SYSCFG_EXTICR1_EXTI3_PB   (0x00001000U)
#define SYSCFG_EXTICR1_EXTI3_PC   (0x00002000U)
#define SYSCFG_EXTICR1_EXTI3_PD   (0x00003000U)
#define SYSCFG_EXTICR1_EXTI3_PE   (0x00004000U)
#define SYSCFG_EXTICR1_EXTI3_PF   (0x00005000U)
#define SYSCFG_EXTICR1_EXTI3_PG   (0x00006000U)
#define SYSCFG_EXTICR1_EXTI3_PH   (0x00007000U)
#define SYSCFG_EXTICR1_EXTI3_PI   (0x00008000U)
#define SYSCFG_EXTICR1_EXTI3_PJ   (0x00009000U)
#define SYSCFG_EXTICR1_EXTI3_PK   (0x0000A000U)
#define SYSCFG_EXTICR2_EXTI4_Pos   (0U)
#define SYSCFG_EXTICR2_EXTI4_Msk   (0xFUL << SYSCFG_EXTICR2_EXTI4_Pos)
#define SYSCFG_EXTICR2_EXTI4   SYSCFG_EXTICR2_EXTI4_Msk
#define SYSCFG_EXTICR2_EXTI5_Pos   (4U)
#define SYSCFG_EXTICR2_EXTI5_Msk   (0xFUL << SYSCFG_EXTICR2_EXTI5_Pos)
#define SYSCFG_EXTICR2_EXTI5   SYSCFG_EXTICR2_EXTI5_Msk
#define SYSCFG_EXTICR2_EXTI6_Pos   (8U)
#define SYSCFG_EXTICR2_EXTI6_Msk   (0xFUL << SYSCFG_EXTICR2_EXTI6_Pos)
#define SYSCFG_EXTICR2_EXTI6   SYSCFG_EXTICR2_EXTI6_Msk
#define SYSCFG_EXTICR2_EXTI7_Pos   (12U)
#define SYSCFG_EXTICR2_EXTI7_Msk   (0xFUL << SYSCFG_EXTICR2_EXTI7_Pos)
#define SYSCFG_EXTICR2_EXTI7   SYSCFG_EXTICR2_EXTI7_Msk
#define SYSCFG_EXTICR2_EXTI4_PA   (0U)
 EXTI4 configuration.
#define SYSCFG_EXTICR2_EXTI4_PB   (0x00000001U)
#define SYSCFG_EXTICR2_EXTI4_PC   (0x00000002U)
#define SYSCFG_EXTICR2_EXTI4_PD   (0x00000003U)
#define SYSCFG_EXTICR2_EXTI4_PE   (0x00000004U)
#define SYSCFG_EXTICR2_EXTI4_PF   (0x00000005U)
#define SYSCFG_EXTICR2_EXTI4_PG   (0x00000006U)
#define SYSCFG_EXTICR2_EXTI4_PH   (0x00000007U)
#define SYSCFG_EXTICR2_EXTI4_PI   (0x00000008U)
#define SYSCFG_EXTICR2_EXTI4_PJ   (0x00000009U)
#define SYSCFG_EXTICR2_EXTI4_PK   (0x0000000AU)
#define SYSCFG_EXTICR2_EXTI5_PA   (0U)
 EXTI5 configuration.
#define SYSCFG_EXTICR2_EXTI5_PB   (0x00000010U)
#define SYSCFG_EXTICR2_EXTI5_PC   (0x00000020U)
#define SYSCFG_EXTICR2_EXTI5_PD   (0x00000030U)
#define SYSCFG_EXTICR2_EXTI5_PE   (0x00000040U)
#define SYSCFG_EXTICR2_EXTI5_PF   (0x00000050U)
#define SYSCFG_EXTICR2_EXTI5_PG   (0x00000060U)
#define SYSCFG_EXTICR2_EXTI5_PH   (0x00000070U)
#define SYSCFG_EXTICR2_EXTI5_PI   (0x00000080U)
#define SYSCFG_EXTICR2_EXTI5_PJ   (0x00000090U)
#define SYSCFG_EXTICR2_EXTI5_PK   (0x000000A0U)
#define SYSCFG_EXTICR2_EXTI6_PA   (0U)
 EXTI6 configuration.
#define SYSCFG_EXTICR2_EXTI6_PB   (0x00000100U)
#define SYSCFG_EXTICR2_EXTI6_PC   (0x00000200U)
#define SYSCFG_EXTICR2_EXTI6_PD   (0x00000300U)
#define SYSCFG_EXTICR2_EXTI6_PE   (0x00000400U)
#define SYSCFG_EXTICR2_EXTI6_PF   (0x00000500U)
#define SYSCFG_EXTICR2_EXTI6_PG   (0x00000600U)
#define SYSCFG_EXTICR2_EXTI6_PH   (0x00000700U)
#define SYSCFG_EXTICR2_EXTI6_PI   (0x00000800U)
#define SYSCFG_EXTICR2_EXTI6_PJ   (0x00000900U)
#define SYSCFG_EXTICR2_EXTI6_PK   (0x00000A00U)
#define SYSCFG_EXTICR2_EXTI7_PA   (0U)
 EXTI7 configuration.
#define SYSCFG_EXTICR2_EXTI7_PB   (0x00001000U)
#define SYSCFG_EXTICR2_EXTI7_PC   (0x00002000U)
#define SYSCFG_EXTICR2_EXTI7_PD   (0x00003000U)
#define SYSCFG_EXTICR2_EXTI7_PE   (0x00004000U)
#define SYSCFG_EXTICR2_EXTI7_PF   (0x00005000U)
#define SYSCFG_EXTICR2_EXTI7_PG   (0x00006000U)
#define SYSCFG_EXTICR2_EXTI7_PH   (0x00007000U)
#define SYSCFG_EXTICR2_EXTI7_PI   (0x00008000U)
#define SYSCFG_EXTICR2_EXTI7_PJ   (0x00009000U)
#define SYSCFG_EXTICR2_EXTI7_PK   (0x0000A000U)
#define SYSCFG_EXTICR3_EXTI8_Pos   (0U)
#define SYSCFG_EXTICR3_EXTI8_Msk   (0xFUL << SYSCFG_EXTICR3_EXTI8_Pos)
#define SYSCFG_EXTICR3_EXTI8   SYSCFG_EXTICR3_EXTI8_Msk
#define SYSCFG_EXTICR3_EXTI9_Pos   (4U)
#define SYSCFG_EXTICR3_EXTI9_Msk   (0xFUL << SYSCFG_EXTICR3_EXTI9_Pos)
#define SYSCFG_EXTICR3_EXTI9   SYSCFG_EXTICR3_EXTI9_Msk
#define SYSCFG_EXTICR3_EXTI10_Pos   (8U)
#define SYSCFG_EXTICR3_EXTI10_Msk   (0xFUL << SYSCFG_EXTICR3_EXTI10_Pos)
#define SYSCFG_EXTICR3_EXTI10   SYSCFG_EXTICR3_EXTI10_Msk
#define SYSCFG_EXTICR3_EXTI11_Pos   (12U)
#define SYSCFG_EXTICR3_EXTI11_Msk   (0xFUL << SYSCFG_EXTICR3_EXTI11_Pos)
#define SYSCFG_EXTICR3_EXTI11   SYSCFG_EXTICR3_EXTI11_Msk
#define SYSCFG_EXTICR3_EXTI8_PA   (0U)
 EXTI8 configuration.
#define SYSCFG_EXTICR3_EXTI8_PB   (0x00000001U)
#define SYSCFG_EXTICR3_EXTI8_PC   (0x00000002U)
#define SYSCFG_EXTICR3_EXTI8_PD   (0x00000003U)
#define SYSCFG_EXTICR3_EXTI8_PE   (0x00000004U)
#define SYSCFG_EXTICR3_EXTI8_PF   (0x00000005U)
#define SYSCFG_EXTICR3_EXTI8_PG   (0x00000006U)
#define SYSCFG_EXTICR3_EXTI8_PH   (0x00000007U)
#define SYSCFG_EXTICR3_EXTI8_PI   (0x00000008U)
#define SYSCFG_EXTICR3_EXTI8_PJ   (0x00000009U)
#define SYSCFG_EXTICR3_EXTI8_PK   (0x0000000AU)
#define SYSCFG_EXTICR3_EXTI9_PA   (0U)
 EXTI9 configuration.
#define SYSCFG_EXTICR3_EXTI9_PB   (0x00000010U)
#define SYSCFG_EXTICR3_EXTI9_PC   (0x00000020U)
#define SYSCFG_EXTICR3_EXTI9_PD   (0x00000030U)
#define SYSCFG_EXTICR3_EXTI9_PE   (0x00000040U)
#define SYSCFG_EXTICR3_EXTI9_PF   (0x00000050U)
#define SYSCFG_EXTICR3_EXTI9_PG   (0x00000060U)
#define SYSCFG_EXTICR3_EXTI9_PH   (0x00000070U)
#define SYSCFG_EXTICR3_EXTI9_PI   (0x00000080U)
#define SYSCFG_EXTICR3_EXTI9_PJ   (0x00000090U)
#define SYSCFG_EXTICR3_EXTI9_PK   (0x000000A0U)
#define SYSCFG_EXTICR3_EXTI10_PA   (0U)
 EXTI10 configuration.
#define SYSCFG_EXTICR3_EXTI10_PB   (0x00000100U)
#define SYSCFG_EXTICR3_EXTI10_PC   (0x00000200U)
#define SYSCFG_EXTICR3_EXTI10_PD   (0x00000300U)
#define SYSCFG_EXTICR3_EXTI10_PE   (0x00000400U)
#define SYSCFG_EXTICR3_EXTI10_PF   (0x00000500U)
#define SYSCFG_EXTICR3_EXTI10_PG   (0x00000600U)
#define SYSCFG_EXTICR3_EXTI10_PH   (0x00000700U)
#define SYSCFG_EXTICR3_EXTI10_PI   (0x00000800U)
#define SYSCFG_EXTICR3_EXTI10_PJ   (0x00000900U)
#define SYSCFG_EXTICR3_EXTI10_PK   (0x00000A00U)
#define SYSCFG_EXTICR3_EXTI11_PA   (0U)
 EXTI11 configuration.
#define SYSCFG_EXTICR3_EXTI11_PB   (0x00001000U)
#define SYSCFG_EXTICR3_EXTI11_PC   (0x00002000U)
#define SYSCFG_EXTICR3_EXTI11_PD   (0x00003000U)
#define SYSCFG_EXTICR3_EXTI11_PE   (0x00004000U)
#define SYSCFG_EXTICR3_EXTI11_PF   (0x00005000U)
#define SYSCFG_EXTICR3_EXTI11_PG   (0x00006000U)
#define SYSCFG_EXTICR3_EXTI11_PH   (0x00007000U)
#define SYSCFG_EXTICR3_EXTI11_PI   (0x00008000U)
#define SYSCFG_EXTICR3_EXTI11_PJ   (0x00009000U)
#define SYSCFG_EXTICR3_EXTI11_PK   (0x0000A000U)
#define SYSCFG_EXTICR4_EXTI12_Pos   (0U)
#define SYSCFG_EXTICR4_EXTI12_Msk   (0xFUL << SYSCFG_EXTICR4_EXTI12_Pos)
#define SYSCFG_EXTICR4_EXTI12   SYSCFG_EXTICR4_EXTI12_Msk
#define SYSCFG_EXTICR4_EXTI13_Pos   (4U)
#define SYSCFG_EXTICR4_EXTI13_Msk   (0xFUL << SYSCFG_EXTICR4_EXTI13_Pos)
#define SYSCFG_EXTICR4_EXTI13   SYSCFG_EXTICR4_EXTI13_Msk
#define SYSCFG_EXTICR4_EXTI14_Pos   (8U)
#define SYSCFG_EXTICR4_EXTI14_Msk   (0xFUL << SYSCFG_EXTICR4_EXTI14_Pos)
#define SYSCFG_EXTICR4_EXTI14   SYSCFG_EXTICR4_EXTI14_Msk
#define SYSCFG_EXTICR4_EXTI15_Pos   (12U)
#define SYSCFG_EXTICR4_EXTI15_Msk   (0xFUL << SYSCFG_EXTICR4_EXTI15_Pos)
#define SYSCFG_EXTICR4_EXTI15   SYSCFG_EXTICR4_EXTI15_Msk
#define SYSCFG_EXTICR4_EXTI12_PA   (0U)
 EXTI12 configuration.
#define SYSCFG_EXTICR4_EXTI12_PB   (0x00000001U)
#define SYSCFG_EXTICR4_EXTI12_PC   (0x00000002U)
#define SYSCFG_EXTICR4_EXTI12_PD   (0x00000003U)
#define SYSCFG_EXTICR4_EXTI12_PE   (0x00000004U)
#define SYSCFG_EXTICR4_EXTI12_PF   (0x00000005U)
#define SYSCFG_EXTICR4_EXTI12_PG   (0x00000006U)
#define SYSCFG_EXTICR4_EXTI12_PH   (0x00000007U)
#define SYSCFG_EXTICR4_EXTI12_PI   (0x00000008U)
#define SYSCFG_EXTICR4_EXTI12_PJ   (0x00000009U)
#define SYSCFG_EXTICR4_EXTI12_PK   (0x0000000AU)
#define SYSCFG_EXTICR4_EXTI13_PA   (0U)
 EXTI13 configuration.
#define SYSCFG_EXTICR4_EXTI13_PB   (0x00000010U)
#define SYSCFG_EXTICR4_EXTI13_PC   (0x00000020U)
#define SYSCFG_EXTICR4_EXTI13_PD   (0x00000030U)
#define SYSCFG_EXTICR4_EXTI13_PE   (0x00000040U)
#define SYSCFG_EXTICR4_EXTI13_PF   (0x00000050U)
#define SYSCFG_EXTICR4_EXTI13_PG   (0x00000060U)
#define SYSCFG_EXTICR4_EXTI13_PH   (0x00000070U)
#define SYSCFG_EXTICR4_EXTI13_PI   (0x00000080U)
#define SYSCFG_EXTICR4_EXTI13_PJ   (0x00000090U)
#define SYSCFG_EXTICR4_EXTI13_PK   (0x000000A0U)
#define SYSCFG_EXTICR4_EXTI14_PA   (0U)
 EXTI14 configuration.
#define SYSCFG_EXTICR4_EXTI14_PB   (0x00000100U)
#define SYSCFG_EXTICR4_EXTI14_PC   (0x00000200U)
#define SYSCFG_EXTICR4_EXTI14_PD   (0x00000300U)
#define SYSCFG_EXTICR4_EXTI14_PE   (0x00000400U)
#define SYSCFG_EXTICR4_EXTI14_PF   (0x00000500U)
#define SYSCFG_EXTICR4_EXTI14_PG   (0x00000600U)
#define SYSCFG_EXTICR4_EXTI14_PH   (0x00000700U)
#define SYSCFG_EXTICR4_EXTI14_PI   (0x00000800U)
#define SYSCFG_EXTICR4_EXTI14_PJ   (0x00000900U)
#define SYSCFG_EXTICR4_EXTI14_PK   (0x00000A00U)
#define SYSCFG_EXTICR4_EXTI15_PA   (0U)
 EXTI15 configuration.
#define SYSCFG_EXTICR4_EXTI15_PB   (0x00001000U)
#define SYSCFG_EXTICR4_EXTI15_PC   (0x00002000U)
#define SYSCFG_EXTICR4_EXTI15_PD   (0x00003000U)
#define SYSCFG_EXTICR4_EXTI15_PE   (0x00004000U)
#define SYSCFG_EXTICR4_EXTI15_PF   (0x00005000U)
#define SYSCFG_EXTICR4_EXTI15_PG   (0x00006000U)
#define SYSCFG_EXTICR4_EXTI15_PH   (0x00007000U)
#define SYSCFG_EXTICR4_EXTI15_PI   (0x00008000U)
#define SYSCFG_EXTICR4_EXTI15_PJ   (0x00009000U)
#define SYSCFG_EXTICR4_EXTI15_PK   (0x0000A000U)
#define SYSCFG_CFGR_PVDL_Pos   (2U)
#define SYSCFG_CFGR_PVDL_Msk   (0x1UL << SYSCFG_CFGR_PVDL_Pos)
#define SYSCFG_CFGR_PVDL   SYSCFG_CFGR_PVDL_Msk
#define SYSCFG_CFGR_FLASHL_Pos   (3U)
#define SYSCFG_CFGR_FLASHL_Msk   (0x1UL << SYSCFG_CFGR_FLASHL_Pos)
#define SYSCFG_CFGR_FLASHL   SYSCFG_CFGR_FLASHL_Msk
#define SYSCFG_CFGR_CM7L_Pos   (6U)
#define SYSCFG_CFGR_CM7L_Msk   (0x1UL << SYSCFG_CFGR_CM7L_Pos)
#define SYSCFG_CFGR_CM7L   SYSCFG_CFGR_CM7L_Msk
#define SYSCFG_CFGR_DTCML_Pos   (13U)
#define SYSCFG_CFGR_DTCML_Msk   (0x1UL << SYSCFG_CFGR_DTCML_Pos)
#define SYSCFG_CFGR_DTCML   SYSCFG_CFGR_DTCML_Msk
#define SYSCFG_CFGR_ITCML_Pos   (14U)
#define SYSCFG_CFGR_ITCML_Msk   (0x1UL << SYSCFG_CFGR_ITCML_Pos)
#define SYSCFG_CFGR_ITCML   SYSCFG_CFGR_ITCML_Msk
#define SYSCFG_CCCSR_EN_Pos   (0U)
#define SYSCFG_CCCSR_EN_Msk   (0x1UL << SYSCFG_CCCSR_EN_Pos)
#define SYSCFG_CCCSR_EN   SYSCFG_CCCSR_EN_Msk
#define SYSCFG_CCCSR_CS_Pos   (1U)
#define SYSCFG_CCCSR_CS_Msk   (0x1UL << SYSCFG_CCCSR_CS_Pos)
#define SYSCFG_CCCSR_CS   SYSCFG_CCCSR_CS_Msk
#define SYSCFG_CCCSR_CS_MMC_Pos   (3U)
#define SYSCFG_CCCSR_CS_MMC_Msk   (0x1UL << SYSCFG_CCCSR_CS_MMC_Pos)
#define SYSCFG_CCCSR_CS_MMC   SYSCFG_CCCSR_CS_MMC_Msk
#define SYSCFG_CCCSR_READY_Pos   (8U)
#define SYSCFG_CCCSR_READY_Msk   (0x1UL << SYSCFG_CCCSR_READY_Pos)
#define SYSCFG_CCCSR_READY   SYSCFG_CCCSR_READY_Msk
#define SYSCFG_CCCSR_HSLV0_Pos   (16U)
#define SYSCFG_CCCSR_HSLV0_Msk   (0x1UL << SYSCFG_CCCSR_HSLV0_Pos)
#define SYSCFG_CCCSR_HSLV0   SYSCFG_CCCSR_HSLV0_Msk
#define SYSCFG_CCCSR_HSLV1_Pos   (17U)
#define SYSCFG_CCCSR_HSLV1_Msk   (0x1UL << SYSCFG_CCCSR_HSLV1_Pos)
#define SYSCFG_CCCSR_HSLV1   SYSCFG_CCCSR_HSLV1_Msk
#define SYSCFG_CCCSR_HSLV2_Pos   (18U)
#define SYSCFG_CCCSR_HSLV2_Msk   (0x1UL << SYSCFG_CCCSR_HSLV2_Pos)
#define SYSCFG_CCCSR_HSLV2   SYSCFG_CCCSR_HSLV2_Msk
#define SYSCFG_CCCSR_HSLV3_Pos   (19U)
#define SYSCFG_CCCSR_HSLV3_Msk   (0x1UL << SYSCFG_CCCSR_HSLV3_Pos)
#define SYSCFG_CCCSR_HSLV3   SYSCFG_CCCSR_HSLV3_Msk
#define SYSCFG_CCVR_NCV_Pos   (0U)
#define SYSCFG_CCVR_NCV_Msk   (0xFUL << SYSCFG_CCVR_NCV_Pos)
#define SYSCFG_CCVR_NCV   SYSCFG_CCVR_NCV_Msk
#define SYSCFG_CCVR_PCV_Pos   (4U)
#define SYSCFG_CCVR_PCV_Msk   (0xFUL << SYSCFG_CCVR_PCV_Pos)
#define SYSCFG_CCVR_PCV   SYSCFG_CCVR_PCV_Msk
#define SYSCFG_CCCR_NCC_Pos   (0U)
#define SYSCFG_CCCR_NCC_Msk   (0xFUL << SYSCFG_CCCR_NCC_Pos)
#define SYSCFG_CCCR_NCC   SYSCFG_CCCR_NCC_Msk
#define SYSCFG_CCCR_PCC_Pos   (4U)
#define SYSCFG_CCCR_PCC_Msk   (0xFUL << SYSCFG_CCCR_PCC_Pos)
#define SYSCFG_CCCR_PCC   SYSCFG_CCCR_PCC_Msk
#define SYSCFG_CCCR_NCC_MMC_Pos   (8U)
#define SYSCFG_CCCR_NCC_MMC_Msk   (0xFUL << SYSCFG_CCCR_NCC_MMC_Pos)
#define SYSCFG_CCCR_NCC_MMC   SYSCFG_CCCR_NCC_MMC_Msk
#define SYSCFG_CCCR_PCC_MMC_Pos   (12U)
#define SYSCFG_CCCR_PCC_MMC_Msk   (0xFUL << SYSCFG_CCCR_PCC_MMC_Pos)
#define SYSCFG_CCCR_PCC_MMC   SYSCFG_CCCR_PCC_MMC_Msk
#define DTS_CFGR1_TS1_EN_Pos   (0U)
#define DTS_CFGR1_TS1_EN_Msk   (0x1UL << DTS_CFGR1_TS1_EN_Pos)
#define DTS_CFGR1_TS1_EN   DTS_CFGR1_TS1_EN_Msk
#define DTS_CFGR1_TS1_START_Pos   (4U)
#define DTS_CFGR1_TS1_START_Msk   (0x1UL << DTS_CFGR1_TS1_START_Pos)
#define DTS_CFGR1_TS1_START   DTS_CFGR1_TS1_START_Msk
#define DTS_CFGR1_TS1_INTRIG_SEL_Pos   (8U)
#define DTS_CFGR1_TS1_INTRIG_SEL_Msk   (0xFUL << DTS_CFGR1_TS1_INTRIG_SEL_Pos)
#define DTS_CFGR1_TS1_INTRIG_SEL   DTS_CFGR1_TS1_INTRIG_SEL_Msk
#define DTS_CFGR1_TS1_INTRIG_SEL_0   (0x1UL << DTS_CFGR1_TS1_INTRIG_SEL_Pos)
#define DTS_CFGR1_TS1_INTRIG_SEL_1   (0x2UL << DTS_CFGR1_TS1_INTRIG_SEL_Pos)
#define DTS_CFGR1_TS1_INTRIG_SEL_2   (0x4UL << DTS_CFGR1_TS1_INTRIG_SEL_Pos)
#define DTS_CFGR1_TS1_INTRIG_SEL_3   (0x8UL << DTS_CFGR1_TS1_INTRIG_SEL_Pos)
#define DTS_CFGR1_TS1_SMP_TIME_Pos   (16U)
#define DTS_CFGR1_TS1_SMP_TIME_Msk   (0xFUL << DTS_CFGR1_TS1_SMP_TIME_Pos)
#define DTS_CFGR1_TS1_SMP_TIME   DTS_CFGR1_TS1_SMP_TIME_Msk
#define DTS_CFGR1_TS1_SMP_TIME_0   (0x1UL << DTS_CFGR1_TS1_SMP_TIME_Pos)
#define DTS_CFGR1_TS1_SMP_TIME_1   (0x2UL << DTS_CFGR1_TS1_SMP_TIME_Pos)
#define DTS_CFGR1_TS1_SMP_TIME_2   (0x4UL << DTS_CFGR1_TS1_SMP_TIME_Pos)
#define DTS_CFGR1_TS1_SMP_TIME_3   (0x8UL << DTS_CFGR1_TS1_SMP_TIME_Pos)
#define DTS_CFGR1_REFCLK_SEL_Pos   (20U)
#define DTS_CFGR1_REFCLK_SEL_Msk   (0x1UL << DTS_CFGR1_REFCLK_SEL_Pos)
#define DTS_CFGR1_REFCLK_SEL   DTS_CFGR1_REFCLK_SEL_Msk
#define DTS_CFGR1_Q_MEAS_OPT_Pos   (21U)
#define DTS_CFGR1_Q_MEAS_OPT_Msk   (0x1UL << DTS_CFGR1_Q_MEAS_OPT_Pos)
#define DTS_CFGR1_Q_MEAS_OPT   DTS_CFGR1_Q_MEAS_OPT_Msk
#define DTS_CFGR1_HSREF_CLK_DIV_Pos   (24U)
#define DTS_CFGR1_HSREF_CLK_DIV_Msk   (0x7FUL << DTS_CFGR1_HSREF_CLK_DIV_Pos)
#define DTS_CFGR1_HSREF_CLK_DIV   DTS_CFGR1_HSREF_CLK_DIV_Msk
#define DTS_T0VALR1_TS1_FMT0_Pos   (0U)
#define DTS_T0VALR1_TS1_FMT0_Msk   (0xFFFFUL << DTS_T0VALR1_TS1_FMT0_Pos)
#define DTS_T0VALR1_TS1_FMT0   DTS_T0VALR1_TS1_FMT0_Msk
#define DTS_T0VALR1_TS1_T0_Pos   (16U)
#define DTS_T0VALR1_TS1_T0_Msk   (0x3UL << DTS_T0VALR1_TS1_T0_Pos)
#define DTS_T0VALR1_TS1_T0   DTS_T0VALR1_TS1_T0_Msk
#define DTS_RAMPVALR_TS1_RAMP_COEFF_Pos   (0U)
#define DTS_RAMPVALR_TS1_RAMP_COEFF_Msk   (0xFFFFUL << DTS_RAMPVALR_TS1_RAMP_COEFF_Pos)
#define DTS_RAMPVALR_TS1_RAMP_COEFF   DTS_RAMPVALR_TS1_RAMP_COEFF_Msk
#define DTS_ITR1_TS1_LITTHD_Pos   (0U)
#define DTS_ITR1_TS1_LITTHD_Msk   (0xFFFFUL << DTS_ITR1_TS1_LITTHD_Pos)
#define DTS_ITR1_TS1_LITTHD   DTS_ITR1_TS1_LITTHD_Msk
#define DTS_ITR1_TS1_HITTHD_Pos   (16U)
#define DTS_ITR1_TS1_HITTHD_Msk   (0xFFFFUL << DTS_ITR1_TS1_HITTHD_Pos)
#define DTS_ITR1_TS1_HITTHD   DTS_ITR1_TS1_HITTHD_Msk
#define DTS_DR_TS1_MFREQ_Pos   (0U)
#define DTS_DR_TS1_MFREQ_Msk   (0xFFFFUL << DTS_DR_TS1_MFREQ_Pos)
#define DTS_DR_TS1_MFREQ   DTS_DR_TS1_MFREQ_Msk
#define DTS_SR_TS1_ITEF_Pos   (0U)
#define DTS_SR_TS1_ITEF_Msk   (0x1UL << DTS_SR_TS1_ITEF_Pos)
#define DTS_SR_TS1_ITEF   DTS_SR_TS1_ITEF_Msk
#define DTS_SR_TS1_ITLF_Pos   (1U)
#define DTS_SR_TS1_ITLF_Msk   (0x1UL << DTS_SR_TS1_ITLF_Pos)
#define DTS_SR_TS1_ITLF   DTS_SR_TS1_ITLF_Msk
#define DTS_SR_TS1_ITHF_Pos   (2U)
#define DTS_SR_TS1_ITHF_Msk   (0x1UL << DTS_SR_TS1_ITHF_Pos)
#define DTS_SR_TS1_ITHF   DTS_SR_TS1_ITHF_Msk
#define DTS_SR_TS1_AITEF_Pos   (4U)
#define DTS_SR_TS1_AITEF_Msk   (0x1UL << DTS_SR_TS1_AITEF_Pos)
#define DTS_SR_TS1_AITEF   DTS_SR_TS1_AITEF_Msk
#define DTS_SR_TS1_AITLF_Pos   (5U)
#define DTS_SR_TS1_AITLF_Msk   (0x1UL << DTS_SR_TS1_AITLF_Pos)
#define DTS_SR_TS1_AITLF   DTS_SR_TS1_AITLF_Msk
#define DTS_SR_TS1_AITHF_Pos   (6U)
#define DTS_SR_TS1_AITHF_Msk   (0x1UL << DTS_SR_TS1_AITHF_Pos)
#define DTS_SR_TS1_AITHF   DTS_SR_TS1_AITHF_Msk
#define DTS_SR_TS1_RDY_Pos   (15U)
#define DTS_SR_TS1_RDY_Msk   (0x1UL << DTS_SR_TS1_RDY_Pos)
#define DTS_SR_TS1_RDY   DTS_SR_TS1_RDY_Msk
#define DTS_ITENR_TS1_ITEEN_Pos   (0U)
#define DTS_ITENR_TS1_ITEEN_Msk   (0x1UL << DTS_ITENR_TS1_ITEEN_Pos)
#define DTS_ITENR_TS1_ITEEN   DTS_ITENR_TS1_ITEEN_Msk
#define DTS_ITENR_TS1_ITLEN_Pos   (1U)
#define DTS_ITENR_TS1_ITLEN_Msk   (0x1UL << DTS_ITENR_TS1_ITLEN_Pos)
#define DTS_ITENR_TS1_ITLEN   DTS_ITENR_TS1_ITLEN_Msk
#define DTS_ITENR_TS1_ITHEN_Pos   (2U)
#define DTS_ITENR_TS1_ITHEN_Msk   (0x1UL << DTS_ITENR_TS1_ITHEN_Pos)
#define DTS_ITENR_TS1_ITHEN   DTS_ITENR_TS1_ITHEN_Msk
#define DTS_ITENR_TS1_AITEEN_Pos   (4U)
#define DTS_ITENR_TS1_AITEEN_Msk   (0x1UL << DTS_ITENR_TS1_AITEEN_Pos)
#define DTS_ITENR_TS1_AITEEN   DTS_ITENR_TS1_AITEEN_Msk
#define DTS_ITENR_TS1_AITLEN_Pos   (5U)
#define DTS_ITENR_TS1_AITLEN_Msk   (0x1UL << DTS_ITENR_TS1_AITLEN_Pos)
#define DTS_ITENR_TS1_AITLEN   DTS_ITENR_TS1_AITLEN_Msk
#define DTS_ITENR_TS1_AITHEN_Pos   (6U)
#define DTS_ITENR_TS1_AITHEN_Msk   (0x1UL << DTS_ITENR_TS1_AITHEN_Pos)
#define DTS_ITENR_TS1_AITHEN   DTS_ITENR_TS1_AITHEN_Msk
#define DTS_ICIFR_TS1_CITEF_Pos   (0U)
#define DTS_ICIFR_TS1_CITEF_Msk   (0x1UL << DTS_ICIFR_TS1_CITEF_Pos)
#define DTS_ICIFR_TS1_CITEF   DTS_ICIFR_TS1_CITEF_Msk
#define DTS_ICIFR_TS1_CITLF_Pos   (1U)
#define DTS_ICIFR_TS1_CITLF_Msk   (0x1UL << DTS_ICIFR_TS1_CITLF_Pos)
#define DTS_ICIFR_TS1_CITLF   DTS_ICIFR_TS1_CITLF_Msk
#define DTS_ICIFR_TS1_CITHF_Pos   (2U)
#define DTS_ICIFR_TS1_CITHF_Msk   (0x1UL << DTS_ICIFR_TS1_CITHF_Pos)
#define DTS_ICIFR_TS1_CITHF   DTS_ICIFR_TS1_CITHF_Msk
#define DTS_ICIFR_TS1_CAITEF_Pos   (4U)
#define DTS_ICIFR_TS1_CAITEF_Msk   (0x1UL << DTS_ICIFR_TS1_CAITEF_Pos)
#define DTS_ICIFR_TS1_CAITEF   DTS_ICIFR_TS1_CAITEF_Msk
#define DTS_ICIFR_TS1_CAITLF_Pos   (5U)
#define DTS_ICIFR_TS1_CAITLF_Msk   (0x1UL << DTS_ICIFR_TS1_CAITLF_Pos)
#define DTS_ICIFR_TS1_CAITLF   DTS_ICIFR_TS1_CAITLF_Msk
#define DTS_ICIFR_TS1_CAITHF_Pos   (6U)
#define DTS_ICIFR_TS1_CAITHF_Msk   (0x1UL << DTS_ICIFR_TS1_CAITHF_Pos)
#define DTS_ICIFR_TS1_CAITHF   DTS_ICIFR_TS1_CAITHF_Msk
#define TIM_BREAK_INPUT_SUPPORT
#define TIM_CR1_CEN_Pos   (0U)
#define TIM_CR1_CEN_Msk   (0x1UL << TIM_CR1_CEN_Pos)
#define TIM_CR1_CEN   TIM_CR1_CEN_Msk
#define TIM_CR1_UDIS_Pos   (1U)
#define TIM_CR1_UDIS_Msk   (0x1UL << TIM_CR1_UDIS_Pos)
#define TIM_CR1_UDIS   TIM_CR1_UDIS_Msk
#define TIM_CR1_URS_Pos   (2U)
#define TIM_CR1_URS_Msk   (0x1UL << TIM_CR1_URS_Pos)
#define TIM_CR1_URS   TIM_CR1_URS_Msk
#define TIM_CR1_OPM_Pos   (3U)
#define TIM_CR1_OPM_Msk   (0x1UL << TIM_CR1_OPM_Pos)
#define TIM_CR1_OPM   TIM_CR1_OPM_Msk
#define TIM_CR1_DIR_Pos   (4U)
#define TIM_CR1_DIR_Msk   (0x1UL << TIM_CR1_DIR_Pos)
#define TIM_CR1_DIR   TIM_CR1_DIR_Msk
#define TIM_CR1_CMS_Pos   (5U)
#define TIM_CR1_CMS_Msk   (0x3UL << TIM_CR1_CMS_Pos)
#define TIM_CR1_CMS   TIM_CR1_CMS_Msk
#define TIM_CR1_CMS_0   (0x1UL << TIM_CR1_CMS_Pos)
#define TIM_CR1_CMS_1   (0x2UL << TIM_CR1_CMS_Pos)
#define TIM_CR1_ARPE_Pos   (7U)
#define TIM_CR1_ARPE_Msk   (0x1UL << TIM_CR1_ARPE_Pos)
#define TIM_CR1_ARPE   TIM_CR1_ARPE_Msk
#define TIM_CR1_CKD_Pos   (8U)
#define TIM_CR1_CKD_Msk   (0x3UL << TIM_CR1_CKD_Pos)
#define TIM_CR1_CKD   TIM_CR1_CKD_Msk
#define TIM_CR1_CKD_0   (0x1UL << TIM_CR1_CKD_Pos)
#define TIM_CR1_CKD_1   (0x2UL << TIM_CR1_CKD_Pos)
#define TIM_CR1_UIFREMAP_Pos   (11U)
#define TIM_CR1_UIFREMAP_Msk   (0x1UL << TIM_CR1_UIFREMAP_Pos)
#define TIM_CR1_UIFREMAP   TIM_CR1_UIFREMAP_Msk
#define TIM_CR2_CCPC_Pos   (0U)
#define TIM_CR2_CCPC_Msk   (0x1UL << TIM_CR2_CCPC_Pos)
#define TIM_CR2_CCPC   TIM_CR2_CCPC_Msk
#define TIM_CR2_CCUS_Pos   (2U)
#define TIM_CR2_CCUS_Msk   (0x1UL << TIM_CR2_CCUS_Pos)
#define TIM_CR2_CCUS   TIM_CR2_CCUS_Msk
#define TIM_CR2_CCDS_Pos   (3U)
#define TIM_CR2_CCDS_Msk   (0x1UL << TIM_CR2_CCDS_Pos)
#define TIM_CR2_CCDS   TIM_CR2_CCDS_Msk
#define TIM_CR2_MMS_Pos   (4U)
#define TIM_CR2_MMS_Msk   (0x7UL << TIM_CR2_MMS_Pos)
#define TIM_CR2_MMS   TIM_CR2_MMS_Msk
#define TIM_CR2_MMS_0   (0x1UL << TIM_CR2_MMS_Pos)
#define TIM_CR2_MMS_1   (0x2UL << TIM_CR2_MMS_Pos)
#define TIM_CR2_MMS_2   (0x4UL << TIM_CR2_MMS_Pos)
#define TIM_CR2_TI1S_Pos   (7U)
#define TIM_CR2_TI1S_Msk   (0x1UL << TIM_CR2_TI1S_Pos)
#define TIM_CR2_TI1S   TIM_CR2_TI1S_Msk
#define TIM_CR2_OIS1_Pos   (8U)
#define TIM_CR2_OIS1_Msk   (0x1UL << TIM_CR2_OIS1_Pos)
#define TIM_CR2_OIS1   TIM_CR2_OIS1_Msk
#define TIM_CR2_OIS1N_Pos   (9U)
#define TIM_CR2_OIS1N_Msk   (0x1UL << TIM_CR2_OIS1N_Pos)
#define TIM_CR2_OIS1N   TIM_CR2_OIS1N_Msk
#define TIM_CR2_OIS2_Pos   (10U)
#define TIM_CR2_OIS2_Msk   (0x1UL << TIM_CR2_OIS2_Pos)
#define TIM_CR2_OIS2   TIM_CR2_OIS2_Msk
#define TIM_CR2_OIS2N_Pos   (11U)
#define TIM_CR2_OIS2N_Msk   (0x1UL << TIM_CR2_OIS2N_Pos)
#define TIM_CR2_OIS2N   TIM_CR2_OIS2N_Msk
#define TIM_CR2_OIS3_Pos   (12U)
#define TIM_CR2_OIS3_Msk   (0x1UL << TIM_CR2_OIS3_Pos)
#define TIM_CR2_OIS3   TIM_CR2_OIS3_Msk
#define TIM_CR2_OIS3N_Pos   (13U)
#define TIM_CR2_OIS3N_Msk   (0x1UL << TIM_CR2_OIS3N_Pos)
#define TIM_CR2_OIS3N   TIM_CR2_OIS3N_Msk
#define TIM_CR2_OIS4_Pos   (14U)
#define TIM_CR2_OIS4_Msk   (0x1UL << TIM_CR2_OIS4_Pos)
#define TIM_CR2_OIS4   TIM_CR2_OIS4_Msk
#define TIM_CR2_OIS5_Pos   (16U)
#define TIM_CR2_OIS5_Msk   (0x1UL << TIM_CR2_OIS5_Pos)
#define TIM_CR2_OIS5   TIM_CR2_OIS5_Msk
#define TIM_CR2_OIS6_Pos   (18U)
#define TIM_CR2_OIS6_Msk   (0x1UL << TIM_CR2_OIS6_Pos)
#define TIM_CR2_OIS6   TIM_CR2_OIS6_Msk
#define TIM_CR2_MMS2_Pos   (20U)
#define TIM_CR2_MMS2_Msk   (0xFUL << TIM_CR2_MMS2_Pos)
#define TIM_CR2_MMS2   TIM_CR2_MMS2_Msk
#define TIM_CR2_MMS2_0   (0x1UL << TIM_CR2_MMS2_Pos)
#define TIM_CR2_MMS2_1   (0x2UL << TIM_CR2_MMS2_Pos)
#define TIM_CR2_MMS2_2   (0x4UL << TIM_CR2_MMS2_Pos)
#define TIM_CR2_MMS2_3   (0x8UL << TIM_CR2_MMS2_Pos)
#define TIM_SMCR_SMS_Pos   (0U)
#define TIM_SMCR_SMS_Msk   (0x10007UL << TIM_SMCR_SMS_Pos)
#define TIM_SMCR_SMS   TIM_SMCR_SMS_Msk
#define TIM_SMCR_SMS_0   (0x00001UL << TIM_SMCR_SMS_Pos)
#define TIM_SMCR_SMS_1   (0x00002UL << TIM_SMCR_SMS_Pos)
#define TIM_SMCR_SMS_2   (0x00004UL << TIM_SMCR_SMS_Pos)
#define TIM_SMCR_SMS_3   (0x10000UL << TIM_SMCR_SMS_Pos)
#define TIM_SMCR_TS_Pos   (4U)
#define TIM_SMCR_TS_Msk   (0x30007UL << TIM_SMCR_TS_Pos)
#define TIM_SMCR_TS   TIM_SMCR_TS_Msk
#define TIM_SMCR_TS_0   (0x00001UL << TIM_SMCR_TS_Pos)
#define TIM_SMCR_TS_1   (0x00002UL << TIM_SMCR_TS_Pos)
#define TIM_SMCR_TS_2   (0x00004UL << TIM_SMCR_TS_Pos)
#define TIM_SMCR_TS_3   (0x10000UL << TIM_SMCR_TS_Pos)
#define TIM_SMCR_TS_4   (0x20000UL << TIM_SMCR_TS_Pos)
#define TIM_SMCR_MSM_Pos   (7U)
#define TIM_SMCR_MSM_Msk   (0x1UL << TIM_SMCR_MSM_Pos)
#define TIM_SMCR_MSM   TIM_SMCR_MSM_Msk
#define TIM_SMCR_ETF_Pos   (8U)
#define TIM_SMCR_ETF_Msk   (0xFUL << TIM_SMCR_ETF_Pos)
#define TIM_SMCR_ETF   TIM_SMCR_ETF_Msk
#define TIM_SMCR_ETF_0   (0x1UL << TIM_SMCR_ETF_Pos)
#define TIM_SMCR_ETF_1   (0x2UL << TIM_SMCR_ETF_Pos)
#define TIM_SMCR_ETF_2   (0x4UL << TIM_SMCR_ETF_Pos)
#define TIM_SMCR_ETF_3   (0x8UL << TIM_SMCR_ETF_Pos)
#define TIM_SMCR_ETPS_Pos   (12U)
#define TIM_SMCR_ETPS_Msk   (0x3UL << TIM_SMCR_ETPS_Pos)
#define TIM_SMCR_ETPS   TIM_SMCR_ETPS_Msk
#define TIM_SMCR_ETPS_0   (0x1UL << TIM_SMCR_ETPS_Pos)
#define TIM_SMCR_ETPS_1   (0x2UL << TIM_SMCR_ETPS_Pos)
#define TIM_SMCR_ECE_Pos   (14U)
#define TIM_SMCR_ECE_Msk   (0x1UL << TIM_SMCR_ECE_Pos)
#define TIM_SMCR_ECE   TIM_SMCR_ECE_Msk
#define TIM_SMCR_ETP_Pos   (15U)
#define TIM_SMCR_ETP_Msk   (0x1UL << TIM_SMCR_ETP_Pos)
#define TIM_SMCR_ETP   TIM_SMCR_ETP_Msk
#define TIM_DIER_UIE_Pos   (0U)
#define TIM_DIER_UIE_Msk   (0x1UL << TIM_DIER_UIE_Pos)
#define TIM_DIER_UIE   TIM_DIER_UIE_Msk
#define TIM_DIER_CC1IE_Pos   (1U)
#define TIM_DIER_CC1IE_Msk   (0x1UL << TIM_DIER_CC1IE_Pos)
#define TIM_DIER_CC1IE   TIM_DIER_CC1IE_Msk
#define TIM_DIER_CC2IE_Pos   (2U)
#define TIM_DIER_CC2IE_Msk   (0x1UL << TIM_DIER_CC2IE_Pos)
#define TIM_DIER_CC2IE   TIM_DIER_CC2IE_Msk
#define TIM_DIER_CC3IE_Pos   (3U)
#define TIM_DIER_CC3IE_Msk   (0x1UL << TIM_DIER_CC3IE_Pos)
#define TIM_DIER_CC3IE   TIM_DIER_CC3IE_Msk
#define TIM_DIER_CC4IE_Pos   (4U)
#define TIM_DIER_CC4IE_Msk   (0x1UL << TIM_DIER_CC4IE_Pos)
#define TIM_DIER_CC4IE   TIM_DIER_CC4IE_Msk
#define TIM_DIER_COMIE_Pos   (5U)
#define TIM_DIER_COMIE_Msk   (0x1UL << TIM_DIER_COMIE_Pos)
#define TIM_DIER_COMIE   TIM_DIER_COMIE_Msk
#define TIM_DIER_TIE_Pos   (6U)
#define TIM_DIER_TIE_Msk   (0x1UL << TIM_DIER_TIE_Pos)
#define TIM_DIER_TIE   TIM_DIER_TIE_Msk
#define TIM_DIER_BIE_Pos   (7U)
#define TIM_DIER_BIE_Msk   (0x1UL << TIM_DIER_BIE_Pos)
#define TIM_DIER_BIE   TIM_DIER_BIE_Msk
#define TIM_DIER_UDE_Pos   (8U)
#define TIM_DIER_UDE_Msk   (0x1UL << TIM_DIER_UDE_Pos)
#define TIM_DIER_UDE   TIM_DIER_UDE_Msk
#define TIM_DIER_CC1DE_Pos   (9U)
#define TIM_DIER_CC1DE_Msk   (0x1UL << TIM_DIER_CC1DE_Pos)
#define TIM_DIER_CC1DE   TIM_DIER_CC1DE_Msk
#define TIM_DIER_CC2DE_Pos   (10U)
#define TIM_DIER_CC2DE_Msk   (0x1UL << TIM_DIER_CC2DE_Pos)
#define TIM_DIER_CC2DE   TIM_DIER_CC2DE_Msk
#define TIM_DIER_CC3DE_Pos   (11U)
#define TIM_DIER_CC3DE_Msk   (0x1UL << TIM_DIER_CC3DE_Pos)
#define TIM_DIER_CC3DE   TIM_DIER_CC3DE_Msk
#define TIM_DIER_CC4DE_Pos   (12U)
#define TIM_DIER_CC4DE_Msk   (0x1UL << TIM_DIER_CC4DE_Pos)
#define TIM_DIER_CC4DE   TIM_DIER_CC4DE_Msk
#define TIM_DIER_COMDE_Pos   (13U)
#define TIM_DIER_COMDE_Msk   (0x1UL << TIM_DIER_COMDE_Pos)
#define TIM_DIER_COMDE   TIM_DIER_COMDE_Msk
#define TIM_DIER_TDE_Pos   (14U)
#define TIM_DIER_TDE_Msk   (0x1UL << TIM_DIER_TDE_Pos)
#define TIM_DIER_TDE   TIM_DIER_TDE_Msk
#define TIM_SR_UIF_Pos   (0U)
#define TIM_SR_UIF_Msk   (0x1UL << TIM_SR_UIF_Pos)
#define TIM_SR_UIF   TIM_SR_UIF_Msk
#define TIM_SR_CC1IF_Pos   (1U)
#define TIM_SR_CC1IF_Msk   (0x1UL << TIM_SR_CC1IF_Pos)
#define TIM_SR_CC1IF   TIM_SR_CC1IF_Msk
#define TIM_SR_CC2IF_Pos   (2U)
#define TIM_SR_CC2IF_Msk   (0x1UL << TIM_SR_CC2IF_Pos)
#define TIM_SR_CC2IF   TIM_SR_CC2IF_Msk
#define TIM_SR_CC3IF_Pos   (3U)
#define TIM_SR_CC3IF_Msk   (0x1UL << TIM_SR_CC3IF_Pos)
#define TIM_SR_CC3IF   TIM_SR_CC3IF_Msk
#define TIM_SR_CC4IF_Pos   (4U)
#define TIM_SR_CC4IF_Msk   (0x1UL << TIM_SR_CC4IF_Pos)
#define TIM_SR_CC4IF   TIM_SR_CC4IF_Msk
#define TIM_SR_COMIF_Pos   (5U)
#define TIM_SR_COMIF_Msk   (0x1UL << TIM_SR_COMIF_Pos)
#define TIM_SR_COMIF   TIM_SR_COMIF_Msk
#define TIM_SR_TIF_Pos   (6U)
#define TIM_SR_TIF_Msk   (0x1UL << TIM_SR_TIF_Pos)
#define TIM_SR_TIF   TIM_SR_TIF_Msk
#define TIM_SR_BIF_Pos   (7U)
#define TIM_SR_BIF_Msk   (0x1UL << TIM_SR_BIF_Pos)
#define TIM_SR_BIF   TIM_SR_BIF_Msk
#define TIM_SR_B2IF_Pos   (8U)
#define TIM_SR_B2IF_Msk   (0x1UL << TIM_SR_B2IF_Pos)
#define TIM_SR_B2IF   TIM_SR_B2IF_Msk
#define TIM_SR_CC1OF_Pos   (9U)
#define TIM_SR_CC1OF_Msk   (0x1UL << TIM_SR_CC1OF_Pos)
#define TIM_SR_CC1OF   TIM_SR_CC1OF_Msk
#define TIM_SR_CC2OF_Pos   (10U)
#define TIM_SR_CC2OF_Msk   (0x1UL << TIM_SR_CC2OF_Pos)
#define TIM_SR_CC2OF   TIM_SR_CC2OF_Msk
#define TIM_SR_CC3OF_Pos   (11U)
#define TIM_SR_CC3OF_Msk   (0x1UL << TIM_SR_CC3OF_Pos)
#define TIM_SR_CC3OF   TIM_SR_CC3OF_Msk
#define TIM_SR_CC4OF_Pos   (12U)
#define TIM_SR_CC4OF_Msk   (0x1UL << TIM_SR_CC4OF_Pos)
#define TIM_SR_CC4OF   TIM_SR_CC4OF_Msk
#define TIM_SR_CC5IF_Pos   (16U)
#define TIM_SR_CC5IF_Msk   (0x1UL << TIM_SR_CC5IF_Pos)
#define TIM_SR_CC5IF   TIM_SR_CC5IF_Msk
#define TIM_SR_CC6IF_Pos   (17U)
#define TIM_SR_CC6IF_Msk   (0x1UL << TIM_SR_CC6IF_Pos)
#define TIM_SR_CC6IF   TIM_SR_CC6IF_Msk
#define TIM_SR_SBIF_Pos   (13U)
#define TIM_SR_SBIF_Msk   (0x1UL << TIM_SR_SBIF_Pos)
#define TIM_SR_SBIF   TIM_SR_SBIF_Msk
#define TIM_EGR_UG_Pos   (0U)
#define TIM_EGR_UG_Msk   (0x1UL << TIM_EGR_UG_Pos)
#define TIM_EGR_UG   TIM_EGR_UG_Msk
#define TIM_EGR_CC1G_Pos   (1U)
#define TIM_EGR_CC1G_Msk   (0x1UL << TIM_EGR_CC1G_Pos)
#define TIM_EGR_CC1G   TIM_EGR_CC1G_Msk
#define TIM_EGR_CC2G_Pos   (2U)
#define TIM_EGR_CC2G_Msk   (0x1UL << TIM_EGR_CC2G_Pos)
#define TIM_EGR_CC2G   TIM_EGR_CC2G_Msk
#define TIM_EGR_CC3G_Pos   (3U)
#define TIM_EGR_CC3G_Msk   (0x1UL << TIM_EGR_CC3G_Pos)
#define TIM_EGR_CC3G   TIM_EGR_CC3G_Msk
#define TIM_EGR_CC4G_Pos   (4U)
#define TIM_EGR_CC4G_Msk   (0x1UL << TIM_EGR_CC4G_Pos)
#define TIM_EGR_CC4G   TIM_EGR_CC4G_Msk
#define TIM_EGR_COMG_Pos   (5U)
#define TIM_EGR_COMG_Msk   (0x1UL << TIM_EGR_COMG_Pos)
#define TIM_EGR_COMG   TIM_EGR_COMG_Msk
#define TIM_EGR_TG_Pos   (6U)
#define TIM_EGR_TG_Msk   (0x1UL << TIM_EGR_TG_Pos)
#define TIM_EGR_TG   TIM_EGR_TG_Msk
#define TIM_EGR_BG_Pos   (7U)
#define TIM_EGR_BG_Msk   (0x1UL << TIM_EGR_BG_Pos)
#define TIM_EGR_BG   TIM_EGR_BG_Msk
#define TIM_EGR_B2G_Pos   (8U)
#define TIM_EGR_B2G_Msk   (0x1UL << TIM_EGR_B2G_Pos)
#define TIM_EGR_B2G   TIM_EGR_B2G_Msk
#define TIM_CCMR1_CC1S_Pos   (0U)
#define TIM_CCMR1_CC1S_Msk   (0x3UL << TIM_CCMR1_CC1S_Pos)
#define TIM_CCMR1_CC1S   TIM_CCMR1_CC1S_Msk
#define TIM_CCMR1_CC1S_0   (0x1UL << TIM_CCMR1_CC1S_Pos)
#define TIM_CCMR1_CC1S_1   (0x2UL << TIM_CCMR1_CC1S_Pos)
#define TIM_CCMR1_OC1FE_Pos   (2U)
#define TIM_CCMR1_OC1FE_Msk   (0x1UL << TIM_CCMR1_OC1FE_Pos)
#define TIM_CCMR1_OC1FE   TIM_CCMR1_OC1FE_Msk
#define TIM_CCMR1_OC1PE_Pos   (3U)
#define TIM_CCMR1_OC1PE_Msk   (0x1UL << TIM_CCMR1_OC1PE_Pos)
#define TIM_CCMR1_OC1PE   TIM_CCMR1_OC1PE_Msk
#define TIM_CCMR1_OC1M_Pos   (4U)
#define TIM_CCMR1_OC1M_Msk   (0x1007UL << TIM_CCMR1_OC1M_Pos)
#define TIM_CCMR1_OC1M   TIM_CCMR1_OC1M_Msk
#define TIM_CCMR1_OC1M_0   (0x0001UL << TIM_CCMR1_OC1M_Pos)
#define TIM_CCMR1_OC1M_1   (0x0002UL << TIM_CCMR1_OC1M_Pos)
#define TIM_CCMR1_OC1M_2   (0x0004UL << TIM_CCMR1_OC1M_Pos)
#define TIM_CCMR1_OC1M_3   (0x1000UL << TIM_CCMR1_OC1M_Pos)
#define TIM_CCMR1_OC1CE_Pos   (7U)
#define TIM_CCMR1_OC1CE_Msk   (0x1UL << TIM_CCMR1_OC1CE_Pos)
#define TIM_CCMR1_OC1CE   TIM_CCMR1_OC1CE_Msk
#define TIM_CCMR1_CC2S_Pos   (8U)
#define TIM_CCMR1_CC2S_Msk   (0x3UL << TIM_CCMR1_CC2S_Pos)
#define TIM_CCMR1_CC2S   TIM_CCMR1_CC2S_Msk
#define TIM_CCMR1_CC2S_0   (0x1UL << TIM_CCMR1_CC2S_Pos)
#define TIM_CCMR1_CC2S_1   (0x2UL << TIM_CCMR1_CC2S_Pos)
#define TIM_CCMR1_OC2FE_Pos   (10U)
#define TIM_CCMR1_OC2FE_Msk   (0x1UL << TIM_CCMR1_OC2FE_Pos)
#define TIM_CCMR1_OC2FE   TIM_CCMR1_OC2FE_Msk
#define TIM_CCMR1_OC2PE_Pos   (11U)
#define TIM_CCMR1_OC2PE_Msk   (0x1UL << TIM_CCMR1_OC2PE_Pos)
#define TIM_CCMR1_OC2PE   TIM_CCMR1_OC2PE_Msk
#define TIM_CCMR1_OC2M_Pos   (12U)
#define TIM_CCMR1_OC2M_Msk   (0x1007UL << TIM_CCMR1_OC2M_Pos)
#define TIM_CCMR1_OC2M   TIM_CCMR1_OC2M_Msk
#define TIM_CCMR1_OC2M_0   (0x0001UL << TIM_CCMR1_OC2M_Pos)
#define TIM_CCMR1_OC2M_1   (0x0002UL << TIM_CCMR1_OC2M_Pos)
#define TIM_CCMR1_OC2M_2   (0x0004UL << TIM_CCMR1_OC2M_Pos)
#define TIM_CCMR1_OC2M_3   (0x1000UL << TIM_CCMR1_OC2M_Pos)
#define TIM_CCMR1_OC2CE_Pos   (15U)
#define TIM_CCMR1_OC2CE_Msk   (0x1UL << TIM_CCMR1_OC2CE_Pos)
#define TIM_CCMR1_OC2CE   TIM_CCMR1_OC2CE_Msk
#define TIM_CCMR1_IC1PSC_Pos   (2U)
#define TIM_CCMR1_IC1PSC_Msk   (0x3UL << TIM_CCMR1_IC1PSC_Pos)
#define TIM_CCMR1_IC1PSC   TIM_CCMR1_IC1PSC_Msk
#define TIM_CCMR1_IC1PSC_0   (0x1UL << TIM_CCMR1_IC1PSC_Pos)
#define TIM_CCMR1_IC1PSC_1   (0x2UL << TIM_CCMR1_IC1PSC_Pos)
#define TIM_CCMR1_IC1F_Pos   (4U)
#define TIM_CCMR1_IC1F_Msk   (0xFUL << TIM_CCMR1_IC1F_Pos)
#define TIM_CCMR1_IC1F   TIM_CCMR1_IC1F_Msk
#define TIM_CCMR1_IC1F_0   (0x1UL << TIM_CCMR1_IC1F_Pos)
#define TIM_CCMR1_IC1F_1   (0x2UL << TIM_CCMR1_IC1F_Pos)
#define TIM_CCMR1_IC1F_2   (0x4UL << TIM_CCMR1_IC1F_Pos)
#define TIM_CCMR1_IC1F_3   (0x8UL << TIM_CCMR1_IC1F_Pos)
#define TIM_CCMR1_IC2PSC_Pos   (10U)
#define TIM_CCMR1_IC2PSC_Msk   (0x3UL << TIM_CCMR1_IC2PSC_Pos)
#define TIM_CCMR1_IC2PSC   TIM_CCMR1_IC2PSC_Msk
#define TIM_CCMR1_IC2PSC_0   (0x1UL << TIM_CCMR1_IC2PSC_Pos)
#define TIM_CCMR1_IC2PSC_1   (0x2UL << TIM_CCMR1_IC2PSC_Pos)
#define TIM_CCMR1_IC2F_Pos   (12U)
#define TIM_CCMR1_IC2F_Msk   (0xFUL << TIM_CCMR1_IC2F_Pos)
#define TIM_CCMR1_IC2F   TIM_CCMR1_IC2F_Msk
#define TIM_CCMR1_IC2F_0   (0x1UL << TIM_CCMR1_IC2F_Pos)
#define TIM_CCMR1_IC2F_1   (0x2UL << TIM_CCMR1_IC2F_Pos)
#define TIM_CCMR1_IC2F_2   (0x4UL << TIM_CCMR1_IC2F_Pos)
#define TIM_CCMR1_IC2F_3   (0x8UL << TIM_CCMR1_IC2F_Pos)
#define TIM_CCMR2_CC3S_Pos   (0U)
#define TIM_CCMR2_CC3S_Msk   (0x3UL << TIM_CCMR2_CC3S_Pos)
#define TIM_CCMR2_CC3S   TIM_CCMR2_CC3S_Msk
#define TIM_CCMR2_CC3S_0   (0x1UL << TIM_CCMR2_CC3S_Pos)
#define TIM_CCMR2_CC3S_1   (0x2UL << TIM_CCMR2_CC3S_Pos)
#define TIM_CCMR2_OC3FE_Pos   (2U)
#define TIM_CCMR2_OC3FE_Msk   (0x1UL << TIM_CCMR2_OC3FE_Pos)
#define TIM_CCMR2_OC3FE   TIM_CCMR2_OC3FE_Msk
#define TIM_CCMR2_OC3PE_Pos   (3U)
#define TIM_CCMR2_OC3PE_Msk   (0x1UL << TIM_CCMR2_OC3PE_Pos)
#define TIM_CCMR2_OC3PE   TIM_CCMR2_OC3PE_Msk
#define TIM_CCMR2_OC3M_Pos   (4U)
#define TIM_CCMR2_OC3M_Msk   (0x1007UL << TIM_CCMR2_OC3M_Pos)
#define TIM_CCMR2_OC3M   TIM_CCMR2_OC3M_Msk
#define TIM_CCMR2_OC3M_0   (0x1UL << TIM_CCMR2_OC3M_Pos)
#define TIM_CCMR2_OC3M_1   (0x2UL << TIM_CCMR2_OC3M_Pos)
#define TIM_CCMR2_OC3M_2   (0x4UL << TIM_CCMR2_OC3M_Pos)
#define TIM_CCMR2_OC3M_3   (0x1000UL << TIM_CCMR2_OC3M_Pos)
#define TIM_CCMR2_OC3CE_Pos   (7U)
#define TIM_CCMR2_OC3CE_Msk   (0x1UL << TIM_CCMR2_OC3CE_Pos)
#define TIM_CCMR2_OC3CE   TIM_CCMR2_OC3CE_Msk
#define TIM_CCMR2_CC4S_Pos   (8U)
#define TIM_CCMR2_CC4S_Msk   (0x3UL << TIM_CCMR2_CC4S_Pos)
#define TIM_CCMR2_CC4S   TIM_CCMR2_CC4S_Msk
#define TIM_CCMR2_CC4S_0   (0x1UL << TIM_CCMR2_CC4S_Pos)
#define TIM_CCMR2_CC4S_1   (0x2UL << TIM_CCMR2_CC4S_Pos)
#define TIM_CCMR2_OC4FE_Pos   (10U)
#define TIM_CCMR2_OC4FE_Msk   (0x1UL << TIM_CCMR2_OC4FE_Pos)
#define TIM_CCMR2_OC4FE   TIM_CCMR2_OC4FE_Msk
#define TIM_CCMR2_OC4PE_Pos   (11U)
#define TIM_CCMR2_OC4PE_Msk   (0x1UL << TIM_CCMR2_OC4PE_Pos)
#define TIM_CCMR2_OC4PE   TIM_CCMR2_OC4PE_Msk
#define TIM_CCMR2_OC4M_Pos   (12U)
#define TIM_CCMR2_OC4M_Msk   (0x1007UL << TIM_CCMR2_OC4M_Pos)
#define TIM_CCMR2_OC4M   TIM_CCMR2_OC4M_Msk
#define TIM_CCMR2_OC4M_0   (0x1UL << TIM_CCMR2_OC4M_Pos)
#define TIM_CCMR2_OC4M_1   (0x2UL << TIM_CCMR2_OC4M_Pos)
#define TIM_CCMR2_OC4M_2   (0x4UL << TIM_CCMR2_OC4M_Pos)
#define TIM_CCMR2_OC4M_3   (0x1000UL << TIM_CCMR2_OC4M_Pos)
#define TIM_CCMR2_OC4CE_Pos   (15U)
#define TIM_CCMR2_OC4CE_Msk   (0x1UL << TIM_CCMR2_OC4CE_Pos)
#define TIM_CCMR2_OC4CE   TIM_CCMR2_OC4CE_Msk
#define TIM_CCMR2_IC3PSC_Pos   (2U)
#define TIM_CCMR2_IC3PSC_Msk   (0x3UL << TIM_CCMR2_IC3PSC_Pos)
#define TIM_CCMR2_IC3PSC   TIM_CCMR2_IC3PSC_Msk
#define TIM_CCMR2_IC3PSC_0   (0x1UL << TIM_CCMR2_IC3PSC_Pos)
#define TIM_CCMR2_IC3PSC_1   (0x2UL << TIM_CCMR2_IC3PSC_Pos)
#define TIM_CCMR2_IC3F_Pos   (4U)
#define TIM_CCMR2_IC3F_Msk   (0xFUL << TIM_CCMR2_IC3F_Pos)
#define TIM_CCMR2_IC3F   TIM_CCMR2_IC3F_Msk
#define TIM_CCMR2_IC3F_0   (0x1UL << TIM_CCMR2_IC3F_Pos)
#define TIM_CCMR2_IC3F_1   (0x2UL << TIM_CCMR2_IC3F_Pos)
#define TIM_CCMR2_IC3F_2   (0x4UL << TIM_CCMR2_IC3F_Pos)
#define TIM_CCMR2_IC3F_3   (0x8UL << TIM_CCMR2_IC3F_Pos)
#define TIM_CCMR2_IC4PSC_Pos   (10U)
#define TIM_CCMR2_IC4PSC_Msk   (0x3UL << TIM_CCMR2_IC4PSC_Pos)
#define TIM_CCMR2_IC4PSC   TIM_CCMR2_IC4PSC_Msk
#define TIM_CCMR2_IC4PSC_0   (0x1UL << TIM_CCMR2_IC4PSC_Pos)
#define TIM_CCMR2_IC4PSC_1   (0x2UL << TIM_CCMR2_IC4PSC_Pos)
#define TIM_CCMR2_IC4F_Pos   (12U)
#define TIM_CCMR2_IC4F_Msk   (0xFUL << TIM_CCMR2_IC4F_Pos)
#define TIM_CCMR2_IC4F   TIM_CCMR2_IC4F_Msk
#define TIM_CCMR2_IC4F_0   (0x1UL << TIM_CCMR2_IC4F_Pos)
#define TIM_CCMR2_IC4F_1   (0x2UL << TIM_CCMR2_IC4F_Pos)
#define TIM_CCMR2_IC4F_2   (0x4UL << TIM_CCMR2_IC4F_Pos)
#define TIM_CCMR2_IC4F_3   (0x8UL << TIM_CCMR2_IC4F_Pos)
#define TIM_CCER_CC1E_Pos   (0U)
#define TIM_CCER_CC1E_Msk   (0x1UL << TIM_CCER_CC1E_Pos)
#define TIM_CCER_CC1E   TIM_CCER_CC1E_Msk
#define TIM_CCER_CC1P_Pos   (1U)
#define TIM_CCER_CC1P_Msk   (0x1UL << TIM_CCER_CC1P_Pos)
#define TIM_CCER_CC1P   TIM_CCER_CC1P_Msk
#define TIM_CCER_CC1NE_Pos   (2U)
#define TIM_CCER_CC1NE_Msk   (0x1UL << TIM_CCER_CC1NE_Pos)
#define TIM_CCER_CC1NE   TIM_CCER_CC1NE_Msk
#define TIM_CCER_CC1NP_Pos   (3U)
#define TIM_CCER_CC1NP_Msk   (0x1UL << TIM_CCER_CC1NP_Pos)
#define TIM_CCER_CC1NP   TIM_CCER_CC1NP_Msk
#define TIM_CCER_CC2E_Pos   (4U)
#define TIM_CCER_CC2E_Msk   (0x1UL << TIM_CCER_CC2E_Pos)
#define TIM_CCER_CC2E   TIM_CCER_CC2E_Msk
#define TIM_CCER_CC2P_Pos   (5U)
#define TIM_CCER_CC2P_Msk   (0x1UL << TIM_CCER_CC2P_Pos)
#define TIM_CCER_CC2P   TIM_CCER_CC2P_Msk
#define TIM_CCER_CC2NE_Pos   (6U)
#define TIM_CCER_CC2NE_Msk   (0x1UL << TIM_CCER_CC2NE_Pos)
#define TIM_CCER_CC2NE   TIM_CCER_CC2NE_Msk
#define TIM_CCER_CC2NP_Pos   (7U)
#define TIM_CCER_CC2NP_Msk   (0x1UL << TIM_CCER_CC2NP_Pos)
#define TIM_CCER_CC2NP   TIM_CCER_CC2NP_Msk
#define TIM_CCER_CC3E_Pos   (8U)
#define TIM_CCER_CC3E_Msk   (0x1UL << TIM_CCER_CC3E_Pos)
#define TIM_CCER_CC3E   TIM_CCER_CC3E_Msk
#define TIM_CCER_CC3P_Pos   (9U)
#define TIM_CCER_CC3P_Msk   (0x1UL << TIM_CCER_CC3P_Pos)
#define TIM_CCER_CC3P   TIM_CCER_CC3P_Msk
#define TIM_CCER_CC3NE_Pos   (10U)
#define TIM_CCER_CC3NE_Msk   (0x1UL << TIM_CCER_CC3NE_Pos)
#define TIM_CCER_CC3NE   TIM_CCER_CC3NE_Msk
#define TIM_CCER_CC3NP_Pos   (11U)
#define TIM_CCER_CC3NP_Msk   (0x1UL << TIM_CCER_CC3NP_Pos)
#define TIM_CCER_CC3NP   TIM_CCER_CC3NP_Msk
#define TIM_CCER_CC4E_Pos   (12U)
#define TIM_CCER_CC4E_Msk   (0x1UL << TIM_CCER_CC4E_Pos)
#define TIM_CCER_CC4E   TIM_CCER_CC4E_Msk
#define TIM_CCER_CC4P_Pos   (13U)
#define TIM_CCER_CC4P_Msk   (0x1UL << TIM_CCER_CC4P_Pos)
#define TIM_CCER_CC4P   TIM_CCER_CC4P_Msk
#define TIM_CCER_CC4NP_Pos   (15U)
#define TIM_CCER_CC4NP_Msk   (0x1UL << TIM_CCER_CC4NP_Pos)
#define TIM_CCER_CC4NP   TIM_CCER_CC4NP_Msk
#define TIM_CCER_CC5E_Pos   (16U)
#define TIM_CCER_CC5E_Msk   (0x1UL << TIM_CCER_CC5E_Pos)
#define TIM_CCER_CC5E   TIM_CCER_CC5E_Msk
#define TIM_CCER_CC5P_Pos   (17U)
#define TIM_CCER_CC5P_Msk   (0x1UL << TIM_CCER_CC5P_Pos)
#define TIM_CCER_CC5P   TIM_CCER_CC5P_Msk
#define TIM_CCER_CC6E_Pos   (20U)
#define TIM_CCER_CC6E_Msk   (0x1UL << TIM_CCER_CC6E_Pos)
#define TIM_CCER_CC6E   TIM_CCER_CC6E_Msk
#define TIM_CCER_CC6P_Pos   (21U)
#define TIM_CCER_CC6P_Msk   (0x1UL << TIM_CCER_CC6P_Pos)
#define TIM_CCER_CC6P   TIM_CCER_CC6P_Msk
#define TIM_CNT_CNT_Pos   (0U)
#define TIM_CNT_CNT_Msk   (0xFFFFFFFFUL << TIM_CNT_CNT_Pos)
#define TIM_CNT_CNT   TIM_CNT_CNT_Msk
#define TIM_CNT_UIFCPY_Pos   (31U)
#define TIM_CNT_UIFCPY_Msk   (0x1UL << TIM_CNT_UIFCPY_Pos)
#define TIM_CNT_UIFCPY   TIM_CNT_UIFCPY_Msk
#define TIM_PSC_PSC_Pos   (0U)
#define TIM_PSC_PSC_Msk   (0xFFFFUL << TIM_PSC_PSC_Pos)
#define TIM_PSC_PSC   TIM_PSC_PSC_Msk
#define TIM_ARR_ARR_Pos   (0U)
#define TIM_ARR_ARR_Msk   (0xFFFFFFFFUL << TIM_ARR_ARR_Pos)
#define TIM_ARR_ARR   TIM_ARR_ARR_Msk
#define TIM_RCR_REP_Pos   (0U)
#define TIM_RCR_REP_Msk   (0xFFUL << TIM_RCR_REP_Pos)
#define TIM_RCR_REP   TIM_RCR_REP_Msk
#define TIM_CCR1_CCR1_Pos   (0U)
#define TIM_CCR1_CCR1_Msk   (0xFFFFUL << TIM_CCR1_CCR1_Pos)
#define TIM_CCR1_CCR1   TIM_CCR1_CCR1_Msk
#define TIM_CCR2_CCR2_Pos   (0U)
#define TIM_CCR2_CCR2_Msk   (0xFFFFUL << TIM_CCR2_CCR2_Pos)
#define TIM_CCR2_CCR2   TIM_CCR2_CCR2_Msk
#define TIM_CCR3_CCR3_Pos   (0U)
#define TIM_CCR3_CCR3_Msk   (0xFFFFUL << TIM_CCR3_CCR3_Pos)
#define TIM_CCR3_CCR3   TIM_CCR3_CCR3_Msk
#define TIM_CCR4_CCR4_Pos   (0U)
#define TIM_CCR4_CCR4_Msk   (0xFFFFUL << TIM_CCR4_CCR4_Pos)
#define TIM_CCR4_CCR4   TIM_CCR4_CCR4_Msk
#define TIM_CCR5_CCR5_Pos   (0U)
#define TIM_CCR5_CCR5_Msk   (0xFFFFFFFFUL << TIM_CCR5_CCR5_Pos)
#define TIM_CCR5_CCR5   TIM_CCR5_CCR5_Msk
#define TIM_CCR5_GC5C1_Pos   (29U)
#define TIM_CCR5_GC5C1_Msk   (0x1UL << TIM_CCR5_GC5C1_Pos)
#define TIM_CCR5_GC5C1   TIM_CCR5_GC5C1_Msk
#define TIM_CCR5_GC5C2_Pos   (30U)
#define TIM_CCR5_GC5C2_Msk   (0x1UL << TIM_CCR5_GC5C2_Pos)
#define TIM_CCR5_GC5C2   TIM_CCR5_GC5C2_Msk
#define TIM_CCR5_GC5C3_Pos   (31U)
#define TIM_CCR5_GC5C3_Msk   (0x1UL << TIM_CCR5_GC5C3_Pos)
#define TIM_CCR5_GC5C3   TIM_CCR5_GC5C3_Msk
#define TIM_CCR6_CCR6_Pos   (0U)
#define TIM_CCR6_CCR6_Msk   (0xFFFFUL << TIM_CCR6_CCR6_Pos)
#define TIM_CCR6_CCR6   TIM_CCR6_CCR6_Msk
#define TIM_BDTR_DTG_Pos   (0U)
#define TIM_BDTR_DTG_Msk   (0xFFUL << TIM_BDTR_DTG_Pos)
#define TIM_BDTR_DTG   TIM_BDTR_DTG_Msk
#define TIM_BDTR_DTG_0   (0x01UL << TIM_BDTR_DTG_Pos)
#define TIM_BDTR_DTG_1   (0x02UL << TIM_BDTR_DTG_Pos)
#define TIM_BDTR_DTG_2   (0x04UL << TIM_BDTR_DTG_Pos)
#define TIM_BDTR_DTG_3   (0x08UL << TIM_BDTR_DTG_Pos)
#define TIM_BDTR_DTG_4   (0x10UL << TIM_BDTR_DTG_Pos)
#define TIM_BDTR_DTG_5   (0x20UL << TIM_BDTR_DTG_Pos)
#define TIM_BDTR_DTG_6   (0x40UL << TIM_BDTR_DTG_Pos)
#define TIM_BDTR_DTG_7   (0x80UL << TIM_BDTR_DTG_Pos)
#define TIM_BDTR_LOCK_Pos   (8U)
#define TIM_BDTR_LOCK_Msk   (0x3UL << TIM_BDTR_LOCK_Pos)
#define TIM_BDTR_LOCK   TIM_BDTR_LOCK_Msk
#define TIM_BDTR_LOCK_0   (0x1UL << TIM_BDTR_LOCK_Pos)
#define TIM_BDTR_LOCK_1   (0x2UL << TIM_BDTR_LOCK_Pos)
#define TIM_BDTR_OSSI_Pos   (10U)
#define TIM_BDTR_OSSI_Msk   (0x1UL << TIM_BDTR_OSSI_Pos)
#define TIM_BDTR_OSSI   TIM_BDTR_OSSI_Msk
#define TIM_BDTR_OSSR_Pos   (11U)
#define TIM_BDTR_OSSR_Msk   (0x1UL << TIM_BDTR_OSSR_Pos)
#define TIM_BDTR_OSSR   TIM_BDTR_OSSR_Msk
#define TIM_BDTR_BKE_Pos   (12U)
#define TIM_BDTR_BKE_Msk   (0x1UL << TIM_BDTR_BKE_Pos)
#define TIM_BDTR_BKE   TIM_BDTR_BKE_Msk
#define TIM_BDTR_BKP_Pos   (13U)
#define TIM_BDTR_BKP_Msk   (0x1UL << TIM_BDTR_BKP_Pos)
#define TIM_BDTR_BKP   TIM_BDTR_BKP_Msk
#define TIM_BDTR_AOE_Pos   (14U)
#define TIM_BDTR_AOE_Msk   (0x1UL << TIM_BDTR_AOE_Pos)
#define TIM_BDTR_AOE   TIM_BDTR_AOE_Msk
#define TIM_BDTR_MOE_Pos   (15U)
#define TIM_BDTR_MOE_Msk   (0x1UL << TIM_BDTR_MOE_Pos)
#define TIM_BDTR_MOE   TIM_BDTR_MOE_Msk
#define TIM_BDTR_BKF_Pos   (16U)
#define TIM_BDTR_BKF_Msk   (0xFUL << TIM_BDTR_BKF_Pos)
#define TIM_BDTR_BKF   TIM_BDTR_BKF_Msk
#define TIM_BDTR_BK2F_Pos   (20U)
#define TIM_BDTR_BK2F_Msk   (0xFUL << TIM_BDTR_BK2F_Pos)
#define TIM_BDTR_BK2F   TIM_BDTR_BK2F_Msk
#define TIM_BDTR_BK2E_Pos   (24U)
#define TIM_BDTR_BK2E_Msk   (0x1UL << TIM_BDTR_BK2E_Pos)
#define TIM_BDTR_BK2E   TIM_BDTR_BK2E_Msk
#define TIM_BDTR_BK2P_Pos   (25U)
#define TIM_BDTR_BK2P_Msk   (0x1UL << TIM_BDTR_BK2P_Pos)
#define TIM_BDTR_BK2P   TIM_BDTR_BK2P_Msk
#define TIM_BDTR_BKDSRM_Pos   (26U)
#define TIM_BDTR_BKDSRM_Msk   (0x1UL << TIM_BDTR_BKDSRM_Pos)
#define TIM_BDTR_BKDSRM   TIM_BDTR_BKDSRM_Msk
#define TIM_BDTR_BK2DSRM_Pos   (27U)
#define TIM_BDTR_BK2DSRM_Msk   (0x1UL << TIM_BDTR_BK2DSRM_Pos)
#define TIM_BDTR_BK2DSRM   TIM_BDTR_BK2DSRM_Msk
#define TIM_BDTR_BKBID_Pos   (28U)
#define TIM_BDTR_BKBID_Msk   (0x1UL << TIM_BDTR_BKBID_Pos)
#define TIM_BDTR_BKBID   TIM_BDTR_BKBID_Msk
#define TIM_BDTR_BK2BID_Pos   (29U)
#define TIM_BDTR_BK2BID_Msk   (0x1UL << TIM_BDTR_BK2BID_Pos)
#define TIM_BDTR_BK2BID   TIM_BDTR_BK2BID_Msk
#define TIM_DCR_DBA_Pos   (0U)
#define TIM_DCR_DBA_Msk   (0x1FUL << TIM_DCR_DBA_Pos)
#define TIM_DCR_DBA   TIM_DCR_DBA_Msk
#define TIM_DCR_DBA_0   (0x01UL << TIM_DCR_DBA_Pos)
#define TIM_DCR_DBA_1   (0x02UL << TIM_DCR_DBA_Pos)
#define TIM_DCR_DBA_2   (0x04UL << TIM_DCR_DBA_Pos)
#define TIM_DCR_DBA_3   (0x08UL << TIM_DCR_DBA_Pos)
#define TIM_DCR_DBA_4   (0x10UL << TIM_DCR_DBA_Pos)
#define TIM_DCR_DBL_Pos   (8U)
#define TIM_DCR_DBL_Msk   (0x1FUL << TIM_DCR_DBL_Pos)
#define TIM_DCR_DBL   TIM_DCR_DBL_Msk
#define TIM_DCR_DBL_0   (0x01UL << TIM_DCR_DBL_Pos)
#define TIM_DCR_DBL_1   (0x02UL << TIM_DCR_DBL_Pos)
#define TIM_DCR_DBL_2   (0x04UL << TIM_DCR_DBL_Pos)
#define TIM_DCR_DBL_3   (0x08UL << TIM_DCR_DBL_Pos)
#define TIM_DCR_DBL_4   (0x10UL << TIM_DCR_DBL_Pos)
#define TIM_DMAR_DMAB_Pos   (0U)
#define TIM_DMAR_DMAB_Msk   (0xFFFFUL << TIM_DMAR_DMAB_Pos)
#define TIM_DMAR_DMAB   TIM_DMAR_DMAB_Msk
#define TIM_CCMR3_OC5FE_Pos   (2U)
#define TIM_CCMR3_OC5FE_Msk   (0x1UL << TIM_CCMR3_OC5FE_Pos)
#define TIM_CCMR3_OC5FE   TIM_CCMR3_OC5FE_Msk
#define TIM_CCMR3_OC5PE_Pos   (3U)
#define TIM_CCMR3_OC5PE_Msk   (0x1UL << TIM_CCMR3_OC5PE_Pos)
#define TIM_CCMR3_OC5PE   TIM_CCMR3_OC5PE_Msk
#define TIM_CCMR3_OC5M_Pos   (4U)
#define TIM_CCMR3_OC5M_Msk   (0x1007UL << TIM_CCMR3_OC5M_Pos)
#define TIM_CCMR3_OC5M   TIM_CCMR3_OC5M_Msk
#define TIM_CCMR3_OC5M_0   (0x1UL << TIM_CCMR3_OC5M_Pos)
#define TIM_CCMR3_OC5M_1   (0x2UL << TIM_CCMR3_OC5M_Pos)
#define TIM_CCMR3_OC5M_2   (0x4UL << TIM_CCMR3_OC5M_Pos)
#define TIM_CCMR3_OC5M_3   (0x1000UL << TIM_CCMR3_OC5M_Pos)
#define TIM_CCMR3_OC5CE_Pos   (7U)
#define TIM_CCMR3_OC5CE_Msk   (0x1UL << TIM_CCMR3_OC5CE_Pos)
#define TIM_CCMR3_OC5CE   TIM_CCMR3_OC5CE_Msk
#define TIM_CCMR3_OC6FE_Pos   (10U)
#define TIM_CCMR3_OC6FE_Msk   (0x1UL << TIM_CCMR3_OC6FE_Pos)
#define TIM_CCMR3_OC6FE   TIM_CCMR3_OC6FE_Msk
#define TIM_CCMR3_OC6PE_Pos   (11U)
#define TIM_CCMR3_OC6PE_Msk   (0x1UL << TIM_CCMR3_OC6PE_Pos)
#define TIM_CCMR3_OC6PE   TIM_CCMR3_OC6PE_Msk
#define TIM_CCMR3_OC6M_Pos   (12U)
#define TIM_CCMR3_OC6M_Msk   (0x1007UL << TIM_CCMR3_OC6M_Pos)
#define TIM_CCMR3_OC6M   TIM_CCMR3_OC6M_Msk
#define TIM_CCMR3_OC6M_0   (0x1UL << TIM_CCMR3_OC6M_Pos)
#define TIM_CCMR3_OC6M_1   (0x2UL << TIM_CCMR3_OC6M_Pos)
#define TIM_CCMR3_OC6M_2   (0x4UL << TIM_CCMR3_OC6M_Pos)
#define TIM_CCMR3_OC6M_3   (0x1000UL << TIM_CCMR3_OC6M_Pos)
#define TIM_CCMR3_OC6CE_Pos   (15U)
#define TIM_CCMR3_OC6CE_Msk   (0x1UL << TIM_CCMR3_OC6CE_Pos)
#define TIM_CCMR3_OC6CE   TIM_CCMR3_OC6CE_Msk
#define TIM1_AF1_BKINE_Pos   (0U)
#define TIM1_AF1_BKINE_Msk   (0x1UL << TIM1_AF1_BKINE_Pos)
#define TIM1_AF1_BKINE   TIM1_AF1_BKINE_Msk
#define TIM1_AF1_BKCMP1E_Pos   (1U)
#define TIM1_AF1_BKCMP1E_Msk   (0x1UL << TIM1_AF1_BKCMP1E_Pos)
#define TIM1_AF1_BKCMP1E   TIM1_AF1_BKCMP1E_Msk
#define TIM1_AF1_BKCMP2E_Pos   (2U)
#define TIM1_AF1_BKCMP2E_Msk   (0x1UL << TIM1_AF1_BKCMP2E_Pos)
#define TIM1_AF1_BKCMP2E   TIM1_AF1_BKCMP2E_Msk
#define TIM1_AF1_BKDF1BK0E_Pos   (8U)
#define TIM1_AF1_BKDF1BK0E_Msk   (0x1UL << TIM1_AF1_BKDF1BK0E_Pos)
#define TIM1_AF1_BKDF1BK0E   TIM1_AF1_BKDF1BK0E_Msk
#define TIM1_AF1_BKINP_Pos   (9U)
#define TIM1_AF1_BKINP_Msk   (0x1UL << TIM1_AF1_BKINP_Pos)
#define TIM1_AF1_BKINP   TIM1_AF1_BKINP_Msk
#define TIM1_AF1_BKCMP1P_Pos   (10U)
#define TIM1_AF1_BKCMP1P_Msk   (0x1UL << TIM1_AF1_BKCMP1P_Pos)
#define TIM1_AF1_BKCMP1P   TIM1_AF1_BKCMP1P_Msk
#define TIM1_AF1_BKCMP2P_Pos   (11U)
#define TIM1_AF1_BKCMP2P_Msk   (0x1UL << TIM1_AF1_BKCMP2P_Pos)
#define TIM1_AF1_BKCMP2P   TIM1_AF1_BKCMP2P_Msk
#define TIM1_AF1_ETRSEL_Pos   (14U)
#define TIM1_AF1_ETRSEL_Msk   (0xFUL << TIM1_AF1_ETRSEL_Pos)
#define TIM1_AF1_ETRSEL   TIM1_AF1_ETRSEL_Msk
#define TIM1_AF1_ETRSEL_0   (0x1UL << TIM1_AF1_ETRSEL_Pos)
#define TIM1_AF1_ETRSEL_1   (0x2UL << TIM1_AF1_ETRSEL_Pos)
#define TIM1_AF1_ETRSEL_2   (0x4UL << TIM1_AF1_ETRSEL_Pos)
#define TIM1_AF1_ETRSEL_3   (0x8UL << TIM1_AF1_ETRSEL_Pos)
#define TIM1_AF2_BK2INE_Pos   (0U)
#define TIM1_AF2_BK2INE_Msk   (0x1UL << TIM1_AF2_BK2INE_Pos)
#define TIM1_AF2_BK2INE   TIM1_AF2_BK2INE_Msk
#define TIM1_AF2_BK2CMP1E_Pos   (1U)
#define TIM1_AF2_BK2CMP1E_Msk   (0x1UL << TIM1_AF2_BK2CMP1E_Pos)
#define TIM1_AF2_BK2CMP1E   TIM1_AF2_BK2CMP1E_Msk
#define TIM1_AF2_BK2CMP2E_Pos   (2U)
#define TIM1_AF2_BK2CMP2E_Msk   (0x1UL << TIM1_AF2_BK2CMP2E_Pos)
#define TIM1_AF2_BK2CMP2E   TIM1_AF2_BK2CMP2E_Msk
#define TIM1_AF2_BK2DFBK1E_Pos   (8U)
#define TIM1_AF2_BK2DFBK1E_Msk   (0x1UL << TIM1_AF2_BK2DFBK1E_Pos)
#define TIM1_AF2_BK2DFBK1E   TIM1_AF2_BK2DFBK1E_Msk
#define TIM1_AF2_BK2INP_Pos   (9U)
#define TIM1_AF2_BK2INP_Msk   (0x1UL << TIM1_AF2_BK2INP_Pos)
#define TIM1_AF2_BK2INP   TIM1_AF2_BK2INP_Msk
#define TIM1_AF2_BK2CMP1P_Pos   (10U)
#define TIM1_AF2_BK2CMP1P_Msk   (0x1UL << TIM1_AF2_BK2CMP1P_Pos)
#define TIM1_AF2_BK2CMP1P   TIM1_AF2_BK2CMP1P_Msk
#define TIM1_AF2_BK2CMP2P_Pos   (11U)
#define TIM1_AF2_BK2CMP2P_Msk   (0x1UL << TIM1_AF2_BK2CMP2P_Pos)
#define TIM1_AF2_BK2CMP2P   TIM1_AF2_BK2CMP2P_Msk
#define TIM_TISEL_TI1SEL_Pos   (0U)
#define TIM_TISEL_TI1SEL_Msk   (0xFUL << TIM_TISEL_TI1SEL_Pos)
#define TIM_TISEL_TI1SEL   TIM_TISEL_TI1SEL_Msk
#define TIM_TISEL_TI1SEL_0   (0x1UL << TIM_TISEL_TI1SEL_Pos)
#define TIM_TISEL_TI1SEL_1   (0x2UL << TIM_TISEL_TI1SEL_Pos)
#define TIM_TISEL_TI1SEL_2   (0x4UL << TIM_TISEL_TI1SEL_Pos)
#define TIM_TISEL_TI1SEL_3   (0x8UL << TIM_TISEL_TI1SEL_Pos)
#define TIM_TISEL_TI2SEL_Pos   (8U)
#define TIM_TISEL_TI2SEL_Msk   (0xFUL << TIM_TISEL_TI2SEL_Pos)
#define TIM_TISEL_TI2SEL   TIM_TISEL_TI2SEL_Msk
#define TIM_TISEL_TI2SEL_0   (0x1UL << TIM_TISEL_TI2SEL_Pos)
#define TIM_TISEL_TI2SEL_1   (0x2UL << TIM_TISEL_TI2SEL_Pos)
#define TIM_TISEL_TI2SEL_2   (0x4UL << TIM_TISEL_TI2SEL_Pos)
#define TIM_TISEL_TI2SEL_3   (0x8UL << TIM_TISEL_TI2SEL_Pos)
#define TIM_TISEL_TI3SEL_Pos   (16U)
#define TIM_TISEL_TI3SEL_Msk   (0xFUL << TIM_TISEL_TI3SEL_Pos)
#define TIM_TISEL_TI3SEL   TIM_TISEL_TI3SEL_Msk
#define TIM_TISEL_TI3SEL_0   (0x1UL << TIM_TISEL_TI3SEL_Pos)
#define TIM_TISEL_TI3SEL_1   (0x2UL << TIM_TISEL_TI3SEL_Pos)
#define TIM_TISEL_TI3SEL_2   (0x4UL << TIM_TISEL_TI3SEL_Pos)
#define TIM_TISEL_TI3SEL_3   (0x8UL << TIM_TISEL_TI3SEL_Pos)
#define TIM_TISEL_TI4SEL_Pos   (24U)
#define TIM_TISEL_TI4SEL_Msk   (0xFUL << TIM_TISEL_TI4SEL_Pos)
#define TIM_TISEL_TI4SEL   TIM_TISEL_TI4SEL_Msk
#define TIM_TISEL_TI4SEL_0   (0x1UL << TIM_TISEL_TI4SEL_Pos)
#define TIM_TISEL_TI4SEL_1   (0x2UL << TIM_TISEL_TI4SEL_Pos)
#define TIM_TISEL_TI4SEL_2   (0x4UL << TIM_TISEL_TI4SEL_Pos)
#define TIM_TISEL_TI4SEL_3   (0x8UL << TIM_TISEL_TI4SEL_Pos)
#define TIM8_AF1_BKINE_Pos   (0U)
#define TIM8_AF1_BKINE_Msk   (0x1UL << TIM8_AF1_BKINE_Pos)
#define TIM8_AF1_BKINE   TIM8_AF1_BKINE_Msk
#define TIM8_AF1_BKCMP1E_Pos   (1U)
#define TIM8_AF1_BKCMP1E_Msk   (0x1UL << TIM8_AF1_BKCMP1E_Pos)
#define TIM8_AF1_BKCMP1E   TIM8_AF1_BKCMP1E_Msk
#define TIM8_AF1_BKCMP2E_Pos   (2U)
#define TIM8_AF1_BKCMP2E_Msk   (0x1UL << TIM8_AF1_BKCMP2E_Pos)
#define TIM8_AF1_BKCMP2E   TIM8_AF1_BKCMP2E_Msk
#define TIM8_AF1_BKDFBK2E_Pos   (8U)
#define TIM8_AF1_BKDFBK2E_Msk   (0x1UL << TIM8_AF1_BKDFBK2E_Pos)
#define TIM8_AF1_BKDFBK2E   TIM8_AF1_BKDFBK2E_Msk
#define TIM8_AF1_BKINP_Pos   (9U)
#define TIM8_AF1_BKINP_Msk   (0x1UL << TIM8_AF1_BKINP_Pos)
#define TIM8_AF1_BKINP   TIM8_AF1_BKINP_Msk
#define TIM8_AF1_BKCMP1P_Pos   (10U)
#define TIM8_AF1_BKCMP1P_Msk   (0x1UL << TIM8_AF1_BKCMP1P_Pos)
#define TIM8_AF1_BKCMP1P   TIM8_AF1_BKCMP1P_Msk
#define TIM8_AF1_BKCMP2P_Pos   (11U)
#define TIM8_AF1_BKCMP2P_Msk   (0x1UL << TIM8_AF1_BKCMP2P_Pos)
#define TIM8_AF1_BKCMP2P   TIM8_AF1_BKCMP2P_Msk
#define TIM8_AF1_ETRSEL_Pos   (14U)
#define TIM8_AF1_ETRSEL_Msk   (0xFUL << TIM8_AF1_ETRSEL_Pos)
#define TIM8_AF1_ETRSEL   TIM8_AF1_ETRSEL_Msk
#define TIM8_AF1_ETRSEL_0   (0x1UL << TIM8_AF1_ETRSEL_Pos)
#define TIM8_AF1_ETRSEL_1   (0x2UL << TIM8_AF1_ETRSEL_Pos)
#define TIM8_AF1_ETRSEL_2   (0x4UL << TIM8_AF1_ETRSEL_Pos)
#define TIM8_AF1_ETRSEL_3   (0x8UL << TIM8_AF1_ETRSEL_Pos)
#define TIM8_AF2_BK2INE_Pos   (0U)
#define TIM8_AF2_BK2INE_Msk   (0x1UL << TIM8_AF2_BK2INE_Pos)
#define TIM8_AF2_BK2INE   TIM8_AF2_BK2INE_Msk
#define TIM8_AF2_BK2CMP1E_Pos   (1U)
#define TIM8_AF2_BK2CMP1E_Msk   (0x1UL << TIM8_AF2_BK2CMP1E_Pos)
#define TIM8_AF2_BK2CMP1E   TIM8_AF2_BK2CMP1E_Msk
#define TIM8_AF2_BK2CMP2E_Pos   (2U)
#define TIM8_AF2_BK2CMP2E_Msk   (0x1UL << TIM8_AF2_BK2CMP2E_Pos)
#define TIM8_AF2_BK2CMP2E   TIM8_AF2_BK2CMP2E_Msk
#define TIM8_AF2_BK2DFBK3E_Pos   (8U)
#define TIM8_AF2_BK2DFBK3E_Msk   (0x1UL << TIM8_AF2_BK2DFBK3E_Pos)
#define TIM8_AF2_BK2DFBK3E   TIM8_AF2_BK2DFBK3E_Msk
#define TIM8_AF2_BK2INP_Pos   (9U)
#define TIM8_AF2_BK2INP_Msk   (0x1UL << TIM8_AF2_BK2INP_Pos)
#define TIM8_AF2_BK2INP   TIM8_AF2_BK2INP_Msk
#define TIM8_AF2_BK2CMP1P_Pos   (10U)
#define TIM8_AF2_BK2CMP1P_Msk   (0x1UL << TIM8_AF2_BK2CMP1P_Pos)
#define TIM8_AF2_BK2CMP1P   TIM8_AF2_BK2CMP1P_Msk
#define TIM8_AF2_BK2CMP2P_Pos   (11U)
#define TIM8_AF2_BK2CMP2P_Msk   (0x1UL << TIM8_AF2_BK2CMP2P_Pos)
#define TIM8_AF2_BK2CMP2P   TIM8_AF2_BK2CMP2P_Msk
#define TIM2_AF1_ETRSEL_Pos   (14U)
#define TIM2_AF1_ETRSEL_Msk   (0xFUL << TIM2_AF1_ETRSEL_Pos)
#define TIM2_AF1_ETRSEL   TIM2_AF1_ETRSEL_Msk
#define TIM2_AF1_ETRSEL_0   (0x1UL << TIM2_AF1_ETRSEL_Pos)
#define TIM2_AF1_ETRSEL_1   (0x2UL << TIM2_AF1_ETRSEL_Pos)
#define TIM2_AF1_ETRSEL_2   (0x4UL << TIM2_AF1_ETRSEL_Pos)
#define TIM2_AF1_ETRSEL_3   (0x8UL << TIM2_AF1_ETRSEL_Pos)
#define TIM3_AF1_ETRSEL_Pos   (14U)
#define TIM3_AF1_ETRSEL_Msk   (0xFUL << TIM3_AF1_ETRSEL_Pos)
#define TIM3_AF1_ETRSEL   TIM3_AF1_ETRSEL_Msk
#define TIM3_AF1_ETRSEL_0   (0x1UL << TIM3_AF1_ETRSEL_Pos)
#define TIM3_AF1_ETRSEL_1   (0x2UL << TIM3_AF1_ETRSEL_Pos)
#define TIM3_AF1_ETRSEL_2   (0x4UL << TIM3_AF1_ETRSEL_Pos)
#define TIM3_AF1_ETRSEL_3   (0x8UL << TIM3_AF1_ETRSEL_Pos)
#define TIM5_AF1_ETRSEL_Pos   (14U)
#define TIM5_AF1_ETRSEL_Msk   (0xFUL << TIM5_AF1_ETRSEL_Pos)
#define TIM5_AF1_ETRSEL   TIM5_AF1_ETRSEL_Msk
#define TIM5_AF1_ETRSEL_0   (0x1UL << TIM5_AF1_ETRSEL_Pos)
#define TIM5_AF1_ETRSEL_1   (0x2UL << TIM5_AF1_ETRSEL_Pos)
#define TIM5_AF1_ETRSEL_2   (0x4UL << TIM5_AF1_ETRSEL_Pos)
#define TIM5_AF1_ETRSEL_3   (0x8UL << TIM5_AF1_ETRSEL_Pos)
#define TIM15_AF1_BKINE_Pos   (0U)
#define TIM15_AF1_BKINE_Msk   (0x1UL << TIM15_AF1_BKINE_Pos)
#define TIM15_AF1_BKINE   TIM15_AF1_BKINE_Msk
#define TIM15_AF1_BKCMP1E_Pos   (1U)
#define TIM15_AF1_BKCMP1E_Msk   (0x1UL << TIM15_AF1_BKCMP1E_Pos)
#define TIM15_AF1_BKCMP1E   TIM15_AF1_BKCMP1E_Msk
#define TIM15_AF1_BKCMP2E_Pos   (2U)
#define TIM15_AF1_BKCMP2E_Msk   (0x1UL << TIM15_AF1_BKCMP2E_Pos)
#define TIM15_AF1_BKCMP2E   TIM15_AF1_BKCMP2E_Msk
#define TIM15_AF1_BKDF1BK2E_Pos   (8U)
#define TIM15_AF1_BKDF1BK2E_Msk   (0x1UL << TIM15_AF1_BKDF1BK2E_Pos)
#define TIM15_AF1_BKDF1BK2E   TIM15_AF1_BKDF1BK2E_Msk
#define TIM15_AF1_BKINP_Pos   (9U)
#define TIM15_AF1_BKINP_Msk   (0x1UL << TIM15_AF1_BKINP_Pos)
#define TIM15_AF1_BKINP   TIM15_AF1_BKINP_Msk
#define TIM15_AF1_BKCMP1P_Pos   (10U)
#define TIM15_AF1_BKCMP1P_Msk   (0x1UL << TIM15_AF1_BKCMP1P_Pos)
#define TIM15_AF1_BKCMP1P   TIM15_AF1_BKCMP1P_Msk
#define TIM15_AF1_BKCMP2P_Pos   (11U)
#define TIM15_AF1_BKCMP2P_Msk   (0x1UL << TIM15_AF1_BKCMP2P_Pos)
#define TIM15_AF1_BKCMP2P   TIM15_AF1_BKCMP2P_Msk
#define TIM16_AF1_BKINE_Pos   (0U)
#define TIM16_AF1_BKINE_Msk   (0x1UL << TIM16_AF1_BKINE_Pos)
#define TIM16_AF1_BKINE   TIM16_AF1_BKINE_Msk
#define TIM16_AF1_BKCMP1E_Pos   (1U)
#define TIM16_AF1_BKCMP1E_Msk   (0x1UL << TIM16_AF1_BKCMP1E_Pos)
#define TIM16_AF1_BKCMP1E   TIM16_AF1_BKCMP1E_Msk
#define TIM16_AF1_BKCMP2E_Pos   (2U)
#define TIM16_AF1_BKCMP2E_Msk   (0x1UL << TIM16_AF1_BKCMP2E_Pos)
#define TIM16_AF1_BKCMP2E   TIM16_AF1_BKCMP2E_Msk
#define TIM16_AF1_BKDF1BK2E_Pos   (8U)
#define TIM16_AF1_BKDF1BK2E_Msk   (0x1UL << TIM16_AF1_BKDF1BK2E_Pos)
#define TIM16_AF1_BKDF1BK2E   TIM16_AF1_BKDF1BK2E_Msk
#define TIM16_AF1_BKINP_Pos   (9U)
#define TIM16_AF1_BKINP_Msk   (0x1UL << TIM16_AF1_BKINP_Pos)
#define TIM16_AF1_BKINP   TIM16_AF1_BKINP_Msk
#define TIM16_AF1_BKCMP1P_Pos   (10U)
#define TIM16_AF1_BKCMP1P_Msk   (0x1UL << TIM16_AF1_BKCMP1P_Pos)
#define TIM16_AF1_BKCMP1P   TIM16_AF1_BKCMP1P_Msk
#define TIM16_AF1_BKCMP2P_Pos   (11U)
#define TIM16_AF1_BKCMP2P_Msk   (0x1UL << TIM16_AF1_BKCMP2P_Pos)
#define TIM16_AF1_BKCMP2P   TIM16_AF1_BKCMP2P_Msk
#define TIM17_AF1_BKINE_Pos   (0U)
#define TIM17_AF1_BKINE_Msk   (0x1UL << TIM17_AF1_BKINE_Pos)
#define TIM17_AF1_BKINE   TIM17_AF1_BKINE_Msk
#define TIM17_AF1_BKCMP1E_Pos   (1U)
#define TIM17_AF1_BKCMP1E_Msk   (0x1UL << TIM17_AF1_BKCMP1E_Pos)
#define TIM17_AF1_BKCMP1E   TIM17_AF1_BKCMP1E_Msk
#define TIM17_AF1_BKCMP2E_Pos   (2U)
#define TIM17_AF1_BKCMP2E_Msk   (0x1UL << TIM17_AF1_BKCMP2E_Pos)
#define TIM17_AF1_BKCMP2E   TIM17_AF1_BKCMP2E_Msk
#define TIM17_AF1_BKDF1BK2E_Pos   (8U)
#define TIM17_AF1_BKDF1BK2E_Msk   (0x1UL << TIM17_AF1_BKDF1BK2E_Pos)
#define TIM17_AF1_BKDF1BK2E   TIM17_AF1_BKDF1BK2E_Msk
#define TIM17_AF1_BKINP_Pos   (9U)
#define TIM17_AF1_BKINP_Msk   (0x1UL << TIM17_AF1_BKINP_Pos)
#define TIM17_AF1_BKINP   TIM17_AF1_BKINP_Msk
#define TIM17_AF1_BKCMP1P_Pos   (10U)
#define TIM17_AF1_BKCMP1P_Msk   (0x1UL << TIM17_AF1_BKCMP1P_Pos)
#define TIM17_AF1_BKCMP1P   TIM17_AF1_BKCMP1P_Msk
#define TIM17_AF1_BKCMP2P_Pos   (11U)
#define TIM17_AF1_BKCMP2P_Msk   (0x1UL << TIM17_AF1_BKCMP2P_Pos)
#define TIM17_AF1_BKCMP2P   TIM17_AF1_BKCMP2P_Msk
#define LPTIM_ISR_CMPM_Pos   (0U)
#define LPTIM_ISR_CMPM_Msk   (0x1UL << LPTIM_ISR_CMPM_Pos)
#define LPTIM_ISR_CMPM   LPTIM_ISR_CMPM_Msk
#define LPTIM_ISR_ARRM_Pos   (1U)
#define LPTIM_ISR_ARRM_Msk   (0x1UL << LPTIM_ISR_ARRM_Pos)
#define LPTIM_ISR_ARRM   LPTIM_ISR_ARRM_Msk
#define LPTIM_ISR_EXTTRIG_Pos   (2U)
#define LPTIM_ISR_EXTTRIG_Msk   (0x1UL << LPTIM_ISR_EXTTRIG_Pos)
#define LPTIM_ISR_EXTTRIG   LPTIM_ISR_EXTTRIG_Msk
#define LPTIM_ISR_CMPOK_Pos   (3U)
#define LPTIM_ISR_CMPOK_Msk   (0x1UL << LPTIM_ISR_CMPOK_Pos)
#define LPTIM_ISR_CMPOK   LPTIM_ISR_CMPOK_Msk
#define LPTIM_ISR_ARROK_Pos   (4U)
#define LPTIM_ISR_ARROK_Msk   (0x1UL << LPTIM_ISR_ARROK_Pos)
#define LPTIM_ISR_ARROK   LPTIM_ISR_ARROK_Msk
#define LPTIM_ISR_UP_Pos   (5U)
#define LPTIM_ISR_UP_Msk   (0x1UL << LPTIM_ISR_UP_Pos)
#define LPTIM_ISR_UP   LPTIM_ISR_UP_Msk
#define LPTIM_ISR_DOWN_Pos   (6U)
#define LPTIM_ISR_DOWN_Msk   (0x1UL << LPTIM_ISR_DOWN_Pos)
#define LPTIM_ISR_DOWN   LPTIM_ISR_DOWN_Msk
#define LPTIM_ICR_CMPMCF_Pos   (0U)
#define LPTIM_ICR_CMPMCF_Msk   (0x1UL << LPTIM_ICR_CMPMCF_Pos)
#define LPTIM_ICR_CMPMCF   LPTIM_ICR_CMPMCF_Msk
#define LPTIM_ICR_ARRMCF_Pos   (1U)
#define LPTIM_ICR_ARRMCF_Msk   (0x1UL << LPTIM_ICR_ARRMCF_Pos)
#define LPTIM_ICR_ARRMCF   LPTIM_ICR_ARRMCF_Msk
#define LPTIM_ICR_EXTTRIGCF_Pos   (2U)
#define LPTIM_ICR_EXTTRIGCF_Msk   (0x1UL << LPTIM_ICR_EXTTRIGCF_Pos)
#define LPTIM_ICR_EXTTRIGCF   LPTIM_ICR_EXTTRIGCF_Msk
#define LPTIM_ICR_CMPOKCF_Pos   (3U)
#define LPTIM_ICR_CMPOKCF_Msk   (0x1UL << LPTIM_ICR_CMPOKCF_Pos)
#define LPTIM_ICR_CMPOKCF   LPTIM_ICR_CMPOKCF_Msk
#define LPTIM_ICR_ARROKCF_Pos   (4U)
#define LPTIM_ICR_ARROKCF_Msk   (0x1UL << LPTIM_ICR_ARROKCF_Pos)
#define LPTIM_ICR_ARROKCF   LPTIM_ICR_ARROKCF_Msk
#define LPTIM_ICR_UPCF_Pos   (5U)
#define LPTIM_ICR_UPCF_Msk   (0x1UL << LPTIM_ICR_UPCF_Pos)
#define LPTIM_ICR_UPCF   LPTIM_ICR_UPCF_Msk
#define LPTIM_ICR_DOWNCF_Pos   (6U)
#define LPTIM_ICR_DOWNCF_Msk   (0x1UL << LPTIM_ICR_DOWNCF_Pos)
#define LPTIM_ICR_DOWNCF   LPTIM_ICR_DOWNCF_Msk
#define LPTIM_IER_CMPMIE_Pos   (0U)
#define LPTIM_IER_CMPMIE_Msk   (0x1UL << LPTIM_IER_CMPMIE_Pos)
#define LPTIM_IER_CMPMIE   LPTIM_IER_CMPMIE_Msk
#define LPTIM_IER_ARRMIE_Pos   (1U)
#define LPTIM_IER_ARRMIE_Msk   (0x1UL << LPTIM_IER_ARRMIE_Pos)
#define LPTIM_IER_ARRMIE   LPTIM_IER_ARRMIE_Msk
#define LPTIM_IER_EXTTRIGIE_Pos   (2U)
#define LPTIM_IER_EXTTRIGIE_Msk   (0x1UL << LPTIM_IER_EXTTRIGIE_Pos)
#define LPTIM_IER_EXTTRIGIE   LPTIM_IER_EXTTRIGIE_Msk
#define LPTIM_IER_CMPOKIE_Pos   (3U)
#define LPTIM_IER_CMPOKIE_Msk   (0x1UL << LPTIM_IER_CMPOKIE_Pos)
#define LPTIM_IER_CMPOKIE   LPTIM_IER_CMPOKIE_Msk
#define LPTIM_IER_ARROKIE_Pos   (4U)
#define LPTIM_IER_ARROKIE_Msk   (0x1UL << LPTIM_IER_ARROKIE_Pos)
#define LPTIM_IER_ARROKIE   LPTIM_IER_ARROKIE_Msk
#define LPTIM_IER_UPIE_Pos   (5U)
#define LPTIM_IER_UPIE_Msk   (0x1UL << LPTIM_IER_UPIE_Pos)
#define LPTIM_IER_UPIE   LPTIM_IER_UPIE_Msk
#define LPTIM_IER_DOWNIE_Pos   (6U)
#define LPTIM_IER_DOWNIE_Msk   (0x1UL << LPTIM_IER_DOWNIE_Pos)
#define LPTIM_IER_DOWNIE   LPTIM_IER_DOWNIE_Msk
#define LPTIM_CFGR_CKSEL_Pos   (0U)
#define LPTIM_CFGR_CKSEL_Msk   (0x1UL << LPTIM_CFGR_CKSEL_Pos)
#define LPTIM_CFGR_CKSEL   LPTIM_CFGR_CKSEL_Msk
#define LPTIM_CFGR_CKPOL_Pos   (1U)
#define LPTIM_CFGR_CKPOL_Msk   (0x3UL << LPTIM_CFGR_CKPOL_Pos)
#define LPTIM_CFGR_CKPOL   LPTIM_CFGR_CKPOL_Msk
#define LPTIM_CFGR_CKPOL_0   (0x1UL << LPTIM_CFGR_CKPOL_Pos)
#define LPTIM_CFGR_CKPOL_1   (0x2UL << LPTIM_CFGR_CKPOL_Pos)
#define LPTIM_CFGR_CKFLT_Pos   (3U)
#define LPTIM_CFGR_CKFLT_Msk   (0x3UL << LPTIM_CFGR_CKFLT_Pos)
#define LPTIM_CFGR_CKFLT   LPTIM_CFGR_CKFLT_Msk
#define LPTIM_CFGR_CKFLT_0   (0x1UL << LPTIM_CFGR_CKFLT_Pos)
#define LPTIM_CFGR_CKFLT_1   (0x2UL << LPTIM_CFGR_CKFLT_Pos)
#define LPTIM_CFGR_TRGFLT_Pos   (6U)
#define LPTIM_CFGR_TRGFLT_Msk   (0x3UL << LPTIM_CFGR_TRGFLT_Pos)
#define LPTIM_CFGR_TRGFLT   LPTIM_CFGR_TRGFLT_Msk
#define LPTIM_CFGR_TRGFLT_0   (0x1UL << LPTIM_CFGR_TRGFLT_Pos)
#define LPTIM_CFGR_TRGFLT_1   (0x2UL << LPTIM_CFGR_TRGFLT_Pos)
#define LPTIM_CFGR_PRESC_Pos   (9U)
#define LPTIM_CFGR_PRESC_Msk   (0x7UL << LPTIM_CFGR_PRESC_Pos)
#define LPTIM_CFGR_PRESC   LPTIM_CFGR_PRESC_Msk
#define LPTIM_CFGR_PRESC_0   (0x1UL << LPTIM_CFGR_PRESC_Pos)
#define LPTIM_CFGR_PRESC_1   (0x2UL << LPTIM_CFGR_PRESC_Pos)
#define LPTIM_CFGR_PRESC_2   (0x4UL << LPTIM_CFGR_PRESC_Pos)
#define LPTIM_CFGR_TRIGSEL_Pos   (13U)
#define LPTIM_CFGR_TRIGSEL_Msk   (0x7UL << LPTIM_CFGR_TRIGSEL_Pos)
#define LPTIM_CFGR_TRIGSEL   LPTIM_CFGR_TRIGSEL_Msk
#define LPTIM_CFGR_TRIGSEL_0   (0x1UL << LPTIM_CFGR_TRIGSEL_Pos)
#define LPTIM_CFGR_TRIGSEL_1   (0x2UL << LPTIM_CFGR_TRIGSEL_Pos)
#define LPTIM_CFGR_TRIGSEL_2   (0x4UL << LPTIM_CFGR_TRIGSEL_Pos)
#define LPTIM_CFGR_TRIGEN_Pos   (17U)
#define LPTIM_CFGR_TRIGEN_Msk   (0x3UL << LPTIM_CFGR_TRIGEN_Pos)
#define LPTIM_CFGR_TRIGEN   LPTIM_CFGR_TRIGEN_Msk
#define LPTIM_CFGR_TRIGEN_0   (0x1UL << LPTIM_CFGR_TRIGEN_Pos)
#define LPTIM_CFGR_TRIGEN_1   (0x2UL << LPTIM_CFGR_TRIGEN_Pos)
#define LPTIM_CFGR_TIMOUT_Pos   (19U)
#define LPTIM_CFGR_TIMOUT_Msk   (0x1UL << LPTIM_CFGR_TIMOUT_Pos)
#define LPTIM_CFGR_TIMOUT   LPTIM_CFGR_TIMOUT_Msk
#define LPTIM_CFGR_WAVE_Pos   (20U)
#define LPTIM_CFGR_WAVE_Msk   (0x1UL << LPTIM_CFGR_WAVE_Pos)
#define LPTIM_CFGR_WAVE   LPTIM_CFGR_WAVE_Msk
#define LPTIM_CFGR_WAVPOL_Pos   (21U)
#define LPTIM_CFGR_WAVPOL_Msk   (0x1UL << LPTIM_CFGR_WAVPOL_Pos)
#define LPTIM_CFGR_WAVPOL   LPTIM_CFGR_WAVPOL_Msk
#define LPTIM_CFGR_PRELOAD_Pos   (22U)
#define LPTIM_CFGR_PRELOAD_Msk   (0x1UL << LPTIM_CFGR_PRELOAD_Pos)
#define LPTIM_CFGR_PRELOAD   LPTIM_CFGR_PRELOAD_Msk
#define LPTIM_CFGR_COUNTMODE_Pos   (23U)
#define LPTIM_CFGR_COUNTMODE_Msk   (0x1UL << LPTIM_CFGR_COUNTMODE_Pos)
#define LPTIM_CFGR_COUNTMODE   LPTIM_CFGR_COUNTMODE_Msk
#define LPTIM_CFGR_ENC_Pos   (24U)
#define LPTIM_CFGR_ENC_Msk   (0x1UL << LPTIM_CFGR_ENC_Pos)
#define LPTIM_CFGR_ENC   LPTIM_CFGR_ENC_Msk
#define LPTIM_CR_ENABLE_Pos   (0U)
#define LPTIM_CR_ENABLE_Msk   (0x1UL << LPTIM_CR_ENABLE_Pos)
#define LPTIM_CR_ENABLE   LPTIM_CR_ENABLE_Msk
#define LPTIM_CR_SNGSTRT_Pos   (1U)
#define LPTIM_CR_SNGSTRT_Msk   (0x40001UL << LPTIM_CR_SNGSTRT_Pos)
#define LPTIM_CR_SNGSTRT   LPTIM_CR_SNGSTRT_Msk
#define LPTIM_CR_CNTSTRT_Pos   (2U)
#define LPTIM_CR_CNTSTRT_Msk   (0x1UL << LPTIM_CR_CNTSTRT_Pos)
#define LPTIM_CR_CNTSTRT   LPTIM_CR_CNTSTRT_Msk
#define LPTIM_CR_COUNTRST_Pos   (3U)
#define LPTIM_CR_COUNTRST_Msk   (0x1UL << LPTIM_CR_COUNTRST_Pos)
#define LPTIM_CR_COUNTRST   LPTIM_CR_COUNTRST_Msk
#define LPTIM_CR_RSTARE_Pos   (4U)
#define LPTIM_CR_RSTARE_Msk   (0x1UL << LPTIM_CR_RSTARE_Pos)
#define LPTIM_CR_RSTARE   LPTIM_CR_RSTARE_Msk
#define LPTIM_CMP_CMP_Pos   (0U)
#define LPTIM_CMP_CMP_Msk   (0xFFFFUL << LPTIM_CMP_CMP_Pos)
#define LPTIM_CMP_CMP   LPTIM_CMP_CMP_Msk
#define LPTIM_ARR_ARR_Pos   (0U)
#define LPTIM_ARR_ARR_Msk   (0xFFFFUL << LPTIM_ARR_ARR_Pos)
#define LPTIM_ARR_ARR   LPTIM_ARR_ARR_Msk
#define LPTIM_CNT_CNT_Pos   (0U)
#define LPTIM_CNT_CNT_Msk   (0xFFFFUL << LPTIM_CNT_CNT_Pos)
#define LPTIM_CNT_CNT   LPTIM_CNT_CNT_Msk
#define LPTIM_CFGR2_IN1SEL_Pos   (0U)
#define LPTIM_CFGR2_IN1SEL_Msk   (0x3UL << LPTIM_CFGR2_IN1SEL_Pos)
#define LPTIM_CFGR2_IN1SEL   LPTIM_CFGR2_IN1SEL_Msk
#define LPTIM_CFGR2_IN1SEL_0   (0x1UL << LPTIM_CFGR2_IN1SEL_Pos)
#define LPTIM_CFGR2_IN1SEL_1   (0x2UL << LPTIM_CFGR2_IN1SEL_Pos)
#define LPTIM_CFGR2_IN2SEL_Pos   (4U)
#define LPTIM_CFGR2_IN2SEL_Msk   (0x3UL << LPTIM_CFGR2_IN2SEL_Pos)
#define LPTIM_CFGR2_IN2SEL   LPTIM_CFGR2_IN2SEL_Msk
#define LPTIM_CFGR2_IN2SEL_0   (0x1UL << LPTIM_CFGR2_IN2SEL_Pos)
#define LPTIM_CFGR2_IN2SEL_1   (0x2UL << LPTIM_CFGR2_IN2SEL_Pos)
#define OCTOSPI_CR_EN_Pos   (0U)
#define OCTOSPI_CR_EN_Msk   (0x1UL << OCTOSPI_CR_EN_Pos)
#define OCTOSPI_CR_EN   OCTOSPI_CR_EN_Msk
#define OCTOSPI_CR_ABORT_Pos   (1U)
#define OCTOSPI_CR_ABORT_Msk   (0x1UL << OCTOSPI_CR_ABORT_Pos)
#define OCTOSPI_CR_ABORT   OCTOSPI_CR_ABORT_Msk
#define OCTOSPI_CR_DMAEN_Pos   (2U)
#define OCTOSPI_CR_DMAEN_Msk   (0x1UL << OCTOSPI_CR_DMAEN_Pos)
#define OCTOSPI_CR_DMAEN   OCTOSPI_CR_DMAEN_Msk
#define OCTOSPI_CR_TCEN_Pos   (3U)
#define OCTOSPI_CR_TCEN_Msk   (0x1UL << OCTOSPI_CR_TCEN_Pos)
#define OCTOSPI_CR_TCEN   OCTOSPI_CR_TCEN_Msk
#define OCTOSPI_CR_DQM_Pos   (6U)
#define OCTOSPI_CR_DQM_Msk   (0x1UL << OCTOSPI_CR_DQM_Pos)
#define OCTOSPI_CR_DQM   OCTOSPI_CR_DQM_Msk
#define OCTOSPI_CR_FSEL_Pos   (7U)
#define OCTOSPI_CR_FSEL_Msk   (0x1UL << OCTOSPI_CR_FSEL_Pos)
#define OCTOSPI_CR_FSEL   OCTOSPI_CR_FSEL_Msk
#define OCTOSPI_CR_FTHRES_Pos   (8U)
#define OCTOSPI_CR_FTHRES_Msk   (0x1FUL << OCTOSPI_CR_FTHRES_Pos)
#define OCTOSPI_CR_FTHRES   OCTOSPI_CR_FTHRES_Msk
#define OCTOSPI_CR_TEIE_Pos   (16U)
#define OCTOSPI_CR_TEIE_Msk   (0x1UL << OCTOSPI_CR_TEIE_Pos)
#define OCTOSPI_CR_TEIE   OCTOSPI_CR_TEIE_Msk
#define OCTOSPI_CR_TCIE_Pos   (17U)
#define OCTOSPI_CR_TCIE_Msk   (0x1UL << OCTOSPI_CR_TCIE_Pos)
#define OCTOSPI_CR_TCIE   OCTOSPI_CR_TCIE_Msk
#define OCTOSPI_CR_FTIE_Pos   (18U)
#define OCTOSPI_CR_FTIE_Msk   (0x1UL << OCTOSPI_CR_FTIE_Pos)
#define OCTOSPI_CR_FTIE   OCTOSPI_CR_FTIE_Msk
#define OCTOSPI_CR_SMIE_Pos   (19U)
#define OCTOSPI_CR_SMIE_Msk   (0x1UL << OCTOSPI_CR_SMIE_Pos)
#define OCTOSPI_CR_SMIE   OCTOSPI_CR_SMIE_Msk
#define OCTOSPI_CR_TOIE_Pos   (20U)
#define OCTOSPI_CR_TOIE_Msk   (0x1UL << OCTOSPI_CR_TOIE_Pos)
#define OCTOSPI_CR_TOIE   OCTOSPI_CR_TOIE_Msk
#define OCTOSPI_CR_APMS_Pos   (22U)
#define OCTOSPI_CR_APMS_Msk   (0x1UL << OCTOSPI_CR_APMS_Pos)
#define OCTOSPI_CR_APMS   OCTOSPI_CR_APMS_Msk
#define OCTOSPI_CR_PMM_Pos   (23U)
#define OCTOSPI_CR_PMM_Msk   (0x1UL << OCTOSPI_CR_PMM_Pos)
#define OCTOSPI_CR_PMM   OCTOSPI_CR_PMM_Msk
#define OCTOSPI_CR_FMODE_Pos   (28U)
#define OCTOSPI_CR_FMODE_Msk   (0x3UL << OCTOSPI_CR_FMODE_Pos)
#define OCTOSPI_CR_FMODE   OCTOSPI_CR_FMODE_Msk
#define OCTOSPI_CR_FMODE_0   (0x1UL << OCTOSPI_CR_FMODE_Pos)
#define OCTOSPI_CR_FMODE_1   (0x2UL << OCTOSPI_CR_FMODE_Pos)
#define OCTOSPI_DCR1_CKMODE_Pos   (0U)
#define OCTOSPI_DCR1_CKMODE_Msk   (0x1UL << OCTOSPI_DCR1_CKMODE_Pos)
#define OCTOSPI_DCR1_CKMODE   OCTOSPI_DCR1_CKMODE_Msk
#define OCTOSPI_DCR1_FRCK_Pos   (1U)
#define OCTOSPI_DCR1_FRCK_Msk   (0x1UL << OCTOSPI_DCR1_FRCK_Pos)
#define OCTOSPI_DCR1_FRCK   OCTOSPI_DCR1_FRCK_Msk
#define OCTOSPI_DCR1_DLYBYP_Pos   (3U)
#define OCTOSPI_DCR1_DLYBYP_Msk   (0x1UL << OCTOSPI_DCR1_DLYBYP_Pos)
#define OCTOSPI_DCR1_DLYBYP   OCTOSPI_DCR1_DLYBYP_Msk
#define OCTOSPI_DCR1_CSHT_Pos   (8U)
#define OCTOSPI_DCR1_CSHT_Msk   (0x7UL << OCTOSPI_DCR1_CSHT_Pos)
#define OCTOSPI_DCR1_CSHT   OCTOSPI_DCR1_CSHT_Msk
#define OCTOSPI_DCR1_DEVSIZE_Pos   (16U)
#define OCTOSPI_DCR1_DEVSIZE_Msk   (0x1FUL << OCTOSPI_DCR1_DEVSIZE_Pos)
#define OCTOSPI_DCR1_DEVSIZE   OCTOSPI_DCR1_DEVSIZE_Msk
#define OCTOSPI_DCR1_MTYP_Pos   (24U)
#define OCTOSPI_DCR1_MTYP_Msk   (0x7UL << OCTOSPI_DCR1_MTYP_Pos)
#define OCTOSPI_DCR1_MTYP   OCTOSPI_DCR1_MTYP_Msk
#define OCTOSPI_DCR1_MTYP_0   (0x1UL << OCTOSPI_DCR1_MTYP_Pos)
#define OCTOSPI_DCR1_MTYP_1   (0x2UL << OCTOSPI_DCR1_MTYP_Pos)
#define OCTOSPI_DCR1_MTYP_2   (0x4UL << OCTOSPI_DCR1_MTYP_Pos)
#define OCTOSPI_DCR1_CKCSHT_Pos   (4U)
#define OCTOSPI_DCR1_CKCSHT_Msk   (0x7UL << OCTOSPI_DCR1_CKCSHT_Pos)
#define OCTOSPI_DCR1_CKCSHT   OCTOSPI_DCR1_CKCSHT_Msk
#define OCTOSPI_DCR2_PRESCALER_Pos   (0U)
#define OCTOSPI_DCR2_PRESCALER_Msk   (0xFFUL << OCTOSPI_DCR2_PRESCALER_Pos)
#define OCTOSPI_DCR2_PRESCALER   OCTOSPI_DCR2_PRESCALER_Msk
#define OCTOSPI_DCR2_WRAPSIZE_Pos   (16U)
#define OCTOSPI_DCR2_WRAPSIZE_Msk   (0x7UL << OCTOSPI_DCR2_WRAPSIZE_Pos)
#define OCTOSPI_DCR2_WRAPSIZE   OCTOSPI_DCR2_WRAPSIZE_Msk
#define OCTOSPI_DCR2_WRAPSIZE_0   (0x1UL << OCTOSPI_DCR2_WRAPSIZE_Pos)
#define OCTOSPI_DCR2_WRAPSIZE_1   (0x2UL << OCTOSPI_DCR2_WRAPSIZE_Pos)
#define OCTOSPI_DCR2_WRAPSIZE_2   (0x4UL << OCTOSPI_DCR2_WRAPSIZE_Pos)
#define OCTOSPI_DCR3_MAXTRAN_Pos   (0U)
#define OCTOSPI_DCR3_MAXTRAN_Msk   (0xFFUL << OCTOSPI_DCR3_MAXTRAN_Pos)
#define OCTOSPI_DCR3_MAXTRAN   OCTOSPI_DCR3_MAXTRAN_Msk
#define OCTOSPI_DCR3_CSBOUND_Pos   (16U)
#define OCTOSPI_DCR3_CSBOUND_Msk   (0x1FUL << OCTOSPI_DCR3_CSBOUND_Pos)
#define OCTOSPI_DCR3_CSBOUND   OCTOSPI_DCR3_CSBOUND_Msk
#define OCTOSPI_DCR4_REFRESH_Pos   (0U)
#define OCTOSPI_DCR4_REFRESH_Msk   (0xFFFFFFFFUL << OCTOSPI_DCR4_REFRESH_Pos)
#define OCTOSPI_DCR4_REFRESH   OCTOSPI_DCR4_REFRESH_Msk
#define OCTOSPI_SR_TEF_Pos   (0U)
#define OCTOSPI_SR_TEF_Msk   (0x1UL << OCTOSPI_SR_TEF_Pos)
#define OCTOSPI_SR_TEF   OCTOSPI_SR_TEF_Msk
#define OCTOSPI_SR_TCF_Pos   (1U)
#define OCTOSPI_SR_TCF_Msk   (0x1UL << OCTOSPI_SR_TCF_Pos)
#define OCTOSPI_SR_TCF   OCTOSPI_SR_TCF_Msk
#define OCTOSPI_SR_FTF_Pos   (2U)
#define OCTOSPI_SR_FTF_Msk   (0x1UL << OCTOSPI_SR_FTF_Pos)
#define OCTOSPI_SR_FTF   OCTOSPI_SR_FTF_Msk
#define OCTOSPI_SR_SMF_Pos   (3U)
#define OCTOSPI_SR_SMF_Msk   (0x1UL << OCTOSPI_SR_SMF_Pos)
#define OCTOSPI_SR_SMF   OCTOSPI_SR_SMF_Msk
#define OCTOSPI_SR_TOF_Pos   (4U)
#define OCTOSPI_SR_TOF_Msk   (0x1UL << OCTOSPI_SR_TOF_Pos)
#define OCTOSPI_SR_TOF   OCTOSPI_SR_TOF_Msk
#define OCTOSPI_SR_BUSY_Pos   (5U)
#define OCTOSPI_SR_BUSY_Msk   (0x1UL << OCTOSPI_SR_BUSY_Pos)
#define OCTOSPI_SR_BUSY   OCTOSPI_SR_BUSY_Msk
#define OCTOSPI_SR_FLEVEL_Pos   (8U)
#define OCTOSPI_SR_FLEVEL_Msk   (0x3FUL << OCTOSPI_SR_FLEVEL_Pos)
#define OCTOSPI_SR_FLEVEL   OCTOSPI_SR_FLEVEL_Msk
#define OCTOSPI_FCR_CTEF_Pos   (0U)
#define OCTOSPI_FCR_CTEF_Msk   (0x1UL << OCTOSPI_FCR_CTEF_Pos)
#define OCTOSPI_FCR_CTEF   OCTOSPI_FCR_CTEF_Msk
#define OCTOSPI_FCR_CTCF_Pos   (1U)
#define OCTOSPI_FCR_CTCF_Msk   (0x1UL << OCTOSPI_FCR_CTCF_Pos)
#define OCTOSPI_FCR_CTCF   OCTOSPI_FCR_CTCF_Msk
#define OCTOSPI_FCR_CSMF_Pos   (3U)
#define OCTOSPI_FCR_CSMF_Msk   (0x1UL << OCTOSPI_FCR_CSMF_Pos)
#define OCTOSPI_FCR_CSMF   OCTOSPI_FCR_CSMF_Msk
#define OCTOSPI_FCR_CTOF_Pos   (4U)
#define OCTOSPI_FCR_CTOF_Msk   (0x1UL << OCTOSPI_FCR_CTOF_Pos)
#define OCTOSPI_FCR_CTOF   OCTOSPI_FCR_CTOF_Msk
#define OCTOSPI_DLR_DL_Pos   (0U)
#define OCTOSPI_DLR_DL_Msk   (0xFFFFFFFFUL << OCTOSPI_DLR_DL_Pos)
#define OCTOSPI_DLR_DL   OCTOSPI_DLR_DL_Msk
#define OCTOSPI_AR_ADDRESS_Pos   (0U)
#define OCTOSPI_AR_ADDRESS_Msk   (0xFFFFFFFFUL << OCTOSPI_AR_ADDRESS_Pos)
#define OCTOSPI_AR_ADDRESS   OCTOSPI_AR_ADDRESS_Msk
#define OCTOSPI_DR_DATA_Pos   (0U)
#define OCTOSPI_DR_DATA_Msk   (0xFFFFFFFFUL << OCTOSPI_DR_DATA_Pos)
#define OCTOSPI_DR_DATA   OCTOSPI_DR_DATA_Msk
#define OCTOSPI_PSMKR_MASK_Pos   (0U)
#define OCTOSPI_PSMKR_MASK_Msk   (0xFFFFFFFFUL << OCTOSPI_PSMKR_MASK_Pos)
#define OCTOSPI_PSMKR_MASK   OCTOSPI_PSMKR_MASK_Msk
#define OCTOSPI_PSMAR_MATCH_Pos   (0U)
#define OCTOSPI_PSMAR_MATCH_Msk   (0xFFFFFFFFUL << OCTOSPI_PSMAR_MATCH_Pos)
#define OCTOSPI_PSMAR_MATCH   OCTOSPI_PSMAR_MATCH_Msk
#define OCTOSPI_PIR_INTERVAL_Pos   (0U)
#define OCTOSPI_PIR_INTERVAL_Msk   (0xFFFFUL << OCTOSPI_PIR_INTERVAL_Pos)
#define OCTOSPI_PIR_INTERVAL   OCTOSPI_PIR_INTERVAL_Msk
#define OCTOSPI_CCR_IMODE_Pos   (0U)
#define OCTOSPI_CCR_IMODE_Msk   (0x7UL << OCTOSPI_CCR_IMODE_Pos)
#define OCTOSPI_CCR_IMODE   OCTOSPI_CCR_IMODE_Msk
#define OCTOSPI_CCR_IMODE_0   (0x1UL << OCTOSPI_CCR_IMODE_Pos)
#define OCTOSPI_CCR_IMODE_1   (0x2UL << OCTOSPI_CCR_IMODE_Pos)
#define OCTOSPI_CCR_IMODE_2   (0x4UL << OCTOSPI_CCR_IMODE_Pos)
#define OCTOSPI_CCR_IDTR_Pos   (3U)
#define OCTOSPI_CCR_IDTR_Msk   (0x1UL << OCTOSPI_CCR_IDTR_Pos)
#define OCTOSPI_CCR_IDTR   OCTOSPI_CCR_IDTR_Msk
#define OCTOSPI_CCR_ISIZE_Pos   (4U)
#define OCTOSPI_CCR_ISIZE_Msk   (0x3UL << OCTOSPI_CCR_ISIZE_Pos)
#define OCTOSPI_CCR_ISIZE   OCTOSPI_CCR_ISIZE_Msk
#define OCTOSPI_CCR_ISIZE_0   (0x1UL << OCTOSPI_CCR_ISIZE_Pos)
#define OCTOSPI_CCR_ISIZE_1   (0x2UL << OCTOSPI_CCR_ISIZE_Pos)
#define OCTOSPI_CCR_ADMODE_Pos   (8U)
#define OCTOSPI_CCR_ADMODE_Msk   (0x7UL << OCTOSPI_CCR_ADMODE_Pos)
#define OCTOSPI_CCR_ADMODE   OCTOSPI_CCR_ADMODE_Msk
#define OCTOSPI_CCR_ADMODE_0   (0x1UL << OCTOSPI_CCR_ADMODE_Pos)
#define OCTOSPI_CCR_ADMODE_1   (0x2UL << OCTOSPI_CCR_ADMODE_Pos)
#define OCTOSPI_CCR_ADMODE_2   (0x4UL << OCTOSPI_CCR_ADMODE_Pos)
#define OCTOSPI_CCR_ADDTR_Pos   (11U)
#define OCTOSPI_CCR_ADDTR_Msk   (0x1UL << OCTOSPI_CCR_ADDTR_Pos)
#define OCTOSPI_CCR_ADDTR   OCTOSPI_CCR_ADDTR_Msk
#define OCTOSPI_CCR_ADSIZE_Pos   (12U)
#define OCTOSPI_CCR_ADSIZE_Msk   (0x3UL << OCTOSPI_CCR_ADSIZE_Pos)
#define OCTOSPI_CCR_ADSIZE   OCTOSPI_CCR_ADSIZE_Msk
#define OCTOSPI_CCR_ADSIZE_0   (0x1UL << OCTOSPI_CCR_ADSIZE_Pos)
#define OCTOSPI_CCR_ADSIZE_1   (0x2UL << OCTOSPI_CCR_ADSIZE_Pos)
#define OCTOSPI_CCR_ABMODE_Pos   (16U)
#define OCTOSPI_CCR_ABMODE_Msk   (0x7UL << OCTOSPI_CCR_ABMODE_Pos)
#define OCTOSPI_CCR_ABMODE   OCTOSPI_CCR_ABMODE_Msk
#define OCTOSPI_CCR_ABMODE_0   (0x1UL << OCTOSPI_CCR_ABMODE_Pos)
#define OCTOSPI_CCR_ABMODE_1   (0x2UL << OCTOSPI_CCR_ABMODE_Pos)
#define OCTOSPI_CCR_ABMODE_2   (0x4UL << OCTOSPI_CCR_ABMODE_Pos)
#define OCTOSPI_CCR_ABDTR_Pos   (19U)
#define OCTOSPI_CCR_ABDTR_Msk   (0x1UL << OCTOSPI_CCR_ABDTR_Pos)
#define OCTOSPI_CCR_ABDTR   OCTOSPI_CCR_ABDTR_Msk
#define OCTOSPI_CCR_ABSIZE_Pos   (20U)
#define OCTOSPI_CCR_ABSIZE_Msk   (0x3UL << OCTOSPI_CCR_ABSIZE_Pos)
#define OCTOSPI_CCR_ABSIZE   OCTOSPI_CCR_ABSIZE_Msk
#define OCTOSPI_CCR_ABSIZE_0   (0x1UL << OCTOSPI_CCR_ABSIZE_Pos)
#define OCTOSPI_CCR_ABSIZE_1   (0x2UL << OCTOSPI_CCR_ABSIZE_Pos)
#define OCTOSPI_CCR_DMODE_Pos   (24U)
#define OCTOSPI_CCR_DMODE_Msk   (0x7UL << OCTOSPI_CCR_DMODE_Pos)
#define OCTOSPI_CCR_DMODE   OCTOSPI_CCR_DMODE_Msk
#define OCTOSPI_CCR_DMODE_0   (0x1UL << OCTOSPI_CCR_DMODE_Pos)
#define OCTOSPI_CCR_DMODE_1   (0x2UL << OCTOSPI_CCR_DMODE_Pos)
#define OCTOSPI_CCR_DMODE_2   (0x4UL << OCTOSPI_CCR_DMODE_Pos)
#define OCTOSPI_CCR_DDTR_Pos   (27U)
#define OCTOSPI_CCR_DDTR_Msk   (0x1UL << OCTOSPI_CCR_DDTR_Pos)
#define OCTOSPI_CCR_DDTR   OCTOSPI_CCR_DDTR_Msk
#define OCTOSPI_CCR_DQSE_Pos   (29U)
#define OCTOSPI_CCR_DQSE_Msk   (0x1UL << OCTOSPI_CCR_DQSE_Pos)
#define OCTOSPI_CCR_DQSE   OCTOSPI_CCR_DQSE_Msk
#define OCTOSPI_CCR_SIOO_Pos   (31U)
#define OCTOSPI_CCR_SIOO_Msk   (0x1UL << OCTOSPI_CCR_SIOO_Pos)
#define OCTOSPI_CCR_SIOO   OCTOSPI_CCR_SIOO_Msk
#define OCTOSPI_TCR_DCYC_Pos   (0U)
#define OCTOSPI_TCR_DCYC_Msk   (0x1FUL << OCTOSPI_TCR_DCYC_Pos)
#define OCTOSPI_TCR_DCYC   OCTOSPI_TCR_DCYC_Msk
#define OCTOSPI_TCR_DHQC_Pos   (28U)
#define OCTOSPI_TCR_DHQC_Msk   (0x1UL << OCTOSPI_TCR_DHQC_Pos)
#define OCTOSPI_TCR_DHQC   OCTOSPI_TCR_DHQC_Msk
#define OCTOSPI_TCR_SSHIFT_Pos   (30U)
#define OCTOSPI_TCR_SSHIFT_Msk   (0x1UL << OCTOSPI_TCR_SSHIFT_Pos)
#define OCTOSPI_TCR_SSHIFT   OCTOSPI_TCR_SSHIFT_Msk
#define OCTOSPI_IR_INSTRUCTION_Pos   (0U)
#define OCTOSPI_IR_INSTRUCTION_Msk   (0xFFFFFFFFUL << OCTOSPI_IR_INSTRUCTION_Pos)
#define OCTOSPI_IR_INSTRUCTION   OCTOSPI_IR_INSTRUCTION_Msk
#define OCTOSPI_ABR_ALTERNATE_Pos   (0U)
#define OCTOSPI_ABR_ALTERNATE_Msk   (0xFFFFFFFFUL << OCTOSPI_ABR_ALTERNATE_Pos)
#define OCTOSPI_ABR_ALTERNATE   OCTOSPI_ABR_ALTERNATE_Msk
#define OCTOSPI_LPTR_TIMEOUT_Pos   (0U)
#define OCTOSPI_LPTR_TIMEOUT_Msk   (0xFFFFUL << OCTOSPI_LPTR_TIMEOUT_Pos)
#define OCTOSPI_LPTR_TIMEOUT   OCTOSPI_LPTR_TIMEOUT_Msk
#define OCTOSPI_WPCCR_IMODE_Pos   (0U)
#define OCTOSPI_WPCCR_IMODE_Msk   (0x7UL << OCTOSPI_WPCCR_IMODE_Pos)
#define OCTOSPI_WPCCR_IMODE   OCTOSPI_WPCCR_IMODE_Msk
#define OCTOSPI_WPCCR_IMODE_0   (0x1UL << OCTOSPI_WPCCR_IMODE_Pos)
#define OCTOSPI_WPCCR_IMODE_1   (0x2UL << OCTOSPI_WPCCR_IMODE_Pos)
#define OCTOSPI_WPCCR_IMODE_2   (0x4UL << OCTOSPI_WPCCR_IMODE_Pos)
#define OCTOSPI_WPCCR_IDTR_Pos   (3U)
#define OCTOSPI_WPCCR_IDTR_Msk   (0x1UL << OCTOSPI_WPCCR_IDTR_Pos)
#define OCTOSPI_WPCCR_IDTR   OCTOSPI_WPCCR_IDTR_Msk
#define OCTOSPI_WPCCR_ISIZE_Pos   (4U)
#define OCTOSPI_WPCCR_ISIZE_Msk   (0x3UL << OCTOSPI_WPCCR_ISIZE_Pos)
#define OCTOSPI_WPCCR_ISIZE   OCTOSPI_WPCCR_ISIZE_Msk
#define OCTOSPI_WPCCR_ISIZE_0   (0x1UL << OCTOSPI_WPCCR_ISIZE_Pos)
#define OCTOSPI_WPCCR_ISIZE_1   (0x2UL << OCTOSPI_WPCCR_ISIZE_Pos)
#define OCTOSPI_WPCCR_ADMODE_Pos   (8U)
#define OCTOSPI_WPCCR_ADMODE_Msk   (0x7UL << OCTOSPI_WPCCR_ADMODE_Pos)
#define OCTOSPI_WPCCR_ADMODE   OCTOSPI_WPCCR_ADMODE_Msk
#define OCTOSPI_WPCCR_ADMODE_0   (0x1UL << OCTOSPI_WPCCR_ADMODE_Pos)
#define OCTOSPI_WPCCR_ADMODE_1   (0x2UL << OCTOSPI_WPCCR_ADMODE_Pos)
#define OCTOSPI_WPCCR_ADMODE_2   (0x4UL << OCTOSPI_WPCCR_ADMODE_Pos)
#define OCTOSPI_WPCCR_ADDTR_Pos   (11U)
#define OCTOSPI_WPCCR_ADDTR_Msk   (0x1UL << OCTOSPI_WPCCR_ADDTR_Pos)
#define OCTOSPI_WPCCR_ADDTR   OCTOSPI_WPCCR_ADDTR_Msk
#define OCTOSPI_WPCCR_ADSIZE_Pos   (12U)
#define OCTOSPI_WPCCR_ADSIZE_Msk   (0x3UL << OCTOSPI_WPCCR_ADSIZE_Pos)
#define OCTOSPI_WPCCR_ADSIZE   OCTOSPI_WPCCR_ADSIZE_Msk
#define OCTOSPI_WPCCR_ADSIZE_0   (0x1UL << OCTOSPI_WPCCR_ADSIZE_Pos)
#define OCTOSPI_WPCCR_ADSIZE_1   (0x2UL << OCTOSPI_WPCCR_ADSIZE_Pos)
#define OCTOSPI_WPCCR_ABMODE_Pos   (16U)
#define OCTOSPI_WPCCR_ABMODE_Msk   (0x7UL << OCTOSPI_WPCCR_ABMODE_Pos)
#define OCTOSPI_WPCCR_ABMODE   OCTOSPI_WPCCR_ABMODE_Msk
#define OCTOSPI_WPCCR_ABMODE_0   (0x1UL << OCTOSPI_WPCCR_ABMODE_Pos)
#define OCTOSPI_WPCCR_ABMODE_1   (0x2UL << OCTOSPI_WPCCR_ABMODE_Pos)
#define OCTOSPI_WPCCR_ABMODE_2   (0x4UL << OCTOSPI_WPCCR_ABMODE_Pos)
#define OCTOSPI_WPCCR_ABDTR_Pos   (19U)
#define OCTOSPI_WPCCR_ABDTR_Msk   (0x1UL << OCTOSPI_WPCCR_ABDTR_Pos)
#define OCTOSPI_WPCCR_ABDTR   OCTOSPI_WPCCR_ABDTR_Msk
#define OCTOSPI_WPCCR_ABSIZE_Pos   (20U)
#define OCTOSPI_WPCCR_ABSIZE_Msk   (0x3UL << OCTOSPI_WPCCR_ABSIZE_Pos)
#define OCTOSPI_WPCCR_ABSIZE   OCTOSPI_WPCCR_ABSIZE_Msk
#define OCTOSPI_WPCCR_ABSIZE_0   (0x1UL << OCTOSPI_WPCCR_ABSIZE_Pos)
#define OCTOSPI_WPCCR_ABSIZE_1   (0x2UL << OCTOSPI_WPCCR_ABSIZE_Pos)
#define OCTOSPI_WPCCR_DMODE_Pos   (24U)
#define OCTOSPI_WPCCR_DMODE_Msk   (0x7UL << OCTOSPI_WPCCR_DMODE_Pos)
#define OCTOSPI_WPCCR_DMODE   OCTOSPI_WPCCR_DMODE_Msk
#define OCTOSPI_WPCCR_DMODE_0   (0x1UL << OCTOSPI_WPCCR_DMODE_Pos)
#define OCTOSPI_WPCCR_DMODE_1   (0x2UL << OCTOSPI_WPCCR_DMODE_Pos)
#define OCTOSPI_WPCCR_DMODE_2   (0x4UL << OCTOSPI_WPCCR_DMODE_Pos)
#define OCTOSPI_WPCCR_DDTR_Pos   (27U)
#define OCTOSPI_WPCCR_DDTR_Msk   (0x1UL << OCTOSPI_WPCCR_DDTR_Pos)
#define OCTOSPI_WPCCR_DDTR   OCTOSPI_WPCCR_DDTR_Msk
#define OCTOSPI_WPCCR_DQSE_Pos   (29U)
#define OCTOSPI_WPCCR_DQSE_Msk   (0x1UL << OCTOSPI_WPCCR_DQSE_Pos)
#define OCTOSPI_WPCCR_DQSE   OCTOSPI_WPCCR_DQSE_Msk
#define OCTOSPI_WPCCR_SIOO_Pos   (31U)
#define OCTOSPI_WPCCR_SIOO_Msk   (0x1UL << OCTOSPI_WPCCR_SIOO_Pos)
#define OCTOSPI_WPCCR_SIOO   OCTOSPI_WPCCR_SIOO_Msk
#define OCTOSPI_WPTCR_DCYC_Pos   (0U)
#define OCTOSPI_WPTCR_DCYC_Msk   (0x1FUL << OCTOSPI_WPTCR_DCYC_Pos)
#define OCTOSPI_WPTCR_DCYC   OCTOSPI_WPTCR_DCYC_Msk
#define OCTOSPI_WPTCR_DHQC_Pos   (28U)
#define OCTOSPI_WPTCR_DHQC_Msk   (0x1UL << OCTOSPI_WPTCR_DHQC_Pos)
#define OCTOSPI_WPTCR_DHQC   OCTOSPI_WPTCR_DHQC_Msk
#define OCTOSPI_WPTCR_SSHIFT_Pos   (30U)
#define OCTOSPI_WPTCR_SSHIFT_Msk   (0x1UL << OCTOSPI_WPTCR_SSHIFT_Pos)
#define OCTOSPI_WPTCR_SSHIFT   OCTOSPI_WPTCR_SSHIFT_Msk
#define OCTOSPI_WPIR_INSTRUCTION_Pos   (0U)
#define OCTOSPI_WPIR_INSTRUCTION_Msk   (0xFFFFFFFFUL << OCTOSPI_WPIR_INSTRUCTION_Pos)
#define OCTOSPI_WPIR_INSTRUCTION   OCTOSPI_WPIR_INSTRUCTION_Msk
#define OCTOSPI_WPABR_ALTERNATE_Pos   (0U)
#define OCTOSPI_WPABR_ALTERNATE_Msk   (0xFFFFFFFFUL << OCTOSPI_WPABR_ALTERNATE_Pos)
#define OCTOSPI_WPABR_ALTERNATE   OCTOSPI_WPABR_ALTERNATE_Msk
#define OCTOSPI_WCCR_IMODE_Pos   (0U)
#define OCTOSPI_WCCR_IMODE_Msk   (0x7UL << OCTOSPI_WCCR_IMODE_Pos)
#define OCTOSPI_WCCR_IMODE   OCTOSPI_WCCR_IMODE_Msk
#define OCTOSPI_WCCR_IMODE_0   (0x1UL << OCTOSPI_WCCR_IMODE_Pos)
#define OCTOSPI_WCCR_IMODE_1   (0x2UL << OCTOSPI_WCCR_IMODE_Pos)
#define OCTOSPI_WCCR_IMODE_2   (0x4UL << OCTOSPI_WCCR_IMODE_Pos)
#define OCTOSPI_WCCR_IDTR_Pos   (3U)
#define OCTOSPI_WCCR_IDTR_Msk   (0x1UL << OCTOSPI_WCCR_IDTR_Pos)
#define OCTOSPI_WCCR_IDTR   OCTOSPI_WCCR_IDTR_Msk
#define OCTOSPI_WCCR_ISIZE_Pos   (4U)
#define OCTOSPI_WCCR_ISIZE_Msk   (0x3UL << OCTOSPI_WCCR_ISIZE_Pos)
#define OCTOSPI_WCCR_ISIZE   OCTOSPI_WCCR_ISIZE_Msk
#define OCTOSPI_WCCR_ISIZE_0   (0x1UL << OCTOSPI_WCCR_ISIZE_Pos)
#define OCTOSPI_WCCR_ISIZE_1   (0x2UL << OCTOSPI_WCCR_ISIZE_Pos)
#define OCTOSPI_WCCR_ADMODE_Pos   (8U)
#define OCTOSPI_WCCR_ADMODE_Msk   (0x7UL << OCTOSPI_WCCR_ADMODE_Pos)
#define OCTOSPI_WCCR_ADMODE   OCTOSPI_WCCR_ADMODE_Msk
#define OCTOSPI_WCCR_ADMODE_0   (0x1UL << OCTOSPI_WCCR_ADMODE_Pos)
#define OCTOSPI_WCCR_ADMODE_1   (0x2UL << OCTOSPI_WCCR_ADMODE_Pos)
#define OCTOSPI_WCCR_ADMODE_2   (0x4UL << OCTOSPI_WCCR_ADMODE_Pos)
#define OCTOSPI_WCCR_ADDTR_Pos   (11U)
#define OCTOSPI_WCCR_ADDTR_Msk   (0x1UL << OCTOSPI_WCCR_ADDTR_Pos)
#define OCTOSPI_WCCR_ADDTR   OCTOSPI_WCCR_ADDTR_Msk
#define OCTOSPI_WCCR_ADSIZE_Pos   (12U)
#define OCTOSPI_WCCR_ADSIZE_Msk   (0x3UL << OCTOSPI_WCCR_ADSIZE_Pos)
#define OCTOSPI_WCCR_ADSIZE   OCTOSPI_WCCR_ADSIZE_Msk
#define OCTOSPI_WCCR_ADSIZE_0   (0x1UL << OCTOSPI_WCCR_ADSIZE_Pos)
#define OCTOSPI_WCCR_ADSIZE_1   (0x2UL << OCTOSPI_WCCR_ADSIZE_Pos)
#define OCTOSPI_WCCR_ABMODE_Pos   (16U)
#define OCTOSPI_WCCR_ABMODE_Msk   (0x7UL << OCTOSPI_WCCR_ABMODE_Pos)
#define OCTOSPI_WCCR_ABMODE   OCTOSPI_WCCR_ABMODE_Msk
#define OCTOSPI_WCCR_ABMODE_0   (0x1UL << OCTOSPI_WCCR_ABMODE_Pos)
#define OCTOSPI_WCCR_ABMODE_1   (0x2UL << OCTOSPI_WCCR_ABMODE_Pos)
#define OCTOSPI_WCCR_ABMODE_2   (0x4UL << OCTOSPI_WCCR_ABMODE_Pos)
#define OCTOSPI_WCCR_ABDTR_Pos   (19U)
#define OCTOSPI_WCCR_ABDTR_Msk   (0x1UL << OCTOSPI_WCCR_ABDTR_Pos)
#define OCTOSPI_WCCR_ABDTR   OCTOSPI_WCCR_ABDTR_Msk
#define OCTOSPI_WCCR_ABSIZE_Pos   (20U)
#define OCTOSPI_WCCR_ABSIZE_Msk   (0x3UL << OCTOSPI_WCCR_ABSIZE_Pos)
#define OCTOSPI_WCCR_ABSIZE   OCTOSPI_WCCR_ABSIZE_Msk
#define OCTOSPI_WCCR_ABSIZE_0   (0x1UL << OCTOSPI_WCCR_ABSIZE_Pos)
#define OCTOSPI_WCCR_ABSIZE_1   (0x2UL << OCTOSPI_WCCR_ABSIZE_Pos)
#define OCTOSPI_WCCR_DMODE_Pos   (24U)
#define OCTOSPI_WCCR_DMODE_Msk   (0x7UL << OCTOSPI_WCCR_DMODE_Pos)
#define OCTOSPI_WCCR_DMODE   OCTOSPI_WCCR_DMODE_Msk
#define OCTOSPI_WCCR_DMODE_0   (0x1UL << OCTOSPI_WCCR_DMODE_Pos)
#define OCTOSPI_WCCR_DMODE_1   (0x2UL << OCTOSPI_WCCR_DMODE_Pos)
#define OCTOSPI_WCCR_DMODE_2   (0x4UL << OCTOSPI_WCCR_DMODE_Pos)
#define OCTOSPI_WCCR_DDTR_Pos   (27U)
#define OCTOSPI_WCCR_DDTR_Msk   (0x1UL << OCTOSPI_WCCR_DDTR_Pos)
#define OCTOSPI_WCCR_DDTR   OCTOSPI_WCCR_DDTR_Msk
#define OCTOSPI_WCCR_DQSE_Pos   (29U)
#define OCTOSPI_WCCR_DQSE_Msk   (0x1UL << OCTOSPI_WCCR_DQSE_Pos)
#define OCTOSPI_WCCR_DQSE   OCTOSPI_WCCR_DQSE_Msk
#define OCTOSPI_WCCR_SIOO_Pos   (31U)
#define OCTOSPI_WCCR_SIOO_Msk   (0x1UL << OCTOSPI_WCCR_SIOO_Pos)
#define OCTOSPI_WCCR_SIOO   OCTOSPI_WCCR_SIOO_Msk
#define OCTOSPI_WTCR_DCYC_Pos   (0U)
#define OCTOSPI_WTCR_DCYC_Msk   (0x1FUL << OCTOSPI_WTCR_DCYC_Pos)
#define OCTOSPI_WTCR_DCYC   OCTOSPI_WTCR_DCYC_Msk
#define OCTOSPI_WIR_INSTRUCTION_Pos   (0U)
#define OCTOSPI_WIR_INSTRUCTION_Msk   (0xFFFFFFFFUL << OCTOSPI_WIR_INSTRUCTION_Pos)
#define OCTOSPI_WIR_INSTRUCTION   OCTOSPI_WIR_INSTRUCTION_Msk
#define OCTOSPI_WABR_ALTERNATE_Pos   (0U)
#define OCTOSPI_WABR_ALTERNATE_Msk   (0xFFFFFFFFUL << OCTOSPI_WABR_ALTERNATE_Pos)
#define OCTOSPI_WABR_ALTERNATE   OCTOSPI_WABR_ALTERNATE_Msk
#define OCTOSPI_HLCR_LM_Pos   (0U)
#define OCTOSPI_HLCR_LM_Msk   (0x1UL << OCTOSPI_HLCR_LM_Pos)
#define OCTOSPI_HLCR_LM   OCTOSPI_HLCR_LM_Msk
#define OCTOSPI_HLCR_WZL_Pos   (1U)
#define OCTOSPI_HLCR_WZL_Msk   (0x1UL << OCTOSPI_HLCR_WZL_Pos)
#define OCTOSPI_HLCR_WZL   OCTOSPI_HLCR_WZL_Msk
#define OCTOSPI_HLCR_TACC_Pos   (8U)
#define OCTOSPI_HLCR_TACC_Msk   (0xFFUL << OCTOSPI_HLCR_TACC_Pos)
#define OCTOSPI_HLCR_TACC   OCTOSPI_HLCR_TACC_Msk
#define OCTOSPI_HLCR_TRWR_Pos   (16U)
#define OCTOSPI_HLCR_TRWR_Msk   (0xFFUL << OCTOSPI_HLCR_TRWR_Pos)
#define OCTOSPI_HLCR_TRWR   OCTOSPI_HLCR_TRWR_Msk
#define OCTOSPI_VER_VER_Pos   (0U)
#define OCTOSPI_VER_VER_Msk   (0xFFUL << OCTOSPI_VER_VER_Pos)
#define OCTOSPI_VER_VER   OCTOSPI_VER_VER_Msk
#define OCTOSPI_ID_ID_Pos   (0U)
#define OCTOSPI_ID_ID_Msk   (0xFFFFFFFFUL << OCTOSPI_ID_ID_Pos)
#define OCTOSPI_ID_ID   OCTOSPI_ID_ID_Msk
#define OCTOSPI_MID_MID_Pos   (0U)
#define OCTOSPI_MID_MID_Msk   (0xFFFFFFFFUL << OCTOSPI_MID_MID_Pos)
#define OCTOSPI_MID_MID   OCTOSPI_MID_MID_Msk
#define OCTOSPIM_CR_MUXEN_Pos   (0U)
#define OCTOSPIM_CR_MUXEN_Msk   (0x1UL << OCTOSPIM_CR_MUXEN_Pos)
#define OCTOSPIM_CR_MUXEN   OCTOSPIM_CR_MUXEN_Msk
#define OCTOSPIM_CR_REQ2ACK_TIME_Pos   (16U)
#define OCTOSPIM_CR_REQ2ACK_TIME_Msk   (0xFFUL << OCTOSPIM_CR_REQ2ACK_TIME_Pos)
#define OCTOSPIM_CR_REQ2ACK_TIME   OCTOSPIM_CR_REQ2ACK_TIME_Msk
#define OCTOSPIM_PCR_CLKEN_Pos   (0U)
#define OCTOSPIM_PCR_CLKEN_Msk   (0x1UL << OCTOSPIM_PCR_CLKEN_Pos)
#define OCTOSPIM_PCR_CLKEN   OCTOSPIM_PCR_CLKEN_Msk
#define OCTOSPIM_PCR_CLKSRC_Pos   (1U)
#define OCTOSPIM_PCR_CLKSRC_Msk   (0x1UL << OCTOSPIM_PCR_CLKSRC_Pos)
#define OCTOSPIM_PCR_CLKSRC   OCTOSPIM_PCR_CLKSRC_Msk
#define OCTOSPIM_PCR_DQSEN_Pos   (4U)
#define OCTOSPIM_PCR_DQSEN_Msk   (0x1UL << OCTOSPIM_PCR_DQSEN_Pos)
#define OCTOSPIM_PCR_DQSEN   OCTOSPIM_PCR_DQSEN_Msk
#define OCTOSPIM_PCR_DQSSRC_Pos   (5U)
#define OCTOSPIM_PCR_DQSSRC_Msk   (0x1UL << OCTOSPIM_PCR_DQSSRC_Pos)
#define OCTOSPIM_PCR_DQSSRC   OCTOSPIM_PCR_DQSSRC_Msk
#define OCTOSPIM_PCR_NCSEN_Pos   (8U)
#define OCTOSPIM_PCR_NCSEN_Msk   (0x1UL << OCTOSPIM_PCR_NCSEN_Pos)
#define OCTOSPIM_PCR_NCSEN   OCTOSPIM_PCR_NCSEN_Msk
#define OCTOSPIM_PCR_NCSSRC_Pos   (9U)
#define OCTOSPIM_PCR_NCSSRC_Msk   (0x1UL << OCTOSPIM_PCR_NCSSRC_Pos)
#define OCTOSPIM_PCR_NCSSRC   OCTOSPIM_PCR_NCSSRC_Msk
#define OCTOSPIM_PCR_IOLEN_Pos   (16U)
#define OCTOSPIM_PCR_IOLEN_Msk   (0x1UL << OCTOSPIM_PCR_IOLEN_Pos)
#define OCTOSPIM_PCR_IOLEN   OCTOSPIM_PCR_IOLEN_Msk
#define OCTOSPIM_PCR_IOLSRC_Pos   (17U)
#define OCTOSPIM_PCR_IOLSRC_Msk   (0x3UL << OCTOSPIM_PCR_IOLSRC_Pos)
#define OCTOSPIM_PCR_IOLSRC   OCTOSPIM_PCR_IOLSRC_Msk
#define OCTOSPIM_PCR_IOLSRC_0   (0x1UL << OCTOSPIM_PCR_IOLSRC_Pos)
#define OCTOSPIM_PCR_IOLSRC_1   (0x2UL << OCTOSPIM_PCR_IOLSRC_Pos)
#define OCTOSPIM_PCR_IOHEN_Pos   (24U)
#define OCTOSPIM_PCR_IOHEN_Msk   (0x1UL << OCTOSPIM_PCR_IOHEN_Pos)
#define OCTOSPIM_PCR_IOHEN   OCTOSPIM_PCR_IOHEN_Msk
#define OCTOSPIM_PCR_IOHSRC_Pos   (25U)
#define OCTOSPIM_PCR_IOHSRC_Msk   (0x3UL << OCTOSPIM_PCR_IOHSRC_Pos)
#define OCTOSPIM_PCR_IOHSRC   OCTOSPIM_PCR_IOHSRC_Msk
#define OCTOSPIM_PCR_IOHSRC_0   (0x1UL << OCTOSPIM_PCR_IOHSRC_Pos)
#define OCTOSPIM_PCR_IOHSRC_1   (0x2UL << OCTOSPIM_PCR_IOHSRC_Pos)
#define COMP_SR_C1VAL_Pos   (0U)
#define COMP_SR_C1VAL_Msk   (0x1UL << COMP_SR_C1VAL_Pos)
#define COMP_SR_C1VAL   COMP_SR_C1VAL_Msk
#define COMP_SR_C2VAL_Pos   (1U)
#define COMP_SR_C2VAL_Msk   (0x1UL << COMP_SR_C2VAL_Pos)
#define COMP_SR_C2VAL   COMP_SR_C2VAL_Msk
#define COMP_SR_C1IF_Pos   (16U)
#define COMP_SR_C1IF_Msk   (0x1UL << COMP_SR_C1IF_Pos)
#define COMP_SR_C1IF   COMP_SR_C1IF_Msk
#define COMP_SR_C2IF_Pos   (17U)
#define COMP_SR_C2IF_Msk   (0x1UL << COMP_SR_C2IF_Pos)
#define COMP_SR_C2IF   COMP_SR_C2IF_Msk
#define COMP_ICFR_C1IF_Pos   (16U)
#define COMP_ICFR_C1IF_Msk   (0x1UL << COMP_ICFR_C1IF_Pos)
#define COMP_ICFR_C1IF   COMP_ICFR_C1IF_Msk
#define COMP_ICFR_C2IF_Pos   (17U)
#define COMP_ICFR_C2IF_Msk   (0x1UL << COMP_ICFR_C2IF_Pos)
#define COMP_ICFR_C2IF   COMP_ICFR_C2IF_Msk
#define COMP_OR_AFOPA6_Pos   (0U)
#define COMP_OR_AFOPA6_Msk   (0x1UL << COMP_OR_AFOPA6_Pos)
#define COMP_OR_AFOPA6   COMP_OR_AFOPA6_Msk
#define COMP_OR_AFOPA8_Pos   (1U)
#define COMP_OR_AFOPA8_Msk   (0x1UL << COMP_OR_AFOPA8_Pos)
#define COMP_OR_AFOPA8   COMP_OR_AFOPA8_Msk
#define COMP_OR_AFOPB12_Pos   (2U)
#define COMP_OR_AFOPB12_Msk   (0x1UL << COMP_OR_AFOPB12_Pos)
#define COMP_OR_AFOPB12   COMP_OR_AFOPB12_Msk
#define COMP_OR_AFOPE6_Pos   (3U)
#define COMP_OR_AFOPE6_Msk   (0x1UL << COMP_OR_AFOPE6_Pos)
#define COMP_OR_AFOPE6   COMP_OR_AFOPE6_Msk
#define COMP_OR_AFOPE15_Pos   (4U)
#define COMP_OR_AFOPE15_Msk   (0x1UL << COMP_OR_AFOPE15_Pos)
#define COMP_OR_AFOPE15   COMP_OR_AFOPE15_Msk
#define COMP_OR_AFOPG2_Pos   (5U)
#define COMP_OR_AFOPG2_Msk   (0x1UL << COMP_OR_AFOPG2_Pos)
#define COMP_OR_AFOPG2   COMP_OR_AFOPG2_Msk
#define COMP_OR_AFOPG3_Pos   (6U)
#define COMP_OR_AFOPG3_Msk   (0x1UL << COMP_OR_AFOPG3_Pos)
#define COMP_OR_AFOPG3   COMP_OR_AFOPG3_Msk
#define COMP_OR_AFOPG4_Pos   (7U)
#define COMP_OR_AFOPG4_Msk   (0x1UL << COMP_OR_AFOPG4_Pos)
#define COMP_OR_AFOPG4   COMP_OR_AFOPG4_Msk
#define COMP_OR_AFOPI1_Pos   (8U)
#define COMP_OR_AFOPI1_Msk   (0x1UL << COMP_OR_AFOPI1_Pos)
#define COMP_OR_AFOPI1   COMP_OR_AFOPI1_Msk
#define COMP_OR_AFOPI4_Pos   (9U)
#define COMP_OR_AFOPI4_Msk   (0x1UL << COMP_OR_AFOPI4_Pos)
#define COMP_OR_AFOPI4   COMP_OR_AFOPI4_Msk
#define COMP_OR_AFOPK2_Pos   (10U)
#define COMP_OR_AFOPK2_Msk   (0x1UL << COMP_OR_AFOPK2_Pos)
#define COMP_OR_AFOPK2   COMP_OR_AFOPK2_Msk
#define COMP_CFGRx_EN_Pos   (0U)
#define COMP_CFGRx_EN_Msk   (0x1UL << COMP_CFGRx_EN_Pos)
#define COMP_CFGRx_EN   COMP_CFGRx_EN_Msk
#define COMP_CFGRx_BRGEN_Pos   (1U)
#define COMP_CFGRx_BRGEN_Msk   (0x1UL << COMP_CFGRx_BRGEN_Pos)
#define COMP_CFGRx_BRGEN   COMP_CFGRx_BRGEN_Msk
#define COMP_CFGRx_SCALEN_Pos   (2U)
#define COMP_CFGRx_SCALEN_Msk   (0x1UL << COMP_CFGRx_SCALEN_Pos)
#define COMP_CFGRx_SCALEN   COMP_CFGRx_SCALEN_Msk
#define COMP_CFGRx_POLARITY_Pos   (3U)
#define COMP_CFGRx_POLARITY_Msk   (0x1UL << COMP_CFGRx_POLARITY_Pos)
#define COMP_CFGRx_POLARITY   COMP_CFGRx_POLARITY_Msk
#define COMP_CFGRx_WINMODE_Pos   (4U)
#define COMP_CFGRx_WINMODE_Msk   (0x1UL << COMP_CFGRx_WINMODE_Pos)
#define COMP_CFGRx_WINMODE   COMP_CFGRx_WINMODE_Msk
#define COMP_CFGRx_ITEN_Pos   (6U)
#define COMP_CFGRx_ITEN_Msk   (0x1UL << COMP_CFGRx_ITEN_Pos)
#define COMP_CFGRx_ITEN   COMP_CFGRx_ITEN_Msk
#define COMP_CFGRx_HYST_Pos   (8U)
#define COMP_CFGRx_HYST_Msk   (0x3UL << COMP_CFGRx_HYST_Pos)
#define COMP_CFGRx_HYST   COMP_CFGRx_HYST_Msk
#define COMP_CFGRx_HYST_0   (0x1UL << COMP_CFGRx_HYST_Pos)
#define COMP_CFGRx_HYST_1   (0x2UL << COMP_CFGRx_HYST_Pos)
#define COMP_CFGRx_PWRMODE_Pos   (12U)
#define COMP_CFGRx_PWRMODE_Msk   (0x3UL << COMP_CFGRx_PWRMODE_Pos)
#define COMP_CFGRx_PWRMODE   COMP_CFGRx_PWRMODE_Msk
#define COMP_CFGRx_PWRMODE_0   (0x1UL << COMP_CFGRx_PWRMODE_Pos)
#define COMP_CFGRx_PWRMODE_1   (0x2UL << COMP_CFGRx_PWRMODE_Pos)
#define COMP_CFGRx_INMSEL_Pos   (16U)
#define COMP_CFGRx_INMSEL_Msk   (0xFUL << COMP_CFGRx_INMSEL_Pos)
#define COMP_CFGRx_INMSEL   COMP_CFGRx_INMSEL_Msk
#define COMP_CFGRx_INMSEL_0   (0x1UL << COMP_CFGRx_INMSEL_Pos)
#define COMP_CFGRx_INMSEL_1   (0x2UL << COMP_CFGRx_INMSEL_Pos)
#define COMP_CFGRx_INMSEL_2   (0x4UL << COMP_CFGRx_INMSEL_Pos)
#define COMP_CFGRx_INMSEL_3   (0x8UL << COMP_CFGRx_INMSEL_Pos)
#define COMP_CFGRx_INPSEL_Pos   (20U)
#define COMP_CFGRx_INPSEL_Msk   (0x1UL << COMP_CFGRx_INPSEL_Pos)
#define COMP_CFGRx_INPSEL   COMP_CFGRx_INPSEL_Msk
#define COMP_CFGRx_INP2SEL_Pos   (22U)
#define COMP_CFGRx_INP2SEL_Msk   (0x1UL << COMP_CFGRx_INP2SEL_Pos)
#define COMP_CFGRx_INP2SEL   COMP_CFGRx_INP2SEL_Msk
#define COMP_CFGRx_BLANKING_Pos   (24U)
#define COMP_CFGRx_BLANKING_Msk   (0xFUL << COMP_CFGRx_BLANKING_Pos)
#define COMP_CFGRx_BLANKING   COMP_CFGRx_BLANKING_Msk
#define COMP_CFGRx_BLANKING_0   (0x1UL << COMP_CFGRx_BLANKING_Pos)
#define COMP_CFGRx_BLANKING_1   (0x2UL << COMP_CFGRx_BLANKING_Pos)
#define COMP_CFGRx_BLANKING_2   (0x4UL << COMP_CFGRx_BLANKING_Pos)
#define COMP_CFGRx_LOCK_Pos   (31U)
#define COMP_CFGRx_LOCK_Msk   (0x1UL << COMP_CFGRx_LOCK_Pos)
#define COMP_CFGRx_LOCK   COMP_CFGRx_LOCK_Msk
#define USART_CR1_UE_Pos   (0U)
#define USART_CR1_UE_Msk   (0x1UL << USART_CR1_UE_Pos)
#define USART_CR1_UE   USART_CR1_UE_Msk
#define USART_CR1_UESM_Pos   (1U)
#define USART_CR1_UESM_Msk   (0x1UL << USART_CR1_UESM_Pos)
#define USART_CR1_UESM   USART_CR1_UESM_Msk
#define USART_CR1_RE_Pos   (2U)
#define USART_CR1_RE_Msk   (0x1UL << USART_CR1_RE_Pos)
#define USART_CR1_RE   USART_CR1_RE_Msk
#define USART_CR1_TE_Pos   (3U)
#define USART_CR1_TE_Msk   (0x1UL << USART_CR1_TE_Pos)
#define USART_CR1_TE   USART_CR1_TE_Msk
#define USART_CR1_IDLEIE_Pos   (4U)
#define USART_CR1_IDLEIE_Msk   (0x1UL << USART_CR1_IDLEIE_Pos)
#define USART_CR1_IDLEIE   USART_CR1_IDLEIE_Msk
#define USART_CR1_RXNEIE_RXFNEIE_Pos   (5U)
#define USART_CR1_RXNEIE_RXFNEIE_Msk   (0x1UL << USART_CR1_RXNEIE_RXFNEIE_Pos)
#define USART_CR1_RXNEIE_RXFNEIE   USART_CR1_RXNEIE_RXFNEIE_Msk
#define USART_CR1_TCIE_Pos   (6U)
#define USART_CR1_TCIE_Msk   (0x1UL << USART_CR1_TCIE_Pos)
#define USART_CR1_TCIE   USART_CR1_TCIE_Msk
#define USART_CR1_TXEIE_TXFNFIE_Pos   (7U)
#define USART_CR1_TXEIE_TXFNFIE_Msk   (0x1UL << USART_CR1_TXEIE_TXFNFIE_Pos)
#define USART_CR1_TXEIE_TXFNFIE   USART_CR1_TXEIE_TXFNFIE_Msk
#define USART_CR1_PEIE_Pos   (8U)
#define USART_CR1_PEIE_Msk   (0x1UL << USART_CR1_PEIE_Pos)
#define USART_CR1_PEIE   USART_CR1_PEIE_Msk
#define USART_CR1_PS_Pos   (9U)
#define USART_CR1_PS_Msk   (0x1UL << USART_CR1_PS_Pos)
#define USART_CR1_PS   USART_CR1_PS_Msk
#define USART_CR1_PCE_Pos   (10U)
#define USART_CR1_PCE_Msk   (0x1UL << USART_CR1_PCE_Pos)
#define USART_CR1_PCE   USART_CR1_PCE_Msk
#define USART_CR1_WAKE_Pos   (11U)
#define USART_CR1_WAKE_Msk   (0x1UL << USART_CR1_WAKE_Pos)
#define USART_CR1_WAKE   USART_CR1_WAKE_Msk
#define USART_CR1_M_Pos   (12U)
#define USART_CR1_M_Msk   (0x10001UL << USART_CR1_M_Pos)
#define USART_CR1_M   USART_CR1_M_Msk
#define USART_CR1_M0_Pos   (12U)
#define USART_CR1_M0_Msk   (0x1UL << USART_CR1_M0_Pos)
#define USART_CR1_M0   USART_CR1_M0_Msk
#define USART_CR1_MME_Pos   (13U)
#define USART_CR1_MME_Msk   (0x1UL << USART_CR1_MME_Pos)
#define USART_CR1_MME   USART_CR1_MME_Msk
#define USART_CR1_CMIE_Pos   (14U)
#define USART_CR1_CMIE_Msk   (0x1UL << USART_CR1_CMIE_Pos)
#define USART_CR1_CMIE   USART_CR1_CMIE_Msk
#define USART_CR1_OVER8_Pos   (15U)
#define USART_CR1_OVER8_Msk   (0x1UL << USART_CR1_OVER8_Pos)
#define USART_CR1_OVER8   USART_CR1_OVER8_Msk
#define USART_CR1_DEDT_Pos   (16U)
#define USART_CR1_DEDT_Msk   (0x1FUL << USART_CR1_DEDT_Pos)
#define USART_CR1_DEDT   USART_CR1_DEDT_Msk
#define USART_CR1_DEDT_0   (0x01UL << USART_CR1_DEDT_Pos)
#define USART_CR1_DEDT_1   (0x02UL << USART_CR1_DEDT_Pos)
#define USART_CR1_DEDT_2   (0x04UL << USART_CR1_DEDT_Pos)
#define USART_CR1_DEDT_3   (0x08UL << USART_CR1_DEDT_Pos)
#define USART_CR1_DEDT_4   (0x10UL << USART_CR1_DEDT_Pos)
#define USART_CR1_DEAT_Pos   (21U)
#define USART_CR1_DEAT_Msk   (0x1FUL << USART_CR1_DEAT_Pos)
#define USART_CR1_DEAT   USART_CR1_DEAT_Msk
#define USART_CR1_DEAT_0   (0x01UL << USART_CR1_DEAT_Pos)
#define USART_CR1_DEAT_1   (0x02UL << USART_CR1_DEAT_Pos)
#define USART_CR1_DEAT_2   (0x04UL << USART_CR1_DEAT_Pos)
#define USART_CR1_DEAT_3   (0x08UL << USART_CR1_DEAT_Pos)
#define USART_CR1_DEAT_4   (0x10UL << USART_CR1_DEAT_Pos)
#define USART_CR1_RTOIE_Pos   (26U)
#define USART_CR1_RTOIE_Msk   (0x1UL << USART_CR1_RTOIE_Pos)
#define USART_CR1_RTOIE   USART_CR1_RTOIE_Msk
#define USART_CR1_EOBIE_Pos   (27U)
#define USART_CR1_EOBIE_Msk   (0x1UL << USART_CR1_EOBIE_Pos)
#define USART_CR1_EOBIE   USART_CR1_EOBIE_Msk
#define USART_CR1_M1_Pos   (28U)
#define USART_CR1_M1_Msk   (0x1UL << USART_CR1_M1_Pos)
#define USART_CR1_M1   USART_CR1_M1_Msk
#define USART_CR1_FIFOEN_Pos   (29U)
#define USART_CR1_FIFOEN_Msk   (0x1UL << USART_CR1_FIFOEN_Pos)
#define USART_CR1_FIFOEN   USART_CR1_FIFOEN_Msk
#define USART_CR1_TXFEIE_Pos   (30U)
#define USART_CR1_TXFEIE_Msk   (0x1UL << USART_CR1_TXFEIE_Pos)
#define USART_CR1_TXFEIE   USART_CR1_TXFEIE_Msk
#define USART_CR1_RXFFIE_Pos   (31U)
#define USART_CR1_RXFFIE_Msk   (0x1UL << USART_CR1_RXFFIE_Pos)
#define USART_CR1_RXFFIE   USART_CR1_RXFFIE_Msk
#define USART_CR1_RXNEIE   USART_CR1_RXNEIE_RXFNEIE
#define USART_CR1_TXEIE   USART_CR1_TXEIE_TXFNFIE
#define USART_CR2_SLVEN_Pos   (0U)
#define USART_CR2_SLVEN_Msk   (0x1UL << USART_CR2_SLVEN_Pos)
#define USART_CR2_SLVEN   USART_CR2_SLVEN_Msk
#define USART_CR2_DIS_NSS_Pos   (3U)
#define USART_CR2_DIS_NSS_Msk   (0x1UL << USART_CR2_DIS_NSS_Pos)
#define USART_CR2_DIS_NSS   USART_CR2_DIS_NSS_Msk
#define USART_CR2_ADDM7_Pos   (4U)
#define USART_CR2_ADDM7_Msk   (0x1UL << USART_CR2_ADDM7_Pos)
#define USART_CR2_ADDM7   USART_CR2_ADDM7_Msk
#define USART_CR2_LBDL_Pos   (5U)
#define USART_CR2_LBDL_Msk   (0x1UL << USART_CR2_LBDL_Pos)
#define USART_CR2_LBDL   USART_CR2_LBDL_Msk
#define USART_CR2_LBDIE_Pos   (6U)
#define USART_CR2_LBDIE_Msk   (0x1UL << USART_CR2_LBDIE_Pos)
#define USART_CR2_LBDIE   USART_CR2_LBDIE_Msk
#define USART_CR2_LBCL_Pos   (8U)
#define USART_CR2_LBCL_Msk   (0x1UL << USART_CR2_LBCL_Pos)
#define USART_CR2_LBCL   USART_CR2_LBCL_Msk
#define USART_CR2_CPHA_Pos   (9U)
#define USART_CR2_CPHA_Msk   (0x1UL << USART_CR2_CPHA_Pos)
#define USART_CR2_CPHA   USART_CR2_CPHA_Msk
#define USART_CR2_CPOL_Pos   (10U)
#define USART_CR2_CPOL_Msk   (0x1UL << USART_CR2_CPOL_Pos)
#define USART_CR2_CPOL   USART_CR2_CPOL_Msk
#define USART_CR2_CLKEN_Pos   (11U)
#define USART_CR2_CLKEN_Msk   (0x1UL << USART_CR2_CLKEN_Pos)
#define USART_CR2_CLKEN   USART_CR2_CLKEN_Msk
#define USART_CR2_STOP_Pos   (12U)
#define USART_CR2_STOP_Msk   (0x3UL << USART_CR2_STOP_Pos)
#define USART_CR2_STOP   USART_CR2_STOP_Msk
#define USART_CR2_STOP_0   (0x1UL << USART_CR2_STOP_Pos)
#define USART_CR2_STOP_1   (0x2UL << USART_CR2_STOP_Pos)
#define USART_CR2_LINEN_Pos   (14U)
#define USART_CR2_LINEN_Msk   (0x1UL << USART_CR2_LINEN_Pos)
#define USART_CR2_LINEN   USART_CR2_LINEN_Msk
#define USART_CR2_SWAP_Pos   (15U)
#define USART_CR2_SWAP_Msk   (0x1UL << USART_CR2_SWAP_Pos)
#define USART_CR2_SWAP   USART_CR2_SWAP_Msk
#define USART_CR2_RXINV_Pos   (16U)
#define USART_CR2_RXINV_Msk   (0x1UL << USART_CR2_RXINV_Pos)
#define USART_CR2_RXINV   USART_CR2_RXINV_Msk
#define USART_CR2_TXINV_Pos   (17U)
#define USART_CR2_TXINV_Msk   (0x1UL << USART_CR2_TXINV_Pos)
#define USART_CR2_TXINV   USART_CR2_TXINV_Msk
#define USART_CR2_DATAINV_Pos   (18U)
#define USART_CR2_DATAINV_Msk   (0x1UL << USART_CR2_DATAINV_Pos)
#define USART_CR2_DATAINV   USART_CR2_DATAINV_Msk
#define USART_CR2_MSBFIRST_Pos   (19U)
#define USART_CR2_MSBFIRST_Msk   (0x1UL << USART_CR2_MSBFIRST_Pos)
#define USART_CR2_MSBFIRST   USART_CR2_MSBFIRST_Msk
#define USART_CR2_ABREN_Pos   (20U)
#define USART_CR2_ABREN_Msk   (0x1UL << USART_CR2_ABREN_Pos)
#define USART_CR2_ABREN   USART_CR2_ABREN_Msk
#define USART_CR2_ABRMODE_Pos   (21U)
#define USART_CR2_ABRMODE_Msk   (0x3UL << USART_CR2_ABRMODE_Pos)
#define USART_CR2_ABRMODE   USART_CR2_ABRMODE_Msk
#define USART_CR2_ABRMODE_0   (0x1UL << USART_CR2_ABRMODE_Pos)
#define USART_CR2_ABRMODE_1   (0x2UL << USART_CR2_ABRMODE_Pos)
#define USART_CR2_RTOEN_Pos   (23U)
#define USART_CR2_RTOEN_Msk   (0x1UL << USART_CR2_RTOEN_Pos)
#define USART_CR2_RTOEN   USART_CR2_RTOEN_Msk
#define USART_CR2_ADD_Pos   (24U)
#define USART_CR2_ADD_Msk   (0xFFUL << USART_CR2_ADD_Pos)
#define USART_CR2_ADD   USART_CR2_ADD_Msk
#define USART_CR3_EIE_Pos   (0U)
#define USART_CR3_EIE_Msk   (0x1UL << USART_CR3_EIE_Pos)
#define USART_CR3_EIE   USART_CR3_EIE_Msk
#define USART_CR3_IREN_Pos   (1U)
#define USART_CR3_IREN_Msk   (0x1UL << USART_CR3_IREN_Pos)
#define USART_CR3_IREN   USART_CR3_IREN_Msk
#define USART_CR3_IRLP_Pos   (2U)
#define USART_CR3_IRLP_Msk   (0x1UL << USART_CR3_IRLP_Pos)
#define USART_CR3_IRLP   USART_CR3_IRLP_Msk
#define USART_CR3_HDSEL_Pos   (3U)
#define USART_CR3_HDSEL_Msk   (0x1UL << USART_CR3_HDSEL_Pos)
#define USART_CR3_HDSEL   USART_CR3_HDSEL_Msk
#define USART_CR3_NACK_Pos   (4U)
#define USART_CR3_NACK_Msk   (0x1UL << USART_CR3_NACK_Pos)
#define USART_CR3_NACK   USART_CR3_NACK_Msk
#define USART_CR3_SCEN_Pos   (5U)
#define USART_CR3_SCEN_Msk   (0x1UL << USART_CR3_SCEN_Pos)
#define USART_CR3_SCEN   USART_CR3_SCEN_Msk
#define USART_CR3_DMAR_Pos   (6U)
#define USART_CR3_DMAR_Msk   (0x1UL << USART_CR3_DMAR_Pos)
#define USART_CR3_DMAR   USART_CR3_DMAR_Msk
#define USART_CR3_DMAT_Pos   (7U)
#define USART_CR3_DMAT_Msk   (0x1UL << USART_CR3_DMAT_Pos)
#define USART_CR3_DMAT   USART_CR3_DMAT_Msk
#define USART_CR3_RTSE_Pos   (8U)
#define USART_CR3_RTSE_Msk   (0x1UL << USART_CR3_RTSE_Pos)
#define USART_CR3_RTSE   USART_CR3_RTSE_Msk
#define USART_CR3_CTSE_Pos   (9U)
#define USART_CR3_CTSE_Msk   (0x1UL << USART_CR3_CTSE_Pos)
#define USART_CR3_CTSE   USART_CR3_CTSE_Msk
#define USART_CR3_CTSIE_Pos   (10U)
#define USART_CR3_CTSIE_Msk   (0x1UL << USART_CR3_CTSIE_Pos)
#define USART_CR3_CTSIE   USART_CR3_CTSIE_Msk
#define USART_CR3_ONEBIT_Pos   (11U)
#define USART_CR3_ONEBIT_Msk   (0x1UL << USART_CR3_ONEBIT_Pos)
#define USART_CR3_ONEBIT   USART_CR3_ONEBIT_Msk
#define USART_CR3_OVRDIS_Pos   (12U)
#define USART_CR3_OVRDIS_Msk   (0x1UL << USART_CR3_OVRDIS_Pos)
#define USART_CR3_OVRDIS   USART_CR3_OVRDIS_Msk
#define USART_CR3_DDRE_Pos   (13U)
#define USART_CR3_DDRE_Msk   (0x1UL << USART_CR3_DDRE_Pos)
#define USART_CR3_DDRE   USART_CR3_DDRE_Msk
#define USART_CR3_DEM_Pos   (14U)
#define USART_CR3_DEM_Msk   (0x1UL << USART_CR3_DEM_Pos)
#define USART_CR3_DEM   USART_CR3_DEM_Msk
#define USART_CR3_DEP_Pos   (15U)
#define USART_CR3_DEP_Msk   (0x1UL << USART_CR3_DEP_Pos)
#define USART_CR3_DEP   USART_CR3_DEP_Msk
#define USART_CR3_SCARCNT_Pos   (17U)
#define USART_CR3_SCARCNT_Msk   (0x7UL << USART_CR3_SCARCNT_Pos)
#define USART_CR3_SCARCNT   USART_CR3_SCARCNT_Msk
#define USART_CR3_SCARCNT_0   (0x1UL << USART_CR3_SCARCNT_Pos)
#define USART_CR3_SCARCNT_1   (0x2UL << USART_CR3_SCARCNT_Pos)
#define USART_CR3_SCARCNT_2   (0x4UL << USART_CR3_SCARCNT_Pos)
#define USART_CR3_WUS_Pos   (20U)
#define USART_CR3_WUS_Msk   (0x3UL << USART_CR3_WUS_Pos)
#define USART_CR3_WUS   USART_CR3_WUS_Msk
#define USART_CR3_WUS_0   (0x1UL << USART_CR3_WUS_Pos)
#define USART_CR3_WUS_1   (0x2UL << USART_CR3_WUS_Pos)
#define USART_CR3_WUFIE_Pos   (22U)
#define USART_CR3_WUFIE_Msk   (0x1UL << USART_CR3_WUFIE_Pos)
#define USART_CR3_WUFIE   USART_CR3_WUFIE_Msk
#define USART_CR3_TXFTIE_Pos   (23U)
#define USART_CR3_TXFTIE_Msk   (0x1UL << USART_CR3_TXFTIE_Pos)
#define USART_CR3_TXFTIE   USART_CR3_TXFTIE_Msk
#define USART_CR3_TCBGTIE_Pos   (24U)
#define USART_CR3_TCBGTIE_Msk   (0x1UL << USART_CR3_TCBGTIE_Pos)
#define USART_CR3_TCBGTIE   USART_CR3_TCBGTIE_Msk
#define USART_CR3_RXFTCFG_Pos   (25U)
#define USART_CR3_RXFTCFG_Msk   (0x7UL << USART_CR3_RXFTCFG_Pos)
#define USART_CR3_RXFTCFG   USART_CR3_RXFTCFG_Msk
#define USART_CR3_RXFTCFG_0   (0x1UL << USART_CR3_RXFTCFG_Pos)
#define USART_CR3_RXFTCFG_1   (0x2UL << USART_CR3_RXFTCFG_Pos)
#define USART_CR3_RXFTCFG_2   (0x4UL << USART_CR3_RXFTCFG_Pos)
#define USART_CR3_RXFTIE_Pos   (28U)
#define USART_CR3_RXFTIE_Msk   (0x1UL << USART_CR3_RXFTIE_Pos)
#define USART_CR3_RXFTIE   USART_CR3_RXFTIE_Msk
#define USART_CR3_TXFTCFG_Pos   (29U)
#define USART_CR3_TXFTCFG_Msk   (0x7UL << USART_CR3_TXFTCFG_Pos)
#define USART_CR3_TXFTCFG   USART_CR3_TXFTCFG_Msk
#define USART_CR3_TXFTCFG_0   (0x1UL << USART_CR3_TXFTCFG_Pos)
#define USART_CR3_TXFTCFG_1   (0x2UL << USART_CR3_TXFTCFG_Pos)
#define USART_CR3_TXFTCFG_2   (0x4UL << USART_CR3_TXFTCFG_Pos)
#define USART_BRR_DIV_FRACTION_Pos   (0U)
#define USART_BRR_DIV_FRACTION_Msk   (0xFUL << USART_BRR_DIV_FRACTION_Pos)
#define USART_BRR_DIV_FRACTION   USART_BRR_DIV_FRACTION_Msk
#define USART_BRR_DIV_MANTISSA_Pos   (4U)
#define USART_BRR_DIV_MANTISSA_Msk   (0xFFFUL << USART_BRR_DIV_MANTISSA_Pos)
#define USART_BRR_DIV_MANTISSA   USART_BRR_DIV_MANTISSA_Msk
#define USART_GTPR_PSC_Pos   (0U)
#define USART_GTPR_PSC_Msk   (0xFFUL << USART_GTPR_PSC_Pos)
#define USART_GTPR_PSC   USART_GTPR_PSC_Msk
#define USART_GTPR_GT_Pos   (8U)
#define USART_GTPR_GT_Msk   (0xFFUL << USART_GTPR_GT_Pos)
#define USART_GTPR_GT   USART_GTPR_GT_Msk
#define USART_RTOR_RTO_Pos   (0U)
#define USART_RTOR_RTO_Msk   (0xFFFFFFUL << USART_RTOR_RTO_Pos)
#define USART_RTOR_RTO   USART_RTOR_RTO_Msk
#define USART_RTOR_BLEN_Pos   (24U)
#define USART_RTOR_BLEN_Msk   (0xFFUL << USART_RTOR_BLEN_Pos)
#define USART_RTOR_BLEN   USART_RTOR_BLEN_Msk
#define USART_RQR_ABRRQ_Pos   (0U)
#define USART_RQR_ABRRQ_Msk   (0x1UL << USART_RQR_ABRRQ_Pos)
#define USART_RQR_ABRRQ   USART_RQR_ABRRQ_Msk
#define USART_RQR_SBKRQ_Pos   (1U)
#define USART_RQR_SBKRQ_Msk   (0x1UL << USART_RQR_SBKRQ_Pos)
#define USART_RQR_SBKRQ   USART_RQR_SBKRQ_Msk
#define USART_RQR_MMRQ_Pos   (2U)
#define USART_RQR_MMRQ_Msk   (0x1UL << USART_RQR_MMRQ_Pos)
#define USART_RQR_MMRQ   USART_RQR_MMRQ_Msk
#define USART_RQR_RXFRQ_Pos   (3U)
#define USART_RQR_RXFRQ_Msk   (0x1UL << USART_RQR_RXFRQ_Pos)
#define USART_RQR_RXFRQ   USART_RQR_RXFRQ_Msk
#define USART_RQR_TXFRQ_Pos   (4U)
#define USART_RQR_TXFRQ_Msk   (0x1UL << USART_RQR_TXFRQ_Pos)
#define USART_RQR_TXFRQ   USART_RQR_TXFRQ_Msk
#define USART_ISR_PE_Pos   (0U)
#define USART_ISR_PE_Msk   (0x1UL << USART_ISR_PE_Pos)
#define USART_ISR_PE   USART_ISR_PE_Msk
#define USART_ISR_FE_Pos   (1U)
#define USART_ISR_FE_Msk   (0x1UL << USART_ISR_FE_Pos)
#define USART_ISR_FE   USART_ISR_FE_Msk
#define USART_ISR_NE_Pos   (2U)
#define USART_ISR_NE_Msk   (0x1UL << USART_ISR_NE_Pos)
#define USART_ISR_NE   USART_ISR_NE_Msk
#define USART_ISR_ORE_Pos   (3U)
#define USART_ISR_ORE_Msk   (0x1UL << USART_ISR_ORE_Pos)
#define USART_ISR_ORE   USART_ISR_ORE_Msk
#define USART_ISR_IDLE_Pos   (4U)
#define USART_ISR_IDLE_Msk   (0x1UL << USART_ISR_IDLE_Pos)
#define USART_ISR_IDLE   USART_ISR_IDLE_Msk
#define USART_ISR_RXNE_RXFNE_Pos   (5U)
#define USART_ISR_RXNE_RXFNE_Msk   (0x1UL << USART_ISR_RXNE_RXFNE_Pos)
#define USART_ISR_RXNE_RXFNE   USART_ISR_RXNE_RXFNE_Msk
#define USART_ISR_TC_Pos   (6U)
#define USART_ISR_TC_Msk   (0x1UL << USART_ISR_TC_Pos)
#define USART_ISR_TC   USART_ISR_TC_Msk
#define USART_ISR_TXE_TXFNF_Pos   (7U)
#define USART_ISR_TXE_TXFNF_Msk   (0x1UL << USART_ISR_TXE_TXFNF_Pos)
#define USART_ISR_TXE_TXFNF   USART_ISR_TXE_TXFNF_Msk
#define USART_ISR_LBDF_Pos   (8U)
#define USART_ISR_LBDF_Msk   (0x1UL << USART_ISR_LBDF_Pos)
#define USART_ISR_LBDF   USART_ISR_LBDF_Msk
#define USART_ISR_CTSIF_Pos   (9U)
#define USART_ISR_CTSIF_Msk   (0x1UL << USART_ISR_CTSIF_Pos)
#define USART_ISR_CTSIF   USART_ISR_CTSIF_Msk
#define USART_ISR_CTS_Pos   (10U)
#define USART_ISR_CTS_Msk   (0x1UL << USART_ISR_CTS_Pos)
#define USART_ISR_CTS   USART_ISR_CTS_Msk
#define USART_ISR_RTOF_Pos   (11U)
#define USART_ISR_RTOF_Msk   (0x1UL << USART_ISR_RTOF_Pos)
#define USART_ISR_RTOF   USART_ISR_RTOF_Msk
#define USART_ISR_EOBF_Pos   (12U)
#define USART_ISR_EOBF_Msk   (0x1UL << USART_ISR_EOBF_Pos)
#define USART_ISR_EOBF   USART_ISR_EOBF_Msk
#define USART_ISR_UDR_Pos   (13U)
#define USART_ISR_UDR_Msk   (0x1UL << USART_ISR_UDR_Pos)
#define USART_ISR_UDR   USART_ISR_UDR_Msk
#define USART_ISR_ABRE_Pos   (14U)
#define USART_ISR_ABRE_Msk   (0x1UL << USART_ISR_ABRE_Pos)
#define USART_ISR_ABRE   USART_ISR_ABRE_Msk
#define USART_ISR_ABRF_Pos   (15U)
#define USART_ISR_ABRF_Msk   (0x1UL << USART_ISR_ABRF_Pos)
#define USART_ISR_ABRF   USART_ISR_ABRF_Msk
#define USART_ISR_BUSY_Pos   (16U)
#define USART_ISR_BUSY_Msk   (0x1UL << USART_ISR_BUSY_Pos)
#define USART_ISR_BUSY   USART_ISR_BUSY_Msk
#define USART_ISR_CMF_Pos   (17U)
#define USART_ISR_CMF_Msk   (0x1UL << USART_ISR_CMF_Pos)
#define USART_ISR_CMF   USART_ISR_CMF_Msk
#define USART_ISR_SBKF_Pos   (18U)
#define USART_ISR_SBKF_Msk   (0x1UL << USART_ISR_SBKF_Pos)
#define USART_ISR_SBKF   USART_ISR_SBKF_Msk
#define USART_ISR_RWU_Pos   (19U)
#define USART_ISR_RWU_Msk   (0x1UL << USART_ISR_RWU_Pos)
#define USART_ISR_RWU   USART_ISR_RWU_Msk
#define USART_ISR_WUF_Pos   (20U)
#define USART_ISR_WUF_Msk   (0x1UL << USART_ISR_WUF_Pos)
#define USART_ISR_WUF   USART_ISR_WUF_Msk
#define USART_ISR_TEACK_Pos   (21U)
#define USART_ISR_TEACK_Msk   (0x1UL << USART_ISR_TEACK_Pos)
#define USART_ISR_TEACK   USART_ISR_TEACK_Msk
#define USART_ISR_REACK_Pos   (22U)
#define USART_ISR_REACK_Msk   (0x1UL << USART_ISR_REACK_Pos)
#define USART_ISR_REACK   USART_ISR_REACK_Msk
#define USART_ISR_TXFE_Pos   (23U)
#define USART_ISR_TXFE_Msk   (0x1UL << USART_ISR_TXFE_Pos)
#define USART_ISR_TXFE   USART_ISR_TXFE_Msk
#define USART_ISR_RXFF_Pos   (24U)
#define USART_ISR_RXFF_Msk   (0x1UL << USART_ISR_RXFF_Pos)
#define USART_ISR_RXFF   USART_ISR_RXFF_Msk
#define USART_ISR_TCBGT_Pos   (25U)
#define USART_ISR_TCBGT_Msk   (0x1UL << USART_ISR_TCBGT_Pos)
#define USART_ISR_TCBGT   USART_ISR_TCBGT_Msk
#define USART_ISR_RXFT_Pos   (26U)
#define USART_ISR_RXFT_Msk   (0x1UL << USART_ISR_RXFT_Pos)
#define USART_ISR_RXFT   USART_ISR_RXFT_Msk
#define USART_ISR_TXFT_Pos   (27U)
#define USART_ISR_TXFT_Msk   (0x1UL << USART_ISR_TXFT_Pos)
#define USART_ISR_TXFT   USART_ISR_TXFT_Msk
#define USART_ICR_PECF_Pos   (0U)
#define USART_ICR_PECF_Msk   (0x1UL << USART_ICR_PECF_Pos)
#define USART_ICR_PECF   USART_ICR_PECF_Msk
#define USART_ICR_FECF_Pos   (1U)
#define USART_ICR_FECF_Msk   (0x1UL << USART_ICR_FECF_Pos)
#define USART_ICR_FECF   USART_ICR_FECF_Msk
#define USART_ICR_NECF_Pos   (2U)
#define USART_ICR_NECF_Msk   (0x1UL << USART_ICR_NECF_Pos)
#define USART_ICR_NECF   USART_ICR_NECF_Msk
#define USART_ICR_ORECF_Pos   (3U)
#define USART_ICR_ORECF_Msk   (0x1UL << USART_ICR_ORECF_Pos)
#define USART_ICR_ORECF   USART_ICR_ORECF_Msk
#define USART_ICR_IDLECF_Pos   (4U)
#define USART_ICR_IDLECF_Msk   (0x1UL << USART_ICR_IDLECF_Pos)
#define USART_ICR_IDLECF   USART_ICR_IDLECF_Msk
#define USART_ICR_TXFECF_Pos   (5U)
#define USART_ICR_TXFECF_Msk   (0x1UL << USART_ICR_TXFECF_Pos)
#define USART_ICR_TXFECF   USART_ICR_TXFECF_Msk
#define USART_ICR_TCCF_Pos   (6U)
#define USART_ICR_TCCF_Msk   (0x1UL << USART_ICR_TCCF_Pos)
#define USART_ICR_TCCF   USART_ICR_TCCF_Msk
#define USART_ICR_TCBGTCF_Pos   (7U)
#define USART_ICR_TCBGTCF_Msk   (0x1UL << USART_ICR_TCBGTCF_Pos)
#define USART_ICR_TCBGTCF   USART_ICR_TCBGTCF_Msk
#define USART_ICR_LBDCF_Pos   (8U)
#define USART_ICR_LBDCF_Msk   (0x1UL << USART_ICR_LBDCF_Pos)
#define USART_ICR_LBDCF   USART_ICR_LBDCF_Msk
#define USART_ICR_CTSCF_Pos   (9U)
#define USART_ICR_CTSCF_Msk   (0x1UL << USART_ICR_CTSCF_Pos)
#define USART_ICR_CTSCF   USART_ICR_CTSCF_Msk
#define USART_ICR_RTOCF_Pos   (11U)
#define USART_ICR_RTOCF_Msk   (0x1UL << USART_ICR_RTOCF_Pos)
#define USART_ICR_RTOCF   USART_ICR_RTOCF_Msk
#define USART_ICR_EOBCF_Pos   (12U)
#define USART_ICR_EOBCF_Msk   (0x1UL << USART_ICR_EOBCF_Pos)
#define USART_ICR_EOBCF   USART_ICR_EOBCF_Msk
#define USART_ICR_UDRCF_Pos   (13U)
#define USART_ICR_UDRCF_Msk   (0x1UL << USART_ICR_UDRCF_Pos)
#define USART_ICR_UDRCF   USART_ICR_UDRCF_Msk
#define USART_ICR_CMCF_Pos   (17U)
#define USART_ICR_CMCF_Msk   (0x1UL << USART_ICR_CMCF_Pos)
#define USART_ICR_CMCF   USART_ICR_CMCF_Msk
#define USART_ICR_WUCF_Pos   (20U)
#define USART_ICR_WUCF_Msk   (0x1UL << USART_ICR_WUCF_Pos)
#define USART_ICR_WUCF   USART_ICR_WUCF_Msk
#define USART_RDR_RDR_Pos   (0U)
#define USART_RDR_RDR_Msk   (0x1FFUL << USART_RDR_RDR_Pos)
#define USART_RDR_RDR   USART_RDR_RDR_Msk
#define USART_TDR_TDR_Pos   (0U)
#define USART_TDR_TDR_Msk   (0x1FFUL << USART_TDR_TDR_Pos)
#define USART_TDR_TDR   USART_TDR_TDR_Msk
#define USART_PRESC_PRESCALER_Pos   (0U)
#define USART_PRESC_PRESCALER_Msk   (0xFUL << USART_PRESC_PRESCALER_Pos)
#define USART_PRESC_PRESCALER   USART_PRESC_PRESCALER_Msk
#define USART_PRESC_PRESCALER_0   (0x1UL << USART_PRESC_PRESCALER_Pos)
#define USART_PRESC_PRESCALER_1   (0x2UL << USART_PRESC_PRESCALER_Pos)
#define USART_PRESC_PRESCALER_2   (0x4UL << USART_PRESC_PRESCALER_Pos)
#define USART_PRESC_PRESCALER_3   (0x8UL << USART_PRESC_PRESCALER_Pos)
#define SWPMI_CR_RXDMA_Pos   (0U)
#define SWPMI_CR_RXDMA_Msk   (0x1UL << SWPMI_CR_RXDMA_Pos)
#define SWPMI_CR_RXDMA   SWPMI_CR_RXDMA_Msk
#define SWPMI_CR_TXDMA_Pos   (1U)
#define SWPMI_CR_TXDMA_Msk   (0x1UL << SWPMI_CR_TXDMA_Pos)
#define SWPMI_CR_TXDMA   SWPMI_CR_TXDMA_Msk
#define SWPMI_CR_RXMODE_Pos   (2U)
#define SWPMI_CR_RXMODE_Msk   (0x1UL << SWPMI_CR_RXMODE_Pos)
#define SWPMI_CR_RXMODE   SWPMI_CR_RXMODE_Msk
#define SWPMI_CR_TXMODE_Pos   (3U)
#define SWPMI_CR_TXMODE_Msk   (0x1UL << SWPMI_CR_TXMODE_Pos)
#define SWPMI_CR_TXMODE   SWPMI_CR_TXMODE_Msk
#define SWPMI_CR_LPBK_Pos   (4U)
#define SWPMI_CR_LPBK_Msk   (0x1UL << SWPMI_CR_LPBK_Pos)
#define SWPMI_CR_LPBK   SWPMI_CR_LPBK_Msk
#define SWPMI_CR_SWPACT_Pos   (5U)
#define SWPMI_CR_SWPACT_Msk   (0x1UL << SWPMI_CR_SWPACT_Pos)
#define SWPMI_CR_SWPACT   SWPMI_CR_SWPACT_Msk
#define SWPMI_CR_DEACT_Pos   (10U)
#define SWPMI_CR_DEACT_Msk   (0x1UL << SWPMI_CR_DEACT_Pos)
#define SWPMI_CR_DEACT   SWPMI_CR_DEACT_Msk
#define SWPMI_CR_SWPEN_Pos   (11U)
#define SWPMI_CR_SWPEN_Msk   (0x1UL << SWPMI_CR_SWPEN_Pos)
#define SWPMI_CR_SWPEN   SWPMI_CR_SWPEN_Msk
#define SWPMI_BRR_BR_Pos   (0U)
#define SWPMI_BRR_BR_Msk   (0xFFUL << SWPMI_BRR_BR_Pos)
#define SWPMI_BRR_BR   SWPMI_BRR_BR_Msk
#define SWPMI_ISR_RXBFF_Pos   (0U)
#define SWPMI_ISR_RXBFF_Msk   (0x1UL << SWPMI_ISR_RXBFF_Pos)
#define SWPMI_ISR_RXBFF   SWPMI_ISR_RXBFF_Msk
#define SWPMI_ISR_TXBEF_Pos   (1U)
#define SWPMI_ISR_TXBEF_Msk   (0x1UL << SWPMI_ISR_TXBEF_Pos)
#define SWPMI_ISR_TXBEF   SWPMI_ISR_TXBEF_Msk
#define SWPMI_ISR_RXBERF_Pos   (2U)
#define SWPMI_ISR_RXBERF_Msk   (0x1UL << SWPMI_ISR_RXBERF_Pos)
#define SWPMI_ISR_RXBERF   SWPMI_ISR_RXBERF_Msk
#define SWPMI_ISR_RXOVRF_Pos   (3U)
#define SWPMI_ISR_RXOVRF_Msk   (0x1UL << SWPMI_ISR_RXOVRF_Pos)
#define SWPMI_ISR_RXOVRF   SWPMI_ISR_RXOVRF_Msk
#define SWPMI_ISR_TXUNRF_Pos   (4U)
#define SWPMI_ISR_TXUNRF_Msk   (0x1UL << SWPMI_ISR_TXUNRF_Pos)
#define SWPMI_ISR_TXUNRF   SWPMI_ISR_TXUNRF_Msk
#define SWPMI_ISR_RXNE_Pos   (5U)
#define SWPMI_ISR_RXNE_Msk   (0x1UL << SWPMI_ISR_RXNE_Pos)
#define SWPMI_ISR_RXNE   SWPMI_ISR_RXNE_Msk
#define SWPMI_ISR_TXE_Pos   (6U)
#define SWPMI_ISR_TXE_Msk   (0x1UL << SWPMI_ISR_TXE_Pos)
#define SWPMI_ISR_TXE   SWPMI_ISR_TXE_Msk
#define SWPMI_ISR_TCF_Pos   (7U)
#define SWPMI_ISR_TCF_Msk   (0x1UL << SWPMI_ISR_TCF_Pos)
#define SWPMI_ISR_TCF   SWPMI_ISR_TCF_Msk
#define SWPMI_ISR_SRF_Pos   (8U)
#define SWPMI_ISR_SRF_Msk   (0x1UL << SWPMI_ISR_SRF_Pos)
#define SWPMI_ISR_SRF   SWPMI_ISR_SRF_Msk
#define SWPMI_ISR_SUSP_Pos   (9U)
#define SWPMI_ISR_SUSP_Msk   (0x1UL << SWPMI_ISR_SUSP_Pos)
#define SWPMI_ISR_SUSP   SWPMI_ISR_SUSP_Msk
#define SWPMI_ISR_DEACTF_Pos   (10U)
#define SWPMI_ISR_DEACTF_Msk   (0x1UL << SWPMI_ISR_DEACTF_Pos)
#define SWPMI_ISR_DEACTF   SWPMI_ISR_DEACTF_Msk
#define SWPMI_ISR_RDYF_Pos   (11U)
#define SWPMI_ISR_RDYF_Msk   (0x1UL << SWPMI_ISR_RDYF_Pos)
#define SWPMI_ISR_RDYF   SWPMI_ISR_RDYF_Msk
#define SWPMI_ICR_CRXBFF_Pos   (0U)
#define SWPMI_ICR_CRXBFF_Msk   (0x1UL << SWPMI_ICR_CRXBFF_Pos)
#define SWPMI_ICR_CRXBFF   SWPMI_ICR_CRXBFF_Msk
#define SWPMI_ICR_CTXBEF_Pos   (1U)
#define SWPMI_ICR_CTXBEF_Msk   (0x1UL << SWPMI_ICR_CTXBEF_Pos)
#define SWPMI_ICR_CTXBEF   SWPMI_ICR_CTXBEF_Msk
#define SWPMI_ICR_CRXBERF_Pos   (2U)
#define SWPMI_ICR_CRXBERF_Msk   (0x1UL << SWPMI_ICR_CRXBERF_Pos)
#define SWPMI_ICR_CRXBERF   SWPMI_ICR_CRXBERF_Msk
#define SWPMI_ICR_CRXOVRF_Pos   (3U)
#define SWPMI_ICR_CRXOVRF_Msk   (0x1UL << SWPMI_ICR_CRXOVRF_Pos)
#define SWPMI_ICR_CRXOVRF   SWPMI_ICR_CRXOVRF_Msk
#define SWPMI_ICR_CTXUNRF_Pos   (4U)
#define SWPMI_ICR_CTXUNRF_Msk   (0x1UL << SWPMI_ICR_CTXUNRF_Pos)
#define SWPMI_ICR_CTXUNRF   SWPMI_ICR_CTXUNRF_Msk
#define SWPMI_ICR_CTCF_Pos   (7U)
#define SWPMI_ICR_CTCF_Msk   (0x1UL << SWPMI_ICR_CTCF_Pos)
#define SWPMI_ICR_CTCF   SWPMI_ICR_CTCF_Msk
#define SWPMI_ICR_CSRF_Pos   (8U)
#define SWPMI_ICR_CSRF_Msk   (0x1UL << SWPMI_ICR_CSRF_Pos)
#define SWPMI_ICR_CSRF   SWPMI_ICR_CSRF_Msk
#define SWPMI_ICR_CRDYF_Pos   (11U)
#define SWPMI_ICR_CRDYF_Msk   (0x1UL << SWPMI_ICR_CRDYF_Pos)
#define SWPMI_ICR_CRDYF   SWPMI_ICR_CRDYF_Msk
#define SWPMI_IER_RXBFIE_Pos   (0U)
#define SWPMI_IER_RXBFIE_Msk   (0x1UL << SWPMI_IER_RXBFIE_Pos)
#define SWPMI_IER_RXBFIE   SWPMI_IER_RXBFIE_Msk
#define SWPMI_IER_TXBEIE_Pos   (1U)
#define SWPMI_IER_TXBEIE_Msk   (0x1UL << SWPMI_IER_TXBEIE_Pos)
#define SWPMI_IER_TXBEIE   SWPMI_IER_TXBEIE_Msk
#define SWPMI_IER_RXBERIE_Pos   (2U)
#define SWPMI_IER_RXBERIE_Msk   (0x1UL << SWPMI_IER_RXBERIE_Pos)
#define SWPMI_IER_RXBERIE   SWPMI_IER_RXBERIE_Msk
#define SWPMI_IER_RXOVRIE_Pos   (3U)
#define SWPMI_IER_RXOVRIE_Msk   (0x1UL << SWPMI_IER_RXOVRIE_Pos)
#define SWPMI_IER_RXOVRIE   SWPMI_IER_RXOVRIE_Msk
#define SWPMI_IER_TXUNRIE_Pos   (4U)
#define SWPMI_IER_TXUNRIE_Msk   (0x1UL << SWPMI_IER_TXUNRIE_Pos)
#define SWPMI_IER_TXUNRIE   SWPMI_IER_TXUNRIE_Msk
#define SWPMI_IER_RIE_Pos   (5U)
#define SWPMI_IER_RIE_Msk   (0x1UL << SWPMI_IER_RIE_Pos)
#define SWPMI_IER_RIE   SWPMI_IER_RIE_Msk
#define SWPMI_IER_TIE_Pos   (6U)
#define SWPMI_IER_TIE_Msk   (0x1UL << SWPMI_IER_TIE_Pos)
#define SWPMI_IER_TIE   SWPMI_IER_TIE_Msk
#define SWPMI_IER_TCIE_Pos   (7U)
#define SWPMI_IER_TCIE_Msk   (0x1UL << SWPMI_IER_TCIE_Pos)
#define SWPMI_IER_TCIE   SWPMI_IER_TCIE_Msk
#define SWPMI_IER_SRIE_Pos   (8U)
#define SWPMI_IER_SRIE_Msk   (0x1UL << SWPMI_IER_SRIE_Pos)
#define SWPMI_IER_SRIE   SWPMI_IER_SRIE_Msk
#define SWPMI_IER_RDYIE_Pos   (11U)
#define SWPMI_IER_RDYIE_Msk   (0x1UL << SWPMI_IER_RDYIE_Pos)
#define SWPMI_IER_RDYIE   SWPMI_IER_RDYIE_Msk
#define SWPMI_RFL_RFL_Pos   (0U)
#define SWPMI_RFL_RFL_Msk   (0x1FUL << SWPMI_RFL_RFL_Pos)
#define SWPMI_RFL_RFL   SWPMI_RFL_RFL_Msk
#define SWPMI_RFL_RFL_0_1   (0x00000003U)
#define SWPMI_TDR_TD_Pos   (0U)
#define SWPMI_TDR_TD_Msk   (0xFFFFFFFFUL << SWPMI_TDR_TD_Pos)
#define SWPMI_TDR_TD   SWPMI_TDR_TD_Msk
#define SWPMI_RDR_RD_Pos   (0U)
#define SWPMI_RDR_RD_Msk   (0xFFFFFFFFUL << SWPMI_RDR_RD_Pos)
#define SWPMI_RDR_RD   SWPMI_RDR_RD_Msk
#define SWPMI_OR_TBYP_Pos   (0U)
#define SWPMI_OR_TBYP_Msk   (0x1UL << SWPMI_OR_TBYP_Pos)
#define SWPMI_OR_TBYP   SWPMI_OR_TBYP_Msk
#define SWPMI_OR_CLASS_Pos   (1U)
#define SWPMI_OR_CLASS_Msk   (0x1UL << SWPMI_OR_CLASS_Pos)
#define SWPMI_OR_CLASS   SWPMI_OR_CLASS_Msk
#define WWDG_CR_T_Pos   (0U)
#define WWDG_CR_T_Msk   (0x7FUL << WWDG_CR_T_Pos)
#define WWDG_CR_T   WWDG_CR_T_Msk
#define WWDG_CR_T_0   (0x01UL << WWDG_CR_T_Pos)
#define WWDG_CR_T_1   (0x02UL << WWDG_CR_T_Pos)
#define WWDG_CR_T_2   (0x04UL << WWDG_CR_T_Pos)
#define WWDG_CR_T_3   (0x08UL << WWDG_CR_T_Pos)
#define WWDG_CR_T_4   (0x10UL << WWDG_CR_T_Pos)
#define WWDG_CR_T_5   (0x20UL << WWDG_CR_T_Pos)
#define WWDG_CR_T_6   (0x40UL << WWDG_CR_T_Pos)
#define WWDG_CR_WDGA_Pos   (7U)
#define WWDG_CR_WDGA_Msk   (0x1UL << WWDG_CR_WDGA_Pos)
#define WWDG_CR_WDGA   WWDG_CR_WDGA_Msk
#define WWDG_CFR_W_Pos   (0U)
#define WWDG_CFR_W_Msk   (0x7FUL << WWDG_CFR_W_Pos)
#define WWDG_CFR_W   WWDG_CFR_W_Msk
#define WWDG_CFR_W_0   (0x01UL << WWDG_CFR_W_Pos)
#define WWDG_CFR_W_1   (0x02UL << WWDG_CFR_W_Pos)
#define WWDG_CFR_W_2   (0x04UL << WWDG_CFR_W_Pos)
#define WWDG_CFR_W_3   (0x08UL << WWDG_CFR_W_Pos)
#define WWDG_CFR_W_4   (0x10UL << WWDG_CFR_W_Pos)
#define WWDG_CFR_W_5   (0x20UL << WWDG_CFR_W_Pos)
#define WWDG_CFR_W_6   (0x40UL << WWDG_CFR_W_Pos)
#define WWDG_CFR_EWI_Pos   (9U)
#define WWDG_CFR_EWI_Msk   (0x1UL << WWDG_CFR_EWI_Pos)
#define WWDG_CFR_EWI   WWDG_CFR_EWI_Msk
#define WWDG_CFR_WDGTB_Pos   (11U)
#define WWDG_CFR_WDGTB_Msk   (0x7UL << WWDG_CFR_WDGTB_Pos)
#define WWDG_CFR_WDGTB   WWDG_CFR_WDGTB_Msk
#define WWDG_CFR_WDGTB_0   (0x1UL << WWDG_CFR_WDGTB_Pos)
#define WWDG_CFR_WDGTB_1   (0x2UL << WWDG_CFR_WDGTB_Pos)
#define WWDG_CFR_WDGTB_2   (0x4UL << WWDG_CFR_WDGTB_Pos)
#define WWDG_SR_EWIF_Pos   (0U)
#define WWDG_SR_EWIF_Msk   (0x1UL << WWDG_SR_EWIF_Pos)
#define WWDG_SR_EWIF   WWDG_SR_EWIF_Msk
#define STM32H7_DEV_ID   0x480UL
#define DBGMCU_IDCODE_DEV_ID_Pos   (0U)
#define DBGMCU_IDCODE_DEV_ID_Msk   (0xFFFUL << DBGMCU_IDCODE_DEV_ID_Pos)
#define DBGMCU_IDCODE_DEV_ID   DBGMCU_IDCODE_DEV_ID_Msk
#define DBGMCU_IDCODE_REV_ID_Pos   (16U)
#define DBGMCU_IDCODE_REV_ID_Msk   (0xFFFFUL << DBGMCU_IDCODE_REV_ID_Pos)
#define DBGMCU_IDCODE_REV_ID   DBGMCU_IDCODE_REV_ID_Msk
#define DBGMCU_CR_DBG_SLEEPCD_Pos   (0U)
#define DBGMCU_CR_DBG_SLEEPCD_Msk   (0x1UL << DBGMCU_CR_DBG_SLEEPCD_Pos)
#define DBGMCU_CR_DBG_SLEEPCD   DBGMCU_CR_DBG_SLEEPCD_Msk
#define DBGMCU_CR_DBG_STOPCD_Pos   (1U)
#define DBGMCU_CR_DBG_STOPCD_Msk   (0x1UL << DBGMCU_CR_DBG_STOPCD_Pos)
#define DBGMCU_CR_DBG_STOPCD   DBGMCU_CR_DBG_STOPCD_Msk
#define DBGMCU_CR_DBG_STANDBYCD_Pos   (2U)
#define DBGMCU_CR_DBG_STANDBYCD_Msk   (0x1UL << DBGMCU_CR_DBG_STANDBYCD_Pos)
#define DBGMCU_CR_DBG_STANDBYCD   DBGMCU_CR_DBG_STANDBYCD_Msk
#define DBGMCU_CR_DBG_SLEEPD1_Pos   DBGMCU_CR_DBG_SLEEPCD_Pos
#define DBGMCU_CR_DBG_SLEEPD1_Msk   DBGMCU_CR_DBG_SLEEPCD_Msk
#define DBGMCU_CR_DBG_SLEEPD1   DBGMCU_CR_DBG_SLEEPCD
#define DBGMCU_CR_DBG_STOPD1_Pos   DBGMCU_CR_DBG_STOPCD_Pos
#define DBGMCU_CR_DBG_STOPD1_Msk   DBGMCU_CR_DBG_STOPCD_Msk
#define DBGMCU_CR_DBG_STOPD1   DBGMCU_CR_DBG_STOPCD
#define DBGMCU_CR_DBG_STANDBYD1_Pos   DBGMCU_CR_DBG_STANDBYCD_Pos
#define DBGMCU_CR_DBG_STANDBYD1_Msk   DBGMCU_CR_DBG_STANDBYCD_Msk
#define DBGMCU_CR_DBG_STANDBYD1   DBGMCU_CR_DBG_STANDBYCD
#define DBGMCU_CR_DBG_STOPSRD_Pos   (7U)
#define DBGMCU_CR_DBG_STOPSRD_Msk   (0x1UL << DBGMCU_CR_DBG_STOPSRD_Pos)
#define DBGMCU_CR_DBG_STOPSRD   DBGMCU_CR_DBG_STOPSRD_Msk
#define DBGMCU_CR_DBG_STANDBYSRD_Pos   (8U)
#define DBGMCU_CR_DBG_STANDBYSRD_Msk   (0x1UL << DBGMCU_CR_DBG_STANDBYSRD_Pos)
#define DBGMCU_CR_DBG_STANDBYSRD   DBGMCU_CR_DBG_STANDBYSRD_Msk
#define DBGMCU_CR_DBG_STOPD3_Pos   DBGMCU_CR_DBG_STOPSRD_Pos
#define DBGMCU_CR_DBG_STOPD3_Msk   DBGMCU_CR_DBG_STOPSRD_Msk
#define DBGMCU_CR_DBG_STOPD3   DBGMCU_CR_DBG_STOPSRD
#define DBGMCU_CR_DBG_STANDBYD3_Pos   DBGMCU_CR_DBG_STANDBYSRD_Pos
#define DBGMCU_CR_DBG_STANDBYD3_Msk   DBGMCU_CR_DBG_STANDBYSRD_Msk
#define DBGMCU_CR_DBG_STANDBYD3   DBGMCU_CR_DBG_STANDBYSRD
#define DBGMCU_CR_DBG_TRACECKEN_Pos   (20U)
#define DBGMCU_CR_DBG_TRACECKEN_Msk   (0x1UL << DBGMCU_CR_DBG_TRACECKEN_Pos)
#define DBGMCU_CR_DBG_TRACECKEN   DBGMCU_CR_DBG_TRACECKEN_Msk
#define DBGMCU_CR_DBG_CKCDEN_Pos   (21U)
#define DBGMCU_CR_DBG_CKCDEN_Msk   (0x1UL << DBGMCU_CR_DBG_CKCDEN_Pos)
#define DBGMCU_CR_DBG_CKCDEN   DBGMCU_CR_DBG_CKCDEN_Msk
#define DBGMCU_CR_DBG_CKSRDEN_Pos   (22U)
#define DBGMCU_CR_DBG_CKSRDEN_Msk   (0x1UL << DBGMCU_CR_DBG_CKSRDEN_Pos)
#define DBGMCU_CR_DBG_CKSRDEN   DBGMCU_CR_DBG_CKSRDEN_Msk
#define DBGMCU_CR_DBG_CKD1EN_Pos   DBGMCU_CR_DBG_CKCDEN_Pos
#define DBGMCU_CR_DBG_CKD1EN_Msk   DBGMCU_CR_DBG_CKCDEN_Msk
#define DBGMCU_CR_DBG_CKD1EN   DBGMCU_CR_DBG_CKCDEN
#define DBGMCU_CR_DBG_CKD3EN_Pos   DBGMCU_CR_DBG_CKSRDEN_Pos
#define DBGMCU_CR_DBG_CKD3EN_Msk   DBGMCU_CR_DBG_CKSRDEN_Msk
#define DBGMCU_CR_DBG_CKD3EN   DBGMCU_CR_DBG_CKSRDEN
#define DBGMCU_CR_DBG_TRGOEN_Pos   (28U)
#define DBGMCU_CR_DBG_TRGOEN_Msk   (0x1UL << DBGMCU_CR_DBG_TRGOEN_Pos)
#define DBGMCU_CR_DBG_TRGOEN   DBGMCU_CR_DBG_TRGOEN_Msk
#define DBGMCU_APB3FZ1_DBG_WWDG1_Pos   (6U)
#define DBGMCU_APB3FZ1_DBG_WWDG1_Msk   (0x1UL << DBGMCU_APB3FZ1_DBG_WWDG1_Pos)
#define DBGMCU_APB3FZ1_DBG_WWDG1   DBGMCU_APB3FZ1_DBG_WWDG1_Msk
#define DBGMCU_APB1LFZ1_DBG_TIM2_Pos   (0U)
#define DBGMCU_APB1LFZ1_DBG_TIM2_Msk   (0x1UL << DBGMCU_APB1LFZ1_DBG_TIM2_Pos)
#define DBGMCU_APB1LFZ1_DBG_TIM2   DBGMCU_APB1LFZ1_DBG_TIM2_Msk
#define DBGMCU_APB1LFZ1_DBG_TIM3_Pos   (1U)
#define DBGMCU_APB1LFZ1_DBG_TIM3_Msk   (0x1UL << DBGMCU_APB1LFZ1_DBG_TIM3_Pos)
#define DBGMCU_APB1LFZ1_DBG_TIM3   DBGMCU_APB1LFZ1_DBG_TIM3_Msk
#define DBGMCU_APB1LFZ1_DBG_TIM4_Pos   (2U)
#define DBGMCU_APB1LFZ1_DBG_TIM4_Msk   (0x1UL << DBGMCU_APB1LFZ1_DBG_TIM4_Pos)
#define DBGMCU_APB1LFZ1_DBG_TIM4   DBGMCU_APB1LFZ1_DBG_TIM4_Msk
#define DBGMCU_APB1LFZ1_DBG_TIM5_Pos   (3U)
#define DBGMCU_APB1LFZ1_DBG_TIM5_Msk   (0x1UL << DBGMCU_APB1LFZ1_DBG_TIM5_Pos)
#define DBGMCU_APB1LFZ1_DBG_TIM5   DBGMCU_APB1LFZ1_DBG_TIM5_Msk
#define DBGMCU_APB1LFZ1_DBG_TIM6_Pos   (4U)
#define DBGMCU_APB1LFZ1_DBG_TIM6_Msk   (0x1UL << DBGMCU_APB1LFZ1_DBG_TIM6_Pos)
#define DBGMCU_APB1LFZ1_DBG_TIM6   DBGMCU_APB1LFZ1_DBG_TIM6_Msk
#define DBGMCU_APB1LFZ1_DBG_TIM7_Pos   (5U)
#define DBGMCU_APB1LFZ1_DBG_TIM7_Msk   (0x1UL << DBGMCU_APB1LFZ1_DBG_TIM7_Pos)
#define DBGMCU_APB1LFZ1_DBG_TIM7   DBGMCU_APB1LFZ1_DBG_TIM7_Msk
#define DBGMCU_APB1LFZ1_DBG_TIM12_Pos   (6U)
#define DBGMCU_APB1LFZ1_DBG_TIM12_Msk   (0x1UL << DBGMCU_APB1LFZ1_DBG_TIM12_Pos)
#define DBGMCU_APB1LFZ1_DBG_TIM12   DBGMCU_APB1LFZ1_DBG_TIM12_Msk
#define DBGMCU_APB1LFZ1_DBG_TIM13_Pos   (7U)
#define DBGMCU_APB1LFZ1_DBG_TIM13_Msk   (0x1UL << DBGMCU_APB1LFZ1_DBG_TIM13_Pos)
#define DBGMCU_APB1LFZ1_DBG_TIM13   DBGMCU_APB1LFZ1_DBG_TIM13_Msk
#define DBGMCU_APB1LFZ1_DBG_TIM14_Pos   (8U)
#define DBGMCU_APB1LFZ1_DBG_TIM14_Msk   (0x1UL << DBGMCU_APB1LFZ1_DBG_TIM14_Pos)
#define DBGMCU_APB1LFZ1_DBG_TIM14   DBGMCU_APB1LFZ1_DBG_TIM14_Msk
#define DBGMCU_APB1LFZ1_DBG_LPTIM1_Pos   (9U)
#define DBGMCU_APB1LFZ1_DBG_LPTIM1_Msk   (0x1UL << DBGMCU_APB1LFZ1_DBG_LPTIM1_Pos)
#define DBGMCU_APB1LFZ1_DBG_LPTIM1   DBGMCU_APB1LFZ1_DBG_LPTIM1_Msk
#define DBGMCU_APB1LFZ1_DBG_I2C1_Pos   (21U)
#define DBGMCU_APB1LFZ1_DBG_I2C1_Msk   (0x1UL << DBGMCU_APB1LFZ1_DBG_I2C1_Pos)
#define DBGMCU_APB1LFZ1_DBG_I2C1   DBGMCU_APB1LFZ1_DBG_I2C1_Msk
#define DBGMCU_APB1LFZ1_DBG_I2C2_Pos   (22U)
#define DBGMCU_APB1LFZ1_DBG_I2C2_Msk   (0x1UL << DBGMCU_APB1LFZ1_DBG_I2C2_Pos)
#define DBGMCU_APB1LFZ1_DBG_I2C2   DBGMCU_APB1LFZ1_DBG_I2C2_Msk
#define DBGMCU_APB1LFZ1_DBG_I2C3_Pos   (23U)
#define DBGMCU_APB1LFZ1_DBG_I2C3_Msk   (0x1UL << DBGMCU_APB1LFZ1_DBG_I2C3_Pos)
#define DBGMCU_APB1LFZ1_DBG_I2C3   DBGMCU_APB1LFZ1_DBG_I2C3_Msk
#define DBGMCU_APB2FZ1_DBG_TIM1_Pos   (0U)
#define DBGMCU_APB2FZ1_DBG_TIM1_Msk   (0x1UL << DBGMCU_APB2FZ1_DBG_TIM1_Pos)
#define DBGMCU_APB2FZ1_DBG_TIM1   DBGMCU_APB2FZ1_DBG_TIM1_Msk
#define DBGMCU_APB2FZ1_DBG_TIM8_Pos   (1U)
#define DBGMCU_APB2FZ1_DBG_TIM8_Msk   (0x1UL << DBGMCU_APB2FZ1_DBG_TIM8_Pos)
#define DBGMCU_APB2FZ1_DBG_TIM8   DBGMCU_APB2FZ1_DBG_TIM8_Msk
#define DBGMCU_APB2FZ1_DBG_TIM15_Pos   (16U)
#define DBGMCU_APB2FZ1_DBG_TIM15_Msk   (0x1UL << DBGMCU_APB2FZ1_DBG_TIM15_Pos)
#define DBGMCU_APB2FZ1_DBG_TIM15   DBGMCU_APB2FZ1_DBG_TIM15_Msk
#define DBGMCU_APB2FZ1_DBG_TIM16_Pos   (17U)
#define DBGMCU_APB2FZ1_DBG_TIM16_Msk   (0x1UL << DBGMCU_APB2FZ1_DBG_TIM16_Pos)
#define DBGMCU_APB2FZ1_DBG_TIM16   DBGMCU_APB2FZ1_DBG_TIM16_Msk
#define DBGMCU_APB2FZ1_DBG_TIM17_Pos   (18U)
#define DBGMCU_APB2FZ1_DBG_TIM17_Msk   (0x1UL << DBGMCU_APB2FZ1_DBG_TIM17_Pos)
#define DBGMCU_APB2FZ1_DBG_TIM17   DBGMCU_APB2FZ1_DBG_TIM17_Msk
#define DBGMCU_APB4FZ1_DBG_I2C4_Pos   (7U)
#define DBGMCU_APB4FZ1_DBG_I2C4_Msk   (0x1UL << DBGMCU_APB4FZ1_DBG_I2C4_Pos)
#define DBGMCU_APB4FZ1_DBG_I2C4   DBGMCU_APB4FZ1_DBG_I2C4_Msk
#define DBGMCU_APB4FZ1_DBG_LPTIM2_Pos   (9U)
#define DBGMCU_APB4FZ1_DBG_LPTIM2_Msk   (0x1UL << DBGMCU_APB4FZ1_DBG_LPTIM2_Pos)
#define DBGMCU_APB4FZ1_DBG_LPTIM2   DBGMCU_APB4FZ1_DBG_LPTIM2_Msk
#define DBGMCU_APB4FZ1_DBG_LPTIM3_Pos   (10U)
#define DBGMCU_APB4FZ1_DBG_LPTIM3_Msk   (0x1UL << DBGMCU_APB4FZ1_DBG_LPTIM3_Pos)
#define DBGMCU_APB4FZ1_DBG_LPTIM3   DBGMCU_APB4FZ1_DBG_LPTIM3_Msk
#define DBGMCU_APB4FZ1_DBG_RTC_Pos   (16U)
#define DBGMCU_APB4FZ1_DBG_RTC_Msk   (0x1UL << DBGMCU_APB4FZ1_DBG_RTC_Pos)
#define DBGMCU_APB4FZ1_DBG_RTC   DBGMCU_APB4FZ1_DBG_RTC_Msk
#define DBGMCU_APB4FZ1_DBG_IWDG1_Pos   (18U)
#define DBGMCU_APB4FZ1_DBG_IWDG1_Msk   (0x1UL << DBGMCU_APB4FZ1_DBG_IWDG1_Pos)
#define DBGMCU_APB4FZ1_DBG_IWDG1   DBGMCU_APB4FZ1_DBG_IWDG1_Msk
#define RAMECC_IER_GECCDEBWIE_Pos   (3U)
#define RAMECC_IER_GECCDEBWIE_Msk   (0x1UL << RAMECC_IER_GECCDEBWIE_Pos)
#define RAMECC_IER_GECCDEBWIE   RAMECC_IER_GECCDEBWIE_Msk
#define RAMECC_IER_GECCDEIE_Pos   (2U)
#define RAMECC_IER_GECCDEIE_Msk   (0x1UL << RAMECC_IER_GECCDEIE_Pos)
#define RAMECC_IER_GECCDEIE   RAMECC_IER_GECCDEIE_Msk
#define RAMECC_IER_GECCSEIE_Pos   (1U)
#define RAMECC_IER_GECCSEIE_Msk   (0x1UL << RAMECC_IER_GECCSEIE_Pos)
#define RAMECC_IER_GECCSEIE   RAMECC_IER_GECCSEIE_Msk
#define RAMECC_IER_GIE_Pos   (0U)
#define RAMECC_IER_GIE_Msk   (0x1UL << RAMECC_IER_GIE_Pos)
#define RAMECC_IER_GIE   RAMECC_IER_GIE_Msk
#define RAMECC_CR_ECCELEN_Pos   (5U)
#define RAMECC_CR_ECCELEN_Msk   (0x1UL << RAMECC_CR_ECCELEN_Pos)
#define RAMECC_CR_ECCELEN   RAMECC_CR_ECCELEN_Msk
#define RAMECC_CR_ECCDEBWIE_Pos   (4U)
#define RAMECC_CR_ECCDEBWIE_Msk   (0x1UL << RAMECC_CR_ECCDEBWIE_Pos)
#define RAMECC_CR_ECCDEBWIE   RAMECC_CR_ECCDEBWIE_Msk
#define RAMECC_CR_ECCDEIE_Pos   (3U)
#define RAMECC_CR_ECCDEIE_Msk   (0x1UL << RAMECC_CR_ECCDEIE_Pos)
#define RAMECC_CR_ECCDEIE   RAMECC_CR_ECCDEIE_Msk
#define RAMECC_CR_ECCSEIE_Pos   (2U)
#define RAMECC_CR_ECCSEIE_Msk   (0x1UL << RAMECC_CR_ECCSEIE_Pos)
#define RAMECC_CR_ECCSEIE   RAMECC_CR_ECCSEIE_Msk
#define RAMECC_SR_DEBWDF_Pos   (2U)
#define RAMECC_SR_DEBWDF_Msk   (0x1UL << RAMECC_SR_DEBWDF_Pos)
#define RAMECC_SR_DEBWDF   RAMECC_SR_DEBWDF_Msk
#define RAMECC_SR_DEDF_Pos   (1U)
#define RAMECC_SR_DEDF_Msk   (0x1UL << RAMECC_SR_DEDF_Pos)
#define RAMECC_SR_DEDF   RAMECC_SR_DEDF_Msk
#define RAMECC_SR_SEDCF_Pos   (0U)
#define RAMECC_SR_SEDCF_Msk   (0x1UL << RAMECC_SR_SEDCF_Pos)
#define RAMECC_SR_SEDCF   RAMECC_SR_SEDCF_Msk
#define RAMECC_FAR_FADD_Pos   (0U)
#define RAMECC_FAR_FADD_Msk   (0xFFFFFFFFUL << RAMECC_FAR_FADD_Pos)
#define RAMECC_FAR_FADD   RAMECC_FAR_FADD_Msk
#define RAMECC_FAR_FDATAL_Pos   (0U)
#define RAMECC_FAR_FDATAL_Msk   (0xFFFFFFFFUL << RAMECC_FAR_FDATAL_Pos)
#define RAMECC_FAR_FDATAL   RAMECC_FAR_FDATAL_Msk
#define RAMECC_FAR_FDATAH_Pos   (0U)
#define RAMECC_FAR_FDATAH_Msk   (0xFFFFFFFFUL << RAMECC_FAR_FDATAH_Pos)
#define RAMECC_FAR_FDATAH   RAMECC_FAR_FDATAH_Msk /* Failing data high (64-bit memory) */
#define RAMECC_FECR_FEC_Pos   (0U)
#define RAMECC_FECR_FEC_Msk   (0xFFFFFFFFUL << RAMECC_FECR_FEC_Pos)
#define RAMECC_FECR_FEC   RAMECC_FECR_FEC_Msk
#define MDIOS_CR_EN_Pos   (0U)
#define MDIOS_CR_EN_Msk   (0x1UL << MDIOS_CR_EN_Pos)
#define MDIOS_CR_EN   MDIOS_CR_EN_Msk
#define MDIOS_CR_WRIE_Pos   (1U)
#define MDIOS_CR_WRIE_Msk   (0x1UL << MDIOS_CR_WRIE_Pos)
#define MDIOS_CR_WRIE   MDIOS_CR_WRIE_Msk
#define MDIOS_CR_RDIE_Pos   (2U)
#define MDIOS_CR_RDIE_Msk   (0x1UL << MDIOS_CR_RDIE_Pos)
#define MDIOS_CR_RDIE   MDIOS_CR_RDIE_Msk
#define MDIOS_CR_EIE_Pos   (3U)
#define MDIOS_CR_EIE_Msk   (0x1UL << MDIOS_CR_EIE_Pos)
#define MDIOS_CR_EIE   MDIOS_CR_EIE_Msk
#define MDIOS_CR_DPC_Pos   (7U)
#define MDIOS_CR_DPC_Msk   (0x1UL << MDIOS_CR_DPC_Pos)
#define MDIOS_CR_DPC   MDIOS_CR_DPC_Msk
#define MDIOS_CR_PORT_ADDRESS_Pos   (8U)
#define MDIOS_CR_PORT_ADDRESS_Msk   (0x1FUL << MDIOS_CR_PORT_ADDRESS_Pos)
#define MDIOS_CR_PORT_ADDRESS   MDIOS_CR_PORT_ADDRESS_Msk
#define MDIOS_CR_PORT_ADDRESS_0   (0x01UL << MDIOS_CR_PORT_ADDRESS_Pos)
#define MDIOS_CR_PORT_ADDRESS_1   (0x02UL << MDIOS_CR_PORT_ADDRESS_Pos)
#define MDIOS_CR_PORT_ADDRESS_2   (0x04UL << MDIOS_CR_PORT_ADDRESS_Pos)
#define MDIOS_CR_PORT_ADDRESS_3   (0x08UL << MDIOS_CR_PORT_ADDRESS_Pos)
#define MDIOS_CR_PORT_ADDRESS_4   (0x10UL << MDIOS_CR_PORT_ADDRESS_Pos)
#define MDIOS_SR_PERF_Pos   (0U)
#define MDIOS_SR_PERF_Msk   (0x1UL << MDIOS_SR_PERF_Pos)
#define MDIOS_SR_PERF   MDIOS_SR_PERF_Msk
#define MDIOS_SR_SERF_Pos   (1U)
#define MDIOS_SR_SERF_Msk   (0x1UL << MDIOS_SR_SERF_Pos)
#define MDIOS_SR_SERF   MDIOS_SR_SERF_Msk
#define MDIOS_SR_TERF_Pos   (2U)
#define MDIOS_SR_TERF_Msk   (0x1UL << MDIOS_SR_TERF_Pos)
#define MDIOS_SR_TERF   MDIOS_SR_TERF_Msk
#define MDIOS_SR_CPERF_Pos   (0U)
#define MDIOS_SR_CPERF_Msk   (0x1UL << MDIOS_SR_CPERF_Pos)
#define MDIOS_SR_CPERF   MDIOS_SR_CPERF_Msk
#define MDIOS_SR_CSERF_Pos   (1U)
#define MDIOS_SR_CSERF_Msk   (0x1UL << MDIOS_SR_CSERF_Pos)
#define MDIOS_SR_CSERF   MDIOS_SR_CSERF_Msk
#define MDIOS_SR_CTERF_Pos   (2U)
#define MDIOS_SR_CTERF_Msk   (0x1UL << MDIOS_SR_CTERF_Pos)
#define MDIOS_SR_CTERF   MDIOS_SR_CTERF_Msk
#define USB_OTG_GOTGCTL_SRQSCS_Pos   (0U)
#define USB_OTG_GOTGCTL_SRQSCS_Msk   (0x1UL << USB_OTG_GOTGCTL_SRQSCS_Pos)
#define USB_OTG_GOTGCTL_SRQSCS   USB_OTG_GOTGCTL_SRQSCS_Msk
#define USB_OTG_GOTGCTL_SRQ_Pos   (1U)
#define USB_OTG_GOTGCTL_SRQ_Msk   (0x1UL << USB_OTG_GOTGCTL_SRQ_Pos)
#define USB_OTG_GOTGCTL_SRQ   USB_OTG_GOTGCTL_SRQ_Msk
#define USB_OTG_GOTGCTL_VBVALOEN_Pos   (2U)
#define USB_OTG_GOTGCTL_VBVALOEN_Msk   (0x1UL << USB_OTG_GOTGCTL_VBVALOEN_Pos)
#define USB_OTG_GOTGCTL_VBVALOEN   USB_OTG_GOTGCTL_VBVALOEN_Msk
#define USB_OTG_GOTGCTL_VBVALOVAL_Pos   (3U)
#define USB_OTG_GOTGCTL_VBVALOVAL_Msk   (0x1UL << USB_OTG_GOTGCTL_VBVALOVAL_Pos)
#define USB_OTG_GOTGCTL_VBVALOVAL   USB_OTG_GOTGCTL_VBVALOVAL_Msk
#define USB_OTG_GOTGCTL_AVALOEN_Pos   (4U)
#define USB_OTG_GOTGCTL_AVALOEN_Msk   (0x1UL << USB_OTG_GOTGCTL_AVALOEN_Pos)
#define USB_OTG_GOTGCTL_AVALOEN   USB_OTG_GOTGCTL_AVALOEN_Msk
#define USB_OTG_GOTGCTL_AVALOVAL_Pos   (5U)
#define USB_OTG_GOTGCTL_AVALOVAL_Msk   (0x1UL << USB_OTG_GOTGCTL_AVALOVAL_Pos)
#define USB_OTG_GOTGCTL_AVALOVAL   USB_OTG_GOTGCTL_AVALOVAL_Msk
#define USB_OTG_GOTGCTL_BVALOEN_Pos   (6U)
#define USB_OTG_GOTGCTL_BVALOEN_Msk   (0x1UL << USB_OTG_GOTGCTL_BVALOEN_Pos)
#define USB_OTG_GOTGCTL_BVALOEN   USB_OTG_GOTGCTL_BVALOEN_Msk
#define USB_OTG_GOTGCTL_BVALOVAL_Pos   (7U)
#define USB_OTG_GOTGCTL_BVALOVAL_Msk   (0x1UL << USB_OTG_GOTGCTL_BVALOVAL_Pos)
#define USB_OTG_GOTGCTL_BVALOVAL   USB_OTG_GOTGCTL_BVALOVAL_Msk
#define USB_OTG_GOTGCTL_HNGSCS_Pos   (8U)
#define USB_OTG_GOTGCTL_HNGSCS_Msk   (0x1UL << USB_OTG_GOTGCTL_HNGSCS_Pos)
#define USB_OTG_GOTGCTL_HNGSCS   USB_OTG_GOTGCTL_HNGSCS_Msk
#define USB_OTG_GOTGCTL_HNPRQ_Pos   (9U)
#define USB_OTG_GOTGCTL_HNPRQ_Msk   (0x1UL << USB_OTG_GOTGCTL_HNPRQ_Pos)
#define USB_OTG_GOTGCTL_HNPRQ   USB_OTG_GOTGCTL_HNPRQ_Msk
#define USB_OTG_GOTGCTL_HSHNPEN_Pos   (10U)
#define USB_OTG_GOTGCTL_HSHNPEN_Msk   (0x1UL << USB_OTG_GOTGCTL_HSHNPEN_Pos)
#define USB_OTG_GOTGCTL_HSHNPEN   USB_OTG_GOTGCTL_HSHNPEN_Msk
#define USB_OTG_GOTGCTL_DHNPEN_Pos   (11U)
#define USB_OTG_GOTGCTL_DHNPEN_Msk   (0x1UL << USB_OTG_GOTGCTL_DHNPEN_Pos)
#define USB_OTG_GOTGCTL_DHNPEN   USB_OTG_GOTGCTL_DHNPEN_Msk
#define USB_OTG_GOTGCTL_EHEN_Pos   (12U)
#define USB_OTG_GOTGCTL_EHEN_Msk   (0x1UL << USB_OTG_GOTGCTL_EHEN_Pos)
#define USB_OTG_GOTGCTL_EHEN   USB_OTG_GOTGCTL_EHEN_Msk
#define USB_OTG_GOTGCTL_CIDSTS_Pos   (16U)
#define USB_OTG_GOTGCTL_CIDSTS_Msk   (0x1UL << USB_OTG_GOTGCTL_CIDSTS_Pos)
#define USB_OTG_GOTGCTL_CIDSTS   USB_OTG_GOTGCTL_CIDSTS_Msk
#define USB_OTG_GOTGCTL_DBCT_Pos   (17U)
#define USB_OTG_GOTGCTL_DBCT_Msk   (0x1UL << USB_OTG_GOTGCTL_DBCT_Pos)
#define USB_OTG_GOTGCTL_DBCT   USB_OTG_GOTGCTL_DBCT_Msk
#define USB_OTG_GOTGCTL_ASVLD_Pos   (18U)
#define USB_OTG_GOTGCTL_ASVLD_Msk   (0x1UL << USB_OTG_GOTGCTL_ASVLD_Pos)
#define USB_OTG_GOTGCTL_ASVLD   USB_OTG_GOTGCTL_ASVLD_Msk
#define USB_OTG_GOTGCTL_BSESVLD_Pos   (19U)
#define USB_OTG_GOTGCTL_BSESVLD_Msk   (0x1UL << USB_OTG_GOTGCTL_BSESVLD_Pos)
#define USB_OTG_GOTGCTL_BSESVLD   USB_OTG_GOTGCTL_BSESVLD_Msk
#define USB_OTG_GOTGCTL_OTGVER_Pos   (20U)
#define USB_OTG_GOTGCTL_OTGVER_Msk   (0x1UL << USB_OTG_GOTGCTL_OTGVER_Pos)
#define USB_OTG_GOTGCTL_OTGVER   USB_OTG_GOTGCTL_OTGVER_Msk
#define USB_OTG_GOTGCTL_CURMOD_Pos   (21U)
#define USB_OTG_GOTGCTL_CURMOD_Msk   (0x1UL << USB_OTG_GOTGCTL_CURMOD_Pos)
#define USB_OTG_GOTGCTL_CURMOD   USB_OTG_GOTGCTL_CURMOD_Msk
#define USB_OTG_HCFG_FSLSPCS_Pos   (0U)
#define USB_OTG_HCFG_FSLSPCS_Msk   (0x3UL << USB_OTG_HCFG_FSLSPCS_Pos)
#define USB_OTG_HCFG_FSLSPCS   USB_OTG_HCFG_FSLSPCS_Msk
#define USB_OTG_HCFG_FSLSPCS_0   (0x1UL << USB_OTG_HCFG_FSLSPCS_Pos)
#define USB_OTG_HCFG_FSLSPCS_1   (0x2UL << USB_OTG_HCFG_FSLSPCS_Pos)
#define USB_OTG_HCFG_FSLSS_Pos   (2U)
#define USB_OTG_HCFG_FSLSS_Msk   (0x1UL << USB_OTG_HCFG_FSLSS_Pos)
#define USB_OTG_HCFG_FSLSS   USB_OTG_HCFG_FSLSS_Msk
#define USB_OTG_DCFG_DSPD_Pos   (0U)
#define USB_OTG_DCFG_DSPD_Msk   (0x3UL << USB_OTG_DCFG_DSPD_Pos)
#define USB_OTG_DCFG_DSPD   USB_OTG_DCFG_DSPD_Msk
#define USB_OTG_DCFG_DSPD_0   (0x1UL << USB_OTG_DCFG_DSPD_Pos)
#define USB_OTG_DCFG_DSPD_1   (0x2UL << USB_OTG_DCFG_DSPD_Pos)
#define USB_OTG_DCFG_NZLSOHSK_Pos   (2U)
#define USB_OTG_DCFG_NZLSOHSK_Msk   (0x1UL << USB_OTG_DCFG_NZLSOHSK_Pos)
#define USB_OTG_DCFG_NZLSOHSK   USB_OTG_DCFG_NZLSOHSK_Msk
#define USB_OTG_DCFG_DAD_Pos   (4U)
#define USB_OTG_DCFG_DAD_Msk   (0x7FUL << USB_OTG_DCFG_DAD_Pos)
#define USB_OTG_DCFG_DAD   USB_OTG_DCFG_DAD_Msk
#define USB_OTG_DCFG_DAD_0   (0x01UL << USB_OTG_DCFG_DAD_Pos)
#define USB_OTG_DCFG_DAD_1   (0x02UL << USB_OTG_DCFG_DAD_Pos)
#define USB_OTG_DCFG_DAD_2   (0x04UL << USB_OTG_DCFG_DAD_Pos)
#define USB_OTG_DCFG_DAD_3   (0x08UL << USB_OTG_DCFG_DAD_Pos)
#define USB_OTG_DCFG_DAD_4   (0x10UL << USB_OTG_DCFG_DAD_Pos)
#define USB_OTG_DCFG_DAD_5   (0x20UL << USB_OTG_DCFG_DAD_Pos)
#define USB_OTG_DCFG_DAD_6   (0x40UL << USB_OTG_DCFG_DAD_Pos)
#define USB_OTG_DCFG_PFIVL_Pos   (11U)
#define USB_OTG_DCFG_PFIVL_Msk   (0x3UL << USB_OTG_DCFG_PFIVL_Pos)
#define USB_OTG_DCFG_PFIVL   USB_OTG_DCFG_PFIVL_Msk
#define USB_OTG_DCFG_PFIVL_0   (0x1UL << USB_OTG_DCFG_PFIVL_Pos)
#define USB_OTG_DCFG_PFIVL_1   (0x2UL << USB_OTG_DCFG_PFIVL_Pos)
#define USB_OTG_DCFG_XCVRDLY_Pos   (14U)
#define USB_OTG_DCFG_XCVRDLY_Msk   (0x1UL << USB_OTG_DCFG_XCVRDLY_Pos)
#define USB_OTG_DCFG_XCVRDLY   USB_OTG_DCFG_XCVRDLY_Msk
#define USB_OTG_DCFG_ERRATIM_Pos   (15U)
#define USB_OTG_DCFG_ERRATIM_Msk   (0x1UL << USB_OTG_DCFG_ERRATIM_Pos)
#define USB_OTG_DCFG_ERRATIM   USB_OTG_DCFG_ERRATIM_Msk
#define USB_OTG_DCFG_PERSCHIVL_Pos   (24U)
#define USB_OTG_DCFG_PERSCHIVL_Msk   (0x3UL << USB_OTG_DCFG_PERSCHIVL_Pos)
#define USB_OTG_DCFG_PERSCHIVL   USB_OTG_DCFG_PERSCHIVL_Msk
#define USB_OTG_DCFG_PERSCHIVL_0   (0x1UL << USB_OTG_DCFG_PERSCHIVL_Pos)
#define USB_OTG_DCFG_PERSCHIVL_1   (0x2UL << USB_OTG_DCFG_PERSCHIVL_Pos)
#define USB_OTG_PCGCR_STPPCLK_Pos   (0U)
#define USB_OTG_PCGCR_STPPCLK_Msk   (0x1UL << USB_OTG_PCGCR_STPPCLK_Pos)
#define USB_OTG_PCGCR_STPPCLK   USB_OTG_PCGCR_STPPCLK_Msk
#define USB_OTG_PCGCR_GATEHCLK_Pos   (1U)
#define USB_OTG_PCGCR_GATEHCLK_Msk   (0x1UL << USB_OTG_PCGCR_GATEHCLK_Pos)
#define USB_OTG_PCGCR_GATEHCLK   USB_OTG_PCGCR_GATEHCLK_Msk
#define USB_OTG_PCGCR_PHYSUSP_Pos   (4U)
#define USB_OTG_PCGCR_PHYSUSP_Msk   (0x1UL << USB_OTG_PCGCR_PHYSUSP_Pos)
#define USB_OTG_PCGCR_PHYSUSP   USB_OTG_PCGCR_PHYSUSP_Msk
#define USB_OTG_GOTGINT_SEDET_Pos   (2U)
#define USB_OTG_GOTGINT_SEDET_Msk   (0x1UL << USB_OTG_GOTGINT_SEDET_Pos)
#define USB_OTG_GOTGINT_SEDET   USB_OTG_GOTGINT_SEDET_Msk
#define USB_OTG_GOTGINT_SRSSCHG_Pos   (8U)
#define USB_OTG_GOTGINT_SRSSCHG_Msk   (0x1UL << USB_OTG_GOTGINT_SRSSCHG_Pos)
#define USB_OTG_GOTGINT_SRSSCHG   USB_OTG_GOTGINT_SRSSCHG_Msk
#define USB_OTG_GOTGINT_HNSSCHG_Pos   (9U)
#define USB_OTG_GOTGINT_HNSSCHG_Msk   (0x1UL << USB_OTG_GOTGINT_HNSSCHG_Pos)
#define USB_OTG_GOTGINT_HNSSCHG   USB_OTG_GOTGINT_HNSSCHG_Msk
#define USB_OTG_GOTGINT_HNGDET_Pos   (17U)
#define USB_OTG_GOTGINT_HNGDET_Msk   (0x1UL << USB_OTG_GOTGINT_HNGDET_Pos)
#define USB_OTG_GOTGINT_HNGDET   USB_OTG_GOTGINT_HNGDET_Msk
#define USB_OTG_GOTGINT_ADTOCHG_Pos   (18U)
#define USB_OTG_GOTGINT_ADTOCHG_Msk   (0x1UL << USB_OTG_GOTGINT_ADTOCHG_Pos)
#define USB_OTG_GOTGINT_ADTOCHG   USB_OTG_GOTGINT_ADTOCHG_Msk
#define USB_OTG_GOTGINT_DBCDNE_Pos   (19U)
#define USB_OTG_GOTGINT_DBCDNE_Msk   (0x1UL << USB_OTG_GOTGINT_DBCDNE_Pos)
#define USB_OTG_GOTGINT_DBCDNE   USB_OTG_GOTGINT_DBCDNE_Msk
#define USB_OTG_DCTL_RWUSIG_Pos   (0U)
#define USB_OTG_DCTL_RWUSIG_Msk   (0x1UL << USB_OTG_DCTL_RWUSIG_Pos)
#define USB_OTG_DCTL_RWUSIG   USB_OTG_DCTL_RWUSIG_Msk
#define USB_OTG_DCTL_SDIS_Pos   (1U)
#define USB_OTG_DCTL_SDIS_Msk   (0x1UL << USB_OTG_DCTL_SDIS_Pos)
#define USB_OTG_DCTL_SDIS   USB_OTG_DCTL_SDIS_Msk
#define USB_OTG_DCTL_GINSTS_Pos   (2U)
#define USB_OTG_DCTL_GINSTS_Msk   (0x1UL << USB_OTG_DCTL_GINSTS_Pos)
#define USB_OTG_DCTL_GINSTS   USB_OTG_DCTL_GINSTS_Msk
#define USB_OTG_DCTL_GONSTS_Pos   (3U)
#define USB_OTG_DCTL_GONSTS_Msk   (0x1UL << USB_OTG_DCTL_GONSTS_Pos)
#define USB_OTG_DCTL_GONSTS   USB_OTG_DCTL_GONSTS_Msk
#define USB_OTG_DCTL_TCTL_Pos   (4U)
#define USB_OTG_DCTL_TCTL_Msk   (0x7UL << USB_OTG_DCTL_TCTL_Pos)
#define USB_OTG_DCTL_TCTL   USB_OTG_DCTL_TCTL_Msk
#define USB_OTG_DCTL_TCTL_0   (0x1UL << USB_OTG_DCTL_TCTL_Pos)
#define USB_OTG_DCTL_TCTL_1   (0x2UL << USB_OTG_DCTL_TCTL_Pos)
#define USB_OTG_DCTL_TCTL_2   (0x4UL << USB_OTG_DCTL_TCTL_Pos)
#define USB_OTG_DCTL_SGINAK_Pos   (7U)
#define USB_OTG_DCTL_SGINAK_Msk   (0x1UL << USB_OTG_DCTL_SGINAK_Pos)
#define USB_OTG_DCTL_SGINAK   USB_OTG_DCTL_SGINAK_Msk
#define USB_OTG_DCTL_CGINAK_Pos   (8U)
#define USB_OTG_DCTL_CGINAK_Msk   (0x1UL << USB_OTG_DCTL_CGINAK_Pos)
#define USB_OTG_DCTL_CGINAK   USB_OTG_DCTL_CGINAK_Msk
#define USB_OTG_DCTL_SGONAK_Pos   (9U)
#define USB_OTG_DCTL_SGONAK_Msk   (0x1UL << USB_OTG_DCTL_SGONAK_Pos)
#define USB_OTG_DCTL_SGONAK   USB_OTG_DCTL_SGONAK_Msk
#define USB_OTG_DCTL_CGONAK_Pos   (10U)
#define USB_OTG_DCTL_CGONAK_Msk   (0x1UL << USB_OTG_DCTL_CGONAK_Pos)
#define USB_OTG_DCTL_CGONAK   USB_OTG_DCTL_CGONAK_Msk
#define USB_OTG_DCTL_POPRGDNE_Pos   (11U)
#define USB_OTG_DCTL_POPRGDNE_Msk   (0x1UL << USB_OTG_DCTL_POPRGDNE_Pos)
#define USB_OTG_DCTL_POPRGDNE   USB_OTG_DCTL_POPRGDNE_Msk
#define USB_OTG_DCTL_ENCONTONBNA_Pos   (17U)
#define USB_OTG_DCTL_ENCONTONBNA_Msk   (0x1UL << USB_OTG_DCTL_ENCONTONBNA_Pos)
#define USB_OTG_DCTL_ENCONTONBNA   USB_OTG_DCTL_ENCONTONBNA_Msk
#define USB_OTG_DCTL_DSBESLRJCT_Pos   (18U)
#define USB_OTG_DCTL_DSBESLRJCT_Msk   (0x1UL << USB_OTG_DCTL_DSBESLRJCT_Pos)
#define USB_OTG_DCTL_DSBESLRJCT   USB_OTG_DCTL_DSBESLRJCT_Msk
#define USB_OTG_HFIR_FRIVL_Pos   (0U)
#define USB_OTG_HFIR_FRIVL_Msk   (0xFFFFUL << USB_OTG_HFIR_FRIVL_Pos)
#define USB_OTG_HFIR_FRIVL   USB_OTG_HFIR_FRIVL_Msk
#define USB_OTG_HFNUM_FRNUM_Pos   (0U)
#define USB_OTG_HFNUM_FRNUM_Msk   (0xFFFFUL << USB_OTG_HFNUM_FRNUM_Pos)
#define USB_OTG_HFNUM_FRNUM   USB_OTG_HFNUM_FRNUM_Msk
#define USB_OTG_HFNUM_FTREM_Pos   (16U)
#define USB_OTG_HFNUM_FTREM_Msk   (0xFFFFUL << USB_OTG_HFNUM_FTREM_Pos)
#define USB_OTG_HFNUM_FTREM   USB_OTG_HFNUM_FTREM_Msk
#define USB_OTG_DSTS_SUSPSTS_Pos   (0U)
#define USB_OTG_DSTS_SUSPSTS_Msk   (0x1UL << USB_OTG_DSTS_SUSPSTS_Pos)
#define USB_OTG_DSTS_SUSPSTS   USB_OTG_DSTS_SUSPSTS_Msk
#define USB_OTG_DSTS_ENUMSPD_Pos   (1U)
#define USB_OTG_DSTS_ENUMSPD_Msk   (0x3UL << USB_OTG_DSTS_ENUMSPD_Pos)
#define USB_OTG_DSTS_ENUMSPD   USB_OTG_DSTS_ENUMSPD_Msk
#define USB_OTG_DSTS_ENUMSPD_0   (0x1UL << USB_OTG_DSTS_ENUMSPD_Pos)
#define USB_OTG_DSTS_ENUMSPD_1   (0x2UL << USB_OTG_DSTS_ENUMSPD_Pos)
#define USB_OTG_DSTS_EERR_Pos   (3U)
#define USB_OTG_DSTS_EERR_Msk   (0x1UL << USB_OTG_DSTS_EERR_Pos)
#define USB_OTG_DSTS_EERR   USB_OTG_DSTS_EERR_Msk
#define USB_OTG_DSTS_FNSOF_Pos   (8U)
#define USB_OTG_DSTS_FNSOF_Msk   (0x3FFFUL << USB_OTG_DSTS_FNSOF_Pos)
#define USB_OTG_DSTS_FNSOF   USB_OTG_DSTS_FNSOF_Msk
#define USB_OTG_GAHBCFG_GINT_Pos   (0U)
#define USB_OTG_GAHBCFG_GINT_Msk   (0x1UL << USB_OTG_GAHBCFG_GINT_Pos)
#define USB_OTG_GAHBCFG_GINT   USB_OTG_GAHBCFG_GINT_Msk
#define USB_OTG_GAHBCFG_HBSTLEN_Pos   (1U)
#define USB_OTG_GAHBCFG_HBSTLEN_Msk   (0xFUL << USB_OTG_GAHBCFG_HBSTLEN_Pos)
#define USB_OTG_GAHBCFG_HBSTLEN   USB_OTG_GAHBCFG_HBSTLEN_Msk
#define USB_OTG_GAHBCFG_HBSTLEN_0   (0x0UL << USB_OTG_GAHBCFG_HBSTLEN_Pos)
#define USB_OTG_GAHBCFG_HBSTLEN_1   (0x1UL << USB_OTG_GAHBCFG_HBSTLEN_Pos)
#define USB_OTG_GAHBCFG_HBSTLEN_2   (0x3UL << USB_OTG_GAHBCFG_HBSTLEN_Pos)
#define USB_OTG_GAHBCFG_HBSTLEN_3   (0x5UL << USB_OTG_GAHBCFG_HBSTLEN_Pos)
#define USB_OTG_GAHBCFG_HBSTLEN_4   (0x7UL << USB_OTG_GAHBCFG_HBSTLEN_Pos)
#define USB_OTG_GAHBCFG_DMAEN_Pos   (5U)
#define USB_OTG_GAHBCFG_DMAEN_Msk   (0x1UL << USB_OTG_GAHBCFG_DMAEN_Pos)
#define USB_OTG_GAHBCFG_DMAEN   USB_OTG_GAHBCFG_DMAEN_Msk
#define USB_OTG_GAHBCFG_TXFELVL_Pos   (7U)
#define USB_OTG_GAHBCFG_TXFELVL_Msk   (0x1UL << USB_OTG_GAHBCFG_TXFELVL_Pos)
#define USB_OTG_GAHBCFG_TXFELVL   USB_OTG_GAHBCFG_TXFELVL_Msk
#define USB_OTG_GAHBCFG_PTXFELVL_Pos   (8U)
#define USB_OTG_GAHBCFG_PTXFELVL_Msk   (0x1UL << USB_OTG_GAHBCFG_PTXFELVL_Pos)
#define USB_OTG_GAHBCFG_PTXFELVL   USB_OTG_GAHBCFG_PTXFELVL_Msk
#define USB_OTG_GUSBCFG_TOCAL_Pos   (0U)
#define USB_OTG_GUSBCFG_TOCAL_Msk   (0x7UL << USB_OTG_GUSBCFG_TOCAL_Pos)
#define USB_OTG_GUSBCFG_TOCAL   USB_OTG_GUSBCFG_TOCAL_Msk
#define USB_OTG_GUSBCFG_TOCAL_0   (0x1UL << USB_OTG_GUSBCFG_TOCAL_Pos)
#define USB_OTG_GUSBCFG_TOCAL_1   (0x2UL << USB_OTG_GUSBCFG_TOCAL_Pos)
#define USB_OTG_GUSBCFG_TOCAL_2   (0x4UL << USB_OTG_GUSBCFG_TOCAL_Pos)
#define USB_OTG_GUSBCFG_PHYSEL_Pos   (6U)
#define USB_OTG_GUSBCFG_PHYSEL_Msk   (0x1UL << USB_OTG_GUSBCFG_PHYSEL_Pos)
#define USB_OTG_GUSBCFG_PHYSEL   USB_OTG_GUSBCFG_PHYSEL_Msk
#define USB_OTG_GUSBCFG_SRPCAP_Pos   (8U)
#define USB_OTG_GUSBCFG_SRPCAP_Msk   (0x1UL << USB_OTG_GUSBCFG_SRPCAP_Pos)
#define USB_OTG_GUSBCFG_SRPCAP   USB_OTG_GUSBCFG_SRPCAP_Msk
#define USB_OTG_GUSBCFG_HNPCAP_Pos   (9U)
#define USB_OTG_GUSBCFG_HNPCAP_Msk   (0x1UL << USB_OTG_GUSBCFG_HNPCAP_Pos)
#define USB_OTG_GUSBCFG_HNPCAP   USB_OTG_GUSBCFG_HNPCAP_Msk
#define USB_OTG_GUSBCFG_TRDT_Pos   (10U)
#define USB_OTG_GUSBCFG_TRDT_Msk   (0xFUL << USB_OTG_GUSBCFG_TRDT_Pos)
#define USB_OTG_GUSBCFG_TRDT   USB_OTG_GUSBCFG_TRDT_Msk
#define USB_OTG_GUSBCFG_TRDT_0   (0x1UL << USB_OTG_GUSBCFG_TRDT_Pos)
#define USB_OTG_GUSBCFG_TRDT_1   (0x2UL << USB_OTG_GUSBCFG_TRDT_Pos)
#define USB_OTG_GUSBCFG_TRDT_2   (0x4UL << USB_OTG_GUSBCFG_TRDT_Pos)
#define USB_OTG_GUSBCFG_TRDT_3   (0x8UL << USB_OTG_GUSBCFG_TRDT_Pos)
#define USB_OTG_GUSBCFG_PHYLPCS_Pos   (15U)
#define USB_OTG_GUSBCFG_PHYLPCS_Msk   (0x1UL << USB_OTG_GUSBCFG_PHYLPCS_Pos)
#define USB_OTG_GUSBCFG_PHYLPCS   USB_OTG_GUSBCFG_PHYLPCS_Msk
#define USB_OTG_GUSBCFG_ULPIFSLS_Pos   (17U)
#define USB_OTG_GUSBCFG_ULPIFSLS_Msk   (0x1UL << USB_OTG_GUSBCFG_ULPIFSLS_Pos)
#define USB_OTG_GUSBCFG_ULPIFSLS   USB_OTG_GUSBCFG_ULPIFSLS_Msk
#define USB_OTG_GUSBCFG_ULPIAR_Pos   (18U)
#define USB_OTG_GUSBCFG_ULPIAR_Msk   (0x1UL << USB_OTG_GUSBCFG_ULPIAR_Pos)
#define USB_OTG_GUSBCFG_ULPIAR   USB_OTG_GUSBCFG_ULPIAR_Msk
#define USB_OTG_GUSBCFG_ULPICSM_Pos   (19U)
#define USB_OTG_GUSBCFG_ULPICSM_Msk   (0x1UL << USB_OTG_GUSBCFG_ULPICSM_Pos)
#define USB_OTG_GUSBCFG_ULPICSM   USB_OTG_GUSBCFG_ULPICSM_Msk
#define USB_OTG_GUSBCFG_ULPIEVBUSD_Pos   (20U)
#define USB_OTG_GUSBCFG_ULPIEVBUSD_Msk   (0x1UL << USB_OTG_GUSBCFG_ULPIEVBUSD_Pos)
#define USB_OTG_GUSBCFG_ULPIEVBUSD   USB_OTG_GUSBCFG_ULPIEVBUSD_Msk
#define USB_OTG_GUSBCFG_ULPIEVBUSI_Pos   (21U)
#define USB_OTG_GUSBCFG_ULPIEVBUSI_Msk   (0x1UL << USB_OTG_GUSBCFG_ULPIEVBUSI_Pos)
#define USB_OTG_GUSBCFG_ULPIEVBUSI   USB_OTG_GUSBCFG_ULPIEVBUSI_Msk
#define USB_OTG_GUSBCFG_TSDPS_Pos   (22U)
#define USB_OTG_GUSBCFG_TSDPS_Msk   (0x1UL << USB_OTG_GUSBCFG_TSDPS_Pos)
#define USB_OTG_GUSBCFG_TSDPS   USB_OTG_GUSBCFG_TSDPS_Msk
#define USB_OTG_GUSBCFG_PCCI_Pos   (23U)
#define USB_OTG_GUSBCFG_PCCI_Msk   (0x1UL << USB_OTG_GUSBCFG_PCCI_Pos)
#define USB_OTG_GUSBCFG_PCCI   USB_OTG_GUSBCFG_PCCI_Msk
#define USB_OTG_GUSBCFG_PTCI_Pos   (24U)
#define USB_OTG_GUSBCFG_PTCI_Msk   (0x1UL << USB_OTG_GUSBCFG_PTCI_Pos)
#define USB_OTG_GUSBCFG_PTCI   USB_OTG_GUSBCFG_PTCI_Msk
#define USB_OTG_GUSBCFG_ULPIIPD_Pos   (25U)
#define USB_OTG_GUSBCFG_ULPIIPD_Msk   (0x1UL << USB_OTG_GUSBCFG_ULPIIPD_Pos)
#define USB_OTG_GUSBCFG_ULPIIPD   USB_OTG_GUSBCFG_ULPIIPD_Msk
#define USB_OTG_GUSBCFG_FHMOD_Pos   (29U)
#define USB_OTG_GUSBCFG_FHMOD_Msk   (0x1UL << USB_OTG_GUSBCFG_FHMOD_Pos)
#define USB_OTG_GUSBCFG_FHMOD   USB_OTG_GUSBCFG_FHMOD_Msk
#define USB_OTG_GUSBCFG_FDMOD_Pos   (30U)
#define USB_OTG_GUSBCFG_FDMOD_Msk   (0x1UL << USB_OTG_GUSBCFG_FDMOD_Pos)
#define USB_OTG_GUSBCFG_FDMOD   USB_OTG_GUSBCFG_FDMOD_Msk
#define USB_OTG_GUSBCFG_CTXPKT_Pos   (31U)
#define USB_OTG_GUSBCFG_CTXPKT_Msk   (0x1UL << USB_OTG_GUSBCFG_CTXPKT_Pos)
#define USB_OTG_GUSBCFG_CTXPKT   USB_OTG_GUSBCFG_CTXPKT_Msk
#define USB_OTG_GRSTCTL_CSRST_Pos   (0U)
#define USB_OTG_GRSTCTL_CSRST_Msk   (0x1UL << USB_OTG_GRSTCTL_CSRST_Pos)
#define USB_OTG_GRSTCTL_CSRST   USB_OTG_GRSTCTL_CSRST_Msk
#define USB_OTG_GRSTCTL_HSRST_Pos   (1U)
#define USB_OTG_GRSTCTL_HSRST_Msk   (0x1UL << USB_OTG_GRSTCTL_HSRST_Pos)
#define USB_OTG_GRSTCTL_HSRST   USB_OTG_GRSTCTL_HSRST_Msk
#define USB_OTG_GRSTCTL_FCRST_Pos   (2U)
#define USB_OTG_GRSTCTL_FCRST_Msk   (0x1UL << USB_OTG_GRSTCTL_FCRST_Pos)
#define USB_OTG_GRSTCTL_FCRST   USB_OTG_GRSTCTL_FCRST_Msk
#define USB_OTG_GRSTCTL_RXFFLSH_Pos   (4U)
#define USB_OTG_GRSTCTL_RXFFLSH_Msk   (0x1UL << USB_OTG_GRSTCTL_RXFFLSH_Pos)
#define USB_OTG_GRSTCTL_RXFFLSH   USB_OTG_GRSTCTL_RXFFLSH_Msk
#define USB_OTG_GRSTCTL_TXFFLSH_Pos   (5U)
#define USB_OTG_GRSTCTL_TXFFLSH_Msk   (0x1UL << USB_OTG_GRSTCTL_TXFFLSH_Pos)
#define USB_OTG_GRSTCTL_TXFFLSH   USB_OTG_GRSTCTL_TXFFLSH_Msk
#define USB_OTG_GRSTCTL_TXFNUM_Pos   (6U)
#define USB_OTG_GRSTCTL_TXFNUM_Msk   (0x1FUL << USB_OTG_GRSTCTL_TXFNUM_Pos)
#define USB_OTG_GRSTCTL_TXFNUM   USB_OTG_GRSTCTL_TXFNUM_Msk
#define USB_OTG_GRSTCTL_TXFNUM_0   (0x01UL << USB_OTG_GRSTCTL_TXFNUM_Pos)
#define USB_OTG_GRSTCTL_TXFNUM_1   (0x02UL << USB_OTG_GRSTCTL_TXFNUM_Pos)
#define USB_OTG_GRSTCTL_TXFNUM_2   (0x04UL << USB_OTG_GRSTCTL_TXFNUM_Pos)
#define USB_OTG_GRSTCTL_TXFNUM_3   (0x08UL << USB_OTG_GRSTCTL_TXFNUM_Pos)
#define USB_OTG_GRSTCTL_TXFNUM_4   (0x10UL << USB_OTG_GRSTCTL_TXFNUM_Pos)
#define USB_OTG_GRSTCTL_DMAREQ_Pos   (30U)
#define USB_OTG_GRSTCTL_DMAREQ_Msk   (0x1UL << USB_OTG_GRSTCTL_DMAREQ_Pos)
#define USB_OTG_GRSTCTL_DMAREQ   USB_OTG_GRSTCTL_DMAREQ_Msk
#define USB_OTG_GRSTCTL_AHBIDL_Pos   (31U)
#define USB_OTG_GRSTCTL_AHBIDL_Msk   (0x1UL << USB_OTG_GRSTCTL_AHBIDL_Pos)
#define USB_OTG_GRSTCTL_AHBIDL   USB_OTG_GRSTCTL_AHBIDL_Msk
#define USB_OTG_DIEPMSK_XFRCM_Pos   (0U)
#define USB_OTG_DIEPMSK_XFRCM_Msk   (0x1UL << USB_OTG_DIEPMSK_XFRCM_Pos)
#define USB_OTG_DIEPMSK_XFRCM   USB_OTG_DIEPMSK_XFRCM_Msk
#define USB_OTG_DIEPMSK_EPDM_Pos   (1U)
#define USB_OTG_DIEPMSK_EPDM_Msk   (0x1UL << USB_OTG_DIEPMSK_EPDM_Pos)
#define USB_OTG_DIEPMSK_EPDM   USB_OTG_DIEPMSK_EPDM_Msk
#define USB_OTG_DIEPMSK_TOM_Pos   (3U)
#define USB_OTG_DIEPMSK_TOM_Msk   (0x1UL << USB_OTG_DIEPMSK_TOM_Pos)
#define USB_OTG_DIEPMSK_TOM   USB_OTG_DIEPMSK_TOM_Msk
#define USB_OTG_DIEPMSK_ITTXFEMSK_Pos   (4U)
#define USB_OTG_DIEPMSK_ITTXFEMSK_Msk   (0x1UL << USB_OTG_DIEPMSK_ITTXFEMSK_Pos)
#define USB_OTG_DIEPMSK_ITTXFEMSK   USB_OTG_DIEPMSK_ITTXFEMSK_Msk
#define USB_OTG_DIEPMSK_INEPNMM_Pos   (5U)
#define USB_OTG_DIEPMSK_INEPNMM_Msk   (0x1UL << USB_OTG_DIEPMSK_INEPNMM_Pos)
#define USB_OTG_DIEPMSK_INEPNMM   USB_OTG_DIEPMSK_INEPNMM_Msk
#define USB_OTG_DIEPMSK_INEPNEM_Pos   (6U)
#define USB_OTG_DIEPMSK_INEPNEM_Msk   (0x1UL << USB_OTG_DIEPMSK_INEPNEM_Pos)
#define USB_OTG_DIEPMSK_INEPNEM   USB_OTG_DIEPMSK_INEPNEM_Msk
#define USB_OTG_DIEPMSK_TXFURM_Pos   (8U)
#define USB_OTG_DIEPMSK_TXFURM_Msk   (0x1UL << USB_OTG_DIEPMSK_TXFURM_Pos)
#define USB_OTG_DIEPMSK_TXFURM   USB_OTG_DIEPMSK_TXFURM_Msk
#define USB_OTG_DIEPMSK_BIM_Pos   (9U)
#define USB_OTG_DIEPMSK_BIM_Msk   (0x1UL << USB_OTG_DIEPMSK_BIM_Pos)
#define USB_OTG_DIEPMSK_BIM   USB_OTG_DIEPMSK_BIM_Msk
#define USB_OTG_HPTXSTS_PTXFSAVL_Pos   (0U)
#define USB_OTG_HPTXSTS_PTXFSAVL_Msk   (0xFFFFUL << USB_OTG_HPTXSTS_PTXFSAVL_Pos)
#define USB_OTG_HPTXSTS_PTXFSAVL   USB_OTG_HPTXSTS_PTXFSAVL_Msk
#define USB_OTG_HPTXSTS_PTXQSAV_Pos   (16U)
#define USB_OTG_HPTXSTS_PTXQSAV_Msk   (0xFFUL << USB_OTG_HPTXSTS_PTXQSAV_Pos)
#define USB_OTG_HPTXSTS_PTXQSAV   USB_OTG_HPTXSTS_PTXQSAV_Msk
#define USB_OTG_HPTXSTS_PTXQSAV_0   (0x01UL << USB_OTG_HPTXSTS_PTXQSAV_Pos)
#define USB_OTG_HPTXSTS_PTXQSAV_1   (0x02UL << USB_OTG_HPTXSTS_PTXQSAV_Pos)
#define USB_OTG_HPTXSTS_PTXQSAV_2   (0x04UL << USB_OTG_HPTXSTS_PTXQSAV_Pos)
#define USB_OTG_HPTXSTS_PTXQSAV_3   (0x08UL << USB_OTG_HPTXSTS_PTXQSAV_Pos)
#define USB_OTG_HPTXSTS_PTXQSAV_4   (0x10UL << USB_OTG_HPTXSTS_PTXQSAV_Pos)
#define USB_OTG_HPTXSTS_PTXQSAV_5   (0x20UL << USB_OTG_HPTXSTS_PTXQSAV_Pos)
#define USB_OTG_HPTXSTS_PTXQSAV_6   (0x40UL << USB_OTG_HPTXSTS_PTXQSAV_Pos)
#define USB_OTG_HPTXSTS_PTXQSAV_7   (0x80UL << USB_OTG_HPTXSTS_PTXQSAV_Pos)
#define USB_OTG_HPTXSTS_PTXQTOP_Pos   (24U)
#define USB_OTG_HPTXSTS_PTXQTOP_Msk   (0xFFUL << USB_OTG_HPTXSTS_PTXQTOP_Pos)
#define USB_OTG_HPTXSTS_PTXQTOP   USB_OTG_HPTXSTS_PTXQTOP_Msk
#define USB_OTG_HPTXSTS_PTXQTOP_0   (0x01UL << USB_OTG_HPTXSTS_PTXQTOP_Pos)
#define USB_OTG_HPTXSTS_PTXQTOP_1   (0x02UL << USB_OTG_HPTXSTS_PTXQTOP_Pos)
#define USB_OTG_HPTXSTS_PTXQTOP_2   (0x04UL << USB_OTG_HPTXSTS_PTXQTOP_Pos)
#define USB_OTG_HPTXSTS_PTXQTOP_3   (0x08UL << USB_OTG_HPTXSTS_PTXQTOP_Pos)
#define USB_OTG_HPTXSTS_PTXQTOP_4   (0x10UL << USB_OTG_HPTXSTS_PTXQTOP_Pos)
#define USB_OTG_HPTXSTS_PTXQTOP_5   (0x20UL << USB_OTG_HPTXSTS_PTXQTOP_Pos)
#define USB_OTG_HPTXSTS_PTXQTOP_6   (0x40UL << USB_OTG_HPTXSTS_PTXQTOP_Pos)
#define USB_OTG_HPTXSTS_PTXQTOP_7   (0x80UL << USB_OTG_HPTXSTS_PTXQTOP_Pos)
#define USB_OTG_HAINT_HAINT_Pos   (0U)
#define USB_OTG_HAINT_HAINT_Msk   (0xFFFFUL << USB_OTG_HAINT_HAINT_Pos)
#define USB_OTG_HAINT_HAINT   USB_OTG_HAINT_HAINT_Msk
#define USB_OTG_DOEPMSK_XFRCM_Pos   (0U)
#define USB_OTG_DOEPMSK_XFRCM_Msk   (0x1UL << USB_OTG_DOEPMSK_XFRCM_Pos)
#define USB_OTG_DOEPMSK_XFRCM   USB_OTG_DOEPMSK_XFRCM_Msk
#define USB_OTG_DOEPMSK_EPDM_Pos   (1U)
#define USB_OTG_DOEPMSK_EPDM_Msk   (0x1UL << USB_OTG_DOEPMSK_EPDM_Pos)
#define USB_OTG_DOEPMSK_EPDM   USB_OTG_DOEPMSK_EPDM_Msk
#define USB_OTG_DOEPMSK_AHBERRM_Pos   (2U)
#define USB_OTG_DOEPMSK_AHBERRM_Msk   (0x1UL << USB_OTG_DOEPMSK_AHBERRM_Pos)
#define USB_OTG_DOEPMSK_AHBERRM   USB_OTG_DOEPMSK_AHBERRM_Msk
#define USB_OTG_DOEPMSK_STUPM_Pos   (3U)
#define USB_OTG_DOEPMSK_STUPM_Msk   (0x1UL << USB_OTG_DOEPMSK_STUPM_Pos)
#define USB_OTG_DOEPMSK_STUPM   USB_OTG_DOEPMSK_STUPM_Msk
#define USB_OTG_DOEPMSK_OTEPDM_Pos   (4U)
#define USB_OTG_DOEPMSK_OTEPDM_Msk   (0x1UL << USB_OTG_DOEPMSK_OTEPDM_Pos)
#define USB_OTG_DOEPMSK_OTEPDM   USB_OTG_DOEPMSK_OTEPDM_Msk
#define USB_OTG_DOEPMSK_OTEPSPRM_Pos   (5U)
#define USB_OTG_DOEPMSK_OTEPSPRM_Msk   (0x1UL << USB_OTG_DOEPMSK_OTEPSPRM_Pos)
#define USB_OTG_DOEPMSK_OTEPSPRM   USB_OTG_DOEPMSK_OTEPSPRM_Msk
#define USB_OTG_DOEPMSK_B2BSTUP_Pos   (6U)
#define USB_OTG_DOEPMSK_B2BSTUP_Msk   (0x1UL << USB_OTG_DOEPMSK_B2BSTUP_Pos)
#define USB_OTG_DOEPMSK_B2BSTUP   USB_OTG_DOEPMSK_B2BSTUP_Msk
#define USB_OTG_DOEPMSK_OPEM_Pos   (8U)
#define USB_OTG_DOEPMSK_OPEM_Msk   (0x1UL << USB_OTG_DOEPMSK_OPEM_Pos)
#define USB_OTG_DOEPMSK_OPEM   USB_OTG_DOEPMSK_OPEM_Msk
#define USB_OTG_DOEPMSK_BOIM_Pos   (9U)
#define USB_OTG_DOEPMSK_BOIM_Msk   (0x1UL << USB_OTG_DOEPMSK_BOIM_Pos)
#define USB_OTG_DOEPMSK_BOIM   USB_OTG_DOEPMSK_BOIM_Msk
#define USB_OTG_DOEPMSK_BERRM_Pos   (12U)
#define USB_OTG_DOEPMSK_BERRM_Msk   (0x1UL << USB_OTG_DOEPMSK_BERRM_Pos)
#define USB_OTG_DOEPMSK_BERRM   USB_OTG_DOEPMSK_BERRM_Msk
#define USB_OTG_DOEPMSK_NAKM_Pos   (13U)
#define USB_OTG_DOEPMSK_NAKM_Msk   (0x1UL << USB_OTG_DOEPMSK_NAKM_Pos)
#define USB_OTG_DOEPMSK_NAKM   USB_OTG_DOEPMSK_NAKM_Msk
#define USB_OTG_DOEPMSK_NYETM_Pos   (14U)
#define USB_OTG_DOEPMSK_NYETM_Msk   (0x1UL << USB_OTG_DOEPMSK_NYETM_Pos)
#define USB_OTG_DOEPMSK_NYETM   USB_OTG_DOEPMSK_NYETM_Msk
#define USB_OTG_GINTSTS_CMOD_Pos   (0U)
#define USB_OTG_GINTSTS_CMOD_Msk   (0x1UL << USB_OTG_GINTSTS_CMOD_Pos)
#define USB_OTG_GINTSTS_CMOD   USB_OTG_GINTSTS_CMOD_Msk
#define USB_OTG_GINTSTS_MMIS_Pos   (1U)
#define USB_OTG_GINTSTS_MMIS_Msk   (0x1UL << USB_OTG_GINTSTS_MMIS_Pos)
#define USB_OTG_GINTSTS_MMIS   USB_OTG_GINTSTS_MMIS_Msk
#define USB_OTG_GINTSTS_OTGINT_Pos   (2U)
#define USB_OTG_GINTSTS_OTGINT_Msk   (0x1UL << USB_OTG_GINTSTS_OTGINT_Pos)
#define USB_OTG_GINTSTS_OTGINT   USB_OTG_GINTSTS_OTGINT_Msk
#define USB_OTG_GINTSTS_SOF_Pos   (3U)
#define USB_OTG_GINTSTS_SOF_Msk   (0x1UL << USB_OTG_GINTSTS_SOF_Pos)
#define USB_OTG_GINTSTS_SOF   USB_OTG_GINTSTS_SOF_Msk
#define USB_OTG_GINTSTS_RXFLVL_Pos   (4U)
#define USB_OTG_GINTSTS_RXFLVL_Msk   (0x1UL << USB_OTG_GINTSTS_RXFLVL_Pos)
#define USB_OTG_GINTSTS_RXFLVL   USB_OTG_GINTSTS_RXFLVL_Msk
#define USB_OTG_GINTSTS_NPTXFE_Pos   (5U)
#define USB_OTG_GINTSTS_NPTXFE_Msk   (0x1UL << USB_OTG_GINTSTS_NPTXFE_Pos)
#define USB_OTG_GINTSTS_NPTXFE   USB_OTG_GINTSTS_NPTXFE_Msk
#define USB_OTG_GINTSTS_GINAKEFF_Pos   (6U)
#define USB_OTG_GINTSTS_GINAKEFF_Msk   (0x1UL << USB_OTG_GINTSTS_GINAKEFF_Pos)
#define USB_OTG_GINTSTS_GINAKEFF   USB_OTG_GINTSTS_GINAKEFF_Msk
#define USB_OTG_GINTSTS_BOUTNAKEFF_Pos   (7U)
#define USB_OTG_GINTSTS_BOUTNAKEFF_Msk   (0x1UL << USB_OTG_GINTSTS_BOUTNAKEFF_Pos)
#define USB_OTG_GINTSTS_BOUTNAKEFF   USB_OTG_GINTSTS_BOUTNAKEFF_Msk
#define USB_OTG_GINTSTS_ESUSP_Pos   (10U)
#define USB_OTG_GINTSTS_ESUSP_Msk   (0x1UL << USB_OTG_GINTSTS_ESUSP_Pos)
#define USB_OTG_GINTSTS_ESUSP   USB_OTG_GINTSTS_ESUSP_Msk
#define USB_OTG_GINTSTS_USBSUSP_Pos   (11U)
#define USB_OTG_GINTSTS_USBSUSP_Msk   (0x1UL << USB_OTG_GINTSTS_USBSUSP_Pos)
#define USB_OTG_GINTSTS_USBSUSP   USB_OTG_GINTSTS_USBSUSP_Msk
#define USB_OTG_GINTSTS_USBRST_Pos   (12U)
#define USB_OTG_GINTSTS_USBRST_Msk   (0x1UL << USB_OTG_GINTSTS_USBRST_Pos)
#define USB_OTG_GINTSTS_USBRST   USB_OTG_GINTSTS_USBRST_Msk
#define USB_OTG_GINTSTS_ENUMDNE_Pos   (13U)
#define USB_OTG_GINTSTS_ENUMDNE_Msk   (0x1UL << USB_OTG_GINTSTS_ENUMDNE_Pos)
#define USB_OTG_GINTSTS_ENUMDNE   USB_OTG_GINTSTS_ENUMDNE_Msk
#define USB_OTG_GINTSTS_ISOODRP_Pos   (14U)
#define USB_OTG_GINTSTS_ISOODRP_Msk   (0x1UL << USB_OTG_GINTSTS_ISOODRP_Pos)
#define USB_OTG_GINTSTS_ISOODRP   USB_OTG_GINTSTS_ISOODRP_Msk
#define USB_OTG_GINTSTS_EOPF_Pos   (15U)
#define USB_OTG_GINTSTS_EOPF_Msk   (0x1UL << USB_OTG_GINTSTS_EOPF_Pos)
#define USB_OTG_GINTSTS_EOPF   USB_OTG_GINTSTS_EOPF_Msk
#define USB_OTG_GINTSTS_IEPINT_Pos   (18U)
#define USB_OTG_GINTSTS_IEPINT_Msk   (0x1UL << USB_OTG_GINTSTS_IEPINT_Pos)
#define USB_OTG_GINTSTS_IEPINT   USB_OTG_GINTSTS_IEPINT_Msk
#define USB_OTG_GINTSTS_OEPINT_Pos   (19U)
#define USB_OTG_GINTSTS_OEPINT_Msk   (0x1UL << USB_OTG_GINTSTS_OEPINT_Pos)
#define USB_OTG_GINTSTS_OEPINT   USB_OTG_GINTSTS_OEPINT_Msk
#define USB_OTG_GINTSTS_IISOIXFR_Pos   (20U)
#define USB_OTG_GINTSTS_IISOIXFR_Msk   (0x1UL << USB_OTG_GINTSTS_IISOIXFR_Pos)
#define USB_OTG_GINTSTS_IISOIXFR   USB_OTG_GINTSTS_IISOIXFR_Msk
#define USB_OTG_GINTSTS_PXFR_INCOMPISOOUT_Pos   (21U)
#define USB_OTG_GINTSTS_PXFR_INCOMPISOOUT_Msk   (0x1UL << USB_OTG_GINTSTS_PXFR_INCOMPISOOUT_Pos)
#define USB_OTG_GINTSTS_PXFR_INCOMPISOOUT   USB_OTG_GINTSTS_PXFR_INCOMPISOOUT_Msk
#define USB_OTG_GINTSTS_DATAFSUSP_Pos   (22U)
#define USB_OTG_GINTSTS_DATAFSUSP_Msk   (0x1UL << USB_OTG_GINTSTS_DATAFSUSP_Pos)
#define USB_OTG_GINTSTS_DATAFSUSP   USB_OTG_GINTSTS_DATAFSUSP_Msk
#define USB_OTG_GINTSTS_RSTDET_Pos   (23U)
#define USB_OTG_GINTSTS_RSTDET_Msk   (0x1UL << USB_OTG_GINTSTS_RSTDET_Pos)
#define USB_OTG_GINTSTS_RSTDET   USB_OTG_GINTSTS_RSTDET_Msk
#define USB_OTG_GINTSTS_HPRTINT_Pos   (24U)
#define USB_OTG_GINTSTS_HPRTINT_Msk   (0x1UL << USB_OTG_GINTSTS_HPRTINT_Pos)
#define USB_OTG_GINTSTS_HPRTINT   USB_OTG_GINTSTS_HPRTINT_Msk
#define USB_OTG_GINTSTS_HCINT_Pos   (25U)
#define USB_OTG_GINTSTS_HCINT_Msk   (0x1UL << USB_OTG_GINTSTS_HCINT_Pos)
#define USB_OTG_GINTSTS_HCINT   USB_OTG_GINTSTS_HCINT_Msk
#define USB_OTG_GINTSTS_PTXFE_Pos   (26U)
#define USB_OTG_GINTSTS_PTXFE_Msk   (0x1UL << USB_OTG_GINTSTS_PTXFE_Pos)
#define USB_OTG_GINTSTS_PTXFE   USB_OTG_GINTSTS_PTXFE_Msk
#define USB_OTG_GINTSTS_LPMINT_Pos   (27U)
#define USB_OTG_GINTSTS_LPMINT_Msk   (0x1UL << USB_OTG_GINTSTS_LPMINT_Pos)
#define USB_OTG_GINTSTS_LPMINT   USB_OTG_GINTSTS_LPMINT_Msk
#define USB_OTG_GINTSTS_CIDSCHG_Pos   (28U)
#define USB_OTG_GINTSTS_CIDSCHG_Msk   (0x1UL << USB_OTG_GINTSTS_CIDSCHG_Pos)
#define USB_OTG_GINTSTS_CIDSCHG   USB_OTG_GINTSTS_CIDSCHG_Msk
#define USB_OTG_GINTSTS_DISCINT_Pos   (29U)
#define USB_OTG_GINTSTS_DISCINT_Msk   (0x1UL << USB_OTG_GINTSTS_DISCINT_Pos)
#define USB_OTG_GINTSTS_DISCINT   USB_OTG_GINTSTS_DISCINT_Msk
#define USB_OTG_GINTSTS_SRQINT_Pos   (30U)
#define USB_OTG_GINTSTS_SRQINT_Msk   (0x1UL << USB_OTG_GINTSTS_SRQINT_Pos)
#define USB_OTG_GINTSTS_SRQINT   USB_OTG_GINTSTS_SRQINT_Msk
#define USB_OTG_GINTSTS_WKUINT_Pos   (31U)
#define USB_OTG_GINTSTS_WKUINT_Msk   (0x1UL << USB_OTG_GINTSTS_WKUINT_Pos)
#define USB_OTG_GINTSTS_WKUINT   USB_OTG_GINTSTS_WKUINT_Msk
#define USB_OTG_GINTMSK_MMISM_Pos   (1U)
#define USB_OTG_GINTMSK_MMISM_Msk   (0x1UL << USB_OTG_GINTMSK_MMISM_Pos)
#define USB_OTG_GINTMSK_MMISM   USB_OTG_GINTMSK_MMISM_Msk
#define USB_OTG_GINTMSK_OTGINT_Pos   (2U)
#define USB_OTG_GINTMSK_OTGINT_Msk   (0x1UL << USB_OTG_GINTMSK_OTGINT_Pos)
#define USB_OTG_GINTMSK_OTGINT   USB_OTG_GINTMSK_OTGINT_Msk
#define USB_OTG_GINTMSK_SOFM_Pos   (3U)
#define USB_OTG_GINTMSK_SOFM_Msk   (0x1UL << USB_OTG_GINTMSK_SOFM_Pos)
#define USB_OTG_GINTMSK_SOFM   USB_OTG_GINTMSK_SOFM_Msk
#define USB_OTG_GINTMSK_RXFLVLM_Pos   (4U)
#define USB_OTG_GINTMSK_RXFLVLM_Msk   (0x1UL << USB_OTG_GINTMSK_RXFLVLM_Pos)
#define USB_OTG_GINTMSK_RXFLVLM   USB_OTG_GINTMSK_RXFLVLM_Msk
#define USB_OTG_GINTMSK_NPTXFEM_Pos   (5U)
#define USB_OTG_GINTMSK_NPTXFEM_Msk   (0x1UL << USB_OTG_GINTMSK_NPTXFEM_Pos)
#define USB_OTG_GINTMSK_NPTXFEM   USB_OTG_GINTMSK_NPTXFEM_Msk
#define USB_OTG_GINTMSK_GINAKEFFM_Pos   (6U)
#define USB_OTG_GINTMSK_GINAKEFFM_Msk   (0x1UL << USB_OTG_GINTMSK_GINAKEFFM_Pos)
#define USB_OTG_GINTMSK_GINAKEFFM   USB_OTG_GINTMSK_GINAKEFFM_Msk
#define USB_OTG_GINTMSK_GONAKEFFM_Pos   (7U)
#define USB_OTG_GINTMSK_GONAKEFFM_Msk   (0x1UL << USB_OTG_GINTMSK_GONAKEFFM_Pos)
#define USB_OTG_GINTMSK_GONAKEFFM   USB_OTG_GINTMSK_GONAKEFFM_Msk
#define USB_OTG_GINTMSK_ESUSPM_Pos   (10U)
#define USB_OTG_GINTMSK_ESUSPM_Msk   (0x1UL << USB_OTG_GINTMSK_ESUSPM_Pos)
#define USB_OTG_GINTMSK_ESUSPM   USB_OTG_GINTMSK_ESUSPM_Msk
#define USB_OTG_GINTMSK_USBSUSPM_Pos   (11U)
#define USB_OTG_GINTMSK_USBSUSPM_Msk   (0x1UL << USB_OTG_GINTMSK_USBSUSPM_Pos)
#define USB_OTG_GINTMSK_USBSUSPM   USB_OTG_GINTMSK_USBSUSPM_Msk
#define USB_OTG_GINTMSK_USBRST_Pos   (12U)
#define USB_OTG_GINTMSK_USBRST_Msk   (0x1UL << USB_OTG_GINTMSK_USBRST_Pos)
#define USB_OTG_GINTMSK_USBRST   USB_OTG_GINTMSK_USBRST_Msk
#define USB_OTG_GINTMSK_ENUMDNEM_Pos   (13U)
#define USB_OTG_GINTMSK_ENUMDNEM_Msk   (0x1UL << USB_OTG_GINTMSK_ENUMDNEM_Pos)
#define USB_OTG_GINTMSK_ENUMDNEM   USB_OTG_GINTMSK_ENUMDNEM_Msk
#define USB_OTG_GINTMSK_ISOODRPM_Pos   (14U)
#define USB_OTG_GINTMSK_ISOODRPM_Msk   (0x1UL << USB_OTG_GINTMSK_ISOODRPM_Pos)
#define USB_OTG_GINTMSK_ISOODRPM   USB_OTG_GINTMSK_ISOODRPM_Msk
#define USB_OTG_GINTMSK_EOPFM_Pos   (15U)
#define USB_OTG_GINTMSK_EOPFM_Msk   (0x1UL << USB_OTG_GINTMSK_EOPFM_Pos)
#define USB_OTG_GINTMSK_EOPFM   USB_OTG_GINTMSK_EOPFM_Msk
#define USB_OTG_GINTMSK_EPMISM_Pos   (17U)
#define USB_OTG_GINTMSK_EPMISM_Msk   (0x1UL << USB_OTG_GINTMSK_EPMISM_Pos)
#define USB_OTG_GINTMSK_EPMISM   USB_OTG_GINTMSK_EPMISM_Msk
#define USB_OTG_GINTMSK_IEPINT_Pos   (18U)
#define USB_OTG_GINTMSK_IEPINT_Msk   (0x1UL << USB_OTG_GINTMSK_IEPINT_Pos)
#define USB_OTG_GINTMSK_IEPINT   USB_OTG_GINTMSK_IEPINT_Msk
#define USB_OTG_GINTMSK_OEPINT_Pos   (19U)
#define USB_OTG_GINTMSK_OEPINT_Msk   (0x1UL << USB_OTG_GINTMSK_OEPINT_Pos)
#define USB_OTG_GINTMSK_OEPINT   USB_OTG_GINTMSK_OEPINT_Msk
#define USB_OTG_GINTMSK_IISOIXFRM_Pos   (20U)
#define USB_OTG_GINTMSK_IISOIXFRM_Msk   (0x1UL << USB_OTG_GINTMSK_IISOIXFRM_Pos)
#define USB_OTG_GINTMSK_IISOIXFRM   USB_OTG_GINTMSK_IISOIXFRM_Msk
#define USB_OTG_GINTMSK_PXFRM_IISOOXFRM_Pos   (21U)
#define USB_OTG_GINTMSK_PXFRM_IISOOXFRM_Msk   (0x1UL << USB_OTG_GINTMSK_PXFRM_IISOOXFRM_Pos)
#define USB_OTG_GINTMSK_PXFRM_IISOOXFRM   USB_OTG_GINTMSK_PXFRM_IISOOXFRM_Msk
#define USB_OTG_GINTMSK_FSUSPM_Pos   (22U)
#define USB_OTG_GINTMSK_FSUSPM_Msk   (0x1UL << USB_OTG_GINTMSK_FSUSPM_Pos)
#define USB_OTG_GINTMSK_FSUSPM   USB_OTG_GINTMSK_FSUSPM_Msk
#define USB_OTG_GINTMSK_RSTDEM_Pos   (23U)
#define USB_OTG_GINTMSK_RSTDEM_Msk   (0x1UL << USB_OTG_GINTMSK_RSTDEM_Pos)
#define USB_OTG_GINTMSK_RSTDEM   USB_OTG_GINTMSK_RSTDEM_Msk
#define USB_OTG_GINTMSK_PRTIM_Pos   (24U)
#define USB_OTG_GINTMSK_PRTIM_Msk   (0x1UL << USB_OTG_GINTMSK_PRTIM_Pos)
#define USB_OTG_GINTMSK_PRTIM   USB_OTG_GINTMSK_PRTIM_Msk
#define USB_OTG_GINTMSK_HCIM_Pos   (25U)
#define USB_OTG_GINTMSK_HCIM_Msk   (0x1UL << USB_OTG_GINTMSK_HCIM_Pos)
#define USB_OTG_GINTMSK_HCIM   USB_OTG_GINTMSK_HCIM_Msk
#define USB_OTG_GINTMSK_PTXFEM_Pos   (26U)
#define USB_OTG_GINTMSK_PTXFEM_Msk   (0x1UL << USB_OTG_GINTMSK_PTXFEM_Pos)
#define USB_OTG_GINTMSK_PTXFEM   USB_OTG_GINTMSK_PTXFEM_Msk
#define USB_OTG_GINTMSK_LPMINTM_Pos   (27U)
#define USB_OTG_GINTMSK_LPMINTM_Msk   (0x1UL << USB_OTG_GINTMSK_LPMINTM_Pos)
#define USB_OTG_GINTMSK_LPMINTM   USB_OTG_GINTMSK_LPMINTM_Msk
#define USB_OTG_GINTMSK_CIDSCHGM_Pos   (28U)
#define USB_OTG_GINTMSK_CIDSCHGM_Msk   (0x1UL << USB_OTG_GINTMSK_CIDSCHGM_Pos)
#define USB_OTG_GINTMSK_CIDSCHGM   USB_OTG_GINTMSK_CIDSCHGM_Msk
#define USB_OTG_GINTMSK_DISCINT_Pos   (29U)
#define USB_OTG_GINTMSK_DISCINT_Msk   (0x1UL << USB_OTG_GINTMSK_DISCINT_Pos)
#define USB_OTG_GINTMSK_DISCINT   USB_OTG_GINTMSK_DISCINT_Msk
#define USB_OTG_GINTMSK_SRQIM_Pos   (30U)
#define USB_OTG_GINTMSK_SRQIM_Msk   (0x1UL << USB_OTG_GINTMSK_SRQIM_Pos)
#define USB_OTG_GINTMSK_SRQIM   USB_OTG_GINTMSK_SRQIM_Msk
#define USB_OTG_GINTMSK_WUIM_Pos   (31U)
#define USB_OTG_GINTMSK_WUIM_Msk   (0x1UL << USB_OTG_GINTMSK_WUIM_Pos)
#define USB_OTG_GINTMSK_WUIM   USB_OTG_GINTMSK_WUIM_Msk
#define USB_OTG_DAINT_IEPINT_Pos   (0U)
#define USB_OTG_DAINT_IEPINT_Msk   (0xFFFFUL << USB_OTG_DAINT_IEPINT_Pos)
#define USB_OTG_DAINT_IEPINT   USB_OTG_DAINT_IEPINT_Msk
#define USB_OTG_DAINT_OEPINT_Pos   (16U)
#define USB_OTG_DAINT_OEPINT_Msk   (0xFFFFUL << USB_OTG_DAINT_OEPINT_Pos)
#define USB_OTG_DAINT_OEPINT   USB_OTG_DAINT_OEPINT_Msk
#define USB_OTG_HAINTMSK_HAINTM_Pos   (0U)
#define USB_OTG_HAINTMSK_HAINTM_Msk   (0xFFFFUL << USB_OTG_HAINTMSK_HAINTM_Pos)
#define USB_OTG_HAINTMSK_HAINTM   USB_OTG_HAINTMSK_HAINTM_Msk
#define USB_OTG_GRXSTSP_EPNUM_Pos   (0U)
#define USB_OTG_GRXSTSP_EPNUM_Msk   (0xFUL << USB_OTG_GRXSTSP_EPNUM_Pos)
#define USB_OTG_GRXSTSP_EPNUM   USB_OTG_GRXSTSP_EPNUM_Msk
#define USB_OTG_GRXSTSP_BCNT_Pos   (4U)
#define USB_OTG_GRXSTSP_BCNT_Msk   (0x7FFUL << USB_OTG_GRXSTSP_BCNT_Pos)
#define USB_OTG_GRXSTSP_BCNT   USB_OTG_GRXSTSP_BCNT_Msk
#define USB_OTG_GRXSTSP_DPID_Pos   (15U)
#define USB_OTG_GRXSTSP_DPID_Msk   (0x3UL << USB_OTG_GRXSTSP_DPID_Pos)
#define USB_OTG_GRXSTSP_DPID   USB_OTG_GRXSTSP_DPID_Msk
#define USB_OTG_GRXSTSP_PKTSTS_Pos   (17U)
#define USB_OTG_GRXSTSP_PKTSTS_Msk   (0xFUL << USB_OTG_GRXSTSP_PKTSTS_Pos)
#define USB_OTG_GRXSTSP_PKTSTS   USB_OTG_GRXSTSP_PKTSTS_Msk
#define USB_OTG_DAINTMSK_IEPM_Pos   (0U)
#define USB_OTG_DAINTMSK_IEPM_Msk   (0xFFFFUL << USB_OTG_DAINTMSK_IEPM_Pos)
#define USB_OTG_DAINTMSK_IEPM   USB_OTG_DAINTMSK_IEPM_Msk
#define USB_OTG_DAINTMSK_OEPM_Pos   (16U)
#define USB_OTG_DAINTMSK_OEPM_Msk   (0xFFFFUL << USB_OTG_DAINTMSK_OEPM_Pos)
#define USB_OTG_DAINTMSK_OEPM   USB_OTG_DAINTMSK_OEPM_Msk
#define USB_OTG_CHNUM_Pos   (0U)
#define USB_OTG_CHNUM_Msk   (0xFUL << USB_OTG_CHNUM_Pos)
#define USB_OTG_CHNUM   USB_OTG_CHNUM_Msk
#define USB_OTG_CHNUM_0   (0x1UL << USB_OTG_CHNUM_Pos)
#define USB_OTG_CHNUM_1   (0x2UL << USB_OTG_CHNUM_Pos)
#define USB_OTG_CHNUM_2   (0x4UL << USB_OTG_CHNUM_Pos)
#define USB_OTG_CHNUM_3   (0x8UL << USB_OTG_CHNUM_Pos)
#define USB_OTG_BCNT_Pos   (4U)
#define USB_OTG_BCNT_Msk   (0x7FFUL << USB_OTG_BCNT_Pos)
#define USB_OTG_BCNT   USB_OTG_BCNT_Msk
#define USB_OTG_DPID_Pos   (15U)
#define USB_OTG_DPID_Msk   (0x3UL << USB_OTG_DPID_Pos)
#define USB_OTG_DPID   USB_OTG_DPID_Msk
#define USB_OTG_DPID_0   (0x1UL << USB_OTG_DPID_Pos)
#define USB_OTG_DPID_1   (0x2UL << USB_OTG_DPID_Pos)
#define USB_OTG_PKTSTS_Pos   (17U)
#define USB_OTG_PKTSTS_Msk   (0xFUL << USB_OTG_PKTSTS_Pos)
#define USB_OTG_PKTSTS   USB_OTG_PKTSTS_Msk
#define USB_OTG_PKTSTS_0   (0x1UL << USB_OTG_PKTSTS_Pos)
#define USB_OTG_PKTSTS_1   (0x2UL << USB_OTG_PKTSTS_Pos)
#define USB_OTG_PKTSTS_2   (0x4UL << USB_OTG_PKTSTS_Pos)
#define USB_OTG_PKTSTS_3   (0x8UL << USB_OTG_PKTSTS_Pos)
#define USB_OTG_EPNUM_Pos   (0U)
#define USB_OTG_EPNUM_Msk   (0xFUL << USB_OTG_EPNUM_Pos)
#define USB_OTG_EPNUM   USB_OTG_EPNUM_Msk
#define USB_OTG_EPNUM_0   (0x1UL << USB_OTG_EPNUM_Pos)
#define USB_OTG_EPNUM_1   (0x2UL << USB_OTG_EPNUM_Pos)
#define USB_OTG_EPNUM_2   (0x4UL << USB_OTG_EPNUM_Pos)
#define USB_OTG_EPNUM_3   (0x8UL << USB_OTG_EPNUM_Pos)
#define USB_OTG_FRMNUM_Pos   (21U)
#define USB_OTG_FRMNUM_Msk   (0xFUL << USB_OTG_FRMNUM_Pos)
#define USB_OTG_FRMNUM   USB_OTG_FRMNUM_Msk
#define USB_OTG_FRMNUM_0   (0x1UL << USB_OTG_FRMNUM_Pos)
#define USB_OTG_FRMNUM_1   (0x2UL << USB_OTG_FRMNUM_Pos)
#define USB_OTG_FRMNUM_2   (0x4UL << USB_OTG_FRMNUM_Pos)
#define USB_OTG_FRMNUM_3   (0x8UL << USB_OTG_FRMNUM_Pos)
#define USB_OTG_GRXFSIZ_RXFD_Pos   (0U)
#define USB_OTG_GRXFSIZ_RXFD_Msk   (0xFFFFUL << USB_OTG_GRXFSIZ_RXFD_Pos)
#define USB_OTG_GRXFSIZ_RXFD   USB_OTG_GRXFSIZ_RXFD_Msk
#define USB_OTG_DVBUSDIS_VBUSDT_Pos   (0U)
#define USB_OTG_DVBUSDIS_VBUSDT_Msk   (0xFFFFUL << USB_OTG_DVBUSDIS_VBUSDT_Pos)
#define USB_OTG_DVBUSDIS_VBUSDT   USB_OTG_DVBUSDIS_VBUSDT_Msk
#define USB_OTG_NPTXFSA_Pos   (0U)
#define USB_OTG_NPTXFSA_Msk   (0xFFFFUL << USB_OTG_NPTXFSA_Pos)
#define USB_OTG_NPTXFSA   USB_OTG_NPTXFSA_Msk
#define USB_OTG_NPTXFD_Pos   (16U)
#define USB_OTG_NPTXFD_Msk   (0xFFFFUL << USB_OTG_NPTXFD_Pos)
#define USB_OTG_NPTXFD   USB_OTG_NPTXFD_Msk
#define USB_OTG_TX0FSA_Pos   (0U)
#define USB_OTG_TX0FSA_Msk   (0xFFFFUL << USB_OTG_TX0FSA_Pos)
#define USB_OTG_TX0FSA   USB_OTG_TX0FSA_Msk
#define USB_OTG_TX0FD_Pos   (16U)
#define USB_OTG_TX0FD_Msk   (0xFFFFUL << USB_OTG_TX0FD_Pos)
#define USB_OTG_TX0FD   USB_OTG_TX0FD_Msk
#define USB_OTG_DVBUSPULSE_DVBUSP_Pos   (0U)
#define USB_OTG_DVBUSPULSE_DVBUSP_Msk   (0xFFFUL << USB_OTG_DVBUSPULSE_DVBUSP_Pos)
#define USB_OTG_DVBUSPULSE_DVBUSP   USB_OTG_DVBUSPULSE_DVBUSP_Msk
#define USB_OTG_GNPTXSTS_NPTXFSAV_Pos   (0U)
#define USB_OTG_GNPTXSTS_NPTXFSAV_Msk   (0xFFFFUL << USB_OTG_GNPTXSTS_NPTXFSAV_Pos)
#define USB_OTG_GNPTXSTS_NPTXFSAV   USB_OTG_GNPTXSTS_NPTXFSAV_Msk
#define USB_OTG_GNPTXSTS_NPTQXSAV_Pos   (16U)
#define USB_OTG_GNPTXSTS_NPTQXSAV_Msk   (0xFFUL << USB_OTG_GNPTXSTS_NPTQXSAV_Pos)
#define USB_OTG_GNPTXSTS_NPTQXSAV   USB_OTG_GNPTXSTS_NPTQXSAV_Msk
#define USB_OTG_GNPTXSTS_NPTQXSAV_0   (0x01UL << USB_OTG_GNPTXSTS_NPTQXSAV_Pos)
#define USB_OTG_GNPTXSTS_NPTQXSAV_1   (0x02UL << USB_OTG_GNPTXSTS_NPTQXSAV_Pos)
#define USB_OTG_GNPTXSTS_NPTQXSAV_2   (0x04UL << USB_OTG_GNPTXSTS_NPTQXSAV_Pos)
#define USB_OTG_GNPTXSTS_NPTQXSAV_3   (0x08UL << USB_OTG_GNPTXSTS_NPTQXSAV_Pos)
#define USB_OTG_GNPTXSTS_NPTQXSAV_4   (0x10UL << USB_OTG_GNPTXSTS_NPTQXSAV_Pos)
#define USB_OTG_GNPTXSTS_NPTQXSAV_5   (0x20UL << USB_OTG_GNPTXSTS_NPTQXSAV_Pos)
#define USB_OTG_GNPTXSTS_NPTQXSAV_6   (0x40UL << USB_OTG_GNPTXSTS_NPTQXSAV_Pos)
#define USB_OTG_GNPTXSTS_NPTQXSAV_7   (0x80UL << USB_OTG_GNPTXSTS_NPTQXSAV_Pos)
#define USB_OTG_GNPTXSTS_NPTXQTOP_Pos   (24U)
#define USB_OTG_GNPTXSTS_NPTXQTOP_Msk   (0x7FUL << USB_OTG_GNPTXSTS_NPTXQTOP_Pos)
#define USB_OTG_GNPTXSTS_NPTXQTOP   USB_OTG_GNPTXSTS_NPTXQTOP_Msk
#define USB_OTG_GNPTXSTS_NPTXQTOP_0   (0x01UL << USB_OTG_GNPTXSTS_NPTXQTOP_Pos)
#define USB_OTG_GNPTXSTS_NPTXQTOP_1   (0x02UL << USB_OTG_GNPTXSTS_NPTXQTOP_Pos)
#define USB_OTG_GNPTXSTS_NPTXQTOP_2   (0x04UL << USB_OTG_GNPTXSTS_NPTXQTOP_Pos)
#define USB_OTG_GNPTXSTS_NPTXQTOP_3   (0x08UL << USB_OTG_GNPTXSTS_NPTXQTOP_Pos)
#define USB_OTG_GNPTXSTS_NPTXQTOP_4   (0x10UL << USB_OTG_GNPTXSTS_NPTXQTOP_Pos)
#define USB_OTG_GNPTXSTS_NPTXQTOP_5   (0x20UL << USB_OTG_GNPTXSTS_NPTXQTOP_Pos)
#define USB_OTG_GNPTXSTS_NPTXQTOP_6   (0x40UL << USB_OTG_GNPTXSTS_NPTXQTOP_Pos)
#define USB_OTG_DTHRCTL_NONISOTHREN_Pos   (0U)
#define USB_OTG_DTHRCTL_NONISOTHREN_Msk   (0x1UL << USB_OTG_DTHRCTL_NONISOTHREN_Pos)
#define USB_OTG_DTHRCTL_NONISOTHREN   USB_OTG_DTHRCTL_NONISOTHREN_Msk
#define USB_OTG_DTHRCTL_ISOTHREN_Pos   (1U)
#define USB_OTG_DTHRCTL_ISOTHREN_Msk   (0x1UL << USB_OTG_DTHRCTL_ISOTHREN_Pos)
#define USB_OTG_DTHRCTL_ISOTHREN   USB_OTG_DTHRCTL_ISOTHREN_Msk
#define USB_OTG_DTHRCTL_TXTHRLEN_Pos   (2U)
#define USB_OTG_DTHRCTL_TXTHRLEN_Msk   (0x1FFUL << USB_OTG_DTHRCTL_TXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_TXTHRLEN   USB_OTG_DTHRCTL_TXTHRLEN_Msk
#define USB_OTG_DTHRCTL_TXTHRLEN_0   (0x001UL << USB_OTG_DTHRCTL_TXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_TXTHRLEN_1   (0x002UL << USB_OTG_DTHRCTL_TXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_TXTHRLEN_2   (0x004UL << USB_OTG_DTHRCTL_TXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_TXTHRLEN_3   (0x008UL << USB_OTG_DTHRCTL_TXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_TXTHRLEN_4   (0x010UL << USB_OTG_DTHRCTL_TXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_TXTHRLEN_5   (0x020UL << USB_OTG_DTHRCTL_TXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_TXTHRLEN_6   (0x040UL << USB_OTG_DTHRCTL_TXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_TXTHRLEN_7   (0x080UL << USB_OTG_DTHRCTL_TXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_TXTHRLEN_8   (0x100UL << USB_OTG_DTHRCTL_TXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_RXTHREN_Pos   (16U)
#define USB_OTG_DTHRCTL_RXTHREN_Msk   (0x1UL << USB_OTG_DTHRCTL_RXTHREN_Pos)
#define USB_OTG_DTHRCTL_RXTHREN   USB_OTG_DTHRCTL_RXTHREN_Msk
#define USB_OTG_DTHRCTL_RXTHRLEN_Pos   (17U)
#define USB_OTG_DTHRCTL_RXTHRLEN_Msk   (0x1FFUL << USB_OTG_DTHRCTL_RXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_RXTHRLEN   USB_OTG_DTHRCTL_RXTHRLEN_Msk
#define USB_OTG_DTHRCTL_RXTHRLEN_0   (0x001UL << USB_OTG_DTHRCTL_RXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_RXTHRLEN_1   (0x002UL << USB_OTG_DTHRCTL_RXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_RXTHRLEN_2   (0x004UL << USB_OTG_DTHRCTL_RXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_RXTHRLEN_3   (0x008UL << USB_OTG_DTHRCTL_RXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_RXTHRLEN_4   (0x010UL << USB_OTG_DTHRCTL_RXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_RXTHRLEN_5   (0x020UL << USB_OTG_DTHRCTL_RXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_RXTHRLEN_6   (0x040UL << USB_OTG_DTHRCTL_RXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_RXTHRLEN_7   (0x080UL << USB_OTG_DTHRCTL_RXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_RXTHRLEN_8   (0x100UL << USB_OTG_DTHRCTL_RXTHRLEN_Pos)
#define USB_OTG_DTHRCTL_ARPEN_Pos   (27U)
#define USB_OTG_DTHRCTL_ARPEN_Msk   (0x1UL << USB_OTG_DTHRCTL_ARPEN_Pos)
#define USB_OTG_DTHRCTL_ARPEN   USB_OTG_DTHRCTL_ARPEN_Msk
#define USB_OTG_DIEPEMPMSK_INEPTXFEM_Pos   (0U)
#define USB_OTG_DIEPEMPMSK_INEPTXFEM_Msk   (0xFFFFUL << USB_OTG_DIEPEMPMSK_INEPTXFEM_Pos)
#define USB_OTG_DIEPEMPMSK_INEPTXFEM   USB_OTG_DIEPEMPMSK_INEPTXFEM_Msk
#define USB_OTG_DEACHINT_IEP1INT_Pos   (1U)
#define USB_OTG_DEACHINT_IEP1INT_Msk   (0x1UL << USB_OTG_DEACHINT_IEP1INT_Pos)
#define USB_OTG_DEACHINT_IEP1INT   USB_OTG_DEACHINT_IEP1INT_Msk
#define USB_OTG_DEACHINT_OEP1INT_Pos   (17U)
#define USB_OTG_DEACHINT_OEP1INT_Msk   (0x1UL << USB_OTG_DEACHINT_OEP1INT_Pos)
#define USB_OTG_DEACHINT_OEP1INT   USB_OTG_DEACHINT_OEP1INT_Msk
#define USB_OTG_GCCFG_DCDET_Pos   (0U)
#define USB_OTG_GCCFG_DCDET_Msk   (0x1UL << USB_OTG_GCCFG_DCDET_Pos)
#define USB_OTG_GCCFG_DCDET   USB_OTG_GCCFG_DCDET_Msk
#define USB_OTG_GCCFG_PDET_Pos   (1U)
#define USB_OTG_GCCFG_PDET_Msk   (0x1UL << USB_OTG_GCCFG_PDET_Pos)
#define USB_OTG_GCCFG_PDET   USB_OTG_GCCFG_PDET_Msk
#define USB_OTG_GCCFG_SDET_Pos   (2U)
#define USB_OTG_GCCFG_SDET_Msk   (0x1UL << USB_OTG_GCCFG_SDET_Pos)
#define USB_OTG_GCCFG_SDET   USB_OTG_GCCFG_SDET_Msk
#define USB_OTG_GCCFG_PS2DET_Pos   (3U)
#define USB_OTG_GCCFG_PS2DET_Msk   (0x1UL << USB_OTG_GCCFG_PS2DET_Pos)
#define USB_OTG_GCCFG_PS2DET   USB_OTG_GCCFG_PS2DET_Msk
#define USB_OTG_GCCFG_PWRDWN_Pos   (16U)
#define USB_OTG_GCCFG_PWRDWN_Msk   (0x1UL << USB_OTG_GCCFG_PWRDWN_Pos)
#define USB_OTG_GCCFG_PWRDWN   USB_OTG_GCCFG_PWRDWN_Msk
#define USB_OTG_GCCFG_BCDEN_Pos   (17U)
#define USB_OTG_GCCFG_BCDEN_Msk   (0x1UL << USB_OTG_GCCFG_BCDEN_Pos)
#define USB_OTG_GCCFG_BCDEN   USB_OTG_GCCFG_BCDEN_Msk
#define USB_OTG_GCCFG_DCDEN_Pos   (18U)
#define USB_OTG_GCCFG_DCDEN_Msk   (0x1UL << USB_OTG_GCCFG_DCDEN_Pos)
#define USB_OTG_GCCFG_DCDEN   USB_OTG_GCCFG_DCDEN_Msk
#define USB_OTG_GCCFG_PDEN_Pos   (19U)
#define USB_OTG_GCCFG_PDEN_Msk   (0x1UL << USB_OTG_GCCFG_PDEN_Pos)
#define USB_OTG_GCCFG_PDEN   USB_OTG_GCCFG_PDEN_Msk
#define USB_OTG_GCCFG_SDEN_Pos   (20U)
#define USB_OTG_GCCFG_SDEN_Msk   (0x1UL << USB_OTG_GCCFG_SDEN_Pos)
#define USB_OTG_GCCFG_SDEN   USB_OTG_GCCFG_SDEN_Msk
#define USB_OTG_GCCFG_VBDEN_Pos   (21U)
#define USB_OTG_GCCFG_VBDEN_Msk   (0x1UL << USB_OTG_GCCFG_VBDEN_Pos)
#define USB_OTG_GCCFG_VBDEN   USB_OTG_GCCFG_VBDEN_Msk
#define USB_OTG_GPWRDN_ADPMEN_Pos   (0U)
#define USB_OTG_GPWRDN_ADPMEN_Msk   (0x1UL << USB_OTG_GPWRDN_ADPMEN_Pos)
#define USB_OTG_GPWRDN_ADPMEN   USB_OTG_GPWRDN_ADPMEN_Msk
#define USB_OTG_GPWRDN_ADPIF_Pos   (23U)
#define USB_OTG_GPWRDN_ADPIF_Msk   (0x1UL << USB_OTG_GPWRDN_ADPIF_Pos)
#define USB_OTG_GPWRDN_ADPIF   USB_OTG_GPWRDN_ADPIF_Msk
#define USB_OTG_DEACHINTMSK_IEP1INTM_Pos   (1U)
#define USB_OTG_DEACHINTMSK_IEP1INTM_Msk   (0x1UL << USB_OTG_DEACHINTMSK_IEP1INTM_Pos)
#define USB_OTG_DEACHINTMSK_IEP1INTM   USB_OTG_DEACHINTMSK_IEP1INTM_Msk
#define USB_OTG_DEACHINTMSK_OEP1INTM_Pos   (17U)
#define USB_OTG_DEACHINTMSK_OEP1INTM_Msk   (0x1UL << USB_OTG_DEACHINTMSK_OEP1INTM_Pos)
#define USB_OTG_DEACHINTMSK_OEP1INTM   USB_OTG_DEACHINTMSK_OEP1INTM_Msk
#define USB_OTG_CID_PRODUCT_ID_Pos   (0U)
#define USB_OTG_CID_PRODUCT_ID_Msk   (0xFFFFFFFFUL << USB_OTG_CID_PRODUCT_ID_Pos)
#define USB_OTG_CID_PRODUCT_ID   USB_OTG_CID_PRODUCT_ID_Msk
#define USB_OTG_GLPMCFG_LPMEN_Pos   (0U)
#define USB_OTG_GLPMCFG_LPMEN_Msk   (0x1UL << USB_OTG_GLPMCFG_LPMEN_Pos)
#define USB_OTG_GLPMCFG_LPMEN   USB_OTG_GLPMCFG_LPMEN_Msk
#define USB_OTG_GLPMCFG_LPMACK_Pos   (1U)
#define USB_OTG_GLPMCFG_LPMACK_Msk   (0x1UL << USB_OTG_GLPMCFG_LPMACK_Pos)
#define USB_OTG_GLPMCFG_LPMACK   USB_OTG_GLPMCFG_LPMACK_Msk
#define USB_OTG_GLPMCFG_BESL_Pos   (2U)
#define USB_OTG_GLPMCFG_BESL_Msk   (0xFUL << USB_OTG_GLPMCFG_BESL_Pos)
#define USB_OTG_GLPMCFG_BESL   USB_OTG_GLPMCFG_BESL_Msk
#define USB_OTG_GLPMCFG_REMWAKE_Pos   (6U)
#define USB_OTG_GLPMCFG_REMWAKE_Msk   (0x1UL << USB_OTG_GLPMCFG_REMWAKE_Pos)
#define USB_OTG_GLPMCFG_REMWAKE   USB_OTG_GLPMCFG_REMWAKE_Msk
#define USB_OTG_GLPMCFG_L1SSEN_Pos   (7U)
#define USB_OTG_GLPMCFG_L1SSEN_Msk   (0x1UL << USB_OTG_GLPMCFG_L1SSEN_Pos)
#define USB_OTG_GLPMCFG_L1SSEN   USB_OTG_GLPMCFG_L1SSEN_Msk
#define USB_OTG_GLPMCFG_BESLTHRS_Pos   (8U)
#define USB_OTG_GLPMCFG_BESLTHRS_Msk   (0xFUL << USB_OTG_GLPMCFG_BESLTHRS_Pos)
#define USB_OTG_GLPMCFG_BESLTHRS   USB_OTG_GLPMCFG_BESLTHRS_Msk
#define USB_OTG_GLPMCFG_L1DSEN_Pos   (12U)
#define USB_OTG_GLPMCFG_L1DSEN_Msk   (0x1UL << USB_OTG_GLPMCFG_L1DSEN_Pos)
#define USB_OTG_GLPMCFG_L1DSEN   USB_OTG_GLPMCFG_L1DSEN_Msk
#define USB_OTG_GLPMCFG_LPMRSP_Pos   (13U)
#define USB_OTG_GLPMCFG_LPMRSP_Msk   (0x3UL << USB_OTG_GLPMCFG_LPMRSP_Pos)
#define USB_OTG_GLPMCFG_LPMRSP   USB_OTG_GLPMCFG_LPMRSP_Msk
#define USB_OTG_GLPMCFG_SLPSTS_Pos   (15U)
#define USB_OTG_GLPMCFG_SLPSTS_Msk   (0x1UL << USB_OTG_GLPMCFG_SLPSTS_Pos)
#define USB_OTG_GLPMCFG_SLPSTS   USB_OTG_GLPMCFG_SLPSTS_Msk
#define USB_OTG_GLPMCFG_L1RSMOK_Pos   (16U)
#define USB_OTG_GLPMCFG_L1RSMOK_Msk   (0x1UL << USB_OTG_GLPMCFG_L1RSMOK_Pos)
#define USB_OTG_GLPMCFG_L1RSMOK   USB_OTG_GLPMCFG_L1RSMOK_Msk
#define USB_OTG_GLPMCFG_LPMCHIDX_Pos   (17U)
#define USB_OTG_GLPMCFG_LPMCHIDX_Msk   (0xFUL << USB_OTG_GLPMCFG_LPMCHIDX_Pos)
#define USB_OTG_GLPMCFG_LPMCHIDX   USB_OTG_GLPMCFG_LPMCHIDX_Msk
#define USB_OTG_GLPMCFG_LPMRCNT_Pos   (21U)
#define USB_OTG_GLPMCFG_LPMRCNT_Msk   (0x7UL << USB_OTG_GLPMCFG_LPMRCNT_Pos)
#define USB_OTG_GLPMCFG_LPMRCNT   USB_OTG_GLPMCFG_LPMRCNT_Msk
#define USB_OTG_GLPMCFG_SNDLPM_Pos   (24U)
#define USB_OTG_GLPMCFG_SNDLPM_Msk   (0x1UL << USB_OTG_GLPMCFG_SNDLPM_Pos)
#define USB_OTG_GLPMCFG_SNDLPM   USB_OTG_GLPMCFG_SNDLPM_Msk
#define USB_OTG_GLPMCFG_LPMRCNTSTS_Pos   (25U)
#define USB_OTG_GLPMCFG_LPMRCNTSTS_Msk   (0x7UL << USB_OTG_GLPMCFG_LPMRCNTSTS_Pos)
#define USB_OTG_GLPMCFG_LPMRCNTSTS   USB_OTG_GLPMCFG_LPMRCNTSTS_Msk
#define USB_OTG_GLPMCFG_ENBESL_Pos   (28U)
#define USB_OTG_GLPMCFG_ENBESL_Msk   (0x1UL << USB_OTG_GLPMCFG_ENBESL_Pos)
#define USB_OTG_GLPMCFG_ENBESL   USB_OTG_GLPMCFG_ENBESL_Msk
#define USB_OTG_DIEPEACHMSK1_XFRCM_Pos   (0U)
#define USB_OTG_DIEPEACHMSK1_XFRCM_Msk   (0x1UL << USB_OTG_DIEPEACHMSK1_XFRCM_Pos)
#define USB_OTG_DIEPEACHMSK1_XFRCM   USB_OTG_DIEPEACHMSK1_XFRCM_Msk
#define USB_OTG_DIEPEACHMSK1_EPDM_Pos   (1U)
#define USB_OTG_DIEPEACHMSK1_EPDM_Msk   (0x1UL << USB_OTG_DIEPEACHMSK1_EPDM_Pos)
#define USB_OTG_DIEPEACHMSK1_EPDM   USB_OTG_DIEPEACHMSK1_EPDM_Msk
#define USB_OTG_DIEPEACHMSK1_TOM_Pos   (3U)
#define USB_OTG_DIEPEACHMSK1_TOM_Msk   (0x1UL << USB_OTG_DIEPEACHMSK1_TOM_Pos)
#define USB_OTG_DIEPEACHMSK1_TOM   USB_OTG_DIEPEACHMSK1_TOM_Msk
#define USB_OTG_DIEPEACHMSK1_ITTXFEMSK_Pos   (4U)
#define USB_OTG_DIEPEACHMSK1_ITTXFEMSK_Msk   (0x1UL << USB_OTG_DIEPEACHMSK1_ITTXFEMSK_Pos)
#define USB_OTG_DIEPEACHMSK1_ITTXFEMSK   USB_OTG_DIEPEACHMSK1_ITTXFEMSK_Msk
#define USB_OTG_DIEPEACHMSK1_INEPNMM_Pos   (5U)
#define USB_OTG_DIEPEACHMSK1_INEPNMM_Msk   (0x1UL << USB_OTG_DIEPEACHMSK1_INEPNMM_Pos)
#define USB_OTG_DIEPEACHMSK1_INEPNMM   USB_OTG_DIEPEACHMSK1_INEPNMM_Msk
#define USB_OTG_DIEPEACHMSK1_INEPNEM_Pos   (6U)
#define USB_OTG_DIEPEACHMSK1_INEPNEM_Msk   (0x1UL << USB_OTG_DIEPEACHMSK1_INEPNEM_Pos)
#define USB_OTG_DIEPEACHMSK1_INEPNEM   USB_OTG_DIEPEACHMSK1_INEPNEM_Msk
#define USB_OTG_DIEPEACHMSK1_TXFURM_Pos   (8U)
#define USB_OTG_DIEPEACHMSK1_TXFURM_Msk   (0x1UL << USB_OTG_DIEPEACHMSK1_TXFURM_Pos)
#define USB_OTG_DIEPEACHMSK1_TXFURM   USB_OTG_DIEPEACHMSK1_TXFURM_Msk
#define USB_OTG_DIEPEACHMSK1_BIM_Pos   (9U)
#define USB_OTG_DIEPEACHMSK1_BIM_Msk   (0x1UL << USB_OTG_DIEPEACHMSK1_BIM_Pos)
#define USB_OTG_DIEPEACHMSK1_BIM   USB_OTG_DIEPEACHMSK1_BIM_Msk
#define USB_OTG_DIEPEACHMSK1_NAKM_Pos   (13U)
#define USB_OTG_DIEPEACHMSK1_NAKM_Msk   (0x1UL << USB_OTG_DIEPEACHMSK1_NAKM_Pos)
#define USB_OTG_DIEPEACHMSK1_NAKM   USB_OTG_DIEPEACHMSK1_NAKM_Msk
#define USB_OTG_HPRT_PCSTS_Pos   (0U)
#define USB_OTG_HPRT_PCSTS_Msk   (0x1UL << USB_OTG_HPRT_PCSTS_Pos)
#define USB_OTG_HPRT_PCSTS   USB_OTG_HPRT_PCSTS_Msk
#define USB_OTG_HPRT_PCDET_Pos   (1U)
#define USB_OTG_HPRT_PCDET_Msk   (0x1UL << USB_OTG_HPRT_PCDET_Pos)
#define USB_OTG_HPRT_PCDET   USB_OTG_HPRT_PCDET_Msk
#define USB_OTG_HPRT_PENA_Pos   (2U)
#define USB_OTG_HPRT_PENA_Msk   (0x1UL << USB_OTG_HPRT_PENA_Pos)
#define USB_OTG_HPRT_PENA   USB_OTG_HPRT_PENA_Msk
#define USB_OTG_HPRT_PENCHNG_Pos   (3U)
#define USB_OTG_HPRT_PENCHNG_Msk   (0x1UL << USB_OTG_HPRT_PENCHNG_Pos)
#define USB_OTG_HPRT_PENCHNG   USB_OTG_HPRT_PENCHNG_Msk
#define USB_OTG_HPRT_POCA_Pos   (4U)
#define USB_OTG_HPRT_POCA_Msk   (0x1UL << USB_OTG_HPRT_POCA_Pos)
#define USB_OTG_HPRT_POCA   USB_OTG_HPRT_POCA_Msk
#define USB_OTG_HPRT_POCCHNG_Pos   (5U)
#define USB_OTG_HPRT_POCCHNG_Msk   (0x1UL << USB_OTG_HPRT_POCCHNG_Pos)
#define USB_OTG_HPRT_POCCHNG   USB_OTG_HPRT_POCCHNG_Msk
#define USB_OTG_HPRT_PRES_Pos   (6U)
#define USB_OTG_HPRT_PRES_Msk   (0x1UL << USB_OTG_HPRT_PRES_Pos)
#define USB_OTG_HPRT_PRES   USB_OTG_HPRT_PRES_Msk
#define USB_OTG_HPRT_PSUSP_Pos   (7U)
#define USB_OTG_HPRT_PSUSP_Msk   (0x1UL << USB_OTG_HPRT_PSUSP_Pos)
#define USB_OTG_HPRT_PSUSP   USB_OTG_HPRT_PSUSP_Msk
#define USB_OTG_HPRT_PRST_Pos   (8U)
#define USB_OTG_HPRT_PRST_Msk   (0x1UL << USB_OTG_HPRT_PRST_Pos)
#define USB_OTG_HPRT_PRST   USB_OTG_HPRT_PRST_Msk
#define USB_OTG_HPRT_PLSTS_Pos   (10U)
#define USB_OTG_HPRT_PLSTS_Msk   (0x3UL << USB_OTG_HPRT_PLSTS_Pos)
#define USB_OTG_HPRT_PLSTS   USB_OTG_HPRT_PLSTS_Msk
#define USB_OTG_HPRT_PLSTS_0   (0x1UL << USB_OTG_HPRT_PLSTS_Pos)
#define USB_OTG_HPRT_PLSTS_1   (0x2UL << USB_OTG_HPRT_PLSTS_Pos)
#define USB_OTG_HPRT_PPWR_Pos   (12U)
#define USB_OTG_HPRT_PPWR_Msk   (0x1UL << USB_OTG_HPRT_PPWR_Pos)
#define USB_OTG_HPRT_PPWR   USB_OTG_HPRT_PPWR_Msk
#define USB_OTG_HPRT_PTCTL_Pos   (13U)
#define USB_OTG_HPRT_PTCTL_Msk   (0xFUL << USB_OTG_HPRT_PTCTL_Pos)
#define USB_OTG_HPRT_PTCTL   USB_OTG_HPRT_PTCTL_Msk
#define USB_OTG_HPRT_PTCTL_0   (0x1UL << USB_OTG_HPRT_PTCTL_Pos)
#define USB_OTG_HPRT_PTCTL_1   (0x2UL << USB_OTG_HPRT_PTCTL_Pos)
#define USB_OTG_HPRT_PTCTL_2   (0x4UL << USB_OTG_HPRT_PTCTL_Pos)
#define USB_OTG_HPRT_PTCTL_3   (0x8UL << USB_OTG_HPRT_PTCTL_Pos)
#define USB_OTG_HPRT_PSPD_Pos   (17U)
#define USB_OTG_HPRT_PSPD_Msk   (0x3UL << USB_OTG_HPRT_PSPD_Pos)
#define USB_OTG_HPRT_PSPD   USB_OTG_HPRT_PSPD_Msk
#define USB_OTG_HPRT_PSPD_0   (0x1UL << USB_OTG_HPRT_PSPD_Pos)
#define USB_OTG_HPRT_PSPD_1   (0x2UL << USB_OTG_HPRT_PSPD_Pos)
#define USB_OTG_DOEPEACHMSK1_XFRCM_Pos   (0U)
#define USB_OTG_DOEPEACHMSK1_XFRCM_Msk   (0x1UL << USB_OTG_DOEPEACHMSK1_XFRCM_Pos)
#define USB_OTG_DOEPEACHMSK1_XFRCM   USB_OTG_DOEPEACHMSK1_XFRCM_Msk
#define USB_OTG_DOEPEACHMSK1_EPDM_Pos   (1U)
#define USB_OTG_DOEPEACHMSK1_EPDM_Msk   (0x1UL << USB_OTG_DOEPEACHMSK1_EPDM_Pos)
#define USB_OTG_DOEPEACHMSK1_EPDM   USB_OTG_DOEPEACHMSK1_EPDM_Msk
#define USB_OTG_DOEPEACHMSK1_TOM_Pos   (3U)
#define USB_OTG_DOEPEACHMSK1_TOM_Msk   (0x1UL << USB_OTG_DOEPEACHMSK1_TOM_Pos)
#define USB_OTG_DOEPEACHMSK1_TOM   USB_OTG_DOEPEACHMSK1_TOM_Msk
#define USB_OTG_DOEPEACHMSK1_ITTXFEMSK_Pos   (4U)
#define USB_OTG_DOEPEACHMSK1_ITTXFEMSK_Msk   (0x1UL << USB_OTG_DOEPEACHMSK1_ITTXFEMSK_Pos)
#define USB_OTG_DOEPEACHMSK1_ITTXFEMSK   USB_OTG_DOEPEACHMSK1_ITTXFEMSK_Msk
#define USB_OTG_DOEPEACHMSK1_INEPNMM_Pos   (5U)
#define USB_OTG_DOEPEACHMSK1_INEPNMM_Msk   (0x1UL << USB_OTG_DOEPEACHMSK1_INEPNMM_Pos)
#define USB_OTG_DOEPEACHMSK1_INEPNMM   USB_OTG_DOEPEACHMSK1_INEPNMM_Msk
#define USB_OTG_DOEPEACHMSK1_INEPNEM_Pos   (6U)
#define USB_OTG_DOEPEACHMSK1_INEPNEM_Msk   (0x1UL << USB_OTG_DOEPEACHMSK1_INEPNEM_Pos)
#define USB_OTG_DOEPEACHMSK1_INEPNEM   USB_OTG_DOEPEACHMSK1_INEPNEM_Msk
#define USB_OTG_DOEPEACHMSK1_TXFURM_Pos   (8U)
#define USB_OTG_DOEPEACHMSK1_TXFURM_Msk   (0x1UL << USB_OTG_DOEPEACHMSK1_TXFURM_Pos)
#define USB_OTG_DOEPEACHMSK1_TXFURM   USB_OTG_DOEPEACHMSK1_TXFURM_Msk
#define USB_OTG_DOEPEACHMSK1_BIM_Pos   (9U)
#define USB_OTG_DOEPEACHMSK1_BIM_Msk   (0x1UL << USB_OTG_DOEPEACHMSK1_BIM_Pos)
#define USB_OTG_DOEPEACHMSK1_BIM   USB_OTG_DOEPEACHMSK1_BIM_Msk
#define USB_OTG_DOEPEACHMSK1_BERRM_Pos   (12U)
#define USB_OTG_DOEPEACHMSK1_BERRM_Msk   (0x1UL << USB_OTG_DOEPEACHMSK1_BERRM_Pos)
#define USB_OTG_DOEPEACHMSK1_BERRM   USB_OTG_DOEPEACHMSK1_BERRM_Msk
#define USB_OTG_DOEPEACHMSK1_NAKM_Pos   (13U)
#define USB_OTG_DOEPEACHMSK1_NAKM_Msk   (0x1UL << USB_OTG_DOEPEACHMSK1_NAKM_Pos)
#define USB_OTG_DOEPEACHMSK1_NAKM   USB_OTG_DOEPEACHMSK1_NAKM_Msk
#define USB_OTG_DOEPEACHMSK1_NYETM_Pos   (14U)
#define USB_OTG_DOEPEACHMSK1_NYETM_Msk   (0x1UL << USB_OTG_DOEPEACHMSK1_NYETM_Pos)
#define USB_OTG_DOEPEACHMSK1_NYETM   USB_OTG_DOEPEACHMSK1_NYETM_Msk
#define USB_OTG_HPTXFSIZ_PTXSA_Pos   (0U)
#define USB_OTG_HPTXFSIZ_PTXSA_Msk   (0xFFFFUL << USB_OTG_HPTXFSIZ_PTXSA_Pos)
#define USB_OTG_HPTXFSIZ_PTXSA   USB_OTG_HPTXFSIZ_PTXSA_Msk
#define USB_OTG_HPTXFSIZ_PTXFD_Pos   (16U)
#define USB_OTG_HPTXFSIZ_PTXFD_Msk   (0xFFFFUL << USB_OTG_HPTXFSIZ_PTXFD_Pos)
#define USB_OTG_HPTXFSIZ_PTXFD   USB_OTG_HPTXFSIZ_PTXFD_Msk
#define USB_OTG_DIEPCTL_MPSIZ_Pos   (0U)
#define USB_OTG_DIEPCTL_MPSIZ_Msk   (0x7FFUL << USB_OTG_DIEPCTL_MPSIZ_Pos)
#define USB_OTG_DIEPCTL_MPSIZ   USB_OTG_DIEPCTL_MPSIZ_Msk
#define USB_OTG_DIEPCTL_USBAEP_Pos   (15U)
#define USB_OTG_DIEPCTL_USBAEP_Msk   (0x1UL << USB_OTG_DIEPCTL_USBAEP_Pos)
#define USB_OTG_DIEPCTL_USBAEP   USB_OTG_DIEPCTL_USBAEP_Msk
#define USB_OTG_DIEPCTL_EONUM_DPID_Pos   (16U)
#define USB_OTG_DIEPCTL_EONUM_DPID_Msk   (0x1UL << USB_OTG_DIEPCTL_EONUM_DPID_Pos)
#define USB_OTG_DIEPCTL_EONUM_DPID   USB_OTG_DIEPCTL_EONUM_DPID_Msk
#define USB_OTG_DIEPCTL_NAKSTS_Pos   (17U)
#define USB_OTG_DIEPCTL_NAKSTS_Msk   (0x1UL << USB_OTG_DIEPCTL_NAKSTS_Pos)
#define USB_OTG_DIEPCTL_NAKSTS   USB_OTG_DIEPCTL_NAKSTS_Msk
#define USB_OTG_DIEPCTL_EPTYP_Pos   (18U)
#define USB_OTG_DIEPCTL_EPTYP_Msk   (0x3UL << USB_OTG_DIEPCTL_EPTYP_Pos)
#define USB_OTG_DIEPCTL_EPTYP   USB_OTG_DIEPCTL_EPTYP_Msk
#define USB_OTG_DIEPCTL_EPTYP_0   (0x1UL << USB_OTG_DIEPCTL_EPTYP_Pos)
#define USB_OTG_DIEPCTL_EPTYP_1   (0x2UL << USB_OTG_DIEPCTL_EPTYP_Pos)
#define USB_OTG_DIEPCTL_STALL_Pos   (21U)
#define USB_OTG_DIEPCTL_STALL_Msk   (0x1UL << USB_OTG_DIEPCTL_STALL_Pos)
#define USB_OTG_DIEPCTL_STALL   USB_OTG_DIEPCTL_STALL_Msk
#define USB_OTG_DIEPCTL_TXFNUM_Pos   (22U)
#define USB_OTG_DIEPCTL_TXFNUM_Msk   (0xFUL << USB_OTG_DIEPCTL_TXFNUM_Pos)
#define USB_OTG_DIEPCTL_TXFNUM   USB_OTG_DIEPCTL_TXFNUM_Msk
#define USB_OTG_DIEPCTL_TXFNUM_0   (0x1UL << USB_OTG_DIEPCTL_TXFNUM_Pos)
#define USB_OTG_DIEPCTL_TXFNUM_1   (0x2UL << USB_OTG_DIEPCTL_TXFNUM_Pos)
#define USB_OTG_DIEPCTL_TXFNUM_2   (0x4UL << USB_OTG_DIEPCTL_TXFNUM_Pos)
#define USB_OTG_DIEPCTL_TXFNUM_3   (0x8UL << USB_OTG_DIEPCTL_TXFNUM_Pos)
#define USB_OTG_DIEPCTL_CNAK_Pos   (26U)
#define USB_OTG_DIEPCTL_CNAK_Msk   (0x1UL << USB_OTG_DIEPCTL_CNAK_Pos)
#define USB_OTG_DIEPCTL_CNAK   USB_OTG_DIEPCTL_CNAK_Msk
#define USB_OTG_DIEPCTL_SNAK_Pos   (27U)
#define USB_OTG_DIEPCTL_SNAK_Msk   (0x1UL << USB_OTG_DIEPCTL_SNAK_Pos)
#define USB_OTG_DIEPCTL_SNAK   USB_OTG_DIEPCTL_SNAK_Msk
#define USB_OTG_DIEPCTL_SD0PID_SEVNFRM_Pos   (28U)
#define USB_OTG_DIEPCTL_SD0PID_SEVNFRM_Msk   (0x1UL << USB_OTG_DIEPCTL_SD0PID_SEVNFRM_Pos)
#define USB_OTG_DIEPCTL_SD0PID_SEVNFRM   USB_OTG_DIEPCTL_SD0PID_SEVNFRM_Msk
#define USB_OTG_DIEPCTL_SODDFRM_Pos   (29U)
#define USB_OTG_DIEPCTL_SODDFRM_Msk   (0x1UL << USB_OTG_DIEPCTL_SODDFRM_Pos)
#define USB_OTG_DIEPCTL_SODDFRM   USB_OTG_DIEPCTL_SODDFRM_Msk
#define USB_OTG_DIEPCTL_EPDIS_Pos   (30U)
#define USB_OTG_DIEPCTL_EPDIS_Msk   (0x1UL << USB_OTG_DIEPCTL_EPDIS_Pos)
#define USB_OTG_DIEPCTL_EPDIS   USB_OTG_DIEPCTL_EPDIS_Msk
#define USB_OTG_DIEPCTL_EPENA_Pos   (31U)
#define USB_OTG_DIEPCTL_EPENA_Msk   (0x1UL << USB_OTG_DIEPCTL_EPENA_Pos)
#define USB_OTG_DIEPCTL_EPENA   USB_OTG_DIEPCTL_EPENA_Msk
#define USB_OTG_HCCHAR_MPSIZ_Pos   (0U)
#define USB_OTG_HCCHAR_MPSIZ_Msk   (0x7FFUL << USB_OTG_HCCHAR_MPSIZ_Pos)
#define USB_OTG_HCCHAR_MPSIZ   USB_OTG_HCCHAR_MPSIZ_Msk
#define USB_OTG_HCCHAR_EPNUM_Pos   (11U)
#define USB_OTG_HCCHAR_EPNUM_Msk   (0xFUL << USB_OTG_HCCHAR_EPNUM_Pos)
#define USB_OTG_HCCHAR_EPNUM   USB_OTG_HCCHAR_EPNUM_Msk
#define USB_OTG_HCCHAR_EPNUM_0   (0x1UL << USB_OTG_HCCHAR_EPNUM_Pos)
#define USB_OTG_HCCHAR_EPNUM_1   (0x2UL << USB_OTG_HCCHAR_EPNUM_Pos)
#define USB_OTG_HCCHAR_EPNUM_2   (0x4UL << USB_OTG_HCCHAR_EPNUM_Pos)
#define USB_OTG_HCCHAR_EPNUM_3   (0x8UL << USB_OTG_HCCHAR_EPNUM_Pos)
#define USB_OTG_HCCHAR_EPDIR_Pos   (15U)
#define USB_OTG_HCCHAR_EPDIR_Msk   (0x1UL << USB_OTG_HCCHAR_EPDIR_Pos)
#define USB_OTG_HCCHAR_EPDIR   USB_OTG_HCCHAR_EPDIR_Msk
#define USB_OTG_HCCHAR_LSDEV_Pos   (17U)
#define USB_OTG_HCCHAR_LSDEV_Msk   (0x1UL << USB_OTG_HCCHAR_LSDEV_Pos)
#define USB_OTG_HCCHAR_LSDEV   USB_OTG_HCCHAR_LSDEV_Msk
#define USB_OTG_HCCHAR_EPTYP_Pos   (18U)
#define USB_OTG_HCCHAR_EPTYP_Msk   (0x3UL << USB_OTG_HCCHAR_EPTYP_Pos)
#define USB_OTG_HCCHAR_EPTYP   USB_OTG_HCCHAR_EPTYP_Msk
#define USB_OTG_HCCHAR_EPTYP_0   (0x1UL << USB_OTG_HCCHAR_EPTYP_Pos)
#define USB_OTG_HCCHAR_EPTYP_1   (0x2UL << USB_OTG_HCCHAR_EPTYP_Pos)
#define USB_OTG_HCCHAR_MC_Pos   (20U)
#define USB_OTG_HCCHAR_MC_Msk   (0x3UL << USB_OTG_HCCHAR_MC_Pos)
#define USB_OTG_HCCHAR_MC   USB_OTG_HCCHAR_MC_Msk
#define USB_OTG_HCCHAR_MC_0   (0x1UL << USB_OTG_HCCHAR_MC_Pos)
#define USB_OTG_HCCHAR_MC_1   (0x2UL << USB_OTG_HCCHAR_MC_Pos)
#define USB_OTG_HCCHAR_DAD_Pos   (22U)
#define USB_OTG_HCCHAR_DAD_Msk   (0x7FUL << USB_OTG_HCCHAR_DAD_Pos)
#define USB_OTG_HCCHAR_DAD   USB_OTG_HCCHAR_DAD_Msk
#define USB_OTG_HCCHAR_DAD_0   (0x01UL << USB_OTG_HCCHAR_DAD_Pos)
#define USB_OTG_HCCHAR_DAD_1   (0x02UL << USB_OTG_HCCHAR_DAD_Pos)
#define USB_OTG_HCCHAR_DAD_2   (0x04UL << USB_OTG_HCCHAR_DAD_Pos)
#define USB_OTG_HCCHAR_DAD_3   (0x08UL << USB_OTG_HCCHAR_DAD_Pos)
#define USB_OTG_HCCHAR_DAD_4   (0x10UL << USB_OTG_HCCHAR_DAD_Pos)
#define USB_OTG_HCCHAR_DAD_5   (0x20UL << USB_OTG_HCCHAR_DAD_Pos)
#define USB_OTG_HCCHAR_DAD_6   (0x40UL << USB_OTG_HCCHAR_DAD_Pos)
#define USB_OTG_HCCHAR_ODDFRM_Pos   (29U)
#define USB_OTG_HCCHAR_ODDFRM_Msk   (0x1UL << USB_OTG_HCCHAR_ODDFRM_Pos)
#define USB_OTG_HCCHAR_ODDFRM   USB_OTG_HCCHAR_ODDFRM_Msk
#define USB_OTG_HCCHAR_CHDIS_Pos   (30U)
#define USB_OTG_HCCHAR_CHDIS_Msk   (0x1UL << USB_OTG_HCCHAR_CHDIS_Pos)
#define USB_OTG_HCCHAR_CHDIS   USB_OTG_HCCHAR_CHDIS_Msk
#define USB_OTG_HCCHAR_CHENA_Pos   (31U)
#define USB_OTG_HCCHAR_CHENA_Msk   (0x1UL << USB_OTG_HCCHAR_CHENA_Pos)
#define USB_OTG_HCCHAR_CHENA   USB_OTG_HCCHAR_CHENA_Msk
#define USB_OTG_HCSPLT_PRTADDR_Pos   (0U)
#define USB_OTG_HCSPLT_PRTADDR_Msk   (0x7FUL << USB_OTG_HCSPLT_PRTADDR_Pos)
#define USB_OTG_HCSPLT_PRTADDR   USB_OTG_HCSPLT_PRTADDR_Msk
#define USB_OTG_HCSPLT_PRTADDR_0   (0x01UL << USB_OTG_HCSPLT_PRTADDR_Pos)
#define USB_OTG_HCSPLT_PRTADDR_1   (0x02UL << USB_OTG_HCSPLT_PRTADDR_Pos)
#define USB_OTG_HCSPLT_PRTADDR_2   (0x04UL << USB_OTG_HCSPLT_PRTADDR_Pos)
#define USB_OTG_HCSPLT_PRTADDR_3   (0x08UL << USB_OTG_HCSPLT_PRTADDR_Pos)
#define USB_OTG_HCSPLT_PRTADDR_4   (0x10UL << USB_OTG_HCSPLT_PRTADDR_Pos)
#define USB_OTG_HCSPLT_PRTADDR_5   (0x20UL << USB_OTG_HCSPLT_PRTADDR_Pos)
#define USB_OTG_HCSPLT_PRTADDR_6   (0x40UL << USB_OTG_HCSPLT_PRTADDR_Pos)
#define USB_OTG_HCSPLT_HUBADDR_Pos   (7U)
#define USB_OTG_HCSPLT_HUBADDR_Msk   (0x7FUL << USB_OTG_HCSPLT_HUBADDR_Pos)
#define USB_OTG_HCSPLT_HUBADDR   USB_OTG_HCSPLT_HUBADDR_Msk
#define USB_OTG_HCSPLT_HUBADDR_0   (0x01UL << USB_OTG_HCSPLT_HUBADDR_Pos)
#define USB_OTG_HCSPLT_HUBADDR_1   (0x02UL << USB_OTG_HCSPLT_HUBADDR_Pos)
#define USB_OTG_HCSPLT_HUBADDR_2   (0x04UL << USB_OTG_HCSPLT_HUBADDR_Pos)
#define USB_OTG_HCSPLT_HUBADDR_3   (0x08UL << USB_OTG_HCSPLT_HUBADDR_Pos)
#define USB_OTG_HCSPLT_HUBADDR_4   (0x10UL << USB_OTG_HCSPLT_HUBADDR_Pos)
#define USB_OTG_HCSPLT_HUBADDR_5   (0x20UL << USB_OTG_HCSPLT_HUBADDR_Pos)
#define USB_OTG_HCSPLT_HUBADDR_6   (0x40UL << USB_OTG_HCSPLT_HUBADDR_Pos)
#define USB_OTG_HCSPLT_XACTPOS_Pos   (14U)
#define USB_OTG_HCSPLT_XACTPOS_Msk   (0x3UL << USB_OTG_HCSPLT_XACTPOS_Pos)
#define USB_OTG_HCSPLT_XACTPOS   USB_OTG_HCSPLT_XACTPOS_Msk
#define USB_OTG_HCSPLT_XACTPOS_0   (0x1UL << USB_OTG_HCSPLT_XACTPOS_Pos)
#define USB_OTG_HCSPLT_XACTPOS_1   (0x2UL << USB_OTG_HCSPLT_XACTPOS_Pos)
#define USB_OTG_HCSPLT_COMPLSPLT_Pos   (16U)
#define USB_OTG_HCSPLT_COMPLSPLT_Msk   (0x1UL << USB_OTG_HCSPLT_COMPLSPLT_Pos)
#define USB_OTG_HCSPLT_COMPLSPLT   USB_OTG_HCSPLT_COMPLSPLT_Msk
#define USB_OTG_HCSPLT_SPLITEN_Pos   (31U)
#define USB_OTG_HCSPLT_SPLITEN_Msk   (0x1UL << USB_OTG_HCSPLT_SPLITEN_Pos)
#define USB_OTG_HCSPLT_SPLITEN   USB_OTG_HCSPLT_SPLITEN_Msk
#define USB_OTG_HCINT_XFRC_Pos   (0U)
#define USB_OTG_HCINT_XFRC_Msk   (0x1UL << USB_OTG_HCINT_XFRC_Pos)
#define USB_OTG_HCINT_XFRC   USB_OTG_HCINT_XFRC_Msk
#define USB_OTG_HCINT_CHH_Pos   (1U)
#define USB_OTG_HCINT_CHH_Msk   (0x1UL << USB_OTG_HCINT_CHH_Pos)
#define USB_OTG_HCINT_CHH   USB_OTG_HCINT_CHH_Msk
#define USB_OTG_HCINT_AHBERR_Pos   (2U)
#define USB_OTG_HCINT_AHBERR_Msk   (0x1UL << USB_OTG_HCINT_AHBERR_Pos)
#define USB_OTG_HCINT_AHBERR   USB_OTG_HCINT_AHBERR_Msk
#define USB_OTG_HCINT_STALL_Pos   (3U)
#define USB_OTG_HCINT_STALL_Msk   (0x1UL << USB_OTG_HCINT_STALL_Pos)
#define USB_OTG_HCINT_STALL   USB_OTG_HCINT_STALL_Msk
#define USB_OTG_HCINT_NAK_Pos   (4U)
#define USB_OTG_HCINT_NAK_Msk   (0x1UL << USB_OTG_HCINT_NAK_Pos)
#define USB_OTG_HCINT_NAK   USB_OTG_HCINT_NAK_Msk
#define USB_OTG_HCINT_ACK_Pos   (5U)
#define USB_OTG_HCINT_ACK_Msk   (0x1UL << USB_OTG_HCINT_ACK_Pos)
#define USB_OTG_HCINT_ACK   USB_OTG_HCINT_ACK_Msk
#define USB_OTG_HCINT_NYET_Pos   (6U)
#define USB_OTG_HCINT_NYET_Msk   (0x1UL << USB_OTG_HCINT_NYET_Pos)
#define USB_OTG_HCINT_NYET   USB_OTG_HCINT_NYET_Msk
#define USB_OTG_HCINT_TXERR_Pos   (7U)
#define USB_OTG_HCINT_TXERR_Msk   (0x1UL << USB_OTG_HCINT_TXERR_Pos)
#define USB_OTG_HCINT_TXERR   USB_OTG_HCINT_TXERR_Msk
#define USB_OTG_HCINT_BBERR_Pos   (8U)
#define USB_OTG_HCINT_BBERR_Msk   (0x1UL << USB_OTG_HCINT_BBERR_Pos)
#define USB_OTG_HCINT_BBERR   USB_OTG_HCINT_BBERR_Msk
#define USB_OTG_HCINT_FRMOR_Pos   (9U)
#define USB_OTG_HCINT_FRMOR_Msk   (0x1UL << USB_OTG_HCINT_FRMOR_Pos)
#define USB_OTG_HCINT_FRMOR   USB_OTG_HCINT_FRMOR_Msk
#define USB_OTG_HCINT_DTERR_Pos   (10U)
#define USB_OTG_HCINT_DTERR_Msk   (0x1UL << USB_OTG_HCINT_DTERR_Pos)
#define USB_OTG_HCINT_DTERR   USB_OTG_HCINT_DTERR_Msk
#define USB_OTG_DIEPINT_XFRC_Pos   (0U)
#define USB_OTG_DIEPINT_XFRC_Msk   (0x1UL << USB_OTG_DIEPINT_XFRC_Pos)
#define USB_OTG_DIEPINT_XFRC   USB_OTG_DIEPINT_XFRC_Msk
#define USB_OTG_DIEPINT_EPDISD_Pos   (1U)
#define USB_OTG_DIEPINT_EPDISD_Msk   (0x1UL << USB_OTG_DIEPINT_EPDISD_Pos)
#define USB_OTG_DIEPINT_EPDISD   USB_OTG_DIEPINT_EPDISD_Msk
#define USB_OTG_DIEPINT_AHBERR_Pos   (2U)
#define USB_OTG_DIEPINT_AHBERR_Msk   (0x1UL << USB_OTG_DIEPINT_AHBERR_Pos)
#define USB_OTG_DIEPINT_AHBERR   USB_OTG_DIEPINT_AHBERR_Msk
#define USB_OTG_DIEPINT_TOC_Pos   (3U)
#define USB_OTG_DIEPINT_TOC_Msk   (0x1UL << USB_OTG_DIEPINT_TOC_Pos)
#define USB_OTG_DIEPINT_TOC   USB_OTG_DIEPINT_TOC_Msk
#define USB_OTG_DIEPINT_ITTXFE_Pos   (4U)
#define USB_OTG_DIEPINT_ITTXFE_Msk   (0x1UL << USB_OTG_DIEPINT_ITTXFE_Pos)
#define USB_OTG_DIEPINT_ITTXFE   USB_OTG_DIEPINT_ITTXFE_Msk
#define USB_OTG_DIEPINT_INEPNM_Pos   (5U)
#define USB_OTG_DIEPINT_INEPNM_Msk   (0x1UL << USB_OTG_DIEPINT_INEPNM_Pos)
#define USB_OTG_DIEPINT_INEPNM   USB_OTG_DIEPINT_INEPNM_Msk
#define USB_OTG_DIEPINT_INEPNE_Pos   (6U)
#define USB_OTG_DIEPINT_INEPNE_Msk   (0x1UL << USB_OTG_DIEPINT_INEPNE_Pos)
#define USB_OTG_DIEPINT_INEPNE   USB_OTG_DIEPINT_INEPNE_Msk
#define USB_OTG_DIEPINT_TXFE_Pos   (7U)
#define USB_OTG_DIEPINT_TXFE_Msk   (0x1UL << USB_OTG_DIEPINT_TXFE_Pos)
#define USB_OTG_DIEPINT_TXFE   USB_OTG_DIEPINT_TXFE_Msk
#define USB_OTG_DIEPINT_TXFIFOUDRN_Pos   (8U)
#define USB_OTG_DIEPINT_TXFIFOUDRN_Msk   (0x1UL << USB_OTG_DIEPINT_TXFIFOUDRN_Pos)
#define USB_OTG_DIEPINT_TXFIFOUDRN   USB_OTG_DIEPINT_TXFIFOUDRN_Msk
#define USB_OTG_DIEPINT_BNA_Pos   (9U)
#define USB_OTG_DIEPINT_BNA_Msk   (0x1UL << USB_OTG_DIEPINT_BNA_Pos)
#define USB_OTG_DIEPINT_BNA   USB_OTG_DIEPINT_BNA_Msk
#define USB_OTG_DIEPINT_PKTDRPSTS_Pos   (11U)
#define USB_OTG_DIEPINT_PKTDRPSTS_Msk   (0x1UL << USB_OTG_DIEPINT_PKTDRPSTS_Pos)
#define USB_OTG_DIEPINT_PKTDRPSTS   USB_OTG_DIEPINT_PKTDRPSTS_Msk
#define USB_OTG_DIEPINT_BERR_Pos   (12U)
#define USB_OTG_DIEPINT_BERR_Msk   (0x1UL << USB_OTG_DIEPINT_BERR_Pos)
#define USB_OTG_DIEPINT_BERR   USB_OTG_DIEPINT_BERR_Msk
#define USB_OTG_DIEPINT_NAK_Pos   (13U)
#define USB_OTG_DIEPINT_NAK_Msk   (0x1UL << USB_OTG_DIEPINT_NAK_Pos)
#define USB_OTG_DIEPINT_NAK   USB_OTG_DIEPINT_NAK_Msk
#define USB_OTG_HCINTMSK_XFRCM_Pos   (0U)
#define USB_OTG_HCINTMSK_XFRCM_Msk   (0x1UL << USB_OTG_HCINTMSK_XFRCM_Pos)
#define USB_OTG_HCINTMSK_XFRCM   USB_OTG_HCINTMSK_XFRCM_Msk
#define USB_OTG_HCINTMSK_CHHM_Pos   (1U)
#define USB_OTG_HCINTMSK_CHHM_Msk   (0x1UL << USB_OTG_HCINTMSK_CHHM_Pos)
#define USB_OTG_HCINTMSK_CHHM   USB_OTG_HCINTMSK_CHHM_Msk
#define USB_OTG_HCINTMSK_AHBERR_Pos   (2U)
#define USB_OTG_HCINTMSK_AHBERR_Msk   (0x1UL << USB_OTG_HCINTMSK_AHBERR_Pos)
#define USB_OTG_HCINTMSK_AHBERR   USB_OTG_HCINTMSK_AHBERR_Msk
#define USB_OTG_HCINTMSK_STALLM_Pos   (3U)
#define USB_OTG_HCINTMSK_STALLM_Msk   (0x1UL << USB_OTG_HCINTMSK_STALLM_Pos)
#define USB_OTG_HCINTMSK_STALLM   USB_OTG_HCINTMSK_STALLM_Msk
#define USB_OTG_HCINTMSK_NAKM_Pos   (4U)
#define USB_OTG_HCINTMSK_NAKM_Msk   (0x1UL << USB_OTG_HCINTMSK_NAKM_Pos)
#define USB_OTG_HCINTMSK_NAKM   USB_OTG_HCINTMSK_NAKM_Msk
#define USB_OTG_HCINTMSK_ACKM_Pos   (5U)
#define USB_OTG_HCINTMSK_ACKM_Msk   (0x1UL << USB_OTG_HCINTMSK_ACKM_Pos)
#define USB_OTG_HCINTMSK_ACKM   USB_OTG_HCINTMSK_ACKM_Msk
#define USB_OTG_HCINTMSK_NYET_Pos   (6U)
#define USB_OTG_HCINTMSK_NYET_Msk   (0x1UL << USB_OTG_HCINTMSK_NYET_Pos)
#define USB_OTG_HCINTMSK_NYET   USB_OTG_HCINTMSK_NYET_Msk
#define USB_OTG_HCINTMSK_TXERRM_Pos   (7U)
#define USB_OTG_HCINTMSK_TXERRM_Msk   (0x1UL << USB_OTG_HCINTMSK_TXERRM_Pos)
#define USB_OTG_HCINTMSK_TXERRM   USB_OTG_HCINTMSK_TXERRM_Msk
#define USB_OTG_HCINTMSK_BBERRM_Pos   (8U)
#define USB_OTG_HCINTMSK_BBERRM_Msk   (0x1UL << USB_OTG_HCINTMSK_BBERRM_Pos)
#define USB_OTG_HCINTMSK_BBERRM   USB_OTG_HCINTMSK_BBERRM_Msk
#define USB_OTG_HCINTMSK_FRMORM_Pos   (9U)
#define USB_OTG_HCINTMSK_FRMORM_Msk   (0x1UL << USB_OTG_HCINTMSK_FRMORM_Pos)
#define USB_OTG_HCINTMSK_FRMORM   USB_OTG_HCINTMSK_FRMORM_Msk
#define USB_OTG_HCINTMSK_DTERRM_Pos   (10U)
#define USB_OTG_HCINTMSK_DTERRM_Msk   (0x1UL << USB_OTG_HCINTMSK_DTERRM_Pos)
#define USB_OTG_HCINTMSK_DTERRM   USB_OTG_HCINTMSK_DTERRM_Msk
#define USB_OTG_DIEPTSIZ_XFRSIZ_Pos   (0U)
#define USB_OTG_DIEPTSIZ_XFRSIZ_Msk   (0x7FFFFUL << USB_OTG_DIEPTSIZ_XFRSIZ_Pos)
#define USB_OTG_DIEPTSIZ_XFRSIZ   USB_OTG_DIEPTSIZ_XFRSIZ_Msk
#define USB_OTG_DIEPTSIZ_PKTCNT_Pos   (19U)
#define USB_OTG_DIEPTSIZ_PKTCNT_Msk   (0x3FFUL << USB_OTG_DIEPTSIZ_PKTCNT_Pos)
#define USB_OTG_DIEPTSIZ_PKTCNT   USB_OTG_DIEPTSIZ_PKTCNT_Msk
#define USB_OTG_DIEPTSIZ_MULCNT_Pos   (29U)
#define USB_OTG_DIEPTSIZ_MULCNT_Msk   (0x3UL << USB_OTG_DIEPTSIZ_MULCNT_Pos)
#define USB_OTG_DIEPTSIZ_MULCNT   USB_OTG_DIEPTSIZ_MULCNT_Msk
#define USB_OTG_HCTSIZ_XFRSIZ_Pos   (0U)
#define USB_OTG_HCTSIZ_XFRSIZ_Msk   (0x7FFFFUL << USB_OTG_HCTSIZ_XFRSIZ_Pos)
#define USB_OTG_HCTSIZ_XFRSIZ   USB_OTG_HCTSIZ_XFRSIZ_Msk
#define USB_OTG_HCTSIZ_PKTCNT_Pos   (19U)
#define USB_OTG_HCTSIZ_PKTCNT_Msk   (0x3FFUL << USB_OTG_HCTSIZ_PKTCNT_Pos)
#define USB_OTG_HCTSIZ_PKTCNT   USB_OTG_HCTSIZ_PKTCNT_Msk
#define USB_OTG_HCTSIZ_DOPING_Pos   (31U)
#define USB_OTG_HCTSIZ_DOPING_Msk   (0x1UL << USB_OTG_HCTSIZ_DOPING_Pos)
#define USB_OTG_HCTSIZ_DOPING   USB_OTG_HCTSIZ_DOPING_Msk
#define USB_OTG_HCTSIZ_DPID_Pos   (29U)
#define USB_OTG_HCTSIZ_DPID_Msk   (0x3UL << USB_OTG_HCTSIZ_DPID_Pos)
#define USB_OTG_HCTSIZ_DPID   USB_OTG_HCTSIZ_DPID_Msk
#define USB_OTG_HCTSIZ_DPID_0   (0x1UL << USB_OTG_HCTSIZ_DPID_Pos)
#define USB_OTG_HCTSIZ_DPID_1   (0x2UL << USB_OTG_HCTSIZ_DPID_Pos)
#define USB_OTG_DIEPDMA_DMAADDR_Pos   (0U)
#define USB_OTG_DIEPDMA_DMAADDR_Msk   (0xFFFFFFFFUL << USB_OTG_DIEPDMA_DMAADDR_Pos)
#define USB_OTG_DIEPDMA_DMAADDR   USB_OTG_DIEPDMA_DMAADDR_Msk
#define USB_OTG_HCDMA_DMAADDR_Pos   (0U)
#define USB_OTG_HCDMA_DMAADDR_Msk   (0xFFFFFFFFUL << USB_OTG_HCDMA_DMAADDR_Pos)
#define USB_OTG_HCDMA_DMAADDR   USB_OTG_HCDMA_DMAADDR_Msk
#define USB_OTG_DTXFSTS_INEPTFSAV_Pos   (0U)
#define USB_OTG_DTXFSTS_INEPTFSAV_Msk   (0xFFFFUL << USB_OTG_DTXFSTS_INEPTFSAV_Pos)
#define USB_OTG_DTXFSTS_INEPTFSAV   USB_OTG_DTXFSTS_INEPTFSAV_Msk
#define USB_OTG_DIEPTXF_INEPTXSA_Pos   (0U)
#define USB_OTG_DIEPTXF_INEPTXSA_Msk   (0xFFFFUL << USB_OTG_DIEPTXF_INEPTXSA_Pos)
#define USB_OTG_DIEPTXF_INEPTXSA   USB_OTG_DIEPTXF_INEPTXSA_Msk
#define USB_OTG_DIEPTXF_INEPTXFD_Pos   (16U)
#define USB_OTG_DIEPTXF_INEPTXFD_Msk   (0xFFFFUL << USB_OTG_DIEPTXF_INEPTXFD_Pos)
#define USB_OTG_DIEPTXF_INEPTXFD   USB_OTG_DIEPTXF_INEPTXFD_Msk
#define USB_OTG_DOEPCTL_MPSIZ_Pos   (0U)
#define USB_OTG_DOEPCTL_MPSIZ_Msk   (0x7FFUL << USB_OTG_DOEPCTL_MPSIZ_Pos)
#define USB_OTG_DOEPCTL_MPSIZ   USB_OTG_DOEPCTL_MPSIZ_Msk /*!< Maximum packet size */
#define USB_OTG_DOEPCTL_USBAEP_Pos   (15U)
#define USB_OTG_DOEPCTL_USBAEP_Msk   (0x1UL << USB_OTG_DOEPCTL_USBAEP_Pos)
#define USB_OTG_DOEPCTL_USBAEP   USB_OTG_DOEPCTL_USBAEP_Msk
#define USB_OTG_DOEPCTL_NAKSTS_Pos   (17U)
#define USB_OTG_DOEPCTL_NAKSTS_Msk   (0x1UL << USB_OTG_DOEPCTL_NAKSTS_Pos)
#define USB_OTG_DOEPCTL_NAKSTS   USB_OTG_DOEPCTL_NAKSTS_Msk
#define USB_OTG_DOEPCTL_SD0PID_SEVNFRM_Pos   (28U)
#define USB_OTG_DOEPCTL_SD0PID_SEVNFRM_Msk   (0x1UL << USB_OTG_DOEPCTL_SD0PID_SEVNFRM_Pos)
#define USB_OTG_DOEPCTL_SD0PID_SEVNFRM   USB_OTG_DOEPCTL_SD0PID_SEVNFRM_Msk
#define USB_OTG_DOEPCTL_SODDFRM_Pos   (29U)
#define USB_OTG_DOEPCTL_SODDFRM_Msk   (0x1UL << USB_OTG_DOEPCTL_SODDFRM_Pos)
#define USB_OTG_DOEPCTL_SODDFRM   USB_OTG_DOEPCTL_SODDFRM_Msk
#define USB_OTG_DOEPCTL_EPTYP_Pos   (18U)
#define USB_OTG_DOEPCTL_EPTYP_Msk   (0x3UL << USB_OTG_DOEPCTL_EPTYP_Pos)
#define USB_OTG_DOEPCTL_EPTYP   USB_OTG_DOEPCTL_EPTYP_Msk
#define USB_OTG_DOEPCTL_EPTYP_0   (0x1UL << USB_OTG_DOEPCTL_EPTYP_Pos)
#define USB_OTG_DOEPCTL_EPTYP_1   (0x2UL << USB_OTG_DOEPCTL_EPTYP_Pos)
#define USB_OTG_DOEPCTL_SNPM_Pos   (20U)
#define USB_OTG_DOEPCTL_SNPM_Msk   (0x1UL << USB_OTG_DOEPCTL_SNPM_Pos)
#define USB_OTG_DOEPCTL_SNPM   USB_OTG_DOEPCTL_SNPM_Msk
#define USB_OTG_DOEPCTL_STALL_Pos   (21U)
#define USB_OTG_DOEPCTL_STALL_Msk   (0x1UL << USB_OTG_DOEPCTL_STALL_Pos)
#define USB_OTG_DOEPCTL_STALL   USB_OTG_DOEPCTL_STALL_Msk
#define USB_OTG_DOEPCTL_CNAK_Pos   (26U)
#define USB_OTG_DOEPCTL_CNAK_Msk   (0x1UL << USB_OTG_DOEPCTL_CNAK_Pos)
#define USB_OTG_DOEPCTL_CNAK   USB_OTG_DOEPCTL_CNAK_Msk
#define USB_OTG_DOEPCTL_SNAK_Pos   (27U)
#define USB_OTG_DOEPCTL_SNAK_Msk   (0x1UL << USB_OTG_DOEPCTL_SNAK_Pos)
#define USB_OTG_DOEPCTL_SNAK   USB_OTG_DOEPCTL_SNAK_Msk
#define USB_OTG_DOEPCTL_EPDIS_Pos   (30U)
#define USB_OTG_DOEPCTL_EPDIS_Msk   (0x1UL << USB_OTG_DOEPCTL_EPDIS_Pos)
#define USB_OTG_DOEPCTL_EPDIS   USB_OTG_DOEPCTL_EPDIS_Msk
#define USB_OTG_DOEPCTL_EPENA_Pos   (31U)
#define USB_OTG_DOEPCTL_EPENA_Msk   (0x1UL << USB_OTG_DOEPCTL_EPENA_Pos)
#define USB_OTG_DOEPCTL_EPENA   USB_OTG_DOEPCTL_EPENA_Msk
#define USB_OTG_DOEPINT_XFRC_Pos   (0U)
#define USB_OTG_DOEPINT_XFRC_Msk   (0x1UL << USB_OTG_DOEPINT_XFRC_Pos)
#define USB_OTG_DOEPINT_XFRC   USB_OTG_DOEPINT_XFRC_Msk
#define USB_OTG_DOEPINT_EPDISD_Pos   (1U)
#define USB_OTG_DOEPINT_EPDISD_Msk   (0x1UL << USB_OTG_DOEPINT_EPDISD_Pos)
#define USB_OTG_DOEPINT_EPDISD   USB_OTG_DOEPINT_EPDISD_Msk
#define USB_OTG_DOEPINT_AHBERR_Pos   (2U)
#define USB_OTG_DOEPINT_AHBERR_Msk   (0x1UL << USB_OTG_DOEPINT_AHBERR_Pos)
#define USB_OTG_DOEPINT_AHBERR   USB_OTG_DOEPINT_AHBERR_Msk
#define USB_OTG_DOEPINT_STUP_Pos   (3U)
#define USB_OTG_DOEPINT_STUP_Msk   (0x1UL << USB_OTG_DOEPINT_STUP_Pos)
#define USB_OTG_DOEPINT_STUP   USB_OTG_DOEPINT_STUP_Msk
#define USB_OTG_DOEPINT_OTEPDIS_Pos   (4U)
#define USB_OTG_DOEPINT_OTEPDIS_Msk   (0x1UL << USB_OTG_DOEPINT_OTEPDIS_Pos)
#define USB_OTG_DOEPINT_OTEPDIS   USB_OTG_DOEPINT_OTEPDIS_Msk
#define USB_OTG_DOEPINT_OTEPSPR_Pos   (5U)
#define USB_OTG_DOEPINT_OTEPSPR_Msk   (0x1UL << USB_OTG_DOEPINT_OTEPSPR_Pos)
#define USB_OTG_DOEPINT_OTEPSPR   USB_OTG_DOEPINT_OTEPSPR_Msk
#define USB_OTG_DOEPINT_B2BSTUP_Pos   (6U)
#define USB_OTG_DOEPINT_B2BSTUP_Msk   (0x1UL << USB_OTG_DOEPINT_B2BSTUP_Pos)
#define USB_OTG_DOEPINT_B2BSTUP   USB_OTG_DOEPINT_B2BSTUP_Msk
#define USB_OTG_DOEPINT_OUTPKTERR_Pos   (8U)
#define USB_OTG_DOEPINT_OUTPKTERR_Msk   (0x1UL << USB_OTG_DOEPINT_OUTPKTERR_Pos)
#define USB_OTG_DOEPINT_OUTPKTERR   USB_OTG_DOEPINT_OUTPKTERR_Msk
#define USB_OTG_DOEPINT_BNA_Pos   (9U)
#define USB_OTG_DOEPINT_BNA_Msk   (0x1UL << USB_OTG_DOEPINT_BNA_Pos)
#define USB_OTG_DOEPINT_BNA   USB_OTG_DOEPINT_BNA_Msk
#define USB_OTG_DOEPINT_BERR_Pos   (12U)
#define USB_OTG_DOEPINT_BERR_Msk   (0x1UL << USB_OTG_DOEPINT_BERR_Pos)
#define USB_OTG_DOEPINT_BERR   USB_OTG_DOEPINT_BERR_Msk
#define USB_OTG_DOEPINT_NAK_Pos   (13U)
#define USB_OTG_DOEPINT_NAK_Msk   (0x1UL << USB_OTG_DOEPINT_NAK_Pos)
#define USB_OTG_DOEPINT_NAK   USB_OTG_DOEPINT_NAK_Msk
#define USB_OTG_DOEPINT_NYET_Pos   (14U)
#define USB_OTG_DOEPINT_NYET_Msk   (0x1UL << USB_OTG_DOEPINT_NYET_Pos)
#define USB_OTG_DOEPINT_NYET   USB_OTG_DOEPINT_NYET_Msk
#define USB_OTG_DOEPINT_STPKTRX_Pos   (15U)
#define USB_OTG_DOEPINT_STPKTRX_Msk   (0x1UL << USB_OTG_DOEPINT_STPKTRX_Pos)
#define USB_OTG_DOEPINT_STPKTRX   USB_OTG_DOEPINT_STPKTRX_Msk
#define USB_OTG_DOEPTSIZ_XFRSIZ_Pos   (0U)
#define USB_OTG_DOEPTSIZ_XFRSIZ_Msk   (0x7FFFFUL << USB_OTG_DOEPTSIZ_XFRSIZ_Pos)
#define USB_OTG_DOEPTSIZ_XFRSIZ   USB_OTG_DOEPTSIZ_XFRSIZ_Msk
#define USB_OTG_DOEPTSIZ_PKTCNT_Pos   (19U)
#define USB_OTG_DOEPTSIZ_PKTCNT_Msk   (0x3FFUL << USB_OTG_DOEPTSIZ_PKTCNT_Pos)
#define USB_OTG_DOEPTSIZ_PKTCNT   USB_OTG_DOEPTSIZ_PKTCNT_Msk
#define USB_OTG_DOEPTSIZ_STUPCNT_Pos   (29U)
#define USB_OTG_DOEPTSIZ_STUPCNT_Msk   (0x3UL << USB_OTG_DOEPTSIZ_STUPCNT_Pos)
#define USB_OTG_DOEPTSIZ_STUPCNT   USB_OTG_DOEPTSIZ_STUPCNT_Msk
#define USB_OTG_DOEPTSIZ_STUPCNT_0   (0x1UL << USB_OTG_DOEPTSIZ_STUPCNT_Pos)
#define USB_OTG_DOEPTSIZ_STUPCNT_1   (0x2UL << USB_OTG_DOEPTSIZ_STUPCNT_Pos)
#define USB_OTG_PCGCCTL_STOPCLK_Pos   (0U)
#define USB_OTG_PCGCCTL_STOPCLK_Msk   (0x1UL << USB_OTG_PCGCCTL_STOPCLK_Pos)
#define USB_OTG_PCGCCTL_STOPCLK   USB_OTG_PCGCCTL_STOPCLK_Msk
#define USB_OTG_PCGCCTL_GATECLK_Pos   (1U)
#define USB_OTG_PCGCCTL_GATECLK_Msk   (0x1UL << USB_OTG_PCGCCTL_GATECLK_Pos)
#define USB_OTG_PCGCCTL_GATECLK   USB_OTG_PCGCCTL_GATECLK_Msk
#define USB_OTG_PCGCCTL_PHYSUSP_Pos   (4U)
#define USB_OTG_PCGCCTL_PHYSUSP_Msk   (0x1UL << USB_OTG_PCGCCTL_PHYSUSP_Pos)
#define USB_OTG_PCGCCTL_PHYSUSP   USB_OTG_PCGCCTL_PHYSUSP_Msk
#define IS_ADC_ALL_INSTANCE(INSTANCE)
#define IS_ADC_MULTIMODE_MASTER_INSTANCE(INSTANCE)   ((INSTANCE) == ADC1)
#define IS_ADC_COMMON_INSTANCE(INSTANCE)   ((INSTANCE) == ADC12_COMMON)
#define IS_COMP_ALL_INSTANCE(INSTANCE)
#define IS_COMP_COMMON_INSTANCE(INSTANCE)   ((INSTANCE) == COMP12_COMMON)
#define IS_COMP_WINDOWMODE_INSTANCE(INSTANCE)   ((INSTANCE) == COMP2)
#define IS_DTS_ALL_INSTANCE(INSTANCE)   ((INSTANCE) == DTS)
#define IS_CRC_ALL_INSTANCE(INSTANCE)   ((INSTANCE) == CRC)
#define IS_DAC_ALL_INSTANCE(INSTANCE)
#define IS_DCMI_ALL_INSTANCE(__INSTANCE__)   ((__INSTANCE__) == DCMI)
#define IS_DLYB_ALL_INSTANCE(INSTANCE)
#define IS_DFSDM_FILTER_ALL_INSTANCE(INSTANCE)
#define IS_DFSDM_CHANNEL_ALL_INSTANCE(INSTANCE)
#define IS_RAMECC_MONITOR_ALL_INSTANCE(INSTANCE)
#define IS_DMA_ALL_INSTANCE(INSTANCE)
#define IS_BDMA_CHANNEL_INSTANCE(INSTANCE)
#define IS_DMA_DMAMUX_ALL_INSTANCE(INSTANCE)
#define IS_BDMA_CHANNEL_DMAMUX_INSTANCE(INSTANCE)
#define IS_DMA_STREAM_INSTANCE(INSTANCE)
#define IS_DMA_STREAM_DMAMUX_INSTANCE(INSTANCE)
#define IS_DMA_REQUEST_GEN_ALL_INSTANCE(INSTANCE)
#define IS_DMA2D_ALL_INSTANCE(__INSTANCE__)   ((__INSTANCE__) == DMA2D)
#define IS_PSSI_ALL_INSTANCE(INSTANCE)   ((INSTANCE) == PSSI)
#define IS_MDMA_STREAM_ALL_INSTANCE(INSTANCE)
#define IS_FDCAN_ALL_INSTANCE(__INSTANCE__)
#define IS_FDCAN_TT_INSTANCE(__INSTANCE__)   ((__INSTANCE__) == FDCAN1)
#define IS_GFXMMU_ALL_INSTANCE(INSTANCE)   ((INSTANCE) == GFXMMU)
#define IS_GPIO_ALL_INSTANCE(INSTANCE)
#define IS_GPIO_AF_INSTANCE(INSTANCE)   IS_GPIO_ALL_INSTANCE(INSTANCE)
#define IS_GPIO_LOCK_INSTANCE(INSTANCE)   IS_GPIO_ALL_INSTANCE(INSTANCE)
#define IS_HSEM_ALL_INSTANCE(INSTANCE)   ((INSTANCE) == HSEM)
#define HSEM_CPU1_COREID   (0x00000001U) /* Semaphore Core CM7 ID */
#define HSEM_CR_COREID_CPU1   (HSEM_CPU1_COREID << HSEM_CR_COREID_Pos)
#define HSEM_CR_COREID_CURRENT   (HSEM_CPU1_COREID << HSEM_CR_COREID_Pos)
#define HSEM_SEMID_MIN   (0U) /* HSEM ID Min*/
#define HSEM_SEMID_MAX   (15U) /* HSEM ID Max */
#define HSEM_PROCESSID_MIN   (0U) /* HSEM Process ID Min */
#define HSEM_PROCESSID_MAX   (255U) /* HSEM Process ID Max */
#define HSEM_CLEAR_KEY_MIN   (0U) /* HSEM clear Key Min value */
#define HSEM_CLEAR_KEY_MAX   (0xFFFFU) /* HSEM clear Key Max value */
#define IS_I2C_ALL_INSTANCE(INSTANCE)
#define IS_SMBUS_ALL_INSTANCE(INSTANCE)
#define IS_I2C_WAKEUP_FROMSTOP_INSTANCE(INSTANCE)   IS_I2C_ALL_INSTANCE(INSTANCE)
#define IS_I2S_ALL_INSTANCE(INSTANCE)
#define IS_LTDC_ALL_INSTANCE(INSTANCE)   ((INSTANCE) == LTDC)
#define IS_RNG_ALL_INSTANCE(INSTANCE)   ((INSTANCE) == RNG)
#define IS_RTC_ALL_INSTANCE(INSTANCE)   ((INSTANCE) == RTC)
#define IS_SDMMC_ALL_INSTANCE(_INSTANCE_)
#define IS_SPI_ALL_INSTANCE(INSTANCE)
#define IS_SPI_HIGHEND_INSTANCE(INSTANCE)
#define IS_SWPMI_INSTANCE(INSTANCE)   ((INSTANCE) == SWPMI1)
#define IS_LPTIM_INSTANCE(INSTANCE)
#define IS_LPTIM_ENCODER_INTERFACE_INSTANCE(INSTANCE)
#define IS_TIM_INSTANCE(INSTANCE)
#define IS_TIM_CC1_INSTANCE(INSTANCE)
#define IS_TIM_CC2_INSTANCE(INSTANCE)
#define IS_TIM_CC3_INSTANCE(INSTANCE)
#define IS_TIM_CC4_INSTANCE(INSTANCE)
#define IS_TIM_CC5_INSTANCE(INSTANCE)
#define IS_TIM_CC6_INSTANCE(INSTANCE)
#define IS_TIM_ADVANCED_INSTANCE(__INSTANCE__)
#define IS_TIM_XOR_INSTANCE(INSTANCE)
#define IS_TIM_DMA_INSTANCE(INSTANCE)
#define IS_TIM_DMA_CC_INSTANCE(INSTANCE)
#define IS_TIM_CCDMA_INSTANCE(INSTANCE)
#define IS_TIM_DMABURST_INSTANCE(INSTANCE)
#define IS_TIM_ETR_INSTANCE(INSTANCE)
#define IS_TIM_REMAP_INSTANCE(INSTANCE)
#define IS_TIM_ETRSEL_INSTANCE(INSTANCE)
#define IS_TIM_MASTER_INSTANCE(INSTANCE)
#define IS_TIM_SLAVE_INSTANCE(INSTANCE)
#define IS_TIM_TRGO2_INSTANCE(INSTANCE)
#define IS_TIM_TISEL_INSTANCE(INSTANCE)
#define IS_TIM_COMMUTATION_EVENT_INSTANCE(INSTANCE)
#define IS_TIM_ENCODER_INTERFACE_INSTANCE(__INSTANCE__)
#define IS_TIM_COMBINED3PHASEPWM_INSTANCE(INSTANCE)
#define IS_TIM_CCX_INSTANCE(INSTANCE, CHANNEL)
#define IS_TIM_BREAK_INSTANCE(INSTANCE)
#define IS_TIM_BREAKSOURCE_INSTANCE(INSTANCE)
#define IS_TIM_CCXN_INSTANCE(INSTANCE, CHANNEL)
#define IS_TIM_COUNTER_MODE_SELECT_INSTANCE(INSTANCE)
#define IS_TIM_REPETITION_COUNTER_INSTANCE(INSTANCE)
#define IS_TIM_SYNCHRO_INSTANCE(__INSTANCE__)
#define IS_TIM_CLOCK_DIVISION_INSTANCE(INSTANCE)
#define IS_TIM_CLOCKSOURCE_ETRMODE1_INSTANCE(INSTANCE)
#define IS_TIM_CLOCKSOURCE_ETRMODE2_INSTANCE(INSTANCE)
#define IS_TIM_CLOCKSOURCE_TIX_INSTANCE(INSTANCE)
#define IS_TIM_CLOCKSOURCE_ITRX_INSTANCE(INSTANCE)
#define IS_TIM_OCXREF_CLEAR_INSTANCE(INSTANCE)
#define IS_TIM_32B_COUNTER_INSTANCE(INSTANCE)
#define IS_TIM_BKIN2_INSTANCE(INSTANCE)
#define IS_TIM_HALL_SENSOR_INTERFACE_INSTANCE(__INSTANCE__)
#define IS_USART_INSTANCE(INSTANCE)
#define IS_UART_SPI_SLAVE_INSTANCE(INSTANCE)
#define IS_UART_INSTANCE(INSTANCE)
#define IS_UART_FIFO_INSTANCE(INSTANCE)
#define IS_USART_AUTOBAUDRATE_DETECTION_INSTANCE(INSTANCE)
#define IS_UART_DRIVER_ENABLE_INSTANCE(INSTANCE)
#define IS_UART_HALFDUPLEX_INSTANCE(INSTANCE)
#define IS_UART_HWFLOW_INSTANCE(INSTANCE)
#define IS_UART_LIN_INSTANCE(INSTANCE)
#define IS_UART_WAKEUP_FROMSTOP_INSTANCE(INSTANCE)
#define IS_IRDA_INSTANCE(INSTANCE)
#define IS_SMARTCARD_INSTANCE(INSTANCE)
#define IS_LPUART_INSTANCE(INSTANCE)   ((INSTANCE) == LPUART1)
#define IS_IWDG_ALL_INSTANCE(INSTANCE)   ((INSTANCE) == IWDG1)
#define IS_USB_ALL_INSTANCE(INSTANCE)   ((INSTANCE) == USB)
#define IS_WWDG_ALL_INSTANCE(INSTANCE)   ((INSTANCE) == WWDG1)
#define IS_MDIOS_ALL_INSTANCE(INSTANCE)   ((INSTANCE) == MDIOS)
#define IS_CEC_ALL_INSTANCE(__INSTANCE__)   ((__INSTANCE__) == CEC)
#define IS_SAI_ALL_INSTANCE(INSTANCE)
#define IS_SPDIFRX_ALL_INSTANCE(INSTANCE)   ((INSTANCE) == SPDIFRX)
#define IS_OPAMP_ALL_INSTANCE(INSTANCE)
#define IS_OPAMP_COMMON_INSTANCE(COMMON_INSTANCE)   ((COMMON_INSTANCE) == OPAMP12_COMMON)
#define IS_PCD_ALL_INSTANCE(INSTANCE)   ((INSTANCE) == USB_OTG_HS)
#define IS_HCD_ALL_INSTANCE(INSTANCE)   ((INSTANCE) == USB_OTG_HS)
#define HASH_RNG_IRQn   RNG_IRQn
#define TIM1_BRK_TIM9_IRQn   TIM1_BRK_IRQn
#define TIM1_UP_TIM10_IRQn   TIM1_UP_IRQn
#define TIM1_TRG_COM_TIM11_IRQn   TIM1_TRG_COM_IRQn
#define PVD_IRQn   PVD_AVD_IRQn
#define BDMA_Channel0_IRQn   BDMA2_Channel0_IRQn
#define BDMA_Channel1_IRQn   BDMA2_Channel1_IRQn
#define BDMA_Channel2_IRQn   BDMA2_Channel2_IRQn
#define BDMA_Channel3_IRQn   BDMA2_Channel3_IRQn
#define BDMA_Channel4_IRQn   BDMA2_Channel4_IRQn
#define BDMA_Channel5_IRQn   BDMA2_Channel5_IRQn
#define BDMA_Channel6_IRQn   BDMA2_Channel6_IRQn
#define BDMA_Channel7_IRQn   BDMA2_Channel7_IRQn
#define PVD_AVD_IRQn   PVD_PVM_IRQn
#define DCMI_IRQn   DCMI_PSSI_IRQn
#define HASH_RNG_IRQHandler   RNG_IRQHandler
#define TIM1_BRK_TIM9_IRQHandler   TIM1_BRK_IRQHandler
#define TIM1_UP_TIM9_IRQHandler   TIM1_UP_IRQHandler
#define TIM1_TRG_COM_TIM11_IRQHandler   TIM1_TRG_COM_IRQHandler
#define PVD_IRQHandler   PVD_AVD_IRQHandler
#define BDMA_Channel0_IRQHandler   BDMA2_Channel0_IRQHandler
#define BDMA_Channel1_IRQHandler   BDMA2_Channel1_IRQHandler
#define BDMA_Channel2_IRQHandler   BDMA2_Channel2_IRQHandler
#define BDMA_Channel3_IRQHandler   BDMA2_Channel3_IRQHandler
#define BDMA_Channel4_IRQHandler   BDMA2_Channel4_IRQHandler
#define BDMA_Channel5_IRQHandler   BDMA2_Channel5_IRQHandler
#define BDMA_Channel6_IRQHandler   BDMA2_Channel6_IRQHandler
#define BDMA_Channel7_IRQHandler   BDMA2_Channel7_IRQHandler
#define PVD_AVD_IRQHandler   PVD_PVM_IRQHandler
#define DCMI_IRQHandler   DCMI_PSSI_IRQHandler
#define BDMA_BASE   BDMA2_BASE
#define BDMA_Channel0_BASE   BDMA2_Channel0_BASE
#define BDMA_Channel1_BASE   BDMA2_Channel1_BASE
#define BDMA_Channel2_BASE   BDMA2_Channel2_BASE
#define BDMA_Channel3_BASE   BDMA2_Channel3_BASE
#define BDMA_Channel4_BASE   BDMA2_Channel4_BASE
#define BDMA_Channel5_BASE   BDMA2_Channel5_BASE
#define BDMA_Channel6_BASE   BDMA2_Channel6_BASE
#define BDMA_Channel7_BASE   BDMA2_Channel7_BASE
#define BDMA   BDMA2
#define BDMA_Channel0   BDMA2_Channel0
#define BDMA_Channel1   BDMA2_Channel1
#define BDMA_Channel2   BDMA2_Channel2
#define BDMA_Channel3   BDMA2_Channel3
#define BDMA_Channel4   BDMA2_Channel4
#define BDMA_Channel5   BDMA2_Channel5
#define BDMA_Channel6   BDMA2_Channel6
#define BDMA_Channel7   BDMA2_Channel7
#define PWR_CPUCR_RUN_D3   PWR_CPUCR_RUN_SRD
#define PWR_CPUCR_PDDS_D3   PWR_CPUCR_PDDS_SRD
#define PWR_CPUCR_PDDS_D1   PWR_CPUCR_RETDS_CD
#define PWR_D3CR_VOS   PWR_SRDCR_VOS
#define PWR_D3CR_VOS_0   PWR_SRDCR_VOS_0
#define PWR_D3CR_VOS_1   PWR_SRDCR_VOS_1
#define PWR_D3CR_VOSRDY   PWR_SRDCR_VOSRDY
enum  IRQn_Type {
  NonMaskableInt_IRQn = -14 , HardFault_IRQn = -13 , MemoryManagement_IRQn = -12 , BusFault_IRQn = -11 ,
  UsageFault_IRQn = -10 , SVCall_IRQn = -5 , DebugMonitor_IRQn = -4 , PendSV_IRQn = -2 ,
  SysTick_IRQn = -1 , WWDG_IRQn = 0 , PVD_AVD_IRQn = 1 , TAMP_STAMP_IRQn = 2 ,
  RTC_WKUP_IRQn = 3 , FLASH_IRQn = 4 , RCC_IRQn = 5 , EXTI0_IRQn = 6 ,
  EXTI1_IRQn = 7 , EXTI2_IRQn = 8 , EXTI3_IRQn = 9 , EXTI4_IRQn = 10 ,
  DMA1_Stream0_IRQn = 11 , DMA1_Stream1_IRQn = 12 , DMA1_Stream2_IRQn = 13 , DMA1_Stream3_IRQn = 14 ,
  DMA1_Stream4_IRQn = 15 , DMA1_Stream5_IRQn = 16 , DMA1_Stream6_IRQn = 17 , ADC_IRQn = 18 ,
  FDCAN1_IT0_IRQn = 19 , FDCAN2_IT0_IRQn = 20 , FDCAN1_IT1_IRQn = 21 , FDCAN2_IT1_IRQn = 22 ,
  EXTI9_5_IRQn = 23 , TIM1_BRK_IRQn = 24 , TIM1_UP_IRQn = 25 , TIM1_TRG_COM_IRQn = 26 ,
  TIM1_CC_IRQn = 27 , TIM2_IRQn = 28 , TIM3_IRQn = 29 , TIM4_IRQn = 30 ,
  I2C1_EV_IRQn = 31 , I2C1_ER_IRQn = 32 , I2C2_EV_IRQn = 33 , I2C2_ER_IRQn = 34 ,
  SPI1_IRQn = 35 , SPI2_IRQn = 36 , USART1_IRQn = 37 , USART2_IRQn = 38 ,
  USART3_IRQn = 39 , EXTI15_10_IRQn = 40 , RTC_Alarm_IRQn = 41 , TIM8_BRK_TIM12_IRQn = 43 ,
  TIM8_UP_TIM13_IRQn = 44 , TIM8_TRG_COM_TIM14_IRQn = 45 , TIM8_CC_IRQn = 46 , DMA1_Stream7_IRQn = 47 ,
  FMC_IRQn = 48 , SDMMC1_IRQn = 49 , TIM5_IRQn = 50 , SPI3_IRQn = 51 ,
  UART4_IRQn = 52 , UART5_IRQn = 53 , TIM6_DAC_IRQn = 54 , TIM7_IRQn = 55 ,
  DMA2_Stream0_IRQn = 56 , DMA2_Stream1_IRQn = 57 , DMA2_Stream2_IRQn = 58 , DMA2_Stream3_IRQn = 59 ,
  DMA2_Stream4_IRQn = 60 , ETH_IRQn = 61 , ETH_WKUP_IRQn = 62 , FDCAN_CAL_IRQn = 63 ,
  DMA2_Stream5_IRQn = 68 , DMA2_Stream6_IRQn = 69 , DMA2_Stream7_IRQn = 70 , USART6_IRQn = 71 ,
  I2C3_EV_IRQn = 72 , I2C3_ER_IRQn = 73 , OTG_HS_EP1_OUT_IRQn = 74 , OTG_HS_EP1_IN_IRQn = 75 ,
  OTG_HS_WKUP_IRQn = 76 , OTG_HS_IRQn = 77 , DCMI_PSSI_IRQn = 78 , RNG_IRQn = 80 ,
  FPU_IRQn = 81 , UART7_IRQn = 82 , UART8_IRQn = 83 , SPI4_IRQn = 84 ,
  SPI5_IRQn = 85 , SPI6_IRQn = 86 , SAI1_IRQn = 87 , LTDC_IRQn = 88 ,
  LTDC_ER_IRQn = 89 , DMA2D_IRQn = 90 , OCTOSPI1_IRQn = 92 , LPTIM1_IRQn = 93 ,
  CEC_IRQn = 94 , I2C4_EV_IRQn = 95 , I2C4_ER_IRQn = 96 , SPDIF_RX_IRQn = 97 ,
  DMAMUX1_OVR_IRQn = 102 , DFSDM1_FLT0_IRQn = 110 , DFSDM1_FLT1_IRQn = 111 , DFSDM1_FLT2_IRQn = 112 ,
  DFSDM1_FLT3_IRQn = 113 , SWPMI1_IRQn = 115 , TIM15_IRQn = 116 , TIM16_IRQn = 117 ,
  TIM17_IRQn = 118 , MDIOS_WKUP_IRQn = 119 , MDIOS_IRQn = 120 , MDMA_IRQn = 122 ,
  SDMMC2_IRQn = 124 , HSEM1_IRQn = 125 , ADC3_IRQn = 127 , DMAMUX2_OVR_IRQn = 128 ,
  BDMA_Channel0_IRQn = 129 , BDMA_Channel1_IRQn = 130 , BDMA_Channel2_IRQn = 131 , BDMA_Channel3_IRQn = 132 ,
  BDMA_Channel4_IRQn = 133 , BDMA_Channel5_IRQn = 134 , BDMA_Channel6_IRQn = 135 , BDMA_Channel7_IRQn = 136 ,
  COMP_IRQn = 137 , LPTIM2_IRQn = 138 , LPTIM3_IRQn = 139 , LPTIM4_IRQn = 140 ,
  LPTIM5_IRQn = 141 , LPUART1_IRQn = 142 , CRS_IRQn = 144 , ECC_IRQn = 145 ,
  SAI4_IRQn = 146 , DTS_IRQn = 147 , WAKEUP_PIN_IRQn = 149 , OCTOSPI2_IRQn = 150 ,
  FMAC_IRQn = 153 , CORDIC_IRQn = 154 , UART9_IRQn = 155 , USART10_IRQn = 156 ,
  I2C5_EV_IRQn = 157 , I2C5_ER_IRQn = 158 , FDCAN3_IT0_IRQn = 159 , FDCAN3_IT1_IRQn = 160 ,
  TIM23_IRQn = 161 , TIM24_IRQn = 162 , NonMaskableInt_IRQn = -14 , HardFault_IRQn = -13 ,
  MemoryManagement_IRQn = -12 , BusFault_IRQn = -11 , UsageFault_IRQn = -10 , SVCall_IRQn = -5 ,
  DebugMonitor_IRQn = -4 , PendSV_IRQn = -2 , SysTick_IRQn = -1 , WWDG_IRQn = 0 ,
  PVD_AVD_IRQn = 1 , TAMP_STAMP_IRQn = 2 , RTC_WKUP_IRQn = 3 , FLASH_IRQn = 4 ,
  RCC_IRQn = 5 , EXTI0_IRQn = 6 , EXTI1_IRQn = 7 , EXTI2_IRQn = 8 ,
  EXTI3_IRQn = 9 , EXTI4_IRQn = 10 , DMA1_Stream0_IRQn = 11 , DMA1_Stream1_IRQn = 12 ,
  DMA1_Stream2_IRQn = 13 , DMA1_Stream3_IRQn = 14 , DMA1_Stream4_IRQn = 15 , DMA1_Stream5_IRQn = 16 ,
  DMA1_Stream6_IRQn = 17 , ADC_IRQn = 18 , FDCAN1_IT0_IRQn = 19 , FDCAN2_IT0_IRQn = 20 ,
  FDCAN1_IT1_IRQn = 21 , FDCAN2_IT1_IRQn = 22 , EXTI9_5_IRQn = 23 , TIM1_BRK_IRQn = 24 ,
  TIM1_UP_IRQn = 25 , TIM1_TRG_COM_IRQn = 26 , TIM1_CC_IRQn = 27 , TIM2_IRQn = 28 ,
  TIM3_IRQn = 29 , TIM4_IRQn = 30 , I2C1_EV_IRQn = 31 , I2C1_ER_IRQn = 32 ,
  I2C2_EV_IRQn = 33 , I2C2_ER_IRQn = 34 , SPI1_IRQn = 35 , SPI2_IRQn = 36 ,
  USART1_IRQn = 37 , USART2_IRQn = 38 , USART3_IRQn = 39 , EXTI15_10_IRQn = 40 ,
  RTC_Alarm_IRQn = 41 , TIM8_BRK_TIM12_IRQn = 43 , TIM8_UP_TIM13_IRQn = 44 , TIM8_TRG_COM_TIM14_IRQn = 45 ,
  TIM8_CC_IRQn = 46 , DMA1_Stream7_IRQn = 47 , FMC_IRQn = 48 , SDMMC1_IRQn = 49 ,
  TIM5_IRQn = 50 , SPI3_IRQn = 51 , UART4_IRQn = 52 , UART5_IRQn = 53 ,
  TIM6_DAC_IRQn = 54 , TIM7_IRQn = 55 , DMA2_Stream0_IRQn = 56 , DMA2_Stream1_IRQn = 57 ,
  DMA2_Stream2_IRQn = 58 , DMA2_Stream3_IRQn = 59 , DMA2_Stream4_IRQn = 60 , ETH_IRQn = 61 ,
  ETH_WKUP_IRQn = 62 , FDCAN_CAL_IRQn = 63 , DMA2_Stream5_IRQn = 68 , DMA2_Stream6_IRQn = 69 ,
  DMA2_Stream7_IRQn = 70 , USART6_IRQn = 71 , I2C3_EV_IRQn = 72 , I2C3_ER_IRQn = 73 ,
  OTG_HS_EP1_OUT_IRQn = 74 , OTG_HS_EP1_IN_IRQn = 75 , OTG_HS_WKUP_IRQn = 76 , OTG_HS_IRQn = 77 ,
  DCMI_PSSI_IRQn = 78 , RNG_IRQn = 80 , FPU_IRQn = 81 , UART7_IRQn = 82 ,
  UART8_IRQn = 83 , SPI4_IRQn = 84 , SPI5_IRQn = 85 , SPI6_IRQn = 86 ,
  SAI1_IRQn = 87 , LTDC_IRQn = 88 , LTDC_ER_IRQn = 89 , DMA2D_IRQn = 90 ,
  OCTOSPI1_IRQn = 92 , LPTIM1_IRQn = 93 , CEC_IRQn = 94 , I2C4_EV_IRQn = 95 ,
  I2C4_ER_IRQn = 96 , SPDIF_RX_IRQn = 97 , DMAMUX1_OVR_IRQn = 102 , DFSDM1_FLT0_IRQn = 110 ,
  DFSDM1_FLT1_IRQn = 111 , DFSDM1_FLT2_IRQn = 112 , DFSDM1_FLT3_IRQn = 113 , SWPMI1_IRQn = 115 ,
  TIM15_IRQn = 116 , TIM16_IRQn = 117 , TIM17_IRQn = 118 , MDIOS_WKUP_IRQn = 119 ,
  MDIOS_IRQn = 120 , MDMA_IRQn = 122 , SDMMC2_IRQn = 124 , HSEM1_IRQn = 125 ,
  ADC3_IRQn = 127 , DMAMUX2_OVR_IRQn = 128 , BDMA_Channel0_IRQn = 129 , BDMA_Channel1_IRQn = 130 ,
  BDMA_Channel2_IRQn = 131 , BDMA_Channel3_IRQn = 132 , BDMA_Channel4_IRQn = 133 , BDMA_Channel5_IRQn = 134 ,
  BDMA_Channel6_IRQn = 135 , BDMA_Channel7_IRQn = 136 , COMP_IRQn = 137 , LPTIM2_IRQn = 138 ,
  LPTIM3_IRQn = 139 , LPTIM4_IRQn = 140 , LPTIM5_IRQn = 141 , LPUART1_IRQn = 142 ,
  CRS_IRQn = 144 , ECC_IRQn = 145 , SAI4_IRQn = 146 , DTS_IRQn = 147 ,
  WAKEUP_PIN_IRQn = 149 , OCTOSPI2_IRQn = 150 , FMAC_IRQn = 153 , CORDIC_IRQn = 154 ,
  UART9_IRQn = 155 , USART10_IRQn = 156 , I2C5_EV_IRQn = 157 , I2C5_ER_IRQn = 158 ,
  FDCAN3_IT0_IRQn = 159 , FDCAN3_IT1_IRQn = 160 , TIM23_IRQn = 161 , TIM24_IRQn = 162 ,
  OTG_HS_WKUP_IRQn = 76 , OTG_HS_IRQn = 77 , DCMI_PSSI_IRQn = 78 , CRYP_IRQn = 79 ,
  HASH_RNG_IRQn = 80 , FPU_IRQn = 81 , UART7_IRQn = 82 , UART8_IRQn = 83 ,
  SPI4_IRQn = 84 , SPI5_IRQn = 85 , SPI6_IRQn = 86 , SAI1_IRQn = 87 ,
  LTDC_IRQn = 88 , LTDC_ER_IRQn = 89 , DMA2D_IRQn = 90 , OCTOSPI1_IRQn = 92 ,
  LPTIM1_IRQn = 93 , CEC_IRQn = 94 , I2C4_EV_IRQn = 95 , I2C4_ER_IRQn = 96 ,
  SPDIF_RX_IRQn = 97 , DMAMUX1_OVR_IRQn = 102 , DFSDM1_FLT0_IRQn = 110 , DFSDM1_FLT1_IRQn = 111 ,
  DFSDM1_FLT2_IRQn = 112 , DFSDM1_FLT3_IRQn = 113 , SWPMI1_IRQn = 115 , TIM15_IRQn = 116 ,
  TIM16_IRQn = 117 , TIM17_IRQn = 118 , MDIOS_WKUP_IRQn = 119 , MDIOS_IRQn = 120 ,
  MDMA_IRQn = 122 , SDMMC2_IRQn = 124 , HSEM1_IRQn = 125 , ADC3_IRQn = 127 ,
  DMAMUX2_OVR_IRQn = 128 , BDMA_Channel0_IRQn = 129 , BDMA_Channel1_IRQn = 130 , BDMA_Channel2_IRQn = 131 ,
  BDMA_Channel3_IRQn = 132 , BDMA_Channel4_IRQn = 133 , BDMA_Channel5_IRQn = 134 , BDMA_Channel6_IRQn = 135 ,
  BDMA_Channel7_IRQn = 136 , COMP_IRQn = 137 , LPTIM2_IRQn = 138 , LPTIM3_IRQn = 139 ,
  LPTIM4_IRQn = 140 , LPTIM5_IRQn = 141 , LPUART1_IRQn = 142 , CRS_IRQn = 144 ,
  ECC_IRQn = 145 , SAI4_IRQn = 146 , DTS_IRQn = 147 , WAKEUP_PIN_IRQn = 149 ,
  OCTOSPI2_IRQn = 150 , OTFDEC1_IRQn = 151 , OTFDEC2_IRQn = 152 , FMAC_IRQn = 153 ,
  CORDIC_IRQn = 154 , UART9_IRQn = 155 , USART10_IRQn = 156 , I2C5_EV_IRQn = 157 ,
  I2C5_ER_IRQn = 158 , FDCAN3_IT0_IRQn = 159 , FDCAN3_IT1_IRQn = 160 , TIM23_IRQn = 161 ,
  TIM24_IRQn = 162 , NonMaskableInt_IRQn = -14 , HardFault_IRQn = -13 , MemoryManagement_IRQn = -12 ,
  BusFault_IRQn = -11 , UsageFault_IRQn = -10 , SVCall_IRQn = -5 , DebugMonitor_IRQn = -4 ,
  PendSV_IRQn = -2 , SysTick_IRQn = -1 , WWDG_IRQn = 0 , PVD_AVD_IRQn = 1 ,
  TAMP_STAMP_IRQn = 2 , RTC_WKUP_IRQn = 3 , FLASH_IRQn = 4 , RCC_IRQn = 5 ,
  EXTI0_IRQn = 6 , EXTI1_IRQn = 7 , EXTI2_IRQn = 8 , EXTI3_IRQn = 9 ,
  EXTI4_IRQn = 10 , DMA1_Stream0_IRQn = 11 , DMA1_Stream1_IRQn = 12 , DMA1_Stream2_IRQn = 13 ,
  DMA1_Stream3_IRQn = 14 , DMA1_Stream4_IRQn = 15 , DMA1_Stream5_IRQn = 16 , DMA1_Stream6_IRQn = 17 ,
  ADC_IRQn = 18 , FDCAN1_IT0_IRQn = 19 , FDCAN2_IT0_IRQn = 20 , FDCAN1_IT1_IRQn = 21 ,
  FDCAN2_IT1_IRQn = 22 , EXTI9_5_IRQn = 23 , TIM1_BRK_IRQn = 24 , TIM1_UP_IRQn = 25 ,
  TIM1_TRG_COM_IRQn = 26 , TIM1_CC_IRQn = 27 , TIM2_IRQn = 28 , TIM3_IRQn = 29 ,
  TIM4_IRQn = 30 , I2C1_EV_IRQn = 31 , I2C1_ER_IRQn = 32 , I2C2_EV_IRQn = 33 ,
  I2C2_ER_IRQn = 34 , SPI1_IRQn = 35 , SPI2_IRQn = 36 , USART1_IRQn = 37 ,
  USART2_IRQn = 38 , USART3_IRQn = 39 , EXTI15_10_IRQn = 40 , RTC_Alarm_IRQn = 41 ,
  TIM8_BRK_TIM12_IRQn = 43 , TIM8_UP_TIM13_IRQn = 44 , TIM8_TRG_COM_TIM14_IRQn = 45 , TIM8_CC_IRQn = 46 ,
  DMA1_Stream7_IRQn = 47 , FMC_IRQn = 48 , SDMMC1_IRQn = 49 , TIM5_IRQn = 50 ,
  SPI3_IRQn = 51 , UART4_IRQn = 52 , UART5_IRQn = 53 , TIM6_DAC_IRQn = 54 ,
  TIM7_IRQn = 55 , DMA2_Stream0_IRQn = 56 , DMA2_Stream1_IRQn = 57 , DMA2_Stream2_IRQn = 58 ,
  DMA2_Stream3_IRQn = 59 , DMA2_Stream4_IRQn = 60 , ETH_IRQn = 61 , ETH_WKUP_IRQn = 62 ,
  FDCAN_CAL_IRQn = 63 , DMA2_Stream5_IRQn = 68 , DMA2_Stream6_IRQn = 69 , DMA2_Stream7_IRQn = 70 ,
  USART6_IRQn = 71 , I2C3_EV_IRQn = 72 , I2C3_ER_IRQn = 73 , OTG_HS_EP1_OUT_IRQn = 74 ,
  OTG_HS_EP1_IN_IRQn = 75 , OTG_HS_WKUP_IRQn = 76 , OTG_HS_IRQn = 77 , DCMI_PSSI_IRQn = 78 ,
  CRYP_IRQn = 79 , HASH_RNG_IRQn = 80 , FPU_IRQn = 81 , UART7_IRQn = 82 ,
  WAKEUP_PIN_IRQn = 149 , OCTOSPI2_IRQn = 150 , OTFDEC1_IRQn = 151 , OTFDEC2_IRQn = 152 ,
  DCMI_PSSI_IRQn = 78 , CRYP_IRQn = 79 , HASH_RNG_IRQn = 80 , FPU_IRQn = 81 ,
  UART7_IRQn = 82 , UART8_IRQn = 83 , SPI4_IRQn = 84 , SPI5_IRQn = 85 ,
  SPI6_IRQn = 86 , SAI1_IRQn = 87 , LTDC_IRQn = 88 , LTDC_ER_IRQn = 89 ,
  DMA2D_IRQn = 90 , OCTOSPI1_IRQn = 92 , LPTIM1_IRQn = 93 , CEC_IRQn = 94 ,
  I2C4_EV_IRQn = 95 , I2C4_ER_IRQn = 96 , SPDIF_RX_IRQn = 97 , DMAMUX1_OVR_IRQn = 102 ,
  DFSDM1_FLT0_IRQn = 110 , DFSDM1_FLT1_IRQn = 111 , DFSDM1_FLT2_IRQn = 112 , DFSDM1_FLT3_IRQn = 113 ,
  SWPMI1_IRQn = 115 , TIM15_IRQn = 116 , TIM16_IRQn = 117 , TIM17_IRQn = 118 ,
  MDIOS_WKUP_IRQn = 119 , MDIOS_IRQn = 120 , MDMA_IRQn = 122 , SDMMC2_IRQn = 124 ,
  HSEM1_IRQn = 125 , ADC3_IRQn = 127 , DMAMUX2_OVR_IRQn = 128 , BDMA_Channel0_IRQn = 129 ,
  BDMA_Channel1_IRQn = 130 , BDMA_Channel2_IRQn = 131 , BDMA_Channel3_IRQn = 132 , BDMA_Channel4_IRQn = 133 ,
  BDMA_Channel5_IRQn = 134 , BDMA_Channel6_IRQn = 135 , BDMA_Channel7_IRQn = 136 , COMP_IRQn = 137 ,
  LPTIM2_IRQn = 138 , LPTIM3_IRQn = 139 , LPTIM4_IRQn = 140 , LPTIM5_IRQn = 141 ,
  LPUART1_IRQn = 142 , CRS_IRQn = 144 , ECC_IRQn = 145 , SAI4_IRQn = 146 ,
  DTS_IRQn = 147 , WAKEUP_PIN_IRQn = 149 , OCTOSPI2_IRQn = 150 , OTFDEC1_IRQn = 151 ,
  OTFDEC2_IRQn = 152 , FMAC_IRQn = 153 , CORDIC_IRQn = 154 , UART9_IRQn = 155 ,
  USART10_IRQn = 156 , I2C5_EV_IRQn = 157 , I2C5_ER_IRQn = 158 , FDCAN3_IT0_IRQn = 159 ,
  FDCAN3_IT1_IRQn = 160 , TIM23_IRQn = 161 , TIM24_IRQn = 162 , NonMaskableInt_IRQn = -14 ,
  HardFault_IRQn = -13 , MemoryManagement_IRQn = -12 , BusFault_IRQn = -11 , UsageFault_IRQn = -10 ,
  SVCall_IRQn = -5 , DebugMonitor_IRQn = -4 , PendSV_IRQn = -2 , SysTick_IRQn = -1 ,
  WWDG_IRQn = 0 , PVD_AVD_IRQn = 1 , TAMP_STAMP_IRQn = 2 , RTC_WKUP_IRQn = 3 ,
  FLASH_IRQn = 4 , RCC_IRQn = 5 , EXTI0_IRQn = 6 , EXTI1_IRQn = 7 ,
  EXTI2_IRQn = 8 , EXTI3_IRQn = 9 , EXTI4_IRQn = 10 , DMA1_Stream0_IRQn = 11 ,
  DMA1_Stream1_IRQn = 12 , DMA1_Stream2_IRQn = 13 , DMA1_Stream3_IRQn = 14 , DMA1_Stream4_IRQn = 15 ,
  DMA1_Stream5_IRQn = 16 , DMA1_Stream6_IRQn = 17 , ADC_IRQn = 18 , FDCAN1_IT0_IRQn = 19 ,
  FDCAN2_IT0_IRQn = 20 , FDCAN1_IT1_IRQn = 21 , FDCAN2_IT1_IRQn = 22 , EXTI9_5_IRQn = 23 ,
  TIM1_BRK_IRQn = 24 , TIM1_UP_IRQn = 25 , TIM1_TRG_COM_IRQn = 26 , TIM1_CC_IRQn = 27 ,
  TIM2_IRQn = 28 , TIM3_IRQn = 29 , TIM4_IRQn = 30 , I2C1_EV_IRQn = 31 ,
  I2C1_ER_IRQn = 32 , I2C2_EV_IRQn = 33 , I2C2_ER_IRQn = 34 , SPI1_IRQn = 35 ,
  SPI2_IRQn = 36 , USART1_IRQn = 37 , USART2_IRQn = 38 , USART3_IRQn = 39 ,
  EXTI15_10_IRQn = 40 , RTC_Alarm_IRQn = 41 , TIM8_BRK_TIM12_IRQn = 43 , TIM8_UP_TIM13_IRQn = 44 ,
  TIM8_TRG_COM_TIM14_IRQn = 45 , TIM8_CC_IRQn = 46 , DMA1_Stream7_IRQn = 47 , FMC_IRQn = 48 ,
  SDMMC1_IRQn = 49 , TIM5_IRQn = 50 , SPI3_IRQn = 51 , UART4_IRQn = 52 ,
  UART5_IRQn = 53 , TIM6_DAC_IRQn = 54 , TIM7_IRQn = 55 , DMA2_Stream0_IRQn = 56 ,
  DMA2_Stream1_IRQn = 57 , DMA2_Stream2_IRQn = 58 , DMA2_Stream3_IRQn = 59 , DMA2_Stream4_IRQn = 60 ,
  ETH_IRQn = 61 , ETH_WKUP_IRQn = 62 , FDCAN_CAL_IRQn = 63 , DMA2_Stream5_IRQn = 68 ,
  DMA2_Stream6_IRQn = 69 , DMA2_Stream7_IRQn = 70 , USART6_IRQn = 71 , I2C3_EV_IRQn = 72 ,
  I2C3_ER_IRQn = 73 , OTG_HS_EP1_OUT_IRQn = 74 , OTG_HS_EP1_IN_IRQn = 75 , OTG_HS_WKUP_IRQn = 76 ,
  OTG_HS_IRQn = 77 , DCMI_PSSI_IRQn = 78 , CRYP_IRQn = 79 , HASH_RNG_IRQn = 80 ,
  OTFDEC1_IRQn = 151 , OTFDEC2_IRQn = 152 , FMAC_IRQn = 153 , CORDIC_IRQn = 154 ,
  OTG_HS_WKUP_IRQn = 76 , OTG_HS_IRQn = 77 , DCMI_IRQn = 78 , RNG_IRQn = 80 ,
  SPI5_IRQn = 85 , SPI6_IRQn = 86 , SAI1_IRQn = 87 , DMA2D_IRQn = 90 ,
  SAI2_IRQn = 91 , QUADSPI_IRQn = 92 , LPTIM1_IRQn = 93 , CEC_IRQn = 94 ,
  I2C4_EV_IRQn = 95 , I2C4_ER_IRQn = 96 , SPDIF_RX_IRQn = 97 , OTG_FS_EP1_OUT_IRQn = 98 ,
  OTG_FS_EP1_IN_IRQn = 99 , OTG_FS_WKUP_IRQn = 100 , OTG_FS_IRQn = 101 , DMAMUX1_OVR_IRQn = 102 ,
  HRTIM1_Master_IRQn = 103 , HRTIM1_TIMA_IRQn = 104 , HRTIM1_TIMB_IRQn = 105 , HRTIM1_TIMC_IRQn = 106 ,
  HRTIM1_TIMD_IRQn = 107 , HRTIM1_TIME_IRQn = 108 , HRTIM1_FLT_IRQn = 109 , DFSDM1_FLT0_IRQn = 110 ,
  DFSDM1_FLT1_IRQn = 111 , DFSDM1_FLT2_IRQn = 112 , DFSDM1_FLT3_IRQn = 113 , SAI3_IRQn = 114 ,
  WAKEUP_PIN_IRQn = 149 , NonMaskableInt_IRQn = -14 , HardFault_IRQn = -13 , MemoryManagement_IRQn = -12 ,
  OTG_HS_EP1_IN_IRQn = 75 , OTG_HS_WKUP_IRQn = 76 , OTG_HS_IRQn = 77 , DCMI_IRQn = 78 ,
  LTDC_IRQn = 88 , LTDC_ER_IRQn = 89 , DMA2D_IRQn = 90 , SAI2_IRQn = 91 ,
  QUADSPI_IRQn = 92 , LPTIM1_IRQn = 93 , CEC_IRQn = 94 , I2C4_EV_IRQn = 95 ,
  I2C4_ER_IRQn = 96 , SPDIF_RX_IRQn = 97 , OTG_FS_EP1_OUT_IRQn = 98 , OTG_FS_EP1_IN_IRQn = 99 ,
  OTG_FS_WKUP_IRQn = 100 , OTG_FS_IRQn = 101 , DMAMUX1_OVR_IRQn = 102 , HRTIM1_Master_IRQn = 103 ,
  HRTIM1_TIMA_IRQn = 104 , HRTIM1_TIMB_IRQn = 105 , HRTIM1_TIMC_IRQn = 106 , HRTIM1_TIMD_IRQn = 107 ,
  HRTIM1_TIME_IRQn = 108 , HRTIM1_FLT_IRQn = 109 , DFSDM1_FLT0_IRQn = 110 , DFSDM1_FLT1_IRQn = 111 ,
  DFSDM1_FLT2_IRQn = 112 , DFSDM1_FLT3_IRQn = 113 , SAI3_IRQn = 114 , SWPMI1_IRQn = 115 ,
  MDIOS_IRQn = 120 , JPEG_IRQn = 121 , MDMA_IRQn = 122 , SDMMC2_IRQn = 124 ,
  FDCAN_CAL_IRQn = 63 , CM7_SEV_IRQn = 64 , CM4_SEV_IRQn = 65 , DMA2_Stream5_IRQn = 68 ,
  OTG_HS_IRQn = 77 , DCMI_IRQn = 78 , RNG_IRQn = 80 , FPU_IRQn = 81 ,
  DMA2D_IRQn = 90 , SAI2_IRQn = 91 , QUADSPI_IRQn = 92 , LPTIM1_IRQn = 93 ,
  OTG_FS_EP1_OUT_IRQn = 98 , OTG_FS_EP1_IN_IRQn = 99 , OTG_FS_WKUP_IRQn = 100 , OTG_FS_IRQn = 101 ,
  DMAMUX1_OVR_IRQn = 102 , HRTIM1_Master_IRQn = 103 , HRTIM1_TIMA_IRQn = 104 , HRTIM1_TIMB_IRQn = 105 ,
  HRTIM1_TIMC_IRQn = 106 , HRTIM1_TIMD_IRQn = 107 , HRTIM1_TIME_IRQn = 108 , HRTIM1_FLT_IRQn = 109 ,
  SAI3_IRQn = 114 , SWPMI1_IRQn = 115 , TIM15_IRQn = 116 , TIM16_IRQn = 117 ,
  TIM17_IRQn = 118 , MDIOS_WKUP_IRQn = 119 , MDIOS_IRQn = 120 , JPEG_IRQn = 121 ,
  MDMA_IRQn = 122 , SDMMC2_IRQn = 124 , HSEM1_IRQn = 125 , HSEM2_IRQn = 126 ,
  WWDG_RST_IRQn = 143 , CRS_IRQn = 144 , ECC_IRQn = 145 , SAI4_IRQn = 146 ,
  HOLD_CORE_IRQn = 148 , WAKEUP_PIN_IRQn = 149 , NonMaskableInt_IRQn = -14 , HardFault_IRQn = -13 ,
  ETH_WKUP_IRQn = 62 , FDCAN_CAL_IRQn = 63 , CM7_SEV_IRQn = 64 , CM4_SEV_IRQn = 65 ,
  LTDC_ER_IRQn = 89 , DMA2D_IRQn = 90 , SAI2_IRQn = 91 , QUADSPI_IRQn = 92 ,
  SPDIF_RX_IRQn = 97 , OTG_FS_EP1_OUT_IRQn = 98 , OTG_FS_EP1_IN_IRQn = 99 , OTG_FS_WKUP_IRQn = 100 ,
  OTG_FS_IRQn = 101 , DMAMUX1_OVR_IRQn = 102 , HRTIM1_Master_IRQn = 103 , HRTIM1_TIMA_IRQn = 104 ,
  HRTIM1_TIMB_IRQn = 105 , HRTIM1_TIMC_IRQn = 106 , HRTIM1_TIMD_IRQn = 107 , HRTIM1_TIME_IRQn = 108 ,
  HRTIM1_FLT_IRQn = 109 , DFSDM1_FLT0_IRQn = 110 , DFSDM1_FLT1_IRQn = 111 , DFSDM1_FLT2_IRQn = 112 ,
  DFSDM1_FLT3_IRQn = 113 , SAI3_IRQn = 114 , SWPMI1_IRQn = 115 , TIM15_IRQn = 116 ,
  JPEG_IRQn = 121 , MDMA_IRQn = 122 , SDMMC2_IRQn = 124 , HSEM1_IRQn = 125 ,
  HSEM2_IRQn = 126 , ADC3_IRQn = 127 , DMAMUX2_OVR_IRQn = 128 , BDMA_Channel0_IRQn = 129 ,
  LPUART1_IRQn = 142 , WWDG_RST_IRQn = 143 , CRS_IRQn = 144 , ECC_IRQn = 145 ,
  SAI4_IRQn = 146 , HOLD_CORE_IRQn = 148 , WAKEUP_PIN_IRQn = 149 , NonMaskableInt_IRQn = -14 ,
  ETH_IRQn = 61 , ETH_WKUP_IRQn = 62 , FDCAN_CAL_IRQn = 63 , CM7_SEV_IRQn = 64 ,
  CM4_SEV_IRQn = 65 , DMA2_Stream5_IRQn = 68 , DMA2_Stream6_IRQn = 69 , DMA2_Stream7_IRQn = 70 ,
  MDIOS_IRQn = 120 , JPEG_IRQn = 121 , MDMA_IRQn = 122 , DSI_IRQn = 123 ,
  SDMMC2_IRQn = 124 , HSEM1_IRQn = 125 , HSEM2_IRQn = 126 , ADC3_IRQn = 127 ,
  LPTIM4_IRQn = 140 , LPTIM5_IRQn = 141 , LPUART1_IRQn = 142 , WWDG_RST_IRQn = 143 ,
  CRS_IRQn = 144 , ECC_IRQn = 145 , SAI4_IRQn = 146 , HOLD_CORE_IRQn = 148 ,
  MDMA_IRQn = 122 , DSI_IRQn = 123 , SDMMC2_IRQn = 124 , HSEM1_IRQn = 125 ,
  OTG_HS_IRQn = 77 , DCMI_IRQn = 78 , CRYP_IRQn = 79 , HASH_RNG_IRQn = 80 ,
  CRS_IRQn = 144 , ECC_IRQn = 145 , SAI4_IRQn = 146 , WAKEUP_PIN_IRQn = 149 ,
  OTG_HS_WKUP_IRQn = 76 , OTG_HS_IRQn = 77 , DCMI_IRQn = 78 , CRYP_IRQn = 79 ,
  MDIOS_WKUP_IRQn = 119 , MDIOS_IRQn = 120 , JPEG_IRQn = 121 , MDMA_IRQn = 122 ,
  DSI_IRQn = 123 , SDMMC2_IRQn = 124 , HSEM1_IRQn = 125 , HSEM2_IRQn = 126 ,
  PVD_PVM_IRQn = 1 , RTC_TAMP_STAMP_CSS_LSE_IRQn = 2 , RTC_WKUP_IRQn = 3 , FLASH_IRQn = 4 ,
  RTC_Alarm_IRQn = 41 , DFSDM2_IRQn = 42 , TIM8_BRK_TIM12_IRQn = 43 , TIM8_UP_TIM13_IRQn = 44 ,
  FDCAN_CAL_IRQn = 63 , DFSDM1_FLT4_IRQn = 64 , DFSDM1_FLT5_IRQn = 65 , DFSDM1_FLT6_IRQn = 66 ,
  DFSDM1_FLT7_IRQn = 67 , DMA2_Stream5_IRQn = 68 , DMA2_Stream6_IRQn = 69 , DMA2_Stream7_IRQn = 70 ,
  HSEM1_IRQn = 125 , DAC2_IRQn = 127 , DMAMUX2_OVR_IRQn = 128 , BDMA2_Channel0_IRQn = 129 ,
  BDMA2_Channel1_IRQn = 130 , BDMA2_Channel2_IRQn = 131 , BDMA2_Channel3_IRQn = 132 , BDMA2_Channel4_IRQn = 133 ,
  BDMA2_Channel5_IRQn = 134 , BDMA2_Channel6_IRQn = 135 , BDMA2_Channel7_IRQn = 136 , COMP_IRQn = 137 ,
  LPTIM2_IRQn = 138 , LPTIM3_IRQn = 139 , UART9_IRQn = 140 , USART10_IRQn = 141 ,
  DTS_IRQn = 147 , WAKEUP_PIN_IRQn = 149 , OCTOSPI2_IRQn = 150 , GFXMMU_IRQn = 153 ,
  BDMA1_IRQn = 154 , NonMaskableInt_IRQn = -14 , HardFault_IRQn = -13 , MemoryManagement_IRQn = -12 ,
  PendSV_IRQn = -2 , SysTick_IRQn = -1 , WWDG_IRQn = 0 , PVD_PVM_IRQn = 1 ,
  RTC_TAMP_STAMP_CSS_LSE_IRQn = 2 , RTC_WKUP_IRQn = 3 , FLASH_IRQn = 4 , RCC_IRQn = 5 ,
  DFSDM2_IRQn = 42 , TIM8_BRK_TIM12_IRQn = 43 , TIM8_UP_TIM13_IRQn = 44 , TIM8_TRG_COM_TIM14_IRQn = 45 ,
  DMA2_Stream2_IRQn = 58 , DMA2_Stream3_IRQn = 59 , DMA2_Stream4_IRQn = 60 , FDCAN_CAL_IRQn = 63 ,
  DFSDM1_FLT4_IRQn = 64 , DFSDM1_FLT5_IRQn = 65 , DFSDM1_FLT6_IRQn = 66 , DFSDM1_FLT7_IRQn = 67 ,
  LTDC_ER_IRQn = 89 , DMA2D_IRQn = 90 , SAI2_IRQn = 91 , OCTOSPI1_IRQn = 92 ,
  DAC2_IRQn = 127 , DMAMUX2_OVR_IRQn = 128 , BDMA2_Channel0_IRQn = 129 , BDMA2_Channel1_IRQn = 130 ,
  BDMA2_Channel2_IRQn = 131 , BDMA2_Channel3_IRQn = 132 , BDMA2_Channel4_IRQn = 133 , BDMA2_Channel5_IRQn = 134 ,
  BDMA2_Channel6_IRQn = 135 , BDMA2_Channel7_IRQn = 136 , COMP_IRQn = 137 , LPTIM2_IRQn = 138 ,
  LPTIM3_IRQn = 139 , UART9_IRQn = 140 , USART10_IRQn = 141 , LPUART1_IRQn = 142 ,
  WWDG_RST_IRQn = 143 , CRS_IRQn = 144 , ECC_IRQn = 145 , DTS_IRQn = 147 ,
  WAKEUP_PIN_IRQn = 149 , OCTOSPI2_IRQn = 150 , GFXMMU_IRQn = 153 , BDMA1_IRQn = 154 ,
  SysTick_IRQn = -1 , WWDG_IRQn = 0 , PVD_PVM_IRQn = 1 , RTC_TAMP_STAMP_CSS_LSE_IRQn = 2 ,
  USART3_IRQn = 39 , EXTI15_10_IRQn = 40 , RTC_Alarm_IRQn = 41 , DFSDM2_IRQn = 42 ,
  DMA2_Stream3_IRQn = 59 , DMA2_Stream4_IRQn = 60 , FDCAN_CAL_IRQn = 63 , DFSDM1_FLT4_IRQn = 64 ,
  DFSDM1_FLT5_IRQn = 65 , DFSDM1_FLT6_IRQn = 66 , DFSDM1_FLT7_IRQn = 67 , DMA2_Stream5_IRQn = 68 ,
  GFXMMU_IRQn = 153 , BDMA1_IRQn = 154 , NonMaskableInt_IRQn = -14 , HardFault_IRQn = -13 ,
  SAI2_IRQn = 91 , OCTOSPI1_IRQn = 92 , LPTIM1_IRQn = 93 , CEC_IRQn = 94 ,
  SDMMC2_IRQn = 124 , HSEM1_IRQn = 125 , DAC2_IRQn = 127 , DMAMUX2_OVR_IRQn = 128 ,
  BDMA2_Channel0_IRQn = 129 , BDMA2_Channel1_IRQn = 130 , BDMA2_Channel2_IRQn = 131 , BDMA2_Channel3_IRQn = 132 ,
  BDMA2_Channel4_IRQn = 133 , BDMA2_Channel5_IRQn = 134 , BDMA2_Channel6_IRQn = 135 , BDMA2_Channel7_IRQn = 136 ,
  COMP_IRQn = 137 , LPTIM2_IRQn = 138 , LPTIM3_IRQn = 139 , UART9_IRQn = 140 ,
  USART10_IRQn = 141 , LPUART1_IRQn = 142 , WWDG_RST_IRQn = 143 , CRS_IRQn = 144 ,
  ECC_IRQn = 145 , DTS_IRQn = 147 , WAKEUP_PIN_IRQn = 149 , OCTOSPI2_IRQn = 150 ,
  OTFDEC1_IRQn = 151 , OTFDEC2_IRQn = 152 , GFXMMU_IRQn = 153 , BDMA1_IRQn = 154 ,
 STM32H7XX Interrupt Number Definition, according to the selected device in Library_configuration_section. More...
CMSIS STM32H7A3xx Device Peripheral Access Layer Header File.
Author
MCD Application Team
     This file contains:
      - Data structures and the address mapping for all peripherals
      - Peripheral's registers declarations and bits definition
      - Macros to access peripheral's registers hardware
Attention
Copyright (c) 2019 STMicroelectronics. All rights reserved.
