RTEMS 6.2
| #define | __CM7_REV 0x0110U |
| Configuration of the Cortex-M7 Processor and Core Peripherals. | |
| #define | __MPU_PRESENT 1U |
| #define | __NVIC_PRIO_BITS 4U |
| #define | __Vendor_SysTickConfig 0U |
| #define | __FPU_PRESENT 1U |
| #define | __ICACHE_PRESENT 1U |
| #define | __DCACHE_PRESENT 1U |
| #define | SMPS |
| #define | SMPS |
| #define | SMPS |
| #define | __CM7_REV 0x0101U |
| #define | DUAL_CORE |
| #define | SMPS |
| #define | SMPS |
| #define | SMPS |
| #define | SMPS |
| #define | SMPS |
| #define | SMPS |
| #define | SMPS |
| #define | SMPS |
| #define | SMPS |
| #define __CM7_REV 0x0110U |
Cortex-M7 revision r1p2
| #define __CM7_REV 0x0101U |
Cortex-M7 revision r1p1
| #define __DCACHE_PRESENT 1U |
CM7 data cache present
Cortex-M7 processor and core peripherals
| #define __FPU_PRESENT 1U |
FPU present
FPU present
FPU present
FPU present
FPU present
FPU present
FPU present
FPU present
FPU present
FPU present
FPU present
FPU present
FPU present
FPU present
FPU present
FPU present
| #define __ICACHE_PRESENT 1U |
CM7 instruction cache present
| #define __MPU_PRESENT 1U |
CM7 provides an MPU
CM7 provides an MPU
CM7 provides an MPU
CM7 provides an MPU
CM7 provides an MPU
CM7 provides an MPU
CM7 provides an MPU
CM7 provides an MPU
CM7 provides an MPU
CM7 provides an MPU
CM7 provides an MPU
CM7 provides an MPU
CM7 provides an MPU
CM7 provides an MPU
CM7 provides an MPU
CM7 provides an MPU
| #define __NVIC_PRIO_BITS 4U |
CM7 uses 4 Bits for the Priority Levels
| #define __Vendor_SysTickConfig 0U |
Set to 1 if different SysTick Config is used
| #define DUAL_CORE |
Dual core line feature
| #define DUAL_CORE |
| #define DUAL_CORE |
| #define DUAL_CORE |
| #define DUAL_CORE |
| #define DUAL_CORE |
| #define SMPS |
Switched mode power supply feature
| #define SMPS |
| #define SMPS |
| #define SMPS |
| #define SMPS |
| #define SMPS |
| #define SMPS |
| #define SMPS |
| #define SMPS |
| #define SMPS |
| #define SMPS |
| #define SMPS |
