RTEMS 6.2
This header file provides the Event Manager API. More...
#include <stdint.h>#include <rtems/rtems/options.h>#include <rtems/rtems/status.h>#include <rtems/rtems/types.h>Go to the source code of this file.
| #define | RTEMS_ALL_EVENTS 0xffffffff |
| This event set constant represents all events of an event set. | |
| #define | RTEMS_EVENT_0 0x00000001 |
| This event set constant represents the bit in the event set associated with event 0. | |
| #define | RTEMS_EVENT_1 0x00000002 |
| This event set constant represents the bit in the event set associated with event 1. | |
| #define | RTEMS_EVENT_2 0x00000004 |
| This event set constant represents the bit in the event set associated with event 2. | |
| #define | RTEMS_EVENT_3 0x00000008 |
| This event set constant represents the bit in the event set associated with event 3. | |
| #define | RTEMS_EVENT_4 0x00000010 |
| This event set constant represents the bit in the event set associated with event 4. | |
| #define | RTEMS_EVENT_5 0x00000020 |
| This event set constant represents the bit in the event set associated with event 5. | |
| #define | RTEMS_EVENT_6 0x00000040 |
| This event set constant represents the bit in the event set associated with event 6. | |
| #define | RTEMS_EVENT_7 0x00000080 |
| This event set constant represents the bit in the event set associated with event 7. | |
| #define | RTEMS_EVENT_8 0x00000100 |
| This event set constant represents the bit in the event set associated with event 8. | |
| #define | RTEMS_EVENT_9 0x00000200 |
| This event set constant represents the bit in the event set associated with event 9. | |
| #define | RTEMS_EVENT_10 0x00000400 |
| This event set constant represents the bit in the event set associated with event 10. | |
| #define | RTEMS_EVENT_11 0x00000800 |
| This event set constant represents the bit in the event set associated with event 11. | |
| #define | RTEMS_EVENT_12 0x00001000 |
| This event set constant represents the bit in the event set associated with event 12. | |
| #define | RTEMS_EVENT_13 0x00002000 |
| This event set constant represents the bit in the event set associated with event 13. | |
| #define | RTEMS_EVENT_14 0x00004000 |
| This event set constant represents the bit in the event set associated with event 14. | |
| #define | RTEMS_EVENT_15 0x00008000 |
| This event set constant represents the bit in the event set associated with event 15. | |
| #define | RTEMS_EVENT_16 0x00010000 |
| This event set constant represents the bit in the event set associated with event 16. | |
| #define | RTEMS_EVENT_17 0x00020000 |
| This event set constant represents the bit in the event set associated with event 17. | |
| #define | RTEMS_EVENT_18 0x00040000 |
| This event set constant represents the bit in the event set associated with event 18. | |
| #define | RTEMS_EVENT_19 0x00080000 |
| This event set constant represents the bit in the event set associated with event 19. | |
| #define | RTEMS_EVENT_20 0x00100000 |
| This event set constant represents the bit in the event set associated with event 20. | |
| #define | RTEMS_EVENT_21 0x00200000 |
| This event set constant represents the bit in the event set associated with event 21. | |
| #define | RTEMS_EVENT_22 0x00400000 |
| This event set constant represents the bit in the event set associated with event 22. | |
| #define | RTEMS_EVENT_23 0x00800000 |
| This event set constant represents the bit in the event set associated with event 23. | |
| #define | RTEMS_EVENT_24 0x01000000 |
| This event set constant represents the bit in the event set associated with event 24. | |
| #define | RTEMS_EVENT_25 0x02000000 |
| This event set constant represents the bit in the event set associated with event 25. | |
| #define | RTEMS_EVENT_26 0x04000000 |
| This event set constant represents the bit in the event set associated with event 26. | |
| #define | RTEMS_EVENT_27 0x08000000 |
| This event set constant represents the bit in the event set associated with event 27. | |
| #define | RTEMS_EVENT_28 0x10000000 |
| This event set constant represents the bit in the event set associated with event 28. | |
| #define | RTEMS_EVENT_29 0x20000000 |
| This event set constant represents the bit in the event set associated with event 29. | |
| #define | RTEMS_EVENT_30 0x40000000 |
| This event set constant represents the bit in the event set associated with event 30. | |
| #define | RTEMS_EVENT_31 0x80000000 |
| This event set constant represents the bit in the event set associated with event 31. | |
| #define | RTEMS_PENDING_EVENTS 0 |
| This event set constant indicates that rtems_event_receive() shall return the set of pending events. | |
| #define | RTEMS_EVENT_SYSTEM_AIO_SUSPENSION_TERMINATED RTEMS_EVENT_27 |
| This event set constant represents the reserved system event that is internally used by aio_suspend to notify of suspension termination. | |
| #define | RTEMS_EVENT_SYSTEM_LIO_LIST_COMPLETED RTEMS_EVENT_28 |
| This event set constant represents the reserved system event internally used to notify list completion when lio_listio is called using LIO_WAIT. | |
| #define | RTEMS_EVENT_SYSTEM_NETWORK_CLOSE RTEMS_EVENT_26 |
| This event set constant represents the reserved system event for a network socket close. | |
| #define | RTEMS_EVENT_SYSTEM_NETWORK_SBWAIT RTEMS_EVENT_24 |
| This event set constant represents the reserved system event for a network socket buffer wait usage. | |
| #define | RTEMS_EVENT_SYSTEM_NETWORK_SOSLEEP RTEMS_EVENT_25 |
| This event set constant represents the reserved system event for a network socket sleep. | |
| #define | RTEMS_EVENT_SYSTEM_SERVER RTEMS_EVENT_30 |
| This event set constant represents the reserved system event for server thread usage, for example the timer or interrupt server. | |
| #define | RTEMS_EVENT_SYSTEM_SERVER_RESUME RTEMS_EVENT_29 |
| This event set constant represents the reserved system event to resume a server thread, for example the timer or interrupt server. | |
| #define | RTEMS_EVENT_SYSTEM_TRANSIENT RTEMS_EVENT_31 |
| This event set constant represents the reserved system event for transient usage. | |
Typedefs | |
| typedef uint32_t | rtems_event_set |
| This integer type represents a bit field which can hold exactly 32 individual events. | |
| rtems_status_code | rtems_event_system_receive (rtems_event_set event_in, rtems_option option_set, rtems_interval ticks, rtems_event_set *event_out) |
| Receives or gets a system event set from the executing task. | |
| rtems_status_code | rtems_event_system_send (rtems_id id, rtems_event_set event_in) |
| Sends the system event set to the task. | |
| rtems_status_code | rtems_event_send (rtems_id id, rtems_event_set event_in) |
| Sends the event set to the task. | |
| rtems_status_code | rtems_event_receive (rtems_event_set event_in, rtems_option option_set, rtems_interval ticks, rtems_event_set *event_out) |
| Receives or gets an event set from the calling task. | |
| rtems_status_code rtems_event_system_receive | ( | rtems_event_set | event_in, |
| rtems_option | option_set, | ||
| rtems_interval | ticks, | ||
| rtems_event_set * | event_out | ||
| event_in | is the event set of interest. Use RTEMS_PENDING_EVENTS to get the pending events. |
| option_set | is the option set. |
| ticks | is the timeout in clock ticks if the RTEMS_WAIT option was set. Use RTEMS_NO_TIMEOUT to wait potentially forever. |
| event_out | is the pointer to an event set. The received or pending events are stored in the referenced event set if the operation was successful. |
This directive performs the same actions as the rtems_event_receive() directive except that it operates with a different set of events for each task.
The following constraints apply to this directive:
| rtems_status_code rtems_event_system_send | ( | rtems_id | id, |
| rtems_event_set | event_in | ||
| id | is the identifier of the target task to receive the event set. |
| event_in | is the event set to send. |
