RTEMS 6.2
Typedefs | Functions
rtems-fdt-shell.h File Reference
RTEMS Flattened Device Tree Shell Command. More...
#include <rtems/rtems-fdt.h>
typedef void(* rtems_fdt_write_handler) (uintptr_t address, uint32_t value)
typedef uint32_t(* rtems_fdt_read_handler) (uintptr_t address)
void rtems_fdt_add_shell_command (void)
rtems_fdt_handlertems_fdt_get_shell_handle (void)
rtems_fdt_write_handler rtems_fdt_set_shell_write_handler (rtems_fdt_write_handler handler)
rtems_fdt_read_handler rtems_fdt_set_shell_read_handler (rtems_fdt_read_handler handler)
Support for loading, managing and accessing FDT blobs in RTEMS.
Typedef Documentation
◆ rtems_fdt_read_handler
Read handler call to read from the address property.
◆ rtems_fdt_write_handler
Write handler call to write from the address property.
◆ rtems_fdt_add_shell_command()
void rtems_fdt_add_shell_command ( void  )
Add a shell command to access memory and registers associated with the DTF.
◆ rtems_fdt_get_shell_handle()
rtems_fdt_handle * rtems_fdt_get_shell_handle ( void  )
Get a pointer to the handle. You can use this to load files or register blobs and have the shell command access them.
◆ rtems_fdt_set_shell_read_handler()
rtems_fdt_read_handler rtems_fdt_set_shell_read_handler ( rtems_fdt_read_handler  handler)
Set the read handler returning the current handler.
◆ rtems_fdt_set_shell_write_handler()
rtems_fdt_write_handler rtems_fdt_set_shell_write_handler ( rtems_fdt_write_handler  handler)
Set the write handler returning the current handler.
