RTEMS 6.2
pwmc.c File Reference
#include "chip.h"
#include <stdint.h>
#include <assert.h>
void PWMC_ConfigureChannel (Pwm *pPwm, uint8_t channel, uint32_t prescaler, uint32_t alignment, uint32_t polarity)
 Configures PWM a channel with the given parameters, basic configure function.
void PWMC_ConfigureChannelExt (Pwm *pPwm, uint8_t channel, uint32_t prescaler, uint32_t alignment, uint32_t polarity, uint32_t countEventSelect, uint32_t DTEnable, uint32_t DTHInverte, uint32_t DTLInverte)
 Configures PWM a channel with the given parameters, extend configure function. The PWM controller must have been clocked in the PMC prior to calling this function. Beware: this function disables the channel. It waits until disable is effective.
void PWMC_ConfigureClocks (Pwm *pPwm, uint32_t clka, uint32_t clkb, uint32_t mck)
 Configures PWM clocks A & B to run at the given frequencies.
void PWMC_SetPeriod (Pwm *pPwm, uint8_t channel, uint16_t period)
 Sets the period value used by a PWM channel.
void PWMC_SetDutyCycle (Pwm *pPwm, uint8_t channel, uint16_t duty)
 Sets the duty cycle used by a PWM channel. This function writes directly to the CDTY register if the channel is disabled; otherwise it uses the update register CDTYUPD. Note that the duty cycle must always be inferior or equal to the channel period.
void PWMC_SetDeadTime (Pwm *pPwm, uint8_t channel, uint16_t timeH, uint16_t timeL)
 Sets the dead time used by a PWM channel. This function writes directly to the DT register if the channel is disabled; otherwise it uses the update register DTUPD. Note that the dead time must always be inferior or equal to the channel period.
void PWMC_ConfigureSyncChannel (Pwm *pPwm, uint32_t channels, uint32_t updateMode, uint32_t requestMode, uint32_t requestComparisonSelect)
 Configures Synchronous channel with the given parameters. Beware: At this time, the channels should be disabled.
void PWMC_SetSyncChannelUpdatePeriod (Pwm *pPwm, uint8_t period)
 Sets the update period of the synchronous channels. This function writes directly to the SCUP register if the channel #0 is disabled; otherwise it uses the update register SCUPUPD.
void PWMC_SetSyncChannelUpdateUnlock (Pwm *pPwm)
 Sets synchronous channels update unlock.
void PWMC_EnableChannel (Pwm *pPwm, uint8_t channel)
 Enables the given PWM channel.
void PWMC_DisableChannel (Pwm *pPwm, uint8_t channel)
 Disables the given PWM channel.
void PWMC_EnableChannelIt (Pwm *pPwm, uint8_t channel)
 Enables the period interrupt for the given PWM channel.
uint32_t PWMC_GetStatus2 (Pwm *pPwm)
 Return PWM Interrupt Status2 Register.
void PWMC_DisableChannelIt (Pwm *pPwm, uint8_t channel)
 Disables the period interrupt for the given PWM channel.
void PWMC_EnableIt (Pwm *pPwm, uint32_t sources1, uint32_t sources2)
 Enables the selected interrupts sources on a PWMC peripheral.
void PWMC_DisableIt (Pwm *pPwm, uint32_t sources1, uint32_t sources2)
 Disables the selected interrupts sources on a PWMC peripheral.
void PWMC_SetOverrideValue (Pwm *pPwm, uint32_t value)
 Set PWM output override value.
void PWMC_EnableOverrideOutput (Pwm *pPwm, uint32_t value, uint32_t sync)
 Enable override output.
void PWMC_OutputOverrideSelection (Pwm *pPwm, uint32_t value)
 Output Selection for override PWM output.
void PWMC_DisableOverrideOutput (Pwm *pPwm, uint32_t value, uint32_t sync)
 Disable override output.
void PWMC_SetFaultMode (Pwm *pPwm, uint32_t mode)
 Set PWM fault mode.
void PWMC_FaultClear (Pwm *pPwm, uint32_t fault)
 PWM fault clear.
void PWMC_SetFaultProtectionValue (Pwm *pPwm, uint32_t value)
 Set PWM fault protection value.
void PWMC_EnableFaultProtection (Pwm *pPwm, uint32_t value)
 Enable PWM fault protection.
void PWMC_ConfigureComparisonUnit (Pwm *pPwm, uint32_t x, uint32_t value, uint32_t mode)
 Configure comparison unit.
void PWMC_ConfigureEventLineMode (Pwm *pPwm, uint32_t x, uint32_t mode)
 Configure event line mode.
Implementation of the Pulse Width Modulation Controller (PWM) peripheral.
◆ PWMC_ConfigureChannel()
void PWMC_ConfigureChannel ( Pwm pPwm,
uint8_t  channel,
uint32_t  prescaler,
uint32_t  alignment,
uint32_t  polarity
Parameters
channelChannel number.
prescalerChannel prescaler.
alignmentChannel alignment.
polarityChannel polarity.
◆ PWMC_ConfigureChannelExt()
void PWMC_ConfigureChannelExt ( Pwm pPwm,
uint8_t  channel,
uint32_t  prescaler,
uint32_t  alignment,
uint32_t  polarity,
uint32_t  DTEnable,
uint32_t  DTLInverte
Parameters
countEventSelectChannel counter event selection.
DTEnableChannel dead time generator enable.
DTHInverteChannel Dead-Time PWMHx output Inverted.
DTLInverteChannel Dead-Time PWMHx output Inverted.
◆ PWMC_ConfigureClocks()
void PWMC_ConfigureClocks ( Pwm pPwm,
uint32_t  clka,
uint32_t  clkb,
uint32_t  mck
This function finds the best MCK divisor and prescaler values automatically.
Parameters
clkaDesired clock A frequency (0 if not used).
clkbDesired clock B frequency (0 if not used).
mckMaster clock frequency.
◆ PWMC_ConfigureComparisonUnit()
void PWMC_ConfigureComparisonUnit ( Pwm pPwm,
uint32_t  x,
uint32_t  value,
uint32_t  mode
Parameters
xcomparison x index
valuecomparison x value.
modecomparison x mode
◆ PWMC_ConfigureEventLineMode()
void PWMC_ConfigureEventLineMode ( Pwm pPwm,
uint32_t  x,
uint32_t  mode
Parameters
xLine x
modeBitwise OR of line mode selection
◆ PWMC_ConfigureSyncChannel()
void PWMC_ConfigureSyncChannel ( Pwm pPwm,
uint32_t  channels,
Parameters
channelsBitwise OR of Synchronous channels.
updateModeSynchronous channel update mode.
requestModePDC transfer request mode.
requestComparisonSelectPDC transfer request comparison selection.
◆ PWMC_DisableChannel()
void PWMC_DisableChannel ( Pwm pPwm,
uint8_t  channel
Beware, channel will be effectively disabled at the end of the current period. Application can check channel is disabled using the following wait loop: while ((PWM->PWM_SR & (1 << channel)) != 0);
Parameters
◆ PWMC_DisableChannelIt()
void PWMC_DisableChannelIt ( Pwm pPwm,
uint8_t  channel
Parameters
◆ PWMC_DisableIt()
void PWMC_DisableIt ( Pwm pPwm,
uint32_t  sources1,
uint32_t  sources2
Parameters
sources1Bitwise OR of selected interrupt sources of PWM_IDR1.
sources2Bitwise OR of selected interrupt sources of PWM_IDR2.
◆ PWMC_DisableOverrideOutput()
void PWMC_DisableOverrideOutput ( Pwm pPwm,
uint32_t  value,
uint32_t  sync
Parameters
valueBitwise OR of output selection.
sync0: enable the output asynchronously, 1: enable it synchronously
◆ PWMC_EnableChannel()
void PWMC_EnableChannel ( Pwm pPwm,
uint8_t  channel
This does NOT enable the corresponding pin;this must be done in the user code.
Parameters
◆ PWMC_EnableChannelIt()
void PWMC_EnableChannelIt ( Pwm pPwm,
uint8_t  channel
Parameters
◆ PWMC_EnableFaultProtection()
void PWMC_EnableFaultProtection ( Pwm pPwm,
uint32_t  value
Parameters
valueBitwise OR of FPEx[y].
◆ PWMC_EnableIt()
void PWMC_EnableIt ( Pwm pPwm,
uint32_t  sources1,
uint32_t  sources2
Parameters
sources1Bitwise OR of selected interrupt sources of PWM_IER1.
sources2Bitwise OR of selected interrupt sources of PWM_IER2.
◆ PWMC_EnableOverrideOutput()
void PWMC_EnableOverrideOutput ( Pwm pPwm,
uint32_t  value,
uint32_t  sync
Parameters
◆ PWMC_FaultClear()
void PWMC_FaultClear ( Pwm pPwm,
uint32_t  fault
PWM fault clear.
Parameters
faultBitwise OR of fault to clear.
◆ PWMC_GetStatus2()
uint32_t PWMC_GetStatus2 ( Pwm pPwm)
◆ PWMC_OutputOverrideSelection()
void PWMC_OutputOverrideSelection ( Pwm pPwm,
uint32_t  value
Parameters
valueBitwise OR of output override value.
◆ PWMC_SetDeadTime()
void PWMC_SetDeadTime ( Pwm pPwm,
uint8_t  channel,
uint16_t  timeH,
uint16_t  timeL
Parameters
timeHDead time value for PWMHx output.
timeLDead time value for PWMLx output.
◆ PWMC_SetDutyCycle()
void PWMC_SetDutyCycle ( Pwm pPwm,
uint8_t  channel,
uint16_t  duty
Parameters
dutyDuty cycle value.
◆ PWMC_SetFaultMode()
void PWMC_SetFaultMode ( Pwm pPwm,
uint32_t  mode
Set PWM fault mode.
Parameters
modeBitwise OR of fault mode.
◆ PWMC_SetFaultProtectionValue()
void PWMC_SetFaultProtectionValue ( Pwm pPwm,
uint32_t  value
Parameters
valueBitwise OR of fault protection value.
◆ PWMC_SetOverrideValue()
void PWMC_SetOverrideValue ( Pwm pPwm,
uint32_t  value
Parameters
◆ PWMC_SetPeriod()
void PWMC_SetPeriod ( Pwm pPwm,
uint8_t  channel,
uint16_t  period
This function writes directly to the CPRD register if the channel is disabled; otherwise, it uses the update register CPRDUPD.
Parameters
periodPeriod value.
◆ PWMC_SetSyncChannelUpdatePeriod()
void PWMC_SetSyncChannelUpdatePeriod ( Pwm pPwm,
uint8_t  period
Parameters
periodupdate period.
◆ PWMC_SetSyncChannelUpdateUnlock()
void PWMC_SetSyncChannelUpdateUnlock ( Pwm pPwm)
Note: If the UPDM field is set to 0, writing the UPDULOCK bit to 1 triggers the update of the period value, the duty-cycle and the dead-time values of synchronous channels at the beginning of the next PWM period. If the field UPDM is set to 1 or 2, writing the UPDULOCK bit to 1 triggers only the update of the period value and of the dead-time values of synchronous channels. This bit is automatically reset when the update is done.
