RTEMS 6.2
Data Structures | Functions | Variables
ns16550.c File Reference
#include <rtems/libio.h>
#include <rtems/ringbuf.h>
#include <rtems/bspIo.h>
#include <rtems/termiostypes.h>
#include <libchip/serial.h>
#include <libchip/sersupp.h>
#include <bsp.h>
#include <libchip/ns16550_p.h>
#include <libchip/ns16550.h>
struct  NS16550Context
NS16550_STATIC void ns16550_init (int minor)
NS16550_STATIC int ns16550_open (int major, int minor, void *arg)
NS16550_STATIC int ns16550_close (int major, int minor, void *arg)
NS16550_STATIC void ns16550_write_polled (int minor, char cChar)
NS16550_STATIC int ns16550_assert_RTS (int minor)
NS16550_STATIC int ns16550_negate_RTS (int minor)
NS16550_STATIC int ns16550_assert_DTR (int minor)
NS16550_STATIC int ns16550_negate_DTR (int minor)
NS16550_STATIC void ns16550_initialize_interrupts (int minor)
NS16550_STATIC void ns16550_cleanup_interrupts (int minor)
NS16550_STATIC ssize_t ns16550_write_support_int (int minor, const char *buf, size_t len)
 Transmits up to len characters from buf.
NS16550_STATIC ssize_t ns16550_write_support_polled (int minor, const char *buf, size_t len)
int ns16550_inbyte_nonblocking_polled (int minor)
NS16550_STATIC void ns16550_enable_interrupts (console_tbl *c, int mask)
NS16550_STATIC int ns16550_set_attributes (int minor, const struct termios *t)
void ns16550_outch_polled (console_tbl *c, char out)
 Polled write for NS16550.
int ns16550_inch_polled (console_tbl *c)
const console_flow ns16550_flow_RTSCTS
const console_flow ns16550_flow_DTRCTS
const console_fns ns16550_fns
const console_fns ns16550_fns_polled
This file contains the TTY driver for the National Semiconductor NS16550.
This part is widely cloned and second sourced. It is found in a number of "Super IO" controllers.
This driver uses the termios pseudo driver.
◆ ns16550_write_support_int()
ssize_t ns16550_write_support_int ( int  minor,
const char *  buf,
size_t  len
This routine is invoked either from task context with disabled interrupts to start a new transmission process with exactly one character in case of an idle output state or from the interrupt handler to refill the transmitter.
Returns always zero.
Variable Documentation
◆ ns16550_flow_DTRCTS
Initial value:
ns16550_negate_DTR,
ns16550_assert_DTR
◆ ns16550_flow_RTSCTS
Initial value:
ns16550_negate_RTS,
ns16550_assert_RTS
◆ ns16550_fns
Initial value:
libchip_serial_default_probe,
ns16550_open,
ns16550_close,
NULL,
ns16550_init,
ns16550_write_polled,
ns16550_set_attributes,
true
NS16550_STATIC ssize_t ns16550_write_support_int(int minor, const char *buf, size_t len)
Definition: ns16550.c:660
◆ ns16550_fns_polled
Initial value:
ns16550_open,
ns16550_close,
ns16550_inbyte_nonblocking_polled,
ns16550_write_support_polled,
ns16550_init,
false
